[petsc-users] reusing LU factorization?
Tue Jan 28 17:34:16 CST 2014
  Ok then use -log_summary and put the first solve in a separate stage (see PetscStageRegister()) and send the results of a run back demonstrating the slow first solver and we may be able to see what the story is.
   Barry
On Jan 28, 2014, at 5:23 PM, David Liu <daveliu at mit.edu> wrote:
> wow that is news to me. I always assumed that this is normal.
> I'm pretty certain it's not the preallocation. I'm using MatCreateMPI, and to my knowledge I wouldn't even be able to set the values without crashing if I didn't preallocate. (If I'm not mistaken, the setting values slowly without preallocating is only possible if you create the Mat using MatCreate + MatSetup).
> Also, I'm certain that the time is taken on the first solve, not the setting of values, because I use the matrix in a MatMult first to get the RHS before solving, and the MatMult happens before the long first solve.
> On Tue, Jan 28, 2014 at 5:04 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jan 28, 2014, at 1:36 PM, David Liu <daveliu at mit.edu> wrote:
> > Hi, I'm writing an application that solves a sparse matrix many times using Pastix. I notice that the first solves takes a very long time,
>   Is it the first “solve” or the first time you put values into that matrix that “takes a long time”? If you are not properly preallocating the matrix then the initial setting of values will be slow and waste memory.  See http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatXAIJSetPreallocation.html
>   The symbolic factorization is usually much faster than a numeric factorization so that is not the cause of the slow “first solve”.
>    Barry
> > while the subsequent solves are very fast. I don't fully understand what's going on behind the curtains, but I'm guessing it's because the very first solve has to read in the non-zero structure for the LU factorization, while the subsequent solves are faster because the nonzero structure doesn't change.
> > My question is, is there any way to save the information obtained from the very first solve, so that the next time I run the application, the very first solve can be fast too (provided that I still have the same nonzero structure)?
