[petsc-users] Setting up a PETSc section for field-split
Tue Jan 28 10:20:43 CST 2014
On Tue, Jan 28, 2014 at 10:11 AM, Luc Berger-Vergiat <lb2653 at columbia.edu>wrote:
>  What I don't really understand is why the size of all the sub fields is
> zero?
> As you can see all the matrix object in my fieldsplit preconditioner have
> total:nonzeros=0, allocated nonzeros=0.
> This seems strange since I issued the following command:
>      call DMSetDefaultSection(FSDM, FSSection, ierr)
That section looks like you never called PetscSectionSetUp().
   Matt
> with a the following FSSection:
> PetscSection with 4 fields
>   field 0 with 1 components
> Process 0:
>   (   0) dim  0 offset   0
>   (   1) dim  1 offset   0
>   (   2) dim  0 offset   0
>   (   3) dim  0 offset   0
>   (   4) dim  1 offset   0
>   (   5) dim  0 offset   0
>   (   6) dim  0 offset   0
>   (   7) dim  0 offset   0
>   (   8) dim  0 offset   0
>   (   9) dim  0 offset   0
>   (  10) dim  0 offset   0
>   (  11) dim  0 offset   0
>   (  12) dim  0 offset   0
>   (  13) dim  0 offset   0
>   (  14) dim  0 offset   0
>   (  15) dim  0 offset   0
>   field 1 with 1 components
> Process 0:
>   (   0) dim  1 offset   0
>   (   1) dim  0 offset   1
>   (   2) dim  1 offset   0
>   (   3) dim  1 offset   0
>   (   4) dim  0 offset   1
>   (   5) dim  1 offset   0
>   (   6) dim  0 offset   0
>   (   7) dim  0 offset   0
>   (   8) dim  0 offset   0
>   (   9) dim  0 offset   0
>   field 2 with 1 components
> Process 0:
>   (   0) dim  0 offset   1
>   (   1) dim  0 offset   1
>   (   2) dim  0 offset   1
>   (   3) dim  0 offset   1
>   (   4) dim  0 offset   1
>   (   5) dim  0 offset   1
>   (   6) dim  1 offset   0
>   (   7) dim  1 offset   0
>   (   8) dim  1 offset   0
>   (   9) dim  1 offset   0
>   (  10) dim  1 offset   0
>   (  11) dim  1 offset   0
>   field 3 with 1 components
> Process 0:
>   (   0) dim  0 offset   1
>   (   1) dim  0 offset   1
>   (   2) dim  0 offset   1
>   (   3) dim  0 offset   1
>   (   4) dim  0 offset   1
>   (   5) dim  0 offset   1
>   (   6) dim  0 offset   1
>   (   7) dim  0 offset   1
>   (   8) dim  0 offset   1
>   (   9) dim  0 offset   1
>   (  10) dim  0 offset   1
>   (  11) dim  0 offset   1
>   (  12) dim  1 offset   0
>   (  13) dim  1 offset   0
>   (  14) dim  1 offset   0
>   (  15) dim  1 offset   0
> I thought that by using DMSetDefaultSection() I would be done setting the
> fields and that the fieldsplit would detect that section and use it to
> construct the splits.
> Should I use another command to tell the PC to use the DM section?
> Best,
> Luc
> On 01/28/2014 10:25 AM, Matthew Knepley wrote:
>  On Mon, Jan 27, 2014 at 1:35 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>wrote:
>>  Thanks Matt,
>> this indeed setting the number of fields earlier solve my issue!
>> I have now made some progress getting my DM setup but I am having
>> troubles setting my splitfield options.
>> I ran my problem with the -ksp_view option to see what is going on and I
>> guess that somehow the section that I define in my DM is not used by the
>> preconditioner to split the fields.
>> Here is the output of PETSc
>> KSP Object: 1 MPI processes
>>   type: gmres
>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>     GMRES: happy breakdown tolerance 1e-30
>>   maximum iterations=10000, initial guess is zero
>>   tolerances:  relative=1e-08, absolute=1e-16, divergence=1e+16
>>   left preconditioning
>>   using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>>   type: fieldsplit
>>     FieldSplit with MULTIPLICATIVE composition: total splits = 4
>>     Solver info for each split is in the following KSP objects:
>>     Split number 0 Defined by IS
>  There are 4 splits here and they are defined by an IS. Why do you think
> that is not what you asked for?
>    Thanks,
>      Matt
>>      KSP Object:    (fieldsplit_Field_0_)     1 MPI processes
>>       type: preonly
>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>       using NONE norm type for convergence test
>>     PC Object:    (fieldsplit_Field_0_)     1 MPI processes
>>       type: ilu
>>         ILU: out-of-place factorization
>>         0 levels of fill
>>         tolerance for zero pivot 2.22045e-14
>>         using diagonal shift on blocks to prevent zero pivot
>>         matrix ordering: natural
>>         factor fill ratio given 1, needed 1
>>           Factored matrix follows:
>>             Matrix Object:             1 MPI processes
>>               type: seqaij
>>               rows=0, cols=0
>>               package used to perform factorization: petsc
>>               total: nonzeros=0, allocated nonzeros=0
>>               total number of mallocs used during MatSetValues calls =0
>>                 not using I-node routines
>>       linear system matrix = precond matrix:
>>         type: seqaij
>>         rows=0, cols=0
>>     Split number 1 Defined by IS
>>     KSP Object:    (fieldsplit_Field_1_)     1 MPI processes
>>       type: preonly
>>     PC Object:    (fieldsplit_Field_1_)     1 MPI processes
>>       type: ilu
>>         0 levels of fill
>>               type: seqaij
>>               rows=0, cols=0
>>         type: seqaij
>>         rows=0, cols=0
>>     Split number 2 Defined by IS
>>     KSP Object:    (fieldsplit_Field_2_)     1 MPI processes
>>       type: preonly
>>     PC Object:    (fieldsplit_Field_2_)     1 MPI processes
>>       type: ilu
>>         0 levels of fill
>>               type: seqaij
>>               rows=0, cols=0
>>         type: seqaij
>>         rows=0, cols=0
>>     Split number 3 Defined by IS
>>     KSP Object:    (fieldsplit_Field_3_)     1 MPI processes
>>       type: preonly
>>     PC Object:    (fieldsplit_Field_3_)     1 MPI processes
>>       type: ilu
>>         0 levels of fill
>>               type: seqaij
>>               rows=0, cols=0
>>         type: seqaij
>>         rows=0, cols=0
>>     type: seqaij
>>     rows=16, cols=16
>>     total: nonzeros=256, allocated nonzeros=256
>>       using I-node routines: found 4 nodes, limit used is 5
>> I am also attaching part of my code which I use to generate the DM, the
>> KSP and the PC objects.
>> Best,
>> Luc
>> On 01/25/2014 10:31 AM, Matthew Knepley wrote:
>>  On Fri, Jan 24, 2014 at 5:10 PM, Luc Berger-Vergiat <lb2653 at columbia.edu
>> > wrote:
>>> Hi all,
>>> I want to use PETSc as a solver for an FEM problem: modelization of
>>> shear bands using a 4 fields mixed formulation.
>>> So far I am just trying to set up a two fields in a Petsc section,
>>> assign dof too each field and then set up the section to pass it to a DM. I
>>> am taking this approach because in general I want for fieldsplit to work
>>> purely on the algebraic level without knowledge of boundary conditions or
>>> geometry.
>>> As of now I have issues when I try to assign a point and its associated
>>> degree of freedom to a field using: PetscSectionSetFieldDof.
>>> Is this the correct way to associate a dof/point to a field?
>>  You have to set the number of fields before the chart. I am updating
>> the docs.
>>   Thanks,
>>      Matt
>>> I attached an example code and its makefile.
>>> Best,
>>> Luc
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140128/244887ec/attachment-0001.html>
