[petsc-users] Prometheus vs GAMG for elasticity/plasticity problems
Jed Brown jed at jedbrown.org
Mon Jan 27 12:00:39 CST 2014
Thomas Gross <tgross at ilsb.tuwien.ac.at> writes:
> I ran it with:
> -ksp_type cg -pc_type gamg -pc_gamg_type agg -log_summary -ksp_monitor -ksp_view -options_left -mg_levels_ksp_max_it 1 > GAMG_log_max_it.txt
> and
> -ksp_type cg -pc_type gamg -pc_gamg_type agg -log_summary -ksp_monitor -ksp_view -options_left -mg_levels_ksp_type richardson -mg_levels_pc_type sor > GAMG_log_Rich.txt
> (Log files attached)
> However, the solution time did not decrease and I still needed to call KSPSolve 3 times although I had -mg_levels_ksp_max_it 1.
Your original Prometheus output had
  KSPSolve               1 1.0 4.6679e-02 1.0 4.10e+07 1.2 3.0e+02 2.7e+03 1.9e+02 34100 99100 86  34100 99100 87  1631
Now you have
Cheby(2)/Jacobi
  KSPSolve               3 1.0 1.3235e-01 1.0 3.36e+07 1.0 8.5e+02 2.3e+03 1.2e+03 36100 99100 96  36100 99100 96   507
Cheby(1)/Jacobi
  KSPSolve               3 1.0 1.3466e-01 1.0 3.28e+07 1.0 8.5e+02 2.3e+03 1.2e+03 49100 99100 96  49100 99100 96   486
Richardson/SOR
  KSPSolve               3 1.0 1.2476e-01 1.0 3.36e+07 1.0 7.0e+02 2.4e+03 1.2e+03 38100 99100 96  38100 99100 96   538
The cost _per solve_ looks fine here, so why do you/FEAP call KSPSolve
three times when using GAMG, going to a residual norm of 1e-16 when you
were only going to rtol 1e-8 with Prometheus?  For example, here is the
convergence the With Prometheus:
    0 KSP Residual norm 1.444126847260e-01
    1 KSP Residual norm 5.357525404213e-03
    2 KSP Residual norm 1.471040678379e-03
    3 KSP Residual norm 3.704652302293e-04
    4 KSP Residual norm 9.809180893460e-05
    5 KSP Residual norm 3.175497350277e-05
    6 KSP Residual norm 8.859979496890e-06
    7 KSP Residual norm 2.071384344082e-06
    8 KSP Residual norm 5.035483717523e-07
    9 KSP Residual norm 1.516500637412e-07
   10 KSP Residual norm 5.134577847338e-08
   11 KSP Residual norm 1.270806138401e-08
   12 KSP Residual norm 3.074793756862e-09
   13 KSP Residual norm 1.048189477307e-09
and here is with GAMG Richardson/SOR:
    0 KSP Residual norm 1.407866441446e-01
    1 KSP Residual norm 6.331036946837e-03
    2 KSP Residual norm 2.744397946950e-04
    3 KSP Residual norm 1.419791977305e-05
    4 KSP Residual norm 7.670137315396e-07
    5 KSP Residual norm 4.636628100571e-08
    6 KSP Residual norm 3.374396803942e-09
    7 KSP Residual norm 1.936237763969e-10
The latter has reduced the residual more (in preconditioned norm) in
half the iterations.  Try running with -ksp_norm_type unpreconditioned
if you're concerned about the accuracy of the GAMG solve.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140127/ab962de6/attachment.pgp>
