[petsc-users] Prometheus vs GAMG for elasticity/plasticity problems
Jed Brown jed at jedbrown.org
Mon Jan 27 10:53:36 CST 2014
Thomas Gross <tgross at ilsb.tuwien.ac.at> writes:
> Please find enclosed the log summary for the runs.
> I used the following options for Prometheus and GAMG:
> Prometheus:
> -ksp_type cg -pc_type prometheus -log_summary -ksp_monitor -ksp_view -aggmg_smooths 1 -options_left
> GAMG:
> -ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -log_summary -ksp_monitor -ksp_view -options_left
This is a pretty small problem, but switch back to a single smoothing
iteration -mg_levels_ksp_max_it 1.  An alternative is
-mg_levels_ksp_type richardson -mg_levels_pc_type sor.
Note that you are calling KSPSolve 3 times with GAMG, but only once with
Prometheus.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140127/848762a1/attachment.pgp>
