[petsc-users] Prometheus vs GAMG for elasticity/plasticity problems
Thomas Gross tgross at ilsb.tuwien.ac.at
Mon Jan 27 02:42:57 CST 2014
Dear petsc users/developers,
I am using petsc in a parallel FEAP framework (http://www.ce.berkeley.edu/projects/feap/) for mechanics oriented problems (mainly linear elasticity or plasticity).
In earlier petsc versions (3.2.7) I always used the petsc options:
-ksp_type cg -pc_type prometheus (with standard settings) and achieved a great level of performance.
After updating to petsc 3.4.3, where the “Prometheus” preconditioner was replaced by “GAMG”, I can not reach the same level of performance. My settings are:
-ksp_type cg -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 (settings recommended for FEAP).
Is there a set of GAMG settings, which are equivalent to the standard Prometheus settings?
Many thanks and best regards,
Thomas
