[petsc-users] SNESSetConvergenceTest
Dharmendar Reddy dharmareddy84 at gmail.com
Thu Jan 23 16:15:15 CST 2014
Hello,
          How should i fix the issue mentioned below ?
On Thu, Jan 23, 2014 at 12:47 AM, Dharmendar Reddy
<dharmareddy84 at gmail.com> wrote:
> Hello,
>         I think, i found the cause of the crashes. It is due to _cb
> defined in zsnesf.c and a particular usage pattern.
> Here is how it is:
> The code has snes object wrapped inside a fortran data type (Solver_t)
> Say i have two solver objects:
> type(solver_t) :: solver1
> type(solver_t) :: solver2
> I first use solver1 to solve an equation where i do not use DM
> In the snes in Solver1 , i set function first and then jacobian.
> Now, ths static struct _cb in zsnsef has:
> _cb  = {function = 1000, test = 0, destroy = 0, jacobian = 1001,
> monitor = 0, mondestroy = 0, gs = 0}
> Now i call the second solver with DM, where is set the function and
> jacobain via DMSetFxn/Jac
> Then i call snessetconvergenceset
> _cb not takes the value :
> _cb  = {function = 1000, test = 1002, destroy = 0, jacobian = 1001,
> but the snes hdr has num_fortrancallback[0] = 1
> leading to an error: at line  262 in src/sys/objects/inherit.c
>   if (PetscUnlikely(cid >=
> PETSC_SMALLEST_FORTRAN_CALLBACK+obj->num_fortrancallback[cbtype]))
> SETERRQ(obj->comm,PETSC_ERR_ARG_CORRUPT,"Fortran callback not set on
> this object");
> There is another scenario where my code hangs, i noted it as case (2)
> [line 968 in solver.F90] in the comments of the attached test case.
> i have attahced the logs for each of the three cases considered.
> why cannot _cb reside inside the snes object  ?
> Thanks
> Reddy
> On Wed, Jan 22, 2014 at 8:20 PM, Dharmendar Reddy
>> Hello,
>>          I will try to f-blas-pack. later today.
>> I did some more digging of the code:
>> When i look at the snes object...I find the follwoing:  I can see that
>> the ctx and residual and jacobian functions are set right. Where as
>> the fortran callbacks in the snes seem to be wrong..even though snes
>> says it has one fortran callback..am i reading this right ?
>> (idb) print (*snes).dm.dmsnes.fortrancallback[1][0]
>> $95 = {func = 0x7e9e7e <functionresidualwithdm>, ctx = 0x2b591f8}
>> (idb) print (*snes).dm.dmsnes.fortrancallback[1][1]
>> $96 = {func = 0x7e9bb8 <functionjacobianwithdm>, ctx = 0x2b591f8}
>> (idb) print (*snes).hdr
>> $97 = {classid = 1211230, bops = 0x53bc4d0, comm = -2080374784, type =
>> 0, flops = 0, time = 0, mem = 1340, memchild
>> ren = 0, id = 67, refct = 1, tag = 1073741734, qlist = 0x0, olist =
>> 0x0, class_name = 0x2b592d32b9fc "SNES", descri
>> ption = 0x2b592d32ba04 "Nonlinear solver", mansec = 0x2b592d32b9fc
>> "SNES", type_name = 0x5416040 "newtonls", parent
>>  = 0x0, parentid = 0, name = 0x0, prefix = 0x54146b0 "ddm_", tablevel
>> = 0, cpp = 0x0, state = 0, int_idmax = 0, int
>> star_idmax = 0, intcomposedstate = 0x0, intstarcomposedstate = 0x0,
>> intcomposeddata = 0x0, intstarcomposeddata = 0x
>> 0, real_idmax = 0, realstar_idmax = 0, realcomposedstate = 0x0,
>> realstarcomposedstate = 0x0, realcomposeddata = 0x0
>> , realstarcomposeddata = 0x0, scalar_idmax = 0, scalarstar_idmax = 0,
>> scalarcomposedstate = 0x0, scalarstarcomposed
>> state = 0x0, scalarcomposeddata = 0x0, scalarstarcomposeddata = 0x0,
>> fortran_func_pointers = 0x0, num_fortran_func_
>> pointers = 0, *fortrancallback = {0x54cd5e0, 0x0}, num_fortrancallback
>> = {1, 0}, python_context = 0x0, python_destr
>> oy = 0x0, noptionhandler = 0, (*optionhandler)(PetscObject, void *) =
>> {0x0, 0x0, 0x0, 0x0, 0x0}, (*optiondestroy)(P
>> etscObject, void *) = {0x0, 0x0, 0x0, 0x0, 0x0}, *optionctx = {0x0,
>> 0x0, 0x0, 0x0, 0x0}, precision = PETSC_PRECISIO
>> N_DOUBLE, optionsprinted = PETSC_TRUE}
>> (idb) print (*snes).hdr.fortrancallback[0][0]
>> $98 = {func = 0x0, ctx = 0x0}
>> The call which sets the convergence test function is : You can see
>> that the cctx object has same address as the context set in
>> Breakpoint 1, SOLVERUTILS_M::solve_solver (this=0x2b591f8,
>> ierr=-1070882422) at /home1/00924/Reddy135/projects/ut
>> gds/src/solver/Solver.F90:348
>> 348            call SNESSetConvergenceTest(this%snes,
>> SNESConvergenceTest_snes, this,PETSC_NULL_FUNCTION, ierr);
>> CHKERRQ(ierr)
>> (idb) c
>> Continuing.
>> Breakpoint 4, snessetconvergencetest_ (snes=0x2b59210, func=0x7ea300
>> <snesconvergencetest_snes>, cctx=0x2b591f8,
>> destroy=0x0, ierr=0x7fffcd0c04f4) at
>> /home1/00924/Reddy135/LocalApps/petsc/src/snes/interface/ftn-custom/zsnesf.c
>> :254
>> The stack trace is..
>> (idb) bt
>> #0  0x00002b592ca05849 in SNESSolve_NEWTONLS (snes=0x53bba60) at
>> /home1/00924/Reddy135/LocalApps/petsc/src/snes/imp
>> ls/ls/ls.c:197
>> #1  0x00002b592caaf980 in SNESSolve (snes=0x53bba60, b=0x0,
>> x=0x53ddc00) at /home1/00924/Reddy135/LocalApps/petsc/s
>> rc/snes/interface/snes.c:3809
>> #2  0x00002b592cae975b in snessolve_ (snes=0x2b59210, b=0xe2f780,
>> x=0x2b59258, __ierr=0x7fffcd0c04f4) at /home1/009
>> 24/Reddy135/LocalApps/petsc/src/snes/interface/ftn-custom/zsnesf.c:171
>> #3  0x00000000007ea68f in SOLVERUTILS_M::solve_solver (this=0x2b591f8,
>> ierr=0) at /home1/00924/Reddy135/projects/ut
>> gds/src/solver/Solver.F90:350
>> #4  0x00000000005b99d9 in FEMLIB_M::solve2_vp (this=0x2b58d60,
>> solinit={...}) at /home1/00924/Reddy135/projects/utg
>> ds/src/fem/VariationalProblemBoundProcedures.F90:793
>> #5  0x0000000000430277 in UTGDS_M::runsimulation_ddm
>> (this=0x7fffcd0c11f0) at /home1/00924/Reddy135/projects/utgds/
>> src/devicesimulator/runDDM.F90:39
>> #6  0x000000000042623e in UTGDS_M::runsimulation_device
>> ds/src/devicesimulator/UTGDSmod.F90:267
>> #7  0x000000000040840f in oneddgfetpoissonschrod () at
>> /home1/00924/Reddy135/projects/utgds/test/testDDM/RTDPoisTes
>> t.F90:13
>> #8  0x0000000000407e4c in main () in
>> /home1/00924/Reddy135/projects/utgds/test/testDDM/PoisTest
>> #9  0x000000390881ecdd in __libc_start_main () in /lib64/libc-2.12.so
>> Thanks
>> Reddy
>> On Wed, Jan 22, 2014 at 5:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Wed, Jan 22, 2014 at 5:37 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
>>> wrote:
>>>> On Wed, Jan 22, 2014 at 5:33 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>> > On Wed, Jan 22, 2014 at 4:50 PM, Dharmendar Reddy
>>>> > wrote:
>>>> >> I take back my earlier email...
>>>> > Do you have the threadcomm stuff turned on?
>>>> I do not know what this means. Is related to compile time flags for my
>>>> fortran code ? I link to mkl which is threaded. But otherwise, i
>>>> guess, the answer is no.
>>> The weird business looks like its in pthreads, so could you reconfigure
>>> without MKL?
>>>   $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py --download-f-blas-lapack
>>> --PETSC_ARCH=arch-testing
>>> It would not surprise me if this was the problem.
>>>    Matt
>>>> >    Matt
>>>> >> I see the error  irrespective of valgrind options. I did a clean
>>>> >> compile to test it few times now.
>>>> >> See the attached valgrind.log
>>>> >> Now the difference between, ex5f90.F and my code is that i use
>>>> >> DMSNESSetFunctionLocal in the case where the code fails.
>>>> >> I have also attached the solver.F90 which wraps the calls to snes, Now
>>>> >> the solver has to interface (1) for equations which are handled with a
>>>> >> DM and (2) for equation with out DM , here i use SNESSetFunction, and
>>>> >> this part of the code runs fine with the test case in the code which
>>>> >> can be compiled with -DTestSolver and standard petsc makefile
>>>> >> The case with DM is linked deeply into my code, i am trying to get to
>>>> >> a test case for that.
>>>> >> thanks
>>>> >> Reddy
>>>> >> On Wed, Jan 22, 2014 at 4:30 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>> >> wrote:
>>>> >> >    The thing to use in valgrind is -q --tool=memcheck
>>>> >> >     This checks for corrupted and illegally accessed memory,
>>>> >> > uninitialized memory etc  It shows the exact lines that memory is
>>>> >> > used
>>>> >> > incorrectly so you can fix your code.
>>>> >> >    Barry
>>>> >> > On Jan 22, 2014, at 4:02 PM, Dharmendar Reddy
>>>> >> > wrote:
>>>> >> >> Hello,
>>>> >> >>        The code works fine if i run with valgrind --leak-check=yes
>>>> >> >> exename args
>>>> >> >> it fails if i run  valgrind exename args
>>>> >> >> Any suggestions on what to look for my code?
>>>> >> >> Thanks
>>>> >> >> Reddy
>>>> >> >> On Wed, Jan 22, 2014 at 3:31 PM, Dharmendar Reddy
>>>> >> >>> Hello,
>>>> >> >>>        I tried using the SNESSetConvergenceTest in ex5f90.F using
>>>> >> >>> my
>>>> >> >>> subroutine. Works as expected. I will try to run my code through
>>>> >> >>> valgrind.
>>>> >> >>> Thanks
>>>> >> >>> Reddy
>>>> >> >>> On Wed, Jan 22, 2014 at 2:33 PM, Dharmendar Reddy
>>>> >> >>>> Hello,
>>>> >> >>>>         I will also try to create a stand alone test case.
>>>> >> >>>> Thanks
>>>> >> >>>> Reddy
>>>> >> >>>> On Wed, Jan 22, 2014 at 1:53 PM, Matthew Knepley
>>>> >> >>>> wrote:
>>>> >> >>>>> On Wed, Jan 22, 2014 at 1:52 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>> >> >>>>> wrote:
>>>> >> >>>>>>  We need more information to track this down. Could you make a
>>>> >> >>>>>> simple
>>>> >> >>>>>> standalone code that reproduces the problem? Just creates a
>>>> >> >>>>>> this,
>>>> >> >>>>>> creates a
>>>> >> >>>>>> SNES, sets the function, sets the test code and then crashes
>>>> >> >>>>>> when
>>>> >> >>>>>> runs.
>>>> >> >>>>>>   But since it is not crashing in the SNESConvergenceTest_snes
>>>> >> >>>>>> routine I
>>>> >> >>>>>> suspect it may be memory corruption. Have you run your code
>>>> >> >>>>>> under
>>>> >> >>>>>> valgrind?
>>>> >> >>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>> >> >>>>> I am putting his convergence test into ex5f right now. This can
>>>> >> >>>>> be
>>>> >> >>>>> valgrinded. I will send an update when it runs.
>>>> >> >>>>>  Matt
>>>> >> >>>>>>   Barry
>>>> >> >>>>>> On Jan 20, 2014, at 7:14 PM, Dharmendar Reddy
>>>> >> >>>>>> wrote:
>>>> >> >>>>>>> Hello,
>>>> >> >>>>>>>        I am getting a segmentation fault when i use
>>>> >> >>>>>>> SNESSetConvergenceTest from Fortran.
>>>> >> >>>>>>> I use the following:
>>>> >> >>>>>>> this,PETSC_NULL_FUNCTION, ierr)   (Line 1)
>>>> >> >>>>>>> where the soubtoutine is
>>>> >> >>>>>>> subroutine
>>>> >> >>>>>>> SNESConvergenceTest_snes(snes,it,xnorm,gnorm,fnorm,reason,this,
>>>> >> >>>>>>> ierr)
>>>> >> >>>>>>> implicit none
>>>> >> >>>>>>> #include "finclude/petsc.h"
>>>> >> >>>>>>> ! IO Variables
>>>> >> >>>>>>> SNES :: snes
>>>> >> >>>>>>> integer :: it
>>>> >> >>>>>>> PetscReal :: xnorm
>>>> >> >>>>>>> PetscReal :: gnorm
>>>> >> >>>>>>> PetscReal :: fnorm
>>>> >> >>>>>>> SNESConvergedReason :: reason
>>>> >> >>>>>>> type(Solver_t) :: this
>>>> >> >>>>>>> PetscErrorCode :: ierr
>>>> >> >>>>>>> ! Local Variables
>>>> >> >>>>>>> Vec :: X, dX
>>>> >> >>>>>>> Vec :: F, W, G
>>>> >> >>>>>>> real(WP) :: lambda
>>>> >> >>>>>>> print*, 'Calling custom test',it,xnorm,fnorm,gnorm
>>>> >> >>>>>>> !call SNESLineSearchGetLambda(this%linesearch, lambda, ierr)
>>>> >> >>>>>>> !call SNESLineSearchGetVecs(this%linesearch, X, F, dX, W, G,
>>>> >> >>>>>>> ierr)
>>>> >> >>>>>>> !call this%SNESConvergenceTest(it, fnorm, lambda, X, dX,
>>>> >> >>>>>>> reason,
>>>> >> >>>>>>> ierr)
>>>> >> >>>>>>> reason = SNES_DIVERGED_FUNCTION_COUNT
>>>> >> >>>>>>> end subroutine SNESConvergenceTest_snes
>>>> >> >>>>>>> Code works fine if  the call at Line 1 is commented i.e, if i
>>>> >> >>>>>>> donot
>>>> >> >>>>>>> set the convergencetest
>>>> >> >>>>>>> I have attached the stack trace when the code fails
>>>> >> >>>>>>> (traceFail.log)
>>>> >> >>>>>>> and stack trace of the code which runs well (tracePass.log).
>>>> >> >>>>>>> Thanks
>>>> >> >>>>>>> Reddy
>>>> >> >>>>>>> <traceFail.log><tracePass.log>
>>>> >> >>>>> What most experimenters take for granted before they begin their
>>>> >> >>>>> experiments
>>>> >> >>>>> is infinitely more interesting than any results to which their
>>>> >> >>>>> experiments
>>>> >> >>>>> lead.
>>>> >> >>>>> -- Norbert Wiener
>>>> >> >>>> Dharmendar Reddy Palle
>>>> >> >>>> Graduate Student
>>>> >> >>>> Microelectronics Research center,
>>>> >> >>>> University of Texas at Austin,
>>>> >> >>>> 10100 Burnet Road, Bldg. 160
>>>> >> >>>> MER 2.608F, TX 78758-4445
>>>> >> >>>> e-mail: dharmareddy84 at gmail.com
>>>> >> >>>> Phone: +1-512-350-9082
>>>> >> >>>> United States of America.
>>>> >> >>>> Homepage: https://webspace.utexas.edu/~dpr342
>>>> >> >>> Graduate Student
>>>> >> >> Graduate Student
>>>> >> Graduate Student
>>>> > experiments
>>>> > experiments
>>>> > lead.
>>>> > -- Norbert Wiener
>>>> Graduate Student
>>> What most experimenters take for granted before they begin their experiments
>>> is infinitely more interesting than any results to which their experiments
>>> lead.
>>> -- Norbert Wiener
>> Graduate Student
Graduate Student
