[petsc-users] Command line option to set number iterations for Chebyshev eigenvalue estimation?
Thu Jan 23 08:56:03 CST 2014
On Thu, Jan 23, 2014 at 8:54 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> If you don't have any prefix set on the outer KSP, you should be able to
> simply do
> -mg_levels_ksp_type chebychev
> -mg_levels_ksp_chebychev_estimate_eigenvalues 0,0.2,0,1.1
> -mg_levels_est_ksp_type cg
> -mg_levels_est_ksp_max_it X
Are you sure the est_ is not specest_?
     Matt
> Cheers,
>   Dave
> On 23 January 2014 15:49, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>> On 2014-01-23 14:32, Matthew Knepley wrote:
>>> On Thu, Jan 23, 2014 at 5:35 AM, Garth N. Wells <gnw20 at cam.ac.uk>
>>> wrote:
>>>  Is there are command line option to set the number of iterations
>>>> used for the eigenvalue estimation inside the Chebyshev
>>>> preconditioner?  "-gamg_est_ksp_max_it" does the trick with GAMG,
>>>> but I'd also like to change the number of iterations when using
>>>> Chebyshev smoothing with ML.
>>> In GAMG, we use PETSc itself to do the estimate, and give it the
>>> prefix gamg_est_. In ML, as far as I can see from the code, we use the
>>> internal
>>> estimator, and I don't think they give us this knob.
>> I'm not so interested in the what happens inside ML, but the Chebyshev
>> smoother that PETSc applies. With the default 10 GMRES iterations, the
>> eigenvalue estimate is not good enough for my problem, which leads to the
>> outer CG breaking down with an indefinite operator error.
>> I can get it working by changing
>>   -mg_levels_ksp_chebyshev_estimate_eigenvalues
>> but I'd rather do a few more iterations to get a better eigenvalue
>> estimate. It would also be nice to be able to switch from GMRES to CG. I
>> can do this with GAMG via "-gamg_est_ksp_type"
>> Garth
>>     Matt
>>>  Garth
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>>  -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140123/1208a909/attachment.html>
