[petsc-users] SNESSetConvergenceTest
Dharmendar Reddy dharmareddy84 at gmail.com
Wed Jan 22 15:31:01 CST 2014
Hello,
        I tried using the SNESSetConvergenceTest in ex5f90.F using my
subroutine. Works as expected. I will try to run my code through
valgrind.
Thanks
Reddy
On Wed, Jan 22, 2014 at 2:33 PM, Dharmendar Reddy
<dharmareddy84 at gmail.com> wrote:
> Hello,
>          I will also try to create a stand alone test case.
> Thanks
> Reddy
> On Wed, Jan 22, 2014 at 1:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Jan 22, 2014 at 1:52 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>   We need more information to track this down. Could you make a simple
>>> standalone code that reproduces the problem? Just creates a this, creates a
>>> SNES, sets the function, sets the test code and then crashes when runs.
>>>    But since it is not crashing in the SNESConvergenceTest_snes routine I
>>> suspect it may be memory corruption. Have you run your code under valgrind?
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> I am putting his convergence test into ex5f right now. This can be
>> valgrinded. I will send an update when it runs.
>>   Matt
>>>    Barry
>>> On Jan 20, 2014, at 7:14 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
>>> wrote:
>>> > Hello,
>>> >         I am getting a segmentation fault when i use
>>> > SNESSetConvergenceTest from Fortran.
>>> > I use the following:
>>> > call SNESSetConvergenceTest(this%snes, SNESConvergenceTest_snes,
>>> > this,PETSC_NULL_FUNCTION, ierr)   (Line 1)
>>> > where the soubtoutine is
>>> > subroutine
>>> > SNESConvergenceTest_snes(snes,it,xnorm,gnorm,fnorm,reason,this, ierr)
>>> >  implicit none
>>> > #include "finclude/petsc.h"
>>> >  ! IO Variables
>>> >  SNES :: snes
>>> >  integer :: it
>>> >  PetscReal :: xnorm
>>> >  PetscReal :: gnorm
>>> >  PetscReal :: fnorm
>>> >  SNESConvergedReason :: reason
>>> >  type(Solver_t) :: this
>>> >  PetscErrorCode :: ierr
>>> >  ! Local Variables
>>> >  Vec :: X, dX
>>> >  Vec :: F, W, G
>>> >  real(WP) :: lambda
>>> >  print*, 'Calling custom test',it,xnorm,fnorm,gnorm
>>> >  !call SNESLineSearchGetLambda(this%linesearch, lambda, ierr)
>>> >  !call SNESLineSearchGetVecs(this%linesearch, X, F, dX, W, G, ierr)
>>> >  !call this%SNESConvergenceTest(it, fnorm, lambda, X, dX, reason, ierr)
>>> >  reason = SNES_DIVERGED_FUNCTION_COUNT
>>> > end subroutine SNESConvergenceTest_snes
>>> > Code works fine if  the call at Line 1 is commented i.e, if i donot
>>> > set the convergencetest
>>> > I have attached the stack trace when the code fails (traceFail.log)
>>> > and stack trace of the code which runs well (tracePass.log).
>>> > Thanks
>>> > Reddy
>>> > <traceFail.log><tracePass.log>
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
> Dharmendar Reddy Palle
> Graduate Student
> Microelectronics Research center,
> University of Texas at Austin,
> 10100 Burnet Road, Bldg. 160
> MER 2.608F, TX 78758-4445
> e-mail: dharmareddy84 at gmail.com
> Phone: +1-512-350-9082
> United States of America.
> Homepage: https://webspace.utexas.edu/~dpr342
Graduate Student
