[petsc-users] Questions on dense and sparse matrix block
Danyang Su danyang.su at gmail.com
Wed Jan 22 14:11:59 CST 2014
Dear All,
I have a reactive transport problem that use block matrices. Each block
can be dense with a lot of zero entries or sparse without zero entries.
The model has been tested for a 1D reactive transport problem. When
dense block is used, it works well and time step can be increased
gradually to reach a maximum time step, but when sparse block is used,
the time step remains at a small value. I checked the entries for both
dense blocks and sparse blocks (A), they have the same non-zero entries.
With the same RHS (b), the solution (X) is a little different, but seems
acceptable. The first matrix with both dense blocks and sparse blocks
has been attached. The matrix is exported in matrix market exchange
format (.mtp).
I wonder if this is caused by the outer newton iteration or the solver
as this is not a general problem. This problem only occurs in some cases.
Does anyone run into this problem before?
Thanks and regards,
Danyang
%%MatrixMarket matrix coordinate real general
% This ASCII file represents a sparse MxN matrix with L
% nonzeros in the following Matrix Market format:
% |%%MatrixMarket matrix coordinate real general | <--- header line
% |% comments                                    |    |-- 0 or more comment lines
% |    M  N  L                                   | <--- rows, columns, entries
% |    I1  J1  A(I1, J1)                         | <--+
% |    I2  J2  A(I2, J2)                         |    |
% |    I3  J3  A(I3, J3)                         |    |-- L lines
% |    IL JL  A(IL, JL)                          | <--+
% Indices are 1-based, i.e. A(1,1) is the first element.
        1010         1010        30100
           1            1   0.48972610E+04
           1            2   0.00000000E+00
           1            3   0.00000000E+00
           1            4   0.00000000E+00
           1            5   0.00000000E+00
           1            6   0.39942105E+02
           1            7   0.38058900E+02
           1            8   0.00000000E+00
           1            9   0.00000000E+00
           1           10   0.18153565E+04
           1           11  -0.35206361E-04
           1           12   0.00000000E+00
           1           13   0.00000000E+00
           1           14   0.00000000E+00
           1           15   0.00000000E+00
           1           16  -0.28714265E-06
           1           17  -0.27360508E-06
           1           18   0.00000000E+00
           1           19   0.00000000E+00
           1           20  -0.13050579E-04
           2            2   0.30832492E+04
           2            1   0.00000000E+00
           2            3   0.00000000E+00
           2            4   0.31725108E+01
           2            5   0.31725108E+01
           2            6   0.00000000E+00
           2            7  -0.10568165E+02
           2            8   0.00000000E+00
           2            9   0.00000000E+00
           2           10   0.12417046E+03
           2           11   0.00000000E+00
           2           12  -0.22157848E-04
           2           13   0.00000000E+00
           2           14   0.00000000E+00
           2           15   0.00000000E+00
           2           16   0.00000000E+00
           2           17   0.00000000E+00
           2           18   0.00000000E+00
           2           19   0.00000000E+00
           2           20  -0.89266026E-06
           3            3   0.39041096E+03
           3            1   0.00000000E+00
           3            2   0.00000000E+00
           3            4   0.00000000E+00
           3            5   0.00000000E+00
           3            6   0.00000000E+00
           3            7   0.00000000E+00
           3            8   0.00000000E+00
           3            9   0.00000000E+00
           3           10   0.00000000E+00
           3           11   0.00000000E+00
           3           12   0.00000000E+00
           3           13  -0.28066608E-05
           3           14   0.00000000E+00
           3           15   0.00000000E+00
           3           16   0.00000000E+00
           3           17   0.00000000E+00
           3           18   0.00000000E+00
           3           19   0.00000000E+00
           3           20   0.00000000E+00
           4            4   0.67047646E+03
           4            1   0.00000000E+00
           4            2   0.31721936E+01
           4            3   0.00000000E+00
           4            5   0.95175325E+01
           4            6   0.00000000E+00
           4            7  -0.32918410E+02
           4            8   0.00000000E+00
           4            9   0.00000000E+00
           4           10   0.00000000E+00
           4           11   0.00000000E+00
           4           12   0.00000000E+00
           4           13   0.00000000E+00
           4           14  -0.47516275E-05
           4           15   0.00000000E+00
           4           16   0.00000000E+00
           4           17   0.87268201E-08
           4           18   0.00000000E+00
           4           19   0.00000000E+00
           4           20   0.00000000E+00
           5            5   0.95264187E+01
           5            1   0.00000000E+00
           5            2   0.31721936E+01
           5            3   0.00000000E+00
           5            4   0.95175325E+01
           5            6   0.00000000E+00
           5            7  -0.31738933E+02
           5            8   0.00000000E+00
           5            9   0.00000000E+00
           5           10   0.10897822E-05
           5           11   0.00000000E+00
           5           12   0.00000000E+00
           5           13   0.00000000E+00
           5           14   0.00000000E+00
           5           15  -0.63765367E-10
           5           16   0.00000000E+00
           5           17   0.24721601E-09
           5           18   0.00000000E+00
           5           19   0.00000000E+00
           5           20  -0.78344339E-14
           6            6   0.85373309E+03
           6            1   0.39942105E+02
           6            2   0.00000000E+00
           6            3   0.00000000E+00
           6            4   0.00000000E+00
           6            5   0.00000000E+00
           6            7   0.97718649E+03
           6            8   0.00000000E+00
           6            9   0.21599416E-04
           6           10   0.00000000E+00
           6           11  -0.28714265E-06
           6           12   0.00000000E+00
           6           13   0.00000000E+00
           6           14   0.00000000E+00
           6           15   0.00000000E+00
           6           16  -0.61374783E-05
           6           17  -0.70249846E-05
           6           18   0.00000000E+00
           6           19   0.00000000E+00
           6           20   0.00000000E+00
           7            7   0.13361859E+04
           7            1   0.38058900E+02
           7            2  -0.10573979E+02
           7            3   0.00000000E+00
           7            4  -0.32939144E+02
           7            5  -0.31759554E+02
           7            6   0.97717390E+03
           7            8  -0.19443751E-04
           7            9  -0.60179924E-01
           7           10   0.24752575E-01
           7           11  -0.27360508E-06
           7           12   0.00000000E+00
           7           13   0.00000000E+00
           7           14   0.87276927E-08
           7           15   0.24727690E-09
           7           16  -0.70248941E-05
           7           17  -0.88460827E-05
           7           18   0.23585210E-13
           7           19   0.43266612E-09
           7           20  -0.17787962E-09
           8            8   0.33154131E-04
           8            1   0.00000000E+00
           8            2   0.00000000E+00
           8            3   0.00000000E+00
           8            4   0.00000000E+00
           8            5   0.00000000E+00
           8            6   0.00000000E+00
           8            7  -0.19448461E-04
           8            9  -0.74731227E-05
           8           10  -0.18525968E-04
           8           11   0.00000000E+00
           8           12   0.00000000E+00
           8           13   0.00000000E+00
           8           14   0.00000000E+00
           8           15   0.00000000E+00
           8           16   0.00000000E+00
           8           17   0.23587113E-13
           8           18  -0.35002201E-13
           8           19  -0.43867309E-14
           8           20   0.16955322E-13
           9            9   0.49678112E+02
           9            1   0.00000000E+00
           9            2   0.00000000E+00
           9            3   0.00000000E+00
           9            4   0.00000000E+00
           9            5   0.00000000E+00
           9            6   0.21599416E-04
           9            7  -0.60173906E-01
           9            8  -0.74713272E-05
           9           10   0.16768354E+02
           9           11   0.00000000E+00
           9           12   0.00000000E+00
           9           13   0.00000000E+00
           9           14   0.00000000E+00
           9           15   0.00000000E+00
           9           16   0.00000000E+00
           9           17   0.43262286E-09
           9           18  -0.43865664E-14
           9           19  -0.35713531E-06
           9           20  -0.12054751E-06
          10           10   0.67424664E+04
          10            1   0.18153565E+04
          10            2   0.12417046E+03
          10            3   0.00000000E+00
          10            4   0.00000000E+00
          10            5   0.10897670E-05
          10            6   0.00000000E+00
          10            7   0.24752575E-01
          10            8  -0.18521169E-04
          10            9   0.16768354E+02
          10           11  -0.13050579E-04
          10           12  -0.89266026E-06
          10           13   0.00000000E+00
          10           14   0.00000000E+00
          10           15  -0.78343250E-14
          10           16   0.00000000E+00
          10           17  -0.17787962E-09
          10           18   0.16952779E-13
          10           19  -0.12054751E-06
          10           20  -0.48471527E-04
          11           11   0.97945219E+04
          11           12   0.00000000E+00
          11           13   0.00000000E+00
          11           14   0.00000000E+00
          11           15   0.00000000E+00
          11           16   0.79884210E+02
          11           17   0.76117799E+02
          11           18   0.00000000E+00
          11           19   0.00000000E+00
          11           20   0.36307130E+04
          11            1  -0.23456562E-04
          11            2   0.00000000E+00
          11            3   0.00000000E+00
          11            4   0.00000000E+00
          11            5   0.00000000E+00
          11            6  -0.19131143E-06
          11            7  -0.18229190E-06
          11            8   0.00000000E+00
          11            9   0.00000000E+00
          11           10  -0.86950685E-05
          11           21  -0.35206361E-04
          11           22   0.00000000E+00
          11           23   0.00000000E+00
          11           24   0.00000000E+00
          11           25   0.00000000E+00
          11           26  -0.28714265E-06
          11           27  -0.27360508E-06
          11           28   0.00000000E+00
          11           29   0.00000000E+00
          11           30  -0.13050579E-04
          12           12   0.61664984E+04
          12           11   0.00000000E+00
          12           13   0.00000000E+00
          12           14   0.63450217E+01
          12           15   0.63450217E+01
          12           16   0.00000000E+00
          12           17  -0.21136331E+02
          12           18   0.00000000E+00
          12           19   0.00000000E+00
          12           20   0.24834091E+03
          12            1   0.00000000E+00
          12            2  -0.14762870E-04
          12            3   0.00000000E+00
          12            4   0.00000000E+00
          12            5   0.00000000E+00
          12            6   0.00000000E+00
          12            7   0.00000000E+00
          12            8   0.00000000E+00
          12            9   0.00000000E+00
          12           10  -0.59474311E-06
          12           21   0.00000000E+00
          12           22  -0.22157848E-04
          12           23   0.00000000E+00
          12           24   0.00000000E+00
          12           25   0.00000000E+00
          12           26   0.00000000E+00
          12           27   0.00000000E+00
          12           28   0.00000000E+00
          12           29   0.00000000E+00
          12           30  -0.89266026E-06
          13           13   0.78082192E+03
          13           11   0.00000000E+00
          13           12   0.00000000E+00
          13           14   0.00000000E+00
          13           15   0.00000000E+00
          13           16   0.00000000E+00
          13           17   0.00000000E+00
          13           18   0.00000000E+00
          13           19   0.00000000E+00
          13           20   0.00000000E+00
          13            1   0.00000000E+00
          13            2   0.00000000E+00
          13            3  -0.18699636E-05
          13            4   0.00000000E+00
          13            5   0.00000000E+00
          13            6   0.00000000E+00
          13            7   0.00000000E+00
          13            8   0.00000000E+00
          13            9   0.00000000E+00
          13           10   0.00000000E+00
          13           21   0.00000000E+00
          13           22   0.00000000E+00
          13           23  -0.28066608E-05
          13           24   0.00000000E+00
          13           25   0.00000000E+00
          13           26   0.00000000E+00
          13           27   0.00000000E+00
          13           28   0.00000000E+00
          13           29   0.00000000E+00
          13           30   0.00000000E+00
          14           14   0.13409529E+04
          14           11   0.00000000E+00
          14           12   0.63443872E+01
          14           13   0.00000000E+00
          14           15   0.19035065E+02
          14           16   0.00000000E+00
          14           17  -0.65836821E+02
          14           18   0.00000000E+00
          14           19   0.00000000E+00
          14           20   0.00000000E+00
          14            1   0.00000000E+00
          14            2   0.00000000E+00
          14            3   0.00000000E+00
          14            4  -0.31658155E-05
          14            5   0.00000000E+00
          14            6   0.00000000E+00
          14            7   0.58143241E-08
          14            8   0.00000000E+00
          14            9   0.00000000E+00
          14           10   0.00000000E+00
          14           21   0.00000000E+00
          14           22   0.00000000E+00
          14           23   0.00000000E+00
          14           24  -0.47516275E-05
          14           25   0.00000000E+00
          14           26   0.00000000E+00
          14           27   0.87268201E-08
          14           28   0.00000000E+00
          14           29   0.00000000E+00
          14           30   0.00000000E+00
          15           15   0.19052837E+02
          15           11   0.00000000E+00
          15           12   0.63443872E+01
          15           13   0.00000000E+00
          15           14   0.19035065E+02
          15           16   0.00000000E+00
          15           17  -0.63477866E+02
          15           18   0.00000000E+00
          15           19   0.00000000E+00
          15           20   0.21795643E-05
          15            1   0.00000000E+00
          15            2   0.00000000E+00
          15            3   0.00000000E+00
          15            4   0.00000000E+00
          15            5  -0.42484262E-10
          15            6   0.00000000E+00
          15            7   0.16470994E-09
          15            8   0.00000000E+00
          15            9   0.00000000E+00
          15           10  -0.52197636E-14
          15           21   0.00000000E+00
          15           22   0.00000000E+00
          15           23   0.00000000E+00
          15           24   0.00000000E+00
          15           25  -0.63765367E-10
          15           26   0.00000000E+00
          15           27   0.24721601E-09
          15           28   0.00000000E+00
          15           29   0.00000000E+00
          15           30  -0.78344339E-14
          16           16   0.17074662E+04
          16           11   0.79884210E+02
          16           12   0.00000000E+00
          16           13   0.00000000E+00
          16           14   0.00000000E+00
          16           15   0.00000000E+00
          16           17   0.19543730E+04
          16           18   0.00000000E+00
          16           19   0.43198833E-04
          16           20   0.00000000E+00
          16            1  -0.19131143E-06
          16            2   0.00000000E+00
          16            3   0.00000000E+00
          16            4   0.00000000E+00
          16            5   0.00000000E+00
          16            6  -0.40891514E-05
          16            7  -0.46804606E-05
          16            8   0.00000000E+00
          16            9   0.00000000E+00
          16           10   0.00000000E+00
          16           21  -0.28714265E-06
          16           22   0.00000000E+00
          16           23   0.00000000E+00
          16           24   0.00000000E+00
          16           25   0.00000000E+00
          16           26  -0.61374783E-05
          16           27  -0.70249846E-05
          16           28   0.00000000E+00
          16           29   0.00000000E+00
          16           30   0.00000000E+00
          17           17   0.26723718E+04
          17           11   0.76117799E+02
          17           12  -0.21147957E+02
          17           13   0.00000000E+00
          17           14  -0.65878288E+02
          17           15  -0.63519108E+02
          17           16   0.19543478E+04
          17           18  -0.38887502E-04
          17           19  -0.12035985E+00
          17           20   0.49505150E-01
          17            1  -0.18229190E-06
          17            2   0.00000000E+00
          17            3   0.00000000E+00
          17            4   0.58149055E-08
          17            5   0.16475051E-09
          17            6  -0.46804003E-05
          17            7  -0.58937839E-05
          17            8   0.15713863E-13
          17            9   0.28826778E-09
          17           10  -0.11851393E-09
          17           21  -0.27360508E-06
          17           22   0.00000000E+00
          17           23   0.00000000E+00
          17           24   0.87276927E-08
          17           25   0.24727690E-09
          17           26  -0.70248941E-05
          17           27  -0.88460827E-05
          17           28   0.23585210E-13
          17           29   0.43266612E-09
          17           30  -0.17787962E-09
          18           18   0.66308262E-04
          18           11   0.00000000E+00
          18           12   0.00000000E+00
          18           13   0.00000000E+00
          18           14   0.00000000E+00
          18           15   0.00000000E+00
          18           16   0.00000000E+00
          18           17  -0.38896922E-04
          18           19  -0.14946245E-04
          18           20  -0.37051937E-04
          18            1   0.00000000E+00
          18            2   0.00000000E+00
          18            3   0.00000000E+00
          18            4   0.00000000E+00
          18            5   0.00000000E+00
          18            6   0.00000000E+00
          18            7   0.15715131E-13
          18            8  -0.23320538E-13
          18            9  -0.29226998E-14
          18           10   0.11296639E-13
          18           21   0.00000000E+00
          18           22   0.00000000E+00
          18           23   0.00000000E+00
          18           24   0.00000000E+00
          18           25   0.00000000E+00
          18           26   0.00000000E+00
          18           27   0.23587113E-13
          18           28  -0.35002201E-13
          18           29  -0.43867309E-14
          18           30   0.16955322E-13
          19           19   0.99356224E+02
          19           11   0.00000000E+00
          19           12   0.00000000E+00
          19           13   0.00000000E+00
          19           14   0.00000000E+00
          19           15   0.00000000E+00
          19           16   0.43198833E-04
          19           17  -0.12034781E+00
          19           18  -0.14942654E-04
          19           20   0.33536708E+02
          19            1   0.00000000E+00
          19            2   0.00000000E+00
          19            3   0.00000000E+00
          19            4   0.00000000E+00
          19            5   0.00000000E+00
          19            6   0.00000000E+00
          19            7   0.28823896E-09
          19            8  -0.29225902E-14
          19            9  -0.23794469E-06
          19           10  -0.80315886E-07
          19           21   0.00000000E+00
          19           22   0.00000000E+00
          19           23   0.00000000E+00
          19           24   0.00000000E+00
          19           25   0.00000000E+00
          19           26   0.00000000E+00
          19           27   0.43262286E-09
          19           28  -0.43865664E-14
          19           29  -0.35713531E-06
          19           30  -0.12054751E-06
          20           20   0.13484933E+05
          20           11   0.36307130E+04
          20           12   0.24834091E+03
          20           13   0.00000000E+00
          20           14   0.00000000E+00
          20           15   0.21795340E-05
          20           16   0.00000000E+00
          20           17   0.49505150E-01
          20           18  -0.37042339E-04
          20           19   0.33536708E+02
          20            1  -0.86950685E-05
          20            2  -0.59474311E-06
          20            3   0.00000000E+00
          20            4   0.00000000E+00
          20            5  -0.52196911E-14
          20            6   0.00000000E+00
          20            7  -0.11851393E-09
          20            8   0.11294945E-13
          20            9  -0.80315886E-07
          20           10  -0.32294600E-04
          20           21  -0.13050579E-04
          20           22  -0.89266026E-06
          20           23   0.00000000E+00
          20           24   0.00000000E+00
          20           25  -0.78343250E-14
          20           26   0.00000000E+00
          20           27  -0.17787962E-09
          20           28   0.16952779E-13
          20           29  -0.12054751E-06
          20           30  -0.48471527E-04
          21           21   0.97945219E+04
          21           22   0.00000000E+00
          21           23   0.00000000E+00
          21           24   0.00000000E+00
          21           25   0.00000000E+00
          21           26   0.79884210E+02
          21           27   0.76117799E+02
          21           28   0.00000000E+00
          21           29   0.00000000E+00
          21           30   0.36307130E+04
          21           11  -0.23456562E-04
          21           12   0.00000000E+00
          21           13   0.00000000E+00
          21           14   0.00000000E+00
          21           15   0.00000000E+00
          21           16  -0.19131143E-06
          21           17  -0.18229190E-06
          21           18   0.00000000E+00
          21           19   0.00000000E+00
          21           20  -0.86950685E-05
          21           31  -0.35206361E-04
          21           32   0.00000000E+00
          21           33   0.00000000E+00
          21           34   0.00000000E+00
          21           35   0.00000000E+00
          21           36  -0.28714265E-06
          21           37  -0.27360508E-06
          21           38   0.00000000E+00
          21           39   0.00000000E+00
          21           40  -0.13050579E-04
          22           22   0.61664984E+04
          22           21   0.00000000E+00
          22           23   0.00000000E+00
          22           24   0.63450217E+01
          22           25   0.63450217E+01
          22           26   0.00000000E+00
          22           27  -0.21136331E+02
          22           28   0.00000000E+00
          22           29   0.00000000E+00
          22           30   0.24834091E+03
          22           11   0.00000000E+00
          22           12  -0.14762870E-04
          22           13   0.00000000E+00
          22           14   0.00000000E+00
          22           15   0.00000000E+00
          22           16   0.00000000E+00
          22           17   0.00000000E+00
          22           18   0.00000000E+00
          22           19   0.00000000E+00
          22           20  -0.59474311E-06
          22           31   0.00000000E+00
          22           32  -0.22157848E-04
          22           33   0.00000000E+00
          22           34   0.00000000E+00
          22           35   0.00000000E+00
          22           36   0.00000000E+00
          22           37   0.00000000E+00
          22           38   0.00000000E+00
          22           39   0.00000000E+00
          22           40  -0.89266026E-06
          23           23   0.78082192E+03
          23           21   0.00000000E+00
          23           22   0.00000000E+00
          23           24   0.00000000E+00
          23           25   0.00000000E+00
          23           26   0.00000000E+00
          23           27   0.00000000E+00
          23           28   0.00000000E+00
          23           29   0.00000000E+00
          23           30   0.00000000E+00
          23           11   0.00000000E+00
          23           12   0.00000000E+00
          23           13  -0.18699636E-05
          23           14   0.00000000E+00
          23           15   0.00000000E+00
          23           16   0.00000000E+00
          23           17   0.00000000E+00
          23           18   0.00000000E+00
          23           19   0.00000000E+00
          23           20   0.00000000E+00
          23           31   0.00000000E+00
          23           32   0.00000000E+00
          23           33  -0.28066608E-05
          23           34   0.00000000E+00
          23           35   0.00000000E+00
          23           36   0.00000000E+00
          23           37   0.00000000E+00
          23           38   0.00000000E+00
          23           39   0.00000000E+00
          23           40   0.00000000E+00
          24           24   0.13409529E+04
          24           21   0.00000000E+00
          24           22   0.63443872E+01
          24           23   0.00000000E+00
          24           25   0.19035065E+02
          24           26   0.00000000E+00
          24           27  -0.65836821E+02
          24           28   0.00000000E+00
          24           29   0.00000000E+00
          24           30   0.00000000E+00
          24           11   0.00000000E+00
          24           12   0.00000000E+00
          24           13   0.00000000E+00
          24           14  -0.31658155E-05
          24           15   0.00000000E+00
          24           16   0.00000000E+00
          24           17   0.58143241E-08
          24           18   0.00000000E+00
          24           19   0.00000000E+00
          24           20   0.00000000E+00
          24           31   0.00000000E+00
          24           32   0.00000000E+00
          24           33   0.00000000E+00
          24           34  -0.47516275E-05
          24           35   0.00000000E+00
          24           36   0.00000000E+00
          24           37   0.87268201E-08
          24           38   0.00000000E+00
          24           39   0.00000000E+00
          24           40   0.00000000E+00
          25           25   0.19052837E+02
          25           21   0.00000000E+00
          25           22   0.63443872E+01
          25           23   0.00000000E+00
          25           24   0.19035065E+02
          25           26   0.00000000E+00
          25           27  -0.63477866E+02
          25           28   0.00000000E+00
          25           29   0.00000000E+00
          25           30   0.21795643E-05
          25           11   0.00000000E+00
          25           12   0.00000000E+00
          25           13   0.00000000E+00
          25           14   0.00000000E+00
          25           15  -0.42484262E-10
          25           16   0.00000000E+00
          25           17   0.16470994E-09
          25           18   0.00000000E+00
          25           19   0.00000000E+00
          25           20  -0.52197636E-14
          25           31   0.00000000E+00
          25           32   0.00000000E+00
          25           33   0.00000000E+00
          25           34   0.00000000E+00
          25           35  -0.63765367E-10
          25           36   0.00000000E+00
          25           37   0.24721601E-09
          25           38   0.00000000E+00
          25           39   0.00000000E+00
          25           40  -0.78344339E-14
          26           26   0.17074662E+04
          26           21   0.79884210E+02
          26           22   0.00000000E+00
          26           23   0.00000000E+00
          26           24   0.00000000E+00
          26           25   0.00000000E+00
          26           27   0.19543730E+04
          26           28   0.00000000E+00
          26           29   0.43198833E-04
          26           30   0.00000000E+00
          26           11  -0.19131143E-06
          26           12   0.00000000E+00
          26           13   0.00000000E+00
          26           14   0.00000000E+00
          26           15   0.00000000E+00
          26           16  -0.40891514E-05
          26           17  -0.46804606E-05
          26           18   0.00000000E+00
          26           19   0.00000000E+00
          26           20   0.00000000E+00
          26           31  -0.28714265E-06
          26           32   0.00000000E+00
          26           33   0.00000000E+00
          26           34   0.00000000E+00
          26           35   0.00000000E+00
          26           36  -0.61374783E-05
          26           37  -0.70249846E-05
          26           38   0.00000000E+00
          26           39   0.00000000E+00
          26           40   0.00000000E+00
          27           27   0.26723718E+04
          27           21   0.76117799E+02
          27           22  -0.21147957E+02
          27           23   0.00000000E+00
          27           24  -0.65878288E+02
          27           25  -0.63519108E+02
          27           26   0.19543478E+04
          27           28  -0.38887502E-04
          27           29  -0.12035985E+00
          27           30   0.49505150E-01
          27           11  -0.18229190E-06
          27           12   0.00000000E+00
          27           13   0.00000000E+00
          27           14   0.58149055E-08
          27           15   0.16475051E-09
          27           16  -0.46804003E-05
          27           17  -0.58937839E-05
          27           18   0.15713863E-13
          27           19   0.28826778E-09
          27           20  -0.11851393E-09
          27           31  -0.27360508E-06
          27           32   0.00000000E+00
          27           33   0.00000000E+00
          27           34   0.87276927E-08
          27           35   0.24727690E-09
          27           36  -0.70248941E-05
          27           37  -0.88460827E-05
          27           38   0.23585210E-13
          27           39   0.43266612E-09
          27           40  -0.17787962E-09
          28           28   0.66308262E-04
          28           21   0.00000000E+00
          28           22   0.00000000E+00
          28           23   0.00000000E+00
          28           24   0.00000000E+00
          28           25   0.00000000E+00
          28           26   0.00000000E+00
          28           27  -0.38896922E-04
          28           29  -0.14946245E-04
          28           30  -0.37051937E-04
          28           11   0.00000000E+00
          28           12   0.00000000E+00
          28           13   0.00000000E+00
          28           14   0.00000000E+00
          28           15   0.00000000E+00
          28           16   0.00000000E+00
          28           17   0.15715131E-13
          28           18  -0.23320538E-13
          28           19  -0.29226998E-14
          28           20   0.11296639E-13
          28           31   0.00000000E+00
          28           32   0.00000000E+00
          28           33   0.00000000E+00
          28           34   0.00000000E+00
          28           35   0.00000000E+00
          28           36   0.00000000E+00
          28           37   0.23587113E-13
          28           38  -0.35002201E-13
          28           39  -0.43867309E-14
          28           40   0.16955322E-13
          29           29   0.99356224E+02
          29           21   0.00000000E+00
          29           22   0.00000000E+00
          29           23   0.00000000E+00
          29           24   0.00000000E+00
          29           25   0.00000000E+00
          29           26   0.43198833E-04
          29           27  -0.12034781E+00
          29           28  -0.14942654E-04
          29           30   0.33536708E+02
          29           11   0.00000000E+00
          29           12   0.00000000E+00
          29           13   0.00000000E+00
          29           14   0.00000000E+00
          29           15   0.00000000E+00
          29           16   0.00000000E+00
          29           17   0.28823896E-09
          29           18  -0.29225902E-14
          29           19  -0.23794469E-06
          29           20  -0.80315886E-07
          29           31   0.00000000E+00
          29           32   0.00000000E+00
          29           33   0.00000000E+00
          29           34   0.00000000E+00
          29           35   0.00000000E+00
          29           36   0.00000000E+00
          29           37   0.43262286E-09
          29           38  -0.43865664E-14
          29           39  -0.35713531E-06
          29           40  -0.12054751E-06
          30           30   0.13484933E+05
          30           21   0.36307130E+04
          30           22   0.24834091E+03
          30           23   0.00000000E+00
          30           24   0.00000000E+00
          30           25   0.21795340E-05
          30           26   0.00000000E+00
          30           27   0.49505150E-01
          30           28  -0.37042339E-04
          30           29   0.33536708E+02
          30           11  -0.86950685E-05
          30           12  -0.59474311E-06
          30           13   0.00000000E+00
          30           14   0.00000000E+00
          30           15  -0.52196911E-14
          30           16   0.00000000E+00
          30           17  -0.11851393E-09
          30           18   0.11294945E-13
          30           19  -0.80315886E-07
          30           20  -0.32294600E-04
          30           31  -0.13050579E-04
          30           32  -0.89266026E-06
          30           33   0.00000000E+00
          30           34   0.00000000E+00
          30           35  -0.78343250E-14
          30           36   0.00000000E+00
          30           37  -0.17787962E-09
          30           38   0.16952779E-13
          30           39  -0.12054751E-06
          30           40  -0.48471527E-04
          31           31   0.97945219E+04
          31           32   0.00000000E+00
          31           33   0.00000000E+00
          31           34   0.00000000E+00
          31           35   0.00000000E+00
          31           36   0.79884210E+02
          31           37   0.76117799E+02
          31           38   0.00000000E+00
          31           39   0.00000000E+00
          31           40   0.36307130E+04
          31           21  -0.23456562E-04
          31           22   0.00000000E+00
          31           23   0.00000000E+00
          31           24   0.00000000E+00
          31           25   0.00000000E+00
          31           26  -0.19131143E-06
          31           27  -0.18229190E-06
          31           28   0.00000000E+00
          31           29   0.00000000E+00
          31           30  -0.86950685E-05
          31           41  -0.35206361E-04
          31           42   0.00000000E+00
          31           43   0.00000000E+00
          31           44   0.00000000E+00
          31           45   0.00000000E+00
          31           46  -0.28714265E-06
          31           47  -0.27360508E-06
          31           48   0.00000000E+00
          31           49   0.00000000E+00
          31           50  -0.13050579E-04
          32           32   0.61664984E+04
          32           31   0.00000000E+00
          32           33   0.00000000E+00
          32           34   0.63450217E+01
          32           35   0.63450217E+01
          32           36   0.00000000E+00
          32           37  -0.21136331E+02
          32           38   0.00000000E+00
          32           39   0.00000000E+00
          32           40   0.24834091E+03
          32           21   0.00000000E+00
          32           22  -0.14762870E-04
          32           23   0.00000000E+00
          32           24   0.00000000E+00
          32           25   0.00000000E+00
          32           26   0.00000000E+00
          32           27   0.00000000E+00
          32           28   0.00000000E+00
          32           29   0.00000000E+00
          32           30  -0.59474311E-06
          32           41   0.00000000E+00
          32           42  -0.22157848E-04
          32           43   0.00000000E+00
          32           44   0.00000000E+00
          32           45   0.00000000E+00
          32           46   0.00000000E+00
          32           47   0.00000000E+00
          32           48   0.00000000E+00
          32           49   0.00000000E+00
          32           50  -0.89266026E-06
          33           33   0.78082192E+03
          33           31   0.00000000E+00
          33           32   0.00000000E+00
          33           34   0.00000000E+00
          33           35   0.00000000E+00
          33           36   0.00000000E+00
          33           37   0.00000000E+00
          33           38   0.00000000E+00
          33           39   0.00000000E+00
          33           40   0.00000000E+00
          33           21   0.00000000E+00
          33           22   0.00000000E+00
          33           23  -0.18699636E-05
          33           24   0.00000000E+00
          33           25   0.00000000E+00
          33           26   0.00000000E+00
          33           27   0.00000000E+00
          33           28   0.00000000E+00
          33           29   0.00000000E+00
          33           30   0.00000000E+00
          33           41   0.00000000E+00
          33           42   0.00000000E+00
          33           43  -0.28066608E-05
          33           44   0.00000000E+00
          33           45   0.00000000E+00
          33           46   0.00000000E+00
          33           47   0.00000000E+00
          33           48   0.00000000E+00
          33           49   0.00000000E+00
          33           50   0.00000000E+00
          34           34   0.13409529E+04
          34           31   0.00000000E+00
          34           32   0.63443872E+01
          34           33   0.00000000E+00
          34           35   0.19035065E+02
          34           36   0.00000000E+00
          34           37  -0.65836821E+02
          34           38   0.00000000E+00
          34           39   0.00000000E+00
          34           40   0.00000000E+00
          34           21   0.00000000E+00
          34           22   0.00000000E+00
          34           23   0.00000000E+00
          34           24  -0.31658155E-05
          34           25   0.00000000E+00
          34           26   0.00000000E+00
          34           27   0.58143241E-08
          34           28   0.00000000E+00
          34           29   0.00000000E+00
          34           30   0.00000000E+00
          34           41   0.00000000E+00
          34           42   0.00000000E+00
          34           43   0.00000000E+00
          34           44  -0.47516275E-05
          34           45   0.00000000E+00
          34           46   0.00000000E+00
          34           47   0.87268201E-08
          34           48   0.00000000E+00
          34           49   0.00000000E+00
          34           50   0.00000000E+00
          35           35   0.19052837E+02
          35           31   0.00000000E+00
          35           32   0.63443872E+01
          35           33   0.00000000E+00
          35           34   0.19035065E+02
          35           36   0.00000000E+00
          35           37  -0.63477866E+02
          35           38   0.00000000E+00
          35           39   0.00000000E+00
          35           40   0.21795643E-05
          35           21   0.00000000E+00
          35           22   0.00000000E+00
          35           23   0.00000000E+00
          35           24   0.00000000E+00
          35           25  -0.42484262E-10
          35           26   0.00000000E+00
          35           27   0.16470994E-09
          35           28   0.00000000E+00
          35           29   0.00000000E+00
          35           30  -0.52197636E-14
          35           41   0.00000000E+00
          35           42   0.00000000E+00
          35           43   0.00000000E+00
          35           44   0.00000000E+00
          35           45  -0.63765367E-10
          35           46   0.00000000E+00
          35           47   0.24721601E-09
          35           48   0.00000000E+00
          35           49   0.00000000E+00
          35           50  -0.78344339E-14
          36           36   0.17074662E+04
          36           31   0.79884210E+02
          36           32   0.00000000E+00
          36           33   0.00000000E+00
          36           34   0.00000000E+00
          36           35   0.00000000E+00
          36           37   0.19543730E+04
          36           38   0.00000000E+00
          36           39   0.43198833E-04
          36           40   0.00000000E+00
          36           21  -0.19131143E-06
          36           22   0.00000000E+00
          36           23   0.00000000E+00
          36           24   0.00000000E+00
          36           25   0.00000000E+00
          36           26  -0.40891514E-05
          36           27  -0.46804606E-05
          36           28   0.00000000E+00
          36           29   0.00000000E+00
          36           30   0.00000000E+00
          36           41  -0.28714265E-06
          36           42   0.00000000E+00
          36           43   0.00000000E+00
          36           44   0.00000000E+00
          36           45   0.00000000E+00
          36           46  -0.61374783E-05
          36           47  -0.70249846E-05
          36           48   0.00000000E+00
          36           49   0.00000000E+00
          36           50   0.00000000E+00
          37           37   0.26723718E+04
          37           31   0.76117799E+02
          37           32  -0.21147957E+02
          37           33   0.00000000E+00
          37           34  -0.65878288E+02
          37           35  -0.63519108E+02
          37           36   0.19543478E+04
          37           38  -0.38887502E-04
          37           39  -0.12035985E+00
          37           40   0.49505150E-01
          37           21  -0.18229190E-06
          37           22   0.00000000E+00
          37           23   0.00000000E+00
          37           24   0.58149055E-08
          37           25   0.16475051E-09
          37           26  -0.46804003E-05
          37           27  -0.58937839E-05
          37           28   0.15713863E-13
          37           29   0.28826778E-09
          37           30  -0.11851393E-09
          37           41  -0.27360508E-06
          37           42   0.00000000E+00
          37           43   0.00000000E+00
          37           44   0.87276927E-08
          37           45   0.24727690E-09
          37           46  -0.70248941E-05
          37           47  -0.88460827E-05
          37           48   0.23585210E-13
          37           49   0.43266612E-09
          37           50  -0.17787962E-09
          38           38   0.66308262E-04
          38           31   0.00000000E+00
          38           32   0.00000000E+00
          38           33   0.00000000E+00
          38           34   0.00000000E+00
          38           35   0.00000000E+00
          38           36   0.00000000E+00
          38           37  -0.38896922E-04
          38           39  -0.14946245E-04
          38           40  -0.37051937E-04
          38           21   0.00000000E+00
          38           22   0.00000000E+00
          38           23   0.00000000E+00
          38           24   0.00000000E+00
          38           25   0.00000000E+00
          38           26   0.00000000E+00
          38           27   0.15715131E-13
          38           28  -0.23320538E-13
          38           29  -0.29226998E-14
          38           30   0.11296639E-13
          38           41   0.00000000E+00
          38           42   0.00000000E+00
          38           43   0.00000000E+00
          38           44   0.00000000E+00
          38           45   0.00000000E+00
          38           46   0.00000000E+00
          38           47   0.23587113E-13
          38           48  -0.35002201E-13
          38           49  -0.43867309E-14
          38           50   0.16955322E-13
          39           39   0.99356224E+02
          39           31   0.00000000E+00
          39           32   0.00000000E+00
          39           33   0.00000000E+00
          39           34   0.00000000E+00
          39           35   0.00000000E+00
          39           36   0.43198833E-04
          39           37  -0.12034781E+00
          39           38  -0.14942654E-04
          39           40   0.33536708E+02
          39           21   0.00000000E+00
          39           22   0.00000000E+00
          39           23   0.00000000E+00
          39           24   0.00000000E+00
          39           25   0.00000000E+00
          39           26   0.00000000E+00
          39           27   0.28823896E-09
          39           28  -0.29225902E-14
          39           29  -0.23794469E-06
          39           30  -0.80315886E-07
          39           41   0.00000000E+00
          39           42   0.00000000E+00
          39           43   0.00000000E+00
          39           44   0.00000000E+00
          39           45   0.00000000E+00
          39           46   0.00000000E+00
          39           47   0.43262286E-09
          39           48  -0.43865664E-14
          39           49  -0.35713531E-06
          39           50  -0.12054751E-06
          40           40   0.13484933E+05
          40           31   0.36307130E+04
          40           32   0.24834091E+03
          40           33   0.00000000E+00
          40           34   0.00000000E+00
          40           35   0.21795340E-05
          40           36   0.00000000E+00
          40           37   0.49505150E-01
          40           38  -0.37042339E-04
          40           39   0.33536708E+02
          40           21  -0.86950685E-05
          40           22  -0.59474311E-06
          40           23   0.00000000E+00
          40           24   0.00000000E+00
          40           25  -0.52196911E-14
          40           26   0.00000000E+00
          40           27  -0.11851393E-09
          40           28   0.11294945E-13
          40           29  -0.80315886E-07
          40           30  -0.32294600E-04
          40           41  -0.13050579E-04
          40           42  -0.89266026E-06
          40           43   0.00000000E+00
          40           44   0.00000000E+00
          40           45  -0.78343250E-14
          40           46   0.00000000E+00
          40           47  -0.17787962E-09
          40           48   0.16952779E-13
          40           49  -0.12054751E-06
          40           50  -0.48471527E-04
          41           41   0.97945219E+04
          41           42   0.00000000E+00
          41           43   0.00000000E+00
          41           44   0.00000000E+00
          41           45   0.00000000E+00
          41           46   0.79884210E+02
          41           47   0.76117799E+02
          41           48   0.00000000E+00
          41           49   0.00000000E+00
          41           50   0.36307130E+04
          41           31  -0.23456562E-04
          41           32   0.00000000E+00
          41           33   0.00000000E+00
          41           34   0.00000000E+00
          41           35   0.00000000E+00
          41           36  -0.19131143E-06
          41           37  -0.18229190E-06
          41           38   0.00000000E+00
          41           39   0.00000000E+00
          41           40  -0.86950685E-05
          41           51  -0.35206361E-04
          41           52   0.00000000E+00
          41           53   0.00000000E+00
          41           54   0.00000000E+00
          41           55   0.00000000E+00
          41           56  -0.28714265E-06
          41           57  -0.27360508E-06
          41           58   0.00000000E+00
          41           59   0.00000000E+00
          41           60  -0.13050579E-04
          42           42   0.61664984E+04
          42           41   0.00000000E+00
          42           43   0.00000000E+00
          42           44   0.63450217E+01
          42           45   0.63450217E+01
          42           46   0.00000000E+00
          42           47  -0.21136331E+02
          42           48   0.00000000E+00
          42           49   0.00000000E+00
          42           50   0.24834091E+03
          42           31   0.00000000E+00
          42           32  -0.14762870E-04
          42           33   0.00000000E+00
          42           34   0.00000000E+00
          42           35   0.00000000E+00
          42           36   0.00000000E+00
          42           37   0.00000000E+00
          42           38   0.00000000E+00
          42           39   0.00000000E+00
          42           40  -0.59474311E-06
          42           51   0.00000000E+00
          42           52  -0.22157848E-04
          42           53   0.00000000E+00
          42           54   0.00000000E+00
          42           55   0.00000000E+00
          42           56   0.00000000E+00
          42           57   0.00000000E+00
          42           58   0.00000000E+00
          42           59   0.00000000E+00
          42           60  -0.89266026E-06
          43           43   0.78082192E+03
          43           41   0.00000000E+00
          43           42   0.00000000E+00
          43           44   0.00000000E+00
          43           45   0.00000000E+00
          43           46   0.00000000E+00
          43           47   0.00000000E+00
          43           48   0.00000000E+00
          43           49   0.00000000E+00
          43           50   0.00000000E+00
          43           31   0.00000000E+00
          43           32   0.00000000E+00
          43           33  -0.18699636E-05
          43           34   0.00000000E+00
          43           35   0.00000000E+00
          43           36   0.00000000E+00
          43           37   0.00000000E+00
          43           38   0.00000000E+00
          43           39   0.00000000E+00
          43           40   0.00000000E+00
          43           51   0.00000000E+00
          43           52   0.00000000E+00
          43           53  -0.28066608E-05
          43           54   0.00000000E+00
          43           55   0.00000000E+00
          43           56   0.00000000E+00
          43           57   0.00000000E+00
          43           58   0.00000000E+00
          43           59   0.00000000E+00
          43           60   0.00000000E+00
          44           44   0.13409529E+04
          44           41   0.00000000E+00
          44           42   0.63443872E+01
          44           43   0.00000000E+00
          44           45   0.19035065E+02
          44           46   0.00000000E+00
          44           47  -0.65836821E+02
          44           48   0.00000000E+00
          44           49   0.00000000E+00
          44           50   0.00000000E+00
          44           31   0.00000000E+00
          44           32   0.00000000E+00
          44           33   0.00000000E+00
          44           34  -0.31658155E-05
          44           35   0.00000000E+00
          44           36   0.00000000E+00
          44           37   0.58143241E-08
          44           38   0.00000000E+00
          44           39   0.00000000E+00
          44           40   0.00000000E+00
          44           51   0.00000000E+00
          44           52   0.00000000E+00
          44           53   0.00000000E+00
          44           54  -0.47516275E-05
          44           55   0.00000000E+00
          44           56   0.00000000E+00
          44           57   0.87268201E-08
          44           58   0.00000000E+00
          44           59   0.00000000E+00
          44           60   0.00000000E+00
          45           45   0.19052837E+02
          45           41   0.00000000E+00
          45           42   0.63443872E+01
          45           43   0.00000000E+00
          45           44   0.19035065E+02
          45           46   0.00000000E+00
          45           47  -0.63477866E+02
          45           48   0.00000000E+00
          45           49   0.00000000E+00
          45           50   0.21795643E-05
          45           31   0.00000000E+00
          45           32   0.00000000E+00
          45           33   0.00000000E+00
          45           34   0.00000000E+00
          45           35  -0.42484262E-10
          45           36   0.00000000E+00
          45           37   0.16470994E-09
          45           38   0.00000000E+00
          45           39   0.00000000E+00
          45           40  -0.52197636E-14
          45           51   0.00000000E+00
          45           52   0.00000000E+00
          45           53   0.00000000E+00
          45           54   0.00000000E+00
          45           55  -0.63765367E-10
          45           56   0.00000000E+00
          45           57   0.24721601E-09
          45           58   0.00000000E+00
          45           59   0.00000000E+00
          45           60  -0.78344339E-14
          46           46   0.17074662E+04
          46           41   0.79884210E+02
          46           42   0.00000000E+00
          46           43   0.00000000E+00
          46           44   0.00000000E+00
          46           45   0.00000000E+00
          46           47   0.19543730E+04
          46           48   0.00000000E+00
          46           49   0.43198833E-04
          46           50   0.00000000E+00
          46           31  -0.19131143E-06
          46           32   0.00000000E+00
          46           33   0.00000000E+00
          46           34   0.00000000E+00
          46           35   0.00000000E+00
          46           36  -0.40891514E-05
          46           37  -0.46804606E-05
          46           38   0.00000000E+00
          46           39   0.00000000E+00
          46           40   0.00000000E+00
          46           51  -0.28714265E-06
          46           52   0.00000000E+00
          46           53   0.00000000E+00
          46           54   0.00000000E+00
          46           55   0.00000000E+00
          46           56  -0.61374783E-05
          46           57  -0.70249846E-05
          46           58   0.00000000E+00
          46           59   0.00000000E+00
          46           60   0.00000000E+00
          47           47   0.26723718E+04
          47           41   0.76117799E+02
          47           42  -0.21147957E+02
          47           43   0.00000000E+00
          47           44  -0.65878288E+02
          47           45  -0.63519108E+02
          47           46   0.19543478E+04
          47           48  -0.38887502E-04
          47           49  -0.12035985E+00
          47           50   0.49505150E-01
          47           31  -0.18229190E-06
          47           32   0.00000000E+00
          47           33   0.00000000E+00
          47           34   0.58149055E-08
          47           35   0.16475051E-09
          47           36  -0.46804003E-05
          47           37  -0.58937839E-05
          47           38   0.15713863E-13
          47           39   0.28826778E-09
          47           40  -0.11851393E-09
          47           51  -0.27360508E-06
          47           52   0.00000000E+00
          47           53   0.00000000E+00
          47           54   0.87276927E-08
          47           55   0.24727690E-09
          47           56  -0.70248941E-05
          47           57  -0.88460827E-05
          47           58   0.23585210E-13
          47           59   0.43266612E-09
          47           60  -0.17787962E-09
          48           48   0.66308262E-04
          48           41   0.00000000E+00
          48           42   0.00000000E+00
          48           43   0.00000000E+00
          48           44   0.00000000E+00
          48           45   0.00000000E+00
          48           46   0.00000000E+00
          48           47  -0.38896922E-04
          48           49  -0.14946245E-04
          48           50  -0.37051937E-04
          48           31   0.00000000E+00
          48           32   0.00000000E+00
          48           33   0.00000000E+00
          48           34   0.00000000E+00
          48           35   0.00000000E+00
          48           36   0.00000000E+00
          48           37   0.15715131E-13
          48           38  -0.23320538E-13
          48           39  -0.29226998E-14
          48           40   0.11296639E-13
          48           51   0.00000000E+00
          48           52   0.00000000E+00
          48           53   0.00000000E+00
          48           54   0.00000000E+00
          48           55   0.00000000E+00
          48           56   0.00000000E+00
          48           57   0.23587113E-13
          48           58  -0.35002201E-13
          48           59  -0.43867309E-14
          48           60   0.16955322E-13
          49           49   0.99356224E+02
          49           41   0.00000000E+00
          49           42   0.00000000E+00
          49           43   0.00000000E+00
          49           44   0.00000000E+00
          49           45   0.00000000E+00
          49           46   0.43198833E-04
          49           47  -0.12034781E+00
          49           48  -0.14942654E-04
          49           50   0.33536708E+02
          49           31   0.00000000E+00
          49           32   0.00000000E+00
          49           33   0.00000000E+00
          49           34   0.00000000E+00
          49           35   0.00000000E+00
          49           36   0.00000000E+00
          49           37   0.28823896E-09
          49           38  -0.29225902E-14
          49           39  -0.23794469E-06
          49           40  -0.80315886E-07
          49           51   0.00000000E+00
          49           52   0.00000000E+00
          49           53   0.00000000E+00
          49           54   0.00000000E+00
          49           55   0.00000000E+00
          49           56   0.00000000E+00
          49           57   0.43262286E-09
          49           58  -0.43865664E-14
          49           59  -0.35713531E-06
          49           60  -0.12054751E-06
          50           50   0.13484933E+05
          50           41   0.36307130E+04
          50           42   0.24834091E+03
          50           43   0.00000000E+00
          50           44   0.00000000E+00
          50           45   0.21795340E-05
          50           46   0.00000000E+00
          50           47   0.49505150E-01
          50           48  -0.37042339E-04
          50           49   0.33536708E+02
          50           31  -0.86950685E-05
          50           32  -0.59474311E-06
          50           33   0.00000000E+00
          50           34   0.00000000E+00
          50           35  -0.52196911E-14
          50           36   0.00000000E+00
          50           37  -0.11851393E-09
          50           38   0.11294945E-13
          50           39  -0.80315886E-07
          50           40  -0.32294600E-04
          50           51  -0.13050579E-04
          50           52  -0.89266026E-06
          50           53   0.00000000E+00
          50           54   0.00000000E+00
          50           55  -0.78343250E-14
          50           56   0.00000000E+00
          50           57  -0.17787962E-09
          50           58   0.16952779E-13
          50           59  -0.12054751E-06
          50           60  -0.48471527E-04
          51           51   0.97945219E+04
          51           52   0.00000000E+00
          51           53   0.00000000E+00
          51           54   0.00000000E+00
          51           55   0.00000000E+00
          51           56   0.79884210E+02
          51           57   0.76117799E+02
          51           58   0.00000000E+00
          51           59   0.00000000E+00
          51           60   0.36307130E+04
          51           41  -0.23456562E-04
          51           42   0.00000000E+00
          51           43   0.00000000E+00
          51           44   0.00000000E+00
          51           45   0.00000000E+00
          51           46  -0.19131143E-06
          51           47  -0.18229190E-06
          51           48   0.00000000E+00
          51           49   0.00000000E+00
          51           50  -0.86950685E-05
          51           61  -0.35206361E-04
          51           62   0.00000000E+00
          51           63   0.00000000E+00
          51           64   0.00000000E+00
          51           65   0.00000000E+00
          51           66  -0.28714265E-06
          51           67  -0.27360508E-06
          51           68   0.00000000E+00
          51           69   0.00000000E+00
          51           70  -0.13050579E-04
          52           52   0.61664984E+04
          52           51   0.00000000E+00
          52           53   0.00000000E+00
          52           54   0.63450217E+01
          52           55   0.63450217E+01
          52           56   0.00000000E+00
          52           57  -0.21136331E+02
          52           58   0.00000000E+00
          52           59   0.00000000E+00
          52           60   0.24834091E+03
          52           41   0.00000000E+00
          52           42  -0.14762870E-04
          52           43   0.00000000E+00
          52           44   0.00000000E+00
          52           45   0.00000000E+00
          52           46   0.00000000E+00
          52           47   0.00000000E+00
          52           48   0.00000000E+00
          52           49   0.00000000E+00
          52           50  -0.59474311E-06
          52           61   0.00000000E+00
          52           62  -0.22157848E-04
          52           63   0.00000000E+00
          52           64   0.00000000E+00
          52           65   0.00000000E+00
          52           66   0.00000000E+00
          52           67   0.00000000E+00
          52           68   0.00000000E+00
          52           69   0.00000000E+00
          52           70  -0.89266026E-06
          53           53   0.78082192E+03
          53           51   0.00000000E+00
          53           52   0.00000000E+00
          53           54   0.00000000E+00
          53           55   0.00000000E+00
          53           56   0.00000000E+00
          53           57   0.00000000E+00
          53           58   0.00000000E+00
          53           59   0.00000000E+00
          53           60   0.00000000E+00
          53           41   0.00000000E+00
          53           42   0.00000000E+00
          53           43  -0.18699636E-05
          53           44   0.00000000E+00
          53           45   0.00000000E+00
          53           46   0.00000000E+00
          53           47   0.00000000E+00
          53           48   0.00000000E+00
          53           49   0.00000000E+00
          53           50   0.00000000E+00
          53           61   0.00000000E+00
          53           62   0.00000000E+00
          53           63  -0.28066608E-05
          53           64   0.00000000E+00
          53           65   0.00000000E+00
          53           66   0.00000000E+00
          53           67   0.00000000E+00
          53           68   0.00000000E+00
          53           69   0.00000000E+00
          53           70   0.00000000E+00
          54           54   0.13409529E+04
          54           51   0.00000000E+00
          54           52   0.63443872E+01
          54           53   0.00000000E+00
          54           55   0.19035065E+02
          54           56   0.00000000E+00
          54           57  -0.65836821E+02
          54           58   0.00000000E+00
          54           59   0.00000000E+00
          54           60   0.00000000E+00
          54           41   0.00000000E+00
          54           42   0.00000000E+00
          54           43   0.00000000E+00
          54           44  -0.31658155E-05
          54           45   0.00000000E+00
          54           46   0.00000000E+00
          54           47   0.58143241E-08
          54           48   0.00000000E+00
          54           49   0.00000000E+00
          54           50   0.00000000E+00
          54           61   0.00000000E+00
          54           62   0.00000000E+00
          54           63   0.00000000E+00
          54           64  -0.47516275E-05
          54           65   0.00000000E+00
          54           66   0.00000000E+00
          54           67   0.87268201E-08
          54           68   0.00000000E+00
          54           69   0.00000000E+00
          54           70   0.00000000E+00
          55           55   0.19052837E+02
          55           51   0.00000000E+00
          55           52   0.63443872E+01
          55           53   0.00000000E+00
          55           54   0.19035065E+02
          55           56   0.00000000E+00
          55           57  -0.63477866E+02
          55           58   0.00000000E+00
          55           59   0.00000000E+00
          55           60   0.21795643E-05
          55           41   0.00000000E+00
          55           42   0.00000000E+00
          55           43   0.00000000E+00
          55           44   0.00000000E+00
          55           45  -0.42484262E-10
          55           46   0.00000000E+00
          55           47   0.16470994E-09
          55           48   0.00000000E+00
          55           49   0.00000000E+00
          55           50  -0.52197636E-14
          55           61   0.00000000E+00
          55           62   0.00000000E+00
          55           63   0.00000000E+00
          55           64   0.00000000E+00
          55           65  -0.63765367E-10
          55           66   0.00000000E+00
          55           67   0.24721601E-09
          55           68   0.00000000E+00
          55           69   0.00000000E+00
          55           70  -0.78344339E-14
          56           56   0.17074662E+04
          56           51   0.79884210E+02
          56           52   0.00000000E+00
          56           53   0.00000000E+00
          56           54   0.00000000E+00
          56           55   0.00000000E+00
          56           57   0.19543730E+04
          56           58   0.00000000E+00
          56           59   0.43198833E-04
          56           60   0.00000000E+00
          56           41  -0.19131143E-06
          56           42   0.00000000E+00
          56           43   0.00000000E+00
          56           44   0.00000000E+00
          56           45   0.00000000E+00
          56           46  -0.40891514E-05
          56           47  -0.46804606E-05
          56           48   0.00000000E+00
          56           49   0.00000000E+00
          56           50   0.00000000E+00
          56           61  -0.28714265E-06
          56           62   0.00000000E+00
          56           63   0.00000000E+00
          56           64   0.00000000E+00
          56           65   0.00000000E+00
          56           66  -0.61374783E-05
          56           67  -0.70249846E-05
          56           68   0.00000000E+00
          56           69   0.00000000E+00
          56           70   0.00000000E+00
          57           57   0.26723718E+04
          57           51   0.76117799E+02
          57           52  -0.21147957E+02
          57           53   0.00000000E+00
          57           54  -0.65878288E+02
          57           55  -0.63519108E+02
          57           56   0.19543478E+04
          57           58  -0.38887502E-04
          57           59  -0.12035985E+00
          57           60   0.49505150E-01
          57           41  -0.18229190E-06
          57           42   0.00000000E+00
          57           43   0.00000000E+00
          57           44   0.58149055E-08
          57           45   0.16475051E-09
          57           46  -0.46804003E-05
          57           47  -0.58937839E-05
          57           48   0.15713863E-13
          57           49   0.28826778E-09
          57           50  -0.11851393E-09
          57           61  -0.27360508E-06
          57           62   0.00000000E+00
          57           63   0.00000000E+00
          57           64   0.87276927E-08
          57           65   0.24727690E-09
          57           66  -0.70248941E-05
          57           67  -0.88460827E-05
          57           68   0.23585210E-13
          57           69   0.43266612E-09
          57           70  -0.17787962E-09
          58           58   0.66308262E-04
          58           51   0.00000000E+00
          58           52   0.00000000E+00
          58           53   0.00000000E+00
          58           54   0.00000000E+00
          58           55   0.00000000E+00
          58           56   0.00000000E+00
          58           57  -0.38896922E-04
          58           59  -0.14946245E-04
          58           60  -0.37051937E-04
          58           41   0.00000000E+00
          58           42   0.00000000E+00
          58           43   0.00000000E+00
          58           44   0.00000000E+00
          58           45   0.00000000E+00
          58           46   0.00000000E+00
          58           47   0.15715131E-13
          58           48  -0.23320538E-13
          58           49  -0.29226998E-14
          58           50   0.11296639E-13
          58           61   0.00000000E+00
          58           62   0.00000000E+00
          58           63   0.00000000E+00
          58           64   0.00000000E+00
          58           65   0.00000000E+00
          58           66   0.00000000E+00
          58           67   0.23587113E-13
          58           68  -0.35002201E-13
          58           69  -0.43867309E-14
          58           70   0.16955322E-13
          59           59   0.99356224E+02
          59           51   0.00000000E+00
          59           52   0.00000000E+00
          59           53   0.00000000E+00
          59           54   0.00000000E+00
          59           55   0.00000000E+00
          59           56   0.43198833E-04
          59           57  -0.12034781E+00
          59           58  -0.14942654E-04
          59           60   0.33536708E+02
          59           41   0.00000000E+00
          59           42   0.00000000E+00
          59           43   0.00000000E+00
          59           44   0.00000000E+00
          59           45   0.00000000E+00
          59           46   0.00000000E+00
          59           47   0.28823896E-09
          59           48  -0.29225902E-14
          59           49  -0.23794469E-06
          59           50  -0.80315886E-07
          59           61   0.00000000E+00
          59           62   0.00000000E+00
          59           63   0.00000000E+00
          59           64   0.00000000E+00
          59           65   0.00000000E+00
          59           66   0.00000000E+00
          59           67   0.43262286E-09
          59           68  -0.43865664E-14
          59           69  -0.35713531E-06
          59           70  -0.12054751E-06
          60           60   0.13484933E+05
          60           51   0.36307130E+04
          60           52   0.24834091E+03
          60           53   0.00000000E+00
          60           54   0.00000000E+00
          60           55   0.21795340E-05
          60           56   0.00000000E+00
          60           57   0.49505150E-01
          60           58  -0.37042339E-04
          60           59   0.33536708E+02
          60           41  -0.86950685E-05
          60           42  -0.59474311E-06
          60           43   0.00000000E+00
          60           44   0.00000000E+00
          60           45  -0.52196911E-14
          60           46   0.00000000E+00
          60           47  -0.11851393E-09
          60           48   0.11294945E-13
          60           49  -0.80315886E-07
          60           50  -0.32294600E-04
          60           61  -0.13050579E-04
          60           62  -0.89266026E-06
          60           63   0.00000000E+00
          60           64   0.00000000E+00
          60           65  -0.78343250E-14
          60           66   0.00000000E+00
          60           67  -0.17787962E-09
          60           68   0.16952779E-13
          60           69  -0.12054751E-06
          60           70  -0.48471527E-04
          61           61   0.97945219E+04
          61           62   0.00000000E+00
          61           63   0.00000000E+00
          61           64   0.00000000E+00
          61           65   0.00000000E+00
          61           66   0.79884210E+02
          61           67   0.76117799E+02
          61           68   0.00000000E+00
          61           69   0.00000000E+00
          61           70   0.36307130E+04
          61           51  -0.23456562E-04
          61           52   0.00000000E+00
          61           53   0.00000000E+00
          61           54   0.00000000E+00
          61           55   0.00000000E+00
          61           56  -0.19131143E-06
          61           57  -0.18229190E-06
          61           58   0.00000000E+00
          61           59   0.00000000E+00
          61           60  -0.86950685E-05
          61           71  -0.35206361E-04
          61           72   0.00000000E+00
          61           73   0.00000000E+00
          61           74   0.00000000E+00
          61           75   0.00000000E+00
          61           76  -0.28714265E-06
          61           77  -0.27360508E-06
          61           78   0.00000000E+00
          61           79   0.00000000E+00
          61           80  -0.13050579E-04
          62           62   0.61664984E+04
          62           61   0.00000000E+00
          62           63   0.00000000E+00
          62           64   0.63450217E+01
          62           65   0.63450217E+01
          62           66   0.00000000E+00
          62           67  -0.21136331E+02
          62           68   0.00000000E+00
          62           69   0.00000000E+00
          62           70   0.24834091E+03
          62           51   0.00000000E+00
          62           52  -0.14762870E-04
          62           53   0.00000000E+00
          62           54   0.00000000E+00
          62           55   0.00000000E+00
          62           56   0.00000000E+00
          62           57   0.00000000E+00
          62           58   0.00000000E+00
          62           59   0.00000000E+00
          62           60  -0.59474311E-06
          62           71   0.00000000E+00
          62           72  -0.22157848E-04
          62           73   0.00000000E+00
          62           74   0.00000000E+00
          62           75   0.00000000E+00
          62           76   0.00000000E+00
          62           77   0.00000000E+00
          62           78   0.00000000E+00
          62           79   0.00000000E+00
          62           80  -0.89266026E-06
          63           63   0.78082192E+03
          63           61   0.00000000E+00
          63           62   0.00000000E+00
          63           64   0.00000000E+00
          63           65   0.00000000E+00
          63           66   0.00000000E+00
          63           67   0.00000000E+00
          63           68   0.00000000E+00
          63           69   0.00000000E+00
          63           70   0.00000000E+00
          63           51   0.00000000E+00
          63           52   0.00000000E+00
          63           53  -0.18699636E-05
          63           54   0.00000000E+00
          63           55   0.00000000E+00
          63           56   0.00000000E+00
          63           57   0.00000000E+00
          63           58   0.00000000E+00
          63           59   0.00000000E+00
          63           60   0.00000000E+00
          63           71   0.00000000E+00
          63           72   0.00000000E+00
          63           73  -0.28066608E-05
          63           74   0.00000000E+00
          63           75   0.00000000E+00
          63           76   0.00000000E+00
          63           77   0.00000000E+00
          63           78   0.00000000E+00
          63           79   0.00000000E+00
          63           80   0.00000000E+00
          64           64   0.13409529E+04
          64           61   0.00000000E+00
          64           62   0.63443872E+01
          64           63   0.00000000E+00
          64           65   0.19035065E+02
          64           66   0.00000000E+00
          64           67  -0.65836821E+02
          64           68   0.00000000E+00
          64           69   0.00000000E+00
          64           70   0.00000000E+00
          64           51   0.00000000E+00
          64           52   0.00000000E+00
          64           53   0.00000000E+00
          64           54  -0.31658155E-05
          64           55   0.00000000E+00
          64           56   0.00000000E+00
          64           57   0.58143241E-08
          64           58   0.00000000E+00
          64           59   0.00000000E+00
          64           60   0.00000000E+00
          64           71   0.00000000E+00
          64           72   0.00000000E+00
          64           73   0.00000000E+00
          64           74  -0.47516275E-05
          64           75   0.00000000E+00
          64           76   0.00000000E+00
          64           77   0.87268201E-08
          64           78   0.00000000E+00
          64           79   0.00000000E+00
          64           80   0.00000000E+00
          65           65   0.19052837E+02
          65           61   0.00000000E+00
          65           62   0.63443872E+01
          65           63   0.00000000E+00
          65           64   0.19035065E+02
          65           66   0.00000000E+00
          65           67  -0.63477866E+02
          65           68   0.00000000E+00
          65           69   0.00000000E+00
          65           70   0.21795643E-05
          65           51   0.00000000E+00
          65           52   0.00000000E+00
          65           53   0.00000000E+00
          65           54   0.00000000E+00
          65           55  -0.42484262E-10
          65           56   0.00000000E+00
          65           57   0.16470994E-09
          65           58   0.00000000E+00
          65           59   0.00000000E+00
          65           60  -0.52197636E-14
          65           71   0.00000000E+00
          65           72   0.00000000E+00
          65           73   0.00000000E+00
          65           74   0.00000000E+00
          65           75  -0.63765367E-10
          65           76   0.00000000E+00
          65           77   0.24721601E-09
          65           78   0.00000000E+00
          65           79   0.00000000E+00
          65           80  -0.78344339E-14
          66           66   0.17074662E+04
          66           61   0.79884210E+02
          66           62   0.00000000E+00
          66           63   0.00000000E+00
          66           64   0.00000000E+00
          66           65   0.00000000E+00
          66           67   0.19543730E+04
          66           68   0.00000000E+00
          66           69   0.43198833E-04
          66           70   0.00000000E+00
          66           51  -0.19131143E-06
          66           52   0.00000000E+00
          66           53   0.00000000E+00
          66           54   0.00000000E+00
          66           55   0.00000000E+00
          66           56  -0.40891514E-05
          66           57  -0.46804606E-05
          66           58   0.00000000E+00
          66           59   0.00000000E+00
          66           60   0.00000000E+00
          66           71  -0.28714265E-06
          66           72   0.00000000E+00
          66           73   0.00000000E+00
          66           74   0.00000000E+00
          66           75   0.00000000E+00
          66           76  -0.61374783E-05
          66           77  -0.70249846E-05
          66           78   0.00000000E+00
          66           79   0.00000000E+00
          66           80   0.00000000E+00
          67           67   0.26723718E+04
          67           61   0.76117799E+02
          67           62  -0.21147957E+02
          67           63   0.00000000E+00
          67           64  -0.65878288E+02
          67           65  -0.63519108E+02
          67           66   0.19543478E+04
          67           68  -0.38887502E-04
          67           69  -0.12035985E+00
          67           70   0.49505150E-01
          67           51  -0.18229190E-06
          67           52   0.00000000E+00
          67           53   0.00000000E+00
          67           54   0.58149055E-08
          67           55   0.16475051E-09
          67           56  -0.46804003E-05
          67           57  -0.58937839E-05
          67           58   0.15713863E-13
          67           59   0.28826778E-09
          67           60  -0.11851393E-09
          67           71  -0.27360508E-06
          67           72   0.00000000E+00
          67           73   0.00000000E+00
          67           74   0.87276927E-08
          67           75   0.24727690E-09
          67           76  -0.70248941E-05
          67           77  -0.88460827E-05
          67           78   0.23585210E-13
          67           79   0.43266612E-09
          67           80  -0.17787962E-09
          68           68   0.66308262E-04
          68           61   0.00000000E+00
          68           62   0.00000000E+00
          68           63   0.00000000E+00
          68           64   0.00000000E+00
          68           65   0.00000000E+00
          68           66   0.00000000E+00
          68           67  -0.38896922E-04
          68           69  -0.14946245E-04
          68           70  -0.37051937E-04
          68           51   0.00000000E+00
          68           52   0.00000000E+00
          68           53   0.00000000E+00
          68           54   0.00000000E+00
          68           55   0.00000000E+00
          68           56   0.00000000E+00
          68           57   0.15715131E-13
          68           58  -0.23320538E-13
          68           59  -0.29226998E-14
          68           60   0.11296639E-13
          68           71   0.00000000E+00
          68           72   0.00000000E+00
          68           73   0.00000000E+00
          68           74   0.00000000E+00
          68           75   0.00000000E+00
          68           76   0.00000000E+00
          68           77   0.23587113E-13
          68           78  -0.35002201E-13
          68           79  -0.43867309E-14
          68           80   0.16955322E-13
          69           69   0.99356224E+02
          69           61   0.00000000E+00
          69           62   0.00000000E+00
          69           63   0.00000000E+00
          69           64   0.00000000E+00
          69           65   0.00000000E+00
          69           66   0.43198833E-04
          69           67  -0.12034781E+00
          69           68  -0.14942654E-04
          69           70   0.33536708E+02
          69           51   0.00000000E+00
          69           52   0.00000000E+00
          69           53   0.00000000E+00
          69           54   0.00000000E+00
          69           55   0.00000000E+00
          69           56   0.00000000E+00
          69           57   0.28823896E-09
          69           58  -0.29225902E-14
          69           59  -0.23794469E-06
          69           60  -0.80315886E-07
          69           71   0.00000000E+00
          69           72   0.00000000E+00
          69           73   0.00000000E+00
          69           74   0.00000000E+00
          69           75   0.00000000E+00
          69           76   0.00000000E+00
          69           77   0.43262286E-09
          69           78  -0.43865664E-14
          69           79  -0.35713531E-06
          69           80  -0.12054751E-06
          70           70   0.13484933E+05
          70           61   0.36307130E+04
          70           62   0.24834091E+03
          70           63   0.00000000E+00
          70           64   0.00000000E+00
          70           65   0.21795340E-05
          70           66   0.00000000E+00
          70           67   0.49505150E-01
          70           68  -0.37042339E-04
          70           69   0.33536708E+02
          70           51  -0.86950685E-05
          70           52  -0.59474311E-06
          70           53   0.00000000E+00
          70           54   0.00000000E+00
          70           55  -0.52196911E-14
          70           56   0.00000000E+00
          70           57  -0.11851393E-09
          70           58   0.11294945E-13
          70           59  -0.80315886E-07
          70           60  -0.32294600E-04
          70           71  -0.13050579E-04
          70           72  -0.89266026E-06
          70           73   0.00000000E+00
          70           74   0.00000000E+00
          70           75  -0.78343250E-14
          70           76   0.00000000E+00
          70           77  -0.17787962E-09
          70           78   0.16952779E-13
          70           79  -0.12054751E-06
          70           80  -0.48471527E-04
          71           71   0.97945219E+04
          71           72   0.00000000E+00
          71           73   0.00000000E+00
          71           74   0.00000000E+00
          71           75   0.00000000E+00
          71           76   0.79884210E+02
          71           77   0.76117799E+02
          71           78   0.00000000E+00
          71           79   0.00000000E+00
          71           80   0.36307130E+04
          71           61  -0.23456562E-04
          71           62   0.00000000E+00
          71           63   0.00000000E+00
          71           64   0.00000000E+00
          71           65   0.00000000E+00
          71           66  -0.19131143E-06
          71           67  -0.18229190E-06
          71           68   0.00000000E+00
          71           69   0.00000000E+00
          71           70  -0.86950685E-05
          71           81  -0.35206361E-04
          71           82   0.00000000E+00
          71           83   0.00000000E+00
          71           84   0.00000000E+00
          71           85   0.00000000E+00
          71           86  -0.28714265E-06
          71           87  -0.27360508E-06
          71           88   0.00000000E+00
          71           89   0.00000000E+00
          71           90  -0.13050579E-04
          72           72   0.61664984E+04
          72           71   0.00000000E+00
          72           73   0.00000000E+00
          72           74   0.63450217E+01
          72           75   0.63450217E+01
          72           76   0.00000000E+00
          72           77  -0.21136331E+02
          72           78   0.00000000E+00
          72           79   0.00000000E+00
          72           80   0.24834091E+03
          72           61   0.00000000E+00
          72           62  -0.14762870E-04
          72           63   0.00000000E+00
          72           64   0.00000000E+00
          72           65   0.00000000E+00
          72           66   0.00000000E+00
          72           67   0.00000000E+00
          72           68   0.00000000E+00
          72           69   0.00000000E+00
          72           70  -0.59474311E-06
          72           81   0.00000000E+00
          72           82  -0.22157848E-04
          72           83   0.00000000E+00
          72           84   0.00000000E+00
          72           85   0.00000000E+00
          72           86   0.00000000E+00
          72           87   0.00000000E+00
          72           88   0.00000000E+00
          72           89   0.00000000E+00
          72           90  -0.89266026E-06
          73           73   0.78082192E+03
          73           71   0.00000000E+00
          73           72   0.00000000E+00
          73           74   0.00000000E+00
          73           75   0.00000000E+00
          73           76   0.00000000E+00
          73           77   0.00000000E+00
          73           78   0.00000000E+00
          73           79   0.00000000E+00
          73           80   0.00000000E+00
          73           61   0.00000000E+00
          73           62   0.00000000E+00
          73           63  -0.18699636E-05
          73           64   0.00000000E+00
          73           65   0.00000000E+00
          73           66   0.00000000E+00
          73           67   0.00000000E+00
          73           68   0.00000000E+00
          73           69   0.00000000E+00
          73           70   0.00000000E+00
          73           81   0.00000000E+00
          73           82   0.00000000E+00
          73           83  -0.28066608E-05
          73           84   0.00000000E+00
          73           85   0.00000000E+00
          73           86   0.00000000E+00
          73           87   0.00000000E+00
          73           88   0.00000000E+00
          73           89   0.00000000E+00
          73           90   0.00000000E+00
          74           74   0.13409529E+04
          74           71   0.00000000E+00
          74           72   0.63443872E+01
          74           73   0.00000000E+00
          74           75   0.19035065E+02
          74           76   0.00000000E+00
          74           77  -0.65836821E+02
          74           78   0.00000000E+00
          74           79   0.00000000E+00
          74           80   0.00000000E+00
          74           61   0.00000000E+00
          74           62   0.00000000E+00
          74           63   0.00000000E+00
          74           64  -0.31658155E-05
          74           65   0.00000000E+00
          74           66   0.00000000E+00
          74           67   0.58143241E-08
          74           68   0.00000000E+00
          74           69   0.00000000E+00
          74           70   0.00000000E+00
          74           81   0.00000000E+00
          74           82   0.00000000E+00
          74           83   0.00000000E+00
          74           84  -0.47516275E-05
          74           85   0.00000000E+00
          74           86   0.00000000E+00
          74           87   0.87268201E-08
          74           88   0.00000000E+00
          74           89   0.00000000E+00
          74           90   0.00000000E+00
          75           75   0.19052837E+02
          75           71   0.00000000E+00
          75           72   0.63443872E+01
          75           73   0.00000000E+00
          75           74   0.19035065E+02
          75           76   0.00000000E+00
          75           77  -0.63477866E+02
          75           78   0.00000000E+00
          75           79   0.00000000E+00
          75           80   0.21795643E-05
          75           61   0.00000000E+00
          75           62   0.00000000E+00
          75           63   0.00000000E+00
          75           64   0.00000000E+00
          75           65  -0.42484262E-10
          75           66   0.00000000E+00
          75           67   0.16470994E-09
          75           68   0.00000000E+00
          75           69   0.00000000E+00
          75           70  -0.52197636E-14
          75           81   0.00000000E+00
          75           82   0.00000000E+00
          75           83   0.00000000E+00
          75           84   0.00000000E+00
          75           85  -0.63765367E-10
          75           86   0.00000000E+00
          75           87   0.24721601E-09
          75           88   0.00000000E+00
          75           89   0.00000000E+00
          75           90  -0.78344339E-14
          76           76   0.17074662E+04
          76           71   0.79884210E+02
          76           72   0.00000000E+00
          76           73   0.00000000E+00
          76           74   0.00000000E+00
          76           75   0.00000000E+00
          76           77   0.19543730E+04
          76           78   0.00000000E+00
          76           79   0.43198833E-04
          76           80   0.00000000E+00
          76           61  -0.19131143E-06
          76           62   0.00000000E+00
          76           63   0.00000000E+00
          76           64   0.00000000E+00
          76           65   0.00000000E+00
          76           66  -0.40891514E-05
          76           67  -0.46804606E-05
          76           68   0.00000000E+00
          76           69   0.00000000E+00
          76           70   0.00000000E+00
          76           81  -0.28714265E-06
          76           82   0.00000000E+00
          76           83   0.00000000E+00
          76           84   0.00000000E+00
          76           85   0.00000000E+00
          76           86  -0.61374783E-05
          76           87  -0.70249846E-05
          76           88   0.00000000E+00
          76           89   0.00000000E+00
          76           90   0.00000000E+00
          77           77   0.26723718E+04
          77           71   0.76117799E+02
          77           72  -0.21147957E+02
          77           73   0.00000000E+00
          77           74  -0.65878288E+02
          77           75  -0.63519108E+02
          77           76   0.19543478E+04
          77           78  -0.38887502E-04
          77           79  -0.12035985E+00
          77           80   0.49505150E-01
          77           61  -0.18229190E-06
          77           62   0.00000000E+00
          77           63   0.00000000E+00
          77           64   0.58149055E-08
          77           65   0.16475051E-09
          77           66  -0.46804003E-05
          77           67  -0.58937839E-05
          77           68   0.15713863E-13
          77           69   0.28826778E-09
          77           70  -0.11851393E-09
          77           81  -0.27360508E-06
          77           82   0.00000000E+00
          77           83   0.00000000E+00
          77           84   0.87276927E-08
          77           85   0.24727690E-09
          77           86  -0.70248941E-05
          77           87  -0.88460827E-05
          77           88   0.23585210E-13
          77           89   0.43266612E-09
          77           90  -0.17787962E-09
          78           78   0.66308262E-04
          78           71   0.00000000E+00
          78           72   0.00000000E+00
          78           73   0.00000000E+00
          78           74   0.00000000E+00
          78           75   0.00000000E+00
          78           76   0.00000000E+00
          78           77  -0.38896922E-04
          78           79  -0.14946245E-04
          78           80  -0.37051937E-04
          78           61   0.00000000E+00
          78           62   0.00000000E+00
          78           63   0.00000000E+00
          78           64   0.00000000E+00
          78           65   0.00000000E+00
          78           66   0.00000000E+00
          78           67   0.15715131E-13
          78           68  -0.23320538E-13
          78           69  -0.29226998E-14
          78           70   0.11296639E-13
          78           81   0.00000000E+00
          78           82   0.00000000E+00
          78           83   0.00000000E+00
          78           84   0.00000000E+00
          78           85   0.00000000E+00
          78           86   0.00000000E+00
          78           87   0.23587113E-13
          78           88  -0.35002201E-13
          78           89  -0.43867309E-14
          78           90   0.16955322E-13
          79           79   0.99356224E+02
          79           71   0.00000000E+00
          79           72   0.00000000E+00
          79           73   0.00000000E+00
          79           74   0.00000000E+00
          79           75   0.00000000E+00
          79           76   0.43198833E-04
          79           77  -0.12034781E+00
          79           78  -0.14942654E-04
          79           80   0.33536708E+02
          79           61   0.00000000E+00
          79           62   0.00000000E+00
          79           63   0.00000000E+00
          79           64   0.00000000E+00
          79           65   0.00000000E+00
          79           66   0.00000000E+00
          79           67   0.28823896E-09
          79           68  -0.29225902E-14
          79           69  -0.23794469E-06
          79           70  -0.80315886E-07
          79           81   0.00000000E+00
          79           82   0.00000000E+00
          79           83   0.00000000E+00
          79           84   0.00000000E+00
          79           85   0.00000000E+00
          79           86   0.00000000E+00
          79           87   0.43262286E-09
          79           88  -0.43865664E-14
          79           89  -0.35713531E-06
          79           90  -0.12054751E-06
          80           80   0.13484933E+05
          80           71   0.36307130E+04
          80           72   0.24834091E+03
          80           73   0.00000000E+00
          80           74   0.00000000E+00
          80           75   0.21795340E-05
          80           76   0.00000000E+00
          80           77   0.49505150E-01
          80           78  -0.37042339E-04
          80           79   0.33536708E+02
          80           61  -0.86950685E-05
          80           62  -0.59474311E-06
          80           63   0.00000000E+00
          80           64   0.00000000E+00
          80           65  -0.52196911E-14
          80           66   0.00000000E+00
          80           67  -0.11851393E-09
          80           68   0.11294945E-13
          80           69  -0.80315886E-07
          80           70  -0.32294600E-04
          80           81  -0.13050579E-04
          80           82  -0.89266026E-06
          80           83   0.00000000E+00
          80           84   0.00000000E+00
          80           85  -0.78343250E-14
          80           86   0.00000000E+00
          80           87  -0.17787962E-09
          80           88   0.16952779E-13
          80           89  -0.12054751E-06
          80           90  -0.48471527E-04
          81           81   0.97945219E+04
          81           82   0.00000000E+00
          81           83   0.00000000E+00
          81           84   0.00000000E+00
          81           85   0.00000000E+00
          81           86   0.79884210E+02
          81           87   0.76117799E+02
          81           88   0.00000000E+00
          81           89   0.00000000E+00
          81           90   0.36307130E+04
          81           71  -0.23456562E-04
          81           72   0.00000000E+00
          81           73   0.00000000E+00
          81           74   0.00000000E+00
          81           75   0.00000000E+00
          81           76  -0.19131143E-06
          81           77  -0.18229190E-06
          81           78   0.00000000E+00
          81           79   0.00000000E+00
          81           80  -0.86950685E-05
          81           91  -0.35206361E-04
          81           92   0.00000000E+00
          81           93   0.00000000E+00
          81           94   0.00000000E+00
          81           95   0.00000000E+00
          81           96  -0.28714265E-06
          81           97  -0.27360508E-06
          81           98   0.00000000E+00
          81           99   0.00000000E+00
          81          100  -0.13050579E-04
          82           82   0.61664984E+04
          82           81   0.00000000E+00
          82           83   0.00000000E+00
          82           84   0.63450217E+01
          82           85   0.63450217E+01
          82           86   0.00000000E+00
          82           87  -0.21136331E+02
          82           88   0.00000000E+00
          82           89   0.00000000E+00
          82           90   0.24834091E+03
          82           71   0.00000000E+00
          82           72  -0.14762870E-04
          82           73   0.00000000E+00
          82           74   0.00000000E+00
          82           75   0.00000000E+00
          82           76   0.00000000E+00
          82           77   0.00000000E+00
          82           78   0.00000000E+00
          82           79   0.00000000E+00
          82           80  -0.59474311E-06
          82           91   0.00000000E+00
          82           92  -0.22157848E-04
          82           93   0.00000000E+00
          82           94   0.00000000E+00
          82           95   0.00000000E+00
          82           96   0.00000000E+00
          82           97   0.00000000E+00
          82           98   0.00000000E+00
          82           99   0.00000000E+00
          82          100  -0.89266026E-06
          83           83   0.78082192E+03
          83           81   0.00000000E+00
          83           82   0.00000000E+00
          83           84   0.00000000E+00
          83           85   0.00000000E+00
          83           86   0.00000000E+00
          83           87   0.00000000E+00
          83           88   0.00000000E+00
          83           89   0.00000000E+00
          83           90   0.00000000E+00
          83           71   0.00000000E+00
          83           72   0.00000000E+00
          83           73  -0.18699636E-05
          83           74   0.00000000E+00
          83           75   0.00000000E+00
          83           76   0.00000000E+00
          83           77   0.00000000E+00
          83           78   0.00000000E+00
          83           79   0.00000000E+00
          83           80   0.00000000E+00
          83           91   0.00000000E+00
          83           92   0.00000000E+00
          83           93  -0.28066608E-05
          83           94   0.00000000E+00
          83           95   0.00000000E+00
          83           96   0.00000000E+00
          83           97   0.00000000E+00
          83           98   0.00000000E+00
          83           99   0.00000000E+00
          83          100   0.00000000E+00
          84           84   0.13409529E+04
          84           81   0.00000000E+00
          84           82   0.63443872E+01
          84           83   0.00000000E+00
          84           85   0.19035065E+02
          84           86   0.00000000E+00
          84           87  -0.65836821E+02
          84           88   0.00000000E+00
          84           89   0.00000000E+00
          84           90   0.00000000E+00
          84           71   0.00000000E+00
          84           72   0.00000000E+00
          84           73   0.00000000E+00
          84           74  -0.31658155E-05
          84           75   0.00000000E+00
          84           76   0.00000000E+00
          84           77   0.58143241E-08
          84           78   0.00000000E+00
          84           79   0.00000000E+00
          84           80   0.00000000E+00
          84           91   0.00000000E+00
          84           92   0.00000000E+00
          84           93   0.00000000E+00
          84           94  -0.47516275E-05
          84           95   0.00000000E+00
          84           96   0.00000000E+00
          84           97   0.87268201E-08
          84           98   0.00000000E+00
          84           99   0.00000000E+00
          84          100   0.00000000E+00
          85           85   0.19052837E+02
          85           81   0.00000000E+00
          85           82   0.63443872E+01
          85           83   0.00000000E+00
          85           84   0.19035065E+02
          85           86   0.00000000E+00
          85           87  -0.63477866E+02
          85           88   0.00000000E+00
          85           89   0.00000000E+00
          85           90   0.21795643E-05
          85           71   0.00000000E+00
          85           72   0.00000000E+00
          85           73   0.00000000E+00
          85           74   0.00000000E+00
          85           75  -0.42484262E-10
          85           76   0.00000000E+00
          85           77   0.16470994E-09
          85           78   0.00000000E+00
          85           79   0.00000000E+00
          85           80  -0.52197636E-14
          85           91   0.00000000E+00
          85           92   0.00000000E+00
          85           93   0.00000000E+00
          85           94   0.00000000E+00
          85           95  -0.63765367E-10
          85           96   0.00000000E+00
          85           97   0.24721601E-09
          85           98   0.00000000E+00
          85           99   0.00000000E+00
          85          100  -0.78344339E-14
          86           86   0.17074662E+04
          86           81   0.79884210E+02
          86           82   0.00000000E+00
          86           83   0.00000000E+00
          86           84   0.00000000E+00
          86           85   0.00000000E+00
          86           87   0.19543730E+04
          86           88   0.00000000E+00
          86           89   0.43198833E-04
          86           90   0.00000000E+00
          86           71  -0.19131143E-06
          86           72   0.00000000E+00
          86           73   0.00000000E+00
          86           74   0.00000000E+00
          86           75   0.00000000E+00
          86           76  -0.40891514E-05
          86           77  -0.46804606E-05
          86           78   0.00000000E+00
          86           79   0.00000000E+00
          86           80   0.00000000E+00
          86           91  -0.28714265E-06
          86           92   0.00000000E+00
          86           93   0.00000000E+00
          86           94   0.00000000E+00
          86           95   0.00000000E+00
          86           96  -0.61374783E-05
          86           97  -0.70249846E-05
          86           98   0.00000000E+00
          86           99   0.00000000E+00
          86          100   0.00000000E+00
          87           87   0.26723718E+04
          87           81   0.76117799E+02
          87           82  -0.21147957E+02
          87           83   0.00000000E+00
          87           84  -0.65878288E+02
          87           85  -0.63519108E+02
          87           86   0.19543478E+04
          87           88  -0.38887502E-04
          87           89  -0.12035985E+00
          87           90   0.49505150E-01
          87           71  -0.18229190E-06
          87           72   0.00000000E+00
          87           73   0.00000000E+00
          87           74   0.58149055E-08
          87           75   0.16475051E-09
          87           76  -0.46804003E-05
          87           77  -0.58937839E-05
          87           78   0.15713863E-13
          87           79   0.28826778E-09
          87           80  -0.11851393E-09
          87           91  -0.27360508E-06
          87           92   0.00000000E+00
          87           93   0.00000000E+00
          87           94   0.87276927E-08
          87           95   0.24727690E-09
          87           96  -0.70248941E-05
          87           97  -0.88460827E-05
          87           98   0.23585210E-13
          87           99   0.43266612E-09
          87          100  -0.17787962E-09
          88           88   0.66308262E-04
          88           81   0.00000000E+00
          88           82   0.00000000E+00
          88           83   0.00000000E+00
          88           84   0.00000000E+00
          88           85   0.00000000E+00
          88           86   0.00000000E+00
          88           87  -0.38896922E-04
          88           89  -0.14946245E-04
          88           90  -0.37051937E-04
          88           71   0.00000000E+00
          88           72   0.00000000E+00
          88           73   0.00000000E+00
          88           74   0.00000000E+00
          88           75   0.00000000E+00
          88           76   0.00000000E+00
          88           77   0.15715131E-13
          88           78  -0.23320538E-13
          88           79  -0.29226998E-14
          88           80   0.11296639E-13
          88           91   0.00000000E+00
          88           92   0.00000000E+00
          88           93   0.00000000E+00
          88           94   0.00000000E+00
          88           95   0.00000000E+00
          88           96   0.00000000E+00
          88           97   0.23587113E-13
          88           98  -0.35002201E-13
          88           99  -0.43867309E-14
          88          100   0.16955322E-13
          89           89   0.99356224E+02
          89           81   0.00000000E+00
          89           82   0.00000000E+00
          89           83   0.00000000E+00
          89           84   0.00000000E+00
          89           85   0.00000000E+00
          89           86   0.43198833E-04
          89           87  -0.12034781E+00
          89           88  -0.14942654E-04
          89           90   0.33536708E+02
          89           71   0.00000000E+00
          89           72   0.00000000E+00
          89           73   0.00000000E+00
          89           74   0.00000000E+00
          89           75   0.00000000E+00
          89           76   0.00000000E+00
          89           77   0.28823896E-09
          89           78  -0.29225902E-14
          89           79  -0.23794469E-06
          89           80  -0.80315886E-07
          89           91   0.00000000E+00
          89           92   0.00000000E+00
          89           93   0.00000000E+00
          89           94   0.00000000E+00
          89           95   0.00000000E+00
          89           96   0.00000000E+00
          89           97   0.43262286E-09
          89           98  -0.43865664E-14
          89           99  -0.35713531E-06
          89          100  -0.12054751E-06
          90           90   0.13484933E+05
          90           81   0.36307130E+04
          90           82   0.24834091E+03
          90           83   0.00000000E+00
          90           84   0.00000000E+00
          90           85   0.21795340E-05
          90           86   0.00000000E+00
          90           87   0.49505150E-01
          90           88  -0.37042339E-04
          90           89   0.33536708E+02
          90           71  -0.86950685E-05
          90           72  -0.59474311E-06
          90           73   0.00000000E+00
          90           74   0.00000000E+00
          90           75  -0.52196911E-14
          90           76   0.00000000E+00
          90           77  -0.11851393E-09
          90           78   0.11294945E-13
          90           79  -0.80315886E-07
          90           80  -0.32294600E-04
          90           91  -0.13050579E-04
          90           92  -0.89266026E-06
          90           93   0.00000000E+00
          90           94   0.00000000E+00
          90           95  -0.78343250E-14
          90           96   0.00000000E+00
          90           97  -0.17787962E-09
          90           98   0.16952779E-13
          90           99  -0.12054751E-06
          90          100  -0.48471527E-04
          91           91   0.97945219E+04
          91           92   0.00000000E+00
          91           93   0.00000000E+00
          91           94   0.00000000E+00
          91           95   0.00000000E+00
          91           96   0.79884210E+02
          91           97   0.76117799E+02
          91           98   0.00000000E+00
          91           99   0.00000000E+00
          91          100   0.36307130E+04
          91           81  -0.23456562E-04
          91           82   0.00000000E+00
          91           83   0.00000000E+00
          91           84   0.00000000E+00
          91           85   0.00000000E+00
          91           86  -0.19131143E-06
          91           87  -0.18229190E-06
          91           88   0.00000000E+00
          91           89   0.00000000E+00
          91           90  -0.86950685E-05
          91          101  -0.35206361E-04
          91          102   0.00000000E+00
          91          103   0.00000000E+00
          91          104   0.00000000E+00
          91          105   0.00000000E+00
          91          106  -0.28714265E-06
          91          107  -0.27360508E-06
          91          108   0.00000000E+00
          91          109   0.00000000E+00
          91          110  -0.13050579E-04
          92           92   0.61664984E+04
          92           91   0.00000000E+00
          92           93   0.00000000E+00
          92           94   0.63450217E+01
          92           95   0.63450217E+01
          92           96   0.00000000E+00
          92           97  -0.21136331E+02
          92           98   0.00000000E+00
          92           99   0.00000000E+00
          92          100   0.24834091E+03
          92           81   0.00000000E+00
          92           82  -0.14762870E-04
          92           83   0.00000000E+00
          92           84   0.00000000E+00
          92           85   0.00000000E+00
          92           86   0.00000000E+00
          92           87   0.00000000E+00
          92           88   0.00000000E+00
          92           89   0.00000000E+00
          92           90  -0.59474311E-06
          92          101   0.00000000E+00
          92          102  -0.22157848E-04
          92          103   0.00000000E+00
          92          104   0.00000000E+00
          92          105   0.00000000E+00
          92          106   0.00000000E+00
          92          107   0.00000000E+00
          92          108   0.00000000E+00
          92          109   0.00000000E+00
          92          110  -0.89266026E-06
          93           93   0.78082192E+03
          93           91   0.00000000E+00
          93           92   0.00000000E+00
          93           94   0.00000000E+00
          93           95   0.00000000E+00
          93           96   0.00000000E+00
          93           97   0.00000000E+00
          93           98   0.00000000E+00
          93           99   0.00000000E+00
          93          100   0.00000000E+00
          93           81   0.00000000E+00
          93           82   0.00000000E+00
          93           83  -0.18699636E-05
          93           84   0.00000000E+00
          93           85   0.00000000E+00
          93           86   0.00000000E+00
          93           87   0.00000000E+00
          93           88   0.00000000E+00
          93           89   0.00000000E+00
          93           90   0.00000000E+00
          93          101   0.00000000E+00
          93          102   0.00000000E+00
          93          103  -0.28066608E-05
          93          104   0.00000000E+00
          93          105   0.00000000E+00
          93          106   0.00000000E+00
          93          107   0.00000000E+00
          93          108   0.00000000E+00
          93          109   0.00000000E+00
          93          110   0.00000000E+00
          94           94   0.13409529E+04
          94           91   0.00000000E+00
          94           92   0.63443872E+01
          94           93   0.00000000E+00
          94           95   0.19035065E+02
          94           96   0.00000000E+00
          94           97  -0.65836821E+02
          94           98   0.00000000E+00
          94           99   0.00000000E+00
          94          100   0.00000000E+00
          94           81   0.00000000E+00
          94           82   0.00000000E+00
          94           83   0.00000000E+00
          94           84  -0.31658155E-05
          94           85   0.00000000E+00
          94           86   0.00000000E+00
          94           87   0.58143241E-08
          94           88   0.00000000E+00
          94           89   0.00000000E+00
          94           90   0.00000000E+00
          94          101   0.00000000E+00
          94          102   0.00000000E+00
          94          103   0.00000000E+00
          94          104  -0.47516275E-05
          94          105   0.00000000E+00
          94          106   0.00000000E+00
          94          107   0.87268201E-08
          94          108   0.00000000E+00
          94          109   0.00000000E+00
          94          110   0.00000000E+00
          95           95   0.19052837E+02
          95           91   0.00000000E+00
          95           92   0.63443872E+01
          95           93   0.00000000E+00
          95           94   0.19035065E+02
          95           96   0.00000000E+00
          95           97  -0.63477866E+02
          95           98   0.00000000E+00
          95           99   0.00000000E+00
          95          100   0.21795643E-05
          95           81   0.00000000E+00
          95           82   0.00000000E+00
          95           83   0.00000000E+00
          95           84   0.00000000E+00
          95           85  -0.42484262E-10
          95           86   0.00000000E+00
          95           87   0.16470994E-09
          95           88   0.00000000E+00
          95           89   0.00000000E+00
          95           90  -0.52197636E-14
          95          101   0.00000000E+00
          95          102   0.00000000E+00
          95          103   0.00000000E+00
          95          104   0.00000000E+00
          95          105  -0.63765367E-10
          95          106   0.00000000E+00
          95          107   0.24721601E-09
          95          108   0.00000000E+00
          95          109   0.00000000E+00
          95          110  -0.78344339E-14
          96           96   0.17074662E+04
          96           91   0.79884210E+02
          96           92   0.00000000E+00
          96           93   0.00000000E+00
          96           94   0.00000000E+00
          96           95   0.00000000E+00
          96           97   0.19543730E+04
          96           98   0.00000000E+00
          96           99   0.43198833E-04
          96          100   0.00000000E+00
          96           81  -0.19131143E-06
          96           82   0.00000000E+00
          96           83   0.00000000E+00
          96           84   0.00000000E+00
          96           85   0.00000000E+00
          96           86  -0.40891514E-05
          96           87  -0.46804606E-05
          96           88   0.00000000E+00
          96           89   0.00000000E+00
          96           90   0.00000000E+00
          96          101  -0.28714265E-06
          96          102   0.00000000E+00
          96          103   0.00000000E+00
          96          104   0.00000000E+00
          96          105   0.00000000E+00
          96          106  -0.61374783E-05
          96          107  -0.70249846E-05
          96          108   0.00000000E+00
          96          109   0.00000000E+00
          96          110   0.00000000E+00
          97           97   0.26723718E+04
          97           91   0.76117799E+02
          97           92  -0.21147957E+02
          97           93   0.00000000E+00
          97           94  -0.65878288E+02
          97           95  -0.63519108E+02
          97           96   0.19543478E+04
          97           98  -0.38887502E-04
          97           99  -0.12035985E+00
          97          100   0.49505150E-01
          97           81  -0.18229190E-06
          97           82   0.00000000E+00
          97           83   0.00000000E+00
          97           84   0.58149055E-08
          97           85   0.16475051E-09
          97           86  -0.46804003E-05
          97           87  -0.58937839E-05
          97           88   0.15713863E-13
          97           89   0.28826778E-09
          97           90  -0.11851393E-09
          97          101  -0.27360508E-06
          97          102   0.00000000E+00
          97          103   0.00000000E+00
          97          104   0.87276927E-08
          97          105   0.24727690E-09
          97          106  -0.70248941E-05
          97          107  -0.88460827E-05
          97          108   0.23585210E-13
          97          109   0.43266612E-09
          97          110  -0.17787962E-09
          98           98   0.66308262E-04
          98           91   0.00000000E+00
          98           92   0.00000000E+00
          98           93   0.00000000E+00
          98           94   0.00000000E+00
          98           95   0.00000000E+00
          98           96   0.00000000E+00
          98           97  -0.38896922E-04
          98           99  -0.14946245E-04
          98          100  -0.37051937E-04
          98           81   0.00000000E+00
          98           82   0.00000000E+00
          98           83   0.00000000E+00
          98           84   0.00000000E+00
          98           85   0.00000000E+00
          98           86   0.00000000E+00
          98           87   0.15715131E-13
          98           88  -0.23320538E-13
          98           89  -0.29226998E-14
          98           90   0.11296639E-13
          98          101   0.00000000E+00
          98          102   0.00000000E+00
          98          103   0.00000000E+00
          98          104   0.00000000E+00
          98          105   0.00000000E+00
          98          106   0.00000000E+00
          98          107   0.23587113E-13
          98          108  -0.35002201E-13
          98          109  -0.43867309E-14
          98          110   0.16955322E-13
          99           99   0.99356224E+02
          99           91   0.00000000E+00
          99           92   0.00000000E+00
          99           93   0.00000000E+00
          99           94   0.00000000E+00
          99           95   0.00000000E+00
          99           96   0.43198833E-04
          99           97  -0.12034781E+00
          99           98  -0.14942654E-04
          99          100   0.33536708E+02
          99           81   0.00000000E+00
          99           82   0.00000000E+00
          99           83   0.00000000E+00
          99           84   0.00000000E+00
          99           85   0.00000000E+00
          99           86   0.00000000E+00
          99           87   0.28823896E-09
          99           88  -0.29225902E-14
          99           89  -0.23794469E-06
          99           90  -0.80315886E-07
          99          101   0.00000000E+00
          99          102   0.00000000E+00
          99          103   0.00000000E+00
          99          104   0.00000000E+00
          99          105   0.00000000E+00
          99          106   0.00000000E+00
          99          107   0.43262286E-09
          99          108  -0.43865664E-14
          99          109  -0.35713531E-06
          99          110  -0.12054751E-06
         100          100   0.13484933E+05
         100           91   0.36307130E+04
         100           92   0.24834091E+03
         100           93   0.00000000E+00
         100           94   0.00000000E+00
         100           95   0.21795340E-05
         100           96   0.00000000E+00
         100           97   0.49505150E-01
         100           98  -0.37042339E-04
         100           99   0.33536708E+02
         100           81  -0.86950685E-05
         100           82  -0.59474311E-06
         100           83   0.00000000E+00
         100           84   0.00000000E+00
         100           85  -0.52196911E-14
         100           86   0.00000000E+00
         100           87  -0.11851393E-09
         100           88   0.11294945E-13
         100           89  -0.80315886E-07
         100           90  -0.32294600E-04
         100          101  -0.13050579E-04
         100          102  -0.89266026E-06
         100          103   0.00000000E+00
         100          104   0.00000000E+00
         100          105  -0.78343250E-14
         100          106   0.00000000E+00
         100          107  -0.17787962E-09
         100          108   0.16952779E-13
         100          109  -0.12054751E-06
         100          110  -0.48471527E-04
         101          101   0.97945219E+04
         101          102   0.00000000E+00
         101          103   0.00000000E+00
         101          104   0.00000000E+00
         101          105   0.00000000E+00
         101          106   0.79884210E+02
         101          107   0.76117799E+02
         101          108   0.00000000E+00
         101          109   0.00000000E+00
         101          110   0.36307130E+04
         101           91  -0.23456562E-04
         101           92   0.00000000E+00
         101           93   0.00000000E+00
         101           94   0.00000000E+00
         101           95   0.00000000E+00
         101           96  -0.19131143E-06
         101           97  -0.18229190E-06
         101           98   0.00000000E+00
         101           99   0.00000000E+00
         101          100  -0.86950685E-05
         101          111  -0.35206361E-04
         101          112   0.00000000E+00
         101          113   0.00000000E+00
         101          114   0.00000000E+00
         101          115   0.00000000E+00
         101          116  -0.28714265E-06
         101          117  -0.27360508E-06
         101          118   0.00000000E+00
         101          119   0.00000000E+00
         101          120  -0.13050579E-04
         102          102   0.61664984E+04
         102          101   0.00000000E+00
         102          103   0.00000000E+00
         102          104   0.63450217E+01
         102          105   0.63450217E+01
         102          106   0.00000000E+00
         102          107  -0.21136331E+02
         102          108   0.00000000E+00
         102          109   0.00000000E+00
         102          110   0.24834091E+03
         102           91   0.00000000E+00
         102           92  -0.14762870E-04
         102           93   0.00000000E+00
         102           94   0.00000000E+00
         102           95   0.00000000E+00
         102           96   0.00000000E+00
         102           97   0.00000000E+00
         102           98   0.00000000E+00
         102           99   0.00000000E+00
         102          100  -0.59474311E-06
         102          111   0.00000000E+00
         102          112  -0.22157848E-04
         102          113   0.00000000E+00
         102          114   0.00000000E+00
         102          115   0.00000000E+00
         102          116   0.00000000E+00
         102          117   0.00000000E+00
         102          118   0.00000000E+00
         102          119   0.00000000E+00
         102          120  -0.89266026E-06
         103          103   0.78082192E+03
         103          101   0.00000000E+00
         103          102   0.00000000E+00
         103          104   0.00000000E+00
         103          105   0.00000000E+00
         103          106   0.00000000E+00
         103          107   0.00000000E+00
         103          108   0.00000000E+00
         103          109   0.00000000E+00
         103          110   0.00000000E+00
         103           91   0.00000000E+00
         103           92   0.00000000E+00
         103           93  -0.18699636E-05
         103           94   0.00000000E+00
         103           95   0.00000000E+00
         103           96   0.00000000E+00
         103           97   0.00000000E+00
         103           98   0.00000000E+00
         103           99   0.00000000E+00
         103          100   0.00000000E+00
         103          111   0.00000000E+00
         103          112   0.00000000E+00
         103          113  -0.28066608E-05
         103          114   0.00000000E+00
         103          115   0.00000000E+00
         103          116   0.00000000E+00
         103          117   0.00000000E+00
         103          118   0.00000000E+00
         103          119   0.00000000E+00
         103          120   0.00000000E+00
         104          104   0.13409529E+04
         104          101   0.00000000E+00
         104          102   0.63443872E+01
         104          103   0.00000000E+00
         104          105   0.19035065E+02
         104          106   0.00000000E+00
         104          107  -0.65836821E+02
         104          108   0.00000000E+00
         104          109   0.00000000E+00
         104          110   0.00000000E+00
         104           91   0.00000000E+00
         104           92   0.00000000E+00
         104           93   0.00000000E+00
         104           94  -0.31658155E-05
         104           95   0.00000000E+00
         104           96   0.00000000E+00
         104           97   0.58143241E-08
         104           98   0.00000000E+00
         104           99   0.00000000E+00
         104          100   0.00000000E+00
         104          111   0.00000000E+00
         104          112   0.00000000E+00
         104          113   0.00000000E+00
         104          114  -0.47516275E-05
         104          115   0.00000000E+00
         104          116   0.00000000E+00
         104          117   0.87268201E-08
         104          118   0.00000000E+00
         104          119   0.00000000E+00
         104          120   0.00000000E+00
         105          105   0.19052837E+02
         105          101   0.00000000E+00
         105          102   0.63443872E+01
         105          103   0.00000000E+00
         105          104   0.19035065E+02
         105          106   0.00000000E+00
         105          107  -0.63477866E+02
         105          108   0.00000000E+00
         105          109   0.00000000E+00
         105          110   0.21795643E-05
         105           91   0.00000000E+00
         105           92   0.00000000E+00
         105           93   0.00000000E+00
         105           94   0.00000000E+00
         105           95  -0.42484262E-10
         105           96   0.00000000E+00
         105           97   0.16470994E-09
         105           98   0.00000000E+00
         105           99   0.00000000E+00
         105          100  -0.52197636E-14
         105          111   0.00000000E+00
         105          112   0.00000000E+00
         105          113   0.00000000E+00
         105          114   0.00000000E+00
         105          115  -0.63765367E-10
         105          116   0.00000000E+00
         105          117   0.24721601E-09
         105          118   0.00000000E+00
         105          119   0.00000000E+00
         105          120  -0.78344339E-14
         106          106   0.17074662E+04
         106          101   0.79884210E+02
         106          102   0.00000000E+00
         106          103   0.00000000E+00
         106          104   0.00000000E+00
         106          105   0.00000000E+00
         106          107   0.19543730E+04
         106          108   0.00000000E+00
         106          109   0.43198833E-04
         106          110   0.00000000E+00
         106           91  -0.19131143E-06
         106           92   0.00000000E+00
         106           93   0.00000000E+00
         106           94   0.00000000E+00
         106           95   0.00000000E+00
         106           96  -0.40891514E-05
         106           97  -0.46804606E-05
         106           98   0.00000000E+00
         106           99   0.00000000E+00
         106          100   0.00000000E+00
         106          111  -0.28714265E-06
         106          112   0.00000000E+00
         106          113   0.00000000E+00
         106          114   0.00000000E+00
         106          115   0.00000000E+00
         106          116  -0.61374783E-05
         106          117  -0.70249846E-05
         106          118   0.00000000E+00
         106          119   0.00000000E+00
         106          120   0.00000000E+00
         107          107   0.26723718E+04
         107          101   0.76117799E+02
         107          102  -0.21147957E+02
         107          103   0.00000000E+00
         107          104  -0.65878288E+02
         107          105  -0.63519108E+02
         107          106   0.19543478E+04
         107          108  -0.38887502E-04
         107          109  -0.12035985E+00
         107          110   0.49505150E-01
         107           91  -0.18229190E-06
         107           92   0.00000000E+00
         107           93   0.00000000E+00
         107           94   0.58149055E-08
         107           95   0.16475051E-09
         107           96  -0.46804003E-05
         107           97  -0.58937839E-05
         107           98   0.15713863E-13
         107           99   0.28826778E-09
         107          100  -0.11851393E-09
         107          111  -0.27360508E-06
         107          112   0.00000000E+00
         107          113   0.00000000E+00
         107          114   0.87276927E-08
         107          115   0.24727690E-09
         107          116  -0.70248941E-05
         107          117  -0.88460827E-05
         107          118   0.23585210E-13
         107          119   0.43266612E-09
         107          120  -0.17787962E-09
         108          108   0.66308262E-04
         108          101   0.00000000E+00
         108          102   0.00000000E+00
         108          103   0.00000000E+00
         108          104   0.00000000E+00
         108          105   0.00000000E+00
         108          106   0.00000000E+00
         108          107  -0.38896922E-04
         108          109  -0.14946245E-04
         108          110  -0.37051937E-04
         108           91   0.00000000E+00
         108           92   0.00000000E+00
         108           93   0.00000000E+00
         108           94   0.00000000E+00
         108           95   0.00000000E+00
         108           96   0.00000000E+00
         108           97   0.15715131E-13
         108           98  -0.23320538E-13
         108           99  -0.29226998E-14
         108          100   0.11296639E-13
         108          111   0.00000000E+00
         108          112   0.00000000E+00
         108          113   0.00000000E+00
         108          114   0.00000000E+00
         108          115   0.00000000E+00
         108          116   0.00000000E+00
         108          117   0.23587113E-13
         108          118  -0.35002201E-13
         108          119  -0.43867309E-14
         108          120   0.16955322E-13
         109          109   0.99356224E+02
         109          101   0.00000000E+00
         109          102   0.00000000E+00
         109          103   0.00000000E+00
         109          104   0.00000000E+00
         109          105   0.00000000E+00
         109          106   0.43198833E-04
         109          107  -0.12034781E+00
         109          108  -0.14942654E-04
         109          110   0.33536708E+02
         109           91   0.00000000E+00
         109           92   0.00000000E+00
         109           93   0.00000000E+00
         109           94   0.00000000E+00
         109           95   0.00000000E+00
         109           96   0.00000000E+00
         109           97   0.28823896E-09
         109           98  -0.29225902E-14
         109           99  -0.23794469E-06
         109          100  -0.80315886E-07
         109          111   0.00000000E+00
         109          112   0.00000000E+00
         109          113   0.00000000E+00
         109          114   0.00000000E+00
         109          115   0.00000000E+00
         109          116   0.00000000E+00
         109          117   0.43262286E-09
         109          118  -0.43865664E-14
         109          119  -0.35713531E-06
         109          120  -0.12054751E-06
         110          110   0.13484933E+05
         110          101   0.36307130E+04
         110          102   0.24834091E+03
         110          103   0.00000000E+00
         110          104   0.00000000E+00
         110          105   0.21795340E-05
         110          106   0.00000000E+00
         110          107   0.49505150E-01
         110          108  -0.37042339E-04
         110          109   0.33536708E+02
         110           91  -0.86950685E-05
         110           92  -0.59474311E-06
         110           93   0.00000000E+00
         110           94   0.00000000E+00
         110           95  -0.52196911E-14
         110           96   0.00000000E+00
         110           97  -0.11851393E-09
         110           98   0.11294945E-13
         110           99  -0.80315886E-07
         110          100  -0.32294600E-04
         110          111  -0.13050579E-04
         110          112  -0.89266026E-06
         110          113   0.00000000E+00
         110          114   0.00000000E+00
         110          115  -0.78343250E-14
         110          116   0.00000000E+00
         110          117  -0.17787962E-09
         110          118   0.16952779E-13
         110          119  -0.12054751E-06
         110          120  -0.48471527E-04
         111          111   0.97945219E+04
         111          112   0.00000000E+00
         111          113   0.00000000E+00
         111          114   0.00000000E+00
         111          115   0.00000000E+00
         111          116   0.79884210E+02
         111          117   0.76117799E+02
         111          118   0.00000000E+00
         111          119   0.00000000E+00
         111          120   0.36307130E+04
         111          101  -0.23456562E-04
         111          102   0.00000000E+00
         111          103   0.00000000E+00
         111          104   0.00000000E+00
         111          105   0.00000000E+00
         111          106  -0.19131143E-06
         111          107  -0.18229190E-06
         111          108   0.00000000E+00
         111          109   0.00000000E+00
         111          110  -0.86950685E-05
         111          121  -0.35206361E-04
         111          122   0.00000000E+00
         111          123   0.00000000E+00
         111          124   0.00000000E+00
         111          125   0.00000000E+00
         111          126  -0.28714265E-06
         111          127  -0.27360508E-06
         111          128   0.00000000E+00
         111          129   0.00000000E+00
         111          130  -0.13050579E-04
         112          112   0.61664984E+04
         112          111   0.00000000E+00
         112          113   0.00000000E+00
         112          114   0.63450217E+01
         112          115   0.63450217E+01
         112          116   0.00000000E+00
         112          117  -0.21136331E+02
         112          118   0.00000000E+00
         112          119   0.00000000E+00
         112          120   0.24834091E+03
         112          101   0.00000000E+00
         112          102  -0.14762870E-04
         112          103   0.00000000E+00
         112          104   0.00000000E+00
         112          105   0.00000000E+00
         112          106   0.00000000E+00
         112          107   0.00000000E+00
         112          108   0.00000000E+00
         112          109   0.00000000E+00
         112          110  -0.59474311E-06
         112          121   0.00000000E+00
         112          122  -0.22157848E-04
         112          123   0.00000000E+00
         112          124   0.00000000E+00
         112          125   0.00000000E+00
         112          126   0.00000000E+00
         112          127   0.00000000E+00
         112          128   0.00000000E+00
         112          129   0.00000000E+00
         112          130  -0.89266026E-06
         113          113   0.78082192E+03
         113          111   0.00000000E+00
         113          112   0.00000000E+00
         113          114   0.00000000E+00
         113          115   0.00000000E+00
         113          116   0.00000000E+00
         113          117   0.00000000E+00
         113          118   0.00000000E+00
         113          119   0.00000000E+00
         113          120   0.00000000E+00
         113          101   0.00000000E+00
         113          102   0.00000000E+00
         113          103  -0.18699636E-05
         113          104   0.00000000E+00
         113          105   0.00000000E+00
         113          106   0.00000000E+00
         113          107   0.00000000E+00
         113          108   0.00000000E+00
         113          109   0.00000000E+00
         113          110   0.00000000E+00
         113          121   0.00000000E+00
         113          122   0.00000000E+00
         113          123  -0.28066608E-05
         113          124   0.00000000E+00
         113          125   0.00000000E+00
         113          126   0.00000000E+00
         113          127   0.00000000E+00
         113          128   0.00000000E+00
         113          129   0.00000000E+00
         113          130   0.00000000E+00
         114          114   0.13409529E+04
         114          111   0.00000000E+00
         114          112   0.63443872E+01
         114          113   0.00000000E+00
         114          115   0.19035065E+02
         114          116   0.00000000E+00
         114          117  -0.65836821E+02
         114          118   0.00000000E+00
         114          119   0.00000000E+00
         114          120   0.00000000E+00
         114          101   0.00000000E+00
         114          102   0.00000000E+00
         114          103   0.00000000E+00
         114          104  -0.31658155E-05
         114          105   0.00000000E+00
         114          106   0.00000000E+00
         114          107   0.58143241E-08
         114          108   0.00000000E+00
         114          109   0.00000000E+00
         114          110   0.00000000E+00
         114          121   0.00000000E+00
         114          122   0.00000000E+00
         114          123   0.00000000E+00
         114          124  -0.47516275E-05
         114          125   0.00000000E+00
         114          126   0.00000000E+00
         114          127   0.87268201E-08
         114          128   0.00000000E+00
         114          129   0.00000000E+00
         114          130   0.00000000E+00
         115          115   0.19052837E+02
         115          111   0.00000000E+00
         115          112   0.63443872E+01
         115          113   0.00000000E+00
         115          114   0.19035065E+02
         115          116   0.00000000E+00
         115          117  -0.63477866E+02
         115          118   0.00000000E+00
         115          119   0.00000000E+00
         115          120   0.21795643E-05
         115          101   0.00000000E+00
         115          102   0.00000000E+00
         115          103   0.00000000E+00
         115          104   0.00000000E+00
         115          105  -0.42484262E-10
         115          106   0.00000000E+00
         115          107   0.16470994E-09
         115          108   0.00000000E+00
         115          109   0.00000000E+00
         115          110  -0.52197636E-14
         115          121   0.00000000E+00
         115          122   0.00000000E+00
         115          123   0.00000000E+00
         115          124   0.00000000E+00
         115          125  -0.63765367E-10
         115          126   0.00000000E+00
         115          127   0.24721601E-09
         115          128   0.00000000E+00
         115          129   0.00000000E+00
         115          130  -0.78344339E-14
         116          116   0.17074662E+04
         116          111   0.79884210E+02
         116          112   0.00000000E+00
         116          113   0.00000000E+00
         116          114   0.00000000E+00
         116          115   0.00000000E+00
         116          117   0.19543730E+04
         116          118   0.00000000E+00
         116          119   0.43198833E-04
         116          120   0.00000000E+00
         116          101  -0.19131143E-06
         116          102   0.00000000E+00
         116          103   0.00000000E+00
         116          104   0.00000000E+00
         116          105   0.00000000E+00
         116          106  -0.40891514E-05
         116          107  -0.46804606E-05
         116          108   0.00000000E+00
         116          109   0.00000000E+00
         116          110   0.00000000E+00
         116          121  -0.28714265E-06
         116          122   0.00000000E+00
         116          123   0.00000000E+00
         116          124   0.00000000E+00
         116          125   0.00000000E+00
         116          126  -0.61374783E-05
         116          127  -0.70249846E-05
         116          128   0.00000000E+00
         116          129   0.00000000E+00
         116          130   0.00000000E+00
         117          117   0.26723718E+04
         117          111   0.76117799E+02
         117          112  -0.21147957E+02
         117          113   0.00000000E+00
         117          114  -0.65878288E+02
         117          115  -0.63519108E+02
         117          116   0.19543478E+04
         117          118  -0.38887502E-04
         117          119  -0.12035985E+00
         117          120   0.49505150E-01
         117          101  -0.18229190E-06
         117          102   0.00000000E+00
         117          103   0.00000000E+00
         117          104   0.58149055E-08
         117          105   0.16475051E-09
         117          106  -0.46804003E-05
         117          107  -0.58937839E-05
         117          108   0.15713863E-13
         117          109   0.28826778E-09
         117          110  -0.11851393E-09
         117          121  -0.27360508E-06
         117          122   0.00000000E+00
         117          123   0.00000000E+00
         117          124   0.87276927E-08
         117          125   0.24727690E-09
         117          126  -0.70248941E-05
         117          127  -0.88460827E-05
         117          128   0.23585210E-13
         117          129   0.43266612E-09
         117          130  -0.17787962E-09
         118          118   0.66308262E-04
         118          111   0.00000000E+00
         118          112   0.00000000E+00
         118          113   0.00000000E+00
         118          114   0.00000000E+00
         118          115   0.00000000E+00
         118          116   0.00000000E+00
         118          117  -0.38896922E-04
         118          119  -0.14946245E-04
         118          120  -0.37051937E-04
         118          101   0.00000000E+00
         118          102   0.00000000E+00
         118          103   0.00000000E+00
         118          104   0.00000000E+00
         118          105   0.00000000E+00
         118          106   0.00000000E+00
         118          107   0.15715131E-13
         118          108  -0.23320538E-13
         118          109  -0.29226998E-14
         118          110   0.11296639E-13
         118          121   0.00000000E+00
         118          122   0.00000000E+00
         118          123   0.00000000E+00
         118          124   0.00000000E+00
         118          125   0.00000000E+00
         118          126   0.00000000E+00
         118          127   0.23587113E-13
         118          128  -0.35002201E-13
         118          129  -0.43867309E-14
         118          130   0.16955322E-13
         119          119   0.99356224E+02
         119          111   0.00000000E+00
         119          112   0.00000000E+00
         119          113   0.00000000E+00
         119          114   0.00000000E+00
         119          115   0.00000000E+00
         119          116   0.43198833E-04
         119          117  -0.12034781E+00
         119          118  -0.14942654E-04
         119          120   0.33536708E+02
         119          101   0.00000000E+00
         119          102   0.00000000E+00
         119          103   0.00000000E+00
         119          104   0.00000000E+00
         119          105   0.00000000E+00
         119          106   0.00000000E+00
         119          107   0.28823896E-09
         119          108  -0.29225902E-14
         119          109  -0.23794469E-06
         119          110  -0.80315886E-07
         119          121   0.00000000E+00
         119          122   0.00000000E+00
         119          123   0.00000000E+00
         119          124   0.00000000E+00
         119          125   0.00000000E+00
         119          126   0.00000000E+00
         119          127   0.43262286E-09
         119          128  -0.43865664E-14
         119          129  -0.35713531E-06
         119          130  -0.12054751E-06
         120          120   0.13484933E+05
         120          111   0.36307130E+04
         120          112   0.24834091E+03
         120          113   0.00000000E+00
         120          114   0.00000000E+00
         120          115   0.21795340E-05
         120          116   0.00000000E+00
         120          117   0.49505150E-01
         120          118  -0.37042339E-04
         120          119   0.33536708E+02
         120          101  -0.86950685E-05
         120          102  -0.59474311E-06
         120          103   0.00000000E+00
         120          104   0.00000000E+00
         120          105  -0.52196911E-14
         120          106   0.00000000E+00
         120          107  -0.11851393E-09
         120          108   0.11294945E-13
         120          109  -0.80315886E-07
         120          110  -0.32294600E-04
         120          121  -0.13050579E-04
         120          122  -0.89266026E-06
         120          123   0.00000000E+00
         120          124   0.00000000E+00
         120          125  -0.78343250E-14
         120          126   0.00000000E+00
         120          127  -0.17787962E-09
         120          128   0.16952779E-13
         120          129  -0.12054751E-06
         120          130  -0.48471527E-04
         121          121   0.97945219E+04
         121          122   0.00000000E+00
         121          123   0.00000000E+00
         121          124   0.00000000E+00
         121          125   0.00000000E+00
         121          126   0.79884210E+02
         121          127   0.76117799E+02
         121          128   0.00000000E+00
         121          129   0.00000000E+00
         121          130   0.36307130E+04
         121          111  -0.23456562E-04
         121          112   0.00000000E+00
         121          113   0.00000000E+00
         121          114   0.00000000E+00
         121          115   0.00000000E+00
         121          116  -0.19131143E-06
         121          117  -0.18229190E-06
         121          118   0.00000000E+00
         121          119   0.00000000E+00
         121          120  -0.86950685E-05
         121          131  -0.35206361E-04
         121          132   0.00000000E+00
         121          133   0.00000000E+00
         121          134   0.00000000E+00
         121          135   0.00000000E+00
         121          136  -0.28714265E-06
         121          137  -0.27360508E-06
         121          138   0.00000000E+00
         121          139   0.00000000E+00
         121          140  -0.13050579E-04
         122          122   0.61664984E+04
         122          121   0.00000000E+00
         122          123   0.00000000E+00
         122          124   0.63450217E+01
         122          125   0.63450217E+01
         122          126   0.00000000E+00
         122          127  -0.21136331E+02
         122          128   0.00000000E+00
         122          129   0.00000000E+00
         122          130   0.24834091E+03
         122          111   0.00000000E+00
         122          112  -0.14762870E-04
         122          113   0.00000000E+00
         122          114   0.00000000E+00
         122          115   0.00000000E+00
         122          116   0.00000000E+00
         122          117   0.00000000E+00
         122          118   0.00000000E+00
         122          119   0.00000000E+00
         122          120  -0.59474311E-06
         122          131   0.00000000E+00
         122          132  -0.22157848E-04
         122          133   0.00000000E+00
         122          134   0.00000000E+00
         122          135   0.00000000E+00
         122          136   0.00000000E+00
         122          137   0.00000000E+00
         122          138   0.00000000E+00
         122          139   0.00000000E+00
         122          140  -0.89266026E-06
         123          123   0.78082192E+03
         123          121   0.00000000E+00
         123          122   0.00000000E+00
         123          124   0.00000000E+00
         123          125   0.00000000E+00
         123          126   0.00000000E+00
         123          127   0.00000000E+00
         123          128   0.00000000E+00
         123          129   0.00000000E+00
         123          130   0.00000000E+00
         123          111   0.00000000E+00
         123          112   0.00000000E+00
         123          113  -0.18699636E-05
         123          114   0.00000000E+00
         123          115   0.00000000E+00
         123          116   0.00000000E+00
         123          117   0.00000000E+00
         123          118   0.00000000E+00
         123          119   0.00000000E+00
         123          120   0.00000000E+00
         123          131   0.00000000E+00
         123          132   0.00000000E+00
         123          133  -0.28066608E-05
         123          134   0.00000000E+00
         123          135   0.00000000E+00
         123          136   0.00000000E+00
         123          137   0.00000000E+00
         123          138   0.00000000E+00
         123          139   0.00000000E+00
         123          140   0.00000000E+00
         124          124   0.13409529E+04
         124          121   0.00000000E+00
         124          122   0.63443872E+01
         124          123   0.00000000E+00
         124          125   0.19035065E+02
         124          126   0.00000000E+00
         124          127  -0.65836821E+02
         124          128   0.00000000E+00
         124          129   0.00000000E+00
         124          130   0.00000000E+00
         124          111   0.00000000E+00
         124          112   0.00000000E+00
         124          113   0.00000000E+00
         124          114  -0.31658155E-05
         124          115   0.00000000E+00
         124          116   0.00000000E+00
         124          117   0.58143241E-08
         124          118   0.00000000E+00
         124          119   0.00000000E+00
         124          120   0.00000000E+00
         124          131   0.00000000E+00
         124          132   0.00000000E+00
         124          133   0.00000000E+00
         124          134  -0.47516275E-05
         124          135   0.00000000E+00
         124          136   0.00000000E+00
         124          137   0.87268201E-08
         124          138   0.00000000E+00
         124          139   0.00000000E+00
         124          140   0.00000000E+00
         125          125   0.19052837E+02
         125          121   0.00000000E+00
         125          122   0.63443872E+01
         125          123   0.00000000E+00
         125          124   0.19035065E+02
         125          126   0.00000000E+00
         125          127  -0.63477866E+02
         125          128   0.00000000E+00
         125          129   0.00000000E+00
         125          130   0.21795643E-05
         125          111   0.00000000E+00
         125          112   0.00000000E+00
         125          113   0.00000000E+00
         125          114   0.00000000E+00
         125          115  -0.42484262E-10
         125          116   0.00000000E+00
         125          117   0.16470994E-09
         125          118   0.00000000E+00
         125          119   0.00000000E+00
         125          120  -0.52197636E-14
         125          131   0.00000000E+00
         125          132   0.00000000E+00
         125          133   0.00000000E+00
         125          134   0.00000000E+00
         125          135  -0.63765367E-10
         125          136   0.00000000E+00
         125          137   0.24721601E-09
         125          138   0.00000000E+00
         125          139   0.00000000E+00
         125          140  -0.78344339E-14
         126          126   0.17074662E+04
         126          121   0.79884210E+02
         126          122   0.00000000E+00
         126          123   0.00000000E+00
         126          124   0.00000000E+00
         126          125   0.00000000E+00
         126          127   0.19543730E+04
         126          128   0.00000000E+00
         126          129   0.43198833E-04
         126          130   0.00000000E+00
         126          111  -0.19131143E-06
         126          112   0.00000000E+00
         126          113   0.00000000E+00
         126          114   0.00000000E+00
         126          115   0.00000000E+00
         126          116  -0.40891514E-05
         126          117  -0.46804606E-05
         126          118   0.00000000E+00
         126          119   0.00000000E+00
         126          120   0.00000000E+00
         126          131  -0.28714265E-06
         126          132   0.00000000E+00
         126          133   0.00000000E+00
         126          134   0.00000000E+00
         126          135   0.00000000E+00
         126          136  -0.61374783E-05
         126          137  -0.70249846E-05
         126          138   0.00000000E+00
         126          139   0.00000000E+00
         126          140   0.00000000E+00
         127          127   0.26723718E+04
         127          121   0.76117799E+02
         127          122  -0.21147957E+02
         127          123   0.00000000E+00
         127          124  -0.65878288E+02
         127          125  -0.63519108E+02
         127          126   0.19543478E+04
         127          128  -0.38887502E-04
         127          129  -0.12035985E+00
         127          130   0.49505150E-01
         127          111  -0.18229190E-06
         127          112   0.00000000E+00
         127          113   0.00000000E+00
         127          114   0.58149055E-08
         127          115   0.16475051E-09
         127          116  -0.46804003E-05
         127          117  -0.58937839E-05
         127          118   0.15713863E-13
         127          119   0.28826778E-09
         127          120  -0.11851393E-09
         127          131  -0.27360508E-06
         127          132   0.00000000E+00
         127          133   0.00000000E+00
         127          134   0.87276927E-08
         127          135   0.24727690E-09
         127          136  -0.70248941E-05
         127          137  -0.88460827E-05
         127          138   0.23585210E-13
         127          139   0.43266612E-09
         127          140  -0.17787962E-09
         128          128   0.66308262E-04
         128          121   0.00000000E+00
         128          122   0.00000000E+00
         128          123   0.00000000E+00
         128          124   0.00000000E+00
         128          125   0.00000000E+00
         128          126   0.00000000E+00
         128          127  -0.38896922E-04
         128          129  -0.14946245E-04
         128          130  -0.37051937E-04
         128          111   0.00000000E+00
         128          112   0.00000000E+00
         128          113   0.00000000E+00
         128          114   0.00000000E+00
         128          115   0.00000000E+00
         128          116   0.00000000E+00
         128          117   0.15715131E-13
         128          118  -0.23320538E-13
         128          119  -0.29226998E-14
         128          120   0.11296639E-13
         128          131   0.00000000E+00
         128          132   0.00000000E+00
         128          133   0.00000000E+00
         128          134   0.00000000E+00
         128          135   0.00000000E+00
         128          136   0.00000000E+00
         128          137   0.23587113E-13
         128          138  -0.35002201E-13
         128          139  -0.43867309E-14
         128          140   0.16955322E-13
         129          129   0.99356224E+02
         129          121   0.00000000E+00
         129          122   0.00000000E+00
         129          123   0.00000000E+00
         129          124   0.00000000E+00
         129          125   0.00000000E+00
         129          126   0.43198833E-04
         129          127  -0.12034781E+00
         129          128  -0.14942654E-04
         129          130   0.33536708E+02
         129          111   0.00000000E+00
         129          112   0.00000000E+00
         129          113   0.00000000E+00
         129          114   0.00000000E+00
         129          115   0.00000000E+00
         129          116   0.00000000E+00
         129          117   0.28823896E-09
         129          118  -0.29225902E-14
         129          119  -0.23794469E-06
         129          120  -0.80315886E-07
         129          131   0.00000000E+00
         129          132   0.00000000E+00
         129          133   0.00000000E+00
         129          134   0.00000000E+00
         129          135   0.00000000E+00
         129          136   0.00000000E+00
         129          137   0.43262286E-09
         129          138  -0.43865664E-14
         129          139  -0.35713531E-06
         129          140  -0.12054751E-06
         130          130   0.13484933E+05
         130          121   0.36307130E+04
         130          122   0.24834091E+03
         130          123   0.00000000E+00
         130          124   0.00000000E+00
         130          125   0.21795340E-05
         130          126   0.00000000E+00
         130          127   0.49505150E-01
         130          128  -0.37042339E-04
         130          129   0.33536708E+02
         130          111  -0.86950685E-05
         130          112  -0.59474311E-06
         130          113   0.00000000E+00
         130          114   0.00000000E+00
         130          115  -0.52196911E-14
         130          116   0.00000000E+00
         130          117  -0.11851393E-09
         130          118   0.11294945E-13
         130          119  -0.80315886E-07
         130          120  -0.32294600E-04
         130          131  -0.13050579E-04
         130          132  -0.89266026E-06
         130          133   0.00000000E+00
         130          134   0.00000000E+00
         130          135  -0.78343250E-14
         130          136   0.00000000E+00
         130          137  -0.17787962E-09
         130          138   0.16952779E-13
         130          139  -0.12054751E-06
         130          140  -0.48471527E-04
         131          131   0.97945219E+04
         131          132   0.00000000E+00
         131          133   0.00000000E+00
         131          134   0.00000000E+00
         131          135   0.00000000E+00
         131          136   0.79884210E+02
         131          137   0.76117799E+02
         131          138   0.00000000E+00
         131          139   0.00000000E+00
         131          140   0.36307130E+04
         131          121  -0.23456562E-04
         131          122   0.00000000E+00
         131          123   0.00000000E+00
         131          124   0.00000000E+00
         131          125   0.00000000E+00
         131          126  -0.19131143E-06
         131          127  -0.18229190E-06
         131          128   0.00000000E+00
         131          129   0.00000000E+00
         131          130  -0.86950685E-05
         131          141  -0.35206361E-04
         131          142   0.00000000E+00
         131          143   0.00000000E+00
         131          144   0.00000000E+00
         131          145   0.00000000E+00
         131          146  -0.28714265E-06
         131          147  -0.27360508E-06
         131          148   0.00000000E+00
         131          149   0.00000000E+00
         131          150  -0.13050579E-04
         132          132   0.61664984E+04
         132          131   0.00000000E+00
         132          133   0.00000000E+00
         132          134   0.63450217E+01
         132          135   0.63450217E+01
         132          136   0.00000000E+00
         132          137  -0.21136331E+02
         132          138   0.00000000E+00
         132          139   0.00000000E+00
         132          140   0.24834091E+03
         132          121   0.00000000E+00
         132          122  -0.14762870E-04
         132          123   0.00000000E+00
         132          124   0.00000000E+00
         132          125   0.00000000E+00
         132          126   0.00000000E+00
         132          127   0.00000000E+00
         132          128   0.00000000E+00
         132          129   0.00000000E+00
         132          130  -0.59474311E-06
         132          141   0.00000000E+00
         132          142  -0.22157848E-04
         132          143   0.00000000E+00
         132          144   0.00000000E+00
         132          145   0.00000000E+00
         132          146   0.00000000E+00
         132          147   0.00000000E+00
         132          148   0.00000000E+00
         132          149   0.00000000E+00
         132          150  -0.89266026E-06
         133          133   0.78082192E+03
         133          131   0.00000000E+00
         133          132   0.00000000E+00
         133          134   0.00000000E+00
         133          135   0.00000000E+00
         133          136   0.00000000E+00
         133          137   0.00000000E+00
         133          138   0.00000000E+00
         133          139   0.00000000E+00
         133          140   0.00000000E+00
         133          121   0.00000000E+00
         133          122   0.00000000E+00
         133          123  -0.18699636E-05
         133          124   0.00000000E+00
         133          125   0.00000000E+00
         133          126   0.00000000E+00
         133          127   0.00000000E+00
         133          128   0.00000000E+00
         133          129   0.00000000E+00
         133          130   0.00000000E+00
         133          141   0.00000000E+00
         133          142   0.00000000E+00
         133          143  -0.28066608E-05
         133          144   0.00000000E+00
         133          145   0.00000000E+00
         133          146   0.00000000E+00
         133          147   0.00000000E+00
         133          148   0.00000000E+00
         133          149   0.00000000E+00
         133          150   0.00000000E+00
         134          134   0.13409529E+04
         134          131   0.00000000E+00
         134          132   0.63443872E+01
         134          133   0.00000000E+00
         134          135   0.19035065E+02
         134          136   0.00000000E+00
         134          137  -0.65836821E+02
         134          138   0.00000000E+00
         134          139   0.00000000E+00
         134          140   0.00000000E+00
         134          121   0.00000000E+00
         134          122   0.00000000E+00
         134          123   0.00000000E+00
         134          124  -0.31658155E-05
         134          125   0.00000000E+00
         134          126   0.00000000E+00
         134          127   0.58143241E-08
         134          128   0.00000000E+00
         134          129   0.00000000E+00
         134          130   0.00000000E+00
         134          141   0.00000000E+00
         134          142   0.00000000E+00
         134          143   0.00000000E+00
         134          144  -0.47516275E-05
         134          145   0.00000000E+00
         134          146   0.00000000E+00
         134          147   0.87268201E-08
         134          148   0.00000000E+00
         134          149   0.00000000E+00
         134          150   0.00000000E+00
         135          135   0.19052837E+02
         135          131   0.00000000E+00
         135          132   0.63443872E+01
         135          133   0.00000000E+00
         135          134   0.19035065E+02
         135          136   0.00000000E+00
         135          137  -0.63477866E+02
         135          138   0.00000000E+00
         135          139   0.00000000E+00
         135          140   0.21795643E-05
         135          121   0.00000000E+00
         135          122   0.00000000E+00
         135          123   0.00000000E+00
         135          124   0.00000000E+00
         135          125  -0.42484262E-10
         135          126   0.00000000E+00
         135          127   0.16470994E-09
         135          128   0.00000000E+00
         135          129   0.00000000E+00
         135          130  -0.52197636E-14
         135          141   0.00000000E+00
         135          142   0.00000000E+00
         135          143   0.00000000E+00
         135          144   0.00000000E+00
         135          145  -0.63765367E-10
         135          146   0.00000000E+00
         135          147   0.24721601E-09
         135          148   0.00000000E+00
         135          149   0.00000000E+00
         135          150  -0.78344339E-14
         136          136   0.17074662E+04
         136          131   0.79884210E+02
         136          132   0.00000000E+00
         136          133   0.00000000E+00
         136          134   0.00000000E+00
         136          135   0.00000000E+00
         136          137   0.19543730E+04
         136          138   0.00000000E+00
         136          139   0.43198833E-04
         136          140   0.00000000E+00
         136          121  -0.19131143E-06
         136          122   0.00000000E+00
         136          123   0.00000000E+00
         136          124   0.00000000E+00
         136          125   0.00000000E+00
         136          126  -0.40891514E-05
         136          127  -0.46804606E-05
         136          128   0.00000000E+00
         136          129   0.00000000E+00
         136          130   0.00000000E+00
         136          141  -0.28714265E-06
         136          142   0.00000000E+00
         136          143   0.00000000E+00
         136          144   0.00000000E+00
         136          145   0.00000000E+00
         136          146  -0.61374783E-05
         136          147  -0.70249846E-05
         136          148   0.00000000E+00
         136          149   0.00000000E+00
         136          150   0.00000000E+00
         137          137   0.26723718E+04
         137          131   0.76117799E+02
         137          132  -0.21147957E+02
         137          133   0.00000000E+00
         137          134  -0.65878288E+02
         137          135  -0.63519108E+02
         137          136   0.19543478E+04
         137          138  -0.38887502E-04
         137          139  -0.12035985E+00
         137          140   0.49505150E-01
         137          121  -0.18229190E-06
         137          122   0.00000000E+00
         137          123   0.00000000E+00
         137          124   0.58149055E-08
         137          125   0.16475051E-09
         137          126  -0.46804003E-05
         137          127  -0.58937839E-05
         137          128   0.15713863E-13
         137          129   0.28826778E-09
         137          130  -0.11851393E-09
         137          141  -0.27360508E-06
         137          142   0.00000000E+00
         137          143   0.00000000E+00
         137          144   0.87276927E-08
         137          145   0.24727690E-09
         137          146  -0.70248941E-05
         137          147  -0.88460827E-05
         137          148   0.23585210E-13
         137          149   0.43266612E-09
         137          150  -0.17787962E-09
         138          138   0.66308262E-04
         138          131   0.00000000E+00
         138          132   0.00000000E+00
         138          133   0.00000000E+00
         138          134   0.00000000E+00
         138          135   0.00000000E+00
         138          136   0.00000000E+00
         138          137  -0.38896922E-04
         138          139  -0.14946245E-04
         138          140  -0.37051937E-04
         138          121   0.00000000E+00
         138          122   0.00000000E+00
         138          123   0.00000000E+00
         138          124   0.00000000E+00
         138          125   0.00000000E+00
         138          126   0.00000000E+00
         138          127   0.15715131E-13
         138          128  -0.23320538E-13
         138          129  -0.29226998E-14
         138          130   0.11296639E-13
         138          141   0.00000000E+00
         138          142   0.00000000E+00
         138          143   0.00000000E+00
         138          144   0.00000000E+00
         138          145   0.00000000E+00
         138          146   0.00000000E+00
         138          147   0.23587113E-13
         138          148  -0.35002201E-13
         138          149  -0.43867309E-14
         138          150   0.16955322E-13
         139          139   0.99356224E+02
         139          131   0.00000000E+00
         139          132   0.00000000E+00
         139          133   0.00000000E+00
         139          134   0.00000000E+00
         139          135   0.00000000E+00
         139          136   0.43198833E-04
         139          137  -0.12034781E+00
         139          138  -0.14942654E-04
         139          140   0.33536708E+02
         139          121   0.00000000E+00
         139          122   0.00000000E+00
         139          123   0.00000000E+00
         139          124   0.00000000E+00
         139          125   0.00000000E+00
         139          126   0.00000000E+00
         139          127   0.28823896E-09
         139          128  -0.29225902E-14
         139          129  -0.23794469E-06
         139          130  -0.80315886E-07
         139          141   0.00000000E+00
         139          142   0.00000000E+00
         139          143   0.00000000E+00
         139          144   0.00000000E+00
         139          145   0.00000000E+00
         139          146   0.00000000E+00
         139          147   0.43262286E-09
         139          148  -0.43865664E-14
         139          149  -0.35713531E-06
         139          150  -0.12054751E-06
         140          140   0.13484933E+05
         140          131   0.36307130E+04
         140          132   0.24834091E+03
         140          133   0.00000000E+00
         140          134   0.00000000E+00
         140          135   0.21795340E-05
         140          136   0.00000000E+00
         140          137   0.49505150E-01
         140          138  -0.37042339E-04
         140          139   0.33536708E+02
         140          121  -0.86950685E-05
         140          122  -0.59474311E-06
         140          123   0.00000000E+00
         140          124   0.00000000E+00
         140          125  -0.52196911E-14
         140          126   0.00000000E+00
         140          127  -0.11851393E-09
         140          128   0.11294945E-13
         140          129  -0.80315886E-07
         140          130  -0.32294600E-04
         140          141  -0.13050579E-04
         140          142  -0.89266026E-06
         140          143   0.00000000E+00
         140          144   0.00000000E+00
         140          145  -0.78343250E-14
         140          146   0.00000000E+00
         140          147  -0.17787962E-09
         140          148   0.16952779E-13
         140          149  -0.12054751E-06
         140          150  -0.48471527E-04
         141          141   0.97945219E+04
         141          142   0.00000000E+00
         141          143   0.00000000E+00
         141          144   0.00000000E+00
         141          145   0.00000000E+00
         141          146   0.79884210E+02
         141          147   0.76117799E+02
         141          148   0.00000000E+00
         141          149   0.00000000E+00
         141          150   0.36307130E+04
         141          131  -0.23456562E-04
         141          132   0.00000000E+00
         141          133   0.00000000E+00
         141          134   0.00000000E+00
         141          135   0.00000000E+00
         141          136  -0.19131143E-06
         141          137  -0.18229190E-06
         141          138   0.00000000E+00
         141          139   0.00000000E+00
         141          140  -0.86950685E-05
         141          151  -0.35206361E-04
         141          152   0.00000000E+00
         141          153   0.00000000E+00
         141          154   0.00000000E+00
         141          155   0.00000000E+00
         141          156  -0.28714265E-06
         141          157  -0.27360508E-06
         141          158   0.00000000E+00
         141          159   0.00000000E+00
         141          160  -0.13050579E-04
         142          142   0.61664984E+04
         142          141   0.00000000E+00
         142          143   0.00000000E+00
         142          144   0.63450217E+01
         142          145   0.63450217E+01
         142          146   0.00000000E+00
         142          147  -0.21136331E+02
         142          148   0.00000000E+00
         142          149   0.00000000E+00
         142          150   0.24834091E+03
         142          131   0.00000000E+00
         142          132  -0.14762870E-04
         142          133   0.00000000E+00
         142          134   0.00000000E+00
         142          135   0.00000000E+00
         142          136   0.00000000E+00
         142          137   0.00000000E+00
         142          138   0.00000000E+00
         142          139   0.00000000E+00
         142          140  -0.59474311E-06
         142          151   0.00000000E+00
         142          152  -0.22157848E-04
         142          153   0.00000000E+00
         142          154   0.00000000E+00
         142          155   0.00000000E+00
         142          156   0.00000000E+00
         142          157   0.00000000E+00
         142          158   0.00000000E+00
         142          159   0.00000000E+00
         142          160  -0.89266026E-06
         143          143   0.78082192E+03
         143          141   0.00000000E+00
         143          142   0.00000000E+00
         143          144   0.00000000E+00
         143          145   0.00000000E+00
         143          146   0.00000000E+00
         143          147   0.00000000E+00
         143          148   0.00000000E+00
         143          149   0.00000000E+00
         143          150   0.00000000E+00
         143          131   0.00000000E+00
         143          132   0.00000000E+00
         143          133  -0.18699636E-05
         143          134   0.00000000E+00
         143          135   0.00000000E+00
         143          136   0.00000000E+00
         143          137   0.00000000E+00
         143          138   0.00000000E+00
         143          139   0.00000000E+00
         143          140   0.00000000E+00
         143          151   0.00000000E+00
         143          152   0.00000000E+00
         143          153  -0.28066608E-05
         143          154   0.00000000E+00
         143          155   0.00000000E+00
         143          156   0.00000000E+00
         143          157   0.00000000E+00
         143          158   0.00000000E+00
         143          159   0.00000000E+00
         143          160   0.00000000E+00
         144          144   0.13409529E+04
         144          141   0.00000000E+00
         144          142   0.63443872E+01
         144          143   0.00000000E+00
         144          145   0.19035065E+02
         144          146   0.00000000E+00
         144          147  -0.65836821E+02
         144          148   0.00000000E+00
         144          149   0.00000000E+00
         144          150   0.00000000E+00
         144          131   0.00000000E+00
         144          132   0.00000000E+00
         144          133   0.00000000E+00
         144          134  -0.31658155E-05
         144          135   0.00000000E+00
         144          136   0.00000000E+00
         144          137   0.58143241E-08
         144          138   0.00000000E+00
         144          139   0.00000000E+00
         144          140   0.00000000E+00
         144          151   0.00000000E+00
         144          152   0.00000000E+00
         144          153   0.00000000E+00
         144          154  -0.47516275E-05
         144          155   0.00000000E+00
         144          156   0.00000000E+00
         144          157   0.87268201E-08
         144          158   0.00000000E+00
         144          159   0.00000000E+00
         144          160   0.00000000E+00
         145          145   0.19052837E+02
         145          141   0.00000000E+00
         145          142   0.63443872E+01
         145          143   0.00000000E+00
         145          144   0.19035065E+02
         145          146   0.00000000E+00
         145          147  -0.63477866E+02
         145          148   0.00000000E+00
         145          149   0.00000000E+00
         145          150   0.21795643E-05
         145          131   0.00000000E+00
         145          132   0.00000000E+00
         145          133   0.00000000E+00
         145          134   0.00000000E+00
         145          135  -0.42484262E-10
         145          136   0.00000000E+00
         145          137   0.16470994E-09
         145          138   0.00000000E+00
         145          139   0.00000000E+00
         145          140  -0.52197636E-14
         145          151   0.00000000E+00
         145          152   0.00000000E+00
         145          153   0.00000000E+00
         145          154   0.00000000E+00
         145          155  -0.63765367E-10
         145          156   0.00000000E+00
         145          157   0.24721601E-09
         145          158   0.00000000E+00
         145          159   0.00000000E+00
         145          160  -0.78344339E-14
         146          146   0.17074662E+04
         146          141   0.79884210E+02
         146          142   0.00000000E+00
         146          143   0.00000000E+00
         146          144   0.00000000E+00
         146          145   0.00000000E+00
         146          147   0.19543730E+04
         146          148   0.00000000E+00
         146          149   0.43198833E-04
         146          150   0.00000000E+00
         146          131  -0.19131143E-06
         146          132   0.00000000E+00
         146          133   0.00000000E+00
         146          134   0.00000000E+00
         146          135   0.00000000E+00
         146          136  -0.40891514E-05
         146          137  -0.46804606E-05
         146          138   0.00000000E+00
         146          139   0.00000000E+00
         146          140   0.00000000E+00
         146          151  -0.28714265E-06
         146          152   0.00000000E+00
         146          153   0.00000000E+00
         146          154   0.00000000E+00
         146          155   0.00000000E+00
         146          156  -0.61374783E-05
         146          157  -0.70249846E-05
         146          158   0.00000000E+00
         146          159   0.00000000E+00
         146          160   0.00000000E+00
         147          147   0.26723718E+04
         147          141   0.76117799E+02
         147          142  -0.21147957E+02
         147          143   0.00000000E+00
         147          144  -0.65878288E+02
         147          145  -0.63519108E+02
         147          146   0.19543478E+04
         147          148  -0.38887502E-04
         147          149  -0.12035985E+00
         147          150   0.49505150E-01
         147          131  -0.18229190E-06
         147          132   0.00000000E+00
         147          133   0.00000000E+00
         147          134   0.58149055E-08
         147          135   0.16475051E-09
         147          136  -0.46804003E-05
         147          137  -0.58937839E-05
         147          138   0.15713863E-13
         147          139   0.28826778E-09
         147          140  -0.11851393E-09
         147          151  -0.27360508E-06
         147          152   0.00000000E+00
         147          153   0.00000000E+00
         147          154   0.87276927E-08
         147          155   0.24727690E-09
         147          156  -0.70248941E-05
         147          157  -0.88460827E-05
         147          158   0.23585210E-13
         147          159   0.43266612E-09
         147          160  -0.17787962E-09
         148          148   0.66308262E-04
         148          141   0.00000000E+00
         148          142   0.00000000E+00
         148          143   0.00000000E+00
         148          144   0.00000000E+00
         148          145   0.00000000E+00
         148          146   0.00000000E+00
         148          147  -0.38896922E-04
         148          149  -0.14946245E-04
         148          150  -0.37051937E-04
         148          131   0.00000000E+00
         148          132   0.00000000E+00
         148          133   0.00000000E+00
         148          134   0.00000000E+00
         148          135   0.00000000E+00
         148          136   0.00000000E+00
         148          137   0.15715131E-13
         148          138  -0.23320538E-13
         148          139  -0.29226998E-14
         148          140   0.11296639E-13
         148          151   0.00000000E+00
         148          152   0.00000000E+00
         148          153   0.00000000E+00
         148          154   0.00000000E+00
         148          155   0.00000000E+00
         148          156   0.00000000E+00
         148          157   0.23587113E-13
         148          158  -0.35002201E-13
         148          159  -0.43867309E-14
         148          160   0.16955322E-13
         149          149   0.99356224E+02
         149          141   0.00000000E+00
         149          142   0.00000000E+00
         149          143   0.00000000E+00
         149          144   0.00000000E+00
         149          145   0.00000000E+00
         149          146   0.43198833E-04
         149          147  -0.12034781E+00
         149          148  -0.14942654E-04
         149          150   0.33536708E+02
         149          131   0.00000000E+00
         149          132   0.00000000E+00
         149          133   0.00000000E+00
         149          134   0.00000000E+00
         149          135   0.00000000E+00
         149          136   0.00000000E+00
         149          137   0.28823896E-09
         149          138  -0.29225902E-14
         149          139  -0.23794469E-06
         149          140  -0.80315886E-07
         149          151   0.00000000E+00
         149          152   0.00000000E+00
         149          153   0.00000000E+00
         149          154   0.00000000E+00
         149          155   0.00000000E+00
         149          156   0.00000000E+00
         149          157   0.43262286E-09
         149          158  -0.43865664E-14
         149          159  -0.35713531E-06
         149          160  -0.12054751E-06
         150          150   0.13484933E+05
         150          141   0.36307130E+04
         150          142   0.24834091E+03
         150          143   0.00000000E+00
         150          144   0.00000000E+00
         150          145   0.21795340E-05
         150          146   0.00000000E+00
         150          147   0.49505150E-01
         150          148  -0.37042339E-04
         150          149   0.33536708E+02
         150          131  -0.86950685E-05
         150          132  -0.59474311E-06
         150          133   0.00000000E+00
         150          134   0.00000000E+00
         150          135  -0.52196911E-14
         150          136   0.00000000E+00
         150          137  -0.11851393E-09
         150          138   0.11294945E-13
         150          139  -0.80315886E-07
         150          140  -0.32294600E-04
         150          151  -0.13050579E-04
         150          152  -0.89266026E-06
         150          153   0.00000000E+00
         150          154   0.00000000E+00
         150          155  -0.78343250E-14
         150          156   0.00000000E+00
         150          157  -0.17787962E-09
         150          158   0.16952779E-13
         150          159  -0.12054751E-06
         150          160  -0.48471527E-04
         151          151   0.97945219E+04
         151          152   0.00000000E+00
         151          153   0.00000000E+00
         151          154   0.00000000E+00
         151          155   0.00000000E+00
         151          156   0.79884210E+02
         151          157   0.76117799E+02
         151          158   0.00000000E+00
         151          159   0.00000000E+00
         151          160   0.36307130E+04
         151          141  -0.23456562E-04
         151          142   0.00000000E+00
         151          143   0.00000000E+00
         151          144   0.00000000E+00
         151          145   0.00000000E+00
         151          146  -0.19131143E-06
         151          147  -0.18229190E-06
         151          148   0.00000000E+00
         151          149   0.00000000E+00
         151          150  -0.86950685E-05
         151          161  -0.35206361E-04
         151          162   0.00000000E+00
         151          163   0.00000000E+00
         151          164   0.00000000E+00
         151          165   0.00000000E+00
         151          166  -0.28714265E-06
         151          167  -0.27360508E-06
         151          168   0.00000000E+00
         151          169   0.00000000E+00
         151          170  -0.13050579E-04
         152          152   0.61664984E+04
         152          151   0.00000000E+00
         152          153   0.00000000E+00
         152          154   0.63450217E+01
         152          155   0.63450217E+01
         152          156   0.00000000E+00
         152          157  -0.21136331E+02
         152          158   0.00000000E+00
         152          159   0.00000000E+00
         152          160   0.24834091E+03
         152          141   0.00000000E+00
         152          142  -0.14762870E-04
         152          143   0.00000000E+00
         152          144   0.00000000E+00
         152          145   0.00000000E+00
         152          146   0.00000000E+00
         152          147   0.00000000E+00
         152          148   0.00000000E+00
         152          149   0.00000000E+00
         152          150  -0.59474311E-06
         152          161   0.00000000E+00
         152          162  -0.22157848E-04
         152          163   0.00000000E+00
         152          164   0.00000000E+00
         152          165   0.00000000E+00
         152          166   0.00000000E+00
         152          167   0.00000000E+00
         152          168   0.00000000E+00
         152          169   0.00000000E+00
         152          170  -0.89266026E-06
         153          153   0.78082192E+03
         153          151   0.00000000E+00
         153          152   0.00000000E+00
         153          154   0.00000000E+00
         153          155   0.00000000E+00
         153          156   0.00000000E+00
         153          157   0.00000000E+00
         153          158   0.00000000E+00
         153          159   0.00000000E+00
         153          160   0.00000000E+00
         153          141   0.00000000E+00
         153          142   0.00000000E+00
         153          143  -0.18699636E-05
         153          144   0.00000000E+00
         153          145   0.00000000E+00
         153          146   0.00000000E+00
         153          147   0.00000000E+00
         153          148   0.00000000E+00
         153          149   0.00000000E+00
         153          150   0.00000000E+00
         153          161   0.00000000E+00
         153          162   0.00000000E+00
         153          163  -0.28066608E-05
         153          164   0.00000000E+00
         153          165   0.00000000E+00
         153          166   0.00000000E+00
         153          167   0.00000000E+00
         153          168   0.00000000E+00
         153          169   0.00000000E+00
         153          170   0.00000000E+00
         154          154   0.13409529E+04
         154          151   0.00000000E+00
         154          152   0.63443872E+01
         154          153   0.00000000E+00
         154          155   0.19035065E+02
         154          156   0.00000000E+00
         154          157  -0.65836821E+02
         154          158   0.00000000E+00
         154          159   0.00000000E+00
         154          160   0.00000000E+00
         154          141   0.00000000E+00
         154          142   0.00000000E+00
         154          143   0.00000000E+00
         154          144  -0.31658155E-05
         154          145   0.00000000E+00
         154          146   0.00000000E+00
         154          147   0.58143241E-08
         154          148   0.00000000E+00
         154          149   0.00000000E+00
         154          150   0.00000000E+00
         154          161   0.00000000E+00
         154          162   0.00000000E+00
         154          163   0.00000000E+00
         154          164  -0.47516275E-05
         154          165   0.00000000E+00
         154          166   0.00000000E+00
         154          167   0.87268201E-08
         154          168   0.00000000E+00
         154          169   0.00000000E+00
         154          170   0.00000000E+00
         155          155   0.19052837E+02
         155          151   0.00000000E+00
         155          152   0.63443872E+01
         155          153   0.00000000E+00
         155          154   0.19035065E+02
         155          156   0.00000000E+00
         155          157  -0.63477866E+02
         155          158   0.00000000E+00
         155          159   0.00000000E+00
         155          160   0.21795643E-05
         155          141   0.00000000E+00
         155          142   0.00000000E+00
         155          143   0.00000000E+00
         155          144   0.00000000E+00
         155          145  -0.42484262E-10
         155          146   0.00000000E+00
         155          147   0.16470994E-09
         155          148   0.00000000E+00
         155          149   0.00000000E+00
         155          150  -0.52197636E-14
         155          161   0.00000000E+00
         155          162   0.00000000E+00
         155          163   0.00000000E+00
         155          164   0.00000000E+00
         155          165  -0.63765367E-10
         155          166   0.00000000E+00
         155          167   0.24721601E-09
         155          168   0.00000000E+00
         155          169   0.00000000E+00
         155          170  -0.78344339E-14
         156          156   0.17074662E+04
         156          151   0.79884210E+02
         156          152   0.00000000E+00
         156          153   0.00000000E+00
         156          154   0.00000000E+00
         156          155   0.00000000E+00
         156          157   0.19543730E+04
         156          158   0.00000000E+00
         156          159   0.43198833E-04
         156          160   0.00000000E+00
         156          141  -0.19131143E-06
         156          142   0.00000000E+00
         156          143   0.00000000E+00
         156          144   0.00000000E+00
         156          145   0.00000000E+00
         156          146  -0.40891514E-05
         156          147  -0.46804606E-05
         156          148   0.00000000E+00
         156          149   0.00000000E+00
         156          150   0.00000000E+00
         156          161  -0.28714265E-06
         156          162   0.00000000E+00
         156          163   0.00000000E+00
         156          164   0.00000000E+00
         156          165   0.00000000E+00
         156          166  -0.61374783E-05
         156          167  -0.70249846E-05
         156          168   0.00000000E+00
         156          169   0.00000000E+00
         156          170   0.00000000E+00
         157          157   0.26723718E+04
         157          151   0.76117799E+02
         157          152  -0.21147957E+02
         157          153   0.00000000E+00
         157          154  -0.65878288E+02
         157          155  -0.63519108E+02
         157          156   0.19543478E+04
         157          158  -0.38887502E-04
         157          159  -0.12035985E+00
         157          160   0.49505150E-01
         157          141  -0.18229190E-06
         157          142   0.00000000E+00
         157          143   0.00000000E+00
         157          144   0.58149055E-08
         157          145   0.16475051E-09
         157          146  -0.46804003E-05
         157          147  -0.58937839E-05
         157          148   0.15713863E-13
         157          149   0.28826778E-09
         157          150  -0.11851393E-09
         157          161  -0.27360508E-06
         157          162   0.00000000E+00
         157          163   0.00000000E+00
         157          164   0.87276927E-08
         157          165   0.24727690E-09
         157          166  -0.70248941E-05
         157          167  -0.88460827E-05
         157          168   0.23585210E-13
         157          169   0.43266612E-09
         157          170  -0.17787962E-09
         158          158   0.66308262E-04
         158          151   0.00000000E+00
         158          152   0.00000000E+00
         158          153   0.00000000E+00
         158          154   0.00000000E+00
         158          155   0.00000000E+00
         158          156   0.00000000E+00
         158          157  -0.38896922E-04
         158          159  -0.14946245E-04
         158          160  -0.37051937E-04
         158          141   0.00000000E+00
         158          142   0.00000000E+00
         158          143   0.00000000E+00
         158          144   0.00000000E+00
         158          145   0.00000000E+00
         158          146   0.00000000E+00
         158          147   0.15715131E-13
         158          148  -0.23320538E-13
         158          149  -0.29226998E-14
         158          150   0.11296639E-13
         158          161   0.00000000E+00
         158          162   0.00000000E+00
         158          163   0.00000000E+00
         158          164   0.00000000E+00
         158          165   0.00000000E+00
         158          166   0.00000000E+00
         158          167   0.23587113E-13
         158          168  -0.35002201E-13
         158          169  -0.43867309E-14
         158          170   0.16955322E-13
         159          159   0.99356224E+02
         159          151   0.00000000E+00
         159          152   0.00000000E+00
         159          153   0.00000000E+00
         159          154   0.00000000E+00
         159          155   0.00000000E+00
         159          156   0.43198833E-04
         159          157  -0.12034781E+00
         159          158  -0.14942654E-04
         159          160   0.33536708E+02
         159          141   0.00000000E+00
         159          142   0.00000000E+00
         159          143   0.00000000E+00
         159          144   0.00000000E+00
         159          145   0.00000000E+00
         159          146   0.00000000E+00
         159          147   0.28823896E-09
         159          148  -0.29225902E-14
         159          149  -0.23794469E-06
         159          150  -0.80315886E-07
         159          161   0.00000000E+00
         159          162   0.00000000E+00
         159          163   0.00000000E+00
         159          164   0.00000000E+00
         159          165   0.00000000E+00
         159          166   0.00000000E+00
         159          167   0.43262286E-09
         159          168  -0.43865664E-14
         159          169  -0.35713531E-06
         159          170  -0.12054751E-06
         160          160   0.13484933E+05
         160          151   0.36307130E+04
         160          152   0.24834091E+03
         160          153   0.00000000E+00
         160          154   0.00000000E+00
         160          155   0.21795340E-05
         160          156   0.00000000E+00
         160          157   0.49505150E-01
         160          158  -0.37042339E-04
         160          159   0.33536708E+02
         160          141  -0.86950685E-05
         160          142  -0.59474311E-06
         160          143   0.00000000E+00
         160          144   0.00000000E+00
         160          145  -0.52196911E-14
         160          146   0.00000000E+00
         160          147  -0.11851393E-09
         160          148   0.11294945E-13
         160          149  -0.80315886E-07
         160          150  -0.32294600E-04
         160          161  -0.13050579E-04
         160          162  -0.89266026E-06
         160          163   0.00000000E+00
         160          164   0.00000000E+00
         160          165  -0.78343250E-14
         160          166   0.00000000E+00
         160          167  -0.17787962E-09
         160          168   0.16952779E-13
         160          169  -0.12054751E-06
         160          170  -0.48471527E-04
         161          161   0.97945219E+04
         161          162   0.00000000E+00
         161          163   0.00000000E+00
         161          164   0.00000000E+00
         161          165   0.00000000E+00
         161          166   0.79884210E+02
         161          167   0.76117799E+02
         161          168   0.00000000E+00
         161          169   0.00000000E+00
         161          170   0.36307130E+04
         161          151  -0.23456562E-04
         161          152   0.00000000E+00
         161          153   0.00000000E+00
         161          154   0.00000000E+00
         161          155   0.00000000E+00
         161          156  -0.19131143E-06
         161          157  -0.18229190E-06
         161          158   0.00000000E+00
         161          159   0.00000000E+00
         161          160  -0.86950685E-05
         161          171  -0.35206361E-04
         161          172   0.00000000E+00
         161          173   0.00000000E+00
         161          174   0.00000000E+00
         161          175   0.00000000E+00
         161          176  -0.28714265E-06
         161          177  -0.27360508E-06
         161          178   0.00000000E+00
         161          179   0.00000000E+00
         161          180  -0.13050579E-04
         162          162   0.61664984E+04
         162          161   0.00000000E+00
         162          163   0.00000000E+00
         162          164   0.63450217E+01
         162          165   0.63450217E+01
         162          166   0.00000000E+00
         162          167  -0.21136331E+02
         162          168   0.00000000E+00
         162          169   0.00000000E+00
         162          170   0.24834091E+03
         162          151   0.00000000E+00
         162          152  -0.14762870E-04
         162          153   0.00000000E+00
         162          154   0.00000000E+00
         162          155   0.00000000E+00
         162          156   0.00000000E+00
         162          157   0.00000000E+00
         162          158   0.00000000E+00
         162          159   0.00000000E+00
         162          160  -0.59474311E-06
         162          171   0.00000000E+00
         162          172  -0.22157848E-04
         162          173   0.00000000E+00
         162          174   0.00000000E+00
         162          175   0.00000000E+00
         162          176   0.00000000E+00
         162          177   0.00000000E+00
         162          178   0.00000000E+00
         162          179   0.00000000E+00
         162          180  -0.89266026E-06
         163          163   0.78082192E+03
         163          161   0.00000000E+00
         163          162   0.00000000E+00
         163          164   0.00000000E+00
         163          165   0.00000000E+00
         163          166   0.00000000E+00
         163          167   0.00000000E+00
         163          168   0.00000000E+00
         163          169   0.00000000E+00
         163          170   0.00000000E+00
         163          151   0.00000000E+00
         163          152   0.00000000E+00
         163          153  -0.18699636E-05
         163          154   0.00000000E+00
         163          155   0.00000000E+00
         163          156   0.00000000E+00
         163          157   0.00000000E+00
         163          158   0.00000000E+00
         163          159   0.00000000E+00
         163          160   0.00000000E+00
         163          171   0.00000000E+00
         163          172   0.00000000E+00
         163          173  -0.28066608E-05
         163          174   0.00000000E+00
         163          175   0.00000000E+00
         163          176   0.00000000E+00
         163          177   0.00000000E+00
         163          178   0.00000000E+00
         163          179   0.00000000E+00
         163          180   0.00000000E+00
         164          164   0.13409529E+04
         164          161   0.00000000E+00
         164          162   0.63443872E+01
         164          163   0.00000000E+00
         164          165   0.19035065E+02
         164          166   0.00000000E+00
         164          167  -0.65836821E+02
         164          168   0.00000000E+00
         164          169   0.00000000E+00
         164          170   0.00000000E+00
         164          151   0.00000000E+00
         164          152   0.00000000E+00
         164          153   0.00000000E+00
         164          154  -0.31658155E-05
         164          155   0.00000000E+00
         164          156   0.00000000E+00
         164          157   0.58143241E-08
         164          158   0.00000000E+00
         164          159   0.00000000E+00
         164          160   0.00000000E+00
         164          171   0.00000000E+00
         164          172   0.00000000E+00
         164          173   0.00000000E+00
         164          174  -0.47516275E-05
         164          175   0.00000000E+00
         164          176   0.00000000E+00
         164          177   0.87268201E-08
         164          178   0.00000000E+00
         164          179   0.00000000E+00
         164          180   0.00000000E+00
         165          165   0.19052837E+02
         165          161   0.00000000E+00
         165          162   0.63443872E+01
         165          163   0.00000000E+00
         165          164   0.19035065E+02
         165          166   0.00000000E+00
         165          167  -0.63477866E+02
         165          168   0.00000000E+00
         165          169   0.00000000E+00
         165          170   0.21795643E-05
         165          151   0.00000000E+00
         165          152   0.00000000E+00
         165          153   0.00000000E+00
         165          154   0.00000000E+00
         165          155  -0.42484262E-10
         165          156   0.00000000E+00
         165          157   0.16470994E-09
         165          158   0.00000000E+00
         165          159   0.00000000E+00
         165          160  -0.52197636E-14
         165          171   0.00000000E+00
         165          172   0.00000000E+00
         165          173   0.00000000E+00
         165          174   0.00000000E+00
         165          175  -0.63765367E-10
         165          176   0.00000000E+00
         165          177   0.24721601E-09
         165          178   0.00000000E+00
         165          179   0.00000000E+00
         165          180  -0.78344339E-14
         166          166   0.17074662E+04
         166          161   0.79884210E+02
         166          162   0.00000000E+00
         166          163   0.00000000E+00
         166          164   0.00000000E+00
         166          165   0.00000000E+00
         166          167   0.19543730E+04
         166          168   0.00000000E+00
         166          169   0.43198833E-04
         166          170   0.00000000E+00
         166          151  -0.19131143E-06
         166          152   0.00000000E+00
         166          153   0.00000000E+00
         166          154   0.00000000E+00
         166          155   0.00000000E+00
         166          156  -0.40891514E-05
         166          157  -0.46804606E-05
         166          158   0.00000000E+00
         166          159   0.00000000E+00
         166          160   0.00000000E+00
         166          171  -0.28714265E-06
         166          172   0.00000000E+00
         166          173   0.00000000E+00
         166          174   0.00000000E+00
         166          175   0.00000000E+00
         166          176  -0.61374783E-05
         166          177  -0.70249846E-05
         166          178   0.00000000E+00
         166          179   0.00000000E+00
         166          180   0.00000000E+00
         167          167   0.26723718E+04
         167          161   0.76117799E+02
         167          162  -0.21147957E+02
         167          163   0.00000000E+00
         167          164  -0.65878288E+02
         167          165  -0.63519108E+02
         167          166   0.19543478E+04
         167          168  -0.38887502E-04
         167          169  -0.12035985E+00
         167          170   0.49505150E-01
         167          151  -0.18229190E-06
         167          152   0.00000000E+00
         167          153   0.00000000E+00
         167          154   0.58149055E-08
         167          155   0.16475051E-09
         167          156  -0.46804003E-05
         167          157  -0.58937839E-05
         167          158   0.15713863E-13
         167          159   0.28826778E-09
         167          160  -0.11851393E-09
         167          171  -0.27360508E-06
         167          172   0.00000000E+00
         167          173   0.00000000E+00
         167          174   0.87276927E-08
         167          175   0.24727690E-09
         167          176  -0.70248941E-05
         167          177  -0.88460827E-05
         167          178   0.23585210E-13
         167          179   0.43266612E-09
         167          180  -0.17787962E-09
         168          168   0.66308262E-04
         168          161   0.00000000E+00
         168          162   0.00000000E+00
         168          163   0.00000000E+00
         168          164   0.00000000E+00
         168          165   0.00000000E+00
         168          166   0.00000000E+00
         168          167  -0.38896922E-04
         168          169  -0.14946245E-04
         168          170  -0.37051937E-04
         168          151   0.00000000E+00
         168          152   0.00000000E+00
         168          153   0.00000000E+00
         168          154   0.00000000E+00
         168          155   0.00000000E+00
         168          156   0.00000000E+00
         168          157   0.15715131E-13
         168          158  -0.23320538E-13
         168          159  -0.29226998E-14
         168          160   0.11296639E-13
         168          171   0.00000000E+00
         168          172   0.00000000E+00
         168          173   0.00000000E+00
         168          174   0.00000000E+00
         168          175   0.00000000E+00
         168          176   0.00000000E+00
         168          177   0.23587113E-13
         168          178  -0.35002201E-13
         168          179  -0.43867309E-14
         168          180   0.16955322E-13
         169          169   0.99356224E+02
         169          161   0.00000000E+00
         169          162   0.00000000E+00
         169          163   0.00000000E+00
         169          164   0.00000000E+00
         169          165   0.00000000E+00
         169          166   0.43198833E-04
         169          167  -0.12034781E+00
         169          168  -0.14942654E-04
         169          170   0.33536708E+02
         169          151   0.00000000E+00
         169          152   0.00000000E+00
         169          153   0.00000000E+00
         169          154   0.00000000E+00
         169          155   0.00000000E+00
         169          156   0.00000000E+00
         169          157   0.28823896E-09
         169          158  -0.29225902E-14
         169          159  -0.23794469E-06
         169          160  -0.80315886E-07
         169          171   0.00000000E+00
         169          172   0.00000000E+00
         169          173   0.00000000E+00
         169          174   0.00000000E+00
         169          175   0.00000000E+00
         169          176   0.00000000E+00
         169          177   0.43262286E-09
         169          178  -0.43865664E-14
         169          179  -0.35713531E-06
         169          180  -0.12054751E-06
         170          170   0.13484933E+05
         170          161   0.36307130E+04
         170          162   0.24834091E+03
         170          163   0.00000000E+00
         170          164   0.00000000E+00
         170          165   0.21795340E-05
         170          166   0.00000000E+00
         170          167   0.49505150E-01
         170          168  -0.37042339E-04
         170          169   0.33536708E+02
         170          151  -0.86950685E-05
         170          152  -0.59474311E-06
         170          153   0.00000000E+00
         170          154   0.00000000E+00
         170          155  -0.52196911E-14
         170          156   0.00000000E+00
         170          157  -0.11851393E-09
         170          158   0.11294945E-13
         170          159  -0.80315886E-07
         170          160  -0.32294600E-04
         170          171  -0.13050579E-04
         170          172  -0.89266026E-06
         170          173   0.00000000E+00
         170          174   0.00000000E+00
         170          175  -0.78343250E-14
         170          176   0.00000000E+00
         170          177  -0.17787962E-09
         170          178   0.16952779E-13
         170          179  -0.12054751E-06
         170          180  -0.48471527E-04
         171          171   0.97945219E+04
         171          172   0.00000000E+00
         171          173   0.00000000E+00
         171          174   0.00000000E+00
         171          175   0.00000000E+00
         171          176   0.79884210E+02
         171          177   0.76117799E+02
         171          178   0.00000000E+00
         171          179   0.00000000E+00
         171          180   0.36307130E+04
         171          161  -0.23456562E-04
         171          162   0.00000000E+00
         171          163   0.00000000E+00
         171          164   0.00000000E+00
         171          165   0.00000000E+00
         171          166  -0.19131143E-06
         171          167  -0.18229190E-06
         171          168   0.00000000E+00
         171          169   0.00000000E+00
         171          170  -0.86950685E-05
         171          181  -0.35206361E-04
         171          182   0.00000000E+00
         171          183   0.00000000E+00
         171          184   0.00000000E+00
         171          185   0.00000000E+00
         171          186  -0.28714265E-06
         171          187  -0.27360508E-06
         171          188   0.00000000E+00
         171          189   0.00000000E+00
         171          190  -0.13050579E-04
         172          172   0.61664984E+04
         172          171   0.00000000E+00
         172          173   0.00000000E+00
         172          174   0.63450217E+01
         172          175   0.63450217E+01
         172          176   0.00000000E+00
         172          177  -0.21136331E+02
         172          178   0.00000000E+00
         172          179   0.00000000E+00
         172          180   0.24834091E+03
         172          161   0.00000000E+00
         172          162  -0.14762870E-04
         172          163   0.00000000E+00
         172          164   0.00000000E+00
         172          165   0.00000000E+00
         172          166   0.00000000E+00
         172          167   0.00000000E+00
         172          168   0.00000000E+00
         172          169   0.00000000E+00
         172          170  -0.59474311E-06
         172          181   0.00000000E+00
         172          182  -0.22157848E-04
         172          183   0.00000000E+00
         172          184   0.00000000E+00
         172          185   0.00000000E+00
         172          186   0.00000000E+00
         172          187   0.00000000E+00
         172          188   0.00000000E+00
         172          189   0.00000000E+00
         172          190  -0.89266026E-06
         173          173   0.78082192E+03
         173          171   0.00000000E+00
         173          172   0.00000000E+00
         173          174   0.00000000E+00
         173          175   0.00000000E+00
         173          176   0.00000000E+00
         173          177   0.00000000E+00
         173          178   0.00000000E+00
         173          179   0.00000000E+00
         173          180   0.00000000E+00
         173          161   0.00000000E+00
         173          162   0.00000000E+00
         173          163  -0.18699636E-05
         173          164   0.00000000E+00
         173          165   0.00000000E+00
         173          166   0.00000000E+00
         173          167   0.00000000E+00
         173          168   0.00000000E+00
         173          169   0.00000000E+00
         173          170   0.00000000E+00
         173          181   0.00000000E+00
         173          182   0.00000000E+00
         173          183  -0.28066608E-05
         173          184   0.00000000E+00
         173          185   0.00000000E+00
         173          186   0.00000000E+00
         173          187   0.00000000E+00
         173          188   0.00000000E+00
         173          189   0.00000000E+00
         173          190   0.00000000E+00
         174          174   0.13409529E+04
         174          171   0.00000000E+00
         174          172   0.63443872E+01
         174          173   0.00000000E+00
         174          175   0.19035065E+02
         174          176   0.00000000E+00
         174          177  -0.65836821E+02
         174          178   0.00000000E+00
         174          179   0.00000000E+00
         174          180   0.00000000E+00
         174          161   0.00000000E+00
         174          162   0.00000000E+00
         174          163   0.00000000E+00
         174          164  -0.31658155E-05
         174          165   0.00000000E+00
         174          166   0.00000000E+00
         174          167   0.58143241E-08
         174          168   0.00000000E+00
         174          169   0.00000000E+00
         174          170   0.00000000E+00
         174          181   0.00000000E+00
         174          182   0.00000000E+00
         174          183   0.00000000E+00
         174          184  -0.47516275E-05
         174          185   0.00000000E+00
         174          186   0.00000000E+00
         174          187   0.87268201E-08
         174          188   0.00000000E+00
         174          189   0.00000000E+00
         174          190   0.00000000E+00
         175          175   0.19052837E+02
         175          171   0.00000000E+00
         175          172   0.63443872E+01
         175          173   0.00000000E+00
         175          174   0.19035065E+02
         175          176   0.00000000E+00
         175          177  -0.63477866E+02
         175          178   0.00000000E+00
         175          179   0.00000000E+00
         175          180   0.21795643E-05
         175          161   0.00000000E+00
         175          162   0.00000000E+00
         175          163   0.00000000E+00
         175          164   0.00000000E+00
         175          165  -0.42484262E-10
         175          166   0.00000000E+00
         175          167   0.16470994E-09
         175          168   0.00000000E+00
         175          169   0.00000000E+00
         175          170  -0.52197636E-14
         175          181   0.00000000E+00
         175          182   0.00000000E+00
         175          183   0.00000000E+00
         175          184   0.00000000E+00
         175          185  -0.63765367E-10
         175          186   0.00000000E+00
         175          187   0.24721601E-09
         175          188   0.00000000E+00
         175          189   0.00000000E+00
         175          190  -0.78344339E-14
         176          176   0.17074662E+04
         176          171   0.79884210E+02
         176          172   0.00000000E+00
         176          173   0.00000000E+00
         176          174   0.00000000E+00
         176          175   0.00000000E+00
         176          177   0.19543730E+04
         176          178   0.00000000E+00
         176          179   0.43198833E-04
         176          180   0.00000000E+00
         176          161  -0.19131143E-06
         176          162   0.00000000E+00
         176          163   0.00000000E+00
         176          164   0.00000000E+00
         176          165   0.00000000E+00
         176          166  -0.40891514E-05
         176          167  -0.46804606E-05
         176          168   0.00000000E+00
         176          169   0.00000000E+00
         176          170   0.00000000E+00
         176          181  -0.28714265E-06
         176          182   0.00000000E+00
         176          183   0.00000000E+00
         176          184   0.00000000E+00
         176          185   0.00000000E+00
         176          186  -0.61374783E-05
         176          187  -0.70249846E-05
         176          188   0.00000000E+00
         176          189   0.00000000E+00
         176          190   0.00000000E+00
         177          177   0.26723718E+04
         177          171   0.76117799E+02
         177          172  -0.21147957E+02
         177          173   0.00000000E+00
         177          174  -0.65878288E+02
         177          175  -0.63519108E+02
         177          176   0.19543478E+04
         177          178  -0.38887502E-04
         177          179  -0.12035985E+00
         177          180   0.49505150E-01
         177          161  -0.18229190E-06
         177          162   0.00000000E+00
         177          163   0.00000000E+00
         177          164   0.58149055E-08
         177          165   0.16475051E-09
         177          166  -0.46804003E-05
         177          167  -0.58937839E-05
         177          168   0.15713863E-13
         177          169   0.28826778E-09
         177          170  -0.11851393E-09
         177          181  -0.27360508E-06
         177          182   0.00000000E+00
         177          183   0.00000000E+00
         177          184   0.87276927E-08
         177          185   0.24727690E-09
         177          186  -0.70248941E-05
         177          187  -0.88460827E-05
         177          188   0.23585210E-13
         177          189   0.43266612E-09
         177          190  -0.17787962E-09
         178          178   0.66308262E-04
         178          171   0.00000000E+00
         178          172   0.00000000E+00
         178          173   0.00000000E+00
         178          174   0.00000000E+00
         178          175   0.00000000E+00
         178          176   0.00000000E+00
         178          177  -0.38896922E-04
         178          179  -0.14946245E-04
         178          180  -0.37051937E-04
         178          161   0.00000000E+00
         178          162   0.00000000E+00
         178          163   0.00000000E+00
         178          164   0.00000000E+00
         178          165   0.00000000E+00
         178          166   0.00000000E+00
         178          167   0.15715131E-13
         178          168  -0.23320538E-13
         178          169  -0.29226998E-14
         178          170   0.11296639E-13
         178          181   0.00000000E+00
         178          182   0.00000000E+00
         178          183   0.00000000E+00
         178          184   0.00000000E+00
         178          185   0.00000000E+00
         178          186   0.00000000E+00
         178          187   0.23587113E-13
         178          188  -0.35002201E-13
         178          189  -0.43867309E-14
         178          190   0.16955322E-13
         179          179   0.99356224E+02
         179          171   0.00000000E+00
         179          172   0.00000000E+00
         179          173   0.00000000E+00
         179          174   0.00000000E+00
         179          175   0.00000000E+00
         179          176   0.43198833E-04
         179          177  -0.12034781E+00
         179          178  -0.14942654E-04
         179          180   0.33536708E+02
         179          161   0.00000000E+00
         179          162   0.00000000E+00
         179          163   0.00000000E+00
         179          164   0.00000000E+00
         179          165   0.00000000E+00
         179          166   0.00000000E+00
         179          167   0.28823896E-09
         179          168  -0.29225902E-14
         179          169  -0.23794469E-06
         179          170  -0.80315886E-07
         179          181   0.00000000E+00
         179          182   0.00000000E+00
         179          183   0.00000000E+00
         179          184   0.00000000E+00
         179          185   0.00000000E+00
         179          186   0.00000000E+00
         179          187   0.43262286E-09
         179          188  -0.43865664E-14
         179          189  -0.35713531E-06
         179          190  -0.12054751E-06
         180          180   0.13484933E+05
         180          171   0.36307130E+04
         180          172   0.24834091E+03
         180          173   0.00000000E+00
         180          174   0.00000000E+00
         180          175   0.21795340E-05
         180          176   0.00000000E+00
         180          177   0.49505150E-01
         180          178  -0.37042339E-04
         180          179   0.33536708E+02
         180          161  -0.86950685E-05
         180          162  -0.59474311E-06
         180          163   0.00000000E+00
         180          164   0.00000000E+00
         180          165  -0.52196911E-14
         180          166   0.00000000E+00
         180          167  -0.11851393E-09
         180          168   0.11294945E-13
         180          169  -0.80315886E-07
         180          170  -0.32294600E-04
         180          181  -0.13050579E-04
         180          182  -0.89266026E-06
         180          183   0.00000000E+00
         180          184   0.00000000E+00
         180          185  -0.78343250E-14
         180          186   0.00000000E+00
         180          187  -0.17787962E-09
         180          188   0.16952779E-13
         180          189  -0.12054751E-06
         180          190  -0.48471527E-04
         181          181   0.97945219E+04
         181          182   0.00000000E+00
         181          183   0.00000000E+00
         181          184   0.00000000E+00
         181          185   0.00000000E+00
         181          186   0.79884210E+02
         181          187   0.76117799E+02
         181          188   0.00000000E+00
         181          189   0.00000000E+00
         181          190   0.36307130E+04
         181          171  -0.23456562E-04
         181          172   0.00000000E+00
         181          173   0.00000000E+00
         181          174   0.00000000E+00
         181          175   0.00000000E+00
         181          176  -0.19131143E-06
         181          177  -0.18229190E-06
         181          178   0.00000000E+00
         181          179   0.00000000E+00
         181          180  -0.86950685E-05
         181          191  -0.35206361E-04
         181          192   0.00000000E+00
         181          193   0.00000000E+00
         181          194   0.00000000E+00
         181          195   0.00000000E+00
         181          196  -0.28714265E-06
         181          197  -0.27360508E-06
         181          198   0.00000000E+00
         181          199   0.00000000E+00
         181          200  -0.13050579E-04
         182          182   0.61664984E+04
         182          181   0.00000000E+00
         182          183   0.00000000E+00
         182          184   0.63450217E+01
         182          185   0.63450217E+01
         182          186   0.00000000E+00
         182          187  -0.21136331E+02
         182          188   0.00000000E+00
         182          189   0.00000000E+00
         182          190   0.24834091E+03
         182          171   0.00000000E+00
         182          172  -0.14762870E-04
         182          173   0.00000000E+00
         182          174   0.00000000E+00
         182          175   0.00000000E+00
         182          176   0.00000000E+00
         182          177   0.00000000E+00
         182          178   0.00000000E+00
         182          179   0.00000000E+00
         182          180  -0.59474311E-06
         182          191   0.00000000E+00
         182          192  -0.22157848E-04
         182          193   0.00000000E+00
         182          194   0.00000000E+00
         182          195   0.00000000E+00
         182          196   0.00000000E+00
         182          197   0.00000000E+00
         182          198   0.00000000E+00
         182          199   0.00000000E+00
         182          200  -0.89266026E-06
         183          183   0.78082192E+03
         183          181   0.00000000E+00
         183          182   0.00000000E+00
         183          184   0.00000000E+00
         183          185   0.00000000E+00
         183          186   0.00000000E+00
         183          187   0.00000000E+00
         183          188   0.00000000E+00
         183          189   0.00000000E+00
         183          190   0.00000000E+00
         183          171   0.00000000E+00
         183          172   0.00000000E+00
         183          173  -0.18699636E-05
         183          174   0.00000000E+00
         183          175   0.00000000E+00
         183          176   0.00000000E+00
         183          177   0.00000000E+00
         183          178   0.00000000E+00
         183          179   0.00000000E+00
         183          180   0.00000000E+00
         183          191   0.00000000E+00
         183          192   0.00000000E+00
         183          193  -0.28066608E-05
         183          194   0.00000000E+00
         183          195   0.00000000E+00
         183          196   0.00000000E+00
         183          197   0.00000000E+00
         183          198   0.00000000E+00
         183          199   0.00000000E+00
         183          200   0.00000000E+00
         184          184   0.13409529E+04
         184          181   0.00000000E+00
         184          182   0.63443872E+01
         184          183   0.00000000E+00
         184          185   0.19035065E+02
         184          186   0.00000000E+00
         184          187  -0.65836821E+02
         184          188   0.00000000E+00
         184          189   0.00000000E+00
         184          190   0.00000000E+00
         184          171   0.00000000E+00
         184          172   0.00000000E+00
         184          173   0.00000000E+00
         184          174  -0.31658155E-05
         184          175   0.00000000E+00
         184          176   0.00000000E+00
         184          177   0.58143241E-08
         184          178   0.00000000E+00
         184          179   0.00000000E+00
         184          180   0.00000000E+00
         184          191   0.00000000E+00
         184          192   0.00000000E+00
         184          193   0.00000000E+00
         184          194  -0.47516275E-05
         184          195   0.00000000E+00
         184          196   0.00000000E+00
         184          197   0.87268201E-08
         184          198   0.00000000E+00
         184          199   0.00000000E+00
         184          200   0.00000000E+00
         185          185   0.19052837E+02
         185          181   0.00000000E+00
         185          182   0.63443872E+01
         185          183   0.00000000E+00
         185          184   0.19035065E+02
         185          186   0.00000000E+00
         185          187  -0.63477866E+02
         185          188   0.00000000E+00
         185          189   0.00000000E+00
         185          190   0.21795643E-05
         185          171   0.00000000E+00
         185          172   0.00000000E+00
         185          173   0.00000000E+00
         185          174   0.00000000E+00
         185          175  -0.42484262E-10
         185          176   0.00000000E+00
         185          177   0.16470994E-09
         185          178   0.00000000E+00
         185          179   0.00000000E+00
         185          180  -0.52197636E-14
         185          191   0.00000000E+00
         185          192   0.00000000E+00
         185          193   0.00000000E+00
         185          194   0.00000000E+00
         185          195  -0.63765367E-10
         185          196   0.00000000E+00
         185          197   0.24721601E-09
         185          198   0.00000000E+00
         185          199   0.00000000E+00
         185          200  -0.78344339E-14
         186          186   0.17074662E+04
         186          181   0.79884210E+02
         186          182   0.00000000E+00
         186          183   0.00000000E+00
         186          184   0.00000000E+00
         186          185   0.00000000E+00
         186          187   0.19543730E+04
         186          188   0.00000000E+00
         186          189   0.43198833E-04
         186          190   0.00000000E+00
         186          171  -0.19131143E-06
         186          172   0.00000000E+00
         186          173   0.00000000E+00
         186          174   0.00000000E+00
         186          175   0.00000000E+00
         186          176  -0.40891514E-05
         186          177  -0.46804606E-05
         186          178   0.00000000E+00
         186          179   0.00000000E+00
         186          180   0.00000000E+00
         186          191  -0.28714265E-06
         186          192   0.00000000E+00
         186          193   0.00000000E+00
         186          194   0.00000000E+00
         186          195   0.00000000E+00
         186          196  -0.61374783E-05
         186          197  -0.70249846E-05
         186          198   0.00000000E+00
         186          199   0.00000000E+00
         186          200   0.00000000E+00
         187          187   0.26723718E+04
         187          181   0.76117799E+02
         187          182  -0.21147957E+02
         187          183   0.00000000E+00
         187          184  -0.65878288E+02
         187          185  -0.63519108E+02
         187          186   0.19543478E+04
         187          188  -0.38887502E-04
         187          189  -0.12035985E+00
         187          190   0.49505150E-01
         187          171  -0.18229190E-06
         187          172   0.00000000E+00
         187          173   0.00000000E+00
         187          174   0.58149055E-08
         187          175   0.16475051E-09
         187          176  -0.46804003E-05
         187          177  -0.58937839E-05
         187          178   0.15713863E-13
         187          179   0.28826778E-09
         187          180  -0.11851393E-09
         187          191  -0.27360508E-06
         187          192   0.00000000E+00
         187          193   0.00000000E+00
         187          194   0.87276927E-08
         187          195   0.24727690E-09
         187          196  -0.70248941E-05
         187          197  -0.88460827E-05
         187          198   0.23585210E-13
         187          199   0.43266612E-09
         187          200  -0.17787962E-09
         188          188   0.66308262E-04
         188          181   0.00000000E+00
         188          182   0.00000000E+00
         188          183   0.00000000E+00
         188          184   0.00000000E+00
         188          185   0.00000000E+00
         188          186   0.00000000E+00
         188          187  -0.38896922E-04
         188          189  -0.14946245E-04
         188          190  -0.37051937E-04
         188          171   0.00000000E+00
         188          172   0.00000000E+00
         188          173   0.00000000E+00
         188          174   0.00000000E+00
         188          175   0.00000000E+00
         188          176   0.00000000E+00
         188          177   0.15715131E-13
         188          178  -0.23320538E-13
         188          179  -0.29226998E-14
         188          180   0.11296639E-13
         188          191   0.00000000E+00
         188          192   0.00000000E+00
         188          193   0.00000000E+00
         188          194   0.00000000E+00
         188          195   0.00000000E+00
         188          196   0.00000000E+00
         188          197   0.23587113E-13
         188          198  -0.35002201E-13
         188          199  -0.43867309E-14
         188          200   0.16955322E-13
         189          189   0.99356224E+02
         189          181   0.00000000E+00
         189          182   0.00000000E+00
         189          183   0.00000000E+00
         189          184   0.00000000E+00
         189          185   0.00000000E+00
         189          186   0.43198833E-04
         189          187  -0.12034781E+00
         189          188  -0.14942654E-04
         189          190   0.33536708E+02
         189          171   0.00000000E+00
         189          172   0.00000000E+00
         189          173   0.00000000E+00
         189          174   0.00000000E+00
         189          175   0.00000000E+00
         189          176   0.00000000E+00
         189          177   0.28823896E-09
         189          178  -0.29225902E-14
         189          179  -0.23794469E-06
         189          180  -0.80315886E-07
         189          191   0.00000000E+00
         189          192   0.00000000E+00
         189          193   0.00000000E+00
         189          194   0.00000000E+00
         189          195   0.00000000E+00
         189          196   0.00000000E+00
         189          197   0.43262286E-09
         189          198  -0.43865664E-14
         189          199  -0.35713531E-06
         189          200  -0.12054751E-06
         190          190   0.13484933E+05
         190          181   0.36307130E+04
         190          182   0.24834091E+03
         190          183   0.00000000E+00
         190          184   0.00000000E+00
         190          185   0.21795340E-05
         190          186   0.00000000E+00
         190          187   0.49505150E-01
         190          188  -0.37042339E-04
         190          189   0.33536708E+02
         190          171  -0.86950685E-05
         190          172  -0.59474311E-06
         190          173   0.00000000E+00
         190          174   0.00000000E+00
         190          175  -0.52196911E-14
         190          176   0.00000000E+00
         190          177  -0.11851393E-09
         190          178   0.11294945E-13
         190          179  -0.80315886E-07
         190          180  -0.32294600E-04
         190          191  -0.13050579E-04
         190          192  -0.89266026E-06
         190          193   0.00000000E+00
         190          194   0.00000000E+00
         190          195  -0.78343250E-14
         190          196   0.00000000E+00
         190          197  -0.17787962E-09
         190          198   0.16952779E-13
         190          199  -0.12054751E-06
         190          200  -0.48471527E-04
         191          191   0.97945219E+04
         191          192   0.00000000E+00
         191          193   0.00000000E+00
         191          194   0.00000000E+00
         191          195   0.00000000E+00
         191          196   0.79884210E+02
         191          197   0.76117799E+02
         191          198   0.00000000E+00
         191          199   0.00000000E+00
         191          200   0.36307130E+04
         191          181  -0.23456562E-04
         191          182   0.00000000E+00
         191          183   0.00000000E+00
         191          184   0.00000000E+00
         191          185   0.00000000E+00
         191          186  -0.19131143E-06
         191          187  -0.18229190E-06
         191          188   0.00000000E+00
         191          189   0.00000000E+00
         191          190  -0.86950685E-05
         191          201  -0.35206361E-04
         191          202   0.00000000E+00
         191          203   0.00000000E+00
         191          204   0.00000000E+00
         191          205   0.00000000E+00
         191          206  -0.28714265E-06
         191          207  -0.27360508E-06
         191          208   0.00000000E+00
         191          209   0.00000000E+00
         191          210  -0.13050579E-04
         192          192   0.61664984E+04
         192          191   0.00000000E+00
         192          193   0.00000000E+00
         192          194   0.63450217E+01
         192          195   0.63450217E+01
         192          196   0.00000000E+00
         192          197  -0.21136331E+02
         192          198   0.00000000E+00
         192          199   0.00000000E+00
         192          200   0.24834091E+03
         192          181   0.00000000E+00
         192          182  -0.14762870E-04
         192          183   0.00000000E+00
         192          184   0.00000000E+00
         192          185   0.00000000E+00
         192          186   0.00000000E+00
         192          187   0.00000000E+00
         192          188   0.00000000E+00
         192          189   0.00000000E+00
         192          190  -0.59474311E-06
         192          201   0.00000000E+00
         192          202  -0.22157848E-04
         192          203   0.00000000E+00
         192          204   0.00000000E+00
         192          205   0.00000000E+00
         192          206   0.00000000E+00
         192          207   0.00000000E+00
         192          208   0.00000000E+00
         192          209   0.00000000E+00
         192          210  -0.89266026E-06
         193          193   0.78082192E+03
         193          191   0.00000000E+00
         193          192   0.00000000E+00
         193          194   0.00000000E+00
         193          195   0.00000000E+00
         193          196   0.00000000E+00
         193          197   0.00000000E+00
         193          198   0.00000000E+00
         193          199   0.00000000E+00
         193          200   0.00000000E+00
         193          181   0.00000000E+00
         193          182   0.00000000E+00
         193          183  -0.18699636E-05
         193          184   0.00000000E+00
         193          185   0.00000000E+00
         193          186   0.00000000E+00
         193          187   0.00000000E+00
         193          188   0.00000000E+00
         193          189   0.00000000E+00
         193          190   0.00000000E+00
         193          201   0.00000000E+00
         193          202   0.00000000E+00
         193          203  -0.28066608E-05
         193          204   0.00000000E+00
         193          205   0.00000000E+00
         193          206   0.00000000E+00
         193          207   0.00000000E+00
         193          208   0.00000000E+00
         193          209   0.00000000E+00
         193          210   0.00000000E+00
         194          194   0.13409529E+04
         194          191   0.00000000E+00
         194          192   0.63443872E+01
         194          193   0.00000000E+00
         194          195   0.19035065E+02
         194          196   0.00000000E+00
         194          197  -0.65836821E+02
         194          198   0.00000000E+00
         194          199   0.00000000E+00
         194          200   0.00000000E+00
         194          181   0.00000000E+00
         194          182   0.00000000E+00
         194          183   0.00000000E+00
         194          184  -0.31658155E-05
         194          185   0.00000000E+00
         194          186   0.00000000E+00
         194          187   0.58143241E-08
         194          188   0.00000000E+00
         194          189   0.00000000E+00
         194          190   0.00000000E+00
         194          201   0.00000000E+00
         194          202   0.00000000E+00
         194          203   0.00000000E+00
         194          204  -0.47516275E-05
         194          205   0.00000000E+00
         194          206   0.00000000E+00
         194          207   0.87268201E-08
         194          208   0.00000000E+00
         194          209   0.00000000E+00
         194          210   0.00000000E+00
         195          195   0.19052837E+02
         195          191   0.00000000E+00
         195          192   0.63443872E+01
         195          193   0.00000000E+00
         195          194   0.19035065E+02
         195          196   0.00000000E+00
         195          197  -0.63477866E+02
         195          198   0.00000000E+00
         195          199   0.00000000E+00
         195          200   0.21795643E-05
         195          181   0.00000000E+00
         195          182   0.00000000E+00
         195          183   0.00000000E+00
         195          184   0.00000000E+00
         195          185  -0.42484262E-10
         195          186   0.00000000E+00
         195          187   0.16470994E-09
         195          188   0.00000000E+00
         195          189   0.00000000E+00
         195          190  -0.52197636E-14
         195          201   0.00000000E+00
         195          202   0.00000000E+00
         195          203   0.00000000E+00
         195          204   0.00000000E+00
         195          205  -0.63765367E-10
         195          206   0.00000000E+00
         195          207   0.24721601E-09
         195          208   0.00000000E+00
         195          209   0.00000000E+00
         195          210  -0.78344339E-14
         196          196   0.17074662E+04
         196          191   0.79884210E+02
         196          192   0.00000000E+00
         196          193   0.00000000E+00
         196          194   0.00000000E+00
         196          195   0.00000000E+00
         196          197   0.19543730E+04
         196          198   0.00000000E+00
         196          199   0.43198833E-04
         196          200   0.00000000E+00
         196          181  -0.19131143E-06
         196          182   0.00000000E+00
         196          183   0.00000000E+00
         196          184   0.00000000E+00
         196          185   0.00000000E+00
         196          186  -0.40891514E-05
         196          187  -0.46804606E-05
         196          188   0.00000000E+00
         196          189   0.00000000E+00
         196          190   0.00000000E+00
         196          201  -0.28714265E-06
         196          202   0.00000000E+00
         196          203   0.00000000E+00
         196          204   0.00000000E+00
         196          205   0.00000000E+00
         196          206  -0.61374783E-05
         196          207  -0.70249846E-05
         196          208   0.00000000E+00
         196          209   0.00000000E+00
         196          210   0.00000000E+00
         197          197   0.26723718E+04
         197          191   0.76117799E+02
         197          192  -0.21147957E+02
         197          193   0.00000000E+00
         197          194  -0.65878288E+02
         197          195  -0.63519108E+02
         197          196   0.19543478E+04
         197          198  -0.38887502E-04
         197          199  -0.12035985E+00
         197          200   0.49505150E-01
         197          181  -0.18229190E-06
         197          182   0.00000000E+00
         197          183   0.00000000E+00
         197          184   0.58149055E-08
         197          185   0.16475051E-09
         197          186  -0.46804003E-05
         197          187  -0.58937839E-05
         197          188   0.15713863E-13
         197          189   0.28826778E-09
         197          190  -0.11851393E-09
         197          201  -0.27360508E-06
         197          202   0.00000000E+00
         197          203   0.00000000E+00
         197          204   0.87276927E-08
         197          205   0.24727690E-09
         197          206  -0.70248941E-05
         197          207  -0.88460827E-05
         197          208   0.23585210E-13
         197          209   0.43266612E-09
         197          210  -0.17787962E-09
         198          198   0.66308262E-04
         198          191   0.00000000E+00
         198          192   0.00000000E+00
         198          193   0.00000000E+00
         198          194   0.00000000E+00
         198          195   0.00000000E+00
         198          196   0.00000000E+00
         198          197  -0.38896922E-04
         198          199  -0.14946245E-04
         198          200  -0.37051937E-04
         198          181   0.00000000E+00
         198          182   0.00000000E+00
         198          183   0.00000000E+00
         198          184   0.00000000E+00
         198          185   0.00000000E+00
         198          186   0.00000000E+00
         198          187   0.15715131E-13
         198          188  -0.23320538E-13
         198          189  -0.29226998E-14
         198          190   0.11296639E-13
         198          201   0.00000000E+00
         198          202   0.00000000E+00
         198          203   0.00000000E+00
         198          204   0.00000000E+00
         198          205   0.00000000E+00
         198          206   0.00000000E+00
         198          207   0.23587113E-13
         198          208  -0.35002201E-13
         198          209  -0.43867309E-14
         198          210   0.16955322E-13
         199          199   0.99356224E+02
         199          191   0.00000000E+00
         199          192   0.00000000E+00
         199          193   0.00000000E+00
         199          194   0.00000000E+00
         199          195   0.00000000E+00
         199          196   0.43198833E-04
         199          197  -0.12034781E+00
         199          198  -0.14942654E-04
         199          200   0.33536708E+02
         199          181   0.00000000E+00
         199          182   0.00000000E+00
         199          183   0.00000000E+00
         199          184   0.00000000E+00
         199          185   0.00000000E+00
         199          186   0.00000000E+00
         199          187   0.28823896E-09
         199          188  -0.29225902E-14
         199          189  -0.23794469E-06
         199          190  -0.80315886E-07
         199          201   0.00000000E+00
         199          202   0.00000000E+00
         199          203   0.00000000E+00
         199          204   0.00000000E+00
         199          205   0.00000000E+00
         199          206   0.00000000E+00
         199          207   0.43262286E-09
         199          208  -0.43865664E-14
         199          209  -0.35713531E-06
         199          210  -0.12054751E-06
         200          200   0.13484933E+05
         200          191   0.36307130E+04
         200          192   0.24834091E+03
         200          193   0.00000000E+00
         200          194   0.00000000E+00
         200          195   0.21795340E-05
         200          196   0.00000000E+00
         200          197   0.49505150E-01
         200          198  -0.37042339E-04
         200          199   0.33536708E+02
         200          181  -0.86950685E-05
         200          182  -0.59474311E-06
         200          183   0.00000000E+00
         200          184   0.00000000E+00
         200          185  -0.52196911E-14
         200          186   0.00000000E+00
         200          187  -0.11851393E-09
         200          188   0.11294945E-13
         200          189  -0.80315886E-07
         200          190  -0.32294600E-04
         200          201  -0.13050579E-04
         200          202  -0.89266026E-06
         200          203   0.00000000E+00
         200          204   0.00000000E+00
         200          205  -0.78343250E-14
         200          206   0.00000000E+00
         200          207  -0.17787962E-09
         200          208   0.16952779E-13
         200          209  -0.12054751E-06
         200          210  -0.48471527E-04
         201          201   0.97945219E+04
         201          202   0.00000000E+00
         201          203   0.00000000E+00
         201          204   0.00000000E+00
         201          205   0.00000000E+00
         201          206   0.79884210E+02
         201          207   0.76117799E+02
         201          208   0.00000000E+00
         201          209   0.00000000E+00
         201          210   0.36307130E+04
         201          191  -0.23456562E-04
         201          192   0.00000000E+00
         201          193   0.00000000E+00
         201          194   0.00000000E+00
         201          195   0.00000000E+00
         201          196  -0.19131143E-06
         201          197  -0.18229190E-06
         201          198   0.00000000E+00
         201          199   0.00000000E+00
         201          200  -0.86950685E-05
         201          211  -0.35206361E-04
         201          212   0.00000000E+00
         201          213   0.00000000E+00
         201          214   0.00000000E+00
         201          215   0.00000000E+00
         201          216  -0.28714265E-06
         201          217  -0.27360508E-06
         201          218   0.00000000E+00
         201          219   0.00000000E+00
         201          220  -0.13050579E-04
         202          202   0.61664984E+04
         202          201   0.00000000E+00
         202          203   0.00000000E+00
         202          204   0.63450217E+01
         202          205   0.63450217E+01
         202          206   0.00000000E+00
         202          207  -0.21136331E+02
         202          208   0.00000000E+00
         202          209   0.00000000E+00
         202          210   0.24834091E+03
         202          191   0.00000000E+00
         202          192  -0.14762870E-04
         202          193   0.00000000E+00
         202          194   0.00000000E+00
         202          195   0.00000000E+00
         202          196   0.00000000E+00
         202          197   0.00000000E+00
         202          198   0.00000000E+00
         202          199   0.00000000E+00
         202          200  -0.59474311E-06
         202          211   0.00000000E+00
         202          212  -0.22157848E-04
         202          213   0.00000000E+00
         202          214   0.00000000E+00
         202          215   0.00000000E+00
         202          216   0.00000000E+00
         202          217   0.00000000E+00
         202          218   0.00000000E+00
         202          219   0.00000000E+00
         202          220  -0.89266026E-06
         203          203   0.78082192E+03
         203          201   0.00000000E+00
         203          202   0.00000000E+00
         203          204   0.00000000E+00
         203          205   0.00000000E+00
         203          206   0.00000000E+00
         203          207   0.00000000E+00
         203          208   0.00000000E+00
         203          209   0.00000000E+00
         203          210   0.00000000E+00
         203          191   0.00000000E+00
         203          192   0.00000000E+00
         203          193  -0.18699636E-05
         203          194   0.00000000E+00
         203          195   0.00000000E+00
         203          196   0.00000000E+00
         203          197   0.00000000E+00
         203          198   0.00000000E+00
         203          199   0.00000000E+00
         203          200   0.00000000E+00
         203          211   0.00000000E+00
         203          212   0.00000000E+00
         203          213  -0.28066608E-05
         203          214   0.00000000E+00
         203          215   0.00000000E+00
         203          216   0.00000000E+00
         203          217   0.00000000E+00
         203          218   0.00000000E+00
         203          219   0.00000000E+00
         203          220   0.00000000E+00
         204          204   0.13409529E+04
         204          201   0.00000000E+00
         204          202   0.63443872E+01
         204          203   0.00000000E+00
         204          205   0.19035065E+02
         204          206   0.00000000E+00
         204          207  -0.65836821E+02
         204          208   0.00000000E+00
         204          209   0.00000000E+00
         204          210   0.00000000E+00
         204          191   0.00000000E+00
         204          192   0.00000000E+00
         204          193   0.00000000E+00
         204          194  -0.31658155E-05
         204          195   0.00000000E+00
         204          196   0.00000000E+00
         204          197   0.58143241E-08
         204          198   0.00000000E+00
         204          199   0.00000000E+00
         204          200   0.00000000E+00
         204          211   0.00000000E+00
         204          212   0.00000000E+00
         204          213   0.00000000E+00
         204          214  -0.47516275E-05
         204          215   0.00000000E+00
         204          216   0.00000000E+00
         204          217   0.87268201E-08
         204          218   0.00000000E+00
         204          219   0.00000000E+00
         204          220   0.00000000E+00
         205          205   0.19052837E+02
         205          201   0.00000000E+00
         205          202   0.63443872E+01
         205          203   0.00000000E+00
         205          204   0.19035065E+02
         205          206   0.00000000E+00
         205          207  -0.63477866E+02
         205          208   0.00000000E+00
         205          209   0.00000000E+00
         205          210   0.21795643E-05
         205          191   0.00000000E+00
         205          192   0.00000000E+00
         205          193   0.00000000E+00
         205          194   0.00000000E+00
         205          195  -0.42484262E-10
         205          196   0.00000000E+00
         205          197   0.16470994E-09
         205          198   0.00000000E+00
         205          199   0.00000000E+00
         205          200  -0.52197636E-14
         205          211   0.00000000E+00
         205          212   0.00000000E+00
         205          213   0.00000000E+00
         205          214   0.00000000E+00
         205          215  -0.63765367E-10
         205          216   0.00000000E+00
         205          217   0.24721601E-09
         205          218   0.00000000E+00
         205          219   0.00000000E+00
         205          220  -0.78344339E-14
         206          206   0.17074662E+04
         206          201   0.79884210E+02
         206          202   0.00000000E+00
         206          203   0.00000000E+00
         206          204   0.00000000E+00
         206          205   0.00000000E+00
         206          207   0.19543730E+04
         206          208   0.00000000E+00
         206          209   0.43198833E-04
         206          210   0.00000000E+00
         206          191  -0.19131143E-06
         206          192   0.00000000E+00
         206          193   0.00000000E+00
         206          194   0.00000000E+00
         206          195   0.00000000E+00
         206          196  -0.40891514E-05
         206          197  -0.46804606E-05
         206          198   0.00000000E+00
         206          199   0.00000000E+00
         206          200   0.00000000E+00
         206          211  -0.28714265E-06
         206          212   0.00000000E+00
         206          213   0.00000000E+00
         206          214   0.00000000E+00
         206          215   0.00000000E+00
         206          216  -0.61374783E-05
         206          217  -0.70249846E-05
         206          218   0.00000000E+00
         206          219   0.00000000E+00
         206          220   0.00000000E+00
         207          207   0.26723718E+04
         207          201   0.76117799E+02
         207          202  -0.21147957E+02
         207          203   0.00000000E+00
         207          204  -0.65878288E+02
         207          205  -0.63519108E+02
         207          206   0.19543478E+04
         207          208  -0.38887502E-04
         207          209  -0.12035985E+00
         207          210   0.49505150E-01
         207          191  -0.18229190E-06
         207          192   0.00000000E+00
         207          193   0.00000000E+00
         207          194   0.58149055E-08
         207          195   0.16475051E-09
         207          196  -0.46804003E-05
         207          197  -0.58937839E-05
         207          198   0.15713863E-13
         207          199   0.28826778E-09
         207          200  -0.11851393E-09
         207          211  -0.27360508E-06
         207          212   0.00000000E+00
         207          213   0.00000000E+00
         207          214   0.87276927E-08
         207          215   0.24727690E-09
         207          216  -0.70248941E-05
         207          217  -0.88460827E-05
         207          218   0.23585210E-13
         207          219   0.43266612E-09
         207          220  -0.17787962E-09
         208          208   0.66308262E-04
         208          201   0.00000000E+00
         208          202   0.00000000E+00
         208          203   0.00000000E+00
         208          204   0.00000000E+00
         208          205   0.00000000E+00
         208          206   0.00000000E+00
         208          207  -0.38896922E-04
         208          209  -0.14946245E-04
         208          210  -0.37051937E-04
         208          191   0.00000000E+00
         208          192   0.00000000E+00
         208          193   0.00000000E+00
         208          194   0.00000000E+00
         208          195   0.00000000E+00
         208          196   0.00000000E+00
         208          197   0.15715131E-13
         208          198  -0.23320538E-13
         208          199  -0.29226998E-14
         208          200   0.11296639E-13
         208          211   0.00000000E+00
         208          212   0.00000000E+00
         208          213   0.00000000E+00
         208          214   0.00000000E+00
         208          215   0.00000000E+00
         208          216   0.00000000E+00
         208          217   0.23587113E-13
         208          218  -0.35002201E-13
         208          219  -0.43867309E-14
         208          220   0.16955322E-13
         209          209   0.99356224E+02
         209          201   0.00000000E+00
         209          202   0.00000000E+00
         209          203   0.00000000E+00
         209          204   0.00000000E+00
         209          205   0.00000000E+00
         209          206   0.43198833E-04
         209          207  -0.12034781E+00
         209          208  -0.14942654E-04
         209          210   0.33536708E+02
         209          191   0.00000000E+00
         209          192   0.00000000E+00
         209          193   0.00000000E+00
         209          194   0.00000000E+00
         209          195   0.00000000E+00
         209          196   0.00000000E+00
         209          197   0.28823896E-09
         209          198  -0.29225902E-14
         209          199  -0.23794469E-06
         209          200  -0.80315886E-07
         209          211   0.00000000E+00
         209          212   0.00000000E+00
         209          213   0.00000000E+00
         209          214   0.00000000E+00
         209          215   0.00000000E+00
         209          216   0.00000000E+00
         209          217   0.43262286E-09
         209          218  -0.43865664E-14
         209          219  -0.35713531E-06
         209          220  -0.12054751E-06
         210          210   0.13484933E+05
         210          201   0.36307130E+04
         210          202   0.24834091E+03
         210          203   0.00000000E+00
         210          204   0.00000000E+00
         210          205   0.21795340E-05
         210          206   0.00000000E+00
         210          207   0.49505150E-01
         210          208  -0.37042339E-04
         210          209   0.33536708E+02
         210          191  -0.86950685E-05
         210          192  -0.59474311E-06
         210          193   0.00000000E+00
         210          194   0.00000000E+00
         210          195  -0.52196911E-14
         210          196   0.00000000E+00
         210          197  -0.11851393E-09
         210          198   0.11294945E-13
         210          199  -0.80315886E-07
         210          200  -0.32294600E-04
         210          211  -0.13050579E-04
         210          212  -0.89266026E-06
         210          213   0.00000000E+00
         210          214   0.00000000E+00
         210          215  -0.78343250E-14
         210          216   0.00000000E+00
         210          217  -0.17787962E-09
         210          218   0.16952779E-13
         210          219  -0.12054751E-06
         210          220  -0.48471527E-04
         211          211   0.97945219E+04
         211          212   0.00000000E+00
         211          213   0.00000000E+00
         211          214   0.00000000E+00
         211          215   0.00000000E+00
         211          216   0.79884210E+02
         211          217   0.76117799E+02
         211          218   0.00000000E+00
         211          219   0.00000000E+00
         211          220   0.36307130E+04
         211          201  -0.23456562E-04
         211          202   0.00000000E+00
         211          203   0.00000000E+00
         211          204   0.00000000E+00
         211          205   0.00000000E+00
         211          206  -0.19131143E-06
         211          207  -0.18229190E-06
         211          208   0.00000000E+00
         211          209   0.00000000E+00
         211          210  -0.86950685E-05
         211          221  -0.35206361E-04
         211          222   0.00000000E+00
         211          223   0.00000000E+00
         211          224   0.00000000E+00
         211          225   0.00000000E+00
         211          226  -0.28714265E-06
         211          227  -0.27360508E-06
         211          228   0.00000000E+00
         211          229   0.00000000E+00
         211          230  -0.13050579E-04
         212          212   0.61664984E+04
         212          211   0.00000000E+00
         212          213   0.00000000E+00
         212          214   0.63450217E+01
         212          215   0.63450217E+01
         212          216   0.00000000E+00
         212          217  -0.21136331E+02
         212          218   0.00000000E+00
         212          219   0.00000000E+00
         212          220   0.24834091E+03
         212          201   0.00000000E+00
         212          202  -0.14762870E-04
         212          203   0.00000000E+00
         212          204   0.00000000E+00
         212          205   0.00000000E+00
         212          206   0.00000000E+00
         212          207   0.00000000E+00
         212          208   0.00000000E+00
         212          209   0.00000000E+00
         212          210  -0.59474311E-06
         212          221   0.00000000E+00
         212          222  -0.22157848E-04
         212          223   0.00000000E+00
         212          224   0.00000000E+00
         212          225   0.00000000E+00
         212          226   0.00000000E+00
         212          227   0.00000000E+00
         212          228   0.00000000E+00
         212          229   0.00000000E+00
         212          230  -0.89266026E-06
         213          213   0.78082192E+03
         213          211   0.00000000E+00
         213          212   0.00000000E+00
         213          214   0.00000000E+00
         213          215   0.00000000E+00
         213          216   0.00000000E+00
         213          217   0.00000000E+00
         213          218   0.00000000E+00
         213          219   0.00000000E+00
         213          220   0.00000000E+00
         213          201   0.00000000E+00
         213          202   0.00000000E+00
         213          203  -0.18699636E-05
         213          204   0.00000000E+00
         213          205   0.00000000E+00
         213          206   0.00000000E+00
         213          207   0.00000000E+00
         213          208   0.00000000E+00
         213          209   0.00000000E+00
         213          210   0.00000000E+00
         213          221   0.00000000E+00
         213          222   0.00000000E+00
         213          223  -0.28066608E-05
         213          224   0.00000000E+00
         213          225   0.00000000E+00
         213          226   0.00000000E+00
         213          227   0.00000000E+00
         213          228   0.00000000E+00
         213          229   0.00000000E+00
         213          230   0.00000000E+00
         214          214   0.13409529E+04
         214          211   0.00000000E+00
         214          212   0.63443872E+01
         214          213   0.00000000E+00
         214          215   0.19035065E+02
         214          216   0.00000000E+00
         214          217  -0.65836821E+02
         214          218   0.00000000E+00
         214          219   0.00000000E+00
         214          220   0.00000000E+00
         214          201   0.00000000E+00
         214          202   0.00000000E+00
         214          203   0.00000000E+00
         214          204  -0.31658155E-05
         214          205   0.00000000E+00
         214          206   0.00000000E+00
         214          207   0.58143241E-08
         214          208   0.00000000E+00
         214          209   0.00000000E+00
         214          210   0.00000000E+00
         214          221   0.00000000E+00
         214          222   0.00000000E+00
         214          223   0.00000000E+00
         214          224  -0.47516275E-05
         214          225   0.00000000E+00
         214          226   0.00000000E+00
         214          227   0.87268201E-08
         214          228   0.00000000E+00
         214          229   0.00000000E+00
         214          230   0.00000000E+00
         215          215   0.19052837E+02
         215          211   0.00000000E+00
         215          212   0.63443872E+01
         215          213   0.00000000E+00
         215          214   0.19035065E+02
         215          216   0.00000000E+00
         215          217  -0.63477866E+02
         215          218   0.00000000E+00
         215          219   0.00000000E+00
         215          220   0.21795643E-05
         215          201   0.00000000E+00
         215          202   0.00000000E+00
         215          203   0.00000000E+00
         215          204   0.00000000E+00
         215          205  -0.42484262E-10
         215          206   0.00000000E+00
         215          207   0.16470994E-09
         215          208   0.00000000E+00
         215          209   0.00000000E+00
         215          210  -0.52197636E-14
         215          221   0.00000000E+00
         215          222   0.00000000E+00
         215          223   0.00000000E+00
         215          224   0.00000000E+00
         215          225  -0.63765367E-10
         215          226   0.00000000E+00
         215          227   0.24721601E-09
         215          228   0.00000000E+00
         215          229   0.00000000E+00
         215          230  -0.78344339E-14
         216          216   0.17074662E+04
         216          211   0.79884210E+02
         216          212   0.00000000E+00
         216          213   0.00000000E+00
         216          214   0.00000000E+00
         216          215   0.00000000E+00
         216          217   0.19543730E+04
         216          218   0.00000000E+00
         216          219   0.43198833E-04
         216          220   0.00000000E+00
         216          201  -0.19131143E-06
         216          202   0.00000000E+00
         216          203   0.00000000E+00
         216          204   0.00000000E+00
         216          205   0.00000000E+00
         216          206  -0.40891514E-05
         216          207  -0.46804606E-05
         216          208   0.00000000E+00
         216          209   0.00000000E+00
         216          210   0.00000000E+00
         216          221  -0.28714265E-06
         216          222   0.00000000E+00
         216          223   0.00000000E+00
         216          224   0.00000000E+00
         216          225   0.00000000E+00
         216          226  -0.61374783E-05
         216          227  -0.70249846E-05
         216          228   0.00000000E+00
         216          229   0.00000000E+00
         216          230   0.00000000E+00
         217          217   0.26723718E+04
         217          211   0.76117799E+02
         217          212  -0.21147957E+02
         217          213   0.00000000E+00
         217          214  -0.65878288E+02
         217          215  -0.63519108E+02
         217          216   0.19543478E+04
         217          218  -0.38887502E-04
         217          219  -0.12035985E+00
         217          220   0.49505150E-01
         217          201  -0.18229190E-06
         217          202   0.00000000E+00
         217          203   0.00000000E+00
         217          204   0.58149055E-08
         217          205   0.16475051E-09
         217          206  -0.46804003E-05
         217          207  -0.58937839E-05
         217          208   0.15713863E-13
         217          209   0.28826778E-09
         217          210  -0.11851393E-09
         217          221  -0.27360508E-06
         217          222   0.00000000E+00
         217          223   0.00000000E+00
         217          224   0.87276927E-08
         217          225   0.24727690E-09
         217          226  -0.70248941E-05
         217          227  -0.88460827E-05
         217          228   0.23585210E-13
         217          229   0.43266612E-09
         217          230  -0.17787962E-09
         218          218   0.66308262E-04
         218          211   0.00000000E+00
         218          212   0.00000000E+00
         218          213   0.00000000E+00
         218          214   0.00000000E+00
         218          215   0.00000000E+00
         218          216   0.00000000E+00
         218          217  -0.38896922E-04
         218          219  -0.14946245E-04
         218          220  -0.37051937E-04
         218          201   0.00000000E+00
         218          202   0.00000000E+00
         218          203   0.00000000E+00
         218          204   0.00000000E+00
         218          205   0.00000000E+00
         218          206   0.00000000E+00
         218          207   0.15715131E-13
         218          208  -0.23320538E-13
         218          209  -0.29226998E-14
         218          210   0.11296639E-13
         218          221   0.00000000E+00
         218          222   0.00000000E+00
         218          223   0.00000000E+00
         218          224   0.00000000E+00
         218          225   0.00000000E+00
         218          226   0.00000000E+00
         218          227   0.23587113E-13
         218          228  -0.35002201E-13
         218          229  -0.43867309E-14
         218          230   0.16955322E-13
         219          219   0.99356224E+02
         219          211   0.00000000E+00
         219          212   0.00000000E+00
         219          213   0.00000000E+00
         219          214   0.00000000E+00
         219          215   0.00000000E+00
         219          216   0.43198833E-04
         219          217  -0.12034781E+00
         219          218  -0.14942654E-04
         219          220   0.33536708E+02
         219          201   0.00000000E+00
         219          202   0.00000000E+00
         219          203   0.00000000E+00
         219          204   0.00000000E+00
         219          205   0.00000000E+00
         219          206   0.00000000E+00
         219          207   0.28823896E-09
         219          208  -0.29225902E-14
         219          209  -0.23794469E-06
         219          210  -0.80315886E-07
         219          221   0.00000000E+00
         219          222   0.00000000E+00
         219          223   0.00000000E+00
         219          224   0.00000000E+00
         219          225   0.00000000E+00
         219          226   0.00000000E+00
         219          227   0.43262286E-09
         219          228  -0.43865664E-14
         219          229  -0.35713531E-06
         219          230  -0.12054751E-06
         220          220   0.13484933E+05
         220          211   0.36307130E+04
         220          212   0.24834091E+03
         220          213   0.00000000E+00
         220          214   0.00000000E+00
         220          215   0.21795340E-05
         220          216   0.00000000E+00
         220          217   0.49505150E-01
         220          218  -0.37042339E-04
         220          219   0.33536708E+02
         220          201  -0.86950685E-05
         220          202  -0.59474311E-06
         220          203   0.00000000E+00
         220          204   0.00000000E+00
         220          205  -0.52196911E-14
         220          206   0.00000000E+00
         220          207  -0.11851393E-09
         220          208   0.11294945E-13
         220          209  -0.80315886E-07
         220          210  -0.32294600E-04
         220          221  -0.13050579E-04
         220          222  -0.89266026E-06
         220          223   0.00000000E+00
         220          224   0.00000000E+00
         220          225  -0.78343250E-14
         220          226   0.00000000E+00
         220          227  -0.17787962E-09
         220          228   0.16952779E-13
         220          229  -0.12054751E-06
         220          230  -0.48471527E-04
         221          221   0.97945219E+04
         221          222   0.00000000E+00
         221          223   0.00000000E+00
         221          224   0.00000000E+00
         221          225   0.00000000E+00
         221          226   0.79884210E+02
         221          227   0.76117799E+02
         221          228   0.00000000E+00
         221          229   0.00000000E+00
         221          230   0.36307130E+04
         221          211  -0.23456562E-04
         221          212   0.00000000E+00
         221          213   0.00000000E+00
         221          214   0.00000000E+00
         221          215   0.00000000E+00
         221          216  -0.19131143E-06
         221          217  -0.18229190E-06
         221          218   0.00000000E+00
         221          219   0.00000000E+00
         221          220  -0.86950685E-05
         221          231  -0.35206361E-04
         221          232   0.00000000E+00
         221          233   0.00000000E+00
         221          234   0.00000000E+00
         221          235   0.00000000E+00
         221          236  -0.28714265E-06
         221          237  -0.27360508E-06
         221          238   0.00000000E+00
         221          239   0.00000000E+00
         221          240  -0.13050579E-04
         222          222   0.61664984E+04
         222          221   0.00000000E+00
         222          223   0.00000000E+00
         222          224   0.63450217E+01
         222          225   0.63450217E+01
         222          226   0.00000000E+00
         222          227  -0.21136331E+02
         222          228   0.00000000E+00
         222          229   0.00000000E+00
         222          230   0.24834091E+03
         222          211   0.00000000E+00
         222          212  -0.14762870E-04
         222          213   0.00000000E+00
         222          214   0.00000000E+00
         222          215   0.00000000E+00
         222          216   0.00000000E+00
         222          217   0.00000000E+00
         222          218   0.00000000E+00
         222          219   0.00000000E+00
         222          220  -0.59474311E-06
         222          231   0.00000000E+00
         222          232  -0.22157848E-04
         222          233   0.00000000E+00
         222          234   0.00000000E+00
         222          235   0.00000000E+00
         222          236   0.00000000E+00
         222          237   0.00000000E+00
         222          238   0.00000000E+00
         222          239   0.00000000E+00
         222          240  -0.89266026E-06
         223          223   0.78082192E+03
         223          221   0.00000000E+00
         223          222   0.00000000E+00
         223          224   0.00000000E+00
         223          225   0.00000000E+00
         223          226   0.00000000E+00
         223          227   0.00000000E+00
         223          228   0.00000000E+00
         223          229   0.00000000E+00
         223          230   0.00000000E+00
         223          211   0.00000000E+00
         223          212   0.00000000E+00
         223          213  -0.18699636E-05
         223          214   0.00000000E+00
         223          215   0.00000000E+00
         223          216   0.00000000E+00
         223          217   0.00000000E+00
         223          218   0.00000000E+00
         223          219   0.00000000E+00
         223          220   0.00000000E+00
         223          231   0.00000000E+00
         223          232   0.00000000E+00
         223          233  -0.28066608E-05
         223          234   0.00000000E+00
         223          235   0.00000000E+00
         223          236   0.00000000E+00
         223          237   0.00000000E+00
         223          238   0.00000000E+00
         223          239   0.00000000E+00
         223          240   0.00000000E+00
         224          224   0.13409529E+04
         224          221   0.00000000E+00
         224          222   0.63443872E+01
         224          223   0.00000000E+00
         224          225   0.19035065E+02
         224          226   0.00000000E+00
         224          227  -0.65836821E+02
         224          228   0.00000000E+00
         224          229   0.00000000E+00
         224          230   0.00000000E+00
         224          211   0.00000000E+00
         224          212   0.00000000E+00
         224          213   0.00000000E+00
         224          214  -0.31658155E-05
         224          215   0.00000000E+00
         224          216   0.00000000E+00
         224          217   0.58143241E-08
         224          218   0.00000000E+00
         224          219   0.00000000E+00
         224          220   0.00000000E+00
         224          231   0.00000000E+00
         224          232   0.00000000E+00
         224          233   0.00000000E+00
         224          234  -0.47516275E-05
         224          235   0.00000000E+00
         224          236   0.00000000E+00
         224          237   0.87268201E-08
         224          238   0.00000000E+00
         224          239   0.00000000E+00
         224          240   0.00000000E+00
         225          225   0.19052837E+02
         225          221   0.00000000E+00
         225          222   0.63443872E+01
         225          223   0.00000000E+00
         225          224   0.19035065E+02
         225          226   0.00000000E+00
         225          227  -0.63477866E+02
         225          228   0.00000000E+00
         225          229   0.00000000E+00
         225          230   0.21795643E-05
         225          211   0.00000000E+00
         225          212   0.00000000E+00
         225          213   0.00000000E+00
         225          214   0.00000000E+00
         225          215  -0.42484262E-10
         225          216   0.00000000E+00
         225          217   0.16470994E-09
         225          218   0.00000000E+00
         225          219   0.00000000E+00
         225          220  -0.52197636E-14
         225          231   0.00000000E+00
         225          232   0.00000000E+00
         225          233   0.00000000E+00
         225          234   0.00000000E+00
         225          235  -0.63765367E-10
         225          236   0.00000000E+00
         225          237   0.24721601E-09
         225          238   0.00000000E+00
         225          239   0.00000000E+00
         225          240  -0.78344339E-14
         226          226   0.17074662E+04
         226          221   0.79884210E+02
         226          222   0.00000000E+00
         226          223   0.00000000E+00
         226          224   0.00000000E+00
         226          225   0.00000000E+00
         226          227   0.19543730E+04
         226          228   0.00000000E+00
         226          229   0.43198833E-04
         226          230   0.00000000E+00
         226          211  -0.19131143E-06
         226          212   0.00000000E+00
         226          213   0.00000000E+00
         226          214   0.00000000E+00
         226          215   0.00000000E+00
         226          216  -0.40891514E-05
         226          217  -0.46804606E-05
         226          218   0.00000000E+00
         226          219   0.00000000E+00
         226          220   0.00000000E+00
         226          231  -0.28714265E-06
         226          232   0.00000000E+00
         226          233   0.00000000E+00
         226          234   0.00000000E+00
         226          235   0.00000000E+00
         226          236  -0.61374783E-05
         226          237  -0.70249846E-05
         226          238   0.00000000E+00
         226          239   0.00000000E+00
         226          240   0.00000000E+00
         227          227   0.26723718E+04
         227          221   0.76117799E+02
         227          222  -0.21147957E+02
         227          223   0.00000000E+00
         227          224  -0.65878288E+02
         227          225  -0.63519108E+02
         227          226   0.19543478E+04
         227          228  -0.38887502E-04
         227          229  -0.12035985E+00
         227          230   0.49505150E-01
         227          211  -0.18229190E-06
         227          212   0.00000000E+00
         227          213   0.00000000E+00
         227          214   0.58149055E-08
         227          215   0.16475051E-09
         227          216  -0.46804003E-05
         227          217  -0.58937839E-05
         227          218   0.15713863E-13
         227          219   0.28826778E-09
         227          220  -0.11851393E-09
         227          231  -0.27360508E-06
         227          232   0.00000000E+00
         227          233   0.00000000E+00
         227          234   0.87276927E-08
         227          235   0.24727690E-09
         227          236  -0.70248941E-05
         227          237  -0.88460827E-05
         227          238   0.23585210E-13
         227          239   0.43266612E-09
         227          240  -0.17787962E-09
         228          228   0.66308262E-04
         228          221   0.00000000E+00
         228          222   0.00000000E+00
         228          223   0.00000000E+00
         228          224   0.00000000E+00
         228          225   0.00000000E+00
         228          226   0.00000000E+00
         228          227  -0.38896922E-04
         228          229  -0.14946245E-04
         228          230  -0.37051937E-04
         228          211   0.00000000E+00
         228          212   0.00000000E+00
         228          213   0.00000000E+00
         228          214   0.00000000E+00
         228          215   0.00000000E+00
         228          216   0.00000000E+00
         228          217   0.15715131E-13
         228          218  -0.23320538E-13
         228          219  -0.29226998E-14
         228          220   0.11296639E-13
         228          231   0.00000000E+00
         228          232   0.00000000E+00
         228          233   0.00000000E+00
         228          234   0.00000000E+00
         228          235   0.00000000E+00
         228          236   0.00000000E+00
         228          237   0.23587113E-13
         228          238  -0.35002201E-13
         228          239  -0.43867309E-14
         228          240   0.16955322E-13
         229          229   0.99356224E+02
         229          221   0.00000000E+00
         229          222   0.00000000E+00
         229          223   0.00000000E+00
         229          224   0.00000000E+00
         229          225   0.00000000E+00
         229          226   0.43198833E-04
         229          227  -0.12034781E+00
         229          228  -0.14942654E-04
         229          230   0.33536708E+02
         229          211   0.00000000E+00
         229          212   0.00000000E+00
         229          213   0.00000000E+00
         229          214   0.00000000E+00
         229          215   0.00000000E+00
         229          216   0.00000000E+00
         229          217   0.28823896E-09
         229          218  -0.29225902E-14
         229          219  -0.23794469E-06
         229          220  -0.80315886E-07
         229          231   0.00000000E+00
         229          232   0.00000000E+00
         229          233   0.00000000E+00
         229          234   0.00000000E+00
         229          235   0.00000000E+00
         229          236   0.00000000E+00
         229          237   0.43262286E-09
         229          238  -0.43865664E-14
         229          239  -0.35713531E-06
         229          240  -0.12054751E-06
         230          230   0.13484933E+05
         230          221   0.36307130E+04
         230          222   0.24834091E+03
         230          223   0.00000000E+00
         230          224   0.00000000E+00
         230          225   0.21795340E-05
         230          226   0.00000000E+00
         230          227   0.49505150E-01
         230          228  -0.37042339E-04
         230          229   0.33536708E+02
         230          211  -0.86950685E-05
         230          212  -0.59474311E-06
         230          213   0.00000000E+00
         230          214   0.00000000E+00
         230          215  -0.52196911E-14
         230          216   0.00000000E+00
         230          217  -0.11851393E-09
         230          218   0.11294945E-13
         230          219  -0.80315886E-07
         230          220  -0.32294600E-04
         230          231  -0.13050579E-04
         230          232  -0.89266026E-06
         230          233   0.00000000E+00
         230          234   0.00000000E+00
         230          235  -0.78343250E-14
         230          236   0.00000000E+00
         230          237  -0.17787962E-09
         230          238   0.16952779E-13
         230          239  -0.12054751E-06
         230          240  -0.48471527E-04
         231          231   0.97945219E+04
         231          232   0.00000000E+00
         231          233   0.00000000E+00
         231          234   0.00000000E+00
         231          235   0.00000000E+00
         231          236   0.79884210E+02
         231          237   0.76117799E+02
         231          238   0.00000000E+00
         231          239   0.00000000E+00
         231          240   0.36307130E+04
         231          221  -0.23456562E-04
         231          222   0.00000000E+00
         231          223   0.00000000E+00
         231          224   0.00000000E+00
         231          225   0.00000000E+00
         231          226  -0.19131143E-06
         231          227  -0.18229190E-06
         231          228   0.00000000E+00
         231          229   0.00000000E+00
         231          230  -0.86950685E-05
         231          241  -0.35206361E-04
         231          242   0.00000000E+00
         231          243   0.00000000E+00
         231          244   0.00000000E+00
         231          245   0.00000000E+00
         231          246  -0.28714265E-06
         231          247  -0.27360508E-06
         231          248   0.00000000E+00
         231          249   0.00000000E+00
         231          250  -0.13050579E-04
         232          232   0.61664984E+04
         232          231   0.00000000E+00
         232          233   0.00000000E+00
         232          234   0.63450217E+01
         232          235   0.63450217E+01
         232          236   0.00000000E+00
         232          237  -0.21136331E+02
         232          238   0.00000000E+00
         232          239   0.00000000E+00
         232          240   0.24834091E+03
         232          221   0.00000000E+00
         232          222  -0.14762870E-04
         232          223   0.00000000E+00
         232          224   0.00000000E+00
         232          225   0.00000000E+00
         232          226   0.00000000E+00
         232          227   0.00000000E+00
         232          228   0.00000000E+00
         232          229   0.00000000E+00
         232          230  -0.59474311E-06
         232          241   0.00000000E+00
         232          242  -0.22157848E-04
         232          243   0.00000000E+00
         232          244   0.00000000E+00
         232          245   0.00000000E+00
         232          246   0.00000000E+00
         232          247   0.00000000E+00
         232          248   0.00000000E+00
         232          249   0.00000000E+00
         232          250  -0.89266026E-06
         233          233   0.78082192E+03
         233          231   0.00000000E+00
         233          232   0.00000000E+00
         233          234   0.00000000E+00
         233          235   0.00000000E+00
         233          236   0.00000000E+00
         233          237   0.00000000E+00
         233          238   0.00000000E+00
         233          239   0.00000000E+00
         233          240   0.00000000E+00
         233          221   0.00000000E+00
         233          222   0.00000000E+00
         233          223  -0.18699636E-05
         233          224   0.00000000E+00
         233          225   0.00000000E+00
         233          226   0.00000000E+00
         233          227   0.00000000E+00
         233          228   0.00000000E+00
         233          229   0.00000000E+00
         233          230   0.00000000E+00
         233          241   0.00000000E+00
         233          242   0.00000000E+00
         233          243  -0.28066608E-05
         233          244   0.00000000E+00
         233          245   0.00000000E+00
         233          246   0.00000000E+00
         233          247   0.00000000E+00
         233          248   0.00000000E+00
         233          249   0.00000000E+00
         233          250   0.00000000E+00
         234          234   0.13409529E+04
         234          231   0.00000000E+00
         234          232   0.63443872E+01
         234          233   0.00000000E+00
         234          235   0.19035065E+02
         234          236   0.00000000E+00
         234          237  -0.65836821E+02
         234          238   0.00000000E+00
         234          239   0.00000000E+00
         234          240   0.00000000E+00
         234          221   0.00000000E+00
         234          222   0.00000000E+00
         234          223   0.00000000E+00
         234          224  -0.31658155E-05
         234          225   0.00000000E+00
         234          226   0.00000000E+00
         234          227   0.58143241E-08
         234          228   0.00000000E+00
         234          229   0.00000000E+00
         234          230   0.00000000E+00
         234          241   0.00000000E+00
         234          242   0.00000000E+00
         234          243   0.00000000E+00
         234          244  -0.47516275E-05
         234          245   0.00000000E+00
         234          246   0.00000000E+00
         234          247   0.87268201E-08
         234          248   0.00000000E+00
         234          249   0.00000000E+00
         234          250   0.00000000E+00
         235          235   0.19052837E+02
         235          231   0.00000000E+00
         235          232   0.63443872E+01
         235          233   0.00000000E+00
         235          234   0.19035065E+02
         235          236   0.00000000E+00
         235          237  -0.63477866E+02
         235          238   0.00000000E+00
         235          239   0.00000000E+00
         235          240   0.21795643E-05
         235          221   0.00000000E+00
         235          222   0.00000000E+00
         235          223   0.00000000E+00
         235          224   0.00000000E+00
         235          225  -0.42484262E-10
         235          226   0.00000000E+00
         235          227   0.16470994E-09
         235          228   0.00000000E+00
         235          229   0.00000000E+00
         235          230  -0.52197636E-14
         235          241   0.00000000E+00
         235          242   0.00000000E+00
         235          243   0.00000000E+00
         235          244   0.00000000E+00
         235          245  -0.63765367E-10
         235          246   0.00000000E+00
         235          247   0.24721601E-09
         235          248   0.00000000E+00
         235          249   0.00000000E+00
         235          250  -0.78344339E-14
         236          236   0.17074662E+04
         236          231   0.79884210E+02
         236          232   0.00000000E+00
         236          233   0.00000000E+00
         236          234   0.00000000E+00
         236          235   0.00000000E+00
         236          237   0.19543730E+04
         236          238   0.00000000E+00
         236          239   0.43198833E-04
         236          240   0.00000000E+00
         236          221  -0.19131143E-06
         236          222   0.00000000E+00
         236          223   0.00000000E+00
         236          224   0.00000000E+00
         236          225   0.00000000E+00
         236          226  -0.40891514E-05
         236          227  -0.46804606E-05
         236          228   0.00000000E+00
         236          229   0.00000000E+00
         236          230   0.00000000E+00
         236          241  -0.28714265E-06
         236          242   0.00000000E+00
         236          243   0.00000000E+00
         236          244   0.00000000E+00
         236          245   0.00000000E+00
         236          246  -0.61374783E-05
         236          247  -0.70249846E-05
         236          248   0.00000000E+00
         236          249   0.00000000E+00
         236          250   0.00000000E+00
         237          237   0.26723718E+04
         237          231   0.76117799E+02
         237          232  -0.21147957E+02
         237          233   0.00000000E+00
         237          234  -0.65878288E+02
         237          235  -0.63519108E+02
         237          236   0.19543478E+04
         237          238  -0.38887502E-04
         237          239  -0.12035985E+00
         237          240   0.49505150E-01
         237          221  -0.18229190E-06
         237          222   0.00000000E+00
         237          223   0.00000000E+00
         237          224   0.58149055E-08
         237          225   0.16475051E-09
         237          226  -0.46804003E-05
         237          227  -0.58937839E-05
         237          228   0.15713863E-13
         237          229   0.28826778E-09
         237          230  -0.11851393E-09
         237          241  -0.27360508E-06
         237          242   0.00000000E+00
         237          243   0.00000000E+00
         237          244   0.87276927E-08
         237          245   0.24727690E-09
         237          246  -0.70248941E-05
         237          247  -0.88460827E-05
         237          248   0.23585210E-13
         237          249   0.43266612E-09
         237          250  -0.17787962E-09
         238          238   0.66308262E-04
         238          231   0.00000000E+00
         238          232   0.00000000E+00
         238          233   0.00000000E+00
         238          234   0.00000000E+00
         238          235   0.00000000E+00
         238          236   0.00000000E+00
         238          237  -0.38896922E-04
         238          239  -0.14946245E-04
         238          240  -0.37051937E-04
         238          221   0.00000000E+00
         238          222   0.00000000E+00
         238          223   0.00000000E+00
         238          224   0.00000000E+00
         238          225   0.00000000E+00
         238          226   0.00000000E+00
         238          227   0.15715131E-13
         238          228  -0.23320538E-13
         238          229  -0.29226998E-14
         238          230   0.11296639E-13
         238          241   0.00000000E+00
         238          242   0.00000000E+00
         238          243   0.00000000E+00
         238          244   0.00000000E+00
         238          245   0.00000000E+00
         238          246   0.00000000E+00
         238          247   0.23587113E-13
         238          248  -0.35002201E-13
         238          249  -0.43867309E-14
         238          250   0.16955322E-13
         239          239   0.99356224E+02
         239          231   0.00000000E+00
         239          232   0.00000000E+00
         239          233   0.00000000E+00
         239          234   0.00000000E+00
         239          235   0.00000000E+00
         239          236   0.43198833E-04
         239          237  -0.12034781E+00
         239          238  -0.14942654E-04
         239          240   0.33536708E+02
         239          221   0.00000000E+00
         239          222   0.00000000E+00
         239          223   0.00000000E+00
         239          224   0.00000000E+00
         239          225   0.00000000E+00
         239          226   0.00000000E+00
         239          227   0.28823896E-09
         239          228  -0.29225902E-14
         239          229  -0.23794469E-06
         239          230  -0.80315886E-07
         239          241   0.00000000E+00
         239          242   0.00000000E+00
         239          243   0.00000000E+00
         239          244   0.00000000E+00
         239          245   0.00000000E+00
         239          246   0.00000000E+00
         239          247   0.43262286E-09
         239          248  -0.43865664E-14
         239          249  -0.35713531E-06
         239          250  -0.12054751E-06
         240          240   0.13484933E+05
         240          231   0.36307130E+04
         240          232   0.24834091E+03
         240          233   0.00000000E+00
         240          234   0.00000000E+00
         240          235   0.21795340E-05
         240          236   0.00000000E+00
         240          237   0.49505150E-01
         240          238  -0.37042339E-04
         240          239   0.33536708E+02
         240          221  -0.86950685E-05
         240          222  -0.59474311E-06
         240          223   0.00000000E+00
         240          224   0.00000000E+00
         240          225  -0.52196911E-14
         240          226   0.00000000E+00
         240          227  -0.11851393E-09
         240          228   0.11294945E-13
         240          229  -0.80315886E-07
         240          230  -0.32294600E-04
         240          241  -0.13050579E-04
         240          242  -0.89266026E-06
         240          243   0.00000000E+00
         240          244   0.00000000E+00
         240          245  -0.78343250E-14
         240          246   0.00000000E+00
         240          247  -0.17787962E-09
         240          248   0.16952779E-13
         240          249  -0.12054751E-06
         240          250  -0.48471527E-04
         241          241   0.97945219E+04
         241          242   0.00000000E+00
         241          243   0.00000000E+00
         241          244   0.00000000E+00
         241          245   0.00000000E+00
         241          246   0.79884210E+02
         241          247   0.76117799E+02
         241          248   0.00000000E+00
         241          249   0.00000000E+00
         241          250   0.36307130E+04
         241          231  -0.23456562E-04
         241          232   0.00000000E+00
         241          233   0.00000000E+00
         241          234   0.00000000E+00
         241          235   0.00000000E+00
         241          236  -0.19131143E-06
         241          237  -0.18229190E-06
         241          238   0.00000000E+00
         241          239   0.00000000E+00
         241          240  -0.86950685E-05
         241          251  -0.35206361E-04
         241          252   0.00000000E+00
         241          253   0.00000000E+00
         241          254   0.00000000E+00
         241          255   0.00000000E+00
         241          256  -0.28714265E-06
         241          257  -0.27360508E-06
         241          258   0.00000000E+00
         241          259   0.00000000E+00
         241          260  -0.13050579E-04
         242          242   0.61664984E+04
         242          241   0.00000000E+00
         242          243   0.00000000E+00
         242          244   0.63450217E+01
         242          245   0.63450217E+01
         242          246   0.00000000E+00
         242          247  -0.21136331E+02
         242          248   0.00000000E+00
         242          249   0.00000000E+00
         242          250   0.24834091E+03
         242          231   0.00000000E+00
         242          232  -0.14762870E-04
         242          233   0.00000000E+00
         242          234   0.00000000E+00
         242          235   0.00000000E+00
         242          236   0.00000000E+00
         242          237   0.00000000E+00
         242          238   0.00000000E+00
         242          239   0.00000000E+00
         242          240  -0.59474311E-06
         242          251   0.00000000E+00
         242          252  -0.22157848E-04
         242          253   0.00000000E+00
         242          254   0.00000000E+00
         242          255   0.00000000E+00
         242          256   0.00000000E+00
         242          257   0.00000000E+00
         242          258   0.00000000E+00
         242          259   0.00000000E+00
         242          260  -0.89266026E-06
         243          243   0.78082192E+03
         243          241   0.00000000E+00
         243          242   0.00000000E+00
         243          244   0.00000000E+00
         243          245   0.00000000E+00
         243          246   0.00000000E+00
         243          247   0.00000000E+00
         243          248   0.00000000E+00
         243          249   0.00000000E+00
         243          250   0.00000000E+00
         243          231   0.00000000E+00
         243          232   0.00000000E+00
         243          233  -0.18699636E-05
         243          234   0.00000000E+00
         243          235   0.00000000E+00
         243          236   0.00000000E+00
         243          237   0.00000000E+00
         243          238   0.00000000E+00
         243          239   0.00000000E+00
         243          240   0.00000000E+00
         243          251   0.00000000E+00
         243          252   0.00000000E+00
         243          253  -0.28066608E-05
         243          254   0.00000000E+00
         243          255   0.00000000E+00
         243          256   0.00000000E+00
         243          257   0.00000000E+00
         243          258   0.00000000E+00
         243          259   0.00000000E+00
         243          260   0.00000000E+00
         244          244   0.13409529E+04
         244          241   0.00000000E+00
         244          242   0.63443872E+01
         244          243   0.00000000E+00
         244          245   0.19035065E+02
         244          246   0.00000000E+00
         244          247  -0.65836821E+02
         244          248   0.00000000E+00
         244          249   0.00000000E+00
         244          250   0.00000000E+00
         244          231   0.00000000E+00
         244          232   0.00000000E+00
         244          233   0.00000000E+00
         244          234  -0.31658155E-05
         244          235   0.00000000E+00
         244          236   0.00000000E+00
         244          237   0.58143241E-08
         244          238   0.00000000E+00
         244          239   0.00000000E+00
         244          240   0.00000000E+00
         244          251   0.00000000E+00
         244          252   0.00000000E+00
         244          253   0.00000000E+00
         244          254  -0.47516275E-05
         244          255   0.00000000E+00
         244          256   0.00000000E+00
         244          257   0.87268201E-08
         244          258   0.00000000E+00
         244          259   0.00000000E+00
         244          260   0.00000000E+00
         245          245   0.19052837E+02
         245          241   0.00000000E+00
         245          242   0.63443872E+01
         245          243   0.00000000E+00
         245          244   0.19035065E+02
         245          246   0.00000000E+00
         245          247  -0.63477866E+02
         245          248   0.00000000E+00
         245          249   0.00000000E+00
         245          250   0.21795643E-05
         245          231   0.00000000E+00
         245          232   0.00000000E+00
         245          233   0.00000000E+00
         245          234   0.00000000E+00
         245          235  -0.42484262E-10
         245          236   0.00000000E+00
         245          237   0.16470994E-09
         245          238   0.00000000E+00
         245          239   0.00000000E+00
         245          240  -0.52197636E-14
         245          251   0.00000000E+00
         245          252   0.00000000E+00
         245          253   0.00000000E+00
         245          254   0.00000000E+00
         245          255  -0.63765367E-10
         245          256   0.00000000E+00
         245          257   0.24721601E-09
         245          258   0.00000000E+00
         245          259   0.00000000E+00
         245          260  -0.78344339E-14
         246          246   0.17074662E+04
         246          241   0.79884210E+02
         246          242   0.00000000E+00
         246          243   0.00000000E+00
         246          244   0.00000000E+00
         246          245   0.00000000E+00
         246          247   0.19543730E+04
         246          248   0.00000000E+00
         246          249   0.43198833E-04
         246          250   0.00000000E+00
         246          231  -0.19131143E-06
         246          232   0.00000000E+00
         246          233   0.00000000E+00
         246          234   0.00000000E+00
         246          235   0.00000000E+00
         246          236  -0.40891514E-05
         246          237  -0.46804606E-05
         246          238   0.00000000E+00
         246          239   0.00000000E+00
         246          240   0.00000000E+00
         246          251  -0.28714265E-06
         246          252   0.00000000E+00
         246          253   0.00000000E+00
         246          254   0.00000000E+00
         246          255   0.00000000E+00
         246          256  -0.61374783E-05
         246          257  -0.70249846E-05
         246          258   0.00000000E+00
         246          259   0.00000000E+00
         246          260   0.00000000E+00
         247          247   0.26723718E+04
         247          241   0.76117799E+02
         247          242  -0.21147957E+02
         247          243   0.00000000E+00
         247          244  -0.65878288E+02
         247          245  -0.63519108E+02
         247          246   0.19543478E+04
         247          248  -0.38887502E-04
         247          249  -0.12035985E+00
         247          250   0.49505150E-01
         247          231  -0.18229190E-06
         247          232   0.00000000E+00
         247          233   0.00000000E+00
         247          234   0.58149055E-08
         247          235   0.16475051E-09
         247          236  -0.46804003E-05
         247          237  -0.58937839E-05
         247          238   0.15713863E-13
         247          239   0.28826778E-09
         247          240  -0.11851393E-09
         247          251  -0.27360508E-06
         247          252   0.00000000E+00
         247          253   0.00000000E+00
         247          254   0.87276927E-08
         247          255   0.24727690E-09
         247          256  -0.70248941E-05
         247          257  -0.88460827E-05
         247          258   0.23585210E-13
         247          259   0.43266612E-09
         247          260  -0.17787962E-09
         248          248   0.66308262E-04
         248          241   0.00000000E+00
         248          242   0.00000000E+00
         248          243   0.00000000E+00
         248          244   0.00000000E+00
         248          245   0.00000000E+00
         248          246   0.00000000E+00
         248          247  -0.38896922E-04
         248          249  -0.14946245E-04
         248          250  -0.37051937E-04
         248          231   0.00000000E+00
         248          232   0.00000000E+00
         248          233   0.00000000E+00
         248          234   0.00000000E+00
         248          235   0.00000000E+00
         248          236   0.00000000E+00
         248          237   0.15715131E-13
         248          238  -0.23320538E-13
         248          239  -0.29226998E-14
         248          240   0.11296639E-13
         248          251   0.00000000E+00
         248          252   0.00000000E+00
         248          253   0.00000000E+00
         248          254   0.00000000E+00
         248          255   0.00000000E+00
         248          256   0.00000000E+00
         248          257   0.23587113E-13
         248          258  -0.35002201E-13
         248          259  -0.43867309E-14
         248          260   0.16955322E-13
         249          249   0.99356224E+02
         249          241   0.00000000E+00
         249          242   0.00000000E+00
         249          243   0.00000000E+00
         249          244   0.00000000E+00
         249          245   0.00000000E+00
         249          246   0.43198833E-04
         249          247  -0.12034781E+00
         249          248  -0.14942654E-04
         249          250   0.33536708E+02
         249          231   0.00000000E+00
         249          232   0.00000000E+00
         249          233   0.00000000E+00
         249          234   0.00000000E+00
         249          235   0.00000000E+00
         249          236   0.00000000E+00
         249          237   0.28823896E-09
         249          238  -0.29225902E-14
         249          239  -0.23794469E-06
         249          240  -0.80315886E-07
         249          251   0.00000000E+00
         249          252   0.00000000E+00
         249          253   0.00000000E+00
         249          254   0.00000000E+00
         249          255   0.00000000E+00
         249          256   0.00000000E+00
         249          257   0.43262286E-09
         249          258  -0.43865664E-14
         249          259  -0.35713531E-06
         249          260  -0.12054751E-06
         250          250   0.13484933E+05
         250          241   0.36307130E+04
         250          242   0.24834091E+03
         250          243   0.00000000E+00
         250          244   0.00000000E+00
         250          245   0.21795340E-05
         250          246   0.00000000E+00
         250          247   0.49505150E-01
         250          248  -0.37042339E-04
         250          249   0.33536708E+02
         250          231  -0.86950685E-05
         250          232  -0.59474311E-06
         250          233   0.00000000E+00
         250          234   0.00000000E+00
         250          235  -0.52196911E-14
         250          236   0.00000000E+00
         250          237  -0.11851393E-09
         250          238   0.11294945E-13
         250          239  -0.80315886E-07
         250          240  -0.32294600E-04
         250          251  -0.13050579E-04
         250          252  -0.89266026E-06
         250          253   0.00000000E+00
         250          254   0.00000000E+00
         250          255  -0.78343250E-14
         250          256   0.00000000E+00
         250          257  -0.17787962E-09
         250          258   0.16952779E-13
         250          259  -0.12054751E-06
         250          260  -0.48471527E-04
         251          251   0.97945219E+04
         251          252   0.00000000E+00
         251          253   0.00000000E+00
         251          254   0.00000000E+00
         251          255   0.00000000E+00
         251          256   0.79884210E+02
         251          257   0.76117799E+02
         251          258   0.00000000E+00
         251          259   0.00000000E+00
         251          260   0.36307130E+04
         251          241  -0.23456562E-04
         251          242   0.00000000E+00
         251          243   0.00000000E+00
         251          244   0.00000000E+00
         251          245   0.00000000E+00
         251          246  -0.19131143E-06
         251          247  -0.18229190E-06
         251          248   0.00000000E+00
         251          249   0.00000000E+00
         251          250  -0.86950685E-05
         251          261  -0.35206434E-04
         251          262   0.00000000E+00
         251          263   0.00000000E+00
         251          264   0.00000000E+00
         251          265   0.00000000E+00
         251          266  -0.28714324E-06
         251          267  -0.27360564E-06
         251          268   0.00000000E+00
         251          269   0.00000000E+00
         251          270  -0.13050606E-04
         252          252   0.61664984E+04
         252          251   0.00000000E+00
         252          253   0.00000000E+00
         252          254   0.63450217E+01
         252          255   0.63450217E+01
         252          256   0.00000000E+00
         252          257  -0.21136331E+02
         252          258   0.00000000E+00
         252          259   0.00000000E+00
         252          260   0.24834091E+03
         252          241   0.00000000E+00
         252          242  -0.14762870E-04
         252          243   0.00000000E+00
         252          244   0.00000000E+00
         252          245   0.00000000E+00
         252          246   0.00000000E+00
         252          247   0.00000000E+00
         252          248   0.00000000E+00
         252          249   0.00000000E+00
         252          250  -0.59474311E-06
         252          261   0.00000000E+00
         252          262  -0.22157894E-04
         252          263   0.00000000E+00
         252          264   0.00000000E+00
         252          265   0.00000000E+00
         252          266   0.00000000E+00
         252          267   0.00000000E+00
         252          268   0.00000000E+00
         252          269   0.00000000E+00
         252          270  -0.89266210E-06
         253          253   0.78082192E+03
         253          251   0.00000000E+00
         253          252   0.00000000E+00
         253          254   0.00000000E+00
         253          255   0.00000000E+00
         253          256   0.00000000E+00
         253          257   0.00000000E+00
         253          258   0.00000000E+00
         253          259   0.00000000E+00
         253          260   0.00000000E+00
         253          241   0.00000000E+00
         253          242   0.00000000E+00
         253          243  -0.18699636E-05
         253          244   0.00000000E+00
         253          245   0.00000000E+00
         253          246   0.00000000E+00
         253          247   0.00000000E+00
         253          248   0.00000000E+00
         253          249   0.00000000E+00
         253          250   0.00000000E+00
         253          261   0.00000000E+00
         253          262   0.00000000E+00
         253          263  -0.28066666E-05
         253          264   0.00000000E+00
         253          265   0.00000000E+00
         253          266   0.00000000E+00
         253          267   0.00000000E+00
         253          268   0.00000000E+00
         253          269   0.00000000E+00
         253          270   0.00000000E+00
         254          254   0.13409529E+04
         254          251   0.00000000E+00
         254          252   0.63443872E+01
         254          253   0.00000000E+00
         254          255   0.19035065E+02
         254          256   0.00000000E+00
         254          257  -0.65836821E+02
         254          258   0.00000000E+00
         254          259   0.00000000E+00
         254          260   0.00000000E+00
         254          241   0.00000000E+00
         254          242   0.00000000E+00
         254          243   0.00000000E+00
         254          244  -0.31658155E-05
         254          245   0.00000000E+00
         254          246   0.00000000E+00
         254          247   0.58143241E-08
         254          248   0.00000000E+00
         254          249   0.00000000E+00
         254          250   0.00000000E+00
         254          261   0.00000000E+00
         254          262   0.00000000E+00
         254          263   0.00000000E+00
         254          264  -0.47516372E-05
         254          265   0.00000000E+00
         254          266   0.00000000E+00
         254          267   0.87268380E-08
         254          268   0.00000000E+00
         254          269   0.00000000E+00
         254          270   0.00000000E+00
         255          255   0.19052837E+02
         255          251   0.00000000E+00
         255          252   0.63443872E+01
         255          253   0.00000000E+00
         255          254   0.19035065E+02
         255          256   0.00000000E+00
         255          257  -0.63477866E+02
         255          258   0.00000000E+00
         255          259   0.00000000E+00
         255          260   0.21795643E-05
         255          241   0.00000000E+00
         255          242   0.00000000E+00
         255          243   0.00000000E+00
         255          244   0.00000000E+00
         255          245  -0.42484262E-10
         255          246   0.00000000E+00
         255          247   0.16470994E-09
         255          248   0.00000000E+00
         255          249   0.00000000E+00
         255          250  -0.52197636E-14
         255          261   0.00000000E+00
         255          262   0.00000000E+00
         255          263   0.00000000E+00
         255          264   0.00000000E+00
         255          265  -0.63765498E-10
         255          266   0.00000000E+00
         255          267   0.24721652E-09
         255          268   0.00000000E+00
         255          269   0.00000000E+00
         255          270  -0.78344501E-14
         256          256   0.17074662E+04
         256          251   0.79884210E+02
         256          252   0.00000000E+00
         256          253   0.00000000E+00
         256          254   0.00000000E+00
         256          255   0.00000000E+00
         256          257   0.19543730E+04
         256          258   0.00000000E+00
         256          259   0.43198833E-04
         256          260   0.00000000E+00
         256          241  -0.19131143E-06
         256          242   0.00000000E+00
         256          243   0.00000000E+00
         256          244   0.00000000E+00
         256          245   0.00000000E+00
         256          246  -0.40891514E-05
         256          247  -0.46804606E-05
         256          248   0.00000000E+00
         256          249   0.00000000E+00
         256          250   0.00000000E+00
         256          261  -0.28714324E-06
         256          262   0.00000000E+00
         256          263   0.00000000E+00
         256          264   0.00000000E+00
         256          265   0.00000000E+00
         256          266  -0.61374910E-05
         256          267  -0.70249991E-05
         256          268   0.00000000E+00
         256          269   0.00000000E+00
         256          270   0.00000000E+00
         257          257   0.26723718E+04
         257          251   0.76117799E+02
         257          252  -0.21147957E+02
         257          253   0.00000000E+00
         257          254  -0.65878288E+02
         257          255  -0.63519108E+02
         257          256   0.19543478E+04
         257          258  -0.38887502E-04
         257          259  -0.12035985E+00
         257          260   0.49505150E-01
         257          241  -0.18229190E-06
         257          242   0.00000000E+00
         257          243   0.00000000E+00
         257          244   0.58149055E-08
         257          245   0.16475051E-09
         257          246  -0.46804003E-05
         257          247  -0.58937839E-05
         257          248   0.15713863E-13
         257          249   0.28826778E-09
         257          250  -0.11851393E-09
         257          261  -0.27360564E-06
         257          262   0.00000000E+00
         257          263   0.00000000E+00
         257          264   0.87277107E-08
         257          265   0.24727741E-09
         257          266  -0.70249086E-05
         257          267  -0.88461009E-05
         257          268   0.23585258E-13
         257          269   0.43266701E-09
         257          270  -0.17787998E-09
         258          258   0.66308262E-04
         258          251   0.00000000E+00
         258          252   0.00000000E+00
         258          253   0.00000000E+00
         258          254   0.00000000E+00
         258          255   0.00000000E+00
         258          256   0.00000000E+00
         258          257  -0.38896922E-04
         258          259  -0.14946245E-04
         258          260  -0.37051937E-04
         258          241   0.00000000E+00
         258          242   0.00000000E+00
         258          243   0.00000000E+00
         258          244   0.00000000E+00
         258          245   0.00000000E+00
         258          246   0.00000000E+00
         258          247   0.15715131E-13
         258          248  -0.23320538E-13
         258          249  -0.29226998E-14
         258          250   0.11296639E-13
         258          261   0.00000000E+00
         258          262   0.00000000E+00
         258          263   0.00000000E+00
         258          264   0.00000000E+00
         258          265   0.00000000E+00
         258          266   0.00000000E+00
         258          267   0.23587162E-13
         258          268  -0.35002273E-13
         258          269  -0.43867399E-14
         258          270   0.16955357E-13
         259          259   0.99356224E+02
         259          251   0.00000000E+00
         259          252   0.00000000E+00
         259          253   0.00000000E+00
         259          254   0.00000000E+00
         259          255   0.00000000E+00
         259          256   0.43198833E-04
         259          257  -0.12034781E+00
         259          258  -0.14942654E-04
         259          260   0.33536708E+02
         259          241   0.00000000E+00
         259          242   0.00000000E+00
         259          243   0.00000000E+00
         259          244   0.00000000E+00
         259          245   0.00000000E+00
         259          246   0.00000000E+00
         259          247   0.28823896E-09
         259          248  -0.29225902E-14
         259          249  -0.23794469E-06
         259          250  -0.80315886E-07
         259          261   0.00000000E+00
         259          262   0.00000000E+00
         259          263   0.00000000E+00
         259          264   0.00000000E+00
         259          265   0.00000000E+00
         259          266   0.00000000E+00
         259          267   0.43262375E-09
         259          268  -0.43865754E-14
         259          269  -0.35713605E-06
         259          270  -0.12054776E-06
         260          260   0.13484933E+05
         260          251   0.36307130E+04
         260          252   0.24834091E+03
         260          253   0.00000000E+00
         260          254   0.00000000E+00
         260          255   0.21795340E-05
         260          256   0.00000000E+00
         260          257   0.49505150E-01
         260          258  -0.37042339E-04
         260          259   0.33536708E+02
         260          241  -0.86950685E-05
         260          242  -0.59474311E-06
         260          243   0.00000000E+00
         260          244   0.00000000E+00
         260          245  -0.52196911E-14
         260          246   0.00000000E+00
         260          247  -0.11851393E-09
         260          248   0.11294945E-13
         260          249  -0.80315886E-07
         260          250  -0.32294600E-04
         260          261  -0.13050606E-04
         260          262  -0.89266210E-06
         260          263   0.00000000E+00
         260          264   0.00000000E+00
         260          265  -0.78343411E-14
         260          266   0.00000000E+00
         260          267  -0.17787998E-09
         260          268   0.16952814E-13
         260          269  -0.12054776E-06
         260          270  -0.48471626E-04
         261          261   0.97945219E+04
         261          262   0.00000000E+00
         261          263   0.00000000E+00
         261          264   0.00000000E+00
         261          265   0.00000000E+00
         261          266   0.79884210E+02
         261          267   0.76117799E+02
         261          268   0.00000000E+00
         261          269   0.00000000E+00
         261          270   0.36307130E+04
         261          251  -0.23456563E-04
         261          252   0.00000000E+00
         261          253   0.00000000E+00
         261          254   0.00000000E+00
         261          255   0.00000000E+00
         261          256  -0.19131143E-06
         261          257  -0.18229190E-06
         261          258   0.00000000E+00
         261          259   0.00000000E+00
         261          260  -0.86950688E-05
         261          271  -0.35206435E-04
         261          272   0.00000000E+00
         261          273   0.00000000E+00
         261          274   0.00000000E+00
         261          275   0.00000000E+00
         261          276  -0.28714324E-06
         261          277  -0.27360565E-06
         261          278   0.00000000E+00
         261          279   0.00000000E+00
         261          280  -0.13050607E-04
         262          262   0.61664984E+04
         262          261   0.00000000E+00
         262          263   0.00000000E+00
         262          264   0.63450217E+01
         262          265   0.63450217E+01
         262          266   0.00000000E+00
         262          267  -0.21136331E+02
         262          268   0.00000000E+00
         262          269   0.00000000E+00
         262          270   0.24834091E+03
         262          251   0.00000000E+00
         262          252  -0.14762871E-04
         262          253   0.00000000E+00
         262          254   0.00000000E+00
         262          255   0.00000000E+00
         262          256   0.00000000E+00
         262          257   0.00000000E+00
         262          258   0.00000000E+00
         262          259   0.00000000E+00
         262          260  -0.59474313E-06
         262          271   0.00000000E+00
         262          272  -0.22157895E-04
         262          273   0.00000000E+00
         262          274   0.00000000E+00
         262          275   0.00000000E+00
         262          276   0.00000000E+00
         262          277   0.00000000E+00
         262          278   0.00000000E+00
         262          279   0.00000000E+00
         262          280  -0.89266212E-06
         263          263   0.78082192E+03
         263          261   0.00000000E+00
         263          262   0.00000000E+00
         263          264   0.00000000E+00
         263          265   0.00000000E+00
         263          266   0.00000000E+00
         263          267   0.00000000E+00
         263          268   0.00000000E+00
         263          269   0.00000000E+00
         263          270   0.00000000E+00
         263          251   0.00000000E+00
         263          252   0.00000000E+00
         263          253  -0.18699636E-05
         263          254   0.00000000E+00
         263          255   0.00000000E+00
         263          256   0.00000000E+00
         263          257   0.00000000E+00
         263          258   0.00000000E+00
         263          259   0.00000000E+00
         263          260   0.00000000E+00
         263          271   0.00000000E+00
         263          272   0.00000000E+00
         263          273  -0.28066666E-05
         263          274   0.00000000E+00
         263          275   0.00000000E+00
         263          276   0.00000000E+00
         263          277   0.00000000E+00
         263          278   0.00000000E+00
         263          279   0.00000000E+00
         263          280   0.00000000E+00
         264          264   0.13409529E+04
         264          261   0.00000000E+00
         264          262   0.63443872E+01
         264          263   0.00000000E+00
         264          265   0.19035065E+02
         264          266   0.00000000E+00
         264          267  -0.65836821E+02
         264          268   0.00000000E+00
         264          269   0.00000000E+00
         264          270   0.00000000E+00
         264          251   0.00000000E+00
         264          252   0.00000000E+00
         264          253   0.00000000E+00
         264          254  -0.31658156E-05
         264          255   0.00000000E+00
         264          256   0.00000000E+00
         264          257   0.58143243E-08
         264          258   0.00000000E+00
         264          259   0.00000000E+00
         264          260   0.00000000E+00
         264          271   0.00000000E+00
         264          272   0.00000000E+00
         264          273   0.00000000E+00
         264          274  -0.47516374E-05
         264          275   0.00000000E+00
         264          276   0.00000000E+00
         264          277   0.87268382E-08
         264          278   0.00000000E+00
         264          279   0.00000000E+00
         264          280   0.00000000E+00
         265          265   0.19052837E+02
         265          261   0.00000000E+00
         265          262   0.63443872E+01
         265          263   0.00000000E+00
         265          264   0.19035065E+02
         265          266   0.00000000E+00
         265          267  -0.63477866E+02
         265          268   0.00000000E+00
         265          269   0.00000000E+00
         265          270   0.21795643E-05
         265          251   0.00000000E+00
         265          252   0.00000000E+00
         265          253   0.00000000E+00
         265          254   0.00000000E+00
         265          255  -0.42484263E-10
         265          256   0.00000000E+00
         265          257   0.16470995E-09
         265          258   0.00000000E+00
         265          259   0.00000000E+00
         265          260  -0.52197638E-14
         265          271   0.00000000E+00
         265          272   0.00000000E+00
         265          273   0.00000000E+00
         265          274   0.00000000E+00
         265          275  -0.63765499E-10
         265          276   0.00000000E+00
         265          277   0.24721653E-09
         265          278   0.00000000E+00
         265          279   0.00000000E+00
         265          280  -0.78344502E-14
         266          266   0.17074662E+04
         266          261   0.79884210E+02
         266          262   0.00000000E+00
         266          263   0.00000000E+00
         266          264   0.00000000E+00
         266          265   0.00000000E+00
         266          267   0.19543730E+04
         266          268   0.00000000E+00
         266          269   0.43198833E-04
         266          270   0.00000000E+00
         266          251  -0.19131143E-06
         266          252   0.00000000E+00
         266          253   0.00000000E+00
         266          254   0.00000000E+00
         266          255   0.00000000E+00
         266          256  -0.40891515E-05
         266          257  -0.46804608E-05
         266          258   0.00000000E+00
         266          259   0.00000000E+00
         266          260   0.00000000E+00
         266          271  -0.28714324E-06
         266          272   0.00000000E+00
         266          273   0.00000000E+00
         266          274   0.00000000E+00
         266          275   0.00000000E+00
         266          276  -0.61374911E-05
         266          277  -0.70249993E-05
         266          278   0.00000000E+00
         266          279   0.00000000E+00
         266          280   0.00000000E+00
         267          267   0.26723718E+04
         267          261   0.76117799E+02
         267          262  -0.21147957E+02
         267          263   0.00000000E+00
         267          264  -0.65878288E+02
         267          265  -0.63519108E+02
         267          266   0.19543478E+04
         267          268  -0.38887502E-04
         267          269  -0.12035985E+00
         267          270   0.49505150E-01
         267          251  -0.18229190E-06
         267          252   0.00000000E+00
         267          253   0.00000000E+00
         267          254   0.58149057E-08
         267          255   0.16475051E-09
         267          256  -0.46804005E-05
         267          257  -0.58937841E-05
         267          258   0.15713863E-13
         267          259   0.28826779E-09
         267          260  -0.11851393E-09
         267          271  -0.27360565E-06
         267          272   0.00000000E+00
         267          273   0.00000000E+00
         267          274   0.87277109E-08
         267          275   0.24727742E-09
         267          276  -0.70249088E-05
         267          277  -0.88461011E-05
         267          278   0.23585259E-13
         267          279   0.43266702E-09
         267          280  -0.17787999E-09
         268          268   0.66308262E-04
         268          261   0.00000000E+00
         268          262   0.00000000E+00
         268          263   0.00000000E+00
         268          264   0.00000000E+00
         268          265   0.00000000E+00
         268          266   0.00000000E+00
         268          267  -0.38896922E-04
         268          269  -0.14946245E-04
         268          270  -0.37051937E-04
         268          251   0.00000000E+00
         268          252   0.00000000E+00
         268          253   0.00000000E+00
         268          254   0.00000000E+00
         268          255   0.00000000E+00
         268          256   0.00000000E+00
         268          257   0.15715132E-13
         268          258  -0.23320539E-13
         268          259  -0.29226999E-14
         268          260   0.11296639E-13
         268          271   0.00000000E+00
         268          272   0.00000000E+00
         268          273   0.00000000E+00
         268          274   0.00000000E+00
         268          275   0.00000000E+00
         268          276   0.00000000E+00
         268          277   0.23587162E-13
         268          278  -0.35002274E-13
         268          279  -0.43867400E-14
         268          280   0.16955357E-13
         269          269   0.99356224E+02
         269          261   0.00000000E+00
         269          262   0.00000000E+00
         269          263   0.00000000E+00
         269          264   0.00000000E+00
         269          265   0.00000000E+00
         269          266   0.43198833E-04
         269          267  -0.12034781E+00
         269          268  -0.14942654E-04
         269          270   0.33536708E+02
         269          251   0.00000000E+00
         269          252   0.00000000E+00
         269          253   0.00000000E+00
         269          254   0.00000000E+00
         269          255   0.00000000E+00
         269          256   0.00000000E+00
         269          257   0.28823897E-09
         269          258  -0.29225903E-14
         269          259  -0.23794469E-06
         269          260  -0.80315889E-07
         269          271   0.00000000E+00
         269          272   0.00000000E+00
         269          273   0.00000000E+00
         269          274   0.00000000E+00
         269          275   0.00000000E+00
         269          276   0.00000000E+00
         269          277   0.43262376E-09
         269          278  -0.43865755E-14
         269          279  -0.35713606E-06
         269          280  -0.12054776E-06
         270          270   0.13484933E+05
         270          261   0.36307130E+04
         270          262   0.24834091E+03
         270          263   0.00000000E+00
         270          264   0.00000000E+00
         270          265   0.21795340E-05
         270          266   0.00000000E+00
         270          267   0.49505150E-01
         270          268  -0.37042339E-04
         270          269   0.33536708E+02
         270          251  -0.86950688E-05
         270          252  -0.59474313E-06
         270          253   0.00000000E+00
         270          254   0.00000000E+00
         270          255  -0.52196912E-14
         270          256   0.00000000E+00
         270          257  -0.11851393E-09
         270          258   0.11294945E-13
         270          259  -0.80315889E-07
         270          260  -0.32294601E-04
         270          271  -0.13050607E-04
         270          272  -0.89266212E-06
         270          273   0.00000000E+00
         270          274   0.00000000E+00
         270          275  -0.78343413E-14
         270          276   0.00000000E+00
         270          277  -0.17787999E-09
         270          278   0.16952814E-13
         270          279  -0.12054776E-06
         270          280  -0.48471627E-04
         271          271   0.97945219E+04
         271          272   0.00000000E+00
         271          273   0.00000000E+00
         271          274   0.00000000E+00
         271          275   0.00000000E+00
         271          276   0.79884210E+02
         271          277   0.76117799E+02
         271          278   0.00000000E+00
         271          279   0.00000000E+00
         271          280   0.36307130E+04
         271          261  -0.23456563E-04
         271          262   0.00000000E+00
         271          263   0.00000000E+00
         271          264   0.00000000E+00
         271          265   0.00000000E+00
         271          266  -0.19131143E-06
         271          267  -0.18229190E-06
         271          268   0.00000000E+00
         271          269   0.00000000E+00
         271          270  -0.86950688E-05
         271          281  -0.35206435E-04
         271          282   0.00000000E+00
         271          283   0.00000000E+00
         271          284   0.00000000E+00
         271          285   0.00000000E+00
         271          286  -0.28714324E-06
         271          287  -0.27360565E-06
         271          288   0.00000000E+00
         271          289   0.00000000E+00
         271          290  -0.13050607E-04
         272          272   0.61664984E+04
         272          271   0.00000000E+00
         272          273   0.00000000E+00
         272          274   0.63450217E+01
         272          275   0.63450217E+01
         272          276   0.00000000E+00
         272          277  -0.21136331E+02
         272          278   0.00000000E+00
         272          279   0.00000000E+00
         272          280   0.24834091E+03
         272          261   0.00000000E+00
         272          262  -0.14762871E-04
         272          263   0.00000000E+00
         272          264   0.00000000E+00
         272          265   0.00000000E+00
         272          266   0.00000000E+00
         272          267   0.00000000E+00
         272          268   0.00000000E+00
         272          269   0.00000000E+00
         272          270  -0.59474313E-06
         272          281   0.00000000E+00
         272          282  -0.22157895E-04
         272          283   0.00000000E+00
         272          284   0.00000000E+00
         272          285   0.00000000E+00
         272          286   0.00000000E+00
         272          287   0.00000000E+00
         272          288   0.00000000E+00
         272          289   0.00000000E+00
         272          290  -0.89266212E-06
         273          273   0.78082192E+03
         273          271   0.00000000E+00
         273          272   0.00000000E+00
         273          274   0.00000000E+00
         273          275   0.00000000E+00
         273          276   0.00000000E+00
         273          277   0.00000000E+00
         273          278   0.00000000E+00
         273          279   0.00000000E+00
         273          280   0.00000000E+00
         273          261   0.00000000E+00
         273          262   0.00000000E+00
         273          263  -0.18699636E-05
         273          264   0.00000000E+00
         273          265   0.00000000E+00
         273          266   0.00000000E+00
         273          267   0.00000000E+00
         273          268   0.00000000E+00
         273          269   0.00000000E+00
         273          270   0.00000000E+00
         273          281   0.00000000E+00
         273          282   0.00000000E+00
         273          283  -0.28066666E-05
         273          284   0.00000000E+00
         273          285   0.00000000E+00
         273          286   0.00000000E+00
         273          287   0.00000000E+00
         273          288   0.00000000E+00
         273          289   0.00000000E+00
         273          290   0.00000000E+00
         274          274   0.13409529E+04
         274          271   0.00000000E+00
         274          272   0.63443872E+01
         274          273   0.00000000E+00
         274          275   0.19035065E+02
         274          276   0.00000000E+00
         274          277  -0.65836821E+02
         274          278   0.00000000E+00
         274          279   0.00000000E+00
         274          280   0.00000000E+00
         274          261   0.00000000E+00
         274          262   0.00000000E+00
         274          263   0.00000000E+00
         274          264  -0.31658156E-05
         274          265   0.00000000E+00
         274          266   0.00000000E+00
         274          267   0.58143243E-08
         274          268   0.00000000E+00
         274          269   0.00000000E+00
         274          270   0.00000000E+00
         274          281   0.00000000E+00
         274          282   0.00000000E+00
         274          283   0.00000000E+00
         274          284  -0.47516374E-05
         274          285   0.00000000E+00
         274          286   0.00000000E+00
         274          287   0.87268382E-08
         274          288   0.00000000E+00
         274          289   0.00000000E+00
         274          290   0.00000000E+00
         275          275   0.19052837E+02
         275          271   0.00000000E+00
         275          272   0.63443872E+01
         275          273   0.00000000E+00
         275          274   0.19035065E+02
         275          276   0.00000000E+00
         275          277  -0.63477866E+02
         275          278   0.00000000E+00
         275          279   0.00000000E+00
         275          280   0.21795643E-05
         275          261   0.00000000E+00
         275          262   0.00000000E+00
         275          263   0.00000000E+00
         275          264   0.00000000E+00
         275          265  -0.42484263E-10
         275          266   0.00000000E+00
         275          267   0.16470995E-09
         275          268   0.00000000E+00
         275          269   0.00000000E+00
         275          270  -0.52197638E-14
         275          281   0.00000000E+00
         275          282   0.00000000E+00
         275          283   0.00000000E+00
         275          284   0.00000000E+00
         275          285  -0.63765499E-10
         275          286   0.00000000E+00
         275          287   0.24721653E-09
         275          288   0.00000000E+00
         275          289   0.00000000E+00
         275          290  -0.78344502E-14
         276          276   0.17074662E+04
         276          271   0.79884210E+02
         276          272   0.00000000E+00
         276          273   0.00000000E+00
         276          274   0.00000000E+00
         276          275   0.00000000E+00
         276          277   0.19543730E+04
         276          278   0.00000000E+00
         276          279   0.43198833E-04
         276          280   0.00000000E+00
         276          261  -0.19131143E-06
         276          262   0.00000000E+00
         276          263   0.00000000E+00
         276          264   0.00000000E+00
         276          265   0.00000000E+00
         276          266  -0.40891515E-05
         276          267  -0.46804608E-05
         276          268   0.00000000E+00
         276          269   0.00000000E+00
         276          270   0.00000000E+00
         276          281  -0.28714324E-06
         276          282   0.00000000E+00
         276          283   0.00000000E+00
         276          284   0.00000000E+00
         276          285   0.00000000E+00
         276          286  -0.61374911E-05
         276          287  -0.70249993E-05
         276          288   0.00000000E+00
         276          289   0.00000000E+00
         276          290   0.00000000E+00
         277          277   0.26723718E+04
         277          271   0.76117799E+02
         277          272  -0.21147957E+02
         277          273   0.00000000E+00
         277          274  -0.65878288E+02
         277          275  -0.63519108E+02
         277          276   0.19543478E+04
         277          278  -0.38887502E-04
         277          279  -0.12035985E+00
         277          280   0.49505150E-01
         277          261  -0.18229190E-06
         277          262   0.00000000E+00
         277          263   0.00000000E+00
         277          264   0.58149057E-08
         277          265   0.16475051E-09
         277          266  -0.46804005E-05
         277          267  -0.58937841E-05
         277          268   0.15713863E-13
         277          269   0.28826779E-09
         277          270  -0.11851393E-09
         277          281  -0.27360565E-06
         277          282   0.00000000E+00
         277          283   0.00000000E+00
         277          284   0.87277109E-08
         277          285   0.24727742E-09
         277          286  -0.70249088E-05
         277          287  -0.88461011E-05
         277          288   0.23585259E-13
         277          289   0.43266702E-09
         277          290  -0.17787999E-09
         278          278   0.66308262E-04
         278          271   0.00000000E+00
         278          272   0.00000000E+00
         278          273   0.00000000E+00
         278          274   0.00000000E+00
         278          275   0.00000000E+00
         278          276   0.00000000E+00
         278          277  -0.38896922E-04
         278          279  -0.14946245E-04
         278          280  -0.37051937E-04
         278          261   0.00000000E+00
         278          262   0.00000000E+00
         278          263   0.00000000E+00
         278          264   0.00000000E+00
         278          265   0.00000000E+00
         278          266   0.00000000E+00
         278          267   0.15715132E-13
         278          268  -0.23320539E-13
         278          269  -0.29226999E-14
         278          270   0.11296639E-13
         278          281   0.00000000E+00
         278          282   0.00000000E+00
         278          283   0.00000000E+00
         278          284   0.00000000E+00
         278          285   0.00000000E+00
         278          286   0.00000000E+00
         278          287   0.23587162E-13
         278          288  -0.35002274E-13
         278          289  -0.43867400E-14
         278          290   0.16955357E-13
         279          279   0.99356224E+02
         279          271   0.00000000E+00
         279          272   0.00000000E+00
         279          273   0.00000000E+00
         279          274   0.00000000E+00
         279          275   0.00000000E+00
         279          276   0.43198833E-04
         279          277  -0.12034781E+00
         279          278  -0.14942654E-04
         279          280   0.33536708E+02
         279          261   0.00000000E+00
         279          262   0.00000000E+00
         279          263   0.00000000E+00
         279          264   0.00000000E+00
         279          265   0.00000000E+00
         279          266   0.00000000E+00
         279          267   0.28823897E-09
         279          268  -0.29225903E-14
         279          269  -0.23794469E-06
         279          270  -0.80315889E-07
         279          281   0.00000000E+00
         279          282   0.00000000E+00
         279          283   0.00000000E+00
         279          284   0.00000000E+00
         279          285   0.00000000E+00
         279          286   0.00000000E+00
         279          287   0.43262376E-09
         279          288  -0.43865755E-14
         279          289  -0.35713606E-06
         279          290  -0.12054776E-06
         280          280   0.13484933E+05
         280          271   0.36307130E+04
         280          272   0.24834091E+03
         280          273   0.00000000E+00
         280          274   0.00000000E+00
         280          275   0.21795340E-05
         280          276   0.00000000E+00
         280          277   0.49505150E-01
         280          278  -0.37042339E-04
         280          279   0.33536708E+02
         280          261  -0.86950688E-05
         280          262  -0.59474313E-06
         280          263   0.00000000E+00
         280          264   0.00000000E+00
         280          265  -0.52196912E-14
         280          266   0.00000000E+00
         280          267  -0.11851393E-09
         280          268   0.11294945E-13
         280          269  -0.80315889E-07
         280          270  -0.32294601E-04
         280          281  -0.13050607E-04
         280          282  -0.89266212E-06
         280          283   0.00000000E+00
         280          284   0.00000000E+00
         280          285  -0.78343413E-14
         280          286   0.00000000E+00
         280          287  -0.17787999E-09
         280          288   0.16952814E-13
         280          289  -0.12054776E-06
         280          290  -0.48471627E-04
         281          281   0.97945219E+04
         281          282   0.00000000E+00
         281          283   0.00000000E+00
         281          284   0.00000000E+00
         281          285   0.00000000E+00
         281          286   0.79884210E+02
         281          287   0.76117799E+02
         281          288   0.00000000E+00
         281          289   0.00000000E+00
         281          290   0.36307130E+04
         281          271  -0.23456563E-04
         281          272   0.00000000E+00
         281          273   0.00000000E+00
         281          274   0.00000000E+00
         281          275   0.00000000E+00
         281          276  -0.19131143E-06
         281          277  -0.18229190E-06
         281          278   0.00000000E+00
         281          279   0.00000000E+00
         281          280  -0.86950688E-05
         281          291  -0.35206435E-04
         281          292   0.00000000E+00
         281          293   0.00000000E+00
         281          294   0.00000000E+00
         281          295   0.00000000E+00
         281          296  -0.28714324E-06
         281          297  -0.27360565E-06
         281          298   0.00000000E+00
         281          299   0.00000000E+00
         281          300  -0.13050607E-04
         282          282   0.61664984E+04
         282          281   0.00000000E+00
         282          283   0.00000000E+00
         282          284   0.63450217E+01
         282          285   0.63450217E+01
         282          286   0.00000000E+00
         282          287  -0.21136331E+02
         282          288   0.00000000E+00
         282          289   0.00000000E+00
         282          290   0.24834091E+03
         282          271   0.00000000E+00
         282          272  -0.14762871E-04
         282          273   0.00000000E+00
         282          274   0.00000000E+00
         282          275   0.00000000E+00
         282          276   0.00000000E+00
         282          277   0.00000000E+00
         282          278   0.00000000E+00
         282          279   0.00000000E+00
         282          280  -0.59474313E-06
         282          291   0.00000000E+00
         282          292  -0.22157895E-04
         282          293   0.00000000E+00
         282          294   0.00000000E+00
         282          295   0.00000000E+00
         282          296   0.00000000E+00
         282          297   0.00000000E+00
         282          298   0.00000000E+00
         282          299   0.00000000E+00
         282          300  -0.89266212E-06
         283          283   0.78082192E+03
         283          281   0.00000000E+00
         283          282   0.00000000E+00
         283          284   0.00000000E+00
         283          285   0.00000000E+00
         283          286   0.00000000E+00
         283          287   0.00000000E+00
         283          288   0.00000000E+00
         283          289   0.00000000E+00
         283          290   0.00000000E+00
         283          271   0.00000000E+00
         283          272   0.00000000E+00
         283          273  -0.18699636E-05
         283          274   0.00000000E+00
         283          275   0.00000000E+00
         283          276   0.00000000E+00
         283          277   0.00000000E+00
         283          278   0.00000000E+00
         283          279   0.00000000E+00
         283          280   0.00000000E+00
         283          291   0.00000000E+00
         283          292   0.00000000E+00
         283          293  -0.28066666E-05
         283          294   0.00000000E+00
         283          295   0.00000000E+00
         283          296   0.00000000E+00
         283          297   0.00000000E+00
         283          298   0.00000000E+00
         283          299   0.00000000E+00
         283          300   0.00000000E+00
         284          284   0.13409529E+04
         284          281   0.00000000E+00
         284          282   0.63443872E+01
         284          283   0.00000000E+00
         284          285   0.19035065E+02
         284          286   0.00000000E+00
         284          287  -0.65836821E+02
         284          288   0.00000000E+00
         284          289   0.00000000E+00
         284          290   0.00000000E+00
         284          271   0.00000000E+00
         284          272   0.00000000E+00
         284          273   0.00000000E+00
         284          274  -0.31658156E-05
         284          275   0.00000000E+00
         284          276   0.00000000E+00
         284          277   0.58143243E-08
         284          278   0.00000000E+00
         284          279   0.00000000E+00
         284          280   0.00000000E+00
         284          291   0.00000000E+00
         284          292   0.00000000E+00
         284          293   0.00000000E+00
         284          294  -0.47516374E-05
         284          295   0.00000000E+00
         284          296   0.00000000E+00
         284          297   0.87268382E-08
         284          298   0.00000000E+00
         284          299   0.00000000E+00
         284          300   0.00000000E+00
         285          285   0.19052837E+02
         285          281   0.00000000E+00
         285          282   0.63443872E+01
         285          283   0.00000000E+00
         285          284   0.19035065E+02
         285          286   0.00000000E+00
         285          287  -0.63477866E+02
         285          288   0.00000000E+00
         285          289   0.00000000E+00
         285          290   0.21795643E-05
         285          271   0.00000000E+00
         285          272   0.00000000E+00
         285          273   0.00000000E+00
         285          274   0.00000000E+00
         285          275  -0.42484263E-10
         285          276   0.00000000E+00
         285          277   0.16470995E-09
         285          278   0.00000000E+00
         285          279   0.00000000E+00
         285          280  -0.52197638E-14
         285          291   0.00000000E+00
         285          292   0.00000000E+00
         285          293   0.00000000E+00
         285          294   0.00000000E+00
         285          295  -0.63765499E-10
         285          296   0.00000000E+00
         285          297   0.24721653E-09
         285          298   0.00000000E+00
         285          299   0.00000000E+00
         285          300  -0.78344502E-14
         286          286   0.17074662E+04
         286          281   0.79884210E+02
         286          282   0.00000000E+00
         286          283   0.00000000E+00
         286          284   0.00000000E+00
         286          285   0.00000000E+00
         286          287   0.19543730E+04
         286          288   0.00000000E+00
         286          289   0.43198833E-04
         286          290   0.00000000E+00
         286          271  -0.19131143E-06
         286          272   0.00000000E+00
         286          273   0.00000000E+00
         286          274   0.00000000E+00
         286          275   0.00000000E+00
         286          276  -0.40891515E-05
         286          277  -0.46804608E-05
         286          278   0.00000000E+00
         286          279   0.00000000E+00
         286          280   0.00000000E+00
         286          291  -0.28714324E-06
         286          292   0.00000000E+00
         286          293   0.00000000E+00
         286          294   0.00000000E+00
         286          295   0.00000000E+00
         286          296  -0.61374911E-05
         286          297  -0.70249993E-05
         286          298   0.00000000E+00
         286          299   0.00000000E+00
         286          300   0.00000000E+00
         287          287   0.26723718E+04
         287          281   0.76117799E+02
         287          282  -0.21147957E+02
         287          283   0.00000000E+00
         287          284  -0.65878288E+02
         287          285  -0.63519108E+02
         287          286   0.19543478E+04
         287          288  -0.38887502E-04
         287          289  -0.12035985E+00
         287          290   0.49505150E-01
         287          271  -0.18229190E-06
         287          272   0.00000000E+00
         287          273   0.00000000E+00
         287          274   0.58149057E-08
         287          275   0.16475051E-09
         287          276  -0.46804005E-05
         287          277  -0.58937841E-05
         287          278   0.15713863E-13
         287          279   0.28826779E-09
         287          280  -0.11851393E-09
         287          291  -0.27360565E-06
         287          292   0.00000000E+00
         287          293   0.00000000E+00
         287          294   0.87277109E-08
         287          295   0.24727742E-09
         287          296  -0.70249088E-05
         287          297  -0.88461011E-05
         287          298   0.23585259E-13
         287          299   0.43266702E-09
         287          300  -0.17787999E-09
         288          288   0.66308262E-04
         288          281   0.00000000E+00
         288          282   0.00000000E+00
         288          283   0.00000000E+00
         288          284   0.00000000E+00
         288          285   0.00000000E+00
         288          286   0.00000000E+00
         288          287  -0.38896922E-04
         288          289  -0.14946245E-04
         288          290  -0.37051937E-04
         288          271   0.00000000E+00
         288          272   0.00000000E+00
         288          273   0.00000000E+00
         288          274   0.00000000E+00
         288          275   0.00000000E+00
         288          276   0.00000000E+00
         288          277   0.15715132E-13
         288          278  -0.23320539E-13
         288          279  -0.29226999E-14
         288          280   0.11296639E-13
         288          291   0.00000000E+00
         288          292   0.00000000E+00
         288          293   0.00000000E+00
         288          294   0.00000000E+00
         288          295   0.00000000E+00
         288          296   0.00000000E+00
         288          297   0.23587162E-13
         288          298  -0.35002274E-13
         288          299  -0.43867400E-14
         288          300   0.16955357E-13
         289          289   0.99356224E+02
         289          281   0.00000000E+00
         289          282   0.00000000E+00
         289          283   0.00000000E+00
         289          284   0.00000000E+00
         289          285   0.00000000E+00
         289          286   0.43198833E-04
         289          287  -0.12034781E+00
         289          288  -0.14942654E-04
         289          290   0.33536708E+02
         289          271   0.00000000E+00
         289          272   0.00000000E+00
         289          273   0.00000000E+00
         289          274   0.00000000E+00
         289          275   0.00000000E+00
         289          276   0.00000000E+00
         289          277   0.28823897E-09
         289          278  -0.29225903E-14
         289          279  -0.23794469E-06
         289          280  -0.80315889E-07
         289          291   0.00000000E+00
         289          292   0.00000000E+00
         289          293   0.00000000E+00
         289          294   0.00000000E+00
         289          295   0.00000000E+00
         289          296   0.00000000E+00
         289          297   0.43262376E-09
         289          298  -0.43865755E-14
         289          299  -0.35713606E-06
         289          300  -0.12054776E-06
         290          290   0.13484933E+05
         290          281   0.36307130E+04
         290          282   0.24834091E+03
         290          283   0.00000000E+00
         290          284   0.00000000E+00
         290          285   0.21795340E-05
         290          286   0.00000000E+00
         290          287   0.49505150E-01
         290          288  -0.37042339E-04
         290          289   0.33536708E+02
         290          271  -0.86950688E-05
         290          272  -0.59474313E-06
         290          273   0.00000000E+00
         290          274   0.00000000E+00
         290          275  -0.52196912E-14
         290          276   0.00000000E+00
         290          277  -0.11851393E-09
         290          278   0.11294945E-13
         290          279  -0.80315889E-07
         290          280  -0.32294601E-04
         290          291  -0.13050607E-04
         290          292  -0.89266212E-06
         290          293   0.00000000E+00
         290          294   0.00000000E+00
         290          295  -0.78343413E-14
         290          296   0.00000000E+00
         290          297  -0.17787999E-09
         290          298   0.16952814E-13
         290          299  -0.12054776E-06
         290          300  -0.48471627E-04
         291          291   0.97945219E+04
         291          292   0.00000000E+00
         291          293   0.00000000E+00
         291          294   0.00000000E+00
         291          295   0.00000000E+00
         291          296   0.79884210E+02
         291          297   0.76117799E+02
         291          298   0.00000000E+00
         291          299   0.00000000E+00
         291          300   0.36307130E+04
         291          281  -0.23456563E-04
         291          282   0.00000000E+00
         291          283   0.00000000E+00
         291          284   0.00000000E+00
         291          285   0.00000000E+00
         291          286  -0.19131143E-06
         291          287  -0.18229190E-06
         291          288   0.00000000E+00
         291          289   0.00000000E+00
         291          290  -0.86950688E-05
         291          301  -0.35206435E-04
         291          302   0.00000000E+00
         291          303   0.00000000E+00
         291          304   0.00000000E+00
         291          305   0.00000000E+00
         291          306  -0.28714324E-06
         291          307  -0.27360565E-06
         291          308   0.00000000E+00
         291          309   0.00000000E+00
         291          310  -0.13050607E-04
         292          292   0.61664984E+04
         292          291   0.00000000E+00
         292          293   0.00000000E+00
         292          294   0.63450217E+01
         292          295   0.63450217E+01
         292          296   0.00000000E+00
         292          297  -0.21136331E+02
         292          298   0.00000000E+00
         292          299   0.00000000E+00
         292          300   0.24834091E+03
         292          281   0.00000000E+00
         292          282  -0.14762871E-04
         292          283   0.00000000E+00
         292          284   0.00000000E+00
         292          285   0.00000000E+00
         292          286   0.00000000E+00
         292          287   0.00000000E+00
         292          288   0.00000000E+00
         292          289   0.00000000E+00
         292          290  -0.59474313E-06
         292          301   0.00000000E+00
         292          302  -0.22157895E-04
         292          303   0.00000000E+00
         292          304   0.00000000E+00
         292          305   0.00000000E+00
         292          306   0.00000000E+00
         292          307   0.00000000E+00
         292          308   0.00000000E+00
         292          309   0.00000000E+00
         292          310  -0.89266212E-06
         293          293   0.78082192E+03
         293          291   0.00000000E+00
         293          292   0.00000000E+00
         293          294   0.00000000E+00
         293          295   0.00000000E+00
         293          296   0.00000000E+00
         293          297   0.00000000E+00
         293          298   0.00000000E+00
         293          299   0.00000000E+00
         293          300   0.00000000E+00
         293          281   0.00000000E+00
         293          282   0.00000000E+00
         293          283  -0.18699636E-05
         293          284   0.00000000E+00
         293          285   0.00000000E+00
         293          286   0.00000000E+00
         293          287   0.00000000E+00
         293          288   0.00000000E+00
         293          289   0.00000000E+00
         293          290   0.00000000E+00
         293          301   0.00000000E+00
         293          302   0.00000000E+00
         293          303  -0.28066666E-05
         293          304   0.00000000E+00
         293          305   0.00000000E+00
         293          306   0.00000000E+00
         293          307   0.00000000E+00
         293          308   0.00000000E+00
         293          309   0.00000000E+00
         293          310   0.00000000E+00
         294          294   0.13409529E+04
         294          291   0.00000000E+00
         294          292   0.63443872E+01
         294          293   0.00000000E+00
         294          295   0.19035065E+02
         294          296   0.00000000E+00
         294          297  -0.65836821E+02
         294          298   0.00000000E+00
         294          299   0.00000000E+00
         294          300   0.00000000E+00
         294          281   0.00000000E+00
         294          282   0.00000000E+00
         294          283   0.00000000E+00
         294          284  -0.31658156E-05
         294          285   0.00000000E+00
         294          286   0.00000000E+00
         294          287   0.58143243E-08
         294          288   0.00000000E+00
         294          289   0.00000000E+00
         294          290   0.00000000E+00
         294          301   0.00000000E+00
         294          302   0.00000000E+00
         294          303   0.00000000E+00
         294          304  -0.47516374E-05
         294          305   0.00000000E+00
         294          306   0.00000000E+00
         294          307   0.87268382E-08
         294          308   0.00000000E+00
         294          309   0.00000000E+00
         294          310   0.00000000E+00
         295          295   0.19052837E+02
         295          291   0.00000000E+00
         295          292   0.63443872E+01
         295          293   0.00000000E+00
         295          294   0.19035065E+02
         295          296   0.00000000E+00
         295          297  -0.63477866E+02
         295          298   0.00000000E+00
         295          299   0.00000000E+00
         295          300   0.21795643E-05
         295          281   0.00000000E+00
         295          282   0.00000000E+00
         295          283   0.00000000E+00
         295          284   0.00000000E+00
         295          285  -0.42484263E-10
         295          286   0.00000000E+00
         295          287   0.16470995E-09
         295          288   0.00000000E+00
         295          289   0.00000000E+00
         295          290  -0.52197638E-14
         295          301   0.00000000E+00
         295          302   0.00000000E+00
         295          303   0.00000000E+00
         295          304   0.00000000E+00
         295          305  -0.63765499E-10
         295          306   0.00000000E+00
         295          307   0.24721653E-09
         295          308   0.00000000E+00
         295          309   0.00000000E+00
         295          310  -0.78344502E-14
         296          296   0.17074662E+04
         296          291   0.79884210E+02
         296          292   0.00000000E+00
         296          293   0.00000000E+00
         296          294   0.00000000E+00
         296          295   0.00000000E+00
         296          297   0.19543730E+04
         296          298   0.00000000E+00
         296          299   0.43198833E-04
         296          300   0.00000000E+00
         296          281  -0.19131143E-06
         296          282   0.00000000E+00
         296          283   0.00000000E+00
         296          284   0.00000000E+00
         296          285   0.00000000E+00
         296          286  -0.40891515E-05
         296          287  -0.46804608E-05
         296          288   0.00000000E+00
         296          289   0.00000000E+00
         296          290   0.00000000E+00
         296          301  -0.28714324E-06
         296          302   0.00000000E+00
         296          303   0.00000000E+00
         296          304   0.00000000E+00
         296          305   0.00000000E+00
         296          306  -0.61374911E-05
         296          307  -0.70249993E-05
         296          308   0.00000000E+00
         296          309   0.00000000E+00
         296          310   0.00000000E+00
         297          297   0.26723718E+04
         297          291   0.76117799E+02
         297          292  -0.21147957E+02
         297          293   0.00000000E+00
         297          294  -0.65878288E+02
         297          295  -0.63519108E+02
         297          296   0.19543478E+04
         297          298  -0.38887502E-04
         297          299  -0.12035985E+00
         297          300   0.49505150E-01
         297          281  -0.18229190E-06
         297          282   0.00000000E+00
         297          283   0.00000000E+00
         297          284   0.58149057E-08
         297          285   0.16475051E-09
         297          286  -0.46804005E-05
         297          287  -0.58937841E-05
         297          288   0.15713863E-13
         297          289   0.28826779E-09
         297          290  -0.11851393E-09
         297          301  -0.27360565E-06
         297          302   0.00000000E+00
         297          303   0.00000000E+00
         297          304   0.87277109E-08
         297          305   0.24727742E-09
         297          306  -0.70249088E-05
         297          307  -0.88461011E-05
         297          308   0.23585259E-13
         297          309   0.43266702E-09
         297          310  -0.17787999E-09
         298          298   0.66308262E-04
         298          291   0.00000000E+00
         298          292   0.00000000E+00
         298          293   0.00000000E+00
         298          294   0.00000000E+00
         298          295   0.00000000E+00
         298          296   0.00000000E+00
         298          297  -0.38896922E-04
         298          299  -0.14946245E-04
         298          300  -0.37051937E-04
         298          281   0.00000000E+00
         298          282   0.00000000E+00
         298          283   0.00000000E+00
         298          284   0.00000000E+00
         298          285   0.00000000E+00
         298          286   0.00000000E+00
         298          287   0.15715132E-13
         298          288  -0.23320539E-13
         298          289  -0.29226999E-14
         298          290   0.11296639E-13
         298          301   0.00000000E+00
         298          302   0.00000000E+00
         298          303   0.00000000E+00
         298          304   0.00000000E+00
         298          305   0.00000000E+00
         298          306   0.00000000E+00
         298          307   0.23587162E-13
         298          308  -0.35002274E-13
         298          309  -0.43867400E-14
         298          310   0.16955357E-13
         299          299   0.99356224E+02
         299          291   0.00000000E+00
         299          292   0.00000000E+00
         299          293   0.00000000E+00
         299          294   0.00000000E+00
         299          295   0.00000000E+00
         299          296   0.43198833E-04
         299          297  -0.12034781E+00
         299          298  -0.14942654E-04
         299          300   0.33536708E+02
         299          281   0.00000000E+00
         299          282   0.00000000E+00
         299          283   0.00000000E+00
         299          284   0.00000000E+00
         299          285   0.00000000E+00
         299          286   0.00000000E+00
         299          287   0.28823897E-09
         299          288  -0.29225903E-14
         299          289  -0.23794469E-06
         299          290  -0.80315889E-07
         299          301   0.00000000E+00
         299          302   0.00000000E+00
         299          303   0.00000000E+00
         299          304   0.00000000E+00
         299          305   0.00000000E+00
         299          306   0.00000000E+00
         299          307   0.43262376E-09
         299          308  -0.43865755E-14
         299          309  -0.35713606E-06
         299          310  -0.12054776E-06
         300          300   0.13484933E+05
         300          291   0.36307130E+04
         300          292   0.24834091E+03
         300          293   0.00000000E+00
         300          294   0.00000000E+00
         300          295   0.21795340E-05
         300          296   0.00000000E+00
         300          297   0.49505150E-01
         300          298  -0.37042339E-04
         300          299   0.33536708E+02
         300          281  -0.86950688E-05
         300          282  -0.59474313E-06
         300          283   0.00000000E+00
         300          284   0.00000000E+00
         300          285  -0.52196912E-14
         300          286   0.00000000E+00
         300          287  -0.11851393E-09
         300          288   0.11294945E-13
         300          289  -0.80315889E-07
         300          290  -0.32294601E-04
         300          301  -0.13050607E-04
         300          302  -0.89266212E-06
         300          303   0.00000000E+00
         300          304   0.00000000E+00
         300          305  -0.78343413E-14
         300          306   0.00000000E+00
         300          307  -0.17787999E-09
         300          308   0.16952814E-13
         300          309  -0.12054776E-06
         300          310  -0.48471627E-04
         301          301   0.97945219E+04
         301          302   0.00000000E+00
         301          303   0.00000000E+00
         301          304   0.00000000E+00
         301          305   0.00000000E+00
         301          306   0.79884210E+02
         301          307   0.76117799E+02
         301          308   0.00000000E+00
         301          309   0.00000000E+00
         301          310   0.36307130E+04
         301          291  -0.23456563E-04
         301          292   0.00000000E+00
         301          293   0.00000000E+00
         301          294   0.00000000E+00
         301          295   0.00000000E+00
         301          296  -0.19131143E-06
         301          297  -0.18229190E-06
         301          298   0.00000000E+00
         301          299   0.00000000E+00
         301          300  -0.86950688E-05
         301          311  -0.35206435E-04
         301          312   0.00000000E+00
         301          313   0.00000000E+00
         301          314   0.00000000E+00
         301          315   0.00000000E+00
         301          316  -0.28714324E-06
         301          317  -0.27360565E-06
         301          318   0.00000000E+00
         301          319   0.00000000E+00
         301          320  -0.13050607E-04
         302          302   0.61664984E+04
         302          301   0.00000000E+00
         302          303   0.00000000E+00
         302          304   0.63450217E+01
         302          305   0.63450217E+01
         302          306   0.00000000E+00
         302          307  -0.21136331E+02
         302          308   0.00000000E+00
         302          309   0.00000000E+00
         302          310   0.24834091E+03
         302          291   0.00000000E+00
         302          292  -0.14762871E-04
         302          293   0.00000000E+00
         302          294   0.00000000E+00
         302          295   0.00000000E+00
         302          296   0.00000000E+00
         302          297   0.00000000E+00
         302          298   0.00000000E+00
         302          299   0.00000000E+00
         302          300  -0.59474313E-06
         302          311   0.00000000E+00
         302          312  -0.22157895E-04
         302          313   0.00000000E+00
         302          314   0.00000000E+00
         302          315   0.00000000E+00
         302          316   0.00000000E+00
         302          317   0.00000000E+00
         302          318   0.00000000E+00
         302          319   0.00000000E+00
         302          320  -0.89266212E-06
         303          303   0.78082192E+03
         303          301   0.00000000E+00
         303          302   0.00000000E+00
         303          304   0.00000000E+00
         303          305   0.00000000E+00
         303          306   0.00000000E+00
         303          307   0.00000000E+00
         303          308   0.00000000E+00
         303          309   0.00000000E+00
         303          310   0.00000000E+00
         303          291   0.00000000E+00
         303          292   0.00000000E+00
         303          293  -0.18699636E-05
         303          294   0.00000000E+00
         303          295   0.00000000E+00
         303          296   0.00000000E+00
         303          297   0.00000000E+00
         303          298   0.00000000E+00
         303          299   0.00000000E+00
         303          300   0.00000000E+00
         303          311   0.00000000E+00
         303          312   0.00000000E+00
         303          313  -0.28066666E-05
         303          314   0.00000000E+00
         303          315   0.00000000E+00
         303          316   0.00000000E+00
         303          317   0.00000000E+00
         303          318   0.00000000E+00
         303          319   0.00000000E+00
         303          320   0.00000000E+00
         304          304   0.13409529E+04
         304          301   0.00000000E+00
         304          302   0.63443872E+01
         304          303   0.00000000E+00
         304          305   0.19035065E+02
         304          306   0.00000000E+00
         304          307  -0.65836821E+02
         304          308   0.00000000E+00
         304          309   0.00000000E+00
         304          310   0.00000000E+00
         304          291   0.00000000E+00
         304          292   0.00000000E+00
         304          293   0.00000000E+00
         304          294  -0.31658156E-05
         304          295   0.00000000E+00
         304          296   0.00000000E+00
         304          297   0.58143243E-08
         304          298   0.00000000E+00
         304          299   0.00000000E+00
         304          300   0.00000000E+00
         304          311   0.00000000E+00
         304          312   0.00000000E+00
         304          313   0.00000000E+00
         304          314  -0.47516374E-05
         304          315   0.00000000E+00
         304          316   0.00000000E+00
         304          317   0.87268382E-08
         304          318   0.00000000E+00
         304          319   0.00000000E+00
         304          320   0.00000000E+00
         305          305   0.19052837E+02
         305          301   0.00000000E+00
         305          302   0.63443872E+01
         305          303   0.00000000E+00
         305          304   0.19035065E+02
         305          306   0.00000000E+00
         305          307  -0.63477866E+02
         305          308   0.00000000E+00
         305          309   0.00000000E+00
         305          310   0.21795643E-05
         305          291   0.00000000E+00
         305          292   0.00000000E+00
         305          293   0.00000000E+00
         305          294   0.00000000E+00
         305          295  -0.42484263E-10
         305          296   0.00000000E+00
         305          297   0.16470995E-09
         305          298   0.00000000E+00
         305          299   0.00000000E+00
         305          300  -0.52197638E-14
         305          311   0.00000000E+00
         305          312   0.00000000E+00
         305          313   0.00000000E+00
         305          314   0.00000000E+00
         305          315  -0.63765499E-10
         305          316   0.00000000E+00
         305          317   0.24721653E-09
         305          318   0.00000000E+00
         305          319   0.00000000E+00
         305          320  -0.78344502E-14
         306          306   0.17074662E+04
         306          301   0.79884210E+02
         306          302   0.00000000E+00
         306          303   0.00000000E+00
         306          304   0.00000000E+00
         306          305   0.00000000E+00
         306          307   0.19543730E+04
         306          308   0.00000000E+00
         306          309   0.43198833E-04
         306          310   0.00000000E+00
         306          291  -0.19131143E-06
         306          292   0.00000000E+00
         306          293   0.00000000E+00
         306          294   0.00000000E+00
         306          295   0.00000000E+00
         306          296  -0.40891515E-05
         306          297  -0.46804608E-05
         306          298   0.00000000E+00
         306          299   0.00000000E+00
         306          300   0.00000000E+00
         306          311  -0.28714324E-06
         306          312   0.00000000E+00
         306          313   0.00000000E+00
         306          314   0.00000000E+00
         306          315   0.00000000E+00
         306          316  -0.61374911E-05
         306          317  -0.70249993E-05
         306          318   0.00000000E+00
         306          319   0.00000000E+00
         306          320   0.00000000E+00
         307          307   0.26723718E+04
         307          301   0.76117799E+02
         307          302  -0.21147957E+02
         307          303   0.00000000E+00
         307          304  -0.65878288E+02
         307          305  -0.63519108E+02
         307          306   0.19543478E+04
         307          308  -0.38887502E-04
         307          309  -0.12035985E+00
         307          310   0.49505150E-01
         307          291  -0.18229190E-06
         307          292   0.00000000E+00
         307          293   0.00000000E+00
         307          294   0.58149057E-08
         307          295   0.16475051E-09
         307          296  -0.46804005E-05
         307          297  -0.58937841E-05
         307          298   0.15713863E-13
         307          299   0.28826779E-09
         307          300  -0.11851393E-09
         307          311  -0.27360565E-06
         307          312   0.00000000E+00
         307          313   0.00000000E+00
         307          314   0.87277109E-08
         307          315   0.24727742E-09
         307          316  -0.70249088E-05
         307          317  -0.88461011E-05
         307          318   0.23585259E-13
         307          319   0.43266702E-09
         307          320  -0.17787999E-09
         308          308   0.66308262E-04
         308          301   0.00000000E+00
         308          302   0.00000000E+00
         308          303   0.00000000E+00
         308          304   0.00000000E+00
         308          305   0.00000000E+00
         308          306   0.00000000E+00
         308          307  -0.38896922E-04
         308          309  -0.14946245E-04
         308          310  -0.37051937E-04
         308          291   0.00000000E+00
         308          292   0.00000000E+00
         308          293   0.00000000E+00
         308          294   0.00000000E+00
         308          295   0.00000000E+00
         308          296   0.00000000E+00
         308          297   0.15715132E-13
         308          298  -0.23320539E-13
         308          299  -0.29226999E-14
         308          300   0.11296639E-13
         308          311   0.00000000E+00
         308          312   0.00000000E+00
         308          313   0.00000000E+00
         308          314   0.00000000E+00
         308          315   0.00000000E+00
         308          316   0.00000000E+00
         308          317   0.23587162E-13
         308          318  -0.35002274E-13
         308          319  -0.43867400E-14
         308          320   0.16955357E-13
         309          309   0.99356224E+02
         309          301   0.00000000E+00
         309          302   0.00000000E+00
         309          303   0.00000000E+00
         309          304   0.00000000E+00
         309          305   0.00000000E+00
         309          306   0.43198833E-04
         309          307  -0.12034781E+00
         309          308  -0.14942654E-04
         309          310   0.33536708E+02
         309          291   0.00000000E+00
         309          292   0.00000000E+00
         309          293   0.00000000E+00
         309          294   0.00000000E+00
         309          295   0.00000000E+00
         309          296   0.00000000E+00
         309          297   0.28823897E-09
         309          298  -0.29225903E-14
         309          299  -0.23794469E-06
         309          300  -0.80315889E-07
         309          311   0.00000000E+00
         309          312   0.00000000E+00
         309          313   0.00000000E+00
         309          314   0.00000000E+00
         309          315   0.00000000E+00
         309          316   0.00000000E+00
         309          317   0.43262376E-09
         309          318  -0.43865755E-14
         309          319  -0.35713606E-06
         309          320  -0.12054776E-06
         310          310   0.13484933E+05
         310          301   0.36307130E+04
         310          302   0.24834091E+03
         310          303   0.00000000E+00
         310          304   0.00000000E+00
         310          305   0.21795340E-05
         310          306   0.00000000E+00
         310          307   0.49505150E-01
         310          308  -0.37042339E-04
         310          309   0.33536708E+02
         310          291  -0.86950688E-05
         310          292  -0.59474313E-06
         310          293   0.00000000E+00
         310          294   0.00000000E+00
         310          295  -0.52196912E-14
         310          296   0.00000000E+00
         310          297  -0.11851393E-09
         310          298   0.11294945E-13
         310          299  -0.80315889E-07
         310          300  -0.32294601E-04
         310          311  -0.13050607E-04
         310          312  -0.89266212E-06
         310          313   0.00000000E+00
         310          314   0.00000000E+00
         310          315  -0.78343413E-14
         310          316   0.00000000E+00
         310          317  -0.17787999E-09
         310          318   0.16952814E-13
         310          319  -0.12054776E-06
         310          320  -0.48471627E-04
         311          311   0.97945219E+04
         311          312   0.00000000E+00
         311          313   0.00000000E+00
         311          314   0.00000000E+00
         311          315   0.00000000E+00
         311          316   0.79884210E+02
         311          317   0.76117799E+02
         311          318   0.00000000E+00
         311          319   0.00000000E+00
         311          320   0.36307130E+04
         311          301  -0.23456563E-04
         311          302   0.00000000E+00
         311          303   0.00000000E+00
         311          304   0.00000000E+00
         311          305   0.00000000E+00
         311          306  -0.19131143E-06
         311          307  -0.18229190E-06
         311          308   0.00000000E+00
         311          309   0.00000000E+00
         311          310  -0.86950688E-05
         311          321  -0.35206435E-04
         311          322   0.00000000E+00
         311          323   0.00000000E+00
         311          324   0.00000000E+00
         311          325   0.00000000E+00
         311          326  -0.28714324E-06
         311          327  -0.27360565E-06
         311          328   0.00000000E+00
         311          329   0.00000000E+00
         311          330  -0.13050607E-04
         312          312   0.61664984E+04
         312          311   0.00000000E+00
         312          313   0.00000000E+00
         312          314   0.63450217E+01
         312          315   0.63450217E+01
         312          316   0.00000000E+00
         312          317  -0.21136331E+02
         312          318   0.00000000E+00
         312          319   0.00000000E+00
         312          320   0.24834091E+03
         312          301   0.00000000E+00
         312          302  -0.14762871E-04
         312          303   0.00000000E+00
         312          304   0.00000000E+00
         312          305   0.00000000E+00
         312          306   0.00000000E+00
         312          307   0.00000000E+00
         312          308   0.00000000E+00
         312          309   0.00000000E+00
         312          310  -0.59474313E-06
         312          321   0.00000000E+00
         312          322  -0.22157895E-04
         312          323   0.00000000E+00
         312          324   0.00000000E+00
         312          325   0.00000000E+00
         312          326   0.00000000E+00
         312          327   0.00000000E+00
         312          328   0.00000000E+00
         312          329   0.00000000E+00
         312          330  -0.89266212E-06
         313          313   0.78082192E+03
         313          311   0.00000000E+00
         313          312   0.00000000E+00
         313          314   0.00000000E+00
         313          315   0.00000000E+00
         313          316   0.00000000E+00
         313          317   0.00000000E+00
         313          318   0.00000000E+00
         313          319   0.00000000E+00
         313          320   0.00000000E+00
         313          301   0.00000000E+00
         313          302   0.00000000E+00
         313          303  -0.18699636E-05
         313          304   0.00000000E+00
         313          305   0.00000000E+00
         313          306   0.00000000E+00
         313          307   0.00000000E+00
         313          308   0.00000000E+00
         313          309   0.00000000E+00
         313          310   0.00000000E+00
         313          321   0.00000000E+00
         313          322   0.00000000E+00
         313          323  -0.28066666E-05
         313          324   0.00000000E+00
         313          325   0.00000000E+00
         313          326   0.00000000E+00
         313          327   0.00000000E+00
         313          328   0.00000000E+00
         313          329   0.00000000E+00
         313          330   0.00000000E+00
         314          314   0.13409529E+04
         314          311   0.00000000E+00
         314          312   0.63443872E+01
         314          313   0.00000000E+00
         314          315   0.19035065E+02
         314          316   0.00000000E+00
         314          317  -0.65836821E+02
         314          318   0.00000000E+00
         314          319   0.00000000E+00
         314          320   0.00000000E+00
         314          301   0.00000000E+00
         314          302   0.00000000E+00
         314          303   0.00000000E+00
         314          304  -0.31658156E-05
         314          305   0.00000000E+00
         314          306   0.00000000E+00
         314          307   0.58143243E-08
         314          308   0.00000000E+00
         314          309   0.00000000E+00
         314          310   0.00000000E+00
         314          321   0.00000000E+00
         314          322   0.00000000E+00
         314          323   0.00000000E+00
         314          324  -0.47516374E-05
         314          325   0.00000000E+00
         314          326   0.00000000E+00
         314          327   0.87268382E-08
         314          328   0.00000000E+00
         314          329   0.00000000E+00
         314          330   0.00000000E+00
         315          315   0.19052837E+02
         315          311   0.00000000E+00
         315          312   0.63443872E+01
         315          313   0.00000000E+00
         315          314   0.19035065E+02
         315          316   0.00000000E+00
         315          317  -0.63477866E+02
         315          318   0.00000000E+00
         315          319   0.00000000E+00
         315          320   0.21795643E-05
         315          301   0.00000000E+00
         315          302   0.00000000E+00
         315          303   0.00000000E+00
         315          304   0.00000000E+00
         315          305  -0.42484263E-10
         315          306   0.00000000E+00
         315          307   0.16470995E-09
         315          308   0.00000000E+00
         315          309   0.00000000E+00
         315          310  -0.52197638E-14
         315          321   0.00000000E+00
         315          322   0.00000000E+00
         315          323   0.00000000E+00
         315          324   0.00000000E+00
         315          325  -0.63765499E-10
         315          326   0.00000000E+00
         315          327   0.24721653E-09
         315          328   0.00000000E+00
         315          329   0.00000000E+00
         315          330  -0.78344502E-14
         316          316   0.17074662E+04
         316          311   0.79884210E+02
         316          312   0.00000000E+00
         316          313   0.00000000E+00
         316          314   0.00000000E+00
         316          315   0.00000000E+00
         316          317   0.19543730E+04
         316          318   0.00000000E+00
         316          319   0.43198833E-04
         316          320   0.00000000E+00
         316          301  -0.19131143E-06
         316          302   0.00000000E+00
         316          303   0.00000000E+00
         316          304   0.00000000E+00
         316          305   0.00000000E+00
         316          306  -0.40891515E-05
         316          307  -0.46804608E-05
         316          308   0.00000000E+00
         316          309   0.00000000E+00
         316          310   0.00000000E+00
         316          321  -0.28714324E-06
         316          322   0.00000000E+00
         316          323   0.00000000E+00
         316          324   0.00000000E+00
         316          325   0.00000000E+00
         316          326  -0.61374911E-05
         316          327  -0.70249993E-05
         316          328   0.00000000E+00
         316          329   0.00000000E+00
         316          330   0.00000000E+00
         317          317   0.26723718E+04
         317          311   0.76117799E+02
         317          312  -0.21147957E+02
         317          313   0.00000000E+00
         317          314  -0.65878288E+02
         317          315  -0.63519108E+02
         317          316   0.19543478E+04
         317          318  -0.38887502E-04
         317          319  -0.12035985E+00
         317          320   0.49505150E-01
         317          301  -0.18229190E-06
         317          302   0.00000000E+00
         317          303   0.00000000E+00
         317          304   0.58149057E-08
         317          305   0.16475051E-09
         317          306  -0.46804005E-05
         317          307  -0.58937841E-05
         317          308   0.15713863E-13
         317          309   0.28826779E-09
         317          310  -0.11851393E-09
         317          321  -0.27360565E-06
         317          322   0.00000000E+00
         317          323   0.00000000E+00
         317          324   0.87277109E-08
         317          325   0.24727742E-09
         317          326  -0.70249088E-05
         317          327  -0.88461011E-05
         317          328   0.23585259E-13
         317          329   0.43266702E-09
         317          330  -0.17787999E-09
         318          318   0.66308262E-04
         318          311   0.00000000E+00
         318          312   0.00000000E+00
         318          313   0.00000000E+00
         318          314   0.00000000E+00
         318          315   0.00000000E+00
         318          316   0.00000000E+00
         318          317  -0.38896922E-04
         318          319  -0.14946245E-04
         318          320  -0.37051937E-04
         318          301   0.00000000E+00
         318          302   0.00000000E+00
         318          303   0.00000000E+00
         318          304   0.00000000E+00
         318          305   0.00000000E+00
         318          306   0.00000000E+00
         318          307   0.15715132E-13
         318          308  -0.23320539E-13
         318          309  -0.29226999E-14
         318          310   0.11296639E-13
         318          321   0.00000000E+00
         318          322   0.00000000E+00
         318          323   0.00000000E+00
         318          324   0.00000000E+00
         318          325   0.00000000E+00
         318          326   0.00000000E+00
         318          327   0.23587162E-13
         318          328  -0.35002274E-13
         318          329  -0.43867400E-14
         318          330   0.16955357E-13
         319          319   0.99356224E+02
         319          311   0.00000000E+00
         319          312   0.00000000E+00
         319          313   0.00000000E+00
         319          314   0.00000000E+00
         319          315   0.00000000E+00
         319          316   0.43198833E-04
         319          317  -0.12034781E+00
         319          318  -0.14942654E-04
         319          320   0.33536708E+02
         319          301   0.00000000E+00
         319          302   0.00000000E+00
         319          303   0.00000000E+00
         319          304   0.00000000E+00
         319          305   0.00000000E+00
         319          306   0.00000000E+00
         319          307   0.28823897E-09
         319          308  -0.29225903E-14
         319          309  -0.23794469E-06
         319          310  -0.80315889E-07
         319          321   0.00000000E+00
         319          322   0.00000000E+00
         319          323   0.00000000E+00
         319          324   0.00000000E+00
         319          325   0.00000000E+00
         319          326   0.00000000E+00
         319          327   0.43262376E-09
         319          328  -0.43865755E-14
         319          329  -0.35713606E-06
         319          330  -0.12054776E-06
         320          320   0.13484933E+05
         320          311   0.36307130E+04
         320          312   0.24834091E+03
         320          313   0.00000000E+00
         320          314   0.00000000E+00
         320          315   0.21795340E-05
         320          316   0.00000000E+00
         320          317   0.49505150E-01
         320          318  -0.37042339E-04
         320          319   0.33536708E+02
         320          301  -0.86950688E-05
         320          302  -0.59474313E-06
         320          303   0.00000000E+00
         320          304   0.00000000E+00
         320          305  -0.52196912E-14
         320          306   0.00000000E+00
         320          307  -0.11851393E-09
         320          308   0.11294945E-13
         320          309  -0.80315889E-07
         320          310  -0.32294601E-04
         320          321  -0.13050607E-04
         320          322  -0.89266212E-06
         320          323   0.00000000E+00
         320          324   0.00000000E+00
         320          325  -0.78343413E-14
         320          326   0.00000000E+00
         320          327  -0.17787999E-09
         320          328   0.16952814E-13
         320          329  -0.12054776E-06
         320          330  -0.48471627E-04
         321          321   0.97945219E+04
         321          322   0.00000000E+00
         321          323   0.00000000E+00
         321          324   0.00000000E+00
         321          325   0.00000000E+00
         321          326   0.79884210E+02
         321          327   0.76117799E+02
         321          328   0.00000000E+00
         321          329   0.00000000E+00
         321          330   0.36307130E+04
         321          311  -0.23456563E-04
         321          312   0.00000000E+00
         321          313   0.00000000E+00
         321          314   0.00000000E+00
         321          315   0.00000000E+00
         321          316  -0.19131143E-06
         321          317  -0.18229190E-06
         321          318   0.00000000E+00
         321          319   0.00000000E+00
         321          320  -0.86950688E-05
         321          331  -0.35206435E-04
         321          332   0.00000000E+00
         321          333   0.00000000E+00
         321          334   0.00000000E+00
         321          335   0.00000000E+00
         321          336  -0.28714324E-06
         321          337  -0.27360565E-06
         321          338   0.00000000E+00
         321          339   0.00000000E+00
         321          340  -0.13050607E-04
         322          322   0.61664984E+04
         322          321   0.00000000E+00
         322          323   0.00000000E+00
         322          324   0.63450217E+01
         322          325   0.63450217E+01
         322          326   0.00000000E+00
         322          327  -0.21136331E+02
         322          328   0.00000000E+00
         322          329   0.00000000E+00
         322          330   0.24834091E+03
         322          311   0.00000000E+00
         322          312  -0.14762871E-04
         322          313   0.00000000E+00
         322          314   0.00000000E+00
         322          315   0.00000000E+00
         322          316   0.00000000E+00
         322          317   0.00000000E+00
         322          318   0.00000000E+00
         322          319   0.00000000E+00
         322          320  -0.59474313E-06
         322          331   0.00000000E+00
         322          332  -0.22157895E-04
         322          333   0.00000000E+00
         322          334   0.00000000E+00
         322          335   0.00000000E+00
         322          336   0.00000000E+00
         322          337   0.00000000E+00
         322          338   0.00000000E+00
         322          339   0.00000000E+00
         322          340  -0.89266212E-06
         323          323   0.78082192E+03
         323          321   0.00000000E+00
         323          322   0.00000000E+00
         323          324   0.00000000E+00
         323          325   0.00000000E+00
         323          326   0.00000000E+00
         323          327   0.00000000E+00
         323          328   0.00000000E+00
         323          329   0.00000000E+00
         323          330   0.00000000E+00
         323          311   0.00000000E+00
         323          312   0.00000000E+00
         323          313  -0.18699636E-05
         323          314   0.00000000E+00
         323          315   0.00000000E+00
         323          316   0.00000000E+00
         323          317   0.00000000E+00
         323          318   0.00000000E+00
         323          319   0.00000000E+00
         323          320   0.00000000E+00
         323          331   0.00000000E+00
         323          332   0.00000000E+00
         323          333  -0.28066666E-05
         323          334   0.00000000E+00
         323          335   0.00000000E+00
         323          336   0.00000000E+00
         323          337   0.00000000E+00
         323          338   0.00000000E+00
         323          339   0.00000000E+00
         323          340   0.00000000E+00
         324          324   0.13409529E+04
         324          321   0.00000000E+00
         324          322   0.63443872E+01
         324          323   0.00000000E+00
         324          325   0.19035065E+02
         324          326   0.00000000E+00
         324          327  -0.65836821E+02
         324          328   0.00000000E+00
         324          329   0.00000000E+00
         324          330   0.00000000E+00
         324          311   0.00000000E+00
         324          312   0.00000000E+00
         324          313   0.00000000E+00
         324          314  -0.31658156E-05
         324          315   0.00000000E+00
         324          316   0.00000000E+00
         324          317   0.58143243E-08
         324          318   0.00000000E+00
         324          319   0.00000000E+00
         324          320   0.00000000E+00
         324          331   0.00000000E+00
         324          332   0.00000000E+00
         324          333   0.00000000E+00
         324          334  -0.47516374E-05
         324          335   0.00000000E+00
         324          336   0.00000000E+00
         324          337   0.87268382E-08
         324          338   0.00000000E+00
         324          339   0.00000000E+00
         324          340   0.00000000E+00
         325          325   0.19052837E+02
         325          321   0.00000000E+00
         325          322   0.63443872E+01
         325          323   0.00000000E+00
         325          324   0.19035065E+02
         325          326   0.00000000E+00
         325          327  -0.63477866E+02
         325          328   0.00000000E+00
         325          329   0.00000000E+00
         325          330   0.21795643E-05
         325          311   0.00000000E+00
         325          312   0.00000000E+00
         325          313   0.00000000E+00
         325          314   0.00000000E+00
         325          315  -0.42484263E-10
         325          316   0.00000000E+00
         325          317   0.16470995E-09
         325          318   0.00000000E+00
         325          319   0.00000000E+00
         325          320  -0.52197638E-14
         325          331   0.00000000E+00
         325          332   0.00000000E+00
         325          333   0.00000000E+00
         325          334   0.00000000E+00
         325          335  -0.63765499E-10
         325          336   0.00000000E+00
         325          337   0.24721653E-09
         325          338   0.00000000E+00
         325          339   0.00000000E+00
         325          340  -0.78344502E-14
         326          326   0.17074662E+04
         326          321   0.79884210E+02
         326          322   0.00000000E+00
         326          323   0.00000000E+00
         326          324   0.00000000E+00
         326          325   0.00000000E+00
         326          327   0.19543730E+04
         326          328   0.00000000E+00
         326          329   0.43198833E-04
         326          330   0.00000000E+00
         326          311  -0.19131143E-06
         326          312   0.00000000E+00
         326          313   0.00000000E+00
         326          314   0.00000000E+00
         326          315   0.00000000E+00
         326          316  -0.40891515E-05
         326          317  -0.46804608E-05
         326          318   0.00000000E+00
         326          319   0.00000000E+00
         326          320   0.00000000E+00
         326          331  -0.28714324E-06
         326          332   0.00000000E+00
         326          333   0.00000000E+00
         326          334   0.00000000E+00
         326          335   0.00000000E+00
         326          336  -0.61374911E-05
         326          337  -0.70249993E-05
         326          338   0.00000000E+00
         326          339   0.00000000E+00
         326          340   0.00000000E+00
         327          327   0.26723718E+04
         327          321   0.76117799E+02
         327          322  -0.21147957E+02
         327          323   0.00000000E+00
         327          324  -0.65878288E+02
         327          325  -0.63519108E+02
         327          326   0.19543478E+04
         327          328  -0.38887502E-04
         327          329  -0.12035985E+00
         327          330   0.49505150E-01
         327          311  -0.18229190E-06
         327          312   0.00000000E+00
         327          313   0.00000000E+00
         327          314   0.58149057E-08
         327          315   0.16475051E-09
         327          316  -0.46804005E-05
         327          317  -0.58937841E-05
         327          318   0.15713863E-13
         327          319   0.28826779E-09
         327          320  -0.11851393E-09
         327          331  -0.27360565E-06
         327          332   0.00000000E+00
         327          333   0.00000000E+00
         327          334   0.87277109E-08
         327          335   0.24727742E-09
         327          336  -0.70249088E-05
         327          337  -0.88461011E-05
         327          338   0.23585259E-13
         327          339   0.43266702E-09
         327          340  -0.17787999E-09
         328          328   0.66308262E-04
         328          321   0.00000000E+00
         328          322   0.00000000E+00
         328          323   0.00000000E+00
         328          324   0.00000000E+00
         328          325   0.00000000E+00
         328          326   0.00000000E+00
         328          327  -0.38896922E-04
         328          329  -0.14946245E-04
         328          330  -0.37051937E-04
         328          311   0.00000000E+00
         328          312   0.00000000E+00
         328          313   0.00000000E+00
         328          314   0.00000000E+00
         328          315   0.00000000E+00
         328          316   0.00000000E+00
         328          317   0.15715132E-13
         328          318  -0.23320539E-13
         328          319  -0.29226999E-14
         328          320   0.11296639E-13
         328          331   0.00000000E+00
         328          332   0.00000000E+00
         328          333   0.00000000E+00
         328          334   0.00000000E+00
         328          335   0.00000000E+00
         328          336   0.00000000E+00
         328          337   0.23587162E-13
         328          338  -0.35002274E-13
         328          339  -0.43867400E-14
         328          340   0.16955357E-13
         329          329   0.99356224E+02
         329          321   0.00000000E+00
         329          322   0.00000000E+00
         329          323   0.00000000E+00
         329          324   0.00000000E+00
         329          325   0.00000000E+00
         329          326   0.43198833E-04
         329          327  -0.12034781E+00
         329          328  -0.14942654E-04
         329          330   0.33536708E+02
         329          311   0.00000000E+00
         329          312   0.00000000E+00
         329          313   0.00000000E+00
         329          314   0.00000000E+00
         329          315   0.00000000E+00
         329          316   0.00000000E+00
         329          317   0.28823897E-09
         329          318  -0.29225903E-14
         329          319  -0.23794469E-06
         329          320  -0.80315889E-07
         329          331   0.00000000E+00
         329          332   0.00000000E+00
         329          333   0.00000000E+00
         329          334   0.00000000E+00
         329          335   0.00000000E+00
         329          336   0.00000000E+00
         329          337   0.43262376E-09
         329          338  -0.43865755E-14
         329          339  -0.35713606E-06
         329          340  -0.12054776E-06
         330          330   0.13484933E+05
         330          321   0.36307130E+04
         330          322   0.24834091E+03
         330          323   0.00000000E+00
         330          324   0.00000000E+00
         330          325   0.21795340E-05
         330          326   0.00000000E+00
         330          327   0.49505150E-01
         330          328  -0.37042339E-04
         330          329   0.33536708E+02
         330          311  -0.86950688E-05
         330          312  -0.59474313E-06
         330          313   0.00000000E+00
         330          314   0.00000000E+00
         330          315  -0.52196912E-14
         330          316   0.00000000E+00
         330          317  -0.11851393E-09
         330          318   0.11294945E-13
         330          319  -0.80315889E-07
         330          320  -0.32294601E-04
         330          331  -0.13050607E-04
         330          332  -0.89266212E-06
         330          333   0.00000000E+00
         330          334   0.00000000E+00
         330          335  -0.78343413E-14
         330          336   0.00000000E+00
         330          337  -0.17787999E-09
         330          338   0.16952814E-13
         330          339  -0.12054776E-06
         330          340  -0.48471627E-04
         331          331   0.97945219E+04
         331          332   0.00000000E+00
         331          333   0.00000000E+00
         331          334   0.00000000E+00
         331          335   0.00000000E+00
         331          336   0.79884210E+02
         331          337   0.76117799E+02
         331          338   0.00000000E+00
         331          339   0.00000000E+00
         331          340   0.36307130E+04
         331          321  -0.23456563E-04
         331          322   0.00000000E+00
         331          323   0.00000000E+00
         331          324   0.00000000E+00
         331          325   0.00000000E+00
         331          326  -0.19131143E-06
         331          327  -0.18229190E-06
         331          328   0.00000000E+00
         331          329   0.00000000E+00
         331          330  -0.86950688E-05
         331          341  -0.35206435E-04
         331          342   0.00000000E+00
         331          343   0.00000000E+00
         331          344   0.00000000E+00
         331          345   0.00000000E+00
         331          346  -0.28714324E-06
         331          347  -0.27360565E-06
         331          348   0.00000000E+00
         331          349   0.00000000E+00
         331          350  -0.13050607E-04
         332          332   0.61664984E+04
         332          331   0.00000000E+00
         332          333   0.00000000E+00
         332          334   0.63450217E+01
         332          335   0.63450217E+01
         332          336   0.00000000E+00
         332          337  -0.21136331E+02
         332          338   0.00000000E+00
         332          339   0.00000000E+00
         332          340   0.24834091E+03
         332          321   0.00000000E+00
         332          322  -0.14762871E-04
         332          323   0.00000000E+00
         332          324   0.00000000E+00
         332          325   0.00000000E+00
         332          326   0.00000000E+00
         332          327   0.00000000E+00
         332          328   0.00000000E+00
         332          329   0.00000000E+00
         332          330  -0.59474313E-06
         332          341   0.00000000E+00
         332          342  -0.22157895E-04
         332          343   0.00000000E+00
         332          344   0.00000000E+00
         332          345   0.00000000E+00
         332          346   0.00000000E+00
         332          347   0.00000000E+00
         332          348   0.00000000E+00
         332          349   0.00000000E+00
         332          350  -0.89266212E-06
         333          333   0.78082192E+03
         333          331   0.00000000E+00
         333          332   0.00000000E+00
         333          334   0.00000000E+00
         333          335   0.00000000E+00
         333          336   0.00000000E+00
         333          337   0.00000000E+00
         333          338   0.00000000E+00
         333          339   0.00000000E+00
         333          340   0.00000000E+00
         333          321   0.00000000E+00
         333          322   0.00000000E+00
         333          323  -0.18699636E-05
         333          324   0.00000000E+00
         333          325   0.00000000E+00
         333          326   0.00000000E+00
         333          327   0.00000000E+00
         333          328   0.00000000E+00
         333          329   0.00000000E+00
         333          330   0.00000000E+00
         333          341   0.00000000E+00
         333          342   0.00000000E+00
         333          343  -0.28066666E-05
         333          344   0.00000000E+00
         333          345   0.00000000E+00
         333          346   0.00000000E+00
         333          347   0.00000000E+00
         333          348   0.00000000E+00
         333          349   0.00000000E+00
         333          350   0.00000000E+00
         334          334   0.13409529E+04
         334          331   0.00000000E+00
         334          332   0.63443872E+01
         334          333   0.00000000E+00
         334          335   0.19035065E+02
         334          336   0.00000000E+00
         334          337  -0.65836821E+02
         334          338   0.00000000E+00
         334          339   0.00000000E+00
         334          340   0.00000000E+00
         334          321   0.00000000E+00
         334          322   0.00000000E+00
         334          323   0.00000000E+00
         334          324  -0.31658156E-05
         334          325   0.00000000E+00
         334          326   0.00000000E+00
         334          327   0.58143243E-08
         334          328   0.00000000E+00
         334          329   0.00000000E+00
         334          330   0.00000000E+00
         334          341   0.00000000E+00
         334          342   0.00000000E+00
         334          343   0.00000000E+00
         334          344  -0.47516374E-05
         334          345   0.00000000E+00
         334          346   0.00000000E+00
         334          347   0.87268382E-08
         334          348   0.00000000E+00
         334          349   0.00000000E+00
         334          350   0.00000000E+00
         335          335   0.19052837E+02
         335          331   0.00000000E+00
         335          332   0.63443872E+01
         335          333   0.00000000E+00
         335          334   0.19035065E+02
         335          336   0.00000000E+00
         335          337  -0.63477866E+02
         335          338   0.00000000E+00
         335          339   0.00000000E+00
         335          340   0.21795643E-05
         335          321   0.00000000E+00
         335          322   0.00000000E+00
         335          323   0.00000000E+00
         335          324   0.00000000E+00
         335          325  -0.42484263E-10
         335          326   0.00000000E+00
         335          327   0.16470995E-09
         335          328   0.00000000E+00
         335          329   0.00000000E+00
         335          330  -0.52197638E-14
         335          341   0.00000000E+00
         335          342   0.00000000E+00
         335          343   0.00000000E+00
         335          344   0.00000000E+00
         335          345  -0.63765499E-10
         335          346   0.00000000E+00
         335          347   0.24721653E-09
         335          348   0.00000000E+00
         335          349   0.00000000E+00
         335          350  -0.78344502E-14
         336          336   0.17074662E+04
         336          331   0.79884210E+02
         336          332   0.00000000E+00
         336          333   0.00000000E+00
         336          334   0.00000000E+00
         336          335   0.00000000E+00
         336          337   0.19543730E+04
         336          338   0.00000000E+00
         336          339   0.43198833E-04
         336          340   0.00000000E+00
         336          321  -0.19131143E-06
         336          322   0.00000000E+00
         336          323   0.00000000E+00
         336          324   0.00000000E+00
         336          325   0.00000000E+00
         336          326  -0.40891515E-05
         336          327  -0.46804608E-05
         336          328   0.00000000E+00
         336          329   0.00000000E+00
         336          330   0.00000000E+00
         336          341  -0.28714324E-06
         336          342   0.00000000E+00
         336          343   0.00000000E+00
         336          344   0.00000000E+00
         336          345   0.00000000E+00
         336          346  -0.61374911E-05
         336          347  -0.70249993E-05
         336          348   0.00000000E+00
         336          349   0.00000000E+00
         336          350   0.00000000E+00
         337          337   0.26723718E+04
         337          331   0.76117799E+02
         337          332  -0.21147957E+02
         337          333   0.00000000E+00
         337          334  -0.65878288E+02
         337          335  -0.63519108E+02
         337          336   0.19543478E+04
         337          338  -0.38887502E-04
         337          339  -0.12035985E+00
         337          340   0.49505150E-01
         337          321  -0.18229190E-06
         337          322   0.00000000E+00
         337          323   0.00000000E+00
         337          324   0.58149057E-08
         337          325   0.16475051E-09
         337          326  -0.46804005E-05
         337          327  -0.58937841E-05
         337          328   0.15713863E-13
         337          329   0.28826779E-09
         337          330  -0.11851393E-09
         337          341  -0.27360565E-06
         337          342   0.00000000E+00
         337          343   0.00000000E+00
         337          344   0.87277109E-08
         337          345   0.24727742E-09
         337          346  -0.70249088E-05
         337          347  -0.88461011E-05
         337          348   0.23585259E-13
         337          349   0.43266702E-09
         337          350  -0.17787999E-09
         338          338   0.66308262E-04
         338          331   0.00000000E+00
         338          332   0.00000000E+00
         338          333   0.00000000E+00
         338          334   0.00000000E+00
         338          335   0.00000000E+00
         338          336   0.00000000E+00
         338          337  -0.38896922E-04
         338          339  -0.14946245E-04
         338          340  -0.37051937E-04
         338          321   0.00000000E+00
         338          322   0.00000000E+00
         338          323   0.00000000E+00
         338          324   0.00000000E+00
         338          325   0.00000000E+00
         338          326   0.00000000E+00
         338          327   0.15715132E-13
         338          328  -0.23320539E-13
         338          329  -0.29226999E-14
         338          330   0.11296639E-13
         338          341   0.00000000E+00
         338          342   0.00000000E+00
         338          343   0.00000000E+00
         338          344   0.00000000E+00
         338          345   0.00000000E+00
         338          346   0.00000000E+00
         338          347   0.23587162E-13
         338          348  -0.35002274E-13
         338          349  -0.43867400E-14
         338          350   0.16955357E-13
         339          339   0.99356224E+02
         339          331   0.00000000E+00
         339          332   0.00000000E+00
         339          333   0.00000000E+00
         339          334   0.00000000E+00
         339          335   0.00000000E+00
         339          336   0.43198833E-04
         339          337  -0.12034781E+00
         339          338  -0.14942654E-04
         339          340   0.33536708E+02
         339          321   0.00000000E+00
         339          322   0.00000000E+00
         339          323   0.00000000E+00
         339          324   0.00000000E+00
         339          325   0.00000000E+00
         339          326   0.00000000E+00
         339          327   0.28823897E-09
         339          328  -0.29225903E-14
         339          329  -0.23794469E-06
         339          330  -0.80315889E-07
         339          341   0.00000000E+00
         339          342   0.00000000E+00
         339          343   0.00000000E+00
         339          344   0.00000000E+00
         339          345   0.00000000E+00
         339          346   0.00000000E+00
         339          347   0.43262376E-09
         339          348  -0.43865755E-14
         339          349  -0.35713606E-06
         339          350  -0.12054776E-06
         340          340   0.13484933E+05
         340          331   0.36307130E+04
         340          332   0.24834091E+03
         340          333   0.00000000E+00
         340          334   0.00000000E+00
         340          335   0.21795340E-05
         340          336   0.00000000E+00
         340          337   0.49505150E-01
         340          338  -0.37042339E-04
         340          339   0.33536708E+02
         340          321  -0.86950688E-05
         340          322  -0.59474313E-06
         340          323   0.00000000E+00
         340          324   0.00000000E+00
         340          325  -0.52196912E-14
         340          326   0.00000000E+00
         340          327  -0.11851393E-09
         340          328   0.11294945E-13
         340          329  -0.80315889E-07
         340          330  -0.32294601E-04
         340          341  -0.13050607E-04
         340          342  -0.89266212E-06
         340          343   0.00000000E+00
         340          344   0.00000000E+00
         340          345  -0.78343413E-14
         340          346   0.00000000E+00
         340          347  -0.17787999E-09
         340          348   0.16952814E-13
         340          349  -0.12054776E-06
         340          350  -0.48471627E-04
         341          341   0.97945219E+04
         341          342   0.00000000E+00
         341          343   0.00000000E+00
         341          344   0.00000000E+00
         341          345   0.00000000E+00
         341          346   0.79884210E+02
         341          347   0.76117799E+02
         341          348   0.00000000E+00
         341          349   0.00000000E+00
         341          350   0.36307130E+04
         341          331  -0.23456563E-04
         341          332   0.00000000E+00
         341          333   0.00000000E+00
         341          334   0.00000000E+00
         341          335   0.00000000E+00
         341          336  -0.19131143E-06
         341          337  -0.18229190E-06
         341          338   0.00000000E+00
         341          339   0.00000000E+00
         341          340  -0.86950688E-05
         341          351  -0.35206435E-04
         341          352   0.00000000E+00
         341          353   0.00000000E+00
         341          354   0.00000000E+00
         341          355   0.00000000E+00
         341          356  -0.28714324E-06
         341          357  -0.27360565E-06
         341          358   0.00000000E+00
         341          359   0.00000000E+00
         341          360  -0.13050607E-04
         342          342   0.61664984E+04
         342          341   0.00000000E+00
         342          343   0.00000000E+00
         342          344   0.63450217E+01
         342          345   0.63450217E+01
         342          346   0.00000000E+00
         342          347  -0.21136331E+02
         342          348   0.00000000E+00
         342          349   0.00000000E+00
         342          350   0.24834091E+03
         342          331   0.00000000E+00
         342          332  -0.14762871E-04
         342          333   0.00000000E+00
         342          334   0.00000000E+00
         342          335   0.00000000E+00
         342          336   0.00000000E+00
         342          337   0.00000000E+00
         342          338   0.00000000E+00
         342          339   0.00000000E+00
         342          340  -0.59474313E-06
         342          351   0.00000000E+00
         342          352  -0.22157895E-04
         342          353   0.00000000E+00
         342          354   0.00000000E+00
         342          355   0.00000000E+00
         342          356   0.00000000E+00
         342          357   0.00000000E+00
         342          358   0.00000000E+00
         342          359   0.00000000E+00
         342          360  -0.89266212E-06
         343          343   0.78082192E+03
         343          341   0.00000000E+00
         343          342   0.00000000E+00
         343          344   0.00000000E+00
         343          345   0.00000000E+00
         343          346   0.00000000E+00
         343          347   0.00000000E+00
         343          348   0.00000000E+00
         343          349   0.00000000E+00
         343          350   0.00000000E+00
         343          331   0.00000000E+00
         343          332   0.00000000E+00
         343          333  -0.18699636E-05
         343          334   0.00000000E+00
         343          335   0.00000000E+00
         343          336   0.00000000E+00
         343          337   0.00000000E+00
         343          338   0.00000000E+00
         343          339   0.00000000E+00
         343          340   0.00000000E+00
         343          351   0.00000000E+00
         343          352   0.00000000E+00
         343          353  -0.28066666E-05
         343          354   0.00000000E+00
         343          355   0.00000000E+00
         343          356   0.00000000E+00
         343          357   0.00000000E+00
         343          358   0.00000000E+00
         343          359   0.00000000E+00
         343          360   0.00000000E+00
         344          344   0.13409529E+04
         344          341   0.00000000E+00
         344          342   0.63443872E+01
         344          343   0.00000000E+00
         344          345   0.19035065E+02
         344          346   0.00000000E+00
         344          347  -0.65836821E+02
         344          348   0.00000000E+00
         344          349   0.00000000E+00
         344          350   0.00000000E+00
         344          331   0.00000000E+00
         344          332   0.00000000E+00
         344          333   0.00000000E+00
         344          334  -0.31658156E-05
         344          335   0.00000000E+00
         344          336   0.00000000E+00
         344          337   0.58143243E-08
         344          338   0.00000000E+00
         344          339   0.00000000E+00
         344          340   0.00000000E+00
         344          351   0.00000000E+00
         344          352   0.00000000E+00
         344          353   0.00000000E+00
         344          354  -0.47516374E-05
         344          355   0.00000000E+00
         344          356   0.00000000E+00
         344          357   0.87268382E-08
         344          358   0.00000000E+00
         344          359   0.00000000E+00
         344          360   0.00000000E+00
         345          345   0.19052837E+02
         345          341   0.00000000E+00
         345          342   0.63443872E+01
         345          343   0.00000000E+00
         345          344   0.19035065E+02
         345          346   0.00000000E+00
         345          347  -0.63477866E+02
         345          348   0.00000000E+00
         345          349   0.00000000E+00
         345          350   0.21795643E-05
         345          331   0.00000000E+00
         345          332   0.00000000E+00
         345          333   0.00000000E+00
         345          334   0.00000000E+00
         345          335  -0.42484263E-10
         345          336   0.00000000E+00
         345          337   0.16470995E-09
         345          338   0.00000000E+00
         345          339   0.00000000E+00
         345          340  -0.52197638E-14
         345          351   0.00000000E+00
         345          352   0.00000000E+00
         345          353   0.00000000E+00
         345          354   0.00000000E+00
         345          355  -0.63765499E-10
         345          356   0.00000000E+00
         345          357   0.24721653E-09
         345          358   0.00000000E+00
         345          359   0.00000000E+00
         345          360  -0.78344502E-14
         346          346   0.17074662E+04
         346          341   0.79884210E+02
         346          342   0.00000000E+00
         346          343   0.00000000E+00
         346          344   0.00000000E+00
         346          345   0.00000000E+00
         346          347   0.19543730E+04
         346          348   0.00000000E+00
         346          349   0.43198833E-04
         346          350   0.00000000E+00
         346          331  -0.19131143E-06
         346          332   0.00000000E+00
         346          333   0.00000000E+00
         346          334   0.00000000E+00
         346          335   0.00000000E+00
         346          336  -0.40891515E-05
         346          337  -0.46804608E-05
         346          338   0.00000000E+00
         346          339   0.00000000E+00
         346          340   0.00000000E+00
         346          351  -0.28714324E-06
         346          352   0.00000000E+00
         346          353   0.00000000E+00
         346          354   0.00000000E+00
         346          355   0.00000000E+00
         346          356  -0.61374911E-05
         346          357  -0.70249993E-05
         346          358   0.00000000E+00
         346          359   0.00000000E+00
         346          360   0.00000000E+00
         347          347   0.26723718E+04
         347          341   0.76117799E+02
         347          342  -0.21147957E+02
         347          343   0.00000000E+00
         347          344  -0.65878288E+02
         347          345  -0.63519108E+02
         347          346   0.19543478E+04
         347          348  -0.38887502E-04
         347          349  -0.12035985E+00
         347          350   0.49505150E-01
         347          331  -0.18229190E-06
         347          332   0.00000000E+00
         347          333   0.00000000E+00
         347          334   0.58149057E-08
         347          335   0.16475051E-09
         347          336  -0.46804005E-05
         347          337  -0.58937841E-05
         347          338   0.15713863E-13
         347          339   0.28826779E-09
         347          340  -0.11851393E-09
         347          351  -0.27360565E-06
         347          352   0.00000000E+00
         347          353   0.00000000E+00
         347          354   0.87277109E-08
         347          355   0.24727742E-09
         347          356  -0.70249088E-05
         347          357  -0.88461011E-05
         347          358   0.23585259E-13
         347          359   0.43266702E-09
         347          360  -0.17787999E-09
         348          348   0.66308262E-04
         348          341   0.00000000E+00
         348          342   0.00000000E+00
         348          343   0.00000000E+00
         348          344   0.00000000E+00
         348          345   0.00000000E+00
         348          346   0.00000000E+00
         348          347  -0.38896922E-04
         348          349  -0.14946245E-04
         348          350  -0.37051937E-04
         348          331   0.00000000E+00
         348          332   0.00000000E+00
         348          333   0.00000000E+00
         348          334   0.00000000E+00
         348          335   0.00000000E+00
         348          336   0.00000000E+00
         348          337   0.15715132E-13
         348          338  -0.23320539E-13
         348          339  -0.29226999E-14
         348          340   0.11296639E-13
         348          351   0.00000000E+00
         348          352   0.00000000E+00
         348          353   0.00000000E+00
         348          354   0.00000000E+00
         348          355   0.00000000E+00
         348          356   0.00000000E+00
         348          357   0.23587162E-13
         348          358  -0.35002274E-13
         348          359  -0.43867400E-14
         348          360   0.16955357E-13
         349          349   0.99356224E+02
         349          341   0.00000000E+00
         349          342   0.00000000E+00
         349          343   0.00000000E+00
         349          344   0.00000000E+00
         349          345   0.00000000E+00
         349          346   0.43198833E-04
         349          347  -0.12034781E+00
         349          348  -0.14942654E-04
         349          350   0.33536708E+02
         349          331   0.00000000E+00
         349          332   0.00000000E+00
         349          333   0.00000000E+00
         349          334   0.00000000E+00
         349          335   0.00000000E+00
         349          336   0.00000000E+00
         349          337   0.28823897E-09
         349          338  -0.29225903E-14
         349          339  -0.23794469E-06
         349          340  -0.80315889E-07
         349          351   0.00000000E+00
         349          352   0.00000000E+00
         349          353   0.00000000E+00
         349          354   0.00000000E+00
         349          355   0.00000000E+00
         349          356   0.00000000E+00
         349          357   0.43262376E-09
         349          358  -0.43865755E-14
         349          359  -0.35713606E-06
         349          360  -0.12054776E-06
         350          350   0.13484933E+05
         350          341   0.36307130E+04
         350          342   0.24834091E+03
         350          343   0.00000000E+00
         350          344   0.00000000E+00
         350          345   0.21795340E-05
         350          346   0.00000000E+00
         350          347   0.49505150E-01
         350          348  -0.37042339E-04
         350          349   0.33536708E+02
         350          331  -0.86950688E-05
         350          332  -0.59474313E-06
         350          333   0.00000000E+00
         350          334   0.00000000E+00
         350          335  -0.52196912E-14
         350          336   0.00000000E+00
         350          337  -0.11851393E-09
         350          338   0.11294945E-13
         350          339  -0.80315889E-07
         350          340  -0.32294601E-04
         350          351  -0.13050607E-04
         350          352  -0.89266212E-06
         350          353   0.00000000E+00
         350          354   0.00000000E+00
         350          355  -0.78343413E-14
         350          356   0.00000000E+00
         350          357  -0.17787999E-09
         350          358   0.16952814E-13
         350          359  -0.12054776E-06
         350          360  -0.48471627E-04
         351          351   0.97945219E+04
         351          352   0.00000000E+00
         351          353   0.00000000E+00
         351          354   0.00000000E+00
         351          355   0.00000000E+00
         351          356   0.79884210E+02
         351          357   0.76117799E+02
         351          358   0.00000000E+00
         351          359   0.00000000E+00
         351          360   0.36307130E+04
         351          341  -0.23456563E-04
         351          342   0.00000000E+00
         351          343   0.00000000E+00
         351          344   0.00000000E+00
         351          345   0.00000000E+00
         351          346  -0.19131143E-06
         351          347  -0.18229190E-06
         351          348   0.00000000E+00
         351          349   0.00000000E+00
         351          350  -0.86950688E-05
         351          361  -0.35206435E-04
         351          362   0.00000000E+00
         351          363   0.00000000E+00
         351          364   0.00000000E+00
         351          365   0.00000000E+00
         351          366  -0.28714324E-06
         351          367  -0.27360565E-06
         351          368   0.00000000E+00
         351          369   0.00000000E+00
         351          370  -0.13050607E-04
         352          352   0.61664984E+04
         352          351   0.00000000E+00
         352          353   0.00000000E+00
         352          354   0.63450217E+01
         352          355   0.63450217E+01
         352          356   0.00000000E+00
         352          357  -0.21136331E+02
         352          358   0.00000000E+00
         352          359   0.00000000E+00
         352          360   0.24834091E+03
         352          341   0.00000000E+00
         352          342  -0.14762871E-04
         352          343   0.00000000E+00
         352          344   0.00000000E+00
         352          345   0.00000000E+00
         352          346   0.00000000E+00
         352          347   0.00000000E+00
         352          348   0.00000000E+00
         352          349   0.00000000E+00
         352          350  -0.59474313E-06
         352          361   0.00000000E+00
         352          362  -0.22157895E-04
         352          363   0.00000000E+00
         352          364   0.00000000E+00
         352          365   0.00000000E+00
         352          366   0.00000000E+00
         352          367   0.00000000E+00
         352          368   0.00000000E+00
         352          369   0.00000000E+00
         352          370  -0.89266212E-06
         353          353   0.78082192E+03
         353          351   0.00000000E+00
         353          352   0.00000000E+00
         353          354   0.00000000E+00
         353          355   0.00000000E+00
         353          356   0.00000000E+00
         353          357   0.00000000E+00
         353          358   0.00000000E+00
         353          359   0.00000000E+00
         353          360   0.00000000E+00
         353          341   0.00000000E+00
         353          342   0.00000000E+00
         353          343  -0.18699636E-05
         353          344   0.00000000E+00
         353          345   0.00000000E+00
         353          346   0.00000000E+00
         353          347   0.00000000E+00
         353          348   0.00000000E+00
         353          349   0.00000000E+00
         353          350   0.00000000E+00
         353          361   0.00000000E+00
         353          362   0.00000000E+00
         353          363  -0.28066666E-05
         353          364   0.00000000E+00
         353          365   0.00000000E+00
         353          366   0.00000000E+00
         353          367   0.00000000E+00
         353          368   0.00000000E+00
         353          369   0.00000000E+00
         353          370   0.00000000E+00
         354          354   0.13409529E+04
         354          351   0.00000000E+00
         354          352   0.63443872E+01
         354          353   0.00000000E+00
         354          355   0.19035065E+02
         354          356   0.00000000E+00
         354          357  -0.65836821E+02
         354          358   0.00000000E+00
         354          359   0.00000000E+00
         354          360   0.00000000E+00
         354          341   0.00000000E+00
         354          342   0.00000000E+00
         354          343   0.00000000E+00
         354          344  -0.31658156E-05
         354          345   0.00000000E+00
         354          346   0.00000000E+00
         354          347   0.58143243E-08
         354          348   0.00000000E+00
         354          349   0.00000000E+00
         354          350   0.00000000E+00
         354          361   0.00000000E+00
         354          362   0.00000000E+00
         354          363   0.00000000E+00
         354          364  -0.47516374E-05
         354          365   0.00000000E+00
         354          366   0.00000000E+00
         354          367   0.87268382E-08
         354          368   0.00000000E+00
         354          369   0.00000000E+00
         354          370   0.00000000E+00
         355          355   0.19052837E+02
         355          351   0.00000000E+00
         355          352   0.63443872E+01
         355          353   0.00000000E+00
         355          354   0.19035065E+02
         355          356   0.00000000E+00
         355          357  -0.63477866E+02
         355          358   0.00000000E+00
         355          359   0.00000000E+00
         355          360   0.21795643E-05
         355          341   0.00000000E+00
         355          342   0.00000000E+00
         355          343   0.00000000E+00
         355          344   0.00000000E+00
         355          345  -0.42484263E-10
         355          346   0.00000000E+00
         355          347   0.16470995E-09
         355          348   0.00000000E+00
         355          349   0.00000000E+00
         355          350  -0.52197638E-14
         355          361   0.00000000E+00
         355          362   0.00000000E+00
         355          363   0.00000000E+00
         355          364   0.00000000E+00
         355          365  -0.63765499E-10
         355          366   0.00000000E+00
         355          367   0.24721653E-09
         355          368   0.00000000E+00
         355          369   0.00000000E+00
         355          370  -0.78344502E-14
         356          356   0.17074662E+04
         356          351   0.79884210E+02
         356          352   0.00000000E+00
         356          353   0.00000000E+00
         356          354   0.00000000E+00
         356          355   0.00000000E+00
         356          357   0.19543730E+04
         356          358   0.00000000E+00
         356          359   0.43198833E-04
         356          360   0.00000000E+00
         356          341  -0.19131143E-06
         356          342   0.00000000E+00
         356          343   0.00000000E+00
         356          344   0.00000000E+00
         356          345   0.00000000E+00
         356          346  -0.40891515E-05
         356          347  -0.46804608E-05
         356          348   0.00000000E+00
         356          349   0.00000000E+00
         356          350   0.00000000E+00
         356          361  -0.28714324E-06
         356          362   0.00000000E+00
         356          363   0.00000000E+00
         356          364   0.00000000E+00
         356          365   0.00000000E+00
         356          366  -0.61374911E-05
         356          367  -0.70249993E-05
         356          368   0.00000000E+00
         356          369   0.00000000E+00
         356          370   0.00000000E+00
         357          357   0.26723718E+04
         357          351   0.76117799E+02
         357          352  -0.21147957E+02
         357          353   0.00000000E+00
         357          354  -0.65878288E+02
         357          355  -0.63519108E+02
         357          356   0.19543478E+04
         357          358  -0.38887502E-04
         357          359  -0.12035985E+00
         357          360   0.49505150E-01
         357          341  -0.18229190E-06
         357          342   0.00000000E+00
         357          343   0.00000000E+00
         357          344   0.58149057E-08
         357          345   0.16475051E-09
         357          346  -0.46804005E-05
         357          347  -0.58937841E-05
         357          348   0.15713863E-13
         357          349   0.28826779E-09
         357          350  -0.11851393E-09
         357          361  -0.27360565E-06
         357          362   0.00000000E+00
         357          363   0.00000000E+00
         357          364   0.87277109E-08
         357          365   0.24727742E-09
         357          366  -0.70249088E-05
         357          367  -0.88461011E-05
         357          368   0.23585259E-13
         357          369   0.43266702E-09
         357          370  -0.17787999E-09
         358          358   0.66308262E-04
         358          351   0.00000000E+00
         358          352   0.00000000E+00
         358          353   0.00000000E+00
         358          354   0.00000000E+00
         358          355   0.00000000E+00
         358          356   0.00000000E+00
         358          357  -0.38896922E-04
         358          359  -0.14946245E-04
         358          360  -0.37051937E-04
         358          341   0.00000000E+00
         358          342   0.00000000E+00
         358          343   0.00000000E+00
         358          344   0.00000000E+00
         358          345   0.00000000E+00
         358          346   0.00000000E+00
         358          347   0.15715132E-13
         358          348  -0.23320539E-13
         358          349  -0.29226999E-14
         358          350   0.11296639E-13
         358          361   0.00000000E+00
         358          362   0.00000000E+00
         358          363   0.00000000E+00
         358          364   0.00000000E+00
         358          365   0.00000000E+00
         358          366   0.00000000E+00
         358          367   0.23587162E-13
         358          368  -0.35002274E-13
         358          369  -0.43867400E-14
         358          370   0.16955357E-13
         359          359   0.99356224E+02
         359          351   0.00000000E+00
         359          352   0.00000000E+00
         359          353   0.00000000E+00
         359          354   0.00000000E+00
         359          355   0.00000000E+00
         359          356   0.43198833E-04
         359          357  -0.12034781E+00
         359          358  -0.14942654E-04
         359          360   0.33536708E+02
         359          341   0.00000000E+00
         359          342   0.00000000E+00
         359          343   0.00000000E+00
         359          344   0.00000000E+00
         359          345   0.00000000E+00
         359          346   0.00000000E+00
         359          347   0.28823897E-09
         359          348  -0.29225903E-14
         359          349  -0.23794469E-06
         359          350  -0.80315889E-07
         359          361   0.00000000E+00
         359          362   0.00000000E+00
         359          363   0.00000000E+00
         359          364   0.00000000E+00
         359          365   0.00000000E+00
         359          366   0.00000000E+00
         359          367   0.43262376E-09
         359          368  -0.43865755E-14
         359          369  -0.35713606E-06
         359          370  -0.12054776E-06
         360          360   0.13484933E+05
         360          351   0.36307130E+04
         360          352   0.24834091E+03
         360          353   0.00000000E+00
         360          354   0.00000000E+00
         360          355   0.21795340E-05
         360          356   0.00000000E+00
         360          357   0.49505150E-01
         360          358  -0.37042339E-04
         360          359   0.33536708E+02
         360          341  -0.86950688E-05
         360          342  -0.59474313E-06
         360          343   0.00000000E+00
         360          344   0.00000000E+00
         360          345  -0.52196912E-14
         360          346   0.00000000E+00
         360          347  -0.11851393E-09
         360          348   0.11294945E-13
         360          349  -0.80315889E-07
         360          350  -0.32294601E-04
         360          361  -0.13050607E-04
         360          362  -0.89266212E-06
         360          363   0.00000000E+00
         360          364   0.00000000E+00
         360          365  -0.78343413E-14
         360          366   0.00000000E+00
         360          367  -0.17787999E-09
         360          368   0.16952814E-13
         360          369  -0.12054776E-06
         360          370  -0.48471627E-04
         361          361   0.97945219E+04
         361          362   0.00000000E+00
         361          363   0.00000000E+00
         361          364   0.00000000E+00
         361          365   0.00000000E+00
         361          366   0.79884210E+02
         361          367   0.76117799E+02
         361          368   0.00000000E+00
         361          369   0.00000000E+00
         361          370   0.36307130E+04
         361          351  -0.23456563E-04
         361          352   0.00000000E+00
         361          353   0.00000000E+00
         361          354   0.00000000E+00
         361          355   0.00000000E+00
         361          356  -0.19131143E-06
         361          357  -0.18229190E-06
         361          358   0.00000000E+00
         361          359   0.00000000E+00
         361          360  -0.86950688E-05
         361          371  -0.35206435E-04
         361          372   0.00000000E+00
         361          373   0.00000000E+00
         361          374   0.00000000E+00
         361          375   0.00000000E+00
         361          376  -0.28714324E-06
         361          377  -0.27360565E-06
         361          378   0.00000000E+00
         361          379   0.00000000E+00
         361          380  -0.13050607E-04
         362          362   0.61664984E+04
         362          361   0.00000000E+00
         362          363   0.00000000E+00
         362          364   0.63450217E+01
         362          365   0.63450217E+01
         362          366   0.00000000E+00
         362          367  -0.21136331E+02
         362          368   0.00000000E+00
         362          369   0.00000000E+00
         362          370   0.24834091E+03
         362          351   0.00000000E+00
         362          352  -0.14762871E-04
         362          353   0.00000000E+00
         362          354   0.00000000E+00
         362          355   0.00000000E+00
         362          356   0.00000000E+00
         362          357   0.00000000E+00
         362          358   0.00000000E+00
         362          359   0.00000000E+00
         362          360  -0.59474313E-06
         362          371   0.00000000E+00
         362          372  -0.22157895E-04
         362          373   0.00000000E+00
         362          374   0.00000000E+00
         362          375   0.00000000E+00
         362          376   0.00000000E+00
         362          377   0.00000000E+00
         362          378   0.00000000E+00
         362          379   0.00000000E+00
         362          380  -0.89266212E-06
         363          363   0.78082192E+03
         363          361   0.00000000E+00
         363          362   0.00000000E+00
         363          364   0.00000000E+00
         363          365   0.00000000E+00
         363          366   0.00000000E+00
         363          367   0.00000000E+00
         363          368   0.00000000E+00
         363          369   0.00000000E+00
         363          370   0.00000000E+00
         363          351   0.00000000E+00
         363          352   0.00000000E+00
         363          353  -0.18699636E-05
         363          354   0.00000000E+00
         363          355   0.00000000E+00
         363          356   0.00000000E+00
         363          357   0.00000000E+00
         363          358   0.00000000E+00
         363          359   0.00000000E+00
         363          360   0.00000000E+00
         363          371   0.00000000E+00
         363          372   0.00000000E+00
         363          373  -0.28066666E-05
         363          374   0.00000000E+00
         363          375   0.00000000E+00
         363          376   0.00000000E+00
         363          377   0.00000000E+00
         363          378   0.00000000E+00
         363          379   0.00000000E+00
         363          380   0.00000000E+00
         364          364   0.13409529E+04
         364          361   0.00000000E+00
         364          362   0.63443872E+01
         364          363   0.00000000E+00
         364          365   0.19035065E+02
         364          366   0.00000000E+00
         364          367  -0.65836821E+02
         364          368   0.00000000E+00
         364          369   0.00000000E+00
         364          370   0.00000000E+00
         364          351   0.00000000E+00
         364          352   0.00000000E+00
         364          353   0.00000000E+00
         364          354  -0.31658156E-05
         364          355   0.00000000E+00
         364          356   0.00000000E+00
         364          357   0.58143243E-08
         364          358   0.00000000E+00
         364          359   0.00000000E+00
         364          360   0.00000000E+00
         364          371   0.00000000E+00
         364          372   0.00000000E+00
         364          373   0.00000000E+00
         364          374  -0.47516374E-05
         364          375   0.00000000E+00
         364          376   0.00000000E+00
         364          377   0.87268382E-08
         364          378   0.00000000E+00
         364          379   0.00000000E+00
         364          380   0.00000000E+00
         365          365   0.19052837E+02
         365          361   0.00000000E+00
         365          362   0.63443872E+01
         365          363   0.00000000E+00
         365          364   0.19035065E+02
         365          366   0.00000000E+00
         365          367  -0.63477866E+02
         365          368   0.00000000E+00
         365          369   0.00000000E+00
         365          370   0.21795643E-05
         365          351   0.00000000E+00
         365          352   0.00000000E+00
         365          353   0.00000000E+00
         365          354   0.00000000E+00
         365          355  -0.42484263E-10
         365          356   0.00000000E+00
         365          357   0.16470995E-09
         365          358   0.00000000E+00
         365          359   0.00000000E+00
         365          360  -0.52197638E-14
         365          371   0.00000000E+00
         365          372   0.00000000E+00
         365          373   0.00000000E+00
         365          374   0.00000000E+00
         365          375  -0.63765499E-10
         365          376   0.00000000E+00
         365          377   0.24721653E-09
         365          378   0.00000000E+00
         365          379   0.00000000E+00
         365          380  -0.78344502E-14
         366          366   0.17074662E+04
         366          361   0.79884210E+02
         366          362   0.00000000E+00
         366          363   0.00000000E+00
         366          364   0.00000000E+00
         366          365   0.00000000E+00
         366          367   0.19543730E+04
         366          368   0.00000000E+00
         366          369   0.43198833E-04
         366          370   0.00000000E+00
         366          351  -0.19131143E-06
         366          352   0.00000000E+00
         366          353   0.00000000E+00
         366          354   0.00000000E+00
         366          355   0.00000000E+00
         366          356  -0.40891515E-05
         366          357  -0.46804608E-05
         366          358   0.00000000E+00
         366          359   0.00000000E+00
         366          360   0.00000000E+00
         366          371  -0.28714324E-06
         366          372   0.00000000E+00
         366          373   0.00000000E+00
         366          374   0.00000000E+00
         366          375   0.00000000E+00
         366          376  -0.61374911E-05
         366          377  -0.70249993E-05
         366          378   0.00000000E+00
         366          379   0.00000000E+00
         366          380   0.00000000E+00
         367          367   0.26723718E+04
         367          361   0.76117799E+02
         367          362  -0.21147957E+02
         367          363   0.00000000E+00
         367          364  -0.65878288E+02
         367          365  -0.63519108E+02
         367          366   0.19543478E+04
         367          368  -0.38887502E-04
         367          369  -0.12035985E+00
         367          370   0.49505150E-01
         367          351  -0.18229190E-06
         367          352   0.00000000E+00
         367          353   0.00000000E+00
         367          354   0.58149057E-08
         367          355   0.16475051E-09
         367          356  -0.46804005E-05
         367          357  -0.58937841E-05
         367          358   0.15713863E-13
         367          359   0.28826779E-09
         367          360  -0.11851393E-09
         367          371  -0.27360565E-06
         367          372   0.00000000E+00
         367          373   0.00000000E+00
         367          374   0.87277109E-08
         367          375   0.24727742E-09
         367          376  -0.70249088E-05
         367          377  -0.88461011E-05
         367          378   0.23585259E-13
         367          379   0.43266702E-09
         367          380  -0.17787999E-09
         368          368   0.66308262E-04
         368          361   0.00000000E+00
         368          362   0.00000000E+00
         368          363   0.00000000E+00
         368          364   0.00000000E+00
         368          365   0.00000000E+00
         368          366   0.00000000E+00
         368          367  -0.38896922E-04
         368          369  -0.14946245E-04
         368          370  -0.37051937E-04
         368          351   0.00000000E+00
         368          352   0.00000000E+00
         368          353   0.00000000E+00
         368          354   0.00000000E+00
         368          355   0.00000000E+00
         368          356   0.00000000E+00
         368          357   0.15715132E-13
         368          358  -0.23320539E-13
         368          359  -0.29226999E-14
         368          360   0.11296639E-13
         368          371   0.00000000E+00
         368          372   0.00000000E+00
         368          373   0.00000000E+00
         368          374   0.00000000E+00
         368          375   0.00000000E+00
         368          376   0.00000000E+00
         368          377   0.23587162E-13
         368          378  -0.35002274E-13
         368          379  -0.43867400E-14
         368          380   0.16955357E-13
         369          369   0.99356224E+02
         369          361   0.00000000E+00
         369          362   0.00000000E+00
         369          363   0.00000000E+00
         369          364   0.00000000E+00
         369          365   0.00000000E+00
         369          366   0.43198833E-04
         369          367  -0.12034781E+00
         369          368  -0.14942654E-04
         369          370   0.33536708E+02
         369          351   0.00000000E+00
         369          352   0.00000000E+00
         369          353   0.00000000E+00
         369          354   0.00000000E+00
         369          355   0.00000000E+00
         369          356   0.00000000E+00
         369          357   0.28823897E-09
         369          358  -0.29225903E-14
         369          359  -0.23794469E-06
         369          360  -0.80315889E-07
         369          371   0.00000000E+00
         369          372   0.00000000E+00
         369          373   0.00000000E+00
         369          374   0.00000000E+00
         369          375   0.00000000E+00
         369          376   0.00000000E+00
         369          377   0.43262376E-09
         369          378  -0.43865755E-14
         369          379  -0.35713606E-06
         369          380  -0.12054776E-06
         370          370   0.13484933E+05
         370          361   0.36307130E+04
         370          362   0.24834091E+03
         370          363   0.00000000E+00
         370          364   0.00000000E+00
         370          365   0.21795340E-05
         370          366   0.00000000E+00
         370          367   0.49505150E-01
         370          368  -0.37042339E-04
         370          369   0.33536708E+02
         370          351  -0.86950688E-05
         370          352  -0.59474313E-06
         370          353   0.00000000E+00
         370          354   0.00000000E+00
         370          355  -0.52196912E-14
         370          356   0.00000000E+00
         370          357  -0.11851393E-09
         370          358   0.11294945E-13
         370          359  -0.80315889E-07
         370          360  -0.32294601E-04
         370          371  -0.13050607E-04
         370          372  -0.89266212E-06
         370          373   0.00000000E+00
         370          374   0.00000000E+00
         370          375  -0.78343413E-14
         370          376   0.00000000E+00
         370          377  -0.17787999E-09
         370          378   0.16952814E-13
         370          379  -0.12054776E-06
         370          380  -0.48471627E-04
         371          371   0.97945219E+04
         371          372   0.00000000E+00
         371          373   0.00000000E+00
         371          374   0.00000000E+00
         371          375   0.00000000E+00
         371          376   0.79884210E+02
         371          377   0.76117799E+02
         371          378   0.00000000E+00
         371          379   0.00000000E+00
         371          380   0.36307130E+04
         371          361  -0.23456563E-04
         371          362   0.00000000E+00
         371          363   0.00000000E+00
         371          364   0.00000000E+00
         371          365   0.00000000E+00
         371          366  -0.19131143E-06
         371          367  -0.18229190E-06
         371          368   0.00000000E+00
         371          369   0.00000000E+00
         371          370  -0.86950688E-05
         371          381  -0.35206435E-04
         371          382   0.00000000E+00
         371          383   0.00000000E+00
         371          384   0.00000000E+00
         371          385   0.00000000E+00
         371          386  -0.28714324E-06
         371          387  -0.27360565E-06
         371          388   0.00000000E+00
         371          389   0.00000000E+00
         371          390  -0.13050607E-04
         372          372   0.61664984E+04
         372          371   0.00000000E+00
         372          373   0.00000000E+00
         372          374   0.63450217E+01
         372          375   0.63450217E+01
         372          376   0.00000000E+00
         372          377  -0.21136331E+02
         372          378   0.00000000E+00
         372          379   0.00000000E+00
         372          380   0.24834091E+03
         372          361   0.00000000E+00
         372          362  -0.14762871E-04
         372          363   0.00000000E+00
         372          364   0.00000000E+00
         372          365   0.00000000E+00
         372          366   0.00000000E+00
         372          367   0.00000000E+00
         372          368   0.00000000E+00
         372          369   0.00000000E+00
         372          370  -0.59474313E-06
         372          381   0.00000000E+00
         372          382  -0.22157895E-04
         372          383   0.00000000E+00
         372          384   0.00000000E+00
         372          385   0.00000000E+00
         372          386   0.00000000E+00
         372          387   0.00000000E+00
         372          388   0.00000000E+00
         372          389   0.00000000E+00
         372          390  -0.89266212E-06
         373          373   0.78082192E+03
         373          371   0.00000000E+00
         373          372   0.00000000E+00
         373          374   0.00000000E+00
         373          375   0.00000000E+00
         373          376   0.00000000E+00
         373          377   0.00000000E+00
         373          378   0.00000000E+00
         373          379   0.00000000E+00
         373          380   0.00000000E+00
         373          361   0.00000000E+00
         373          362   0.00000000E+00
         373          363  -0.18699636E-05
         373          364   0.00000000E+00
         373          365   0.00000000E+00
         373          366   0.00000000E+00
         373          367   0.00000000E+00
         373          368   0.00000000E+00
         373          369   0.00000000E+00
         373          370   0.00000000E+00
         373          381   0.00000000E+00
         373          382   0.00000000E+00
         373          383  -0.28066666E-05
         373          384   0.00000000E+00
         373          385   0.00000000E+00
         373          386   0.00000000E+00
         373          387   0.00000000E+00
         373          388   0.00000000E+00
         373          389   0.00000000E+00
         373          390   0.00000000E+00
         374          374   0.13409529E+04
         374          371   0.00000000E+00
         374          372   0.63443872E+01
         374          373   0.00000000E+00
         374          375   0.19035065E+02
         374          376   0.00000000E+00
         374          377  -0.65836821E+02
         374          378   0.00000000E+00
         374          379   0.00000000E+00
         374          380   0.00000000E+00
         374          361   0.00000000E+00
         374          362   0.00000000E+00
         374          363   0.00000000E+00
         374          364  -0.31658156E-05
         374          365   0.00000000E+00
         374          366   0.00000000E+00
         374          367   0.58143243E-08
         374          368   0.00000000E+00
         374          369   0.00000000E+00
         374          370   0.00000000E+00
         374          381   0.00000000E+00
         374          382   0.00000000E+00
         374          383   0.00000000E+00
         374          384  -0.47516374E-05
         374          385   0.00000000E+00
         374          386   0.00000000E+00
         374          387   0.87268382E-08
         374          388   0.00000000E+00
         374          389   0.00000000E+00
         374          390   0.00000000E+00
         375          375   0.19052837E+02
         375          371   0.00000000E+00
         375          372   0.63443872E+01
         375          373   0.00000000E+00
         375          374   0.19035065E+02
         375          376   0.00000000E+00
         375          377  -0.63477866E+02
         375          378   0.00000000E+00
         375          379   0.00000000E+00
         375          380   0.21795643E-05
         375          361   0.00000000E+00
         375          362   0.00000000E+00
         375          363   0.00000000E+00
         375          364   0.00000000E+00
         375          365  -0.42484263E-10
         375          366   0.00000000E+00
         375          367   0.16470995E-09
         375          368   0.00000000E+00
         375          369   0.00000000E+00
         375          370  -0.52197638E-14
         375          381   0.00000000E+00
         375          382   0.00000000E+00
         375          383   0.00000000E+00
         375          384   0.00000000E+00
         375          385  -0.63765499E-10
         375          386   0.00000000E+00
         375          387   0.24721653E-09
         375          388   0.00000000E+00
         375          389   0.00000000E+00
         375          390  -0.78344502E-14
         376          376   0.17074662E+04
         376          371   0.79884210E+02
         376          372   0.00000000E+00
         376          373   0.00000000E+00
         376          374   0.00000000E+00
         376          375   0.00000000E+00
         376          377   0.19543730E+04
         376          378   0.00000000E+00
         376          379   0.43198833E-04
         376          380   0.00000000E+00
         376          361  -0.19131143E-06
         376          362   0.00000000E+00
         376          363   0.00000000E+00
         376          364   0.00000000E+00
         376          365   0.00000000E+00
         376          366  -0.40891515E-05
         376          367  -0.46804608E-05
         376          368   0.00000000E+00
         376          369   0.00000000E+00
         376          370   0.00000000E+00
         376          381  -0.28714324E-06
         376          382   0.00000000E+00
         376          383   0.00000000E+00
         376          384   0.00000000E+00
         376          385   0.00000000E+00
         376          386  -0.61374911E-05
         376          387  -0.70249993E-05
         376          388   0.00000000E+00
         376          389   0.00000000E+00
         376          390   0.00000000E+00
         377          377   0.26723718E+04
         377          371   0.76117799E+02
         377          372  -0.21147957E+02
         377          373   0.00000000E+00
         377          374  -0.65878288E+02
         377          375  -0.63519108E+02
         377          376   0.19543478E+04
         377          378  -0.38887502E-04
         377          379  -0.12035985E+00
         377          380   0.49505150E-01
         377          361  -0.18229190E-06
         377          362   0.00000000E+00
         377          363   0.00000000E+00
         377          364   0.58149057E-08
         377          365   0.16475051E-09
         377          366  -0.46804005E-05
         377          367  -0.58937841E-05
         377          368   0.15713863E-13
         377          369   0.28826779E-09
         377          370  -0.11851393E-09
         377          381  -0.27360565E-06
         377          382   0.00000000E+00
         377          383   0.00000000E+00
         377          384   0.87277109E-08
         377          385   0.24727742E-09
         377          386  -0.70249088E-05
         377          387  -0.88461011E-05
         377          388   0.23585259E-13
         377          389   0.43266702E-09
         377          390  -0.17787999E-09
         378          378   0.66308262E-04
         378          371   0.00000000E+00
         378          372   0.00000000E+00
         378          373   0.00000000E+00
         378          374   0.00000000E+00
         378          375   0.00000000E+00
         378          376   0.00000000E+00
         378          377  -0.38896922E-04
         378          379  -0.14946245E-04
         378          380  -0.37051937E-04
         378          361   0.00000000E+00
         378          362   0.00000000E+00
         378          363   0.00000000E+00
         378          364   0.00000000E+00
         378          365   0.00000000E+00
         378          366   0.00000000E+00
         378          367   0.15715132E-13
         378          368  -0.23320539E-13
         378          369  -0.29226999E-14
         378          370   0.11296639E-13
         378          381   0.00000000E+00
         378          382   0.00000000E+00
         378          383   0.00000000E+00
         378          384   0.00000000E+00
         378          385   0.00000000E+00
         378          386   0.00000000E+00
         378          387   0.23587162E-13
         378          388  -0.35002274E-13
         378          389  -0.43867400E-14
         378          390   0.16955357E-13
         379          379   0.99356224E+02
         379          371   0.00000000E+00
         379          372   0.00000000E+00
         379          373   0.00000000E+00
         379          374   0.00000000E+00
         379          375   0.00000000E+00
         379          376   0.43198833E-04
         379          377  -0.12034781E+00
         379          378  -0.14942654E-04
         379          380   0.33536708E+02
         379          361   0.00000000E+00
         379          362   0.00000000E+00
         379          363   0.00000000E+00
         379          364   0.00000000E+00
         379          365   0.00000000E+00
         379          366   0.00000000E+00
         379          367   0.28823897E-09
         379          368  -0.29225903E-14
         379          369  -0.23794469E-06
         379          370  -0.80315889E-07
         379          381   0.00000000E+00
         379          382   0.00000000E+00
         379          383   0.00000000E+00
         379          384   0.00000000E+00
         379          385   0.00000000E+00
         379          386   0.00000000E+00
         379          387   0.43262376E-09
         379          388  -0.43865755E-14
         379          389  -0.35713606E-06
         379          390  -0.12054776E-06
         380          380   0.13484933E+05
         380          371   0.36307130E+04
         380          372   0.24834091E+03
         380          373   0.00000000E+00
         380          374   0.00000000E+00
         380          375   0.21795340E-05
         380          376   0.00000000E+00
         380          377   0.49505150E-01
         380          378  -0.37042339E-04
         380          379   0.33536708E+02
         380          361  -0.86950688E-05
         380          362  -0.59474313E-06
         380          363   0.00000000E+00
         380          364   0.00000000E+00
         380          365  -0.52196912E-14
         380          366   0.00000000E+00
         380          367  -0.11851393E-09
         380          368   0.11294945E-13
         380          369  -0.80315889E-07
         380          370  -0.32294601E-04
         380          381  -0.13050607E-04
         380          382  -0.89266212E-06
         380          383   0.00000000E+00
         380          384   0.00000000E+00
         380          385  -0.78343413E-14
         380          386   0.00000000E+00
         380          387  -0.17787999E-09
         380          388   0.16952814E-13
         380          389  -0.12054776E-06
         380          390  -0.48471627E-04
         381          381   0.97945219E+04
         381          382   0.00000000E+00
         381          383   0.00000000E+00
         381          384   0.00000000E+00
         381          385   0.00000000E+00
         381          386   0.79884210E+02
         381          387   0.76117799E+02
         381          388   0.00000000E+00
         381          389   0.00000000E+00
         381          390   0.36307130E+04
         381          371  -0.23456563E-04
         381          372   0.00000000E+00
         381          373   0.00000000E+00
         381          374   0.00000000E+00
         381          375   0.00000000E+00
         381          376  -0.19131143E-06
         381          377  -0.18229190E-06
         381          378   0.00000000E+00
         381          379   0.00000000E+00
         381          380  -0.86950688E-05
         381          391  -0.35206435E-04
         381          392   0.00000000E+00
         381          393   0.00000000E+00
         381          394   0.00000000E+00
         381          395   0.00000000E+00
         381          396  -0.28714324E-06
         381          397  -0.27360565E-06
         381          398   0.00000000E+00
         381          399   0.00000000E+00
         381          400  -0.13050607E-04
         382          382   0.61664984E+04
         382          381   0.00000000E+00
         382          383   0.00000000E+00
         382          384   0.63450217E+01
         382          385   0.63450217E+01
         382          386   0.00000000E+00
         382          387  -0.21136331E+02
         382          388   0.00000000E+00
         382          389   0.00000000E+00
         382          390   0.24834091E+03
         382          371   0.00000000E+00
         382          372  -0.14762871E-04
         382          373   0.00000000E+00
         382          374   0.00000000E+00
         382          375   0.00000000E+00
         382          376   0.00000000E+00
         382          377   0.00000000E+00
         382          378   0.00000000E+00
         382          379   0.00000000E+00
         382          380  -0.59474313E-06
         382          391   0.00000000E+00
         382          392  -0.22157895E-04
         382          393   0.00000000E+00
         382          394   0.00000000E+00
         382          395   0.00000000E+00
         382          396   0.00000000E+00
         382          397   0.00000000E+00
         382          398   0.00000000E+00
         382          399   0.00000000E+00
         382          400  -0.89266212E-06
         383          383   0.78082192E+03
         383          381   0.00000000E+00
         383          382   0.00000000E+00
         383          384   0.00000000E+00
         383          385   0.00000000E+00
         383          386   0.00000000E+00
         383          387   0.00000000E+00
         383          388   0.00000000E+00
         383          389   0.00000000E+00
         383          390   0.00000000E+00
         383          371   0.00000000E+00
         383          372   0.00000000E+00
         383          373  -0.18699636E-05
         383          374   0.00000000E+00
         383          375   0.00000000E+00
         383          376   0.00000000E+00
         383          377   0.00000000E+00
         383          378   0.00000000E+00
         383          379   0.00000000E+00
         383          380   0.00000000E+00
         383          391   0.00000000E+00
         383          392   0.00000000E+00
         383          393  -0.28066666E-05
         383          394   0.00000000E+00
         383          395   0.00000000E+00
         383          396   0.00000000E+00
         383          397   0.00000000E+00
         383          398   0.00000000E+00
         383          399   0.00000000E+00
         383          400   0.00000000E+00
         384          384   0.13409529E+04
         384          381   0.00000000E+00
         384          382   0.63443872E+01
         384          383   0.00000000E+00
         384          385   0.19035065E+02
         384          386   0.00000000E+00
         384          387  -0.65836821E+02
         384          388   0.00000000E+00
         384          389   0.00000000E+00
         384          390   0.00000000E+00
         384          371   0.00000000E+00
         384          372   0.00000000E+00
         384          373   0.00000000E+00
         384          374  -0.31658156E-05
         384          375   0.00000000E+00
         384          376   0.00000000E+00
         384          377   0.58143243E-08
         384          378   0.00000000E+00
         384          379   0.00000000E+00
         384          380   0.00000000E+00
         384          391   0.00000000E+00
         384          392   0.00000000E+00
         384          393   0.00000000E+00
         384          394  -0.47516374E-05
         384          395   0.00000000E+00
         384          396   0.00000000E+00
         384          397   0.87268382E-08
         384          398   0.00000000E+00
         384          399   0.00000000E+00
         384          400   0.00000000E+00
         385          385   0.19052837E+02
         385          381   0.00000000E+00
         385          382   0.63443872E+01
         385          383   0.00000000E+00
         385          384   0.19035065E+02
         385          386   0.00000000E+00
         385          387  -0.63477866E+02
         385          388   0.00000000E+00
         385          389   0.00000000E+00
         385          390   0.21795643E-05
         385          371   0.00000000E+00
         385          372   0.00000000E+00
         385          373   0.00000000E+00
         385          374   0.00000000E+00
         385          375  -0.42484263E-10
         385          376   0.00000000E+00
         385          377   0.16470995E-09
         385          378   0.00000000E+00
         385          379   0.00000000E+00
         385          380  -0.52197638E-14
         385          391   0.00000000E+00
         385          392   0.00000000E+00
         385          393   0.00000000E+00
         385          394   0.00000000E+00
         385          395  -0.63765499E-10
         385          396   0.00000000E+00
         385          397   0.24721653E-09
         385          398   0.00000000E+00
         385          399   0.00000000E+00
         385          400  -0.78344502E-14
         386          386   0.17074662E+04
         386          381   0.79884210E+02
         386          382   0.00000000E+00
         386          383   0.00000000E+00
         386          384   0.00000000E+00
         386          385   0.00000000E+00
         386          387   0.19543730E+04
         386          388   0.00000000E+00
         386          389   0.43198833E-04
         386          390   0.00000000E+00
         386          371  -0.19131143E-06
         386          372   0.00000000E+00
         386          373   0.00000000E+00
         386          374   0.00000000E+00
         386          375   0.00000000E+00
         386          376  -0.40891515E-05
         386          377  -0.46804608E-05
         386          378   0.00000000E+00
         386          379   0.00000000E+00
         386          380   0.00000000E+00
         386          391  -0.28714324E-06
         386          392   0.00000000E+00
         386          393   0.00000000E+00
         386          394   0.00000000E+00
         386          395   0.00000000E+00
         386          396  -0.61374911E-05
         386          397  -0.70249993E-05
         386          398   0.00000000E+00
         386          399   0.00000000E+00
         386          400   0.00000000E+00
         387          387   0.26723718E+04
         387          381   0.76117799E+02
         387          382  -0.21147957E+02
         387          383   0.00000000E+00
         387          384  -0.65878288E+02
         387          385  -0.63519108E+02
         387          386   0.19543478E+04
         387          388  -0.38887502E-04
         387          389  -0.12035985E+00
         387          390   0.49505150E-01
         387          371  -0.18229190E-06
         387          372   0.00000000E+00
         387          373   0.00000000E+00
         387          374   0.58149057E-08
         387          375   0.16475051E-09
         387          376  -0.46804005E-05
         387          377  -0.58937841E-05
         387          378   0.15713863E-13
         387          379   0.28826779E-09
         387          380  -0.11851393E-09
         387          391  -0.27360565E-06
         387          392   0.00000000E+00
         387          393   0.00000000E+00
         387          394   0.87277109E-08
         387          395   0.24727742E-09
         387          396  -0.70249088E-05
         387          397  -0.88461011E-05
         387          398   0.23585259E-13
         387          399   0.43266702E-09
         387          400  -0.17787999E-09
         388          388   0.66308262E-04
         388          381   0.00000000E+00
         388          382   0.00000000E+00
         388          383   0.00000000E+00
         388          384   0.00000000E+00
         388          385   0.00000000E+00
         388          386   0.00000000E+00
         388          387  -0.38896922E-04
         388          389  -0.14946245E-04
         388          390  -0.37051937E-04
         388          371   0.00000000E+00
         388          372   0.00000000E+00
         388          373   0.00000000E+00
         388          374   0.00000000E+00
         388          375   0.00000000E+00
         388          376   0.00000000E+00
         388          377   0.15715132E-13
         388          378  -0.23320539E-13
         388          379  -0.29226999E-14
         388          380   0.11296639E-13
         388          391   0.00000000E+00
         388          392   0.00000000E+00
         388          393   0.00000000E+00
         388          394   0.00000000E+00
         388          395   0.00000000E+00
         388          396   0.00000000E+00
         388          397   0.23587162E-13
         388          398  -0.35002274E-13
         388          399  -0.43867400E-14
         388          400   0.16955357E-13
         389          389   0.99356224E+02
         389          381   0.00000000E+00
         389          382   0.00000000E+00
         389          383   0.00000000E+00
         389          384   0.00000000E+00
         389          385   0.00000000E+00
         389          386   0.43198833E-04
         389          387  -0.12034781E+00
         389          388  -0.14942654E-04
         389          390   0.33536708E+02
         389          371   0.00000000E+00
         389          372   0.00000000E+00
         389          373   0.00000000E+00
         389          374   0.00000000E+00
         389          375   0.00000000E+00
         389          376   0.00000000E+00
         389          377   0.28823897E-09
         389          378  -0.29225903E-14
         389          379  -0.23794469E-06
         389          380  -0.80315889E-07
         389          391   0.00000000E+00
         389          392   0.00000000E+00
         389          393   0.00000000E+00
         389          394   0.00000000E+00
         389          395   0.00000000E+00
         389          396   0.00000000E+00
         389          397   0.43262376E-09
         389          398  -0.43865755E-14
         389          399  -0.35713606E-06
         389          400  -0.12054776E-06
         390          390   0.13484933E+05
         390          381   0.36307130E+04
         390          382   0.24834091E+03
         390          383   0.00000000E+00
         390          384   0.00000000E+00
         390          385   0.21795340E-05
         390          386   0.00000000E+00
         390          387   0.49505150E-01
         390          388  -0.37042339E-04
         390          389   0.33536708E+02
         390          371  -0.86950688E-05
         390          372  -0.59474313E-06
         390          373   0.00000000E+00
         390          374   0.00000000E+00
         390          375  -0.52196912E-14
         390          376   0.00000000E+00
         390          377  -0.11851393E-09
         390          378   0.11294945E-13
         390          379  -0.80315889E-07
         390          380  -0.32294601E-04
         390          391  -0.13050607E-04
         390          392  -0.89266212E-06
         390          393   0.00000000E+00
         390          394   0.00000000E+00
         390          395  -0.78343413E-14
         390          396   0.00000000E+00
         390          397  -0.17787999E-09
         390          398   0.16952814E-13
         390          399  -0.12054776E-06
         390          400  -0.48471627E-04
         391          391   0.97945219E+04
         391          392   0.00000000E+00
         391          393   0.00000000E+00
         391          394   0.00000000E+00
         391          395   0.00000000E+00
         391          396   0.79884210E+02
         391          397   0.76117799E+02
         391          398   0.00000000E+00
         391          399   0.00000000E+00
         391          400   0.36307130E+04
         391          381  -0.23456563E-04
         391          382   0.00000000E+00
         391          383   0.00000000E+00
         391          384   0.00000000E+00
         391          385   0.00000000E+00
         391          386  -0.19131143E-06
         391          387  -0.18229190E-06
         391          388   0.00000000E+00
         391          389   0.00000000E+00
         391          390  -0.86950688E-05
         391          401  -0.35206435E-04
         391          402   0.00000000E+00
         391          403   0.00000000E+00
         391          404   0.00000000E+00
         391          405   0.00000000E+00
         391          406  -0.28714324E-06
         391          407  -0.27360565E-06
         391          408   0.00000000E+00
         391          409   0.00000000E+00
         391          410  -0.13050607E-04
         392          392   0.61664984E+04
         392          391   0.00000000E+00
         392          393   0.00000000E+00
         392          394   0.63450217E+01
         392          395   0.63450217E+01
         392          396   0.00000000E+00
         392          397  -0.21136331E+02
         392          398   0.00000000E+00
         392          399   0.00000000E+00
         392          400   0.24834091E+03
         392          381   0.00000000E+00
         392          382  -0.14762871E-04
         392          383   0.00000000E+00
         392          384   0.00000000E+00
         392          385   0.00000000E+00
         392          386   0.00000000E+00
         392          387   0.00000000E+00
         392          388   0.00000000E+00
         392          389   0.00000000E+00
         392          390  -0.59474313E-06
         392          401   0.00000000E+00
         392          402  -0.22157895E-04
         392          403   0.00000000E+00
         392          404   0.00000000E+00
         392          405   0.00000000E+00
         392          406   0.00000000E+00
         392          407   0.00000000E+00
         392          408   0.00000000E+00
         392          409   0.00000000E+00
         392          410  -0.89266212E-06
         393          393   0.78082192E+03
         393          391   0.00000000E+00
         393          392   0.00000000E+00
         393          394   0.00000000E+00
         393          395   0.00000000E+00
         393          396   0.00000000E+00
         393          397   0.00000000E+00
         393          398   0.00000000E+00
         393          399   0.00000000E+00
         393          400   0.00000000E+00
         393          381   0.00000000E+00
         393          382   0.00000000E+00
         393          383  -0.18699636E-05
         393          384   0.00000000E+00
         393          385   0.00000000E+00
         393          386   0.00000000E+00
         393          387   0.00000000E+00
         393          388   0.00000000E+00
         393          389   0.00000000E+00
         393          390   0.00000000E+00
         393          401   0.00000000E+00
         393          402   0.00000000E+00
         393          403  -0.28066666E-05
         393          404   0.00000000E+00
         393          405   0.00000000E+00
         393          406   0.00000000E+00
         393          407   0.00000000E+00
         393          408   0.00000000E+00
         393          409   0.00000000E+00
         393          410   0.00000000E+00
         394          394   0.13409529E+04
         394          391   0.00000000E+00
         394          392   0.63443872E+01
         394          393   0.00000000E+00
         394          395   0.19035065E+02
         394          396   0.00000000E+00
         394          397  -0.65836821E+02
         394          398   0.00000000E+00
         394          399   0.00000000E+00
         394          400   0.00000000E+00
         394          381   0.00000000E+00
         394          382   0.00000000E+00
         394          383   0.00000000E+00
         394          384  -0.31658156E-05
         394          385   0.00000000E+00
         394          386   0.00000000E+00
         394          387   0.58143243E-08
         394          388   0.00000000E+00
         394          389   0.00000000E+00
         394          390   0.00000000E+00
         394          401   0.00000000E+00
         394          402   0.00000000E+00
         394          403   0.00000000E+00
         394          404  -0.47516374E-05
         394          405   0.00000000E+00
         394          406   0.00000000E+00
         394          407   0.87268382E-08
         394          408   0.00000000E+00
         394          409   0.00000000E+00
         394          410   0.00000000E+00
         395          395   0.19052837E+02
         395          391   0.00000000E+00
         395          392   0.63443872E+01
         395          393   0.00000000E+00
         395          394   0.19035065E+02
         395          396   0.00000000E+00
         395          397  -0.63477866E+02
         395          398   0.00000000E+00
         395          399   0.00000000E+00
         395          400   0.21795643E-05
         395          381   0.00000000E+00
         395          382   0.00000000E+00
         395          383   0.00000000E+00
         395          384   0.00000000E+00
         395          385  -0.42484263E-10
         395          386   0.00000000E+00
         395          387   0.16470995E-09
         395          388   0.00000000E+00
         395          389   0.00000000E+00
         395          390  -0.52197638E-14
         395          401   0.00000000E+00
         395          402   0.00000000E+00
         395          403   0.00000000E+00
         395          404   0.00000000E+00
         395          405  -0.63765499E-10
         395          406   0.00000000E+00
         395          407   0.24721653E-09
         395          408   0.00000000E+00
         395          409   0.00000000E+00
         395          410  -0.78344502E-14
         396          396   0.17074662E+04
         396          391   0.79884210E+02
         396          392   0.00000000E+00
         396          393   0.00000000E+00
         396          394   0.00000000E+00
         396          395   0.00000000E+00
         396          397   0.19543730E+04
         396          398   0.00000000E+00
         396          399   0.43198833E-04
         396          400   0.00000000E+00
         396          381  -0.19131143E-06
         396          382   0.00000000E+00
         396          383   0.00000000E+00
         396          384   0.00000000E+00
         396          385   0.00000000E+00
         396          386  -0.40891515E-05
         396          387  -0.46804608E-05
         396          388   0.00000000E+00
         396          389   0.00000000E+00
         396          390   0.00000000E+00
         396          401  -0.28714324E-06
         396          402   0.00000000E+00
         396          403   0.00000000E+00
         396          404   0.00000000E+00
         396          405   0.00000000E+00
         396          406  -0.61374911E-05
         396          407  -0.70249993E-05
         396          408   0.00000000E+00
         396          409   0.00000000E+00
         396          410   0.00000000E+00
         397          397   0.26723718E+04
         397          391   0.76117799E+02
         397          392  -0.21147957E+02
         397          393   0.00000000E+00
         397          394  -0.65878288E+02
         397          395  -0.63519108E+02
         397          396   0.19543478E+04
         397          398  -0.38887502E-04
         397          399  -0.12035985E+00
         397          400   0.49505150E-01
         397          381  -0.18229190E-06
         397          382   0.00000000E+00
         397          383   0.00000000E+00
         397          384   0.58149057E-08
         397          385   0.16475051E-09
         397          386  -0.46804005E-05
         397          387  -0.58937841E-05
         397          388   0.15713863E-13
         397          389   0.28826779E-09
         397          390  -0.11851393E-09
         397          401  -0.27360565E-06
         397          402   0.00000000E+00
         397          403   0.00000000E+00
         397          404   0.87277109E-08
         397          405   0.24727742E-09
         397          406  -0.70249088E-05
         397          407  -0.88461011E-05
         397          408   0.23585259E-13
         397          409   0.43266702E-09
         397          410  -0.17787999E-09
         398          398   0.66308262E-04
         398          391   0.00000000E+00
         398          392   0.00000000E+00
         398          393   0.00000000E+00
         398          394   0.00000000E+00
         398          395   0.00000000E+00
         398          396   0.00000000E+00
         398          397  -0.38896922E-04
         398          399  -0.14946245E-04
         398          400  -0.37051937E-04
         398          381   0.00000000E+00
         398          382   0.00000000E+00
         398          383   0.00000000E+00
         398          384   0.00000000E+00
         398          385   0.00000000E+00
         398          386   0.00000000E+00
         398          387   0.15715132E-13
         398          388  -0.23320539E-13
         398          389  -0.29226999E-14
         398          390   0.11296639E-13
         398          401   0.00000000E+00
         398          402   0.00000000E+00
         398          403   0.00000000E+00
         398          404   0.00000000E+00
         398          405   0.00000000E+00
         398          406   0.00000000E+00
         398          407   0.23587162E-13
         398          408  -0.35002274E-13
         398          409  -0.43867400E-14
         398          410   0.16955357E-13
         399          399   0.99356224E+02
         399          391   0.00000000E+00
         399          392   0.00000000E+00
         399          393   0.00000000E+00
         399          394   0.00000000E+00
         399          395   0.00000000E+00
         399          396   0.43198833E-04
         399          397  -0.12034781E+00
         399          398  -0.14942654E-04
         399          400   0.33536708E+02
         399          381   0.00000000E+00
         399          382   0.00000000E+00
         399          383   0.00000000E+00
         399          384   0.00000000E+00
         399          385   0.00000000E+00
         399          386   0.00000000E+00
         399          387   0.28823897E-09
         399          388  -0.29225903E-14
         399          389  -0.23794469E-06
         399          390  -0.80315889E-07
         399          401   0.00000000E+00
         399          402   0.00000000E+00
         399          403   0.00000000E+00
         399          404   0.00000000E+00
         399          405   0.00000000E+00
         399          406   0.00000000E+00
         399          407   0.43262376E-09
         399          408  -0.43865755E-14
         399          409  -0.35713606E-06
         399          410  -0.12054776E-06
         400          400   0.13484933E+05
         400          391   0.36307130E+04
         400          392   0.24834091E+03
         400          393   0.00000000E+00
         400          394   0.00000000E+00
         400          395   0.21795340E-05
         400          396   0.00000000E+00
         400          397   0.49505150E-01
         400          398  -0.37042339E-04
         400          399   0.33536708E+02
         400          381  -0.86950688E-05
         400          382  -0.59474313E-06
         400          383   0.00000000E+00
         400          384   0.00000000E+00
         400          385  -0.52196912E-14
         400          386   0.00000000E+00
         400          387  -0.11851393E-09
         400          388   0.11294945E-13
         400          389  -0.80315889E-07
         400          390  -0.32294601E-04
         400          401  -0.13050607E-04
         400          402  -0.89266212E-06
         400          403   0.00000000E+00
         400          404   0.00000000E+00
         400          405  -0.78343413E-14
         400          406   0.00000000E+00
         400          407  -0.17787999E-09
         400          408   0.16952814E-13
         400          409  -0.12054776E-06
         400          410  -0.48471627E-04
         401          401   0.97945219E+04
         401          402   0.00000000E+00
         401          403   0.00000000E+00
         401          404   0.00000000E+00
         401          405   0.00000000E+00
         401          406   0.79884210E+02
         401          407   0.76117799E+02
         401          408   0.00000000E+00
         401          409   0.00000000E+00
         401          410   0.36307130E+04
         401          391  -0.23456563E-04
         401          392   0.00000000E+00
         401          393   0.00000000E+00
         401          394   0.00000000E+00
         401          395   0.00000000E+00
         401          396  -0.19131143E-06
         401          397  -0.18229190E-06
         401          398   0.00000000E+00
         401          399   0.00000000E+00
         401          400  -0.86950688E-05
         401          411  -0.35206435E-04
         401          412   0.00000000E+00
         401          413   0.00000000E+00
         401          414   0.00000000E+00
         401          415   0.00000000E+00
         401          416  -0.28714324E-06
         401          417  -0.27360565E-06
         401          418   0.00000000E+00
         401          419   0.00000000E+00
         401          420  -0.13050607E-04
         402          402   0.61664984E+04
         402          401   0.00000000E+00
         402          403   0.00000000E+00
         402          404   0.63450217E+01
         402          405   0.63450217E+01
         402          406   0.00000000E+00
         402          407  -0.21136331E+02
         402          408   0.00000000E+00
         402          409   0.00000000E+00
         402          410   0.24834091E+03
         402          391   0.00000000E+00
         402          392  -0.14762871E-04
         402          393   0.00000000E+00
         402          394   0.00000000E+00
         402          395   0.00000000E+00
         402          396   0.00000000E+00
         402          397   0.00000000E+00
         402          398   0.00000000E+00
         402          399   0.00000000E+00
         402          400  -0.59474313E-06
         402          411   0.00000000E+00
         402          412  -0.22157895E-04
         402          413   0.00000000E+00
         402          414   0.00000000E+00
         402          415   0.00000000E+00
         402          416   0.00000000E+00
         402          417   0.00000000E+00
         402          418   0.00000000E+00
         402          419   0.00000000E+00
         402          420  -0.89266212E-06
         403          403   0.78082192E+03
         403          401   0.00000000E+00
         403          402   0.00000000E+00
         403          404   0.00000000E+00
         403          405   0.00000000E+00
         403          406   0.00000000E+00
         403          407   0.00000000E+00
         403          408   0.00000000E+00
         403          409   0.00000000E+00
         403          410   0.00000000E+00
         403          391   0.00000000E+00
         403          392   0.00000000E+00
         403          393  -0.18699636E-05
         403          394   0.00000000E+00
         403          395   0.00000000E+00
         403          396   0.00000000E+00
         403          397   0.00000000E+00
         403          398   0.00000000E+00
         403          399   0.00000000E+00
         403          400   0.00000000E+00
         403          411   0.00000000E+00
         403          412   0.00000000E+00
         403          413  -0.28066666E-05
         403          414   0.00000000E+00
         403          415   0.00000000E+00
         403          416   0.00000000E+00
         403          417   0.00000000E+00
         403          418   0.00000000E+00
         403          419   0.00000000E+00
         403          420   0.00000000E+00
         404          404   0.13409529E+04
         404          401   0.00000000E+00
         404          402   0.63443872E+01
         404          403   0.00000000E+00
         404          405   0.19035065E+02
         404          406   0.00000000E+00
         404          407  -0.65836821E+02
         404          408   0.00000000E+00
         404          409   0.00000000E+00
         404          410   0.00000000E+00
         404          391   0.00000000E+00
         404          392   0.00000000E+00
         404          393   0.00000000E+00
         404          394  -0.31658156E-05
         404          395   0.00000000E+00
         404          396   0.00000000E+00
         404          397   0.58143243E-08
         404          398   0.00000000E+00
         404          399   0.00000000E+00
         404          400   0.00000000E+00
         404          411   0.00000000E+00
         404          412   0.00000000E+00
         404          413   0.00000000E+00
         404          414  -0.47516374E-05
         404          415   0.00000000E+00
         404          416   0.00000000E+00
         404          417   0.87268382E-08
         404          418   0.00000000E+00
         404          419   0.00000000E+00
         404          420   0.00000000E+00
         405          405   0.19052837E+02
         405          401   0.00000000E+00
         405          402   0.63443872E+01
         405          403   0.00000000E+00
         405          404   0.19035065E+02
         405          406   0.00000000E+00
         405          407  -0.63477866E+02
         405          408   0.00000000E+00
         405          409   0.00000000E+00
         405          410   0.21795643E-05
         405          391   0.00000000E+00
         405          392   0.00000000E+00
         405          393   0.00000000E+00
         405          394   0.00000000E+00
         405          395  -0.42484263E-10
         405          396   0.00000000E+00
         405          397   0.16470995E-09
         405          398   0.00000000E+00
         405          399   0.00000000E+00
         405          400  -0.52197638E-14
         405          411   0.00000000E+00
         405          412   0.00000000E+00
         405          413   0.00000000E+00
         405          414   0.00000000E+00
         405          415  -0.63765499E-10
         405          416   0.00000000E+00
         405          417   0.24721653E-09
         405          418   0.00000000E+00
         405          419   0.00000000E+00
         405          420  -0.78344502E-14
         406          406   0.17074662E+04
         406          401   0.79884210E+02
         406          402   0.00000000E+00
         406          403   0.00000000E+00
         406          404   0.00000000E+00
         406          405   0.00000000E+00
         406          407   0.19543730E+04
         406          408   0.00000000E+00
         406          409   0.43198833E-04
         406          410   0.00000000E+00
         406          391  -0.19131143E-06
         406          392   0.00000000E+00
         406          393   0.00000000E+00
         406          394   0.00000000E+00
         406          395   0.00000000E+00
         406          396  -0.40891515E-05
         406          397  -0.46804608E-05
         406          398   0.00000000E+00
         406          399   0.00000000E+00
         406          400   0.00000000E+00
         406          411  -0.28714324E-06
         406          412   0.00000000E+00
         406          413   0.00000000E+00
         406          414   0.00000000E+00
         406          415   0.00000000E+00
         406          416  -0.61374911E-05
         406          417  -0.70249993E-05
         406          418   0.00000000E+00
         406          419   0.00000000E+00
         406          420   0.00000000E+00
         407          407   0.26723718E+04
         407          401   0.76117799E+02
         407          402  -0.21147957E+02
         407          403   0.00000000E+00
         407          404  -0.65878288E+02
         407          405  -0.63519108E+02
         407          406   0.19543478E+04
         407          408  -0.38887502E-04
         407          409  -0.12035985E+00
         407          410   0.49505150E-01
         407          391  -0.18229190E-06
         407          392   0.00000000E+00
         407          393   0.00000000E+00
         407          394   0.58149057E-08
         407          395   0.16475051E-09
         407          396  -0.46804005E-05
         407          397  -0.58937841E-05
         407          398   0.15713863E-13
         407          399   0.28826779E-09
         407          400  -0.11851393E-09
         407          411  -0.27360565E-06
         407          412   0.00000000E+00
         407          413   0.00000000E+00
         407          414   0.87277109E-08
         407          415   0.24727742E-09
         407          416  -0.70249088E-05
         407          417  -0.88461011E-05
         407          418   0.23585259E-13
         407          419   0.43266702E-09
         407          420  -0.17787999E-09
         408          408   0.66308262E-04
         408          401   0.00000000E+00
         408          402   0.00000000E+00
         408          403   0.00000000E+00
         408          404   0.00000000E+00
         408          405   0.00000000E+00
         408          406   0.00000000E+00
         408          407  -0.38896922E-04
         408          409  -0.14946245E-04
         408          410  -0.37051937E-04
         408          391   0.00000000E+00
         408          392   0.00000000E+00
         408          393   0.00000000E+00
         408          394   0.00000000E+00
         408          395   0.00000000E+00
         408          396   0.00000000E+00
         408          397   0.15715132E-13
         408          398  -0.23320539E-13
         408          399  -0.29226999E-14
         408          400   0.11296639E-13
         408          411   0.00000000E+00
         408          412   0.00000000E+00
         408          413   0.00000000E+00
         408          414   0.00000000E+00
         408          415   0.00000000E+00
         408          416   0.00000000E+00
         408          417   0.23587162E-13
         408          418  -0.35002274E-13
         408          419  -0.43867400E-14
         408          420   0.16955357E-13
         409          409   0.99356224E+02
         409          401   0.00000000E+00
         409          402   0.00000000E+00
         409          403   0.00000000E+00
         409          404   0.00000000E+00
         409          405   0.00000000E+00
         409          406   0.43198833E-04
         409          407  -0.12034781E+00
         409          408  -0.14942654E-04
         409          410   0.33536708E+02
         409          391   0.00000000E+00
         409          392   0.00000000E+00
         409          393   0.00000000E+00
         409          394   0.00000000E+00
         409          395   0.00000000E+00
         409          396   0.00000000E+00
         409          397   0.28823897E-09
         409          398  -0.29225903E-14
         409          399  -0.23794469E-06
         409          400  -0.80315889E-07
         409          411   0.00000000E+00
         409          412   0.00000000E+00
         409          413   0.00000000E+00
         409          414   0.00000000E+00
         409          415   0.00000000E+00
         409          416   0.00000000E+00
         409          417   0.43262376E-09
         409          418  -0.43865755E-14
         409          419  -0.35713606E-06
         409          420  -0.12054776E-06
         410          410   0.13484933E+05
         410          401   0.36307130E+04
         410          402   0.24834091E+03
         410          403   0.00000000E+00
         410          404   0.00000000E+00
         410          405   0.21795340E-05
         410          406   0.00000000E+00
         410          407   0.49505150E-01
         410          408  -0.37042339E-04
         410          409   0.33536708E+02
         410          391  -0.86950688E-05
         410          392  -0.59474313E-06
         410          393   0.00000000E+00
         410          394   0.00000000E+00
         410          395  -0.52196912E-14
         410          396   0.00000000E+00
         410          397  -0.11851393E-09
         410          398   0.11294945E-13
         410          399  -0.80315889E-07
         410          400  -0.32294601E-04
         410          411  -0.13050607E-04
         410          412  -0.89266212E-06
         410          413   0.00000000E+00
         410          414   0.00000000E+00
         410          415  -0.78343413E-14
         410          416   0.00000000E+00
         410          417  -0.17787999E-09
         410          418   0.16952814E-13
         410          419  -0.12054776E-06
         410          420  -0.48471627E-04
         411          411   0.97945219E+04
         411          412   0.00000000E+00
         411          413   0.00000000E+00
         411          414   0.00000000E+00
         411          415   0.00000000E+00
         411          416   0.79884210E+02
         411          417   0.76117799E+02
         411          418   0.00000000E+00
         411          419   0.00000000E+00
         411          420   0.36307130E+04
         411          401  -0.23456563E-04
         411          402   0.00000000E+00
         411          403   0.00000000E+00
         411          404   0.00000000E+00
         411          405   0.00000000E+00
         411          406  -0.19131143E-06
         411          407  -0.18229190E-06
         411          408   0.00000000E+00
         411          409   0.00000000E+00
         411          410  -0.86950688E-05
         411          421  -0.35206435E-04
         411          422   0.00000000E+00
         411          423   0.00000000E+00
         411          424   0.00000000E+00
         411          425   0.00000000E+00
         411          426  -0.28714324E-06
         411          427  -0.27360565E-06
         411          428   0.00000000E+00
         411          429   0.00000000E+00
         411          430  -0.13050607E-04
         412          412   0.61664984E+04
         412          411   0.00000000E+00
         412          413   0.00000000E+00
         412          414   0.63450217E+01
         412          415   0.63450217E+01
         412          416   0.00000000E+00
         412          417  -0.21136331E+02
         412          418   0.00000000E+00
         412          419   0.00000000E+00
         412          420   0.24834091E+03
         412          401   0.00000000E+00
         412          402  -0.14762871E-04
         412          403   0.00000000E+00
         412          404   0.00000000E+00
         412          405   0.00000000E+00
         412          406   0.00000000E+00
         412          407   0.00000000E+00
         412          408   0.00000000E+00
         412          409   0.00000000E+00
         412          410  -0.59474313E-06
         412          421   0.00000000E+00
         412          422  -0.22157895E-04
         412          423   0.00000000E+00
         412          424   0.00000000E+00
         412          425   0.00000000E+00
         412          426   0.00000000E+00
         412          427   0.00000000E+00
         412          428   0.00000000E+00
         412          429   0.00000000E+00
         412          430  -0.89266212E-06
         413          413   0.78082192E+03
         413          411   0.00000000E+00
         413          412   0.00000000E+00
         413          414   0.00000000E+00
         413          415   0.00000000E+00
         413          416   0.00000000E+00
         413          417   0.00000000E+00
         413          418   0.00000000E+00
         413          419   0.00000000E+00
         413          420   0.00000000E+00
         413          401   0.00000000E+00
         413          402   0.00000000E+00
         413          403  -0.18699636E-05
         413          404   0.00000000E+00
         413          405   0.00000000E+00
         413          406   0.00000000E+00
         413          407   0.00000000E+00
         413          408   0.00000000E+00
         413          409   0.00000000E+00
         413          410   0.00000000E+00
         413          421   0.00000000E+00
         413          422   0.00000000E+00
         413          423  -0.28066666E-05
         413          424   0.00000000E+00
         413          425   0.00000000E+00
         413          426   0.00000000E+00
         413          427   0.00000000E+00
         413          428   0.00000000E+00
         413          429   0.00000000E+00
         413          430   0.00000000E+00
         414          414   0.13409529E+04
         414          411   0.00000000E+00
         414          412   0.63443872E+01
         414          413   0.00000000E+00
         414          415   0.19035065E+02
         414          416   0.00000000E+00
         414          417  -0.65836821E+02
         414          418   0.00000000E+00
         414          419   0.00000000E+00
         414          420   0.00000000E+00
         414          401   0.00000000E+00
         414          402   0.00000000E+00
         414          403   0.00000000E+00
         414          404  -0.31658156E-05
         414          405   0.00000000E+00
         414          406   0.00000000E+00
         414          407   0.58143243E-08
         414          408   0.00000000E+00
         414          409   0.00000000E+00
         414          410   0.00000000E+00
         414          421   0.00000000E+00
         414          422   0.00000000E+00
         414          423   0.00000000E+00
         414          424  -0.47516374E-05
         414          425   0.00000000E+00
         414          426   0.00000000E+00
         414          427   0.87268382E-08
         414          428   0.00000000E+00
         414          429   0.00000000E+00
         414          430   0.00000000E+00
         415          415   0.19052837E+02
         415          411   0.00000000E+00
         415          412   0.63443872E+01
         415          413   0.00000000E+00
         415          414   0.19035065E+02
         415          416   0.00000000E+00
         415          417  -0.63477866E+02
         415          418   0.00000000E+00
         415          419   0.00000000E+00
         415          420   0.21795643E-05
         415          401   0.00000000E+00
         415          402   0.00000000E+00
         415          403   0.00000000E+00
         415          404   0.00000000E+00
         415          405  -0.42484263E-10
         415          406   0.00000000E+00
         415          407   0.16470995E-09
         415          408   0.00000000E+00
         415          409   0.00000000E+00
         415          410  -0.52197638E-14
         415          421   0.00000000E+00
         415          422   0.00000000E+00
         415          423   0.00000000E+00
         415          424   0.00000000E+00
         415          425  -0.63765499E-10
         415          426   0.00000000E+00
         415          427   0.24721653E-09
         415          428   0.00000000E+00
         415          429   0.00000000E+00
         415          430  -0.78344502E-14
         416          416   0.17074662E+04
         416          411   0.79884210E+02
         416          412   0.00000000E+00
         416          413   0.00000000E+00
         416          414   0.00000000E+00
         416          415   0.00000000E+00
         416          417   0.19543730E+04
         416          418   0.00000000E+00
         416          419   0.43198833E-04
         416          420   0.00000000E+00
         416          401  -0.19131143E-06
         416          402   0.00000000E+00
         416          403   0.00000000E+00
         416          404   0.00000000E+00
         416          405   0.00000000E+00
         416          406  -0.40891515E-05
         416          407  -0.46804608E-05
         416          408   0.00000000E+00
         416          409   0.00000000E+00
         416          410   0.00000000E+00
         416          421  -0.28714324E-06
         416          422   0.00000000E+00
         416          423   0.00000000E+00
         416          424   0.00000000E+00
         416          425   0.00000000E+00
         416          426  -0.61374911E-05
         416          427  -0.70249993E-05
         416          428   0.00000000E+00
         416          429   0.00000000E+00
         416          430   0.00000000E+00
         417          417   0.26723718E+04
         417          411   0.76117799E+02
         417          412  -0.21147957E+02
         417          413   0.00000000E+00
         417          414  -0.65878288E+02
         417          415  -0.63519108E+02
         417          416   0.19543478E+04
         417          418  -0.38887502E-04
         417          419  -0.12035985E+00
         417          420   0.49505150E-01
         417          401  -0.18229190E-06
         417          402   0.00000000E+00
         417          403   0.00000000E+00
         417          404   0.58149057E-08
         417          405   0.16475051E-09
         417          406  -0.46804005E-05
         417          407  -0.58937841E-05
         417          408   0.15713863E-13
         417          409   0.28826779E-09
         417          410  -0.11851393E-09
         417          421  -0.27360565E-06
         417          422   0.00000000E+00
         417          423   0.00000000E+00
         417          424   0.87277109E-08
         417          425   0.24727742E-09
         417          426  -0.70249088E-05
         417          427  -0.88461011E-05
         417          428   0.23585259E-13
         417          429   0.43266702E-09
         417          430  -0.17787999E-09
         418          418   0.66308262E-04
         418          411   0.00000000E+00
         418          412   0.00000000E+00
         418          413   0.00000000E+00
         418          414   0.00000000E+00
         418          415   0.00000000E+00
         418          416   0.00000000E+00
         418          417  -0.38896922E-04
         418          419  -0.14946245E-04
         418          420  -0.37051937E-04
         418          401   0.00000000E+00
         418          402   0.00000000E+00
         418          403   0.00000000E+00
         418          404   0.00000000E+00
         418          405   0.00000000E+00
         418          406   0.00000000E+00
         418          407   0.15715132E-13
         418          408  -0.23320539E-13
         418          409  -0.29226999E-14
         418          410   0.11296639E-13
         418          421   0.00000000E+00
         418          422   0.00000000E+00
         418          423   0.00000000E+00
         418          424   0.00000000E+00
         418          425   0.00000000E+00
         418          426   0.00000000E+00
         418          427   0.23587162E-13
         418          428  -0.35002274E-13
         418          429  -0.43867400E-14
         418          430   0.16955357E-13
         419          419   0.99356224E+02
         419          411   0.00000000E+00
         419          412   0.00000000E+00
         419          413   0.00000000E+00
         419          414   0.00000000E+00
         419          415   0.00000000E+00
         419          416   0.43198833E-04
         419          417  -0.12034781E+00
         419          418  -0.14942654E-04
         419          420   0.33536708E+02
         419          401   0.00000000E+00
         419          402   0.00000000E+00
         419          403   0.00000000E+00
         419          404   0.00000000E+00
         419          405   0.00000000E+00
         419          406   0.00000000E+00
         419          407   0.28823897E-09
         419          408  -0.29225903E-14
         419          409  -0.23794469E-06
         419          410  -0.80315889E-07
         419          421   0.00000000E+00
         419          422   0.00000000E+00
         419          423   0.00000000E+00
         419          424   0.00000000E+00
         419          425   0.00000000E+00
         419          426   0.00000000E+00
         419          427   0.43262376E-09
         419          428  -0.43865755E-14
         419          429  -0.35713606E-06
         419          430  -0.12054776E-06
         420          420   0.13484933E+05
         420          411   0.36307130E+04
         420          412   0.24834091E+03
         420          413   0.00000000E+00
         420          414   0.00000000E+00
         420          415   0.21795340E-05
         420          416   0.00000000E+00
         420          417   0.49505150E-01
         420          418  -0.37042339E-04
         420          419   0.33536708E+02
         420          401  -0.86950688E-05
         420          402  -0.59474313E-06
         420          403   0.00000000E+00
         420          404   0.00000000E+00
         420          405  -0.52196912E-14
         420          406   0.00000000E+00
         420          407  -0.11851393E-09
         420          408   0.11294945E-13
         420          409  -0.80315889E-07
         420          410  -0.32294601E-04
         420          421  -0.13050607E-04
         420          422  -0.89266212E-06
         420          423   0.00000000E+00
         420          424   0.00000000E+00
         420          425  -0.78343413E-14
         420          426   0.00000000E+00
         420          427  -0.17787999E-09
         420          428   0.16952814E-13
         420          429  -0.12054776E-06
         420          430  -0.48471627E-04
         421          421   0.97945219E+04
         421          422   0.00000000E+00
         421          423   0.00000000E+00
         421          424   0.00000000E+00
         421          425   0.00000000E+00
         421          426   0.79884210E+02
         421          427   0.76117799E+02
         421          428   0.00000000E+00
         421          429   0.00000000E+00
         421          430   0.36307130E+04
         421          411  -0.23456563E-04
         421          412   0.00000000E+00
         421          413   0.00000000E+00
         421          414   0.00000000E+00
         421          415   0.00000000E+00
         421          416  -0.19131143E-06
         421          417  -0.18229190E-06
         421          418   0.00000000E+00
         421          419   0.00000000E+00
         421          420  -0.86950688E-05
         421          431  -0.35206435E-04
         421          432   0.00000000E+00
         421          433   0.00000000E+00
         421          434   0.00000000E+00
         421          435   0.00000000E+00
         421          436  -0.28714324E-06
         421          437  -0.27360565E-06
         421          438   0.00000000E+00
         421          439   0.00000000E+00
         421          440  -0.13050607E-04
         422          422   0.61664984E+04
         422          421   0.00000000E+00
         422          423   0.00000000E+00
         422          424   0.63450217E+01
         422          425   0.63450217E+01
         422          426   0.00000000E+00
         422          427  -0.21136331E+02
         422          428   0.00000000E+00
         422          429   0.00000000E+00
         422          430   0.24834091E+03
         422          411   0.00000000E+00
         422          412  -0.14762871E-04
         422          413   0.00000000E+00
         422          414   0.00000000E+00
         422          415   0.00000000E+00
         422          416   0.00000000E+00
         422          417   0.00000000E+00
         422          418   0.00000000E+00
         422          419   0.00000000E+00
         422          420  -0.59474313E-06
         422          431   0.00000000E+00
         422          432  -0.22157895E-04
         422          433   0.00000000E+00
         422          434   0.00000000E+00
         422          435   0.00000000E+00
         422          436   0.00000000E+00
         422          437   0.00000000E+00
         422          438   0.00000000E+00
         422          439   0.00000000E+00
         422          440  -0.89266212E-06
         423          423   0.78082192E+03
         423          421   0.00000000E+00
         423          422   0.00000000E+00
         423          424   0.00000000E+00
         423          425   0.00000000E+00
         423          426   0.00000000E+00
         423          427   0.00000000E+00
         423          428   0.00000000E+00
         423          429   0.00000000E+00
         423          430   0.00000000E+00
         423          411   0.00000000E+00
         423          412   0.00000000E+00
         423          413  -0.18699636E-05
         423          414   0.00000000E+00
         423          415   0.00000000E+00
         423          416   0.00000000E+00
         423          417   0.00000000E+00
         423          418   0.00000000E+00
         423          419   0.00000000E+00
         423          420   0.00000000E+00
         423          431   0.00000000E+00
         423          432   0.00000000E+00
         423          433  -0.28066666E-05
         423          434   0.00000000E+00
         423          435   0.00000000E+00
         423          436   0.00000000E+00
         423          437   0.00000000E+00
         423          438   0.00000000E+00
         423          439   0.00000000E+00
         423          440   0.00000000E+00
         424          424   0.13409529E+04
         424          421   0.00000000E+00
         424          422   0.63443872E+01
         424          423   0.00000000E+00
         424          425   0.19035065E+02
         424          426   0.00000000E+00
         424          427  -0.65836821E+02
         424          428   0.00000000E+00
         424          429   0.00000000E+00
         424          430   0.00000000E+00
         424          411   0.00000000E+00
         424          412   0.00000000E+00
         424          413   0.00000000E+00
         424          414  -0.31658156E-05
         424          415   0.00000000E+00
         424          416   0.00000000E+00
         424          417   0.58143243E-08
         424          418   0.00000000E+00
         424          419   0.00000000E+00
         424          420   0.00000000E+00
         424          431   0.00000000E+00
         424          432   0.00000000E+00
         424          433   0.00000000E+00
         424          434  -0.47516374E-05
         424          435   0.00000000E+00
         424          436   0.00000000E+00
         424          437   0.87268382E-08
         424          438   0.00000000E+00
         424          439   0.00000000E+00
         424          440   0.00000000E+00
         425          425   0.19052837E+02
         425          421   0.00000000E+00
         425          422   0.63443872E+01
         425          423   0.00000000E+00
         425          424   0.19035065E+02
         425          426   0.00000000E+00
         425          427  -0.63477866E+02
         425          428   0.00000000E+00
         425          429   0.00000000E+00
         425          430   0.21795643E-05
         425          411   0.00000000E+00
         425          412   0.00000000E+00
         425          413   0.00000000E+00
         425          414   0.00000000E+00
         425          415  -0.42484263E-10
         425          416   0.00000000E+00
         425          417   0.16470995E-09
         425          418   0.00000000E+00
         425          419   0.00000000E+00
         425          420  -0.52197638E-14
         425          431   0.00000000E+00
         425          432   0.00000000E+00
         425          433   0.00000000E+00
         425          434   0.00000000E+00
         425          435  -0.63765499E-10
         425          436   0.00000000E+00
         425          437   0.24721653E-09
         425          438   0.00000000E+00
         425          439   0.00000000E+00
         425          440  -0.78344502E-14
         426          426   0.17074662E+04
         426          421   0.79884210E+02
         426          422   0.00000000E+00
         426          423   0.00000000E+00
         426          424   0.00000000E+00
         426          425   0.00000000E+00
         426          427   0.19543730E+04
         426          428   0.00000000E+00
         426          429   0.43198833E-04
         426          430   0.00000000E+00
         426          411  -0.19131143E-06
         426          412   0.00000000E+00
         426          413   0.00000000E+00
         426          414   0.00000000E+00
         426          415   0.00000000E+00
         426          416  -0.40891515E-05
         426          417  -0.46804608E-05
         426          418   0.00000000E+00
         426          419   0.00000000E+00
         426          420   0.00000000E+00
         426          431  -0.28714324E-06
         426          432   0.00000000E+00
         426          433   0.00000000E+00
         426          434   0.00000000E+00
         426          435   0.00000000E+00
         426          436  -0.61374911E-05
         426          437  -0.70249993E-05
         426          438   0.00000000E+00
         426          439   0.00000000E+00
         426          440   0.00000000E+00
         427          427   0.26723718E+04
         427          421   0.76117799E+02
         427          422  -0.21147957E+02
         427          423   0.00000000E+00
         427          424  -0.65878288E+02
         427          425  -0.63519108E+02
         427          426   0.19543478E+04
         427          428  -0.38887502E-04
         427          429  -0.12035985E+00
         427          430   0.49505150E-01
         427          411  -0.18229190E-06
         427          412   0.00000000E+00
         427          413   0.00000000E+00
         427          414   0.58149057E-08
         427          415   0.16475051E-09
         427          416  -0.46804005E-05
         427          417  -0.58937841E-05
         427          418   0.15713863E-13
         427          419   0.28826779E-09
         427          420  -0.11851393E-09
         427          431  -0.27360565E-06
         427          432   0.00000000E+00
         427          433   0.00000000E+00
         427          434   0.87277109E-08
         427          435   0.24727742E-09
         427          436  -0.70249088E-05
         427          437  -0.88461011E-05
         427          438   0.23585259E-13
         427          439   0.43266702E-09
         427          440  -0.17787999E-09
         428          428   0.66308262E-04
         428          421   0.00000000E+00
         428          422   0.00000000E+00
         428          423   0.00000000E+00
         428          424   0.00000000E+00
         428          425   0.00000000E+00
         428          426   0.00000000E+00
         428          427  -0.38896922E-04
         428          429  -0.14946245E-04
         428          430  -0.37051937E-04
         428          411   0.00000000E+00
         428          412   0.00000000E+00
         428          413   0.00000000E+00
         428          414   0.00000000E+00
         428          415   0.00000000E+00
         428          416   0.00000000E+00
         428          417   0.15715132E-13
         428          418  -0.23320539E-13
         428          419  -0.29226999E-14
         428          420   0.11296639E-13
         428          431   0.00000000E+00
         428          432   0.00000000E+00
         428          433   0.00000000E+00
         428          434   0.00000000E+00
         428          435   0.00000000E+00
         428          436   0.00000000E+00
         428          437   0.23587162E-13
         428          438  -0.35002274E-13
         428          439  -0.43867400E-14
         428          440   0.16955357E-13
         429          429   0.99356224E+02
         429          421   0.00000000E+00
         429          422   0.00000000E+00
         429          423   0.00000000E+00
         429          424   0.00000000E+00
         429          425   0.00000000E+00
         429          426   0.43198833E-04
         429          427  -0.12034781E+00
         429          428  -0.14942654E-04
         429          430   0.33536708E+02
         429          411   0.00000000E+00
         429          412   0.00000000E+00
         429          413   0.00000000E+00
         429          414   0.00000000E+00
         429          415   0.00000000E+00
         429          416   0.00000000E+00
         429          417   0.28823897E-09
         429          418  -0.29225903E-14
         429          419  -0.23794469E-06
         429          420  -0.80315889E-07
         429          431   0.00000000E+00
         429          432   0.00000000E+00
         429          433   0.00000000E+00
         429          434   0.00000000E+00
         429          435   0.00000000E+00
         429          436   0.00000000E+00
         429          437   0.43262376E-09
         429          438  -0.43865755E-14
         429          439  -0.35713606E-06
         429          440  -0.12054776E-06
         430          430   0.13484933E+05
         430          421   0.36307130E+04
         430          422   0.24834091E+03
         430          423   0.00000000E+00
         430          424   0.00000000E+00
         430          425   0.21795340E-05
         430          426   0.00000000E+00
         430          427   0.49505150E-01
         430          428  -0.37042339E-04
         430          429   0.33536708E+02
         430          411  -0.86950688E-05
         430          412  -0.59474313E-06
         430          413   0.00000000E+00
         430          414   0.00000000E+00
         430          415  -0.52196912E-14
         430          416   0.00000000E+00
         430          417  -0.11851393E-09
         430          418   0.11294945E-13
         430          419  -0.80315889E-07
         430          420  -0.32294601E-04
         430          431  -0.13050607E-04
         430          432  -0.89266212E-06
         430          433   0.00000000E+00
         430          434   0.00000000E+00
         430          435  -0.78343413E-14
         430          436   0.00000000E+00
         430          437  -0.17787999E-09
         430          438   0.16952814E-13
         430          439  -0.12054776E-06
         430          440  -0.48471627E-04
         431          431   0.97945219E+04
         431          432   0.00000000E+00
         431          433   0.00000000E+00
         431          434   0.00000000E+00
         431          435   0.00000000E+00
         431          436   0.79884210E+02
         431          437   0.76117799E+02
         431          438   0.00000000E+00
         431          439   0.00000000E+00
         431          440   0.36307130E+04
         431          421  -0.23456563E-04
         431          422   0.00000000E+00
         431          423   0.00000000E+00
         431          424   0.00000000E+00
         431          425   0.00000000E+00
         431          426  -0.19131143E-06
         431          427  -0.18229190E-06
         431          428   0.00000000E+00
         431          429   0.00000000E+00
         431          430  -0.86950688E-05
         431          441  -0.35206435E-04
         431          442   0.00000000E+00
         431          443   0.00000000E+00
         431          444   0.00000000E+00
         431          445   0.00000000E+00
         431          446  -0.28714324E-06
         431          447  -0.27360565E-06
         431          448   0.00000000E+00
         431          449   0.00000000E+00
         431          450  -0.13050607E-04
         432          432   0.61664984E+04
         432          431   0.00000000E+00
         432          433   0.00000000E+00
         432          434   0.63450217E+01
         432          435   0.63450217E+01
         432          436   0.00000000E+00
         432          437  -0.21136331E+02
         432          438   0.00000000E+00
         432          439   0.00000000E+00
         432          440   0.24834091E+03
         432          421   0.00000000E+00
         432          422  -0.14762871E-04
         432          423   0.00000000E+00
         432          424   0.00000000E+00
         432          425   0.00000000E+00
         432          426   0.00000000E+00
         432          427   0.00000000E+00
         432          428   0.00000000E+00
         432          429   0.00000000E+00
         432          430  -0.59474313E-06
         432          441   0.00000000E+00
         432          442  -0.22157895E-04
         432          443   0.00000000E+00
         432          444   0.00000000E+00
         432          445   0.00000000E+00
         432          446   0.00000000E+00
         432          447   0.00000000E+00
         432          448   0.00000000E+00
         432          449   0.00000000E+00
         432          450  -0.89266212E-06
         433          433   0.78082192E+03
         433          431   0.00000000E+00
         433          432   0.00000000E+00
         433          434   0.00000000E+00
         433          435   0.00000000E+00
         433          436   0.00000000E+00
         433          437   0.00000000E+00
         433          438   0.00000000E+00
         433          439   0.00000000E+00
         433          440   0.00000000E+00
         433          421   0.00000000E+00
         433          422   0.00000000E+00
         433          423  -0.18699636E-05
         433          424   0.00000000E+00
         433          425   0.00000000E+00
         433          426   0.00000000E+00
         433          427   0.00000000E+00
         433          428   0.00000000E+00
         433          429   0.00000000E+00
         433          430   0.00000000E+00
         433          441   0.00000000E+00
         433          442   0.00000000E+00
         433          443  -0.28066666E-05
         433          444   0.00000000E+00
         433          445   0.00000000E+00
         433          446   0.00000000E+00
         433          447   0.00000000E+00
         433          448   0.00000000E+00
         433          449   0.00000000E+00
         433          450   0.00000000E+00
         434          434   0.13409529E+04
         434          431   0.00000000E+00
         434          432   0.63443872E+01
         434          433   0.00000000E+00
         434          435   0.19035065E+02
         434          436   0.00000000E+00
         434          437  -0.65836821E+02
         434          438   0.00000000E+00
         434          439   0.00000000E+00
         434          440   0.00000000E+00
         434          421   0.00000000E+00
         434          422   0.00000000E+00
         434          423   0.00000000E+00
         434          424  -0.31658156E-05
         434          425   0.00000000E+00
         434          426   0.00000000E+00
         434          427   0.58143243E-08
         434          428   0.00000000E+00
         434          429   0.00000000E+00
         434          430   0.00000000E+00
         434          441   0.00000000E+00
         434          442   0.00000000E+00
         434          443   0.00000000E+00
         434          444  -0.47516374E-05
         434          445   0.00000000E+00
         434          446   0.00000000E+00
         434          447   0.87268382E-08
         434          448   0.00000000E+00
         434          449   0.00000000E+00
         434          450   0.00000000E+00
         435          435   0.19052837E+02
         435          431   0.00000000E+00
         435          432   0.63443872E+01
         435          433   0.00000000E+00
         435          434   0.19035065E+02
         435          436   0.00000000E+00
         435          437  -0.63477866E+02
         435          438   0.00000000E+00
         435          439   0.00000000E+00
         435          440   0.21795643E-05
         435          421   0.00000000E+00
         435          422   0.00000000E+00
         435          423   0.00000000E+00
         435          424   0.00000000E+00
         435          425  -0.42484263E-10
         435          426   0.00000000E+00
         435          427   0.16470995E-09
         435          428   0.00000000E+00
         435          429   0.00000000E+00
         435          430  -0.52197638E-14
         435          441   0.00000000E+00
         435          442   0.00000000E+00
         435          443   0.00000000E+00
         435          444   0.00000000E+00
         435          445  -0.63765499E-10
         435          446   0.00000000E+00
         435          447   0.24721653E-09
         435          448   0.00000000E+00
         435          449   0.00000000E+00
         435          450  -0.78344502E-14
         436          436   0.17074662E+04
         436          431   0.79884210E+02
         436          432   0.00000000E+00
         436          433   0.00000000E+00
         436          434   0.00000000E+00
         436          435   0.00000000E+00
         436          437   0.19543730E+04
         436          438   0.00000000E+00
         436          439   0.43198833E-04
         436          440   0.00000000E+00
         436          421  -0.19131143E-06
         436          422   0.00000000E+00
         436          423   0.00000000E+00
         436          424   0.00000000E+00
         436          425   0.00000000E+00
         436          426  -0.40891515E-05
         436          427  -0.46804608E-05
         436          428   0.00000000E+00
         436          429   0.00000000E+00
         436          430   0.00000000E+00
         436          441  -0.28714324E-06
         436          442   0.00000000E+00
         436          443   0.00000000E+00
         436          444   0.00000000E+00
         436          445   0.00000000E+00
         436          446  -0.61374911E-05
         436          447  -0.70249993E-05
         436          448   0.00000000E+00
         436          449   0.00000000E+00
         436          450   0.00000000E+00
         437          437   0.26723718E+04
         437          431   0.76117799E+02
         437          432  -0.21147957E+02
         437          433   0.00000000E+00
         437          434  -0.65878288E+02
         437          435  -0.63519108E+02
         437          436   0.19543478E+04
         437          438  -0.38887502E-04
         437          439  -0.12035985E+00
         437          440   0.49505150E-01
         437          421  -0.18229190E-06
         437          422   0.00000000E+00
         437          423   0.00000000E+00
         437          424   0.58149057E-08
         437          425   0.16475051E-09
         437          426  -0.46804005E-05
         437          427  -0.58937841E-05
         437          428   0.15713863E-13
         437          429   0.28826779E-09
         437          430  -0.11851393E-09
         437          441  -0.27360565E-06
         437          442   0.00000000E+00
         437          443   0.00000000E+00
         437          444   0.87277109E-08
         437          445   0.24727742E-09
         437          446  -0.70249088E-05
         437          447  -0.88461011E-05
         437          448   0.23585259E-13
         437          449   0.43266702E-09
         437          450  -0.17787999E-09
         438          438   0.66308262E-04
         438          431   0.00000000E+00
         438          432   0.00000000E+00
         438          433   0.00000000E+00
         438          434   0.00000000E+00
         438          435   0.00000000E+00
         438          436   0.00000000E+00
         438          437  -0.38896922E-04
         438          439  -0.14946245E-04
         438          440  -0.37051937E-04
         438          421   0.00000000E+00
         438          422   0.00000000E+00
         438          423   0.00000000E+00
         438          424   0.00000000E+00
         438          425   0.00000000E+00
         438          426   0.00000000E+00
         438          427   0.15715132E-13
         438          428  -0.23320539E-13
         438          429  -0.29226999E-14
         438          430   0.11296639E-13
         438          441   0.00000000E+00
         438          442   0.00000000E+00
         438          443   0.00000000E+00
         438          444   0.00000000E+00
         438          445   0.00000000E+00
         438          446   0.00000000E+00
         438          447   0.23587162E-13
         438          448  -0.35002274E-13
         438          449  -0.43867400E-14
         438          450   0.16955357E-13
         439          439   0.99356224E+02
         439          431   0.00000000E+00
         439          432   0.00000000E+00
         439          433   0.00000000E+00
         439          434   0.00000000E+00
         439          435   0.00000000E+00
         439          436   0.43198833E-04
         439          437  -0.12034781E+00
         439          438  -0.14942654E-04
         439          440   0.33536708E+02
         439          421   0.00000000E+00
         439          422   0.00000000E+00
         439          423   0.00000000E+00
         439          424   0.00000000E+00
         439          425   0.00000000E+00
         439          426   0.00000000E+00
         439          427   0.28823897E-09
         439          428  -0.29225903E-14
         439          429  -0.23794469E-06
         439          430  -0.80315889E-07
         439          441   0.00000000E+00
         439          442   0.00000000E+00
         439          443   0.00000000E+00
         439          444   0.00000000E+00
         439          445   0.00000000E+00
         439          446   0.00000000E+00
         439          447   0.43262376E-09
         439          448  -0.43865755E-14
         439          449  -0.35713606E-06
         439          450  -0.12054776E-06
         440          440   0.13484933E+05
         440          431   0.36307130E+04
         440          432   0.24834091E+03
         440          433   0.00000000E+00
         440          434   0.00000000E+00
         440          435   0.21795340E-05
         440          436   0.00000000E+00
         440          437   0.49505150E-01
         440          438  -0.37042339E-04
         440          439   0.33536708E+02
         440          421  -0.86950688E-05
         440          422  -0.59474313E-06
         440          423   0.00000000E+00
         440          424   0.00000000E+00
         440          425  -0.52196912E-14
         440          426   0.00000000E+00
         440          427  -0.11851393E-09
         440          428   0.11294945E-13
         440          429  -0.80315889E-07
         440          430  -0.32294601E-04
         440          441  -0.13050607E-04
         440          442  -0.89266212E-06
         440          443   0.00000000E+00
         440          444   0.00000000E+00
         440          445  -0.78343413E-14
         440          446   0.00000000E+00
         440          447  -0.17787999E-09
         440          448   0.16952814E-13
         440          449  -0.12054776E-06
         440          450  -0.48471627E-04
         441          441   0.97945219E+04
         441          442   0.00000000E+00
         441          443   0.00000000E+00
         441          444   0.00000000E+00
         441          445   0.00000000E+00
         441          446   0.79884210E+02
         441          447   0.76117799E+02
         441          448   0.00000000E+00
         441          449   0.00000000E+00
         441          450   0.36307130E+04
         441          431  -0.23456563E-04
         441          432   0.00000000E+00
         441          433   0.00000000E+00
         441          434   0.00000000E+00
         441          435   0.00000000E+00
         441          436  -0.19131143E-06
         441          437  -0.18229190E-06
         441          438   0.00000000E+00
         441          439   0.00000000E+00
         441          440  -0.86950688E-05
         441          451  -0.35206435E-04
         441          452   0.00000000E+00
         441          453   0.00000000E+00
         441          454   0.00000000E+00
         441          455   0.00000000E+00
         441          456  -0.28714324E-06
         441          457  -0.27360565E-06
         441          458   0.00000000E+00
         441          459   0.00000000E+00
         441          460  -0.13050607E-04
         442          442   0.61664984E+04
         442          441   0.00000000E+00
         442          443   0.00000000E+00
         442          444   0.63450217E+01
         442          445   0.63450217E+01
         442          446   0.00000000E+00
         442          447  -0.21136331E+02
         442          448   0.00000000E+00
         442          449   0.00000000E+00
         442          450   0.24834091E+03
         442          431   0.00000000E+00
         442          432  -0.14762871E-04
         442          433   0.00000000E+00
         442          434   0.00000000E+00
         442          435   0.00000000E+00
         442          436   0.00000000E+00
         442          437   0.00000000E+00
         442          438   0.00000000E+00
         442          439   0.00000000E+00
         442          440  -0.59474313E-06
         442          451   0.00000000E+00
         442          452  -0.22157895E-04
         442          453   0.00000000E+00
         442          454   0.00000000E+00
         442          455   0.00000000E+00
         442          456   0.00000000E+00
         442          457   0.00000000E+00
         442          458   0.00000000E+00
         442          459   0.00000000E+00
         442          460  -0.89266212E-06
         443          443   0.78082192E+03
         443          441   0.00000000E+00
         443          442   0.00000000E+00
         443          444   0.00000000E+00
         443          445   0.00000000E+00
         443          446   0.00000000E+00
         443          447   0.00000000E+00
         443          448   0.00000000E+00
         443          449   0.00000000E+00
         443          450   0.00000000E+00
         443          431   0.00000000E+00
         443          432   0.00000000E+00
         443          433  -0.18699636E-05
         443          434   0.00000000E+00
         443          435   0.00000000E+00
         443          436   0.00000000E+00
         443          437   0.00000000E+00
         443          438   0.00000000E+00
         443          439   0.00000000E+00
         443          440   0.00000000E+00
         443          451   0.00000000E+00
         443          452   0.00000000E+00
         443          453  -0.28066666E-05
         443          454   0.00000000E+00
         443          455   0.00000000E+00
         443          456   0.00000000E+00
         443          457   0.00000000E+00
         443          458   0.00000000E+00
         443          459   0.00000000E+00
         443          460   0.00000000E+00
         444          444   0.13409529E+04
         444          441   0.00000000E+00
         444          442   0.63443872E+01
         444          443   0.00000000E+00
         444          445   0.19035065E+02
         444          446   0.00000000E+00
         444          447  -0.65836821E+02
         444          448   0.00000000E+00
         444          449   0.00000000E+00
         444          450   0.00000000E+00
         444          431   0.00000000E+00
         444          432   0.00000000E+00
         444          433   0.00000000E+00
         444          434  -0.31658156E-05
         444          435   0.00000000E+00
         444          436   0.00000000E+00
         444          437   0.58143243E-08
         444          438   0.00000000E+00
         444          439   0.00000000E+00
         444          440   0.00000000E+00
         444          451   0.00000000E+00
         444          452   0.00000000E+00
         444          453   0.00000000E+00
         444          454  -0.47516374E-05
         444          455   0.00000000E+00
         444          456   0.00000000E+00
         444          457   0.87268382E-08
         444          458   0.00000000E+00
         444          459   0.00000000E+00
         444          460   0.00000000E+00
         445          445   0.19052837E+02
         445          441   0.00000000E+00
         445          442   0.63443872E+01
         445          443   0.00000000E+00
         445          444   0.19035065E+02
         445          446   0.00000000E+00
         445          447  -0.63477866E+02
         445          448   0.00000000E+00
         445          449   0.00000000E+00
         445          450   0.21795643E-05
         445          431   0.00000000E+00
         445          432   0.00000000E+00
         445          433   0.00000000E+00
         445          434   0.00000000E+00
         445          435  -0.42484263E-10
         445          436   0.00000000E+00
         445          437   0.16470995E-09
         445          438   0.00000000E+00
         445          439   0.00000000E+00
         445          440  -0.52197638E-14
         445          451   0.00000000E+00
         445          452   0.00000000E+00
         445          453   0.00000000E+00
         445          454   0.00000000E+00
         445          455  -0.63765499E-10
         445          456   0.00000000E+00
         445          457   0.24721653E-09
         445          458   0.00000000E+00
         445          459   0.00000000E+00
         445          460  -0.78344502E-14
         446          446   0.17074662E+04
         446          441   0.79884210E+02
         446          442   0.00000000E+00
         446          443   0.00000000E+00
         446          444   0.00000000E+00
         446          445   0.00000000E+00
         446          447   0.19543730E+04
         446          448   0.00000000E+00
         446          449   0.43198833E-04
         446          450   0.00000000E+00
         446          431  -0.19131143E-06
         446          432   0.00000000E+00
         446          433   0.00000000E+00
         446          434   0.00000000E+00
         446          435   0.00000000E+00
         446          436  -0.40891515E-05
         446          437  -0.46804608E-05
         446          438   0.00000000E+00
         446          439   0.00000000E+00
         446          440   0.00000000E+00
         446          451  -0.28714324E-06
         446          452   0.00000000E+00
         446          453   0.00000000E+00
         446          454   0.00000000E+00
         446          455   0.00000000E+00
         446          456  -0.61374911E-05
         446          457  -0.70249993E-05
         446          458   0.00000000E+00
         446          459   0.00000000E+00
         446          460   0.00000000E+00
         447          447   0.26723718E+04
         447          441   0.76117799E+02
         447          442  -0.21147957E+02
         447          443   0.00000000E+00
         447          444  -0.65878288E+02
         447          445  -0.63519108E+02
         447          446   0.19543478E+04
         447          448  -0.38887502E-04
         447          449  -0.12035985E+00
         447          450   0.49505150E-01
         447          431  -0.18229190E-06
         447          432   0.00000000E+00
         447          433   0.00000000E+00
         447          434   0.58149057E-08
         447          435   0.16475051E-09
         447          436  -0.46804005E-05
         447          437  -0.58937841E-05
         447          438   0.15713863E-13
         447          439   0.28826779E-09
         447          440  -0.11851393E-09
         447          451  -0.27360565E-06
         447          452   0.00000000E+00
         447          453   0.00000000E+00
         447          454   0.87277109E-08
         447          455   0.24727742E-09
         447          456  -0.70249088E-05
         447          457  -0.88461011E-05
         447          458   0.23585259E-13
         447          459   0.43266702E-09
         447          460  -0.17787999E-09
         448          448   0.66308262E-04
         448          441   0.00000000E+00
         448          442   0.00000000E+00
         448          443   0.00000000E+00
         448          444   0.00000000E+00
         448          445   0.00000000E+00
         448          446   0.00000000E+00
         448          447  -0.38896922E-04
         448          449  -0.14946245E-04
         448          450  -0.37051937E-04
         448          431   0.00000000E+00
         448          432   0.00000000E+00
         448          433   0.00000000E+00
         448          434   0.00000000E+00
         448          435   0.00000000E+00
         448          436   0.00000000E+00
         448          437   0.15715132E-13
         448          438  -0.23320539E-13
         448          439  -0.29226999E-14
         448          440   0.11296639E-13
         448          451   0.00000000E+00
         448          452   0.00000000E+00
         448          453   0.00000000E+00
         448          454   0.00000000E+00
         448          455   0.00000000E+00
         448          456   0.00000000E+00
         448          457   0.23587162E-13
         448          458  -0.35002274E-13
         448          459  -0.43867400E-14
         448          460   0.16955357E-13
         449          449   0.99356224E+02
         449          441   0.00000000E+00
         449          442   0.00000000E+00
         449          443   0.00000000E+00
         449          444   0.00000000E+00
         449          445   0.00000000E+00
         449          446   0.43198833E-04
         449          447  -0.12034781E+00
         449          448  -0.14942654E-04
         449          450   0.33536708E+02
         449          431   0.00000000E+00
         449          432   0.00000000E+00
         449          433   0.00000000E+00
         449          434   0.00000000E+00
         449          435   0.00000000E+00
         449          436   0.00000000E+00
         449          437   0.28823897E-09
         449          438  -0.29225903E-14
         449          439  -0.23794469E-06
         449          440  -0.80315889E-07
         449          451   0.00000000E+00
         449          452   0.00000000E+00
         449          453   0.00000000E+00
         449          454   0.00000000E+00
         449          455   0.00000000E+00
         449          456   0.00000000E+00
         449          457   0.43262376E-09
         449          458  -0.43865755E-14
         449          459  -0.35713606E-06
         449          460  -0.12054776E-06
         450          450   0.13484933E+05
         450          441   0.36307130E+04
         450          442   0.24834091E+03
         450          443   0.00000000E+00
         450          444   0.00000000E+00
         450          445   0.21795340E-05
         450          446   0.00000000E+00
         450          447   0.49505150E-01
         450          448  -0.37042339E-04
         450          449   0.33536708E+02
         450          431  -0.86950688E-05
         450          432  -0.59474313E-06
         450          433   0.00000000E+00
         450          434   0.00000000E+00
         450          435  -0.52196912E-14
         450          436   0.00000000E+00
         450          437  -0.11851393E-09
         450          438   0.11294945E-13
         450          439  -0.80315889E-07
         450          440  -0.32294601E-04
         450          451  -0.13050607E-04
         450          452  -0.89266212E-06
         450          453   0.00000000E+00
         450          454   0.00000000E+00
         450          455  -0.78343413E-14
         450          456   0.00000000E+00
         450          457  -0.17787999E-09
         450          458   0.16952814E-13
         450          459  -0.12054776E-06
         450          460  -0.48471627E-04
         451          451   0.97945219E+04
         451          452   0.00000000E+00
         451          453   0.00000000E+00
         451          454   0.00000000E+00
         451          455   0.00000000E+00
         451          456   0.79884210E+02
         451          457   0.76117799E+02
         451          458   0.00000000E+00
         451          459   0.00000000E+00
         451          460   0.36307130E+04
         451          441  -0.23456563E-04
         451          442   0.00000000E+00
         451          443   0.00000000E+00
         451          444   0.00000000E+00
         451          445   0.00000000E+00
         451          446  -0.19131143E-06
         451          447  -0.18229190E-06
         451          448   0.00000000E+00
         451          449   0.00000000E+00
         451          450  -0.86950688E-05
         451          461  -0.35206435E-04
         451          462   0.00000000E+00
         451          463   0.00000000E+00
         451          464   0.00000000E+00
         451          465   0.00000000E+00
         451          466  -0.28714324E-06
         451          467  -0.27360565E-06
         451          468   0.00000000E+00
         451          469   0.00000000E+00
         451          470  -0.13050607E-04
         452          452   0.61664984E+04
         452          451   0.00000000E+00
         452          453   0.00000000E+00
         452          454   0.63450217E+01
         452          455   0.63450217E+01
         452          456   0.00000000E+00
         452          457  -0.21136331E+02
         452          458   0.00000000E+00
         452          459   0.00000000E+00
         452          460   0.24834091E+03
         452          441   0.00000000E+00
         452          442  -0.14762871E-04
         452          443   0.00000000E+00
         452          444   0.00000000E+00
         452          445   0.00000000E+00
         452          446   0.00000000E+00
         452          447   0.00000000E+00
         452          448   0.00000000E+00
         452          449   0.00000000E+00
         452          450  -0.59474313E-06
         452          461   0.00000000E+00
         452          462  -0.22157895E-04
         452          463   0.00000000E+00
         452          464   0.00000000E+00
         452          465   0.00000000E+00
         452          466   0.00000000E+00
         452          467   0.00000000E+00
         452          468   0.00000000E+00
         452          469   0.00000000E+00
         452          470  -0.89266212E-06
         453          453   0.78082192E+03
         453          451   0.00000000E+00
         453          452   0.00000000E+00
         453          454   0.00000000E+00
         453          455   0.00000000E+00
         453          456   0.00000000E+00
         453          457   0.00000000E+00
         453          458   0.00000000E+00
         453          459   0.00000000E+00
         453          460   0.00000000E+00
         453          441   0.00000000E+00
         453          442   0.00000000E+00
         453          443  -0.18699636E-05
         453          444   0.00000000E+00
         453          445   0.00000000E+00
         453          446   0.00000000E+00
         453          447   0.00000000E+00
         453          448   0.00000000E+00
         453          449   0.00000000E+00
         453          450   0.00000000E+00
         453          461   0.00000000E+00
         453          462   0.00000000E+00
         453          463  -0.28066666E-05
         453          464   0.00000000E+00
         453          465   0.00000000E+00
         453          466   0.00000000E+00
         453          467   0.00000000E+00
         453          468   0.00000000E+00
         453          469   0.00000000E+00
         453          470   0.00000000E+00
         454          454   0.13409529E+04
         454          451   0.00000000E+00
         454          452   0.63443872E+01
         454          453   0.00000000E+00
         454          455   0.19035065E+02
         454          456   0.00000000E+00
         454          457  -0.65836821E+02
         454          458   0.00000000E+00
         454          459   0.00000000E+00
         454          460   0.00000000E+00
         454          441   0.00000000E+00
         454          442   0.00000000E+00
         454          443   0.00000000E+00
         454          444  -0.31658156E-05
         454          445   0.00000000E+00
         454          446   0.00000000E+00
         454          447   0.58143243E-08
         454          448   0.00000000E+00
         454          449   0.00000000E+00
         454          450   0.00000000E+00
         454          461   0.00000000E+00
         454          462   0.00000000E+00
         454          463   0.00000000E+00
         454          464  -0.47516374E-05
         454          465   0.00000000E+00
         454          466   0.00000000E+00
         454          467   0.87268382E-08
         454          468   0.00000000E+00
         454          469   0.00000000E+00
         454          470   0.00000000E+00
         455          455   0.19052837E+02
         455          451   0.00000000E+00
         455          452   0.63443872E+01
         455          453   0.00000000E+00
         455          454   0.19035065E+02
         455          456   0.00000000E+00
         455          457  -0.63477866E+02
         455          458   0.00000000E+00
         455          459   0.00000000E+00
         455          460   0.21795643E-05
         455          441   0.00000000E+00
         455          442   0.00000000E+00
         455          443   0.00000000E+00
         455          444   0.00000000E+00
         455          445  -0.42484263E-10
         455          446   0.00000000E+00
         455          447   0.16470995E-09
         455          448   0.00000000E+00
         455          449   0.00000000E+00
         455          450  -0.52197638E-14
         455          461   0.00000000E+00
         455          462   0.00000000E+00
         455          463   0.00000000E+00
         455          464   0.00000000E+00
         455          465  -0.63765499E-10
         455          466   0.00000000E+00
         455          467   0.24721653E-09
         455          468   0.00000000E+00
         455          469   0.00000000E+00
         455          470  -0.78344502E-14
         456          456   0.17074662E+04
         456          451   0.79884210E+02
         456          452   0.00000000E+00
         456          453   0.00000000E+00
         456          454   0.00000000E+00
         456          455   0.00000000E+00
         456          457   0.19543730E+04
         456          458   0.00000000E+00
         456          459   0.43198833E-04
         456          460   0.00000000E+00
         456          441  -0.19131143E-06
         456          442   0.00000000E+00
         456          443   0.00000000E+00
         456          444   0.00000000E+00
         456          445   0.00000000E+00
         456          446  -0.40891515E-05
         456          447  -0.46804608E-05
         456          448   0.00000000E+00
         456          449   0.00000000E+00
         456          450   0.00000000E+00
         456          461  -0.28714324E-06
         456          462   0.00000000E+00
         456          463   0.00000000E+00
         456          464   0.00000000E+00
         456          465   0.00000000E+00
         456          466  -0.61374911E-05
         456          467  -0.70249993E-05
         456          468   0.00000000E+00
         456          469   0.00000000E+00
         456          470   0.00000000E+00
         457          457   0.26723718E+04
         457          451   0.76117799E+02
         457          452  -0.21147957E+02
         457          453   0.00000000E+00
         457          454  -0.65878288E+02
         457          455  -0.63519108E+02
         457          456   0.19543478E+04
         457          458  -0.38887502E-04
         457          459  -0.12035985E+00
         457          460   0.49505150E-01
         457          441  -0.18229190E-06
         457          442   0.00000000E+00
         457          443   0.00000000E+00
         457          444   0.58149057E-08
         457          445   0.16475051E-09
         457          446  -0.46804005E-05
         457          447  -0.58937841E-05
         457          448   0.15713863E-13
         457          449   0.28826779E-09
         457          450  -0.11851393E-09
         457          461  -0.27360565E-06
         457          462   0.00000000E+00
         457          463   0.00000000E+00
         457          464   0.87277109E-08
         457          465   0.24727742E-09
         457          466  -0.70249088E-05
         457          467  -0.88461011E-05
         457          468   0.23585259E-13
         457          469   0.43266702E-09
         457          470  -0.17787999E-09
         458          458   0.66308262E-04
         458          451   0.00000000E+00
         458          452   0.00000000E+00
         458          453   0.00000000E+00
         458          454   0.00000000E+00
         458          455   0.00000000E+00
         458          456   0.00000000E+00
         458          457  -0.38896922E-04
         458          459  -0.14946245E-04
         458          460  -0.37051937E-04
         458          441   0.00000000E+00
         458          442   0.00000000E+00
         458          443   0.00000000E+00
         458          444   0.00000000E+00
         458          445   0.00000000E+00
         458          446   0.00000000E+00
         458          447   0.15715132E-13
         458          448  -0.23320539E-13
         458          449  -0.29226999E-14
         458          450   0.11296639E-13
         458          461   0.00000000E+00
         458          462   0.00000000E+00
         458          463   0.00000000E+00
         458          464   0.00000000E+00
         458          465   0.00000000E+00
         458          466   0.00000000E+00
         458          467   0.23587162E-13
         458          468  -0.35002274E-13
         458          469  -0.43867400E-14
         458          470   0.16955357E-13
         459          459   0.99356224E+02
         459          451   0.00000000E+00
         459          452   0.00000000E+00
         459          453   0.00000000E+00
         459          454   0.00000000E+00
         459          455   0.00000000E+00
         459          456   0.43198833E-04
         459          457  -0.12034781E+00
         459          458  -0.14942654E-04
         459          460   0.33536708E+02
         459          441   0.00000000E+00
         459          442   0.00000000E+00
         459          443   0.00000000E+00
         459          444   0.00000000E+00
         459          445   0.00000000E+00
         459          446   0.00000000E+00
         459          447   0.28823897E-09
         459          448  -0.29225903E-14
         459          449  -0.23794469E-06
         459          450  -0.80315889E-07
         459          461   0.00000000E+00
         459          462   0.00000000E+00
         459          463   0.00000000E+00
         459          464   0.00000000E+00
         459          465   0.00000000E+00
         459          466   0.00000000E+00
         459          467   0.43262376E-09
         459          468  -0.43865755E-14
         459          469  -0.35713606E-06
         459          470  -0.12054776E-06
         460          460   0.13484933E+05
         460          451   0.36307130E+04
         460          452   0.24834091E+03
         460          453   0.00000000E+00
         460          454   0.00000000E+00
         460          455   0.21795340E-05
         460          456   0.00000000E+00
         460          457   0.49505150E-01
         460          458  -0.37042339E-04
         460          459   0.33536708E+02
         460          441  -0.86950688E-05
         460          442  -0.59474313E-06
         460          443   0.00000000E+00
         460          444   0.00000000E+00
         460          445  -0.52196912E-14
         460          446   0.00000000E+00
         460          447  -0.11851393E-09
         460          448   0.11294945E-13
         460          449  -0.80315889E-07
         460          450  -0.32294601E-04
         460          461  -0.13050607E-04
         460          462  -0.89266212E-06
         460          463   0.00000000E+00
         460          464   0.00000000E+00
         460          465  -0.78343413E-14
         460          466   0.00000000E+00
         460          467  -0.17787999E-09
         460          468   0.16952814E-13
         460          469  -0.12054776E-06
         460          470  -0.48471627E-04
         461          461   0.97945219E+04
         461          462   0.00000000E+00
         461          463   0.00000000E+00
         461          464   0.00000000E+00
         461          465   0.00000000E+00
         461          466   0.79884210E+02
         461          467   0.76117799E+02
         461          468   0.00000000E+00
         461          469   0.00000000E+00
         461          470   0.36307130E+04
         461          451  -0.23456563E-04
         461          452   0.00000000E+00
         461          453   0.00000000E+00
         461          454   0.00000000E+00
         461          455   0.00000000E+00
         461          456  -0.19131143E-06
         461          457  -0.18229190E-06
         461          458   0.00000000E+00
         461          459   0.00000000E+00
         461          460  -0.86950688E-05
         461          471  -0.35206435E-04
         461          472   0.00000000E+00
         461          473   0.00000000E+00
         461          474   0.00000000E+00
         461          475   0.00000000E+00
         461          476  -0.28714324E-06
         461          477  -0.27360565E-06
         461          478   0.00000000E+00
         461          479   0.00000000E+00
         461          480  -0.13050607E-04
         462          462   0.61664984E+04
         462          461   0.00000000E+00
         462          463   0.00000000E+00
         462          464   0.63450217E+01
         462          465   0.63450217E+01
         462          466   0.00000000E+00
         462          467  -0.21136331E+02
         462          468   0.00000000E+00
         462          469   0.00000000E+00
         462          470   0.24834091E+03
         462          451   0.00000000E+00
         462          452  -0.14762871E-04
         462          453   0.00000000E+00
         462          454   0.00000000E+00
         462          455   0.00000000E+00
         462          456   0.00000000E+00
         462          457   0.00000000E+00
         462          458   0.00000000E+00
         462          459   0.00000000E+00
         462          460  -0.59474313E-06
         462          471   0.00000000E+00
         462          472  -0.22157895E-04
         462          473   0.00000000E+00
         462          474   0.00000000E+00
         462          475   0.00000000E+00
         462          476   0.00000000E+00
         462          477   0.00000000E+00
         462          478   0.00000000E+00
         462          479   0.00000000E+00
         462          480  -0.89266212E-06
         463          463   0.78082192E+03
         463          461   0.00000000E+00
         463          462   0.00000000E+00
         463          464   0.00000000E+00
         463          465   0.00000000E+00
         463          466   0.00000000E+00
         463          467   0.00000000E+00
         463          468   0.00000000E+00
         463          469   0.00000000E+00
         463          470   0.00000000E+00
         463          451   0.00000000E+00
         463          452   0.00000000E+00
         463          453  -0.18699636E-05
         463          454   0.00000000E+00
         463          455   0.00000000E+00
         463          456   0.00000000E+00
         463          457   0.00000000E+00
         463          458   0.00000000E+00
         463          459   0.00000000E+00
         463          460   0.00000000E+00
         463          471   0.00000000E+00
         463          472   0.00000000E+00
         463          473  -0.28066666E-05
         463          474   0.00000000E+00
         463          475   0.00000000E+00
         463          476   0.00000000E+00
         463          477   0.00000000E+00
         463          478   0.00000000E+00
         463          479   0.00000000E+00
         463          480   0.00000000E+00
         464          464   0.13409529E+04
         464          461   0.00000000E+00
         464          462   0.63443872E+01
         464          463   0.00000000E+00
         464          465   0.19035065E+02
         464          466   0.00000000E+00
         464          467  -0.65836821E+02
         464          468   0.00000000E+00
         464          469   0.00000000E+00
         464          470   0.00000000E+00
         464          451   0.00000000E+00
         464          452   0.00000000E+00
         464          453   0.00000000E+00
         464          454  -0.31658156E-05
         464          455   0.00000000E+00
         464          456   0.00000000E+00
         464          457   0.58143243E-08
         464          458   0.00000000E+00
         464          459   0.00000000E+00
         464          460   0.00000000E+00
         464          471   0.00000000E+00
         464          472   0.00000000E+00
         464          473   0.00000000E+00
         464          474  -0.47516374E-05
         464          475   0.00000000E+00
         464          476   0.00000000E+00
         464          477   0.87268382E-08
         464          478   0.00000000E+00
         464          479   0.00000000E+00
         464          480   0.00000000E+00
         465          465   0.19052837E+02
         465          461   0.00000000E+00
         465          462   0.63443872E+01
         465          463   0.00000000E+00
         465          464   0.19035065E+02
         465          466   0.00000000E+00
         465          467  -0.63477866E+02
         465          468   0.00000000E+00
         465          469   0.00000000E+00
         465          470   0.21795643E-05
         465          451   0.00000000E+00
         465          452   0.00000000E+00
         465          453   0.00000000E+00
         465          454   0.00000000E+00
         465          455  -0.42484263E-10
         465          456   0.00000000E+00
         465          457   0.16470995E-09
         465          458   0.00000000E+00
         465          459   0.00000000E+00
         465          460  -0.52197638E-14
         465          471   0.00000000E+00
         465          472   0.00000000E+00
         465          473   0.00000000E+00
         465          474   0.00000000E+00
         465          475  -0.63765499E-10
         465          476   0.00000000E+00
         465          477   0.24721653E-09
         465          478   0.00000000E+00
         465          479   0.00000000E+00
         465          480  -0.78344502E-14
         466          466   0.17074662E+04
         466          461   0.79884210E+02
         466          462   0.00000000E+00
         466          463   0.00000000E+00
         466          464   0.00000000E+00
         466          465   0.00000000E+00
         466          467   0.19543730E+04
         466          468   0.00000000E+00
         466          469   0.43198833E-04
         466          470   0.00000000E+00
         466          451  -0.19131143E-06
         466          452   0.00000000E+00
         466          453   0.00000000E+00
         466          454   0.00000000E+00
         466          455   0.00000000E+00
         466          456  -0.40891515E-05
         466          457  -0.46804608E-05
         466          458   0.00000000E+00
         466          459   0.00000000E+00
         466          460   0.00000000E+00
         466          471  -0.28714324E-06
         466          472   0.00000000E+00
         466          473   0.00000000E+00
         466          474   0.00000000E+00
         466          475   0.00000000E+00
         466          476  -0.61374911E-05
         466          477  -0.70249993E-05
         466          478   0.00000000E+00
         466          479   0.00000000E+00
         466          480   0.00000000E+00
         467          467   0.26723718E+04
         467          461   0.76117799E+02
         467          462  -0.21147957E+02
         467          463   0.00000000E+00
         467          464  -0.65878288E+02
         467          465  -0.63519108E+02
         467          466   0.19543478E+04
         467          468  -0.38887502E-04
         467          469  -0.12035985E+00
         467          470   0.49505150E-01
         467          451  -0.18229190E-06
         467          452   0.00000000E+00
         467          453   0.00000000E+00
         467          454   0.58149057E-08
         467          455   0.16475051E-09
         467          456  -0.46804005E-05
         467          457  -0.58937841E-05
         467          458   0.15713863E-13
         467          459   0.28826779E-09
         467          460  -0.11851393E-09
         467          471  -0.27360565E-06
         467          472   0.00000000E+00
         467          473   0.00000000E+00
         467          474   0.87277109E-08
         467          475   0.24727742E-09
         467          476  -0.70249088E-05
         467          477  -0.88461011E-05
         467          478   0.23585259E-13
         467          479   0.43266702E-09
         467          480  -0.17787999E-09
         468          468   0.66308262E-04
         468          461   0.00000000E+00
         468          462   0.00000000E+00
         468          463   0.00000000E+00
         468          464   0.00000000E+00
         468          465   0.00000000E+00
         468          466   0.00000000E+00
         468          467  -0.38896922E-04
         468          469  -0.14946245E-04
         468          470  -0.37051937E-04
         468          451   0.00000000E+00
         468          452   0.00000000E+00
         468          453   0.00000000E+00
         468          454   0.00000000E+00
         468          455   0.00000000E+00
         468          456   0.00000000E+00
         468          457   0.15715132E-13
         468          458  -0.23320539E-13
         468          459  -0.29226999E-14
         468          460   0.11296639E-13
         468          471   0.00000000E+00
         468          472   0.00000000E+00
         468          473   0.00000000E+00
         468          474   0.00000000E+00
         468          475   0.00000000E+00
         468          476   0.00000000E+00
         468          477   0.23587162E-13
         468          478  -0.35002274E-13
         468          479  -0.43867400E-14
         468          480   0.16955357E-13
         469          469   0.99356224E+02
         469          461   0.00000000E+00
         469          462   0.00000000E+00
         469          463   0.00000000E+00
         469          464   0.00000000E+00
         469          465   0.00000000E+00
         469          466   0.43198833E-04
         469          467  -0.12034781E+00
         469          468  -0.14942654E-04
         469          470   0.33536708E+02
         469          451   0.00000000E+00
         469          452   0.00000000E+00
         469          453   0.00000000E+00
         469          454   0.00000000E+00
         469          455   0.00000000E+00
         469          456   0.00000000E+00
         469          457   0.28823897E-09
         469          458  -0.29225903E-14
         469          459  -0.23794469E-06
         469          460  -0.80315889E-07
         469          471   0.00000000E+00
         469          472   0.00000000E+00
         469          473   0.00000000E+00
         469          474   0.00000000E+00
         469          475   0.00000000E+00
         469          476   0.00000000E+00
         469          477   0.43262376E-09
         469          478  -0.43865755E-14
         469          479  -0.35713606E-06
         469          480  -0.12054776E-06
         470          470   0.13484933E+05
         470          461   0.36307130E+04
         470          462   0.24834091E+03
         470          463   0.00000000E+00
         470          464   0.00000000E+00
         470          465   0.21795340E-05
         470          466   0.00000000E+00
         470          467   0.49505150E-01
         470          468  -0.37042339E-04
         470          469   0.33536708E+02
         470          451  -0.86950688E-05
         470          452  -0.59474313E-06
         470          453   0.00000000E+00
         470          454   0.00000000E+00
         470          455  -0.52196912E-14
         470          456   0.00000000E+00
         470          457  -0.11851393E-09
         470          458   0.11294945E-13
         470          459  -0.80315889E-07
         470          460  -0.32294601E-04
         470          471  -0.13050607E-04
         470          472  -0.89266212E-06
         470          473   0.00000000E+00
         470          474   0.00000000E+00
         470          475  -0.78343413E-14
         470          476   0.00000000E+00
         470          477  -0.17787999E-09
         470          478   0.16952814E-13
         470          479  -0.12054776E-06
         470          480  -0.48471627E-04
         471          471   0.97945219E+04
         471          472   0.00000000E+00
         471          473   0.00000000E+00
         471          474   0.00000000E+00
         471          475   0.00000000E+00
         471          476   0.79884210E+02
         471          477   0.76117799E+02
         471          478   0.00000000E+00
         471          479   0.00000000E+00
         471          480   0.36307130E+04
         471          461  -0.23456563E-04
         471          462   0.00000000E+00
         471          463   0.00000000E+00
         471          464   0.00000000E+00
         471          465   0.00000000E+00
         471          466  -0.19131143E-06
         471          467  -0.18229190E-06
         471          468   0.00000000E+00
         471          469   0.00000000E+00
         471          470  -0.86950688E-05
         471          481  -0.35206435E-04
         471          482   0.00000000E+00
         471          483   0.00000000E+00
         471          484   0.00000000E+00
         471          485   0.00000000E+00
         471          486  -0.28714324E-06
         471          487  -0.27360565E-06
         471          488   0.00000000E+00
         471          489   0.00000000E+00
         471          490  -0.13050607E-04
         472          472   0.61664984E+04
         472          471   0.00000000E+00
         472          473   0.00000000E+00
         472          474   0.63450217E+01
         472          475   0.63450217E+01
         472          476   0.00000000E+00
         472          477  -0.21136331E+02
         472          478   0.00000000E+00
         472          479   0.00000000E+00
         472          480   0.24834091E+03
         472          461   0.00000000E+00
         472          462  -0.14762871E-04
         472          463   0.00000000E+00
         472          464   0.00000000E+00
         472          465   0.00000000E+00
         472          466   0.00000000E+00
         472          467   0.00000000E+00
         472          468   0.00000000E+00
         472          469   0.00000000E+00
         472          470  -0.59474313E-06
         472          481   0.00000000E+00
         472          482  -0.22157895E-04
         472          483   0.00000000E+00
         472          484   0.00000000E+00
         472          485   0.00000000E+00
         472          486   0.00000000E+00
         472          487   0.00000000E+00
         472          488   0.00000000E+00
         472          489   0.00000000E+00
         472          490  -0.89266212E-06
         473          473   0.78082192E+03
         473          471   0.00000000E+00
         473          472   0.00000000E+00
         473          474   0.00000000E+00
         473          475   0.00000000E+00
         473          476   0.00000000E+00
         473          477   0.00000000E+00
         473          478   0.00000000E+00
         473          479   0.00000000E+00
         473          480   0.00000000E+00
         473          461   0.00000000E+00
         473          462   0.00000000E+00
         473          463  -0.18699636E-05
         473          464   0.00000000E+00
         473          465   0.00000000E+00
         473          466   0.00000000E+00
         473          467   0.00000000E+00
         473          468   0.00000000E+00
         473          469   0.00000000E+00
         473          470   0.00000000E+00
         473          481   0.00000000E+00
         473          482   0.00000000E+00
         473          483  -0.28066666E-05
         473          484   0.00000000E+00
         473          485   0.00000000E+00
         473          486   0.00000000E+00
         473          487   0.00000000E+00
         473          488   0.00000000E+00
         473          489   0.00000000E+00
         473          490   0.00000000E+00
         474          474   0.13409529E+04
         474          471   0.00000000E+00
         474          472   0.63443872E+01
         474          473   0.00000000E+00
         474          475   0.19035065E+02
         474          476   0.00000000E+00
         474          477  -0.65836821E+02
         474          478   0.00000000E+00
         474          479   0.00000000E+00
         474          480   0.00000000E+00
         474          461   0.00000000E+00
         474          462   0.00000000E+00
         474          463   0.00000000E+00
         474          464  -0.31658156E-05
         474          465   0.00000000E+00
         474          466   0.00000000E+00
         474          467   0.58143243E-08
         474          468   0.00000000E+00
         474          469   0.00000000E+00
         474          470   0.00000000E+00
         474          481   0.00000000E+00
         474          482   0.00000000E+00
         474          483   0.00000000E+00
         474          484  -0.47516374E-05
         474          485   0.00000000E+00
         474          486   0.00000000E+00
         474          487   0.87268382E-08
         474          488   0.00000000E+00
         474          489   0.00000000E+00
         474          490   0.00000000E+00
         475          475   0.19052837E+02
         475          471   0.00000000E+00
         475          472   0.63443872E+01
         475          473   0.00000000E+00
         475          474   0.19035065E+02
         475          476   0.00000000E+00
         475          477  -0.63477866E+02
         475          478   0.00000000E+00
         475          479   0.00000000E+00
         475          480   0.21795643E-05
         475          461   0.00000000E+00
         475          462   0.00000000E+00
         475          463   0.00000000E+00
         475          464   0.00000000E+00
         475          465  -0.42484263E-10
         475          466   0.00000000E+00
         475          467   0.16470995E-09
         475          468   0.00000000E+00
         475          469   0.00000000E+00
         475          470  -0.52197638E-14
         475          481   0.00000000E+00
         475          482   0.00000000E+00
         475          483   0.00000000E+00
         475          484   0.00000000E+00
         475          485  -0.63765499E-10
         475          486   0.00000000E+00
         475          487   0.24721653E-09
         475          488   0.00000000E+00
         475          489   0.00000000E+00
         475          490  -0.78344502E-14
         476          476   0.17074662E+04
         476          471   0.79884210E+02
         476          472   0.00000000E+00
         476          473   0.00000000E+00
         476          474   0.00000000E+00
         476          475   0.00000000E+00
         476          477   0.19543730E+04
         476          478   0.00000000E+00
         476          479   0.43198833E-04
         476          480   0.00000000E+00
         476          461  -0.19131143E-06
         476          462   0.00000000E+00
         476          463   0.00000000E+00
         476          464   0.00000000E+00
         476          465   0.00000000E+00
         476          466  -0.40891515E-05
         476          467  -0.46804608E-05
         476          468   0.00000000E+00
         476          469   0.00000000E+00
         476          470   0.00000000E+00
         476          481  -0.28714324E-06
         476          482   0.00000000E+00
         476          483   0.00000000E+00
         476          484   0.00000000E+00
         476          485   0.00000000E+00
         476          486  -0.61374911E-05
         476          487  -0.70249993E-05
         476          488   0.00000000E+00
         476          489   0.00000000E+00
         476          490   0.00000000E+00
         477          477   0.26723718E+04
         477          471   0.76117799E+02
         477          472  -0.21147957E+02
         477          473   0.00000000E+00
         477          474  -0.65878288E+02
         477          475  -0.63519108E+02
         477          476   0.19543478E+04
         477          478  -0.38887502E-04
         477          479  -0.12035985E+00
         477          480   0.49505150E-01
         477          461  -0.18229190E-06
         477          462   0.00000000E+00
         477          463   0.00000000E+00
         477          464   0.58149057E-08
         477          465   0.16475051E-09
         477          466  -0.46804005E-05
         477          467  -0.58937841E-05
         477          468   0.15713863E-13
         477          469   0.28826779E-09
         477          470  -0.11851393E-09
         477          481  -0.27360565E-06
         477          482   0.00000000E+00
         477          483   0.00000000E+00
         477          484   0.87277109E-08
         477          485   0.24727742E-09
         477          486  -0.70249088E-05
         477          487  -0.88461011E-05
         477          488   0.23585259E-13
         477          489   0.43266702E-09
         477          490  -0.17787999E-09
         478          478   0.66308262E-04
         478          471   0.00000000E+00
         478          472   0.00000000E+00
         478          473   0.00000000E+00
         478          474   0.00000000E+00
         478          475   0.00000000E+00
         478          476   0.00000000E+00
         478          477  -0.38896922E-04
         478          479  -0.14946245E-04
         478          480  -0.37051937E-04
         478          461   0.00000000E+00
         478          462   0.00000000E+00
         478          463   0.00000000E+00
         478          464   0.00000000E+00
         478          465   0.00000000E+00
         478          466   0.00000000E+00
         478          467   0.15715132E-13
         478          468  -0.23320539E-13
         478          469  -0.29226999E-14
         478          470   0.11296639E-13
         478          481   0.00000000E+00
         478          482   0.00000000E+00
         478          483   0.00000000E+00
         478          484   0.00000000E+00
         478          485   0.00000000E+00
         478          486   0.00000000E+00
         478          487   0.23587162E-13
         478          488  -0.35002274E-13
         478          489  -0.43867400E-14
         478          490   0.16955357E-13
         479          479   0.99356224E+02
         479          471   0.00000000E+00
         479          472   0.00000000E+00
         479          473   0.00000000E+00
         479          474   0.00000000E+00
         479          475   0.00000000E+00
         479          476   0.43198833E-04
         479          477  -0.12034781E+00
         479          478  -0.14942654E-04
         479          480   0.33536708E+02
         479          461   0.00000000E+00
         479          462   0.00000000E+00
         479          463   0.00000000E+00
         479          464   0.00000000E+00
         479          465   0.00000000E+00
         479          466   0.00000000E+00
         479          467   0.28823897E-09
         479          468  -0.29225903E-14
         479          469  -0.23794469E-06
         479          470  -0.80315889E-07
         479          481   0.00000000E+00
         479          482   0.00000000E+00
         479          483   0.00000000E+00
         479          484   0.00000000E+00
         479          485   0.00000000E+00
         479          486   0.00000000E+00
         479          487   0.43262376E-09
         479          488  -0.43865755E-14
         479          489  -0.35713606E-06
         479          490  -0.12054776E-06
         480          480   0.13484933E+05
         480          471   0.36307130E+04
         480          472   0.24834091E+03
         480          473   0.00000000E+00
         480          474   0.00000000E+00
         480          475   0.21795340E-05
         480          476   0.00000000E+00
         480          477   0.49505150E-01
         480          478  -0.37042339E-04
         480          479   0.33536708E+02
         480          461  -0.86950688E-05
         480          462  -0.59474313E-06
         480          463   0.00000000E+00
         480          464   0.00000000E+00
         480          465  -0.52196912E-14
         480          466   0.00000000E+00
         480          467  -0.11851393E-09
         480          468   0.11294945E-13
         480          469  -0.80315889E-07
         480          470  -0.32294601E-04
         480          481  -0.13050607E-04
         480          482  -0.89266212E-06
         480          483   0.00000000E+00
         480          484   0.00000000E+00
         480          485  -0.78343413E-14
         480          486   0.00000000E+00
         480          487  -0.17787999E-09
         480          488   0.16952814E-13
         480          489  -0.12054776E-06
         480          490  -0.48471627E-04
         481          481   0.97945219E+04
         481          482   0.00000000E+00
         481          483   0.00000000E+00
         481          484   0.00000000E+00
         481          485   0.00000000E+00
         481          486   0.79884210E+02
         481          487   0.76117799E+02
         481          488   0.00000000E+00
         481          489   0.00000000E+00
         481          490   0.36307130E+04
         481          471  -0.23456563E-04
         481          472   0.00000000E+00
         481          473   0.00000000E+00
         481          474   0.00000000E+00
         481          475   0.00000000E+00
         481          476  -0.19131143E-06
         481          477  -0.18229190E-06
         481          478   0.00000000E+00
         481          479   0.00000000E+00
         481          480  -0.86950688E-05
         481          491  -0.35206435E-04
         481          492   0.00000000E+00
         481          493   0.00000000E+00
         481          494   0.00000000E+00
         481          495   0.00000000E+00
         481          496  -0.28714324E-06
         481          497  -0.27360565E-06
         481          498   0.00000000E+00
         481          499   0.00000000E+00
         481          500  -0.13050607E-04
         482          482   0.61664984E+04
         482          481   0.00000000E+00
         482          483   0.00000000E+00
         482          484   0.63450217E+01
         482          485   0.63450217E+01
         482          486   0.00000000E+00
         482          487  -0.21136331E+02
         482          488   0.00000000E+00
         482          489   0.00000000E+00
         482          490   0.24834091E+03
         482          471   0.00000000E+00
         482          472  -0.14762871E-04
         482          473   0.00000000E+00
         482          474   0.00000000E+00
         482          475   0.00000000E+00
         482          476   0.00000000E+00
         482          477   0.00000000E+00
         482          478   0.00000000E+00
         482          479   0.00000000E+00
         482          480  -0.59474313E-06
         482          491   0.00000000E+00
         482          492  -0.22157895E-04
         482          493   0.00000000E+00
         482          494   0.00000000E+00
         482          495   0.00000000E+00
         482          496   0.00000000E+00
         482          497   0.00000000E+00
         482          498   0.00000000E+00
         482          499   0.00000000E+00
         482          500  -0.89266212E-06
         483          483   0.78082192E+03
         483          481   0.00000000E+00
         483          482   0.00000000E+00
         483          484   0.00000000E+00
         483          485   0.00000000E+00
         483          486   0.00000000E+00
         483          487   0.00000000E+00
         483          488   0.00000000E+00
         483          489   0.00000000E+00
         483          490   0.00000000E+00
         483          471   0.00000000E+00
         483          472   0.00000000E+00
         483          473  -0.18699636E-05
         483          474   0.00000000E+00
         483          475   0.00000000E+00
         483          476   0.00000000E+00
         483          477   0.00000000E+00
         483          478   0.00000000E+00
         483          479   0.00000000E+00
         483          480   0.00000000E+00
         483          491   0.00000000E+00
         483          492   0.00000000E+00
         483          493  -0.28066666E-05
         483          494   0.00000000E+00
         483          495   0.00000000E+00
         483          496   0.00000000E+00
         483          497   0.00000000E+00
         483          498   0.00000000E+00
         483          499   0.00000000E+00
         483          500   0.00000000E+00
         484          484   0.13409529E+04
         484          481   0.00000000E+00
         484          482   0.63443872E+01
         484          483   0.00000000E+00
         484          485   0.19035065E+02
         484          486   0.00000000E+00
         484          487  -0.65836821E+02
         484          488   0.00000000E+00
         484          489   0.00000000E+00
         484          490   0.00000000E+00
         484          471   0.00000000E+00
         484          472   0.00000000E+00
         484          473   0.00000000E+00
         484          474  -0.31658156E-05
         484          475   0.00000000E+00
         484          476   0.00000000E+00
         484          477   0.58143243E-08
         484          478   0.00000000E+00
         484          479   0.00000000E+00
         484          480   0.00000000E+00
         484          491   0.00000000E+00
         484          492   0.00000000E+00
         484          493   0.00000000E+00
         484          494  -0.47516374E-05
         484          495   0.00000000E+00
         484          496   0.00000000E+00
         484          497   0.87268382E-08
         484          498   0.00000000E+00
         484          499   0.00000000E+00
         484          500   0.00000000E+00
         485          485   0.19052837E+02
         485          481   0.00000000E+00
         485          482   0.63443872E+01
         485          483   0.00000000E+00
         485          484   0.19035065E+02
         485          486   0.00000000E+00
         485          487  -0.63477866E+02
         485          488   0.00000000E+00
         485          489   0.00000000E+00
         485          490   0.21795643E-05
         485          471   0.00000000E+00
         485          472   0.00000000E+00
         485          473   0.00000000E+00
         485          474   0.00000000E+00
         485          475  -0.42484263E-10
         485          476   0.00000000E+00
         485          477   0.16470995E-09
         485          478   0.00000000E+00
         485          479   0.00000000E+00
         485          480  -0.52197638E-14
         485          491   0.00000000E+00
         485          492   0.00000000E+00
         485          493   0.00000000E+00
         485          494   0.00000000E+00
         485          495  -0.63765499E-10
         485          496   0.00000000E+00
         485          497   0.24721653E-09
         485          498   0.00000000E+00
         485          499   0.00000000E+00
         485          500  -0.78344502E-14
         486          486   0.17074662E+04
         486          481   0.79884210E+02
         486          482   0.00000000E+00
         486          483   0.00000000E+00
         486          484   0.00000000E+00
         486          485   0.00000000E+00
         486          487   0.19543730E+04
         486          488   0.00000000E+00
         486          489   0.43198833E-04
         486          490   0.00000000E+00
         486          471  -0.19131143E-06
         486          472   0.00000000E+00
         486          473   0.00000000E+00
         486          474   0.00000000E+00
         486          475   0.00000000E+00
         486          476  -0.40891515E-05
         486          477  -0.46804608E-05
         486          478   0.00000000E+00
         486          479   0.00000000E+00
         486          480   0.00000000E+00
         486          491  -0.28714324E-06
         486          492   0.00000000E+00
         486          493   0.00000000E+00
         486          494   0.00000000E+00
         486          495   0.00000000E+00
         486          496  -0.61374911E-05
         486          497  -0.70249993E-05
         486          498   0.00000000E+00
         486          499   0.00000000E+00
         486          500   0.00000000E+00
         487          487   0.26723718E+04
         487          481   0.76117799E+02
         487          482  -0.21147957E+02
         487          483   0.00000000E+00
         487          484  -0.65878288E+02
         487          485  -0.63519108E+02
         487          486   0.19543478E+04
         487          488  -0.38887502E-04
         487          489  -0.12035985E+00
         487          490   0.49505150E-01
         487          471  -0.18229190E-06
         487          472   0.00000000E+00
         487          473   0.00000000E+00
         487          474   0.58149057E-08
         487          475   0.16475051E-09
         487          476  -0.46804005E-05
         487          477  -0.58937841E-05
         487          478   0.15713863E-13
         487          479   0.28826779E-09
         487          480  -0.11851393E-09
         487          491  -0.27360565E-06
         487          492   0.00000000E+00
         487          493   0.00000000E+00
         487          494   0.87277109E-08
         487          495   0.24727742E-09
         487          496  -0.70249088E-05
         487          497  -0.88461011E-05
         487          498   0.23585259E-13
         487          499   0.43266702E-09
         487          500  -0.17787999E-09
         488          488   0.66308262E-04
         488          481   0.00000000E+00
         488          482   0.00000000E+00
         488          483   0.00000000E+00
         488          484   0.00000000E+00
         488          485   0.00000000E+00
         488          486   0.00000000E+00
         488          487  -0.38896922E-04
         488          489  -0.14946245E-04
         488          490  -0.37051937E-04
         488          471   0.00000000E+00
         488          472   0.00000000E+00
         488          473   0.00000000E+00
         488          474   0.00000000E+00
         488          475   0.00000000E+00
         488          476   0.00000000E+00
         488          477   0.15715132E-13
         488          478  -0.23320539E-13
         488          479  -0.29226999E-14
         488          480   0.11296639E-13
         488          491   0.00000000E+00
         488          492   0.00000000E+00
         488          493   0.00000000E+00
         488          494   0.00000000E+00
         488          495   0.00000000E+00
         488          496   0.00000000E+00
         488          497   0.23587162E-13
         488          498  -0.35002274E-13
         488          499  -0.43867400E-14
         488          500   0.16955357E-13
         489          489   0.99356224E+02
         489          481   0.00000000E+00
         489          482   0.00000000E+00
         489          483   0.00000000E+00
         489          484   0.00000000E+00
         489          485   0.00000000E+00
         489          486   0.43198833E-04
         489          487  -0.12034781E+00
         489          488  -0.14942654E-04
         489          490   0.33536708E+02
         489          471   0.00000000E+00
         489          472   0.00000000E+00
         489          473   0.00000000E+00
         489          474   0.00000000E+00
         489          475   0.00000000E+00
         489          476   0.00000000E+00
         489          477   0.28823897E-09
         489          478  -0.29225903E-14
         489          479  -0.23794469E-06
         489          480  -0.80315889E-07
         489          491   0.00000000E+00
         489          492   0.00000000E+00
         489          493   0.00000000E+00
         489          494   0.00000000E+00
         489          495   0.00000000E+00
         489          496   0.00000000E+00
         489          497   0.43262376E-09
         489          498  -0.43865755E-14
         489          499  -0.35713606E-06
         489          500  -0.12054776E-06
         490          490   0.13484933E+05
         490          481   0.36307130E+04
         490          482   0.24834091E+03
         490          483   0.00000000E+00
         490          484   0.00000000E+00
         490          485   0.21795340E-05
         490          486   0.00000000E+00
         490          487   0.49505150E-01
         490          488  -0.37042339E-04
         490          489   0.33536708E+02
         490          471  -0.86950688E-05
         490          472  -0.59474313E-06
         490          473   0.00000000E+00
         490          474   0.00000000E+00
         490          475  -0.52196912E-14
         490          476   0.00000000E+00
         490          477  -0.11851393E-09
         490          478   0.11294945E-13
         490          479  -0.80315889E-07
         490          480  -0.32294601E-04
         490          491  -0.13050607E-04
         490          492  -0.89266212E-06
         490          493   0.00000000E+00
         490          494   0.00000000E+00
         490          495  -0.78343413E-14
         490          496   0.00000000E+00
         490          497  -0.17787999E-09
         490          498   0.16952814E-13
         490          499  -0.12054776E-06
         490          500  -0.48471627E-04
         491          491   0.97945219E+04
         491          492   0.00000000E+00
         491          493   0.00000000E+00
         491          494   0.00000000E+00
         491          495   0.00000000E+00
         491          496   0.79884210E+02
         491          497   0.76117799E+02
         491          498   0.00000000E+00
         491          499   0.00000000E+00
         491          500   0.36307130E+04
         491          481  -0.23456563E-04
         491          482   0.00000000E+00
         491          483   0.00000000E+00
         491          484   0.00000000E+00
         491          485   0.00000000E+00
         491          486  -0.19131143E-06
         491          487  -0.18229190E-06
         491          488   0.00000000E+00
         491          489   0.00000000E+00
         491          490  -0.86950688E-05
         491          501  -0.35206435E-04
         491          502   0.00000000E+00
         491          503   0.00000000E+00
         491          504   0.00000000E+00
         491          505   0.00000000E+00
         491          506  -0.28714324E-06
         491          507  -0.27360565E-06
         491          508   0.00000000E+00
         491          509   0.00000000E+00
         491          510  -0.13050607E-04
         492          492   0.61664984E+04
         492          491   0.00000000E+00
         492          493   0.00000000E+00
         492          494   0.63450217E+01
         492          495   0.63450217E+01
         492          496   0.00000000E+00
         492          497  -0.21136331E+02
         492          498   0.00000000E+00
         492          499   0.00000000E+00
         492          500   0.24834091E+03
         492          481   0.00000000E+00
         492          482  -0.14762871E-04
         492          483   0.00000000E+00
         492          484   0.00000000E+00
         492          485   0.00000000E+00
         492          486   0.00000000E+00
         492          487   0.00000000E+00
         492          488   0.00000000E+00
         492          489   0.00000000E+00
         492          490  -0.59474313E-06
         492          501   0.00000000E+00
         492          502  -0.22157895E-04
         492          503   0.00000000E+00
         492          504   0.00000000E+00
         492          505   0.00000000E+00
         492          506   0.00000000E+00
         492          507   0.00000000E+00
         492          508   0.00000000E+00
         492          509   0.00000000E+00
         492          510  -0.89266212E-06
         493          493   0.78082192E+03
         493          491   0.00000000E+00
         493          492   0.00000000E+00
         493          494   0.00000000E+00
         493          495   0.00000000E+00
         493          496   0.00000000E+00
         493          497   0.00000000E+00
         493          498   0.00000000E+00
         493          499   0.00000000E+00
         493          500   0.00000000E+00
         493          481   0.00000000E+00
         493          482   0.00000000E+00
         493          483  -0.18699636E-05
         493          484   0.00000000E+00
         493          485   0.00000000E+00
         493          486   0.00000000E+00
         493          487   0.00000000E+00
         493          488   0.00000000E+00
         493          489   0.00000000E+00
         493          490   0.00000000E+00
         493          501   0.00000000E+00
         493          502   0.00000000E+00
         493          503  -0.28066666E-05
         493          504   0.00000000E+00
         493          505   0.00000000E+00
         493          506   0.00000000E+00
         493          507   0.00000000E+00
         493          508   0.00000000E+00
         493          509   0.00000000E+00
         493          510   0.00000000E+00
         494          494   0.13409529E+04
         494          491   0.00000000E+00
         494          492   0.63443872E+01
         494          493   0.00000000E+00
         494          495   0.19035065E+02
         494          496   0.00000000E+00
         494          497  -0.65836821E+02
         494          498   0.00000000E+00
         494          499   0.00000000E+00
         494          500   0.00000000E+00
         494          481   0.00000000E+00
         494          482   0.00000000E+00
         494          483   0.00000000E+00
         494          484  -0.31658156E-05
         494          485   0.00000000E+00
         494          486   0.00000000E+00
         494          487   0.58143243E-08
         494          488   0.00000000E+00
         494          489   0.00000000E+00
         494          490   0.00000000E+00
         494          501   0.00000000E+00
         494          502   0.00000000E+00
         494          503   0.00000000E+00
         494          504  -0.47516374E-05
         494          505   0.00000000E+00
         494          506   0.00000000E+00
         494          507   0.87268382E-08
         494          508   0.00000000E+00
         494          509   0.00000000E+00
         494          510   0.00000000E+00
         495          495   0.19052837E+02
         495          491   0.00000000E+00
         495          492   0.63443872E+01
         495          493   0.00000000E+00
         495          494   0.19035065E+02
         495          496   0.00000000E+00
         495          497  -0.63477866E+02
         495          498   0.00000000E+00
         495          499   0.00000000E+00
         495          500   0.21795643E-05
         495          481   0.00000000E+00
         495          482   0.00000000E+00
         495          483   0.00000000E+00
         495          484   0.00000000E+00
         495          485  -0.42484263E-10
         495          486   0.00000000E+00
         495          487   0.16470995E-09
         495          488   0.00000000E+00
         495          489   0.00000000E+00
         495          490  -0.52197638E-14
         495          501   0.00000000E+00
         495          502   0.00000000E+00
         495          503   0.00000000E+00
         495          504   0.00000000E+00
         495          505  -0.63765499E-10
         495          506   0.00000000E+00
         495          507   0.24721653E-09
         495          508   0.00000000E+00
         495          509   0.00000000E+00
         495          510  -0.78344502E-14
         496          496   0.17074662E+04
         496          491   0.79884210E+02
         496          492   0.00000000E+00
         496          493   0.00000000E+00
         496          494   0.00000000E+00
         496          495   0.00000000E+00
         496          497   0.19543730E+04
         496          498   0.00000000E+00
         496          499   0.43198833E-04
         496          500   0.00000000E+00
         496          481  -0.19131143E-06
         496          482   0.00000000E+00
         496          483   0.00000000E+00
         496          484   0.00000000E+00
         496          485   0.00000000E+00
         496          486  -0.40891515E-05
         496          487  -0.46804608E-05
         496          488   0.00000000E+00
         496          489   0.00000000E+00
         496          490   0.00000000E+00
         496          501  -0.28714324E-06
         496          502   0.00000000E+00
         496          503   0.00000000E+00
         496          504   0.00000000E+00
         496          505   0.00000000E+00
         496          506  -0.61374911E-05
         496          507  -0.70249993E-05
         496          508   0.00000000E+00
         496          509   0.00000000E+00
         496          510   0.00000000E+00
         497          497   0.26723718E+04
         497          491   0.76117799E+02
         497          492  -0.21147957E+02
         497          493   0.00000000E+00
         497          494  -0.65878288E+02
         497          495  -0.63519108E+02
         497          496   0.19543478E+04
         497          498  -0.38887502E-04
         497          499  -0.12035985E+00
         497          500   0.49505150E-01
         497          481  -0.18229190E-06
         497          482   0.00000000E+00
         497          483   0.00000000E+00
         497          484   0.58149057E-08
         497          485   0.16475051E-09
         497          486  -0.46804005E-05
         497          487  -0.58937841E-05
         497          488   0.15713863E-13
         497          489   0.28826779E-09
         497          490  -0.11851393E-09
         497          501  -0.27360565E-06
         497          502   0.00000000E+00
         497          503   0.00000000E+00
         497          504   0.87277109E-08
         497          505   0.24727742E-09
         497          506  -0.70249088E-05
         497          507  -0.88461011E-05
         497          508   0.23585259E-13
         497          509   0.43266702E-09
         497          510  -0.17787999E-09
         498          498   0.66308262E-04
         498          491   0.00000000E+00
         498          492   0.00000000E+00
         498          493   0.00000000E+00
         498          494   0.00000000E+00
         498          495   0.00000000E+00
         498          496   0.00000000E+00
         498          497  -0.38896922E-04
         498          499  -0.14946245E-04
         498          500  -0.37051937E-04
         498          481   0.00000000E+00
         498          482   0.00000000E+00
         498          483   0.00000000E+00
         498          484   0.00000000E+00
         498          485   0.00000000E+00
         498          486   0.00000000E+00
         498          487   0.15715132E-13
         498          488  -0.23320539E-13
         498          489  -0.29226999E-14
         498          490   0.11296639E-13
         498          501   0.00000000E+00
         498          502   0.00000000E+00
         498          503   0.00000000E+00
         498          504   0.00000000E+00
         498          505   0.00000000E+00
         498          506   0.00000000E+00
         498          507   0.23587162E-13
         498          508  -0.35002274E-13
         498          509  -0.43867400E-14
         498          510   0.16955357E-13
         499          499   0.99356224E+02
         499          491   0.00000000E+00
         499          492   0.00000000E+00
         499          493   0.00000000E+00
         499          494   0.00000000E+00
         499          495   0.00000000E+00
         499          496   0.43198833E-04
         499          497  -0.12034781E+00
         499          498  -0.14942654E-04
         499          500   0.33536708E+02
         499          481   0.00000000E+00
         499          482   0.00000000E+00
         499          483   0.00000000E+00
         499          484   0.00000000E+00
         499          485   0.00000000E+00
         499          486   0.00000000E+00
         499          487   0.28823897E-09
         499          488  -0.29225903E-14
         499          489  -0.23794469E-06
         499          490  -0.80315889E-07
         499          501   0.00000000E+00
         499          502   0.00000000E+00
         499          503   0.00000000E+00
         499          504   0.00000000E+00
         499          505   0.00000000E+00
         499          506   0.00000000E+00
         499          507   0.43262376E-09
         499          508  -0.43865755E-14
         499          509  -0.35713606E-06
         499          510  -0.12054776E-06
         500          500   0.13484933E+05
         500          491   0.36307130E+04
         500          492   0.24834091E+03
         500          493   0.00000000E+00
         500          494   0.00000000E+00
         500          495   0.21795340E-05
         500          496   0.00000000E+00
         500          497   0.49505150E-01
         500          498  -0.37042339E-04
         500          499   0.33536708E+02
         500          481  -0.86950688E-05
         500          482  -0.59474313E-06
         500          483   0.00000000E+00
         500          484   0.00000000E+00
         500          485  -0.52196912E-14
         500          486   0.00000000E+00
         500          487  -0.11851393E-09
         500          488   0.11294945E-13
         500          489  -0.80315889E-07
         500          490  -0.32294601E-04
         500          501  -0.13050607E-04
         500          502  -0.89266212E-06
         500          503   0.00000000E+00
         500          504   0.00000000E+00
         500          505  -0.78343413E-14
         500          506   0.00000000E+00
         500          507  -0.17787999E-09
         500          508   0.16952814E-13
         500          509  -0.12054776E-06
         500          510  -0.48471627E-04
         501          501   0.97945219E+04
         501          502   0.00000000E+00
         501          503   0.00000000E+00
         501          504   0.00000000E+00
         501          505   0.00000000E+00
         501          506   0.79884210E+02
         501          507   0.76117799E+02
         501          508   0.00000000E+00
         501          509   0.00000000E+00
         501          510   0.36307130E+04
         501          491  -0.23456563E-04
         501          492   0.00000000E+00
         501          493   0.00000000E+00
         501          494   0.00000000E+00
         501          495   0.00000000E+00
         501          496  -0.19131143E-06
         501          497  -0.18229190E-06
         501          498   0.00000000E+00
         501          499   0.00000000E+00
         501          500  -0.86950688E-05
         501          511  -0.34866638E-04
         501          512   0.00000000E+00
         501          513   0.00000000E+00
         501          514   0.00000000E+00
         501          515   0.00000000E+00
         501          516  -0.28437186E-06
         501          517  -0.27096493E-06
         501          518   0.00000000E+00
         501          519   0.00000000E+00
         501          520  -0.12924648E-04
         502          502   0.61664984E+04
         502          501   0.00000000E+00
         502          503   0.00000000E+00
         502          504   0.63450217E+01
         502          505   0.63450217E+01
         502          506   0.00000000E+00
         502          507  -0.21136331E+02
         502          508   0.00000000E+00
         502          509   0.00000000E+00
         502          510   0.24834091E+03
         502          491   0.00000000E+00
         502          492  -0.14762871E-04
         502          493   0.00000000E+00
         502          494   0.00000000E+00
         502          495   0.00000000E+00
         502          496   0.00000000E+00
         502          497   0.00000000E+00
         502          498   0.00000000E+00
         502          499   0.00000000E+00
         502          500  -0.59474313E-06
         502          511   0.00000000E+00
         502          512  -0.21944036E-04
         502          513   0.00000000E+00
         502          514   0.00000000E+00
         502          515   0.00000000E+00
         502          516   0.00000000E+00
         502          517   0.00000000E+00
         502          518   0.00000000E+00
         502          519   0.00000000E+00
         502          520  -0.88404654E-06
         503          503   0.78082192E+03
         503          501   0.00000000E+00
         503          502   0.00000000E+00
         503          504   0.00000000E+00
         503          505   0.00000000E+00
         503          506   0.00000000E+00
         503          507   0.00000000E+00
         503          508   0.00000000E+00
         503          509   0.00000000E+00
         503          510   0.00000000E+00
         503          491   0.00000000E+00
         503          492   0.00000000E+00
         503          493  -0.18699636E-05
         503          494   0.00000000E+00
         503          495   0.00000000E+00
         503          496   0.00000000E+00
         503          497   0.00000000E+00
         503          498   0.00000000E+00
         503          499   0.00000000E+00
         503          500   0.00000000E+00
         503          511   0.00000000E+00
         503          512   0.00000000E+00
         503          513  -0.27795779E-05
         503          514   0.00000000E+00
         503          515   0.00000000E+00
         503          516   0.00000000E+00
         503          517   0.00000000E+00
         503          518   0.00000000E+00
         503          519   0.00000000E+00
         503          520   0.00000000E+00
         504          504   0.13409529E+04
         504          501   0.00000000E+00
         504          502   0.63443872E+01
         504          503   0.00000000E+00
         504          505   0.19035065E+02
         504          506   0.00000000E+00
         504          507  -0.65836821E+02
         504          508   0.00000000E+00
         504          509   0.00000000E+00
         504          510   0.00000000E+00
         504          491   0.00000000E+00
         504          492   0.00000000E+00
         504          493   0.00000000E+00
         504          494  -0.31658156E-05
         504          495   0.00000000E+00
         504          496   0.00000000E+00
         504          497   0.58143243E-08
         504          498   0.00000000E+00
         504          499   0.00000000E+00
         504          500   0.00000000E+00
         504          511   0.00000000E+00
         504          512   0.00000000E+00
         504          513   0.00000000E+00
         504          514  -0.47057767E-05
         504          515   0.00000000E+00
         504          516   0.00000000E+00
         504          517   0.86426107E-08
         504          518   0.00000000E+00
         504          519   0.00000000E+00
         504          520   0.00000000E+00
         505          505   0.19052837E+02
         505          501   0.00000000E+00
         505          502   0.63443872E+01
         505          503   0.00000000E+00
         505          504   0.19035065E+02
         505          506   0.00000000E+00
         505          507  -0.63477866E+02
         505          508   0.00000000E+00
         505          509   0.00000000E+00
         505          510   0.21795643E-05
         505          491   0.00000000E+00
         505          492   0.00000000E+00
         505          493   0.00000000E+00
         505          494   0.00000000E+00
         505          495  -0.42484263E-10
         505          496   0.00000000E+00
         505          497   0.16470995E-09
         505          498   0.00000000E+00
         505          499   0.00000000E+00
         505          500  -0.52197638E-14
         505          511   0.00000000E+00
         505          512   0.00000000E+00
         505          513   0.00000000E+00
         505          514   0.00000000E+00
         505          515  -0.63150063E-10
         505          516   0.00000000E+00
         505          517   0.24483050E-09
         505          518   0.00000000E+00
         505          519   0.00000000E+00
         505          520  -0.77588356E-14
         506          506   0.17074662E+04
         506          501   0.79884210E+02
         506          502   0.00000000E+00
         506          503   0.00000000E+00
         506          504   0.00000000E+00
         506          505   0.00000000E+00
         506          507   0.19543730E+04
         506          508   0.00000000E+00
         506          509   0.43198833E-04
         506          510   0.00000000E+00
         506          491  -0.19131143E-06
         506          492   0.00000000E+00
         506          493   0.00000000E+00
         506          494   0.00000000E+00
         506          495   0.00000000E+00
         506          496  -0.40891515E-05
         506          497  -0.46804608E-05
         506          498   0.00000000E+00
         506          499   0.00000000E+00
         506          500   0.00000000E+00
         506          511  -0.28437186E-06
         506          512   0.00000000E+00
         506          513   0.00000000E+00
         506          514   0.00000000E+00
         506          515   0.00000000E+00
         506          516  -0.60783450E-05
         506          517  -0.69573775E-05
         506          518   0.00000000E+00
         506          519   0.00000000E+00
         506          520   0.00000000E+00
         507          507   0.26723718E+04
         507          501   0.76117799E+02
         507          502  -0.21147957E+02
         507          503   0.00000000E+00
         507          504  -0.65878288E+02
         507          505  -0.63519108E+02
         507          506   0.19543478E+04
         507          508  -0.38887502E-04
         507          509  -0.12035985E+00
         507          510   0.49505150E-01
         507          491  -0.18229190E-06
         507          492   0.00000000E+00
         507          493   0.00000000E+00
         507          494   0.58149057E-08
         507          495   0.16475051E-09
         507          496  -0.46804005E-05
         507          497  -0.58937841E-05
         507          498   0.15713863E-13
         507          499   0.28826779E-09
         507          500  -0.11851393E-09
         507          511  -0.27096493E-06
         507          512   0.00000000E+00
         507          513   0.00000000E+00
         507          514   0.86434749E-08
         507          515   0.24489081E-09
         507          516  -0.69572878E-05
         507          517  -0.87610832E-05
         507          518   0.23357624E-13
         507          519   0.42849111E-09
         507          520  -0.17616317E-09
         508          508   0.66308262E-04
         508          501   0.00000000E+00
         508          502   0.00000000E+00
         508          503   0.00000000E+00
         508          504   0.00000000E+00
         508          505   0.00000000E+00
         508          506   0.00000000E+00
         508          507  -0.38896922E-04
         508          509  -0.14946245E-04
         508          510  -0.37051937E-04
         508          491   0.00000000E+00
         508          492   0.00000000E+00
         508          493   0.00000000E+00
         508          494   0.00000000E+00
         508          495   0.00000000E+00
         508          496   0.00000000E+00
         508          497   0.15715132E-13
         508          498  -0.23320539E-13
         508          499  -0.29226999E-14
         508          500   0.11296639E-13
         508          511   0.00000000E+00
         508          512   0.00000000E+00
         508          513   0.00000000E+00
         508          514   0.00000000E+00
         508          515   0.00000000E+00
         508          516   0.00000000E+00
         508          517   0.23359510E-13
         508          518  -0.34664447E-13
         508          519  -0.43444012E-14
         508          520   0.16791712E-13
         509          509   0.99356224E+02
         509          501   0.00000000E+00
         509          502   0.00000000E+00
         509          503   0.00000000E+00
         509          504   0.00000000E+00
         509          505   0.00000000E+00
         509          506   0.43198833E-04
         509          507  -0.12034781E+00
         509          508  -0.14942654E-04
         509          510   0.33536708E+02
         509          491   0.00000000E+00
         509          492   0.00000000E+00
         509          493   0.00000000E+00
         509          494   0.00000000E+00
         509          495   0.00000000E+00
         509          496   0.00000000E+00
         509          497   0.28823897E-09
         509          498  -0.29225903E-14
         509          499  -0.23794469E-06
         509          500  -0.80315889E-07
         509          511   0.00000000E+00
         509          512   0.00000000E+00
         509          513   0.00000000E+00
         509          514   0.00000000E+00
         509          515   0.00000000E+00
         509          516   0.00000000E+00
         509          517   0.42844827E-09
         509          518  -0.43442382E-14
         509          519  -0.35368914E-06
         509          520  -0.11938429E-06
         510          510   0.13484933E+05
         510          501   0.36307130E+04
         510          502   0.24834091E+03
         510          503   0.00000000E+00
         510          504   0.00000000E+00
         510          505   0.21795340E-05
         510          506   0.00000000E+00
         510          507   0.49505150E-01
         510          508  -0.37042339E-04
         510          509   0.33536708E+02
         510          491  -0.86950688E-05
         510          492  -0.59474313E-06
         510          493   0.00000000E+00
         510          494   0.00000000E+00
         510          495  -0.52196912E-14
         510          496   0.00000000E+00
         510          497  -0.11851393E-09
         510          498   0.11294945E-13
         510          499  -0.80315889E-07
         510          500  -0.32294601E-04
         510          511  -0.12924648E-04
         510          512  -0.88404654E-06
         510          513   0.00000000E+00
         510          514   0.00000000E+00
         510          515  -0.77587277E-14
         510          516   0.00000000E+00
         510          517  -0.17616317E-09
         510          518   0.16789193E-13
         510          519  -0.11938429E-06
         510          520  -0.48003801E-04
         511          511   0.97085203E+04
         511          512   0.00000000E+00
         511          513   0.00000000E+00
         511          514   0.00000000E+00
         511          515   0.00000000E+00
         511          516   0.79182782E+02
         511          517   0.75449441E+02
         511          518   0.00000000E+00
         511          519   0.00000000E+00
         511          520   0.35988332E+04
         511          501  -0.23116758E-04
         511          502   0.00000000E+00
         511          503   0.00000000E+00
         511          504   0.00000000E+00
         511          505   0.00000000E+00
         511          506  -0.18853999E-06
         511          507  -0.17965112E-06
         511          508   0.00000000E+00
         511          509   0.00000000E+00
         511          510  -0.85691072E-05
         511          521  -0.33492927E-04
         511          522   0.00000000E+00
         511          523   0.00000000E+00
         511          524   0.00000000E+00
         511          525   0.00000000E+00
         511          526  -0.27316790E-06
         511          527  -0.26028918E-06
         511          528   0.00000000E+00
         511          529   0.00000000E+00
         511          530  -0.12415430E-04
         512          512   0.61123716E+04
         512          511   0.00000000E+00
         512          513   0.00000000E+00
         512          514   0.63450217E+01
         512          515   0.63450217E+01
         512          516   0.00000000E+00
         512          517  -0.21136331E+02
         512          518   0.00000000E+00
         512          519   0.00000000E+00
         512          520   0.24616034E+03
         512          501   0.00000000E+00
         512          502  -0.14549008E-04
         512          503   0.00000000E+00
         512          504   0.00000000E+00
         512          505   0.00000000E+00
         512          506   0.00000000E+00
         512          507   0.00000000E+00
         512          508   0.00000000E+00
         512          509   0.00000000E+00
         512          510  -0.58612735E-06
         512          521   0.00000000E+00
         512          522  -0.21079463E-04
         512          523   0.00000000E+00
         512          524   0.00000000E+00
         512          525   0.00000000E+00
         512          526   0.00000000E+00
         512          527   0.00000000E+00
         512          528   0.00000000E+00
         512          529   0.00000000E+00
         512          530  -0.84921600E-06
         513          513   0.77396585E+03
         513          511   0.00000000E+00
         513          512   0.00000000E+00
         513          514   0.00000000E+00
         513          515   0.00000000E+00
         513          516   0.00000000E+00
         513          517   0.00000000E+00
         513          518   0.00000000E+00
         513          519   0.00000000E+00
         513          520   0.00000000E+00
         513          501   0.00000000E+00
         513          502   0.00000000E+00
         513          503  -0.18428743E-05
         513          504   0.00000000E+00
         513          505   0.00000000E+00
         513          506   0.00000000E+00
         513          507   0.00000000E+00
         513          508   0.00000000E+00
         513          509   0.00000000E+00
         513          510   0.00000000E+00
         513          521   0.00000000E+00
         513          522   0.00000000E+00
         513          523  -0.26700653E-05
         513          524   0.00000000E+00
         513          525   0.00000000E+00
         513          526   0.00000000E+00
         513          527   0.00000000E+00
         513          528   0.00000000E+00
         513          529   0.00000000E+00
         513          530   0.00000000E+00
         514          514   0.13293457E+04
         514          511   0.00000000E+00
         514          512   0.63443872E+01
         514          513   0.00000000E+00
         514          515   0.19035065E+02
         514          516   0.00000000E+00
         514          517  -0.65815503E+02
         514          518   0.00000000E+00
         514          519   0.00000000E+00
         514          520   0.00000000E+00
         514          501   0.00000000E+00
         514          502   0.00000000E+00
         514          503   0.00000000E+00
         514          504  -0.31199538E-05
         514          505   0.00000000E+00
         514          506   0.00000000E+00
         514          507   0.57300948E-08
         514          508   0.00000000E+00
         514          509   0.00000000E+00
         514          510   0.00000000E+00
         514          521   0.00000000E+00
         514          522   0.00000000E+00
         514          523   0.00000000E+00
         514          524  -0.45203738E-05
         514          525   0.00000000E+00
         514          526   0.00000000E+00
         514          527   0.83021005E-08
         514          528   0.00000000E+00
         514          529   0.00000000E+00
         514          530   0.00000000E+00
         515          515   0.19052682E+02
         515          511   0.00000000E+00
         515          512   0.63443872E+01
         515          513   0.00000000E+00
         515          514   0.19035065E+02
         515          516   0.00000000E+00
         515          517  -0.63477262E+02
         515          518   0.00000000E+00
         515          519   0.00000000E+00
         515          520   0.21604265E-05
         515          501   0.00000000E+00
         515          502   0.00000000E+00
         515          503   0.00000000E+00
         515          504   0.00000000E+00
         515          505  -0.41868813E-10
         515          506   0.00000000E+00
         515          507   0.16232387E-09
         515          508   0.00000000E+00
         515          509   0.00000000E+00
         515          510  -0.51441474E-14
         515          521   0.00000000E+00
         515          522   0.00000000E+00
         515          523   0.00000000E+00
         515          524   0.00000000E+00
         515          525  -0.60662014E-10
         515          526   0.00000000E+00
         515          527   0.23518443E-09
         515          528   0.00000000E+00
         515          529   0.00000000E+00
         515          530  -0.74531453E-14
         516          516   0.16952312E+04
         516          511   0.79182782E+02
         516          512   0.00000000E+00
         516          513   0.00000000E+00
         516          514   0.00000000E+00
         516          515   0.00000000E+00
         516          517   0.19427279E+04
         516          518   0.00000000E+00
         516          519   0.43198833E-04
         516          520   0.00000000E+00
         516          501  -0.18853999E-06
         516          502   0.00000000E+00
         516          503   0.00000000E+00
         516          504   0.00000000E+00
         516          505   0.00000000E+00
         516          506  -0.40300040E-05
         516          507  -0.46128374E-05
         516          508   0.00000000E+00
         516          509   0.00000000E+00
         516          510   0.00000000E+00
         516          521  -0.27316790E-06
         516          522   0.00000000E+00
         516          523   0.00000000E+00
         516          524   0.00000000E+00
         516          525   0.00000000E+00
         516          526  -0.58600671E-05
         516          527  -0.67256715E-05
         516          528   0.00000000E+00
         516          529   0.00000000E+00
         516          530   0.00000000E+00
         517          517   0.26617937E+04
         517          511   0.75449441E+02
         517          512  -0.21147957E+02
         517          513   0.00000000E+00
         517          514  -0.65856969E+02
         517          515  -0.63518504E+02
         517          516   0.19427027E+04
         517          518  -0.38829888E-04
         517          519  -0.11930294E+00
         517          520   0.49070628E-01
         517          501  -0.17965112E-06
         517          502   0.00000000E+00
         517          503   0.00000000E+00
         517          504   0.57306678E-08
         517          505   0.16236385E-09
         517          506  -0.46127780E-05
         517          507  -0.58087642E-05
         517          508   0.15486223E-13
         517          509   0.28409178E-09
         517          510  -0.11679707E-09
         517          521  -0.26028918E-06
         517          522   0.00000000E+00
         517          523   0.00000000E+00
         517          524   0.83029307E-08
         517          525   0.23524235E-09
         517          526  -0.67255833E-05
         517          527  -0.85007207E-05
         517          528   0.22437357E-13
         517          529   0.41160899E-09
         517          530  -0.16922252E-09
         518          518   0.66222759E-04
         518          511   0.00000000E+00
         518          512   0.00000000E+00
         518          513   0.00000000E+00
         518          514   0.00000000E+00
         518          515   0.00000000E+00
         518          516   0.00000000E+00
         518          517  -0.38839304E-04
         518          519  -0.14956961E-04
         518          520  -0.37010518E-04
         518          501   0.00000000E+00
         518          502   0.00000000E+00
         518          503   0.00000000E+00
         518          504   0.00000000E+00
         518          505   0.00000000E+00
         518          506   0.00000000E+00
         518          507   0.15487474E-13
         518          508  -0.22982705E-13
         518          509  -0.28803600E-14
         518          510   0.11132990E-13
         518          521   0.00000000E+00
         518          522   0.00000000E+00
         518          523   0.00000000E+00
         518          524   0.00000000E+00
         518          525   0.00000000E+00
         518          526   0.00000000E+00
         518          527   0.22439168E-13
         518          528  -0.33298703E-13
         518          529  -0.41732361E-14
         518          530   0.16130135E-13
         519          519   0.98483819E+02
         519          511   0.00000000E+00
         519          512   0.00000000E+00
         519          513   0.00000000E+00
         519          514   0.00000000E+00
         519          515   0.00000000E+00
         519          516   0.43198833E-04
         519          517  -0.11929101E+00
         519          518  -0.14953370E-04
         519          520   0.33242236E+02
         519          501   0.00000000E+00
         519          502   0.00000000E+00
         519          503   0.00000000E+00
         519          504   0.00000000E+00
         519          505   0.00000000E+00
         519          506   0.00000000E+00
         519          507   0.28406338E-09
         519          508  -0.28802520E-14
         519          509  -0.23449770E-06
         519          510  -0.79152388E-07
         519          521   0.00000000E+00
         519          522   0.00000000E+00
         519          523   0.00000000E+00
         519          524   0.00000000E+00
         519          525   0.00000000E+00
         519          526   0.00000000E+00
         519          527   0.41156783E-09
         519          528  -0.41730796E-14
         519          529  -0.33975414E-06
         519          530  -0.11468067E-06
         520          520   0.13366527E+05
         520          511   0.35988332E+04
         520          512   0.24616034E+03
         520          513   0.00000000E+00
         520          514   0.00000000E+00
         520          515   0.21603965E-05
         520          516   0.00000000E+00
         520          517   0.49070628E-01
         520          518  -0.37000927E-04
         520          519   0.33242236E+02
         520          501  -0.85691072E-05
         520          502  -0.58612735E-06
         520          503   0.00000000E+00
         520          504   0.00000000E+00
         520          505  -0.51440759E-14
         520          506   0.00000000E+00
         520          507  -0.11679707E-09
         520          508   0.11131320E-13
         520          509  -0.79152388E-07
         520          510  -0.31826764E-04
         520          521  -0.12415430E-04
         520          522  -0.84921600E-06
         520          523   0.00000000E+00
         520          524   0.00000000E+00
         520          525  -0.74530416E-14
         520          526   0.00000000E+00
         520          527  -0.16922252E-09
         520          528   0.16127716E-13
         520          529  -0.11468067E-06
         520          530  -0.46112499E-04
         521          521   0.94375150E+04
         521          522   0.00000000E+00
         521          523   0.00000000E+00
         521          524   0.00000000E+00
         521          525   0.00000000E+00
         521          526   0.76972466E+02
         521          527   0.73343332E+02
         521          528   0.00000000E+00
         521          529   0.00000000E+00
         521          530   0.34983748E+04
         521          511  -0.21743131E-04
         521          512   0.00000000E+00
         521          513   0.00000000E+00
         521          514   0.00000000E+00
         521          515   0.00000000E+00
         521          516  -0.17733671E-06
         521          517  -0.16897603E-06
         521          518   0.00000000E+00
         521          519   0.00000000E+00
         521          520  -0.80599200E-05
         521          531  -0.31421328E-04
         521          532   0.00000000E+00
         521          533   0.00000000E+00
         521          534   0.00000000E+00
         521          535   0.00000000E+00
         521          536  -0.25627196E-06
         521          537  -0.24418981E-06
         521          538   0.00000000E+00
         521          539   0.00000000E+00
         521          540  -0.11647512E-04
         522          522   0.59418088E+04
         522          521   0.00000000E+00
         522          523   0.00000000E+00
         522          524   0.63450217E+01
         522          525   0.63450217E+01
         522          526   0.00000000E+00
         522          527  -0.21136331E+02
         522          528   0.00000000E+00
         522          529   0.00000000E+00
         522          530   0.23928897E+03
         522          511   0.00000000E+00
         522          512  -0.13684487E-04
         522          513   0.00000000E+00
         522          514   0.00000000E+00
         522          515   0.00000000E+00
         522          516   0.00000000E+00
         522          517   0.00000000E+00
         522          518   0.00000000E+00
         522          519   0.00000000E+00
         522          520  -0.55129892E-06
         522          531   0.00000000E+00
         522          532  -0.19775659E-04
         522          533   0.00000000E+00
         522          534   0.00000000E+00
         522          535   0.00000000E+00
         522          536   0.00000000E+00
         522          537   0.00000000E+00
         522          538   0.00000000E+00
         522          539   0.00000000E+00
         522          540  -0.79669041E-06
         523          523   0.75236123E+03
         523          521   0.00000000E+00
         523          522   0.00000000E+00
         523          524   0.00000000E+00
         523          525   0.00000000E+00
         523          526   0.00000000E+00
         523          527   0.00000000E+00
         523          528   0.00000000E+00
         523          529   0.00000000E+00
         523          530   0.00000000E+00
         523          511   0.00000000E+00
         523          512   0.00000000E+00
         523          513  -0.17333684E-05
         523          514   0.00000000E+00
         523          515   0.00000000E+00
         523          516   0.00000000E+00
         523          517   0.00000000E+00
         523          518   0.00000000E+00
         523          519   0.00000000E+00
         523          520   0.00000000E+00
         523          531   0.00000000E+00
         523          532   0.00000000E+00
         523          533  -0.25049169E-05
         523          534   0.00000000E+00
         523          535   0.00000000E+00
         523          536   0.00000000E+00
         523          537   0.00000000E+00
         523          538   0.00000000E+00
         523          539   0.00000000E+00
         523          540   0.00000000E+00
         524          524   0.12927695E+04
         524          521   0.00000000E+00
         524          522   0.63443872E+01
         524          523   0.00000000E+00
         524          525   0.19035065E+02
         524          526   0.00000000E+00
         524          527  -0.65748327E+02
         524          528   0.00000000E+00
         524          529   0.00000000E+00
         524          530   0.00000000E+00
         524          511   0.00000000E+00
         524          512   0.00000000E+00
         524          513   0.00000000E+00
         524          514  -0.29345622E-05
         524          515   0.00000000E+00
         524          516   0.00000000E+00
         524          517   0.53896053E-08
         524          518   0.00000000E+00
         524          519   0.00000000E+00
         524          520   0.00000000E+00
         524          531   0.00000000E+00
         524          532   0.00000000E+00
         524          533   0.00000000E+00
         524          534  -0.42407803E-05
         524          535   0.00000000E+00
         524          536   0.00000000E+00
         524          537   0.77886002E-08
         524          538   0.00000000E+00
         524          539   0.00000000E+00
         524          540   0.00000000E+00
         525          525   0.19052191E+02
         525          521   0.00000000E+00
         525          522   0.63443872E+01
         525          523   0.00000000E+00
         525          524   0.19035065E+02
         525          526   0.00000000E+00
         525          527  -0.63475359E+02
         525          528   0.00000000E+00
         525          529   0.00000000E+00
         525          530   0.21001200E-05
         525          511   0.00000000E+00
         525          512   0.00000000E+00
         525          513   0.00000000E+00
         525          514   0.00000000E+00
         525          515  -0.39380915E-10
         525          516   0.00000000E+00
         525          517   0.15267838E-09
         525          518   0.00000000E+00
         525          519   0.00000000E+00
         525          520  -0.48384757E-14
         525          531   0.00000000E+00
         525          532   0.00000000E+00
         525          533   0.00000000E+00
         525          534   0.00000000E+00
         525          535  -0.56909956E-10
         525          536   0.00000000E+00
         525          537   0.22063783E-09
         525          538   0.00000000E+00
         525          539   0.00000000E+00
         525          540  -0.69921544E-14
         526          526   0.16566769E+04
         526          521   0.76972466E+02
         526          522   0.00000000E+00
         526          523   0.00000000E+00
         526          524   0.00000000E+00
         526          525   0.00000000E+00
         526          527   0.19060324E+04
         526          528   0.00000000E+00
         526          529   0.43198833E-04
         526          530   0.00000000E+00
         526          511  -0.17733671E-06
         526          512   0.00000000E+00
         526          513   0.00000000E+00
         526          514   0.00000000E+00
         526          515   0.00000000E+00
         526          516  -0.38117406E-05
         526          517  -0.43811481E-05
         526          518   0.00000000E+00
         526          519   0.00000000E+00
         526          520   0.00000000E+00
         526          531  -0.25627196E-06
         526          532   0.00000000E+00
         526          533   0.00000000E+00
         526          534   0.00000000E+00
         526          535   0.00000000E+00
         526          536  -0.58127031E-05
         526          537  -0.69398919E-05
         526          538   0.00000000E+00
         526          539   0.00000000E+00
         526          540   0.00000000E+00
         527          527   0.26284602E+04
         527          521   0.73343332E+02
         527          522  -0.21147957E+02
         527          523   0.00000000E+00
         527          524  -0.65789786E+02
         527          525  -0.63516600E+02
         527          526   0.19060070E+04
         527          528  -0.38648338E-04
         527          529  -0.11597244E+00
         527          530   0.47701378E-01
         527          511  -0.16897603E-06
         527          512   0.00000000E+00
         527          513   0.00000000E+00
         527          514   0.53901442E-08
         527          515   0.15271598E-09
         527          516  -0.43810900E-05
         527          517  -0.55484227E-05
         527          518   0.14566012E-13
         527          519   0.26721069E-09
         527          520  -0.10985684E-09
         527          531  -0.24418981E-06
         527          532   0.00000000E+00
         527          533   0.00000000E+00
         527          534   0.77893790E-08
         527          535   0.22069218E-09
         527          536  -0.69397776E-05
         527          537  -0.92353668E-05
         527          538   0.21049565E-13
         527          539   0.38615021E-09
         527          540  -0.15875579E-09
         528          528   0.65953325E-04
         528          521   0.00000000E+00
         528          522   0.00000000E+00
         528          523   0.00000000E+00
         528          524   0.00000000E+00
         528          525   0.00000000E+00
         528          526   0.00000000E+00
         528          527  -0.38657739E-04
         528          529  -0.14990729E-04
         528          530  -0.36880003E-04
         528          511   0.00000000E+00
         528          512   0.00000000E+00
         528          513   0.00000000E+00
         528          514   0.00000000E+00
         528          515   0.00000000E+00
         528          516   0.00000000E+00
         528          517   0.14567188E-13
         528          518  -0.21617043E-13
         528          519  -0.27092054E-14
         528          520   0.10471454E-13
         528          531   0.00000000E+00
         528          532   0.00000000E+00
         528          533   0.00000000E+00
         528          534   0.00000000E+00
         528          535   0.00000000E+00
         528          536   0.00000000E+00
         528          537   0.21051264E-13
         528          538  -0.31239116E-13
         528          539  -0.39151137E-14
         528          540   0.15132456E-13
         529          529   0.95734726E+02
         529          521   0.00000000E+00
         529          522   0.00000000E+00
         529          523   0.00000000E+00
         529          524   0.00000000E+00
         529          525   0.00000000E+00
         529          526   0.43198833E-04
         529          527  -0.11596084E+00
         529          528  -0.14987136E-04
         529          530   0.32314307E+02
         529          511   0.00000000E+00
         529          512   0.00000000E+00
         529          513   0.00000000E+00
         529          514   0.00000000E+00
         529          515   0.00000000E+00
         529          516   0.00000000E+00
         529          517   0.26718397E-09
         529          518  -0.27091038E-14
         529          519  -0.22056355E-06
         529          520  -0.74449053E-07
         529          531   0.00000000E+00
         529          532   0.00000000E+00
         529          533   0.00000000E+00
         529          534   0.00000000E+00
         529          535   0.00000000E+00
         529          536   0.00000000E+00
         529          537   0.38611160E-09
         529          538  -0.39149669E-14
         529          539  -0.31873972E-06
         529          540  -0.10758745E-06
         530          530   0.12993412E+05
         530          521   0.34983748E+04
         530          522   0.23928897E+03
         530          523   0.00000000E+00
         530          524   0.00000000E+00
         530          525   0.21000908E-05
         530          526   0.00000000E+00
         530          527   0.47701378E-01
         530          528  -0.36870431E-04
         530          529   0.32314307E+02
         530          511  -0.80599200E-05
         530          512  -0.55129892E-06
         530          513   0.00000000E+00
         530          514   0.00000000E+00
         530          515  -0.48384084E-14
         530          516   0.00000000E+00
         530          517  -0.10985684E-09
         530          518   0.10469883E-13
         530          519  -0.74449053E-07
         530          520  -0.29935577E-04
         530          531  -0.11647512E-04
         530          532  -0.79669041E-06
         530          533   0.00000000E+00
         530          534   0.00000000E+00
         530          535  -0.69920572E-14
         530          536   0.00000000E+00
         530          537  -0.15875579E-09
         530          538   0.15130187E-13
         530          539  -0.10758745E-06
         530          540  -0.43260356E-04
         531          531   0.91387806E+04
         531          532   0.00000000E+00
         531          533   0.00000000E+00
         531          534   0.00000000E+00
         531          535   0.00000000E+00
         531          536   0.74535992E+02
         531          537   0.71021728E+02
         531          538   0.00000000E+00
         531          539   0.00000000E+00
         531          540   0.33876375E+04
         531          521  -0.19671531E-04
         531          522   0.00000000E+00
         531          523   0.00000000E+00
         531          524   0.00000000E+00
         531          525   0.00000000E+00
         531          526  -0.16044076E-06
         531          527  -0.15287666E-06
         531          528   0.00000000E+00
         531          529   0.00000000E+00
         531          530  -0.72920027E-05
         531          541  -0.29444694E-04
         531          542   0.00000000E+00
         531          543   0.00000000E+00
         531          544   0.00000000E+00
         531          545   0.00000000E+00
         531          546  -0.24015056E-06
         531          547  -0.22882847E-06
         531          548   0.00000000E+00
         531          549   0.00000000E+00
         531          550  -0.10914798E-04
         532          532   0.57537941E+04
         532          531   0.00000000E+00
         532          533   0.00000000E+00
         532          534   0.63450217E+01
         532          535   0.63450217E+01
         532          536   0.00000000E+00
         532          537  -0.21136331E+02
         532          538   0.00000000E+00
         532          539   0.00000000E+00
         532          540   0.23171454E+03
         532          521   0.00000000E+00
         532          522  -0.12380683E-04
         532          523   0.00000000E+00
         532          524   0.00000000E+00
         532          525   0.00000000E+00
         532          526   0.00000000E+00
         532          527   0.00000000E+00
         532          528   0.00000000E+00
         532          529   0.00000000E+00
         532          530  -0.49877333E-06
         532          541   0.00000000E+00
         532          542  -0.18531624E-04
         532          543   0.00000000E+00
         532          544   0.00000000E+00
         532          545   0.00000000E+00
         532          546   0.00000000E+00
         532          547   0.00000000E+00
         532          548   0.00000000E+00
         532          549   0.00000000E+00
         532          550  -0.74657270E-06
         533          533   0.72854605E+03
         533          531   0.00000000E+00
         533          532   0.00000000E+00
         533          534   0.00000000E+00
         533          535   0.00000000E+00
         533          536   0.00000000E+00
         533          537   0.00000000E+00
         533          538   0.00000000E+00
         533          539   0.00000000E+00
         533          540   0.00000000E+00
         533          521   0.00000000E+00
         533          522   0.00000000E+00
         533          523  -0.15682199E-05
         533          524   0.00000000E+00
         533          525   0.00000000E+00
         533          526   0.00000000E+00
         533          527   0.00000000E+00
         533          528   0.00000000E+00
         533          529   0.00000000E+00
         533          530   0.00000000E+00
         533          541   0.00000000E+00
         533          542   0.00000000E+00
         533          543  -0.23473391E-05
         533          544   0.00000000E+00
         533          545   0.00000000E+00
         533          546   0.00000000E+00
         533          547   0.00000000E+00
         533          548   0.00000000E+00
         533          549   0.00000000E+00
         533          550   0.00000000E+00
         534          534   0.12524508E+04
         534          531   0.00000000E+00
         534          532   0.63443872E+01
         534          533   0.00000000E+00
         534          535   0.19035065E+02
         534          536   0.00000000E+00
         534          537  -0.65674278E+02
         534          538   0.00000000E+00
         534          539   0.00000000E+00
         534          540   0.00000000E+00
         534          521   0.00000000E+00
         534          522   0.00000000E+00
         534          523   0.00000000E+00
         534          524  -0.26549687E-05
         534          525   0.00000000E+00
         534          526   0.00000000E+00
         534          527   0.48761050E-08
         534          528   0.00000000E+00
         534          529   0.00000000E+00
         534          530   0.00000000E+00
         534          541   0.00000000E+00
         534          542   0.00000000E+00
         534          543   0.00000000E+00
         534          544  -0.39740039E-05
         534          545   0.00000000E+00
         534          546   0.00000000E+00
         534          547   0.72986397E-08
         534          548   0.00000000E+00
         534          549   0.00000000E+00
         534          550   0.00000000E+00
         535          535   0.19051650E+02
         535          531   0.00000000E+00
         535          532   0.63443872E+01
         535          533   0.00000000E+00
         535          534   0.19035065E+02
         535          536   0.00000000E+00
         535          537  -0.63473262E+02
         535          538   0.00000000E+00
         535          539   0.00000000E+00
         535          540   0.20336429E-05
         535          521   0.00000000E+00
         535          522   0.00000000E+00
         535          523   0.00000000E+00
         535          524   0.00000000E+00
         535          525  -0.35628857E-10
         535          526   0.00000000E+00
         535          527   0.13813178E-09
         535          528   0.00000000E+00
         535          529   0.00000000E+00
         535          530  -0.43774848E-14
         535          541   0.00000000E+00
         535          542   0.00000000E+00
         535          543   0.00000000E+00
         535          544   0.00000000E+00
         535          545  -0.53329900E-10
         535          546   0.00000000E+00
         535          547   0.20675808E-09
         535          548   0.00000000E+00
         535          549   0.00000000E+00
         535          550  -0.65522963E-14
         536          536   0.16141777E+04
         536          531   0.74535992E+02
         536          532   0.00000000E+00
         536          533   0.00000000E+00
         536          534   0.00000000E+00
         536          535   0.00000000E+00
         536          537   0.18655822E+04
         536          538   0.00000000E+00
         536          539   0.43198833E-04
         536          540   0.00000000E+00
         536          521  -0.16044076E-06
         536          522   0.00000000E+00
         536          523   0.00000000E+00
         536          524   0.00000000E+00
         536          525   0.00000000E+00
         536          526  -0.37643767E-05
         536          527  -0.45953685E-05
         536          528   0.00000000E+00
         536          529   0.00000000E+00
         536          530   0.00000000E+00
         536          541  -0.24015056E-06
         536          542   0.00000000E+00
         536          543   0.00000000E+00
         536          544   0.00000000E+00
         536          545   0.00000000E+00
         536          546  -0.66630675E-05
         536          547  -0.89354956E-05
         536          548   0.00000000E+00
         536          549   0.00000000E+00
         536          550   0.00000000E+00
         537          537   0.25917161E+04
         537          531   0.71021728E+02
         537          532  -0.21147957E+02
         537          533   0.00000000E+00
         537          534  -0.65715730E+02
         537          535  -0.63514502E+02
         537          536   0.18655566E+04
         537          538  -0.38448212E-04
         537          539  -0.11230116E+00
         537          540   0.46192027E-01
         537          521  -0.15287666E-06
         537          522   0.00000000E+00
         537          523   0.00000000E+00
         537          524   0.48765926E-08
         537          525   0.13816581E-09
         537          526  -0.45952844E-05
         537          527  -0.62830688E-05
         537          528   0.13178220E-13
         537          529   0.24175191E-09
         537          530  -0.99390118E-10
         537          541  -0.22882847E-06
         537          542   0.00000000E+00
         537          543   0.00000000E+00
         537          544   0.72993696E-08
         537          545   0.20680901E-09
         537          546  -0.89352669E-05
         537          547  -0.13518742E-04
         537          548   0.19725392E-13
         537          549   0.36185851E-09
         537          550  -0.14876888E-09
         538          538   0.65656323E-04
         538          531   0.00000000E+00
         538          532   0.00000000E+00
         538          533   0.00000000E+00
         538          534   0.00000000E+00
         538          535   0.00000000E+00
         538          536   0.00000000E+00
         538          537  -0.38457597E-04
         538          539  -0.15027951E-04
         538          540  -0.36736133E-04
         538          521   0.00000000E+00
         538          522   0.00000000E+00
         538          523   0.00000000E+00
         538          524   0.00000000E+00
         538          525   0.00000000E+00
         538          526   0.00000000E+00
         538          527   0.13179284E-13
         538          528  -0.19557457E-13
         538          529  -0.24510830E-14
         538          530   0.94737750E-14
         538          541   0.00000000E+00
         538          542   0.00000000E+00
         538          543   0.00000000E+00
         538          544   0.00000000E+00
         538          545   0.00000000E+00
         538          546   0.00000000E+00
         538          547   0.19726984E-13
         538          548  -0.29273945E-13
         538          549  -0.36688242E-14
         538          550   0.14180513E-13
         539          539   0.92704347E+02
         539          531   0.00000000E+00
         539          532   0.00000000E+00
         539          533   0.00000000E+00
         539          534   0.00000000E+00
         539          535   0.00000000E+00
         539          536   0.43198833E-04
         539          537  -0.11228993E+00
         539          538  -0.15024357E-04
         539          540   0.31291433E+02
         539          521   0.00000000E+00
         539          522   0.00000000E+00
         539          523   0.00000000E+00
         539          524   0.00000000E+00
         539          525   0.00000000E+00
         539          526   0.00000000E+00
         539          527   0.24172774E-09
         539          528  -0.24509911E-14
         539          529  -0.19954912E-06
         539          530  -0.67355841E-07
         539          541   0.00000000E+00
         539          542   0.00000000E+00
         539          543   0.00000000E+00
         539          544   0.00000000E+00
         539          545   0.00000000E+00
         539          546   0.00000000E+00
         539          547   0.36182233E-09
         539          548  -0.36686866E-14
         539          549  -0.29868864E-06
         539          550  -0.10081941E-06
         540          540   0.12582119E+05
         540          531   0.33876375E+04
         540          532   0.23171454E+03
         540          533   0.00000000E+00
         540          534   0.00000000E+00
         540          535   0.20336147E-05
         540          536   0.00000000E+00
         540          537   0.46192027E-01
         540          538  -0.36726582E-04
         540          539   0.31291433E+02
         540          521  -0.72920027E-05
         540          522  -0.49877333E-06
         540          523   0.00000000E+00
         540          524   0.00000000E+00
         540          525  -0.43774239E-14
         540          526   0.00000000E+00
         540          527  -0.99390118E-10
         540          528   0.94723541E-14
         540          529  -0.67355841E-07
         540          530  -0.27083434E-04
         540          541  -0.10914798E-04
         540          542  -0.74657270E-06
         540          543   0.00000000E+00
         540          544   0.00000000E+00
         540          545  -0.65522052E-14
         540          546   0.00000000E+00
         540          547  -0.14876888E-09
         540          548   0.14178386E-13
         540          549  -0.10081941E-06
         540          550  -0.40538960E-04
         541          541   0.88530187E+04
         541          542   0.00000000E+00
         541          543   0.00000000E+00
         541          544   0.00000000E+00
         541          545   0.00000000E+00
         541          546   0.72205322E+02
         541          547   0.68800938E+02
         541          548   0.00000000E+00
         541          549   0.00000000E+00
         541          550   0.32817089E+04
         541          531  -0.17694898E-04
         541          532   0.00000000E+00
         541          533   0.00000000E+00
         541          534   0.00000000E+00
         541          535   0.00000000E+00
         541          536  -0.14431937E-06
         541          537  -0.13751531E-06
         541          538   0.00000000E+00
         541          539   0.00000000E+00
         541          540  -0.65592881E-05
         541          551  -0.27735008E-04
         541          552   0.00000000E+00
         541          553   0.00000000E+00
         541          554   0.00000000E+00
         541          555   0.00000000E+00
         541          556  -0.22620638E-06
         541          557  -0.21554170E-06
         541          558   0.00000000E+00
         541          559   0.00000000E+00
         541          560  -0.10281037E-04
         542          542   0.55739440E+04
         542          541   0.00000000E+00
         542          543   0.00000000E+00
         542          544   0.63450217E+01
         542          545   0.63450217E+01
         542          546   0.00000000E+00
         542          547  -0.21136331E+02
         542          548   0.00000000E+00
         542          549   0.00000000E+00
         542          550   0.22446902E+03
         542          531   0.00000000E+00
         542          532  -0.11136648E-04
         542          533   0.00000000E+00
         542          534   0.00000000E+00
         542          535   0.00000000E+00
         542          536   0.00000000E+00
         542          537   0.00000000E+00
         542          538   0.00000000E+00
         542          539   0.00000000E+00
         542          540  -0.44865563E-06
         542          551   0.00000000E+00
         542          552  -0.17455598E-04
         542          553   0.00000000E+00
         542          554   0.00000000E+00
         542          555   0.00000000E+00
         542          556   0.00000000E+00
         542          557   0.00000000E+00
         542          558   0.00000000E+00
         542          559   0.00000000E+00
         542          560  -0.70322346E-06
         543          543   0.70576503E+03
         543          541   0.00000000E+00
         543          542   0.00000000E+00
         543          544   0.00000000E+00
         543          545   0.00000000E+00
         543          546   0.00000000E+00
         543          547   0.00000000E+00
         543          548   0.00000000E+00
         543          549   0.00000000E+00
         543          550   0.00000000E+00
         543          531   0.00000000E+00
         543          532   0.00000000E+00
         543          533  -0.14106421E-05
         543          534   0.00000000E+00
         543          535   0.00000000E+00
         543          536   0.00000000E+00
         543          537   0.00000000E+00
         543          538   0.00000000E+00
         543          539   0.00000000E+00
         543          540   0.00000000E+00
         543          551   0.00000000E+00
         543          552   0.00000000E+00
         543          553  -0.22110424E-05
         543          554   0.00000000E+00
         543          555   0.00000000E+00
         543          556   0.00000000E+00
         543          557   0.00000000E+00
         543          558   0.00000000E+00
         543          559   0.00000000E+00
         543          560   0.00000000E+00
         544          544   0.12138829E+04
         544          541   0.00000000E+00
         544          542   0.63443872E+01
         544          543   0.00000000E+00
         544          545   0.19035065E+02
         544          546   0.00000000E+00
         544          547  -0.65603445E+02
         544          548   0.00000000E+00
         544          549   0.00000000E+00
         544          550   0.00000000E+00
         544          531   0.00000000E+00
         544          532   0.00000000E+00
         544          533   0.00000000E+00
         544          534  -0.23881923E-05
         544          535   0.00000000E+00
         544          536   0.00000000E+00
         544          537   0.43861445E-08
         544          538   0.00000000E+00
         544          539   0.00000000E+00
         544          540   0.00000000E+00
         544          551   0.00000000E+00
         544          552   0.00000000E+00
         544          553   0.00000000E+00
         544          554  -0.37432560E-05
         544          555   0.00000000E+00
         544          556   0.00000000E+00
         544          557   0.68748491E-08
         544          558   0.00000000E+00
         544          559   0.00000000E+00
         544          560   0.00000000E+00
         545          545   0.19051132E+02
         545          541   0.00000000E+00
         545          542   0.63443872E+01
         545          543   0.00000000E+00
         545          544   0.19035065E+02
         545          546   0.00000000E+00
         545          547  -0.63471255E+02
         545          548   0.00000000E+00
         545          549   0.00000000E+00
         545          550   0.19700526E-05
         545          531   0.00000000E+00
         545          532   0.00000000E+00
         545          533   0.00000000E+00
         545          534   0.00000000E+00
         545          535  -0.32048800E-10
         545          536   0.00000000E+00
         545          537   0.12425203E-09
         545          538   0.00000000E+00
         545          539   0.00000000E+00
         545          540  -0.39376267E-14
         545          551   0.00000000E+00
         545          552   0.00000000E+00
         545          553   0.00000000E+00
         545          554   0.00000000E+00
         545          555  -0.50233335E-10
         545          556   0.00000000E+00
         545          557   0.19475282E-09
         545          558   0.00000000E+00
         545          559   0.00000000E+00
         545          560  -0.61718416E-14
         546          546   0.15735240E+04
         546          541   0.72205322E+02
         546          542   0.00000000E+00
         546          543   0.00000000E+00
         546          544   0.00000000E+00
         546          545   0.00000000E+00
         546          547   0.18268886E+04
         546          548   0.00000000E+00
         546          549   0.43198833E-04
         546          550   0.00000000E+00
         546          531  -0.14431937E-06
         546          532   0.00000000E+00
         546          533   0.00000000E+00
         546          534   0.00000000E+00
         546          535   0.00000000E+00
         546          536  -0.46147410E-05
         546          537  -0.65909722E-05
         546          538   0.00000000E+00
         546          539   0.00000000E+00
         546          540   0.00000000E+00
         546          551  -0.22620638E-06
         546          552   0.00000000E+00
         546          553   0.00000000E+00
         546          554   0.00000000E+00
         546          555   0.00000000E+00
         546          556  -0.88990741E-05
         546          557  -0.13662711E-04
         546          558   0.00000000E+00
         546          559   0.00000000E+00
         546          560   0.00000000E+00
         547          547   0.25565675E+04
         547          541   0.68800938E+02
         547          542  -0.21147957E+02
         547          543   0.00000000E+00
         547          544  -0.65644889E+02
         547          545  -0.63512495E+02
         547          546   0.18268628E+04
         547          548  -0.38256776E-04
         547          549  -0.10878931E+00
         547          550   0.44748219E-01
         547          531  -0.13751531E-06
         547          532   0.00000000E+00
         547          533   0.00000000E+00
         547          534   0.43865831E-08
         547          535   0.12428264E-09
         547          536  -0.65907737E-05
         547          537  -0.10566444E-04
         547          538   0.11854047E-13
         547          539   0.21746021E-09
         547          540  -0.89403207E-10
         547          551  -0.21554170E-06
         547          552   0.00000000E+00
         547          553   0.00000000E+00
         547          554   0.68755366E-08
         547          555   0.19480078E-09
         547          556  -0.13662233E-04
         547          557  -0.23225883E-04
         547          558   0.18580050E-13
         547          559   0.34084744E-09
         547          560  -0.14013071E-09
         548          548   0.65372218E-04
         548          541   0.00000000E+00
         548          542   0.00000000E+00
         548          543   0.00000000E+00
         548          544   0.00000000E+00
         548          545   0.00000000E+00
         548          546   0.00000000E+00
         548          547  -0.38266146E-04
         548          549  -0.15063557E-04
         548          550  -0.36598510E-04
         548          531   0.00000000E+00
         548          532   0.00000000E+00
         548          533   0.00000000E+00
         548          534   0.00000000E+00
         548          535   0.00000000E+00
         548          536   0.00000000E+00
         548          537   0.11855004E-13
         548          538  -0.17592286E-13
         548          539  -0.22047934E-14
         548          540   0.85218317E-14
         548          551   0.00000000E+00
         548          552   0.00000000E+00
         548          553   0.00000000E+00
         548          554   0.00000000E+00
         548          555   0.00000000E+00
         548          556   0.00000000E+00
         548          557   0.18581550E-13
         548          558  -0.27574173E-13
         548          559  -0.34557963E-14
         548          560   0.13357131E-13
         549          549   0.89805562E+02
         549          541   0.00000000E+00
         549          542   0.00000000E+00
         549          543   0.00000000E+00
         549          544   0.00000000E+00
         549          545   0.00000000E+00
         549          546   0.43198833E-04
         549          547  -0.10877843E+00
         549          548  -0.15059962E-04
         549          550   0.30312976E+02
         549          531   0.00000000E+00
         549          532   0.00000000E+00
         549          533   0.00000000E+00
         549          534   0.00000000E+00
         549          535   0.00000000E+00
         549          536   0.00000000E+00
         549          537   0.21743847E-09
         549          538  -0.22047108E-14
         549          539  -0.17949804E-06
         549          540  -0.60587796E-07
         549          551   0.00000000E+00
         549          552   0.00000000E+00
         549          553   0.00000000E+00
         549          554   0.00000000E+00
         549          555   0.00000000E+00
         549          556   0.00000000E+00
         549          557   0.34081336E-09
         549          558  -0.34556668E-14
         549          559  -0.28134548E-06
         549          560  -0.94965397E-07
         550          550   0.12188687E+05
         550          541   0.32817089E+04
         550          542   0.22446902E+03
         550          543   0.00000000E+00
         550          544   0.00000000E+00
         550          545   0.19700253E-05
         550          546   0.00000000E+00
         550          547   0.44748219E-01
         550          548  -0.36588980E-04
         550          549   0.30312976E+02
         550          531  -0.65592881E-05
         550          532  -0.44865563E-06
         550          533   0.00000000E+00
         550          534   0.00000000E+00
         550          535  -0.39375719E-14
         550          536   0.00000000E+00
         550          537  -0.89403207E-10
         550          538   0.85205536E-14
         550          539  -0.60587796E-07
         550          540  -0.24362038E-04
         550          551  -0.10281037E-04
         550          552  -0.70322346E-06
         550          553   0.00000000E+00
         550          554   0.00000000E+00
         550          555  -0.61717558E-14
         550          556   0.00000000E+00
         550          557  -0.14013071E-09
         550          558   0.13355128E-13
         550          559  -0.94965397E-07
         550          560  -0.38185093E-04
         551          551   0.85948552E+04
         551          552   0.00000000E+00
         551          553   0.00000000E+00
         551          554   0.00000000E+00
         551          555   0.00000000E+00
         551          556   0.70099743E+02
         551          557   0.66794629E+02
         551          558   0.00000000E+00
         551          559   0.00000000E+00
         551          560   0.31860108E+04
         551          541  -0.15985211E-04
         551          542   0.00000000E+00
         551          543   0.00000000E+00
         551          544   0.00000000E+00
         551          545   0.00000000E+00
         551          546  -0.13037519E-06
         551          547  -0.12422854E-06
         551          548   0.00000000E+00
         551          549   0.00000000E+00
         551          550  -0.59255277E-05
         551          561  -0.26313584E-04
         551          562   0.00000000E+00
         551          563   0.00000000E+00
         551          564   0.00000000E+00
         551          565   0.00000000E+00
         551          566  -0.21461326E-06
         551          567  -0.20449515E-06
         551          568   0.00000000E+00
         551          569   0.00000000E+00
         551          570  -0.97541326E-05
         552          552   0.54114635E+04
         552          551   0.00000000E+00
         552          553   0.00000000E+00
         552          554   0.63450217E+01
         552          555   0.63450217E+01
         552          556   0.00000000E+00
         552          557  -0.21136331E+02
         552          558   0.00000000E+00
         552          559   0.00000000E+00
         552          560   0.21792326E+03
         552          541   0.00000000E+00
         552          542  -0.10060622E-04
         552          543   0.00000000E+00
         552          544   0.00000000E+00
         552          545   0.00000000E+00
         552          546   0.00000000E+00
         552          547   0.00000000E+00
         552          548   0.00000000E+00
         552          549   0.00000000E+00
         552          550  -0.40530638E-06
         552          561   0.00000000E+00
         552          562  -0.16560996E-04
         552          563   0.00000000E+00
         552          564   0.00000000E+00
         552          565   0.00000000E+00
         552          566   0.00000000E+00
         552          567   0.00000000E+00
         552          568   0.00000000E+00
         552          569   0.00000000E+00
         552          570  -0.66718314E-06
         553          553   0.68518417E+03
         553          551   0.00000000E+00
         553          552   0.00000000E+00
         553          554   0.00000000E+00
         553          555   0.00000000E+00
         553          556   0.00000000E+00
         553          557   0.00000000E+00
         553          558   0.00000000E+00
         553          559   0.00000000E+00
         553          560   0.00000000E+00
         553          541   0.00000000E+00
         553          542   0.00000000E+00
         553          543  -0.12743454E-05
         553          544   0.00000000E+00
         553          545   0.00000000E+00
         553          546   0.00000000E+00
         553          547   0.00000000E+00
         553          548   0.00000000E+00
         553          549   0.00000000E+00
         553          550   0.00000000E+00
         553          561   0.00000000E+00
         553          562   0.00000000E+00
         553          563  -0.20977261E-05
         553          564   0.00000000E+00
         553          565   0.00000000E+00
         553          566   0.00000000E+00
         553          567   0.00000000E+00
         553          568   0.00000000E+00
         553          569   0.00000000E+00
         553          570   0.00000000E+00
         554          554   0.11790399E+04
         554          551   0.00000000E+00
         554          552   0.63443872E+01
         554          553   0.00000000E+00
         554          555   0.19035065E+02
         554          556   0.00000000E+00
         554          557  -0.65539452E+02
         554          558   0.00000000E+00
         554          559   0.00000000E+00
         554          560   0.00000000E+00
         554          541   0.00000000E+00
         554          542   0.00000000E+00
         554          543   0.00000000E+00
         554          544  -0.21574445E-05
         554          545   0.00000000E+00
         554          546   0.00000000E+00
         554          547   0.39623539E-08
         554          548   0.00000000E+00
         554          549   0.00000000E+00
         554          550   0.00000000E+00
         554          561   0.00000000E+00
         554          562   0.00000000E+00
         554          563   0.00000000E+00
         554          564  -0.35514135E-05
         554          565   0.00000000E+00
         554          566   0.00000000E+00
         554          567   0.65225120E-08
         554          568   0.00000000E+00
         554          569   0.00000000E+00
         554          570   0.00000000E+00
         555          555   0.19050665E+02
         555          551   0.00000000E+00
         555          552   0.63443872E+01
         555          553   0.00000000E+00
         555          554   0.19035065E+02
         555          556   0.00000000E+00
         555          557  -0.63469442E+02
         555          558   0.00000000E+00
         555          559   0.00000000E+00
         555          560   0.19126038E-05
         555          541   0.00000000E+00
         555          542   0.00000000E+00
         555          543   0.00000000E+00
         555          544   0.00000000E+00
         555          545  -0.28952236E-10
         555          546   0.00000000E+00
         555          547   0.11224677E-09
         555          548   0.00000000E+00
         555          549   0.00000000E+00
         555          550  -0.35571720E-14
         555          561   0.00000000E+00
         555          562   0.00000000E+00
         555          563   0.00000000E+00
         555          564   0.00000000E+00
         555          565  -0.47658868E-10
         555          566   0.00000000E+00
         555          567   0.18477170E-09
         555          568   0.00000000E+00
         555          569   0.00000000E+00
         555          570  -0.58555337E-14
         556          556   0.15367966E+04
         556          551   0.70099743E+02
         556          552   0.00000000E+00
         556          553   0.00000000E+00
         556          554   0.00000000E+00
         556          555   0.00000000E+00
         556          557   0.17919319E+04
         556          558   0.00000000E+00
         556          559   0.43198833E-04
         556          560   0.00000000E+00
         556          541  -0.13037519E-06
         556          542   0.00000000E+00
         556          543   0.00000000E+00
         556          544   0.00000000E+00
         556          545   0.00000000E+00
         556          546  -0.68507477E-05
         556          547  -0.11318187E-04
         556          548   0.00000000E+00
         556          549   0.00000000E+00
         556          550   0.00000000E+00
         556          561  -0.21461326E-06
         556          562   0.00000000E+00
         556          563   0.00000000E+00
         556          564   0.00000000E+00
         556          565   0.00000000E+00
         556          566  -0.12607606E-04
         556          567  -0.21292133E-04
         556          568   0.00000000E+00
         556          569   0.00000000E+00
         556          570   0.00000000E+00
         557          557   0.25248136E+04
         557          551   0.66794629E+02
         557          552  -0.21147957E+02
         557          553   0.00000000E+00
         557          554  -0.65580890E+02
         557          555  -0.63510682E+02
         557          556   0.17919060E+04
         557          558  -0.38083829E-04
         557          559  -0.10561663E+00
         557          560   0.43443852E-01
         557          541  -0.12422854E-06
         557          542   0.00000000E+00
         557          543   0.00000000E+00
         557          544   0.39627501E-08
         557          545   0.11227441E-09
         557          546  -0.11317740E-04
         557          547  -0.20273585E-04
         557          548   0.10708706E-13
         557          549   0.19644914E-09
         557          550  -0.80765042E-10
         557          561  -0.20449515E-06
         557          562   0.00000000E+00
         557          563   0.00000000E+00
         557          564   0.65231642E-08
         557          565   0.18481721E-09
         557          566  -0.21291263E-04
         557          567  -0.38694829E-04
         557          568   0.17627820E-13
         557          569   0.32337895E-09
         557          570  -0.13294899E-09
         558          558   0.65115552E-04
         558          551   0.00000000E+00
         558          552   0.00000000E+00
         558          553   0.00000000E+00
         558          554   0.00000000E+00
         558          555   0.00000000E+00
         558          556   0.00000000E+00
         558          557  -0.38093184E-04
         558          559  -0.15095724E-04
         558          560  -0.36474179E-04
         558          541   0.00000000E+00
         558          542   0.00000000E+00
         558          543   0.00000000E+00
         558          544   0.00000000E+00
         558          545   0.00000000E+00
         558          546   0.00000000E+00
         558          547   0.10709570E-13
         558          548  -0.15892514E-13
         558          549  -0.19917656E-14
         558          550   0.76984498E-14
         558          561   0.00000000E+00
         558          562   0.00000000E+00
         558          563   0.00000000E+00
         558          564   0.00000000E+00
         558          565   0.00000000E+00
         558          566   0.00000000E+00
         558          567   0.17629243E-13
         558          568  -0.26160992E-13
         558          569  -0.32786862E-14
         558          570   0.12672576E-13
         559          559   0.87186738E+02
         559          551   0.00000000E+00
         559          552   0.00000000E+00
         559          553   0.00000000E+00
         559          554   0.00000000E+00
         559          555   0.00000000E+00
         559          556   0.43198833E-04
         559          557  -0.10560607E+00
         559          558  -0.15092128E-04
         559          560   0.29429018E+02
         559          541   0.00000000E+00
         559          542   0.00000000E+00
         559          543   0.00000000E+00
         559          544   0.00000000E+00
         559          545   0.00000000E+00
         559          546   0.00000000E+00
         559          547   0.19642950E-09
         559          548  -0.19916909E-14
         559          549  -0.16215489E-06
         559          550  -0.54733785E-07
         559          561   0.00000000E+00
         559          562   0.00000000E+00
         559          563   0.00000000E+00
         559          564   0.00000000E+00
         559          565   0.00000000E+00
         559          566   0.00000000E+00
         559          567   0.32334662E-09
         559          568  -0.32785633E-14
         559          569  -0.26692648E-06
         559          570  -0.90098405E-07
         560          560   0.11833252E+05
         560          551   0.31860108E+04
         560          552   0.21792326E+03
         560          553   0.00000000E+00
         560          554   0.00000000E+00
         560          555   0.19125772E-05
         560          556   0.00000000E+00
         560          557   0.43443852E-01
         560          558  -0.36464668E-04
         560          559   0.29429018E+02
         560          541  -0.59255277E-05
         560          542  -0.40530638E-06
         560          543   0.00000000E+00
         560          544   0.00000000E+00
         560          545  -0.35571225E-14
         560          546   0.00000000E+00
         560          547  -0.80765042E-10
         560          548   0.76972952E-14
         560          549  -0.54733785E-07
         560          550  -0.22008170E-04
         560          561  -0.97541326E-05
         560          562  -0.66718314E-06
         560          563   0.00000000E+00
         560          564   0.00000000E+00
         560          565  -0.58554523E-14
         560          566   0.00000000E+00
         560          567  -0.13294899E-09
         560          568   0.12670675E-13
         560          569  -0.90098405E-07
         560          570  -0.36228100E-04
         561          561   0.83686309E+04
         561          562   0.00000000E+00
         561          563   0.00000000E+00
         561          564   0.00000000E+00
         561          565   0.00000000E+00
         561          566   0.68254660E+02
         561          567   0.65036534E+02
         561          568   0.00000000E+00
         561          569   0.00000000E+00
         561          570   0.31021521E+04
         561          551  -0.14563788E-04
         561          552   0.00000000E+00
         561          553   0.00000000E+00
         561          554   0.00000000E+00
         561          555   0.00000000E+00
         561          556  -0.11878207E-06
         561          557  -0.11318200E-06
         561          558   0.00000000E+00
         561          559   0.00000000E+00
         561          560  -0.53986229E-05
         561          571  -0.25153378E-04
         561          572   0.00000000E+00
         561          573   0.00000000E+00
         561          574   0.00000000E+00
         561          575   0.00000000E+00
         561          576  -0.20515064E-06
         561          577  -0.19547865E-06
         561          578   0.00000000E+00
         561          579   0.00000000E+00
         561          580  -0.93240581E-05
         562          562   0.52690845E+04
         562          561   0.00000000E+00
         562          563   0.00000000E+00
         562          564   0.63450217E+01
         562          565   0.63450217E+01
         562          566   0.00000000E+00
         562          567  -0.21136331E+02
         562          568   0.00000000E+00
         562          569   0.00000000E+00
         562          570   0.21218733E+03
         562          551   0.00000000E+00
         562          552  -0.91660196E-05
         562          553   0.00000000E+00
         562          554   0.00000000E+00
         562          555   0.00000000E+00
         562          556   0.00000000E+00
         562          557   0.00000000E+00
         562          558   0.00000000E+00
         562          559   0.00000000E+00
         562          560  -0.36926607E-06
         562          571   0.00000000E+00
         562          572  -0.15830796E-04
         562          573   0.00000000E+00
         562          574   0.00000000E+00
         562          575   0.00000000E+00
         562          576   0.00000000E+00
         562          577   0.00000000E+00
         562          578   0.00000000E+00
         562          579   0.00000000E+00
         562          580  -0.63776603E-06
         563          563   0.66714950E+03
         563          561   0.00000000E+00
         563          562   0.00000000E+00
         563          564   0.00000000E+00
         563          565   0.00000000E+00
         563          566   0.00000000E+00
         563          567   0.00000000E+00
         563          568   0.00000000E+00
         563          569   0.00000000E+00
         563          570   0.00000000E+00
         563          551   0.00000000E+00
         563          552   0.00000000E+00
         563          553  -0.11610291E-05
         563          554   0.00000000E+00
         563          555   0.00000000E+00
         563          556   0.00000000E+00
         563          557   0.00000000E+00
         563          558   0.00000000E+00
         563          559   0.00000000E+00
         563          560   0.00000000E+00
         563          571   0.00000000E+00
         563          572   0.00000000E+00
         563          573  -0.20052342E-05
         563          574   0.00000000E+00
         563          575   0.00000000E+00
         563          576   0.00000000E+00
         563          577   0.00000000E+00
         563          578   0.00000000E+00
         563          579   0.00000000E+00
         563          580   0.00000000E+00
         564          564   0.11485075E+04
         564          561   0.00000000E+00
         564          562   0.63443872E+01
         564          563   0.00000000E+00
         564          565   0.19035065E+02
         564          566   0.00000000E+00
         564          567  -0.65483376E+02
         564          568   0.00000000E+00
         564          569   0.00000000E+00
         564          570   0.00000000E+00
         564          551   0.00000000E+00
         564          552   0.00000000E+00
         564          553   0.00000000E+00
         564          554  -0.19656020E-05
         564          555   0.00000000E+00
         564          556   0.00000000E+00
         564          557   0.36100168E-08
         564          558   0.00000000E+00
         564          559   0.00000000E+00
         564          560   0.00000000E+00
         564          571   0.00000000E+00
         564          572   0.00000000E+00
         564          573   0.00000000E+00
         564          574  -0.33948263E-05
         564          575   0.00000000E+00
         564          576   0.00000000E+00
         564          577   0.62349245E-08
         564          578   0.00000000E+00
         564          579   0.00000000E+00
         564          580   0.00000000E+00
         565          565   0.19050255E+02
         565          561   0.00000000E+00
         565          562   0.63443872E+01
         565          563   0.00000000E+00
         565          564   0.19035065E+02
         565          566   0.00000000E+00
         565          567  -0.63467854E+02
         565          568   0.00000000E+00
         565          569   0.00000000E+00
         565          570   0.18622623E-05
         565          551   0.00000000E+00
         565          552   0.00000000E+00
         565          553   0.00000000E+00
         565          554   0.00000000E+00
         565          555  -0.26377769E-10
         565          556   0.00000000E+00
         565          557   0.10226565E-09
         565          558   0.00000000E+00
         565          559   0.00000000E+00
         565          560  -0.32408641E-14
         565          571   0.00000000E+00
         565          572   0.00000000E+00
         565          573   0.00000000E+00
         565          574   0.00000000E+00
         565          575  -0.45557516E-10
         565          576   0.00000000E+00
         565          577   0.17662484E-09
         565          578   0.00000000E+00
         565          579   0.00000000E+00
         565          580  -0.55973543E-14
         566          566   0.15046130E+04
         566          561   0.68254660E+02
         566          562   0.00000000E+00
         566          563   0.00000000E+00
         566          564   0.00000000E+00
         566          565   0.00000000E+00
         566          567   0.17613000E+04
         566          568   0.00000000E+00
         566          569   0.43198833E-04
         566          570   0.00000000E+00
         566          551  -0.11878207E-06
         566          552   0.00000000E+00
         566          553   0.00000000E+00
         566          554   0.00000000E+00
         566          555   0.00000000E+00
         566          556  -0.10559279E-04
         566          557  -0.18947609E-04
         566          558   0.00000000E+00
         566          559   0.00000000E+00
         566          560   0.00000000E+00
         566          571  -0.20515064E-06
         566          572   0.00000000E+00
         566          573   0.00000000E+00
         566          574   0.00000000E+00
         566          575   0.00000000E+00
         566          576  -0.17548422E-04
         566          577  -0.31347289E-04
         566          578   0.00000000E+00
         566          579   0.00000000E+00
         566          580   0.00000000E+00
         567          567   0.24969882E+04
         567          561   0.65036534E+02
         567          562  -0.21147957E+02
         567          563   0.00000000E+00
         567          564  -0.65524809E+02
         567          565  -0.63509093E+02
         567          566   0.17612739E+04
         567          568  -0.37932279E-04
         567          569  -0.10283646E+00
         567          570   0.42300856E-01
         567          551  -0.11318200E-06
         567          552   0.00000000E+00
         567          553   0.00000000E+00
         567          554   0.36103778E-08
         567          555   0.10229084E-09
         567          556  -0.18946770E-04
         567          557  -0.35742531E-04
         567          558   0.97564750E-14
         567          559   0.17898065E-09
         567          560  -0.73583320E-10
         567          571  -0.19547865E-06
         567          572   0.00000000E+00
         567          573   0.00000000E+00
         567          574   0.62355480E-08
         567          575   0.17666834E-09
         567          576  -0.31345908E-04
         567          577  -0.58976632E-04
         567          578   0.16850582E-13
         567          579   0.30912069E-09
         567          580  -0.12708707E-09
         568          568   0.64890639E-04
         568          561   0.00000000E+00
         568          562   0.00000000E+00
         568          563   0.00000000E+00
         568          564   0.00000000E+00
         568          565   0.00000000E+00
         568          566   0.00000000E+00
         568          567  -0.37941621E-04
         568          569  -0.15123912E-04
         568          570  -0.36365230E-04
         568          551   0.00000000E+00
         568          552   0.00000000E+00
         568          553   0.00000000E+00
         568          554   0.00000000E+00
         568          555   0.00000000E+00
         568          556   0.00000000E+00
         568          557   0.97572625E-14
         568          558  -0.14479333E-13
         568          559  -0.18146555E-14
         568          560   0.70138946E-14
         568          571   0.00000000E+00
         568          572   0.00000000E+00
         568          573   0.00000000E+00
         568          574   0.00000000E+00
         568          575   0.00000000E+00
         568          576   0.00000000E+00
         568          577   0.16851943E-13
         568          578  -0.25007515E-13
         568          579  -0.31341240E-14
         568          580   0.12113823E-13
         569          569   0.84891905E+02
         569          561   0.00000000E+00
         569          562   0.00000000E+00
         569          563   0.00000000E+00
         569          564   0.00000000E+00
         569          565   0.00000000E+00
         569          566   0.43198833E-04
         569          567  -0.10282617E+00
         569          568  -0.15120314E-04
         569          570   0.28654420E+02
         569          551   0.00000000E+00
         569          552   0.00000000E+00
         569          553   0.00000000E+00
         569          554   0.00000000E+00
         569          555   0.00000000E+00
         569          556   0.00000000E+00
         569          557   0.17896276E-09
         569          558  -0.18145875E-14
         569          559  -0.14773588E-06
         569          560  -0.49866793E-07
         569          571   0.00000000E+00
         569          572   0.00000000E+00
         569          573   0.00000000E+00
         569          574   0.00000000E+00
         569          575   0.00000000E+00
         569          576   0.00000000E+00
         569          577   0.30908978E-09
         569          578  -0.31340064E-14
         569          579  -0.25515729E-06
         569          580  -0.86125830E-07
         570          570   0.11521790E+05
         570          561   0.31021521E+04
         570          562   0.21218733E+03
         570          563   0.00000000E+00
         570          564   0.00000000E+00
         570          565   0.18622364E-05
         570          566   0.00000000E+00
         570          567   0.42300856E-01
         570          568  -0.36355735E-04
         570          569   0.28654420E+02
         570          551  -0.53986229E-05
         570          552  -0.36926607E-06
         570          553   0.00000000E+00
         570          554   0.00000000E+00
         570          555  -0.32408190E-14
         570          556   0.00000000E+00
         570          557  -0.73583320E-10
         570          558   0.70128427E-14
         570          559  -0.49866793E-07
         570          560  -0.20051178E-04
         570          571  -0.93240581E-05
         570          572  -0.63776603E-06
         570          573   0.00000000E+00
         570          574   0.00000000E+00
         570          575  -0.55972765E-14
         570          576   0.00000000E+00
         570          577  -0.12708707E-09
         570          578   0.12112006E-13
         570          579  -0.86125830E-07
         570          580  -0.34630748E-04
         571          571   0.81741040E+04
         571          572   0.00000000E+00
         571          573   0.00000000E+00
         571          574   0.00000000E+00
         571          575   0.00000000E+00
         571          576   0.66668102E+02
         571          577   0.63524775E+02
         571          578   0.00000000E+00
         571          579   0.00000000E+00
         571          580   0.30300433E+04
         571          561  -0.13403582E-04
         571          562   0.00000000E+00
         571          563   0.00000000E+00
         571          564   0.00000000E+00
         571          565   0.00000000E+00
         571          566  -0.10931945E-06
         571          567  -0.10416549E-06
         571          568   0.00000000E+00
         571          569   0.00000000E+00
         571          570  -0.49685484E-05
         571          581  -0.24214771E-04
         571          582   0.00000000E+00
         571          583   0.00000000E+00
         571          584   0.00000000E+00
         571          585   0.00000000E+00
         571          586  -0.19749537E-06
         571          587  -0.18818430E-06
         571          588   0.00000000E+00
         571          589   0.00000000E+00
         571          590  -0.89761276E-05
         572          572   0.51466550E+04
         572          571   0.00000000E+00
         572          573   0.00000000E+00
         572          574   0.63450217E+01
         572          575   0.63450217E+01
         572          576   0.00000000E+00
         572          577  -0.21136331E+02
         572          578   0.00000000E+00
         572          579   0.00000000E+00
         572          580   0.20725508E+03
         572          561   0.00000000E+00
         572          562  -0.84358202E-05
         572          563   0.00000000E+00
         572          564   0.00000000E+00
         572          565   0.00000000E+00
         572          566   0.00000000E+00
         572          567   0.00000000E+00
         572          568   0.00000000E+00
         572          569   0.00000000E+00
         572          570  -0.33984895E-06
         572          581   0.00000000E+00
         572          582  -0.15240065E-04
         572          583   0.00000000E+00
         572          584   0.00000000E+00
         572          585   0.00000000E+00
         572          586   0.00000000E+00
         572          587   0.00000000E+00
         572          588   0.00000000E+00
         572          589   0.00000000E+00
         572          590  -0.61396756E-06
         573          573   0.65164176E+03
         573          571   0.00000000E+00
         573          572   0.00000000E+00
         573          574   0.00000000E+00
         573          575   0.00000000E+00
         573          576   0.00000000E+00
         573          577   0.00000000E+00
         573          578   0.00000000E+00
         573          579   0.00000000E+00
         573          580   0.00000000E+00
         573          561   0.00000000E+00
         573          562   0.00000000E+00
         573          563  -0.10685372E-05
         573          564   0.00000000E+00
         573          565   0.00000000E+00
         573          566   0.00000000E+00
         573          567   0.00000000E+00
         573          568   0.00000000E+00
         573          569   0.00000000E+00
         573          570   0.00000000E+00
         573          581   0.00000000E+00
         573          582   0.00000000E+00
         573          583  -0.19304082E-05
         573          584   0.00000000E+00
         573          585   0.00000000E+00
         573          586   0.00000000E+00
         573          587   0.00000000E+00
         573          588   0.00000000E+00
         573          589   0.00000000E+00
         573          590   0.00000000E+00
         574          574   0.11222532E+04
         574          571   0.00000000E+00
         574          572   0.63443872E+01
         574          573   0.00000000E+00
         574          575   0.19035065E+02
         574          576   0.00000000E+00
         574          577  -0.65435158E+02
         574          578   0.00000000E+00
         574          579   0.00000000E+00
         574          580   0.00000000E+00
         574          561   0.00000000E+00
         574          562   0.00000000E+00
         574          563   0.00000000E+00
         574          564  -0.18090148E-05
         574          565   0.00000000E+00
         574          566   0.00000000E+00
         574          567   0.33224293E-08
         574          568   0.00000000E+00
         574          569   0.00000000E+00
         574          570   0.00000000E+00
         574          581   0.00000000E+00
         574          582   0.00000000E+00
         574          583   0.00000000E+00
         574          584  -0.32681472E-05
         574          585   0.00000000E+00
         574          586   0.00000000E+00
         574          587   0.60022661E-08
         574          588   0.00000000E+00
         574          589   0.00000000E+00
         574          590   0.00000000E+00
         575          575   0.19049903E+02
         575          571   0.00000000E+00
         575          572   0.63443872E+01
         575          573   0.00000000E+00
         575          574   0.19035065E+02
         575          576   0.00000000E+00
         575          577  -0.63466488E+02
         575          578   0.00000000E+00
         575          579   0.00000000E+00
         575          580   0.18189745E-05
         575          561   0.00000000E+00
         575          562   0.00000000E+00
         575          563   0.00000000E+00
         575          564   0.00000000E+00
         575          565  -0.24276417E-10
         575          566   0.00000000E+00
         575          567   0.94118787E-10
         575          568   0.00000000E+00
         575          569   0.00000000E+00
         575          570  -0.29826847E-14
         575          581   0.00000000E+00
         575          582   0.00000000E+00
         575          583   0.00000000E+00
         575          584   0.00000000E+00
         575          585  -0.43857522E-10
         575          586   0.00000000E+00
         575          587   0.17003402E-09
         575          588   0.00000000E+00
         575          589   0.00000000E+00
         575          590  -0.53884871E-14
         576          576   0.14769388E+04
         576          571   0.66668102E+02
         576          572   0.00000000E+00
         576          573   0.00000000E+00
         576          574   0.00000000E+00
         576          575   0.00000000E+00
         576          577   0.17349601E+04
         576          578   0.00000000E+00
         576          579   0.43198833E-04
         576          580   0.00000000E+00
         576          561  -0.10931945E-06
         576          562   0.00000000E+00
         576          563   0.00000000E+00
         576          564   0.00000000E+00
         576          565   0.00000000E+00
         576          566  -0.15500095E-04
         576          567  -0.29002765E-04
         576          568   0.00000000E+00
         576          569   0.00000000E+00
         576          570   0.00000000E+00
         576          581  -0.19749537E-06
         576          582   0.00000000E+00
         576          583   0.00000000E+00
         576          584   0.00000000E+00
         576          585   0.00000000E+00
         576          586  -0.23316169E-04
         576          587  -0.43023341E-04
         576          588   0.00000000E+00
         576          589   0.00000000E+00
         576          590   0.00000000E+00
         577          577   0.24730616E+04
         577          571   0.63524775E+02
         577          572  -0.21147957E+02
         577          573   0.00000000E+00
         577          574  -0.65476585E+02
         577          575  -0.63507727E+02
         577          576   0.17349339E+04
         577          578  -0.37801962E-04
         577          579  -0.10044583E+00
         577          580   0.41318012E-01
         577          561  -0.10416549E-06
         577          562   0.00000000E+00
         577          563   0.00000000E+00
         577          564   0.33227616E-08
         577          565   0.94141969E-10
         577          566  -0.29001414E-04
         577          567  -0.56024334E-04
         577          568   0.89792377E-14
         577          569   0.16472238E-09
         577          570  -0.67721397E-10
         577          581  -0.18818430E-06
         577          582   0.00000000E+00
         577          583   0.00000000E+00
         577          584   0.60028663E-08
         577          585   0.17007590E-09
         577          586  -0.43021369E-04
         577          587  -0.82467473E-04
         577          588   0.16221797E-13
         577          589   0.29758574E-09
         577          590  -0.12234477E-09
         578          578   0.64697240E-04
         578          571   0.00000000E+00
         578          572   0.00000000E+00
         578          573   0.00000000E+00
         578          574   0.00000000E+00
         578          575   0.00000000E+00
         578          576   0.00000000E+00
         578          577  -0.37811295E-04
         578          579  -0.15148150E-04
         578          580  -0.36271546E-04
         578          561   0.00000000E+00
         578          562   0.00000000E+00
         578          563   0.00000000E+00
         578          564   0.00000000E+00
         578          565   0.00000000E+00
         578          566   0.00000000E+00
         578          567   0.89799625E-14
         578          568  -0.13325855E-13
         578          569  -0.16700932E-14
         578          570   0.64551415E-14
         578          581   0.00000000E+00
         578          582   0.00000000E+00
         578          583   0.00000000E+00
         578          584   0.00000000E+00
         578          585   0.00000000E+00
         578          586   0.00000000E+00
         578          587   0.16223106E-13
         578          588  -0.24074350E-13
         578          589  -0.30171730E-14
         578          590   0.11661791E-13
         579          579   0.82918613E+02
         579          571   0.00000000E+00
         579          572   0.00000000E+00
         579          573   0.00000000E+00
         579          574   0.00000000E+00
         579          575   0.00000000E+00
         579          576   0.43198833E-04
         579          577  -0.10043579E+00
         579          578  -0.15144552E-04
         579          580   0.27988354E+02
         579          561   0.00000000E+00
         579          562   0.00000000E+00
         579          563   0.00000000E+00
         579          564   0.00000000E+00
         579          565   0.00000000E+00
         579          566   0.00000000E+00
         579          567   0.16470591E-09
         579          568  -0.16700306E-14
         579          569  -0.13596669E-06
         579          570  -0.45894217E-07
         579          581   0.00000000E+00
         579          582   0.00000000E+00
         579          583   0.00000000E+00
         579          584   0.00000000E+00
         579          585   0.00000000E+00
         579          586   0.00000000E+00
         579          587   0.29755598E-09
         579          588  -0.30170599E-14
         579          589  -0.24563600E-06
         579          590  -0.82912014E-07
         580          580   0.11253969E+05
         580          571   0.30300433E+04
         580          572   0.20725508E+03
         580          573   0.00000000E+00
         580          574   0.00000000E+00
         580          575   0.18189492E-05
         580          576   0.00000000E+00
         580          577   0.41318012E-01
         580          578  -0.36262065E-04
         580          579   0.27988354E+02
         580          561  -0.49685484E-05
         580          562  -0.33984895E-06
         580          563   0.00000000E+00
         580          564   0.00000000E+00
         580          565  -0.29826433E-14
         580          566   0.00000000E+00
         580          567  -0.67721397E-10
         580          568   0.64541734E-14
         580          569  -0.45894217E-07
         580          570  -0.18453826E-04
         580          581  -0.89761276E-05
         580          582  -0.61396756E-06
         580          583   0.00000000E+00
         580          584   0.00000000E+00
         580          585  -0.53884122E-14
         580          586   0.00000000E+00
         580          587  -0.12234477E-09
         580          588   0.11660042E-13
         580          589  -0.82912014E-07
         580          590  -0.33338490E-04
         581          581   0.80089945E+04
         581          582   0.00000000E+00
         581          583   0.00000000E+00
         581          584   0.00000000E+00
         581          585   0.00000000E+00
         581          586   0.65321471E+02
         581          587   0.62241632E+02
         581          588   0.00000000E+00
         581          589   0.00000000E+00
         581          590   0.29688392E+04
         581          571  -0.12464975E-04
         581          572   0.00000000E+00
         581          573   0.00000000E+00
         581          574   0.00000000E+00
         581          575   0.00000000E+00
         581          576  -0.10166418E-06
         581          577  -0.96871140E-07
         581          578   0.00000000E+00
         581          579   0.00000000E+00
         581          580  -0.46206178E-05
         581          591  -0.23458652E-04
         581          592   0.00000000E+00
         581          593   0.00000000E+00
         581          594   0.00000000E+00
         581          595   0.00000000E+00
         581          596  -0.19132847E-06
         581          597  -0.18230814E-06
         581          598   0.00000000E+00
         581          599   0.00000000E+00
         581          600  -0.86958432E-05
         582          582   0.50427400E+04
         582          581   0.00000000E+00
         582          583   0.00000000E+00
         582          584   0.63450217E+01
         582          585   0.63450217E+01
         582          586   0.00000000E+00
         582          587  -0.21136331E+02
         582          588   0.00000000E+00
         582          589   0.00000000E+00
         582          590   0.20306871E+03
         582          571   0.00000000E+00
         582          572  -0.78450885E-05
         582          573   0.00000000E+00
         582          574   0.00000000E+00
         582          575   0.00000000E+00
         582          576   0.00000000E+00
         582          577   0.00000000E+00
         582          578   0.00000000E+00
         582          579   0.00000000E+00
         582          580  -0.31605048E-06
         582          591   0.00000000E+00
         582          592  -0.14764186E-04
         582          593   0.00000000E+00
         582          594   0.00000000E+00
         582          595   0.00000000E+00
         582          596   0.00000000E+00
         582          597   0.00000000E+00
         582          598   0.00000000E+00
         582          599   0.00000000E+00
         582          600  -0.59479610E-06
         583          583   0.63847919E+03
         583          581   0.00000000E+00
         583          582   0.00000000E+00
         583          584   0.00000000E+00
         583          585   0.00000000E+00
         583          586   0.00000000E+00
         583          587   0.00000000E+00
         583          588   0.00000000E+00
         583          589   0.00000000E+00
         583          590   0.00000000E+00
         583          571   0.00000000E+00
         583          572   0.00000000E+00
         583          573  -0.99371120E-06
         583          574   0.00000000E+00
         583          575   0.00000000E+00
         583          576   0.00000000E+00
         583          577   0.00000000E+00
         583          578   0.00000000E+00
         583          579   0.00000000E+00
         583          580   0.00000000E+00
         583          591   0.00000000E+00
         583          592   0.00000000E+00
         583          593  -0.18701302E-05
         583          594   0.00000000E+00
         583          595   0.00000000E+00
         583          596   0.00000000E+00
         583          597   0.00000000E+00
         583          598   0.00000000E+00
         583          599   0.00000000E+00
         583          600   0.00000000E+00
         584          584   0.10999692E+04
         584          581   0.00000000E+00
         584          582   0.63443872E+01
         584          583   0.00000000E+00
         584          585   0.19035065E+02
         584          586   0.00000000E+00
         584          587  -0.65394231E+02
         584          588   0.00000000E+00
         584          589   0.00000000E+00
         584          590   0.00000000E+00
         584          571   0.00000000E+00
         584          572   0.00000000E+00
         584          573   0.00000000E+00
         584          574  -0.16823356E-05
         584          575   0.00000000E+00
         584          576   0.00000000E+00
         584          577   0.30897709E-08
         584          578   0.00000000E+00
         584          579   0.00000000E+00
         584          580   0.00000000E+00
         584          591   0.00000000E+00
         584          592   0.00000000E+00
         584          593   0.00000000E+00
         584          594  -0.31660976E-05
         584          595   0.00000000E+00
         584          596   0.00000000E+00
         584          597   0.58148422E-08
         584          598   0.00000000E+00
         584          599   0.00000000E+00
         584          600   0.00000000E+00
         585          585   0.19049603E+02
         585          581   0.00000000E+00
         585          582   0.63443872E+01
         585          583   0.00000000E+00
         585          584   0.19035065E+02
         585          586   0.00000000E+00
         585          587  -0.63465328E+02
         585          588   0.00000000E+00
         585          589   0.00000000E+00
         585          590   0.17822328E-05
         585          571   0.00000000E+00
         585          572   0.00000000E+00
         585          573   0.00000000E+00
         585          574   0.00000000E+00
         585          575  -0.22576422E-10
         585          576   0.00000000E+00
         585          577   0.87527969E-10
         585          578   0.00000000E+00
         585          579   0.00000000E+00
         585          580  -0.27738175E-14
         585          591   0.00000000E+00
         585          592   0.00000000E+00
         585          593   0.00000000E+00
         585          594   0.00000000E+00
         585          595  -0.42488047E-10
         585          596   0.00000000E+00
         585          597   0.16472462E-09
         585          598   0.00000000E+00
         585          599   0.00000000E+00
         585          600  -0.52202287E-14
         586          586   0.14534496E+04
         586          581   0.65321471E+02
         586          582   0.00000000E+00
         586          583   0.00000000E+00
         586          584   0.00000000E+00
         586          585   0.00000000E+00
         586          587   0.17126034E+04
         586          588   0.00000000E+00
         586          589   0.43198833E-04
         586          590   0.00000000E+00
         586          571  -0.10166418E-06
         586          572   0.00000000E+00
         586          573   0.00000000E+00
         586          574   0.00000000E+00
         586          575   0.00000000E+00
         586          576  -0.21267843E-04
         586          577  -0.40678818E-04
         586          578   0.00000000E+00
         586          579   0.00000000E+00
         586          580   0.00000000E+00
         586          591  -0.19132847E-06
         586          592   0.00000000E+00
         586          593   0.00000000E+00
         586          594   0.00000000E+00
         586          595   0.00000000E+00
         586          596  -0.29478432E-04
         586          597  -0.55461249E-04
         586          598   0.00000000E+00
         586          599   0.00000000E+00
         586          600   0.00000000E+00
         587          587   0.24527532E+04
         587          581   0.62241632E+02
         587          582  -0.21147957E+02
         587          583   0.00000000E+00
         587          584  -0.65435654E+02
         587          585  -0.63506567E+02
         587          586   0.17125771E+04
         587          588  -0.37691353E-04
         587          589  -0.98416733E-01
         587          590   0.40483799E-01
         587          571  -0.96871140E-07
         587          572   0.00000000E+00
         587          573   0.00000000E+00
         587          574   0.30900799E-08
         587          575   0.87549528E-10
         587          576  -0.40676876E-04
         587          577  -0.79515175E-04
         587          578   0.83504522E-14
         587          579   0.15318744E-09
         587          580  -0.62979099E-10
         587          591  -0.18230814E-06
         587          592   0.00000000E+00
         587          593   0.00000000E+00
         587          594   0.58154236E-08
         587          595   0.16476519E-09
         587          596  -0.55458650E-04
         587          597  -0.10745505E-03
         587          598   0.15715263E-13
         587          599   0.28829347E-09
         587          600  -0.11852449E-09
         588          588   0.64533088E-04
         588          581   0.00000000E+00
         588          582   0.00000000E+00
         588          583   0.00000000E+00
         588          584   0.00000000E+00
         588          585   0.00000000E+00
         588          586   0.00000000E+00
         588          587  -0.37700677E-04
         588          589  -0.15168723E-04
         588          590  -0.36192030E-04
         588          571   0.00000000E+00
         588          572   0.00000000E+00
         588          573   0.00000000E+00
         588          574   0.00000000E+00
         588          575   0.00000000E+00
         588          576   0.00000000E+00
         588          577   0.83511263E-14
         588          578  -0.12392691E-13
         588          579  -0.15531423E-14
         588          580   0.60031100E-14
         588          591   0.00000000E+00
         588          592   0.00000000E+00
         588          593   0.00000000E+00
         588          594   0.00000000E+00
         588          595   0.00000000E+00
         588          596   0.00000000E+00
         588          597   0.15716531E-13
         588          598  -0.23322616E-13
         588          599  -0.29229602E-14
         588          600   0.11297646E-13
         589          589   0.81243733E+02
         589          581   0.00000000E+00
         589          582   0.00000000E+00
         589          583   0.00000000E+00
         589          584   0.00000000E+00
         589          585   0.00000000E+00
         589          586   0.43198833E-04
         589          587  -0.98406891E-01
         589          588  -0.15165124E-04
         589          590   0.27423015E+02
         589          571   0.00000000E+00
         589          572   0.00000000E+00
         589          573   0.00000000E+00
         589          574   0.00000000E+00
         589          575   0.00000000E+00
         589          576   0.00000000E+00
         589          577   0.15317212E-09
         589          578  -0.15530841E-14
         589          579  -0.12644541E-06
         589          580  -0.42680402E-07
         589          591   0.00000000E+00
         589          592   0.00000000E+00
         589          593   0.00000000E+00
         589          594   0.00000000E+00
         589          595   0.00000000E+00
         589          596   0.00000000E+00
         589          597   0.28826464E-09
         589          598  -0.29228506E-14
         589          599  -0.23796589E-06
         589          600  -0.80323042E-07
         590          590   0.11026649E+05
         590          581   0.29688392E+04
         590          582   0.20306871E+03
         590          583   0.00000000E+00
         590          584   0.00000000E+00
         590          585   0.17822081E-05
         590          586   0.00000000E+00
         590          587   0.40483799E-01
         590          588  -0.36182561E-04
         590          589   0.27423015E+02
         590          571  -0.46206178E-05
         590          572  -0.31605048E-06
         590          573   0.00000000E+00
         590          574   0.00000000E+00
         590          575  -0.27737789E-14
         590          576   0.00000000E+00
         590          577  -0.62979099E-10
         590          578   0.60022096E-14
         590          579  -0.42680402E-07
         590          580  -0.17161568E-04
         590          591  -0.86958432E-05
         590          592  -0.59479610E-06
         590          593   0.00000000E+00
         590          594   0.00000000E+00
         590          595  -0.52201561E-14
         590          596   0.00000000E+00
         590          597  -0.11852449E-09
         590          598   0.11295951E-13
         590          599  -0.80323042E-07
         590          600  -0.32297478E-04
         591          591   0.78702013E+04
         591          592   0.00000000E+00
         591          593   0.00000000E+00
         591          594   0.00000000E+00
         591          595   0.00000000E+00
         591          596   0.64189475E+02
         591          597   0.61163005E+02
         591          598   0.00000000E+00
         591          599   0.00000000E+00
         591          600   0.29173902E+04
         591          581  -0.11708856E-04
         591          582   0.00000000E+00
         591          583   0.00000000E+00
         591          584   0.00000000E+00
         591          585   0.00000000E+00
         591          586  -0.95497281E-07
         591          587  -0.90994985E-07
         591          588   0.00000000E+00
         591          589   0.00000000E+00
         591          590  -0.43403335E-05
         591          601  -0.22850688E-04
         591          602   0.00000000E+00
         591          603   0.00000000E+00
         591          604   0.00000000E+00
         591          605   0.00000000E+00
         591          606  -0.18636993E-06
         591          607  -0.17758337E-06
         591          608   0.00000000E+00
         591          609   0.00000000E+00
         591          610  -0.84704783E-05
         592          592   0.49553876E+04
         592          591   0.00000000E+00
         592          593   0.00000000E+00
         592          594   0.63450217E+01
         592          595   0.63450217E+01
         592          596   0.00000000E+00
         592          597  -0.21136331E+02
         592          598   0.00000000E+00
         592          599   0.00000000E+00
         592          600   0.19954960E+03
         592          581   0.00000000E+00
         592          582  -0.73692093E-05
         592          583   0.00000000E+00
         592          584   0.00000000E+00
         592          585   0.00000000E+00
         592          586   0.00000000E+00
         592          587   0.00000000E+00
         592          588   0.00000000E+00
         592          589   0.00000000E+00
         592          590  -0.29687902E-06
         592          601   0.00000000E+00
         592          602  -0.14381551E-04
         592          603   0.00000000E+00
         592          604   0.00000000E+00
         592          605   0.00000000E+00
         592          606   0.00000000E+00
         592          607   0.00000000E+00
         592          608   0.00000000E+00
         592          609   0.00000000E+00
         592          610  -0.57938113E-06
         593          593   0.62741456E+03
         593          591   0.00000000E+00
         593          592   0.00000000E+00
         593          594   0.00000000E+00
         593          595   0.00000000E+00
         593          596   0.00000000E+00
         593          597   0.00000000E+00
         593          598   0.00000000E+00
         593          599   0.00000000E+00
         593          600   0.00000000E+00
         593          581   0.00000000E+00
         593          582   0.00000000E+00
         593          583  -0.93343318E-06
         593          584   0.00000000E+00
         593          585   0.00000000E+00
         593          586   0.00000000E+00
         593          587   0.00000000E+00
         593          588   0.00000000E+00
         593          589   0.00000000E+00
         593          590   0.00000000E+00
         593          601   0.00000000E+00
         593          602   0.00000000E+00
         593          603  -0.18216631E-05
         593          604   0.00000000E+00
         593          605   0.00000000E+00
         593          606   0.00000000E+00
         593          607   0.00000000E+00
         593          608   0.00000000E+00
         593          609   0.00000000E+00
         593          610   0.00000000E+00
         594          594   0.10812369E+04
         594          591   0.00000000E+00
         594          592   0.63443872E+01
         594          593   0.00000000E+00
         594          595   0.19035065E+02
         594          596   0.00000000E+00
         594          597  -0.65359828E+02
         594          598   0.00000000E+00
         594          599   0.00000000E+00
         594          600   0.00000000E+00
         594          581   0.00000000E+00
         594          582   0.00000000E+00
         594          583   0.00000000E+00
         594          584  -0.15802860E-05
         594          585   0.00000000E+00
         594          586   0.00000000E+00
         594          587   0.29023470E-08
         594          588   0.00000000E+00
         594          589   0.00000000E+00
         594          590   0.00000000E+00
         594          601   0.00000000E+00
         594          602   0.00000000E+00
         594          603   0.00000000E+00
         594          604  -0.30840437E-05
         594          605   0.00000000E+00
         594          606   0.00000000E+00
         594          607   0.56641424E-08
         594          608   0.00000000E+00
         594          609   0.00000000E+00
         594          610   0.00000000E+00
         595          595   0.19049352E+02
         595          591   0.00000000E+00
         595          592   0.63443872E+01
         595          593   0.00000000E+00
         595          594   0.19035065E+02
         595          596   0.00000000E+00
         595          597  -0.63464354E+02
         595          598   0.00000000E+00
         595          599   0.00000000E+00
         595          600   0.17513473E-05
         595          581   0.00000000E+00
         595          582   0.00000000E+00
         595          583   0.00000000E+00
         595          584   0.00000000E+00
         595          585  -0.21206948E-10
         595          586   0.00000000E+00
         595          587   0.82218567E-10
         595          588   0.00000000E+00
         595          589   0.00000000E+00
         595          590  -0.26055591E-14
         595          601   0.00000000E+00
         595          602   0.00000000E+00
         595          603   0.00000000E+00
         595          604   0.00000000E+00
         595          605  -0.41386910E-10
         595          606   0.00000000E+00
         595          607   0.16045555E-09
         595          608   0.00000000E+00
         595          609   0.00000000E+00
         595          610  -0.50849392E-14
         596          596   0.14337043E+04
         596          591   0.64189475E+02
         596          592   0.00000000E+00
         596          593   0.00000000E+00
         596          594   0.00000000E+00
         596          595   0.00000000E+00
         596          597   0.16938101E+04
         596          598   0.00000000E+00
         596          599   0.43198833E-04
         596          600   0.00000000E+00
         596          581  -0.95497281E-07
         596          582   0.00000000E+00
         596          583   0.00000000E+00
         596          584   0.00000000E+00
         596          585   0.00000000E+00
         596          586  -0.27430106E-04
         596          587  -0.53116726E-04
         596          588   0.00000000E+00
         596          589   0.00000000E+00
         596          590   0.00000000E+00
         596          601  -0.18636993E-06
         596          602   0.00000000E+00
         596          603   0.00000000E+00
         596          604   0.00000000E+00
         596          605   0.00000000E+00
         596          606  -0.35659341E-04
         596          607  -0.67914355E-04
         596          608   0.00000000E+00
         596          609   0.00000000E+00
         596          610   0.00000000E+00
         597          597   0.24356818E+04
         597          591   0.61163005E+02
         597          592  -0.21147957E+02
         597          593   0.00000000E+00
         597          594  -0.65401247E+02
         597          595  -0.63505592E+02
         597          596   0.16937837E+04
         597          598  -0.37598374E-04
         597          599  -0.96711044E-01
         597          600   0.39782549E-01
         597          581  -0.90994985E-07
         597          582   0.00000000E+00
         597          583   0.00000000E+00
         597          584   0.29026372E-08
         597          585   0.82238818E-10
         597          586  -0.53114157E-04
         597          587  -0.10450275E-03
         597          588   0.78439180E-14
         597          589   0.14389516E-09
         597          590  -0.59158818E-10
         597          601  -0.17758337E-06
         597          602   0.00000000E+00
         597          603   0.00000000E+00
         597          604   0.56647088E-08
         597          605   0.16049507E-09
         597          606  -0.67911129E-04
         597          607  -0.13245113E-03
         597          608   0.15307980E-13
         597          609   0.28082194E-09
         597          610  -0.11545276E-09
         598          598   0.64395100E-04
         598          591   0.00000000E+00
         598          592   0.00000000E+00
         598          593   0.00000000E+00
         598          594   0.00000000E+00
         598          595   0.00000000E+00
         598          596   0.00000000E+00
         598          597  -0.37607690E-04
         598          599  -0.15186017E-04
         598          600  -0.36125187E-04
         598          581   0.00000000E+00
         598          582   0.00000000E+00
         598          583   0.00000000E+00
         598          584   0.00000000E+00
         598          585   0.00000000E+00
         598          586   0.00000000E+00
         598          587   0.78445512E-14
         598          588  -0.11640956E-13
         598          589  -0.14589295E-14
         598          590   0.56389643E-14
         598          601   0.00000000E+00
         598          602   0.00000000E+00
         598          603   0.00000000E+00
         598          604   0.00000000E+00
         598          605   0.00000000E+00
         598          606   0.00000000E+00
         598          607   0.15309216E-13
         598          608  -0.22718178E-13
         598          609  -0.28472076E-14
         598          610   0.11004851E-13
         599          599   0.79835807E+02
         599          591   0.00000000E+00
         599          592   0.00000000E+00
         599          593   0.00000000E+00
         599          594   0.00000000E+00
         599          595   0.00000000E+00
         599          596   0.43198833E-04
         599          597  -0.96701372E-01
         599          598  -0.15182417E-04
         599          600   0.26947784E+02
         599          581   0.00000000E+00
         599          582   0.00000000E+00
         599          583   0.00000000E+00
         599          584   0.00000000E+00
         599          585   0.00000000E+00
         599          586   0.00000000E+00
         599          587   0.14388078E-09
         599          588  -0.14588748E-14
         599          589  -0.11877529E-06
         599          590  -0.40091430E-07
         599          601   0.00000000E+00
         599          602   0.00000000E+00
         599          603   0.00000000E+00
         599          604   0.00000000E+00
         599          605   0.00000000E+00
         599          606   0.00000000E+00
         599          607   0.28079386E-09
         599          608  -0.28471008E-14
         599          609  -0.23179867E-06
         599          610  -0.78241359E-07
         600          600   0.10835560E+05
         600          591   0.29173902E+04
         600          592   0.19954960E+03
         600          593   0.00000000E+00
         600          594   0.00000000E+00
         600          595   0.17513230E-05
         600          596   0.00000000E+00
         600          597   0.39782549E-01
         600          598  -0.36115728E-04
         600          599   0.26947784E+02
         600          581  -0.43403335E-05
         600          582  -0.29687902E-06
         600          583   0.00000000E+00
         600          584   0.00000000E+00
         600          585  -0.26055229E-14
         600          586   0.00000000E+00
         600          587  -0.59158818E-10
         600          588   0.56381186E-14
         600          589  -0.40091430E-07
         600          590  -0.16120556E-04
         600          601  -0.84704783E-05
         600          602  -0.57938113E-06
         600          603   0.00000000E+00
         600          604   0.00000000E+00
         600          605  -0.50848685E-14
         600          606   0.00000000E+00
         600          607  -0.11545276E-09
         600          608   0.11003201E-13
         600          609  -0.78241359E-07
         600          610  -0.31460444E-04
         601          601   0.77544085E+04
         601          602   0.00000000E+00
         601          603   0.00000000E+00
         601          604   0.00000000E+00
         601          605   0.00000000E+00
         601          606   0.63245071E+02
         601          607   0.60263125E+02
         601          608   0.00000000E+00
         601          609   0.00000000E+00
         601          610   0.28744672E+04
         601          591  -0.11100892E-04
         601          592   0.00000000E+00
         601          593   0.00000000E+00
         601          594   0.00000000E+00
         601          595   0.00000000E+00
         601          596  -0.90538736E-07
         601          597  -0.86270216E-07
         601          598   0.00000000E+00
         601          599   0.00000000E+00
         601          600  -0.41149686E-05
         601          611  -0.22362182E-04
         601          612   0.00000000E+00
         601          613   0.00000000E+00
         601          614   0.00000000E+00
         601          615   0.00000000E+00
         601          616  -0.18238568E-06
         601          617  -0.17378696E-06
         601          618   0.00000000E+00
         601          619   0.00000000E+00
         601          620  -0.82893950E-05
         602          602   0.48825111E+04
         602          601   0.00000000E+00
         602          603   0.00000000E+00
         602          604   0.63450217E+01
         602          605   0.63450217E+01
         602          606   0.00000000E+00
         602          607  -0.21136331E+02
         602          608   0.00000000E+00
         602          609   0.00000000E+00
         602          610   0.19661367E+03
         602          591   0.00000000E+00
         602          592  -0.69865749E-05
         602          593   0.00000000E+00
         602          594   0.00000000E+00
         602          595   0.00000000E+00
         602          596   0.00000000E+00
         602          597   0.00000000E+00
         602          598   0.00000000E+00
         602          599   0.00000000E+00
         602          600  -0.28146405E-06
         602          611   0.00000000E+00
         602          612  -0.14074100E-04
         602          613   0.00000000E+00
         602          614   0.00000000E+00
         602          615   0.00000000E+00
         602          616   0.00000000E+00
         602          617   0.00000000E+00
         602          618   0.00000000E+00
         602          619   0.00000000E+00
         602          620  -0.56699502E-06
         603          603   0.61818352E+03
         603          601   0.00000000E+00
         603          602   0.00000000E+00
         603          604   0.00000000E+00
         603          605   0.00000000E+00
         603          606   0.00000000E+00
         603          607   0.00000000E+00
         603          608   0.00000000E+00
         603          609   0.00000000E+00
         603          610   0.00000000E+00
         603          591   0.00000000E+00
         603          592   0.00000000E+00
         603          593  -0.88496615E-06
         603          594   0.00000000E+00
         603          595   0.00000000E+00
         603          596   0.00000000E+00
         603          597   0.00000000E+00
         603          598   0.00000000E+00
         603          599   0.00000000E+00
         603          600   0.00000000E+00
         603          611   0.00000000E+00
         603          612   0.00000000E+00
         603          613  -0.17827193E-05
         603          614   0.00000000E+00
         603          615   0.00000000E+00
         603          616   0.00000000E+00
         603          617   0.00000000E+00
         603          618   0.00000000E+00
         603          619   0.00000000E+00
         603          620   0.00000000E+00
         604          604   0.10656090E+04
         604          601   0.00000000E+00
         604          602   0.63443872E+01
         604          603   0.00000000E+00
         604          605   0.19035065E+02
         604          606   0.00000000E+00
         604          607  -0.65331125E+02
         604          608   0.00000000E+00
         604          609   0.00000000E+00
         604          610   0.00000000E+00
         604          591   0.00000000E+00
         604          592   0.00000000E+00
         604          593   0.00000000E+00
         604          594  -0.14982322E-05
         604          595   0.00000000E+00
         604          596   0.00000000E+00
         604          597   0.27516472E-08
         604          598   0.00000000E+00
         604          599   0.00000000E+00
         604          600   0.00000000E+00
         604          611   0.00000000E+00
         604          612   0.00000000E+00
         604          613   0.00000000E+00
         604          614  -0.30181125E-05
         604          615   0.00000000E+00
         604          616   0.00000000E+00
         604          617   0.55430534E-08
         604          618   0.00000000E+00
         604          619   0.00000000E+00
         604          620   0.00000000E+00
         605          605   0.19049142E+02
         605          601   0.00000000E+00
         605          602   0.63443872E+01
         605          603   0.00000000E+00
         605          604   0.19035065E+02
         605          606   0.00000000E+00
         605          607  -0.63463541E+02
         605          608   0.00000000E+00
         605          609   0.00000000E+00
         605          610   0.17255801E-05
         605          591   0.00000000E+00
         605          592   0.00000000E+00
         605          593   0.00000000E+00
         605          594   0.00000000E+00
         605          595  -0.20105811E-10
         605          596   0.00000000E+00
         605          597   0.77949499E-10
         605          598   0.00000000E+00
         605          599   0.00000000E+00
         605          600  -0.24702696E-14
         605          611   0.00000000E+00
         605          612   0.00000000E+00
         605          613   0.00000000E+00
         605          614   0.00000000E+00
         605          615  -0.40502134E-10
         605          616   0.00000000E+00
         605          617   0.15702530E-09
         605          618   0.00000000E+00
         605          619   0.00000000E+00
         605          620  -0.49762325E-14
         606          606   0.14172312E+04
         606          601   0.63245071E+02
         606          602   0.00000000E+00
         606          603   0.00000000E+00
         606          604   0.00000000E+00
         606          605   0.00000000E+00
         606          607   0.16781312E+04
         606          608   0.00000000E+00
         606          609   0.43198833E-04
         606          610   0.00000000E+00
         606          591  -0.90538736E-07
         606          592   0.00000000E+00
         606          593   0.00000000E+00
         606          594   0.00000000E+00
         606          595   0.00000000E+00
         606          596  -0.33611015E-04
         606          597  -0.65569832E-04
         606          598   0.00000000E+00
         606          599   0.00000000E+00
         606          600   0.00000000E+00
         606          611  -0.18238568E-06
         606          612   0.00000000E+00
         606          613   0.00000000E+00
         606          614   0.00000000E+00
         606          615   0.00000000E+00
         606          616  -0.41575380E-04
         606          617  -0.79819879E-04
         606          618   0.00000000E+00
         606          619   0.00000000E+00
         606          620   0.00000000E+00
         607          607   0.24214394E+04
         607          601   0.60263125E+02
         607          602  -0.21147957E+02
         607          603   0.00000000E+00
         607          604  -0.65372542E+02
         607          605  -0.63504779E+02
         607          606   0.16781047E+04
         607          608  -0.37520803E-04
         607          609  -0.95288017E-01
         607          610   0.39197507E-01
         607          591  -0.86270216E-07
         607          592   0.00000000E+00
         607          593   0.00000000E+00
         607          594   0.27519224E-08
         607          595   0.77968698E-10
         607          596  -0.65566636E-04
         607          597  -0.12949883E-03
         607          598   0.74366351E-14
         607          599   0.13642364E-09
         607          600  -0.56087091E-10
         607          611  -0.17378696E-06
         607          612   0.00000000E+00
         607          613   0.00000000E+00
         607          614   0.55436077E-08
         607          615   0.15706398E-09
         607          616  -0.79816054E-04
         607          617  -0.15633438E-03
         607          618   0.14980723E-13
         607          619   0.27481848E-09
         607          620  -0.11298459E-09
         608          608   0.64279979E-04
         608          601   0.00000000E+00
         608          602   0.00000000E+00
         608          603   0.00000000E+00
         608          604   0.00000000E+00
         608          605   0.00000000E+00
         608          606   0.00000000E+00
         608          607  -0.37530113E-04
         608          609  -0.15200445E-04
         608          610  -0.36069422E-04
         608          591   0.00000000E+00
         608          592   0.00000000E+00
         608          593   0.00000000E+00
         608          594   0.00000000E+00
         608          595   0.00000000E+00
         608          596   0.00000000E+00
         608          597   0.74372354E-14
         608          598  -0.11036518E-13
         608          599  -0.13831769E-14
         608          600   0.53461701E-14
         608          611   0.00000000E+00
         608          612   0.00000000E+00
         608          613   0.00000000E+00
         608          614   0.00000000E+00
         608          615   0.00000000E+00
         608          616   0.00000000E+00
         608          617   0.14981932E-13
         608          618  -0.22232505E-13
         608          619  -0.27863395E-14
         608          620   0.10769588E-13
         609          609   0.78661199E+02
         609          601   0.00000000E+00
         609          602   0.00000000E+00
         609          603   0.00000000E+00
         609          604   0.00000000E+00
         609          605   0.00000000E+00
         609          606   0.43198833E-04
         609          607  -0.95278487E-01
         609          608  -0.15196844E-04
         609          610   0.26551306E+02
         609          591   0.00000000E+00
         609          592   0.00000000E+00
         609          593   0.00000000E+00
         609          594   0.00000000E+00
         609          595   0.00000000E+00
         609          596   0.00000000E+00
         609          597   0.13641000E-09
         609          598  -0.13831250E-14
         609          599  -0.11260807E-06
         609          600  -0.38009746E-07
         609          611   0.00000000E+00
         609          612   0.00000000E+00
         609          613   0.00000000E+00
         609          614   0.00000000E+00
         609          615   0.00000000E+00
         609          616   0.00000000E+00
         609          617   0.27479100E-09
         609          618  -0.27862350E-14
         609          619  -0.22684324E-06
         609          620  -0.76568701E-07
         610          610   0.10676139E+05
         610          601   0.28744672E+04
         610          602   0.19661367E+03
         610          603   0.00000000E+00
         610          604   0.00000000E+00
         610          605   0.17255561E-05
         610          606   0.00000000E+00
         610          607   0.39197507E-01
         610          608  -0.36059971E-04
         610          609   0.26551306E+02
         610          591  -0.41149686E-05
         610          592  -0.28146405E-06
         610          593   0.00000000E+00
         610          594   0.00000000E+00
         610          595  -0.24702353E-14
         610          596   0.00000000E+00
         610          597  -0.56087091E-10
         610          598   0.53453683E-14
         610          599  -0.38009746E-07
         610          600  -0.15283521E-04
         610          611  -0.82893950E-05
         610          612  -0.56699502E-06
         610          613   0.00000000E+00
         610          614   0.00000000E+00
         610          615  -0.49761633E-14
         610          616   0.00000000E+00
         610          617  -0.11298459E-09
         610          618   0.10767973E-13
         610          619  -0.76568701E-07
         610          620  -0.30787877E-04
         611          611   0.76583920E+04
         611          612   0.00000000E+00
         611          613   0.00000000E+00
         611          614   0.00000000E+00
         611          615   0.00000000E+00
         611          616   0.62461961E+02
         611          617   0.59516936E+02
         611          618   0.00000000E+00
         611          619   0.00000000E+00
         611          620   0.28388750E+04
         611          601  -0.10612386E-04
         611          602   0.00000000E+00
         611          603   0.00000000E+00
         611          604   0.00000000E+00
         611          605   0.00000000E+00
         611          606  -0.86554488E-07
         611          607  -0.82473808E-07
         611          608   0.00000000E+00
         611          609   0.00000000E+00
         611          610  -0.39338853E-05
         611          621  -0.21969690E-04
         611          622   0.00000000E+00
         611          623   0.00000000E+00
         611          624   0.00000000E+00
         611          625   0.00000000E+00
         611          626  -0.17918452E-06
         611          627  -0.17073672E-06
         611          628   0.00000000E+00
         611          629   0.00000000E+00
         611          630  -0.81439028E-05
         612          612   0.48220811E+04
         612          611   0.00000000E+00
         612          613   0.00000000E+00
         612          614   0.63450217E+01
         612          615   0.63450217E+01
         612          616   0.00000000E+00
         612          617  -0.21136331E+02
         612          618   0.00000000E+00
         612          619   0.00000000E+00
         612          620   0.19417916E+03
         612          601   0.00000000E+00
         612          602  -0.66791236E-05
         612          603   0.00000000E+00
         612          604   0.00000000E+00
         612          605   0.00000000E+00
         612          606   0.00000000E+00
         612          607   0.00000000E+00
         612          608   0.00000000E+00
         612          609   0.00000000E+00
         612          610  -0.26907794E-06
         612          621   0.00000000E+00
         612          622  -0.13827077E-04
         612          623   0.00000000E+00
         612          624   0.00000000E+00
         612          625   0.00000000E+00
         612          626   0.00000000E+00
         612          627   0.00000000E+00
         612          628   0.00000000E+00
         612          629   0.00000000E+00
         612          630  -0.55704335E-06
         613          613   0.61052906E+03
         613          611   0.00000000E+00
         613          612   0.00000000E+00
         613          614   0.00000000E+00
         613          615   0.00000000E+00
         613          616   0.00000000E+00
         613          617   0.00000000E+00
         613          618   0.00000000E+00
         613          619   0.00000000E+00
         613          620   0.00000000E+00
         613          601   0.00000000E+00
         613          602   0.00000000E+00
         613          603  -0.84602232E-06
         613          604   0.00000000E+00
         613          605   0.00000000E+00
         613          606   0.00000000E+00
         613          607   0.00000000E+00
         613          608   0.00000000E+00
         613          609   0.00000000E+00
         613          610   0.00000000E+00
         613          621   0.00000000E+00
         613          622   0.00000000E+00
         613          623  -0.17514297E-05
         613          624   0.00000000E+00
         613          625   0.00000000E+00
         613          626   0.00000000E+00
         613          627   0.00000000E+00
         613          628   0.00000000E+00
         613          629   0.00000000E+00
         613          630   0.00000000E+00
         614          614   0.10526501E+04
         614          611   0.00000000E+00
         614          612   0.63443872E+01
         614          613   0.00000000E+00
         614          615   0.19035065E+02
         614          616   0.00000000E+00
         614          617  -0.65307325E+02
         614          618   0.00000000E+00
         614          619   0.00000000E+00
         614          620   0.00000000E+00
         614          601   0.00000000E+00
         614          602   0.00000000E+00
         614          603   0.00000000E+00
         614          604  -0.14323009E-05
         614          605   0.00000000E+00
         614          606   0.00000000E+00
         614          607   0.26305582E-08
         614          608   0.00000000E+00
         614          609   0.00000000E+00
         614          610   0.00000000E+00
         614          621   0.00000000E+00
         614          622   0.00000000E+00
         614          623   0.00000000E+00
         614          624  -0.29651398E-05
         614          625   0.00000000E+00
         614          626   0.00000000E+00
         614          627   0.54457639E-08
         614          628   0.00000000E+00
         614          629   0.00000000E+00
         614          630   0.00000000E+00
         615          615   0.19048968E+02
         615          611   0.00000000E+00
         615          612   0.63443872E+01
         615          613   0.00000000E+00
         615          614   0.19035065E+02
         615          616   0.00000000E+00
         615          617  -0.63462866E+02
         615          618   0.00000000E+00
         615          619   0.00000000E+00
         615          620   0.17042136E-05
         615          601   0.00000000E+00
         615          602   0.00000000E+00
         615          603   0.00000000E+00
         615          604   0.00000000E+00
         615          605  -0.19221034E-10
         615          606   0.00000000E+00
         615          607   0.74519253E-10
         615          608   0.00000000E+00
         615          609   0.00000000E+00
         615          610  -0.23615629E-14
         615          621   0.00000000E+00
         615          622   0.00000000E+00
         615          623   0.00000000E+00
         615          624   0.00000000E+00
         615          625  -0.39791256E-10
         615          626   0.00000000E+00
         615          627   0.15426926E-09
         615          628   0.00000000E+00
         615          629   0.00000000E+00
         615          630  -0.48888917E-14
         616          616   0.14035715E+04
         616          611   0.62461961E+02
         616          612   0.00000000E+00
         616          613   0.00000000E+00
         616          614   0.00000000E+00
         616          615   0.00000000E+00
         616          617   0.16651301E+04
         616          618   0.00000000E+00
         616          619   0.43198833E-04
         616          620   0.00000000E+00
         616          601  -0.86554488E-07
         616          602   0.00000000E+00
         616          603   0.00000000E+00
         616          604   0.00000000E+00
         616          605   0.00000000E+00
         616          606  -0.39527053E-04
         616          607  -0.77475355E-04
         616          608   0.00000000E+00
         616          609   0.00000000E+00
         616          610   0.00000000E+00
         616          621  -0.17918452E-06
         616          622   0.00000000E+00
         616          623   0.00000000E+00
         616          624   0.00000000E+00
         616          625   0.00000000E+00
         616          626  -0.47039573E-04
         616          627  -0.90807348E-04
         616          628   0.00000000E+00
         616          629   0.00000000E+00
         616          630   0.00000000E+00
         617          617   0.24096295E+04
         617          611   0.59516936E+02
         617          612  -0.21147957E+02
         617          613   0.00000000E+00
         617          614  -0.65348740E+02
         617          615  -0.63504104E+02
         617          616   0.16651035E+04
         617          618  -0.37456480E-04
         617          619  -0.94108028E-01
         617          620   0.38712385E-01
         617          601  -0.82473808E-07
         617          602   0.00000000E+00
         617          603   0.00000000E+00
         617          604   0.26308213E-08
         617          605   0.74537607E-10
         617          606  -0.77471560E-04
         617          607  -0.15338208E-03
         617          608   0.71093785E-14
         617          609   0.13042018E-09
         617          610  -0.53618922E-10
         617          621  -0.17073672E-06
         617          622   0.00000000E+00
         617          623   0.00000000E+00
         617          624   0.54463085E-08
         617          625   0.15430725E-09
         617          626  -0.90802971E-04
         617          627  -0.17836733E-03
         617          628   0.14717788E-13
         617          629   0.26999497E-09
         617          630  -0.11100153E-09
         618          618   0.64184519E-04
         618          611   0.00000000E+00
         618          612   0.00000000E+00
         618          613   0.00000000E+00
         618          614   0.00000000E+00
         618          615   0.00000000E+00
         618          616   0.00000000E+00
         618          617  -0.37465785E-04
         618          619  -0.15212408E-04
         618          620  -0.36023180E-04
         618          601   0.00000000E+00
         618          602   0.00000000E+00
         618          603   0.00000000E+00
         618          604   0.00000000E+00
         618          605   0.00000000E+00
         618          606   0.00000000E+00
         618          607   0.71099523E-14
         618          608  -0.10550845E-13
         618          609  -0.13223088E-14
         618          610   0.51109065E-14
         618          621   0.00000000E+00
         618          622   0.00000000E+00
         618          623   0.00000000E+00
         618          624   0.00000000E+00
         618          625   0.00000000E+00
         618          626   0.00000000E+00
         618          627   0.14718976E-13
         618          628  -0.21842289E-13
         618          629  -0.27374348E-14
         618          630   0.10580564E-13
         619          619   0.77687201E+02
         619          611   0.00000000E+00
         619          612   0.00000000E+00
         619          613   0.00000000E+00
         619          614   0.00000000E+00
         619          615   0.00000000E+00
         619          616   0.43198833E-04
         619          617  -0.94098616E-01
         619          618  -0.15208807E-04
         619          620   0.26222543E+02
         619          601   0.00000000E+00
         619          602   0.00000000E+00
         619          603   0.00000000E+00
         619          604   0.00000000E+00
         619          605   0.00000000E+00
         619          606   0.00000000E+00
         619          607   0.13040714E-09
         619          608  -0.13222592E-14
         619          609  -0.10765264E-06
         619          610  -0.36337089E-07
         619          621   0.00000000E+00
         619          622   0.00000000E+00
         619          623   0.00000000E+00
         619          624   0.00000000E+00
         619          625   0.00000000E+00
         619          626   0.00000000E+00
         619          627   0.26996798E-09
         619          628  -0.27373321E-14
         619          629  -0.22286178E-06
         619          630  -0.75224798E-07
         620          620   0.10543945E+05
         620          611   0.28388750E+04
         620          612   0.19417916E+03
         620          613   0.00000000E+00
         620          614   0.00000000E+00
         620          615   0.17041899E-05
         620          616   0.00000000E+00
         620          617   0.38712385E-01
         620          618  -0.36013737E-04
         620          619   0.26222543E+02
         620          601  -0.39338853E-05
         620          602  -0.26907794E-06
         620          603   0.00000000E+00
         620          604   0.00000000E+00
         620          605  -0.23615301E-14
         620          606   0.00000000E+00
         620          607  -0.53618922E-10
         620          608   0.51101400E-14
         620          609  -0.36337089E-07
         620          610  -0.14610955E-04
         620          621  -0.81439028E-05
         620          622  -0.55704335E-06
         620          623   0.00000000E+00
         620          624   0.00000000E+00
         620          625  -0.48888237E-14
         620          626   0.00000000E+00
         620          627  -0.11100153E-09
         620          628   0.10578977E-13
         620          629  -0.75224798E-07
         620          630  -0.30247500E-04
         621          621   0.75791716E+04
         621          622   0.00000000E+00
         621          623   0.00000000E+00
         621          624   0.00000000E+00
         621          625   0.00000000E+00
         621          626   0.61815840E+02
         621          627   0.58901277E+02
         621          628   0.00000000E+00
         621          629   0.00000000E+00
         621          630   0.28095089E+04
         621          611  -0.10219894E-04
         621          612   0.00000000E+00
         621          613   0.00000000E+00
         621          614   0.00000000E+00
         621          615   0.00000000E+00
         621          616  -0.83353327E-07
         621          617  -0.79423569E-07
         621          618   0.00000000E+00
         621          619   0.00000000E+00
         621          620  -0.37883931E-05
         621          631  -0.21654271E-04
         621          632   0.00000000E+00
         621          633   0.00000000E+00
         621          634   0.00000000E+00
         621          635   0.00000000E+00
         621          636  -0.17661197E-06
         621          637  -0.16828546E-06
         621          638   0.00000000E+00
         621          639   0.00000000E+00
         621          640  -0.80269808E-05
         622          622   0.47722221E+04
         622          621   0.00000000E+00
         622          623   0.00000000E+00
         622          624   0.63450217E+01
         622          625   0.63450217E+01
         622          626   0.00000000E+00
         622          627  -0.21136331E+02
         622          628   0.00000000E+00
         622          629   0.00000000E+00
         622          630   0.19217052E+03
         622          611   0.00000000E+00
         622          612  -0.64321006E-05
         622          613   0.00000000E+00
         622          614   0.00000000E+00
         622          615   0.00000000E+00
         622          616   0.00000000E+00
         622          617   0.00000000E+00
         622          618   0.00000000E+00
         622          619   0.00000000E+00
         622          620  -0.25912627E-06
         622          631   0.00000000E+00
         622          632  -0.13628562E-04
         622          633   0.00000000E+00
         622          634   0.00000000E+00
         622          635   0.00000000E+00
         622          636   0.00000000E+00
         622          637   0.00000000E+00
         622          638   0.00000000E+00
         622          639   0.00000000E+00
         622          640  -0.54904588E-06
         623          623   0.60421359E+03
         623          621   0.00000000E+00
         623          622   0.00000000E+00
         623          624   0.00000000E+00
         623          625   0.00000000E+00
         623          626   0.00000000E+00
         623          627   0.00000000E+00
         623          628   0.00000000E+00
         623          629   0.00000000E+00
         623          630   0.00000000E+00
         623          611   0.00000000E+00
         623          612   0.00000000E+00
         623          613  -0.81473274E-06
         623          614   0.00000000E+00
         623          615   0.00000000E+00
         623          616   0.00000000E+00
         623          617   0.00000000E+00
         623          618   0.00000000E+00
         623          619   0.00000000E+00
         623          620   0.00000000E+00
         623          631   0.00000000E+00
         623          632   0.00000000E+00
         623          633  -0.17262845E-05
         623          634   0.00000000E+00
         623          635   0.00000000E+00
         623          636   0.00000000E+00
         623          637   0.00000000E+00
         623          638   0.00000000E+00
         623          639   0.00000000E+00
         623          640   0.00000000E+00
         624          624   0.10419581E+04
         624          621   0.00000000E+00
         624          622   0.63443872E+01
         624          623   0.00000000E+00
         624          625   0.19035065E+02
         624          626   0.00000000E+00
         624          627  -0.65287688E+02
         624          628   0.00000000E+00
         624          629   0.00000000E+00
         624          630   0.00000000E+00
         624          611   0.00000000E+00
         624          612   0.00000000E+00
         624          613   0.00000000E+00
         624          614  -0.13793282E-05
         624          615   0.00000000E+00
         624          616   0.00000000E+00
         624          617   0.25332687E-08
         624          618   0.00000000E+00
         624          619   0.00000000E+00
         624          620   0.00000000E+00
         624          631   0.00000000E+00
         624          632   0.00000000E+00
         624          633   0.00000000E+00
         624          634  -0.29225693E-05
         624          635   0.00000000E+00
         624          636   0.00000000E+00
         624          637   0.53675791E-08
         624          638   0.00000000E+00
         624          639   0.00000000E+00
         624          640   0.00000000E+00
         625          625   0.19048825E+02
         625          621   0.00000000E+00
         625          622   0.63443872E+01
         625          623   0.00000000E+00
         625          624   0.19035065E+02
         625          626   0.00000000E+00
         625          627  -0.63462310E+02
         625          628   0.00000000E+00
         625          629   0.00000000E+00
         625          630   0.16865848E-05
         625          611   0.00000000E+00
         625          612   0.00000000E+00
         625          613   0.00000000E+00
         625          614   0.00000000E+00
         625          615  -0.18510157E-10
         625          616   0.00000000E+00
         625          617   0.71763207E-10
         625          618   0.00000000E+00
         625          619   0.00000000E+00
         625          620  -0.22742221E-14
         625          631   0.00000000E+00
         625          632   0.00000000E+00
         625          633   0.00000000E+00
         625          634   0.00000000E+00
         625          635  -0.39219973E-10
         625          636   0.00000000E+00
         625          637   0.15205441E-09
         625          638   0.00000000E+00
         625          639   0.00000000E+00
         625          640  -0.48187019E-14
         626          626   0.13923013E+04
         626          621   0.61815840E+02
         626          622   0.00000000E+00
         626          623   0.00000000E+00
         626          624   0.00000000E+00
         626          625   0.00000000E+00
         626          627   0.16544033E+04
         626          628   0.00000000E+00
         626          629   0.43198833E-04
         626          630   0.00000000E+00
         626          611  -0.83353327E-07
         626          612   0.00000000E+00
         626          613   0.00000000E+00
         626          614   0.00000000E+00
         626          615   0.00000000E+00
         626          616  -0.44991247E-04
         626          617  -0.88462825E-04
         626          618   0.00000000E+00
         626          619   0.00000000E+00
         626          620   0.00000000E+00
         626          631  -0.17661197E-06
         626          632   0.00000000E+00
         626          633   0.00000000E+00
         626          634   0.00000000E+00
         626          635   0.00000000E+00
         626          636  -0.51948827E-04
         626          637  -0.10067339E-03
         626          638   0.00000000E+00
         626          639   0.00000000E+00
         626          640   0.00000000E+00
         627          627   0.23998855E+04
         627          621   0.58901277E+02
         627          622  -0.21147957E+02
         627          623   0.00000000E+00
         627          624  -0.65329101E+02
         627          625  -0.63503548E+02
         627          626   0.16543767E+04
         627          628  -0.37403409E-04
         627          629  -0.93134454E-01
         627          630   0.38312125E-01
         627          611  -0.79423569E-07
         627          612   0.00000000E+00
         627          613   0.00000000E+00
         627          614   0.25335221E-08
         627          615   0.71780883E-10
         627          616  -0.88458477E-04
         627          617  -0.17541504E-03
         627          618   0.68464428E-14
         627          619   0.12559667E-09
         627          620  -0.51635861E-10
         627          631  -0.16828546E-06
         627          632   0.00000000E+00
         627          633   0.00000000E+00
         627          634   0.53681159E-08
         627          635   0.15209186E-09
         627          636  -0.10066851E-03
         627          637  -0.19814603E-03
         627          638   0.14506484E-13
         627          639   0.26611866E-09
         627          640  -0.10940788E-09
         628          628   0.64105758E-04
         628          621   0.00000000E+00
         628          622   0.00000000E+00
         628          623   0.00000000E+00
         628          624   0.00000000E+00
         628          625   0.00000000E+00
         628          626   0.00000000E+00
         628          627  -0.37412710E-04
         628          629  -0.15222279E-04
         628          630  -0.35985028E-04
         628          611   0.00000000E+00
         628          612   0.00000000E+00
         628          613   0.00000000E+00
         628          614   0.00000000E+00
         628          615   0.00000000E+00
         628          616   0.00000000E+00
         628          617   0.68469954E-14
         628          618  -0.10160629E-13
         628          619  -0.12734041E-14
         628          620   0.49218830E-14
         628          631   0.00000000E+00
         628          632   0.00000000E+00
         628          633   0.00000000E+00
         628          634   0.00000000E+00
         628          635   0.00000000E+00
         628          636   0.00000000E+00
         628          637   0.14507655E-13
         628          638  -0.21528699E-13
         628          639  -0.26981334E-14
         628          640   0.10428659E-13
         629          629   0.76883585E+02
         629          621   0.00000000E+00
         629          622   0.00000000E+00
         629          623   0.00000000E+00
         629          624   0.00000000E+00
         629          625   0.00000000E+00
         629          626   0.43198833E-04
         629          627  -0.93125140E-01
         629          628  -0.15218678E-04
         629          630   0.25951290E+02
         629          611   0.00000000E+00
         629          612   0.00000000E+00
         629          613   0.00000000E+00
         629          614   0.00000000E+00
         629          615   0.00000000E+00
         629          616   0.00000000E+00
         629          617   0.12558411E-09
         629          618  -0.12733563E-14
         629          619  -0.10367118E-06
         629          620  -0.34993186E-07
         629          631   0.00000000E+00
         629          632   0.00000000E+00
         629          633   0.00000000E+00
         629          634   0.00000000E+00
         629          635   0.00000000E+00
         629          636   0.00000000E+00
         629          637   0.26609205E-09
         629          638  -0.26980323E-14
         629          639  -0.21966215E-06
         629          640  -0.74144796E-07
         630          630   0.10434876E+05
         630          621   0.28095089E+04
         630          622   0.19217052E+03
         630          623   0.00000000E+00
         630          624   0.00000000E+00
         630          625   0.16865614E-05
         630          626   0.00000000E+00
         630          627   0.38312125E-01
         630          628  -0.35975590E-04
         630          629   0.25951290E+02
         630          611  -0.37883931E-05
         630          612  -0.25912627E-06
         630          613   0.00000000E+00
         630          614   0.00000000E+00
         630          615  -0.22741904E-14
         630          616   0.00000000E+00
         630          617  -0.51635861E-10
         630          618   0.49211448E-14
         630          619  -0.34993186E-07
         630          620  -0.14070578E-04
         630          631  -0.80269808E-05
         630          632  -0.54904588E-06
         630          633   0.00000000E+00
         630          634   0.00000000E+00
         630          635  -0.48186348E-14
         630          636   0.00000000E+00
         630          637  -0.10940788E-09
         630          638   0.10427095E-13
         630          639  -0.74144796E-07
         630          640  -0.29813237E-04
         631          631   0.75140791E+04
         631          632   0.00000000E+00
         631          633   0.00000000E+00
         631          634   0.00000000E+00
         631          635   0.00000000E+00
         631          636   0.61284947E+02
         631          637   0.58395413E+02
         631          638   0.00000000E+00
         631          639   0.00000000E+00
         631          640   0.27853800E+04
         631          621  -0.99044750E-05
         631          622   0.00000000E+00
         631          623   0.00000000E+00
         631          624   0.00000000E+00
         631          625   0.00000000E+00
         631          626  -0.80780775E-07
         631          627  -0.76972302E-07
         631          628   0.00000000E+00
         631          629   0.00000000E+00
         631          630  -0.36714711E-05
         631          641  -0.21400704E-04
         631          642   0.00000000E+00
         631          643   0.00000000E+00
         631          644   0.00000000E+00
         631          645   0.00000000E+00
         631          646  -0.17454388E-06
         631          647  -0.16631487E-06
         631          648   0.00000000E+00
         631          649   0.00000000E+00
         631          650  -0.79329864E-05
         632          632   0.47312548E+04
         632          631   0.00000000E+00
         632          633   0.00000000E+00
         632          634   0.63450217E+01
         632          635   0.63450217E+01
         632          636   0.00000000E+00
         632          637  -0.21136331E+02
         632          638   0.00000000E+00
         632          639   0.00000000E+00
         632          640   0.19052009E+03
         632          621   0.00000000E+00
         632          622  -0.62335853E-05
         632          623   0.00000000E+00
         632          624   0.00000000E+00
         632          625   0.00000000E+00
         632          626   0.00000000E+00
         632          627   0.00000000E+00
         632          628   0.00000000E+00
         632          629   0.00000000E+00
         632          630  -0.25112880E-06
         632          641   0.00000000E+00
         632          642  -0.13468974E-04
         632          643   0.00000000E+00
         632          644   0.00000000E+00
         632          645   0.00000000E+00
         632          646   0.00000000E+00
         632          647   0.00000000E+00
         632          648   0.00000000E+00
         632          649   0.00000000E+00
         632          650  -0.54261665E-06
         633          633   0.59902440E+03
         633          631   0.00000000E+00
         633          632   0.00000000E+00
         633          634   0.00000000E+00
         633          635   0.00000000E+00
         633          636   0.00000000E+00
         633          637   0.00000000E+00
         633          638   0.00000000E+00
         633          639   0.00000000E+00
         633          640   0.00000000E+00
         633          621   0.00000000E+00
         633          622   0.00000000E+00
         633          623  -0.78958747E-06
         633          624   0.00000000E+00
         633          625   0.00000000E+00
         633          626   0.00000000E+00
         633          627   0.00000000E+00
         633          628   0.00000000E+00
         633          629   0.00000000E+00
         633          630   0.00000000E+00
         633          641   0.00000000E+00
         633          642   0.00000000E+00
         633          643  -0.17060700E-05
         633          644   0.00000000E+00
         633          645   0.00000000E+00
         633          646   0.00000000E+00
         633          647   0.00000000E+00
         633          648   0.00000000E+00
         633          649   0.00000000E+00
         633          650   0.00000000E+00
         634          634   0.10331729E+04
         634          631   0.00000000E+00
         634          632   0.63443872E+01
         634          633   0.00000000E+00
         634          635   0.19035065E+02
         634          636   0.00000000E+00
         634          637  -0.65271553E+02
         634          638   0.00000000E+00
         634          639   0.00000000E+00
         634          640   0.00000000E+00
         634          621   0.00000000E+00
         634          622   0.00000000E+00
         634          623   0.00000000E+00
         634          624  -0.13367577E-05
         634          625   0.00000000E+00
         634          626   0.00000000E+00
         634          627   0.24550839E-08
         634          628   0.00000000E+00
         634          629   0.00000000E+00
         634          630   0.00000000E+00
         634          641   0.00000000E+00
         634          642   0.00000000E+00
         634          643   0.00000000E+00
         634          644  -0.28883466E-05
         634          645   0.00000000E+00
         634          646   0.00000000E+00
         634          647   0.53047258E-08
         634          648   0.00000000E+00
         634          649   0.00000000E+00
         634          650   0.00000000E+00
         635          635   0.19048707E+02
         635          631   0.00000000E+00
         635          632   0.63443872E+01
         635          633   0.00000000E+00
         635          634   0.19035065E+02
         635          636   0.00000000E+00
         635          637  -0.63461853E+02
         635          638   0.00000000E+00
         635          639   0.00000000E+00
         635          640   0.16720999E-05
         635          621   0.00000000E+00
         635          622   0.00000000E+00
         635          623   0.00000000E+00
         635          624   0.00000000E+00
         635          625  -0.17938874E-10
         635          626   0.00000000E+00
         635          627   0.69548363E-10
         635          628   0.00000000E+00
         635          629   0.00000000E+00
         635          630  -0.22040322E-14
         635          641   0.00000000E+00
         635          642   0.00000000E+00
         635          643   0.00000000E+00
         635          644   0.00000000E+00
         635          645  -0.38760715E-10
         635          646   0.00000000E+00
         635          647   0.15027388E-09
         635          648   0.00000000E+00
         635          649   0.00000000E+00
         635          650  -0.47622758E-14
         636          636   0.13830409E+04
         636          631   0.61284947E+02
         636          632   0.00000000E+00
         636          633   0.00000000E+00
         636          634   0.00000000E+00
         636          635   0.00000000E+00
         636          637   0.16455894E+04
         636          638   0.00000000E+00
         636          639   0.43198833E-04
         636          640   0.00000000E+00
         636          621  -0.80780775E-07
         636          622   0.00000000E+00
         636          623   0.00000000E+00
         636          624   0.00000000E+00
         636          625   0.00000000E+00
         636          626  -0.49900501E-04
         636          627  -0.98328864E-04
         636          628   0.00000000E+00
         636          629   0.00000000E+00
         636          630   0.00000000E+00
         636          641  -0.17454388E-06
         636          642   0.00000000E+00
         636          643   0.00000000E+00
         636          644   0.00000000E+00
         636          645   0.00000000E+00
         636          646  -0.56264815E-04
         636          647  -0.10934361E-03
         636          648   0.00000000E+00
         636          649   0.00000000E+00
         636          650   0.00000000E+00
         637          637   0.23918792E+04
         637          631   0.58395413E+02
         637          632  -0.21147957E+02
         637          633   0.00000000E+00
         637          634  -0.65312964E+02
         637          635  -0.63503091E+02
         637          636   0.16455628E+04
         637          638  -0.37359803E-04
         637          639  -0.92334505E-01
         637          640   0.37983247E-01
         637          621  -0.76972302E-07
         637          622   0.00000000E+00
         637          623   0.00000000E+00
         637          624   0.24553294E-08
         637          625   0.69565494E-10
         637          626  -0.98324021E-04
         637          627  -0.19519374E-03
         637          628   0.66351395E-14
         637          629   0.12172035E-09
         637          630  -0.50042212E-10
         637          641  -0.16631487E-06
         637          642   0.00000000E+00
         637          643   0.00000000E+00
         637          644   0.53052562E-08
         637          645   0.15031090E-09
         637          646  -0.10933830E-03
         637          647  -0.21552396E-03
         637          648   0.14336616E-13
         637          649   0.26300246E-09
         637          650  -0.10812674E-09
         638          638   0.64041043E-04
         638          631   0.00000000E+00
         638          632   0.00000000E+00
         638          633   0.00000000E+00
         638          634   0.00000000E+00
         638          635   0.00000000E+00
         638          636   0.00000000E+00
         638          637  -0.37369100E-04
         638          639  -0.15230390E-04
         638          640  -0.35953679E-04
         638          621   0.00000000E+00
         638          622   0.00000000E+00
         638          623   0.00000000E+00
         638          624   0.00000000E+00
         638          625   0.00000000E+00
         638          626   0.00000000E+00
         638          627   0.66356751E-14
         638          628  -0.98470393E-14
         638          629  -0.12341027E-14
         638          630   0.47699778E-14
         638          641   0.00000000E+00
         638          642   0.00000000E+00
         638          643   0.00000000E+00
         638          644   0.00000000E+00
         638          645   0.00000000E+00
         638          646   0.00000000E+00
         638          647   0.14337773E-13
         638          648  -0.21276602E-13
         638          649  -0.26665388E-14
         638          650   0.10306541E-13
         639          639   0.76223284E+02
         639          631   0.00000000E+00
         639          632   0.00000000E+00
         639          633   0.00000000E+00
         639          634   0.00000000E+00
         639          635   0.00000000E+00
         639          636   0.43198833E-04
         639          637  -0.92325271E-01
         639          638  -0.15226788E-04
         639          640   0.25728412E+02
         639          621   0.00000000E+00
         639          622   0.00000000E+00
         639          623   0.00000000E+00
         639          624   0.00000000E+00
         639          625   0.00000000E+00
         639          626   0.00000000E+00
         639          627   0.12170818E-09
         639          628  -0.12340565E-14
         639          629  -0.10047155E-06
         639          630  -0.33913183E-07
         639          641   0.00000000E+00
         639          642   0.00000000E+00
         639          643   0.00000000E+00
         639          644   0.00000000E+00
         639          645   0.00000000E+00
         639          646   0.00000000E+00
         639          647   0.26297616E-09
         639          648  -0.26664388E-14
         639          649  -0.21708995E-06
         639          650  -0.73276574E-07
         640          640   0.10345257E+05
         640          631   0.27853800E+04
         640          632   0.19052009E+03
         640          633   0.00000000E+00
         640          634   0.00000000E+00
         640          635   0.16720766E-05
         640          636   0.00000000E+00
         640          637   0.37983247E-01
         640          638  -0.35944246E-04
         640          639   0.25728412E+02
         640          621  -0.36714711E-05
         640          622  -0.25112880E-06
         640          623   0.00000000E+00
         640          624   0.00000000E+00
         640          625  -0.22040016E-14
         640          626   0.00000000E+00
         640          627  -0.50042212E-10
         640          628   0.47692624E-14
         640          629  -0.33913183E-07
         640          630  -0.13636315E-04
         640          641  -0.79329864E-05
         640          642  -0.54261665E-06
         640          643   0.00000000E+00
         640          644   0.00000000E+00
         640          645  -0.47622095E-14
         640          646   0.00000000E+00
         640          647  -0.10812674E-09
         640          648   0.10304996E-13
         640          649  -0.73276574E-07
         640          650  -0.29464129E-04
         641          641   0.74607781E+04
         641          642   0.00000000E+00
         641          643   0.00000000E+00
         641          644   0.00000000E+00
         641          645   0.00000000E+00
         641          646   0.60850225E+02
         641          647   0.57981186E+02
         641          648   0.00000000E+00
         641          649   0.00000000E+00
         641          650   0.27656219E+04
         641          631  -0.96509076E-05
         641          632   0.00000000E+00
         641          633   0.00000000E+00
         641          634   0.00000000E+00
         641          635   0.00000000E+00
         641          636  -0.78712682E-07
         641          637  -0.75001710E-07
         641          638   0.00000000E+00
         641          639   0.00000000E+00
         641          640  -0.35774766E-05
         641          651  -0.21196782E-04
         641          652   0.00000000E+00
         641          653   0.00000000E+00
         641          654   0.00000000E+00
         641          655   0.00000000E+00
         641          656  -0.17288069E-06
         641          657  -0.16473009E-06
         641          658   0.00000000E+00
         641          659   0.00000000E+00
         641          660  -0.78573950E-05
         642          642   0.46977087E+04
         642          641   0.00000000E+00
         642          643   0.00000000E+00
         642          644   0.63450217E+01
         642          645   0.63450217E+01
         642          646   0.00000000E+00
         642          647  -0.21136331E+02
         642          648   0.00000000E+00
         642          649   0.00000000E+00
         642          650   0.18916864E+03
         642          631   0.00000000E+00
         642          632  -0.60739974E-05
         642          633   0.00000000E+00
         642          634   0.00000000E+00
         642          635   0.00000000E+00
         642          636   0.00000000E+00
         642          637   0.00000000E+00
         642          638   0.00000000E+00
         642          639   0.00000000E+00
         642          640  -0.24469958E-06
         642          651   0.00000000E+00
         642          652  -0.13340631E-04
         642          653   0.00000000E+00
         642          654   0.00000000E+00
         642          655   0.00000000E+00
         642          656   0.00000000E+00
         642          657   0.00000000E+00
         642          658   0.00000000E+00
         642          659   0.00000000E+00
         642          660  -0.53744620E-06
         643          643   0.59477523E+03
         643          641   0.00000000E+00
         643          642   0.00000000E+00
         643          644   0.00000000E+00
         643          645   0.00000000E+00
         643          646   0.00000000E+00
         643          647   0.00000000E+00
         643          648   0.00000000E+00
         643          649   0.00000000E+00
         643          650   0.00000000E+00
         643          631   0.00000000E+00
         643          632   0.00000000E+00
         643          633  -0.76937300E-06
         643          634   0.00000000E+00
         643          635   0.00000000E+00
         643          636   0.00000000E+00
         643          637   0.00000000E+00
         643          638   0.00000000E+00
         643          639   0.00000000E+00
         643          640   0.00000000E+00
         643          651   0.00000000E+00
         643          652   0.00000000E+00
         643          653  -0.16898133E-05
         643          654   0.00000000E+00
         643          655   0.00000000E+00
         643          656   0.00000000E+00
         643          657   0.00000000E+00
         643          658   0.00000000E+00
         643          659   0.00000000E+00
         643          660   0.00000000E+00
         644          644   0.10259791E+04
         644          641   0.00000000E+00
         644          642   0.63443872E+01
         644          643   0.00000000E+00
         644          645   0.19035065E+02
         644          646   0.00000000E+00
         644          647  -0.65258341E+02
         644          648   0.00000000E+00
         644          649   0.00000000E+00
         644          650   0.00000000E+00
         644          631   0.00000000E+00
         644          632   0.00000000E+00
         644          633   0.00000000E+00
         644          634  -0.13025350E-05
         644          635   0.00000000E+00
         644          636   0.00000000E+00
         644          637   0.23922306E-08
         644          638   0.00000000E+00
         644          639   0.00000000E+00
         644          640   0.00000000E+00
         644          651   0.00000000E+00
         644          652   0.00000000E+00
         644          653   0.00000000E+00
         644          654  -0.28608242E-05
         644          655   0.00000000E+00
         644          656   0.00000000E+00
         644          657   0.52541784E-08
         644          658   0.00000000E+00
         644          659   0.00000000E+00
         644          660   0.00000000E+00
         645          645   0.19048611E+02
         645          641   0.00000000E+00
         645          642   0.63443872E+01
         645          643   0.00000000E+00
         645          644   0.19035065E+02
         645          646   0.00000000E+00
         645          647  -0.63461479E+02
         645          648   0.00000000E+00
         645          649   0.00000000E+00
         645          650   0.16602388E-05
         645          631   0.00000000E+00
         645          632   0.00000000E+00
         645          633   0.00000000E+00
         645          634   0.00000000E+00
         645          635  -0.17479616E-10
         645          636   0.00000000E+00
         645          637   0.67767835E-10
         645          638   0.00000000E+00
         645          639   0.00000000E+00
         645          640  -0.21476061E-14
         645          651   0.00000000E+00
         645          652   0.00000000E+00
         645          653   0.00000000E+00
         645          654   0.00000000E+00
         645          655  -0.38391374E-10
         645          656   0.00000000E+00
         645          657   0.14884196E-09
         645          658   0.00000000E+00
         645          659   0.00000000E+00
         645          660  -0.47168972E-14
         646          646   0.13754581E+04
         646          641   0.60850225E+02
         646          642   0.00000000E+00
         646          643   0.00000000E+00
         646          644   0.00000000E+00
         646          645   0.00000000E+00
         646          647   0.16383722E+04
         646          648   0.00000000E+00
         646          649   0.43198833E-04
         646          650   0.00000000E+00
         646          631  -0.78712682E-07
         646          632   0.00000000E+00
         646          633   0.00000000E+00
         646          634   0.00000000E+00
         646          635   0.00000000E+00
         646          636  -0.54216489E-04
         646          637  -0.10699909E-03
         646          638   0.00000000E+00
         646          639   0.00000000E+00
         646          640   0.00000000E+00
         646          651  -0.17288069E-06
         646          652   0.00000000E+00
         646          653   0.00000000E+00
         646          654   0.00000000E+00
         646          655   0.00000000E+00
         646          656  -0.59994603E-04
         646          657  -0.11683397E-03
         646          658   0.00000000E+00
         646          659   0.00000000E+00
         646          660   0.00000000E+00
         647          647   0.23853232E+04
         647          641   0.57981186E+02
         647          642  -0.21147957E+02
         647          643   0.00000000E+00
         647          644  -0.65299751E+02
         647          645  -0.63502717E+02
         647          646   0.16383455E+04
         647          648  -0.37324096E-04
         647          649  -0.91679466E-01
         647          650   0.37713944E-01
         647          631  -0.75001710E-07
         647          632   0.00000000E+00
         647          633   0.00000000E+00
         647          634   0.23924698E-08
         647          635   0.67784526E-10
         647          636  -0.10699381E-03
         647          637  -0.21257166E-03
         647          638   0.64652713E-14
         647          639   0.11860416E-09
         647          640  -0.48761067E-10
         647          651  -0.16473009E-06
         647          652   0.00000000E+00
         647          653   0.00000000E+00
         647          654   0.52547038E-08
         647          655   0.14887862E-09
         647          656  -0.11682829E-03
         647          657  -0.23053483E-03
         647          658   0.14200006E-13
         647          659   0.26049637E-09
         647          660  -0.10709642E-09
         648          648   0.63988051E-04
         648          641   0.00000000E+00
         648          642   0.00000000E+00
         648          643   0.00000000E+00
         648          644   0.00000000E+00
         648          645   0.00000000E+00
         648          646   0.00000000E+00
         648          647  -0.37333390E-04
         648          649  -0.15237031E-04
         648          650  -0.35928010E-04
         648          631   0.00000000E+00
         648          632   0.00000000E+00
         648          633   0.00000000E+00
         648          634   0.00000000E+00
         648          635   0.00000000E+00
         648          636   0.00000000E+00
         648          637   0.64657932E-14
         648          638  -0.95949423E-14
         648          639  -0.12025081E-14
         648          640   0.46478602E-14
         648          651   0.00000000E+00
         648          652   0.00000000E+00
         648          653   0.00000000E+00
         648          654   0.00000000E+00
         648          655   0.00000000E+00
         648          656   0.00000000E+00
         648          657   0.14201152E-13
         648          658  -0.21073863E-13
         648          659  -0.26411300E-14
         648          660   0.10208333E-13
         649          649   0.75682595E+02
         649          641   0.00000000E+00
         649          642   0.00000000E+00
         649          643   0.00000000E+00
         649          644   0.00000000E+00
         649          645   0.00000000E+00
         649          646   0.43198833E-04
         649          647  -0.91670297E-01
         649          648  -0.15233429E-04
         649          650   0.25545908E+02
         649          631   0.00000000E+00
         649          632   0.00000000E+00
         649          633   0.00000000E+00
         649          634   0.00000000E+00
         649          635   0.00000000E+00
         649          636   0.00000000E+00
         649          637   0.11859230E-09
         649          638  -0.12024630E-14
         649          639  -0.97899351E-07
         649          640  -0.33044962E-07
         649          651   0.00000000E+00
         649          652   0.00000000E+00
         649          653   0.00000000E+00
         649          654   0.00000000E+00
         649          655   0.00000000E+00
         649          656   0.00000000E+00
         649          657   0.26047033E-09
         649          658  -0.26410310E-14
         649          659  -0.21502135E-06
         649          660  -0.72578340E-07
         650          650   0.10271873E+05
         650          641   0.27656219E+04
         650          642   0.18916864E+03
         650          643   0.00000000E+00
         650          644   0.00000000E+00
         650          645   0.16602157E-05
         650          646   0.00000000E+00
         650          647   0.37713944E-01
         650          648  -0.35918580E-04
         650          649   0.25545908E+02
         650          631  -0.35774766E-05
         650          632  -0.24469958E-06
         650          633   0.00000000E+00
         650          634   0.00000000E+00
         650          635  -0.21475763E-14
         650          636   0.00000000E+00
         650          637  -0.48761067E-10
         650          638   0.46471631E-14
         650          639  -0.33044962E-07
         650          640  -0.13287207E-04
         650          651  -0.78573950E-05
         650          652  -0.53744620E-06
         650          653   0.00000000E+00
         650          654   0.00000000E+00
         650          655  -0.47168316E-14
         650          656   0.00000000E+00
         650          657  -0.10709642E-09
         650          658   0.10206802E-13
         650          659  -0.72578340E-07
         650          660  -0.29183373E-04
         651          651   0.74172562E+04
         651          652   0.00000000E+00
         651          653   0.00000000E+00
         651          654   0.00000000E+00
         651          655   0.00000000E+00
         651          656   0.60495260E+02
         651          657   0.57642957E+02
         651          658   0.00000000E+00
         651          659   0.00000000E+00
         651          660   0.27494888E+04
         651          641  -0.94469857E-05
         651          642   0.00000000E+00
         651          643   0.00000000E+00
         651          644   0.00000000E+00
         651          645   0.00000000E+00
         651          646  -0.77049498E-07
         651          647  -0.73416938E-07
         651          648   0.00000000E+00
         651          649   0.00000000E+00
         651          650  -0.35018852E-05
         651          661  -0.21032725E-04
         651          662   0.00000000E+00
         651          663   0.00000000E+00
         651          664   0.00000000E+00
         651          665   0.00000000E+00
         651          666  -0.17154265E-06
         651          667  -0.16345513E-06
         651          668   0.00000000E+00
         651          669   0.00000000E+00
         651          670  -0.77965811E-05
         652          652   0.46703173E+04
         652          651   0.00000000E+00
         652          653   0.00000000E+00
         652          654   0.63450217E+01
         652          655   0.63450217E+01
         652          656   0.00000000E+00
         652          657  -0.21136331E+02
         652          658   0.00000000E+00
         652          659   0.00000000E+00
         652          660   0.18806514E+03
         652          641   0.00000000E+00
         652          642  -0.59456549E-05
         652          643   0.00000000E+00
         652          644   0.00000000E+00
         652          645   0.00000000E+00
         652          646   0.00000000E+00
         652          647   0.00000000E+00
         652          648   0.00000000E+00
         652          649   0.00000000E+00
         652          650  -0.23952912E-06
         652          661   0.00000000E+00
         652          662  -0.13237379E-04
         652          663   0.00000000E+00
         652          664   0.00000000E+00
         652          665   0.00000000E+00
         652          666   0.00000000E+00
         652          667   0.00000000E+00
         652          668   0.00000000E+00
         652          669   0.00000000E+00
         652          670  -0.53328652E-06
         653          653   0.59130564E+03
         653          651   0.00000000E+00
         653          652   0.00000000E+00
         653          654   0.00000000E+00
         653          655   0.00000000E+00
         653          656   0.00000000E+00
         653          657   0.00000000E+00
         653          658   0.00000000E+00
         653          659   0.00000000E+00
         653          660   0.00000000E+00
         653          641   0.00000000E+00
         653          642   0.00000000E+00
         653          643  -0.75311629E-06
         653          644   0.00000000E+00
         653          645   0.00000000E+00
         653          646   0.00000000E+00
         653          647   0.00000000E+00
         653          648   0.00000000E+00
         653          649   0.00000000E+00
         653          650   0.00000000E+00
         653          661   0.00000000E+00
         653          662   0.00000000E+00
         653          663  -0.16767346E-05
         653          664   0.00000000E+00
         653          665   0.00000000E+00
         653          666   0.00000000E+00
         653          667   0.00000000E+00
         653          668   0.00000000E+00
         653          669   0.00000000E+00
         653          670   0.00000000E+00
         654          654   0.10201052E+04
         654          651   0.00000000E+00
         654          652   0.63443872E+01
         654          653   0.00000000E+00
         654          655   0.19035065E+02
         654          656   0.00000000E+00
         654          657  -0.65247553E+02
         654          658   0.00000000E+00
         654          659   0.00000000E+00
         654          660   0.00000000E+00
         654          641   0.00000000E+00
         654          642   0.00000000E+00
         654          643   0.00000000E+00
         654          644  -0.12750127E-05
         654          645   0.00000000E+00
         654          646   0.00000000E+00
         654          647   0.23416832E-08
         654          648   0.00000000E+00
         654          649   0.00000000E+00
         654          650   0.00000000E+00
         654          661   0.00000000E+00
         654          662   0.00000000E+00
         654          663   0.00000000E+00
         654          664  -0.28386823E-05
         654          665   0.00000000E+00
         654          666   0.00000000E+00
         654          667   0.52135126E-08
         654          668   0.00000000E+00
         654          669   0.00000000E+00
         654          670   0.00000000E+00
         655          655   0.19048532E+02
         655          651   0.00000000E+00
         655          652   0.63443872E+01
         655          653   0.00000000E+00
         655          654   0.19035065E+02
         655          656   0.00000000E+00
         655          657  -0.63461173E+02
         655          658   0.00000000E+00
         655          659   0.00000000E+00
         655          660   0.16505539E-05
         655          641   0.00000000E+00
         655          642   0.00000000E+00
         655          643   0.00000000E+00
         655          644   0.00000000E+00
         655          645  -0.17110274E-10
         655          646   0.00000000E+00
         655          647   0.66335913E-10
         655          648   0.00000000E+00
         655          649   0.00000000E+00
         655          650  -0.21022276E-14
         655          661   0.00000000E+00
         655          662   0.00000000E+00
         655          663   0.00000000E+00
         655          664   0.00000000E+00
         655          665  -0.38094236E-10
         655          666   0.00000000E+00
         655          667   0.14768997E-09
         655          668   0.00000000E+00
         655          669   0.00000000E+00
         655          670  -0.46803899E-14
         656          656   0.13692665E+04
         656          651   0.60495260E+02
         656          652   0.00000000E+00
         656          653   0.00000000E+00
         656          654   0.00000000E+00
         656          655   0.00000000E+00
         656          657   0.16324791E+04
         656          658   0.00000000E+00
         656          659   0.43198833E-04
         656          660   0.00000000E+00
         656          641  -0.77049498E-07
         656          642   0.00000000E+00
         656          643   0.00000000E+00
         656          644   0.00000000E+00
         656          645   0.00000000E+00
         656          646  -0.57946277E-04
         656          647  -0.11448945E-03
         656          648   0.00000000E+00
         656          649   0.00000000E+00
         656          650   0.00000000E+00
         656          661  -0.17154265E-06
         656          662   0.00000000E+00
         656          663   0.00000000E+00
         656          664   0.00000000E+00
         656          665   0.00000000E+00
         656          666  -0.63174024E-04
         656          667  -0.12321760E-03
         656          668   0.00000000E+00
         656          669   0.00000000E+00
         656          670   0.00000000E+00
         657          657   0.23799701E+04
         657          651   0.57642957E+02
         657          652  -0.21147957E+02
         657          653   0.00000000E+00
         657          654  -0.65288962E+02
         657          655  -0.63502411E+02
         657          656   0.16324524E+04
         657          658  -0.37294940E-04
         657          659  -0.91144606E-01
         657          660   0.37494050E-01
         657          641  -0.73416938E-07
         657          642   0.00000000E+00
         657          643   0.00000000E+00
         657          644   0.23419173E-08
         657          645   0.66352252E-10
         657          646  -0.11448379E-03
         657          647  -0.22758253E-03
         657          648   0.63286613E-14
         657          649   0.11609807E-09
         657          650  -0.47730754E-10
         657          661  -0.16345513E-06
         657          662   0.00000000E+00
         657          663   0.00000000E+00
         657          664   0.52140340E-08
         657          665   0.14772635E-09
         657          666  -0.12321159E-03
         657          667  -0.24332633E-03
         657          668   0.14090102E-13
         657          669   0.25848021E-09
         657          670  -0.10626753E-09
         658          658   0.63944782E-04
         658          651   0.00000000E+00
         658          652   0.00000000E+00
         658          653   0.00000000E+00
         658          654   0.00000000E+00
         658          655   0.00000000E+00
         658          656   0.00000000E+00
         658          657  -0.37304231E-04
         658          659  -0.15242454E-04
         658          660  -0.35907050E-04
         658          641   0.00000000E+00
         658          642   0.00000000E+00
         658          643   0.00000000E+00
         658          644   0.00000000E+00
         658          645   0.00000000E+00
         658          646   0.00000000E+00
         658          647   0.63291721E-14
         658          648  -0.93922029E-14
         658          649  -0.11770993E-14
         658          650   0.45496517E-14
         658          661   0.00000000E+00
         658          662   0.00000000E+00
         658          663   0.00000000E+00
         658          664   0.00000000E+00
         658          665   0.00000000E+00
         658          666   0.00000000E+00
         658          667   0.14091240E-13
         658          668  -0.20910757E-13
         658          669  -0.26206885E-14
         658          670   0.10129324E-13
         659          659   0.75241106E+02
         659          651   0.00000000E+00
         659          652   0.00000000E+00
         659          653   0.00000000E+00
         659          654   0.00000000E+00
         659          655   0.00000000E+00
         659          656   0.43198833E-04
         659          657  -0.91135491E-01
         659          658  -0.15238852E-04
         659          660   0.25396887E+02
         659          641   0.00000000E+00
         659          642   0.00000000E+00
         659          643   0.00000000E+00
         659          644   0.00000000E+00
         659          645   0.00000000E+00
         659          646   0.00000000E+00
         659          647   0.11608646E-09
         659          648  -0.11770552E-14
         659          649  -0.95830755E-07
         659          650  -0.32346728E-07
         659          661   0.00000000E+00
         659          662   0.00000000E+00
         659          663   0.00000000E+00
         659          664   0.00000000E+00
         659          665   0.00000000E+00
         659          666   0.00000000E+00
         659          667   0.25845436E-09
         659          668  -0.26205902E-14
         659          669  -0.21335715E-06
         659          670  -0.72016605E-07
         660          660   0.10211953E+05
         660          651   0.27494888E+04
         660          652   0.18806514E+03
         660          653   0.00000000E+00
         660          654   0.00000000E+00
         660          655   0.16505310E-05
         660          656   0.00000000E+00
         660          657   0.37494050E-01
         660          658  -0.35897623E-04
         660          659   0.25396887E+02
         660          641  -0.35018852E-05
         660          642  -0.23952912E-06
         660          643   0.00000000E+00
         660          644   0.00000000E+00
         660          645  -0.21021984E-14
         660          646   0.00000000E+00
         660          647  -0.47730754E-10
         660          648   0.45489694E-14
         660          649  -0.32346728E-07
         660          650  -0.13006451E-04
         660          661  -0.77965811E-05
         660          662  -0.53328652E-06
         660          663   0.00000000E+00
         660          664   0.00000000E+00
         660          665  -0.46803248E-14
         660          666   0.00000000E+00
         660          667  -0.10626753E-09
         660          668   0.10127804E-13
         660          669  -0.72016605E-07
         660          670  -0.28957503E-04
         661          661   0.73818022E+04
         661          662   0.00000000E+00
         661          663   0.00000000E+00
         661          664   0.00000000E+00
         661          665   0.00000000E+00
         661          666   0.60206098E+02
         661          667   0.57367428E+02
         661          668   0.00000000E+00
         661          669   0.00000000E+00
         661          670   0.27363465E+04
         661          651  -0.92829290E-05
         661          652   0.00000000E+00
         661          653   0.00000000E+00
         661          654   0.00000000E+00
         661          655   0.00000000E+00
         661          656  -0.75711453E-07
         661          657  -0.72141977E-07
         661          658   0.00000000E+00
         661          659   0.00000000E+00
         661          660  -0.34410713E-05
         661          671  -0.20900696E-04
         661          672   0.00000000E+00
         661          673   0.00000000E+00
         661          674   0.00000000E+00
         661          675   0.00000000E+00
         661          676  -0.17046582E-06
         661          677  -0.16242907E-06
         661          678   0.00000000E+00
         661          679   0.00000000E+00
         661          680  -0.77476394E-05
         662          662   0.46480036E+04
         662          661   0.00000000E+00
         662          663   0.00000000E+00
         662          664   0.63450217E+01
         662          665   0.63450217E+01
         662          666   0.00000000E+00
         662          667  -0.21136331E+02
         662          668   0.00000000E+00
         662          669   0.00000000E+00
         662          670   0.18716620E+03
         662          651   0.00000000E+00
         662          652  -0.58424025E-05
         662          653   0.00000000E+00
         662          654   0.00000000E+00
         662          655   0.00000000E+00
         662          656   0.00000000E+00
         662          657   0.00000000E+00
         662          658   0.00000000E+00
         662          659   0.00000000E+00
         662          660  -0.23536945E-06
         662          671   0.00000000E+00
         662          672  -0.13154283E-04
         662          673   0.00000000E+00
         662          674   0.00000000E+00
         662          675   0.00000000E+00
         662          676   0.00000000E+00
         662          677   0.00000000E+00
         662          678   0.00000000E+00
         662          679   0.00000000E+00
         662          680  -0.52993891E-06
         663          663   0.58847925E+03
         663          661   0.00000000E+00
         663          662   0.00000000E+00
         663          664   0.00000000E+00
         663          665   0.00000000E+00
         663          666   0.00000000E+00
         663          667   0.00000000E+00
         663          668   0.00000000E+00
         663          669   0.00000000E+00
         663          670   0.00000000E+00
         663          651   0.00000000E+00
         663          652   0.00000000E+00
         663          653  -0.74003764E-06
         663          654   0.00000000E+00
         663          655   0.00000000E+00
         663          656   0.00000000E+00
         663          657   0.00000000E+00
         663          658   0.00000000E+00
         663          659   0.00000000E+00
         663          660   0.00000000E+00
         663          671   0.00000000E+00
         663          672   0.00000000E+00
         663          673  -0.16662092E-05
         663          674   0.00000000E+00
         663          675   0.00000000E+00
         663          676   0.00000000E+00
         663          677   0.00000000E+00
         663          678   0.00000000E+00
         663          679   0.00000000E+00
         663          680   0.00000000E+00
         664          664   0.10153202E+04
         664          661   0.00000000E+00
         664          662   0.63443872E+01
         664          663   0.00000000E+00
         664          665   0.19035065E+02
         664          666   0.00000000E+00
         664          667  -0.65238765E+02
         664          668   0.00000000E+00
         664          669   0.00000000E+00
         664          670   0.00000000E+00
         664          651   0.00000000E+00
         664          652   0.00000000E+00
         664          653   0.00000000E+00
         664          654  -0.12528707E-05
         664          655   0.00000000E+00
         664          656   0.00000000E+00
         664          657   0.23010174E-08
         664          658   0.00000000E+00
         664          659   0.00000000E+00
         664          660   0.00000000E+00
         664          671   0.00000000E+00
         664          672   0.00000000E+00
         664          673   0.00000000E+00
         664          674  -0.28208630E-05
         664          675   0.00000000E+00
         664          676   0.00000000E+00
         664          677   0.51807857E-08
         664          678   0.00000000E+00
         664          679   0.00000000E+00
         664          680   0.00000000E+00
         665          665   0.19048468E+02
         665          661   0.00000000E+00
         665          662   0.63443872E+01
         665          663   0.00000000E+00
         665          664   0.19035065E+02
         665          666   0.00000000E+00
         665          667  -0.63460924E+02
         665          668   0.00000000E+00
         665          669   0.00000000E+00
         665          670   0.16426644E-05
         665          651   0.00000000E+00
         665          652   0.00000000E+00
         665          653   0.00000000E+00
         665          654   0.00000000E+00
         665          655  -0.16813137E-10
         665          656   0.00000000E+00
         665          657   0.65183921E-10
         665          658   0.00000000E+00
         665          659   0.00000000E+00
         665          660  -0.20657203E-14
         665          671   0.00000000E+00
         665          672   0.00000000E+00
         665          673   0.00000000E+00
         665          674   0.00000000E+00
         665          675  -0.37855106E-10
         665          676   0.00000000E+00
         665          677   0.14676287E-09
         665          678   0.00000000E+00
         665          679   0.00000000E+00
         665          680  -0.46510095E-14
         666          666   0.13642227E+04
         666          661   0.60206098E+02
         666          662   0.00000000E+00
         666          663   0.00000000E+00
         666          664   0.00000000E+00
         666          665   0.00000000E+00
         666          667   0.16276785E+04
         666          668   0.00000000E+00
         666          669   0.43198833E-04
         666          670   0.00000000E+00
         666          651  -0.75711453E-07
         666          652   0.00000000E+00
         666          653   0.00000000E+00
         666          654   0.00000000E+00
         666          655   0.00000000E+00
         666          656  -0.61125697E-04
         666          657  -0.12087308E-03
         666          658   0.00000000E+00
         666          659   0.00000000E+00
         666          660   0.00000000E+00
         666          671  -0.17046582E-06
         666          672   0.00000000E+00
         666          673   0.00000000E+00
         666          674   0.00000000E+00
         666          675   0.00000000E+00
         666          676  -0.65854822E-04
         666          677  -0.12859915E-03
         666          678   0.00000000E+00
         666          679   0.00000000E+00
         666          680   0.00000000E+00
         667          667   0.23756093E+04
         667          661   0.57367428E+02
         667          662  -0.21147957E+02
         667          663   0.00000000E+00
         667          664  -0.65280173E+02
         667          665  -0.63502162E+02
         667          666   0.16276518E+04
         667          668  -0.37271189E-04
         667          669  -0.90708897E-01
         667          670   0.37314920E-01
         667          651  -0.72141977E-07
         667          652   0.00000000E+00
         667          653   0.00000000E+00
         667          654   0.23012475E-08
         667          655   0.65199976E-10
         667          656  -0.12086710E-03
         667          657  -0.24037403E-03
         667          658   0.62187575E-14
         667          659   0.11408191E-09
         667          660  -0.46901860E-10
         667          671  -0.16242907E-06
         667          672   0.00000000E+00
         667          673   0.00000000E+00
         667          674   0.51813038E-08
         667          675   0.14679902E-09
         667          676  -0.12859288E-03
         667          677  -0.25410896E-03
         667          678   0.14001654E-13
         667          679   0.25685765E-09
         667          680  -0.10560046E-09
         668          668   0.63909533E-04
         668          661   0.00000000E+00
         668          662   0.00000000E+00
         668          663   0.00000000E+00
         668          664   0.00000000E+00
         668          665   0.00000000E+00
         668          666   0.00000000E+00
         668          667  -0.37280478E-04
         668          669  -0.15246872E-04
         668          670  -0.35889975E-04
         668          651   0.00000000E+00
         668          652   0.00000000E+00
         668          653   0.00000000E+00
         668          654   0.00000000E+00
         668          655   0.00000000E+00
         668          656   0.00000000E+00
         668          657   0.62192595E-14
         668          658  -0.92290976E-14
         668          659  -0.11566578E-14
         668          660   0.44706423E-14
         668          671   0.00000000E+00
         668          672   0.00000000E+00
         668          673   0.00000000E+00
         668          674   0.00000000E+00
         668          675   0.00000000E+00
         668          676   0.00000000E+00
         668          677   0.14002784E-13
         668          678  -0.20779494E-13
         668          679  -0.26042376E-14
         668          680   0.10065739E-13
         669          669   0.74881459E+02
         669          661   0.00000000E+00
         669          662   0.00000000E+00
         669          663   0.00000000E+00
         669          664   0.00000000E+00
         669          665   0.00000000E+00
         669          666   0.43198833E-04
         669          667  -0.90699826E-01
         669          668  -0.15243269E-04
         669          670   0.25275492E+02
         669          651   0.00000000E+00
         669          652   0.00000000E+00
         669          653   0.00000000E+00
         669          654   0.00000000E+00
         669          655   0.00000000E+00
         669          656   0.00000000E+00
         669          657   0.11407050E-09
         669          658  -0.11566144E-14
         669          659  -0.94166555E-07
         669          660  -0.31784993E-07
         669          671   0.00000000E+00
         669          672   0.00000000E+00
         669          673   0.00000000E+00
         669          674   0.00000000E+00
         669          675   0.00000000E+00
         669          676   0.00000000E+00
         669          677   0.25683196E-09
         669          678  -0.26041399E-14
         669          679  -0.21201784E-06
         669          680  -0.71564534E-07
         670          670   0.10163141E+05
         670          661   0.27363465E+04
         670          662   0.18716620E+03
         670          663   0.00000000E+00
         670          664   0.00000000E+00
         670          665   0.16426416E-05
         670          666   0.00000000E+00
         670          667   0.37314920E-01
         670          668  -0.35880551E-04
         670          669   0.25275492E+02
         670          651  -0.34410713E-05
         670          652  -0.23536945E-06
         670          653   0.00000000E+00
         670          654   0.00000000E+00
         670          655  -0.20656915E-14
         670          656   0.00000000E+00
         670          657  -0.46901860E-10
         670          658   0.44699718E-14
         670          659  -0.31784993E-07
         670          660  -0.12780581E-04
         670          671  -0.77476394E-05
         670          672  -0.52993891E-06
         670          673   0.00000000E+00
         670          674   0.00000000E+00
         670          675  -0.46509449E-14
         670          676   0.00000000E+00
         670          677  -0.10560046E-09
         670          678   0.10064229E-13
         670          679  -0.71564534E-07
         670          680  -0.28775727E-04
         671          671   0.73529763E+04
         671          672   0.00000000E+00
         671          673   0.00000000E+00
         671          674   0.00000000E+00
         671          675   0.00000000E+00
         671          676   0.59970995E+02
         671          677   0.57143408E+02
         671          678   0.00000000E+00
         671          679   0.00000000E+00
         671          680   0.27256611E+04
         671          661  -0.91508997E-05
         671          662   0.00000000E+00
         671          663   0.00000000E+00
         671          664   0.00000000E+00
         671          665   0.00000000E+00
         671          666  -0.74634624E-07
         671          667  -0.71115916E-07
         671          668   0.00000000E+00
         671          669   0.00000000E+00
         671          670  -0.33921297E-05
         671          681  -0.20794410E-04
         671          682   0.00000000E+00
         671          683   0.00000000E+00
         671          684   0.00000000E+00
         671          685   0.00000000E+00
         671          686  -0.16959895E-06
         671          687  -0.16160307E-06
         671          688   0.00000000E+00
         671          689   0.00000000E+00
         671          690  -0.77082406E-05
         672          672   0.46298614E+04
         672          671   0.00000000E+00
         672          673   0.00000000E+00
         672          674   0.63450217E+01
         672          675   0.63450217E+01
         672          676   0.00000000E+00
         672          677  -0.21136331E+02
         672          678   0.00000000E+00
         672          679   0.00000000E+00
         672          680   0.18643532E+03
         672          661   0.00000000E+00
         672          662  -0.57593071E-05
         672          663   0.00000000E+00
         672          664   0.00000000E+00
         672          665   0.00000000E+00
         672          666   0.00000000E+00
         672          667   0.00000000E+00
         672          668   0.00000000E+00
         672          669   0.00000000E+00
         672          670  -0.23202183E-06
         672          681   0.00000000E+00
         672          682  -0.13087390E-04
         672          683   0.00000000E+00
         672          684   0.00000000E+00
         672          685   0.00000000E+00
         672          686   0.00000000E+00
         672          687   0.00000000E+00
         672          688   0.00000000E+00
         672          689   0.00000000E+00
         672          690  -0.52724403E-06
         673          673   0.58618124E+03
         673          671   0.00000000E+00
         673          672   0.00000000E+00
         673          674   0.00000000E+00
         673          675   0.00000000E+00
         673          676   0.00000000E+00
         673          677   0.00000000E+00
         673          678   0.00000000E+00
         673          679   0.00000000E+00
         673          680   0.00000000E+00
         673          661   0.00000000E+00
         673          662   0.00000000E+00
         673          663  -0.72951224E-06
         673          664   0.00000000E+00
         673          665   0.00000000E+00
         673          666   0.00000000E+00
         673          667   0.00000000E+00
         673          668   0.00000000E+00
         673          669   0.00000000E+00
         673          670   0.00000000E+00
         673          681   0.00000000E+00
         673          682   0.00000000E+00
         673          683  -0.16577361E-05
         673          684   0.00000000E+00
         673          685   0.00000000E+00
         673          686   0.00000000E+00
         673          687   0.00000000E+00
         673          688   0.00000000E+00
         673          689   0.00000000E+00
         673          690   0.00000000E+00
         674          674   0.10114297E+04
         674          671   0.00000000E+00
         674          672   0.63443872E+01
         674          673   0.00000000E+00
         674          675   0.19035065E+02
         674          676   0.00000000E+00
         674          677  -0.65231620E+02
         674          678   0.00000000E+00
         674          679   0.00000000E+00
         674          680   0.00000000E+00
         674          661   0.00000000E+00
         674          662   0.00000000E+00
         674          663   0.00000000E+00
         674          664  -0.12350514E-05
         674          665   0.00000000E+00
         674          666   0.00000000E+00
         674          667   0.22682905E-08
         674          668   0.00000000E+00
         674          669   0.00000000E+00
         674          670   0.00000000E+00
         674          681   0.00000000E+00
         674          682   0.00000000E+00
         674          683   0.00000000E+00
         674          684  -0.28065181E-05
         674          685   0.00000000E+00
         674          686   0.00000000E+00
         674          687   0.51544400E-08
         674          688   0.00000000E+00
         674          689   0.00000000E+00
         674          690   0.00000000E+00
         675          675   0.19048415E+02
         675          671   0.00000000E+00
         675          672   0.63443872E+01
         675          673   0.00000000E+00
         675          674   0.19035065E+02
         675          676   0.00000000E+00
         675          677  -0.63460722E+02
         675          678   0.00000000E+00
         675          679   0.00000000E+00
         675          680   0.16362498E-05
         675          661   0.00000000E+00
         675          662   0.00000000E+00
         675          663   0.00000000E+00
         675          664   0.00000000E+00
         675          665  -0.16574007E-10
         675          666   0.00000000E+00
         675          667   0.64256823E-10
         675          668   0.00000000E+00
         675          669   0.00000000E+00
         675          670  -0.20363399E-14
         675          681   0.00000000E+00
         675          682   0.00000000E+00
         675          683   0.00000000E+00
         675          684   0.00000000E+00
         675          685  -0.37662603E-10
         675          686   0.00000000E+00
         675          687   0.14601654E-09
         675          688   0.00000000E+00
         675          689   0.00000000E+00
         675          690  -0.46273579E-14
         676          676   0.13601218E+04
         676          671   0.59970995E+02
         676          672   0.00000000E+00
         676          673   0.00000000E+00
         676          674   0.00000000E+00
         676          675   0.00000000E+00
         676          677   0.16237753E+04
         676          678   0.00000000E+00
         676          679   0.43198833E-04
         676          680   0.00000000E+00
         676          661  -0.74634624E-07
         676          662   0.00000000E+00
         676          663   0.00000000E+00
         676          664   0.00000000E+00
         676          665   0.00000000E+00
         676          666  -0.63806496E-04
         676          667  -0.12625463E-03
         676          668   0.00000000E+00
         676          669   0.00000000E+00
         676          670   0.00000000E+00
         676          681  -0.16959895E-06
         676          682   0.00000000E+00
         676          683   0.00000000E+00
         676          684   0.00000000E+00
         676          685   0.00000000E+00
         676          686  -0.68095481E-04
         676          687  -0.13309655E-03
         676          688   0.00000000E+00
         676          689   0.00000000E+00
         676          690   0.00000000E+00
         677          677   0.23720637E+04
         677          671   0.57143408E+02
         677          672  -0.21147957E+02
         677          673   0.00000000E+00
         677          674  -0.65273027E+02
         677          675  -0.63501959E+02
         677          676   0.16237486E+04
         677          678  -0.37251878E-04
         677          679  -0.90354644E-01
         677          680   0.37169277E-01
         677          661  -0.71115916E-07
         677          662   0.00000000E+00
         677          663   0.00000000E+00
         677          664   0.22685173E-08
         677          665   0.64272650E-10
         677          666  -0.12624839E-03
         677          667  -0.25115666E-03
         677          668   0.61303094E-14
         677          669   0.11245934E-09
         677          670  -0.46234784E-10
         677          681  -0.16160307E-06
         677          682   0.00000000E+00
         677          683   0.00000000E+00
         677          684   0.51549554E-08
         677          685   0.14605251E-09
         677          686  -0.13309005E-03
         677          687  -0.26311945E-03
         677          688   0.13930452E-13
         677          689   0.25555145E-09
         677          690  -0.10506345E-09
         678          678   0.63880874E-04
         678          671   0.00000000E+00
         678          672   0.00000000E+00
         678          673   0.00000000E+00
         678          674   0.00000000E+00
         678          675   0.00000000E+00
         678          676   0.00000000E+00
         678          677  -0.37261166E-04
         678          679  -0.15250463E-04
         678          680  -0.35876092E-04
         678          661   0.00000000E+00
         678          662   0.00000000E+00
         678          663   0.00000000E+00
         678          664   0.00000000E+00
         678          665   0.00000000E+00
         678          666   0.00000000E+00
         678          667   0.61308042E-14
         678          668  -0.90978340E-14
         678          669  -0.11402068E-14
         678          670   0.44070573E-14
         678          681   0.00000000E+00
         678          682   0.00000000E+00
         678          683   0.00000000E+00
         678          684   0.00000000E+00
         678          685   0.00000000E+00
         678          686   0.00000000E+00
         678          687   0.13931576E-13
         678          688  -0.20673824E-13
         678          689  -0.25909943E-14
         678          690   0.10014552E-13
         679          679   0.74589048E+02
         679          671   0.00000000E+00
         679          672   0.00000000E+00
         679          673   0.00000000E+00
         679          674   0.00000000E+00
         679          675   0.00000000E+00
         679          676   0.43198833E-04
         679          677  -0.90345607E-01
         679          678  -0.15246861E-04
         679          680   0.25176792E+02
         679          661   0.00000000E+00
         679          662   0.00000000E+00
         679          663   0.00000000E+00
         679          664   0.00000000E+00
         679          665   0.00000000E+00
         679          666   0.00000000E+00
         679          667   0.11244810E-09
         679          668  -0.11401641E-14
         679          669  -0.92827243E-07
         679          670  -0.31332922E-07
         679          681   0.00000000E+00
         679          682   0.00000000E+00
         679          683   0.00000000E+00
         679          684   0.00000000E+00
         679          685   0.00000000E+00
         679          686   0.00000000E+00
         679          687   0.25552590E-09
         679          688  -0.25908972E-14
         679          689  -0.21093967E-06
         679          690  -0.71200609E-07
         680          680   0.10123454E+05
         680          671   0.27256611E+04
         680          672   0.18643532E+03
         680          673   0.00000000E+00
         680          674   0.00000000E+00
         680          675   0.16362271E-05
         680          676   0.00000000E+00
         680          677   0.37169277E-01
         680          678  -0.35866671E-04
         680          679   0.25176792E+02
         680          661  -0.33921297E-05
         680          662  -0.23202183E-06
         680          663   0.00000000E+00
         680          664   0.00000000E+00
         680          665  -0.20363116E-14
         680          666   0.00000000E+00
         680          667  -0.46234784E-10
         680          668   0.44063963E-14
         680          669  -0.31332922E-07
         680          670  -0.12598805E-04
         680          681  -0.77082406E-05
         680          682  -0.52724403E-06
         680          683   0.00000000E+00
         680          684   0.00000000E+00
         680          685  -0.46272935E-14
         680          686   0.00000000E+00
         680          687  -0.10506345E-09
         680          688   0.10013050E-13
         680          689  -0.71200609E-07
         680          690  -0.28629395E-04
         681          681   0.73295764E+04
         681          682   0.00000000E+00
         681          683   0.00000000E+00
         681          684   0.00000000E+00
         681          685   0.00000000E+00
         681          686   0.59780145E+02
         681          687   0.56961557E+02
         681          688   0.00000000E+00
         681          689   0.00000000E+00
         681          690   0.27169870E+04
         681          671  -0.90446140E-05
         681          672   0.00000000E+00
         681          673   0.00000000E+00
         681          674   0.00000000E+00
         681          675   0.00000000E+00
         681          676  -0.73767759E-07
         681          677  -0.70289920E-07
         681          678   0.00000000E+00
         681          679   0.00000000E+00
         681          680  -0.33527308E-05
         681          691  -0.20708827E-04
         681          692   0.00000000E+00
         681          693   0.00000000E+00
         681          694   0.00000000E+00
         681          695   0.00000000E+00
         681          696  -0.16890093E-06
         681          697  -0.16093797E-06
         681          698   0.00000000E+00
         681          699   0.00000000E+00
         681          700  -0.76765158E-05
         682          682   0.46151342E+04
         682          681   0.00000000E+00
         682          683   0.00000000E+00
         682          684   0.63450217E+01
         682          685   0.63450217E+01
         682          686   0.00000000E+00
         682          687  -0.21136331E+02
         682          688   0.00000000E+00
         682          689   0.00000000E+00
         682          690   0.18584201E+03
         682          671   0.00000000E+00
         682          672  -0.56924140E-05
         682          673   0.00000000E+00
         682          674   0.00000000E+00
         682          675   0.00000000E+00
         682          676   0.00000000E+00
         682          677   0.00000000E+00
         682          678   0.00000000E+00
         682          679   0.00000000E+00
         682          680  -0.22932695E-06
         682          691   0.00000000E+00
         682          692  -0.13033527E-04
         682          693   0.00000000E+00
         682          694   0.00000000E+00
         682          695   0.00000000E+00
         682          696   0.00000000E+00
         682          697   0.00000000E+00
         682          698   0.00000000E+00
         682          699   0.00000000E+00
         682          700  -0.52507405E-06
         683          683   0.58431579E+03
         683          681   0.00000000E+00
         683          682   0.00000000E+00
         683          684   0.00000000E+00
         683          685   0.00000000E+00
         683          686   0.00000000E+00
         683          687   0.00000000E+00
         683          688   0.00000000E+00
         683          689   0.00000000E+00
         683          690   0.00000000E+00
         683          671   0.00000000E+00
         683          672   0.00000000E+00
         683          673  -0.72103911E-06
         683          674   0.00000000E+00
         683          675   0.00000000E+00
         683          676   0.00000000E+00
         683          677   0.00000000E+00
         683          678   0.00000000E+00
         683          679   0.00000000E+00
         683          680   0.00000000E+00
         683          691   0.00000000E+00
         683          692   0.00000000E+00
         683          693  -0.16509134E-05
         683          694   0.00000000E+00
         683          695   0.00000000E+00
         683          696   0.00000000E+00
         683          697   0.00000000E+00
         683          698   0.00000000E+00
         683          699   0.00000000E+00
         683          700   0.00000000E+00
         684          684   0.10082715E+04
         684          681   0.00000000E+00
         684          682   0.63443872E+01
         684          683   0.00000000E+00
         684          685   0.19035065E+02
         684          686   0.00000000E+00
         684          687  -0.65225820E+02
         684          688   0.00000000E+00
         684          689   0.00000000E+00
         684          690   0.00000000E+00
         684          671   0.00000000E+00
         684          672   0.00000000E+00
         684          673   0.00000000E+00
         684          674  -0.12207066E-05
         684          675   0.00000000E+00
         684          676   0.00000000E+00
         684          677   0.22419448E-08
         684          678   0.00000000E+00
         684          679   0.00000000E+00
         684          680   0.00000000E+00
         684          691   0.00000000E+00
         684          692   0.00000000E+00
         684          693   0.00000000E+00
         684          694  -0.27949673E-05
         684          695   0.00000000E+00
         684          696   0.00000000E+00
         684          697   0.51332259E-08
         684          698   0.00000000E+00
         684          699   0.00000000E+00
         684          700   0.00000000E+00
         685          685   0.19048373E+02
         685          681   0.00000000E+00
         685          682   0.63443872E+01
         685          683   0.00000000E+00
         685          684   0.19035065E+02
         685          686   0.00000000E+00
         685          687  -0.63460558E+02
         685          688   0.00000000E+00
         685          689   0.00000000E+00
         685          690   0.16310427E-05
         685          671   0.00000000E+00
         685          672   0.00000000E+00
         685          673   0.00000000E+00
         685          674   0.00000000E+00
         685          675  -0.16381503E-10
         685          676   0.00000000E+00
         685          677   0.63510494E-10
         685          678   0.00000000E+00
         685          679   0.00000000E+00
         685          680  -0.20126883E-14
         685          691   0.00000000E+00
         685          692   0.00000000E+00
         685          693   0.00000000E+00
         685          694   0.00000000E+00
         685          695  -0.37507595E-10
         685          696   0.00000000E+00
         685          697   0.14541558E-09
         685          698   0.00000000E+00
         685          699   0.00000000E+00
         685          700  -0.46083131E-14
         686          686   0.13567928E+04
         686          681   0.59780145E+02
         686          682   0.00000000E+00
         686          683   0.00000000E+00
         686          684   0.00000000E+00
         686          685   0.00000000E+00
         686          687   0.16206069E+04
         686          688   0.00000000E+00
         686          689   0.43198833E-04
         686          690   0.00000000E+00
         686          671  -0.73767759E-07
         686          672   0.00000000E+00
         686          673   0.00000000E+00
         686          674   0.00000000E+00
         686          675   0.00000000E+00
         686          676  -0.66047155E-04
         686          677  -0.13075202E-03
         686          678   0.00000000E+00
         686          679   0.00000000E+00
         686          680   0.00000000E+00
         686          691  -0.16890093E-06
         686          692   0.00000000E+00
         686          693   0.00000000E+00
         686          694   0.00000000E+00
         686          695   0.00000000E+00
         686          696  -0.69955138E-04
         686          697  -0.13682881E-03
         686          698   0.00000000E+00
         686          699   0.00000000E+00
         686          700   0.00000000E+00
         687          687   0.23691856E+04
         687          681   0.56961557E+02
         687          682  -0.21147957E+02
         687          683   0.00000000E+00
         687          684  -0.65267226E+02
         687          685  -0.63501795E+02
         687          686   0.16205801E+04
         687          688  -0.37236202E-04
         687          689  -0.90067072E-01
         687          690   0.37051049E-01
         687          671  -0.70289920E-07
         687          672   0.00000000E+00
         687          673   0.00000000E+00
         687          674   0.22421690E-08
         687          675   0.63526137E-10
         687          676  -0.13074555E-03
         687          677  -0.26016715E-03
         687          678   0.60591072E-14
         687          679   0.11115315E-09
         687          680  -0.45697777E-10
         687          691  -0.16093797E-06
         687          692   0.00000000E+00
         687          693   0.00000000E+00
         687          694   0.51337392E-08
         687          695   0.14545140E-09
         687          696  -0.13682212E-03
         687          697  -0.27059663E-03
         687          698   0.13873118E-13
         687          699   0.25449968E-09
         687          700  -0.10463104E-09
         688          688   0.63857610E-04
         688          681   0.00000000E+00
         688          682   0.00000000E+00
         688          683   0.00000000E+00
         688          684   0.00000000E+00
         688          685   0.00000000E+00
         688          686   0.00000000E+00
         688          687  -0.37245489E-04
         688          689  -0.15253379E-04
         688          690  -0.35864823E-04
         688          671   0.00000000E+00
         688          672   0.00000000E+00
         688          673   0.00000000E+00
         688          674   0.00000000E+00
         688          675   0.00000000E+00
         688          676   0.00000000E+00
         688          677   0.60595962E-14
         688          678  -0.89921646E-14
         688          679  -0.11269636E-14
         688          680   0.43558702E-14
         688          691   0.00000000E+00
         688          692   0.00000000E+00
         688          693   0.00000000E+00
         688          694   0.00000000E+00
         688          695   0.00000000E+00
         688          696   0.00000000E+00
         688          697   0.13874238E-13
         688          698  -0.20588737E-13
         688          699  -0.25803306E-14
         688          700   0.99733347E-14
         689          689   0.74351678E+02
         689          681   0.00000000E+00
         689          682   0.00000000E+00
         689          683   0.00000000E+00
         689          684   0.00000000E+00
         689          685   0.00000000E+00
         689          686   0.43198833E-04
         689          687  -0.90058065E-01
         689          688  -0.15249776E-04
         689          690   0.25096670E+02
         689          671   0.00000000E+00
         689          672   0.00000000E+00
         689          673   0.00000000E+00
         689          674   0.00000000E+00
         689          675   0.00000000E+00
         689          676   0.00000000E+00
         689          677   0.11114204E-09
         689          678  -0.11269213E-14
         689          679  -0.91749074E-07
         689          680  -0.30968997E-07
         689          691   0.00000000E+00
         689          692   0.00000000E+00
         689          693   0.00000000E+00
         689          694   0.00000000E+00
         689          695   0.00000000E+00
         689          696   0.00000000E+00
         689          697   0.25447423E-09
         689          698  -0.25802338E-14
         689          699  -0.21007151E-06
         689          700  -0.70907568E-07
         690          690   0.10091237E+05
         690          681   0.27169870E+04
         690          682   0.18584201E+03
         690          683   0.00000000E+00
         690          684   0.00000000E+00
         690          685   0.16310200E-05
         690          686   0.00000000E+00
         690          687   0.37051049E-01
         690          688  -0.35855403E-04
         690          689   0.25096670E+02
         690          671  -0.33527308E-05
         690          672  -0.22932695E-06
         690          673   0.00000000E+00
         690          674   0.00000000E+00
         690          675  -0.20126603E-14
         690          676   0.00000000E+00
         690          677  -0.45697777E-10
         690          678   0.43552170E-14
         690          679  -0.30968997E-07
         690          680  -0.12452473E-04
         690          691  -0.76765158E-05
         690          692  -0.52507405E-06
         690          693   0.00000000E+00
         690          694   0.00000000E+00
         690          695  -0.46082490E-14
         690          696   0.00000000E+00
         690          697  -0.10463104E-09
         690          698   0.99718389E-14
         690          699  -0.70907568E-07
         690          700  -0.28511565E-04
         691          691   0.73106057E+04
         691          692   0.00000000E+00
         691          693   0.00000000E+00
         691          694   0.00000000E+00
         691          695   0.00000000E+00
         691          696   0.59625420E+02
         691          697   0.56814127E+02
         691          698   0.00000000E+00
         691          699   0.00000000E+00
         691          700   0.27099548E+04
         691          681  -0.89590304E-05
         691          682   0.00000000E+00
         691          683   0.00000000E+00
         691          684   0.00000000E+00
         691          685   0.00000000E+00
         691          686  -0.73069741E-07
         691          687  -0.69624810E-07
         691          688   0.00000000E+00
         691          689   0.00000000E+00
         691          690  -0.33210060E-05
         691          701  -0.20639898E-04
         691          702   0.00000000E+00
         691          703   0.00000000E+00
         691          704   0.00000000E+00
         691          705   0.00000000E+00
         691          706  -0.16833875E-06
         691          707  -0.16040229E-06
         691          708   0.00000000E+00
         691          709   0.00000000E+00
         691          710  -0.76509647E-05
         692          692   0.46031946E+04
         692          691   0.00000000E+00
         692          693   0.00000000E+00
         692          694   0.63450217E+01
         692          695   0.63450217E+01
         692          696   0.00000000E+00
         692          697  -0.21136331E+02
         692          698   0.00000000E+00
         692          699   0.00000000E+00
         692          700   0.18536101E+03
         692          681   0.00000000E+00
         692          682  -0.56385503E-05
         692          683   0.00000000E+00
         692          684   0.00000000E+00
         692          685   0.00000000E+00
         692          686   0.00000000E+00
         692          687   0.00000000E+00
         692          688   0.00000000E+00
         692          689   0.00000000E+00
         692          690  -0.22715697E-06
         692          701   0.00000000E+00
         692          702  -0.12990145E-04
         692          703   0.00000000E+00
         692          704   0.00000000E+00
         692          705   0.00000000E+00
         692          706   0.00000000E+00
         692          707   0.00000000E+00
         692          708   0.00000000E+00
         692          709   0.00000000E+00
         692          710  -0.52332636E-06
         693          693   0.58280344E+03
         693          691   0.00000000E+00
         693          692   0.00000000E+00
         693          694   0.00000000E+00
         693          695   0.00000000E+00
         693          696   0.00000000E+00
         693          697   0.00000000E+00
         693          698   0.00000000E+00
         693          699   0.00000000E+00
         693          700   0.00000000E+00
         693          681   0.00000000E+00
         693          682   0.00000000E+00
         693          683  -0.71421636E-06
         693          684   0.00000000E+00
         693          685   0.00000000E+00
         693          686   0.00000000E+00
         693          687   0.00000000E+00
         693          688   0.00000000E+00
         693          689   0.00000000E+00
         693          690   0.00000000E+00
         693          701   0.00000000E+00
         693          702   0.00000000E+00
         693          703  -0.16454183E-05
         693          704   0.00000000E+00
         693          705   0.00000000E+00
         693          706   0.00000000E+00
         693          707   0.00000000E+00
         693          708   0.00000000E+00
         693          709   0.00000000E+00
         693          710   0.00000000E+00
         694          694   0.10057111E+04
         694          691   0.00000000E+00
         694          692   0.63443872E+01
         694          693   0.00000000E+00
         694          695   0.19035065E+02
         694          696   0.00000000E+00
         694          697  -0.65221117E+02
         694          698   0.00000000E+00
         694          699   0.00000000E+00
         694          700   0.00000000E+00
         694          681   0.00000000E+00
         694          682   0.00000000E+00
         694          683   0.00000000E+00
         694          684  -0.12091558E-05
         694          685   0.00000000E+00
         694          686   0.00000000E+00
         694          687   0.22207307E-08
         694          688   0.00000000E+00
         694          689   0.00000000E+00
         694          690   0.00000000E+00
         694          701   0.00000000E+00
         694          702   0.00000000E+00
         694          703   0.00000000E+00
         694          704  -0.27856644E-05
         694          705   0.00000000E+00
         694          706   0.00000000E+00
         694          707   0.51161401E-08
         694          708   0.00000000E+00
         694          709   0.00000000E+00
         694          710   0.00000000E+00
         695          695   0.19048339E+02
         695          691   0.00000000E+00
         695          692   0.63443872E+01
         695          693   0.00000000E+00
         695          694   0.19035065E+02
         695          696   0.00000000E+00
         695          697  -0.63460424E+02
         695          698   0.00000000E+00
         695          699   0.00000000E+00
         695          700   0.16268211E-05
         695          681   0.00000000E+00
         695          682   0.00000000E+00
         695          683   0.00000000E+00
         695          684   0.00000000E+00
         695          685  -0.16226495E-10
         695          686   0.00000000E+00
         695          687   0.62909533E-10
         695          688   0.00000000E+00
         695          689   0.00000000E+00
         695          690  -0.19936435E-14
         695          701   0.00000000E+00
         695          702   0.00000000E+00
         695          703   0.00000000E+00
         695          704   0.00000000E+00
         695          705  -0.37382752E-10
         695          706   0.00000000E+00
         695          707   0.14493157E-09
         695          708   0.00000000E+00
         695          709   0.00000000E+00
         695          710  -0.45929745E-14
         696          696   0.13540940E+04
         696          691   0.59625420E+02
         696          692   0.00000000E+00
         696          693   0.00000000E+00
         696          694   0.00000000E+00
         696          695   0.00000000E+00
         696          697   0.16180381E+04
         696          698   0.00000000E+00
         696          699   0.43198833E-04
         696          700   0.00000000E+00
         696          681  -0.73069741E-07
         696          682   0.00000000E+00
         696          683   0.00000000E+00
         696          684   0.00000000E+00
         696          685   0.00000000E+00
         696          686  -0.67906812E-04
         696          687  -0.13448429E-03
         696          688   0.00000000E+00
         696          689   0.00000000E+00
         696          690   0.00000000E+00
         696          701  -0.16833875E-06
         696          702   0.00000000E+00
         696          703   0.00000000E+00
         696          704   0.00000000E+00
         696          705   0.00000000E+00
         696          706  -0.71489878E-04
         696          707  -0.13990872E-03
         696          708   0.00000000E+00
         696          709   0.00000000E+00
         696          710   0.00000000E+00
         697          697   0.23668522E+04
         697          691   0.56814127E+02
         697          692  -0.21147957E+02
         697          693   0.00000000E+00
         697          694  -0.65262523E+02
         697          695  -0.63501662E+02
         697          696   0.16180114E+04
         697          698  -0.37223493E-04
         697          699  -0.89833933E-01
         697          700   0.36955200E-01
         697          681  -0.69624810E-07
         697          682   0.00000000E+00
         697          683   0.00000000E+00
         697          684   0.22209527E-08
         697          685   0.62925028E-10
         697          686  -0.13447763E-03
         697          687  -0.26764433E-03
         697          688   0.60017736E-14
         697          689   0.11010138E-09
         697          690  -0.45265368E-10
         697          701  -0.16040229E-06
         697          702   0.00000000E+00
         697          703   0.00000000E+00
         697          704   0.51166517E-08
         697          705   0.14496727E-09
         697          706  -0.13990188E-03
         697          707  -0.27676664E-03
         697          708   0.13826942E-13
         697          709   0.25365259E-09
         697          710  -0.10428278E-09
         698          698   0.63838750E-04
         698          691   0.00000000E+00
         698          692   0.00000000E+00
         698          693   0.00000000E+00
         698          694   0.00000000E+00
         698          695   0.00000000E+00
         698          696   0.00000000E+00
         698          697  -0.37232779E-04
         698          699  -0.15255743E-04
         698          700  -0.35855687E-04
         698          681   0.00000000E+00
         698          682   0.00000000E+00
         698          683   0.00000000E+00
         698          684   0.00000000E+00
         698          685   0.00000000E+00
         698          686   0.00000000E+00
         698          687   0.60022581E-14
         698          688  -0.89070773E-14
         698          689  -0.11162998E-14
         698          690   0.43146534E-14
         698          701   0.00000000E+00
         698          702   0.00000000E+00
         698          703   0.00000000E+00
         698          704   0.00000000E+00
         698          705   0.00000000E+00
         698          706   0.00000000E+00
         698          707   0.13828058E-13
         698          708  -0.20520208E-13
         698          709  -0.25717420E-14
         698          710   0.99401388E-14
         699          699   0.74159238E+02
         699          691   0.00000000E+00
         699          692   0.00000000E+00
         699          693   0.00000000E+00
         699          694   0.00000000E+00
         699          695   0.00000000E+00
         699          696   0.43198833E-04
         699          697  -0.89824949E-01
         699          698  -0.15252140E-04
         699          700   0.25031714E+02
         699          681   0.00000000E+00
         699          682   0.00000000E+00
         699          683   0.00000000E+00
         699          684   0.00000000E+00
         699          685   0.00000000E+00
         699          686   0.00000000E+00
         699          687   0.11009037E-09
         699          688  -0.11162580E-14
         699          689  -0.90880910E-07
         699          690  -0.30675956E-07
         699          701   0.00000000E+00
         699          702   0.00000000E+00
         699          703   0.00000000E+00
         699          704   0.00000000E+00
         699          705   0.00000000E+00
         699          706   0.00000000E+00
         699          707   0.25362723E-09
         699          708  -0.25716456E-14
         699          709  -0.20937229E-06
         699          710  -0.70671555E-07
         700          700   0.10065119E+05
         700          691   0.27099548E+04
         700          692   0.18536101E+03
         700          693   0.00000000E+00
         700          694   0.00000000E+00
         700          695   0.16267985E-05
         700          696   0.00000000E+00
         700          697   0.36955200E-01
         700          698  -0.35846269E-04
         700          699   0.25031714E+02
         700          681  -0.33210060E-05
         700          682  -0.22715697E-06
         700          683   0.00000000E+00
         700          684   0.00000000E+00
         700          685  -0.19936157E-14
         700          686   0.00000000E+00
         700          687  -0.45265368E-10
         700          688   0.43140062E-14
         700          689  -0.30675956E-07
         700          690  -0.12334643E-04
         700          701  -0.76509647E-05
         700          702  -0.52332636E-06
         700          703   0.00000000E+00
         700          704   0.00000000E+00
         700          705  -0.45929106E-14
         700          706   0.00000000E+00
         700          707  -0.10428278E-09
         700          708   0.99386480E-14
         700          709  -0.70671555E-07
         700          710  -0.28416665E-04
         701          701   0.72952421E+04
         701          702   0.00000000E+00
         701          703   0.00000000E+00
         701          704   0.00000000E+00
         701          705   0.00000000E+00
         701          706   0.59500115E+02
         701          707   0.56694729E+02
         701          708   0.00000000E+00
         701          709   0.00000000E+00
         701          710   0.27042597E+04
         701          691  -0.88901018E-05
         701          692   0.00000000E+00
         701          693   0.00000000E+00
         701          694   0.00000000E+00
         701          695   0.00000000E+00
         701          696  -0.72507560E-07
         701          697  -0.69089133E-07
         701          698   0.00000000E+00
         701          699   0.00000000E+00
         701          700  -0.32954550E-05
         701          711  -0.20584373E-04
         701          712   0.00000000E+00
         701          713   0.00000000E+00
         701          714   0.00000000E+00
         701          715   0.00000000E+00
         701          716  -0.16788589E-06
         701          717  -0.15997078E-06
         701          718   0.00000000E+00
         701          719   0.00000000E+00
         701          720  -0.76303824E-05
         702          702   0.45935252E+04
         702          701   0.00000000E+00
         702          703   0.00000000E+00
         702          704   0.63450217E+01
         702          705   0.63450217E+01
         702          706   0.00000000E+00
         702          707  -0.21136331E+02
         702          708   0.00000000E+00
         702          709   0.00000000E+00
         702          710   0.18497146E+03
         702          691   0.00000000E+00
         702          692  -0.55951686E-05
         702          693   0.00000000E+00
         702          694   0.00000000E+00
         702          695   0.00000000E+00
         702          696   0.00000000E+00
         702          697   0.00000000E+00
         702          698   0.00000000E+00
         702          699   0.00000000E+00
         702          700  -0.22540928E-06
         702          711   0.00000000E+00
         702          712  -0.12955199E-04
         702          713   0.00000000E+00
         702          714   0.00000000E+00
         702          715   0.00000000E+00
         702          716   0.00000000E+00
         702          717   0.00000000E+00
         702          718   0.00000000E+00
         702          719   0.00000000E+00
         702          720  -0.52191852E-06
         703          703   0.58157865E+03
         703          701   0.00000000E+00
         703          702   0.00000000E+00
         703          704   0.00000000E+00
         703          705   0.00000000E+00
         703          706   0.00000000E+00
         703          707   0.00000000E+00
         703          708   0.00000000E+00
         703          709   0.00000000E+00
         703          710   0.00000000E+00
         703          691   0.00000000E+00
         703          692   0.00000000E+00
         703          693  -0.70872136E-06
         703          694   0.00000000E+00
         703          695   0.00000000E+00
         703          696   0.00000000E+00
         703          697   0.00000000E+00
         703          698   0.00000000E+00
         703          699   0.00000000E+00
         703          700   0.00000000E+00
         703          711   0.00000000E+00
         703          712   0.00000000E+00
         703          713  -0.16409919E-05
         703          714   0.00000000E+00
         703          715   0.00000000E+00
         703          716   0.00000000E+00
         703          717   0.00000000E+00
         703          718   0.00000000E+00
         703          719   0.00000000E+00
         703          720   0.00000000E+00
         704          704   0.10036376E+04
         704          701   0.00000000E+00
         704          702   0.63443872E+01
         704          703   0.00000000E+00
         704          705   0.19035065E+02
         704          706   0.00000000E+00
         704          707  -0.65217309E+02
         704          708   0.00000000E+00
         704          709   0.00000000E+00
         704          710   0.00000000E+00
         704          691   0.00000000E+00
         704          692   0.00000000E+00
         704          693   0.00000000E+00
         704          694  -0.11998528E-05
         704          695   0.00000000E+00
         704          696   0.00000000E+00
         704          697   0.22036449E-08
         704          698   0.00000000E+00
         704          699   0.00000000E+00
         704          700   0.00000000E+00
         704          711   0.00000000E+00
         704          712   0.00000000E+00
         704          713   0.00000000E+00
         704          714  -0.27781705E-05
         704          715   0.00000000E+00
         704          716   0.00000000E+00
         704          717   0.51023768E-08
         704          718   0.00000000E+00
         704          719   0.00000000E+00
         704          720   0.00000000E+00
         705          705   0.19048311E+02
         705          701   0.00000000E+00
         705          702   0.63443872E+01
         705          703   0.00000000E+00
         705          704   0.19035065E+02
         705          706   0.00000000E+00
         705          707  -0.63460316E+02
         705          708   0.00000000E+00
         705          709   0.00000000E+00
         705          710   0.16234023E-05
         705          691   0.00000000E+00
         705          692   0.00000000E+00
         705          693   0.00000000E+00
         705          694   0.00000000E+00
         705          695  -0.16101653E-10
         705          696   0.00000000E+00
         705          697   0.62425523E-10
         705          698   0.00000000E+00
         705          699   0.00000000E+00
         705          700  -0.19783049E-14
         705          711   0.00000000E+00
         705          712   0.00000000E+00
         705          713   0.00000000E+00
         705          714   0.00000000E+00
         705          715  -0.37282186E-10
         705          716   0.00000000E+00
         705          717   0.14454168E-09
         705          718   0.00000000E+00
         705          719   0.00000000E+00
         705          720  -0.45806186E-14
         706          706   0.13519083E+04
         706          701   0.59500115E+02
         706          702   0.00000000E+00
         706          703   0.00000000E+00
         706          704   0.00000000E+00
         706          705   0.00000000E+00
         706          707   0.16159578E+04
         706          708   0.00000000E+00
         706          709   0.43198833E-04
         706          710   0.00000000E+00
         706          691  -0.72507560E-07
         706          692   0.00000000E+00
         706          693   0.00000000E+00
         706          694   0.00000000E+00
         706          695   0.00000000E+00
         706          696  -0.69441551E-04
         706          697  -0.13756420E-03
         706          698   0.00000000E+00
         706          699   0.00000000E+00
         706          700   0.00000000E+00
         706          711  -0.16788589E-06
         706          712   0.00000000E+00
         706          713   0.00000000E+00
         706          714   0.00000000E+00
         706          715   0.00000000E+00
         706          716  -0.72750722E-04
         706          717  -0.14243882E-03
         706          718   0.00000000E+00
         706          719   0.00000000E+00
         706          720   0.00000000E+00
         707          707   0.23649625E+04
         707          701   0.56694729E+02
         707          702  -0.21147957E+02
         707          703   0.00000000E+00
         707          704  -0.65258714E+02
         707          705  -0.63501554E+02
         707          706   0.16159311E+04
         707          708  -0.37213201E-04
         707          709  -0.89645123E-01
         707          710   0.36877576E-01
         707          691  -0.69089133E-07
         707          692   0.00000000E+00
         707          693   0.00000000E+00
         707          694   0.22038653E-08
         707          695   0.62440899E-10
         707          696  -0.13755739E-03
         707          697  -0.27381434E-03
         707          698   0.59555974E-14
         707          699   0.10925429E-09
         707          700  -0.44917107E-10
         707          711  -0.15997078E-06
         707          712   0.00000000E+00
         707          713   0.00000000E+00
         707          714   0.51028871E-08
         707          715   0.14457728E-09
         707          716  -0.14243185E-03
         707          717  -0.28183504E-03
         707          718   0.13789745E-13
         707          719   0.25297022E-09
         707          720  -0.10400224E-09
         708          708   0.63823475E-04
         708          701   0.00000000E+00
         708          702   0.00000000E+00
         708          703   0.00000000E+00
         708          704   0.00000000E+00
         708          705   0.00000000E+00
         708          706   0.00000000E+00
         708          707  -0.37222486E-04
         708          709  -0.15257657E-04
         708          710  -0.35848288E-04
         708          691   0.00000000E+00
         708          692   0.00000000E+00
         708          693   0.00000000E+00
         708          694   0.00000000E+00
         708          695   0.00000000E+00
         708          696   0.00000000E+00
         708          697   0.59560781E-14
         708          698  -0.88385484E-14
         708          699  -0.11077113E-14
         708          700   0.42814575E-14
         708          711   0.00000000E+00
         708          712   0.00000000E+00
         708          713   0.00000000E+00
         708          714   0.00000000E+00
         708          715   0.00000000E+00
         708          716   0.00000000E+00
         708          717   0.13790858E-13
         708          718  -0.20465005E-13
         708          719  -0.25648236E-14
         708          720   0.99133981E-14
         709          709   0.74003389E+02
         709          701   0.00000000E+00
         709          702   0.00000000E+00
         709          703   0.00000000E+00
         709          704   0.00000000E+00
         709          705   0.00000000E+00
         709          706   0.43198833E-04
         709          707  -0.89636158E-01
         709          708  -0.15254054E-04
         709          710   0.24979108E+02
         709          691   0.00000000E+00
         709          692   0.00000000E+00
         709          693   0.00000000E+00
         709          694   0.00000000E+00
         709          695   0.00000000E+00
         709          696   0.00000000E+00
         709          697   0.10924336E-09
         709          698  -0.11076698E-14
         709          699  -0.90181694E-07
         709          700  -0.30439943E-07
         709          711   0.00000000E+00
         709          712   0.00000000E+00
         709          713   0.00000000E+00
         709          714   0.00000000E+00
         709          715   0.00000000E+00
         709          716   0.00000000E+00
         709          717   0.25294493E-09
         709          718  -0.25647274E-14
         709          719  -0.20880904E-06
         709          720  -0.70481437E-07
         710          710   0.10043966E+05
         710          701   0.27042597E+04
         710          702   0.18497146E+03
         710          703   0.00000000E+00
         710          704   0.00000000E+00
         710          705   0.16233797E-05
         710          706   0.00000000E+00
         710          707   0.36877576E-01
         710          708  -0.35838871E-04
         710          709   0.24979108E+02
         710          691  -0.32954550E-05
         710          692  -0.22540928E-06
         710          693   0.00000000E+00
         710          694   0.00000000E+00
         710          695  -0.19782773E-14
         710          696   0.00000000E+00
         710          697  -0.44917107E-10
         710          698   0.42808153E-14
         710          699  -0.30439943E-07
         710          700  -0.12239743E-04
         710          711  -0.76303824E-05
         710          712  -0.52191852E-06
         710          713   0.00000000E+00
         710          714   0.00000000E+00
         710          715  -0.45805549E-14
         710          716   0.00000000E+00
         710          717  -0.10400224E-09
         710          718   0.99119113E-14
         710          719  -0.70481437E-07
         710          720  -0.28340219E-04
         711          711   0.72828105E+04
         711          712   0.00000000E+00
         711          713   0.00000000E+00
         711          714   0.00000000E+00
         711          715   0.00000000E+00
         711          716   0.59398722E+02
         711          717   0.56598116E+02
         711          718   0.00000000E+00
         711          719   0.00000000E+00
         711          720   0.26996514E+04
         711          701  -0.88345770E-05
         711          702   0.00000000E+00
         711          703   0.00000000E+00
         711          704   0.00000000E+00
         711          705   0.00000000E+00
         711          706  -0.72054700E-07
         711          707  -0.68657624E-07
         711          708   0.00000000E+00
         711          709   0.00000000E+00
         711          710  -0.32748726E-05
         711          721  -0.20539639E-04
         711          722   0.00000000E+00
         711          723   0.00000000E+00
         711          724   0.00000000E+00
         711          725   0.00000000E+00
         711          726  -0.16752104E-06
         711          727  -0.15962313E-06
         711          728   0.00000000E+00
         711          729   0.00000000E+00
         711          730  -0.76137999E-05
         712          712   0.45857011E+04
         712          711   0.00000000E+00
         712          713   0.00000000E+00
         712          714   0.63450217E+01
         712          715   0.63450217E+01
         712          716   0.00000000E+00
         712          717  -0.21136331E+02
         712          718   0.00000000E+00
         712          719   0.00000000E+00
         712          720   0.18465626E+03
         712          701   0.00000000E+00
         712          702  -0.55602229E-05
         712          703   0.00000000E+00
         712          704   0.00000000E+00
         712          705   0.00000000E+00
         712          706   0.00000000E+00
         712          707   0.00000000E+00
         712          708   0.00000000E+00
         712          709   0.00000000E+00
         712          710  -0.22400145E-06
         712          721   0.00000000E+00
         712          722  -0.12927045E-04
         712          723   0.00000000E+00
         712          724   0.00000000E+00
         712          725   0.00000000E+00
         712          726   0.00000000E+00
         712          727   0.00000000E+00
         712          728   0.00000000E+00
         712          729   0.00000000E+00
         712          730  -0.52078428E-06
         713          713   0.58058760E+03
         713          711   0.00000000E+00
         713          712   0.00000000E+00
         713          714   0.00000000E+00
         713          715   0.00000000E+00
         713          716   0.00000000E+00
         713          717   0.00000000E+00
         713          718   0.00000000E+00
         713          719   0.00000000E+00
         713          720   0.00000000E+00
         713          701   0.00000000E+00
         713          702   0.00000000E+00
         713          703  -0.70429490E-06
         713          704   0.00000000E+00
         713          705   0.00000000E+00
         713          706   0.00000000E+00
         713          707   0.00000000E+00
         713          708   0.00000000E+00
         713          709   0.00000000E+00
         713          710   0.00000000E+00
         713          721   0.00000000E+00
         713          722   0.00000000E+00
         713          723  -0.16374257E-05
         713          724   0.00000000E+00
         713          725   0.00000000E+00
         713          726   0.00000000E+00
         713          727   0.00000000E+00
         713          728   0.00000000E+00
         713          729   0.00000000E+00
         713          730   0.00000000E+00
         714          714   0.10019597E+04
         714          711   0.00000000E+00
         714          712   0.63443872E+01
         714          713   0.00000000E+00
         714          715   0.19035065E+02
         714          716   0.00000000E+00
         714          717  -0.65214227E+02
         714          718   0.00000000E+00
         714          719   0.00000000E+00
         714          720   0.00000000E+00
         714          701   0.00000000E+00
         714          702   0.00000000E+00
         714          703   0.00000000E+00
         714          704  -0.11923589E-05
         714          705   0.00000000E+00
         714          706   0.00000000E+00
         714          707   0.21898816E-08
         714          708   0.00000000E+00
         714          709   0.00000000E+00
         714          710   0.00000000E+00
         714          721   0.00000000E+00
         714          722   0.00000000E+00
         714          723   0.00000000E+00
         714          724  -0.27721329E-05
         714          725   0.00000000E+00
         714          726   0.00000000E+00
         714          727   0.50912883E-08
         714          728   0.00000000E+00
         714          729   0.00000000E+00
         714          730   0.00000000E+00
         715          715   0.19048288E+02
         715          711   0.00000000E+00
         715          712   0.63443872E+01
         715          713   0.00000000E+00
         715          714   0.19035065E+02
         715          716   0.00000000E+00
         715          717  -0.63460229E+02
         715          718   0.00000000E+00
         715          719   0.00000000E+00
         715          720   0.16206359E-05
         715          701   0.00000000E+00
         715          702   0.00000000E+00
         715          703   0.00000000E+00
         715          704   0.00000000E+00
         715          705  -0.16001087E-10
         715          706   0.00000000E+00
         715          707   0.62035632E-10
         715          708   0.00000000E+00
         715          709   0.00000000E+00
         715          710  -0.19659490E-14
         715          721   0.00000000E+00
         715          722   0.00000000E+00
         715          723   0.00000000E+00
         715          724   0.00000000E+00
         715          725  -0.37201164E-10
         715          726   0.00000000E+00
         715          727   0.14422756E-09
         715          728   0.00000000E+00
         715          729   0.00000000E+00
         715          730  -0.45706639E-14
         716          716   0.13501397E+04
         716          711   0.59398722E+02
         716          712   0.00000000E+00
         716          713   0.00000000E+00
         716          714   0.00000000E+00
         716          715   0.00000000E+00
         716          717   0.16142745E+04
         716          718   0.00000000E+00
         716          719   0.43198833E-04
         716          720   0.00000000E+00
         716          701  -0.72054700E-07
         716          702   0.00000000E+00
         716          703   0.00000000E+00
         716          704   0.00000000E+00
         716          705   0.00000000E+00
         716          706  -0.70702395E-04
         716          707  -0.14009429E-03
         716          708   0.00000000E+00
         716          709   0.00000000E+00
         716          710   0.00000000E+00
         716          721  -0.16752104E-06
         716          722   0.00000000E+00
         716          723   0.00000000E+00
         716          724   0.00000000E+00
         716          725   0.00000000E+00
         716          726  -0.73782765E-04
         716          727  -0.14450968E-03
         716          728   0.00000000E+00
         716          729   0.00000000E+00
         716          730   0.00000000E+00
         717          717   0.23634334E+04
         717          711   0.56598116E+02
         717          712  -0.21147957E+02
         717          713   0.00000000E+00
         717          714  -0.65255633E+02
         717          715  -0.63501467E+02
         717          716   0.16142477E+04
         717          718  -0.37204873E-04
         717          719  -0.89492345E-01
         717          720   0.36814765E-01
         717          701  -0.68657624E-07
         717          702   0.00000000E+00
         717          703   0.00000000E+00
         717          704   0.21901006E-08
         717          705   0.62050912E-10
         717          706  -0.14008736E-03
         717          707  -0.27888274E-03
         717          708   0.59184006E-14
         717          709   0.10857192E-09
         717          710  -0.44636569E-10
         717          721  -0.15962313E-06
         717          722   0.00000000E+00
         717          723   0.00000000E+00
         717          724   0.50917974E-08
         717          725   0.14426309E-09
         717          726  -0.14450261E-03
         717          727  -0.28598338E-03
         717          728   0.13759777E-13
         717          729   0.25242046E-09
         717          730  -0.10377622E-09
         718          718   0.63811115E-04
         718          711   0.00000000E+00
         718          712   0.00000000E+00
         718          713   0.00000000E+00
         718          714   0.00000000E+00
         718          715   0.00000000E+00
         718          716   0.00000000E+00
         718          717  -0.37214157E-04
         718          719  -0.15259206E-04
         718          720  -0.35842301E-04
         718          701   0.00000000E+00
         718          702   0.00000000E+00
         718          703   0.00000000E+00
         718          704   0.00000000E+00
         718          705   0.00000000E+00
         718          706   0.00000000E+00
         718          707   0.59188783E-14
         718          708  -0.87833456E-14
         718          709  -0.11007929E-14
         718          710   0.42547168E-14
         718          721   0.00000000E+00
         718          722   0.00000000E+00
         718          723   0.00000000E+00
         718          724   0.00000000E+00
         718          725   0.00000000E+00
         718          726   0.00000000E+00
         718          727   0.13760888E-13
         718          728  -0.20420530E-13
         718          729  -0.25592497E-14
         718          730   0.98918542E-14
         719          719   0.73877281E+02
         719          711   0.00000000E+00
         719          712   0.00000000E+00
         719          713   0.00000000E+00
         719          714   0.00000000E+00
         719          715   0.00000000E+00
         719          716   0.43198833E-04
         719          717  -0.89483395E-01
         719          718  -0.15255603E-04
         719          720   0.24936542E+02
         719          701   0.00000000E+00
         719          702   0.00000000E+00
         719          703   0.00000000E+00
         719          704   0.00000000E+00
         719          705   0.00000000E+00
         719          706   0.00000000E+00
         719          707   0.10856106E-09
         719          708  -0.11007516E-14
         719          709  -0.89618448E-07
         719          710  -0.30249824E-07
         719          721   0.00000000E+00
         719          722   0.00000000E+00
         719          723   0.00000000E+00
         719          724   0.00000000E+00
         719          725   0.00000000E+00
         719          726   0.00000000E+00
         719          727   0.25239522E-09
         719          728  -0.25591537E-14
         719          729  -0.20835526E-06
         719          730  -0.70328266E-07
         720          720   0.10026851E+05
         720          711   0.26996514E+04
         720          712   0.18465626E+03
         720          713   0.00000000E+00
         720          714   0.00000000E+00
         720          715   0.16206133E-05
         720          716   0.00000000E+00
         720          717   0.36814765E-01
         720          718  -0.35832884E-04
         720          719   0.24936542E+02
         720          701  -0.32748726E-05
         720          702  -0.22400145E-06
         720          703   0.00000000E+00
         720          704   0.00000000E+00
         720          705  -0.19659216E-14
         720          706   0.00000000E+00
         720          707  -0.44636569E-10
         720          708   0.42540787E-14
         720          709  -0.30249824E-07
         720          710  -0.12163297E-04
         720          721  -0.76137999E-05
         720          722  -0.52078428E-06
         720          723   0.00000000E+00
         720          724   0.00000000E+00
         720          725  -0.45706004E-14
         720          726   0.00000000E+00
         720          727  -0.10377622E-09
         720          728   0.98903706E-14
         720          729  -0.70328266E-07
         720          730  -0.28278630E-04
         721          721   0.72727583E+04
         721          722   0.00000000E+00
         721          723   0.00000000E+00
         721          724   0.00000000E+00
         721          725   0.00000000E+00
         721          726   0.59316737E+02
         721          727   0.56519996E+02
         721          728   0.00000000E+00
         721          729   0.00000000E+00
         721          730   0.26959252E+04
         721          711  -0.87898428E-05
         721          712   0.00000000E+00
         721          713   0.00000000E+00
         721          714   0.00000000E+00
         721          715   0.00000000E+00
         721          716  -0.71689849E-07
         721          717  -0.68309974E-07
         721          718   0.00000000E+00
         721          719   0.00000000E+00
         721          720  -0.32582902E-05
         721          731  -0.20503594E-04
         721          732   0.00000000E+00
         721          733   0.00000000E+00
         721          734   0.00000000E+00
         721          735   0.00000000E+00
         721          736  -0.16722706E-06
         721          737  -0.15934301E-06
         721          738   0.00000000E+00
         721          739   0.00000000E+00
         721          740  -0.76004384E-05
         722          722   0.45793745E+04
         722          721   0.00000000E+00
         722          723   0.00000000E+00
         722          724   0.63450217E+01
         722          725   0.63450217E+01
         722          726   0.00000000E+00
         722          727  -0.21136331E+02
         722          728   0.00000000E+00
         722          729   0.00000000E+00
         722          730   0.18440138E+03
         722          711   0.00000000E+00
         722          712  -0.55320686E-05
         722          713   0.00000000E+00
         722          714   0.00000000E+00
         722          715   0.00000000E+00
         722          716   0.00000000E+00
         722          717   0.00000000E+00
         722          718   0.00000000E+00
         722          719   0.00000000E+00
         722          720  -0.22286721E-06
         722          731   0.00000000E+00
         722          732  -0.12904359E-04
         722          733   0.00000000E+00
         722          734   0.00000000E+00
         722          735   0.00000000E+00
         722          736   0.00000000E+00
         722          737   0.00000000E+00
         722          738   0.00000000E+00
         722          739   0.00000000E+00
         722          740  -0.51987036E-06
         723          723   0.57978623E+03
         723          721   0.00000000E+00
         723          722   0.00000000E+00
         723          724   0.00000000E+00
         723          725   0.00000000E+00
         723          726   0.00000000E+00
         723          727   0.00000000E+00
         723          728   0.00000000E+00
         723          729   0.00000000E+00
         723          730   0.00000000E+00
         723          711   0.00000000E+00
         723          712   0.00000000E+00
         723          713  -0.70072868E-06
         723          714   0.00000000E+00
         723          715   0.00000000E+00
         723          716   0.00000000E+00
         723          717   0.00000000E+00
         723          718   0.00000000E+00
         723          719   0.00000000E+00
         723          720   0.00000000E+00
         723          731   0.00000000E+00
         723          732   0.00000000E+00
         723          733  -0.16345521E-05
         723          734   0.00000000E+00
         723          735   0.00000000E+00
         723          736   0.00000000E+00
         723          737   0.00000000E+00
         723          738   0.00000000E+00
         723          739   0.00000000E+00
         723          740   0.00000000E+00
         724          724   0.10006030E+04
         724          721   0.00000000E+00
         724          722   0.63443872E+01
         724          723   0.00000000E+00
         724          725   0.19035065E+02
         724          726   0.00000000E+00
         724          727  -0.65211736E+02
         724          728   0.00000000E+00
         724          729   0.00000000E+00
         724          730   0.00000000E+00
         724          711   0.00000000E+00
         724          712   0.00000000E+00
         724          713   0.00000000E+00
         724          714  -0.11863214E-05
         724          715   0.00000000E+00
         724          716   0.00000000E+00
         724          717   0.21787931E-08
         724          718   0.00000000E+00
         724          719   0.00000000E+00
         724          720   0.00000000E+00
         724          731   0.00000000E+00
         724          732   0.00000000E+00
         724          733   0.00000000E+00
         724          734  -0.27672681E-05
         724          735   0.00000000E+00
         724          736   0.00000000E+00
         724          737   0.50823536E-08
         724          738   0.00000000E+00
         724          739   0.00000000E+00
         724          740   0.00000000E+00
         725          725   0.19048270E+02
         725          721   0.00000000E+00
         725          722   0.63443872E+01
         725          723   0.00000000E+00
         725          724   0.19035065E+02
         725          726   0.00000000E+00
         725          727  -0.63460159E+02
         725          728   0.00000000E+00
         725          729   0.00000000E+00
         725          730   0.16183990E-05
         725          711   0.00000000E+00
         725          712   0.00000000E+00
         725          713   0.00000000E+00
         725          714   0.00000000E+00
         725          715  -0.15920065E-10
         725          716   0.00000000E+00
         725          717   0.61721513E-10
         725          718   0.00000000E+00
         725          719   0.00000000E+00
         725          720  -0.19559943E-14
         725          731   0.00000000E+00
         725          732   0.00000000E+00
         725          733   0.00000000E+00
         725          734   0.00000000E+00
         725          735  -0.37135880E-10
         725          736   0.00000000E+00
         725          737   0.14397446E-09
         725          738   0.00000000E+00
         725          739   0.00000000E+00
         725          740  -0.45626429E-14
         726          726   0.13487097E+04
         726          721   0.59316737E+02
         726          722   0.00000000E+00
         726          723   0.00000000E+00
         726          724   0.00000000E+00
         726          725   0.00000000E+00
         726          727   0.16129134E+04
         726          728   0.00000000E+00
         726          729   0.43198833E-04
         726          730   0.00000000E+00
         726          711  -0.71689849E-07
         726          712   0.00000000E+00
         726          713   0.00000000E+00
         726          714   0.00000000E+00
         726          715   0.00000000E+00
         726          716  -0.71734439E-04
         726          717  -0.14216516E-03
         726          718   0.00000000E+00
         726          719   0.00000000E+00
         726          720   0.00000000E+00
         726          731  -0.16722706E-06
         726          732   0.00000000E+00
         726          733   0.00000000E+00
         726          734   0.00000000E+00
         726          735   0.00000000E+00
         726          736  -0.74625041E-04
         726          737  -0.14619969E-03
         726          738   0.00000000E+00
         726          739   0.00000000E+00
         726          740   0.00000000E+00
         727          727   0.23621970E+04
         727          721   0.56519996E+02
         727          722  -0.21147957E+02
         727          723   0.00000000E+00
         727          724  -0.65253141E+02
         727          725  -0.63501396E+02
         727          726   0.16128866E+04
         727          728  -0.37198139E-04
         727          729  -0.89368809E-01
         727          730   0.36763976E-01
         727          711  -0.68309974E-07
         727          712   0.00000000E+00
         727          713   0.00000000E+00
         727          714   0.21790110E-08
         727          715   0.61736715E-10
         727          716  -0.14215811E-03
         727          717  -0.28303108E-03
         727          718   0.58884326E-14
         727          719   0.10802216E-09
         727          720  -0.44410550E-10
         727          731  -0.15934301E-06
         727          732   0.00000000E+00
         727          733   0.00000000E+00
         727          734   0.50828618E-08
         727          735   0.14400992E-09
         727          736  -0.14619253E-03
         727          737  -0.28936873E-03
         727          738   0.13735630E-13
         727          739   0.25197749E-09
         727          740  -0.10359410E-09
         728          728   0.63801122E-04
         728          721   0.00000000E+00
         728          722   0.00000000E+00
         728          723   0.00000000E+00
         728          724   0.00000000E+00
         728          725   0.00000000E+00
         728          726   0.00000000E+00
         728          727  -0.37207423E-04
         728          729  -0.15260458E-04
         728          730  -0.35837460E-04
         728          711   0.00000000E+00
         728          712   0.00000000E+00
         728          713   0.00000000E+00
         728          714   0.00000000E+00
         728          715   0.00000000E+00
         728          716   0.00000000E+00
         728          717   0.58889079E-14
         728          718  -0.87388708E-14
         728          719  -0.10952190E-14
         728          720   0.42331729E-14
         728          731   0.00000000E+00
         728          732   0.00000000E+00
         728          733   0.00000000E+00
         728          734   0.00000000E+00
         728          735   0.00000000E+00
         728          736   0.00000000E+00
         728          737   0.13736739E-13
         728          738  -0.20384694E-13
         728          739  -0.25547585E-14
         728          740   0.98744950E-14
         729          729   0.73775311E+02
         729          721   0.00000000E+00
         729          722   0.00000000E+00
         729          723   0.00000000E+00
         729          724   0.00000000E+00
         729          725   0.00000000E+00
         729          726   0.43198833E-04
         729          727  -0.89359871E-01
         729          728  -0.15256856E-04
         729          730   0.24902123E+02
         729          711   0.00000000E+00
         729          712   0.00000000E+00
         729          713   0.00000000E+00
         729          714   0.00000000E+00
         729          715   0.00000000E+00
         729          716   0.00000000E+00
         729          717   0.10801136E-09
         729          718  -0.10951779E-14
         729          719  -0.89164661E-07
         729          720  -0.30096653E-07
         729          731   0.00000000E+00
         729          732   0.00000000E+00
         729          733   0.00000000E+00
         729          734   0.00000000E+00
         729          735   0.00000000E+00
         729          736   0.00000000E+00
         729          737   0.25195229E-09
         729          738  -0.25546627E-14
         729          739  -0.20798961E-06
         729          740  -0.70204846E-07
         730          730   0.10013011E+05
         730          721   0.26959252E+04
         730          722   0.18440138E+03
         730          723   0.00000000E+00
         730          724   0.00000000E+00
         730          725   0.16183765E-05
         730          726   0.00000000E+00
         730          727   0.36763976E-01
         730          728  -0.35828044E-04
         730          729   0.24902123E+02
         730          711  -0.32582902E-05
         730          712  -0.22286721E-06
         730          713   0.00000000E+00
         730          714   0.00000000E+00
         730          715  -0.19559671E-14
         730          716   0.00000000E+00
         730          717  -0.44410550E-10
         730          718   0.42325380E-14
         730          719  -0.30096653E-07
         730          720  -0.12101708E-04
         730          731  -0.76004384E-05
         730          732  -0.51987036E-06
         730          733   0.00000000E+00
         730          734   0.00000000E+00
         730          735  -0.45625794E-14
         730          736   0.00000000E+00
         730          737  -0.10359410E-09
         730          738   0.98730140E-14
         730          739  -0.70204846E-07
         730          740  -0.28229004E-04
         731          731   0.72646347E+04
         731          732   0.00000000E+00
         731          733   0.00000000E+00
         731          734   0.00000000E+00
         731          735   0.00000000E+00
         731          736   0.59250481E+02
         731          737   0.56456864E+02
         731          738   0.00000000E+00
         731          739   0.00000000E+00
         731          740   0.26929139E+04
         731          721  -0.87537978E-05
         731          722   0.00000000E+00
         731          723   0.00000000E+00
         731          724   0.00000000E+00
         731          725   0.00000000E+00
         731          726  -0.71395866E-07
         731          727  -0.68029851E-07
         731          728   0.00000000E+00
         731          729   0.00000000E+00
         731          730  -0.32449287E-05
         731          741  -0.20474547E-04
         731          742   0.00000000E+00
         731          743   0.00000000E+00
         731          744   0.00000000E+00
         731          745   0.00000000E+00
         731          746  -0.16699015E-06
         731          747  -0.15911727E-06
         731          748   0.00000000E+00
         731          749   0.00000000E+00
         731          750  -0.75896712E-05
         732          732   0.45742618E+04
         732          731   0.00000000E+00
         732          733   0.00000000E+00
         732          734   0.63450217E+01
         732          735   0.63450217E+01
         732          736   0.00000000E+00
         732          737  -0.21136331E+02
         732          738   0.00000000E+00
         732          739   0.00000000E+00
         732          740   0.18419541E+03
         732          721   0.00000000E+00
         732          722  -0.55093829E-05
         732          723   0.00000000E+00
         732          724   0.00000000E+00
         732          725   0.00000000E+00
         732          726   0.00000000E+00
         732          727   0.00000000E+00
         732          728   0.00000000E+00
         732          729   0.00000000E+00
         732          730  -0.22195328E-06
         732          741   0.00000000E+00
         732          742  -0.12886078E-04
         732          743   0.00000000E+00
         732          744   0.00000000E+00
         732          745   0.00000000E+00
         732          746   0.00000000E+00
         732          747   0.00000000E+00
         732          748   0.00000000E+00
         732          749   0.00000000E+00
         732          750  -0.51913388E-06
         733          733   0.57913862E+03
         733          731   0.00000000E+00
         733          732   0.00000000E+00
         733          734   0.00000000E+00
         733          735   0.00000000E+00
         733          736   0.00000000E+00
         733          737   0.00000000E+00
         733          738   0.00000000E+00
         733          739   0.00000000E+00
         733          740   0.00000000E+00
         733          721   0.00000000E+00
         733          722   0.00000000E+00
         733          723  -0.69785516E-06
         733          724   0.00000000E+00
         733          725   0.00000000E+00
         733          726   0.00000000E+00
         733          727   0.00000000E+00
         733          728   0.00000000E+00
         733          729   0.00000000E+00
         733          730   0.00000000E+00
         733          741   0.00000000E+00
         733          742   0.00000000E+00
         733          743  -0.16322365E-05
         733          744   0.00000000E+00
         733          745   0.00000000E+00
         733          746   0.00000000E+00
         733          747   0.00000000E+00
         733          748   0.00000000E+00
         733          749   0.00000000E+00
         733          750   0.00000000E+00
         734          734   0.99950663E+03
         734          731   0.00000000E+00
         734          732   0.63443872E+01
         734          733   0.00000000E+00
         734          735   0.19035065E+02
         734          736   0.00000000E+00
         734          737  -0.65209722E+02
         734          738   0.00000000E+00
         734          739   0.00000000E+00
         734          740   0.00000000E+00
         734          721   0.00000000E+00
         734          722   0.00000000E+00
         734          723   0.00000000E+00
         734          724  -0.11814565E-05
         734          725   0.00000000E+00
         734          726   0.00000000E+00
         734          727   0.21698584E-08
         734          728   0.00000000E+00
         734          729   0.00000000E+00
         734          730   0.00000000E+00
         734          741   0.00000000E+00
         734          742   0.00000000E+00
         734          743   0.00000000E+00
         734          744  -0.27633478E-05
         734          745   0.00000000E+00
         734          746   0.00000000E+00
         734          747   0.50751536E-08
         734          748   0.00000000E+00
         734          749   0.00000000E+00
         734          750   0.00000000E+00
         735          735   0.19048255E+02
         735          731   0.00000000E+00
         735          732   0.63443872E+01
         735          733   0.00000000E+00
         735          734   0.19035065E+02
         735          736   0.00000000E+00
         735          737  -0.63460102E+02
         735          738   0.00000000E+00
         735          739   0.00000000E+00
         735          740   0.16165912E-05
         735          721   0.00000000E+00
         735          722   0.00000000E+00
         735          723   0.00000000E+00
         735          724   0.00000000E+00
         735          725  -0.15854780E-10
         735          726   0.00000000E+00
         735          727   0.61468407E-10
         735          728   0.00000000E+00
         735          729   0.00000000E+00
         735          730  -0.19479733E-14
         735          741   0.00000000E+00
         735          742   0.00000000E+00
         735          743   0.00000000E+00
         735          744   0.00000000E+00
         735          745  -0.37083271E-10
         735          746   0.00000000E+00
         735          747   0.14377049E-09
         735          748   0.00000000E+00
         735          749   0.00000000E+00
         735          750  -0.45561791E-14
         736          736   0.13475540E+04
         736          731   0.59250481E+02
         736          732   0.00000000E+00
         736          733   0.00000000E+00
         736          734   0.00000000E+00
         736          735   0.00000000E+00
         736          737   0.16118134E+04
         736          738   0.00000000E+00
         736          739   0.43198833E-04
         736          740   0.00000000E+00
         736          721  -0.71395866E-07
         736          722   0.00000000E+00
         736          723   0.00000000E+00
         736          724   0.00000000E+00
         736          725   0.00000000E+00
         736          726  -0.72576714E-04
         736          727  -0.14385517E-03
         736          728   0.00000000E+00
         736          729   0.00000000E+00
         736          730   0.00000000E+00
         736          741  -0.16699015E-06
         736          742   0.00000000E+00
         736          743   0.00000000E+00
         736          744   0.00000000E+00
         736          745   0.00000000E+00
         736          746  -0.75310812E-04
         736          747  -0.14757563E-03
         736          748   0.00000000E+00
         736          749   0.00000000E+00
         736          750   0.00000000E+00
         737          737   0.23611978E+04
         737          731   0.56456864E+02
         737          732  -0.21147957E+02
         737          733   0.00000000E+00
         737          734  -0.65251127E+02
         737          735  -0.63501339E+02
         737          736   0.16117866E+04
         737          738  -0.37192697E-04
         737          739  -0.89268975E-01
         737          740   0.36722932E-01
         737          721  -0.68029851E-07
         737          722   0.00000000E+00
         737          723   0.00000000E+00
         737          724   0.21700754E-08
         737          725   0.61483547E-10
         737          726  -0.14384804E-03
         737          727  -0.28641643E-03
         737          728   0.58642855E-14
         737          729   0.10757919E-09
         737          730  -0.44228433E-10
         737          741  -0.15911727E-06
         737          742   0.00000000E+00
         737          743   0.00000000E+00
         737          744   0.50756611E-08
         737          745   0.14380590E-09
         737          746  -0.14756841E-03
         737          747  -0.29212490E-03
         737          748   0.13716172E-13
         737          749   0.25162052E-09
         737          750  -0.10344735E-09
         738          738   0.63793045E-04
         738          731   0.00000000E+00
         738          732   0.00000000E+00
         738          733   0.00000000E+00
         738          734   0.00000000E+00
         738          735   0.00000000E+00
         738          736   0.00000000E+00
         738          737  -0.37201980E-04
         738          739  -0.15261471E-04
         738          740  -0.35833547E-04
         738          721   0.00000000E+00
         738          722   0.00000000E+00
         738          723   0.00000000E+00
         738          724   0.00000000E+00
         738          725   0.00000000E+00
         738          726   0.00000000E+00
         738          727   0.58647589E-14
         738          728  -0.87030348E-14
         738          729  -0.10907277E-14
         738          730   0.42158137E-14
         738          741   0.00000000E+00
         738          742   0.00000000E+00
         738          743   0.00000000E+00
         738          744   0.00000000E+00
         738          745   0.00000000E+00
         738          746   0.00000000E+00
         738          747   0.13717279E-13
         738          748  -0.20355816E-13
         738          749  -0.25511392E-14
         738          750   0.98605062E-14
         739          739   0.73692905E+02
         739          731   0.00000000E+00
         739          732   0.00000000E+00
         739          733   0.00000000E+00
         739          734   0.00000000E+00
         739          735   0.00000000E+00
         739          736   0.43198833E-04
         739          737  -0.89260048E-01
         739          738  -0.15257868E-04
         739          740   0.24874308E+02
         739          721   0.00000000E+00
         739          722   0.00000000E+00
         739          723   0.00000000E+00
         739          724   0.00000000E+00
         739          725   0.00000000E+00
         739          726   0.00000000E+00
         739          727   0.10756843E-09
         739          728  -0.10906868E-14
         739          729  -0.88799018E-07
         739          730  -0.29973234E-07
         739          741   0.00000000E+00
         739          742   0.00000000E+00
         739          743   0.00000000E+00
         739          744   0.00000000E+00
         739          745   0.00000000E+00
         739          746   0.00000000E+00
         739          747   0.25159536E-09
         739          748  -0.25510436E-14
         739          749  -0.20769496E-06
         739          750  -0.70105390E-07
         740          740   0.10001827E+05
         740          731   0.26929139E+04
         740          732   0.18419541E+03
         740          733   0.00000000E+00
         740          734   0.00000000E+00
         740          735   0.16165688E-05
         740          736   0.00000000E+00
         740          737   0.36722932E-01
         740          738  -0.35824132E-04
         740          739   0.24874308E+02
         740          721  -0.32449287E-05
         740          722  -0.22195328E-06
         740          723   0.00000000E+00
         740          724   0.00000000E+00
         740          725  -0.19479462E-14
         740          726   0.00000000E+00
         740          727  -0.44228433E-10
         740          728   0.42151814E-14
         740          729  -0.29973234E-07
         740          730  -0.12052082E-04
         740          741  -0.75896712E-05
         740          742  -0.51913388E-06
         740          743   0.00000000E+00
         740          744   0.00000000E+00
         740          745  -0.45561158E-14
         740          746   0.00000000E+00
         740          747  -0.10344735E-09
         740          748   0.98590273E-14
         740          749  -0.70105390E-07
         740          750  -0.28189013E-04
         741          741   0.72580728E+04
         741          742   0.00000000E+00
         741          743   0.00000000E+00
         741          744   0.00000000E+00
         741          745   0.00000000E+00
         741          746   0.59196962E+02
         741          747   0.56405868E+02
         741          748   0.00000000E+00
         741          749   0.00000000E+00
         741          750   0.26904814E+04
         741          731  -0.87247511E-05
         741          732   0.00000000E+00
         741          733   0.00000000E+00
         741          734   0.00000000E+00
         741          735   0.00000000E+00
         741          736  -0.71158961E-07
         741          737  -0.67804116E-07
         741          738   0.00000000E+00
         741          739   0.00000000E+00
         741          740  -0.32341615E-05
         741          751  -0.20451138E-04
         741          752   0.00000000E+00
         741          753   0.00000000E+00
         741          754   0.00000000E+00
         741          755   0.00000000E+00
         741          756  -0.16679923E-06
         741          757  -0.15893535E-06
         741          758   0.00000000E+00
         741          759   0.00000000E+00
         741          760  -0.75809938E-05
         742          742   0.45701319E+04
         742          741   0.00000000E+00
         742          743   0.00000000E+00
         742          744   0.63450217E+01
         742          745   0.63450217E+01
         742          746   0.00000000E+00
         742          747  -0.21136331E+02
         742          748   0.00000000E+00
         742          749   0.00000000E+00
         742          750   0.18402903E+03
         742          731   0.00000000E+00
         742          732  -0.54911017E-05
         742          733   0.00000000E+00
         742          734   0.00000000E+00
         742          735   0.00000000E+00
         742          736   0.00000000E+00
         742          737   0.00000000E+00
         742          738   0.00000000E+00
         742          739   0.00000000E+00
         742          740  -0.22121680E-06
         742          751   0.00000000E+00
         742          752  -0.12871345E-04
         742          753   0.00000000E+00
         742          754   0.00000000E+00
         742          755   0.00000000E+00
         742          756   0.00000000E+00
         742          757   0.00000000E+00
         742          758   0.00000000E+00
         742          759   0.00000000E+00
         742          760  -0.51854034E-06
         743          743   0.57861550E+03
         743          741   0.00000000E+00
         743          742   0.00000000E+00
         743          744   0.00000000E+00
         743          745   0.00000000E+00
         743          746   0.00000000E+00
         743          747   0.00000000E+00
         743          748   0.00000000E+00
         743          749   0.00000000E+00
         743          750   0.00000000E+00
         743          731   0.00000000E+00
         743          732   0.00000000E+00
         743          733  -0.69553955E-06
         743          734   0.00000000E+00
         743          735   0.00000000E+00
         743          736   0.00000000E+00
         743          737   0.00000000E+00
         743          738   0.00000000E+00
         743          739   0.00000000E+00
         743          740   0.00000000E+00
         743          751   0.00000000E+00
         743          752   0.00000000E+00
         743          753  -0.16303704E-05
         743          754   0.00000000E+00
         743          755   0.00000000E+00
         743          756   0.00000000E+00
         743          757   0.00000000E+00
         743          758   0.00000000E+00
         743          759   0.00000000E+00
         743          760   0.00000000E+00
         744          744   0.99862100E+03
         744          741   0.00000000E+00
         744          742   0.63443872E+01
         744          743   0.00000000E+00
         744          745   0.19035065E+02
         744          746   0.00000000E+00
         744          747  -0.65208095E+02
         744          748   0.00000000E+00
         744          749   0.00000000E+00
         744          750   0.00000000E+00
         744          731   0.00000000E+00
         744          732   0.00000000E+00
         744          733   0.00000000E+00
         744          734  -0.11775363E-05
         744          735   0.00000000E+00
         744          736   0.00000000E+00
         744          737   0.21626584E-08
         744          738   0.00000000E+00
         744          739   0.00000000E+00
         744          740   0.00000000E+00
         744          751   0.00000000E+00
         744          752   0.00000000E+00
         744          753   0.00000000E+00
         744          754  -0.27601884E-05
         744          755   0.00000000E+00
         744          756   0.00000000E+00
         744          757   0.50693511E-08
         744          758   0.00000000E+00
         744          759   0.00000000E+00
         744          760   0.00000000E+00
         745          745   0.19048243E+02
         745          741   0.00000000E+00
         745          742   0.63443872E+01
         745          743   0.00000000E+00
         745          744   0.19035065E+02
         745          746   0.00000000E+00
         745          747  -0.63460055E+02
         745          748   0.00000000E+00
         745          749   0.00000000E+00
         745          750   0.16151310E-05
         745          731   0.00000000E+00
         745          732   0.00000000E+00
         745          733   0.00000000E+00
         745          734   0.00000000E+00
         745          735  -0.15802171E-10
         745          736   0.00000000E+00
         745          737   0.61264444E-10
         745          738   0.00000000E+00
         745          739   0.00000000E+00
         745          740  -0.19415095E-14
         745          751   0.00000000E+00
         745          752   0.00000000E+00
         745          753   0.00000000E+00
         745          754   0.00000000E+00
         745          755  -0.37040873E-10
         745          756   0.00000000E+00
         745          757   0.14360612E-09
         745          758   0.00000000E+00
         745          759   0.00000000E+00
         745          760  -0.45509700E-14
         746          746   0.13466204E+04
         746          741   0.59196962E+02
         746          742   0.00000000E+00
         746          743   0.00000000E+00
         746          744   0.00000000E+00
         746          745   0.00000000E+00
         746          747   0.16109249E+04
         746          748   0.00000000E+00
         746          749   0.43198833E-04
         746          750   0.00000000E+00
         746          731  -0.71158961E-07
         746          732   0.00000000E+00
         746          733   0.00000000E+00
         746          734   0.00000000E+00
         746          735   0.00000000E+00
         746          736  -0.73262485E-04
         746          737  -0.14523111E-03
         746          738   0.00000000E+00
         746          739   0.00000000E+00
         746          740   0.00000000E+00
         746          751  -0.16679923E-06
         746          752   0.00000000E+00
         746          753   0.00000000E+00
         746          754   0.00000000E+00
         746          755   0.00000000E+00
         746          756  -0.75868091E-04
         746          757  -0.14869374E-03
         746          758   0.00000000E+00
         746          759   0.00000000E+00
         746          760   0.00000000E+00
         747          747   0.23603907E+04
         747          741   0.56405868E+02
         747          742  -0.21147957E+02
         747          743   0.00000000E+00
         747          744  -0.65249500E+02
         747          745  -0.63501293E+02
         747          746   0.16108981E+04
         747          748  -0.37188301E-04
         747          749  -0.89188333E-01
         747          750   0.36689778E-01
         747          731  -0.67804116E-07
         747          732   0.00000000E+00
         747          733   0.00000000E+00
         747          734   0.21628747E-08
         747          735   0.61279534E-10
         747          736  -0.14522391E-03
         747          737  -0.28917261E-03
         747          738   0.58448267E-14
         747          739   0.10722222E-09
         747          740  -0.44081675E-10
         747          751  -0.15893535E-06
         747          752   0.00000000E+00
         747          753   0.00000000E+00
         747          754   0.50698580E-08
         747          755   0.14364149E-09
         747          756  -0.14868646E-03
         747          757  -0.29436458E-03
         747          758   0.13700490E-13
         747          759   0.25133284E-09
         747          760  -0.10332907E-09
         748          748   0.63786521E-04
         748          741   0.00000000E+00
         748          742   0.00000000E+00
         748          743   0.00000000E+00
         748          744   0.00000000E+00
         748          745   0.00000000E+00
         748          746   0.00000000E+00
         748          747  -0.37197584E-04
         748          749  -0.15262288E-04
         748          750  -0.35830387E-04
         748          731   0.00000000E+00
         748          732   0.00000000E+00
         748          733   0.00000000E+00
         748          734   0.00000000E+00
         748          735   0.00000000E+00
         748          736   0.00000000E+00
         748          737   0.58452985E-14
         748          738  -0.86741566E-14
         748          739  -0.10871085E-14
         748          740   0.42018248E-14
         748          751   0.00000000E+00
         748          752   0.00000000E+00
         748          753   0.00000000E+00
         748          754   0.00000000E+00
         748          755   0.00000000E+00
         748          756   0.00000000E+00
         748          757   0.13701595E-13
         748          758  -0.20332543E-13
         748          759  -0.25482225E-14
         748          760   0.98492324E-14
         749          749   0.73626341E+02
         749          741   0.00000000E+00
         749          742   0.00000000E+00
         749          743   0.00000000E+00
         749          744   0.00000000E+00
         749          745   0.00000000E+00
         749          746   0.43198833E-04
         749          747  -0.89179413E-01
         749          748  -0.15258685E-04
         749          750   0.24851839E+02
         749          731   0.00000000E+00
         749          732   0.00000000E+00
         749          733   0.00000000E+00
         749          734   0.00000000E+00
         749          735   0.00000000E+00
         749          736   0.00000000E+00
         749          737   0.10721150E-09
         749          738  -0.10870677E-14
         749          739  -0.88504367E-07
         749          740  -0.29873778E-07
         749          751   0.00000000E+00
         749          752   0.00000000E+00
         749          753   0.00000000E+00
         749          754   0.00000000E+00
         749          755   0.00000000E+00
         749          756   0.00000000E+00
         749          757   0.25130771E-09
         749          758  -0.25481269E-14
         749          759  -0.20745750E-06
         749          760  -0.70025237E-07
         750          750   0.99927922E+04
         750          741   0.26904814E+04
         750          742   0.18402903E+03
         750          743   0.00000000E+00
         750          744   0.00000000E+00
         750          745   0.16151086E-05
         750          746   0.00000000E+00
         750          747   0.36689778E-01
         750          748  -0.35820973E-04
         750          749   0.24851839E+02
         750          731  -0.32341615E-05
         750          732  -0.22121680E-06
         750          733   0.00000000E+00
         750          734   0.00000000E+00
         750          735  -0.19414825E-14
         750          736   0.00000000E+00
         750          737  -0.44081675E-10
         750          738   0.42011946E-14
         750          739  -0.29873778E-07
         750          740  -0.12012091E-04
         750          751  -0.75809938E-05
         750          752  -0.51854034E-06
         750          753   0.00000000E+00
         750          754   0.00000000E+00
         750          755  -0.45509067E-14
         750          756   0.00000000E+00
         750          757  -0.10332907E-09
         750          758   0.98477552E-14
         750          759  -0.70025237E-07
         750          760  -0.28156784E-04
         751          751   0.72527743E+04
         751          752   0.00000000E+00
         751          753   0.00000000E+00
         751          754   0.00000000E+00
         751          755   0.00000000E+00
         751          756   0.59153748E+02
         751          757   0.56364691E+02
         751          758   0.00000000E+00
         751          759   0.00000000E+00
         751          760   0.26885173E+04
         751          741  -0.87013421E-05
         751          742   0.00000000E+00
         751          743   0.00000000E+00
         751          744   0.00000000E+00
         751          745   0.00000000E+00
         751          746  -0.70968038E-07
         751          747  -0.67622194E-07
         751          748   0.00000000E+00
         751          749   0.00000000E+00
         751          750  -0.32254840E-05
         751          761  -0.20432271E-04
         751          762   0.00000000E+00
         751          763   0.00000000E+00
         751          764   0.00000000E+00
         751          765   0.00000000E+00
         751          766  -0.16664535E-06
         751          767  -0.15878872E-06
         751          768   0.00000000E+00
         751          769   0.00000000E+00
         751          770  -0.75740000E-05
         752          752   0.45667972E+04
         752          751   0.00000000E+00
         752          753   0.00000000E+00
         752          754   0.63450217E+01
         752          755   0.63450217E+01
         752          756   0.00000000E+00
         752          757  -0.21136331E+02
         752          758   0.00000000E+00
         752          759   0.00000000E+00
         752          760   0.18389469E+03
         752          741   0.00000000E+00
         752          742  -0.54763688E-05
         752          743   0.00000000E+00
         752          744   0.00000000E+00
         752          745   0.00000000E+00
         752          746   0.00000000E+00
         752          747   0.00000000E+00
         752          748   0.00000000E+00
         752          749   0.00000000E+00
         752          750  -0.22062326E-06
         752          761   0.00000000E+00
         752          762  -0.12859471E-04
         752          763   0.00000000E+00
         752          764   0.00000000E+00
         752          765   0.00000000E+00
         752          766   0.00000000E+00
         752          767   0.00000000E+00
         752          768   0.00000000E+00
         752          769   0.00000000E+00
         752          770  -0.51806196E-06
         753          753   0.57819310E+03
         753          751   0.00000000E+00
         753          752   0.00000000E+00
         753          754   0.00000000E+00
         753          755   0.00000000E+00
         753          756   0.00000000E+00
         753          757   0.00000000E+00
         753          758   0.00000000E+00
         753          759   0.00000000E+00
         753          760   0.00000000E+00
         753          741   0.00000000E+00
         753          742   0.00000000E+00
         753          743  -0.69367338E-06
         753          744   0.00000000E+00
         753          745   0.00000000E+00
         753          746   0.00000000E+00
         753          747   0.00000000E+00
         753          748   0.00000000E+00
         753          749   0.00000000E+00
         753          750   0.00000000E+00
         753          761   0.00000000E+00
         753          762   0.00000000E+00
         753          763  -0.16288663E-05
         753          764   0.00000000E+00
         753          765   0.00000000E+00
         753          766   0.00000000E+00
         753          767   0.00000000E+00
         753          768   0.00000000E+00
         753          769   0.00000000E+00
         753          770   0.00000000E+00
         754          754   0.99790589E+03
         754          751   0.00000000E+00
         754          752   0.63443872E+01
         754          753   0.00000000E+00
         754          755   0.19035065E+02
         754          756   0.00000000E+00
         754          757  -0.65206782E+02
         754          758   0.00000000E+00
         754          759   0.00000000E+00
         754          760   0.00000000E+00
         754          741   0.00000000E+00
         754          742   0.00000000E+00
         754          743   0.00000000E+00
         754          744  -0.11743769E-05
         754          745   0.00000000E+00
         754          746   0.00000000E+00
         754          747   0.21568559E-08
         754          748   0.00000000E+00
         754          749   0.00000000E+00
         754          750   0.00000000E+00
         754          761   0.00000000E+00
         754          762   0.00000000E+00
         754          763   0.00000000E+00
         754          764  -0.27576420E-05
         754          765   0.00000000E+00
         754          766   0.00000000E+00
         754          767   0.50646744E-08
         754          768   0.00000000E+00
         754          769   0.00000000E+00
         754          770   0.00000000E+00
         755          755   0.19048234E+02
         755          751   0.00000000E+00
         755          752   0.63443872E+01
         755          753   0.00000000E+00
         755          754   0.19035065E+02
         755          756   0.00000000E+00
         755          757  -0.63460018E+02
         755          758   0.00000000E+00
         755          759   0.00000000E+00
         755          760   0.16139520E-05
         755          741   0.00000000E+00
         755          742   0.00000000E+00
         755          743   0.00000000E+00
         755          744   0.00000000E+00
         755          745  -0.15759773E-10
         755          746   0.00000000E+00
         755          747   0.61100068E-10
         755          748   0.00000000E+00
         755          749   0.00000000E+00
         755          750  -0.19363004E-14
         755          761   0.00000000E+00
         755          762   0.00000000E+00
         755          763   0.00000000E+00
         755          764   0.00000000E+00
         755          765  -0.37006701E-10
         755          766   0.00000000E+00
         755          767   0.14347363E-09
         755          768   0.00000000E+00
         755          769   0.00000000E+00
         755          770  -0.45467715E-14
         756          756   0.13458667E+04
         756          751   0.59153748E+02
         756          752   0.00000000E+00
         756          753   0.00000000E+00
         756          754   0.00000000E+00
         756          755   0.00000000E+00
         756          757   0.16102075E+04
         756          758   0.00000000E+00
         756          759   0.43198833E-04
         756          760   0.00000000E+00
         756          741  -0.70968038E-07
         756          742   0.00000000E+00
         756          743   0.00000000E+00
         756          744   0.00000000E+00
         756          745   0.00000000E+00
         756          746  -0.73819765E-04
         756          747  -0.14634922E-03
         756          748   0.00000000E+00
         756          749   0.00000000E+00
         756          750   0.00000000E+00
         756          761  -0.16664535E-06
         756          762   0.00000000E+00
         756          763   0.00000000E+00
         756          764   0.00000000E+00
         756          765   0.00000000E+00
         756          766  -0.76320257E-04
         756          767  -0.14960093E-03
         756          768   0.00000000E+00
         756          769   0.00000000E+00
         756          770   0.00000000E+00
         757          757   0.23597390E+04
         757          751   0.56364691E+02
         757          752  -0.21147957E+02
         757          753   0.00000000E+00
         757          754  -0.65248187E+02
         757          755  -0.63501256E+02
         757          756   0.16101807E+04
         757          758  -0.37184751E-04
         757          759  -0.89123217E-01
         757          760   0.36663008E-01
         757          741  -0.67622194E-07
         757          742   0.00000000E+00
         757          743   0.00000000E+00
         757          744   0.21570715E-08
         757          745   0.61115118E-10
         757          746  -0.14634196E-03
         757          747  -0.29141228E-03
         757          748   0.58291448E-14
         757          749   0.10693454E-09
         757          750  -0.43963401E-10
         757          761  -0.15878872E-06
         757          762   0.00000000E+00
         757          763   0.00000000E+00
         757          764   0.50651808E-08
         757          765   0.14350897E-09
         757          766  -0.14959360E-03
         757          767  -0.29618174E-03
         757          768   0.13687850E-13
         757          769   0.25110097E-09
         757          770  -0.10323375E-09
         758          758   0.63781253E-04
         758          751   0.00000000E+00
         758          752   0.00000000E+00
         758          753   0.00000000E+00
         758          754   0.00000000E+00
         758          755   0.00000000E+00
         758          756   0.00000000E+00
         758          757  -0.37194034E-04
         758          759  -0.15262948E-04
         758          760  -0.35827835E-04
         758          741   0.00000000E+00
         758          742   0.00000000E+00
         758          743   0.00000000E+00
         758          744   0.00000000E+00
         758          745   0.00000000E+00
         758          746   0.00000000E+00
         758          747   0.58296153E-14
         758          748  -0.86508833E-14
         758          749  -0.10841917E-14
         758          750   0.41905511E-14
         758          761   0.00000000E+00
         758          762   0.00000000E+00
         758          763   0.00000000E+00
         758          764   0.00000000E+00
         758          765   0.00000000E+00
         758          766   0.00000000E+00
         758          767   0.13688955E-13
         758          768  -0.20313785E-13
         758          769  -0.25458716E-14
         758          770   0.98401461E-14
         759          759   0.73572592E+02
         759          751   0.00000000E+00
         759          752   0.00000000E+00
         759          753   0.00000000E+00
         759          754   0.00000000E+00
         759          755   0.00000000E+00
         759          756   0.43198833E-04
         759          757  -0.89114304E-01
         759          758  -0.15259346E-04
         759          760   0.24833697E+02
         759          741   0.00000000E+00
         759          742   0.00000000E+00
         759          743   0.00000000E+00
         759          744   0.00000000E+00
         759          745   0.00000000E+00
         759          746   0.00000000E+00
         759          747   0.10692384E-09
         759          748  -0.10841511E-14
         759          749  -0.88266905E-07
         759          750  -0.29793625E-07
         759          761   0.00000000E+00
         759          762   0.00000000E+00
         759          763   0.00000000E+00
         759          764   0.00000000E+00
         759          765   0.00000000E+00
         759          766   0.00000000E+00
         759          767   0.25107587E-09
         759          768  -0.25457761E-14
         759          769  -0.20726611E-06
         759          770  -0.69960635E-07
         760          760   0.99854973E+04
         760          751   0.26885173E+04
         760          752   0.18389469E+03
         760          753   0.00000000E+00
         760          754   0.00000000E+00
         760          755   0.16139295E-05
         760          756   0.00000000E+00
         760          757   0.36663008E-01
         760          758  -0.35818421E-04
         760          759   0.24833697E+02
         760          741  -0.32254840E-05
         760          742  -0.22062326E-06
         760          743   0.00000000E+00
         760          744   0.00000000E+00
         760          745  -0.19362734E-14
         760          746   0.00000000E+00
         760          747  -0.43963401E-10
         760          748   0.41899226E-14
         760          749  -0.29793625E-07
         760          750  -0.11979862E-04
         760          761  -0.75740000E-05
         760          762  -0.51806196E-06
         760          763   0.00000000E+00
         760          764   0.00000000E+00
         760          765  -0.45467083E-14
         760          766   0.00000000E+00
         760          767  -0.10323375E-09
         760          768   0.98386703E-14
         760          769  -0.69960635E-07
         760          770  -0.28130808E-04
         761          761   0.72484972E+04
         761          762   0.00000000E+00
         761          763   0.00000000E+00
         761          764   0.00000000E+00
         761          765   0.00000000E+00
         761          766   0.59118864E+02
         761          767   0.56331452E+02
         761          768   0.00000000E+00
         761          769   0.00000000E+00
         761          770   0.26869319E+04
         761          751  -0.86824753E-05
         761          752   0.00000000E+00
         761          753   0.00000000E+00
         761          754   0.00000000E+00
         761          755   0.00000000E+00
         761          756  -0.70814161E-07
         761          757  -0.67475571E-07
         761          758   0.00000000E+00
         761          759   0.00000000E+00
         761          760  -0.32184903E-05
         761          771  -0.20417064E-04
         761          772   0.00000000E+00
         761          773   0.00000000E+00
         761          774   0.00000000E+00
         761          775   0.00000000E+00
         761          776  -0.16652132E-06
         761          777  -0.15867054E-06
         761          778   0.00000000E+00
         761          779   0.00000000E+00
         761          780  -0.75683629E-05
         762          762   0.45641053E+04
         762          761   0.00000000E+00
         762          763   0.00000000E+00
         762          764   0.63450217E+01
         762          765   0.63450217E+01
         762          766   0.00000000E+00
         762          767  -0.21136331E+02
         762          768   0.00000000E+00
         762          769   0.00000000E+00
         762          770   0.18378624E+03
         762          751   0.00000000E+00
         762          752  -0.54644946E-05
         762          753   0.00000000E+00
         762          754   0.00000000E+00
         762          755   0.00000000E+00
         762          756   0.00000000E+00
         762          757   0.00000000E+00
         762          758   0.00000000E+00
         762          759   0.00000000E+00
         762          760  -0.22014489E-06
         762          771   0.00000000E+00
         762          772  -0.12849900E-04
         762          773   0.00000000E+00
         762          774   0.00000000E+00
         762          775   0.00000000E+00
         762          776   0.00000000E+00
         762          777   0.00000000E+00
         762          778   0.00000000E+00
         762          779   0.00000000E+00
         762          780  -0.51767639E-06
         763          763   0.57785213E+03
         763          761   0.00000000E+00
         763          762   0.00000000E+00
         763          764   0.00000000E+00
         763          765   0.00000000E+00
         763          766   0.00000000E+00
         763          767   0.00000000E+00
         763          768   0.00000000E+00
         763          769   0.00000000E+00
         763          770   0.00000000E+00
         763          751   0.00000000E+00
         763          752   0.00000000E+00
         763          753  -0.69216931E-06
         763          754   0.00000000E+00
         763          755   0.00000000E+00
         763          756   0.00000000E+00
         763          757   0.00000000E+00
         763          758   0.00000000E+00
         763          759   0.00000000E+00
         763          760   0.00000000E+00
         763          771   0.00000000E+00
         763          772   0.00000000E+00
         763          773  -0.16276540E-05
         763          774   0.00000000E+00
         763          775   0.00000000E+00
         763          776   0.00000000E+00
         763          777   0.00000000E+00
         763          778   0.00000000E+00
         763          779   0.00000000E+00
         763          780   0.00000000E+00
         764          764   0.99732863E+03
         764          761   0.00000000E+00
         764          762   0.63443872E+01
         764          763   0.00000000E+00
         764          765   0.19035065E+02
         764          766   0.00000000E+00
         764          767  -0.65205722E+02
         764          768   0.00000000E+00
         764          769   0.00000000E+00
         764          770   0.00000000E+00
         764          751   0.00000000E+00
         764          752   0.00000000E+00
         764          753   0.00000000E+00
         764          754  -0.11718305E-05
         764          755   0.00000000E+00
         764          756   0.00000000E+00
         764          757   0.21521792E-08
         764          758   0.00000000E+00
         764          759   0.00000000E+00
         764          760   0.00000000E+00
         764          771   0.00000000E+00
         764          772   0.00000000E+00
         764          773   0.00000000E+00
         764          774  -0.27555896E-05
         764          775   0.00000000E+00
         764          776   0.00000000E+00
         764          777   0.50609049E-08
         764          778   0.00000000E+00
         764          779   0.00000000E+00
         764          780   0.00000000E+00
         765          765   0.19048226E+02
         765          761   0.00000000E+00
         765          762   0.63443872E+01
         765          763   0.00000000E+00
         765          764   0.19035065E+02
         765          766   0.00000000E+00
         765          767  -0.63459988E+02
         765          768   0.00000000E+00
         765          769   0.00000000E+00
         765          770   0.16130002E-05
         765          751   0.00000000E+00
         765          752   0.00000000E+00
         765          753   0.00000000E+00
         765          754   0.00000000E+00
         765          755  -0.15725602E-10
         765          756   0.00000000E+00
         765          757   0.60967587E-10
         765          758   0.00000000E+00
         765          759   0.00000000E+00
         765          760  -0.19321019E-14
         765          771   0.00000000E+00
         765          772   0.00000000E+00
         765          773   0.00000000E+00
         765          774   0.00000000E+00
         765          775  -0.36979158E-10
         765          776   0.00000000E+00
         765          777   0.14336685E-09
         765          778   0.00000000E+00
         765          779   0.00000000E+00
         765          780  -0.45433875E-14
         766          766   0.13452582E+04
         766          761   0.59118864E+02
         766          762   0.00000000E+00
         766          763   0.00000000E+00
         766          764   0.00000000E+00
         766          765   0.00000000E+00
         766          767   0.16096283E+04
         766          768   0.00000000E+00
         766          769   0.43198833E-04
         766          770   0.00000000E+00
         766          751  -0.70814161E-07
         766          752   0.00000000E+00
         766          753   0.00000000E+00
         766          754   0.00000000E+00
         766          755   0.00000000E+00
         766          756  -0.74271930E-04
         766          757  -0.14725641E-03
         766          758   0.00000000E+00
         766          759   0.00000000E+00
         766          760   0.00000000E+00
         766          771  -0.16652132E-06
         766          772   0.00000000E+00
         766          773   0.00000000E+00
         766          774   0.00000000E+00
         766          775   0.00000000E+00
         766          776  -0.76686679E-04
         766          777  -0.15033608E-03
         766          778   0.00000000E+00
         766          779   0.00000000E+00
         766          780   0.00000000E+00
         767          767   0.23592129E+04
         767          761   0.56331452E+02
         767          762  -0.21147957E+02
         767          763   0.00000000E+00
         767          764  -0.65247126E+02
         767          765  -0.63501226E+02
         767          766   0.16096015E+04
         767          768  -0.37181886E-04
         767          769  -0.89070654E-01
         767          770   0.36641398E-01
         767          751  -0.67475571E-07
         767          752   0.00000000E+00
         767          753   0.00000000E+00
         767          754   0.21523944E-08
         767          755   0.60982604E-10
         767          756  -0.14724911E-03
         767          757  -0.29322945E-03
         767          758   0.58165056E-14
         767          759   0.10670267E-09
         767          760  -0.43868077E-10
         767          771  -0.15867054E-06
         767          772   0.00000000E+00
         767          773   0.00000000E+00
         767          774   0.50614110E-08
         767          775   0.14340217E-09
         767          776  -0.15032871E-03
         767          777  -0.29765429E-03
         767          778   0.13677663E-13
         767          779   0.25091409E-09
         767          780  -0.10315691E-09
         768          768   0.63777001E-04
         768          761   0.00000000E+00
         768          762   0.00000000E+00
         768          763   0.00000000E+00
         768          764   0.00000000E+00
         768          765   0.00000000E+00
         768          766   0.00000000E+00
         768          767  -0.37191168E-04
         768          769  -0.15263481E-04
         768          770  -0.35825776E-04
         768          751   0.00000000E+00
         768          752   0.00000000E+00
         768          753   0.00000000E+00
         768          754   0.00000000E+00
         768          755   0.00000000E+00
         768          756   0.00000000E+00
         768          757   0.58169751E-14
         768          758  -0.86321259E-14
         768          759  -0.10818409E-14
         768          760   0.41814649E-14
         768          771   0.00000000E+00
         768          772   0.00000000E+00
         768          773   0.00000000E+00
         768          774   0.00000000E+00
         768          775   0.00000000E+00
         768          776   0.00000000E+00
         768          777   0.13678767E-13
         768          778  -0.20298667E-13
         768          779  -0.25439768E-14
         768          780   0.98328225E-14
         769          769   0.73529206E+02
         769          761   0.00000000E+00
         769          762   0.00000000E+00
         769          763   0.00000000E+00
         769          764   0.00000000E+00
         769          765   0.00000000E+00
         769          766   0.43198833E-04
         769          767  -0.89061747E-01
         769          768  -0.15259878E-04
         769          770   0.24819052E+02
         769          751   0.00000000E+00
         769          752   0.00000000E+00
         769          753   0.00000000E+00
         769          754   0.00000000E+00
         769          755   0.00000000E+00
         769          756   0.00000000E+00
         769          757   0.10669200E-09
         769          758  -0.10818004E-14
         769          759  -0.88075519E-07
         769          760  -0.29729024E-07
         769          771   0.00000000E+00
         769          772   0.00000000E+00
         769          773   0.00000000E+00
         769          774   0.00000000E+00
         769          775   0.00000000E+00
         769          776   0.00000000E+00
         769          777   0.25088900E-09
         769          778  -0.25438814E-14
         769          779  -0.20711185E-06
         769          780  -0.69908567E-07
         770          770   0.99796087E+04
         770          761   0.26869319E+04
         770          762   0.18378624E+03
         770          763   0.00000000E+00
         770          764   0.00000000E+00
         770          765   0.16129778E-05
         770          766   0.00000000E+00
         770          767   0.36641398E-01
         770          768  -0.35816362E-04
         770          769   0.24819052E+02
         770          751  -0.32184903E-05
         770          752  -0.22014489E-06
         770          753   0.00000000E+00
         770          754   0.00000000E+00
         770          755  -0.19320751E-14
         770          756   0.00000000E+00
         770          757  -0.43868077E-10
         770          758   0.41808377E-14
         770          759  -0.29729024E-07
         770          760  -0.11953886E-04
         770          771  -0.75683629E-05
         770          772  -0.51767639E-06
         770          773   0.00000000E+00
         770          774   0.00000000E+00
         770          775  -0.45433243E-14
         770          776   0.00000000E+00
         770          777  -0.10315691E-09
         770          778   0.98313477E-14
         770          779  -0.69908567E-07
         770          780  -0.28109871E-04
         771          771   0.72450455E+04
         771          772   0.00000000E+00
         771          773   0.00000000E+00
         771          774   0.00000000E+00
         771          775   0.00000000E+00
         771          776   0.59090712E+02
         771          777   0.56304627E+02
         771          778   0.00000000E+00
         771          779   0.00000000E+00
         771          780   0.26856524E+04
         771          761  -0.86672685E-05
         771          762   0.00000000E+00
         771          763   0.00000000E+00
         771          764   0.00000000E+00
         771          765   0.00000000E+00
         771          766  -0.70690134E-07
         771          767  -0.67357391E-07
         771          768   0.00000000E+00
         771          769   0.00000000E+00
         771          770  -0.32128533E-05
         771          781  -0.20404807E-04
         771          782   0.00000000E+00
         771          783   0.00000000E+00
         771          784   0.00000000E+00
         771          785   0.00000000E+00
         771          786  -0.16642135E-06
         771          787  -0.15857529E-06
         771          788   0.00000000E+00
         771          789   0.00000000E+00
         771          790  -0.75638193E-05
         772          772   0.45619329E+04
         772          771   0.00000000E+00
         772          773   0.00000000E+00
         772          774   0.63450217E+01
         772          775   0.63450217E+01
         772          776   0.00000000E+00
         772          777  -0.21136331E+02
         772          778   0.00000000E+00
         772          779   0.00000000E+00
         772          780   0.18369872E+03
         772          761   0.00000000E+00
         772          762  -0.54549239E-05
         772          763   0.00000000E+00
         772          764   0.00000000E+00
         772          765   0.00000000E+00
         772          766   0.00000000E+00
         772          767   0.00000000E+00
         772          768   0.00000000E+00
         772          769   0.00000000E+00
         772          770  -0.21975932E-06
         772          781   0.00000000E+00
         772          782  -0.12842185E-04
         772          783   0.00000000E+00
         772          784   0.00000000E+00
         772          785   0.00000000E+00
         772          786   0.00000000E+00
         772          787   0.00000000E+00
         772          788   0.00000000E+00
         772          789   0.00000000E+00
         772          790  -0.51736561E-06
         773          773   0.57757696E+03
         773          771   0.00000000E+00
         773          772   0.00000000E+00
         773          774   0.00000000E+00
         773          775   0.00000000E+00
         773          776   0.00000000E+00
         773          777   0.00000000E+00
         773          778   0.00000000E+00
         773          779   0.00000000E+00
         773          780   0.00000000E+00
         773          761   0.00000000E+00
         773          762   0.00000000E+00
         773          763  -0.69095702E-06
         773          764   0.00000000E+00
         773          765   0.00000000E+00
         773          766   0.00000000E+00
         773          767   0.00000000E+00
         773          768   0.00000000E+00
         773          769   0.00000000E+00
         773          770   0.00000000E+00
         773          781   0.00000000E+00
         773          782   0.00000000E+00
         773          783  -0.16266768E-05
         773          784   0.00000000E+00
         773          785   0.00000000E+00
         773          786   0.00000000E+00
         773          787   0.00000000E+00
         773          788   0.00000000E+00
         773          789   0.00000000E+00
         773          790   0.00000000E+00
         774          774   0.99686277E+03
         774          771   0.00000000E+00
         774          772   0.63443872E+01
         774          773   0.00000000E+00
         774          775   0.19035065E+02
         774          776   0.00000000E+00
         774          777  -0.65204866E+02
         774          778   0.00000000E+00
         774          779   0.00000000E+00
         774          780   0.00000000E+00
         774          761   0.00000000E+00
         774          762   0.00000000E+00
         774          763   0.00000000E+00
         774          764  -0.11697781E-05
         774          765   0.00000000E+00
         774          766   0.00000000E+00
         774          767   0.21484098E-08
         774          768   0.00000000E+00
         774          769   0.00000000E+00
         774          770   0.00000000E+00
         774          781   0.00000000E+00
         774          782   0.00000000E+00
         774          783   0.00000000E+00
         774          784  -0.27539353E-05
         774          785   0.00000000E+00
         774          786   0.00000000E+00
         774          787   0.50578666E-08
         774          788   0.00000000E+00
         774          789   0.00000000E+00
         774          790   0.00000000E+00
         775          775   0.19048220E+02
         775          771   0.00000000E+00
         775          772   0.63443872E+01
         775          773   0.00000000E+00
         775          774   0.19035065E+02
         775          776   0.00000000E+00
         775          777  -0.63459964E+02
         775          778   0.00000000E+00
         775          779   0.00000000E+00
         775          780   0.16122321E-05
         775          761   0.00000000E+00
         775          762   0.00000000E+00
         775          763   0.00000000E+00
         775          764   0.00000000E+00
         775          765  -0.15698059E-10
         775          766   0.00000000E+00
         775          767   0.60860806E-10
         775          768   0.00000000E+00
         775          769   0.00000000E+00
         775          770  -0.19287180E-14
         775          781   0.00000000E+00
         775          782   0.00000000E+00
         775          783   0.00000000E+00
         775          784   0.00000000E+00
         775          785  -0.36956958E-10
         775          786   0.00000000E+00
         775          787   0.14328078E-09
         775          788   0.00000000E+00
         775          789   0.00000000E+00
         775          790  -0.45406599E-14
         776          776   0.13447671E+04
         776          771   0.59090712E+02
         776          772   0.00000000E+00
         776          773   0.00000000E+00
         776          774   0.00000000E+00
         776          775   0.00000000E+00
         776          777   0.16091610E+04
         776          778   0.00000000E+00
         776          779   0.43198833E-04
         776          780   0.00000000E+00
         776          761  -0.70690134E-07
         776          762   0.00000000E+00
         776          763   0.00000000E+00
         776          764   0.00000000E+00
         776          765   0.00000000E+00
         776          766  -0.74638353E-04
         776          767  -0.14799156E-03
         776          768   0.00000000E+00
         776          769   0.00000000E+00
         776          770   0.00000000E+00
         776          781  -0.16642135E-06
         776          782   0.00000000E+00
         776          783   0.00000000E+00
         776          784   0.00000000E+00
         776          785   0.00000000E+00
         776          786  -0.76983320E-04
         776          787  -0.15093122E-03
         776          788   0.00000000E+00
         776          789   0.00000000E+00
         776          790   0.00000000E+00
         777          777   0.23587884E+04
         777          771   0.56304627E+02
         777          772  -0.21147957E+02
         777          773   0.00000000E+00
         777          774  -0.65246271E+02
         777          775  -0.63501201E+02
         777          776   0.16091342E+04
         777          778  -0.37179574E-04
         777          779  -0.89028235E-01
         777          780   0.36623958E-01
         777          761  -0.67357391E-07
         777          762   0.00000000E+00
         777          763   0.00000000E+00
         777          764   0.21486247E-08
         777          765   0.60875797E-10
         777          766  -0.14798422E-03
         777          767  -0.29470199E-03
         777          768   0.58063184E-14
         777          769   0.10651579E-09
         777          770  -0.43791245E-10
         777          781  -0.15857529E-06
         777          782   0.00000000E+00
         777          783   0.00000000E+00
         777          784   0.50583724E-08
         777          785   0.14331607E-09
         777          786  -0.15092382E-03
         777          787  -0.29884638E-03
         777          788   0.13669452E-13
         777          789   0.25076345E-09
         777          790  -0.10309498E-09
         778          778   0.63773570E-04
         778          771   0.00000000E+00
         778          772   0.00000000E+00
         778          773   0.00000000E+00
         778          774   0.00000000E+00
         778          775   0.00000000E+00
         778          776   0.00000000E+00
         778          777  -0.37188856E-04
         778          779  -0.15263911E-04
         778          780  -0.35824113E-04
         778          761   0.00000000E+00
         778          762   0.00000000E+00
         778          763   0.00000000E+00
         778          764   0.00000000E+00
         778          765   0.00000000E+00
         778          766   0.00000000E+00
         778          767   0.58067871E-14
         778          768  -0.86170073E-14
         778          769  -0.10799461E-14
         778          770   0.41741413E-14
         778          781   0.00000000E+00
         778          782   0.00000000E+00
         778          783   0.00000000E+00
         778          784   0.00000000E+00
         778          785   0.00000000E+00
         778          786   0.00000000E+00
         778          787   0.13670555E-13
         778          788  -0.20286480E-13
         778          789  -0.25424495E-14
         778          790   0.98269193E-14
         779          779   0.73494191E+02
         779          771   0.00000000E+00
         779          772   0.00000000E+00
         779          773   0.00000000E+00
         779          774   0.00000000E+00
         779          775   0.00000000E+00
         779          776   0.43198833E-04
         779          777  -0.89019332E-01
         779          778  -0.15260308E-04
         779          780   0.24807234E+02
         779          761   0.00000000E+00
         779          762   0.00000000E+00
         779          763   0.00000000E+00
         779          764   0.00000000E+00
         779          765   0.00000000E+00
         779          766   0.00000000E+00
         779          767   0.10650514E-09
         779          768  -0.10799057E-14
         779          769  -0.87921260E-07
         779          770  -0.29676956E-07
         779          781   0.00000000E+00
         779          782   0.00000000E+00
         779          783   0.00000000E+00
         779          784   0.00000000E+00
         779          785   0.00000000E+00
         779          786   0.00000000E+00
         779          787   0.25073838E-09
         779          788  -0.25423542E-14
         779          789  -0.20698751E-06
         779          790  -0.69866597E-07
         780          780   0.99748564E+04
         780          771   0.26856524E+04
         780          772   0.18369872E+03
         780          773   0.00000000E+00
         780          774   0.00000000E+00
         780          775   0.16122097E-05
         780          776   0.00000000E+00
         780          777   0.36623958E-01
         780          778  -0.35814700E-04
         780          779   0.24807234E+02
         780          761  -0.32128533E-05
         780          762  -0.21975932E-06
         780          763   0.00000000E+00
         780          764   0.00000000E+00
         780          765  -0.19286912E-14
         780          766   0.00000000E+00
         780          767  -0.43791245E-10
         780          768   0.41735153E-14
         780          769  -0.29676956E-07
         780          770  -0.11932950E-04
         780          781  -0.75638193E-05
         780          782  -0.51736561E-06
         780          783   0.00000000E+00
         780          784   0.00000000E+00
         780          785  -0.45405968E-14
         780          786   0.00000000E+00
         780          787  -0.10309498E-09
         780          788   0.98254455E-14
         780          789  -0.69866597E-07
         780          790  -0.28092995E-04
         781          781   0.72422605E+04
         781          782   0.00000000E+00
         781          783   0.00000000E+00
         781          784   0.00000000E+00
         781          785   0.00000000E+00
         781          786   0.59067997E+02
         781          787   0.56282984E+02
         781          788   0.00000000E+00
         781          789   0.00000000E+00
         781          790   0.26846200E+04
         781          771  -0.86550111E-05
         781          772   0.00000000E+00
         781          773   0.00000000E+00
         781          774   0.00000000E+00
         781          775   0.00000000E+00
         781          776  -0.70590163E-07
         781          777  -0.67262134E-07
         781          778   0.00000000E+00
         781          779   0.00000000E+00
         781          780  -0.32083097E-05
         781          791  -0.20394927E-04
         781          792   0.00000000E+00
         781          793   0.00000000E+00
         781          794   0.00000000E+00
         781          795   0.00000000E+00
         781          796  -0.16634077E-06
         781          797  -0.15849850E-06
         781          798   0.00000000E+00
         781          799   0.00000000E+00
         781          800  -0.75601568E-05
         782          782   0.45601801E+04
         782          781   0.00000000E+00
         782          783   0.00000000E+00
         782          784   0.63450217E+01
         782          785   0.63450217E+01
         782          786   0.00000000E+00
         782          787  -0.21136331E+02
         782          788   0.00000000E+00
         782          789   0.00000000E+00
         782          790   0.18362811E+03
         782          771   0.00000000E+00
         782          772  -0.54472094E-05
         782          773   0.00000000E+00
         782          774   0.00000000E+00
         782          775   0.00000000E+00
         782          776   0.00000000E+00
         782          777   0.00000000E+00
         782          778   0.00000000E+00
         782          779   0.00000000E+00
         782          780  -0.21944854E-06
         782          791   0.00000000E+00
         782          792  -0.12835967E-04
         782          793   0.00000000E+00
         782          794   0.00000000E+00
         782          795   0.00000000E+00
         782          796   0.00000000E+00
         782          797   0.00000000E+00
         782          798   0.00000000E+00
         782          799   0.00000000E+00
         782          800  -0.51711509E-06
         783          783   0.57735494E+03
         783          781   0.00000000E+00
         783          782   0.00000000E+00
         783          784   0.00000000E+00
         783          785   0.00000000E+00
         783          786   0.00000000E+00
         783          787   0.00000000E+00
         783          788   0.00000000E+00
         783          789   0.00000000E+00
         783          790   0.00000000E+00
         783          771   0.00000000E+00
         783          772   0.00000000E+00
         783          773  -0.68997986E-06
         783          774   0.00000000E+00
         783          775   0.00000000E+00
         783          776   0.00000000E+00
         783          777   0.00000000E+00
         783          778   0.00000000E+00
         783          779   0.00000000E+00
         783          780   0.00000000E+00
         783          791   0.00000000E+00
         783          792   0.00000000E+00
         783          793  -0.16258892E-05
         783          794   0.00000000E+00
         783          795   0.00000000E+00
         783          796   0.00000000E+00
         783          797   0.00000000E+00
         783          798   0.00000000E+00
         783          799   0.00000000E+00
         783          800   0.00000000E+00
         784          784   0.99648689E+03
         784          781   0.00000000E+00
         784          782   0.63443872E+01
         784          783   0.00000000E+00
         784          785   0.19035065E+02
         784          786   0.00000000E+00
         784          787  -0.65204176E+02
         784          788   0.00000000E+00
         784          789   0.00000000E+00
         784          790   0.00000000E+00
         784          771   0.00000000E+00
         784          772   0.00000000E+00
         784          773   0.00000000E+00
         784          774  -0.11681238E-05
         784          775   0.00000000E+00
         784          776   0.00000000E+00
         784          777   0.21453715E-08
         784          778   0.00000000E+00
         784          779   0.00000000E+00
         784          780   0.00000000E+00
         784          791   0.00000000E+00
         784          792   0.00000000E+00
         784          793   0.00000000E+00
         784          794  -0.27526018E-05
         784          795   0.00000000E+00
         784          796   0.00000000E+00
         784          797   0.50554175E-08
         784          798   0.00000000E+00
         784          799   0.00000000E+00
         784          800   0.00000000E+00
         785          785   0.19048215E+02
         785          781   0.00000000E+00
         785          782   0.63443872E+01
         785          783   0.00000000E+00
         785          784   0.19035065E+02
         785          786   0.00000000E+00
         785          787  -0.63459944E+02
         785          788   0.00000000E+00
         785          789   0.00000000E+00
         785          790   0.16116123E-05
         785          771   0.00000000E+00
         785          772   0.00000000E+00
         785          773   0.00000000E+00
         785          774   0.00000000E+00
         785          775  -0.15675859E-10
         785          776   0.00000000E+00
         785          777   0.60774736E-10
         785          778   0.00000000E+00
         785          779   0.00000000E+00
         785          780  -0.19259904E-14
         785          791   0.00000000E+00
         785          792   0.00000000E+00
         785          793   0.00000000E+00
         785          794   0.00000000E+00
         785          795  -0.36939063E-10
         785          796   0.00000000E+00
         785          797   0.14321140E-09
         785          798   0.00000000E+00
         785          799   0.00000000E+00
         785          800  -0.45384612E-14
         786          786   0.13443709E+04
         786          781   0.59067997E+02
         786          782   0.00000000E+00
         786          783   0.00000000E+00
         786          784   0.00000000E+00
         786          785   0.00000000E+00
         786          787   0.16087839E+04
         786          788   0.00000000E+00
         786          789   0.43198833E-04
         786          790   0.00000000E+00
         786          771  -0.70590163E-07
         786          772   0.00000000E+00
         786          773   0.00000000E+00
         786          774   0.00000000E+00
         786          775   0.00000000E+00
         786          776  -0.74934994E-04
         786          777  -0.14858670E-03
         786          778   0.00000000E+00
         786          779   0.00000000E+00
         786          780   0.00000000E+00
         786          791  -0.16634077E-06
         786          792   0.00000000E+00
         786          793   0.00000000E+00
         786          794   0.00000000E+00
         786          795   0.00000000E+00
         786          796  -0.77223276E-04
         786          797  -0.15141263E-03
         786          798   0.00000000E+00
         786          799   0.00000000E+00
         786          800   0.00000000E+00
         787          787   0.23584458E+04
         787          781   0.56282984E+02
         787          782  -0.21147957E+02
         787          783   0.00000000E+00
         787          784  -0.65245580E+02
         787          785  -0.63501182E+02
         787          786   0.16087571E+04
         787          788  -0.37177708E-04
         787          789  -0.88994009E-01
         787          790   0.36609887E-01
         787          771  -0.67262134E-07
         787          772   0.00000000E+00
         787          773   0.00000000E+00
         787          774   0.21455860E-08
         787          775   0.60789705E-10
         787          776  -0.14857933E-03
         787          777  -0.29589409E-03
         787          778   0.57981070E-14
         787          779   0.10636516E-09
         787          780  -0.43729314E-10
         787          791  -0.15849850E-06
         787          792   0.00000000E+00
         787          793   0.00000000E+00
         787          794   0.50559231E-08
         787          795   0.14324668E-09
         787          796  -0.15140521E-03
         787          797  -0.29981066E-03
         787          798   0.13662833E-13
         787          799   0.25064203E-09
         787          800  -0.10304506E-09
         788          788   0.63770801E-04
         788          781   0.00000000E+00
         788          782   0.00000000E+00
         788          783   0.00000000E+00
         788          784   0.00000000E+00
         788          785   0.00000000E+00
         788          786   0.00000000E+00
         788          787  -0.37186990E-04
         788          789  -0.15264258E-04
         788          790  -0.35822772E-04
         788          771   0.00000000E+00
         788          772   0.00000000E+00
         788          773   0.00000000E+00
         788          774   0.00000000E+00
         788          775   0.00000000E+00
         788          776   0.00000000E+00
         788          777   0.57985750E-14
         788          778  -0.86048210E-14
         788          779  -0.10784189E-14
         788          780   0.41682382E-14
         788          791   0.00000000E+00
         788          792   0.00000000E+00
         788          793   0.00000000E+00
         788          794   0.00000000E+00
         788          795   0.00000000E+00
         788          796   0.00000000E+00
         788          797   0.13663935E-13
         788          798  -0.20276657E-13
         788          799  -0.25412184E-14
         788          800   0.98221610E-14
         789          789   0.73465940E+02
         789          781   0.00000000E+00
         789          782   0.00000000E+00
         789          783   0.00000000E+00
         789          784   0.00000000E+00
         789          785   0.00000000E+00
         789          786   0.43198833E-04
         789          787  -0.88985109E-01
         789          788  -0.15260655E-04
         789          790   0.24797698E+02
         789          771   0.00000000E+00
         789          772   0.00000000E+00
         789          773   0.00000000E+00
         789          774   0.00000000E+00
         789          775   0.00000000E+00
         789          776   0.00000000E+00
         789          777   0.10635452E-09
         789          778  -0.10783784E-14
         789          779  -0.87796921E-07
         789          780  -0.29634986E-07
         789          791   0.00000000E+00
         789          792   0.00000000E+00
         789          793   0.00000000E+00
         789          794   0.00000000E+00
         789          795   0.00000000E+00
         789          796   0.00000000E+00
         789          797   0.25061697E-09
         789          798  -0.25411232E-14
         789          799  -0.20688729E-06
         789          800  -0.69832766E-07
         790          790   0.99710220E+04
         790          781   0.26846200E+04
         790          782   0.18362811E+03
         790          783   0.00000000E+00
         790          784   0.00000000E+00
         790          785   0.16115899E-05
         790          786   0.00000000E+00
         790          787   0.36609887E-01
         790          788  -0.35813358E-04
         790          789   0.24797698E+02
         790          771  -0.32083097E-05
         790          772  -0.21944854E-06
         790          773   0.00000000E+00
         790          774   0.00000000E+00
         790          775  -0.19259636E-14
         790          776   0.00000000E+00
         790          777  -0.43729314E-10
         790          778   0.41676130E-14
         790          779  -0.29634986E-07
         790          780  -0.11916074E-04
         790          791  -0.75601568E-05
         790          792  -0.51711509E-06
         790          793   0.00000000E+00
         790          794   0.00000000E+00
         790          795  -0.45383981E-14
         790          796   0.00000000E+00
         790          797  -0.10304506E-09
         790          798   0.98206878E-14
         790          799  -0.69832766E-07
         790          800  -0.28079392E-04
         791          791   0.72400137E+04
         791          792   0.00000000E+00
         791          793   0.00000000E+00
         791          794   0.00000000E+00
         791          795   0.00000000E+00
         791          796   0.59049673E+02
         791          797   0.56265523E+02
         791          798   0.00000000E+00
         791          799   0.00000000E+00
         791          800   0.26837871E+04
         791          781  -0.86451308E-05
         791          782   0.00000000E+00
         791          783   0.00000000E+00
         791          784   0.00000000E+00
         791          785   0.00000000E+00
         791          786  -0.70509579E-07
         791          787  -0.67185349E-07
         791          788   0.00000000E+00
         791          789   0.00000000E+00
         791          790  -0.32046471E-05
         791          801  -0.20386962E-04
         791          802   0.00000000E+00
         791          803   0.00000000E+00
         791          804   0.00000000E+00
         791          805   0.00000000E+00
         791          806  -0.16627581E-06
         791          807  -0.15843661E-06
         791          808   0.00000000E+00
         791          809   0.00000000E+00
         791          810  -0.75572044E-05
         792          792   0.45587661E+04
         792          791   0.00000000E+00
         792          793   0.00000000E+00
         792          794   0.63450217E+01
         792          795   0.63450217E+01
         792          796   0.00000000E+00
         792          797  -0.21136331E+02
         792          798   0.00000000E+00
         792          799   0.00000000E+00
         792          800   0.18357114E+03
         792          781   0.00000000E+00
         792          782  -0.54409910E-05
         792          783   0.00000000E+00
         792          784   0.00000000E+00
         792          785   0.00000000E+00
         792          786   0.00000000E+00
         792          787   0.00000000E+00
         792          788   0.00000000E+00
         792          789   0.00000000E+00
         792          790  -0.21919802E-06
         792          801   0.00000000E+00
         792          802  -0.12830954E-04
         792          803   0.00000000E+00
         792          804   0.00000000E+00
         792          805   0.00000000E+00
         792          806   0.00000000E+00
         792          807   0.00000000E+00
         792          808   0.00000000E+00
         792          809   0.00000000E+00
         792          810  -0.51691315E-06
         793          793   0.57717583E+03
         793          791   0.00000000E+00
         793          792   0.00000000E+00
         793          794   0.00000000E+00
         793          795   0.00000000E+00
         793          796   0.00000000E+00
         793          797   0.00000000E+00
         793          798   0.00000000E+00
         793          799   0.00000000E+00
         793          800   0.00000000E+00
         793          781   0.00000000E+00
         793          782   0.00000000E+00
         793          783  -0.68919220E-06
         793          784   0.00000000E+00
         793          785   0.00000000E+00
         793          786   0.00000000E+00
         793          787   0.00000000E+00
         793          788   0.00000000E+00
         793          789   0.00000000E+00
         793          790   0.00000000E+00
         793          801   0.00000000E+00
         793          802   0.00000000E+00
         793          803  -0.16252542E-05
         793          804   0.00000000E+00
         793          805   0.00000000E+00
         793          806   0.00000000E+00
         793          807   0.00000000E+00
         793          808   0.00000000E+00
         793          809   0.00000000E+00
         793          810   0.00000000E+00
         794          794   0.99618365E+03
         794          791   0.00000000E+00
         794          792   0.63443872E+01
         794          793   0.00000000E+00
         794          795   0.19035065E+02
         794          796   0.00000000E+00
         794          797  -0.65203619E+02
         794          798   0.00000000E+00
         794          799   0.00000000E+00
         794          800   0.00000000E+00
         794          781   0.00000000E+00
         794          782   0.00000000E+00
         794          783   0.00000000E+00
         794          784  -0.11667903E-05
         794          785   0.00000000E+00
         794          786   0.00000000E+00
         794          787   0.21429224E-08
         794          788   0.00000000E+00
         794          789   0.00000000E+00
         794          790   0.00000000E+00
         794          801   0.00000000E+00
         794          802   0.00000000E+00
         794          803   0.00000000E+00
         794          804  -0.27515269E-05
         794          805   0.00000000E+00
         794          806   0.00000000E+00
         794          807   0.50534433E-08
         794          808   0.00000000E+00
         794          809   0.00000000E+00
         794          810   0.00000000E+00
         795          795   0.19048211E+02
         795          791   0.00000000E+00
         795          792   0.63443872E+01
         795          793   0.00000000E+00
         795          794   0.19035065E+02
         795          796   0.00000000E+00
         795          797  -0.63459929E+02
         795          798   0.00000000E+00
         795          799   0.00000000E+00
         795          800   0.16111124E-05
         795          781   0.00000000E+00
         795          782   0.00000000E+00
         795          783   0.00000000E+00
         795          784   0.00000000E+00
         795          785  -0.15657964E-10
         795          786   0.00000000E+00
         795          787   0.60705357E-10
         795          788   0.00000000E+00
         795          789   0.00000000E+00
         795          790  -0.19237917E-14
         795          801   0.00000000E+00
         795          802   0.00000000E+00
         795          803   0.00000000E+00
         795          804   0.00000000E+00
         795          805  -0.36924637E-10
         795          806   0.00000000E+00
         795          807   0.14315548E-09
         795          808   0.00000000E+00
         795          809   0.00000000E+00
         795          810  -0.45366889E-14
         796          796   0.13440513E+04
         796          791   0.59049673E+02
         796          792   0.00000000E+00
         796          793   0.00000000E+00
         796          794   0.00000000E+00
         796          795   0.00000000E+00
         796          797   0.16084796E+04
         796          798   0.00000000E+00
         796          799   0.43198833E-04
         796          800   0.00000000E+00
         796          781  -0.70509579E-07
         796          782   0.00000000E+00
         796          783   0.00000000E+00
         796          784   0.00000000E+00
         796          785   0.00000000E+00
         796          786  -0.75174949E-04
         796          787  -0.14906810E-03
         796          788   0.00000000E+00
         796          789   0.00000000E+00
         796          790   0.00000000E+00
         796          801  -0.16627581E-06
         796          802   0.00000000E+00
         796          803   0.00000000E+00
         796          804   0.00000000E+00
         796          805   0.00000000E+00
         796          806  -0.77417251E-04
         796          807  -0.15180179E-03
         796          808   0.00000000E+00
         796          809   0.00000000E+00
         796          810   0.00000000E+00
         797          797   0.23581695E+04
         797          791   0.56265523E+02
         797          792  -0.21147957E+02
         797          793   0.00000000E+00
         797          794  -0.65245023E+02
         797          795  -0.63501166E+02
         797          796   0.16084528E+04
         797          798  -0.37176203E-04
         797          799  -0.88966397E-01
         797          800   0.36598535E-01
         797          781  -0.67185349E-07
         797          782   0.00000000E+00
         797          783   0.00000000E+00
         797          784   0.21431367E-08
         797          785   0.60720309E-10
         797          786  -0.14906071E-03
         797          787  -0.29685836E-03
         797          788   0.57914880E-14
         797          789   0.10624373E-09
         797          790  -0.43679394E-10
         797          801  -0.15843661E-06
         797          802   0.00000000E+00
         797          803   0.00000000E+00
         797          804   0.50539486E-08
         797          805   0.14319074E-09
         797          806  -0.15179435E-03
         797          807  -0.30059015E-03
         797          808   0.13657497E-13
         797          809   0.25054415E-09
         797          810  -0.10300482E-09
         798          798   0.63768567E-04
         798          791   0.00000000E+00
         798          792   0.00000000E+00
         798          793   0.00000000E+00
         798          794   0.00000000E+00
         798          795   0.00000000E+00
         798          796   0.00000000E+00
         798          797  -0.37185485E-04
         798          799  -0.15264538E-04
         798          800  -0.35821690E-04
         798          781   0.00000000E+00
         798          782   0.00000000E+00
         798          783   0.00000000E+00
         798          784   0.00000000E+00
         798          785   0.00000000E+00
         798          786   0.00000000E+00
         798          787   0.57919555E-14
         798          788  -0.85949979E-14
         798          789  -0.10771878E-14
         798          790   0.41634798E-14
         798          801   0.00000000E+00
         798          802   0.00000000E+00
         798          803   0.00000000E+00
         798          804   0.00000000E+00
         798          805   0.00000000E+00
         798          806   0.00000000E+00
         798          807   0.13658599E-13
         798          808  -0.20268739E-13
         798          809  -0.25402261E-14
         798          810   0.98183253E-14
         799          799   0.73443148E+02
         799          791   0.00000000E+00
         799          792   0.00000000E+00
         799          793   0.00000000E+00
         799          794   0.00000000E+00
         799          795   0.00000000E+00
         799          796   0.43198833E-04
         799          797  -0.88957500E-01
         799          798  -0.15260935E-04
         799          800   0.24790005E+02
         799          781   0.00000000E+00
         799          782   0.00000000E+00
         799          783   0.00000000E+00
         799          784   0.00000000E+00
         799          785   0.00000000E+00
         799          786   0.00000000E+00
         799          787   0.10623311E-09
         799          788  -0.10771474E-14
         799          789  -0.87696694E-07
         799          790  -0.29601155E-07
         799          801   0.00000000E+00
         799          802   0.00000000E+00
         799          803   0.00000000E+00
         799          804   0.00000000E+00
         799          805   0.00000000E+00
         799          806   0.00000000E+00
         799          807   0.25051910E-09
         799          808  -0.25401308E-14
         799          809  -0.20680649E-06
         799          810  -0.69805496E-07
         800          800   0.99679287E+04
         800          791   0.26837871E+04
         800          792   0.18357114E+03
         800          793   0.00000000E+00
         800          794   0.00000000E+00
         800          795   0.16110900E-05
         800          796   0.00000000E+00
         800          797   0.36598535E-01
         800          798  -0.35812277E-04
         800          799   0.24790005E+02
         800          781  -0.32046471E-05
         800          782  -0.21919802E-06
         800          783   0.00000000E+00
         800          784   0.00000000E+00
         800          785  -0.19237650E-14
         800          786   0.00000000E+00
         800          787  -0.43679394E-10
         800          788   0.41628554E-14
         800          789  -0.29601155E-07
         800          790  -0.11902471E-04
         800          801  -0.75572044E-05
         800          802  -0.51691315E-06
         800          803   0.00000000E+00
         800          804   0.00000000E+00
         800          805  -0.45366258E-14
         800          806   0.00000000E+00
         800          807  -0.10300482E-09
         800          808   0.98168527E-14
         800          809  -0.69805496E-07
         800          810  -0.28068427E-04
         801          801   0.72382014E+04
         801          802   0.00000000E+00
         801          803   0.00000000E+00
         801          804   0.00000000E+00
         801          805   0.00000000E+00
         801          806   0.59034891E+02
         801          807   0.56251438E+02
         801          808   0.00000000E+00
         801          809   0.00000000E+00
         801          810   0.26831153E+04
         801          791  -0.86371662E-05
         801          792   0.00000000E+00
         801          793   0.00000000E+00
         801          794   0.00000000E+00
         801          795   0.00000000E+00
         801          796  -0.70444620E-07
         801          797  -0.67123453E-07
         801          798   0.00000000E+00
         801          799   0.00000000E+00
         801          800  -0.32016948E-05
         801          811  -0.20380542E-04
         801          812   0.00000000E+00
         801          813   0.00000000E+00
         801          814   0.00000000E+00
         801          815   0.00000000E+00
         801          816  -0.16622345E-06
         801          817  -0.15838671E-06
         801          818   0.00000000E+00
         801          819   0.00000000E+00
         801          820  -0.75548245E-05
         802          802   0.45576254E+04
         802          801   0.00000000E+00
         802          803   0.00000000E+00
         802          804   0.63450217E+01
         802          805   0.63450217E+01
         802          806   0.00000000E+00
         802          807  -0.21136331E+02
         802          808   0.00000000E+00
         802          809   0.00000000E+00
         802          810   0.18352519E+03
         802          791   0.00000000E+00
         802          792  -0.54359784E-05
         802          793   0.00000000E+00
         802          794   0.00000000E+00
         802          795   0.00000000E+00
         802          796   0.00000000E+00
         802          797   0.00000000E+00
         802          798   0.00000000E+00
         802          799   0.00000000E+00
         802          800  -0.21899608E-06
         802          811   0.00000000E+00
         802          812  -0.12826914E-04
         802          813   0.00000000E+00
         802          814   0.00000000E+00
         802          815   0.00000000E+00
         802          816   0.00000000E+00
         802          817   0.00000000E+00
         802          818   0.00000000E+00
         802          819   0.00000000E+00
         802          820  -0.51675036E-06
         803          803   0.57703135E+03
         803          801   0.00000000E+00
         803          802   0.00000000E+00
         803          804   0.00000000E+00
         803          805   0.00000000E+00
         803          806   0.00000000E+00
         803          807   0.00000000E+00
         803          808   0.00000000E+00
         803          809   0.00000000E+00
         803          810   0.00000000E+00
         803          791   0.00000000E+00
         803          792   0.00000000E+00
         803          793  -0.68855726E-06
         803          794   0.00000000E+00
         803          795   0.00000000E+00
         803          796   0.00000000E+00
         803          797   0.00000000E+00
         803          798   0.00000000E+00
         803          799   0.00000000E+00
         803          800   0.00000000E+00
         803          811   0.00000000E+00
         803          812   0.00000000E+00
         803          813  -0.16247424E-05
         803          814   0.00000000E+00
         803          815   0.00000000E+00
         803          816   0.00000000E+00
         803          817   0.00000000E+00
         803          818   0.00000000E+00
         803          819   0.00000000E+00
         803          820   0.00000000E+00
         804          804   0.99593905E+03
         804          801   0.00000000E+00
         804          802   0.63443872E+01
         804          803   0.00000000E+00
         804          805   0.19035065E+02
         804          806   0.00000000E+00
         804          807  -0.65203170E+02
         804          808   0.00000000E+00
         804          809   0.00000000E+00
         804          810   0.00000000E+00
         804          791   0.00000000E+00
         804          792   0.00000000E+00
         804          793   0.00000000E+00
         804          794  -0.11657154E-05
         804          795   0.00000000E+00
         804          796   0.00000000E+00
         804          797   0.21409482E-08
         804          798   0.00000000E+00
         804          799   0.00000000E+00
         804          800   0.00000000E+00
         804          811   0.00000000E+00
         804          812   0.00000000E+00
         804          813   0.00000000E+00
         804          814  -0.27506604E-05
         804          815   0.00000000E+00
         804          816   0.00000000E+00
         804          817   0.50518519E-08
         804          818   0.00000000E+00
         804          819   0.00000000E+00
         804          820   0.00000000E+00
         805          805   0.19048207E+02
         805          801   0.00000000E+00
         805          802   0.63443872E+01
         805          803   0.00000000E+00
         805          804   0.19035065E+02
         805          806   0.00000000E+00
         805          807  -0.63459916E+02
         805          808   0.00000000E+00
         805          809   0.00000000E+00
         805          810   0.16107091E-05
         805          791   0.00000000E+00
         805          792   0.00000000E+00
         805          793   0.00000000E+00
         805          794   0.00000000E+00
         805          795  -0.15643539E-10
         805          796   0.00000000E+00
         805          797   0.60649431E-10
         805          798   0.00000000E+00
         805          799   0.00000000E+00
         805          800  -0.19220194E-14
         805          811   0.00000000E+00
         805          812   0.00000000E+00
         805          813   0.00000000E+00
         805          814   0.00000000E+00
         805          815  -0.36913009E-10
         805          816   0.00000000E+00
         805          817   0.14311039E-09
         805          818   0.00000000E+00
         805          819   0.00000000E+00
         805          820  -0.45352602E-14
         806          806   0.13437935E+04
         806          801   0.59034891E+02
         806          802   0.00000000E+00
         806          803   0.00000000E+00
         806          804   0.00000000E+00
         806          805   0.00000000E+00
         806          807   0.16082342E+04
         806          808   0.00000000E+00
         806          809   0.43198833E-04
         806          810   0.00000000E+00
         806          791  -0.70444620E-07
         806          792   0.00000000E+00
         806          793   0.00000000E+00
         806          794   0.00000000E+00
         806          795   0.00000000E+00
         806          796  -0.75368925E-04
         806          797  -0.14945726E-03
         806          798   0.00000000E+00
         806          799   0.00000000E+00
         806          800   0.00000000E+00
         806          811  -0.16622345E-06
         806          812   0.00000000E+00
         806          813   0.00000000E+00
         806          814   0.00000000E+00
         806          815   0.00000000E+00
         806          816  -0.77573975E-04
         806          817  -0.15211621E-03
         806          818   0.00000000E+00
         806          819   0.00000000E+00
         806          820   0.00000000E+00
         807          807   0.23579466E+04
         807          801   0.56251438E+02
         807          802  -0.21147957E+02
         807          803   0.00000000E+00
         807          804  -0.65244574E+02
         807          805  -0.63501153E+02
         807          806   0.16082074E+04
         807          808  -0.37174989E-04
         807          809  -0.88944124E-01
         807          810   0.36589378E-01
         807          791  -0.67123453E-07
         807          792   0.00000000E+00
         807          793   0.00000000E+00
         807          794   0.21411623E-08
         807          795   0.60664369E-10
         807          796  -0.14944985E-03
         807          797  -0.29763786E-03
         807          798   0.57861525E-14
         807          799   0.10614585E-09
         807          800  -0.43639154E-10
         807          811  -0.15838671E-06
         807          812   0.00000000E+00
         807          813   0.00000000E+00
         807          814   0.50523570E-08
         807          815   0.14314564E-09
         807          816  -0.15210875E-03
         807          817  -0.30121995E-03
         807          818   0.13653196E-13
         807          819   0.25046525E-09
         807          820  -0.10297238E-09
         808          808   0.63766765E-04
         808          801   0.00000000E+00
         808          802   0.00000000E+00
         808          803   0.00000000E+00
         808          804   0.00000000E+00
         808          805   0.00000000E+00
         808          806   0.00000000E+00
         808          807  -0.37184271E-04
         808          809  -0.15264764E-04
         808          810  -0.35820817E-04
         808          791   0.00000000E+00
         808          792   0.00000000E+00
         808          793   0.00000000E+00
         808          794   0.00000000E+00
         808          795   0.00000000E+00
         808          796   0.00000000E+00
         808          797   0.57866195E-14
         808          798  -0.85870796E-14
         808          799  -0.10761954E-14
         808          800   0.41596441E-14
         808          811   0.00000000E+00
         808          812   0.00000000E+00
         808          813   0.00000000E+00
         808          814   0.00000000E+00
         808          815   0.00000000E+00
         808          816   0.00000000E+00
         808          817   0.13654298E-13
         808          818  -0.20262356E-13
         808          819  -0.25394261E-14
         808          820   0.98152333E-14
         809          809   0.73424764E+02
         809          801   0.00000000E+00
         809          802   0.00000000E+00
         809          803   0.00000000E+00
         809          804   0.00000000E+00
         809          805   0.00000000E+00
         809          806   0.43198833E-04
         809          807  -0.88935229E-01
         809          808  -0.15261161E-04
         809          810   0.24783799E+02
         809          791   0.00000000E+00
         809          792   0.00000000E+00
         809          793   0.00000000E+00
         809          794   0.00000000E+00
         809          795   0.00000000E+00
         809          796   0.00000000E+00
         809          797   0.10613524E-09
         809          798  -0.10761550E-14
         809          799  -0.87615901E-07
         809          800  -0.29573885E-07
         809          811   0.00000000E+00
         809          812   0.00000000E+00
         809          813   0.00000000E+00
         809          814   0.00000000E+00
         809          815   0.00000000E+00
         809          816   0.00000000E+00
         809          817   0.25044020E-09
         809          818  -0.25393309E-14
         809          819  -0.20674137E-06
         809          820  -0.69783512E-07
         810          810   0.99654335E+04
         810          801   0.26831153E+04
         810          802   0.18352519E+03
         810          803   0.00000000E+00
         810          804   0.00000000E+00
         810          805   0.16106867E-05
         810          806   0.00000000E+00
         810          807   0.36589378E-01
         810          808  -0.35811404E-04
         810          809   0.24783799E+02
         810          791  -0.32016948E-05
         810          792  -0.21899608E-06
         810          793   0.00000000E+00
         810          794   0.00000000E+00
         810          795  -0.19219926E-14
         810          796   0.00000000E+00
         810          797  -0.43639154E-10
         810          798   0.41590203E-14
         810          799  -0.29573885E-07
         810          800  -0.11891505E-04
         810          811  -0.75548245E-05
         810          812  -0.51675036E-06
         810          813   0.00000000E+00
         810          814   0.00000000E+00
         810          815  -0.45351971E-14
         810          816   0.00000000E+00
         810          817  -0.10297238E-09
         810          818   0.98137612E-14
         810          819  -0.69783512E-07
         810          820  -0.28059588E-04
         811          811   0.72367396E+04
         811          812   0.00000000E+00
         811          813   0.00000000E+00
         811          814   0.00000000E+00
         811          815   0.00000000E+00
         811          816   0.59022969E+02
         811          817   0.56240079E+02
         811          818   0.00000000E+00
         811          819   0.00000000E+00
         811          820   0.26825735E+04
         811          801  -0.86307459E-05
         811          802   0.00000000E+00
         811          803   0.00000000E+00
         811          804   0.00000000E+00
         811          805   0.00000000E+00
         811          806  -0.70392256E-07
         811          807  -0.67073557E-07
         811          808   0.00000000E+00
         811          809   0.00000000E+00
         811          810  -0.31993148E-05
         811          821  -0.20375366E-04
         811          822   0.00000000E+00
         811          823   0.00000000E+00
         811          824   0.00000000E+00
         811          825   0.00000000E+00
         811          826  -0.16618123E-06
         811          827  -0.15834649E-06
         811          828   0.00000000E+00
         811          829   0.00000000E+00
         811          830  -0.75529059E-05
         812          812   0.45567055E+04
         812          811   0.00000000E+00
         812          813   0.00000000E+00
         812          814   0.63450217E+01
         812          815   0.63450217E+01
         812          816   0.00000000E+00
         812          817  -0.21136331E+02
         812          818   0.00000000E+00
         812          819   0.00000000E+00
         812          820   0.18348813E+03
         812          801   0.00000000E+00
         812          802  -0.54319376E-05
         812          803   0.00000000E+00
         812          804   0.00000000E+00
         812          805   0.00000000E+00
         812          806   0.00000000E+00
         812          807   0.00000000E+00
         812          808   0.00000000E+00
         812          809   0.00000000E+00
         812          810  -0.21883329E-06
         812          821   0.00000000E+00
         812          822  -0.12823656E-04
         812          823   0.00000000E+00
         812          824   0.00000000E+00
         812          825   0.00000000E+00
         812          826   0.00000000E+00
         812          827   0.00000000E+00
         812          828   0.00000000E+00
         812          829   0.00000000E+00
         812          830  -0.51661913E-06
         813          813   0.57691482E+03
         813          811   0.00000000E+00
         813          812   0.00000000E+00
         813          814   0.00000000E+00
         813          815   0.00000000E+00
         813          816   0.00000000E+00
         813          817   0.00000000E+00
         813          818   0.00000000E+00
         813          819   0.00000000E+00
         813          820   0.00000000E+00
         813          801   0.00000000E+00
         813          802   0.00000000E+00
         813          803  -0.68804543E-06
         813          804   0.00000000E+00
         813          805   0.00000000E+00
         813          806   0.00000000E+00
         813          807   0.00000000E+00
         813          808   0.00000000E+00
         813          809   0.00000000E+00
         813          810   0.00000000E+00
         813          821   0.00000000E+00
         813          822   0.00000000E+00
         813          823  -0.16243298E-05
         813          824   0.00000000E+00
         813          825   0.00000000E+00
         813          826   0.00000000E+00
         813          827   0.00000000E+00
         813          828   0.00000000E+00
         813          829   0.00000000E+00
         813          830   0.00000000E+00
         814          814   0.99574177E+03
         814          811   0.00000000E+00
         814          812   0.63443872E+01
         814          813   0.00000000E+00
         814          815   0.19035065E+02
         814          816   0.00000000E+00
         814          817  -0.65202808E+02
         814          818   0.00000000E+00
         814          819   0.00000000E+00
         814          820   0.00000000E+00
         814          801   0.00000000E+00
         814          802   0.00000000E+00
         814          803   0.00000000E+00
         814          804  -0.11648488E-05
         814          805   0.00000000E+00
         814          806   0.00000000E+00
         814          807   0.21393567E-08
         814          808   0.00000000E+00
         814          809   0.00000000E+00
         814          810   0.00000000E+00
         814          821   0.00000000E+00
         814          822   0.00000000E+00
         814          823   0.00000000E+00
         814          824  -0.27499618E-05
         814          825   0.00000000E+00
         814          826   0.00000000E+00
         814          827   0.50505689E-08
         814          828   0.00000000E+00
         814          829   0.00000000E+00
         814          830   0.00000000E+00
         815          815   0.19048205E+02
         815          811   0.00000000E+00
         815          812   0.63443872E+01
         815          813   0.00000000E+00
         815          814   0.19035065E+02
         815          816   0.00000000E+00
         815          817  -0.63459906E+02
         815          818   0.00000000E+00
         815          819   0.00000000E+00
         815          820   0.16103838E-05
         815          801   0.00000000E+00
         815          802   0.00000000E+00
         815          803   0.00000000E+00
         815          804   0.00000000E+00
         815          805  -0.15631910E-10
         815          806   0.00000000E+00
         815          807   0.60604348E-10
         815          808   0.00000000E+00
         815          809   0.00000000E+00
         815          810  -0.19205907E-14
         815          821   0.00000000E+00
         815          822   0.00000000E+00
         815          823   0.00000000E+00
         815          824   0.00000000E+00
         815          825  -0.36903635E-10
         815          826   0.00000000E+00
         815          827   0.14307405E-09
         815          828   0.00000000E+00
         815          829   0.00000000E+00
         815          830  -0.45341085E-14
         816          816   0.13435855E+04
         816          811   0.59022969E+02
         816          812   0.00000000E+00
         816          813   0.00000000E+00
         816          814   0.00000000E+00
         816          815   0.00000000E+00
         816          817   0.16080363E+04
         816          818   0.00000000E+00
         816          819   0.43198833E-04
         816          820   0.00000000E+00
         816          801  -0.70392256E-07
         816          802   0.00000000E+00
         816          803   0.00000000E+00
         816          804   0.00000000E+00
         816          805   0.00000000E+00
         816          806  -0.75525649E-04
         816          807  -0.14977168E-03
         816          808   0.00000000E+00
         816          809   0.00000000E+00
         816          810   0.00000000E+00
         816          821  -0.16618123E-06
         816          822   0.00000000E+00
         816          823   0.00000000E+00
         816          824   0.00000000E+00
         816          825   0.00000000E+00
         816          826  -0.77700548E-04
         816          827  -0.15237014E-03
         816          828   0.00000000E+00
         816          829   0.00000000E+00
         816          830   0.00000000E+00
         817          817   0.23577668E+04
         817          811   0.56240079E+02
         817          812  -0.21147957E+02
         817          813   0.00000000E+00
         817          814  -0.65244212E+02
         817          815  -0.63501143E+02
         817          816   0.16080095E+04
         817          818  -0.37174010E-04
         817          819  -0.88926161E-01
         817          820   0.36581993E-01
         817          801  -0.67073557E-07
         817          802   0.00000000E+00
         817          803   0.00000000E+00
         817          804   0.21395707E-08
         817          805   0.60619275E-10
         817          806  -0.14976426E-03
         817          807  -0.29826765E-03
         817          808   0.57818514E-14
         817          809   0.10606695E-09
         817          810  -0.43606715E-10
         817          821  -0.15834649E-06
         817          822   0.00000000E+00
         817          823   0.00000000E+00
         817          824   0.50510740E-08
         817          825   0.14310929E-09
         817          826  -0.15236267E-03
         817          827  -0.30172857E-03
         817          828   0.13649729E-13
         817          829   0.25040164E-09
         817          830  -0.10294623E-09
         818          818   0.63765312E-04
         818          811   0.00000000E+00
         818          812   0.00000000E+00
         818          813   0.00000000E+00
         818          814   0.00000000E+00
         818          815   0.00000000E+00
         818          816   0.00000000E+00
         818          817  -0.37183291E-04
         818          819  -0.15264946E-04
         818          820  -0.35820113E-04
         818          801   0.00000000E+00
         818          802   0.00000000E+00
         818          803   0.00000000E+00
         818          804   0.00000000E+00
         818          805   0.00000000E+00
         818          806   0.00000000E+00
         818          807   0.57823181E-14
         818          808  -0.85806965E-14
         818          809  -0.10753954E-14
         818          810   0.41565521E-14
         818          821   0.00000000E+00
         818          822   0.00000000E+00
         818          823   0.00000000E+00
         818          824   0.00000000E+00
         818          825   0.00000000E+00
         818          826   0.00000000E+00
         818          827   0.13650831E-13
         818          828  -0.20257210E-13
         818          829  -0.25387812E-14
         818          830   0.98127407E-14
         819          819   0.73409936E+02
         819          811   0.00000000E+00
         819          812   0.00000000E+00
         819          813   0.00000000E+00
         819          814   0.00000000E+00
         819          815   0.00000000E+00
         819          816   0.43198833E-04
         819          817  -0.88917267E-01
         819          818  -0.15261343E-04
         819          820   0.24778794E+02
         819          801   0.00000000E+00
         819          802   0.00000000E+00
         819          803   0.00000000E+00
         819          804   0.00000000E+00
         819          805   0.00000000E+00
         819          806   0.00000000E+00
         819          807   0.10605634E-09
         819          808  -0.10753551E-14
         819          809  -0.87550773E-07
         819          810  -0.29551901E-07
         819          821   0.00000000E+00
         819          822   0.00000000E+00
         819          823   0.00000000E+00
         819          824   0.00000000E+00
         819          825   0.00000000E+00
         819          826   0.00000000E+00
         819          827   0.25037660E-09
         819          828  -0.25386860E-14
         819          829  -0.20668886E-06
         819          830  -0.69765791E-07
         820          820   0.99634211E+04
         820          811   0.26825735E+04
         820          812   0.18348813E+03
         820          813   0.00000000E+00
         820          814   0.00000000E+00
         820          815   0.16103614E-05
         820          816   0.00000000E+00
         820          817   0.36581993E-01
         820          818  -0.35810700E-04
         820          819   0.24778794E+02
         820          801  -0.31993148E-05
         820          802  -0.21883329E-06
         820          803   0.00000000E+00
         820          804   0.00000000E+00
         820          805  -0.19205640E-14
         820          806   0.00000000E+00
         820          807  -0.43606715E-10
         820          808   0.41559287E-14
         820          809  -0.29551901E-07
         820          810  -0.11882666E-04
         820          821  -0.75529059E-05
         820          822  -0.51661913E-06
         820          823   0.00000000E+00
         820          824   0.00000000E+00
         820          825  -0.45340454E-14
         820          826   0.00000000E+00
         820          827  -0.10294623E-09
         820          828   0.98112690E-14
         820          829  -0.69765791E-07
         820          830  -0.28052462E-04
         821          821   0.72355608E+04
         821          822   0.00000000E+00
         821          823   0.00000000E+00
         821          824   0.00000000E+00
         821          825   0.00000000E+00
         821          826   0.59013355E+02
         821          827   0.56230917E+02
         821          828   0.00000000E+00
         821          829   0.00000000E+00
         821          830   0.26821365E+04
         821          811  -0.86255703E-05
         821          812   0.00000000E+00
         821          813   0.00000000E+00
         821          814   0.00000000E+00
         821          815   0.00000000E+00
         821          816  -0.70350044E-07
         821          817  -0.67033335E-07
         821          818   0.00000000E+00
         821          819   0.00000000E+00
         821          820  -0.31973963E-05
         821          831  -0.20371194E-04
         821          832   0.00000000E+00
         821          833   0.00000000E+00
         821          834   0.00000000E+00
         821          835   0.00000000E+00
         821          836  -0.16614720E-06
         821          837  -0.15831406E-06
         821          838   0.00000000E+00
         821          839   0.00000000E+00
         821          840  -0.75513593E-05
         822          822   0.45559635E+04
         822          821   0.00000000E+00
         822          823   0.00000000E+00
         822          824   0.63450217E+01
         822          825   0.63450217E+01
         822          826   0.00000000E+00
         822          827  -0.21136331E+02
         822          828   0.00000000E+00
         822          829   0.00000000E+00
         822          830   0.18345824E+03
         822          811   0.00000000E+00
         822          812  -0.54286802E-05
         822          813   0.00000000E+00
         822          814   0.00000000E+00
         822          815   0.00000000E+00
         822          816   0.00000000E+00
         822          817   0.00000000E+00
         822          818   0.00000000E+00
         822          819   0.00000000E+00
         822          820  -0.21870206E-06
         822          831   0.00000000E+00
         822          832  -0.12821030E-04
         822          833   0.00000000E+00
         822          834   0.00000000E+00
         822          835   0.00000000E+00
         822          836   0.00000000E+00
         822          837   0.00000000E+00
         822          838   0.00000000E+00
         822          839   0.00000000E+00
         822          840  -0.51651334E-06
         823          823   0.57682084E+03
         823          821   0.00000000E+00
         823          822   0.00000000E+00
         823          824   0.00000000E+00
         823          825   0.00000000E+00
         823          826   0.00000000E+00
         823          827   0.00000000E+00
         823          828   0.00000000E+00
         823          829   0.00000000E+00
         823          830   0.00000000E+00
         823          811   0.00000000E+00
         823          812   0.00000000E+00
         823          813  -0.68763283E-06
         823          814   0.00000000E+00
         823          815   0.00000000E+00
         823          816   0.00000000E+00
         823          817   0.00000000E+00
         823          818   0.00000000E+00
         823          819   0.00000000E+00
         823          820   0.00000000E+00
         823          831   0.00000000E+00
         823          832   0.00000000E+00
         823          833  -0.16239972E-05
         823          834   0.00000000E+00
         823          835   0.00000000E+00
         823          836   0.00000000E+00
         823          837   0.00000000E+00
         823          838   0.00000000E+00
         823          839   0.00000000E+00
         823          840   0.00000000E+00
         824          824   0.99558267E+03
         824          821   0.00000000E+00
         824          822   0.63443872E+01
         824          823   0.00000000E+00
         824          825   0.19035065E+02
         824          826   0.00000000E+00
         824          827  -0.65202515E+02
         824          828   0.00000000E+00
         824          829   0.00000000E+00
         824          830   0.00000000E+00
         824          811   0.00000000E+00
         824          812   0.00000000E+00
         824          813   0.00000000E+00
         824          814  -0.11641503E-05
         824          815   0.00000000E+00
         824          816   0.00000000E+00
         824          817   0.21380738E-08
         824          818   0.00000000E+00
         824          819   0.00000000E+00
         824          820   0.00000000E+00
         824          831   0.00000000E+00
         824          832   0.00000000E+00
         824          833   0.00000000E+00
         824          834  -0.27493987E-05
         824          835   0.00000000E+00
         824          836   0.00000000E+00
         824          837   0.50495347E-08
         824          838   0.00000000E+00
         824          839   0.00000000E+00
         824          840   0.00000000E+00
         825          825   0.19048203E+02
         825          821   0.00000000E+00
         825          822   0.63443872E+01
         825          823   0.00000000E+00
         825          824   0.19035065E+02
         825          826   0.00000000E+00
         825          827  -0.63459897E+02
         825          828   0.00000000E+00
         825          829   0.00000000E+00
         825          830   0.16101215E-05
         825          811   0.00000000E+00
         825          812   0.00000000E+00
         825          813   0.00000000E+00
         825          814   0.00000000E+00
         825          815  -0.15622536E-10
         825          816   0.00000000E+00
         825          817   0.60568005E-10
         825          818   0.00000000E+00
         825          819   0.00000000E+00
         825          820  -0.19194389E-14
         825          831   0.00000000E+00
         825          832   0.00000000E+00
         825          833   0.00000000E+00
         825          834   0.00000000E+00
         825          835  -0.36896078E-10
         825          836   0.00000000E+00
         825          837   0.14304475E-09
         825          838   0.00000000E+00
         825          839   0.00000000E+00
         825          840  -0.45331800E-14
         826          826   0.13434178E+04
         826          821   0.59013355E+02
         826          822   0.00000000E+00
         826          823   0.00000000E+00
         826          824   0.00000000E+00
         826          825   0.00000000E+00
         826          827   0.16078767E+04
         826          828   0.00000000E+00
         826          829   0.43198833E-04
         826          830   0.00000000E+00
         826          811  -0.70350044E-07
         826          812   0.00000000E+00
         826          813   0.00000000E+00
         826          814   0.00000000E+00
         826          815   0.00000000E+00
         826          816  -0.75652222E-04
         826          817  -0.15002561E-03
         826          818   0.00000000E+00
         826          819   0.00000000E+00
         826          820   0.00000000E+00
         826          831  -0.16614720E-06
         826          832   0.00000000E+00
         826          833   0.00000000E+00
         826          834   0.00000000E+00
         826          835   0.00000000E+00
         826          836  -0.77802735E-04
         826          837  -0.15257514E-03
         826          838   0.00000000E+00
         826          839   0.00000000E+00
         826          840   0.00000000E+00
         827          827   0.23576218E+04
         827          821   0.56230917E+02
         827          822  -0.21147957E+02
         827          823   0.00000000E+00
         827          824  -0.65243919E+02
         827          825  -0.63501135E+02
         827          826   0.16078499E+04
         827          828  -0.37173220E-04
         827          829  -0.88911673E-01
         827          830   0.36576037E-01
         827          811  -0.67033335E-07
         827          812   0.00000000E+00
         827          813   0.00000000E+00
         827          814   0.21382876E-08
         827          815   0.60582923E-10
         827          816  -0.15001818E-03
         827          817  -0.29877627E-03
         827          818   0.57783842E-14
         827          819   0.10600334E-09
         827          820  -0.43580565E-10
         827          831  -0.15831406E-06
         827          832   0.00000000E+00
         827          833   0.00000000E+00
         827          834   0.50500397E-08
         827          835   0.14307999E-09
         827          836  -0.15256767E-03
         827          837  -0.30213920E-03
         827          838   0.13646934E-13
         827          839   0.25035037E-09
         827          840  -0.10292515E-09
         828          828   0.63764140E-04
         828          821   0.00000000E+00
         828          822   0.00000000E+00
         828          823   0.00000000E+00
         828          824   0.00000000E+00
         828          825   0.00000000E+00
         828          826   0.00000000E+00
         828          827  -0.37182501E-04
         828          829  -0.15265093E-04
         828          830  -0.35819545E-04
         828          811   0.00000000E+00
         828          812   0.00000000E+00
         828          813   0.00000000E+00
         828          814   0.00000000E+00
         828          815   0.00000000E+00
         828          816   0.00000000E+00
         828          817   0.57788506E-14
         828          818  -0.85755509E-14
         828          819  -0.10747505E-14
         828          820   0.41540595E-14
         828          831   0.00000000E+00
         828          832   0.00000000E+00
         828          833   0.00000000E+00
         828          834   0.00000000E+00
         828          835   0.00000000E+00
         828          836   0.00000000E+00
         828          837   0.13648035E-13
         828          838  -0.20253062E-13
         828          839  -0.25382613E-14
         828          840   0.98107313E-14
         829          829   0.73397978E+02
         829          821   0.00000000E+00
         829          822   0.00000000E+00
         829          823   0.00000000E+00
         829          824   0.00000000E+00
         829          825   0.00000000E+00
         829          826   0.43198833E-04
         829          827  -0.88902781E-01
         829          828  -0.15261490E-04
         829          830   0.24774758E+02
         829          811   0.00000000E+00
         829          812   0.00000000E+00
         829          813   0.00000000E+00
         829          814   0.00000000E+00
         829          815   0.00000000E+00
         829          816   0.00000000E+00
         829          817   0.10599274E-09
         829          818  -0.10747102E-14
         829          819  -0.87498271E-07
         829          820  -0.29534180E-07
         829          831   0.00000000E+00
         829          832   0.00000000E+00
         829          833   0.00000000E+00
         829          834   0.00000000E+00
         829          835   0.00000000E+00
         829          836   0.00000000E+00
         829          837   0.25032533E-09
         829          838  -0.25381662E-14
         829          839  -0.20664654E-06
         829          840  -0.69751505E-07
         830          830   0.99617980E+04
         830          821   0.26821365E+04
         830          822   0.18345824E+03
         830          823   0.00000000E+00
         830          824   0.00000000E+00
         830          825   0.16100991E-05
         830          826   0.00000000E+00
         830          827   0.36576037E-01
         830          828  -0.35810132E-04
         830          829   0.24774758E+02
         830          811  -0.31973963E-05
         830          812  -0.21870206E-06
         830          813   0.00000000E+00
         830          814   0.00000000E+00
         830          815  -0.19194122E-14
         830          816   0.00000000E+00
         830          817  -0.43580565E-10
         830          818   0.41534365E-14
         830          819  -0.29534180E-07
         830          820  -0.11875540E-04
         830          831  -0.75513593E-05
         830          832  -0.51651334E-06
         830          833   0.00000000E+00
         830          834   0.00000000E+00
         830          835  -0.45331170E-14
         830          836   0.00000000E+00
         830          837  -0.10292515E-09
         830          838   0.98092599E-14
         830          839  -0.69751505E-07
         830          840  -0.28046717E-04
         831          831   0.72346101E+04
         831          832   0.00000000E+00
         831          833   0.00000000E+00
         831          834   0.00000000E+00
         831          835   0.00000000E+00
         831          836   0.59005601E+02
         831          837   0.56223529E+02
         831          838   0.00000000E+00
         831          839   0.00000000E+00
         831          840   0.26817841E+04
         831          821  -0.86213980E-05
         831          822   0.00000000E+00
         831          823   0.00000000E+00
         831          824   0.00000000E+00
         831          825   0.00000000E+00
         831          826  -0.70316015E-07
         831          827  -0.67000910E-07
         831          828   0.00000000E+00
         831          829   0.00000000E+00
         831          830  -0.31958497E-05
         831          841  -0.20367830E-04
         831          842   0.00000000E+00
         831          843   0.00000000E+00
         831          844   0.00000000E+00
         831          845   0.00000000E+00
         831          846  -0.16611977E-06
         831          847  -0.15828792E-06
         831          848   0.00000000E+00
         831          849   0.00000000E+00
         831          850  -0.75501125E-05
         832          832   0.45553652E+04
         832          831   0.00000000E+00
         832          833   0.00000000E+00
         832          834   0.63450217E+01
         832          835   0.63450217E+01
         832          836   0.00000000E+00
         832          837  -0.21136331E+02
         832          838   0.00000000E+00
         832          839   0.00000000E+00
         832          840   0.18343413E+03
         832          821   0.00000000E+00
         832          822  -0.54260543E-05
         832          823   0.00000000E+00
         832          824   0.00000000E+00
         832          825   0.00000000E+00
         832          826   0.00000000E+00
         832          827   0.00000000E+00
         832          828   0.00000000E+00
         832          829   0.00000000E+00
         832          830  -0.21859627E-06
         832          841   0.00000000E+00
         832          842  -0.12818913E-04
         832          843   0.00000000E+00
         832          844   0.00000000E+00
         832          845   0.00000000E+00
         832          846   0.00000000E+00
         832          847   0.00000000E+00
         832          848   0.00000000E+00
         832          849   0.00000000E+00
         832          850  -0.51642806E-06
         833          833   0.57674505E+03
         833          831   0.00000000E+00
         833          832   0.00000000E+00
         833          834   0.00000000E+00
         833          835   0.00000000E+00
         833          836   0.00000000E+00
         833          837   0.00000000E+00
         833          838   0.00000000E+00
         833          839   0.00000000E+00
         833          840   0.00000000E+00
         833          821   0.00000000E+00
         833          822   0.00000000E+00
         833          823  -0.68730021E-06
         833          824   0.00000000E+00
         833          825   0.00000000E+00
         833          826   0.00000000E+00
         833          827   0.00000000E+00
         833          828   0.00000000E+00
         833          829   0.00000000E+00
         833          830   0.00000000E+00
         833          841   0.00000000E+00
         833          842   0.00000000E+00
         833          843  -0.16237290E-05
         833          844   0.00000000E+00
         833          845   0.00000000E+00
         833          846   0.00000000E+00
         833          847   0.00000000E+00
         833          848   0.00000000E+00
         833          849   0.00000000E+00
         833          850   0.00000000E+00
         834          834   0.99545436E+03
         834          831   0.00000000E+00
         834          832   0.63443872E+01
         834          833   0.00000000E+00
         834          835   0.19035065E+02
         834          836   0.00000000E+00
         834          837  -0.65202280E+02
         834          838   0.00000000E+00
         834          839   0.00000000E+00
         834          840   0.00000000E+00
         834          821   0.00000000E+00
         834          822   0.00000000E+00
         834          823   0.00000000E+00
         834          824  -0.11635872E-05
         834          825   0.00000000E+00
         834          826   0.00000000E+00
         834          827   0.21370396E-08
         834          828   0.00000000E+00
         834          829   0.00000000E+00
         834          830   0.00000000E+00
         834          841   0.00000000E+00
         834          842   0.00000000E+00
         834          843   0.00000000E+00
         834          844  -0.27489448E-05
         834          845   0.00000000E+00
         834          846   0.00000000E+00
         834          847   0.50487010E-08
         834          848   0.00000000E+00
         834          849   0.00000000E+00
         834          850   0.00000000E+00
         835          835   0.19048201E+02
         835          831   0.00000000E+00
         835          832   0.63443872E+01
         835          833   0.00000000E+00
         835          834   0.19035065E+02
         835          836   0.00000000E+00
         835          837  -0.63459891E+02
         835          838   0.00000000E+00
         835          839   0.00000000E+00
         835          840   0.16099099E-05
         835          821   0.00000000E+00
         835          822   0.00000000E+00
         835          823   0.00000000E+00
         835          824   0.00000000E+00
         835          825  -0.15614979E-10
         835          826   0.00000000E+00
         835          827   0.60538708E-10
         835          828   0.00000000E+00
         835          829   0.00000000E+00
         835          830  -0.19185105E-14
         835          841   0.00000000E+00
         835          842   0.00000000E+00
         835          843   0.00000000E+00
         835          844   0.00000000E+00
         835          845  -0.36889986E-10
         835          846   0.00000000E+00
         835          847   0.14302114E-09
         835          848   0.00000000E+00
         835          849   0.00000000E+00
         835          850  -0.45324315E-14
         836          836   0.13432826E+04
         836          831   0.59005601E+02
         836          832   0.00000000E+00
         836          833   0.00000000E+00
         836          834   0.00000000E+00
         836          835   0.00000000E+00
         836          837   0.16077480E+04
         836          838   0.00000000E+00
         836          839   0.43198833E-04
         836          840   0.00000000E+00
         836          821  -0.70316015E-07
         836          822   0.00000000E+00
         836          823   0.00000000E+00
         836          824   0.00000000E+00
         836          825   0.00000000E+00
         836          826  -0.75754409E-04
         836          827  -0.15023062E-03
         836          828   0.00000000E+00
         836          829   0.00000000E+00
         836          830   0.00000000E+00
         836          841  -0.16611977E-06
         836          842   0.00000000E+00
         836          843   0.00000000E+00
         836          844   0.00000000E+00
         836          845   0.00000000E+00
         836          846  -0.77885213E-04
         836          847  -0.15274061E-03
         836          848   0.00000000E+00
         836          849   0.00000000E+00
         836          850   0.00000000E+00
         837          837   0.23575049E+04
         837          831   0.56223529E+02
         837          832  -0.21147957E+02
         837          833   0.00000000E+00
         837          834  -0.65243684E+02
         837          835  -0.63501128E+02
         837          836   0.16077212E+04
         837          838  -0.37172583E-04
         837          839  -0.88899990E-01
         837          840   0.36571234E-01
         837          821  -0.67000910E-07
         837          822   0.00000000E+00
         837          823   0.00000000E+00
         837          824   0.21372533E-08
         837          825   0.60553619E-10
         837          826  -0.15022317E-03
         837          827  -0.29918690E-03
         837          828   0.57755891E-14
         837          829   0.10595207E-09
         837          830  -0.43559485E-10
         837          841  -0.15828792E-06
         837          842   0.00000000E+00
         837          843   0.00000000E+00
         837          844   0.50492059E-08
         837          845   0.14305636E-09
         837          846  -0.15273312E-03
         837          847  -0.30247063E-03
         837          848   0.13644680E-13
         837          849   0.25030903E-09
         837          850  -0.10290816E-09
         838          838   0.63763195E-04
         838          831   0.00000000E+00
         838          832   0.00000000E+00
         838          833   0.00000000E+00
         838          834   0.00000000E+00
         838          835   0.00000000E+00
         838          836   0.00000000E+00
         838          837  -0.37181865E-04
         838          839  -0.15265212E-04
         838          840  -0.35819088E-04
         838          821   0.00000000E+00
         838          822   0.00000000E+00
         838          823   0.00000000E+00
         838          824   0.00000000E+00
         838          825   0.00000000E+00
         838          826   0.00000000E+00
         838          827   0.57760553E-14
         838          828  -0.85714028E-14
         838          829  -0.10742307E-14
         838          830   0.41520501E-14
         838          841   0.00000000E+00
         838          842   0.00000000E+00
         838          843   0.00000000E+00
         838          844   0.00000000E+00
         838          845   0.00000000E+00
         838          846   0.00000000E+00
         838          847   0.13645782E-13
         838          848  -0.20249718E-13
         838          849  -0.25378422E-14
         838          850   0.98091114E-14
         839          839   0.73388334E+02
         839          831   0.00000000E+00
         839          832   0.00000000E+00
         839          833   0.00000000E+00
         839          834   0.00000000E+00
         839          835   0.00000000E+00
         839          836   0.43198833E-04
         839          837  -0.88891100E-01
         839          838  -0.15261609E-04
         839          840   0.24771503E+02
         839          821   0.00000000E+00
         839          822   0.00000000E+00
         839          823   0.00000000E+00
         839          824   0.00000000E+00
         839          825   0.00000000E+00
         839          826   0.00000000E+00
         839          827   0.10594147E-09
         839          828  -0.10741904E-14
         839          829  -0.87455947E-07
         839          830  -0.29519894E-07
         839          841   0.00000000E+00
         839          842   0.00000000E+00
         839          843   0.00000000E+00
         839          844   0.00000000E+00
         839          845   0.00000000E+00
         839          846   0.00000000E+00
         839          847   0.25028400E-09
         839          848  -0.25377471E-14
         839          849  -0.20661242E-06
         839          850  -0.69739988E-07
         840          840   0.99604892E+04
         840          831   0.26817841E+04
         840          832   0.18343413E+03
         840          833   0.00000000E+00
         840          834   0.00000000E+00
         840          835   0.16098875E-05
         840          836   0.00000000E+00
         840          837   0.36571234E-01
         840          838  -0.35809675E-04
         840          839   0.24771503E+02
         840          821  -0.31958497E-05
         840          822  -0.21859627E-06
         840          823   0.00000000E+00
         840          824   0.00000000E+00
         840          825  -0.19184838E-14
         840          826   0.00000000E+00
         840          827  -0.43559485E-10
         840          828   0.41514274E-14
         840          829  -0.29519894E-07
         840          830  -0.11869796E-04
         840          841  -0.75501125E-05
         840          842  -0.51642806E-06
         840          843   0.00000000E+00
         840          844   0.00000000E+00
         840          845  -0.45323685E-14
         840          846   0.00000000E+00
         840          847  -0.10290816E-09
         840          848   0.98076403E-14
         840          849  -0.69739988E-07
         840          850  -0.28042087E-04
         841          841   0.72338435E+04
         841          842   0.00000000E+00
         841          843   0.00000000E+00
         841          844   0.00000000E+00
         841          845   0.00000000E+00
         841          846   0.58999349E+02
         841          847   0.56217572E+02
         841          848   0.00000000E+00
         841          849   0.00000000E+00
         841          850   0.26814999E+04
         841          831  -0.86180344E-05
         841          832   0.00000000E+00
         841          833   0.00000000E+00
         841          834   0.00000000E+00
         841          835   0.00000000E+00
         841          836  -0.70288582E-07
         841          837  -0.66974771E-07
         841          838   0.00000000E+00
         841          839   0.00000000E+00
         841          840  -0.31946029E-05
         841          851  -0.20365119E-04
         841          852   0.00000000E+00
         841          853   0.00000000E+00
         841          854   0.00000000E+00
         841          855   0.00000000E+00
         841          856  -0.16609766E-06
         841          857  -0.15826685E-06
         841          858   0.00000000E+00
         841          859   0.00000000E+00
         841          860  -0.75491073E-05
         842          842   0.45548828E+04
         842          841   0.00000000E+00
         842          843   0.00000000E+00
         842          844   0.63450217E+01
         842          845   0.63450217E+01
         842          846   0.00000000E+00
         842          847  -0.21136331E+02
         842          848   0.00000000E+00
         842          849   0.00000000E+00
         842          850   0.18341470E+03
         842          831   0.00000000E+00
         842          832  -0.54239374E-05
         842          833   0.00000000E+00
         842          834   0.00000000E+00
         842          835   0.00000000E+00
         842          836   0.00000000E+00
         842          837   0.00000000E+00
         842          838   0.00000000E+00
         842          839   0.00000000E+00
         842          840  -0.21851099E-06
         842          851   0.00000000E+00
         842          852  -0.12817207E-04
         842          853   0.00000000E+00
         842          854   0.00000000E+00
         842          855   0.00000000E+00
         842          856   0.00000000E+00
         842          857   0.00000000E+00
         842          858   0.00000000E+00
         842          859   0.00000000E+00
         842          860  -0.51635931E-06
         843          843   0.57668394E+03
         843          841   0.00000000E+00
         843          842   0.00000000E+00
         843          844   0.00000000E+00
         843          845   0.00000000E+00
         843          846   0.00000000E+00
         843          847   0.00000000E+00
         843          848   0.00000000E+00
         843          849   0.00000000E+00
         843          850   0.00000000E+00
         843          831   0.00000000E+00
         843          832   0.00000000E+00
         843          833  -0.68703207E-06
         843          834   0.00000000E+00
         843          835   0.00000000E+00
         843          836   0.00000000E+00
         843          837   0.00000000E+00
         843          838   0.00000000E+00
         843          839   0.00000000E+00
         843          840   0.00000000E+00
         843          851   0.00000000E+00
         843          852   0.00000000E+00
         843          853  -0.16235129E-05
         843          854   0.00000000E+00
         843          855   0.00000000E+00
         843          856   0.00000000E+00
         843          857   0.00000000E+00
         843          858   0.00000000E+00
         843          859   0.00000000E+00
         843          860   0.00000000E+00
         844          844   0.99535090E+03
         844          841   0.00000000E+00
         844          842   0.63443872E+01
         844          843   0.00000000E+00
         844          845   0.19035065E+02
         844          846   0.00000000E+00
         844          847  -0.65202090E+02
         844          848   0.00000000E+00
         844          849   0.00000000E+00
         844          850   0.00000000E+00
         844          831   0.00000000E+00
         844          832   0.00000000E+00
         844          833   0.00000000E+00
         844          834  -0.11631332E-05
         844          835   0.00000000E+00
         844          836   0.00000000E+00
         844          837   0.21362059E-08
         844          838   0.00000000E+00
         844          839   0.00000000E+00
         844          840   0.00000000E+00
         844          851   0.00000000E+00
         844          852   0.00000000E+00
         844          853   0.00000000E+00
         844          854  -0.27485788E-05
         844          855   0.00000000E+00
         844          856   0.00000000E+00
         844          857   0.50480289E-08
         844          858   0.00000000E+00
         844          859   0.00000000E+00
         844          860   0.00000000E+00
         845          845   0.19048200E+02
         845          841   0.00000000E+00
         845          842   0.63443872E+01
         845          843   0.00000000E+00
         845          844   0.19035065E+02
         845          846   0.00000000E+00
         845          847  -0.63459885E+02
         845          848   0.00000000E+00
         845          849   0.00000000E+00
         845          850   0.16097393E-05
         845          831   0.00000000E+00
         845          832   0.00000000E+00
         845          833   0.00000000E+00
         845          834   0.00000000E+00
         845          835  -0.15608887E-10
         845          836   0.00000000E+00
         845          837   0.60515089E-10
         845          838   0.00000000E+00
         845          839   0.00000000E+00
         845          840  -0.19177620E-14
         845          851   0.00000000E+00
         845          852   0.00000000E+00
         845          853   0.00000000E+00
         845          854   0.00000000E+00
         845          855  -0.36885075E-10
         845          856   0.00000000E+00
         845          857   0.14300210E-09
         845          858   0.00000000E+00
         845          859   0.00000000E+00
         845          860  -0.45318281E-14
         846          846   0.13431735E+04
         846          841   0.58999349E+02
         846          842   0.00000000E+00
         846          843   0.00000000E+00
         846          844   0.00000000E+00
         846          845   0.00000000E+00
         846          847   0.16076442E+04
         846          848   0.00000000E+00
         846          849   0.43198833E-04
         846          850   0.00000000E+00
         846          831  -0.70288582E-07
         846          832   0.00000000E+00
         846          833   0.00000000E+00
         846          834   0.00000000E+00
         846          835   0.00000000E+00
         846          836  -0.75836886E-04
         846          837  -0.15039608E-03
         846          838   0.00000000E+00
         846          839   0.00000000E+00
         846          840   0.00000000E+00
         846          851  -0.16609766E-06
         846          852   0.00000000E+00
         846          853   0.00000000E+00
         846          854   0.00000000E+00
         846          855   0.00000000E+00
         846          856  -0.77951767E-04
         846          857  -0.15287413E-03
         846          858   0.00000000E+00
         846          859   0.00000000E+00
         846          860   0.00000000E+00
         847          847   0.23574106E+04
         847          841   0.56217572E+02
         847          842  -0.21147957E+02
         847          843   0.00000000E+00
         847          844  -0.65243494E+02
         847          845  -0.63501123E+02
         847          846   0.16076174E+04
         847          848  -0.37172069E-04
         847          849  -0.88890569E-01
         847          850   0.36567360E-01
         847          831  -0.66974771E-07
         847          832   0.00000000E+00
         847          833   0.00000000E+00
         847          834   0.21364195E-08
         847          835   0.60529994E-10
         847          836  -0.15038863E-03
         847          837  -0.29951833E-03
         847          838   0.57733358E-14
         847          839   0.10591073E-09
         847          840  -0.43542490E-10
         847          851  -0.15826685E-06
         847          852   0.00000000E+00
         847          853   0.00000000E+00
         847          854   0.50485337E-08
         847          855   0.14303732E-09
         847          856  -0.15286663E-03
         847          857  -0.30273807E-03
         847          858   0.13642864E-13
         847          859   0.25027571E-09
         847          860  -0.10289446E-09
         848          848   0.63762433E-04
         848          841   0.00000000E+00
         848          842   0.00000000E+00
         848          843   0.00000000E+00
         848          844   0.00000000E+00
         848          845   0.00000000E+00
         848          846   0.00000000E+00
         848          847  -0.37181351E-04
         848          849  -0.15265307E-04
         848          850  -0.35818718E-04
         848          831   0.00000000E+00
         848          832   0.00000000E+00
         848          833   0.00000000E+00
         848          834   0.00000000E+00
         848          835   0.00000000E+00
         848          836   0.00000000E+00
         848          837   0.57738019E-14
         848          838  -0.85680587E-14
         848          839  -0.10738116E-14
         848          840   0.41504303E-14
         848          851   0.00000000E+00
         848          852   0.00000000E+00
         848          853   0.00000000E+00
         848          854   0.00000000E+00
         848          855   0.00000000E+00
         848          856   0.00000000E+00
         848          857   0.13643965E-13
         848          858  -0.20247022E-13
         848          859  -0.25375044E-14
         848          860   0.98078056E-14
         849          849   0.73380558E+02
         849          841   0.00000000E+00
         849          842   0.00000000E+00
         849          843   0.00000000E+00
         849          844   0.00000000E+00
         849          845   0.00000000E+00
         849          846   0.43198833E-04
         849          847  -0.88881680E-01
         849          848  -0.15261704E-04
         849          850   0.24768878E+02
         849          831   0.00000000E+00
         849          832   0.00000000E+00
         849          833   0.00000000E+00
         849          834   0.00000000E+00
         849          835   0.00000000E+00
         849          836   0.00000000E+00
         849          837   0.10590014E-09
         849          838  -0.10737713E-14
         849          839  -0.87421827E-07
         849          840  -0.29508377E-07
         849          851   0.00000000E+00
         849          852   0.00000000E+00
         849          853   0.00000000E+00
         849          854   0.00000000E+00
         849          855   0.00000000E+00
         849          856   0.00000000E+00
         849          857   0.25025068E-09
         849          858  -0.25374092E-14
         849          859  -0.20658491E-06
         849          860  -0.69730703E-07
         850          850   0.99594338E+04
         850          841   0.26814999E+04
         850          842   0.18341470E+03
         850          843   0.00000000E+00
         850          844   0.00000000E+00
         850          845   0.16097169E-05
         850          846   0.00000000E+00
         850          847   0.36567360E-01
         850          848  -0.35809306E-04
         850          849   0.24768878E+02
         850          831  -0.31946029E-05
         850          832  -0.21851099E-06
         850          833   0.00000000E+00
         850          834   0.00000000E+00
         850          835  -0.19177353E-14
         850          836   0.00000000E+00
         850          837  -0.43542490E-10
         850          838   0.41498078E-14
         850          839  -0.29508377E-07
         850          840  -0.11865165E-04
         850          851  -0.75491073E-05
         850          852  -0.51635931E-06
         850          853   0.00000000E+00
         850          854   0.00000000E+00
         850          855  -0.45317651E-14
         850          856   0.00000000E+00
         850          857  -0.10289446E-09
         850          858   0.98063346E-14
         850          859  -0.69730703E-07
         850          860  -0.28038353E-04
         851          851   0.72332254E+04
         851          852   0.00000000E+00
         851          853   0.00000000E+00
         851          854   0.00000000E+00
         851          855   0.00000000E+00
         851          856   0.58994307E+02
         851          857   0.56212768E+02
         851          858   0.00000000E+00
         851          859   0.00000000E+00
         851          860   0.26812708E+04
         851          841  -0.86153229E-05
         851          842   0.00000000E+00
         851          843   0.00000000E+00
         851          844   0.00000000E+00
         851          845   0.00000000E+00
         851          846  -0.70266466E-07
         851          847  -0.66953698E-07
         851          848   0.00000000E+00
         851          849   0.00000000E+00
         851          850  -0.31935977E-05
         851          861  -0.20362933E-04
         851          862   0.00000000E+00
         851          863   0.00000000E+00
         851          864   0.00000000E+00
         851          865   0.00000000E+00
         851          866  -0.16607983E-06
         851          867  -0.15824986E-06
         851          868   0.00000000E+00
         851          869   0.00000000E+00
         851          870  -0.75482970E-05
         852          852   0.45544937E+04
         852          851   0.00000000E+00
         852          853   0.00000000E+00
         852          854   0.63450217E+01
         852          855   0.63450217E+01
         852          856   0.00000000E+00
         852          857  -0.21136331E+02
         852          858   0.00000000E+00
         852          859   0.00000000E+00
         852          860   0.18339902E+03
         852          841   0.00000000E+00
         852          842  -0.54222308E-05
         852          843   0.00000000E+00
         852          844   0.00000000E+00
         852          845   0.00000000E+00
         852          846   0.00000000E+00
         852          847   0.00000000E+00
         852          848   0.00000000E+00
         852          849   0.00000000E+00
         852          850  -0.21844224E-06
         852          861   0.00000000E+00
         852          862  -0.12815831E-04
         852          863   0.00000000E+00
         852          864   0.00000000E+00
         852          865   0.00000000E+00
         852          866   0.00000000E+00
         852          867   0.00000000E+00
         852          868   0.00000000E+00
         852          869   0.00000000E+00
         852          870  -0.51630388E-06
         853          853   0.57663466E+03
         853          851   0.00000000E+00
         853          852   0.00000000E+00
         853          854   0.00000000E+00
         853          855   0.00000000E+00
         853          856   0.00000000E+00
         853          857   0.00000000E+00
         853          858   0.00000000E+00
         853          859   0.00000000E+00
         853          860   0.00000000E+00
         853          841   0.00000000E+00
         853          842   0.00000000E+00
         853          843  -0.68681590E-06
         853          844   0.00000000E+00
         853          845   0.00000000E+00
         853          846   0.00000000E+00
         853          847   0.00000000E+00
         853          848   0.00000000E+00
         853          849   0.00000000E+00
         853          850   0.00000000E+00
         853          861   0.00000000E+00
         853          862   0.00000000E+00
         853          863  -0.16233386E-05
         853          864   0.00000000E+00
         853          865   0.00000000E+00
         853          866   0.00000000E+00
         853          867   0.00000000E+00
         853          868   0.00000000E+00
         853          869   0.00000000E+00
         853          870   0.00000000E+00
         854          854   0.99526747E+03
         854          851   0.00000000E+00
         854          852   0.63443872E+01
         854          853   0.00000000E+00
         854          855   0.19035065E+02
         854          856   0.00000000E+00
         854          857  -0.65201936E+02
         854          858   0.00000000E+00
         854          859   0.00000000E+00
         854          860   0.00000000E+00
         854          841   0.00000000E+00
         854          842   0.00000000E+00
         854          843   0.00000000E+00
         854          844  -0.11627673E-05
         854          845   0.00000000E+00
         854          846   0.00000000E+00
         854          847   0.21355337E-08
         854          848   0.00000000E+00
         854          849   0.00000000E+00
         854          850   0.00000000E+00
         854          861   0.00000000E+00
         854          862   0.00000000E+00
         854          863   0.00000000E+00
         854          864  -0.27482838E-05
         854          865   0.00000000E+00
         854          866   0.00000000E+00
         854          867   0.50474870E-08
         854          868   0.00000000E+00
         854          869   0.00000000E+00
         854          870   0.00000000E+00
         855          855   0.19048198E+02
         855          851   0.00000000E+00
         855          852   0.63443872E+01
         855          853   0.00000000E+00
         855          854   0.19035065E+02
         855          856   0.00000000E+00
         855          857  -0.63459881E+02
         855          858   0.00000000E+00
         855          859   0.00000000E+00
         855          860   0.16096018E-05
         855          841   0.00000000E+00
         855          842   0.00000000E+00
         855          843   0.00000000E+00
         855          844   0.00000000E+00
         855          845  -0.15603976E-10
         855          846   0.00000000E+00
         855          847   0.60496049E-10
         855          848   0.00000000E+00
         855          849   0.00000000E+00
         855          850  -0.19171586E-14
         855          861   0.00000000E+00
         855          862   0.00000000E+00
         855          863   0.00000000E+00
         855          864   0.00000000E+00
         855          865  -0.36881116E-10
         855          866   0.00000000E+00
         855          867   0.14298675E-09
         855          868   0.00000000E+00
         855          869   0.00000000E+00
         855          870  -0.45313417E-14
         856          856   0.13430856E+04
         856          851   0.58994307E+02
         856          852   0.00000000E+00
         856          853   0.00000000E+00
         856          854   0.00000000E+00
         856          855   0.00000000E+00
         856          857   0.16075605E+04
         856          858   0.00000000E+00
         856          859   0.43198833E-04
         856          860   0.00000000E+00
         856          841  -0.70266466E-07
         856          842   0.00000000E+00
         856          843   0.00000000E+00
         856          844   0.00000000E+00
         856          845   0.00000000E+00
         856          846  -0.75903440E-04
         856          847  -0.15052960E-03
         856          848   0.00000000E+00
         856          849   0.00000000E+00
         856          850   0.00000000E+00
         856          861  -0.16607983E-06
         856          862   0.00000000E+00
         856          863   0.00000000E+00
         856          864   0.00000000E+00
         856          865   0.00000000E+00
         856          866  -0.78005462E-04
         856          867  -0.15298185E-03
         856          868   0.00000000E+00
         856          869   0.00000000E+00
         856          870   0.00000000E+00
         857          857   0.23573345E+04
         857          851   0.56212768E+02
         857          852  -0.21147957E+02
         857          853   0.00000000E+00
         857          854  -0.65243340E+02
         857          855  -0.63501118E+02
         857          856   0.16075337E+04
         857          858  -0.37171655E-04
         857          859  -0.88882973E-01
         857          860   0.36564237E-01
         857          841  -0.66953698E-07
         857          842   0.00000000E+00
         857          843   0.00000000E+00
         857          844   0.21357473E-08
         857          845   0.60510949E-10
         857          846  -0.15052214E-03
         857          847  -0.29978577E-03
         857          848   0.57715193E-14
         857          849   0.10587741E-09
         857          850  -0.43528790E-10
         857          861  -0.15824986E-06
         857          862   0.00000000E+00
         857          863   0.00000000E+00
         857          864   0.50479918E-08
         857          865   0.14302196E-09
         857          866  -0.15297435E-03
         857          867  -0.30295384E-03
         857          868   0.13641399E-13
         857          869   0.25024884E-09
         857          870  -0.10288341E-09
         858          858   0.63761818E-04
         858          851   0.00000000E+00
         858          852   0.00000000E+00
         858          853   0.00000000E+00
         858          854   0.00000000E+00
         858          855   0.00000000E+00
         858          856   0.00000000E+00
         858          857  -0.37180937E-04
         858          859  -0.15265384E-04
         858          860  -0.35818421E-04
         858          841   0.00000000E+00
         858          842   0.00000000E+00
         858          843   0.00000000E+00
         858          844   0.00000000E+00
         858          845   0.00000000E+00
         858          846   0.00000000E+00
         858          847   0.57719852E-14
         858          848  -0.85653629E-14
         858          849  -0.10734737E-14
         858          850   0.41491244E-14
         858          861   0.00000000E+00
         858          862   0.00000000E+00
         858          863   0.00000000E+00
         858          864   0.00000000E+00
         858          865   0.00000000E+00
         858          866   0.00000000E+00
         858          867   0.13642501E-13
         858          868  -0.20244849E-13
         858          869  -0.25372320E-14
         858          870   0.98067528E-14
         859          859   0.73374288E+02
         859          851   0.00000000E+00
         859          852   0.00000000E+00
         859          853   0.00000000E+00
         859          854   0.00000000E+00
         859          855   0.00000000E+00
         859          856   0.43198833E-04
         859          857  -0.88874084E-01
         859          858  -0.15261781E-04
         859          860   0.24766761E+02
         859          841   0.00000000E+00
         859          842   0.00000000E+00
         859          843   0.00000000E+00
         859          844   0.00000000E+00
         859          845   0.00000000E+00
         859          846   0.00000000E+00
         859          847   0.10586682E-09
         859          848  -0.10734334E-14
         859          849  -0.87394321E-07
         859          850  -0.29499093E-07
         859          861   0.00000000E+00
         859          862   0.00000000E+00
         859          863   0.00000000E+00
         859          864   0.00000000E+00
         859          865   0.00000000E+00
         859          866   0.00000000E+00
         859          867   0.25022382E-09
         859          868  -0.25371369E-14
         859          869  -0.20656274E-06
         859          870  -0.69723219E-07
         860          860   0.99585827E+04
         860          851   0.26812708E+04
         860          852   0.18339902E+03
         860          853   0.00000000E+00
         860          854   0.00000000E+00
         860          855   0.16095794E-05
         860          856   0.00000000E+00
         860          857   0.36564237E-01
         860          858  -0.35809008E-04
         860          859   0.24766761E+02
         860          841  -0.31935977E-05
         860          842  -0.21844224E-06
         860          843   0.00000000E+00
         860          844   0.00000000E+00
         860          845  -0.19171319E-14
         860          846   0.00000000E+00
         860          847  -0.43528790E-10
         860          848   0.41485021E-14
         860          849  -0.29499093E-07
         860          850  -0.11861432E-04
         860          861  -0.75482970E-05
         860          862  -0.51630388E-06
         860          863   0.00000000E+00
         860          864   0.00000000E+00
         860          865  -0.45312787E-14
         860          866   0.00000000E+00
         860          867  -0.10288341E-09
         860          868   0.98052820E-14
         860          869  -0.69723219E-07
         860          870  -0.28035344E-04
         861          861   0.72327270E+04
         861          862   0.00000000E+00
         861          863   0.00000000E+00
         861          864   0.00000000E+00
         861          865   0.00000000E+00
         861          866   0.58990242E+02
         861          867   0.56208894E+02
         861          868   0.00000000E+00
         861          869   0.00000000E+00
         861          870   0.26810861E+04
         861          851  -0.86131369E-05
         861          852   0.00000000E+00
         861          853   0.00000000E+00
         861          854   0.00000000E+00
         861          855   0.00000000E+00
         861          856  -0.70248638E-07
         861          857  -0.66936710E-07
         861          858   0.00000000E+00
         861          859   0.00000000E+00
         861          860  -0.31927874E-05
         861          871  -0.20361171E-04
         861          872   0.00000000E+00
         861          873   0.00000000E+00
         861          874   0.00000000E+00
         861          875   0.00000000E+00
         861          876  -0.16606545E-06
         861          877  -0.15823617E-06
         861          878   0.00000000E+00
         861          879   0.00000000E+00
         861          880  -0.75476438E-05
         862          862   0.45541800E+04
         862          861   0.00000000E+00
         862          863   0.00000000E+00
         862          864   0.63450217E+01
         862          865   0.63450217E+01
         862          866   0.00000000E+00
         862          867  -0.21136331E+02
         862          868   0.00000000E+00
         862          869   0.00000000E+00
         862          870   0.18338639E+03
         862          851   0.00000000E+00
         862          852  -0.54208551E-05
         862          853   0.00000000E+00
         862          854   0.00000000E+00
         862          855   0.00000000E+00
         862          856   0.00000000E+00
         862          857   0.00000000E+00
         862          858   0.00000000E+00
         862          859   0.00000000E+00
         862          860  -0.21838681E-06
         862          871   0.00000000E+00
         862          872  -0.12814722E-04
         862          873   0.00000000E+00
         862          874   0.00000000E+00
         862          875   0.00000000E+00
         862          876   0.00000000E+00
         862          877   0.00000000E+00
         862          878   0.00000000E+00
         862          879   0.00000000E+00
         862          880  -0.51625920E-06
         863          863   0.57659493E+03
         863          861   0.00000000E+00
         863          862   0.00000000E+00
         863          864   0.00000000E+00
         863          865   0.00000000E+00
         863          866   0.00000000E+00
         863          867   0.00000000E+00
         863          868   0.00000000E+00
         863          869   0.00000000E+00
         863          870   0.00000000E+00
         863          851   0.00000000E+00
         863          852   0.00000000E+00
         863          853  -0.68664164E-06
         863          854   0.00000000E+00
         863          855   0.00000000E+00
         863          856   0.00000000E+00
         863          857   0.00000000E+00
         863          858   0.00000000E+00
         863          859   0.00000000E+00
         863          860   0.00000000E+00
         863          871   0.00000000E+00
         863          872   0.00000000E+00
         863          873  -0.16231981E-05
         863          874   0.00000000E+00
         863          875   0.00000000E+00
         863          876   0.00000000E+00
         863          877   0.00000000E+00
         863          878   0.00000000E+00
         863          879   0.00000000E+00
         863          880   0.00000000E+00
         864          864   0.99520021E+03
         864          861   0.00000000E+00
         864          862   0.63443872E+01
         864          863   0.00000000E+00
         864          865   0.19035065E+02
         864          866   0.00000000E+00
         864          867  -0.65201813E+02
         864          868   0.00000000E+00
         864          869   0.00000000E+00
         864          870   0.00000000E+00
         864          851   0.00000000E+00
         864          852   0.00000000E+00
         864          853   0.00000000E+00
         864          854  -0.11624722E-05
         864          855   0.00000000E+00
         864          856   0.00000000E+00
         864          857   0.21349919E-08
         864          858   0.00000000E+00
         864          859   0.00000000E+00
         864          860   0.00000000E+00
         864          871   0.00000000E+00
         864          872   0.00000000E+00
         864          873   0.00000000E+00
         864          874  -0.27480459E-05
         864          875   0.00000000E+00
         864          876   0.00000000E+00
         864          877   0.50470502E-08
         864          878   0.00000000E+00
         864          879   0.00000000E+00
         864          880   0.00000000E+00
         865          865   0.19048198E+02
         865          861   0.00000000E+00
         865          862   0.63443872E+01
         865          863   0.00000000E+00
         865          864   0.19035065E+02
         865          866   0.00000000E+00
         865          867  -0.63459877E+02
         865          868   0.00000000E+00
         865          869   0.00000000E+00
         865          870   0.16094909E-05
         865          851   0.00000000E+00
         865          852   0.00000000E+00
         865          853   0.00000000E+00
         865          854   0.00000000E+00
         865          855  -0.15600017E-10
         865          856   0.00000000E+00
         865          857   0.60480699E-10
         865          858   0.00000000E+00
         865          859   0.00000000E+00
         865          860  -0.19166721E-14
         865          871   0.00000000E+00
         865          872   0.00000000E+00
         865          873   0.00000000E+00
         865          874   0.00000000E+00
         865          875  -0.36877924E-10
         865          876   0.00000000E+00
         865          877   0.14297437E-09
         865          878   0.00000000E+00
         865          879   0.00000000E+00
         865          880  -0.45309495E-14
         866          866   0.13430147E+04
         866          861   0.58990242E+02
         866          862   0.00000000E+00
         866          863   0.00000000E+00
         866          864   0.00000000E+00
         866          865   0.00000000E+00
         866          867   0.16074930E+04
         866          868   0.00000000E+00
         866          869   0.43198833E-04
         866          870   0.00000000E+00
         866          851  -0.70248638E-07
         866          852   0.00000000E+00
         866          853   0.00000000E+00
         866          854   0.00000000E+00
         866          855   0.00000000E+00
         866          856  -0.75957136E-04
         866          857  -0.15063733E-03
         866          858   0.00000000E+00
         866          859   0.00000000E+00
         866          860   0.00000000E+00
         866          871  -0.16606545E-06
         866          872   0.00000000E+00
         866          873   0.00000000E+00
         866          874   0.00000000E+00
         866          875   0.00000000E+00
         866          876  -0.78048778E-04
         866          877  -0.15306875E-03
         866          878   0.00000000E+00
         866          879   0.00000000E+00
         866          880   0.00000000E+00
         867          867   0.23572732E+04
         867          861   0.56208894E+02
         867          862  -0.21147957E+02
         867          863   0.00000000E+00
         867          864  -0.65243217E+02
         867          865  -0.63501115E+02
         867          866   0.16074662E+04
         867          868  -0.37171321E-04
         867          869  -0.88876848E-01
         867          870   0.36561719E-01
         867          851  -0.66936710E-07
         867          852   0.00000000E+00
         867          853   0.00000000E+00
         867          854   0.21352054E-08
         867          855   0.60495596E-10
         867          856  -0.15062986E-03
         867          857  -0.30000154E-03
         867          858   0.57700549E-14
         867          859   0.10585055E-09
         867          860  -0.43517746E-10
         867          871  -0.15823617E-06
         867          872   0.00000000E+00
         867          873   0.00000000E+00
         867          874   0.50475549E-08
         867          875   0.14300959E-09
         867          876  -0.15306125E-03
         867          877  -0.30312789E-03
         867          878   0.13640219E-13
         867          879   0.25022719E-09
         867          880  -0.10287451E-09
         868          868   0.63761322E-04
         868          861   0.00000000E+00
         868          862   0.00000000E+00
         868          863   0.00000000E+00
         868          864   0.00000000E+00
         868          865   0.00000000E+00
         868          866   0.00000000E+00
         868          867  -0.37180603E-04
         868          869  -0.15265446E-04
         868          870  -0.35818181E-04
         868          851   0.00000000E+00
         868          852   0.00000000E+00
         868          853   0.00000000E+00
         868          854   0.00000000E+00
         868          855   0.00000000E+00
         868          856   0.00000000E+00
         868          857   0.57705207E-14
         868          858  -0.85631896E-14
         868          859  -0.10732013E-14
         868          860   0.41480716E-14
         868          871   0.00000000E+00
         868          872   0.00000000E+00
         868          873   0.00000000E+00
         868          874   0.00000000E+00
         868          875   0.00000000E+00
         868          876   0.00000000E+00
         868          877   0.13641320E-13
         868          878  -0.20243097E-13
         868          879  -0.25370124E-14
         868          880   0.98059041E-14
         869          869   0.73369232E+02
         869          861   0.00000000E+00
         869          862   0.00000000E+00
         869          863   0.00000000E+00
         869          864   0.00000000E+00
         869          865   0.00000000E+00
         869          866   0.43198833E-04
         869          867  -0.88867959E-01
         869          868  -0.15261843E-04
         869          870   0.24765055E+02
         869          851   0.00000000E+00
         869          852   0.00000000E+00
         869          853   0.00000000E+00
         869          854   0.00000000E+00
         869          855   0.00000000E+00
         869          856   0.00000000E+00
         869          857   0.10583996E-09
         869          858  -0.10731611E-14
         869          859  -0.87372147E-07
         869          860  -0.29491608E-07
         869          871   0.00000000E+00
         869          872   0.00000000E+00
         869          873   0.00000000E+00
         869          874   0.00000000E+00
         869          875   0.00000000E+00
         869          876   0.00000000E+00
         869          877   0.25020217E-09
         869          878  -0.25369173E-14
         869          879  -0.20654486E-06
         869          880  -0.69717185E-07
         870          870   0.99578965E+04
         870          861   0.26810861E+04
         870          862   0.18338639E+03
         870          863   0.00000000E+00
         870          864   0.00000000E+00
         870          865   0.16094685E-05
         870          866   0.00000000E+00
         870          867   0.36561719E-01
         870          868  -0.35808768E-04
         870          869   0.24765055E+02
         870          851  -0.31927874E-05
         870          852  -0.21838681E-06
         870          853   0.00000000E+00
         870          854   0.00000000E+00
         870          855  -0.19166455E-14
         870          856   0.00000000E+00
         870          857  -0.43517746E-10
         870          858   0.41474495E-14
         870          859  -0.29491608E-07
         870          860  -0.11858422E-04
         870          871  -0.75476438E-05
         870          872  -0.51625920E-06
         870          873   0.00000000E+00
         870          874   0.00000000E+00
         870          875  -0.45308865E-14
         870          876   0.00000000E+00
         870          877  -0.10287451E-09
         870          878   0.98044334E-14
         870          879  -0.69717185E-07
         870          880  -0.28032918E-04
         871          871   0.72323251E+04
         871          872   0.00000000E+00
         871          873   0.00000000E+00
         871          874   0.00000000E+00
         871          875   0.00000000E+00
         871          876   0.58986965E+02
         871          877   0.56205771E+02
         871          878   0.00000000E+00
         871          879   0.00000000E+00
         871          880   0.26809371E+04
         871          861  -0.86113746E-05
         871          862   0.00000000E+00
         871          863   0.00000000E+00
         871          864   0.00000000E+00
         871          865   0.00000000E+00
         871          866  -0.70234265E-07
         871          867  -0.66923014E-07
         871          868   0.00000000E+00
         871          869   0.00000000E+00
         871          870  -0.31921342E-05
         871          881  -0.20359750E-04
         871          882   0.00000000E+00
         871          883   0.00000000E+00
         871          884   0.00000000E+00
         871          885   0.00000000E+00
         871          886  -0.16605387E-06
         871          887  -0.15822513E-06
         871          888   0.00000000E+00
         871          889   0.00000000E+00
         871          890  -0.75471171E-05
         872          872   0.45539271E+04
         872          871   0.00000000E+00
         872          873   0.00000000E+00
         872          874   0.63450217E+01
         872          875   0.63450217E+01
         872          876   0.00000000E+00
         872          877  -0.21136331E+02
         872          878   0.00000000E+00
         872          879   0.00000000E+00
         872          880   0.18337620E+03
         872          861   0.00000000E+00
         872          862  -0.54197459E-05
         872          863   0.00000000E+00
         872          864   0.00000000E+00
         872          865   0.00000000E+00
         872          866   0.00000000E+00
         872          867   0.00000000E+00
         872          868   0.00000000E+00
         872          869   0.00000000E+00
         872          870  -0.21834213E-06
         872          881   0.00000000E+00
         872          882  -0.12813828E-04
         872          883   0.00000000E+00
         872          884   0.00000000E+00
         872          885   0.00000000E+00
         872          886   0.00000000E+00
         872          887   0.00000000E+00
         872          888   0.00000000E+00
         872          889   0.00000000E+00
         872          890  -0.51622318E-06
         873          873   0.57656289E+03
         873          871   0.00000000E+00
         873          872   0.00000000E+00
         873          874   0.00000000E+00
         873          875   0.00000000E+00
         873          876   0.00000000E+00
         873          877   0.00000000E+00
         873          878   0.00000000E+00
         873          879   0.00000000E+00
         873          880   0.00000000E+00
         873          861   0.00000000E+00
         873          862   0.00000000E+00
         873          863  -0.68650115E-06
         873          864   0.00000000E+00
         873          865   0.00000000E+00
         873          866   0.00000000E+00
         873          867   0.00000000E+00
         873          868   0.00000000E+00
         873          869   0.00000000E+00
         873          870   0.00000000E+00
         873          881   0.00000000E+00
         873          882   0.00000000E+00
         873          883  -0.16230849E-05
         873          884   0.00000000E+00
         873          885   0.00000000E+00
         873          886   0.00000000E+00
         873          887   0.00000000E+00
         873          888   0.00000000E+00
         873          889   0.00000000E+00
         873          890   0.00000000E+00
         874          874   0.99514597E+03
         874          871   0.00000000E+00
         874          872   0.63443872E+01
         874          873   0.00000000E+00
         874          875   0.19035065E+02
         874          876   0.00000000E+00
         874          877  -0.65201713E+02
         874          878   0.00000000E+00
         874          879   0.00000000E+00
         874          880   0.00000000E+00
         874          861   0.00000000E+00
         874          862   0.00000000E+00
         874          863   0.00000000E+00
         874          864  -0.11622344E-05
         874          865   0.00000000E+00
         874          866   0.00000000E+00
         874          867   0.21345551E-08
         874          868   0.00000000E+00
         874          869   0.00000000E+00
         874          870   0.00000000E+00
         874          881   0.00000000E+00
         874          882   0.00000000E+00
         874          883   0.00000000E+00
         874          884  -0.27478542E-05
         874          885   0.00000000E+00
         874          886   0.00000000E+00
         874          887   0.50466980E-08
         874          888   0.00000000E+00
         874          889   0.00000000E+00
         874          890   0.00000000E+00
         875          875   0.19048197E+02
         875          871   0.00000000E+00
         875          872   0.63443872E+01
         875          873   0.00000000E+00
         875          874   0.19035065E+02
         875          876   0.00000000E+00
         875          877  -0.63459875E+02
         875          878   0.00000000E+00
         875          879   0.00000000E+00
         875          880   0.16094014E-05
         875          861   0.00000000E+00
         875          862   0.00000000E+00
         875          863   0.00000000E+00
         875          864   0.00000000E+00
         875          865  -0.15596825E-10
         875          866   0.00000000E+00
         875          867   0.60468325E-10
         875          868   0.00000000E+00
         875          869   0.00000000E+00
         875          870  -0.19162800E-14
         875          881   0.00000000E+00
         875          882   0.00000000E+00
         875          883   0.00000000E+00
         875          884   0.00000000E+00
         875          885  -0.36875351E-10
         875          886   0.00000000E+00
         875          887   0.14296440E-09
         875          888   0.00000000E+00
         875          889   0.00000000E+00
         875          890  -0.45306334E-14
         876          876   0.13429575E+04
         876          871   0.58986965E+02
         876          872   0.00000000E+00
         876          873   0.00000000E+00
         876          874   0.00000000E+00
         876          875   0.00000000E+00
         876          877   0.16074386E+04
         876          878   0.00000000E+00
         876          879   0.43198833E-04
         876          880   0.00000000E+00
         876          861  -0.70234265E-07
         876          862   0.00000000E+00
         876          863   0.00000000E+00
         876          864   0.00000000E+00
         876          865   0.00000000E+00
         876          866  -0.76000451E-04
         876          867  -0.15072422E-03
         876          868   0.00000000E+00
         876          869   0.00000000E+00
         876          870   0.00000000E+00
         876          881  -0.16605387E-06
         876          882   0.00000000E+00
         876          883   0.00000000E+00
         876          884   0.00000000E+00
         876          885   0.00000000E+00
         876          886  -0.78083715E-04
         876          887  -0.15313884E-03
         876          888   0.00000000E+00
         876          889   0.00000000E+00
         876          890   0.00000000E+00
         877          877   0.23572238E+04
         877          871   0.56205771E+02
         877          872  -0.21147957E+02
         877          873   0.00000000E+00
         877          874  -0.65243117E+02
         877          875  -0.63501112E+02
         877          876   0.16074118E+04
         877          878  -0.37171052E-04
         877          879  -0.88871909E-01
         877          880   0.36559689E-01
         877          861  -0.66923014E-07
         877          862   0.00000000E+00
         877          863   0.00000000E+00
         877          864   0.21347685E-08
         877          865   0.60483218E-10
         877          866  -0.15071675E-03
         877          867  -0.30017559E-03
         877          868   0.57688744E-14
         877          869   0.10582889E-09
         877          870  -0.43508842E-10
         877          881  -0.15822513E-06
         877          882   0.00000000E+00
         877          883   0.00000000E+00
         877          884   0.50472027E-08
         877          885   0.14299961E-09
         877          886  -0.15313133E-03
         877          887  -0.30326828E-03
         877          888   0.13639267E-13
         877          889   0.25020973E-09
         877          890  -0.10286733E-09
         878          878   0.63760923E-04
         878          871   0.00000000E+00
         878          872   0.00000000E+00
         878          873   0.00000000E+00
         878          874   0.00000000E+00
         878          875   0.00000000E+00
         878          876   0.00000000E+00
         878          877  -0.37180334E-04
         878          879  -0.15265496E-04
         878          880  -0.35817987E-04
         878          861   0.00000000E+00
         878          862   0.00000000E+00
         878          863   0.00000000E+00
         878          864   0.00000000E+00
         878          865   0.00000000E+00
         878          866   0.00000000E+00
         878          867   0.57693400E-14
         878          868  -0.85614376E-14
         878          869  -0.10729817E-14
         878          870   0.41472229E-14
         878          881   0.00000000E+00
         878          882   0.00000000E+00
         878          883   0.00000000E+00
         878          884   0.00000000E+00
         878          885   0.00000000E+00
         878          886   0.00000000E+00
         878          887   0.13640368E-13
         878          888  -0.20241684E-13
         878          889  -0.25368354E-14
         878          890   0.98052199E-14
         879          879   0.73365155E+02
         879          871   0.00000000E+00
         879          872   0.00000000E+00
         879          873   0.00000000E+00
         879          874   0.00000000E+00
         879          875   0.00000000E+00
         879          876   0.43198833E-04
         879          877  -0.88863021E-01
         879          878  -0.15261893E-04
         879          880   0.24763679E+02
         879          861   0.00000000E+00
         879          862   0.00000000E+00
         879          863   0.00000000E+00
         879          864   0.00000000E+00
         879          865   0.00000000E+00
         879          866   0.00000000E+00
         879          867   0.10581831E-09
         879          868  -0.10729415E-14
         879          869  -0.87354270E-07
         879          870  -0.29485574E-07
         879          881   0.00000000E+00
         879          882   0.00000000E+00
         879          883   0.00000000E+00
         879          884   0.00000000E+00
         879          885   0.00000000E+00
         879          886   0.00000000E+00
         879          887   0.25018471E-09
         879          888  -0.25367403E-14
         879          889  -0.20653045E-06
         879          890  -0.69712320E-07
         880          880   0.99573432E+04
         880          871   0.26809371E+04
         880          872   0.18337620E+03
         880          873   0.00000000E+00
         880          874   0.00000000E+00
         880          875   0.16093791E-05
         880          876   0.00000000E+00
         880          877   0.36559689E-01
         880          878  -0.35808574E-04
         880          879   0.24763679E+02
         880          861  -0.31921342E-05
         880          862  -0.21834213E-06
         880          863   0.00000000E+00
         880          864   0.00000000E+00
         880          865  -0.19162533E-14
         880          866   0.00000000E+00
         880          867  -0.43508842E-10
         880          868   0.41466009E-14
         880          869  -0.29485574E-07
         880          870  -0.11855996E-04
         880          881  -0.75471171E-05
         880          882  -0.51622318E-06
         880          883   0.00000000E+00
         880          884   0.00000000E+00
         880          885  -0.45305704E-14
         880          886   0.00000000E+00
         880          887  -0.10286733E-09
         880          888   0.98037493E-14
         880          889  -0.69712320E-07
         880          890  -0.28030962E-04
         881          881   0.72320011E+04
         881          882   0.00000000E+00
         881          883   0.00000000E+00
         881          884   0.00000000E+00
         881          885   0.00000000E+00
         881          886   0.58984322E+02
         881          887   0.56203253E+02
         881          888   0.00000000E+00
         881          889   0.00000000E+00
         881          890   0.26808170E+04
         881          871  -0.86099539E-05
         881          872   0.00000000E+00
         881          873   0.00000000E+00
         881          874   0.00000000E+00
         881          875   0.00000000E+00
         881          876  -0.70222677E-07
         881          877  -0.66911973E-07
         881          878   0.00000000E+00
         881          879   0.00000000E+00
         881          880  -0.31916075E-05
         881          891  -0.20358605E-04
         881          892   0.00000000E+00
         881          893   0.00000000E+00
         881          894   0.00000000E+00
         881          895   0.00000000E+00
         881          896  -0.16604453E-06
         881          897  -0.15821622E-06
         881          898   0.00000000E+00
         881          899   0.00000000E+00
         881          900  -0.75466926E-05
         882          882   0.45537232E+04
         882          881   0.00000000E+00
         882          883   0.00000000E+00
         882          884   0.63450217E+01
         882          885   0.63450217E+01
         882          886   0.00000000E+00
         882          887  -0.21136331E+02
         882          888   0.00000000E+00
         882          889   0.00000000E+00
         882          890   0.18336798E+03
         882          871   0.00000000E+00
         882          872  -0.54188518E-05
         882          873   0.00000000E+00
         882          874   0.00000000E+00
         882          875   0.00000000E+00
         882          876   0.00000000E+00
         882          877   0.00000000E+00
         882          878   0.00000000E+00
         882          879   0.00000000E+00
         882          880  -0.21830611E-06
         882          891   0.00000000E+00
         882          892  -0.12813107E-04
         882          893   0.00000000E+00
         882          894   0.00000000E+00
         882          895   0.00000000E+00
         882          896   0.00000000E+00
         882          897   0.00000000E+00
         882          898   0.00000000E+00
         882          899   0.00000000E+00
         882          900  -0.51619414E-06
         883          883   0.57653706E+03
         883          881   0.00000000E+00
         883          882   0.00000000E+00
         883          884   0.00000000E+00
         883          885   0.00000000E+00
         883          886   0.00000000E+00
         883          887   0.00000000E+00
         883          888   0.00000000E+00
         883          889   0.00000000E+00
         883          890   0.00000000E+00
         883          871   0.00000000E+00
         883          872   0.00000000E+00
         883          873  -0.68638789E-06
         883          874   0.00000000E+00
         883          875   0.00000000E+00
         883          876   0.00000000E+00
         883          877   0.00000000E+00
         883          878   0.00000000E+00
         883          879   0.00000000E+00
         883          880   0.00000000E+00
         883          891   0.00000000E+00
         883          892   0.00000000E+00
         883          893  -0.16229935E-05
         883          894   0.00000000E+00
         883          895   0.00000000E+00
         883          896   0.00000000E+00
         883          897   0.00000000E+00
         883          898   0.00000000E+00
         883          899   0.00000000E+00
         883          900   0.00000000E+00
         884          884   0.99510224E+03
         884          881   0.00000000E+00
         884          882   0.63443872E+01
         884          883   0.00000000E+00
         884          885   0.19035065E+02
         884          886   0.00000000E+00
         884          887  -0.65201633E+02
         884          888   0.00000000E+00
         884          889   0.00000000E+00
         884          890   0.00000000E+00
         884          871   0.00000000E+00
         884          872   0.00000000E+00
         884          873   0.00000000E+00
         884          874  -0.11620427E-05
         884          875   0.00000000E+00
         884          876   0.00000000E+00
         884          877   0.21342029E-08
         884          878   0.00000000E+00
         884          879   0.00000000E+00
         884          880   0.00000000E+00
         884          891   0.00000000E+00
         884          892   0.00000000E+00
         884          893   0.00000000E+00
         884          894  -0.27476996E-05
         884          895   0.00000000E+00
         884          896   0.00000000E+00
         884          897   0.50464141E-08
         884          898   0.00000000E+00
         884          899   0.00000000E+00
         884          900   0.00000000E+00
         885          885   0.19048196E+02
         885          881   0.00000000E+00
         885          882   0.63443872E+01
         885          883   0.00000000E+00
         885          884   0.19035065E+02
         885          886   0.00000000E+00
         885          887  -0.63459872E+02
         885          888   0.00000000E+00
         885          889   0.00000000E+00
         885          890   0.16093293E-05
         885          871   0.00000000E+00
         885          872   0.00000000E+00
         885          873   0.00000000E+00
         885          874   0.00000000E+00
         885          875  -0.15594252E-10
         885          876   0.00000000E+00
         885          877   0.60458349E-10
         885          878   0.00000000E+00
         885          879   0.00000000E+00
         885          880  -0.19159638E-14
         885          891   0.00000000E+00
         885          892   0.00000000E+00
         885          893   0.00000000E+00
         885          894   0.00000000E+00
         885          895  -0.36873276E-10
         885          896   0.00000000E+00
         885          897   0.14295635E-09
         885          898   0.00000000E+00
         885          899   0.00000000E+00
         885          900  -0.45303785E-14
         886          886   0.13429114E+04
         886          881   0.58984322E+02
         886          882   0.00000000E+00
         886          883   0.00000000E+00
         886          884   0.00000000E+00
         886          885   0.00000000E+00
         886          887   0.16073947E+04
         886          888   0.00000000E+00
         886          889   0.43198833E-04
         886          890   0.00000000E+00
         886          871  -0.70222677E-07
         886          872   0.00000000E+00
         886          873   0.00000000E+00
         886          874   0.00000000E+00
         886          875   0.00000000E+00
         886          876  -0.76035389E-04
         886          877  -0.15079431E-03
         886          878   0.00000000E+00
         886          879   0.00000000E+00
         886          880   0.00000000E+00
         886          891  -0.16604453E-06
         886          892   0.00000000E+00
         886          893   0.00000000E+00
         886          894   0.00000000E+00
         886          895   0.00000000E+00
         886          896  -0.78111892E-04
         886          897  -0.15319537E-03
         886          898   0.00000000E+00
         886          899   0.00000000E+00
         886          900   0.00000000E+00
         887          887   0.23571839E+04
         887          881   0.56203253E+02
         887          882  -0.21147957E+02
         887          883   0.00000000E+00
         887          884  -0.65243037E+02
         887          885  -0.63501110E+02
         887          886   0.16073679E+04
         887          888  -0.37170835E-04
         887          889  -0.88867927E-01
         887          890   0.36558052E-01
         887          871  -0.66911973E-07
         887          872   0.00000000E+00
         887          873   0.00000000E+00
         887          874   0.21344163E-08
         887          875   0.60473240E-10
         887          876  -0.15078684E-03
         887          877  -0.30031598E-03
         887          878   0.57679226E-14
         887          879   0.10581143E-09
         887          880  -0.43501664E-10
         887          891  -0.15821622E-06
         887          892   0.00000000E+00
         887          893   0.00000000E+00
         887          894   0.50469188E-08
         887          895   0.14299156E-09
         887          896  -0.15318786E-03
         887          897  -0.30338151E-03
         887          898   0.13638500E-13
         887          899   0.25019565E-09
         887          900  -0.10286155E-09
         888          888   0.63760601E-04
         888          881   0.00000000E+00
         888          882   0.00000000E+00
         888          883   0.00000000E+00
         888          884   0.00000000E+00
         888          885   0.00000000E+00
         888          886   0.00000000E+00
         888          887  -0.37180117E-04
         888          889  -0.15265537E-04
         888          890  -0.35817831E-04
         888          871   0.00000000E+00
         888          872   0.00000000E+00
         888          873   0.00000000E+00
         888          874   0.00000000E+00
         888          875   0.00000000E+00
         888          876   0.00000000E+00
         888          877   0.57683882E-14
         888          878  -0.85600251E-14
         888          879  -0.10728047E-14
         888          880   0.41465387E-14
         888          891   0.00000000E+00
         888          892   0.00000000E+00
         888          893   0.00000000E+00
         888          894   0.00000000E+00
         888          895   0.00000000E+00
         888          896   0.00000000E+00
         888          897   0.13639601E-13
         888          898  -0.20240546E-13
         888          899  -0.25366927E-14
         888          900   0.98046683E-14
         889          889   0.73361868E+02
         889          881   0.00000000E+00
         889          882   0.00000000E+00
         889          883   0.00000000E+00
         889          884   0.00000000E+00
         889          885   0.00000000E+00
         889          886   0.43198833E-04
         889          887  -0.88859039E-01
         889          888  -0.15261934E-04
         889          890   0.24762569E+02
         889          871   0.00000000E+00
         889          872   0.00000000E+00
         889          873   0.00000000E+00
         889          874   0.00000000E+00
         889          875   0.00000000E+00
         889          876   0.00000000E+00
         889          877   0.10580085E-09
         889          878  -0.10727645E-14
         889          879  -0.87339858E-07
         889          880  -0.29480709E-07
         889          891   0.00000000E+00
         889          892   0.00000000E+00
         889          893   0.00000000E+00
         889          894   0.00000000E+00
         889          895   0.00000000E+00
         889          896   0.00000000E+00
         889          897   0.25017063E-09
         889          898  -0.25365976E-14
         889          899  -0.20651883E-06
         889          900  -0.69708398E-07
         890          890   0.99568971E+04
         890          881   0.26808170E+04
         890          882   0.18336798E+03
         890          883   0.00000000E+00
         890          884   0.00000000E+00
         890          885   0.16093070E-05
         890          886   0.00000000E+00
         890          887   0.36558052E-01
         890          888  -0.35808418E-04
         890          889   0.24762569E+02
         890          871  -0.31916075E-05
         890          872  -0.21830611E-06
         890          873   0.00000000E+00
         890          874   0.00000000E+00
         890          875  -0.19159372E-14
         890          876   0.00000000E+00
         890          877  -0.43501664E-10
         890          878   0.41459168E-14
         890          879  -0.29480709E-07
         890          880  -0.11854040E-04
         890          891  -0.75466926E-05
         890          892  -0.51619414E-06
         890          893   0.00000000E+00
         890          894   0.00000000E+00
         890          895  -0.45303155E-14
         890          896   0.00000000E+00
         890          897  -0.10286155E-09
         890          898   0.98031978E-14
         890          899  -0.69708398E-07
         890          900  -0.28029385E-04
         891          891   0.72317399E+04
         891          892   0.00000000E+00
         891          893   0.00000000E+00
         891          894   0.00000000E+00
         891          895   0.00000000E+00
         891          896   0.58982191E+02
         891          897   0.56201223E+02
         891          898   0.00000000E+00
         891          899   0.00000000E+00
         891          900   0.26807201E+04
         891          881  -0.86088086E-05
         891          882   0.00000000E+00
         891          883   0.00000000E+00
         891          884   0.00000000E+00
         891          885   0.00000000E+00
         891          886  -0.70213336E-07
         891          887  -0.66903072E-07
         891          888   0.00000000E+00
         891          889   0.00000000E+00
         891          890  -0.31911829E-05
         891          901  -0.20357681E-04
         891          902   0.00000000E+00
         891          903   0.00000000E+00
         891          904   0.00000000E+00
         891          905   0.00000000E+00
         891          906  -0.16603699E-06
         891          907  -0.15820905E-06
         891          908   0.00000000E+00
         891          909   0.00000000E+00
         891          910  -0.75463503E-05
         892          892   0.45535588E+04
         892          891   0.00000000E+00
         892          893   0.00000000E+00
         892          894   0.63450217E+01
         892          895   0.63450217E+01
         892          896   0.00000000E+00
         892          897  -0.21136331E+02
         892          898   0.00000000E+00
         892          899   0.00000000E+00
         892          900   0.18336136E+03
         892          881   0.00000000E+00
         892          882  -0.54181309E-05
         892          883   0.00000000E+00
         892          884   0.00000000E+00
         892          885   0.00000000E+00
         892          886   0.00000000E+00
         892          887   0.00000000E+00
         892          888   0.00000000E+00
         892          889   0.00000000E+00
         892          890  -0.21827707E-06
         892          901   0.00000000E+00
         892          902  -0.12812526E-04
         892          903   0.00000000E+00
         892          904   0.00000000E+00
         892          905   0.00000000E+00
         892          906   0.00000000E+00
         892          907   0.00000000E+00
         892          908   0.00000000E+00
         892          909   0.00000000E+00
         892          910  -0.51617072E-06
         893          893   0.57651623E+03
         893          891   0.00000000E+00
         893          892   0.00000000E+00
         893          894   0.00000000E+00
         893          895   0.00000000E+00
         893          896   0.00000000E+00
         893          897   0.00000000E+00
         893          898   0.00000000E+00
         893          899   0.00000000E+00
         893          900   0.00000000E+00
         893          881   0.00000000E+00
         893          882   0.00000000E+00
         893          883  -0.68629658E-06
         893          884   0.00000000E+00
         893          885   0.00000000E+00
         893          886   0.00000000E+00
         893          887   0.00000000E+00
         893          888   0.00000000E+00
         893          889   0.00000000E+00
         893          890   0.00000000E+00
         893          901   0.00000000E+00
         893          902   0.00000000E+00
         893          903  -0.16229199E-05
         893          904   0.00000000E+00
         893          905   0.00000000E+00
         893          906   0.00000000E+00
         893          907   0.00000000E+00
         893          908   0.00000000E+00
         893          909   0.00000000E+00
         893          910   0.00000000E+00
         894          894   0.99506698E+03
         894          891   0.00000000E+00
         894          892   0.63443872E+01
         894          893   0.00000000E+00
         894          895   0.19035065E+02
         894          896   0.00000000E+00
         894          897  -0.65201568E+02
         894          898   0.00000000E+00
         894          899   0.00000000E+00
         894          900   0.00000000E+00
         894          881   0.00000000E+00
         894          882   0.00000000E+00
         894          883   0.00000000E+00
         894          884  -0.11618881E-05
         894          885   0.00000000E+00
         894          886   0.00000000E+00
         894          887   0.21339190E-08
         894          888   0.00000000E+00
         894          889   0.00000000E+00
         894          890   0.00000000E+00
         894          901   0.00000000E+00
         894          902   0.00000000E+00
         894          903   0.00000000E+00
         894          904  -0.27475750E-05
         894          905   0.00000000E+00
         894          906   0.00000000E+00
         894          907   0.50461852E-08
         894          908   0.00000000E+00
         894          909   0.00000000E+00
         894          910   0.00000000E+00
         895          895   0.19048196E+02
         895          891   0.00000000E+00
         895          892   0.63443872E+01
         895          893   0.00000000E+00
         895          894   0.19035065E+02
         895          896   0.00000000E+00
         895          897  -0.63459871E+02
         895          898   0.00000000E+00
         895          899   0.00000000E+00
         895          900   0.16092712E-05
         895          881   0.00000000E+00
         895          882   0.00000000E+00
         895          883   0.00000000E+00
         895          884   0.00000000E+00
         895          885  -0.15592178E-10
         895          886   0.00000000E+00
         895          887   0.60450306E-10
         895          888   0.00000000E+00
         895          889   0.00000000E+00
         895          890  -0.19157090E-14
         895          901   0.00000000E+00
         895          902   0.00000000E+00
         895          903   0.00000000E+00
         895          904   0.00000000E+00
         895          905  -0.36871604E-10
         895          906   0.00000000E+00
         895          907   0.14294987E-09
         895          908   0.00000000E+00
         895          909   0.00000000E+00
         895          910  -0.45301730E-14
         896          896   0.13428742E+04
         896          891   0.58982191E+02
         896          892   0.00000000E+00
         896          893   0.00000000E+00
         896          894   0.00000000E+00
         896          895   0.00000000E+00
         896          897   0.16073593E+04
         896          898   0.00000000E+00
         896          899   0.43198833E-04
         896          900   0.00000000E+00
         896          881  -0.70213336E-07
         896          882   0.00000000E+00
         896          883   0.00000000E+00
         896          884   0.00000000E+00
         896          885   0.00000000E+00
         896          886  -0.76063566E-04
         896          887  -0.15085084E-03
         896          888   0.00000000E+00
         896          889   0.00000000E+00
         896          890   0.00000000E+00
         896          901  -0.16603699E-06
         896          902   0.00000000E+00
         896          903   0.00000000E+00
         896          904   0.00000000E+00
         896          905   0.00000000E+00
         896          906  -0.78134616E-04
         896          907  -0.15324095E-03
         896          908   0.00000000E+00
         896          909   0.00000000E+00
         896          910   0.00000000E+00
         897          897   0.23571518E+04
         897          891   0.56201223E+02
         897          892  -0.21147957E+02
         897          893   0.00000000E+00
         897          894  -0.65242972E+02
         897          895  -0.63501108E+02
         897          896   0.16073325E+04
         897          898  -0.37170660E-04
         897          899  -0.88864716E-01
         897          900   0.36556732E-01
         897          881  -0.66903072E-07
         897          882   0.00000000E+00
         897          883   0.00000000E+00
         897          884   0.21341324E-08
         897          885   0.60465195E-10
         897          886  -0.15084336E-03
         897          887  -0.30042921E-03
         897          888   0.57671553E-14
         897          889   0.10579735E-09
         897          890  -0.43495877E-10
         897          901  -0.15820905E-06
         897          902   0.00000000E+00
         897          903   0.00000000E+00
         897          904   0.50466899E-08
         897          905   0.14298508E-09
         897          906  -0.15323344E-03
         897          907  -0.30347282E-03
         897          908   0.13637881E-13
         897          909   0.25018430E-09
         897          910  -0.10285688E-09
         898          898   0.63760341E-04
         898          891   0.00000000E+00
         898          892   0.00000000E+00
         898          893   0.00000000E+00
         898          894   0.00000000E+00
         898          895   0.00000000E+00
         898          896   0.00000000E+00
         898          897  -0.37179942E-04
         898          899  -0.15265569E-04
         898          900  -0.35817705E-04
         898          881   0.00000000E+00
         898          882   0.00000000E+00
         898          883   0.00000000E+00
         898          884   0.00000000E+00
         898          885   0.00000000E+00
         898          886   0.00000000E+00
         898          887   0.57676208E-14
         898          888  -0.85588864E-14
         898          889  -0.10726620E-14
         898          890   0.41459871E-14
         898          901   0.00000000E+00
         898          902   0.00000000E+00
         898          903   0.00000000E+00
         898          904   0.00000000E+00
         898          905   0.00000000E+00
         898          906   0.00000000E+00
         898          907   0.13638982E-13
         898          908  -0.20239628E-13
         898          909  -0.25365776E-14
         898          910   0.98042236E-14
         899          899   0.73359218E+02
         899          891   0.00000000E+00
         899          892   0.00000000E+00
         899          893   0.00000000E+00
         899          894   0.00000000E+00
         899          895   0.00000000E+00
         899          896   0.43198833E-04
         899          897  -0.88855829E-01
         899          898  -0.15261966E-04
         899          900   0.24761675E+02
         899          881   0.00000000E+00
         899          882   0.00000000E+00
         899          883   0.00000000E+00
         899          884   0.00000000E+00
         899          885   0.00000000E+00
         899          886   0.00000000E+00
         899          887   0.10578677E-09
         899          888  -0.10726218E-14
         899          889  -0.87328240E-07
         899          890  -0.29476787E-07
         899          901   0.00000000E+00
         899          902   0.00000000E+00
         899          903   0.00000000E+00
         899          904   0.00000000E+00
         899          905   0.00000000E+00
         899          906   0.00000000E+00
         899          907   0.25015929E-09
         899          908  -0.25364825E-14
         899          909  -0.20650947E-06
         899          910  -0.69705237E-07
         900          900   0.99565375E+04
         900          891   0.26807201E+04
         900          892   0.18336136E+03
         900          893   0.00000000E+00
         900          894   0.00000000E+00
         900          895   0.16092488E-05
         900          896   0.00000000E+00
         900          897   0.36556732E-01
         900          898  -0.35808293E-04
         900          899   0.24761675E+02
         900          881  -0.31911829E-05
         900          882  -0.21827707E-06
         900          883   0.00000000E+00
         900          884   0.00000000E+00
         900          885  -0.19156823E-14
         900          886   0.00000000E+00
         900          887  -0.43495877E-10
         900          888   0.41453653E-14
         900          889  -0.29476787E-07
         900          890  -0.11852463E-04
         900          901  -0.75463503E-05
         900          902  -0.51617072E-06
         900          903   0.00000000E+00
         900          904   0.00000000E+00
         900          905  -0.45301100E-14
         900          906   0.00000000E+00
         900          907  -0.10285688E-09
         900          908   0.98027532E-14
         900          909  -0.69705237E-07
         900          910  -0.28028113E-04
         901          901   0.72315292E+04
         901          902   0.00000000E+00
         901          903   0.00000000E+00
         901          904   0.00000000E+00
         901          905   0.00000000E+00
         901          906   0.58980474E+02
         901          907   0.56199586E+02
         901          908   0.00000000E+00
         901          909   0.00000000E+00
         901          910   0.26806421E+04
         901          891  -0.86078852E-05
         901          892   0.00000000E+00
         901          893   0.00000000E+00
         901          894   0.00000000E+00
         901          895   0.00000000E+00
         901          896  -0.70205805E-07
         901          897  -0.66895896E-07
         901          898   0.00000000E+00
         901          899   0.00000000E+00
         901          900  -0.31908407E-05
         901          911  -0.20356937E-04
         901          912   0.00000000E+00
         901          913   0.00000000E+00
         901          914   0.00000000E+00
         901          915   0.00000000E+00
         901          916  -0.16603092E-06
         901          917  -0.15820326E-06
         901          918   0.00000000E+00
         901          919   0.00000000E+00
         901          920  -0.75460743E-05
         902          902   0.45534262E+04
         902          901   0.00000000E+00
         902          903   0.00000000E+00
         902          904   0.63450217E+01
         902          905   0.63450217E+01
         902          906   0.00000000E+00
         902          907  -0.21136331E+02
         902          908   0.00000000E+00
         902          909   0.00000000E+00
         902          910   0.18335602E+03
         902          891   0.00000000E+00
         902          892  -0.54175498E-05
         902          893   0.00000000E+00
         902          894   0.00000000E+00
         902          895   0.00000000E+00
         902          896   0.00000000E+00
         902          897   0.00000000E+00
         902          898   0.00000000E+00
         902          899   0.00000000E+00
         902          900  -0.21825366E-06
         902          911   0.00000000E+00
         902          912  -0.12812057E-04
         902          913   0.00000000E+00
         902          914   0.00000000E+00
         902          915   0.00000000E+00
         902          916   0.00000000E+00
         902          917   0.00000000E+00
         902          918   0.00000000E+00
         902          919   0.00000000E+00
         902          920  -0.51615185E-06
         903          903   0.57649944E+03
         903          901   0.00000000E+00
         903          902   0.00000000E+00
         903          904   0.00000000E+00
         903          905   0.00000000E+00
         903          906   0.00000000E+00
         903          907   0.00000000E+00
         903          908   0.00000000E+00
         903          909   0.00000000E+00
         903          910   0.00000000E+00
         903          891   0.00000000E+00
         903          892   0.00000000E+00
         903          893  -0.68622297E-06
         903          894   0.00000000E+00
         903          895   0.00000000E+00
         903          896   0.00000000E+00
         903          897   0.00000000E+00
         903          898   0.00000000E+00
         903          899   0.00000000E+00
         903          900   0.00000000E+00
         903          911   0.00000000E+00
         903          912   0.00000000E+00
         903          913  -0.16228606E-05
         903          914   0.00000000E+00
         903          915   0.00000000E+00
         903          916   0.00000000E+00
         903          917   0.00000000E+00
         903          918   0.00000000E+00
         903          919   0.00000000E+00
         903          920   0.00000000E+00
         904          904   0.99503855E+03
         904          901   0.00000000E+00
         904          902   0.63443872E+01
         904          903   0.00000000E+00
         904          905   0.19035065E+02
         904          906   0.00000000E+00
         904          907  -0.65201516E+02
         904          908   0.00000000E+00
         904          909   0.00000000E+00
         904          910   0.00000000E+00
         904          891   0.00000000E+00
         904          892   0.00000000E+00
         904          893   0.00000000E+00
         904          894  -0.11617635E-05
         904          895   0.00000000E+00
         904          896   0.00000000E+00
         904          897   0.21336901E-08
         904          898   0.00000000E+00
         904          899   0.00000000E+00
         904          900   0.00000000E+00
         904          911   0.00000000E+00
         904          912   0.00000000E+00
         904          913   0.00000000E+00
         904          914  -0.27474745E-05
         904          915   0.00000000E+00
         904          916   0.00000000E+00
         904          917   0.50460007E-08
         904          918   0.00000000E+00
         904          919   0.00000000E+00
         904          920   0.00000000E+00
         905          905   0.19048195E+02
         905          901   0.00000000E+00
         905          902   0.63443872E+01
         905          903   0.00000000E+00
         905          904   0.19035065E+02
         905          906   0.00000000E+00
         905          907  -0.63459869E+02
         905          908   0.00000000E+00
         905          909   0.00000000E+00
         905          910   0.16092243E-05
         905          891   0.00000000E+00
         905          892   0.00000000E+00
         905          893   0.00000000E+00
         905          894   0.00000000E+00
         905          895  -0.15590505E-10
         905          896   0.00000000E+00
         905          897   0.60443822E-10
         905          898   0.00000000E+00
         905          899   0.00000000E+00
         905          900  -0.19155035E-14
         905          911   0.00000000E+00
         905          912   0.00000000E+00
         905          913   0.00000000E+00
         905          914   0.00000000E+00
         905          915  -0.36870256E-10
         905          916   0.00000000E+00
         905          917   0.14294464E-09
         905          918   0.00000000E+00
         905          919   0.00000000E+00
         905          920  -0.45300074E-14
         906          906   0.13428443E+04
         906          901   0.58980474E+02
         906          902   0.00000000E+00
         906          903   0.00000000E+00
         906          904   0.00000000E+00
         906          905   0.00000000E+00
         906          907   0.16073308E+04
         906          908   0.00000000E+00
         906          909   0.43198833E-04
         906          910   0.00000000E+00
         906          891  -0.70205805E-07
         906          892   0.00000000E+00
         906          893   0.00000000E+00
         906          894   0.00000000E+00
         906          895   0.00000000E+00
         906          896  -0.76086290E-04
         906          897  -0.15089643E-03
         906          898   0.00000000E+00
         906          899   0.00000000E+00
         906          900   0.00000000E+00
         906          911  -0.16603092E-06
         906          912   0.00000000E+00
         906          913   0.00000000E+00
         906          914   0.00000000E+00
         906          915   0.00000000E+00
         906          916  -0.78152941E-04
         906          917  -0.15327772E-03
         906          918   0.00000000E+00
         906          919   0.00000000E+00
         906          920   0.00000000E+00
         907          907   0.23571259E+04
         907          901   0.56199586E+02
         907          902  -0.21147957E+02
         907          903   0.00000000E+00
         907          904  -0.65242920E+02
         907          905  -0.63501106E+02
         907          906   0.16073040E+04
         907          908  -0.37170519E-04
         907          909  -0.88862128E-01
         907          910   0.36555667E-01
         907          891  -0.66895896E-07
         907          892   0.00000000E+00
         907          893   0.00000000E+00
         907          894   0.21339035E-08
         907          895   0.60458710E-10
         907          896  -0.15088895E-03
         907          897  -0.30052052E-03
         907          898   0.57665367E-14
         907          899   0.10578600E-09
         907          900  -0.43491212E-10
         907          911  -0.15820326E-06
         907          912   0.00000000E+00
         907          913   0.00000000E+00
         907          914   0.50465053E-08
         907          915   0.14297985E-09
         907          916  -0.15327020E-03
         907          917  -0.30354645E-03
         907          918   0.13637383E-13
         907          919   0.25017515E-09
         907          920  -0.10285312E-09
         908          908   0.63760132E-04
         908          901   0.00000000E+00
         908          902   0.00000000E+00
         908          903   0.00000000E+00
         908          904   0.00000000E+00
         908          905   0.00000000E+00
         908          906   0.00000000E+00
         908          907  -0.37179800E-04
         908          909  -0.15265596E-04
         908          910  -0.35817604E-04
         908          891   0.00000000E+00
         908          892   0.00000000E+00
         908          893   0.00000000E+00
         908          894   0.00000000E+00
         908          895   0.00000000E+00
         908          896   0.00000000E+00
         908          897   0.57670022E-14
         908          898  -0.85579684E-14
         908          899  -0.10725470E-14
         908          900   0.41455424E-14
         908          911   0.00000000E+00
         908          912   0.00000000E+00
         908          913   0.00000000E+00
         908          914   0.00000000E+00
         908          915   0.00000000E+00
         908          916   0.00000000E+00
         908          917   0.13638483E-13
         908          918  -0.20238888E-13
         908          919  -0.25364849E-14
         908          920   0.98038651E-14
         909          909   0.73357082E+02
         909          901   0.00000000E+00
         909          902   0.00000000E+00
         909          903   0.00000000E+00
         909          904   0.00000000E+00
         909          905   0.00000000E+00
         909          906   0.43198833E-04
         909          907  -0.88853241E-01
         909          908  -0.15261993E-04
         909          910   0.24760954E+02
         909          891   0.00000000E+00
         909          892   0.00000000E+00
         909          893   0.00000000E+00
         909          894   0.00000000E+00
         909          895   0.00000000E+00
         909          896   0.00000000E+00
         909          897   0.10577543E-09
         909          898  -0.10725067E-14
         909          899  -0.87318873E-07
         909          900  -0.29473626E-07
         909          911   0.00000000E+00
         909          912   0.00000000E+00
         909          913   0.00000000E+00
         909          914   0.00000000E+00
         909          915   0.00000000E+00
         909          916   0.00000000E+00
         909          917   0.25015014E-09
         909          918  -0.25363898E-14
         909          919  -0.20650192E-06
         909          920  -0.69702688E-07
         910          910   0.99562475E+04
         910          901   0.26806421E+04
         910          902   0.18335602E+03
         910          903   0.00000000E+00
         910          904   0.00000000E+00
         910          905   0.16092019E-05
         910          906   0.00000000E+00
         910          907   0.36555667E-01
         910          908  -0.35808191E-04
         910          909   0.24760954E+02
         910          891  -0.31908407E-05
         910          892  -0.21825366E-06
         910          893   0.00000000E+00
         910          894   0.00000000E+00
         910          895  -0.19154769E-14
         910          896   0.00000000E+00
         910          897  -0.43491212E-10
         910          898   0.41449207E-14
         910          899  -0.29473626E-07
         910          900  -0.11851192E-04
         910          911  -0.75460743E-05
         910          912  -0.51615185E-06
         910          913   0.00000000E+00
         910          914   0.00000000E+00
         910          915  -0.45299444E-14
         910          916   0.00000000E+00
         910          917  -0.10285312E-09
         910          918   0.98023947E-14
         910          919  -0.69702688E-07
         910          920  -0.28027088E-04
         911          911   0.72313594E+04
         911          912   0.00000000E+00
         911          913   0.00000000E+00
         911          914   0.00000000E+00
         911          915   0.00000000E+00
         911          916   0.58979089E+02
         911          917   0.56198267E+02
         911          918   0.00000000E+00
         911          919   0.00000000E+00
         911          920   0.26805791E+04
         911          901  -0.86071408E-05
         911          902   0.00000000E+00
         911          903   0.00000000E+00
         911          904   0.00000000E+00
         911          905   0.00000000E+00
         911          906  -0.70199734E-07
         911          907  -0.66890111E-07
         911          908   0.00000000E+00
         911          909   0.00000000E+00
         911          910  -0.31905647E-05
         911          921  -0.20356337E-04
         911          922   0.00000000E+00
         911          923   0.00000000E+00
         911          924   0.00000000E+00
         911          925   0.00000000E+00
         911          926  -0.16602603E-06
         911          927  -0.15819860E-06
         911          928   0.00000000E+00
         911          929   0.00000000E+00
         911          930  -0.75458519E-05
         912          912   0.45533193E+04
         912          911   0.00000000E+00
         912          913   0.00000000E+00
         912          914   0.63450217E+01
         912          915   0.63450217E+01
         912          916   0.00000000E+00
         912          917  -0.21136331E+02
         912          918   0.00000000E+00
         912          919   0.00000000E+00
         912          920   0.18335171E+03
         912          901   0.00000000E+00
         912          902  -0.54170813E-05
         912          903   0.00000000E+00
         912          904   0.00000000E+00
         912          905   0.00000000E+00
         912          906   0.00000000E+00
         912          907   0.00000000E+00
         912          908   0.00000000E+00
         912          909   0.00000000E+00
         912          910  -0.21823478E-06
         912          921   0.00000000E+00
         912          922  -0.12811680E-04
         912          923   0.00000000E+00
         912          924   0.00000000E+00
         912          925   0.00000000E+00
         912          926   0.00000000E+00
         912          927   0.00000000E+00
         912          928   0.00000000E+00
         912          929   0.00000000E+00
         912          930  -0.51613663E-06
         913          913   0.57648591E+03
         913          911   0.00000000E+00
         913          912   0.00000000E+00
         913          914   0.00000000E+00
         913          915   0.00000000E+00
         913          916   0.00000000E+00
         913          917   0.00000000E+00
         913          918   0.00000000E+00
         913          919   0.00000000E+00
         913          920   0.00000000E+00
         913          901   0.00000000E+00
         913          902   0.00000000E+00
         913          903  -0.68616363E-06
         913          904   0.00000000E+00
         913          905   0.00000000E+00
         913          906   0.00000000E+00
         913          907   0.00000000E+00
         913          908   0.00000000E+00
         913          909   0.00000000E+00
         913          910   0.00000000E+00
         913          921   0.00000000E+00
         913          922   0.00000000E+00
         913          923  -0.16228127E-05
         913          924   0.00000000E+00
         913          925   0.00000000E+00
         913          926   0.00000000E+00
         913          927   0.00000000E+00
         913          928   0.00000000E+00
         913          929   0.00000000E+00
         913          930   0.00000000E+00
         914          914   0.99501563E+03
         914          911   0.00000000E+00
         914          912   0.63443872E+01
         914          913   0.00000000E+00
         914          915   0.19035065E+02
         914          916   0.00000000E+00
         914          917  -0.65201474E+02
         914          918   0.00000000E+00
         914          919   0.00000000E+00
         914          920   0.00000000E+00
         914          901   0.00000000E+00
         914          902   0.00000000E+00
         914          903   0.00000000E+00
         914          904  -0.11616630E-05
         914          905   0.00000000E+00
         914          906   0.00000000E+00
         914          907   0.21335056E-08
         914          908   0.00000000E+00
         914          909   0.00000000E+00
         914          910   0.00000000E+00
         914          921   0.00000000E+00
         914          922   0.00000000E+00
         914          923   0.00000000E+00
         914          924  -0.27473935E-05
         914          925   0.00000000E+00
         914          926   0.00000000E+00
         914          927   0.50458520E-08
         914          928   0.00000000E+00
         914          929   0.00000000E+00
         914          930   0.00000000E+00
         915          915   0.19048195E+02
         915          911   0.00000000E+00
         915          912   0.63443872E+01
         915          913   0.00000000E+00
         915          914   0.19035065E+02
         915          916   0.00000000E+00
         915          917  -0.63459868E+02
         915          918   0.00000000E+00
         915          919   0.00000000E+00
         915          920   0.16091865E-05
         915          901   0.00000000E+00
         915          902   0.00000000E+00
         915          903   0.00000000E+00
         915          904   0.00000000E+00
         915          905  -0.15589157E-10
         915          906   0.00000000E+00
         915          907   0.60438595E-10
         915          908   0.00000000E+00
         915          909   0.00000000E+00
         915          910  -0.19153378E-14
         915          921   0.00000000E+00
         915          922   0.00000000E+00
         915          923   0.00000000E+00
         915          924   0.00000000E+00
         915          925  -0.36869169E-10
         915          926   0.00000000E+00
         915          927   0.14294043E-09
         915          928   0.00000000E+00
         915          929   0.00000000E+00
         915          930  -0.45298738E-14
         916          916   0.13428201E+04
         916          911   0.58979089E+02
         916          912   0.00000000E+00
         916          913   0.00000000E+00
         916          914   0.00000000E+00
         916          915   0.00000000E+00
         916          917   0.16073078E+04
         916          918   0.00000000E+00
         916          919   0.43198833E-04
         916          920   0.00000000E+00
         916          901  -0.70199734E-07
         916          902   0.00000000E+00
         916          903   0.00000000E+00
         916          904   0.00000000E+00
         916          905   0.00000000E+00
         916          906  -0.76104614E-04
         916          907  -0.15093319E-03
         916          908   0.00000000E+00
         916          909   0.00000000E+00
         916          910   0.00000000E+00
         916          921  -0.16602603E-06
         916          922   0.00000000E+00
         916          923   0.00000000E+00
         916          924   0.00000000E+00
         916          925   0.00000000E+00
         916          926  -0.78167717E-04
         916          927  -0.15330736E-03
         916          928   0.00000000E+00
         916          929   0.00000000E+00
         916          930   0.00000000E+00
         917          917   0.23571050E+04
         917          911   0.56198267E+02
         917          912  -0.21147957E+02
         917          913   0.00000000E+00
         917          914  -0.65242878E+02
         917          915  -0.63501105E+02
         917          916   0.16072810E+04
         917          918  -0.37170405E-04
         917          919  -0.88860041E-01
         917          920   0.36554809E-01
         917          901  -0.66890111E-07
         917          902   0.00000000E+00
         917          903   0.00000000E+00
         917          904   0.21337190E-08
         917          905   0.60453482E-10
         917          906  -0.15092571E-03
         917          907  -0.30059415E-03
         917          908   0.57660381E-14
         917          909   0.10577686E-09
         917          910  -0.43487451E-10
         917          921  -0.15819860E-06
         917          922   0.00000000E+00
         917          923   0.00000000E+00
         917          924   0.50463565E-08
         917          925   0.14297563E-09
         917          926  -0.15329984E-03
         917          927  -0.30360583E-03
         917          928   0.13636981E-13
         917          929   0.25016778E-09
         917          930  -0.10285009E-09
         918          918   0.63759963E-04
         918          911   0.00000000E+00
         918          912   0.00000000E+00
         918          913   0.00000000E+00
         918          914   0.00000000E+00
         918          915   0.00000000E+00
         918          916   0.00000000E+00
         918          917  -0.37179687E-04
         918          919  -0.15265617E-04
         918          920  -0.35817522E-04
         918          901   0.00000000E+00
         918          902   0.00000000E+00
         918          903   0.00000000E+00
         918          904   0.00000000E+00
         918          905   0.00000000E+00
         918          906   0.00000000E+00
         918          907   0.57665035E-14
         918          908  -0.85572283E-14
         918          909  -0.10724542E-14
         918          910   0.41451839E-14
         918          921   0.00000000E+00
         918          922   0.00000000E+00
         918          923   0.00000000E+00
         918          924   0.00000000E+00
         918          925   0.00000000E+00
         918          926   0.00000000E+00
         918          927   0.13638081E-13
         918          928  -0.20238291E-13
         918          929  -0.25364101E-14
         918          930   0.98035761E-14
         919          919   0.73355359E+02
         919          911   0.00000000E+00
         919          912   0.00000000E+00
         919          913   0.00000000E+00
         919          914   0.00000000E+00
         919          915   0.00000000E+00
         919          916   0.43198833E-04
         919          917  -0.88851154E-01
         919          918  -0.15262014E-04
         919          920   0.24760372E+02
         919          901   0.00000000E+00
         919          902   0.00000000E+00
         919          903   0.00000000E+00
         919          904   0.00000000E+00
         919          905   0.00000000E+00
         919          906   0.00000000E+00
         919          907   0.10576628E-09
         919          908  -0.10724140E-14
         919          909  -0.87311322E-07
         919          910  -0.29471077E-07
         919          921   0.00000000E+00
         919          922   0.00000000E+00
         919          923   0.00000000E+00
         919          924   0.00000000E+00
         919          925   0.00000000E+00
         919          926   0.00000000E+00
         919          927   0.25014276E-09
         919          928  -0.25363150E-14
         919          929  -0.20649583E-06
         919          930  -0.69700633E-07
         920          920   0.99560137E+04
         920          911   0.26805791E+04
         920          912   0.18335171E+03
         920          913   0.00000000E+00
         920          914   0.00000000E+00
         920          915   0.16091642E-05
         920          916   0.00000000E+00
         920          917   0.36554809E-01
         920          918  -0.35808109E-04
         920          919   0.24760372E+02
         920          901  -0.31905647E-05
         920          902  -0.21823478E-06
         920          903   0.00000000E+00
         920          904   0.00000000E+00
         920          905  -0.19153112E-14
         920          906   0.00000000E+00
         920          907  -0.43487451E-10
         920          908   0.41445622E-14
         920          909  -0.29471077E-07
         920          910  -0.11850167E-04
         920          921  -0.75458519E-05
         920          922  -0.51613663E-06
         920          923   0.00000000E+00
         920          924   0.00000000E+00
         920          925  -0.45298108E-14
         920          926   0.00000000E+00
         920          927  -0.10285009E-09
         920          928   0.98021057E-14
         920          929  -0.69700633E-07
         920          930  -0.28026262E-04
         921          921   0.72312225E+04
         921          922   0.00000000E+00
         921          923   0.00000000E+00
         921          924   0.00000000E+00
         921          925   0.00000000E+00
         921          926   0.58977972E+02
         921          927   0.56197203E+02
         921          928   0.00000000E+00
         921          929   0.00000000E+00
         921          930   0.26805284E+04
         921          911  -0.86065407E-05
         921          912   0.00000000E+00
         921          913   0.00000000E+00
         921          914   0.00000000E+00
         921          915   0.00000000E+00
         921          916  -0.70194839E-07
         921          917  -0.66885447E-07
         921          918   0.00000000E+00
         921          919   0.00000000E+00
         921          920  -0.31903423E-05
         921          931  -0.20355853E-04
         921          932   0.00000000E+00
         921          933   0.00000000E+00
         921          934   0.00000000E+00
         921          935   0.00000000E+00
         921          936  -0.16602208E-06
         921          937  -0.15819484E-06
         921          938   0.00000000E+00
         921          939   0.00000000E+00
         921          940  -0.75456725E-05
         922          922   0.45532332E+04
         922          921   0.00000000E+00
         922          923   0.00000000E+00
         922          924   0.63450217E+01
         922          925   0.63450217E+01
         922          926   0.00000000E+00
         922          927  -0.21136331E+02
         922          928   0.00000000E+00
         922          929   0.00000000E+00
         922          930   0.18334824E+03
         922          911   0.00000000E+00
         922          912  -0.54167036E-05
         922          913   0.00000000E+00
         922          914   0.00000000E+00
         922          915   0.00000000E+00
         922          916   0.00000000E+00
         922          917   0.00000000E+00
         922          918   0.00000000E+00
         922          919   0.00000000E+00
         922          920  -0.21821957E-06
         922          931   0.00000000E+00
         922          932  -0.12811375E-04
         922          933   0.00000000E+00
         922          934   0.00000000E+00
         922          935   0.00000000E+00
         922          936   0.00000000E+00
         922          937   0.00000000E+00
         922          938   0.00000000E+00
         922          939   0.00000000E+00
         922          940  -0.51612437E-06
         923          923   0.57647499E+03
         923          921   0.00000000E+00
         923          922   0.00000000E+00
         923          924   0.00000000E+00
         923          925   0.00000000E+00
         923          926   0.00000000E+00
         923          927   0.00000000E+00
         923          928   0.00000000E+00
         923          929   0.00000000E+00
         923          930   0.00000000E+00
         923          911   0.00000000E+00
         923          912   0.00000000E+00
         923          913  -0.68611579E-06
         923          914   0.00000000E+00
         923          915   0.00000000E+00
         923          916   0.00000000E+00
         923          917   0.00000000E+00
         923          918   0.00000000E+00
         923          919   0.00000000E+00
         923          920   0.00000000E+00
         923          931   0.00000000E+00
         923          932   0.00000000E+00
         923          933  -0.16227742E-05
         923          934   0.00000000E+00
         923          935   0.00000000E+00
         923          936   0.00000000E+00
         923          937   0.00000000E+00
         923          938   0.00000000E+00
         923          939   0.00000000E+00
         923          940   0.00000000E+00
         924          924   0.99499716E+03
         924          921   0.00000000E+00
         924          922   0.63443872E+01
         924          923   0.00000000E+00
         924          925   0.19035065E+02
         924          926   0.00000000E+00
         924          927  -0.65201440E+02
         924          928   0.00000000E+00
         924          929   0.00000000E+00
         924          930   0.00000000E+00
         924          911   0.00000000E+00
         924          912   0.00000000E+00
         924          913   0.00000000E+00
         924          914  -0.11615820E-05
         924          915   0.00000000E+00
         924          916   0.00000000E+00
         924          917   0.21333568E-08
         924          918   0.00000000E+00
         924          919   0.00000000E+00
         924          920   0.00000000E+00
         924          931   0.00000000E+00
         924          932   0.00000000E+00
         924          933   0.00000000E+00
         924          934  -0.27473282E-05
         924          935   0.00000000E+00
         924          936   0.00000000E+00
         924          937   0.50457320E-08
         924          938   0.00000000E+00
         924          939   0.00000000E+00
         924          940   0.00000000E+00
         925          925   0.19048195E+02
         925          921   0.00000000E+00
         925          922   0.63443872E+01
         925          923   0.00000000E+00
         925          924   0.19035065E+02
         925          926   0.00000000E+00
         925          927  -0.63459867E+02
         925          928   0.00000000E+00
         925          929   0.00000000E+00
         925          930   0.16091561E-05
         925          911   0.00000000E+00
         925          912   0.00000000E+00
         925          913   0.00000000E+00
         925          914   0.00000000E+00
         925          915  -0.15588070E-10
         925          916   0.00000000E+00
         925          917   0.60434381E-10
         925          918   0.00000000E+00
         925          919   0.00000000E+00
         925          920  -0.19152043E-14
         925          931   0.00000000E+00
         925          932   0.00000000E+00
         925          933   0.00000000E+00
         925          934   0.00000000E+00
         925          935  -0.36868292E-10
         925          936   0.00000000E+00
         925          937   0.14293703E-09
         925          938   0.00000000E+00
         925          939   0.00000000E+00
         925          940  -0.45297662E-14
         926          926   0.13428006E+04
         926          921   0.58977972E+02
         926          922   0.00000000E+00
         926          923   0.00000000E+00
         926          924   0.00000000E+00
         926          925   0.00000000E+00
         926          927   0.16072893E+04
         926          928   0.00000000E+00
         926          929   0.43198833E-04
         926          930   0.00000000E+00
         926          911  -0.70194839E-07
         926          912   0.00000000E+00
         926          913   0.00000000E+00
         926          914   0.00000000E+00
         926          915   0.00000000E+00
         926          916  -0.76119390E-04
         926          917  -0.15096284E-03
         926          918   0.00000000E+00
         926          919   0.00000000E+00
         926          920   0.00000000E+00
         926          931  -0.16602208E-06
         926          932   0.00000000E+00
         926          933   0.00000000E+00
         926          934   0.00000000E+00
         926          935   0.00000000E+00
         926          936  -0.78179631E-04
         926          937  -0.15333126E-03
         926          938   0.00000000E+00
         926          939   0.00000000E+00
         926          940   0.00000000E+00
         927          927   0.23570882E+04
         927          921   0.56197203E+02
         927          922  -0.21147957E+02
         927          923   0.00000000E+00
         927          924  -0.65242844E+02
         927          925  -0.63501104E+02
         927          926   0.16072625E+04
         927          928  -0.37170314E-04
         927          929  -0.88858359E-01
         927          930   0.36554118E-01
         927          911  -0.66885447E-07
         927          912   0.00000000E+00
         927          913   0.00000000E+00
         927          914   0.21335702E-08
         927          915   0.60449266E-10
         927          916  -0.15095535E-03
         927          917  -0.30065353E-03
         927          918   0.57656360E-14
         927          919   0.10576948E-09
         927          920  -0.43484418E-10
         927          931  -0.15819484E-06
         927          932   0.00000000E+00
         927          933   0.00000000E+00
         927          934   0.50462366E-08
         927          935   0.14297224E-09
         927          936  -0.15332375E-03
         927          937  -0.30365370E-03
         927          938   0.13636656E-13
         927          939   0.25016183E-09
         927          940  -0.10284764E-09
         928          928   0.63759827E-04
         928          921   0.00000000E+00
         928          922   0.00000000E+00
         928          923   0.00000000E+00
         928          924   0.00000000E+00
         928          925   0.00000000E+00
         928          926   0.00000000E+00
         928          927  -0.37179595E-04
         928          929  -0.15265634E-04
         928          930  -0.35817456E-04
         928          911   0.00000000E+00
         928          912   0.00000000E+00
         928          913   0.00000000E+00
         928          914   0.00000000E+00
         928          915   0.00000000E+00
         928          916   0.00000000E+00
         928          917   0.57661014E-14
         928          918  -0.85566317E-14
         928          919  -0.10723794E-14
         928          920   0.41448949E-14
         928          931   0.00000000E+00
         928          932   0.00000000E+00
         928          933   0.00000000E+00
         928          934   0.00000000E+00
         928          935   0.00000000E+00
         928          936   0.00000000E+00
         928          937   0.13637757E-13
         928          938  -0.20237810E-13
         928          939  -0.25363498E-14
         928          940   0.98033431E-14
         929          929   0.73353970E+02
         929          921   0.00000000E+00
         929          922   0.00000000E+00
         929          923   0.00000000E+00
         929          924   0.00000000E+00
         929          925   0.00000000E+00
         929          926   0.43198833E-04
         929          927  -0.88849472E-01
         929          928  -0.15262031E-04
         929          930   0.24759903E+02
         929          911   0.00000000E+00
         929          912   0.00000000E+00
         929          913   0.00000000E+00
         929          914   0.00000000E+00
         929          915   0.00000000E+00
         929          916   0.00000000E+00
         929          917   0.10575891E-09
         929          918  -0.10723392E-14
         929          919  -0.87305234E-07
         929          920  -0.29469022E-07
         929          931   0.00000000E+00
         929          932   0.00000000E+00
         929          933   0.00000000E+00
         929          934   0.00000000E+00
         929          935   0.00000000E+00
         929          936   0.00000000E+00
         929          937   0.25013682E-09
         929          938  -0.25362547E-14
         929          939  -0.20649092E-06
         929          940  -0.69698976E-07
         930          930   0.99558252E+04
         930          921   0.26805284E+04
         930          922   0.18334824E+03
         930          923   0.00000000E+00
         930          924   0.00000000E+00
         930          925   0.16091337E-05
         930          926   0.00000000E+00
         930          927   0.36554118E-01
         930          928  -0.35808043E-04
         930          929   0.24759903E+02
         930          911  -0.31903423E-05
         930          912  -0.21821957E-06
         930          913   0.00000000E+00
         930          914   0.00000000E+00
         930          915  -0.19151777E-14
         930          916   0.00000000E+00
         930          917  -0.43484418E-10
         930          918   0.41442733E-14
         930          919  -0.29469022E-07
         930          920  -0.11849341E-04
         930          931  -0.75456725E-05
         930          932  -0.51612437E-06
         930          933   0.00000000E+00
         930          934   0.00000000E+00
         930          935  -0.45297032E-14
         930          936   0.00000000E+00
         930          937  -0.10284764E-09
         930          938   0.98018728E-14
         930          939  -0.69698976E-07
         930          940  -0.28025596E-04
         931          931   0.72311121E+04
         931          932   0.00000000E+00
         931          933   0.00000000E+00
         931          934   0.00000000E+00
         931          935   0.00000000E+00
         931          936   0.58977072E+02
         931          937   0.56196345E+02
         931          938   0.00000000E+00
         931          939   0.00000000E+00
         931          940   0.26804875E+04
         931          921  -0.86060569E-05
         931          922   0.00000000E+00
         931          923   0.00000000E+00
         931          924   0.00000000E+00
         931          925   0.00000000E+00
         931          926  -0.70190893E-07
         931          927  -0.66881687E-07
         931          928   0.00000000E+00
         931          929   0.00000000E+00
         931          930  -0.31901629E-05
         931          941  -0.20355463E-04
         931          942   0.00000000E+00
         931          943   0.00000000E+00
         931          944   0.00000000E+00
         931          945   0.00000000E+00
         931          946  -0.16601890E-06
         931          947  -0.15819181E-06
         931          948   0.00000000E+00
         931          949   0.00000000E+00
         931          950  -0.75455279E-05
         932          932   0.45531637E+04
         932          931   0.00000000E+00
         932          933   0.00000000E+00
         932          934   0.63450217E+01
         932          935   0.63450217E+01
         932          936   0.00000000E+00
         932          937  -0.21136331E+02
         932          938   0.00000000E+00
         932          939   0.00000000E+00
         932          940   0.18334544E+03
         932          921   0.00000000E+00
         932          922  -0.54163991E-05
         932          923   0.00000000E+00
         932          924   0.00000000E+00
         932          925   0.00000000E+00
         932          926   0.00000000E+00
         932          927   0.00000000E+00
         932          928   0.00000000E+00
         932          929   0.00000000E+00
         932          930  -0.21820730E-06
         932          941   0.00000000E+00
         932          942  -0.12811130E-04
         932          943   0.00000000E+00
         932          944   0.00000000E+00
         932          945   0.00000000E+00
         932          946   0.00000000E+00
         932          947   0.00000000E+00
         932          948   0.00000000E+00
         932          949   0.00000000E+00
         932          950  -0.51611448E-06
         933          933   0.57646619E+03
         933          931   0.00000000E+00
         933          932   0.00000000E+00
         933          934   0.00000000E+00
         933          935   0.00000000E+00
         933          936   0.00000000E+00
         933          937   0.00000000E+00
         933          938   0.00000000E+00
         933          939   0.00000000E+00
         933          940   0.00000000E+00
         933          921   0.00000000E+00
         933          922   0.00000000E+00
         933          923  -0.68607722E-06
         933          924   0.00000000E+00
         933          925   0.00000000E+00
         933          926   0.00000000E+00
         933          927   0.00000000E+00
         933          928   0.00000000E+00
         933          929   0.00000000E+00
         933          930   0.00000000E+00
         933          941   0.00000000E+00
         933          942   0.00000000E+00
         933          943  -0.16227431E-05
         933          944   0.00000000E+00
         933          945   0.00000000E+00
         933          946   0.00000000E+00
         933          947   0.00000000E+00
         933          948   0.00000000E+00
         933          949   0.00000000E+00
         933          950   0.00000000E+00
         934          934   0.99498226E+03
         934          931   0.00000000E+00
         934          932   0.63443872E+01
         934          933   0.00000000E+00
         934          935   0.19035065E+02
         934          936   0.00000000E+00
         934          937  -0.65201413E+02
         934          938   0.00000000E+00
         934          939   0.00000000E+00
         934          940   0.00000000E+00
         934          921   0.00000000E+00
         934          922   0.00000000E+00
         934          923   0.00000000E+00
         934          924  -0.11615167E-05
         934          925   0.00000000E+00
         934          926   0.00000000E+00
         934          927   0.21332369E-08
         934          928   0.00000000E+00
         934          929   0.00000000E+00
         934          930   0.00000000E+00
         934          941   0.00000000E+00
         934          942   0.00000000E+00
         934          943   0.00000000E+00
         934          944  -0.27472756E-05
         934          945   0.00000000E+00
         934          946   0.00000000E+00
         934          947   0.50456353E-08
         934          948   0.00000000E+00
         934          949   0.00000000E+00
         934          950   0.00000000E+00
         935          935   0.19048195E+02
         935          931   0.00000000E+00
         935          932   0.63443872E+01
         935          933   0.00000000E+00
         935          934   0.19035065E+02
         935          936   0.00000000E+00
         935          937  -0.63459866E+02
         935          938   0.00000000E+00
         935          939   0.00000000E+00
         935          940   0.16091315E-05
         935          921   0.00000000E+00
         935          922   0.00000000E+00
         935          923   0.00000000E+00
         935          924   0.00000000E+00
         935          925  -0.15587194E-10
         935          926   0.00000000E+00
         935          927   0.60430984E-10
         935          928   0.00000000E+00
         935          929   0.00000000E+00
         935          930  -0.19150966E-14
         935          941   0.00000000E+00
         935          942   0.00000000E+00
         935          943   0.00000000E+00
         935          944   0.00000000E+00
         935          945  -0.36867586E-10
         935          946   0.00000000E+00
         935          947   0.14293429E-09
         935          948   0.00000000E+00
         935          949   0.00000000E+00
         935          950  -0.45296794E-14
         936          936   0.13427849E+04
         936          931   0.58977072E+02
         936          932   0.00000000E+00
         936          933   0.00000000E+00
         936          934   0.00000000E+00
         936          935   0.00000000E+00
         936          937   0.16072743E+04
         936          938   0.00000000E+00
         936          939   0.43198833E-04
         936          940   0.00000000E+00
         936          921  -0.70190893E-07
         936          922   0.00000000E+00
         936          923   0.00000000E+00
         936          924   0.00000000E+00
         936          925   0.00000000E+00
         936          926  -0.76131305E-04
         936          927  -0.15098674E-03
         936          928   0.00000000E+00
         936          929   0.00000000E+00
         936          930   0.00000000E+00
         936          941  -0.16601890E-06
         936          942   0.00000000E+00
         936          943   0.00000000E+00
         936          944   0.00000000E+00
         936          945   0.00000000E+00
         936          946  -0.78189238E-04
         936          947  -0.15335053E-03
         936          948   0.00000000E+00
         936          949   0.00000000E+00
         936          950   0.00000000E+00
         937          937   0.23570746E+04
         937          931   0.56196345E+02
         937          932  -0.21147957E+02
         937          933   0.00000000E+00
         937          934  -0.65242817E+02
         937          935  -0.63501103E+02
         937          936   0.16072475E+04
         937          938  -0.37170240E-04
         937          939  -0.88857002E-01
         937          940   0.36553560E-01
         937          921  -0.66881687E-07
         937          922   0.00000000E+00
         937          923   0.00000000E+00
         937          924   0.21334502E-08
         937          925   0.60445868E-10
         937          926  -0.15097925E-03
         937          927  -0.30070140E-03
         937          928   0.57653119E-14
         937          929   0.10576354E-09
         937          930  -0.43481974E-10
         937          941  -0.15819181E-06
         937          942   0.00000000E+00
         937          943   0.00000000E+00
         937          944   0.50461399E-08
         937          945   0.14296950E-09
         937          946  -0.15334302E-03
         937          947  -0.30369230E-03
         937          948   0.13636395E-13
         937          949   0.25015704E-09
         937          950  -0.10284567E-09
         938          938   0.63759717E-04
         938          931   0.00000000E+00
         938          932   0.00000000E+00
         938          933   0.00000000E+00
         938          934   0.00000000E+00
         938          935   0.00000000E+00
         938          936   0.00000000E+00
         938          937  -0.37179521E-04
         938          939  -0.15265648E-04
         938          940  -0.35817403E-04
         938          921   0.00000000E+00
         938          922   0.00000000E+00
         938          923   0.00000000E+00
         938          924   0.00000000E+00
         938          925   0.00000000E+00
         938          926   0.00000000E+00
         938          927   0.57657773E-14
         938          928  -0.85561506E-14
         938          929  -0.10723191E-14
         938          930   0.41446619E-14
         938          941   0.00000000E+00
         938          942   0.00000000E+00
         938          943   0.00000000E+00
         938          944   0.00000000E+00
         938          945   0.00000000E+00
         938          946   0.00000000E+00
         938          947   0.13637496E-13
         938          948  -0.20237422E-13
         938          949  -0.25363012E-14
         938          950   0.98031552E-14
         939          939   0.73352851E+02
         939          931   0.00000000E+00
         939          932   0.00000000E+00
         939          933   0.00000000E+00
         939          934   0.00000000E+00
         939          935   0.00000000E+00
         939          936   0.43198833E-04
         939          937  -0.88848116E-01
         939          938  -0.15262045E-04
         939          940   0.24759525E+02
         939          921   0.00000000E+00
         939          922   0.00000000E+00
         939          923   0.00000000E+00
         939          924   0.00000000E+00
         939          925   0.00000000E+00
         939          926   0.00000000E+00
         939          927   0.10575296E-09
         939          928  -0.10722789E-14
         939          929  -0.87300326E-07
         939          930  -0.29467365E-07
         939          941   0.00000000E+00
         939          942   0.00000000E+00
         939          943   0.00000000E+00
         939          944   0.00000000E+00
         939          945   0.00000000E+00
         939          946   0.00000000E+00
         939          947   0.25013203E-09
         939          948  -0.25362061E-14
         939          949  -0.20648696E-06
         939          950  -0.69697641E-07
         940          940   0.99556732E+04
         940          931   0.26804875E+04
         940          932   0.18334544E+03
         940          933   0.00000000E+00
         940          934   0.00000000E+00
         940          935   0.16091091E-05
         940          936   0.00000000E+00
         940          937   0.36553560E-01
         940          938  -0.35807990E-04
         940          939   0.24759525E+02
         940          921  -0.31901629E-05
         940          922  -0.21820730E-06
         940          923   0.00000000E+00
         940          924   0.00000000E+00
         940          925  -0.19150700E-14
         940          926   0.00000000E+00
         940          927  -0.43481974E-10
         940          928   0.41440403E-14
         940          929  -0.29467365E-07
         940          930  -0.11848674E-04
         940          941  -0.75455279E-05
         940          942  -0.51611448E-06
         940          943   0.00000000E+00
         940          944   0.00000000E+00
         940          945  -0.45296164E-14
         940          946   0.00000000E+00
         940          947  -0.10284567E-09
         940          948   0.98016849E-14
         940          949  -0.69697641E-07
         940          950  -0.28025059E-04
         941          941   0.72310231E+04
         941          942   0.00000000E+00
         941          943   0.00000000E+00
         941          944   0.00000000E+00
         941          945   0.00000000E+00
         941          946   0.58976346E+02
         941          947   0.56195653E+02
         941          948   0.00000000E+00
         941          949   0.00000000E+00
         941          950   0.26804545E+04
         941          931  -0.86056668E-05
         941          932   0.00000000E+00
         941          933   0.00000000E+00
         941          934   0.00000000E+00
         941          935   0.00000000E+00
         941          936  -0.70187712E-07
         941          937  -0.66878656E-07
         941          938   0.00000000E+00
         941          939   0.00000000E+00
         941          940  -0.31900183E-05
         941          951  -0.20355148E-04
         941          952   0.00000000E+00
         941          953   0.00000000E+00
         941          954   0.00000000E+00
         941          955   0.00000000E+00
         941          956  -0.16601634E-06
         941          957  -0.15818936E-06
         941          958   0.00000000E+00
         941          959   0.00000000E+00
         941          960  -0.75454114E-05
         942          942   0.45531077E+04
         942          941   0.00000000E+00
         942          943   0.00000000E+00
         942          944   0.63450217E+01
         942          945   0.63450217E+01
         942          946   0.00000000E+00
         942          947  -0.21136331E+02
         942          948   0.00000000E+00
         942          949   0.00000000E+00
         942          950   0.18334319E+03
         942          931   0.00000000E+00
         942          932  -0.54161536E-05
         942          933   0.00000000E+00
         942          934   0.00000000E+00
         942          935   0.00000000E+00
         942          936   0.00000000E+00
         942          937   0.00000000E+00
         942          938   0.00000000E+00
         942          939   0.00000000E+00
         942          940  -0.21819741E-06
         942          951   0.00000000E+00
         942          952  -0.12810932E-04
         942          953   0.00000000E+00
         942          954   0.00000000E+00
         942          955   0.00000000E+00
         942          956   0.00000000E+00
         942          957   0.00000000E+00
         942          958   0.00000000E+00
         942          959   0.00000000E+00
         942          960  -0.51610650E-06
         943          943   0.57645910E+03
         943          941   0.00000000E+00
         943          942   0.00000000E+00
         943          944   0.00000000E+00
         943          945   0.00000000E+00
         943          946   0.00000000E+00
         943          947   0.00000000E+00
         943          948   0.00000000E+00
         943          949   0.00000000E+00
         943          950   0.00000000E+00
         943          931   0.00000000E+00
         943          932   0.00000000E+00
         943          933  -0.68604612E-06
         943          934   0.00000000E+00
         943          935   0.00000000E+00
         943          936   0.00000000E+00
         943          937   0.00000000E+00
         943          938   0.00000000E+00
         943          939   0.00000000E+00
         943          940   0.00000000E+00
         943          951   0.00000000E+00
         943          952   0.00000000E+00
         943          953  -0.16227180E-05
         943          954   0.00000000E+00
         943          955   0.00000000E+00
         943          956   0.00000000E+00
         943          957   0.00000000E+00
         943          958   0.00000000E+00
         943          959   0.00000000E+00
         943          960   0.00000000E+00
         944          944   0.99497025E+03
         944          941   0.00000000E+00
         944          942   0.63443872E+01
         944          943   0.00000000E+00
         944          945   0.19035065E+02
         944          946   0.00000000E+00
         944          947  -0.65201390E+02
         944          948   0.00000000E+00
         944          949   0.00000000E+00
         944          950   0.00000000E+00
         944          931   0.00000000E+00
         944          932   0.00000000E+00
         944          933   0.00000000E+00
         944          934  -0.11614640E-05
         944          935   0.00000000E+00
         944          936   0.00000000E+00
         944          937   0.21331402E-08
         944          938   0.00000000E+00
         944          939   0.00000000E+00
         944          940   0.00000000E+00
         944          951   0.00000000E+00
         944          952   0.00000000E+00
         944          953   0.00000000E+00
         944          954  -0.27472331E-05
         944          955   0.00000000E+00
         944          956   0.00000000E+00
         944          957   0.50455574E-08
         944          958   0.00000000E+00
         944          959   0.00000000E+00
         944          960   0.00000000E+00
         945          945   0.19048194E+02
         945          941   0.00000000E+00
         945          942   0.63443872E+01
         945          943   0.00000000E+00
         945          944   0.19035065E+02
         945          946   0.00000000E+00
         945          947  -0.63459865E+02
         945          948   0.00000000E+00
         945          949   0.00000000E+00
         945          950   0.16091117E-05
         945          931   0.00000000E+00
         945          932   0.00000000E+00
         945          933   0.00000000E+00
         945          934   0.00000000E+00
         945          935  -0.15586487E-10
         945          936   0.00000000E+00
         945          937   0.60428245E-10
         945          938   0.00000000E+00
         945          939   0.00000000E+00
         945          940  -0.19150098E-14
         945          951   0.00000000E+00
         945          952   0.00000000E+00
         945          953   0.00000000E+00
         945          954   0.00000000E+00
         945          955  -0.36867016E-10
         945          956   0.00000000E+00
         945          957   0.14293208E-09
         945          958   0.00000000E+00
         945          959   0.00000000E+00
         945          960  -0.45296094E-14
         946          946   0.13427723E+04
         946          941   0.58976346E+02
         946          942   0.00000000E+00
         946          943   0.00000000E+00
         946          944   0.00000000E+00
         946          945   0.00000000E+00
         946          947   0.16072623E+04
         946          948   0.00000000E+00
         946          949   0.43198833E-04
         946          950   0.00000000E+00
         946          931  -0.70187712E-07
         946          932   0.00000000E+00
         946          933   0.00000000E+00
         946          934   0.00000000E+00
         946          935   0.00000000E+00
         946          936  -0.76140911E-04
         946          937  -0.15100601E-03
         946          938   0.00000000E+00
         946          939   0.00000000E+00
         946          940   0.00000000E+00
         946          951  -0.16601634E-06
         946          952   0.00000000E+00
         946          953   0.00000000E+00
         946          954   0.00000000E+00
         946          955   0.00000000E+00
         946          956  -0.78196983E-04
         946          957  -0.15336607E-03
         946          958   0.00000000E+00
         946          959   0.00000000E+00
         946          960   0.00000000E+00
         947          947   0.23570637E+04
         947          941   0.56195653E+02
         947          942  -0.21147957E+02
         947          943   0.00000000E+00
         947          944  -0.65242794E+02
         947          945  -0.63501103E+02
         947          946   0.16072355E+04
         947          948  -0.37170180E-04
         947          949  -0.88855908E-01
         947          950   0.36553110E-01
         947          931  -0.66878656E-07
         947          932   0.00000000E+00
         947          933   0.00000000E+00
         947          934   0.21333535E-08
         947          935   0.60443129E-10
         947          936  -0.15099852E-03
         947          937  -0.30074001E-03
         947          938   0.57650506E-14
         947          939   0.10575874E-09
         947          940  -0.43480003E-10
         947          951  -0.15818936E-06
         947          952   0.00000000E+00
         947          953   0.00000000E+00
         947          954   0.50460620E-08
         947          955   0.14296729E-09
         947          956  -0.15335855E-03
         947          957  -0.30372343E-03
         947          958   0.13636184E-13
         947          959   0.25015318E-09
         947          960  -0.10284408E-09
         948          948   0.63759628E-04
         948          941   0.00000000E+00
         948          942   0.00000000E+00
         948          943   0.00000000E+00
         948          944   0.00000000E+00
         948          945   0.00000000E+00
         948          946   0.00000000E+00
         948          947  -0.37179461E-04
         948          949  -0.15265659E-04
         948          950  -0.35817360E-04
         948          931   0.00000000E+00
         948          932   0.00000000E+00
         948          933   0.00000000E+00
         948          934   0.00000000E+00
         948          935   0.00000000E+00
         948          936   0.00000000E+00
         948          937   0.57655160E-14
         948          938  -0.85557629E-14
         948          939  -0.10722705E-14
         948          940   0.41444741E-14
         948          951   0.00000000E+00
         948          952   0.00000000E+00
         948          953   0.00000000E+00
         948          954   0.00000000E+00
         948          955   0.00000000E+00
         948          956   0.00000000E+00
         948          957   0.13637285E-13
         948          958  -0.20237110E-13
         948          959  -0.25362620E-14
         948          960   0.98030038E-14
         949          949   0.73351948E+02
         949          941   0.00000000E+00
         949          942   0.00000000E+00
         949          943   0.00000000E+00
         949          944   0.00000000E+00
         949          945   0.00000000E+00
         949          946   0.43198833E-04
         949          947  -0.88847022E-01
         949          948  -0.15262056E-04
         949          950   0.24759221E+02
         949          931   0.00000000E+00
         949          932   0.00000000E+00
         949          933   0.00000000E+00
         949          934   0.00000000E+00
         949          935   0.00000000E+00
         949          936   0.00000000E+00
         949          937   0.10574817E-09
         949          938  -0.10722303E-14
         949          939  -0.87296370E-07
         949          940  -0.29466030E-07
         949          951   0.00000000E+00
         949          952   0.00000000E+00
         949          953   0.00000000E+00
         949          954   0.00000000E+00
         949          955   0.00000000E+00
         949          956   0.00000000E+00
         949          957   0.25012816E-09
         949          958  -0.25361669E-14
         949          959  -0.20648377E-06
         949          960  -0.69696564E-07
         950          950   0.99555507E+04
         950          941   0.26804545E+04
         950          942   0.18334319E+03
         950          943   0.00000000E+00
         950          944   0.00000000E+00
         950          945   0.16090893E-05
         950          946   0.00000000E+00
         950          947   0.36553110E-01
         950          948  -0.35807947E-04
         950          949   0.24759221E+02
         950          931  -0.31900183E-05
         950          932  -0.21819741E-06
         950          933   0.00000000E+00
         950          934   0.00000000E+00
         950          935  -0.19149832E-14
         950          936   0.00000000E+00
         950          937  -0.43480003E-10
         950          938   0.41438525E-14
         950          939  -0.29466030E-07
         950          940  -0.11848137E-04
         950          951  -0.75454114E-05
         950          952  -0.51610650E-06
         950          953   0.00000000E+00
         950          954   0.00000000E+00
         950          955  -0.45295464E-14
         950          956   0.00000000E+00
         950          957  -0.10284408E-09
         950          958   0.98015335E-14
         950          959  -0.69696564E-07
         950          960  -0.28024626E-04
         951          951   0.72309514E+04
         951          952   0.00000000E+00
         951          953   0.00000000E+00
         951          954   0.00000000E+00
         951          955   0.00000000E+00
         951          956   0.58975761E+02
         951          957   0.56195096E+02
         951          958   0.00000000E+00
         951          959   0.00000000E+00
         951          960   0.26804279E+04
         951          941  -0.86053524E-05
         951          942   0.00000000E+00
         951          943   0.00000000E+00
         951          944   0.00000000E+00
         951          945   0.00000000E+00
         951          946  -0.70185147E-07
         951          947  -0.66876212E-07
         951          948   0.00000000E+00
         951          949   0.00000000E+00
         951          950  -0.31899018E-05
         951          961  -0.20354895E-04
         951          962   0.00000000E+00
         951          963   0.00000000E+00
         951          964   0.00000000E+00
         951          965   0.00000000E+00
         951          966  -0.16601427E-06
         951          967  -0.15818739E-06
         951          968   0.00000000E+00
         951          969   0.00000000E+00
         951          970  -0.75453174E-05
         952          952   0.45530625E+04
         952          951   0.00000000E+00
         952          953   0.00000000E+00
         952          954   0.63450217E+01
         952          955   0.63450217E+01
         952          956   0.00000000E+00
         952          957  -0.21136331E+02
         952          958   0.00000000E+00
         952          959   0.00000000E+00
         952          960   0.18334137E+03
         952          941   0.00000000E+00
         952          942  -0.54159557E-05
         952          943   0.00000000E+00
         952          944   0.00000000E+00
         952          945   0.00000000E+00
         952          946   0.00000000E+00
         952          947   0.00000000E+00
         952          948   0.00000000E+00
         952          949   0.00000000E+00
         952          950  -0.21818944E-06
         952          961   0.00000000E+00
         952          962  -0.12810772E-04
         952          963   0.00000000E+00
         952          964   0.00000000E+00
         952          965   0.00000000E+00
         952          966   0.00000000E+00
         952          967   0.00000000E+00
         952          968   0.00000000E+00
         952          969   0.00000000E+00
         952          970  -0.51610008E-06
         953          953   0.57645338E+03
         953          951   0.00000000E+00
         953          952   0.00000000E+00
         953          954   0.00000000E+00
         953          955   0.00000000E+00
         953          956   0.00000000E+00
         953          957   0.00000000E+00
         953          958   0.00000000E+00
         953          959   0.00000000E+00
         953          960   0.00000000E+00
         953          941   0.00000000E+00
         953          942   0.00000000E+00
         953          943  -0.68602105E-06
         953          944   0.00000000E+00
         953          945   0.00000000E+00
         953          946   0.00000000E+00
         953          947   0.00000000E+00
         953          948   0.00000000E+00
         953          949   0.00000000E+00
         953          950   0.00000000E+00
         953          961   0.00000000E+00
         953          962   0.00000000E+00
         953          963  -0.16226978E-05
         953          964   0.00000000E+00
         953          965   0.00000000E+00
         953          966   0.00000000E+00
         953          967   0.00000000E+00
         953          968   0.00000000E+00
         953          969   0.00000000E+00
         953          970   0.00000000E+00
         954          954   0.99496056E+03
         954          951   0.00000000E+00
         954          952   0.63443872E+01
         954          953   0.00000000E+00
         954          955   0.19035065E+02
         954          956   0.00000000E+00
         954          957  -0.65201373E+02
         954          958   0.00000000E+00
         954          959   0.00000000E+00
         954          960   0.00000000E+00
         954          941   0.00000000E+00
         954          942   0.00000000E+00
         954          943   0.00000000E+00
         954          944  -0.11614216E-05
         954          945   0.00000000E+00
         954          946   0.00000000E+00
         954          947   0.21330623E-08
         954          948   0.00000000E+00
         954          949   0.00000000E+00
         954          950   0.00000000E+00
         954          961   0.00000000E+00
         954          962   0.00000000E+00
         954          963   0.00000000E+00
         954          964  -0.27471989E-05
         954          965   0.00000000E+00
         954          966   0.00000000E+00
         954          967   0.50454946E-08
         954          968   0.00000000E+00
         954          969   0.00000000E+00
         954          970   0.00000000E+00
         955          955   0.19048194E+02
         955          951   0.00000000E+00
         955          952   0.63443872E+01
         955          953   0.00000000E+00
         955          954   0.19035065E+02
         955          956   0.00000000E+00
         955          957  -0.63459865E+02
         955          958   0.00000000E+00
         955          959   0.00000000E+00
         955          960   0.16090957E-05
         955          941   0.00000000E+00
         955          942   0.00000000E+00
         955          943   0.00000000E+00
         955          944   0.00000000E+00
         955          945  -0.15585918E-10
         955          946   0.00000000E+00
         955          947   0.60426037E-10
         955          948   0.00000000E+00
         955          949   0.00000000E+00
         955          950  -0.19149399E-14
         955          961   0.00000000E+00
         955          962   0.00000000E+00
         955          963   0.00000000E+00
         955          964   0.00000000E+00
         955          965  -0.36866557E-10
         955          966   0.00000000E+00
         955          967   0.14293030E-09
         955          968   0.00000000E+00
         955          969   0.00000000E+00
         955          970  -0.45295530E-14
         956          956   0.13427621E+04
         956          951   0.58975761E+02
         956          952   0.00000000E+00
         956          953   0.00000000E+00
         956          954   0.00000000E+00
         956          955   0.00000000E+00
         956          957   0.16072526E+04
         956          958   0.00000000E+00
         956          959   0.43198833E-04
         956          960   0.00000000E+00
         956          941  -0.70185147E-07
         956          942   0.00000000E+00
         956          943   0.00000000E+00
         956          944   0.00000000E+00
         956          945   0.00000000E+00
         956          946  -0.76148657E-04
         956          947  -0.15102155E-03
         956          948   0.00000000E+00
         956          949   0.00000000E+00
         956          950   0.00000000E+00
         956          961  -0.16601427E-06
         956          962   0.00000000E+00
         956          963   0.00000000E+00
         956          964   0.00000000E+00
         956          965   0.00000000E+00
         956          966  -0.78203228E-04
         956          967  -0.15337860E-03
         956          968   0.00000000E+00
         956          969   0.00000000E+00
         956          970   0.00000000E+00
         957          957   0.23570548E+04
         957          951   0.56195096E+02
         957          952  -0.21147957E+02
         957          953   0.00000000E+00
         957          954  -0.65242777E+02
         957          955  -0.63501102E+02
         957          956   0.16072257E+04
         957          958  -0.37170132E-04
         957          959  -0.88855027E-01
         957          960   0.36552748E-01
         957          941  -0.66876212E-07
         957          942   0.00000000E+00
         957          943   0.00000000E+00
         957          944   0.21332756E-08
         957          945   0.60440920E-10
         957          946  -0.15101406E-03
         957          947  -0.30077113E-03
         957          948   0.57648399E-14
         957          949   0.10575488E-09
         957          950  -0.43478414E-10
         957          961  -0.15818739E-06
         957          962   0.00000000E+00
         957          963   0.00000000E+00
         957          964   0.50459991E-08
         957          965   0.14296551E-09
         957          966  -0.15337108E-03
         957          967  -0.30374852E-03
         957          968   0.13636015E-13
         957          969   0.25015006E-09
         957          970  -0.10284280E-09
         958          958   0.63759557E-04
         958          951   0.00000000E+00
         958          952   0.00000000E+00
         958          953   0.00000000E+00
         958          954   0.00000000E+00
         958          955   0.00000000E+00
         958          956   0.00000000E+00
         958          957  -0.37179413E-04
         958          959  -0.15265668E-04
         958          960  -0.35817325E-04
         958          941   0.00000000E+00
         958          942   0.00000000E+00
         958          943   0.00000000E+00
         958          944   0.00000000E+00
         958          945   0.00000000E+00
         958          946   0.00000000E+00
         958          947   0.57653053E-14
         958          948  -0.85554502E-14
         958          949  -0.10722314E-14
         958          950   0.41443226E-14
         958          961   0.00000000E+00
         958          962   0.00000000E+00
         958          963   0.00000000E+00
         958          964   0.00000000E+00
         958          965   0.00000000E+00
         958          966   0.00000000E+00
         958          967   0.13637115E-13
         958          968  -0.20236858E-13
         958          969  -0.25362305E-14
         958          970   0.98028817E-14
         959          959   0.73351220E+02
         959          951   0.00000000E+00
         959          952   0.00000000E+00
         959          953   0.00000000E+00
         959          954   0.00000000E+00
         959          955   0.00000000E+00
         959          956   0.43198833E-04
         959          957  -0.88846141E-01
         959          958  -0.15262065E-04
         959          960   0.24758975E+02
         959          941   0.00000000E+00
         959          942   0.00000000E+00
         959          943   0.00000000E+00
         959          944   0.00000000E+00
         959          945   0.00000000E+00
         959          946   0.00000000E+00
         959          947   0.10574430E-09
         959          948  -0.10721912E-14
         959          949  -0.87293180E-07
         959          950  -0.29464953E-07
         959          961   0.00000000E+00
         959          962   0.00000000E+00
         959          963   0.00000000E+00
         959          964   0.00000000E+00
         959          965   0.00000000E+00
         959          966   0.00000000E+00
         959          967   0.25012505E-09
         959          968  -0.25361353E-14
         959          969  -0.20648120E-06
         959          970  -0.69695696E-07
         960          960   0.99554519E+04
         960          951   0.26804279E+04
         960          952   0.18334137E+03
         960          953   0.00000000E+00
         960          954   0.00000000E+00
         960          955   0.16090734E-05
         960          956   0.00000000E+00
         960          957   0.36552748E-01
         960          958  -0.35807913E-04
         960          959   0.24758975E+02
         960          941  -0.31899018E-05
         960          942  -0.21818944E-06
         960          943   0.00000000E+00
         960          944   0.00000000E+00
         960          945  -0.19149132E-14
         960          946   0.00000000E+00
         960          947  -0.43478414E-10
         960          948   0.41437010E-14
         960          949  -0.29464953E-07
         960          950  -0.11847705E-04
         960          961  -0.75453174E-05
         960          962  -0.51610008E-06
         960          963   0.00000000E+00
         960          964   0.00000000E+00
         960          965  -0.45294900E-14
         960          966   0.00000000E+00
         960          967  -0.10284280E-09
         960          968   0.98014114E-14
         960          969  -0.69695696E-07
         960          970  -0.28024277E-04
         961          961   0.72308936E+04
         961          962   0.00000000E+00
         961          963   0.00000000E+00
         961          964   0.00000000E+00
         961          965   0.00000000E+00
         961          966   0.58975289E+02
         961          967   0.56194646E+02
         961          968   0.00000000E+00
         961          969   0.00000000E+00
         961          970   0.26804064E+04
         961          951  -0.86050989E-05
         961          952   0.00000000E+00
         961          953   0.00000000E+00
         961          954   0.00000000E+00
         961          955   0.00000000E+00
         961          956  -0.70183079E-07
         961          957  -0.66874242E-07
         961          958   0.00000000E+00
         961          959   0.00000000E+00
         961          960  -0.31898078E-05
         961          971  -0.20354690E-04
         961          972   0.00000000E+00
         961          973   0.00000000E+00
         961          974   0.00000000E+00
         961          975   0.00000000E+00
         961          976  -0.16601260E-06
         961          977  -0.15818581E-06
         961          978   0.00000000E+00
         961          979   0.00000000E+00
         961          980  -0.75452416E-05
         962          962   0.45530261E+04
         962          961   0.00000000E+00
         962          963   0.00000000E+00
         962          964   0.63450217E+01
         962          965   0.63450217E+01
         962          966   0.00000000E+00
         962          967  -0.21136331E+02
         962          968   0.00000000E+00
         962          969   0.00000000E+00
         962          970   0.18333990E+03
         962          951   0.00000000E+00
         962          952  -0.54157961E-05
         962          953   0.00000000E+00
         962          954   0.00000000E+00
         962          955   0.00000000E+00
         962          956   0.00000000E+00
         962          957   0.00000000E+00
         962          958   0.00000000E+00
         962          959   0.00000000E+00
         962          960  -0.21818301E-06
         962          971   0.00000000E+00
         962          972  -0.12810644E-04
         962          973   0.00000000E+00
         962          974   0.00000000E+00
         962          975   0.00000000E+00
         962          976   0.00000000E+00
         962          977   0.00000000E+00
         962          978   0.00000000E+00
         962          979   0.00000000E+00
         962          980  -0.51609489E-06
         963          963   0.57644877E+03
         963          961   0.00000000E+00
         963          962   0.00000000E+00
         963          964   0.00000000E+00
         963          965   0.00000000E+00
         963          966   0.00000000E+00
         963          967   0.00000000E+00
         963          968   0.00000000E+00
         963          969   0.00000000E+00
         963          970   0.00000000E+00
         963          951   0.00000000E+00
         963          952   0.00000000E+00
         963          953  -0.68600084E-06
         963          954   0.00000000E+00
         963          955   0.00000000E+00
         963          956   0.00000000E+00
         963          957   0.00000000E+00
         963          958   0.00000000E+00
         963          959   0.00000000E+00
         963          960   0.00000000E+00
         963          971   0.00000000E+00
         963          972   0.00000000E+00
         963          973  -0.16226815E-05
         963          974   0.00000000E+00
         963          975   0.00000000E+00
         963          976   0.00000000E+00
         963          977   0.00000000E+00
         963          978   0.00000000E+00
         963          979   0.00000000E+00
         963          980   0.00000000E+00
         964          964   0.99495276E+03
         964          961   0.00000000E+00
         964          962   0.63443872E+01
         964          963   0.00000000E+00
         964          965   0.19035065E+02
         964          966   0.00000000E+00
         964          967  -0.65201358E+02
         964          968   0.00000000E+00
         964          969   0.00000000E+00
         964          970   0.00000000E+00
         964          951   0.00000000E+00
         964          952   0.00000000E+00
         964          953   0.00000000E+00
         964          954  -0.11613874E-05
         964          955   0.00000000E+00
         964          956   0.00000000E+00
         964          957   0.21329994E-08
         964          958   0.00000000E+00
         964          959   0.00000000E+00
         964          960   0.00000000E+00
         964          971   0.00000000E+00
         964          972   0.00000000E+00
         964          973   0.00000000E+00
         964          974  -0.27471713E-05
         964          975   0.00000000E+00
         964          976   0.00000000E+00
         964          977   0.50454439E-08
         964          978   0.00000000E+00
         964          979   0.00000000E+00
         964          980   0.00000000E+00
         965          965   0.19048194E+02
         965          961   0.00000000E+00
         965          962   0.63443872E+01
         965          963   0.00000000E+00
         965          964   0.19035065E+02
         965          966   0.00000000E+00
         965          967  -0.63459865E+02
         965          968   0.00000000E+00
         965          969   0.00000000E+00
         965          970   0.16090829E-05
         965          951   0.00000000E+00
         965          952   0.00000000E+00
         965          953   0.00000000E+00
         965          954   0.00000000E+00
         965          955  -0.15585459E-10
         965          956   0.00000000E+00
         965          957   0.60424257E-10
         965          958   0.00000000E+00
         965          959   0.00000000E+00
         965          960  -0.19148834E-14
         965          971   0.00000000E+00
         965          972   0.00000000E+00
         965          973   0.00000000E+00
         965          974   0.00000000E+00
         965          975  -0.36866187E-10
         965          976   0.00000000E+00
         965          977   0.14292887E-09
         965          978   0.00000000E+00
         965          979   0.00000000E+00
         965          980  -0.45295075E-14
         966          966   0.13427538E+04
         966          961   0.58975289E+02
         966          962   0.00000000E+00
         966          963   0.00000000E+00
         966          964   0.00000000E+00
         966          965   0.00000000E+00
         966          967   0.16072447E+04
         966          968   0.00000000E+00
         966          969   0.43198833E-04
         966          970   0.00000000E+00
         966          951  -0.70183079E-07
         966          952   0.00000000E+00
         966          953   0.00000000E+00
         966          954   0.00000000E+00
         966          955   0.00000000E+00
         966          956  -0.76154902E-04
         966          957  -0.15103408E-03
         966          958   0.00000000E+00
         966          959   0.00000000E+00
         966          960   0.00000000E+00
         966          971  -0.16601260E-06
         966          972   0.00000000E+00
         966          973   0.00000000E+00
         966          974   0.00000000E+00
         966          975   0.00000000E+00
         966          976  -0.78208263E-04
         966          977  -0.15338870E-03
         966          978   0.00000000E+00
         966          979   0.00000000E+00
         966          980   0.00000000E+00
         967          967   0.23570477E+04
         967          961   0.56194646E+02
         967          962  -0.21147957E+02
         967          963   0.00000000E+00
         967          964  -0.65242762E+02
         967          965  -0.63501102E+02
         967          966   0.16072179E+04
         967          968  -0.37170093E-04
         967          969  -0.88854316E-01
         967          970   0.36552456E-01
         967          951  -0.66874242E-07
         967          952   0.00000000E+00
         967          953   0.00000000E+00
         967          954   0.21332127E-08
         967          955   0.60439139E-10
         967          956  -0.15102659E-03
         967          957  -0.30079623E-03
         967          958   0.57646701E-14
         967          959   0.10575176E-09
         967          960  -0.43477134E-10
         967          971  -0.15818581E-06
         967          972   0.00000000E+00
         967          973   0.00000000E+00
         967          974   0.50459484E-08
         967          975   0.14296407E-09
         967          976  -0.15338118E-03
         967          977  -0.30376876E-03
         967          978   0.13635878E-13
         967          979   0.25014755E-09
         967          980  -0.10284177E-09
         968          968   0.63759500E-04
         968          961   0.00000000E+00
         968          962   0.00000000E+00
         968          963   0.00000000E+00
         968          964   0.00000000E+00
         968          965   0.00000000E+00
         968          966   0.00000000E+00
         968          967  -0.37179375E-04
         968          969  -0.15265675E-04
         968          970  -0.35817298E-04
         968          951   0.00000000E+00
         968          952   0.00000000E+00
         968          953   0.00000000E+00
         968          954   0.00000000E+00
         968          955   0.00000000E+00
         968          956   0.00000000E+00
         968          957   0.57651354E-14
         968          958  -0.85551982E-14
         968          959  -0.10721998E-14
         968          960   0.41442005E-14
         968          971   0.00000000E+00
         968          972   0.00000000E+00
         968          973   0.00000000E+00
         968          974   0.00000000E+00
         968          975   0.00000000E+00
         968          976   0.00000000E+00
         968          977   0.13636978E-13
         968          978  -0.20236654E-13
         968          979  -0.25362050E-14
         968          980   0.98027833E-14
         969          969   0.73350633E+02
         969          961   0.00000000E+00
         969          962   0.00000000E+00
         969          963   0.00000000E+00
         969          964   0.00000000E+00
         969          965   0.00000000E+00
         969          966   0.43198833E-04
         969          967  -0.88845430E-01
         969          968  -0.15262072E-04
         969          970   0.24758777E+02
         969          951   0.00000000E+00
         969          952   0.00000000E+00
         969          953   0.00000000E+00
         969          954   0.00000000E+00
         969          955   0.00000000E+00
         969          956   0.00000000E+00
         969          957   0.10574119E-09
         969          958  -0.10721596E-14
         969          959  -0.87290608E-07
         969          960  -0.29464085E-07
         969          971   0.00000000E+00
         969          972   0.00000000E+00
         969          973   0.00000000E+00
         969          974   0.00000000E+00
         969          975   0.00000000E+00
         969          976   0.00000000E+00
         969          977   0.25012254E-09
         969          978  -0.25361099E-14
         969          979  -0.20647913E-06
         969          980  -0.69694996E-07
         970          970   0.99553723E+04
         970          961   0.26804064E+04
         970          962   0.18333990E+03
         970          963   0.00000000E+00
         970          964   0.00000000E+00
         970          965   0.16090605E-05
         970          966   0.00000000E+00
         970          967   0.36552456E-01
         970          968  -0.35807885E-04
         970          969   0.24758777E+02
         970          951  -0.31898078E-05
         970          952  -0.21818301E-06
         970          953   0.00000000E+00
         970          954   0.00000000E+00
         970          955  -0.19148568E-14
         970          956   0.00000000E+00
         970          957  -0.43477134E-10
         970          958   0.41435790E-14
         970          959  -0.29464085E-07
         970          960  -0.11847355E-04
         970          971  -0.75452416E-05
         970          972  -0.51609489E-06
         970          973   0.00000000E+00
         970          974   0.00000000E+00
         970          975  -0.45294445E-14
         970          976   0.00000000E+00
         970          977  -0.10284177E-09
         970          978   0.98013130E-14
         970          979  -0.69694996E-07
         970          980  -0.28023996E-04
         971          971   0.72308469E+04
         971          972   0.00000000E+00
         971          973   0.00000000E+00
         971          974   0.00000000E+00
         971          975   0.00000000E+00
         971          976   0.58974909E+02
         971          977   0.56194284E+02
         971          978   0.00000000E+00
         971          979   0.00000000E+00
         971          980   0.26803891E+04
         971          961  -0.86048945E-05
         971          962   0.00000000E+00
         971          963   0.00000000E+00
         971          964   0.00000000E+00
         971          965   0.00000000E+00
         971          966  -0.70181412E-07
         971          967  -0.66872654E-07
         971          968   0.00000000E+00
         971          969   0.00000000E+00
         971          970  -0.31897320E-05
         971          981  -0.20354526E-04
         971          982   0.00000000E+00
         971          983   0.00000000E+00
         971          984   0.00000000E+00
         971          985   0.00000000E+00
         971          986  -0.16601126E-06
         971          987  -0.15818453E-06
         971          988   0.00000000E+00
         971          989   0.00000000E+00
         971          990  -0.75451806E-05
         972          972   0.45529968E+04
         972          971   0.00000000E+00
         972          973   0.00000000E+00
         972          974   0.63450217E+01
         972          975   0.63450217E+01
         972          976   0.00000000E+00
         972          977  -0.21136331E+02
         972          978   0.00000000E+00
         972          979   0.00000000E+00
         972          980   0.18333872E+03
         972          961   0.00000000E+00
         972          962  -0.54156675E-05
         972          963   0.00000000E+00
         972          964   0.00000000E+00
         972          965   0.00000000E+00
         972          966   0.00000000E+00
         972          967   0.00000000E+00
         972          968   0.00000000E+00
         972          969   0.00000000E+00
         972          970  -0.21817783E-06
         972          981   0.00000000E+00
         972          982  -0.12810540E-04
         972          983   0.00000000E+00
         972          984   0.00000000E+00
         972          985   0.00000000E+00
         972          986   0.00000000E+00
         972          987   0.00000000E+00
         972          988   0.00000000E+00
         972          989   0.00000000E+00
         972          990  -0.51609072E-06
         973          973   0.57644505E+03
         973          971   0.00000000E+00
         973          972   0.00000000E+00
         973          974   0.00000000E+00
         973          975   0.00000000E+00
         973          976   0.00000000E+00
         973          977   0.00000000E+00
         973          978   0.00000000E+00
         973          979   0.00000000E+00
         973          980   0.00000000E+00
         973          961   0.00000000E+00
         973          962   0.00000000E+00
         973          963  -0.68598455E-06
         973          964   0.00000000E+00
         973          965   0.00000000E+00
         973          966   0.00000000E+00
         973          967   0.00000000E+00
         973          968   0.00000000E+00
         973          969   0.00000000E+00
         973          970   0.00000000E+00
         973          981   0.00000000E+00
         973          982   0.00000000E+00
         973          983  -0.16226684E-05
         973          984   0.00000000E+00
         973          985   0.00000000E+00
         973          986   0.00000000E+00
         973          987   0.00000000E+00
         973          988   0.00000000E+00
         973          989   0.00000000E+00
         973          990   0.00000000E+00
         974          974   0.99494646E+03
         974          971   0.00000000E+00
         974          972   0.63443872E+01
         974          973   0.00000000E+00
         974          975   0.19035065E+02
         974          976   0.00000000E+00
         974          977  -0.65201347E+02
         974          978   0.00000000E+00
         974          979   0.00000000E+00
         974          980   0.00000000E+00
         974          961   0.00000000E+00
         974          962   0.00000000E+00
         974          963   0.00000000E+00
         974          964  -0.11613598E-05
         974          965   0.00000000E+00
         974          966   0.00000000E+00
         974          967   0.21329488E-08
         974          968   0.00000000E+00
         974          969   0.00000000E+00
         974          970   0.00000000E+00
         974          981   0.00000000E+00
         974          982   0.00000000E+00
         974          983   0.00000000E+00
         974          984  -0.27471491E-05
         974          985   0.00000000E+00
         974          986   0.00000000E+00
         974          987   0.50454031E-08
         974          988   0.00000000E+00
         974          989   0.00000000E+00
         974          990   0.00000000E+00
         975          975   0.19048194E+02
         975          971   0.00000000E+00
         975          972   0.63443872E+01
         975          973   0.00000000E+00
         975          974   0.19035065E+02
         975          976   0.00000000E+00
         975          977  -0.63459864E+02
         975          978   0.00000000E+00
         975          979   0.00000000E+00
         975          980   0.16090725E-05
         975          961   0.00000000E+00
         975          962   0.00000000E+00
         975          963   0.00000000E+00
         975          964   0.00000000E+00
         975          965  -0.15585088E-10
         975          966   0.00000000E+00
         975          967   0.60422822E-10
         975          968   0.00000000E+00
         975          969   0.00000000E+00
         975          970  -0.19148380E-14
         975          981   0.00000000E+00
         975          982   0.00000000E+00
         975          983   0.00000000E+00
         975          984   0.00000000E+00
         975          985  -0.36865889E-10
         975          986   0.00000000E+00
         975          987   0.14292771E-09
         975          988   0.00000000E+00
         975          989   0.00000000E+00
         975          990  -0.45294708E-14
         976          976   0.13427472E+04
         976          971   0.58974909E+02
         976          972   0.00000000E+00
         976          973   0.00000000E+00
         976          974   0.00000000E+00
         976          975   0.00000000E+00
         976          977   0.16072384E+04
         976          978   0.00000000E+00
         976          979   0.43198833E-04
         976          980   0.00000000E+00
         976          961  -0.70181412E-07
         976          962   0.00000000E+00
         976          963   0.00000000E+00
         976          964   0.00000000E+00
         976          965   0.00000000E+00
         976          966  -0.76159937E-04
         976          967  -0.15104418E-03
         976          968   0.00000000E+00
         976          969   0.00000000E+00
         976          970   0.00000000E+00
         976          981  -0.16601126E-06
         976          982   0.00000000E+00
         976          983   0.00000000E+00
         976          984   0.00000000E+00
         976          985   0.00000000E+00
         976          986  -0.78212323E-04
         976          987  -0.15339685E-03
         976          988   0.00000000E+00
         976          989   0.00000000E+00
         976          990   0.00000000E+00
         977          977   0.23570420E+04
         977          971   0.56194284E+02
         977          972  -0.21147957E+02
         977          973   0.00000000E+00
         977          974  -0.65242751E+02
         977          975  -0.63501102E+02
         977          976   0.16072116E+04
         977          978  -0.37170062E-04
         977          979  -0.88853743E-01
         977          980   0.36552220E-01
         977          961  -0.66872654E-07
         977          962   0.00000000E+00
         977          963   0.00000000E+00
         977          964   0.21331621E-08
         977          965   0.60437704E-10
         977          966  -0.15103669E-03
         977          967  -0.30081646E-03
         977          968   0.57645332E-14
         977          969   0.10574925E-09
         977          970  -0.43476101E-10
         977          981  -0.15818453E-06
         977          982   0.00000000E+00
         977          983   0.00000000E+00
         977          984   0.50459076E-08
         977          985   0.14296292E-09
         977          986  -0.15338933E-03
         977          987  -0.30378507E-03
         977          988   0.13635767E-13
         977          989   0.25014552E-09
         977          990  -0.10284094E-09
         978          978   0.63759453E-04
         978          971   0.00000000E+00
         978          972   0.00000000E+00
         978          973   0.00000000E+00
         978          974   0.00000000E+00
         978          975   0.00000000E+00
         978          976   0.00000000E+00
         978          977  -0.37179343E-04
         978          979  -0.15265681E-04
         978          980  -0.35817275E-04
         978          961   0.00000000E+00
         978          962   0.00000000E+00
         978          963   0.00000000E+00
         978          964   0.00000000E+00
         978          965   0.00000000E+00
         978          966   0.00000000E+00
         978          967   0.57649985E-14
         978          968  -0.85549950E-14
         978          969  -0.10721743E-14
         978          970   0.41441021E-14
         978          981   0.00000000E+00
         978          982   0.00000000E+00
         978          983   0.00000000E+00
         978          984   0.00000000E+00
         978          985   0.00000000E+00
         978          986   0.00000000E+00
         978          987   0.13636868E-13
         978          988  -0.20236490E-13
         978          989  -0.25361845E-14
         978          990   0.98027039E-14
         979          979   0.73350160E+02
         979          971   0.00000000E+00
         979          972   0.00000000E+00
         979          973   0.00000000E+00
         979          974   0.00000000E+00
         979          975   0.00000000E+00
         979          976   0.43198833E-04
         979          977  -0.88844857E-01
         979          978  -0.15262078E-04
         979          980   0.24758617E+02
         979          961   0.00000000E+00
         979          962   0.00000000E+00
         979          963   0.00000000E+00
         979          964   0.00000000E+00
         979          965   0.00000000E+00
         979          966   0.00000000E+00
         979          967   0.10573868E-09
         979          968  -0.10721341E-14
         979          969  -0.87288535E-07
         979          970  -0.29463385E-07
         979          981   0.00000000E+00
         979          982   0.00000000E+00
         979          983   0.00000000E+00
         979          984   0.00000000E+00
         979          985   0.00000000E+00
         979          986   0.00000000E+00
         979          987   0.25012051E-09
         979          988  -0.25360894E-14
         979          989  -0.20647746E-06
         979          990  -0.69694432E-07
         980          980   0.99553081E+04
         980          971   0.26803891E+04
         980          972   0.18333872E+03
         980          973   0.00000000E+00
         980          974   0.00000000E+00
         980          975   0.16090501E-05
         980          976   0.00000000E+00
         980          977   0.36552220E-01
         980          978  -0.35807863E-04
         980          979   0.24758617E+02
         980          961  -0.31897320E-05
         980          962  -0.21817783E-06
         980          963   0.00000000E+00
         980          964   0.00000000E+00
         980          965  -0.19148113E-14
         980          966   0.00000000E+00
         980          967  -0.43476101E-10
         980          968   0.41434806E-14
         980          969  -0.29463385E-07
         980          970  -0.11847074E-04
         980          981  -0.75451806E-05
         980          982  -0.51609072E-06
         980          983   0.00000000E+00
         980          984   0.00000000E+00
         980          985  -0.45294079E-14
         980          986   0.00000000E+00
         980          987  -0.10284094E-09
         980          988   0.98012337E-14
         980          989  -0.69694432E-07
         980          990  -0.28023769E-04
         981          981   0.72308093E+04
         981          982   0.00000000E+00
         981          983   0.00000000E+00
         981          984   0.00000000E+00
         981          985   0.00000000E+00
         981          986   0.58974602E+02
         981          987   0.56193992E+02
         981          988   0.00000000E+00
         981          989   0.00000000E+00
         981          990   0.26803752E+04
         981          971  -0.86047297E-05
         981          972   0.00000000E+00
         981          973   0.00000000E+00
         981          974   0.00000000E+00
         981          975   0.00000000E+00
         981          976  -0.70180069E-07
         981          977  -0.66871373E-07
         981          978   0.00000000E+00
         981          979   0.00000000E+00
         981          980  -0.31896710E-05
         981          991  -0.20354393E-04
         981          992   0.00000000E+00
         981          993   0.00000000E+00
         981          994   0.00000000E+00
         981          995   0.00000000E+00
         981          996  -0.16601018E-06
         981          997  -0.15818349E-06
         981          998   0.00000000E+00
         981          999   0.00000000E+00
         981         1000  -0.75451313E-05
         982          982   0.45529731E+04
         982          981   0.00000000E+00
         982          983   0.00000000E+00
         982          984   0.63450217E+01
         982          985   0.63450217E+01
         982          986   0.00000000E+00
         982          987  -0.21136331E+02
         982          988   0.00000000E+00
         982          989   0.00000000E+00
         982          990   0.18333776E+03
         982          971   0.00000000E+00
         982          972  -0.54155638E-05
         982          973   0.00000000E+00
         982          974   0.00000000E+00
         982          975   0.00000000E+00
         982          976   0.00000000E+00
         982          977   0.00000000E+00
         982          978   0.00000000E+00
         982          979   0.00000000E+00
         982          980  -0.21817365E-06
         982          991   0.00000000E+00
         982          992  -0.12810456E-04
         982          993   0.00000000E+00
         982          994   0.00000000E+00
         982          995   0.00000000E+00
         982          996   0.00000000E+00
         982          997   0.00000000E+00
         982          998   0.00000000E+00
         982          999   0.00000000E+00
         982         1000  -0.51608735E-06
         983          983   0.57644205E+03
         983          981   0.00000000E+00
         983          982   0.00000000E+00
         983          984   0.00000000E+00
         983          985   0.00000000E+00
         983          986   0.00000000E+00
         983          987   0.00000000E+00
         983          988   0.00000000E+00
         983          989   0.00000000E+00
         983          990   0.00000000E+00
         983          971   0.00000000E+00
         983          972   0.00000000E+00
         983          973  -0.68597141E-06
         983          974   0.00000000E+00
         983          975   0.00000000E+00
         983          976   0.00000000E+00
         983          977   0.00000000E+00
         983          978   0.00000000E+00
         983          979   0.00000000E+00
         983          980   0.00000000E+00
         983          991   0.00000000E+00
         983          992   0.00000000E+00
         983          993  -0.16226578E-05
         983          994   0.00000000E+00
         983          995   0.00000000E+00
         983          996   0.00000000E+00
         983          997   0.00000000E+00
         983          998   0.00000000E+00
         983          999   0.00000000E+00
         983         1000   0.00000000E+00
         984          984   0.99494139E+03
         984          981   0.00000000E+00
         984          982   0.63443872E+01
         984          983   0.00000000E+00
         984          985   0.19035065E+02
         984          986   0.00000000E+00
         984          987  -0.65201338E+02
         984          988   0.00000000E+00
         984          989   0.00000000E+00
         984          990   0.00000000E+00
         984          971   0.00000000E+00
         984          972   0.00000000E+00
         984          973   0.00000000E+00
         984          974  -0.11613376E-05
         984          975   0.00000000E+00
         984          976   0.00000000E+00
         984          977   0.21329079E-08
         984          978   0.00000000E+00
         984          979   0.00000000E+00
         984          980   0.00000000E+00
         984          991   0.00000000E+00
         984          992   0.00000000E+00
         984          993   0.00000000E+00
         984          994  -0.27471312E-05
         984          995   0.00000000E+00
         984          996   0.00000000E+00
         984          997   0.50453701E-08
         984          998   0.00000000E+00
         984          999   0.00000000E+00
         984         1000   0.00000000E+00
         985          985   0.19048194E+02
         985          981   0.00000000E+00
         985          982   0.63443872E+01
         985          983   0.00000000E+00
         985          984   0.19035065E+02
         985          986   0.00000000E+00
         985          987  -0.63459864E+02
         985          988   0.00000000E+00
         985          989   0.00000000E+00
         985          990   0.16090641E-05
         985          971   0.00000000E+00
         985          972   0.00000000E+00
         985          973   0.00000000E+00
         985          974   0.00000000E+00
         985          975  -0.15584790E-10
         985          976   0.00000000E+00
         985          977   0.60421665E-10
         985          978   0.00000000E+00
         985          979   0.00000000E+00
         985          980  -0.19148013E-14
         985          991   0.00000000E+00
         985          992   0.00000000E+00
         985          993   0.00000000E+00
         985          994   0.00000000E+00
         985          995  -0.36865648E-10
         985          996   0.00000000E+00
         985          997   0.14292678E-09
         985          998   0.00000000E+00
         985          999   0.00000000E+00
         985         1000  -0.45294413E-14
         986          986   0.13427418E+04
         986          981   0.58974602E+02
         986          982   0.00000000E+00
         986          983   0.00000000E+00
         986          984   0.00000000E+00
         986          985   0.00000000E+00
         986          987   0.16072333E+04
         986          988   0.00000000E+00
         986          989   0.43198833E-04
         986          990   0.00000000E+00
         986          971  -0.70180069E-07
         986          972   0.00000000E+00
         986          973   0.00000000E+00
         986          974   0.00000000E+00
         986          975   0.00000000E+00
         986          976  -0.76163997E-04
         986          977  -0.15105232E-03
         986          978   0.00000000E+00
         986          979   0.00000000E+00
         986          980   0.00000000E+00
         986          991  -0.16601018E-06
         986          992   0.00000000E+00
         986          993   0.00000000E+00
         986          994   0.00000000E+00
         986          995   0.00000000E+00
         986          996  -0.78215596E-04
         986          997  -0.15340341E-03
         986          998   0.00000000E+00
         986          999   0.00000000E+00
         986         1000   0.00000000E+00
         987          987   0.23570374E+04
         987          981   0.56193992E+02
         987          982  -0.21147957E+02
         987          983   0.00000000E+00
         987          984  -0.65242742E+02
         987          985  -0.63501101E+02
         987          986   0.16072065E+04
         987          988  -0.37170037E-04
         987          989  -0.88853281E-01
         987          990   0.36552030E-01
         987          971  -0.66871373E-07
         987          972   0.00000000E+00
         987          973   0.00000000E+00
         987          974   0.21331212E-08
         987          975   0.60436547E-10
         987          976  -0.15104483E-03
         987          977  -0.30083277E-03
         987          978   0.57644228E-14
         987          979   0.10574723E-09
         987          980  -0.43475268E-10
         987          991  -0.15818349E-06
         987          992   0.00000000E+00
         987          993   0.00000000E+00
         987          994   0.50458747E-08
         987          995   0.14296198E-09
         987          996  -0.15339589E-03
         987          997  -0.30379822E-03
         987          998   0.13635678E-13
         987          999   0.25014389E-09
         987         1000  -0.10284027E-09
         988          988   0.63759416E-04
         988          981   0.00000000E+00
         988          982   0.00000000E+00
         988          983   0.00000000E+00
         988          984   0.00000000E+00
         988          985   0.00000000E+00
         988          986   0.00000000E+00
         988          987  -0.37179318E-04
         988          989  -0.15265685E-04
         988          990  -0.35817257E-04
         988          971   0.00000000E+00
         988          972   0.00000000E+00
         988          973   0.00000000E+00
         988          974   0.00000000E+00
         988          975   0.00000000E+00
         988          976   0.00000000E+00
         988          977   0.57648881E-14
         988          978  -0.85548312E-14
         988          979  -0.10721538E-14
         988          980   0.41440227E-14
         988          991   0.00000000E+00
         988          992   0.00000000E+00
         988          993   0.00000000E+00
         988          994   0.00000000E+00
         988          995   0.00000000E+00
         988          996   0.00000000E+00
         988          997   0.13636779E-13
         988          998  -0.20236358E-13
         988          999  -0.25361679E-14
         988         1000   0.98026400E-14
         989          989   0.73349779E+02
         989          981   0.00000000E+00
         989          982   0.00000000E+00
         989          983   0.00000000E+00
         989          984   0.00000000E+00
         989          985   0.00000000E+00
         989          986   0.43198833E-04
         989          987  -0.88844395E-01
         989          988  -0.15262082E-04
         989          990   0.24758489E+02
         989          971   0.00000000E+00
         989          972   0.00000000E+00
         989          973   0.00000000E+00
         989          974   0.00000000E+00
         989          975   0.00000000E+00
         989          976   0.00000000E+00
         989          977   0.10573665E-09
         989          978  -0.10721136E-14
         989          979  -0.87286863E-07
         989          980  -0.29462821E-07
         989          991   0.00000000E+00
         989          992   0.00000000E+00
         989          993   0.00000000E+00
         989          994   0.00000000E+00
         989          995   0.00000000E+00
         989          996   0.00000000E+00
         989          997   0.25011888E-09
         989          998  -0.25360728E-14
         989          999  -0.20647611E-06
         989         1000  -0.69693978E-07
         990          990   0.99552563E+04
         990          981   0.26803752E+04
         990          982   0.18333776E+03
         990          983   0.00000000E+00
         990          984   0.00000000E+00
         990          985   0.16090418E-05
         990          986   0.00000000E+00
         990          987   0.36552030E-01
         990          988  -0.35807844E-04
         990          989   0.24758489E+02
         990          971  -0.31896710E-05
         990          972  -0.21817365E-06
         990          973   0.00000000E+00
         990          974   0.00000000E+00
         990          975  -0.19147747E-14
         990          976   0.00000000E+00
         990          977  -0.43475268E-10
         990          978   0.41434012E-14
         990          979  -0.29462821E-07
         990          980  -0.11846847E-04
         990          991  -0.75451313E-05
         990          992  -0.51608735E-06
         990          993   0.00000000E+00
         990          994   0.00000000E+00
         990          995  -0.45293783E-14
         990          996   0.00000000E+00
         990          997  -0.10284027E-09
         990          998   0.98011698E-14
         990          999  -0.69693978E-07
         990         1000  -0.28023586E-04
         991          991   0.72307790E+04
         991          992   0.00000000E+00
         991          993   0.00000000E+00
         991          994   0.00000000E+00
         991          995   0.00000000E+00
         991          996   0.58974355E+02
         991          997   0.56193756E+02
         991          998   0.00000000E+00
         991          999   0.00000000E+00
         991         1000   0.26803640E+04
         991          981  -0.86045969E-05
         991          982   0.00000000E+00
         991          983   0.00000000E+00
         991          984   0.00000000E+00
         991          985   0.00000000E+00
         991          986  -0.70178985E-07
         991          987  -0.66870341E-07
         991          988   0.00000000E+00
         991          989   0.00000000E+00
         991          990  -0.31896217E-05
         991         1001  -0.20354286E-04
         991         1002   0.00000000E+00
         991         1003   0.00000000E+00
         991         1004   0.00000000E+00
         991         1005   0.00000000E+00
         991         1006  -0.16600930E-06
         991         1007  -0.15818266E-06
         991         1008   0.00000000E+00
         991         1009   0.00000000E+00
         991         1010  -0.75450916E-05
         992          992   0.45529541E+04
         992          991   0.00000000E+00
         992          993   0.00000000E+00
         992          994   0.63450217E+01
         992          995   0.63450217E+01
         992          996   0.00000000E+00
         992          997  -0.21136331E+02
         992          998   0.00000000E+00
         992          999   0.00000000E+00
         992         1000   0.18333700E+03
         992          981   0.00000000E+00
         992          982  -0.54154802E-05
         992          983   0.00000000E+00
         992          984   0.00000000E+00
         992          985   0.00000000E+00
         992          986   0.00000000E+00
         992          987   0.00000000E+00
         992          988   0.00000000E+00
         992          989   0.00000000E+00
         992          990  -0.21817028E-06
         992         1001   0.00000000E+00
         992         1002  -0.12810389E-04
         992         1003   0.00000000E+00
         992         1004   0.00000000E+00
         992         1005   0.00000000E+00
         992         1006   0.00000000E+00
         992         1007   0.00000000E+00
         992         1008   0.00000000E+00
         992         1009   0.00000000E+00
         992         1010  -0.51608463E-06
         993          993   0.57643964E+03
         993          991   0.00000000E+00
         993          992   0.00000000E+00
         993          994   0.00000000E+00
         993          995   0.00000000E+00
         993          996   0.00000000E+00
         993          997   0.00000000E+00
         993          998   0.00000000E+00
         993          999   0.00000000E+00
         993         1000   0.00000000E+00
         993          981   0.00000000E+00
         993          982   0.00000000E+00
         993          983  -0.68596082E-06
         993          984   0.00000000E+00
         993          985   0.00000000E+00
         993          986   0.00000000E+00
         993          987   0.00000000E+00
         993          988   0.00000000E+00
         993          989   0.00000000E+00
         993          990   0.00000000E+00
         993         1001   0.00000000E+00
         993         1002   0.00000000E+00
         993         1003  -0.16226492E-05
         993         1004   0.00000000E+00
         993         1005   0.00000000E+00
         993         1006   0.00000000E+00
         993         1007   0.00000000E+00
         993         1008   0.00000000E+00
         993         1009   0.00000000E+00
         993         1010   0.00000000E+00
         994          994   0.99493730E+03
         994          991   0.00000000E+00
         994          992   0.63443872E+01
         994          993   0.00000000E+00
         994          995   0.19035065E+02
         994          996   0.00000000E+00
         994          997  -0.65201330E+02
         994          998   0.00000000E+00
         994          999   0.00000000E+00
         994         1000   0.00000000E+00
         994          981   0.00000000E+00
         994          982   0.00000000E+00
         994          983   0.00000000E+00
         994          984  -0.11613196E-05
         994          985   0.00000000E+00
         994          986   0.00000000E+00
         994          987   0.21328750E-08
         994          988   0.00000000E+00
         994          989   0.00000000E+00
         994          990   0.00000000E+00
         994         1001   0.00000000E+00
         994         1002   0.00000000E+00
         994         1003   0.00000000E+00
         994         1004  -0.27471167E-05
         994         1005   0.00000000E+00
         994         1006   0.00000000E+00
         994         1007   0.50453436E-08
         994         1008   0.00000000E+00
         994         1009   0.00000000E+00
         994         1010   0.00000000E+00
         995          995   0.19048194E+02
         995          991   0.00000000E+00
         995          992   0.63443872E+01
         995          993   0.00000000E+00
         995          994   0.19035065E+02
         995          996   0.00000000E+00
         995          997  -0.63459864E+02
         995          998   0.00000000E+00
         995          999   0.00000000E+00
         995         1000   0.16090574E-05
         995          981   0.00000000E+00
         995          982   0.00000000E+00
         995          983   0.00000000E+00
         995          984   0.00000000E+00
         995          985  -0.15584549E-10
         995          986   0.00000000E+00
         995          987   0.60420732E-10
         995          988   0.00000000E+00
         995          989   0.00000000E+00
         995          990  -0.19147717E-14
         995         1001   0.00000000E+00
         995         1002   0.00000000E+00
         995         1003   0.00000000E+00
         995         1004   0.00000000E+00
         995         1005  -0.36865454E-10
         995         1006   0.00000000E+00
         995         1007   0.14292603E-09
         995         1008   0.00000000E+00
         995         1009   0.00000000E+00
         995         1010  -0.45294174E-14
         996          996   0.13427375E+04
         996          991   0.58974355E+02
         996          992   0.00000000E+00
         996          993   0.00000000E+00
         996          994   0.00000000E+00
         996          995   0.00000000E+00
         996          997   0.16072292E+04
         996          998   0.00000000E+00
         996          999   0.43198833E-04
         996         1000   0.00000000E+00
         996          981  -0.70178985E-07
         996          982   0.00000000E+00
         996          983   0.00000000E+00
         996          984   0.00000000E+00
         996          985   0.00000000E+00
         996          986  -0.76167269E-04
         996          987  -0.15105889E-03
         996          988   0.00000000E+00
         996          989   0.00000000E+00
         996          990   0.00000000E+00
         996         1001  -0.16600930E-06
         996         1002   0.00000000E+00
         996         1003   0.00000000E+00
         996         1004   0.00000000E+00
         996         1005   0.00000000E+00
         996         1006  -0.78218234E-04
         996         1007  -0.15340871E-03
         996         1008   0.00000000E+00
         996         1009   0.00000000E+00
         996         1010   0.00000000E+00
         997          997   0.23570336E+04
         997          991   0.56193756E+02
         997          992  -0.21147957E+02
         997          993   0.00000000E+00
         997          994  -0.65242734E+02
         997          995  -0.63501101E+02
         997          996   0.16072024E+04
         997          998  -0.37170017E-04
         997          999  -0.88852908E-01
         997         1000   0.36551877E-01
         997          981  -0.66870341E-07
         997          982   0.00000000E+00
         997          983   0.00000000E+00
         997          984   0.21330883E-08
         997          985   0.60435614E-10
         997          986  -0.15105140E-03
         997          987  -0.30084592E-03
         997          988   0.57643338E-14
         997          989   0.10574559E-09
         997          990  -0.43474597E-10
         997         1001  -0.15818266E-06
         997         1002   0.00000000E+00
         997         1003   0.00000000E+00
         997         1004   0.50458481E-08
         997         1005   0.14296123E-09
         997         1006  -0.15340119E-03
         997         1007  -0.30380882E-03
         997         1008   0.13635607E-13
         997         1009   0.25014257E-09
         997         1010  -0.10283973E-09
         998          998   0.63759386E-04
         998          991   0.00000000E+00
         998          992   0.00000000E+00
         998          993   0.00000000E+00
         998          994   0.00000000E+00
         998          995   0.00000000E+00
         998          996   0.00000000E+00
         998          997  -0.37179298E-04
         998          999  -0.15265689E-04
         998         1000  -0.35817242E-04
         998          981   0.00000000E+00
         998          982   0.00000000E+00
         998          983   0.00000000E+00
         998          984   0.00000000E+00
         998          985   0.00000000E+00
         998          986   0.00000000E+00
         998          987   0.57647991E-14
         998          988  -0.85546991E-14
         998          989  -0.10721372E-14
         998          990   0.41439588E-14
         998         1001   0.00000000E+00
         998         1002   0.00000000E+00
         998         1003   0.00000000E+00
         998         1004   0.00000000E+00
         998         1005   0.00000000E+00
         998         1006   0.00000000E+00
         998         1007   0.13636707E-13
         998         1008  -0.20236252E-13
         998         1009  -0.25361546E-14
         998         1010   0.98025883E-14
         999          999   0.73349472E+02
         999          991   0.00000000E+00
         999          992   0.00000000E+00
         999          993   0.00000000E+00
         999          994   0.00000000E+00
         999          995   0.00000000E+00
         999          996   0.43198833E-04
         999          997  -0.88844022E-01
         999          998  -0.15262086E-04
         999         1000   0.24758385E+02
         999          981   0.00000000E+00
         999          982   0.00000000E+00
         999          983   0.00000000E+00
         999          984   0.00000000E+00
         999          985   0.00000000E+00
         999          986   0.00000000E+00
         999          987   0.10573502E-09
         999          988  -0.10720970E-14
         999          989  -0.87285516E-07
         999          990  -0.29462366E-07
         999         1001   0.00000000E+00
         999         1002   0.00000000E+00
         999         1003   0.00000000E+00
         999         1004   0.00000000E+00
         999         1005   0.00000000E+00
         999         1006   0.00000000E+00
         999         1007   0.25011756E-09
         999         1008  -0.25360595E-14
         999         1009  -0.20647502E-06
         999         1010  -0.69693611E-07
        1000         1000   0.99552146E+04
        1000          991   0.26803640E+04
        1000          992   0.18333700E+03
        1000          993   0.00000000E+00
        1000          994   0.00000000E+00
        1000          995   0.16090350E-05
        1000          996   0.00000000E+00
        1000          997   0.36551877E-01
        1000          998  -0.35807830E-04
        1000          999   0.24758385E+02
        1000          981  -0.31896217E-05
        1000          982  -0.21817028E-06
        1000          983   0.00000000E+00
        1000          984   0.00000000E+00
        1000          985  -0.19147451E-14
        1000          986   0.00000000E+00
        1000          987  -0.43474597E-10
        1000          988   0.41433373E-14
        1000          989  -0.29462366E-07
        1000          990  -0.11846664E-04
        1000         1001  -0.75450916E-05
        1000         1002  -0.51608463E-06
        1000         1003   0.00000000E+00
        1000         1004   0.00000000E+00
        1000         1005  -0.45293545E-14
        1000         1006   0.00000000E+00
        1000         1007  -0.10283973E-09
        1000         1008   0.98011182E-14
        1000         1009  -0.69693611E-07
        1000         1010  -0.28023439E-04
        1001         1001   0.36153773E+04
        1001         1002   0.00000000E+00
        1001         1003   0.00000000E+00
        1001         1004   0.00000000E+00
        1001         1005   0.00000000E+00
        1001         1006   0.29487078E+02
        1001         1007   0.28096783E+02
        1001         1008   0.00000000E+00
        1001         1009   0.00000000E+00
        1001         1010   0.13401775E+04
        1001          991  -0.86044898E-05
        1001          992   0.00000000E+00
        1001          993   0.00000000E+00
        1001          994   0.00000000E+00
        1001          995   0.00000000E+00
        1001          996  -0.70178112E-07
        1001          997  -0.66869509E-07
        1001          998   0.00000000E+00
        1001          999   0.00000000E+00
        1001         1000  -0.31895820E-05
        1002         1002   0.22764694E+04
        1002         1001   0.00000000E+00
        1002         1003   0.00000000E+00
        1002         1004   0.31725108E+01
        1002         1005   0.31725108E+01
        1002         1006   0.00000000E+00
        1002         1007  -0.10568165E+02
        1002         1008   0.00000000E+00
        1002         1009   0.00000000E+00
        1002         1010   0.91668189E+02
        1002          991   0.00000000E+00
        1002          992  -0.54154128E-05
        1002          993   0.00000000E+00
        1002          994   0.00000000E+00
        1002          995   0.00000000E+00
        1002          996   0.00000000E+00
        1002          997   0.00000000E+00
        1002          998   0.00000000E+00
        1002          999   0.00000000E+00
        1002         1000  -0.21816756E-06
        1003         1003   0.28821885E+03
        1003         1001   0.00000000E+00
        1003         1002   0.00000000E+00
        1003         1004   0.00000000E+00
        1003         1005   0.00000000E+00
        1003         1006   0.00000000E+00
        1003         1007   0.00000000E+00
        1003         1008   0.00000000E+00
        1003         1009   0.00000000E+00
        1003         1010   0.00000000E+00
        1003          991   0.00000000E+00
        1003          992   0.00000000E+00
        1003          993  -0.68595229E-06
        1003          994   0.00000000E+00
        1003          995   0.00000000E+00
        1003          996   0.00000000E+00
        1003          997   0.00000000E+00
        1003          998   0.00000000E+00
        1003          999   0.00000000E+00
        1003         1000   0.00000000E+00
        1004         1004   0.49746701E+03
        1004         1001   0.00000000E+00
        1004         1002   0.31721936E+01
        1004         1003   0.00000000E+00
        1004         1005   0.95175325E+01
        1004         1006   0.00000000E+00
        1004         1007  -0.32600662E+02
        1004         1008   0.00000000E+00
        1004         1009   0.00000000E+00
        1004         1010   0.00000000E+00
        1004          991   0.00000000E+00
        1004          992   0.00000000E+00
        1004          993   0.00000000E+00
        1004          994  -0.11613052E-05
        1004          995   0.00000000E+00
        1004          996   0.00000000E+00
        1004          997   0.21328485E-08
        1004          998   0.00000000E+00
        1004          999   0.00000000E+00
        1004         1000   0.00000000E+00
        1005         1005   0.95240970E+01
        1005         1001   0.00000000E+00
        1005         1002   0.31721936E+01
        1005         1003   0.00000000E+00
        1005         1004   0.95175325E+01
        1005         1006   0.00000000E+00
        1005         1007  -0.31729932E+02
        1005         1008   0.00000000E+00
        1005         1009   0.00000000E+00
        1005         1010   0.80452598E-06
        1005          991   0.00000000E+00
        1005          992   0.00000000E+00
        1005          993   0.00000000E+00
        1005          994   0.00000000E+00
        1005          995  -0.15584355E-10
        1005          996   0.00000000E+00
        1005          997   0.60419980E-10
        1005          998   0.00000000E+00
        1005          999   0.00000000E+00
        1005         1000  -0.19147479E-14
        1006         1006   0.67136733E+03
        1006         1001   0.29487078E+02
        1006         1002   0.00000000E+00
        1006         1003   0.00000000E+00
        1006         1004   0.00000000E+00
        1006         1005   0.00000000E+00
        1006         1007   0.80361356E+03
        1006         1008   0.00000000E+00
        1006         1009   0.21599416E-04
        1006         1010   0.00000000E+00
        1006          991  -0.70178112E-07
        1006          992   0.00000000E+00
        1006          993   0.00000000E+00
        1006          994   0.00000000E+00
        1006          995   0.00000000E+00
        1006          996  -0.76169908E-04
        1006          997  -0.15106418E-03
        1006          998   0.00000000E+00
        1006          999   0.00000000E+00
        1006         1000   0.00000000E+00
        1007         1007   0.11785165E+04
        1007         1001   0.28096783E+02
        1007         1002  -0.10573979E+02
        1007         1003   0.00000000E+00
        1007         1004  -0.32621364E+02
        1007         1005  -0.31750550E+02
        1007         1006   0.80360015E+03
        1007         1008  -0.18585000E-04
        1007         1009  -0.44426305E-01
        1007         1010   0.18275877E-01
        1007          991  -0.66869509E-07
        1007          992   0.00000000E+00
        1007          993   0.00000000E+00
        1007          994   0.21330618E-08
        1007          995   0.60434862E-10
        1007          996  -0.15105669E-03
        1007          997  -0.30085653E-03
        1007          998   0.57642621E-14
        1007          999   0.10574428E-09
        1007         1000  -0.43474056E-10
        1008         1008   0.31879681E-04
        1008         1001   0.00000000E+00
        1008         1002   0.00000000E+00
        1008         1003   0.00000000E+00
        1008         1004   0.00000000E+00
        1008         1005   0.00000000E+00
        1008         1006   0.00000000E+00
        1008         1007  -0.18589641E-04
        1008         1009  -0.76328461E-05
        1008         1010  -0.17908615E-04
        1008          991   0.00000000E+00
        1008          992   0.00000000E+00
        1008          993   0.00000000E+00
        1008          994   0.00000000E+00
        1008          995   0.00000000E+00
        1008          996   0.00000000E+00
        1008          997   0.57647274E-14
        1008          998  -0.85545926E-14
        1008          999  -0.10721239E-14
        1008         1000   0.41439072E-14
        1009         1009   0.36674612E+02
        1009         1001   0.00000000E+00
        1009         1002   0.00000000E+00
        1009         1003   0.00000000E+00
        1009         1004   0.00000000E+00
        1009         1005   0.00000000E+00
        1009         1006   0.21599416E-04
        1009         1007  -0.44421862E-01
        1009         1008  -0.76310445E-05
        1009         1010   0.12379151E+02
        1009          991   0.00000000E+00
        1009          992   0.00000000E+00
        1009          993   0.00000000E+00
        1009          994   0.00000000E+00
        1009          995   0.00000000E+00
        1009          996   0.00000000E+00
        1009          997   0.10573370E-09
        1009          998  -0.10720837E-14
        1009          999  -0.87284430E-07
        1009         1000  -0.29462000E-07
        1010         1010   0.49775905E+04
        1010         1001   0.13401775E+04
        1010         1002   0.91668189E+02
        1010         1003   0.00000000E+00
        1010         1004   0.00000000E+00
        1010         1005   0.80451479E-06
        1010         1006   0.00000000E+00
        1010         1007   0.18275877E-01
        1010         1008  -0.17903909E-04
        1010         1009   0.12379151E+02
        1010          991  -0.31895820E-05
        1010          992  -0.21816756E-06
        1010          993   0.00000000E+00
        1010          994   0.00000000E+00
        1010          995  -0.19147213E-14
        1010          996   0.00000000E+00
        1010          997  -0.43474056E-10
        1010          998   0.41432857E-14
        1010          999  -0.29462000E-07
        1010         1000  -0.11846517E-04
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140122/266abaa1/attachment-0002.png>
        1010
 -3.449869938711822E-004
  -1.05741178096217
  0.000000000000000E+000
  -3.17219351605396
  -3.17218826825896
 -7.887598353594752E-005
   10.5738682044873
  5.233241132884998E-007
 -3.389991959634191E-006
 -3.559078687230301E-004
 -6.899739877423644E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
 -1.577519670718950E-004
   21.1477364089746
  1.046648226577000E-006
 -6.779983919268382E-006
 -7.118157374460602E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
 -6.899739877423754E-004
  -2.11482356192435
 -8.748791553952855E-019
  -6.34438703210792
  -6.34437653651792
 -1.577519670718970E-004
   21.1477364089746
 -6.779983919268493E-006
 -7.118157374460753E-004
 -6.899739877423425E-004
  -2.11482356192435
  1.749652431672164E-018
  -6.34438703210792
  -6.34437653651792
 -1.577519670718912E-004
   21.1477364089746
 -6.779983919268159E-006
 -7.118157374460300E-004
  -2.11482356192435
 -8.747732762768787E-019
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
 -6.899739877423535E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
 -1.577519670718931E-004
   21.1477364089746
 -6.779983919268271E-006
 -7.118157374460452E-004
 -6.899739877423863E-004
  -2.11482356192435
 -1.749652431672164E-018
  -6.34438703210792
  -6.34437653651792
 -1.577519670718989E-004
   21.1477364089746
 -6.779983919268604E-006
 -7.118157374460905E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
 -6.899739159861965E-004
  -2.11482356187919
  5.720421399947007E-012
  -6.34438703209823
  -6.34437653651792
 -1.577519545627373E-004
   21.1477364089889
  1.046648226576974E-006
 -6.779983191369767E-006
 -7.118156386533741E-004
 -6.899739869539865E-004
  -2.11482356192385
  6.284970873748105E-014
  -6.34438703210781
  -6.34437653651792
 -1.577519669344581E-004
   21.1477364089748
  1.046648226576999E-006
 -6.779983911271031E-006
 -7.118157363606347E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
 -6.899739797405390E-004
  -2.11482356191931
  6.379077183923750E-013
  -6.34438703210684
  -6.34437653651792
 -1.577519656769474E-004
   21.1477364089762
  1.046648226576997E-006
 -6.779983838097413E-006
 -7.118157264292815E-004
 -6.839169730044121E-004
  -2.11482331728470
 -6.662870093233409E-012
  -6.34438703309127
  -6.34437653650898
 -1.567005374296405E-004
   21.1477373988668
  1.046648222910566E-006
 -6.723068088836391E-006
 -7.055702135204329E-004
 -6.648299610889552E-004
  -2.11482254616652
  1.885389461469666E-018
  -6.34438703614308
  -6.34437653648079
 -1.533872462003842E-004
   21.1477405182513
  1.046648211356895E-006
 -6.543713300847808E-006
 -6.858890475224518E-004
 -6.437900739333921E-004
  -2.11482169620430
  8.970078911423041E-019
  -6.34438703951970
  -6.34437653644973
 -1.497349575050653E-004
   21.1477439567907
  1.046648198621096E-006
 -6.346007995049283E-006
 -6.641942440345406E-004
 -6.236638383047850E-004
  -2.11482088315247
  3.435777392300256E-019
  -6.34438704274944
  -6.34437653642001
 -1.462412687857692E-004
   21.1477472460118
  1.046648186438346E-006
 -6.156888029553015E-006
 -6.434415355977556E-004
 -6.054813627073377E-004
  -2.11482014862422
  2.326164231397122E-019
  -6.34438704566743
  -6.34437653639316
 -1.430849950469276E-004
   21.1477502175657
  1.046648175432186E-006
 -5.986032934860665E-006
 -6.246930886437701E-004
 -5.895483600731941E-004
  -2.11481950496933
  1.485484031247229E-019
  -6.34438704822451
  -6.34437653636964
 -1.403192046153178E-004
   21.1477528214891
  1.046648165787671E-006
 -5.836315475427259E-006
 -6.082641356968455E-004
 -5.758478170424553E-004
  -2.11481895150046
  5.696296570285170E-020
  -6.34438705042321
  -6.34437653634941
 -1.379409436665921E-004
   21.1477550605627
  1.046648157494500E-006
 -5.707575703584699E-006
 -5.941371322865401E-004
 -5.642191409952483E-004
  -2.11481848172962
  6.172752603115714E-020
  -6.34438705228938
  -6.34437653633224
 -1.359223361097511E-004
   21.1477569610316
  1.046648150455466E-006
 -5.598304647542227E-006
 -5.821464883635690E-004
 -5.544439266814491E-004
  -2.11481808683408
  8.364450354136216E-021
  -6.34438705385820
  -6.34437653631780
 -1.342254685458599E-004
   21.1477585585907
  1.046648144538364E-006
 -5.506449999843343E-006
 -5.720669987994166E-004
 -5.462886304181852E-004
  -2.11481775737979
  5.293955920339377E-020
  -6.34438705516697
  -6.34437653630576
 -1.328098005021367E-004
   21.1477598914073
  1.046648139601824E-006
 -5.429817197909135E-006
 -5.636578483306119E-004
 -5.395261745261200E-004
  -2.11481748419292
  8.893845946170154E-021
  -6.34438705625206
  -6.34437653629578
 -1.316359142398496E-004
   21.1477609965917
  1.046648135508397E-006
 -5.366272517012090E-006
 -5.566848968145716E-004
 -5.339466764753271E-004
  -2.11481725879472
 -3.494010907423989E-021
  -6.34438705714764
  -6.34437653628754
 -1.306673758597487E-004
   21.1477619084466
  1.046648132131032E-006
 -5.313843693148873E-006
 -5.509317244278313E-004
 -5.293622098695204E-004
  -2.11481707359338
  2.096406544454393E-020
  -6.34438705788341
  -6.34437653628077
 -1.298715638070382E-004
   21.1477626576843
  1.046648129355976E-006
 -5.270764887726361E-006
 -5.462045566172901E-004
 -5.256082148000023E-004
  -2.11481692194053
  1.048203272227197E-020
  -6.34438705848581
  -6.34437653627523
 -1.292199123620203E-004
   21.1477632711978
  1.046648127083620E-006
 -5.235489757396058E-006
 -5.423337089109968E-004
 -5.225429584179513E-004
  -2.11481679811157
  4.658681209898652E-021
  -6.34438705897771
  -6.34437653627070
 -1.286878182204833E-004
   21.1477637721511
  1.046648125228168E-006
 -5.206686497170843E-006
 -5.391730403614336E-004
 -5.200459356619586E-004
  -2.11481669723799
 -3.176373552203626E-021
  -6.34438705937842
  -6.34437653626702
 -1.282543631774347E-004
   21.1477641802387
  1.046648123716679E-006
 -5.183222746994063E-006
 -5.365982924883831E-004
 -5.180157258051534E-004
  -2.11481661522241
  2.472595052153709E-018
  -6.34438705970428
  -6.34437653626402
 -1.279019413676222E-004
   21.1477645120351
  1.046648122487758E-006
 -5.164145495012296E-006
 -5.345048864177030E-004
 -5.163676684011973E-004
  -2.11481654864408
 -2.388209394783500E-018
  -6.34438705996865
  -6.34437653626158
 -1.276158571917882E-004
   21.1477647813760
  1.046648121490161E-006
 -5.148659198600179E-006
 -5.328055287255515E-004
 -5.150315606166338E-004
  -2.11481649466922
  7.379774552953092E-020
  -6.34438706018311
  -6.34437653625961
 -1.273839238554627E-004
   21.1477649997356
  1.046648120681392E-006
 -5.136104211702906E-006
 -5.314278327278900E-004
 -5.139494995206588E-004
  -2.11481645095657
 -5.717472393966527E-021
  -6.34438706035688
  -6.34437653625801
 -1.271960902754225E-004
   21.1477651765761
  1.046648120026402E-006
 -5.125936428204076E-006
 -5.303120906686458E-004
 -5.130739370556627E-004
  -2.11481641558603
 -9.105604182983729E-021
  -6.34438706049738
  -6.34437653625672
 -1.270441022849977E-004
   21.1477653196693
  1.046648119496409E-006
 -5.117709041704634E-006
 -5.294092740344087E-004
 -5.123659583837803E-004
  -2.11481638698508
 -2.234049398383217E-020
  -6.34438706061085
  -6.34437653625567
 -1.269212052582411E-004
   21.1477654353736
  1.046648119067859E-006
 -5.111056384600308E-006
 -5.286792584335477E-004
 -5.117938156890674E-004
  -2.11481636387226
 -2.424631811515435E-020
  -6.34438706070264
  -6.34437653625483
 -1.268218878186382E-004
   21.1477655288786
  1.046648118721531E-006
 -5.105680134207707E-006
 -5.280893063072035E-004
 -5.113316592153980E-004
  -2.11481634520200
 -1.132906566952627E-020
  -6.34438706077690
  -6.34437653625415
 -1.267416624366885E-004
   21.1477656044087
  1.046648118441780E-006
 -5.101337403249047E-006
 -5.276127635103513E-004
 -5.109584859992954E-004
  -2.11481633012671
 -2.076045799402355E-014
  -6.34438706083693
  -6.34437653625360
 -1.266768836765059E-004
   21.1477656653966
  1.046648118215891E-006
 -5.097830791597171E-006
 -5.272279736859138E-004
 -5.106572499054436E-004
  -2.11481631795739
 -6.882612905606035E-015
  -6.34438706088518
  -6.34437653625315
 -1.266245926867701E-004
   21.1477657146269
  1.046648118033549E-006
 -5.095000186731332E-006
 -5.269173628907000E-004
 -5.104141473346194E-004
  -2.11481630813655
 -1.524659305057741E-020
  -6.34438706092408
  -6.34437653625279
 -1.265823928497912E-004
   21.1477657543571
  1.046648117886395E-006
 -5.092715823860421E-006
 -5.266666928532241E-004
 -5.102179976361569E-004
  -2.11481630021266
 -1.281137332722129E-020
  -6.34438706095557
  -6.34437653625250
 -1.265483433134784E-004
   21.1477657864141
  1.046648117767662E-006
 -5.090872661602090E-006
 -5.264644359775928E-004
 -5.100597563983116E-004
  -2.11481629382033
 -9.529120656610879E-021
  -6.34438706098111
  -6.34437653625227
 -1.265208744109423E-004
   21.1477658122754
  1.046648117671875E-006
 -5.089385717309248E-006
 -5.263012697885092E-004
 -5.099321140191491E-004
  -2.11481628866368
 -6.776263578034403E-021
  -6.34438706100146
  -6.34437653625208
 -1.264987170872531E-004
   21.1477658331359
  1.046648117594611E-006
 -5.088186300090830E-006
 -5.261696541796867E-004
 -5.098291653098504E-004
  -2.11481628450450
 -1.905824131322176E-021
  -6.34438706101795
  -6.34437653625193
 -1.264808460937316E-004
   21.1477658499611
  1.046648117532294E-006
 -5.087218909563365E-006
 -5.260635009846245E-004
 -5.097461374045232E-004
  -2.11481628115031
 -1.291725244562808E-020
  -6.34438706103131
  -6.34437653625181
 -1.264664336680100E-004
   21.1477658635299
  1.046648117482036E-006
 -5.086438738844267E-006
 -5.259778888165848E-004
 -5.096791842073509E-004
  -2.11481627844604
  9.529120656610879E-022
  -6.34438706104215
  -6.34437653625171
 -1.264548111878069E-004
   21.1477658744722
  1.046648117441508E-006
 -5.085809585977427E-006
 -5.259088503867411E-004
 -5.096251927214114E-004
  -2.11481627626516
 -6.352747104407253E-021
  -6.34438706105077
  -6.34437653625163
 -1.264454389283695E-004
   21.1477658832959
  1.046648117408826E-006
 -5.085302248051595E-006
 -5.258531788329968E-004
 -5.095816559148314E-004
  -2.11481627450608
  2.541098841762901E-021
  -6.34438706105790
  -6.34437653625156
 -1.264378816957729E-004
   21.1477658904110
  1.046648117382474E-006
 -5.084893165947644E-006
 -5.258082887044721E-004
 -5.095465539041116E-004
  -2.11481627308800
 -2.329340604949326E-021
  -6.34438706106339
  -6.34437653625151
 -1.264317882753473E-004
   21.1477658961476
  1.046648117361225E-006
 -5.084563310432240E-006
 -5.257720923921624E-004
 -5.095182493954511E-004
  -2.11481627194439
 -1.090554919589912E-020
  -6.34438706106785
  -6.34437653625147
 -1.264268750943861E-004
   21.1477659007733
  1.046648117344092E-006
 -5.084297356010633E-006
 -5.257429086400962E-004
 -5.094954306527410E-004
  -2.11481627102297
  1.577598864261134E-020
  -6.34438706107156
  -6.34437653625144
 -1.264229136814157E-004
   21.1477659045031
  1.046648117330278E-006
 -5.084082910474766E-006
 -5.257193769973274E-004
 -5.094770307022287E-004
  -2.11481627027918
 -3.059906521956160E-020
  -6.34438706107453
  -6.34437653625141
 -1.264197196292417E-004
   21.1477659075100
  1.046648117319141E-006
 -5.083910022928004E-006
 -5.257004055386015E-004
 -5.094621964401749E-004
  -2.11481626967975
  2.011703249728963E-020
  -6.34438706107691
  -6.34437653625139
 -1.264171445562565E-004
   21.1477659099342
  1.046648117310162E-006
 -5.083770636114452E-006
 -5.256851102678429E-004
 -5.094502363535248E-004
  -2.11481626919735
  5.823351512373315E-021
  -6.34438706107884
  -6.34437653625137
 -1.264150685225949E-004
   21.1477659118888
  1.046648117302923E-006
 -5.083658252247140E-006
 -5.256727770968291E-004
 -5.094405943802322E-004
  -2.11481626880763
 -1.122318655111948E-020
  -6.34438706108032
  -6.34437653625136
 -1.264133947576435E-004
   21.1477659134647
  1.046648117297085E-006
 -5.083567645248807E-006
 -5.256628345173452E-004
 -5.094328202145093E-004
  -2.11481626849336
 -9.846758011831241E-021
  -6.34438706108166
  -6.34437653625134
 -1.264120454310595E-004
   21.1477659147349
  1.046648117292380E-006
 -5.083494591646390E-006
 -5.256548179658953E-004
 -5.060815356522641E-004
  -2.11481612917191
  9.634999775017666E-021
  -6.34438704980852
  -6.34437652443437
 -1.255838927712457E-004
   21.1477669158700
  1.046648079563715E-006
 -5.052001680164712E-006
 -5.221992149526888E-004
 -5.094214993561429E-004
  -2.11481626803592
 -1.334076891925523E-020
  -6.34438706108344
  -6.34437653625133
 -1.264100803690820E-004
   21.1477659165851
  1.046648117285528E-006
 -5.083388213539689E-006
 -5.256431465981643E-004
 -5.094174263164934E-004
  -2.11481626787136
  2.498747194400186E-020
  -6.34438706108419
  -6.34437653625132
 -1.264093730730575E-004
   21.1477659172509
  1.046648117283062E-006
 -5.083349932254337E-006
 -5.256389452363801E-004
 -5.094141422235573E-004
  -2.11481626773828
 -2.181109839179823E-020
  -6.34438706108463
  -6.34437653625132
 -1.264088029015316E-004
   21.1477659177879
  1.046648117281073E-006
 -5.083319077048680E-006
 -5.256355589611024E-004
 -5.094114937407896E-004
  -2.11481626763190
  4.707452519968607E-015
  -6.34438706108507
  -6.34437653625131
 -1.264083432749158E-004
   21.1477659182206
  1.046648117279471E-006
 -5.083294199208046E-006
 -5.256328284725790E-004
 -5.094093599136891E-004
  -2.11481626754524
 -4.891531625890043E-015
  -6.34438706108553
  -6.34437653625131
 -1.264079727456793E-004
   21.1477659185693
  1.046648117278179E-006
 -5.083274140832774E-006
 -5.256306281535075E-004
 -2.943296861707911E-004
  -1.05740813373827
 -3.278720682676122E-006
  -3.17219906218562
  -3.17218826816752
 -3.613763829702449E-004
   10.5732933234176
  5.592671362847189E-003
 -2.833869742587263E-006
 -3.018267318854513E-004
        1010
 -8.338639944620926E-008
 -3.241213266333320E-007
 -6.244957548924814E-089
 -4.511105185500450E-006
 -0.333032008530929
  1.643013772755755E-005
 -1.443173608816589E-005
  1.577608637637265E-002
 -7.524387757376833E-008
 -2.402851878198262E-008
 -8.338639944626153E-008
 -3.241213266332530E-007
 -8.686834889601040E-081
 -4.511105185501384E-006
 -0.333032008530929
  1.643013772759292E-005
 -1.443173608819680E-005
  1.577608637637263E-002
 -7.524387757380947E-008
 -2.402851878197185E-008
 -8.338639944626158E-008
 -2.416704988544126E-072
 -0.333032008530929
 -6.723349845921039E-064
 -0.333032008530929
 -1.870457228537355E-055
 -0.333032008530929
 -5.203671270966513E-047
 -0.333032008530929
 -1.447677834229689E-038
 -0.333032008530929
 -4.027485601200744E-030
 -0.333032008530929
 -8.338639944626202E-008
 -1.120459254424542E-021
 -0.333032008530929
  1.643013772759287E-005
 -1.443173608819675E-005
 -7.524387757381000E-008
 -2.402851878197340E-008
 -8.338639944625999E-008
  2.240782918675820E-021
 -0.333032008530929
  1.643013772759295E-005
 -1.443173608819681E-005
 -7.524387757380777E-008
 -2.402851878197035E-008
 -1.120323657540768E-021
 -0.333032008530929
 -2.683024578529442E-030
 -0.333032008530929
 -6.425483243650186E-039
 -0.333032008530929
 -1.538816872749579E-047
 -0.333032008530929
 -3.685259579812716E-056
 -0.333032008530929
 -8.825701362589319E-065
 -0.333032008530929
  2.205048830349831E-072
 -0.333032008530929
  6.722536176564358E-064
 -0.333032008530929
  1.870230863144401E-055
 -0.333032008530929
  5.203041515271441E-047
 -0.333032008530929
  1.447502634200082E-038
 -0.333032008530929
  4.026998189167565E-030
 -0.333032008530929
 -8.338639944626100E-008
  1.120323654852658E-021
 -0.333032008530929
 -1.443173608819679E-005
 -7.524387757380886E-008
 -2.402851878197037E-008
 -8.338639944626285E-008
 -2.240782918581001E-021
 -0.333032008530929
 -7.524387757381086E-008
 -2.402851878197411E-008
 -8.338639944466889E-008
 -3.241213266333087E-007
  1.146793082585045E-021
 -4.511105185490691E-006
 -0.333032008530905
  1.643013771474234E-005
 -1.443173608115831E-005
  1.577608637638025E-002
 -7.524387760955054E-008
 -2.402851865108303E-008
 -8.295553399928314E-008
 -3.240918389807619E-007
  7.326153679145749E-015
 -4.511105173242733E-006
 -0.333032008441008
  1.643013392522787E-005
 -1.443173400240163E-005
  1.577608637586688E-002
 -7.524265553094201E-008
 -2.403211002579397E-008
 -8.338639938995583E-008
 -3.241213265559955E-007
  8.049174931317143E-017
 -4.511105185419627E-006
 -0.333032008530929
  1.643013772765890E-005
 -1.443173608818641E-005
  1.577608637637268E-002
 -7.524387751482823E-008
 -2.402851871820742E-008
 -8.338639944624613E-008
 -3.241213266333874E-007
 -2.240590154432371E-021
 -4.511105185502602E-006
 -0.333032008530929
  1.643013772758131E-005
 -1.443173608818665E-005
  1.577608637637264E-002
 -7.524387757379775E-008
 -2.402851878197676E-008
 -8.338639944624392E-008
 -3.241213266333893E-007
  1.120323657541221E-021
 -0.333032008530929
  1.643013772758129E-005
 -1.443173608818663E-005
 -7.524387757379539E-008
 -2.402851878197380E-008
 -8.338639944624481E-008
 -1.343981908475739E-030
 -0.333032008530929
  1.643013772758133E-005
 -1.443173608818667E-005
 -7.524387757379628E-008
 -2.402851878197449E-008
 -8.338639944624529E-008
 -1.120323654852633E-021
 -0.333032008530929
  1.643013772758127E-005
 -1.443173608818662E-005
 -7.524387757379683E-008
 -2.402851878197602E-008
 -8.338639944624318E-008
  2.240782918675632E-021
 -0.333032008530929
  1.643013772758135E-005
 -1.443173608818668E-005
 -7.524387757379457E-008
 -2.402851878197297E-008
 -1.120459261139650E-021
 -0.333032008530929
 -1.120323657535982E-021
 -0.333032008530929
  2.240782914648625E-021
 -0.333032008530929
 -2.240782911965275E-021
 -0.333032008530929
 -7.524387757379776E-008
 -2.402851878197672E-008
  2.240782915992282E-021
 -0.333032008530929
 -0.333032008530929
 -0.333032008530929
 -0.333032008530929
 -0.333032008530929
 -1.120323661563476E-021
 -0.333032008530929
  1.120323664251602E-021
 -0.333032008530929
  1.120459261134548E-021
 -0.333032008530929
 -1.120459259795668E-021
 -0.333032008530929
 -6.710355995153686E-030
 -0.333032008530929
 -1.120323658880126E-021
 -0.333032008530929
  1.120323660224108E-021
 -0.333032008530929
 -8.338639944624476E-008
  6.721074294077672E-030
 -0.333032008530929
 -1.443173608818666E-005
 -7.524387757379630E-008
 -8.338639944632541E-008
 -3.241213266333627E-007
  1.123395861669724E-021
 -4.511105185500120E-006
 -0.333032008530929
  1.643013772762399E-005
 -1.443173608822393E-005
  1.577608637637614E-002
 -7.524387757396101E-008
 -2.402851878191134E-008
 -8.339934019929484E-008
 -3.241219178173349E-007
  8.169694985577998E-016
 -4.511113917780055E-006
 -0.333032024427797
  1.643560280174971E-005
 -1.443651392250660E-005
  1.577608450185033E-002
 -7.589752605896886E-008
 -2.210377552152242E-008
 -8.334073795978511E-008
 -3.241337604524123E-007
 -8.608739088952624E-015
 -4.511048404478379E-006
 -0.333034298579703
  1.630148586825116E-005
 -1.430199720127225E-005
  1.579654413810325E-002
 -7.508309595443940E-008
 -2.404141420823070E-008
 -8.319789795182504E-008
 -3.241741429545018E-007
  2.486129352897697E-021
 -4.510892285954514E-006
 -0.333041525514610
  1.589915201674462E-005
 -1.389626998704731E-005
  1.586135358858087E-002
 -7.458029549699809E-008
 -2.408168256193040E-008
 -8.304230597299879E-008
 -3.242209948691892E-007
  1.231230201853894E-021
 -4.510762415205505E-006
 -0.333049510309380
  1.546097463970450E-005
 -1.345440859407433E-005
  1.593340488280740E-002
 -7.403277751308564E-008
 -2.412548695406859E-008
 -8.289525445200771E-008
 -3.242683161867938E-007
  4.868160466869405E-022
 -4.510682501495960E-006
 -0.333057166103054
  1.504695215436566E-005
 -1.303691769771388E-005
  1.600293446098363E-002
 -7.351551152706548E-008
 -2.416681445955514E-008
 -8.276387421753805E-008
 -3.243133768617191E-007
  3.394947454757474E-022
 -4.510650292249926E-006
 -0.333064097161301
  1.467714732450678E-005
 -1.266402644048611E-005
  1.606626603270028E-002
 -7.305354892894772E-008
 -2.420367111460383E-008
 -8.264987236020149E-008
 -3.243548295916185E-007
  2.226613440731067E-022
 -4.510655481174217E-006
 -0.333070181979942
  1.435634116461210E-005
 -1.234055264657513E-005
  1.612217074561897E-002
 -7.265284351128356E-008
 -2.423559634441786E-008
 -8.255266954838881E-008
 -3.243920643438154E-007
  8.741454193502264E-023
 -4.510686535165102E-006
 -0.333075422503269
  1.408287510977979E-005
 -1.206482057149362E-005
  1.617055053858524E-002
 -7.231130431103293E-008
 -2.426277198322028E-008
 -8.247075602384022E-008
 -3.244249056737025E-007
  9.667899492719744E-023
 -4.510733321865479E-006
 -0.333079876461650
  1.385247616725008E-005
 -1.183251867220238E-005
  1.621183971640100E-002
 -7.202357956743788E-008
 -2.428563809513830E-008
 -8.240231202516021E-008
 -3.244534468703237E-007
  1.333161700734497E-023
 -4.510787915550990E-006
 -0.333083624687679
  1.366000295879637E-005
 -1.163846042935311E-005
  1.624670945101639E-002
 -7.178323616725297E-008
 -2.430471783392017E-008
 -8.234549633628579E-008
 -3.244779465928624E-007
  8.563728595763744E-023
 -4.510844609363291E-006
 -0.333086754659512
  1.350025899485135E-005
 -1.147740440462057E-005
  1.627591431348241E-002
 -7.158377565912027E-008
 -2.432053654866190E-008
 -8.229857914432706E-008
 -3.244987583811678E-007
  1.456744096877508E-023
 -4.510899606041663E-006
 -0.333089352042539
  1.336836813928656E-005
 -1.134443274459416E-005
  1.630021009933829E-002
 -7.141910282362207E-008
 -2.433358545122126E-008
 -8.226000159824927E-008
 -3.245162813660155E-007
 -5.782741253223281E-024
 -4.510950610720384E-006
 -0.333091496407933
  1.325993587461343E-005
 -1.123511367210048E-005
  1.632030987247098E-002
 -7.128372566286996E-008
 -2.434430512360228E-008
 -8.222839269276403E-008
 -3.245309249690926E-007
  3.499701431167663E-023
 -4.510996431561806E-006
 -0.333093259257205
  1.317110155766963E-005
 -1.114555405747368E-005
  1.633686182044688E-002
 -7.117282105314696E-008
 -2.435308157248885E-008
 -8.220256920277538E-008
 -3.245430851440779E-007
  1.762351942027154E-023
 -4.511036639781880E-006
 -0.333094703372962
  1.309853369214132E-005
 -1.107239455062732E-005
  1.635044013956146E-002
 -7.108222721728570E-008
 -2.436024683720493E-008
 -8.218152277640713E-008
 -3.245531299291669E-007
  7.878634781757385E-024
 -4.511071299675832E-006
 -0.333095882941326
  1.303939566869791E-005
 -1.101277495626587E-005
  1.636154382573067E-002
 -7.100840113211583E-008
 -2.436608342966391E-008
 -8.216440410558008E-008
 -3.245613908012156E-007
 -5.397584588295129E-024
 -4.511100768204041E-006
 -0.333096844109551
  1.299129737037988E-005
 -1.096428537699745E-005
  1.637060015309829E-002
 -7.094835806875741E-008
 -2.437082863387522E-008
 -8.215050309387340E-008
 -3.245681597794225E-007
  4.218140874308113E-021
 -4.511125554604211E-006
 -0.333097625765752
  1.295224164010895E-005
 -1.092491218926264E-005
  1.637797073171866E-002
 -7.089960425030349E-008
 -2.437468035725006E-008
 -8.213923004017843E-008
 -3.245736894598993E-007
 -4.087189538260935E-021
 -4.511146226263014E-006
 -0.333098260404386
  1.292057086471042E-005
 -1.089298415877476E-005
  1.638395875221664E-002
 -7.086006959495356E-008
 -2.437780298624575E-008
 -8.213009812350638E-008
 -3.245781959946212E-007
  1.266254404026612E-022
 -4.511163350753952E-006
 -0.333098774992559
  1.289491675968813E-005
 -1.086712178731193E-005
  1.638881651866079E-002
 -7.082804603079192E-008
 -2.438033201634681E-008
 -8.212270735258152E-008
 -3.245818609169984E-007
 -9.830952899720768E-024
 -4.511177460801297E-006
 -0.333099191786852
  1.287415489314502E-005
 -1.084619144739639E-005
  1.639275271767982E-002
 -7.080212963252590E-008
 -2.438237831094261E-008
 -8.211673037889426E-008
 -3.245848366040126E-007
 -1.568342885616003E-023
 -4.511189037115413E-006
 -0.333099529074003
  1.285736455899038E-005
 -1.082926491809532E-005
  1.639593911300207E-002
 -7.078117104498320E-008
 -2.438403293761677E-008
 -8.211189927375862E-008
 -3.245872493032730E-007
 -3.853229492247622E-023
 -4.511198502074142E-006
 -0.333099801824599
  1.284379409739067E-005
 -1.081558441240015E-005
  1.639851651737153E-002
 -7.076423152790794E-008
 -2.438537005451380E-008
 -8.210799658887902E-008
 -3.245892036168048E-007
 -4.186617395048682E-023
 -4.511206219688556E-006
 -0.333100022258411
  1.283283131302725E-005
 -1.080453275209452E-005
  1.640059999909598E-002
 -7.075054726822203E-008
 -2.438645014629337E-008
 -8.210484507513553E-008
 -3.245907849895444E-007
 -1.968078171987806E-023
 -4.511212498692617E-006
 -0.333100200326170
  1.282397857996594E-005
 -1.079560826331225E-005
  1.640228334453317E-002
 -7.073949713261490E-008
 -2.438732224435257E-008
 -8.210645552055764E-008
 -3.245925150998100E-007
 -3.590575180129820E-017
 -4.511217598691698E-006
 -0.333100344116074
  1.281683255250290E-005
 -1.078840408061385E-005
  1.640364283082706E-002
 -7.073027717410267E-008
 -2.440099778952383E-008
 -8.210024739649045E-008
 -3.245930972810695E-007
 -1.191068187799230E-017
 -4.511221733500056E-006
 -0.333100460188581
  1.281106429994649E-005
 -1.078258933010950E-005
  1.640474040297971E-002
 -7.072337696986501E-008
 -2.438859450830671E-008
 -8.209859055947207E-008
 -3.245939321256744E-007
 -2.641175776904863E-023
 -4.511225083255857E-006
 -0.333100553864860
  1.280641033444111E-005
 -1.077789765726724E-005
  1.640562627211491E-002
 -7.071756773358623E-008
 -2.438905290372479E-008
 -8.209725401713199E-008
 -3.245946062976780E-007
 -2.218977009740793E-023
 -4.511227794298860E-006
 -0.333100629450417
  1.280265569380574E-005
 -1.077411259837709E-005
  1.640634111607483E-002
 -7.071288117861824E-008
 -2.438942261798779E-008
 -8.209617574641942E-008
 -3.245951505365930E-007
 -1.650990959323805E-023
 -4.511229986850761E-006
 -0.333100690428943
  1.279962700354774E-005
 -1.077105937277835E-005
  1.640691785010297E-002
 -7.070910067520310E-008
 -2.438972101561128E-008
 -8.209530605283133E-008
 -3.245955896745524E-007
 -1.174331974007180E-023
 -4.511231758615991E-006
 -0.333100739616770
  1.279718416965342E-005
 -1.076859675055524E-005
  1.640738309051952E-002
 -7.070605144858221E-008
 -2.438996160731396E-008
 -8.209460473415056E-008
 -3.245959439777915E-007
 -3.303475869515267E-024
 -4.511233189956583E-006
 -0.333100779289490
  1.279521403967012E-005
 -1.076661066215623E-005
  1.640775834757975E-002
 -7.070359218130028E-008
 -2.439015570946238E-008
 -8.209403894318012E-008
 -3.245962298350942E-007
 -2.239387273369916E-023
 -4.511234345838364E-006
 -0.333100811284997
  1.279362525666892E-005
 -1.076500901014438E-005
  1.640806099683731E-002
 -7.070160911198647E-008
 -2.439031211025945E-008
 -8.209358302598963E-008
 -3.245964605567930E-007
  1.652224027020899E-024
 -4.511235278987577E-006
 -0.333100837087137
  1.279234407705133E-005
 -1.076371745362377E-005
  1.640830506859023E-002
 -7.070000991382714E-008
 -2.439043826774356E-008
 -8.209321514289550E-008
 -3.245966465976744E-007
 -1.101599448612598E-023
 -4.511236031948566E-006
 -0.333100857893601
  1.279131099616036E-005
 -1.076267600520005E-005
  1.640850188845788E-002
 -7.069872036608812E-008
 -2.439054003021793E-008
 -8.209291832970522E-008
 -3.245967965146140E-007
  4.406774336264668E-024
 -4.511236639684068E-006
 -0.333100874670858
  1.279047799835658E-005
 -1.076183626090482E-005
  1.640866059651911E-002
 -7.069768064280034E-008
 -2.439062216722420E-008
 -8.209267941236442E-008
 -3.245969174847342E-007
 -4.039821579585459E-024
 -4.511237129714554E-006
 -0.333100888198689
  1.278980635582760E-005
 -1.076115917851047E-005
  1.640878856758822E-002
 -7.069684229603188E-008
 -2.439068821563619E-008
 -8.209248642309183E-008
 -3.245970149749654E-007
 -1.891476077088988E-023
 -4.511237525017721E-006
 -0.333100899106113
  1.278926482354814E-005
 -1.076061326042853E-005
  1.640889175119780E-002
 -7.069616636306387E-008
 -2.439074167389704E-008
 -8.209233126401144E-008
 -3.245970937377177E-007
  2.736335549281504E-023
 -4.511237843973837E-006
 -0.333100907900510
  1.278882820582347E-005
 -1.076017310667555E-005
  1.640897494642758E-002
 -7.069562129457902E-008
 -2.439078449985416E-008
 -8.209220579651767E-008
 -3.245971570420903E-007
 -5.307580830015295E-023
 -4.511238101188330E-006
 -0.333100914991095
  1.278847618536200E-005
 -1.075981823483942E-005
  1.640904202396119E-002
 -7.069518191411745E-008
 -2.439081924663880E-008
 -8.209210472077040E-008
 -3.245972081386692E-007
  3.489514639284420E-023
 -4.511238308593888E-006
 -0.333100920707867
  1.278819237212667E-005
 -1.075953212287102E-005
  1.640909610542859E-002
 -7.069482770639089E-008
 -2.439084727947349E-008
 -8.209202327064051E-008
 -3.245972495376967E-007
  1.010146378937869E-023
 -4.511238475855008E-006
 -0.333100925316947
  1.278796355198692E-005
 -1.075930144965431E-005
  1.640913970818818E-002
 -7.069454212139620E-008
 -2.439086971000617E-008
 -8.209195766075049E-008
 -3.245972827387949E-007
 -1.946864431923617E-023
 -4.511238610651313E-006
 -0.333100929032925
  1.278777907084497E-005
 -1.075911547463638E-005
  1.640917486218796E-002
 -7.069431185508063E-008
 -2.439088786101856E-008
 -8.209190470121607E-008
 -3.245973094934874E-007
 -1.708124106819505E-023
 -4.511238719485831E-006
 -0.333100932028838
  1.278763033974007E-005
 -1.075896553898537E-005
  1.640920320426555E-002
 -7.069412616874244E-008
 -2.439090244956613E-008
 -8.172502999612137E-008
 -3.245775679406233E-007
  1.671410817918660E-023
 -4.511238908837177E-006
 -0.333100933626445
  1.278781413218150E-005
 -1.075859726436369E-005
  1.640922586148848E-002
 -7.034833126228906E-008
 -2.414445143942690E-008
 -8.209182746896956E-008
 -3.245973484871293E-007
 -2.314284091831589E-023
 -4.511238877816327E-006
 -0.333100936391493
  1.278741375682377E-005
 -1.075874720222776E-005
  1.640924447623802E-002
 -7.069385572071968E-008
 -2.439092396155742E-008
 -8.209179986635592E-008
 -3.245973625390163E-007
  4.334725525655564E-023
 -4.511238934910543E-006
 -0.333100937961430
  1.278733582004617E-005
 -1.075866863397757E-005
  1.640925932828432E-002
 -7.069375845778361E-008
 -2.439093151657964E-008
 -8.209177751278560E-008
 -3.245973737743810E-007
 -3.781426697047665E-023
 -4.511238980776317E-006
 -0.333100939227119
  1.278727298462864E-005
 -1.075860528985067E-005
  1.640927130214213E-002
 -7.069368010300579E-008
 -2.439093772569826E-008
 -8.209175938618202E-008
 -3.245973830324169E-007
  8.166393188012639E-018
 -4.511239017837742E-006
 -0.333100940247529
  1.278722232762371E-005
 -1.075855422256153E-005
  1.640928095554731E-002
 -7.069361691141320E-008
 -2.439094271056848E-008
 -8.209174336402354E-008
 -3.245973903405060E-007
 -4.050809044659481E-017
 -4.511239037121470E-006
 -0.333100941050613
  1.278717564996474E-005
 -1.075850718030293E-005
  1.640934441520463E-002
 -7.069343877486501E-008
 -2.439094576381731E-008
 -2.494102430257046E-007
 -3.479028175763095E-007
 -1.137580248718200E-008
 -4.472608007859953E-006
 -0.333009969847889
 -2.034574097334680E-005
  1.655701586293674E-005
   175.430613487108
  3.625848730814019E-005
  5.537475704721836E-007
%%MatrixMarket matrix coordinate real general
% This ASCII file represents a sparse MxN matrix with L
% nonzeros in the following Matrix Market format:
% |%%MatrixMarket matrix coordinate real general | <--- header line
% |% comments                                    |    |-- 0 or more comment lines
% |    M  N  L                                   | <--- rows, columns, entries
% |    I1  J1  A(I1, J1)                         | <--+
% |    I2  J2  A(I2, J2)                         |    |
% |    I3  J3  A(I3, J3)                         |    |-- L lines
% |    IL JL  A(IL, JL)                          | <--+
% Indices are 1-based, i.e. A(1,1) is the first element.
        1010         1010        12448
           1            1   0.48972610E+04
           1            6   0.39942105E+02
           1            7   0.38058900E+02
           1           10   0.18153565E+04
           1           11  -0.35206361E-04
           1           16  -0.28714265E-06
           1           17  -0.27360508E-06
           1           20  -0.13050579E-04
           2            2   0.30832492E+04
           2            4   0.31725108E+01
           2            5   0.31725108E+01
           2            7  -0.10568165E+02
           2           10   0.12417046E+03
           2           12  -0.22157848E-04
           2           20  -0.89266026E-06
           3            3   0.39041096E+03
           3           13  -0.28066608E-05
           4            4   0.67047646E+03
           4            2   0.31721936E+01
           4            5   0.95175325E+01
           4            7  -0.32918410E+02
           4           14  -0.47516275E-05
           4           17   0.87268201E-08
           5            5   0.95264187E+01
           5            2   0.31721936E+01
           5            4   0.95175325E+01
           5            7  -0.31738933E+02
           5           10   0.10897822E-05
           5           15  -0.63765367E-10
           5           17   0.24721601E-09
           5           20  -0.78344339E-14
           6            6   0.85373309E+03
           6            1   0.39942105E+02
           6            7   0.97718649E+03
           6            9   0.21599416E-04
           6           11  -0.28714265E-06
           6           16  -0.61374783E-05
           6           17  -0.70249846E-05
           7            7   0.13361859E+04
           7            1   0.38058900E+02
           7            2  -0.10573979E+02
           7            4  -0.32939144E+02
           7            5  -0.31759554E+02
           7            6   0.97717390E+03
           7            8  -0.19443751E-04
           7            9  -0.60179924E-01
           7           10   0.24752575E-01
           7           11  -0.27360508E-06
           7           14   0.87276927E-08
           7           15   0.24727690E-09
           7           16  -0.70248941E-05
           7           17  -0.88460827E-05
           7           18   0.23585210E-13
           7           19   0.43266612E-09
           7           20  -0.17787962E-09
           8            8   0.33154131E-04
           8            7  -0.19448461E-04
           8            9  -0.74731227E-05
           8           10  -0.18525968E-04
           8           17   0.23587113E-13
           8           18  -0.35002201E-13
           8           19  -0.43867309E-14
           8           20   0.16955322E-13
           9            9   0.49678112E+02
           9            6   0.21599416E-04
           9            7  -0.60173906E-01
           9            8  -0.74713272E-05
           9           10   0.16768354E+02
           9           17   0.43262286E-09
           9           18  -0.43865664E-14
           9           19  -0.35713531E-06
           9           20  -0.12054751E-06
          10           10   0.67424664E+04
          10            1   0.18153565E+04
          10            2   0.12417046E+03
          10            5   0.10897670E-05
          10            7   0.24752575E-01
          10            8  -0.18521169E-04
          10            9   0.16768354E+02
          10           11  -0.13050579E-04
          10           12  -0.89266026E-06
          10           15  -0.78343250E-14
          10           17  -0.17787962E-09
          10           18   0.16952779E-13
          10           19  -0.12054751E-06
          10           20  -0.48471527E-04
          11           11   0.97945219E+04
          11           16   0.79884210E+02
          11           17   0.76117799E+02
          11           20   0.36307130E+04
          11            1  -0.23456562E-04
          11            6  -0.19131143E-06
          11            7  -0.18229190E-06
          11           10  -0.86950685E-05
          11           21  -0.35206361E-04
          11           26  -0.28714265E-06
          11           27  -0.27360508E-06
          11           30  -0.13050579E-04
          12           12   0.61664984E+04
          12           14   0.63450217E+01
          12           15   0.63450217E+01
          12           17  -0.21136331E+02
          12           20   0.24834091E+03
          12            2  -0.14762870E-04
          12           10  -0.59474311E-06
          12           22  -0.22157848E-04
          12           30  -0.89266026E-06
          13           13   0.78082192E+03
          13            3  -0.18699636E-05
          13           23  -0.28066608E-05
          14           14   0.13409529E+04
          14           12   0.63443872E+01
          14           15   0.19035065E+02
          14           17  -0.65836821E+02
          14            4  -0.31658155E-05
          14            7   0.58143241E-08
          14           24  -0.47516275E-05
          14           27   0.87268201E-08
          15           15   0.19052837E+02
          15           12   0.63443872E+01
          15           14   0.19035065E+02
          15           17  -0.63477866E+02
          15           20   0.21795643E-05
          15            5  -0.42484262E-10
          15            7   0.16470994E-09
          15           10  -0.52197636E-14
          15           25  -0.63765367E-10
          15           27   0.24721601E-09
          15           30  -0.78344339E-14
          16           16   0.17074662E+04
          16           11   0.79884210E+02
          16           17   0.19543730E+04
          16           19   0.43198833E-04
          16            1  -0.19131143E-06
          16            6  -0.40891514E-05
          16            7  -0.46804606E-05
          16           21  -0.28714265E-06
          16           26  -0.61374783E-05
          16           27  -0.70249846E-05
          17           17   0.26723718E+04
          17           11   0.76117799E+02
          17           12  -0.21147957E+02
          17           14  -0.65878288E+02
          17           15  -0.63519108E+02
          17           16   0.19543478E+04
          17           18  -0.38887502E-04
          17           19  -0.12035985E+00
          17           20   0.49505150E-01
          17            1  -0.18229190E-06
          17            4   0.58149055E-08
          17            5   0.16475051E-09
          17            6  -0.46804003E-05
          17            7  -0.58937839E-05
          17            8   0.15713863E-13
          17            9   0.28826778E-09
          17           10  -0.11851393E-09
          17           21  -0.27360508E-06
          17           24   0.87276927E-08
          17           25   0.24727690E-09
          17           26  -0.70248941E-05
          17           27  -0.88460827E-05
          17           28   0.23585210E-13
          17           29   0.43266612E-09
          17           30  -0.17787962E-09
          18           18   0.66308262E-04
          18           17  -0.38896922E-04
          18           19  -0.14946245E-04
          18           20  -0.37051937E-04
          18            7   0.15715131E-13
          18            8  -0.23320538E-13
          18            9  -0.29226998E-14
          18           10   0.11296639E-13
          18           27   0.23587113E-13
          18           28  -0.35002201E-13
          18           29  -0.43867309E-14
          18           30   0.16955322E-13
          19           19   0.99356224E+02
          19           16   0.43198833E-04
          19           17  -0.12034781E+00
          19           18  -0.14942654E-04
          19           20   0.33536708E+02
          19            7   0.28823896E-09
          19            8  -0.29225902E-14
          19            9  -0.23794469E-06
          19           10  -0.80315886E-07
          19           27   0.43262286E-09
          19           28  -0.43865664E-14
          19           29  -0.35713531E-06
          19           30  -0.12054751E-06
          20           20   0.13484933E+05
          20           11   0.36307130E+04
          20           12   0.24834091E+03
          20           15   0.21795340E-05
          20           17   0.49505150E-01
          20           18  -0.37042339E-04
          20           19   0.33536708E+02
          20            1  -0.86950685E-05
          20            2  -0.59474311E-06
          20            5  -0.52196911E-14
          20            7  -0.11851393E-09
          20            8   0.11294945E-13
          20            9  -0.80315886E-07
          20           10  -0.32294600E-04
          20           21  -0.13050579E-04
          20           22  -0.89266026E-06
          20           25  -0.78343250E-14
          20           27  -0.17787962E-09
          20           28   0.16952779E-13
          20           29  -0.12054751E-06
          20           30  -0.48471527E-04
          21           21   0.97945219E+04
          21           26   0.79884210E+02
          21           27   0.76117799E+02
          21           30   0.36307130E+04
          21           11  -0.23456562E-04
          21           16  -0.19131143E-06
          21           17  -0.18229190E-06
          21           20  -0.86950685E-05
          21           31  -0.35206361E-04
          21           36  -0.28714265E-06
          21           37  -0.27360508E-06
          21           40  -0.13050579E-04
          22           22   0.61664984E+04
          22           24   0.63450217E+01
          22           25   0.63450217E+01
          22           27  -0.21136331E+02
          22           30   0.24834091E+03
          22           12  -0.14762870E-04
          22           20  -0.59474311E-06
          22           32  -0.22157848E-04
          22           40  -0.89266026E-06
          23           23   0.78082192E+03
          23           13  -0.18699636E-05
          23           33  -0.28066608E-05
          24           24   0.13409529E+04
          24           22   0.63443872E+01
          24           25   0.19035065E+02
          24           27  -0.65836821E+02
          24           14  -0.31658155E-05
          24           17   0.58143241E-08
          24           34  -0.47516275E-05
          24           37   0.87268201E-08
          25           25   0.19052837E+02
          25           22   0.63443872E+01
          25           24   0.19035065E+02
          25           27  -0.63477866E+02
          25           30   0.21795643E-05
          25           15  -0.42484262E-10
          25           17   0.16470994E-09
          25           20  -0.52197636E-14
          25           35  -0.63765367E-10
          25           37   0.24721601E-09
          25           40  -0.78344339E-14
          26           26   0.17074662E+04
          26           21   0.79884210E+02
          26           27   0.19543730E+04
          26           29   0.43198833E-04
          26           11  -0.19131143E-06
          26           16  -0.40891514E-05
          26           17  -0.46804606E-05
          26           31  -0.28714265E-06
          26           36  -0.61374783E-05
          26           37  -0.70249846E-05
          27           27   0.26723718E+04
          27           21   0.76117799E+02
          27           22  -0.21147957E+02
          27           24  -0.65878288E+02
          27           25  -0.63519108E+02
          27           26   0.19543478E+04
          27           28  -0.38887502E-04
          27           29  -0.12035985E+00
          27           30   0.49505150E-01
          27           11  -0.18229190E-06
          27           14   0.58149055E-08
          27           15   0.16475051E-09
          27           16  -0.46804003E-05
          27           17  -0.58937839E-05
          27           18   0.15713863E-13
          27           19   0.28826778E-09
          27           20  -0.11851393E-09
          27           31  -0.27360508E-06
          27           34   0.87276927E-08
          27           35   0.24727690E-09
          27           36  -0.70248941E-05
          27           37  -0.88460827E-05
          27           38   0.23585210E-13
          27           39   0.43266612E-09
          27           40  -0.17787962E-09
          28           28   0.66308262E-04
          28           27  -0.38896922E-04
          28           29  -0.14946245E-04
          28           30  -0.37051937E-04
          28           17   0.15715131E-13
          28           18  -0.23320538E-13
          28           19  -0.29226998E-14
          28           20   0.11296639E-13
          28           37   0.23587113E-13
          28           38  -0.35002201E-13
          28           39  -0.43867309E-14
          28           40   0.16955322E-13
          29           29   0.99356224E+02
          29           26   0.43198833E-04
          29           27  -0.12034781E+00
          29           28  -0.14942654E-04
          29           30   0.33536708E+02
          29           17   0.28823896E-09
          29           18  -0.29225902E-14
          29           19  -0.23794469E-06
          29           20  -0.80315886E-07
          29           37   0.43262286E-09
          29           38  -0.43865664E-14
          29           39  -0.35713531E-06
          29           40  -0.12054751E-06
          30           30   0.13484933E+05
          30           21   0.36307130E+04
          30           22   0.24834091E+03
          30           25   0.21795340E-05
          30           27   0.49505150E-01
          30           28  -0.37042339E-04
          30           29   0.33536708E+02
          30           11  -0.86950685E-05
          30           12  -0.59474311E-06
          30           15  -0.52196911E-14
          30           17  -0.11851393E-09
          30           18   0.11294945E-13
          30           19  -0.80315886E-07
          30           20  -0.32294600E-04
          30           31  -0.13050579E-04
          30           32  -0.89266026E-06
          30           35  -0.78343250E-14
          30           37  -0.17787962E-09
          30           38   0.16952779E-13
          30           39  -0.12054751E-06
          30           40  -0.48471527E-04
          31           31   0.97945219E+04
          31           36   0.79884210E+02
          31           37   0.76117799E+02
          31           40   0.36307130E+04
          31           21  -0.23456562E-04
          31           26  -0.19131143E-06
          31           27  -0.18229190E-06
          31           30  -0.86950685E-05
          31           41  -0.35206361E-04
          31           46  -0.28714265E-06
          31           47  -0.27360508E-06
          31           50  -0.13050579E-04
          32           32   0.61664984E+04
          32           34   0.63450217E+01
          32           35   0.63450217E+01
          32           37  -0.21136331E+02
          32           40   0.24834091E+03
          32           22  -0.14762870E-04
          32           30  -0.59474311E-06
          32           42  -0.22157848E-04
          32           50  -0.89266026E-06
          33           33   0.78082192E+03
          33           23  -0.18699636E-05
          33           43  -0.28066608E-05
          34           34   0.13409529E+04
          34           32   0.63443872E+01
          34           35   0.19035065E+02
          34           37  -0.65836821E+02
          34           24  -0.31658155E-05
          34           27   0.58143241E-08
          34           44  -0.47516275E-05
          34           47   0.87268201E-08
          35           35   0.19052837E+02
          35           32   0.63443872E+01
          35           34   0.19035065E+02
          35           37  -0.63477866E+02
          35           40   0.21795643E-05
          35           25  -0.42484262E-10
          35           27   0.16470994E-09
          35           30  -0.52197636E-14
          35           45  -0.63765367E-10
          35           47   0.24721601E-09
          35           50  -0.78344339E-14
          36           36   0.17074662E+04
          36           31   0.79884210E+02
          36           37   0.19543730E+04
          36           39   0.43198833E-04
          36           21  -0.19131143E-06
          36           26  -0.40891514E-05
          36           27  -0.46804606E-05
          36           41  -0.28714265E-06
          36           46  -0.61374783E-05
          36           47  -0.70249846E-05
          37           37   0.26723718E+04
          37           31   0.76117799E+02
          37           32  -0.21147957E+02
          37           34  -0.65878288E+02
          37           35  -0.63519108E+02
          37           36   0.19543478E+04
          37           38  -0.38887502E-04
          37           39  -0.12035985E+00
          37           40   0.49505150E-01
          37           21  -0.18229190E-06
          37           24   0.58149055E-08
          37           25   0.16475051E-09
          37           26  -0.46804003E-05
          37           27  -0.58937839E-05
          37           28   0.15713863E-13
          37           29   0.28826778E-09
          37           30  -0.11851393E-09
          37           41  -0.27360508E-06
          37           44   0.87276927E-08
          37           45   0.24727690E-09
          37           46  -0.70248941E-05
          37           47  -0.88460827E-05
          37           48   0.23585210E-13
          37           49   0.43266612E-09
          37           50  -0.17787962E-09
          38           38   0.66308262E-04
          38           37  -0.38896922E-04
          38           39  -0.14946245E-04
          38           40  -0.37051937E-04
          38           27   0.15715131E-13
          38           28  -0.23320538E-13
          38           29  -0.29226998E-14
          38           30   0.11296639E-13
          38           47   0.23587113E-13
          38           48  -0.35002201E-13
          38           49  -0.43867309E-14
          38           50   0.16955322E-13
          39           39   0.99356224E+02
          39           36   0.43198833E-04
          39           37  -0.12034781E+00
          39           38  -0.14942654E-04
          39           40   0.33536708E+02
          39           27   0.28823896E-09
          39           28  -0.29225902E-14
          39           29  -0.23794469E-06
          39           30  -0.80315886E-07
          39           47   0.43262286E-09
          39           48  -0.43865664E-14
          39           49  -0.35713531E-06
          39           50  -0.12054751E-06
          40           40   0.13484933E+05
          40           31   0.36307130E+04
          40           32   0.24834091E+03
          40           35   0.21795340E-05
          40           37   0.49505150E-01
          40           38  -0.37042339E-04
          40           39   0.33536708E+02
          40           21  -0.86950685E-05
          40           22  -0.59474311E-06
          40           25  -0.52196911E-14
          40           27  -0.11851393E-09
          40           28   0.11294945E-13
          40           29  -0.80315886E-07
          40           30  -0.32294600E-04
          40           41  -0.13050579E-04
          40           42  -0.89266026E-06
          40           45  -0.78343250E-14
          40           47  -0.17787962E-09
          40           48   0.16952779E-13
          40           49  -0.12054751E-06
          40           50  -0.48471527E-04
          41           41   0.97945219E+04
          41           46   0.79884210E+02
          41           47   0.76117799E+02
          41           50   0.36307130E+04
          41           31  -0.23456562E-04
          41           36  -0.19131143E-06
          41           37  -0.18229190E-06
          41           40  -0.86950685E-05
          41           51  -0.35206361E-04
          41           56  -0.28714265E-06
          41           57  -0.27360508E-06
          41           60  -0.13050579E-04
          42           42   0.61664984E+04
          42           44   0.63450217E+01
          42           45   0.63450217E+01
          42           47  -0.21136331E+02
          42           50   0.24834091E+03
          42           32  -0.14762870E-04
          42           40  -0.59474311E-06
          42           52  -0.22157848E-04
          42           60  -0.89266026E-06
          43           43   0.78082192E+03
          43           33  -0.18699636E-05
          43           53  -0.28066608E-05
          44           44   0.13409529E+04
          44           42   0.63443872E+01
          44           45   0.19035065E+02
          44           47  -0.65836821E+02
          44           34  -0.31658155E-05
          44           37   0.58143241E-08
          44           54  -0.47516275E-05
          44           57   0.87268201E-08
          45           45   0.19052837E+02
          45           42   0.63443872E+01
          45           44   0.19035065E+02
          45           47  -0.63477866E+02
          45           50   0.21795643E-05
          45           35  -0.42484262E-10
          45           37   0.16470994E-09
          45           40  -0.52197636E-14
          45           55  -0.63765367E-10
          45           57   0.24721601E-09
          45           60  -0.78344339E-14
          46           46   0.17074662E+04
          46           41   0.79884210E+02
          46           47   0.19543730E+04
          46           49   0.43198833E-04
          46           31  -0.19131143E-06
          46           36  -0.40891514E-05
          46           37  -0.46804606E-05
          46           51  -0.28714265E-06
          46           56  -0.61374783E-05
          46           57  -0.70249846E-05
          47           47   0.26723718E+04
          47           41   0.76117799E+02
          47           42  -0.21147957E+02
          47           44  -0.65878288E+02
          47           45  -0.63519108E+02
          47           46   0.19543478E+04
          47           48  -0.38887502E-04
          47           49  -0.12035985E+00
          47           50   0.49505150E-01
          47           31  -0.18229190E-06
          47           34   0.58149055E-08
          47           35   0.16475051E-09
          47           36  -0.46804003E-05
          47           37  -0.58937839E-05
          47           38   0.15713863E-13
          47           39   0.28826778E-09
          47           40  -0.11851393E-09
          47           51  -0.27360508E-06
          47           54   0.87276927E-08
          47           55   0.24727690E-09
          47           56  -0.70248941E-05
          47           57  -0.88460827E-05
          47           58   0.23585210E-13
          47           59   0.43266612E-09
          47           60  -0.17787962E-09
          48           48   0.66308262E-04
          48           47  -0.38896922E-04
          48           49  -0.14946245E-04
          48           50  -0.37051937E-04
          48           37   0.15715131E-13
          48           38  -0.23320538E-13
          48           39  -0.29226998E-14
          48           40   0.11296639E-13
          48           57   0.23587113E-13
          48           58  -0.35002201E-13
          48           59  -0.43867309E-14
          48           60   0.16955322E-13
          49           49   0.99356224E+02
          49           46   0.43198833E-04
          49           47  -0.12034781E+00
          49           48  -0.14942654E-04
          49           50   0.33536708E+02
          49           37   0.28823896E-09
          49           38  -0.29225902E-14
          49           39  -0.23794469E-06
          49           40  -0.80315886E-07
          49           57   0.43262286E-09
          49           58  -0.43865664E-14
          49           59  -0.35713531E-06
          49           60  -0.12054751E-06
          50           50   0.13484933E+05
          50           41   0.36307130E+04
          50           42   0.24834091E+03
          50           45   0.21795340E-05
          50           47   0.49505150E-01
          50           48  -0.37042339E-04
          50           49   0.33536708E+02
          50           31  -0.86950685E-05
          50           32  -0.59474311E-06
          50           35  -0.52196911E-14
          50           37  -0.11851393E-09
          50           38   0.11294945E-13
          50           39  -0.80315886E-07
          50           40  -0.32294600E-04
          50           51  -0.13050579E-04
          50           52  -0.89266026E-06
          50           55  -0.78343250E-14
          50           57  -0.17787962E-09
          50           58   0.16952779E-13
          50           59  -0.12054751E-06
          50           60  -0.48471527E-04
          51           51   0.97945219E+04
          51           56   0.79884210E+02
          51           57   0.76117799E+02
          51           60   0.36307130E+04
          51           41  -0.23456562E-04
          51           46  -0.19131143E-06
          51           47  -0.18229190E-06
          51           50  -0.86950685E-05
          51           61  -0.35206361E-04
          51           66  -0.28714265E-06
          51           67  -0.27360508E-06
          51           70  -0.13050579E-04
          52           52   0.61664984E+04
          52           54   0.63450217E+01
          52           55   0.63450217E+01
          52           57  -0.21136331E+02
          52           60   0.24834091E+03
          52           42  -0.14762870E-04
          52           50  -0.59474311E-06
          52           62  -0.22157848E-04
          52           70  -0.89266026E-06
          53           53   0.78082192E+03
          53           43  -0.18699636E-05
          53           63  -0.28066608E-05
          54           54   0.13409529E+04
          54           52   0.63443872E+01
          54           55   0.19035065E+02
          54           57  -0.65836821E+02
          54           44  -0.31658155E-05
          54           47   0.58143241E-08
          54           64  -0.47516275E-05
          54           67   0.87268201E-08
          55           55   0.19052837E+02
          55           52   0.63443872E+01
          55           54   0.19035065E+02
          55           57  -0.63477866E+02
          55           60   0.21795643E-05
          55           45  -0.42484262E-10
          55           47   0.16470994E-09
          55           50  -0.52197636E-14
          55           65  -0.63765367E-10
          55           67   0.24721601E-09
          55           70  -0.78344339E-14
          56           56   0.17074662E+04
          56           51   0.79884210E+02
          56           57   0.19543730E+04
          56           59   0.43198833E-04
          56           41  -0.19131143E-06
          56           46  -0.40891514E-05
          56           47  -0.46804606E-05
          56           61  -0.28714265E-06
          56           66  -0.61374783E-05
          56           67  -0.70249846E-05
          57           57   0.26723718E+04
          57           51   0.76117799E+02
          57           52  -0.21147957E+02
          57           54  -0.65878288E+02
          57           55  -0.63519108E+02
          57           56   0.19543478E+04
          57           58  -0.38887502E-04
          57           59  -0.12035985E+00
          57           60   0.49505150E-01
          57           41  -0.18229190E-06
          57           44   0.58149055E-08
          57           45   0.16475051E-09
          57           46  -0.46804003E-05
          57           47  -0.58937839E-05
          57           48   0.15713863E-13
          57           49   0.28826778E-09
          57           50  -0.11851393E-09
          57           61  -0.27360508E-06
          57           64   0.87276927E-08
          57           65   0.24727690E-09
          57           66  -0.70248941E-05
          57           67  -0.88460827E-05
          57           68   0.23585210E-13
          57           69   0.43266612E-09
          57           70  -0.17787962E-09
          58           58   0.66308262E-04
          58           57  -0.38896922E-04
          58           59  -0.14946245E-04
          58           60  -0.37051937E-04
          58           47   0.15715131E-13
          58           48  -0.23320538E-13
          58           49  -0.29226998E-14
          58           50   0.11296639E-13
          58           67   0.23587113E-13
          58           68  -0.35002201E-13
          58           69  -0.43867309E-14
          58           70   0.16955322E-13
          59           59   0.99356224E+02
          59           56   0.43198833E-04
          59           57  -0.12034781E+00
          59           58  -0.14942654E-04
          59           60   0.33536708E+02
          59           47   0.28823896E-09
          59           48  -0.29225902E-14
          59           49  -0.23794469E-06
          59           50  -0.80315886E-07
          59           67   0.43262286E-09
          59           68  -0.43865664E-14
          59           69  -0.35713531E-06
          59           70  -0.12054751E-06
          60           60   0.13484933E+05
          60           51   0.36307130E+04
          60           52   0.24834091E+03
          60           55   0.21795340E-05
          60           57   0.49505150E-01
          60           58  -0.37042339E-04
          60           59   0.33536708E+02
          60           41  -0.86950685E-05
          60           42  -0.59474311E-06
          60           45  -0.52196911E-14
          60           47  -0.11851393E-09
          60           48   0.11294945E-13
          60           49  -0.80315886E-07
          60           50  -0.32294600E-04
          60           61  -0.13050579E-04
          60           62  -0.89266026E-06
          60           65  -0.78343250E-14
          60           67  -0.17787962E-09
          60           68   0.16952779E-13
          60           69  -0.12054751E-06
          60           70  -0.48471527E-04
          61           61   0.97945219E+04
          61           66   0.79884210E+02
          61           67   0.76117799E+02
          61           70   0.36307130E+04
          61           51  -0.23456562E-04
          61           56  -0.19131143E-06
          61           57  -0.18229190E-06
          61           60  -0.86950685E-05
          61           71  -0.35206361E-04
          61           76  -0.28714265E-06
          61           77  -0.27360508E-06
          61           80  -0.13050579E-04
          62           62   0.61664984E+04
          62           64   0.63450217E+01
          62           65   0.63450217E+01
          62           67  -0.21136331E+02
          62           70   0.24834091E+03
          62           52  -0.14762870E-04
          62           60  -0.59474311E-06
          62           72  -0.22157848E-04
          62           80  -0.89266026E-06
          63           63   0.78082192E+03
          63           53  -0.18699636E-05
          63           73  -0.28066608E-05
          64           64   0.13409529E+04
          64           62   0.63443872E+01
          64           65   0.19035065E+02
          64           67  -0.65836821E+02
          64           54  -0.31658155E-05
          64           57   0.58143241E-08
          64           74  -0.47516275E-05
          64           77   0.87268201E-08
          65           65   0.19052837E+02
          65           62   0.63443872E+01
          65           64   0.19035065E+02
          65           67  -0.63477866E+02
          65           70   0.21795643E-05
          65           55  -0.42484262E-10
          65           57   0.16470994E-09
          65           60  -0.52197636E-14
          65           75  -0.63765367E-10
          65           77   0.24721601E-09
          65           80  -0.78344339E-14
          66           66   0.17074662E+04
          66           61   0.79884210E+02
          66           67   0.19543730E+04
          66           69   0.43198833E-04
          66           51  -0.19131143E-06
          66           56  -0.40891514E-05
          66           57  -0.46804606E-05
          66           71  -0.28714265E-06
          66           76  -0.61374783E-05
          66           77  -0.70249846E-05
          67           67   0.26723718E+04
          67           61   0.76117799E+02
          67           62  -0.21147957E+02
          67           64  -0.65878288E+02
          67           65  -0.63519108E+02
          67           66   0.19543478E+04
          67           68  -0.38887502E-04
          67           69  -0.12035985E+00
          67           70   0.49505150E-01
          67           51  -0.18229190E-06
          67           54   0.58149055E-08
          67           55   0.16475051E-09
          67           56  -0.46804003E-05
          67           57  -0.58937839E-05
          67           58   0.15713863E-13
          67           59   0.28826778E-09
          67           60  -0.11851393E-09
          67           71  -0.27360508E-06
          67           74   0.87276927E-08
          67           75   0.24727690E-09
          67           76  -0.70248941E-05
          67           77  -0.88460827E-05
          67           78   0.23585210E-13
          67           79   0.43266612E-09
          67           80  -0.17787962E-09
          68           68   0.66308262E-04
          68           67  -0.38896922E-04
          68           69  -0.14946245E-04
          68           70  -0.37051937E-04
          68           57   0.15715131E-13
          68           58  -0.23320538E-13
          68           59  -0.29226998E-14
          68           60   0.11296639E-13
          68           77   0.23587113E-13
          68           78  -0.35002201E-13
          68           79  -0.43867309E-14
          68           80   0.16955322E-13
          69           69   0.99356224E+02
          69           66   0.43198833E-04
          69           67  -0.12034781E+00
          69           68  -0.14942654E-04
          69           70   0.33536708E+02
          69           57   0.28823896E-09
          69           58  -0.29225902E-14
          69           59  -0.23794469E-06
          69           60  -0.80315886E-07
          69           77   0.43262286E-09
          69           78  -0.43865664E-14
          69           79  -0.35713531E-06
          69           80  -0.12054751E-06
          70           70   0.13484933E+05
          70           61   0.36307130E+04
          70           62   0.24834091E+03
          70           65   0.21795340E-05
          70           67   0.49505150E-01
          70           68  -0.37042339E-04
          70           69   0.33536708E+02
          70           51  -0.86950685E-05
          70           52  -0.59474311E-06
          70           55  -0.52196911E-14
          70           57  -0.11851393E-09
          70           58   0.11294945E-13
          70           59  -0.80315886E-07
          70           60  -0.32294600E-04
          70           71  -0.13050579E-04
          70           72  -0.89266026E-06
          70           75  -0.78343250E-14
          70           77  -0.17787962E-09
          70           78   0.16952779E-13
          70           79  -0.12054751E-06
          70           80  -0.48471527E-04
          71           71   0.97945219E+04
          71           76   0.79884210E+02
          71           77   0.76117799E+02
          71           80   0.36307130E+04
          71           61  -0.23456562E-04
          71           66  -0.19131143E-06
          71           67  -0.18229190E-06
          71           70  -0.86950685E-05
          71           81  -0.35206361E-04
          71           86  -0.28714265E-06
          71           87  -0.27360508E-06
          71           90  -0.13050579E-04
          72           72   0.61664984E+04
          72           74   0.63450217E+01
          72           75   0.63450217E+01
          72           77  -0.21136331E+02
          72           80   0.24834091E+03
          72           62  -0.14762870E-04
          72           70  -0.59474311E-06
          72           82  -0.22157848E-04
          72           90  -0.89266026E-06
          73           73   0.78082192E+03
          73           63  -0.18699636E-05
          73           83  -0.28066608E-05
          74           74   0.13409529E+04
          74           72   0.63443872E+01
          74           75   0.19035065E+02
          74           77  -0.65836821E+02
          74           64  -0.31658155E-05
          74           67   0.58143241E-08
          74           84  -0.47516275E-05
          74           87   0.87268201E-08
          75           75   0.19052837E+02
          75           72   0.63443872E+01
          75           74   0.19035065E+02
          75           77  -0.63477866E+02
          75           80   0.21795643E-05
          75           65  -0.42484262E-10
          75           67   0.16470994E-09
          75           70  -0.52197636E-14
          75           85  -0.63765367E-10
          75           87   0.24721601E-09
          75           90  -0.78344339E-14
          76           76   0.17074662E+04
          76           71   0.79884210E+02
          76           77   0.19543730E+04
          76           79   0.43198833E-04
          76           61  -0.19131143E-06
          76           66  -0.40891514E-05
          76           67  -0.46804606E-05
          76           81  -0.28714265E-06
          76           86  -0.61374783E-05
          76           87  -0.70249846E-05
          77           77   0.26723718E+04
          77           71   0.76117799E+02
          77           72  -0.21147957E+02
          77           74  -0.65878288E+02
          77           75  -0.63519108E+02
          77           76   0.19543478E+04
          77           78  -0.38887502E-04
          77           79  -0.12035985E+00
          77           80   0.49505150E-01
          77           61  -0.18229190E-06
          77           64   0.58149055E-08
          77           65   0.16475051E-09
          77           66  -0.46804003E-05
          77           67  -0.58937839E-05
          77           68   0.15713863E-13
          77           69   0.28826778E-09
          77           70  -0.11851393E-09
          77           81  -0.27360508E-06
          77           84   0.87276927E-08
          77           85   0.24727690E-09
          77           86  -0.70248941E-05
          77           87  -0.88460827E-05
          77           88   0.23585210E-13
          77           89   0.43266612E-09
          77           90  -0.17787962E-09
          78           78   0.66308262E-04
          78           77  -0.38896922E-04
          78           79  -0.14946245E-04
          78           80  -0.37051937E-04
          78           67   0.15715131E-13
          78           68  -0.23320538E-13
          78           69  -0.29226998E-14
          78           70   0.11296639E-13
          78           87   0.23587113E-13
          78           88  -0.35002201E-13
          78           89  -0.43867309E-14
          78           90   0.16955322E-13
          79           79   0.99356224E+02
          79           76   0.43198833E-04
          79           77  -0.12034781E+00
          79           78  -0.14942654E-04
          79           80   0.33536708E+02
          79           67   0.28823896E-09
          79           68  -0.29225902E-14
          79           69  -0.23794469E-06
          79           70  -0.80315886E-07
          79           87   0.43262286E-09
          79           88  -0.43865664E-14
          79           89  -0.35713531E-06
          79           90  -0.12054751E-06
          80           80   0.13484933E+05
          80           71   0.36307130E+04
          80           72   0.24834091E+03
          80           75   0.21795340E-05
          80           77   0.49505150E-01
          80           78  -0.37042339E-04
          80           79   0.33536708E+02
          80           61  -0.86950685E-05
          80           62  -0.59474311E-06
          80           65  -0.52196911E-14
          80           67  -0.11851393E-09
          80           68   0.11294945E-13
          80           69  -0.80315886E-07
          80           70  -0.32294600E-04
          80           81  -0.13050579E-04
          80           82  -0.89266026E-06
          80           85  -0.78343250E-14
          80           87  -0.17787962E-09
          80           88   0.16952779E-13
          80           89  -0.12054751E-06
          80           90  -0.48471527E-04
          81           81   0.97945219E+04
          81           86   0.79884210E+02
          81           87   0.76117799E+02
          81           90   0.36307130E+04
          81           71  -0.23456562E-04
          81           76  -0.19131143E-06
          81           77  -0.18229190E-06
          81           80  -0.86950685E-05
          81           91  -0.35206361E-04
          81           96  -0.28714265E-06
          81           97  -0.27360508E-06
          81          100  -0.13050579E-04
          82           82   0.61664984E+04
          82           84   0.63450217E+01
          82           85   0.63450217E+01
          82           87  -0.21136331E+02
          82           90   0.24834091E+03
          82           72  -0.14762870E-04
          82           80  -0.59474311E-06
          82           92  -0.22157848E-04
          82          100  -0.89266026E-06
          83           83   0.78082192E+03
          83           73  -0.18699636E-05
          83           93  -0.28066608E-05
          84           84   0.13409529E+04
          84           82   0.63443872E+01
          84           85   0.19035065E+02
          84           87  -0.65836821E+02
          84           74  -0.31658155E-05
          84           77   0.58143241E-08
          84           94  -0.47516275E-05
          84           97   0.87268201E-08
          85           85   0.19052837E+02
          85           82   0.63443872E+01
          85           84   0.19035065E+02
          85           87  -0.63477866E+02
          85           90   0.21795643E-05
          85           75  -0.42484262E-10
          85           77   0.16470994E-09
          85           80  -0.52197636E-14
          85           95  -0.63765367E-10
          85           97   0.24721601E-09
          85          100  -0.78344339E-14
          86           86   0.17074662E+04
          86           81   0.79884210E+02
          86           87   0.19543730E+04
          86           89   0.43198833E-04
          86           71  -0.19131143E-06
          86           76  -0.40891514E-05
          86           77  -0.46804606E-05
          86           91  -0.28714265E-06
          86           96  -0.61374783E-05
          86           97  -0.70249846E-05
          87           87   0.26723718E+04
          87           81   0.76117799E+02
          87           82  -0.21147957E+02
          87           84  -0.65878288E+02
          87           85  -0.63519108E+02
          87           86   0.19543478E+04
          87           88  -0.38887502E-04
          87           89  -0.12035985E+00
          87           90   0.49505150E-01
          87           71  -0.18229190E-06
          87           74   0.58149055E-08
          87           75   0.16475051E-09
          87           76  -0.46804003E-05
          87           77  -0.58937839E-05
          87           78   0.15713863E-13
          87           79   0.28826778E-09
          87           80  -0.11851393E-09
          87           91  -0.27360508E-06
          87           94   0.87276927E-08
          87           95   0.24727690E-09
          87           96  -0.70248941E-05
          87           97  -0.88460827E-05
          87           98   0.23585210E-13
          87           99   0.43266612E-09
          87          100  -0.17787962E-09
          88           88   0.66308262E-04
          88           87  -0.38896922E-04
          88           89  -0.14946245E-04
          88           90  -0.37051937E-04
          88           77   0.15715131E-13
          88           78  -0.23320538E-13
          88           79  -0.29226998E-14
          88           80   0.11296639E-13
          88           97   0.23587113E-13
          88           98  -0.35002201E-13
          88           99  -0.43867309E-14
          88          100   0.16955322E-13
          89           89   0.99356224E+02
          89           86   0.43198833E-04
          89           87  -0.12034781E+00
          89           88  -0.14942654E-04
          89           90   0.33536708E+02
          89           77   0.28823896E-09
          89           78  -0.29225902E-14
          89           79  -0.23794469E-06
          89           80  -0.80315886E-07
          89           97   0.43262286E-09
          89           98  -0.43865664E-14
          89           99  -0.35713531E-06
          89          100  -0.12054751E-06
          90           90   0.13484933E+05
          90           81   0.36307130E+04
          90           82   0.24834091E+03
          90           85   0.21795340E-05
          90           87   0.49505150E-01
          90           88  -0.37042339E-04
          90           89   0.33536708E+02
          90           71  -0.86950685E-05
          90           72  -0.59474311E-06
          90           75  -0.52196911E-14
          90           77  -0.11851393E-09
          90           78   0.11294945E-13
          90           79  -0.80315886E-07
          90           80  -0.32294600E-04
          90           91  -0.13050579E-04
          90           92  -0.89266026E-06
          90           95  -0.78343250E-14
          90           97  -0.17787962E-09
          90           98   0.16952779E-13
          90           99  -0.12054751E-06
          90          100  -0.48471527E-04
          91           91   0.97945219E+04
          91           96   0.79884210E+02
          91           97   0.76117799E+02
          91          100   0.36307130E+04
          91           81  -0.23456562E-04
          91           86  -0.19131143E-06
          91           87  -0.18229190E-06
          91           90  -0.86950685E-05
          91          101  -0.35206361E-04
          91          106  -0.28714265E-06
          91          107  -0.27360508E-06
          91          110  -0.13050579E-04
          92           92   0.61664984E+04
          92           94   0.63450217E+01
          92           95   0.63450217E+01
          92           97  -0.21136331E+02
          92          100   0.24834091E+03
          92           82  -0.14762870E-04
          92           90  -0.59474311E-06
          92          102  -0.22157848E-04
          92          110  -0.89266026E-06
          93           93   0.78082192E+03
          93           83  -0.18699636E-05
          93          103  -0.28066608E-05
          94           94   0.13409529E+04
          94           92   0.63443872E+01
          94           95   0.19035065E+02
          94           97  -0.65836821E+02
          94           84  -0.31658155E-05
          94           87   0.58143241E-08
          94          104  -0.47516275E-05
          94          107   0.87268201E-08
          95           95   0.19052837E+02
          95           92   0.63443872E+01
          95           94   0.19035065E+02
          95           97  -0.63477866E+02
          95          100   0.21795643E-05
          95           85  -0.42484262E-10
          95           87   0.16470994E-09
          95           90  -0.52197636E-14
          95          105  -0.63765367E-10
          95          107   0.24721601E-09
          95          110  -0.78344339E-14
          96           96   0.17074662E+04
          96           91   0.79884210E+02
          96           97   0.19543730E+04
          96           99   0.43198833E-04
          96           81  -0.19131143E-06
          96           86  -0.40891514E-05
          96           87  -0.46804606E-05
          96          101  -0.28714265E-06
          96          106  -0.61374783E-05
          96          107  -0.70249846E-05
          97           97   0.26723718E+04
          97           91   0.76117799E+02
          97           92  -0.21147957E+02
          97           94  -0.65878288E+02
          97           95  -0.63519108E+02
          97           96   0.19543478E+04
          97           98  -0.38887502E-04
          97           99  -0.12035985E+00
          97          100   0.49505150E-01
          97           81  -0.18229190E-06
          97           84   0.58149055E-08
          97           85   0.16475051E-09
          97           86  -0.46804003E-05
          97           87  -0.58937839E-05
          97           88   0.15713863E-13
          97           89   0.28826778E-09
          97           90  -0.11851393E-09
          97          101  -0.27360508E-06
          97          104   0.87276927E-08
          97          105   0.24727690E-09
          97          106  -0.70248941E-05
          97          107  -0.88460827E-05
          97          108   0.23585210E-13
          97          109   0.43266612E-09
          97          110  -0.17787962E-09
          98           98   0.66308262E-04
          98           97  -0.38896922E-04
          98           99  -0.14946245E-04
          98          100  -0.37051937E-04
          98           87   0.15715131E-13
          98           88  -0.23320538E-13
          98           89  -0.29226998E-14
          98           90   0.11296639E-13
          98          107   0.23587113E-13
          98          108  -0.35002201E-13
          98          109  -0.43867309E-14
          98          110   0.16955322E-13
          99           99   0.99356224E+02
          99           96   0.43198833E-04
          99           97  -0.12034781E+00
          99           98  -0.14942654E-04
          99          100   0.33536708E+02
          99           87   0.28823896E-09
          99           88  -0.29225902E-14
          99           89  -0.23794469E-06
          99           90  -0.80315886E-07
          99          107   0.43262286E-09
          99          108  -0.43865664E-14
          99          109  -0.35713531E-06
          99          110  -0.12054751E-06
         100          100   0.13484933E+05
         100           91   0.36307130E+04
         100           92   0.24834091E+03
         100           95   0.21795340E-05
         100           97   0.49505150E-01
         100           98  -0.37042339E-04
         100           99   0.33536708E+02
         100           81  -0.86950685E-05
         100           82  -0.59474311E-06
         100           85  -0.52196911E-14
         100           87  -0.11851393E-09
         100           88   0.11294945E-13
         100           89  -0.80315886E-07
         100           90  -0.32294600E-04
         100          101  -0.13050579E-04
         100          102  -0.89266026E-06
         100          105  -0.78343250E-14
         100          107  -0.17787962E-09
         100          108   0.16952779E-13
         100          109  -0.12054751E-06
         100          110  -0.48471527E-04
         101          101   0.97945219E+04
         101          106   0.79884210E+02
         101          107   0.76117799E+02
         101          110   0.36307130E+04
         101           91  -0.23456562E-04
         101           96  -0.19131143E-06
         101           97  -0.18229190E-06
         101          100  -0.86950685E-05
         101          111  -0.35206361E-04
         101          116  -0.28714265E-06
         101          117  -0.27360508E-06
         101          120  -0.13050579E-04
         102          102   0.61664984E+04
         102          104   0.63450217E+01
         102          105   0.63450217E+01
         102          107  -0.21136331E+02
         102          110   0.24834091E+03
         102           92  -0.14762870E-04
         102          100  -0.59474311E-06
         102          112  -0.22157848E-04
         102          120  -0.89266026E-06
         103          103   0.78082192E+03
         103           93  -0.18699636E-05
         103          113  -0.28066608E-05
         104          104   0.13409529E+04
         104          102   0.63443872E+01
         104          105   0.19035065E+02
         104          107  -0.65836821E+02
         104           94  -0.31658155E-05
         104           97   0.58143241E-08
         104          114  -0.47516275E-05
         104          117   0.87268201E-08
         105          105   0.19052837E+02
         105          102   0.63443872E+01
         105          104   0.19035065E+02
         105          107  -0.63477866E+02
         105          110   0.21795643E-05
         105           95  -0.42484262E-10
         105           97   0.16470994E-09
         105          100  -0.52197636E-14
         105          115  -0.63765367E-10
         105          117   0.24721601E-09
         105          120  -0.78344339E-14
         106          106   0.17074662E+04
         106          101   0.79884210E+02
         106          107   0.19543730E+04
         106          109   0.43198833E-04
         106           91  -0.19131143E-06
         106           96  -0.40891514E-05
         106           97  -0.46804606E-05
         106          111  -0.28714265E-06
         106          116  -0.61374783E-05
         106          117  -0.70249846E-05
         107          107   0.26723718E+04
         107          101   0.76117799E+02
         107          102  -0.21147957E+02
         107          104  -0.65878288E+02
         107          105  -0.63519108E+02
         107          106   0.19543478E+04
         107          108  -0.38887502E-04
         107          109  -0.12035985E+00
         107          110   0.49505150E-01
         107           91  -0.18229190E-06
         107           94   0.58149055E-08
         107           95   0.16475051E-09
         107           96  -0.46804003E-05
         107           97  -0.58937839E-05
         107           98   0.15713863E-13
         107           99   0.28826778E-09
         107          100  -0.11851393E-09
         107          111  -0.27360508E-06
         107          114   0.87276927E-08
         107          115   0.24727690E-09
         107          116  -0.70248941E-05
         107          117  -0.88460827E-05
         107          118   0.23585210E-13
         107          119   0.43266612E-09
         107          120  -0.17787962E-09
         108          108   0.66308262E-04
         108          107  -0.38896922E-04
         108          109  -0.14946245E-04
         108          110  -0.37051937E-04
         108           97   0.15715131E-13
         108           98  -0.23320538E-13
         108           99  -0.29226998E-14
         108          100   0.11296639E-13
         108          117   0.23587113E-13
         108          118  -0.35002201E-13
         108          119  -0.43867309E-14
         108          120   0.16955322E-13
         109          109   0.99356224E+02
         109          106   0.43198833E-04
         109          107  -0.12034781E+00
         109          108  -0.14942654E-04
         109          110   0.33536708E+02
         109           97   0.28823896E-09
         109           98  -0.29225902E-14
         109           99  -0.23794469E-06
         109          100  -0.80315886E-07
         109          117   0.43262286E-09
         109          118  -0.43865664E-14
         109          119  -0.35713531E-06
         109          120  -0.12054751E-06
         110          110   0.13484933E+05
         110          101   0.36307130E+04
         110          102   0.24834091E+03
         110          105   0.21795340E-05
         110          107   0.49505150E-01
         110          108  -0.37042339E-04
         110          109   0.33536708E+02
         110           91  -0.86950685E-05
         110           92  -0.59474311E-06
         110           95  -0.52196911E-14
         110           97  -0.11851393E-09
         110           98   0.11294945E-13
         110           99  -0.80315886E-07
         110          100  -0.32294600E-04
         110          111  -0.13050579E-04
         110          112  -0.89266026E-06
         110          115  -0.78343250E-14
         110          117  -0.17787962E-09
         110          118   0.16952779E-13
         110          119  -0.12054751E-06
         110          120  -0.48471527E-04
         111          111   0.97945219E+04
         111          116   0.79884210E+02
         111          117   0.76117799E+02
         111          120   0.36307130E+04
         111          101  -0.23456562E-04
         111          106  -0.19131143E-06
         111          107  -0.18229190E-06
         111          110  -0.86950685E-05
         111          121  -0.35206361E-04
         111          126  -0.28714265E-06
         111          127  -0.27360508E-06
         111          130  -0.13050579E-04
         112          112   0.61664984E+04
         112          114   0.63450217E+01
         112          115   0.63450217E+01
         112          117  -0.21136331E+02
         112          120   0.24834091E+03
         112          102  -0.14762870E-04
         112          110  -0.59474311E-06
         112          122  -0.22157848E-04
         112          130  -0.89266026E-06
         113          113   0.78082192E+03
         113          103  -0.18699636E-05
         113          123  -0.28066608E-05
         114          114   0.13409529E+04
         114          112   0.63443872E+01
         114          115   0.19035065E+02
         114          117  -0.65836821E+02
         114          104  -0.31658155E-05
         114          107   0.58143241E-08
         114          124  -0.47516275E-05
         114          127   0.87268201E-08
         115          115   0.19052837E+02
         115          112   0.63443872E+01
         115          114   0.19035065E+02
         115          117  -0.63477866E+02
         115          120   0.21795643E-05
         115          105  -0.42484262E-10
         115          107   0.16470994E-09
         115          110  -0.52197636E-14
         115          125  -0.63765367E-10
         115          127   0.24721601E-09
         115          130  -0.78344339E-14
         116          116   0.17074662E+04
         116          111   0.79884210E+02
         116          117   0.19543730E+04
         116          119   0.43198833E-04
         116          101  -0.19131143E-06
         116          106  -0.40891514E-05
         116          107  -0.46804606E-05
         116          121  -0.28714265E-06
         116          126  -0.61374783E-05
         116          127  -0.70249846E-05
         117          117   0.26723718E+04
         117          111   0.76117799E+02
         117          112  -0.21147957E+02
         117          114  -0.65878288E+02
         117          115  -0.63519108E+02
         117          116   0.19543478E+04
         117          118  -0.38887502E-04
         117          119  -0.12035985E+00
         117          120   0.49505150E-01
         117          101  -0.18229190E-06
         117          104   0.58149055E-08
         117          105   0.16475051E-09
         117          106  -0.46804003E-05
         117          107  -0.58937839E-05
         117          108   0.15713863E-13
         117          109   0.28826778E-09
         117          110  -0.11851393E-09
         117          121  -0.27360508E-06
         117          124   0.87276927E-08
         117          125   0.24727690E-09
         117          126  -0.70248941E-05
         117          127  -0.88460827E-05
         117          128   0.23585210E-13
         117          129   0.43266612E-09
         117          130  -0.17787962E-09
         118          118   0.66308262E-04
         118          117  -0.38896922E-04
         118          119  -0.14946245E-04
         118          120  -0.37051937E-04
         118          107   0.15715131E-13
         118          108  -0.23320538E-13
         118          109  -0.29226998E-14
         118          110   0.11296639E-13
         118          127   0.23587113E-13
         118          128  -0.35002201E-13
         118          129  -0.43867309E-14
         118          130   0.16955322E-13
         119          119   0.99356224E+02
         119          116   0.43198833E-04
         119          117  -0.12034781E+00
         119          118  -0.14942654E-04
         119          120   0.33536708E+02
         119          107   0.28823896E-09
         119          108  -0.29225902E-14
         119          109  -0.23794469E-06
         119          110  -0.80315886E-07
         119          127   0.43262286E-09
         119          128  -0.43865664E-14
         119          129  -0.35713531E-06
         119          130  -0.12054751E-06
         120          120   0.13484933E+05
         120          111   0.36307130E+04
         120          112   0.24834091E+03
         120          115   0.21795340E-05
         120          117   0.49505150E-01
         120          118  -0.37042339E-04
         120          119   0.33536708E+02
         120          101  -0.86950685E-05
         120          102  -0.59474311E-06
         120          105  -0.52196911E-14
         120          107  -0.11851393E-09
         120          108   0.11294945E-13
         120          109  -0.80315886E-07
         120          110  -0.32294600E-04
         120          121  -0.13050579E-04
         120          122  -0.89266026E-06
         120          125  -0.78343250E-14
         120          127  -0.17787962E-09
         120          128   0.16952779E-13
         120          129  -0.12054751E-06
         120          130  -0.48471527E-04
         121          121   0.97945219E+04
         121          126   0.79884210E+02
         121          127   0.76117799E+02
         121          130   0.36307130E+04
         121          111  -0.23456562E-04
         121          116  -0.19131143E-06
         121          117  -0.18229190E-06
         121          120  -0.86950685E-05
         121          131  -0.35206361E-04
         121          136  -0.28714265E-06
         121          137  -0.27360508E-06
         121          140  -0.13050579E-04
         122          122   0.61664984E+04
         122          124   0.63450217E+01
         122          125   0.63450217E+01
         122          127  -0.21136331E+02
         122          130   0.24834091E+03
         122          112  -0.14762870E-04
         122          120  -0.59474311E-06
         122          132  -0.22157848E-04
         122          140  -0.89266026E-06
         123          123   0.78082192E+03
         123          113  -0.18699636E-05
         123          133  -0.28066608E-05
         124          124   0.13409529E+04
         124          122   0.63443872E+01
         124          125   0.19035065E+02
         124          127  -0.65836821E+02
         124          114  -0.31658155E-05
         124          117   0.58143241E-08
         124          134  -0.47516275E-05
         124          137   0.87268201E-08
         125          125   0.19052837E+02
         125          122   0.63443872E+01
         125          124   0.19035065E+02
         125          127  -0.63477866E+02
         125          130   0.21795643E-05
         125          115  -0.42484262E-10
         125          117   0.16470994E-09
         125          120  -0.52197636E-14
         125          135  -0.63765367E-10
         125          137   0.24721601E-09
         125          140  -0.78344339E-14
         126          126   0.17074662E+04
         126          121   0.79884210E+02
         126          127   0.19543730E+04
         126          129   0.43198833E-04
         126          111  -0.19131143E-06
         126          116  -0.40891514E-05
         126          117  -0.46804606E-05
         126          131  -0.28714265E-06
         126          136  -0.61374783E-05
         126          137  -0.70249846E-05
         127          127   0.26723718E+04
         127          121   0.76117799E+02
         127          122  -0.21147957E+02
         127          124  -0.65878288E+02
         127          125  -0.63519108E+02
         127          126   0.19543478E+04
         127          128  -0.38887502E-04
         127          129  -0.12035985E+00
         127          130   0.49505150E-01
         127          111  -0.18229190E-06
         127          114   0.58149055E-08
         127          115   0.16475051E-09
         127          116  -0.46804003E-05
         127          117  -0.58937839E-05
         127          118   0.15713863E-13
         127          119   0.28826778E-09
         127          120  -0.11851393E-09
         127          131  -0.27360508E-06
         127          134   0.87276927E-08
         127          135   0.24727690E-09
         127          136  -0.70248941E-05
         127          137  -0.88460827E-05
         127          138   0.23585210E-13
         127          139   0.43266612E-09
         127          140  -0.17787962E-09
         128          128   0.66308262E-04
         128          127  -0.38896922E-04
         128          129  -0.14946245E-04
         128          130  -0.37051937E-04
         128          117   0.15715131E-13
         128          118  -0.23320538E-13
         128          119  -0.29226998E-14
         128          120   0.11296639E-13
         128          137   0.23587113E-13
         128          138  -0.35002201E-13
         128          139  -0.43867309E-14
         128          140   0.16955322E-13
         129          129   0.99356224E+02
         129          126   0.43198833E-04
         129          127  -0.12034781E+00
         129          128  -0.14942654E-04
         129          130   0.33536708E+02
         129          117   0.28823896E-09
         129          118  -0.29225902E-14
         129          119  -0.23794469E-06
         129          120  -0.80315886E-07
         129          137   0.43262286E-09
         129          138  -0.43865664E-14
         129          139  -0.35713531E-06
         129          140  -0.12054751E-06
         130          130   0.13484933E+05
         130          121   0.36307130E+04
         130          122   0.24834091E+03
         130          125   0.21795340E-05
         130          127   0.49505150E-01
         130          128  -0.37042339E-04
         130          129   0.33536708E+02
         130          111  -0.86950685E-05
         130          112  -0.59474311E-06
         130          115  -0.52196911E-14
         130          117  -0.11851393E-09
         130          118   0.11294945E-13
         130          119  -0.80315886E-07
         130          120  -0.32294600E-04
         130          131  -0.13050579E-04
         130          132  -0.89266026E-06
         130          135  -0.78343250E-14
         130          137  -0.17787962E-09
         130          138   0.16952779E-13
         130          139  -0.12054751E-06
         130          140  -0.48471527E-04
         131          131   0.97945219E+04
         131          136   0.79884210E+02
         131          137   0.76117799E+02
         131          140   0.36307130E+04
         131          121  -0.23456562E-04
         131          126  -0.19131143E-06
         131          127  -0.18229190E-06
         131          130  -0.86950685E-05
         131          141  -0.35206361E-04
         131          146  -0.28714265E-06
         131          147  -0.27360508E-06
         131          150  -0.13050579E-04
         132          132   0.61664984E+04
         132          134   0.63450217E+01
         132          135   0.63450217E+01
         132          137  -0.21136331E+02
         132          140   0.24834091E+03
         132          122  -0.14762870E-04
         132          130  -0.59474311E-06
         132          142  -0.22157848E-04
         132          150  -0.89266026E-06
         133          133   0.78082192E+03
         133          123  -0.18699636E-05
         133          143  -0.28066608E-05
         134          134   0.13409529E+04
         134          132   0.63443872E+01
         134          135   0.19035065E+02
         134          137  -0.65836821E+02
         134          124  -0.31658155E-05
         134          127   0.58143241E-08
         134          144  -0.47516275E-05
         134          147   0.87268201E-08
         135          135   0.19052837E+02
         135          132   0.63443872E+01
         135          134   0.19035065E+02
         135          137  -0.63477866E+02
         135          140   0.21795643E-05
         135          125  -0.42484262E-10
         135          127   0.16470994E-09
         135          130  -0.52197636E-14
         135          145  -0.63765367E-10
         135          147   0.24721601E-09
         135          150  -0.78344339E-14
         136          136   0.17074662E+04
         136          131   0.79884210E+02
         136          137   0.19543730E+04
         136          139   0.43198833E-04
         136          121  -0.19131143E-06
         136          126  -0.40891514E-05
         136          127  -0.46804606E-05
         136          141  -0.28714265E-06
         136          146  -0.61374783E-05
         136          147  -0.70249846E-05
         137          137   0.26723718E+04
         137          131   0.76117799E+02
         137          132  -0.21147957E+02
         137          134  -0.65878288E+02
         137          135  -0.63519108E+02
         137          136   0.19543478E+04
         137          138  -0.38887502E-04
         137          139  -0.12035985E+00
         137          140   0.49505150E-01
         137          121  -0.18229190E-06
         137          124   0.58149055E-08
         137          125   0.16475051E-09
         137          126  -0.46804003E-05
         137          127  -0.58937839E-05
         137          128   0.15713863E-13
         137          129   0.28826778E-09
         137          130  -0.11851393E-09
         137          141  -0.27360508E-06
         137          144   0.87276927E-08
         137          145   0.24727690E-09
         137          146  -0.70248941E-05
         137          147  -0.88460827E-05
         137          148   0.23585210E-13
         137          149   0.43266612E-09
         137          150  -0.17787962E-09
         138          138   0.66308262E-04
         138          137  -0.38896922E-04
         138          139  -0.14946245E-04
         138          140  -0.37051937E-04
         138          127   0.15715131E-13
         138          128  -0.23320538E-13
         138          129  -0.29226998E-14
         138          130   0.11296639E-13
         138          147   0.23587113E-13
         138          148  -0.35002201E-13
         138          149  -0.43867309E-14
         138          150   0.16955322E-13
         139          139   0.99356224E+02
         139          136   0.43198833E-04
         139          137  -0.12034781E+00
         139          138  -0.14942654E-04
         139          140   0.33536708E+02
         139          127   0.28823896E-09
         139          128  -0.29225902E-14
         139          129  -0.23794469E-06
         139          130  -0.80315886E-07
         139          147   0.43262286E-09
         139          148  -0.43865664E-14
         139          149  -0.35713531E-06
         139          150  -0.12054751E-06
         140          140   0.13484933E+05
         140          131   0.36307130E+04
         140          132   0.24834091E+03
         140          135   0.21795340E-05
         140          137   0.49505150E-01
         140          138  -0.37042339E-04
         140          139   0.33536708E+02
         140          121  -0.86950685E-05
         140          122  -0.59474311E-06
         140          125  -0.52196911E-14
         140          127  -0.11851393E-09
         140          128   0.11294945E-13
         140          129  -0.80315886E-07
         140          130  -0.32294600E-04
         140          141  -0.13050579E-04
         140          142  -0.89266026E-06
         140          145  -0.78343250E-14
         140          147  -0.17787962E-09
         140          148   0.16952779E-13
         140          149  -0.12054751E-06
         140          150  -0.48471527E-04
         141          141   0.97945219E+04
         141          146   0.79884210E+02
         141          147   0.76117799E+02
         141          150   0.36307130E+04
         141          131  -0.23456562E-04
         141          136  -0.19131143E-06
         141          137  -0.18229190E-06
         141          140  -0.86950685E-05
         141          151  -0.35206361E-04
         141          156  -0.28714265E-06
         141          157  -0.27360508E-06
         141          160  -0.13050579E-04
         142          142   0.61664984E+04
         142          144   0.63450217E+01
         142          145   0.63450217E+01
         142          147  -0.21136331E+02
         142          150   0.24834091E+03
         142          132  -0.14762870E-04
         142          140  -0.59474311E-06
         142          152  -0.22157848E-04
         142          160  -0.89266026E-06
         143          143   0.78082192E+03
         143          133  -0.18699636E-05
         143          153  -0.28066608E-05
         144          144   0.13409529E+04
         144          142   0.63443872E+01
         144          145   0.19035065E+02
         144          147  -0.65836821E+02
         144          134  -0.31658155E-05
         144          137   0.58143241E-08
         144          154  -0.47516275E-05
         144          157   0.87268201E-08
         145          145   0.19052837E+02
         145          142   0.63443872E+01
         145          144   0.19035065E+02
         145          147  -0.63477866E+02
         145          150   0.21795643E-05
         145          135  -0.42484262E-10
         145          137   0.16470994E-09
         145          140  -0.52197636E-14
         145          155  -0.63765367E-10
         145          157   0.24721601E-09
         145          160  -0.78344339E-14
         146          146   0.17074662E+04
         146          141   0.79884210E+02
         146          147   0.19543730E+04
         146          149   0.43198833E-04
         146          131  -0.19131143E-06
         146          136  -0.40891514E-05
         146          137  -0.46804606E-05
         146          151  -0.28714265E-06
         146          156  -0.61374783E-05
         146          157  -0.70249846E-05
         147          147   0.26723718E+04
         147          141   0.76117799E+02
         147          142  -0.21147957E+02
         147          144  -0.65878288E+02
         147          145  -0.63519108E+02
         147          146   0.19543478E+04
         147          148  -0.38887502E-04
         147          149  -0.12035985E+00
         147          150   0.49505150E-01
         147          131  -0.18229190E-06
         147          134   0.58149055E-08
         147          135   0.16475051E-09
         147          136  -0.46804003E-05
         147          137  -0.58937839E-05
         147          138   0.15713863E-13
         147          139   0.28826778E-09
         147          140  -0.11851393E-09
         147          151  -0.27360508E-06
         147          154   0.87276927E-08
         147          155   0.24727690E-09
         147          156  -0.70248941E-05
         147          157  -0.88460827E-05
         147          158   0.23585210E-13
         147          159   0.43266612E-09
         147          160  -0.17787962E-09
         148          148   0.66308262E-04
         148          147  -0.38896922E-04
         148          149  -0.14946245E-04
         148          150  -0.37051937E-04
         148          137   0.15715131E-13
         148          138  -0.23320538E-13
         148          139  -0.29226998E-14
         148          140   0.11296639E-13
         148          157   0.23587113E-13
         148          158  -0.35002201E-13
         148          159  -0.43867309E-14
         148          160   0.16955322E-13
         149          149   0.99356224E+02
         149          146   0.43198833E-04
         149          147  -0.12034781E+00
         149          148  -0.14942654E-04
         149          150   0.33536708E+02
         149          137   0.28823896E-09
         149          138  -0.29225902E-14
         149          139  -0.23794469E-06
         149          140  -0.80315886E-07
         149          157   0.43262286E-09
         149          158  -0.43865664E-14
         149          159  -0.35713531E-06
         149          160  -0.12054751E-06
         150          150   0.13484933E+05
         150          141   0.36307130E+04
         150          142   0.24834091E+03
         150          145   0.21795340E-05
         150          147   0.49505150E-01
         150          148  -0.37042339E-04
         150          149   0.33536708E+02
         150          131  -0.86950685E-05
         150          132  -0.59474311E-06
         150          135  -0.52196911E-14
         150          137  -0.11851393E-09
         150          138   0.11294945E-13
         150          139  -0.80315886E-07
         150          140  -0.32294600E-04
         150          151  -0.13050579E-04
         150          152  -0.89266026E-06
         150          155  -0.78343250E-14
         150          157  -0.17787962E-09
         150          158   0.16952779E-13
         150          159  -0.12054751E-06
         150          160  -0.48471527E-04
         151          151   0.97945219E+04
         151          156   0.79884210E+02
         151          157   0.76117799E+02
         151          160   0.36307130E+04
         151          141  -0.23456562E-04
         151          146  -0.19131143E-06
         151          147  -0.18229190E-06
         151          150  -0.86950685E-05
         151          161  -0.35206361E-04
         151          166  -0.28714265E-06
         151          167  -0.27360508E-06
         151          170  -0.13050579E-04
         152          152   0.61664984E+04
         152          154   0.63450217E+01
         152          155   0.63450217E+01
         152          157  -0.21136331E+02
         152          160   0.24834091E+03
         152          142  -0.14762870E-04
         152          150  -0.59474311E-06
         152          162  -0.22157848E-04
         152          170  -0.89266026E-06
         153          153   0.78082192E+03
         153          143  -0.18699636E-05
         153          163  -0.28066608E-05
         154          154   0.13409529E+04
         154          152   0.63443872E+01
         154          155   0.19035065E+02
         154          157  -0.65836821E+02
         154          144  -0.31658155E-05
         154          147   0.58143241E-08
         154          164  -0.47516275E-05
         154          167   0.87268201E-08
         155          155   0.19052837E+02
         155          152   0.63443872E+01
         155          154   0.19035065E+02
         155          157  -0.63477866E+02
         155          160   0.21795643E-05
         155          145  -0.42484262E-10
         155          147   0.16470994E-09
         155          150  -0.52197636E-14
         155          165  -0.63765367E-10
         155          167   0.24721601E-09
         155          170  -0.78344339E-14
         156          156   0.17074662E+04
         156          151   0.79884210E+02
         156          157   0.19543730E+04
         156          159   0.43198833E-04
         156          141  -0.19131143E-06
         156          146  -0.40891514E-05
         156          147  -0.46804606E-05
         156          161  -0.28714265E-06
         156          166  -0.61374783E-05
         156          167  -0.70249846E-05
         157          157   0.26723718E+04
         157          151   0.76117799E+02
         157          152  -0.21147957E+02
         157          154  -0.65878288E+02
         157          155  -0.63519108E+02
         157          156   0.19543478E+04
         157          158  -0.38887502E-04
         157          159  -0.12035985E+00
         157          160   0.49505150E-01
         157          141  -0.18229190E-06
         157          144   0.58149055E-08
         157          145   0.16475051E-09
         157          146  -0.46804003E-05
         157          147  -0.58937839E-05
         157          148   0.15713863E-13
         157          149   0.28826778E-09
         157          150  -0.11851393E-09
         157          161  -0.27360508E-06
         157          164   0.87276927E-08
         157          165   0.24727690E-09
         157          166  -0.70248941E-05
         157          167  -0.88460827E-05
         157          168   0.23585210E-13
         157          169   0.43266612E-09
         157          170  -0.17787962E-09
         158          158   0.66308262E-04
         158          157  -0.38896922E-04
         158          159  -0.14946245E-04
         158          160  -0.37051937E-04
         158          147   0.15715131E-13
         158          148  -0.23320538E-13
         158          149  -0.29226998E-14
         158          150   0.11296639E-13
         158          167   0.23587113E-13
         158          168  -0.35002201E-13
         158          169  -0.43867309E-14
         158          170   0.16955322E-13
         159          159   0.99356224E+02
         159          156   0.43198833E-04
         159          157  -0.12034781E+00
         159          158  -0.14942654E-04
         159          160   0.33536708E+02
         159          147   0.28823896E-09
         159          148  -0.29225902E-14
         159          149  -0.23794469E-06
         159          150  -0.80315886E-07
         159          167   0.43262286E-09
         159          168  -0.43865664E-14
         159          169  -0.35713531E-06
         159          170  -0.12054751E-06
         160          160   0.13484933E+05
         160          151   0.36307130E+04
         160          152   0.24834091E+03
         160          155   0.21795340E-05
         160          157   0.49505150E-01
         160          158  -0.37042339E-04
         160          159   0.33536708E+02
         160          141  -0.86950685E-05
         160          142  -0.59474311E-06
         160          145  -0.52196911E-14
         160          147  -0.11851393E-09
         160          148   0.11294945E-13
         160          149  -0.80315886E-07
         160          150  -0.32294600E-04
         160          161  -0.13050579E-04
         160          162  -0.89266026E-06
         160          165  -0.78343250E-14
         160          167  -0.17787962E-09
         160          168   0.16952779E-13
         160          169  -0.12054751E-06
         160          170  -0.48471527E-04
         161          161   0.97945219E+04
         161          166   0.79884210E+02
         161          167   0.76117799E+02
         161          170   0.36307130E+04
         161          151  -0.23456562E-04
         161          156  -0.19131143E-06
         161          157  -0.18229190E-06
         161          160  -0.86950685E-05
         161          171  -0.35206361E-04
         161          176  -0.28714265E-06
         161          177  -0.27360508E-06
         161          180  -0.13050579E-04
         162          162   0.61664984E+04
         162          164   0.63450217E+01
         162          165   0.63450217E+01
         162          167  -0.21136331E+02
         162          170   0.24834091E+03
         162          152  -0.14762870E-04
         162          160  -0.59474311E-06
         162          172  -0.22157848E-04
         162          180  -0.89266026E-06
         163          163   0.78082192E+03
         163          153  -0.18699636E-05
         163          173  -0.28066608E-05
         164          164   0.13409529E+04
         164          162   0.63443872E+01
         164          165   0.19035065E+02
         164          167  -0.65836821E+02
         164          154  -0.31658155E-05
         164          157   0.58143241E-08
         164          174  -0.47516275E-05
         164          177   0.87268201E-08
         165          165   0.19052837E+02
         165          162   0.63443872E+01
         165          164   0.19035065E+02
         165          167  -0.63477866E+02
         165          170   0.21795643E-05
         165          155  -0.42484262E-10
         165          157   0.16470994E-09
         165          160  -0.52197636E-14
         165          175  -0.63765367E-10
         165          177   0.24721601E-09
         165          180  -0.78344339E-14
         166          166   0.17074662E+04
         166          161   0.79884210E+02
         166          167   0.19543730E+04
         166          169   0.43198833E-04
         166          151  -0.19131143E-06
         166          156  -0.40891514E-05
         166          157  -0.46804606E-05
         166          171  -0.28714265E-06
         166          176  -0.61374783E-05
         166          177  -0.70249846E-05
         167          167   0.26723718E+04
         167          161   0.76117799E+02
         167          162  -0.21147957E+02
         167          164  -0.65878288E+02
         167          165  -0.63519108E+02
         167          166   0.19543478E+04
         167          168  -0.38887502E-04
         167          169  -0.12035985E+00
         167          170   0.49505150E-01
         167          151  -0.18229190E-06
         167          154   0.58149055E-08
         167          155   0.16475051E-09
         167          156  -0.46804003E-05
         167          157  -0.58937839E-05
         167          158   0.15713863E-13
         167          159   0.28826778E-09
         167          160  -0.11851393E-09
         167          171  -0.27360508E-06
         167          174   0.87276927E-08
         167          175   0.24727690E-09
         167          176  -0.70248941E-05
         167          177  -0.88460827E-05
         167          178   0.23585210E-13
         167          179   0.43266612E-09
         167          180  -0.17787962E-09
         168          168   0.66308262E-04
         168          167  -0.38896922E-04
         168          169  -0.14946245E-04
         168          170  -0.37051937E-04
         168          157   0.15715131E-13
         168          158  -0.23320538E-13
         168          159  -0.29226998E-14
         168          160   0.11296639E-13
         168          177   0.23587113E-13
         168          178  -0.35002201E-13
         168          179  -0.43867309E-14
         168          180   0.16955322E-13
         169          169   0.99356224E+02
         169          166   0.43198833E-04
         169          167  -0.12034781E+00
         169          168  -0.14942654E-04
         169          170   0.33536708E+02
         169          157   0.28823896E-09
         169          158  -0.29225902E-14
         169          159  -0.23794469E-06
         169          160  -0.80315886E-07
         169          177   0.43262286E-09
         169          178  -0.43865664E-14
         169          179  -0.35713531E-06
         169          180  -0.12054751E-06
         170          170   0.13484933E+05
         170          161   0.36307130E+04
         170          162   0.24834091E+03
         170          165   0.21795340E-05
         170          167   0.49505150E-01
         170          168  -0.37042339E-04
         170          169   0.33536708E+02
         170          151  -0.86950685E-05
         170          152  -0.59474311E-06
         170          155  -0.52196911E-14
         170          157  -0.11851393E-09
         170          158   0.11294945E-13
         170          159  -0.80315886E-07
         170          160  -0.32294600E-04
         170          171  -0.13050579E-04
         170          172  -0.89266026E-06
         170          175  -0.78343250E-14
         170          177  -0.17787962E-09
         170          178   0.16952779E-13
         170          179  -0.12054751E-06
         170          180  -0.48471527E-04
         171          171   0.97945219E+04
         171          176   0.79884210E+02
         171          177   0.76117799E+02
         171          180   0.36307130E+04
         171          161  -0.23456562E-04
         171          166  -0.19131143E-06
         171          167  -0.18229190E-06
         171          170  -0.86950685E-05
         171          181  -0.35206361E-04
         171          186  -0.28714265E-06
         171          187  -0.27360508E-06
         171          190  -0.13050579E-04
         172          172   0.61664984E+04
         172          174   0.63450217E+01
         172          175   0.63450217E+01
         172          177  -0.21136331E+02
         172          180   0.24834091E+03
         172          162  -0.14762870E-04
         172          170  -0.59474311E-06
         172          182  -0.22157848E-04
         172          190  -0.89266026E-06
         173          173   0.78082192E+03
         173          163  -0.18699636E-05
         173          183  -0.28066608E-05
         174          174   0.13409529E+04
         174          172   0.63443872E+01
         174          175   0.19035065E+02
         174          177  -0.65836821E+02
         174          164  -0.31658155E-05
         174          167   0.58143241E-08
         174          184  -0.47516275E-05
         174          187   0.87268201E-08
         175          175   0.19052837E+02
         175          172   0.63443872E+01
         175          174   0.19035065E+02
         175          177  -0.63477866E+02
         175          180   0.21795643E-05
         175          165  -0.42484262E-10
         175          167   0.16470994E-09
         175          170  -0.52197636E-14
         175          185  -0.63765367E-10
         175          187   0.24721601E-09
         175          190  -0.78344339E-14
         176          176   0.17074662E+04
         176          171   0.79884210E+02
         176          177   0.19543730E+04
         176          179   0.43198833E-04
         176          161  -0.19131143E-06
         176          166  -0.40891514E-05
         176          167  -0.46804606E-05
         176          181  -0.28714265E-06
         176          186  -0.61374783E-05
         176          187  -0.70249846E-05
         177          177   0.26723718E+04
         177          171   0.76117799E+02
         177          172  -0.21147957E+02
         177          174  -0.65878288E+02
         177          175  -0.63519108E+02
         177          176   0.19543478E+04
         177          178  -0.38887502E-04
         177          179  -0.12035985E+00
         177          180   0.49505150E-01
         177          161  -0.18229190E-06
         177          164   0.58149055E-08
         177          165   0.16475051E-09
         177          166  -0.46804003E-05
         177          167  -0.58937839E-05
         177          168   0.15713863E-13
         177          169   0.28826778E-09
         177          170  -0.11851393E-09
         177          181  -0.27360508E-06
         177          184   0.87276927E-08
         177          185   0.24727690E-09
         177          186  -0.70248941E-05
         177          187  -0.88460827E-05
         177          188   0.23585210E-13
         177          189   0.43266612E-09
         177          190  -0.17787962E-09
         178          178   0.66308262E-04
         178          177  -0.38896922E-04
         178          179  -0.14946245E-04
         178          180  -0.37051937E-04
         178          167   0.15715131E-13
         178          168  -0.23320538E-13
         178          169  -0.29226998E-14
         178          170   0.11296639E-13
         178          187   0.23587113E-13
         178          188  -0.35002201E-13
         178          189  -0.43867309E-14
         178          190   0.16955322E-13
         179          179   0.99356224E+02
         179          176   0.43198833E-04
         179          177  -0.12034781E+00
         179          178  -0.14942654E-04
         179          180   0.33536708E+02
         179          167   0.28823896E-09
         179          168  -0.29225902E-14
         179          169  -0.23794469E-06
         179          170  -0.80315886E-07
         179          187   0.43262286E-09
         179          188  -0.43865664E-14
         179          189  -0.35713531E-06
         179          190  -0.12054751E-06
         180          180   0.13484933E+05
         180          171   0.36307130E+04
         180          172   0.24834091E+03
         180          175   0.21795340E-05
         180          177   0.49505150E-01
         180          178  -0.37042339E-04
         180          179   0.33536708E+02
         180          161  -0.86950685E-05
         180          162  -0.59474311E-06
         180          165  -0.52196911E-14
         180          167  -0.11851393E-09
         180          168   0.11294945E-13
         180          169  -0.80315886E-07
         180          170  -0.32294600E-04
         180          181  -0.13050579E-04
         180          182  -0.89266026E-06
         180          185  -0.78343250E-14
         180          187  -0.17787962E-09
         180          188   0.16952779E-13
         180          189  -0.12054751E-06
         180          190  -0.48471527E-04
         181          181   0.97945219E+04
         181          186   0.79884210E+02
         181          187   0.76117799E+02
         181          190   0.36307130E+04
         181          171  -0.23456562E-04
         181          176  -0.19131143E-06
         181          177  -0.18229190E-06
         181          180  -0.86950685E-05
         181          191  -0.35206361E-04
         181          196  -0.28714265E-06
         181          197  -0.27360508E-06
         181          200  -0.13050579E-04
         182          182   0.61664984E+04
         182          184   0.63450217E+01
         182          185   0.63450217E+01
         182          187  -0.21136331E+02
         182          190   0.24834091E+03
         182          172  -0.14762870E-04
         182          180  -0.59474311E-06
         182          192  -0.22157848E-04
         182          200  -0.89266026E-06
         183          183   0.78082192E+03
         183          173  -0.18699636E-05
         183          193  -0.28066608E-05
         184          184   0.13409529E+04
         184          182   0.63443872E+01
         184          185   0.19035065E+02
         184          187  -0.65836821E+02
         184          174  -0.31658155E-05
         184          177   0.58143241E-08
         184          194  -0.47516275E-05
         184          197   0.87268201E-08
         185          185   0.19052837E+02
         185          182   0.63443872E+01
         185          184   0.19035065E+02
         185          187  -0.63477866E+02
         185          190   0.21795643E-05
         185          175  -0.42484262E-10
         185          177   0.16470994E-09
         185          180  -0.52197636E-14
         185          195  -0.63765367E-10
         185          197   0.24721601E-09
         185          200  -0.78344339E-14
         186          186   0.17074662E+04
         186          181   0.79884210E+02
         186          187   0.19543730E+04
         186          189   0.43198833E-04
         186          171  -0.19131143E-06
         186          176  -0.40891514E-05
         186          177  -0.46804606E-05
         186          191  -0.28714265E-06
         186          196  -0.61374783E-05
         186          197  -0.70249846E-05
         187          187   0.26723718E+04
         187          181   0.76117799E+02
         187          182  -0.21147957E+02
         187          184  -0.65878288E+02
         187          185  -0.63519108E+02
         187          186   0.19543478E+04
         187          188  -0.38887502E-04
         187          189  -0.12035985E+00
         187          190   0.49505150E-01
         187          171  -0.18229190E-06
         187          174   0.58149055E-08
         187          175   0.16475051E-09
         187          176  -0.46804003E-05
         187          177  -0.58937839E-05
         187          178   0.15713863E-13
         187          179   0.28826778E-09
         187          180  -0.11851393E-09
         187          191  -0.27360508E-06
         187          194   0.87276927E-08
         187          195   0.24727690E-09
         187          196  -0.70248941E-05
         187          197  -0.88460827E-05
         187          198   0.23585210E-13
         187          199   0.43266612E-09
         187          200  -0.17787962E-09
         188          188   0.66308262E-04
         188          187  -0.38896922E-04
         188          189  -0.14946245E-04
         188          190  -0.37051937E-04
         188          177   0.15715131E-13
         188          178  -0.23320538E-13
         188          179  -0.29226998E-14
         188          180   0.11296639E-13
         188          197   0.23587113E-13
         188          198  -0.35002201E-13
         188          199  -0.43867309E-14
         188          200   0.16955322E-13
         189          189   0.99356224E+02
         189          186   0.43198833E-04
         189          187  -0.12034781E+00
         189          188  -0.14942654E-04
         189          190   0.33536708E+02
         189          177   0.28823896E-09
         189          178  -0.29225902E-14
         189          179  -0.23794469E-06
         189          180  -0.80315886E-07
         189          197   0.43262286E-09
         189          198  -0.43865664E-14
         189          199  -0.35713531E-06
         189          200  -0.12054751E-06
         190          190   0.13484933E+05
         190          181   0.36307130E+04
         190          182   0.24834091E+03
         190          185   0.21795340E-05
         190          187   0.49505150E-01
         190          188  -0.37042339E-04
         190          189   0.33536708E+02
         190          171  -0.86950685E-05
         190          172  -0.59474311E-06
         190          175  -0.52196911E-14
         190          177  -0.11851393E-09
         190          178   0.11294945E-13
         190          179  -0.80315886E-07
         190          180  -0.32294600E-04
         190          191  -0.13050579E-04
         190          192  -0.89266026E-06
         190          195  -0.78343250E-14
         190          197  -0.17787962E-09
         190          198   0.16952779E-13
         190          199  -0.12054751E-06
         190          200  -0.48471527E-04
         191          191   0.97945219E+04
         191          196   0.79884210E+02
         191          197   0.76117799E+02
         191          200   0.36307130E+04
         191          181  -0.23456562E-04
         191          186  -0.19131143E-06
         191          187  -0.18229190E-06
         191          190  -0.86950685E-05
         191          201  -0.35206361E-04
         191          206  -0.28714265E-06
         191          207  -0.27360508E-06
         191          210  -0.13050579E-04
         192          192   0.61664984E+04
         192          194   0.63450217E+01
         192          195   0.63450217E+01
         192          197  -0.21136331E+02
         192          200   0.24834091E+03
         192          182  -0.14762870E-04
         192          190  -0.59474311E-06
         192          202  -0.22157848E-04
         192          210  -0.89266026E-06
         193          193   0.78082192E+03
         193          183  -0.18699636E-05
         193          203  -0.28066608E-05
         194          194   0.13409529E+04
         194          192   0.63443872E+01
         194          195   0.19035065E+02
         194          197  -0.65836821E+02
         194          184  -0.31658155E-05
         194          187   0.58143241E-08
         194          204  -0.47516275E-05
         194          207   0.87268201E-08
         195          195   0.19052837E+02
         195          192   0.63443872E+01
         195          194   0.19035065E+02
         195          197  -0.63477866E+02
         195          200   0.21795643E-05
         195          185  -0.42484262E-10
         195          187   0.16470994E-09
         195          190  -0.52197636E-14
         195          205  -0.63765367E-10
         195          207   0.24721601E-09
         195          210  -0.78344339E-14
         196          196   0.17074662E+04
         196          191   0.79884210E+02
         196          197   0.19543730E+04
         196          199   0.43198833E-04
         196          181  -0.19131143E-06
         196          186  -0.40891514E-05
         196          187  -0.46804606E-05
         196          201  -0.28714265E-06
         196          206  -0.61374783E-05
         196          207  -0.70249846E-05
         197          197   0.26723718E+04
         197          191   0.76117799E+02
         197          192  -0.21147957E+02
         197          194  -0.65878288E+02
         197          195  -0.63519108E+02
         197          196   0.19543478E+04
         197          198  -0.38887502E-04
         197          199  -0.12035985E+00
         197          200   0.49505150E-01
         197          181  -0.18229190E-06
         197          184   0.58149055E-08
         197          185   0.16475051E-09
         197          186  -0.46804003E-05
         197          187  -0.58937839E-05
         197          188   0.15713863E-13
         197          189   0.28826778E-09
         197          190  -0.11851393E-09
         197          201  -0.27360508E-06
         197          204   0.87276927E-08
         197          205   0.24727690E-09
         197          206  -0.70248941E-05
         197          207  -0.88460827E-05
         197          208   0.23585210E-13
         197          209   0.43266612E-09
         197          210  -0.17787962E-09
         198          198   0.66308262E-04
         198          197  -0.38896922E-04
         198          199  -0.14946245E-04
         198          200  -0.37051937E-04
         198          187   0.15715131E-13
         198          188  -0.23320538E-13
         198          189  -0.29226998E-14
         198          190   0.11296639E-13
         198          207   0.23587113E-13
         198          208  -0.35002201E-13
         198          209  -0.43867309E-14
         198          210   0.16955322E-13
         199          199   0.99356224E+02
         199          196   0.43198833E-04
         199          197  -0.12034781E+00
         199          198  -0.14942654E-04
         199          200   0.33536708E+02
         199          187   0.28823896E-09
         199          188  -0.29225902E-14
         199          189  -0.23794469E-06
         199          190  -0.80315886E-07
         199          207   0.43262286E-09
         199          208  -0.43865664E-14
         199          209  -0.35713531E-06
         199          210  -0.12054751E-06
         200          200   0.13484933E+05
         200          191   0.36307130E+04
         200          192   0.24834091E+03
         200          195   0.21795340E-05
         200          197   0.49505150E-01
         200          198  -0.37042339E-04
         200          199   0.33536708E+02
         200          181  -0.86950685E-05
         200          182  -0.59474311E-06
         200          185  -0.52196911E-14
         200          187  -0.11851393E-09
         200          188   0.11294945E-13
         200          189  -0.80315886E-07
         200          190  -0.32294600E-04
         200          201  -0.13050579E-04
         200          202  -0.89266026E-06
         200          205  -0.78343250E-14
         200          207  -0.17787962E-09
         200          208   0.16952779E-13
         200          209  -0.12054751E-06
         200          210  -0.48471527E-04
         201          201   0.97945219E+04
         201          206   0.79884210E+02
         201          207   0.76117799E+02
         201          210   0.36307130E+04
         201          191  -0.23456562E-04
         201          196  -0.19131143E-06
         201          197  -0.18229190E-06
         201          200  -0.86950685E-05
         201          211  -0.35206361E-04
         201          216  -0.28714265E-06
         201          217  -0.27360508E-06
         201          220  -0.13050579E-04
         202          202   0.61664984E+04
         202          204   0.63450217E+01
         202          205   0.63450217E+01
         202          207  -0.21136331E+02
         202          210   0.24834091E+03
         202          192  -0.14762870E-04
         202          200  -0.59474311E-06
         202          212  -0.22157848E-04
         202          220  -0.89266026E-06
         203          203   0.78082192E+03
         203          193  -0.18699636E-05
         203          213  -0.28066608E-05
         204          204   0.13409529E+04
         204          202   0.63443872E+01
         204          205   0.19035065E+02
         204          207  -0.65836821E+02
         204          194  -0.31658155E-05
         204          197   0.58143241E-08
         204          214  -0.47516275E-05
         204          217   0.87268201E-08
         205          205   0.19052837E+02
         205          202   0.63443872E+01
         205          204   0.19035065E+02
         205          207  -0.63477866E+02
         205          210   0.21795643E-05
         205          195  -0.42484262E-10
         205          197   0.16470994E-09
         205          200  -0.52197636E-14
         205          215  -0.63765367E-10
         205          217   0.24721601E-09
         205          220  -0.78344339E-14
         206          206   0.17074662E+04
         206          201   0.79884210E+02
         206          207   0.19543730E+04
         206          209   0.43198833E-04
         206          191  -0.19131143E-06
         206          196  -0.40891514E-05
         206          197  -0.46804606E-05
         206          211  -0.28714265E-06
         206          216  -0.61374783E-05
         206          217  -0.70249846E-05
         207          207   0.26723718E+04
         207          201   0.76117799E+02
         207          202  -0.21147957E+02
         207          204  -0.65878288E+02
         207          205  -0.63519108E+02
         207          206   0.19543478E+04
         207          208  -0.38887502E-04
         207          209  -0.12035985E+00
         207          210   0.49505150E-01
         207          191  -0.18229190E-06
         207          194   0.58149055E-08
         207          195   0.16475051E-09
         207          196  -0.46804003E-05
         207          197  -0.58937839E-05
         207          198   0.15713863E-13
         207          199   0.28826778E-09
         207          200  -0.11851393E-09
         207          211  -0.27360508E-06
         207          214   0.87276927E-08
         207          215   0.24727690E-09
         207          216  -0.70248941E-05
         207          217  -0.88460827E-05
         207          218   0.23585210E-13
         207          219   0.43266612E-09
         207          220  -0.17787962E-09
         208          208   0.66308262E-04
         208          207  -0.38896922E-04
         208          209  -0.14946245E-04
         208          210  -0.37051937E-04
         208          197   0.15715131E-13
         208          198  -0.23320538E-13
         208          199  -0.29226998E-14
         208          200   0.11296639E-13
         208          217   0.23587113E-13
         208          218  -0.35002201E-13
         208          219  -0.43867309E-14
         208          220   0.16955322E-13
         209          209   0.99356224E+02
         209          206   0.43198833E-04
         209          207  -0.12034781E+00
         209          208  -0.14942654E-04
         209          210   0.33536708E+02
         209          197   0.28823896E-09
         209          198  -0.29225902E-14
         209          199  -0.23794469E-06
         209          200  -0.80315886E-07
         209          217   0.43262286E-09
         209          218  -0.43865664E-14
         209          219  -0.35713531E-06
         209          220  -0.12054751E-06
         210          210   0.13484933E+05
         210          201   0.36307130E+04
         210          202   0.24834091E+03
         210          205   0.21795340E-05
         210          207   0.49505150E-01
         210          208  -0.37042339E-04
         210          209   0.33536708E+02
         210          191  -0.86950685E-05
         210          192  -0.59474311E-06
         210          195  -0.52196911E-14
         210          197  -0.11851393E-09
         210          198   0.11294945E-13
         210          199  -0.80315886E-07
         210          200  -0.32294600E-04
         210          211  -0.13050579E-04
         210          212  -0.89266026E-06
         210          215  -0.78343250E-14
         210          217  -0.17787962E-09
         210          218   0.16952779E-13
         210          219  -0.12054751E-06
         210          220  -0.48471527E-04
         211          211   0.97945219E+04
         211          216   0.79884210E+02
         211          217   0.76117799E+02
         211          220   0.36307130E+04
         211          201  -0.23456562E-04
         211          206  -0.19131143E-06
         211          207  -0.18229190E-06
         211          210  -0.86950685E-05
         211          221  -0.35206361E-04
         211          226  -0.28714265E-06
         211          227  -0.27360508E-06
         211          230  -0.13050579E-04
         212          212   0.61664984E+04
         212          214   0.63450217E+01
         212          215   0.63450217E+01
         212          217  -0.21136331E+02
         212          220   0.24834091E+03
         212          202  -0.14762870E-04
         212          210  -0.59474311E-06
         212          222  -0.22157848E-04
         212          230  -0.89266026E-06
         213          213   0.78082192E+03
         213          203  -0.18699636E-05
         213          223  -0.28066608E-05
         214          214   0.13409529E+04
         214          212   0.63443872E+01
         214          215   0.19035065E+02
         214          217  -0.65836821E+02
         214          204  -0.31658155E-05
         214          207   0.58143241E-08
         214          224  -0.47516275E-05
         214          227   0.87268201E-08
         215          215   0.19052837E+02
         215          212   0.63443872E+01
         215          214   0.19035065E+02
         215          217  -0.63477866E+02
         215          220   0.21795643E-05
         215          205  -0.42484262E-10
         215          207   0.16470994E-09
         215          210  -0.52197636E-14
         215          225  -0.63765367E-10
         215          227   0.24721601E-09
         215          230  -0.78344339E-14
         216          216   0.17074662E+04
         216          211   0.79884210E+02
         216          217   0.19543730E+04
         216          219   0.43198833E-04
         216          201  -0.19131143E-06
         216          206  -0.40891514E-05
         216          207  -0.46804606E-05
         216          221  -0.28714265E-06
         216          226  -0.61374783E-05
         216          227  -0.70249846E-05
         217          217   0.26723718E+04
         217          211   0.76117799E+02
         217          212  -0.21147957E+02
         217          214  -0.65878288E+02
         217          215  -0.63519108E+02
         217          216   0.19543478E+04
         217          218  -0.38887502E-04
         217          219  -0.12035985E+00
         217          220   0.49505150E-01
         217          201  -0.18229190E-06
         217          204   0.58149055E-08
         217          205   0.16475051E-09
         217          206  -0.46804003E-05
         217          207  -0.58937839E-05
         217          208   0.15713863E-13
         217          209   0.28826778E-09
         217          210  -0.11851393E-09
         217          221  -0.27360508E-06
         217          224   0.87276927E-08
         217          225   0.24727690E-09
         217          226  -0.70248941E-05
         217          227  -0.88460827E-05
         217          228   0.23585210E-13
         217          229   0.43266612E-09
         217          230  -0.17787962E-09
         218          218   0.66308262E-04
         218          217  -0.38896922E-04
         218          219  -0.14946245E-04
         218          220  -0.37051937E-04
         218          207   0.15715131E-13
         218          208  -0.23320538E-13
         218          209  -0.29226998E-14
         218          210   0.11296639E-13
         218          227   0.23587113E-13
         218          228  -0.35002201E-13
         218          229  -0.43867309E-14
         218          230   0.16955322E-13
         219          219   0.99356224E+02
         219          216   0.43198833E-04
         219          217  -0.12034781E+00
         219          218  -0.14942654E-04
         219          220   0.33536708E+02
         219          207   0.28823896E-09
         219          208  -0.29225902E-14
         219          209  -0.23794469E-06
         219          210  -0.80315886E-07
         219          227   0.43262286E-09
         219          228  -0.43865664E-14
         219          229  -0.35713531E-06
         219          230  -0.12054751E-06
         220          220   0.13484933E+05
         220          211   0.36307130E+04
         220          212   0.24834091E+03
         220          215   0.21795340E-05
         220          217   0.49505150E-01
         220          218  -0.37042339E-04
         220          219   0.33536708E+02
         220          201  -0.86950685E-05
         220          202  -0.59474311E-06
         220          205  -0.52196911E-14
         220          207  -0.11851393E-09
         220          208   0.11294945E-13
         220          209  -0.80315886E-07
         220          210  -0.32294600E-04
         220          221  -0.13050579E-04
         220          222  -0.89266026E-06
         220          225  -0.78343250E-14
         220          227  -0.17787962E-09
         220          228   0.16952779E-13
         220          229  -0.12054751E-06
         220          230  -0.48471527E-04
         221          221   0.97945219E+04
         221          226   0.79884210E+02
         221          227   0.76117799E+02
         221          230   0.36307130E+04
         221          211  -0.23456562E-04
         221          216  -0.19131143E-06
         221          217  -0.18229190E-06
         221          220  -0.86950685E-05
         221          231  -0.35206361E-04
         221          236  -0.28714265E-06
         221          237  -0.27360508E-06
         221          240  -0.13050579E-04
         222          222   0.61664984E+04
         222          224   0.63450217E+01
         222          225   0.63450217E+01
         222          227  -0.21136331E+02
         222          230   0.24834091E+03
         222          212  -0.14762870E-04
         222          220  -0.59474311E-06
         222          232  -0.22157848E-04
         222          240  -0.89266026E-06
         223          223   0.78082192E+03
         223          213  -0.18699636E-05
         223          233  -0.28066608E-05
         224          224   0.13409529E+04
         224          222   0.63443872E+01
         224          225   0.19035065E+02
         224          227  -0.65836821E+02
         224          214  -0.31658155E-05
         224          217   0.58143241E-08
         224          234  -0.47516275E-05
         224          237   0.87268201E-08
         225          225   0.19052837E+02
         225          222   0.63443872E+01
         225          224   0.19035065E+02
         225          227  -0.63477866E+02
         225          230   0.21795643E-05
         225          215  -0.42484262E-10
         225          217   0.16470994E-09
         225          220  -0.52197636E-14
         225          235  -0.63765367E-10
         225          237   0.24721601E-09
         225          240  -0.78344339E-14
         226          226   0.17074662E+04
         226          221   0.79884210E+02
         226          227   0.19543730E+04
         226          229   0.43198833E-04
         226          211  -0.19131143E-06
         226          216  -0.40891514E-05
         226          217  -0.46804606E-05
         226          231  -0.28714265E-06
         226          236  -0.61374783E-05
         226          237  -0.70249846E-05
         227          227   0.26723718E+04
         227          221   0.76117799E+02
         227          222  -0.21147957E+02
         227          224  -0.65878288E+02
         227          225  -0.63519108E+02
         227          226   0.19543478E+04
         227          228  -0.38887502E-04
         227          229  -0.12035985E+00
         227          230   0.49505150E-01
         227          211  -0.18229190E-06
         227          214   0.58149055E-08
         227          215   0.16475051E-09
         227          216  -0.46804003E-05
         227          217  -0.58937839E-05
         227          218   0.15713863E-13
         227          219   0.28826778E-09
         227          220  -0.11851393E-09
         227          231  -0.27360508E-06
         227          234   0.87276927E-08
         227          235   0.24727690E-09
         227          236  -0.70248941E-05
         227          237  -0.88460827E-05
         227          238   0.23585210E-13
         227          239   0.43266612E-09
         227          240  -0.17787962E-09
         228          228   0.66308262E-04
         228          227  -0.38896922E-04
         228          229  -0.14946245E-04
         228          230  -0.37051937E-04
         228          217   0.15715131E-13
         228          218  -0.23320538E-13
         228          219  -0.29226998E-14
         228          220   0.11296639E-13
         228          237   0.23587113E-13
         228          238  -0.35002201E-13
         228          239  -0.43867309E-14
         228          240   0.16955322E-13
         229          229   0.99356224E+02
         229          226   0.43198833E-04
         229          227  -0.12034781E+00
         229          228  -0.14942654E-04
         229          230   0.33536708E+02
         229          217   0.28823896E-09
         229          218  -0.29225902E-14
         229          219  -0.23794469E-06
         229          220  -0.80315886E-07
         229          237   0.43262286E-09
         229          238  -0.43865664E-14
         229          239  -0.35713531E-06
         229          240  -0.12054751E-06
         230          230   0.13484933E+05
         230          221   0.36307130E+04
         230          222   0.24834091E+03
         230          225   0.21795340E-05
         230          227   0.49505150E-01
         230          228  -0.37042339E-04
         230          229   0.33536708E+02
         230          211  -0.86950685E-05
         230          212  -0.59474311E-06
         230          215  -0.52196911E-14
         230          217  -0.11851393E-09
         230          218   0.11294945E-13
         230          219  -0.80315886E-07
         230          220  -0.32294600E-04
         230          231  -0.13050579E-04
         230          232  -0.89266026E-06
         230          235  -0.78343250E-14
         230          237  -0.17787962E-09
         230          238   0.16952779E-13
         230          239  -0.12054751E-06
         230          240  -0.48471527E-04
         231          231   0.97945219E+04
         231          236   0.79884210E+02
         231          237   0.76117799E+02
         231          240   0.36307130E+04
         231          221  -0.23456562E-04
         231          226  -0.19131143E-06
         231          227  -0.18229190E-06
         231          230  -0.86950685E-05
         231          241  -0.35206361E-04
         231          246  -0.28714265E-06
         231          247  -0.27360508E-06
         231          250  -0.13050579E-04
         232          232   0.61664984E+04
         232          234   0.63450217E+01
         232          235   0.63450217E+01
         232          237  -0.21136331E+02
         232          240   0.24834091E+03
         232          222  -0.14762870E-04
         232          230  -0.59474311E-06
         232          242  -0.22157848E-04
         232          250  -0.89266026E-06
         233          233   0.78082192E+03
         233          223  -0.18699636E-05
         233          243  -0.28066608E-05
         234          234   0.13409529E+04
         234          232   0.63443872E+01
         234          235   0.19035065E+02
         234          237  -0.65836821E+02
         234          224  -0.31658155E-05
         234          227   0.58143241E-08
         234          244  -0.47516275E-05
         234          247   0.87268201E-08
         235          235   0.19052837E+02
         235          232   0.63443872E+01
         235          234   0.19035065E+02
         235          237  -0.63477866E+02
         235          240   0.21795643E-05
         235          225  -0.42484262E-10
         235          227   0.16470994E-09
         235          230  -0.52197636E-14
         235          245  -0.63765367E-10
         235          247   0.24721601E-09
         235          250  -0.78344339E-14
         236          236   0.17074662E+04
         236          231   0.79884210E+02
         236          237   0.19543730E+04
         236          239   0.43198833E-04
         236          221  -0.19131143E-06
         236          226  -0.40891514E-05
         236          227  -0.46804606E-05
         236          241  -0.28714265E-06
         236          246  -0.61374783E-05
         236          247  -0.70249846E-05
         237          237   0.26723718E+04
         237          231   0.76117799E+02
         237          232  -0.21147957E+02
         237          234  -0.65878288E+02
         237          235  -0.63519108E+02
         237          236   0.19543478E+04
         237          238  -0.38887502E-04
         237          239  -0.12035985E+00
         237          240   0.49505150E-01
         237          221  -0.18229190E-06
         237          224   0.58149055E-08
         237          225   0.16475051E-09
         237          226  -0.46804003E-05
         237          227  -0.58937839E-05
         237          228   0.15713863E-13
         237          229   0.28826778E-09
         237          230  -0.11851393E-09
         237          241  -0.27360508E-06
         237          244   0.87276927E-08
         237          245   0.24727690E-09
         237          246  -0.70248941E-05
         237          247  -0.88460827E-05
         237          248   0.23585210E-13
         237          249   0.43266612E-09
         237          250  -0.17787962E-09
         238          238   0.66308262E-04
         238          237  -0.38896922E-04
         238          239  -0.14946245E-04
         238          240  -0.37051937E-04
         238          227   0.15715131E-13
         238          228  -0.23320538E-13
         238          229  -0.29226998E-14
         238          230   0.11296639E-13
         238          247   0.23587113E-13
         238          248  -0.35002201E-13
         238          249  -0.43867309E-14
         238          250   0.16955322E-13
         239          239   0.99356224E+02
         239          236   0.43198833E-04
         239          237  -0.12034781E+00
         239          238  -0.14942654E-04
         239          240   0.33536708E+02
         239          227   0.28823896E-09
         239          228  -0.29225902E-14
         239          229  -0.23794469E-06
         239          230  -0.80315886E-07
         239          247   0.43262286E-09
         239          248  -0.43865664E-14
         239          249  -0.35713531E-06
         239          250  -0.12054751E-06
         240          240   0.13484933E+05
         240          231   0.36307130E+04
         240          232   0.24834091E+03
         240          235   0.21795340E-05
         240          237   0.49505150E-01
         240          238  -0.37042339E-04
         240          239   0.33536708E+02
         240          221  -0.86950685E-05
         240          222  -0.59474311E-06
         240          225  -0.52196911E-14
         240          227  -0.11851393E-09
         240          228   0.11294945E-13
         240          229  -0.80315886E-07
         240          230  -0.32294600E-04
         240          241  -0.13050579E-04
         240          242  -0.89266026E-06
         240          245  -0.78343250E-14
         240          247  -0.17787962E-09
         240          248   0.16952779E-13
         240          249  -0.12054751E-06
         240          250  -0.48471527E-04
         241          241   0.97945219E+04
         241          246   0.79884210E+02
         241          247   0.76117799E+02
         241          250   0.36307130E+04
         241          231  -0.23456562E-04
         241          236  -0.19131143E-06
         241          237  -0.18229190E-06
         241          240  -0.86950685E-05
         241          251  -0.35206361E-04
         241          256  -0.28714265E-06
         241          257  -0.27360508E-06
         241          260  -0.13050579E-04
         242          242   0.61664984E+04
         242          244   0.63450217E+01
         242          245   0.63450217E+01
         242          247  -0.21136331E+02
         242          250   0.24834091E+03
         242          232  -0.14762870E-04
         242          240  -0.59474311E-06
         242          252  -0.22157848E-04
         242          260  -0.89266026E-06
         243          243   0.78082192E+03
         243          233  -0.18699636E-05
         243          253  -0.28066608E-05
         244          244   0.13409529E+04
         244          242   0.63443872E+01
         244          245   0.19035065E+02
         244          247  -0.65836821E+02
         244          234  -0.31658155E-05
         244          237   0.58143241E-08
         244          254  -0.47516275E-05
         244          257   0.87268201E-08
         245          245   0.19052837E+02
         245          242   0.63443872E+01
         245          244   0.19035065E+02
         245          247  -0.63477866E+02
         245          250   0.21795643E-05
         245          235  -0.42484262E-10
         245          237   0.16470994E-09
         245          240  -0.52197636E-14
         245          255  -0.63765367E-10
         245          257   0.24721601E-09
         245          260  -0.78344339E-14
         246          246   0.17074662E+04
         246          241   0.79884210E+02
         246          247   0.19543730E+04
         246          249   0.43198833E-04
         246          231  -0.19131143E-06
         246          236  -0.40891514E-05
         246          237  -0.46804606E-05
         246          251  -0.28714265E-06
         246          256  -0.61374783E-05
         246          257  -0.70249846E-05
         247          247   0.26723718E+04
         247          241   0.76117799E+02
         247          242  -0.21147957E+02
         247          244  -0.65878288E+02
         247          245  -0.63519108E+02
         247          246   0.19543478E+04
         247          248  -0.38887502E-04
         247          249  -0.12035985E+00
         247          250   0.49505150E-01
         247          231  -0.18229190E-06
         247          234   0.58149055E-08
         247          235   0.16475051E-09
         247          236  -0.46804003E-05
         247          237  -0.58937839E-05
         247          238   0.15713863E-13
         247          239   0.28826778E-09
         247          240  -0.11851393E-09
         247          251  -0.27360508E-06
         247          254   0.87276927E-08
         247          255   0.24727690E-09
         247          256  -0.70248941E-05
         247          257  -0.88460827E-05
         247          258   0.23585210E-13
         247          259   0.43266612E-09
         247          260  -0.17787962E-09
         248          248   0.66308262E-04
         248          247  -0.38896922E-04
         248          249  -0.14946245E-04
         248          250  -0.37051937E-04
         248          237   0.15715131E-13
         248          238  -0.23320538E-13
         248          239  -0.29226998E-14
         248          240   0.11296639E-13
         248          257   0.23587113E-13
         248          258  -0.35002201E-13
         248          259  -0.43867309E-14
         248          260   0.16955322E-13
         249          249   0.99356224E+02
         249          246   0.43198833E-04
         249          247  -0.12034781E+00
         249          248  -0.14942654E-04
         249          250   0.33536708E+02
         249          237   0.28823896E-09
         249          238  -0.29225902E-14
         249          239  -0.23794469E-06
         249          240  -0.80315886E-07
         249          257   0.43262286E-09
         249          258  -0.43865664E-14
         249          259  -0.35713531E-06
         249          260  -0.12054751E-06
         250          250   0.13484933E+05
         250          241   0.36307130E+04
         250          242   0.24834091E+03
         250          245   0.21795340E-05
         250          247   0.49505150E-01
         250          248  -0.37042339E-04
         250          249   0.33536708E+02
         250          231  -0.86950685E-05
         250          232  -0.59474311E-06
         250          235  -0.52196911E-14
         250          237  -0.11851393E-09
         250          238   0.11294945E-13
         250          239  -0.80315886E-07
         250          240  -0.32294600E-04
         250          251  -0.13050579E-04
         250          252  -0.89266026E-06
         250          255  -0.78343250E-14
         250          257  -0.17787962E-09
         250          258   0.16952779E-13
         250          259  -0.12054751E-06
         250          260  -0.48471527E-04
         251          251   0.97945219E+04
         251          256   0.79884210E+02
         251          257   0.76117799E+02
         251          260   0.36307130E+04
         251          241  -0.23456562E-04
         251          246  -0.19131143E-06
         251          247  -0.18229190E-06
         251          250  -0.86950685E-05
         251          261  -0.35206434E-04
         251          266  -0.28714324E-06
         251          267  -0.27360564E-06
         251          270  -0.13050606E-04
         252          252   0.61664984E+04
         252          254   0.63450217E+01
         252          255   0.63450217E+01
         252          257  -0.21136331E+02
         252          260   0.24834091E+03
         252          242  -0.14762870E-04
         252          250  -0.59474311E-06
         252          262  -0.22157894E-04
         252          270  -0.89266210E-06
         253          253   0.78082192E+03
         253          243  -0.18699636E-05
         253          263  -0.28066666E-05
         254          254   0.13409529E+04
         254          252   0.63443872E+01
         254          255   0.19035065E+02
         254          257  -0.65836821E+02
         254          244  -0.31658155E-05
         254          247   0.58143241E-08
         254          264  -0.47516372E-05
         254          267   0.87268380E-08
         255          255   0.19052837E+02
         255          252   0.63443872E+01
         255          254   0.19035065E+02
         255          257  -0.63477866E+02
         255          260   0.21795643E-05
         255          245  -0.42484262E-10
         255          247   0.16470994E-09
         255          250  -0.52197636E-14
         255          265  -0.63765498E-10
         255          267   0.24721652E-09
         255          270  -0.78344501E-14
         256          256   0.17074662E+04
         256          251   0.79884210E+02
         256          257   0.19543730E+04
         256          259   0.43198833E-04
         256          241  -0.19131143E-06
         256          246  -0.40891514E-05
         256          247  -0.46804606E-05
         256          261  -0.28714324E-06
         256          266  -0.61374910E-05
         256          267  -0.70249991E-05
         257          257   0.26723718E+04
         257          251   0.76117799E+02
         257          252  -0.21147957E+02
         257          254  -0.65878288E+02
         257          255  -0.63519108E+02
         257          256   0.19543478E+04
         257          258  -0.38887502E-04
         257          259  -0.12035985E+00
         257          260   0.49505150E-01
         257          241  -0.18229190E-06
         257          244   0.58149055E-08
         257          245   0.16475051E-09
         257          246  -0.46804003E-05
         257          247  -0.58937839E-05
         257          248   0.15713863E-13
         257          249   0.28826778E-09
         257          250  -0.11851393E-09
         257          261  -0.27360564E-06
         257          264   0.87277107E-08
         257          265   0.24727741E-09
         257          266  -0.70249086E-05
         257          267  -0.88461009E-05
         257          268   0.23585258E-13
         257          269   0.43266701E-09
         257          270  -0.17787998E-09
         258          258   0.66308262E-04
         258          257  -0.38896922E-04
         258          259  -0.14946245E-04
         258          260  -0.37051937E-04
         258          247   0.15715131E-13
         258          248  -0.23320538E-13
         258          249  -0.29226998E-14
         258          250   0.11296639E-13
         258          267   0.23587162E-13
         258          268  -0.35002273E-13
         258          269  -0.43867399E-14
         258          270   0.16955357E-13
         259          259   0.99356224E+02
         259          256   0.43198833E-04
         259          257  -0.12034781E+00
         259          258  -0.14942654E-04
         259          260   0.33536708E+02
         259          247   0.28823896E-09
         259          248  -0.29225902E-14
         259          249  -0.23794469E-06
         259          250  -0.80315886E-07
         259          267   0.43262375E-09
         259          268  -0.43865754E-14
         259          269  -0.35713605E-06
         259          270  -0.12054776E-06
         260          260   0.13484933E+05
         260          251   0.36307130E+04
         260          252   0.24834091E+03
         260          255   0.21795340E-05
         260          257   0.49505150E-01
         260          258  -0.37042339E-04
         260          259   0.33536708E+02
         260          241  -0.86950685E-05
         260          242  -0.59474311E-06
         260          245  -0.52196911E-14
         260          247  -0.11851393E-09
         260          248   0.11294945E-13
         260          249  -0.80315886E-07
         260          250  -0.32294600E-04
         260          261  -0.13050606E-04
         260          262  -0.89266210E-06
         260          265  -0.78343411E-14
         260          267  -0.17787998E-09
         260          268   0.16952814E-13
         260          269  -0.12054776E-06
         260          270  -0.48471626E-04
         261          261   0.97945219E+04
         261          266   0.79884210E+02
         261          267   0.76117799E+02
         261          270   0.36307130E+04
         261          251  -0.23456563E-04
         261          256  -0.19131143E-06
         261          257  -0.18229190E-06
         261          260  -0.86950688E-05
         261          271  -0.35206435E-04
         261          276  -0.28714324E-06
         261          277  -0.27360565E-06
         261          280  -0.13050607E-04
         262          262   0.61664984E+04
         262          264   0.63450217E+01
         262          265   0.63450217E+01
         262          267  -0.21136331E+02
         262          270   0.24834091E+03
         262          252  -0.14762871E-04
         262          260  -0.59474313E-06
         262          272  -0.22157895E-04
         262          280  -0.89266212E-06
         263          263   0.78082192E+03
         263          253  -0.18699636E-05
         263          273  -0.28066666E-05
         264          264   0.13409529E+04
         264          262   0.63443872E+01
         264          265   0.19035065E+02
         264          267  -0.65836821E+02
         264          254  -0.31658156E-05
         264          257   0.58143243E-08
         264          274  -0.47516374E-05
         264          277   0.87268382E-08
         265          265   0.19052837E+02
         265          262   0.63443872E+01
         265          264   0.19035065E+02
         265          267  -0.63477866E+02
         265          270   0.21795643E-05
         265          255  -0.42484263E-10
         265          257   0.16470995E-09
         265          260  -0.52197638E-14
         265          275  -0.63765499E-10
         265          277   0.24721653E-09
         265          280  -0.78344502E-14
         266          266   0.17074662E+04
         266          261   0.79884210E+02
         266          267   0.19543730E+04
         266          269   0.43198833E-04
         266          251  -0.19131143E-06
         266          256  -0.40891515E-05
         266          257  -0.46804608E-05
         266          271  -0.28714324E-06
         266          276  -0.61374911E-05
         266          277  -0.70249993E-05
         267          267   0.26723718E+04
         267          261   0.76117799E+02
         267          262  -0.21147957E+02
         267          264  -0.65878288E+02
         267          265  -0.63519108E+02
         267          266   0.19543478E+04
         267          268  -0.38887502E-04
         267          269  -0.12035985E+00
         267          270   0.49505150E-01
         267          251  -0.18229190E-06
         267          254   0.58149057E-08
         267          255   0.16475051E-09
         267          256  -0.46804005E-05
         267          257  -0.58937841E-05
         267          258   0.15713863E-13
         267          259   0.28826779E-09
         267          260  -0.11851393E-09
         267          271  -0.27360565E-06
         267          274   0.87277109E-08
         267          275   0.24727742E-09
         267          276  -0.70249088E-05
         267          277  -0.88461011E-05
         267          278   0.23585259E-13
         267          279   0.43266702E-09
         267          280  -0.17787999E-09
         268          268   0.66308262E-04
         268          267  -0.38896922E-04
         268          269  -0.14946245E-04
         268          270  -0.37051937E-04
         268          257   0.15715132E-13
         268          258  -0.23320539E-13
         268          259  -0.29226999E-14
         268          260   0.11296639E-13
         268          277   0.23587162E-13
         268          278  -0.35002274E-13
         268          279  -0.43867400E-14
         268          280   0.16955357E-13
         269          269   0.99356224E+02
         269          266   0.43198833E-04
         269          267  -0.12034781E+00
         269          268  -0.14942654E-04
         269          270   0.33536708E+02
         269          257   0.28823897E-09
         269          258  -0.29225903E-14
         269          259  -0.23794469E-06
         269          260  -0.80315889E-07
         269          277   0.43262376E-09
         269          278  -0.43865755E-14
         269          279  -0.35713606E-06
         269          280  -0.12054776E-06
         270          270   0.13484933E+05
         270          261   0.36307130E+04
         270          262   0.24834091E+03
         270          265   0.21795340E-05
         270          267   0.49505150E-01
         270          268  -0.37042339E-04
         270          269   0.33536708E+02
         270          251  -0.86950688E-05
         270          252  -0.59474313E-06
         270          255  -0.52196912E-14
         270          257  -0.11851393E-09
         270          258   0.11294945E-13
         270          259  -0.80315889E-07
         270          260  -0.32294601E-04
         270          271  -0.13050607E-04
         270          272  -0.89266212E-06
         270          275  -0.78343413E-14
         270          277  -0.17787999E-09
         270          278   0.16952814E-13
         270          279  -0.12054776E-06
         270          280  -0.48471627E-04
         271          271   0.97945219E+04
         271          276   0.79884210E+02
         271          277   0.76117799E+02
         271          280   0.36307130E+04
         271          261  -0.23456563E-04
         271          266  -0.19131143E-06
         271          267  -0.18229190E-06
         271          270  -0.86950688E-05
         271          281  -0.35206435E-04
         271          286  -0.28714324E-06
         271          287  -0.27360565E-06
         271          290  -0.13050607E-04
         272          272   0.61664984E+04
         272          274   0.63450217E+01
         272          275   0.63450217E+01
         272          277  -0.21136331E+02
         272          280   0.24834091E+03
         272          262  -0.14762871E-04
         272          270  -0.59474313E-06
         272          282  -0.22157895E-04
         272          290  -0.89266212E-06
         273          273   0.78082192E+03
         273          263  -0.18699636E-05
         273          283  -0.28066666E-05
         274          274   0.13409529E+04
         274          272   0.63443872E+01
         274          275   0.19035065E+02
         274          277  -0.65836821E+02
         274          264  -0.31658156E-05
         274          267   0.58143243E-08
         274          284  -0.47516374E-05
         274          287   0.87268382E-08
         275          275   0.19052837E+02
         275          272   0.63443872E+01
         275          274   0.19035065E+02
         275          277  -0.63477866E+02
         275          280   0.21795643E-05
         275          265  -0.42484263E-10
         275          267   0.16470995E-09
         275          270  -0.52197638E-14
         275          285  -0.63765499E-10
         275          287   0.24721653E-09
         275          290  -0.78344502E-14
         276          276   0.17074662E+04
         276          271   0.79884210E+02
         276          277   0.19543730E+04
         276          279   0.43198833E-04
         276          261  -0.19131143E-06
         276          266  -0.40891515E-05
         276          267  -0.46804608E-05
         276          281  -0.28714324E-06
         276          286  -0.61374911E-05
         276          287  -0.70249993E-05
         277          277   0.26723718E+04
         277          271   0.76117799E+02
         277          272  -0.21147957E+02
         277          274  -0.65878288E+02
         277          275  -0.63519108E+02
         277          276   0.19543478E+04
         277          278  -0.38887502E-04
         277          279  -0.12035985E+00
         277          280   0.49505150E-01
         277          261  -0.18229190E-06
         277          264   0.58149057E-08
         277          265   0.16475051E-09
         277          266  -0.46804005E-05
         277          267  -0.58937841E-05
         277          268   0.15713863E-13
         277          269   0.28826779E-09
         277          270  -0.11851393E-09
         277          281  -0.27360565E-06
         277          284   0.87277109E-08
         277          285   0.24727742E-09
         277          286  -0.70249088E-05
         277          287  -0.88461011E-05
         277          288   0.23585259E-13
         277          289   0.43266702E-09
         277          290  -0.17787999E-09
         278          278   0.66308262E-04
         278          277  -0.38896922E-04
         278          279  -0.14946245E-04
         278          280  -0.37051937E-04
         278          267   0.15715132E-13
         278          268  -0.23320539E-13
         278          269  -0.29226999E-14
         278          270   0.11296639E-13
         278          287   0.23587162E-13
         278          288  -0.35002274E-13
         278          289  -0.43867400E-14
         278          290   0.16955357E-13
         279          279   0.99356224E+02
         279          276   0.43198833E-04
         279          277  -0.12034781E+00
         279          278  -0.14942654E-04
         279          280   0.33536708E+02
         279          267   0.28823897E-09
         279          268  -0.29225903E-14
         279          269  -0.23794469E-06
         279          270  -0.80315889E-07
         279          287   0.43262376E-09
         279          288  -0.43865755E-14
         279          289  -0.35713606E-06
         279          290  -0.12054776E-06
         280          280   0.13484933E+05
         280          271   0.36307130E+04
         280          272   0.24834091E+03
         280          275   0.21795340E-05
         280          277   0.49505150E-01
         280          278  -0.37042339E-04
         280          279   0.33536708E+02
         280          261  -0.86950688E-05
         280          262  -0.59474313E-06
         280          265  -0.52196912E-14
         280          267  -0.11851393E-09
         280          268   0.11294945E-13
         280          269  -0.80315889E-07
         280          270  -0.32294601E-04
         280          281  -0.13050607E-04
         280          282  -0.89266212E-06
         280          285  -0.78343413E-14
         280          287  -0.17787999E-09
         280          288   0.16952814E-13
         280          289  -0.12054776E-06
         280          290  -0.48471627E-04
         281          281   0.97945219E+04
         281          286   0.79884210E+02
         281          287   0.76117799E+02
         281          290   0.36307130E+04
         281          271  -0.23456563E-04
         281          276  -0.19131143E-06
         281          277  -0.18229190E-06
         281          280  -0.86950688E-05
         281          291  -0.35206435E-04
         281          296  -0.28714324E-06
         281          297  -0.27360565E-06
         281          300  -0.13050607E-04
         282          282   0.61664984E+04
         282          284   0.63450217E+01
         282          285   0.63450217E+01
         282          287  -0.21136331E+02
         282          290   0.24834091E+03
         282          272  -0.14762871E-04
         282          280  -0.59474313E-06
         282          292  -0.22157895E-04
         282          300  -0.89266212E-06
         283          283   0.78082192E+03
         283          273  -0.18699636E-05
         283          293  -0.28066666E-05
         284          284   0.13409529E+04
         284          282   0.63443872E+01
         284          285   0.19035065E+02
         284          287  -0.65836821E+02
         284          274  -0.31658156E-05
         284          277   0.58143243E-08
         284          294  -0.47516374E-05
         284          297   0.87268382E-08
         285          285   0.19052837E+02
         285          282   0.63443872E+01
         285          284   0.19035065E+02
         285          287  -0.63477866E+02
         285          290   0.21795643E-05
         285          275  -0.42484263E-10
         285          277   0.16470995E-09
         285          280  -0.52197638E-14
         285          295  -0.63765499E-10
         285          297   0.24721653E-09
         285          300  -0.78344502E-14
         286          286   0.17074662E+04
         286          281   0.79884210E+02
         286          287   0.19543730E+04
         286          289   0.43198833E-04
         286          271  -0.19131143E-06
         286          276  -0.40891515E-05
         286          277  -0.46804608E-05
         286          291  -0.28714324E-06
         286          296  -0.61374911E-05
         286          297  -0.70249993E-05
         287          287   0.26723718E+04
         287          281   0.76117799E+02
         287          282  -0.21147957E+02
         287          284  -0.65878288E+02
         287          285  -0.63519108E+02
         287          286   0.19543478E+04
         287          288  -0.38887502E-04
         287          289  -0.12035985E+00
         287          290   0.49505150E-01
         287          271  -0.18229190E-06
         287          274   0.58149057E-08
         287          275   0.16475051E-09
         287          276  -0.46804005E-05
         287          277  -0.58937841E-05
         287          278   0.15713863E-13
         287          279   0.28826779E-09
         287          280  -0.11851393E-09
         287          291  -0.27360565E-06
         287          294   0.87277109E-08
         287          295   0.24727742E-09
         287          296  -0.70249088E-05
         287          297  -0.88461011E-05
         287          298   0.23585259E-13
         287          299   0.43266702E-09
         287          300  -0.17787999E-09
         288          288   0.66308262E-04
         288          287  -0.38896922E-04
         288          289  -0.14946245E-04
         288          290  -0.37051937E-04
         288          277   0.15715132E-13
         288          278  -0.23320539E-13
         288          279  -0.29226999E-14
         288          280   0.11296639E-13
         288          297   0.23587162E-13
         288          298  -0.35002274E-13
         288          299  -0.43867400E-14
         288          300   0.16955357E-13
         289          289   0.99356224E+02
         289          286   0.43198833E-04
         289          287  -0.12034781E+00
         289          288  -0.14942654E-04
         289          290   0.33536708E+02
         289          277   0.28823897E-09
         289          278  -0.29225903E-14
         289          279  -0.23794469E-06
         289          280  -0.80315889E-07
         289          297   0.43262376E-09
         289          298  -0.43865755E-14
         289          299  -0.35713606E-06
         289          300  -0.12054776E-06
         290          290   0.13484933E+05
         290          281   0.36307130E+04
         290          282   0.24834091E+03
         290          285   0.21795340E-05
         290          287   0.49505150E-01
         290          288  -0.37042339E-04
         290          289   0.33536708E+02
         290          271  -0.86950688E-05
         290          272  -0.59474313E-06
         290          275  -0.52196912E-14
         290          277  -0.11851393E-09
         290          278   0.11294945E-13
         290          279  -0.80315889E-07
         290          280  -0.32294601E-04
         290          291  -0.13050607E-04
         290          292  -0.89266212E-06
         290          295  -0.78343413E-14
         290          297  -0.17787999E-09
         290          298   0.16952814E-13
         290          299  -0.12054776E-06
         290          300  -0.48471627E-04
         291          291   0.97945219E+04
         291          296   0.79884210E+02
         291          297   0.76117799E+02
         291          300   0.36307130E+04
         291          281  -0.23456563E-04
         291          286  -0.19131143E-06
         291          287  -0.18229190E-06
         291          290  -0.86950688E-05
         291          301  -0.35206435E-04
         291          306  -0.28714324E-06
         291          307  -0.27360565E-06
         291          310  -0.13050607E-04
         292          292   0.61664984E+04
         292          294   0.63450217E+01
         292          295   0.63450217E+01
         292          297  -0.21136331E+02
         292          300   0.24834091E+03
         292          282  -0.14762871E-04
         292          290  -0.59474313E-06
         292          302  -0.22157895E-04
         292          310  -0.89266212E-06
         293          293   0.78082192E+03
         293          283  -0.18699636E-05
         293          303  -0.28066666E-05
         294          294   0.13409529E+04
         294          292   0.63443872E+01
         294          295   0.19035065E+02
         294          297  -0.65836821E+02
         294          284  -0.31658156E-05
         294          287   0.58143243E-08
         294          304  -0.47516374E-05
         294          307   0.87268382E-08
         295          295   0.19052837E+02
         295          292   0.63443872E+01
         295          294   0.19035065E+02
         295          297  -0.63477866E+02
         295          300   0.21795643E-05
         295          285  -0.42484263E-10
         295          287   0.16470995E-09
         295          290  -0.52197638E-14
         295          305  -0.63765499E-10
         295          307   0.24721653E-09
         295          310  -0.78344502E-14
         296          296   0.17074662E+04
         296          291   0.79884210E+02
         296          297   0.19543730E+04
         296          299   0.43198833E-04
         296          281  -0.19131143E-06
         296          286  -0.40891515E-05
         296          287  -0.46804608E-05
         296          301  -0.28714324E-06
         296          306  -0.61374911E-05
         296          307  -0.70249993E-05
         297          297   0.26723718E+04
         297          291   0.76117799E+02
         297          292  -0.21147957E+02
         297          294  -0.65878288E+02
         297          295  -0.63519108E+02
         297          296   0.19543478E+04
         297          298  -0.38887502E-04
         297          299  -0.12035985E+00
         297          300   0.49505150E-01
         297          281  -0.18229190E-06
         297          284   0.58149057E-08
         297          285   0.16475051E-09
         297          286  -0.46804005E-05
         297          287  -0.58937841E-05
         297          288   0.15713863E-13
         297          289   0.28826779E-09
         297          290  -0.11851393E-09
         297          301  -0.27360565E-06
         297          304   0.87277109E-08
         297          305   0.24727742E-09
         297          306  -0.70249088E-05
         297          307  -0.88461011E-05
         297          308   0.23585259E-13
         297          309   0.43266702E-09
         297          310  -0.17787999E-09
         298          298   0.66308262E-04
         298          297  -0.38896922E-04
         298          299  -0.14946245E-04
         298          300  -0.37051937E-04
         298          287   0.15715132E-13
         298          288  -0.23320539E-13
         298          289  -0.29226999E-14
         298          290   0.11296639E-13
         298          307   0.23587162E-13
         298          308  -0.35002274E-13
         298          309  -0.43867400E-14
         298          310   0.16955357E-13
         299          299   0.99356224E+02
         299          296   0.43198833E-04
         299          297  -0.12034781E+00
         299          298  -0.14942654E-04
         299          300   0.33536708E+02
         299          287   0.28823897E-09
         299          288  -0.29225903E-14
         299          289  -0.23794469E-06
         299          290  -0.80315889E-07
         299          307   0.43262376E-09
         299          308  -0.43865755E-14
         299          309  -0.35713606E-06
         299          310  -0.12054776E-06
         300          300   0.13484933E+05
         300          291   0.36307130E+04
         300          292   0.24834091E+03
         300          295   0.21795340E-05
         300          297   0.49505150E-01
         300          298  -0.37042339E-04
         300          299   0.33536708E+02
         300          281  -0.86950688E-05
         300          282  -0.59474313E-06
         300          285  -0.52196912E-14
         300          287  -0.11851393E-09
         300          288   0.11294945E-13
         300          289  -0.80315889E-07
         300          290  -0.32294601E-04
         300          301  -0.13050607E-04
         300          302  -0.89266212E-06
         300          305  -0.78343413E-14
         300          307  -0.17787999E-09
         300          308   0.16952814E-13
         300          309  -0.12054776E-06
         300          310  -0.48471627E-04
         301          301   0.97945219E+04
         301          306   0.79884210E+02
         301          307   0.76117799E+02
         301          310   0.36307130E+04
         301          291  -0.23456563E-04
         301          296  -0.19131143E-06
         301          297  -0.18229190E-06
         301          300  -0.86950688E-05
         301          311  -0.35206435E-04
         301          316  -0.28714324E-06
         301          317  -0.27360565E-06
         301          320  -0.13050607E-04
         302          302   0.61664984E+04
         302          304   0.63450217E+01
         302          305   0.63450217E+01
         302          307  -0.21136331E+02
         302          310   0.24834091E+03
         302          292  -0.14762871E-04
         302          300  -0.59474313E-06
         302          312  -0.22157895E-04
         302          320  -0.89266212E-06
         303          303   0.78082192E+03
         303          293  -0.18699636E-05
         303          313  -0.28066666E-05
         304          304   0.13409529E+04
         304          302   0.63443872E+01
         304          305   0.19035065E+02
         304          307  -0.65836821E+02
         304          294  -0.31658156E-05
         304          297   0.58143243E-08
         304          314  -0.47516374E-05
         304          317   0.87268382E-08
         305          305   0.19052837E+02
         305          302   0.63443872E+01
         305          304   0.19035065E+02
         305          307  -0.63477866E+02
         305          310   0.21795643E-05
         305          295  -0.42484263E-10
         305          297   0.16470995E-09
         305          300  -0.52197638E-14
         305          315  -0.63765499E-10
         305          317   0.24721653E-09
         305          320  -0.78344502E-14
         306          306   0.17074662E+04
         306          301   0.79884210E+02
         306          307   0.19543730E+04
         306          309   0.43198833E-04
         306          291  -0.19131143E-06
         306          296  -0.40891515E-05
         306          297  -0.46804608E-05
         306          311  -0.28714324E-06
         306          316  -0.61374911E-05
         306          317  -0.70249993E-05
         307          307   0.26723718E+04
         307          301   0.76117799E+02
         307          302  -0.21147957E+02
         307          304  -0.65878288E+02
         307          305  -0.63519108E+02
         307          306   0.19543478E+04
         307          308  -0.38887502E-04
         307          309  -0.12035985E+00
         307          310   0.49505150E-01
         307          291  -0.18229190E-06
         307          294   0.58149057E-08
         307          295   0.16475051E-09
         307          296  -0.46804005E-05
         307          297  -0.58937841E-05
         307          298   0.15713863E-13
         307          299   0.28826779E-09
         307          300  -0.11851393E-09
         307          311  -0.27360565E-06
         307          314   0.87277109E-08
         307          315   0.24727742E-09
         307          316  -0.70249088E-05
         307          317  -0.88461011E-05
         307          318   0.23585259E-13
         307          319   0.43266702E-09
         307          320  -0.17787999E-09
         308          308   0.66308262E-04
         308          307  -0.38896922E-04
         308          309  -0.14946245E-04
         308          310  -0.37051937E-04
         308          297   0.15715132E-13
         308          298  -0.23320539E-13
         308          299  -0.29226999E-14
         308          300   0.11296639E-13
         308          317   0.23587162E-13
         308          318  -0.35002274E-13
         308          319  -0.43867400E-14
         308          320   0.16955357E-13
         309          309   0.99356224E+02
         309          306   0.43198833E-04
         309          307  -0.12034781E+00
         309          308  -0.14942654E-04
         309          310   0.33536708E+02
         309          297   0.28823897E-09
         309          298  -0.29225903E-14
         309          299  -0.23794469E-06
         309          300  -0.80315889E-07
         309          317   0.43262376E-09
         309          318  -0.43865755E-14
         309          319  -0.35713606E-06
         309          320  -0.12054776E-06
         310          310   0.13484933E+05
         310          301   0.36307130E+04
         310          302   0.24834091E+03
         310          305   0.21795340E-05
         310          307   0.49505150E-01
         310          308  -0.37042339E-04
         310          309   0.33536708E+02
         310          291  -0.86950688E-05
         310          292  -0.59474313E-06
         310          295  -0.52196912E-14
         310          297  -0.11851393E-09
         310          298   0.11294945E-13
         310          299  -0.80315889E-07
         310          300  -0.32294601E-04
         310          311  -0.13050607E-04
         310          312  -0.89266212E-06
         310          315  -0.78343413E-14
         310          317  -0.17787999E-09
         310          318   0.16952814E-13
         310          319  -0.12054776E-06
         310          320  -0.48471627E-04
         311          311   0.97945219E+04
         311          316   0.79884210E+02
         311          317   0.76117799E+02
         311          320   0.36307130E+04
         311          301  -0.23456563E-04
         311          306  -0.19131143E-06
         311          307  -0.18229190E-06
         311          310  -0.86950688E-05
         311          321  -0.35206435E-04
         311          326  -0.28714324E-06
         311          327  -0.27360565E-06
         311          330  -0.13050607E-04
         312          312   0.61664984E+04
         312          314   0.63450217E+01
         312          315   0.63450217E+01
         312          317  -0.21136331E+02
         312          320   0.24834091E+03
         312          302  -0.14762871E-04
         312          310  -0.59474313E-06
         312          322  -0.22157895E-04
         312          330  -0.89266212E-06
         313          313   0.78082192E+03
         313          303  -0.18699636E-05
         313          323  -0.28066666E-05
         314          314   0.13409529E+04
         314          312   0.63443872E+01
         314          315   0.19035065E+02
         314          317  -0.65836821E+02
         314          304  -0.31658156E-05
         314          307   0.58143243E-08
         314          324  -0.47516374E-05
         314          327   0.87268382E-08
         315          315   0.19052837E+02
         315          312   0.63443872E+01
         315          314   0.19035065E+02
         315          317  -0.63477866E+02
         315          320   0.21795643E-05
         315          305  -0.42484263E-10
         315          307   0.16470995E-09
         315          310  -0.52197638E-14
         315          325  -0.63765499E-10
         315          327   0.24721653E-09
         315          330  -0.78344502E-14
         316          316   0.17074662E+04
         316          311   0.79884210E+02
         316          317   0.19543730E+04
         316          319   0.43198833E-04
         316          301  -0.19131143E-06
         316          306  -0.40891515E-05
         316          307  -0.46804608E-05
         316          321  -0.28714324E-06
         316          326  -0.61374911E-05
         316          327  -0.70249993E-05
         317          317   0.26723718E+04
         317          311   0.76117799E+02
         317          312  -0.21147957E+02
         317          314  -0.65878288E+02
         317          315  -0.63519108E+02
         317          316   0.19543478E+04
         317          318  -0.38887502E-04
         317          319  -0.12035985E+00
         317          320   0.49505150E-01
         317          301  -0.18229190E-06
         317          304   0.58149057E-08
         317          305   0.16475051E-09
         317          306  -0.46804005E-05
         317          307  -0.58937841E-05
         317          308   0.15713863E-13
         317          309   0.28826779E-09
         317          310  -0.11851393E-09
         317          321  -0.27360565E-06
         317          324   0.87277109E-08
         317          325   0.24727742E-09
         317          326  -0.70249088E-05
         317          327  -0.88461011E-05
         317          328   0.23585259E-13
         317          329   0.43266702E-09
         317          330  -0.17787999E-09
         318          318   0.66308262E-04
         318          317  -0.38896922E-04
         318          319  -0.14946245E-04
         318          320  -0.37051937E-04
         318          307   0.15715132E-13
         318          308  -0.23320539E-13
         318          309  -0.29226999E-14
         318          310   0.11296639E-13
         318          327   0.23587162E-13
         318          328  -0.35002274E-13
         318          329  -0.43867400E-14
         318          330   0.16955357E-13
         319          319   0.99356224E+02
         319          316   0.43198833E-04
         319          317  -0.12034781E+00
         319          318  -0.14942654E-04
         319          320   0.33536708E+02
         319          307   0.28823897E-09
         319          308  -0.29225903E-14
         319          309  -0.23794469E-06
         319          310  -0.80315889E-07
         319          327   0.43262376E-09
         319          328  -0.43865755E-14
         319          329  -0.35713606E-06
         319          330  -0.12054776E-06
         320          320   0.13484933E+05
         320          311   0.36307130E+04
         320          312   0.24834091E+03
         320          315   0.21795340E-05
         320          317   0.49505150E-01
         320          318  -0.37042339E-04
         320          319   0.33536708E+02
         320          301  -0.86950688E-05
         320          302  -0.59474313E-06
         320          305  -0.52196912E-14
         320          307  -0.11851393E-09
         320          308   0.11294945E-13
         320          309  -0.80315889E-07
         320          310  -0.32294601E-04
         320          321  -0.13050607E-04
         320          322  -0.89266212E-06
         320          325  -0.78343413E-14
         320          327  -0.17787999E-09
         320          328   0.16952814E-13
         320          329  -0.12054776E-06
         320          330  -0.48471627E-04
         321          321   0.97945219E+04
         321          326   0.79884210E+02
         321          327   0.76117799E+02
         321          330   0.36307130E+04
         321          311  -0.23456563E-04
         321          316  -0.19131143E-06
         321          317  -0.18229190E-06
         321          320  -0.86950688E-05
         321          331  -0.35206435E-04
         321          336  -0.28714324E-06
         321          337  -0.27360565E-06
         321          340  -0.13050607E-04
         322          322   0.61664984E+04
         322          324   0.63450217E+01
         322          325   0.63450217E+01
         322          327  -0.21136331E+02
         322          330   0.24834091E+03
         322          312  -0.14762871E-04
         322          320  -0.59474313E-06
         322          332  -0.22157895E-04
         322          340  -0.89266212E-06
         323          323   0.78082192E+03
         323          313  -0.18699636E-05
         323          333  -0.28066666E-05
         324          324   0.13409529E+04
         324          322   0.63443872E+01
         324          325   0.19035065E+02
         324          327  -0.65836821E+02
         324          314  -0.31658156E-05
         324          317   0.58143243E-08
         324          334  -0.47516374E-05
         324          337   0.87268382E-08
         325          325   0.19052837E+02
         325          322   0.63443872E+01
         325          324   0.19035065E+02
         325          327  -0.63477866E+02
         325          330   0.21795643E-05
         325          315  -0.42484263E-10
         325          317   0.16470995E-09
         325          320  -0.52197638E-14
         325          335  -0.63765499E-10
         325          337   0.24721653E-09
         325          340  -0.78344502E-14
         326          326   0.17074662E+04
         326          321   0.79884210E+02
         326          327   0.19543730E+04
         326          329   0.43198833E-04
         326          311  -0.19131143E-06
         326          316  -0.40891515E-05
         326          317  -0.46804608E-05
         326          331  -0.28714324E-06
         326          336  -0.61374911E-05
         326          337  -0.70249993E-05
         327          327   0.26723718E+04
         327          321   0.76117799E+02
         327          322  -0.21147957E+02
         327          324  -0.65878288E+02
         327          325  -0.63519108E+02
         327          326   0.19543478E+04
         327          328  -0.38887502E-04
         327          329  -0.12035985E+00
         327          330   0.49505150E-01
         327          311  -0.18229190E-06
         327          314   0.58149057E-08
         327          315   0.16475051E-09
         327          316  -0.46804005E-05
         327          317  -0.58937841E-05
         327          318   0.15713863E-13
         327          319   0.28826779E-09
         327          320  -0.11851393E-09
         327          331  -0.27360565E-06
         327          334   0.87277109E-08
         327          335   0.24727742E-09
         327          336  -0.70249088E-05
         327          337  -0.88461011E-05
         327          338   0.23585259E-13
         327          339   0.43266702E-09
         327          340  -0.17787999E-09
         328          328   0.66308262E-04
         328          327  -0.38896922E-04
         328          329  -0.14946245E-04
         328          330  -0.37051937E-04
         328          317   0.15715132E-13
         328          318  -0.23320539E-13
         328          319  -0.29226999E-14
         328          320   0.11296639E-13
         328          337   0.23587162E-13
         328          338  -0.35002274E-13
         328          339  -0.43867400E-14
         328          340   0.16955357E-13
         329          329   0.99356224E+02
         329          326   0.43198833E-04
         329          327  -0.12034781E+00
         329          328  -0.14942654E-04
         329          330   0.33536708E+02
         329          317   0.28823897E-09
         329          318  -0.29225903E-14
         329          319  -0.23794469E-06
         329          320  -0.80315889E-07
         329          337   0.43262376E-09
         329          338  -0.43865755E-14
         329          339  -0.35713606E-06
         329          340  -0.12054776E-06
         330          330   0.13484933E+05
         330          321   0.36307130E+04
         330          322   0.24834091E+03
         330          325   0.21795340E-05
         330          327   0.49505150E-01
         330          328  -0.37042339E-04
         330          329   0.33536708E+02
         330          311  -0.86950688E-05
         330          312  -0.59474313E-06
         330          315  -0.52196912E-14
         330          317  -0.11851393E-09
         330          318   0.11294945E-13
         330          319  -0.80315889E-07
         330          320  -0.32294601E-04
         330          331  -0.13050607E-04
         330          332  -0.89266212E-06
         330          335  -0.78343413E-14
         330          337  -0.17787999E-09
         330          338   0.16952814E-13
         330          339  -0.12054776E-06
         330          340  -0.48471627E-04
         331          331   0.97945219E+04
         331          336   0.79884210E+02
         331          337   0.76117799E+02
         331          340   0.36307130E+04
         331          321  -0.23456563E-04
         331          326  -0.19131143E-06
         331          327  -0.18229190E-06
         331          330  -0.86950688E-05
         331          341  -0.35206435E-04
         331          346  -0.28714324E-06
         331          347  -0.27360565E-06
         331          350  -0.13050607E-04
         332          332   0.61664984E+04
         332          334   0.63450217E+01
         332          335   0.63450217E+01
         332          337  -0.21136331E+02
         332          340   0.24834091E+03
         332          322  -0.14762871E-04
         332          330  -0.59474313E-06
         332          342  -0.22157895E-04
         332          350  -0.89266212E-06
         333          333   0.78082192E+03
         333          323  -0.18699636E-05
         333          343  -0.28066666E-05
         334          334   0.13409529E+04
         334          332   0.63443872E+01
         334          335   0.19035065E+02
         334          337  -0.65836821E+02
         334          324  -0.31658156E-05
         334          327   0.58143243E-08
         334          344  -0.47516374E-05
         334          347   0.87268382E-08
         335          335   0.19052837E+02
         335          332   0.63443872E+01
         335          334   0.19035065E+02
         335          337  -0.63477866E+02
         335          340   0.21795643E-05
         335          325  -0.42484263E-10
         335          327   0.16470995E-09
         335          330  -0.52197638E-14
         335          345  -0.63765499E-10
         335          347   0.24721653E-09
         335          350  -0.78344502E-14
         336          336   0.17074662E+04
         336          331   0.79884210E+02
         336          337   0.19543730E+04
         336          339   0.43198833E-04
         336          321  -0.19131143E-06
         336          326  -0.40891515E-05
         336          327  -0.46804608E-05
         336          341  -0.28714324E-06
         336          346  -0.61374911E-05
         336          347  -0.70249993E-05
         337          337   0.26723718E+04
         337          331   0.76117799E+02
         337          332  -0.21147957E+02
         337          334  -0.65878288E+02
         337          335  -0.63519108E+02
         337          336   0.19543478E+04
         337          338  -0.38887502E-04
         337          339  -0.12035985E+00
         337          340   0.49505150E-01
         337          321  -0.18229190E-06
         337          324   0.58149057E-08
         337          325   0.16475051E-09
         337          326  -0.46804005E-05
         337          327  -0.58937841E-05
         337          328   0.15713863E-13
         337          329   0.28826779E-09
         337          330  -0.11851393E-09
         337          341  -0.27360565E-06
         337          344   0.87277109E-08
         337          345   0.24727742E-09
         337          346  -0.70249088E-05
         337          347  -0.88461011E-05
         337          348   0.23585259E-13
         337          349   0.43266702E-09
         337          350  -0.17787999E-09
         338          338   0.66308262E-04
         338          337  -0.38896922E-04
         338          339  -0.14946245E-04
         338          340  -0.37051937E-04
         338          327   0.15715132E-13
         338          328  -0.23320539E-13
         338          329  -0.29226999E-14
         338          330   0.11296639E-13
         338          347   0.23587162E-13
         338          348  -0.35002274E-13
         338          349  -0.43867400E-14
         338          350   0.16955357E-13
         339          339   0.99356224E+02
         339          336   0.43198833E-04
         339          337  -0.12034781E+00
         339          338  -0.14942654E-04
         339          340   0.33536708E+02
         339          327   0.28823897E-09
         339          328  -0.29225903E-14
         339          329  -0.23794469E-06
         339          330  -0.80315889E-07
         339          347   0.43262376E-09
         339          348  -0.43865755E-14
         339          349  -0.35713606E-06
         339          350  -0.12054776E-06
         340          340   0.13484933E+05
         340          331   0.36307130E+04
         340          332   0.24834091E+03
         340          335   0.21795340E-05
         340          337   0.49505150E-01
         340          338  -0.37042339E-04
         340          339   0.33536708E+02
         340          321  -0.86950688E-05
         340          322  -0.59474313E-06
         340          325  -0.52196912E-14
         340          327  -0.11851393E-09
         340          328   0.11294945E-13
         340          329  -0.80315889E-07
         340          330  -0.32294601E-04
         340          341  -0.13050607E-04
         340          342  -0.89266212E-06
         340          345  -0.78343413E-14
         340          347  -0.17787999E-09
         340          348   0.16952814E-13
         340          349  -0.12054776E-06
         340          350  -0.48471627E-04
         341          341   0.97945219E+04
         341          346   0.79884210E+02
         341          347   0.76117799E+02
         341          350   0.36307130E+04
         341          331  -0.23456563E-04
         341          336  -0.19131143E-06
         341          337  -0.18229190E-06
         341          340  -0.86950688E-05
         341          351  -0.35206435E-04
         341          356  -0.28714324E-06
         341          357  -0.27360565E-06
         341          360  -0.13050607E-04
         342          342   0.61664984E+04
         342          344   0.63450217E+01
         342          345   0.63450217E+01
         342          347  -0.21136331E+02
         342          350   0.24834091E+03
         342          332  -0.14762871E-04
         342          340  -0.59474313E-06
         342          352  -0.22157895E-04
         342          360  -0.89266212E-06
         343          343   0.78082192E+03
         343          333  -0.18699636E-05
         343          353  -0.28066666E-05
         344          344   0.13409529E+04
         344          342   0.63443872E+01
         344          345   0.19035065E+02
         344          347  -0.65836821E+02
         344          334  -0.31658156E-05
         344          337   0.58143243E-08
         344          354  -0.47516374E-05
         344          357   0.87268382E-08
         345          345   0.19052837E+02
         345          342   0.63443872E+01
         345          344   0.19035065E+02
         345          347  -0.63477866E+02
         345          350   0.21795643E-05
         345          335  -0.42484263E-10
         345          337   0.16470995E-09
         345          340  -0.52197638E-14
         345          355  -0.63765499E-10
         345          357   0.24721653E-09
         345          360  -0.78344502E-14
         346          346   0.17074662E+04
         346          341   0.79884210E+02
         346          347   0.19543730E+04
         346          349   0.43198833E-04
         346          331  -0.19131143E-06
         346          336  -0.40891515E-05
         346          337  -0.46804608E-05
         346          351  -0.28714324E-06
         346          356  -0.61374911E-05
         346          357  -0.70249993E-05
         347          347   0.26723718E+04
         347          341   0.76117799E+02
         347          342  -0.21147957E+02
         347          344  -0.65878288E+02
         347          345  -0.63519108E+02
         347          346   0.19543478E+04
         347          348  -0.38887502E-04
         347          349  -0.12035985E+00
         347          350   0.49505150E-01
         347          331  -0.18229190E-06
         347          334   0.58149057E-08
         347          335   0.16475051E-09
         347          336  -0.46804005E-05
         347          337  -0.58937841E-05
         347          338   0.15713863E-13
         347          339   0.28826779E-09
         347          340  -0.11851393E-09
         347          351  -0.27360565E-06
         347          354   0.87277109E-08
         347          355   0.24727742E-09
         347          356  -0.70249088E-05
         347          357  -0.88461011E-05
         347          358   0.23585259E-13
         347          359   0.43266702E-09
         347          360  -0.17787999E-09
         348          348   0.66308262E-04
         348          347  -0.38896922E-04
         348          349  -0.14946245E-04
         348          350  -0.37051937E-04
         348          337   0.15715132E-13
         348          338  -0.23320539E-13
         348          339  -0.29226999E-14
         348          340   0.11296639E-13
         348          357   0.23587162E-13
         348          358  -0.35002274E-13
         348          359  -0.43867400E-14
         348          360   0.16955357E-13
         349          349   0.99356224E+02
         349          346   0.43198833E-04
         349          347  -0.12034781E+00
         349          348  -0.14942654E-04
         349          350   0.33536708E+02
         349          337   0.28823897E-09
         349          338  -0.29225903E-14
         349          339  -0.23794469E-06
         349          340  -0.80315889E-07
         349          357   0.43262376E-09
         349          358  -0.43865755E-14
         349          359  -0.35713606E-06
         349          360  -0.12054776E-06
         350          350   0.13484933E+05
         350          341   0.36307130E+04
         350          342   0.24834091E+03
         350          345   0.21795340E-05
         350          347   0.49505150E-01
         350          348  -0.37042339E-04
         350          349   0.33536708E+02
         350          331  -0.86950688E-05
         350          332  -0.59474313E-06
         350          335  -0.52196912E-14
         350          337  -0.11851393E-09
         350          338   0.11294945E-13
         350          339  -0.80315889E-07
         350          340  -0.32294601E-04
         350          351  -0.13050607E-04
         350          352  -0.89266212E-06
         350          355  -0.78343413E-14
         350          357  -0.17787999E-09
         350          358   0.16952814E-13
         350          359  -0.12054776E-06
         350          360  -0.48471627E-04
         351          351   0.97945219E+04
         351          356   0.79884210E+02
         351          357   0.76117799E+02
         351          360   0.36307130E+04
         351          341  -0.23456563E-04
         351          346  -0.19131143E-06
         351          347  -0.18229190E-06
         351          350  -0.86950688E-05
         351          361  -0.35206435E-04
         351          366  -0.28714324E-06
         351          367  -0.27360565E-06
         351          370  -0.13050607E-04
         352          352   0.61664984E+04
         352          354   0.63450217E+01
         352          355   0.63450217E+01
         352          357  -0.21136331E+02
         352          360   0.24834091E+03
         352          342  -0.14762871E-04
         352          350  -0.59474313E-06
         352          362  -0.22157895E-04
         352          370  -0.89266212E-06
         353          353   0.78082192E+03
         353          343  -0.18699636E-05
         353          363  -0.28066666E-05
         354          354   0.13409529E+04
         354          352   0.63443872E+01
         354          355   0.19035065E+02
         354          357  -0.65836821E+02
         354          344  -0.31658156E-05
         354          347   0.58143243E-08
         354          364  -0.47516374E-05
         354          367   0.87268382E-08
         355          355   0.19052837E+02
         355          352   0.63443872E+01
         355          354   0.19035065E+02
         355          357  -0.63477866E+02
         355          360   0.21795643E-05
         355          345  -0.42484263E-10
         355          347   0.16470995E-09
         355          350  -0.52197638E-14
         355          365  -0.63765499E-10
         355          367   0.24721653E-09
         355          370  -0.78344502E-14
         356          356   0.17074662E+04
         356          351   0.79884210E+02
         356          357   0.19543730E+04
         356          359   0.43198833E-04
         356          341  -0.19131143E-06
         356          346  -0.40891515E-05
         356          347  -0.46804608E-05
         356          361  -0.28714324E-06
         356          366  -0.61374911E-05
         356          367  -0.70249993E-05
         357          357   0.26723718E+04
         357          351   0.76117799E+02
         357          352  -0.21147957E+02
         357          354  -0.65878288E+02
         357          355  -0.63519108E+02
         357          356   0.19543478E+04
         357          358  -0.38887502E-04
         357          359  -0.12035985E+00
         357          360   0.49505150E-01
         357          341  -0.18229190E-06
         357          344   0.58149057E-08
         357          345   0.16475051E-09
         357          346  -0.46804005E-05
         357          347  -0.58937841E-05
         357          348   0.15713863E-13
         357          349   0.28826779E-09
         357          350  -0.11851393E-09
         357          361  -0.27360565E-06
         357          364   0.87277109E-08
         357          365   0.24727742E-09
         357          366  -0.70249088E-05
         357          367  -0.88461011E-05
         357          368   0.23585259E-13
         357          369   0.43266702E-09
         357          370  -0.17787999E-09
         358          358   0.66308262E-04
         358          357  -0.38896922E-04
         358          359  -0.14946245E-04
         358          360  -0.37051937E-04
         358          347   0.15715132E-13
         358          348  -0.23320539E-13
         358          349  -0.29226999E-14
         358          350   0.11296639E-13
         358          367   0.23587162E-13
         358          368  -0.35002274E-13
         358          369  -0.43867400E-14
         358          370   0.16955357E-13
         359          359   0.99356224E+02
         359          356   0.43198833E-04
         359          357  -0.12034781E+00
         359          358  -0.14942654E-04
         359          360   0.33536708E+02
         359          347   0.28823897E-09
         359          348  -0.29225903E-14
         359          349  -0.23794469E-06
         359          350  -0.80315889E-07
         359          367   0.43262376E-09
         359          368  -0.43865755E-14
         359          369  -0.35713606E-06
         359          370  -0.12054776E-06
         360          360   0.13484933E+05
         360          351   0.36307130E+04
         360          352   0.24834091E+03
         360          355   0.21795340E-05
         360          357   0.49505150E-01
         360          358  -0.37042339E-04
         360          359   0.33536708E+02
         360          341  -0.86950688E-05
         360          342  -0.59474313E-06
         360          345  -0.52196912E-14
         360          347  -0.11851393E-09
         360          348   0.11294945E-13
         360          349  -0.80315889E-07
         360          350  -0.32294601E-04
         360          361  -0.13050607E-04
         360          362  -0.89266212E-06
         360          365  -0.78343413E-14
         360          367  -0.17787999E-09
         360          368   0.16952814E-13
         360          369  -0.12054776E-06
         360          370  -0.48471627E-04
         361          361   0.97945219E+04
         361          366   0.79884210E+02
         361          367   0.76117799E+02
         361          370   0.36307130E+04
         361          351  -0.23456563E-04
         361          356  -0.19131143E-06
         361          357  -0.18229190E-06
         361          360  -0.86950688E-05
         361          371  -0.35206435E-04
         361          376  -0.28714324E-06
         361          377  -0.27360565E-06
         361          380  -0.13050607E-04
         362          362   0.61664984E+04
         362          364   0.63450217E+01
         362          365   0.63450217E+01
         362          367  -0.21136331E+02
         362          370   0.24834091E+03
         362          352  -0.14762871E-04
         362          360  -0.59474313E-06
         362          372  -0.22157895E-04
         362          380  -0.89266212E-06
         363          363   0.78082192E+03
         363          353  -0.18699636E-05
         363          373  -0.28066666E-05
         364          364   0.13409529E+04
         364          362   0.63443872E+01
         364          365   0.19035065E+02
         364          367  -0.65836821E+02
         364          354  -0.31658156E-05
         364          357   0.58143243E-08
         364          374  -0.47516374E-05
         364          377   0.87268382E-08
         365          365   0.19052837E+02
         365          362   0.63443872E+01
         365          364   0.19035065E+02
         365          367  -0.63477866E+02
         365          370   0.21795643E-05
         365          355  -0.42484263E-10
         365          357   0.16470995E-09
         365          360  -0.52197638E-14
         365          375  -0.63765499E-10
         365          377   0.24721653E-09
         365          380  -0.78344502E-14
         366          366   0.17074662E+04
         366          361   0.79884210E+02
         366          367   0.19543730E+04
         366          369   0.43198833E-04
         366          351  -0.19131143E-06
         366          356  -0.40891515E-05
         366          357  -0.46804608E-05
         366          371  -0.28714324E-06
         366          376  -0.61374911E-05
         366          377  -0.70249993E-05
         367          367   0.26723718E+04
         367          361   0.76117799E+02
         367          362  -0.21147957E+02
         367          364  -0.65878288E+02
         367          365  -0.63519108E+02
         367          366   0.19543478E+04
         367          368  -0.38887502E-04
         367          369  -0.12035985E+00
         367          370   0.49505150E-01
         367          351  -0.18229190E-06
         367          354   0.58149057E-08
         367          355   0.16475051E-09
         367          356  -0.46804005E-05
         367          357  -0.58937841E-05
         367          358   0.15713863E-13
         367          359   0.28826779E-09
         367          360  -0.11851393E-09
         367          371  -0.27360565E-06
         367          374   0.87277109E-08
         367          375   0.24727742E-09
         367          376  -0.70249088E-05
         367          377  -0.88461011E-05
         367          378   0.23585259E-13
         367          379   0.43266702E-09
         367          380  -0.17787999E-09
         368          368   0.66308262E-04
         368          367  -0.38896922E-04
         368          369  -0.14946245E-04
         368          370  -0.37051937E-04
         368          357   0.15715132E-13
         368          358  -0.23320539E-13
         368          359  -0.29226999E-14
         368          360   0.11296639E-13
         368          377   0.23587162E-13
         368          378  -0.35002274E-13
         368          379  -0.43867400E-14
         368          380   0.16955357E-13
         369          369   0.99356224E+02
         369          366   0.43198833E-04
         369          367  -0.12034781E+00
         369          368  -0.14942654E-04
         369          370   0.33536708E+02
         369          357   0.28823897E-09
         369          358  -0.29225903E-14
         369          359  -0.23794469E-06
         369          360  -0.80315889E-07
         369          377   0.43262376E-09
         369          378  -0.43865755E-14
         369          379  -0.35713606E-06
         369          380  -0.12054776E-06
         370          370   0.13484933E+05
         370          361   0.36307130E+04
         370          362   0.24834091E+03
         370          365   0.21795340E-05
         370          367   0.49505150E-01
         370          368  -0.37042339E-04
         370          369   0.33536708E+02
         370          351  -0.86950688E-05
         370          352  -0.59474313E-06
         370          355  -0.52196912E-14
         370          357  -0.11851393E-09
         370          358   0.11294945E-13
         370          359  -0.80315889E-07
         370          360  -0.32294601E-04
         370          371  -0.13050607E-04
         370          372  -0.89266212E-06
         370          375  -0.78343413E-14
         370          377  -0.17787999E-09
         370          378   0.16952814E-13
         370          379  -0.12054776E-06
         370          380  -0.48471627E-04
         371          371   0.97945219E+04
         371          376   0.79884210E+02
         371          377   0.76117799E+02
         371          380   0.36307130E+04
         371          361  -0.23456563E-04
         371          366  -0.19131143E-06
         371          367  -0.18229190E-06
         371          370  -0.86950688E-05
         371          381  -0.35206435E-04
         371          386  -0.28714324E-06
         371          387  -0.27360565E-06
         371          390  -0.13050607E-04
         372          372   0.61664984E+04
         372          374   0.63450217E+01
         372          375   0.63450217E+01
         372          377  -0.21136331E+02
         372          380   0.24834091E+03
         372          362  -0.14762871E-04
         372          370  -0.59474313E-06
         372          382  -0.22157895E-04
         372          390  -0.89266212E-06
         373          373   0.78082192E+03
         373          363  -0.18699636E-05
         373          383  -0.28066666E-05
         374          374   0.13409529E+04
         374          372   0.63443872E+01
         374          375   0.19035065E+02
         374          377  -0.65836821E+02
         374          364  -0.31658156E-05
         374          367   0.58143243E-08
         374          384  -0.47516374E-05
         374          387   0.87268382E-08
         375          375   0.19052837E+02
         375          372   0.63443872E+01
         375          374   0.19035065E+02
         375          377  -0.63477866E+02
         375          380   0.21795643E-05
         375          365  -0.42484263E-10
         375          367   0.16470995E-09
         375          370  -0.52197638E-14
         375          385  -0.63765499E-10
         375          387   0.24721653E-09
         375          390  -0.78344502E-14
         376          376   0.17074662E+04
         376          371   0.79884210E+02
         376          377   0.19543730E+04
         376          379   0.43198833E-04
         376          361  -0.19131143E-06
         376          366  -0.40891515E-05
         376          367  -0.46804608E-05
         376          381  -0.28714324E-06
         376          386  -0.61374911E-05
         376          387  -0.70249993E-05
         377          377   0.26723718E+04
         377          371   0.76117799E+02
         377          372  -0.21147957E+02
         377          374  -0.65878288E+02
         377          375  -0.63519108E+02
         377          376   0.19543478E+04
         377          378  -0.38887502E-04
         377          379  -0.12035985E+00
         377          380   0.49505150E-01
         377          361  -0.18229190E-06
         377          364   0.58149057E-08
         377          365   0.16475051E-09
         377          366  -0.46804005E-05
         377          367  -0.58937841E-05
         377          368   0.15713863E-13
         377          369   0.28826779E-09
         377          370  -0.11851393E-09
         377          381  -0.27360565E-06
         377          384   0.87277109E-08
         377          385   0.24727742E-09
         377          386  -0.70249088E-05
         377          387  -0.88461011E-05
         377          388   0.23585259E-13
         377          389   0.43266702E-09
         377          390  -0.17787999E-09
         378          378   0.66308262E-04
         378          377  -0.38896922E-04
         378          379  -0.14946245E-04
         378          380  -0.37051937E-04
         378          367   0.15715132E-13
         378          368  -0.23320539E-13
         378          369  -0.29226999E-14
         378          370   0.11296639E-13
         378          387   0.23587162E-13
         378          388  -0.35002274E-13
         378          389  -0.43867400E-14
         378          390   0.16955357E-13
         379          379   0.99356224E+02
         379          376   0.43198833E-04
         379          377  -0.12034781E+00
         379          378  -0.14942654E-04
         379          380   0.33536708E+02
         379          367   0.28823897E-09
         379          368  -0.29225903E-14
         379          369  -0.23794469E-06
         379          370  -0.80315889E-07
         379          387   0.43262376E-09
         379          388  -0.43865755E-14
         379          389  -0.35713606E-06
         379          390  -0.12054776E-06
         380          380   0.13484933E+05
         380          371   0.36307130E+04
         380          372   0.24834091E+03
         380          375   0.21795340E-05
         380          377   0.49505150E-01
         380          378  -0.37042339E-04
         380          379   0.33536708E+02
         380          361  -0.86950688E-05
         380          362  -0.59474313E-06
         380          365  -0.52196912E-14
         380          367  -0.11851393E-09
         380          368   0.11294945E-13
         380          369  -0.80315889E-07
         380          370  -0.32294601E-04
         380          381  -0.13050607E-04
         380          382  -0.89266212E-06
         380          385  -0.78343413E-14
         380          387  -0.17787999E-09
         380          388   0.16952814E-13
         380          389  -0.12054776E-06
         380          390  -0.48471627E-04
         381          381   0.97945219E+04
         381          386   0.79884210E+02
         381          387   0.76117799E+02
         381          390   0.36307130E+04
         381          371  -0.23456563E-04
         381          376  -0.19131143E-06
         381          377  -0.18229190E-06
         381          380  -0.86950688E-05
         381          391  -0.35206435E-04
         381          396  -0.28714324E-06
         381          397  -0.27360565E-06
         381          400  -0.13050607E-04
         382          382   0.61664984E+04
         382          384   0.63450217E+01
         382          385   0.63450217E+01
         382          387  -0.21136331E+02
         382          390   0.24834091E+03
         382          372  -0.14762871E-04
         382          380  -0.59474313E-06
         382          392  -0.22157895E-04
         382          400  -0.89266212E-06
         383          383   0.78082192E+03
         383          373  -0.18699636E-05
         383          393  -0.28066666E-05
         384          384   0.13409529E+04
         384          382   0.63443872E+01
         384          385   0.19035065E+02
         384          387  -0.65836821E+02
         384          374  -0.31658156E-05
         384          377   0.58143243E-08
         384          394  -0.47516374E-05
         384          397   0.87268382E-08
         385          385   0.19052837E+02
         385          382   0.63443872E+01
         385          384   0.19035065E+02
         385          387  -0.63477866E+02
         385          390   0.21795643E-05
         385          375  -0.42484263E-10
         385          377   0.16470995E-09
         385          380  -0.52197638E-14
         385          395  -0.63765499E-10
         385          397   0.24721653E-09
         385          400  -0.78344502E-14
         386          386   0.17074662E+04
         386          381   0.79884210E+02
         386          387   0.19543730E+04
         386          389   0.43198833E-04
         386          371  -0.19131143E-06
         386          376  -0.40891515E-05
         386          377  -0.46804608E-05
         386          391  -0.28714324E-06
         386          396  -0.61374911E-05
         386          397  -0.70249993E-05
         387          387   0.26723718E+04
         387          381   0.76117799E+02
         387          382  -0.21147957E+02
         387          384  -0.65878288E+02
         387          385  -0.63519108E+02
         387          386   0.19543478E+04
         387          388  -0.38887502E-04
         387          389  -0.12035985E+00
         387          390   0.49505150E-01
         387          371  -0.18229190E-06
         387          374   0.58149057E-08
         387          375   0.16475051E-09
         387          376  -0.46804005E-05
         387          377  -0.58937841E-05
         387          378   0.15713863E-13
         387          379   0.28826779E-09
         387          380  -0.11851393E-09
         387          391  -0.27360565E-06
         387          394   0.87277109E-08
         387          395   0.24727742E-09
         387          396  -0.70249088E-05
         387          397  -0.88461011E-05
         387          398   0.23585259E-13
         387          399   0.43266702E-09
         387          400  -0.17787999E-09
         388          388   0.66308262E-04
         388          387  -0.38896922E-04
         388          389  -0.14946245E-04
         388          390  -0.37051937E-04
         388          377   0.15715132E-13
         388          378  -0.23320539E-13
         388          379  -0.29226999E-14
         388          380   0.11296639E-13
         388          397   0.23587162E-13
         388          398  -0.35002274E-13
         388          399  -0.43867400E-14
         388          400   0.16955357E-13
         389          389   0.99356224E+02
         389          386   0.43198833E-04
         389          387  -0.12034781E+00
         389          388  -0.14942654E-04
         389          390   0.33536708E+02
         389          377   0.28823897E-09
         389          378  -0.29225903E-14
         389          379  -0.23794469E-06
         389          380  -0.80315889E-07
         389          397   0.43262376E-09
         389          398  -0.43865755E-14
         389          399  -0.35713606E-06
         389          400  -0.12054776E-06
         390          390   0.13484933E+05
         390          381   0.36307130E+04
         390          382   0.24834091E+03
         390          385   0.21795340E-05
         390          387   0.49505150E-01
         390          388  -0.37042339E-04
         390          389   0.33536708E+02
         390          371  -0.86950688E-05
         390          372  -0.59474313E-06
         390          375  -0.52196912E-14
         390          377  -0.11851393E-09
         390          378   0.11294945E-13
         390          379  -0.80315889E-07
         390          380  -0.32294601E-04
         390          391  -0.13050607E-04
         390          392  -0.89266212E-06
         390          395  -0.78343413E-14
         390          397  -0.17787999E-09
         390          398   0.16952814E-13
         390          399  -0.12054776E-06
         390          400  -0.48471627E-04
         391          391   0.97945219E+04
         391          396   0.79884210E+02
         391          397   0.76117799E+02
         391          400   0.36307130E+04
         391          381  -0.23456563E-04
         391          386  -0.19131143E-06
         391          387  -0.18229190E-06
         391          390  -0.86950688E-05
         391          401  -0.35206435E-04
         391          406  -0.28714324E-06
         391          407  -0.27360565E-06
         391          410  -0.13050607E-04
         392          392   0.61664984E+04
         392          394   0.63450217E+01
         392          395   0.63450217E+01
         392          397  -0.21136331E+02
         392          400   0.24834091E+03
         392          382  -0.14762871E-04
         392          390  -0.59474313E-06
         392          402  -0.22157895E-04
         392          410  -0.89266212E-06
         393          393   0.78082192E+03
         393          383  -0.18699636E-05
         393          403  -0.28066666E-05
         394          394   0.13409529E+04
         394          392   0.63443872E+01
         394          395   0.19035065E+02
         394          397  -0.65836821E+02
         394          384  -0.31658156E-05
         394          387   0.58143243E-08
         394          404  -0.47516374E-05
         394          407   0.87268382E-08
         395          395   0.19052837E+02
         395          392   0.63443872E+01
         395          394   0.19035065E+02
         395          397  -0.63477866E+02
         395          400   0.21795643E-05
         395          385  -0.42484263E-10
         395          387   0.16470995E-09
         395          390  -0.52197638E-14
         395          405  -0.63765499E-10
         395          407   0.24721653E-09
         395          410  -0.78344502E-14
         396          396   0.17074662E+04
         396          391   0.79884210E+02
         396          397   0.19543730E+04
         396          399   0.43198833E-04
         396          381  -0.19131143E-06
         396          386  -0.40891515E-05
         396          387  -0.46804608E-05
         396          401  -0.28714324E-06
         396          406  -0.61374911E-05
         396          407  -0.70249993E-05
         397          397   0.26723718E+04
         397          391   0.76117799E+02
         397          392  -0.21147957E+02
         397          394  -0.65878288E+02
         397          395  -0.63519108E+02
         397          396   0.19543478E+04
         397          398  -0.38887502E-04
         397          399  -0.12035985E+00
         397          400   0.49505150E-01
         397          381  -0.18229190E-06
         397          384   0.58149057E-08
         397          385   0.16475051E-09
         397          386  -0.46804005E-05
         397          387  -0.58937841E-05
         397          388   0.15713863E-13
         397          389   0.28826779E-09
         397          390  -0.11851393E-09
         397          401  -0.27360565E-06
         397          404   0.87277109E-08
         397          405   0.24727742E-09
         397          406  -0.70249088E-05
         397          407  -0.88461011E-05
         397          408   0.23585259E-13
         397          409   0.43266702E-09
         397          410  -0.17787999E-09
         398          398   0.66308262E-04
         398          397  -0.38896922E-04
         398          399  -0.14946245E-04
         398          400  -0.37051937E-04
         398          387   0.15715132E-13
         398          388  -0.23320539E-13
         398          389  -0.29226999E-14
         398          390   0.11296639E-13
         398          407   0.23587162E-13
         398          408  -0.35002274E-13
         398          409  -0.43867400E-14
         398          410   0.16955357E-13
         399          399   0.99356224E+02
         399          396   0.43198833E-04
         399          397  -0.12034781E+00
         399          398  -0.14942654E-04
         399          400   0.33536708E+02
         399          387   0.28823897E-09
         399          388  -0.29225903E-14
         399          389  -0.23794469E-06
         399          390  -0.80315889E-07
         399          407   0.43262376E-09
         399          408  -0.43865755E-14
         399          409  -0.35713606E-06
         399          410  -0.12054776E-06
         400          400   0.13484933E+05
         400          391   0.36307130E+04
         400          392   0.24834091E+03
         400          395   0.21795340E-05
         400          397   0.49505150E-01
         400          398  -0.37042339E-04
         400          399   0.33536708E+02
         400          381  -0.86950688E-05
         400          382  -0.59474313E-06
         400          385  -0.52196912E-14
         400          387  -0.11851393E-09
         400          388   0.11294945E-13
         400          389  -0.80315889E-07
         400          390  -0.32294601E-04
         400          401  -0.13050607E-04
         400          402  -0.89266212E-06
         400          405  -0.78343413E-14
         400          407  -0.17787999E-09
         400          408   0.16952814E-13
         400          409  -0.12054776E-06
         400          410  -0.48471627E-04
         401          401   0.97945219E+04
         401          406   0.79884210E+02
         401          407   0.76117799E+02
         401          410   0.36307130E+04
         401          391  -0.23456563E-04
         401          396  -0.19131143E-06
         401          397  -0.18229190E-06
         401          400  -0.86950688E-05
         401          411  -0.35206435E-04
         401          416  -0.28714324E-06
         401          417  -0.27360565E-06
         401          420  -0.13050607E-04
         402          402   0.61664984E+04
         402          404   0.63450217E+01
         402          405   0.63450217E+01
         402          407  -0.21136331E+02
         402          410   0.24834091E+03
         402          392  -0.14762871E-04
         402          400  -0.59474313E-06
         402          412  -0.22157895E-04
         402          420  -0.89266212E-06
         403          403   0.78082192E+03
         403          393  -0.18699636E-05
         403          413  -0.28066666E-05
         404          404   0.13409529E+04
         404          402   0.63443872E+01
         404          405   0.19035065E+02
         404          407  -0.65836821E+02
         404          394  -0.31658156E-05
         404          397   0.58143243E-08
         404          414  -0.47516374E-05
         404          417   0.87268382E-08
         405          405   0.19052837E+02
         405          402   0.63443872E+01
         405          404   0.19035065E+02
         405          407  -0.63477866E+02
         405          410   0.21795643E-05
         405          395  -0.42484263E-10
         405          397   0.16470995E-09
         405          400  -0.52197638E-14
         405          415  -0.63765499E-10
         405          417   0.24721653E-09
         405          420  -0.78344502E-14
         406          406   0.17074662E+04
         406          401   0.79884210E+02
         406          407   0.19543730E+04
         406          409   0.43198833E-04
         406          391  -0.19131143E-06
         406          396  -0.40891515E-05
         406          397  -0.46804608E-05
         406          411  -0.28714324E-06
         406          416  -0.61374911E-05
         406          417  -0.70249993E-05
         407          407   0.26723718E+04
         407          401   0.76117799E+02
         407          402  -0.21147957E+02
         407          404  -0.65878288E+02
         407          405  -0.63519108E+02
         407          406   0.19543478E+04
         407          408  -0.38887502E-04
         407          409  -0.12035985E+00
         407          410   0.49505150E-01
         407          391  -0.18229190E-06
         407          394   0.58149057E-08
         407          395   0.16475051E-09
         407          396  -0.46804005E-05
         407          397  -0.58937841E-05
         407          398   0.15713863E-13
         407          399   0.28826779E-09
         407          400  -0.11851393E-09
         407          411  -0.27360565E-06
         407          414   0.87277109E-08
         407          415   0.24727742E-09
         407          416  -0.70249088E-05
         407          417  -0.88461011E-05
         407          418   0.23585259E-13
         407          419   0.43266702E-09
         407          420  -0.17787999E-09
         408          408   0.66308262E-04
         408          407  -0.38896922E-04
         408          409  -0.14946245E-04
         408          410  -0.37051937E-04
         408          397   0.15715132E-13
         408          398  -0.23320539E-13
         408          399  -0.29226999E-14
         408          400   0.11296639E-13
         408          417   0.23587162E-13
         408          418  -0.35002274E-13
         408          419  -0.43867400E-14
         408          420   0.16955357E-13
         409          409   0.99356224E+02
         409          406   0.43198833E-04
         409          407  -0.12034781E+00
         409          408  -0.14942654E-04
         409          410   0.33536708E+02
         409          397   0.28823897E-09
         409          398  -0.29225903E-14
         409          399  -0.23794469E-06
         409          400  -0.80315889E-07
         409          417   0.43262376E-09
         409          418  -0.43865755E-14
         409          419  -0.35713606E-06
         409          420  -0.12054776E-06
         410          410   0.13484933E+05
         410          401   0.36307130E+04
         410          402   0.24834091E+03
         410          405   0.21795340E-05
         410          407   0.49505150E-01
         410          408  -0.37042339E-04
         410          409   0.33536708E+02
         410          391  -0.86950688E-05
         410          392  -0.59474313E-06
         410          395  -0.52196912E-14
         410          397  -0.11851393E-09
         410          398   0.11294945E-13
         410          399  -0.80315889E-07
         410          400  -0.32294601E-04
         410          411  -0.13050607E-04
         410          412  -0.89266212E-06
         410          415  -0.78343413E-14
         410          417  -0.17787999E-09
         410          418   0.16952814E-13
         410          419  -0.12054776E-06
         410          420  -0.48471627E-04
         411          411   0.97945219E+04
         411          416   0.79884210E+02
         411          417   0.76117799E+02
         411          420   0.36307130E+04
         411          401  -0.23456563E-04
         411          406  -0.19131143E-06
         411          407  -0.18229190E-06
         411          410  -0.86950688E-05
         411          421  -0.35206435E-04
         411          426  -0.28714324E-06
         411          427  -0.27360565E-06
         411          430  -0.13050607E-04
         412          412   0.61664984E+04
         412          414   0.63450217E+01
         412          415   0.63450217E+01
         412          417  -0.21136331E+02
         412          420   0.24834091E+03
         412          402  -0.14762871E-04
         412          410  -0.59474313E-06
         412          422  -0.22157895E-04
         412          430  -0.89266212E-06
         413          413   0.78082192E+03
         413          403  -0.18699636E-05
         413          423  -0.28066666E-05
         414          414   0.13409529E+04
         414          412   0.63443872E+01
         414          415   0.19035065E+02
         414          417  -0.65836821E+02
         414          404  -0.31658156E-05
         414          407   0.58143243E-08
         414          424  -0.47516374E-05
         414          427   0.87268382E-08
         415          415   0.19052837E+02
         415          412   0.63443872E+01
         415          414   0.19035065E+02
         415          417  -0.63477866E+02
         415          420   0.21795643E-05
         415          405  -0.42484263E-10
         415          407   0.16470995E-09
         415          410  -0.52197638E-14
         415          425  -0.63765499E-10
         415          427   0.24721653E-09
         415          430  -0.78344502E-14
         416          416   0.17074662E+04
         416          411   0.79884210E+02
         416          417   0.19543730E+04
         416          419   0.43198833E-04
         416          401  -0.19131143E-06
         416          406  -0.40891515E-05
         416          407  -0.46804608E-05
         416          421  -0.28714324E-06
         416          426  -0.61374911E-05
         416          427  -0.70249993E-05
         417          417   0.26723718E+04
         417          411   0.76117799E+02
         417          412  -0.21147957E+02
         417          414  -0.65878288E+02
         417          415  -0.63519108E+02
         417          416   0.19543478E+04
         417          418  -0.38887502E-04
         417          419  -0.12035985E+00
         417          420   0.49505150E-01
         417          401  -0.18229190E-06
         417          404   0.58149057E-08
         417          405   0.16475051E-09
         417          406  -0.46804005E-05
         417          407  -0.58937841E-05
         417          408   0.15713863E-13
         417          409   0.28826779E-09
         417          410  -0.11851393E-09
         417          421  -0.27360565E-06
         417          424   0.87277109E-08
         417          425   0.24727742E-09
         417          426  -0.70249088E-05
         417          427  -0.88461011E-05
         417          428   0.23585259E-13
         417          429   0.43266702E-09
         417          430  -0.17787999E-09
         418          418   0.66308262E-04
         418          417  -0.38896922E-04
         418          419  -0.14946245E-04
         418          420  -0.37051937E-04
         418          407   0.15715132E-13
         418          408  -0.23320539E-13
         418          409  -0.29226999E-14
         418          410   0.11296639E-13
         418          427   0.23587162E-13
         418          428  -0.35002274E-13
         418          429  -0.43867400E-14
         418          430   0.16955357E-13
         419          419   0.99356224E+02
         419          416   0.43198833E-04
         419          417  -0.12034781E+00
         419          418  -0.14942654E-04
         419          420   0.33536708E+02
         419          407   0.28823897E-09
         419          408  -0.29225903E-14
         419          409  -0.23794469E-06
         419          410  -0.80315889E-07
         419          427   0.43262376E-09
         419          428  -0.43865755E-14
         419          429  -0.35713606E-06
         419          430  -0.12054776E-06
         420          420   0.13484933E+05
         420          411   0.36307130E+04
         420          412   0.24834091E+03
         420          415   0.21795340E-05
         420          417   0.49505150E-01
         420          418  -0.37042339E-04
         420          419   0.33536708E+02
         420          401  -0.86950688E-05
         420          402  -0.59474313E-06
         420          405  -0.52196912E-14
         420          407  -0.11851393E-09
         420          408   0.11294945E-13
         420          409  -0.80315889E-07
         420          410  -0.32294601E-04
         420          421  -0.13050607E-04
         420          422  -0.89266212E-06
         420          425  -0.78343413E-14
         420          427  -0.17787999E-09
         420          428   0.16952814E-13
         420          429  -0.12054776E-06
         420          430  -0.48471627E-04
         421          421   0.97945219E+04
         421          426   0.79884210E+02
         421          427   0.76117799E+02
         421          430   0.36307130E+04
         421          411  -0.23456563E-04
         421          416  -0.19131143E-06
         421          417  -0.18229190E-06
         421          420  -0.86950688E-05
         421          431  -0.35206435E-04
         421          436  -0.28714324E-06
         421          437  -0.27360565E-06
         421          440  -0.13050607E-04
         422          422   0.61664984E+04
         422          424   0.63450217E+01
         422          425   0.63450217E+01
         422          427  -0.21136331E+02
         422          430   0.24834091E+03
         422          412  -0.14762871E-04
         422          420  -0.59474313E-06
         422          432  -0.22157895E-04
         422          440  -0.89266212E-06
         423          423   0.78082192E+03
         423          413  -0.18699636E-05
         423          433  -0.28066666E-05
         424          424   0.13409529E+04
         424          422   0.63443872E+01
         424          425   0.19035065E+02
         424          427  -0.65836821E+02
         424          414  -0.31658156E-05
         424          417   0.58143243E-08
         424          434  -0.47516374E-05
         424          437   0.87268382E-08
         425          425   0.19052837E+02
         425          422   0.63443872E+01
         425          424   0.19035065E+02
         425          427  -0.63477866E+02
         425          430   0.21795643E-05
         425          415  -0.42484263E-10
         425          417   0.16470995E-09
         425          420  -0.52197638E-14
         425          435  -0.63765499E-10
         425          437   0.24721653E-09
         425          440  -0.78344502E-14
         426          426   0.17074662E+04
         426          421   0.79884210E+02
         426          427   0.19543730E+04
         426          429   0.43198833E-04
         426          411  -0.19131143E-06
         426          416  -0.40891515E-05
         426          417  -0.46804608E-05
         426          431  -0.28714324E-06
         426          436  -0.61374911E-05
         426          437  -0.70249993E-05
         427          427   0.26723718E+04
         427          421   0.76117799E+02
         427          422  -0.21147957E+02
         427          424  -0.65878288E+02
         427          425  -0.63519108E+02
         427          426   0.19543478E+04
         427          428  -0.38887502E-04
         427          429  -0.12035985E+00
         427          430   0.49505150E-01
         427          411  -0.18229190E-06
         427          414   0.58149057E-08
         427          415   0.16475051E-09
         427          416  -0.46804005E-05
         427          417  -0.58937841E-05
         427          418   0.15713863E-13
         427          419   0.28826779E-09
         427          420  -0.11851393E-09
         427          431  -0.27360565E-06
         427          434   0.87277109E-08
         427          435   0.24727742E-09
         427          436  -0.70249088E-05
         427          437  -0.88461011E-05
         427          438   0.23585259E-13
         427          439   0.43266702E-09
         427          440  -0.17787999E-09
         428          428   0.66308262E-04
         428          427  -0.38896922E-04
         428          429  -0.14946245E-04
         428          430  -0.37051937E-04
         428          417   0.15715132E-13
         428          418  -0.23320539E-13
         428          419  -0.29226999E-14
         428          420   0.11296639E-13
         428          437   0.23587162E-13
         428          438  -0.35002274E-13
         428          439  -0.43867400E-14
         428          440   0.16955357E-13
         429          429   0.99356224E+02
         429          426   0.43198833E-04
         429          427  -0.12034781E+00
         429          428  -0.14942654E-04
         429          430   0.33536708E+02
         429          417   0.28823897E-09
         429          418  -0.29225903E-14
         429          419  -0.23794469E-06
         429          420  -0.80315889E-07
         429          437   0.43262376E-09
         429          438  -0.43865755E-14
         429          439  -0.35713606E-06
         429          440  -0.12054776E-06
         430          430   0.13484933E+05
         430          421   0.36307130E+04
         430          422   0.24834091E+03
         430          425   0.21795340E-05
         430          427   0.49505150E-01
         430          428  -0.37042339E-04
         430          429   0.33536708E+02
         430          411  -0.86950688E-05
         430          412  -0.59474313E-06
         430          415  -0.52196912E-14
         430          417  -0.11851393E-09
         430          418   0.11294945E-13
         430          419  -0.80315889E-07
         430          420  -0.32294601E-04
         430          431  -0.13050607E-04
         430          432  -0.89266212E-06
         430          435  -0.78343413E-14
         430          437  -0.17787999E-09
         430          438   0.16952814E-13
         430          439  -0.12054776E-06
         430          440  -0.48471627E-04
         431          431   0.97945219E+04
         431          436   0.79884210E+02
         431          437   0.76117799E+02
         431          440   0.36307130E+04
         431          421  -0.23456563E-04
         431          426  -0.19131143E-06
         431          427  -0.18229190E-06
         431          430  -0.86950688E-05
         431          441  -0.35206435E-04
         431          446  -0.28714324E-06
         431          447  -0.27360565E-06
         431          450  -0.13050607E-04
         432          432   0.61664984E+04
         432          434   0.63450217E+01
         432          435   0.63450217E+01
         432          437  -0.21136331E+02
         432          440   0.24834091E+03
         432          422  -0.14762871E-04
         432          430  -0.59474313E-06
         432          442  -0.22157895E-04
         432          450  -0.89266212E-06
         433          433   0.78082192E+03
         433          423  -0.18699636E-05
         433          443  -0.28066666E-05
         434          434   0.13409529E+04
         434          432   0.63443872E+01
         434          435   0.19035065E+02
         434          437  -0.65836821E+02
         434          424  -0.31658156E-05
         434          427   0.58143243E-08
         434          444  -0.47516374E-05
         434          447   0.87268382E-08
         435          435   0.19052837E+02
         435          432   0.63443872E+01
         435          434   0.19035065E+02
         435          437  -0.63477866E+02
         435          440   0.21795643E-05
         435          425  -0.42484263E-10
         435          427   0.16470995E-09
         435          430  -0.52197638E-14
         435          445  -0.63765499E-10
         435          447   0.24721653E-09
         435          450  -0.78344502E-14
         436          436   0.17074662E+04
         436          431   0.79884210E+02
         436          437   0.19543730E+04
         436          439   0.43198833E-04
         436          421  -0.19131143E-06
         436          426  -0.40891515E-05
         436          427  -0.46804608E-05
         436          441  -0.28714324E-06
         436          446  -0.61374911E-05
         436          447  -0.70249993E-05
         437          437   0.26723718E+04
         437          431   0.76117799E+02
         437          432  -0.21147957E+02
         437          434  -0.65878288E+02
         437          435  -0.63519108E+02
         437          436   0.19543478E+04
         437          438  -0.38887502E-04
         437          439  -0.12035985E+00
         437          440   0.49505150E-01
         437          421  -0.18229190E-06
         437          424   0.58149057E-08
         437          425   0.16475051E-09
         437          426  -0.46804005E-05
         437          427  -0.58937841E-05
         437          428   0.15713863E-13
         437          429   0.28826779E-09
         437          430  -0.11851393E-09
         437          441  -0.27360565E-06
         437          444   0.87277109E-08
         437          445   0.24727742E-09
         437          446  -0.70249088E-05
         437          447  -0.88461011E-05
         437          448   0.23585259E-13
         437          449   0.43266702E-09
         437          450  -0.17787999E-09
         438          438   0.66308262E-04
         438          437  -0.38896922E-04
         438          439  -0.14946245E-04
         438          440  -0.37051937E-04
         438          427   0.15715132E-13
         438          428  -0.23320539E-13
         438          429  -0.29226999E-14
         438          430   0.11296639E-13
         438          447   0.23587162E-13
         438          448  -0.35002274E-13
         438          449  -0.43867400E-14
         438          450   0.16955357E-13
         439          439   0.99356224E+02
         439          436   0.43198833E-04
         439          437  -0.12034781E+00
         439          438  -0.14942654E-04
         439          440   0.33536708E+02
         439          427   0.28823897E-09
         439          428  -0.29225903E-14
         439          429  -0.23794469E-06
         439          430  -0.80315889E-07
         439          447   0.43262376E-09
         439          448  -0.43865755E-14
         439          449  -0.35713606E-06
         439          450  -0.12054776E-06
         440          440   0.13484933E+05
         440          431   0.36307130E+04
         440          432   0.24834091E+03
         440          435   0.21795340E-05
         440          437   0.49505150E-01
         440          438  -0.37042339E-04
         440          439   0.33536708E+02
         440          421  -0.86950688E-05
         440          422  -0.59474313E-06
         440          425  -0.52196912E-14
         440          427  -0.11851393E-09
         440          428   0.11294945E-13
         440          429  -0.80315889E-07
         440          430  -0.32294601E-04
         440          441  -0.13050607E-04
         440          442  -0.89266212E-06
         440          445  -0.78343413E-14
         440          447  -0.17787999E-09
         440          448   0.16952814E-13
         440          449  -0.12054776E-06
         440          450  -0.48471627E-04
         441          441   0.97945219E+04
         441          446   0.79884210E+02
         441          447   0.76117799E+02
         441          450   0.36307130E+04
         441          431  -0.23456563E-04
         441          436  -0.19131143E-06
         441          437  -0.18229190E-06
         441          440  -0.86950688E-05
         441          451  -0.35206435E-04
         441          456  -0.28714324E-06
         441          457  -0.27360565E-06
         441          460  -0.13050607E-04
         442          442   0.61664984E+04
         442          444   0.63450217E+01
         442          445   0.63450217E+01
         442          447  -0.21136331E+02
         442          450   0.24834091E+03
         442          432  -0.14762871E-04
         442          440  -0.59474313E-06
         442          452  -0.22157895E-04
         442          460  -0.89266212E-06
         443          443   0.78082192E+03
         443          433  -0.18699636E-05
         443          453  -0.28066666E-05
         444          444   0.13409529E+04
         444          442   0.63443872E+01
         444          445   0.19035065E+02
         444          447  -0.65836821E+02
         444          434  -0.31658156E-05
         444          437   0.58143243E-08
         444          454  -0.47516374E-05
         444          457   0.87268382E-08
         445          445   0.19052837E+02
         445          442   0.63443872E+01
         445          444   0.19035065E+02
         445          447  -0.63477866E+02
         445          450   0.21795643E-05
         445          435  -0.42484263E-10
         445          437   0.16470995E-09
         445          440  -0.52197638E-14
         445          455  -0.63765499E-10
         445          457   0.24721653E-09
         445          460  -0.78344502E-14
         446          446   0.17074662E+04
         446          441   0.79884210E+02
         446          447   0.19543730E+04
         446          449   0.43198833E-04
         446          431  -0.19131143E-06
         446          436  -0.40891515E-05
         446          437  -0.46804608E-05
         446          451  -0.28714324E-06
         446          456  -0.61374911E-05
         446          457  -0.70249993E-05
         447          447   0.26723718E+04
         447          441   0.76117799E+02
         447          442  -0.21147957E+02
         447          444  -0.65878288E+02
         447          445  -0.63519108E+02
         447          446   0.19543478E+04
         447          448  -0.38887502E-04
         447          449  -0.12035985E+00
         447          450   0.49505150E-01
         447          431  -0.18229190E-06
         447          434   0.58149057E-08
         447          435   0.16475051E-09
         447          436  -0.46804005E-05
         447          437  -0.58937841E-05
         447          438   0.15713863E-13
         447          439   0.28826779E-09
         447          440  -0.11851393E-09
         447          451  -0.27360565E-06
         447          454   0.87277109E-08
         447          455   0.24727742E-09
         447          456  -0.70249088E-05
         447          457  -0.88461011E-05
         447          458   0.23585259E-13
         447          459   0.43266702E-09
         447          460  -0.17787999E-09
         448          448   0.66308262E-04
         448          447  -0.38896922E-04
         448          449  -0.14946245E-04
         448          450  -0.37051937E-04
         448          437   0.15715132E-13
         448          438  -0.23320539E-13
         448          439  -0.29226999E-14
         448          440   0.11296639E-13
         448          457   0.23587162E-13
         448          458  -0.35002274E-13
         448          459  -0.43867400E-14
         448          460   0.16955357E-13
         449          449   0.99356224E+02
         449          446   0.43198833E-04
         449          447  -0.12034781E+00
         449          448  -0.14942654E-04
         449          450   0.33536708E+02
         449          437   0.28823897E-09
         449          438  -0.29225903E-14
         449          439  -0.23794469E-06
         449          440  -0.80315889E-07
         449          457   0.43262376E-09
         449          458  -0.43865755E-14
         449          459  -0.35713606E-06
         449          460  -0.12054776E-06
         450          450   0.13484933E+05
         450          441   0.36307130E+04
         450          442   0.24834091E+03
         450          445   0.21795340E-05
         450          447   0.49505150E-01
         450          448  -0.37042339E-04
         450          449   0.33536708E+02
         450          431  -0.86950688E-05
         450          432  -0.59474313E-06
         450          435  -0.52196912E-14
         450          437  -0.11851393E-09
         450          438   0.11294945E-13
         450          439  -0.80315889E-07
         450          440  -0.32294601E-04
         450          451  -0.13050607E-04
         450          452  -0.89266212E-06
         450          455  -0.78343413E-14
         450          457  -0.17787999E-09
         450          458   0.16952814E-13
         450          459  -0.12054776E-06
         450          460  -0.48471627E-04
         451          451   0.97945219E+04
         451          456   0.79884210E+02
         451          457   0.76117799E+02
         451          460   0.36307130E+04
         451          441  -0.23456563E-04
         451          446  -0.19131143E-06
         451          447  -0.18229190E-06
         451          450  -0.86950688E-05
         451          461  -0.35206435E-04
         451          466  -0.28714324E-06
         451          467  -0.27360565E-06
         451          470  -0.13050607E-04
         452          452   0.61664984E+04
         452          454   0.63450217E+01
         452          455   0.63450217E+01
         452          457  -0.21136331E+02
         452          460   0.24834091E+03
         452          442  -0.14762871E-04
         452          450  -0.59474313E-06
         452          462  -0.22157895E-04
         452          470  -0.89266212E-06
         453          453   0.78082192E+03
         453          443  -0.18699636E-05
         453          463  -0.28066666E-05
         454          454   0.13409529E+04
         454          452   0.63443872E+01
         454          455   0.19035065E+02
         454          457  -0.65836821E+02
         454          444  -0.31658156E-05
         454          447   0.58143243E-08
         454          464  -0.47516374E-05
         454          467   0.87268382E-08
         455          455   0.19052837E+02
         455          452   0.63443872E+01
         455          454   0.19035065E+02
         455          457  -0.63477866E+02
         455          460   0.21795643E-05
         455          445  -0.42484263E-10
         455          447   0.16470995E-09
         455          450  -0.52197638E-14
         455          465  -0.63765499E-10
         455          467   0.24721653E-09
         455          470  -0.78344502E-14
         456          456   0.17074662E+04
         456          451   0.79884210E+02
         456          457   0.19543730E+04
         456          459   0.43198833E-04
         456          441  -0.19131143E-06
         456          446  -0.40891515E-05
         456          447  -0.46804608E-05
         456          461  -0.28714324E-06
         456          466  -0.61374911E-05
         456          467  -0.70249993E-05
         457          457   0.26723718E+04
         457          451   0.76117799E+02
         457          452  -0.21147957E+02
         457          454  -0.65878288E+02
         457          455  -0.63519108E+02
         457          456   0.19543478E+04
         457          458  -0.38887502E-04
         457          459  -0.12035985E+00
         457          460   0.49505150E-01
         457          441  -0.18229190E-06
         457          444   0.58149057E-08
         457          445   0.16475051E-09
         457          446  -0.46804005E-05
         457          447  -0.58937841E-05
         457          448   0.15713863E-13
         457          449   0.28826779E-09
         457          450  -0.11851393E-09
         457          461  -0.27360565E-06
         457          464   0.87277109E-08
         457          465   0.24727742E-09
         457          466  -0.70249088E-05
         457          467  -0.88461011E-05
         457          468   0.23585259E-13
         457          469   0.43266702E-09
         457          470  -0.17787999E-09
         458          458   0.66308262E-04
         458          457  -0.38896922E-04
         458          459  -0.14946245E-04
         458          460  -0.37051937E-04
         458          447   0.15715132E-13
         458          448  -0.23320539E-13
         458          449  -0.29226999E-14
         458          450   0.11296639E-13
         458          467   0.23587162E-13
         458          468  -0.35002274E-13
         458          469  -0.43867400E-14
         458          470   0.16955357E-13
         459          459   0.99356224E+02
         459          456   0.43198833E-04
         459          457  -0.12034781E+00
         459          458  -0.14942654E-04
         459          460   0.33536708E+02
         459          447   0.28823897E-09
         459          448  -0.29225903E-14
         459          449  -0.23794469E-06
         459          450  -0.80315889E-07
         459          467   0.43262376E-09
         459          468  -0.43865755E-14
         459          469  -0.35713606E-06
         459          470  -0.12054776E-06
         460          460   0.13484933E+05
         460          451   0.36307130E+04
         460          452   0.24834091E+03
         460          455   0.21795340E-05
         460          457   0.49505150E-01
         460          458  -0.37042339E-04
         460          459   0.33536708E+02
         460          441  -0.86950688E-05
         460          442  -0.59474313E-06
         460          445  -0.52196912E-14
         460          447  -0.11851393E-09
         460          448   0.11294945E-13
         460          449  -0.80315889E-07
         460          450  -0.32294601E-04
         460          461  -0.13050607E-04
         460          462  -0.89266212E-06
         460          465  -0.78343413E-14
         460          467  -0.17787999E-09
         460          468   0.16952814E-13
         460          469  -0.12054776E-06
         460          470  -0.48471627E-04
         461          461   0.97945219E+04
         461          466   0.79884210E+02
         461          467   0.76117799E+02
         461          470   0.36307130E+04
         461          451  -0.23456563E-04
         461          456  -0.19131143E-06
         461          457  -0.18229190E-06
         461          460  -0.86950688E-05
         461          471  -0.35206435E-04
         461          476  -0.28714324E-06
         461          477  -0.27360565E-06
         461          480  -0.13050607E-04
         462          462   0.61664984E+04
         462          464   0.63450217E+01
         462          465   0.63450217E+01
         462          467  -0.21136331E+02
         462          470   0.24834091E+03
         462          452  -0.14762871E-04
         462          460  -0.59474313E-06
         462          472  -0.22157895E-04
         462          480  -0.89266212E-06
         463          463   0.78082192E+03
         463          453  -0.18699636E-05
         463          473  -0.28066666E-05
         464          464   0.13409529E+04
         464          462   0.63443872E+01
         464          465   0.19035065E+02
         464          467  -0.65836821E+02
         464          454  -0.31658156E-05
         464          457   0.58143243E-08
         464          474  -0.47516374E-05
         464          477   0.87268382E-08
         465          465   0.19052837E+02
         465          462   0.63443872E+01
         465          464   0.19035065E+02
         465          467  -0.63477866E+02
         465          470   0.21795643E-05
         465          455  -0.42484263E-10
         465          457   0.16470995E-09
         465          460  -0.52197638E-14
         465          475  -0.63765499E-10
         465          477   0.24721653E-09
         465          480  -0.78344502E-14
         466          466   0.17074662E+04
         466          461   0.79884210E+02
         466          467   0.19543730E+04
         466          469   0.43198833E-04
         466          451  -0.19131143E-06
         466          456  -0.40891515E-05
         466          457  -0.46804608E-05
         466          471  -0.28714324E-06
         466          476  -0.61374911E-05
         466          477  -0.70249993E-05
         467          467   0.26723718E+04
         467          461   0.76117799E+02
         467          462  -0.21147957E+02
         467          464  -0.65878288E+02
         467          465  -0.63519108E+02
         467          466   0.19543478E+04
         467          468  -0.38887502E-04
         467          469  -0.12035985E+00
         467          470   0.49505150E-01
         467          451  -0.18229190E-06
         467          454   0.58149057E-08
         467          455   0.16475051E-09
         467          456  -0.46804005E-05
         467          457  -0.58937841E-05
         467          458   0.15713863E-13
         467          459   0.28826779E-09
         467          460  -0.11851393E-09
         467          471  -0.27360565E-06
         467          474   0.87277109E-08
         467          475   0.24727742E-09
         467          476  -0.70249088E-05
         467          477  -0.88461011E-05
         467          478   0.23585259E-13
         467          479   0.43266702E-09
         467          480  -0.17787999E-09
         468          468   0.66308262E-04
         468          467  -0.38896922E-04
         468          469  -0.14946245E-04
         468          470  -0.37051937E-04
         468          457   0.15715132E-13
         468          458  -0.23320539E-13
         468          459  -0.29226999E-14
         468          460   0.11296639E-13
         468          477   0.23587162E-13
         468          478  -0.35002274E-13
         468          479  -0.43867400E-14
         468          480   0.16955357E-13
         469          469   0.99356224E+02
         469          466   0.43198833E-04
         469          467  -0.12034781E+00
         469          468  -0.14942654E-04
         469          470   0.33536708E+02
         469          457   0.28823897E-09
         469          458  -0.29225903E-14
         469          459  -0.23794469E-06
         469          460  -0.80315889E-07
         469          477   0.43262376E-09
         469          478  -0.43865755E-14
         469          479  -0.35713606E-06
         469          480  -0.12054776E-06
         470          470   0.13484933E+05
         470          461   0.36307130E+04
         470          462   0.24834091E+03
         470          465   0.21795340E-05
         470          467   0.49505150E-01
         470          468  -0.37042339E-04
         470          469   0.33536708E+02
         470          451  -0.86950688E-05
         470          452  -0.59474313E-06
         470          455  -0.52196912E-14
         470          457  -0.11851393E-09
         470          458   0.11294945E-13
         470          459  -0.80315889E-07
         470          460  -0.32294601E-04
         470          471  -0.13050607E-04
         470          472  -0.89266212E-06
         470          475  -0.78343413E-14
         470          477  -0.17787999E-09
         470          478   0.16952814E-13
         470          479  -0.12054776E-06
         470          480  -0.48471627E-04
         471          471   0.97945219E+04
         471          476   0.79884210E+02
         471          477   0.76117799E+02
         471          480   0.36307130E+04
         471          461  -0.23456563E-04
         471          466  -0.19131143E-06
         471          467  -0.18229190E-06
         471          470  -0.86950688E-05
         471          481  -0.35206435E-04
         471          486  -0.28714324E-06
         471          487  -0.27360565E-06
         471          490  -0.13050607E-04
         472          472   0.61664984E+04
         472          474   0.63450217E+01
         472          475   0.63450217E+01
         472          477  -0.21136331E+02
         472          480   0.24834091E+03
         472          462  -0.14762871E-04
         472          470  -0.59474313E-06
         472          482  -0.22157895E-04
         472          490  -0.89266212E-06
         473          473   0.78082192E+03
         473          463  -0.18699636E-05
         473          483  -0.28066666E-05
         474          474   0.13409529E+04
         474          472   0.63443872E+01
         474          475   0.19035065E+02
         474          477  -0.65836821E+02
         474          464  -0.31658156E-05
         474          467   0.58143243E-08
         474          484  -0.47516374E-05
         474          487   0.87268382E-08
         475          475   0.19052837E+02
         475          472   0.63443872E+01
         475          474   0.19035065E+02
         475          477  -0.63477866E+02
         475          480   0.21795643E-05
         475          465  -0.42484263E-10
         475          467   0.16470995E-09
         475          470  -0.52197638E-14
         475          485  -0.63765499E-10
         475          487   0.24721653E-09
         475          490  -0.78344502E-14
         476          476   0.17074662E+04
         476          471   0.79884210E+02
         476          477   0.19543730E+04
         476          479   0.43198833E-04
         476          461  -0.19131143E-06
         476          466  -0.40891515E-05
         476          467  -0.46804608E-05
         476          481  -0.28714324E-06
         476          486  -0.61374911E-05
         476          487  -0.70249993E-05
         477          477   0.26723718E+04
         477          471   0.76117799E+02
         477          472  -0.21147957E+02
         477          474  -0.65878288E+02
         477          475  -0.63519108E+02
         477          476   0.19543478E+04
         477          478  -0.38887502E-04
         477          479  -0.12035985E+00
         477          480   0.49505150E-01
         477          461  -0.18229190E-06
         477          464   0.58149057E-08
         477          465   0.16475051E-09
         477          466  -0.46804005E-05
         477          467  -0.58937841E-05
         477          468   0.15713863E-13
         477          469   0.28826779E-09
         477          470  -0.11851393E-09
         477          481  -0.27360565E-06
         477          484   0.87277109E-08
         477          485   0.24727742E-09
         477          486  -0.70249088E-05
         477          487  -0.88461011E-05
         477          488   0.23585259E-13
         477          489   0.43266702E-09
         477          490  -0.17787999E-09
         478          478   0.66308262E-04
         478          477  -0.38896922E-04
         478          479  -0.14946245E-04
         478          480  -0.37051937E-04
         478          467   0.15715132E-13
         478          468  -0.23320539E-13
         478          469  -0.29226999E-14
         478          470   0.11296639E-13
         478          487   0.23587162E-13
         478          488  -0.35002274E-13
         478          489  -0.43867400E-14
         478          490   0.16955357E-13
         479          479   0.99356224E+02
         479          476   0.43198833E-04
         479          477  -0.12034781E+00
         479          478  -0.14942654E-04
         479          480   0.33536708E+02
         479          467   0.28823897E-09
         479          468  -0.29225903E-14
         479          469  -0.23794469E-06
         479          470  -0.80315889E-07
         479          487   0.43262376E-09
         479          488  -0.43865755E-14
         479          489  -0.35713606E-06
         479          490  -0.12054776E-06
         480          480   0.13484933E+05
         480          471   0.36307130E+04
         480          472   0.24834091E+03
         480          475   0.21795340E-05
         480          477   0.49505150E-01
         480          478  -0.37042339E-04
         480          479   0.33536708E+02
         480          461  -0.86950688E-05
         480          462  -0.59474313E-06
         480          465  -0.52196912E-14
         480          467  -0.11851393E-09
         480          468   0.11294945E-13
         480          469  -0.80315889E-07
         480          470  -0.32294601E-04
         480          481  -0.13050607E-04
         480          482  -0.89266212E-06
         480          485  -0.78343413E-14
         480          487  -0.17787999E-09
         480          488   0.16952814E-13
         480          489  -0.12054776E-06
         480          490  -0.48471627E-04
         481          481   0.97945219E+04
         481          486   0.79884210E+02
         481          487   0.76117799E+02
         481          490   0.36307130E+04
         481          471  -0.23456563E-04
         481          476  -0.19131143E-06
         481          477  -0.18229190E-06
         481          480  -0.86950688E-05
         481          491  -0.35206435E-04
         481          496  -0.28714324E-06
         481          497  -0.27360565E-06
         481          500  -0.13050607E-04
         482          482   0.61664984E+04
         482          484   0.63450217E+01
         482          485   0.63450217E+01
         482          487  -0.21136331E+02
         482          490   0.24834091E+03
         482          472  -0.14762871E-04
         482          480  -0.59474313E-06
         482          492  -0.22157895E-04
         482          500  -0.89266212E-06
         483          483   0.78082192E+03
         483          473  -0.18699636E-05
         483          493  -0.28066666E-05
         484          484   0.13409529E+04
         484          482   0.63443872E+01
         484          485   0.19035065E+02
         484          487  -0.65836821E+02
         484          474  -0.31658156E-05
         484          477   0.58143243E-08
         484          494  -0.47516374E-05
         484          497   0.87268382E-08
         485          485   0.19052837E+02
         485          482   0.63443872E+01
         485          484   0.19035065E+02
         485          487  -0.63477866E+02
         485          490   0.21795643E-05
         485          475  -0.42484263E-10
         485          477   0.16470995E-09
         485          480  -0.52197638E-14
         485          495  -0.63765499E-10
         485          497   0.24721653E-09
         485          500  -0.78344502E-14
         486          486   0.17074662E+04
         486          481   0.79884210E+02
         486          487   0.19543730E+04
         486          489   0.43198833E-04
         486          471  -0.19131143E-06
         486          476  -0.40891515E-05
         486          477  -0.46804608E-05
         486          491  -0.28714324E-06
         486          496  -0.61374911E-05
         486          497  -0.70249993E-05
         487          487   0.26723718E+04
         487          481   0.76117799E+02
         487          482  -0.21147957E+02
         487          484  -0.65878288E+02
         487          485  -0.63519108E+02
         487          486   0.19543478E+04
         487          488  -0.38887502E-04
         487          489  -0.12035985E+00
         487          490   0.49505150E-01
         487          471  -0.18229190E-06
         487          474   0.58149057E-08
         487          475   0.16475051E-09
         487          476  -0.46804005E-05
         487          477  -0.58937841E-05
         487          478   0.15713863E-13
         487          479   0.28826779E-09
         487          480  -0.11851393E-09
         487          491  -0.27360565E-06
         487          494   0.87277109E-08
         487          495   0.24727742E-09
         487          496  -0.70249088E-05
         487          497  -0.88461011E-05
         487          498   0.23585259E-13
         487          499   0.43266702E-09
         487          500  -0.17787999E-09
         488          488   0.66308262E-04
         488          487  -0.38896922E-04
         488          489  -0.14946245E-04
         488          490  -0.37051937E-04
         488          477   0.15715132E-13
         488          478  -0.23320539E-13
         488          479  -0.29226999E-14
         488          480   0.11296639E-13
         488          497   0.23587162E-13
         488          498  -0.35002274E-13
         488          499  -0.43867400E-14
         488          500   0.16955357E-13
         489          489   0.99356224E+02
         489          486   0.43198833E-04
         489          487  -0.12034781E+00
         489          488  -0.14942654E-04
         489          490   0.33536708E+02
         489          477   0.28823897E-09
         489          478  -0.29225903E-14
         489          479  -0.23794469E-06
         489          480  -0.80315889E-07
         489          497   0.43262376E-09
         489          498  -0.43865755E-14
         489          499  -0.35713606E-06
         489          500  -0.12054776E-06
         490          490   0.13484933E+05
         490          481   0.36307130E+04
         490          482   0.24834091E+03
         490          485   0.21795340E-05
         490          487   0.49505150E-01
         490          488  -0.37042339E-04
         490          489   0.33536708E+02
         490          471  -0.86950688E-05
         490          472  -0.59474313E-06
         490          475  -0.52196912E-14
         490          477  -0.11851393E-09
         490          478   0.11294945E-13
         490          479  -0.80315889E-07
         490          480  -0.32294601E-04
         490          491  -0.13050607E-04
         490          492  -0.89266212E-06
         490          495  -0.78343413E-14
         490          497  -0.17787999E-09
         490          498   0.16952814E-13
         490          499  -0.12054776E-06
         490          500  -0.48471627E-04
         491          491   0.97945219E+04
         491          496   0.79884210E+02
         491          497   0.76117799E+02
         491          500   0.36307130E+04
         491          481  -0.23456563E-04
         491          486  -0.19131143E-06
         491          487  -0.18229190E-06
         491          490  -0.86950688E-05
         491          501  -0.35206435E-04
         491          506  -0.28714324E-06
         491          507  -0.27360565E-06
         491          510  -0.13050607E-04
         492          492   0.61664984E+04
         492          494   0.63450217E+01
         492          495   0.63450217E+01
         492          497  -0.21136331E+02
         492          500   0.24834091E+03
         492          482  -0.14762871E-04
         492          490  -0.59474313E-06
         492          502  -0.22157895E-04
         492          510  -0.89266212E-06
         493          493   0.78082192E+03
         493          483  -0.18699636E-05
         493          503  -0.28066666E-05
         494          494   0.13409529E+04
         494          492   0.63443872E+01
         494          495   0.19035065E+02
         494          497  -0.65836821E+02
         494          484  -0.31658156E-05
         494          487   0.58143243E-08
         494          504  -0.47516374E-05
         494          507   0.87268382E-08
         495          495   0.19052837E+02
         495          492   0.63443872E+01
         495          494   0.19035065E+02
         495          497  -0.63477866E+02
         495          500   0.21795643E-05
         495          485  -0.42484263E-10
         495          487   0.16470995E-09
         495          490  -0.52197638E-14
         495          505  -0.63765499E-10
         495          507   0.24721653E-09
         495          510  -0.78344502E-14
         496          496   0.17074662E+04
         496          491   0.79884210E+02
         496          497   0.19543730E+04
         496          499   0.43198833E-04
         496          481  -0.19131143E-06
         496          486  -0.40891515E-05
         496          487  -0.46804608E-05
         496          501  -0.28714324E-06
         496          506  -0.61374911E-05
         496          507  -0.70249993E-05
         497          497   0.26723718E+04
         497          491   0.76117799E+02
         497          492  -0.21147957E+02
         497          494  -0.65878288E+02
         497          495  -0.63519108E+02
         497          496   0.19543478E+04
         497          498  -0.38887502E-04
         497          499  -0.12035985E+00
         497          500   0.49505150E-01
         497          481  -0.18229190E-06
         497          484   0.58149057E-08
         497          485   0.16475051E-09
         497          486  -0.46804005E-05
         497          487  -0.58937841E-05
         497          488   0.15713863E-13
         497          489   0.28826779E-09
         497          490  -0.11851393E-09
         497          501  -0.27360565E-06
         497          504   0.87277109E-08
         497          505   0.24727742E-09
         497          506  -0.70249088E-05
         497          507  -0.88461011E-05
         497          508   0.23585259E-13
         497          509   0.43266702E-09
         497          510  -0.17787999E-09
         498          498   0.66308262E-04
         498          497  -0.38896922E-04
         498          499  -0.14946245E-04
         498          500  -0.37051937E-04
         498          487   0.15715132E-13
         498          488  -0.23320539E-13
         498          489  -0.29226999E-14
         498          490   0.11296639E-13
         498          507   0.23587162E-13
         498          508  -0.35002274E-13
         498          509  -0.43867400E-14
         498          510   0.16955357E-13
         499          499   0.99356224E+02
         499          496   0.43198833E-04
         499          497  -0.12034781E+00
         499          498  -0.14942654E-04
         499          500   0.33536708E+02
         499          487   0.28823897E-09
         499          488  -0.29225903E-14
         499          489  -0.23794469E-06
         499          490  -0.80315889E-07
         499          507   0.43262376E-09
         499          508  -0.43865755E-14
         499          509  -0.35713606E-06
         499          510  -0.12054776E-06
         500          500   0.13484933E+05
         500          491   0.36307130E+04
         500          492   0.24834091E+03
         500          495   0.21795340E-05
         500          497   0.49505150E-01
         500          498  -0.37042339E-04
         500          499   0.33536708E+02
         500          481  -0.86950688E-05
         500          482  -0.59474313E-06
         500          485  -0.52196912E-14
         500          487  -0.11851393E-09
         500          488   0.11294945E-13
         500          489  -0.80315889E-07
         500          490  -0.32294601E-04
         500          501  -0.13050607E-04
         500          502  -0.89266212E-06
         500          505  -0.78343413E-14
         500          507  -0.17787999E-09
         500          508   0.16952814E-13
         500          509  -0.12054776E-06
         500          510  -0.48471627E-04
         501          501   0.97945219E+04
         501          506   0.79884210E+02
         501          507   0.76117799E+02
         501          510   0.36307130E+04
         501          491  -0.23456563E-04
         501          496  -0.19131143E-06
         501          497  -0.18229190E-06
         501          500  -0.86950688E-05
         501          511  -0.34866638E-04
         501          516  -0.28437186E-06
         501          517  -0.27096493E-06
         501          520  -0.12924648E-04
         502          502   0.61664984E+04
         502          504   0.63450217E+01
         502          505   0.63450217E+01
         502          507  -0.21136331E+02
         502          510   0.24834091E+03
         502          492  -0.14762871E-04
         502          500  -0.59474313E-06
         502          512  -0.21944036E-04
         502          520  -0.88404654E-06
         503          503   0.78082192E+03
         503          493  -0.18699636E-05
         503          513  -0.27795779E-05
         504          504   0.13409529E+04
         504          502   0.63443872E+01
         504          505   0.19035065E+02
         504          507  -0.65836821E+02
         504          494  -0.31658156E-05
         504          497   0.58143243E-08
         504          514  -0.47057767E-05
         504          517   0.86426107E-08
         505          505   0.19052837E+02
         505          502   0.63443872E+01
         505          504   0.19035065E+02
         505          507  -0.63477866E+02
         505          510   0.21795643E-05
         505          495  -0.42484263E-10
         505          497   0.16470995E-09
         505          500  -0.52197638E-14
         505          515  -0.63150063E-10
         505          517   0.24483050E-09
         505          520  -0.77588356E-14
         506          506   0.17074662E+04
         506          501   0.79884210E+02
         506          507   0.19543730E+04
         506          509   0.43198833E-04
         506          491  -0.19131143E-06
         506          496  -0.40891515E-05
         506          497  -0.46804608E-05
         506          511  -0.28437186E-06
         506          516  -0.60783450E-05
         506          517  -0.69573775E-05
         507          507   0.26723718E+04
         507          501   0.76117799E+02
         507          502  -0.21147957E+02
         507          504  -0.65878288E+02
         507          505  -0.63519108E+02
         507          506   0.19543478E+04
         507          508  -0.38887502E-04
         507          509  -0.12035985E+00
         507          510   0.49505150E-01
         507          491  -0.18229190E-06
         507          494   0.58149057E-08
         507          495   0.16475051E-09
         507          496  -0.46804005E-05
         507          497  -0.58937841E-05
         507          498   0.15713863E-13
         507          499   0.28826779E-09
         507          500  -0.11851393E-09
         507          511  -0.27096493E-06
         507          514   0.86434749E-08
         507          515   0.24489081E-09
         507          516  -0.69572878E-05
         507          517  -0.87610832E-05
         507          518   0.23357624E-13
         507          519   0.42849111E-09
         507          520  -0.17616317E-09
         508          508   0.66308262E-04
         508          507  -0.38896922E-04
         508          509  -0.14946245E-04
         508          510  -0.37051937E-04
         508          497   0.15715132E-13
         508          498  -0.23320539E-13
         508          499  -0.29226999E-14
         508          500   0.11296639E-13
         508          517   0.23359510E-13
         508          518  -0.34664447E-13
         508          519  -0.43444012E-14
         508          520   0.16791712E-13
         509          509   0.99356224E+02
         509          506   0.43198833E-04
         509          507  -0.12034781E+00
         509          508  -0.14942654E-04
         509          510   0.33536708E+02
         509          497   0.28823897E-09
         509          498  -0.29225903E-14
         509          499  -0.23794469E-06
         509          500  -0.80315889E-07
         509          517   0.42844827E-09
         509          518  -0.43442382E-14
         509          519  -0.35368914E-06
         509          520  -0.11938429E-06
         510          510   0.13484933E+05
         510          501   0.36307130E+04
         510          502   0.24834091E+03
         510          505   0.21795340E-05
         510          507   0.49505150E-01
         510          508  -0.37042339E-04
         510          509   0.33536708E+02
         510          491  -0.86950688E-05
         510          492  -0.59474313E-06
         510          495  -0.52196912E-14
         510          497  -0.11851393E-09
         510          498   0.11294945E-13
         510          499  -0.80315889E-07
         510          500  -0.32294601E-04
         510          511  -0.12924648E-04
         510          512  -0.88404654E-06
         510          515  -0.77587277E-14
         510          517  -0.17616317E-09
         510          518   0.16789193E-13
         510          519  -0.11938429E-06
         510          520  -0.48003801E-04
         511          511   0.97085203E+04
         511          516   0.79182782E+02
         511          517   0.75449441E+02
         511          520   0.35988332E+04
         511          501  -0.23116758E-04
         511          506  -0.18853999E-06
         511          507  -0.17965112E-06
         511          510  -0.85691072E-05
         511          521  -0.33492927E-04
         511          526  -0.27316790E-06
         511          527  -0.26028918E-06
         511          530  -0.12415430E-04
         512          512   0.61123716E+04
         512          514   0.63450217E+01
         512          515   0.63450217E+01
         512          517  -0.21136331E+02
         512          520   0.24616034E+03
         512          502  -0.14549008E-04
         512          510  -0.58612735E-06
         512          522  -0.21079463E-04
         512          530  -0.84921600E-06
         513          513   0.77396585E+03
         513          503  -0.18428743E-05
         513          523  -0.26700653E-05
         514          514   0.13293457E+04
         514          512   0.63443872E+01
         514          515   0.19035065E+02
         514          517  -0.65815503E+02
         514          504  -0.31199538E-05
         514          507   0.57300948E-08
         514          524  -0.45203738E-05
         514          527   0.83021005E-08
         515          515   0.19052682E+02
         515          512   0.63443872E+01
         515          514   0.19035065E+02
         515          517  -0.63477262E+02
         515          520   0.21604265E-05
         515          505  -0.41868813E-10
         515          507   0.16232387E-09
         515          510  -0.51441474E-14
         515          525  -0.60662014E-10
         515          527   0.23518443E-09
         515          530  -0.74531453E-14
         516          516   0.16952312E+04
         516          511   0.79182782E+02
         516          517   0.19427279E+04
         516          519   0.43198833E-04
         516          501  -0.18853999E-06
         516          506  -0.40300040E-05
         516          507  -0.46128374E-05
         516          521  -0.27316790E-06
         516          526  -0.58600671E-05
         516          527  -0.67256715E-05
         517          517   0.26617937E+04
         517          511   0.75449441E+02
         517          512  -0.21147957E+02
         517          514  -0.65856969E+02
         517          515  -0.63518504E+02
         517          516   0.19427027E+04
         517          518  -0.38829888E-04
         517          519  -0.11930294E+00
         517          520   0.49070628E-01
         517          501  -0.17965112E-06
         517          504   0.57306678E-08
         517          505   0.16236385E-09
         517          506  -0.46127780E-05
         517          507  -0.58087642E-05
         517          508   0.15486223E-13
         517          509   0.28409178E-09
         517          510  -0.11679707E-09
         517          521  -0.26028918E-06
         517          524   0.83029307E-08
         517          525   0.23524235E-09
         517          526  -0.67255833E-05
         517          527  -0.85007207E-05
         517          528   0.22437357E-13
         517          529   0.41160899E-09
         517          530  -0.16922252E-09
         518          518   0.66222759E-04
         518          517  -0.38839304E-04
         518          519  -0.14956961E-04
         518          520  -0.37010518E-04
         518          507   0.15487474E-13
         518          508  -0.22982705E-13
         518          509  -0.28803600E-14
         518          510   0.11132990E-13
         518          527   0.22439168E-13
         518          528  -0.33298703E-13
         518          529  -0.41732361E-14
         518          530   0.16130135E-13
         519          519   0.98483819E+02
         519          516   0.43198833E-04
         519          517  -0.11929101E+00
         519          518  -0.14953370E-04
         519          520   0.33242236E+02
         519          507   0.28406338E-09
         519          508  -0.28802520E-14
         519          509  -0.23449770E-06
         519          510  -0.79152388E-07
         519          527   0.41156783E-09
         519          528  -0.41730796E-14
         519          529  -0.33975414E-06
         519          530  -0.11468067E-06
         520          520   0.13366527E+05
         520          511   0.35988332E+04
         520          512   0.24616034E+03
         520          515   0.21603965E-05
         520          517   0.49070628E-01
         520          518  -0.37000927E-04
         520          519   0.33242236E+02
         520          501  -0.85691072E-05
         520          502  -0.58612735E-06
         520          505  -0.51440759E-14
         520          507  -0.11679707E-09
         520          508   0.11131320E-13
         520          509  -0.79152388E-07
         520          510  -0.31826764E-04
         520          521  -0.12415430E-04
         520          522  -0.84921600E-06
         520          525  -0.74530416E-14
         520          527  -0.16922252E-09
         520          528   0.16127716E-13
         520          529  -0.11468067E-06
         520          530  -0.46112499E-04
         521          521   0.94375150E+04
         521          526   0.76972466E+02
         521          527   0.73343332E+02
         521          530   0.34983748E+04
         521          511  -0.21743131E-04
         521          516  -0.17733671E-06
         521          517  -0.16897603E-06
         521          520  -0.80599200E-05
         521          531  -0.31421328E-04
         521          536  -0.25627196E-06
         521          537  -0.24418981E-06
         521          540  -0.11647512E-04
         522          522   0.59418088E+04
         522          524   0.63450217E+01
         522          525   0.63450217E+01
         522          527  -0.21136331E+02
         522          530   0.23928897E+03
         522          512  -0.13684487E-04
         522          520  -0.55129892E-06
         522          532  -0.19775659E-04
         522          540  -0.79669041E-06
         523          523   0.75236123E+03
         523          513  -0.17333684E-05
         523          533  -0.25049169E-05
         524          524   0.12927695E+04
         524          522   0.63443872E+01
         524          525   0.19035065E+02
         524          527  -0.65748327E+02
         524          514  -0.29345622E-05
         524          517   0.53896053E-08
         524          534  -0.42407803E-05
         524          537   0.77886002E-08
         525          525   0.19052191E+02
         525          522   0.63443872E+01
         525          524   0.19035065E+02
         525          527  -0.63475359E+02
         525          530   0.21001200E-05
         525          515  -0.39380915E-10
         525          517   0.15267838E-09
         525          520  -0.48384757E-14
         525          535  -0.56909956E-10
         525          537   0.22063783E-09
         525          540  -0.69921544E-14
         526          526   0.16566769E+04
         526          521   0.76972466E+02
         526          527   0.19060324E+04
         526          529   0.43198833E-04
         526          511  -0.17733671E-06
         526          516  -0.38117406E-05
         526          517  -0.43811481E-05
         526          531  -0.25627196E-06
         526          536  -0.58127031E-05
         526          537  -0.69398919E-05
         527          527   0.26284602E+04
         527          521   0.73343332E+02
         527          522  -0.21147957E+02
         527          524  -0.65789786E+02
         527          525  -0.63516600E+02
         527          526   0.19060070E+04
         527          528  -0.38648338E-04
         527          529  -0.11597244E+00
         527          530   0.47701378E-01
         527          511  -0.16897603E-06
         527          514   0.53901442E-08
         527          515   0.15271598E-09
         527          516  -0.43810900E-05
         527          517  -0.55484227E-05
         527          518   0.14566012E-13
         527          519   0.26721069E-09
         527          520  -0.10985684E-09
         527          531  -0.24418981E-06
         527          534   0.77893790E-08
         527          535   0.22069218E-09
         527          536  -0.69397776E-05
         527          537  -0.92353668E-05
         527          538   0.21049565E-13
         527          539   0.38615021E-09
         527          540  -0.15875579E-09
         528          528   0.65953325E-04
         528          527  -0.38657739E-04
         528          529  -0.14990729E-04
         528          530  -0.36880003E-04
         528          517   0.14567188E-13
         528          518  -0.21617043E-13
         528          519  -0.27092054E-14
         528          520   0.10471454E-13
         528          537   0.21051264E-13
         528          538  -0.31239116E-13
         528          539  -0.39151137E-14
         528          540   0.15132456E-13
         529          529   0.95734726E+02
         529          526   0.43198833E-04
         529          527  -0.11596084E+00
         529          528  -0.14987136E-04
         529          530   0.32314307E+02
         529          517   0.26718397E-09
         529          518  -0.27091038E-14
         529          519  -0.22056355E-06
         529          520  -0.74449053E-07
         529          537   0.38611160E-09
         529          538  -0.39149669E-14
         529          539  -0.31873972E-06
         529          540  -0.10758745E-06
         530          530   0.12993412E+05
         530          521   0.34983748E+04
         530          522   0.23928897E+03
         530          525   0.21000908E-05
         530          527   0.47701378E-01
         530          528  -0.36870431E-04
         530          529   0.32314307E+02
         530          511  -0.80599200E-05
         530          512  -0.55129892E-06
         530          515  -0.48384084E-14
         530          517  -0.10985684E-09
         530          518   0.10469883E-13
         530          519  -0.74449053E-07
         530          520  -0.29935577E-04
         530          531  -0.11647512E-04
         530          532  -0.79669041E-06
         530          535  -0.69920572E-14
         530          537  -0.15875579E-09
         530          538   0.15130187E-13
         530          539  -0.10758745E-06
         530          540  -0.43260356E-04
         531          531   0.91387806E+04
         531          536   0.74535992E+02
         531          537   0.71021728E+02
         531          540   0.33876375E+04
         531          521  -0.19671531E-04
         531          526  -0.16044076E-06
         531          527  -0.15287666E-06
         531          530  -0.72920027E-05
         531          541  -0.29444694E-04
         531          546  -0.24015056E-06
         531          547  -0.22882847E-06
         531          550  -0.10914798E-04
         532          532   0.57537941E+04
         532          534   0.63450217E+01
         532          535   0.63450217E+01
         532          537  -0.21136331E+02
         532          540   0.23171454E+03
         532          522  -0.12380683E-04
         532          530  -0.49877333E-06
         532          542  -0.18531624E-04
         532          550  -0.74657270E-06
         533          533   0.72854605E+03
         533          523  -0.15682199E-05
         533          543  -0.23473391E-05
         534          534   0.12524508E+04
         534          532   0.63443872E+01
         534          535   0.19035065E+02
         534          537  -0.65674278E+02
         534          524  -0.26549687E-05
         534          527   0.48761050E-08
         534          544  -0.39740039E-05
         534          547   0.72986397E-08
         535          535   0.19051650E+02
         535          532   0.63443872E+01
         535          534   0.19035065E+02
         535          537  -0.63473262E+02
         535          540   0.20336429E-05
         535          525  -0.35628857E-10
         535          527   0.13813178E-09
         535          530  -0.43774848E-14
         535          545  -0.53329900E-10
         535          547   0.20675808E-09
         535          550  -0.65522963E-14
         536          536   0.16141777E+04
         536          531   0.74535992E+02
         536          537   0.18655822E+04
         536          539   0.43198833E-04
         536          521  -0.16044076E-06
         536          526  -0.37643767E-05
         536          527  -0.45953685E-05
         536          541  -0.24015056E-06
         536          546  -0.66630675E-05
         536          547  -0.89354956E-05
         537          537   0.25917161E+04
         537          531   0.71021728E+02
         537          532  -0.21147957E+02
         537          534  -0.65715730E+02
         537          535  -0.63514502E+02
         537          536   0.18655566E+04
         537          538  -0.38448212E-04
         537          539  -0.11230116E+00
         537          540   0.46192027E-01
         537          521  -0.15287666E-06
         537          524   0.48765926E-08
         537          525   0.13816581E-09
         537          526  -0.45952844E-05
         537          527  -0.62830688E-05
         537          528   0.13178220E-13
         537          529   0.24175191E-09
         537          530  -0.99390118E-10
         537          541  -0.22882847E-06
         537          544   0.72993696E-08
         537          545   0.20680901E-09
         537          546  -0.89352669E-05
         537          547  -0.13518742E-04
         537          548   0.19725392E-13
         537          549   0.36185851E-09
         537          550  -0.14876888E-09
         538          538   0.65656323E-04
         538          537  -0.38457597E-04
         538          539  -0.15027951E-04
         538          540  -0.36736133E-04
         538          527   0.13179284E-13
         538          528  -0.19557457E-13
         538          529  -0.24510830E-14
         538          530   0.94737750E-14
         538          547   0.19726984E-13
         538          548  -0.29273945E-13
         538          549  -0.36688242E-14
         538          550   0.14180513E-13
         539          539   0.92704347E+02
         539          536   0.43198833E-04
         539          537  -0.11228993E+00
         539          538  -0.15024357E-04
         539          540   0.31291433E+02
         539          527   0.24172774E-09
         539          528  -0.24509911E-14
         539          529  -0.19954912E-06
         539          530  -0.67355841E-07
         539          547   0.36182233E-09
         539          548  -0.36686866E-14
         539          549  -0.29868864E-06
         539          550  -0.10081941E-06
         540          540   0.12582119E+05
         540          531   0.33876375E+04
         540          532   0.23171454E+03
         540          535   0.20336147E-05
         540          537   0.46192027E-01
         540          538  -0.36726582E-04
         540          539   0.31291433E+02
         540          521  -0.72920027E-05
         540          522  -0.49877333E-06
         540          525  -0.43774239E-14
         540          527  -0.99390118E-10
         540          528   0.94723541E-14
         540          529  -0.67355841E-07
         540          530  -0.27083434E-04
         540          541  -0.10914798E-04
         540          542  -0.74657270E-06
         540          545  -0.65522052E-14
         540          547  -0.14876888E-09
         540          548   0.14178386E-13
         540          549  -0.10081941E-06
         540          550  -0.40538960E-04
         541          541   0.88530187E+04
         541          546   0.72205322E+02
         541          547   0.68800938E+02
         541          550   0.32817089E+04
         541          531  -0.17694898E-04
         541          536  -0.14431937E-06
         541          537  -0.13751531E-06
         541          540  -0.65592881E-05
         541          551  -0.27735008E-04
         541          556  -0.22620638E-06
         541          557  -0.21554170E-06
         541          560  -0.10281037E-04
         542          542   0.55739440E+04
         542          544   0.63450217E+01
         542          545   0.63450217E+01
         542          547  -0.21136331E+02
         542          550   0.22446902E+03
         542          532  -0.11136648E-04
         542          540  -0.44865563E-06
         542          552  -0.17455598E-04
         542          560  -0.70322346E-06
         543          543   0.70576503E+03
         543          533  -0.14106421E-05
         543          553  -0.22110424E-05
         544          544   0.12138829E+04
         544          542   0.63443872E+01
         544          545   0.19035065E+02
         544          547  -0.65603445E+02
         544          534  -0.23881923E-05
         544          537   0.43861445E-08
         544          554  -0.37432560E-05
         544          557   0.68748491E-08
         545          545   0.19051132E+02
         545          542   0.63443872E+01
         545          544   0.19035065E+02
         545          547  -0.63471255E+02
         545          550   0.19700526E-05
         545          535  -0.32048800E-10
         545          537   0.12425203E-09
         545          540  -0.39376267E-14
         545          555  -0.50233335E-10
         545          557   0.19475282E-09
         545          560  -0.61718416E-14
         546          546   0.15735240E+04
         546          541   0.72205322E+02
         546          547   0.18268886E+04
         546          549   0.43198833E-04
         546          531  -0.14431937E-06
         546          536  -0.46147410E-05
         546          537  -0.65909722E-05
         546          551  -0.22620638E-06
         546          556  -0.88990741E-05
         546          557  -0.13662711E-04
         547          547   0.25565675E+04
         547          541   0.68800938E+02
         547          542  -0.21147957E+02
         547          544  -0.65644889E+02
         547          545  -0.63512495E+02
         547          546   0.18268628E+04
         547          548  -0.38256776E-04
         547          549  -0.10878931E+00
         547          550   0.44748219E-01
         547          531  -0.13751531E-06
         547          534   0.43865831E-08
         547          535   0.12428264E-09
         547          536  -0.65907737E-05
         547          537  -0.10566444E-04
         547          538   0.11854047E-13
         547          539   0.21746021E-09
         547          540  -0.89403207E-10
         547          551  -0.21554170E-06
         547          554   0.68755366E-08
         547          555   0.19480078E-09
         547          556  -0.13662233E-04
         547          557  -0.23225883E-04
         547          558   0.18580050E-13
         547          559   0.34084744E-09
         547          560  -0.14013071E-09
         548          548   0.65372218E-04
         548          547  -0.38266146E-04
         548          549  -0.15063557E-04
         548          550  -0.36598510E-04
         548          537   0.11855004E-13
         548          538  -0.17592286E-13
         548          539  -0.22047934E-14
         548          540   0.85218317E-14
         548          557   0.18581550E-13
         548          558  -0.27574173E-13
         548          559  -0.34557963E-14
         548          560   0.13357131E-13
         549          549   0.89805562E+02
         549          546   0.43198833E-04
         549          547  -0.10877843E+00
         549          548  -0.15059962E-04
         549          550   0.30312976E+02
         549          537   0.21743847E-09
         549          538  -0.22047108E-14
         549          539  -0.17949804E-06
         549          540  -0.60587796E-07
         549          557   0.34081336E-09
         549          558  -0.34556668E-14
         549          559  -0.28134548E-06
         549          560  -0.94965397E-07
         550          550   0.12188687E+05
         550          541   0.32817089E+04
         550          542   0.22446902E+03
         550          545   0.19700253E-05
         550          547   0.44748219E-01
         550          548  -0.36588980E-04
         550          549   0.30312976E+02
         550          531  -0.65592881E-05
         550          532  -0.44865563E-06
         550          535  -0.39375719E-14
         550          537  -0.89403207E-10
         550          538   0.85205536E-14
         550          539  -0.60587796E-07
         550          540  -0.24362038E-04
         550          551  -0.10281037E-04
         550          552  -0.70322346E-06
         550          555  -0.61717558E-14
         550          557  -0.14013071E-09
         550          558   0.13355128E-13
         550          559  -0.94965397E-07
         550          560  -0.38185093E-04
         551          551   0.85948552E+04
         551          556   0.70099743E+02
         551          557   0.66794629E+02
         551          560   0.31860108E+04
         551          541  -0.15985211E-04
         551          546  -0.13037519E-06
         551          547  -0.12422854E-06
         551          550  -0.59255277E-05
         551          561  -0.26313584E-04
         551          566  -0.21461326E-06
         551          567  -0.20449515E-06
         551          570  -0.97541326E-05
         552          552   0.54114635E+04
         552          554   0.63450217E+01
         552          555   0.63450217E+01
         552          557  -0.21136331E+02
         552          560   0.21792326E+03
         552          542  -0.10060622E-04
         552          550  -0.40530638E-06
         552          562  -0.16560996E-04
         552          570  -0.66718314E-06
         553          553   0.68518417E+03
         553          543  -0.12743454E-05
         553          563  -0.20977261E-05
         554          554   0.11790399E+04
         554          552   0.63443872E+01
         554          555   0.19035065E+02
         554          557  -0.65539452E+02
         554          544  -0.21574445E-05
         554          547   0.39623539E-08
         554          564  -0.35514135E-05
         554          567   0.65225120E-08
         555          555   0.19050665E+02
         555          552   0.63443872E+01
         555          554   0.19035065E+02
         555          557  -0.63469442E+02
         555          560   0.19126038E-05
         555          545  -0.28952236E-10
         555          547   0.11224677E-09
         555          550  -0.35571720E-14
         555          565  -0.47658868E-10
         555          567   0.18477170E-09
         555          570  -0.58555337E-14
         556          556   0.15367966E+04
         556          551   0.70099743E+02
         556          557   0.17919319E+04
         556          559   0.43198833E-04
         556          541  -0.13037519E-06
         556          546  -0.68507477E-05
         556          547  -0.11318187E-04
         556          561  -0.21461326E-06
         556          566  -0.12607606E-04
         556          567  -0.21292133E-04
         557          557   0.25248136E+04
         557          551   0.66794629E+02
         557          552  -0.21147957E+02
         557          554  -0.65580890E+02
         557          555  -0.63510682E+02
         557          556   0.17919060E+04
         557          558  -0.38083829E-04
         557          559  -0.10561663E+00
         557          560   0.43443852E-01
         557          541  -0.12422854E-06
         557          544   0.39627501E-08
         557          545   0.11227441E-09
         557          546  -0.11317740E-04
         557          547  -0.20273585E-04
         557          548   0.10708706E-13
         557          549   0.19644914E-09
         557          550  -0.80765042E-10
         557          561  -0.20449515E-06
         557          564   0.65231642E-08
         557          565   0.18481721E-09
         557          566  -0.21291263E-04
         557          567  -0.38694829E-04
         557          568   0.17627820E-13
         557          569   0.32337895E-09
         557          570  -0.13294899E-09
         558          558   0.65115552E-04
         558          557  -0.38093184E-04
         558          559  -0.15095724E-04
         558          560  -0.36474179E-04
         558          547   0.10709570E-13
         558          548  -0.15892514E-13
         558          549  -0.19917656E-14
         558          550   0.76984498E-14
         558          567   0.17629243E-13
         558          568  -0.26160992E-13
         558          569  -0.32786862E-14
         558          570   0.12672576E-13
         559          559   0.87186738E+02
         559          556   0.43198833E-04
         559          557  -0.10560607E+00
         559          558  -0.15092128E-04
         559          560   0.29429018E+02
         559          547   0.19642950E-09
         559          548  -0.19916909E-14
         559          549  -0.16215489E-06
         559          550  -0.54733785E-07
         559          567   0.32334662E-09
         559          568  -0.32785633E-14
         559          569  -0.26692648E-06
         559          570  -0.90098405E-07
         560          560   0.11833252E+05
         560          551   0.31860108E+04
         560          552   0.21792326E+03
         560          555   0.19125772E-05
         560          557   0.43443852E-01
         560          558  -0.36464668E-04
         560          559   0.29429018E+02
         560          541  -0.59255277E-05
         560          542  -0.40530638E-06
         560          545  -0.35571225E-14
         560          547  -0.80765042E-10
         560          548   0.76972952E-14
         560          549  -0.54733785E-07
         560          550  -0.22008170E-04
         560          561  -0.97541326E-05
         560          562  -0.66718314E-06
         560          565  -0.58554523E-14
         560          567  -0.13294899E-09
         560          568   0.12670675E-13
         560          569  -0.90098405E-07
         560          570  -0.36228100E-04
         561          561   0.83686309E+04
         561          566   0.68254660E+02
         561          567   0.65036534E+02
         561          570   0.31021521E+04
         561          551  -0.14563788E-04
         561          556  -0.11878207E-06
         561          557  -0.11318200E-06
         561          560  -0.53986229E-05
         561          571  -0.25153378E-04
         561          576  -0.20515064E-06
         561          577  -0.19547865E-06
         561          580  -0.93240581E-05
         562          562   0.52690845E+04
         562          564   0.63450217E+01
         562          565   0.63450217E+01
         562          567  -0.21136331E+02
         562          570   0.21218733E+03
         562          552  -0.91660196E-05
         562          560  -0.36926607E-06
         562          572  -0.15830796E-04
         562          580  -0.63776603E-06
         563          563   0.66714950E+03
         563          553  -0.11610291E-05
         563          573  -0.20052342E-05
         564          564   0.11485075E+04
         564          562   0.63443872E+01
         564          565   0.19035065E+02
         564          567  -0.65483376E+02
         564          554  -0.19656020E-05
         564          557   0.36100168E-08
         564          574  -0.33948263E-05
         564          577   0.62349245E-08
         565          565   0.19050255E+02
         565          562   0.63443872E+01
         565          564   0.19035065E+02
         565          567  -0.63467854E+02
         565          570   0.18622623E-05
         565          555  -0.26377769E-10
         565          557   0.10226565E-09
         565          560  -0.32408641E-14
         565          575  -0.45557516E-10
         565          577   0.17662484E-09
         565          580  -0.55973543E-14
         566          566   0.15046130E+04
         566          561   0.68254660E+02
         566          567   0.17613000E+04
         566          569   0.43198833E-04
         566          551  -0.11878207E-06
         566          556  -0.10559279E-04
         566          557  -0.18947609E-04
         566          571  -0.20515064E-06
         566          576  -0.17548422E-04
         566          577  -0.31347289E-04
         567          567   0.24969882E+04
         567          561   0.65036534E+02
         567          562  -0.21147957E+02
         567          564  -0.65524809E+02
         567          565  -0.63509093E+02
         567          566   0.17612739E+04
         567          568  -0.37932279E-04
         567          569  -0.10283646E+00
         567          570   0.42300856E-01
         567          551  -0.11318200E-06
         567          554   0.36103778E-08
         567          555   0.10229084E-09
         567          556  -0.18946770E-04
         567          557  -0.35742531E-04
         567          558   0.97564750E-14
         567          559   0.17898065E-09
         567          560  -0.73583320E-10
         567          571  -0.19547865E-06
         567          574   0.62355480E-08
         567          575   0.17666834E-09
         567          576  -0.31345908E-04
         567          577  -0.58976632E-04
         567          578   0.16850582E-13
         567          579   0.30912069E-09
         567          580  -0.12708707E-09
         568          568   0.64890639E-04
         568          567  -0.37941621E-04
         568          569  -0.15123912E-04
         568          570  -0.36365230E-04
         568          557   0.97572625E-14
         568          558  -0.14479333E-13
         568          559  -0.18146555E-14
         568          560   0.70138946E-14
         568          577   0.16851943E-13
         568          578  -0.25007515E-13
         568          579  -0.31341240E-14
         568          580   0.12113823E-13
         569          569   0.84891905E+02
         569          566   0.43198833E-04
         569          567  -0.10282617E+00
         569          568  -0.15120314E-04
         569          570   0.28654420E+02
         569          557   0.17896276E-09
         569          558  -0.18145875E-14
         569          559  -0.14773588E-06
         569          560  -0.49866793E-07
         569          577   0.30908978E-09
         569          578  -0.31340064E-14
         569          579  -0.25515729E-06
         569          580  -0.86125830E-07
         570          570   0.11521790E+05
         570          561   0.31021521E+04
         570          562   0.21218733E+03
         570          565   0.18622364E-05
         570          567   0.42300856E-01
         570          568  -0.36355735E-04
         570          569   0.28654420E+02
         570          551  -0.53986229E-05
         570          552  -0.36926607E-06
         570          555  -0.32408190E-14
         570          557  -0.73583320E-10
         570          558   0.70128427E-14
         570          559  -0.49866793E-07
         570          560  -0.20051178E-04
         570          571  -0.93240581E-05
         570          572  -0.63776603E-06
         570          575  -0.55972765E-14
         570          577  -0.12708707E-09
         570          578   0.12112006E-13
         570          579  -0.86125830E-07
         570          580  -0.34630748E-04
         571          571   0.81741040E+04
         571          576   0.66668102E+02
         571          577   0.63524775E+02
         571          580   0.30300433E+04
         571          561  -0.13403582E-04
         571          566  -0.10931945E-06
         571          567  -0.10416549E-06
         571          570  -0.49685484E-05
         571          581  -0.24214771E-04
         571          586  -0.19749537E-06
         571          587  -0.18818430E-06
         571          590  -0.89761276E-05
         572          572   0.51466550E+04
         572          574   0.63450217E+01
         572          575   0.63450217E+01
         572          577  -0.21136331E+02
         572          580   0.20725508E+03
         572          562  -0.84358202E-05
         572          570  -0.33984895E-06
         572          582  -0.15240065E-04
         572          590  -0.61396756E-06
         573          573   0.65164176E+03
         573          563  -0.10685372E-05
         573          583  -0.19304082E-05
         574          574   0.11222532E+04
         574          572   0.63443872E+01
         574          575   0.19035065E+02
         574          577  -0.65435158E+02
         574          564  -0.18090148E-05
         574          567   0.33224293E-08
         574          584  -0.32681472E-05
         574          587   0.60022661E-08
         575          575   0.19049903E+02
         575          572   0.63443872E+01
         575          574   0.19035065E+02
         575          577  -0.63466488E+02
         575          580   0.18189745E-05
         575          565  -0.24276417E-10
         575          567   0.94118787E-10
         575          570  -0.29826847E-14
         575          585  -0.43857522E-10
         575          587   0.17003402E-09
         575          590  -0.53884871E-14
         576          576   0.14769388E+04
         576          571   0.66668102E+02
         576          577   0.17349601E+04
         576          579   0.43198833E-04
         576          561  -0.10931945E-06
         576          566  -0.15500095E-04
         576          567  -0.29002765E-04
         576          581  -0.19749537E-06
         576          586  -0.23316169E-04
         576          587  -0.43023341E-04
         577          577   0.24730616E+04
         577          571   0.63524775E+02
         577          572  -0.21147957E+02
         577          574  -0.65476585E+02
         577          575  -0.63507727E+02
         577          576   0.17349339E+04
         577          578  -0.37801962E-04
         577          579  -0.10044583E+00
         577          580   0.41318012E-01
         577          561  -0.10416549E-06
         577          564   0.33227616E-08
         577          565   0.94141969E-10
         577          566  -0.29001414E-04
         577          567  -0.56024334E-04
         577          568   0.89792377E-14
         577          569   0.16472238E-09
         577          570  -0.67721397E-10
         577          581  -0.18818430E-06
         577          584   0.60028663E-08
         577          585   0.17007590E-09
         577          586  -0.43021369E-04
         577          587  -0.82467473E-04
         577          588   0.16221797E-13
         577          589   0.29758574E-09
         577          590  -0.12234477E-09
         578          578   0.64697240E-04
         578          577  -0.37811295E-04
         578          579  -0.15148150E-04
         578          580  -0.36271546E-04
         578          567   0.89799625E-14
         578          568  -0.13325855E-13
         578          569  -0.16700932E-14
         578          570   0.64551415E-14
         578          587   0.16223106E-13
         578          588  -0.24074350E-13
         578          589  -0.30171730E-14
         578          590   0.11661791E-13
         579          579   0.82918613E+02
         579          576   0.43198833E-04
         579          577  -0.10043579E+00
         579          578  -0.15144552E-04
         579          580   0.27988354E+02
         579          567   0.16470591E-09
         579          568  -0.16700306E-14
         579          569  -0.13596669E-06
         579          570  -0.45894217E-07
         579          587   0.29755598E-09
         579          588  -0.30170599E-14
         579          589  -0.24563600E-06
         579          590  -0.82912014E-07
         580          580   0.11253969E+05
         580          571   0.30300433E+04
         580          572   0.20725508E+03
         580          575   0.18189492E-05
         580          577   0.41318012E-01
         580          578  -0.36262065E-04
         580          579   0.27988354E+02
         580          561  -0.49685484E-05
         580          562  -0.33984895E-06
         580          565  -0.29826433E-14
         580          567  -0.67721397E-10
         580          568   0.64541734E-14
         580          569  -0.45894217E-07
         580          570  -0.18453826E-04
         580          581  -0.89761276E-05
         580          582  -0.61396756E-06
         580          585  -0.53884122E-14
         580          587  -0.12234477E-09
         580          588   0.11660042E-13
         580          589  -0.82912014E-07
         580          590  -0.33338490E-04
         581          581   0.80089945E+04
         581          586   0.65321471E+02
         581          587   0.62241632E+02
         581          590   0.29688392E+04
         581          571  -0.12464975E-04
         581          576  -0.10166418E-06
         581          577  -0.96871140E-07
         581          580  -0.46206178E-05
         581          591  -0.23458652E-04
         581          596  -0.19132847E-06
         581          597  -0.18230814E-06
         581          600  -0.86958432E-05
         582          582   0.50427400E+04
         582          584   0.63450217E+01
         582          585   0.63450217E+01
         582          587  -0.21136331E+02
         582          590   0.20306871E+03
         582          572  -0.78450885E-05
         582          580  -0.31605048E-06
         582          592  -0.14764186E-04
         582          600  -0.59479610E-06
         583          583   0.63847919E+03
         583          573  -0.99371120E-06
         583          593  -0.18701302E-05
         584          584   0.10999692E+04
         584          582   0.63443872E+01
         584          585   0.19035065E+02
         584          587  -0.65394231E+02
         584          574  -0.16823356E-05
         584          577   0.30897709E-08
         584          594  -0.31660976E-05
         584          597   0.58148422E-08
         585          585   0.19049603E+02
         585          582   0.63443872E+01
         585          584   0.19035065E+02
         585          587  -0.63465328E+02
         585          590   0.17822328E-05
         585          575  -0.22576422E-10
         585          577   0.87527969E-10
         585          580  -0.27738175E-14
         585          595  -0.42488047E-10
         585          597   0.16472462E-09
         585          600  -0.52202287E-14
         586          586   0.14534496E+04
         586          581   0.65321471E+02
         586          587   0.17126034E+04
         586          589   0.43198833E-04
         586          571  -0.10166418E-06
         586          576  -0.21267843E-04
         586          577  -0.40678818E-04
         586          591  -0.19132847E-06
         586          596  -0.29478432E-04
         586          597  -0.55461249E-04
         587          587   0.24527532E+04
         587          581   0.62241632E+02
         587          582  -0.21147957E+02
         587          584  -0.65435654E+02
         587          585  -0.63506567E+02
         587          586   0.17125771E+04
         587          588  -0.37691353E-04
         587          589  -0.98416733E-01
         587          590   0.40483799E-01
         587          571  -0.96871140E-07
         587          574   0.30900799E-08
         587          575   0.87549528E-10
         587          576  -0.40676876E-04
         587          577  -0.79515175E-04
         587          578   0.83504522E-14
         587          579   0.15318744E-09
         587          580  -0.62979099E-10
         587          591  -0.18230814E-06
         587          594   0.58154236E-08
         587          595   0.16476519E-09
         587          596  -0.55458650E-04
         587          597  -0.10745505E-03
         587          598   0.15715263E-13
         587          599   0.28829347E-09
         587          600  -0.11852449E-09
         588          588   0.64533088E-04
         588          587  -0.37700677E-04
         588          589  -0.15168723E-04
         588          590  -0.36192030E-04
         588          577   0.83511263E-14
         588          578  -0.12392691E-13
         588          579  -0.15531423E-14
         588          580   0.60031100E-14
         588          597   0.15716531E-13
         588          598  -0.23322616E-13
         588          599  -0.29229602E-14
         588          600   0.11297646E-13
         589          589   0.81243733E+02
         589          586   0.43198833E-04
         589          587  -0.98406891E-01
         589          588  -0.15165124E-04
         589          590   0.27423015E+02
         589          577   0.15317212E-09
         589          578  -0.15530841E-14
         589          579  -0.12644541E-06
         589          580  -0.42680402E-07
         589          597   0.28826464E-09
         589          598  -0.29228506E-14
         589          599  -0.23796589E-06
         589          600  -0.80323042E-07
         590          590   0.11026649E+05
         590          581   0.29688392E+04
         590          582   0.20306871E+03
         590          585   0.17822081E-05
         590          587   0.40483799E-01
         590          588  -0.36182561E-04
         590          589   0.27423015E+02
         590          571  -0.46206178E-05
         590          572  -0.31605048E-06
         590          575  -0.27737789E-14
         590          577  -0.62979099E-10
         590          578   0.60022096E-14
         590          579  -0.42680402E-07
         590          580  -0.17161568E-04
         590          591  -0.86958432E-05
         590          592  -0.59479610E-06
         590          595  -0.52201561E-14
         590          597  -0.11852449E-09
         590          598   0.11295951E-13
         590          599  -0.80323042E-07
         590          600  -0.32297478E-04
         591          591   0.78702013E+04
         591          596   0.64189475E+02
         591          597   0.61163005E+02
         591          600   0.29173902E+04
         591          581  -0.11708856E-04
         591          586  -0.95497281E-07
         591          587  -0.90994985E-07
         591          590  -0.43403335E-05
         591          601  -0.22850688E-04
         591          606  -0.18636993E-06
         591          607  -0.17758337E-06
         591          610  -0.84704783E-05
         592          592   0.49553876E+04
         592          594   0.63450217E+01
         592          595   0.63450217E+01
         592          597  -0.21136331E+02
         592          600   0.19954960E+03
         592          582  -0.73692093E-05
         592          590  -0.29687902E-06
         592          602  -0.14381551E-04
         592          610  -0.57938113E-06
         593          593   0.62741456E+03
         593          583  -0.93343318E-06
         593          603  -0.18216631E-05
         594          594   0.10812369E+04
         594          592   0.63443872E+01
         594          595   0.19035065E+02
         594          597  -0.65359828E+02
         594          584  -0.15802860E-05
         594          587   0.29023470E-08
         594          604  -0.30840437E-05
         594          607   0.56641424E-08
         595          595   0.19049352E+02
         595          592   0.63443872E+01
         595          594   0.19035065E+02
         595          597  -0.63464354E+02
         595          600   0.17513473E-05
         595          585  -0.21206948E-10
         595          587   0.82218567E-10
         595          590  -0.26055591E-14
         595          605  -0.41386910E-10
         595          607   0.16045555E-09
         595          610  -0.50849392E-14
         596          596   0.14337043E+04
         596          591   0.64189475E+02
         596          597   0.16938101E+04
         596          599   0.43198833E-04
         596          581  -0.95497281E-07
         596          586  -0.27430106E-04
         596          587  -0.53116726E-04
         596          601  -0.18636993E-06
         596          606  -0.35659341E-04
         596          607  -0.67914355E-04
         597          597   0.24356818E+04
         597          591   0.61163005E+02
         597          592  -0.21147957E+02
         597          594  -0.65401247E+02
         597          595  -0.63505592E+02
         597          596   0.16937837E+04
         597          598  -0.37598374E-04
         597          599  -0.96711044E-01
         597          600   0.39782549E-01
         597          581  -0.90994985E-07
         597          584   0.29026372E-08
         597          585   0.82238818E-10
         597          586  -0.53114157E-04
         597          587  -0.10450275E-03
         597          588   0.78439180E-14
         597          589   0.14389516E-09
         597          590  -0.59158818E-10
         597          601  -0.17758337E-06
         597          604   0.56647088E-08
         597          605   0.16049507E-09
         597          606  -0.67911129E-04
         597          607  -0.13245113E-03
         597          608   0.15307980E-13
         597          609   0.28082194E-09
         597          610  -0.11545276E-09
         598          598   0.64395100E-04
         598          597  -0.37607690E-04
         598          599  -0.15186017E-04
         598          600  -0.36125187E-04
         598          587   0.78445512E-14
         598          588  -0.11640956E-13
         598          589  -0.14589295E-14
         598          590   0.56389643E-14
         598          607   0.15309216E-13
         598          608  -0.22718178E-13
         598          609  -0.28472076E-14
         598          610   0.11004851E-13
         599          599   0.79835807E+02
         599          596   0.43198833E-04
         599          597  -0.96701372E-01
         599          598  -0.15182417E-04
         599          600   0.26947784E+02
         599          587   0.14388078E-09
         599          588  -0.14588748E-14
         599          589  -0.11877529E-06
         599          590  -0.40091430E-07
         599          607   0.28079386E-09
         599          608  -0.28471008E-14
         599          609  -0.23179867E-06
         599          610  -0.78241359E-07
         600          600   0.10835560E+05
         600          591   0.29173902E+04
         600          592   0.19954960E+03
         600          595   0.17513230E-05
         600          597   0.39782549E-01
         600          598  -0.36115728E-04
         600          599   0.26947784E+02
         600          581  -0.43403335E-05
         600          582  -0.29687902E-06
         600          585  -0.26055229E-14
         600          587  -0.59158818E-10
         600          588   0.56381186E-14
         600          589  -0.40091430E-07
         600          590  -0.16120556E-04
         600          601  -0.84704783E-05
         600          602  -0.57938113E-06
         600          605  -0.50848685E-14
         600          607  -0.11545276E-09
         600          608   0.11003201E-13
         600          609  -0.78241359E-07
         600          610  -0.31460444E-04
         601          601   0.77544085E+04
         601          606   0.63245071E+02
         601          607   0.60263125E+02
         601          610   0.28744672E+04
         601          591  -0.11100892E-04
         601          596  -0.90538736E-07
         601          597  -0.86270216E-07
         601          600  -0.41149686E-05
         601          611  -0.22362182E-04
         601          616  -0.18238568E-06
         601          617  -0.17378696E-06
         601          620  -0.82893950E-05
         602          602   0.48825111E+04
         602          604   0.63450217E+01
         602          605   0.63450217E+01
         602          607  -0.21136331E+02
         602          610   0.19661367E+03
         602          592  -0.69865749E-05
         602          600  -0.28146405E-06
         602          612  -0.14074100E-04
         602          620  -0.56699502E-06
         603          603   0.61818352E+03
         603          593  -0.88496615E-06
         603          613  -0.17827193E-05
         604          604   0.10656090E+04
         604          602   0.63443872E+01
         604          605   0.19035065E+02
         604          607  -0.65331125E+02
         604          594  -0.14982322E-05
         604          597   0.27516472E-08
         604          614  -0.30181125E-05
         604          617   0.55430534E-08
         605          605   0.19049142E+02
         605          602   0.63443872E+01
         605          604   0.19035065E+02
         605          607  -0.63463541E+02
         605          610   0.17255801E-05
         605          595  -0.20105811E-10
         605          597   0.77949499E-10
         605          600  -0.24702696E-14
         605          615  -0.40502134E-10
         605          617   0.15702530E-09
         605          620  -0.49762325E-14
         606          606   0.14172312E+04
         606          601   0.63245071E+02
         606          607   0.16781312E+04
         606          609   0.43198833E-04
         606          591  -0.90538736E-07
         606          596  -0.33611015E-04
         606          597  -0.65569832E-04
         606          611  -0.18238568E-06
         606          616  -0.41575380E-04
         606          617  -0.79819879E-04
         607          607   0.24214394E+04
         607          601   0.60263125E+02
         607          602  -0.21147957E+02
         607          604  -0.65372542E+02
         607          605  -0.63504779E+02
         607          606   0.16781047E+04
         607          608  -0.37520803E-04
         607          609  -0.95288017E-01
         607          610   0.39197507E-01
         607          591  -0.86270216E-07
         607          594   0.27519224E-08
         607          595   0.77968698E-10
         607          596  -0.65566636E-04
         607          597  -0.12949883E-03
         607          598   0.74366351E-14
         607          599   0.13642364E-09
         607          600  -0.56087091E-10
         607          611  -0.17378696E-06
         607          614   0.55436077E-08
         607          615   0.15706398E-09
         607          616  -0.79816054E-04
         607          617  -0.15633438E-03
         607          618   0.14980723E-13
         607          619   0.27481848E-09
         607          620  -0.11298459E-09
         608          608   0.64279979E-04
         608          607  -0.37530113E-04
         608          609  -0.15200445E-04
         608          610  -0.36069422E-04
         608          597   0.74372354E-14
         608          598  -0.11036518E-13
         608          599  -0.13831769E-14
         608          600   0.53461701E-14
         608          617   0.14981932E-13
         608          618  -0.22232505E-13
         608          619  -0.27863395E-14
         608          620   0.10769588E-13
         609          609   0.78661199E+02
         609          606   0.43198833E-04
         609          607  -0.95278487E-01
         609          608  -0.15196844E-04
         609          610   0.26551306E+02
         609          597   0.13641000E-09
         609          598  -0.13831250E-14
         609          599  -0.11260807E-06
         609          600  -0.38009746E-07
         609          617   0.27479100E-09
         609          618  -0.27862350E-14
         609          619  -0.22684324E-06
         609          620  -0.76568701E-07
         610          610   0.10676139E+05
         610          601   0.28744672E+04
         610          602   0.19661367E+03
         610          605   0.17255561E-05
         610          607   0.39197507E-01
         610          608  -0.36059971E-04
         610          609   0.26551306E+02
         610          591  -0.41149686E-05
         610          592  -0.28146405E-06
         610          595  -0.24702353E-14
         610          597  -0.56087091E-10
         610          598   0.53453683E-14
         610          599  -0.38009746E-07
         610          600  -0.15283521E-04
         610          611  -0.82893950E-05
         610          612  -0.56699502E-06
         610          615  -0.49761633E-14
         610          617  -0.11298459E-09
         610          618   0.10767973E-13
         610          619  -0.76568701E-07
         610          620  -0.30787877E-04
         611          611   0.76583920E+04
         611          616   0.62461961E+02
         611          617   0.59516936E+02
         611          620   0.28388750E+04
         611          601  -0.10612386E-04
         611          606  -0.86554488E-07
         611          607  -0.82473808E-07
         611          610  -0.39338853E-05
         611          621  -0.21969690E-04
         611          626  -0.17918452E-06
         611          627  -0.17073672E-06
         611          630  -0.81439028E-05
         612          612   0.48220811E+04
         612          614   0.63450217E+01
         612          615   0.63450217E+01
         612          617  -0.21136331E+02
         612          620   0.19417916E+03
         612          602  -0.66791236E-05
         612          610  -0.26907794E-06
         612          622  -0.13827077E-04
         612          630  -0.55704335E-06
         613          613   0.61052906E+03
         613          603  -0.84602232E-06
         613          623  -0.17514297E-05
         614          614   0.10526501E+04
         614          612   0.63443872E+01
         614          615   0.19035065E+02
         614          617  -0.65307325E+02
         614          604  -0.14323009E-05
         614          607   0.26305582E-08
         614          624  -0.29651398E-05
         614          627   0.54457639E-08
         615          615   0.19048968E+02
         615          612   0.63443872E+01
         615          614   0.19035065E+02
         615          617  -0.63462866E+02
         615          620   0.17042136E-05
         615          605  -0.19221034E-10
         615          607   0.74519253E-10
         615          610  -0.23615629E-14
         615          625  -0.39791256E-10
         615          627   0.15426926E-09
         615          630  -0.48888917E-14
         616          616   0.14035715E+04
         616          611   0.62461961E+02
         616          617   0.16651301E+04
         616          619   0.43198833E-04
         616          601  -0.86554488E-07
         616          606  -0.39527053E-04
         616          607  -0.77475355E-04
         616          621  -0.17918452E-06
         616          626  -0.47039573E-04
         616          627  -0.90807348E-04
         617          617   0.24096295E+04
         617          611   0.59516936E+02
         617          612  -0.21147957E+02
         617          614  -0.65348740E+02
         617          615  -0.63504104E+02
         617          616   0.16651035E+04
         617          618  -0.37456480E-04
         617          619  -0.94108028E-01
         617          620   0.38712385E-01
         617          601  -0.82473808E-07
         617          604   0.26308213E-08
         617          605   0.74537607E-10
         617          606  -0.77471560E-04
         617          607  -0.15338208E-03
         617          608   0.71093785E-14
         617          609   0.13042018E-09
         617          610  -0.53618922E-10
         617          621  -0.17073672E-06
         617          624   0.54463085E-08
         617          625   0.15430725E-09
         617          626  -0.90802971E-04
         617          627  -0.17836733E-03
         617          628   0.14717788E-13
         617          629   0.26999497E-09
         617          630  -0.11100153E-09
         618          618   0.64184519E-04
         618          617  -0.37465785E-04
         618          619  -0.15212408E-04
         618          620  -0.36023180E-04
         618          607   0.71099523E-14
         618          608  -0.10550845E-13
         618          609  -0.13223088E-14
         618          610   0.51109065E-14
         618          627   0.14718976E-13
         618          628  -0.21842289E-13
         618          629  -0.27374348E-14
         618          630   0.10580564E-13
         619          619   0.77687201E+02
         619          616   0.43198833E-04
         619          617  -0.94098616E-01
         619          618  -0.15208807E-04
         619          620   0.26222543E+02
         619          607   0.13040714E-09
         619          608  -0.13222592E-14
         619          609  -0.10765264E-06
         619          610  -0.36337089E-07
         619          627   0.26996798E-09
         619          628  -0.27373321E-14
         619          629  -0.22286178E-06
         619          630  -0.75224798E-07
         620          620   0.10543945E+05
         620          611   0.28388750E+04
         620          612   0.19417916E+03
         620          615   0.17041899E-05
         620          617   0.38712385E-01
         620          618  -0.36013737E-04
         620          619   0.26222543E+02
         620          601  -0.39338853E-05
         620          602  -0.26907794E-06
         620          605  -0.23615301E-14
         620          607  -0.53618922E-10
         620          608   0.51101400E-14
         620          609  -0.36337089E-07
         620          610  -0.14610955E-04
         620          621  -0.81439028E-05
         620          622  -0.55704335E-06
         620          625  -0.48888237E-14
         620          627  -0.11100153E-09
         620          628   0.10578977E-13
         620          629  -0.75224798E-07
         620          630  -0.30247500E-04
         621          621   0.75791716E+04
         621          626   0.61815840E+02
         621          627   0.58901277E+02
         621          630   0.28095089E+04
         621          611  -0.10219894E-04
         621          616  -0.83353327E-07
         621          617  -0.79423569E-07
         621          620  -0.37883931E-05
         621          631  -0.21654271E-04
         621          636  -0.17661197E-06
         621          637  -0.16828546E-06
         621          640  -0.80269808E-05
         622          622   0.47722221E+04
         622          624   0.63450217E+01
         622          625   0.63450217E+01
         622          627  -0.21136331E+02
         622          630   0.19217052E+03
         622          612  -0.64321006E-05
         622          620  -0.25912627E-06
         622          632  -0.13628562E-04
         622          640  -0.54904588E-06
         623          623   0.60421359E+03
         623          613  -0.81473274E-06
         623          633  -0.17262845E-05
         624          624   0.10419581E+04
         624          622   0.63443872E+01
         624          625   0.19035065E+02
         624          627  -0.65287688E+02
         624          614  -0.13793282E-05
         624          617   0.25332687E-08
         624          634  -0.29225693E-05
         624          637   0.53675791E-08
         625          625   0.19048825E+02
         625          622   0.63443872E+01
         625          624   0.19035065E+02
         625          627  -0.63462310E+02
         625          630   0.16865848E-05
         625          615  -0.18510157E-10
         625          617   0.71763207E-10
         625          620  -0.22742221E-14
         625          635  -0.39219973E-10
         625          637   0.15205441E-09
         625          640  -0.48187019E-14
         626          626   0.13923013E+04
         626          621   0.61815840E+02
         626          627   0.16544033E+04
         626          629   0.43198833E-04
         626          611  -0.83353327E-07
         626          616  -0.44991247E-04
         626          617  -0.88462825E-04
         626          631  -0.17661197E-06
         626          636  -0.51948827E-04
         626          637  -0.10067339E-03
         627          627   0.23998855E+04
         627          621   0.58901277E+02
         627          622  -0.21147957E+02
         627          624  -0.65329101E+02
         627          625  -0.63503548E+02
         627          626   0.16543767E+04
         627          628  -0.37403409E-04
         627          629  -0.93134454E-01
         627          630   0.38312125E-01
         627          611  -0.79423569E-07
         627          614   0.25335221E-08
         627          615   0.71780883E-10
         627          616  -0.88458477E-04
         627          617  -0.17541504E-03
         627          618   0.68464428E-14
         627          619   0.12559667E-09
         627          620  -0.51635861E-10
         627          631  -0.16828546E-06
         627          634   0.53681159E-08
         627          635   0.15209186E-09
         627          636  -0.10066851E-03
         627          637  -0.19814603E-03
         627          638   0.14506484E-13
         627          639   0.26611866E-09
         627          640  -0.10940788E-09
         628          628   0.64105758E-04
         628          627  -0.37412710E-04
         628          629  -0.15222279E-04
         628          630  -0.35985028E-04
         628          617   0.68469954E-14
         628          618  -0.10160629E-13
         628          619  -0.12734041E-14
         628          620   0.49218830E-14
         628          637   0.14507655E-13
         628          638  -0.21528699E-13
         628          639  -0.26981334E-14
         628          640   0.10428659E-13
         629          629   0.76883585E+02
         629          626   0.43198833E-04
         629          627  -0.93125140E-01
         629          628  -0.15218678E-04
         629          630   0.25951290E+02
         629          617   0.12558411E-09
         629          618  -0.12733563E-14
         629          619  -0.10367118E-06
         629          620  -0.34993186E-07
         629          637   0.26609205E-09
         629          638  -0.26980323E-14
         629          639  -0.21966215E-06
         629          640  -0.74144796E-07
         630          630   0.10434876E+05
         630          621   0.28095089E+04
         630          622   0.19217052E+03
         630          625   0.16865614E-05
         630          627   0.38312125E-01
         630          628  -0.35975590E-04
         630          629   0.25951290E+02
         630          611  -0.37883931E-05
         630          612  -0.25912627E-06
         630          615  -0.22741904E-14
         630          617  -0.51635861E-10
         630          618   0.49211448E-14
         630          619  -0.34993186E-07
         630          620  -0.14070578E-04
         630          631  -0.80269808E-05
         630          632  -0.54904588E-06
         630          635  -0.48186348E-14
         630          637  -0.10940788E-09
         630          638   0.10427095E-13
         630          639  -0.74144796E-07
         630          640  -0.29813237E-04
         631          631   0.75140791E+04
         631          636   0.61284947E+02
         631          637   0.58395413E+02
         631          640   0.27853800E+04
         631          621  -0.99044750E-05
         631          626  -0.80780775E-07
         631          627  -0.76972302E-07
         631          630  -0.36714711E-05
         631          641  -0.21400704E-04
         631          646  -0.17454388E-06
         631          647  -0.16631487E-06
         631          650  -0.79329864E-05
         632          632   0.47312548E+04
         632          634   0.63450217E+01
         632          635   0.63450217E+01
         632          637  -0.21136331E+02
         632          640   0.19052009E+03
         632          622  -0.62335853E-05
         632          630  -0.25112880E-06
         632          642  -0.13468974E-04
         632          650  -0.54261665E-06
         633          633   0.59902440E+03
         633          623  -0.78958747E-06
         633          643  -0.17060700E-05
         634          634   0.10331729E+04
         634          632   0.63443872E+01
         634          635   0.19035065E+02
         634          637  -0.65271553E+02
         634          624  -0.13367577E-05
         634          627   0.24550839E-08
         634          644  -0.28883466E-05
         634          647   0.53047258E-08
         635          635   0.19048707E+02
         635          632   0.63443872E+01
         635          634   0.19035065E+02
         635          637  -0.63461853E+02
         635          640   0.16720999E-05
         635          625  -0.17938874E-10
         635          627   0.69548363E-10
         635          630  -0.22040322E-14
         635          645  -0.38760715E-10
         635          647   0.15027388E-09
         635          650  -0.47622758E-14
         636          636   0.13830409E+04
         636          631   0.61284947E+02
         636          637   0.16455894E+04
         636          639   0.43198833E-04
         636          621  -0.80780775E-07
         636          626  -0.49900501E-04
         636          627  -0.98328864E-04
         636          641  -0.17454388E-06
         636          646  -0.56264815E-04
         636          647  -0.10934361E-03
         637          637   0.23918792E+04
         637          631   0.58395413E+02
         637          632  -0.21147957E+02
         637          634  -0.65312964E+02
         637          635  -0.63503091E+02
         637          636   0.16455628E+04
         637          638  -0.37359803E-04
         637          639  -0.92334505E-01
         637          640   0.37983247E-01
         637          621  -0.76972302E-07
         637          624   0.24553294E-08
         637          625   0.69565494E-10
         637          626  -0.98324021E-04
         637          627  -0.19519374E-03
         637          628   0.66351395E-14
         637          629   0.12172035E-09
         637          630  -0.50042212E-10
         637          641  -0.16631487E-06
         637          644   0.53052562E-08
         637          645   0.15031090E-09
         637          646  -0.10933830E-03
         637          647  -0.21552396E-03
         637          648   0.14336616E-13
         637          649   0.26300246E-09
         637          650  -0.10812674E-09
         638          638   0.64041043E-04
         638          637  -0.37369100E-04
         638          639  -0.15230390E-04
         638          640  -0.35953679E-04
         638          627   0.66356751E-14
         638          628  -0.98470393E-14
         638          629  -0.12341027E-14
         638          630   0.47699778E-14
         638          647   0.14337773E-13
         638          648  -0.21276602E-13
         638          649  -0.26665388E-14
         638          650   0.10306541E-13
         639          639   0.76223284E+02
         639          636   0.43198833E-04
         639          637  -0.92325271E-01
         639          638  -0.15226788E-04
         639          640   0.25728412E+02
         639          627   0.12170818E-09
         639          628  -0.12340565E-14
         639          629  -0.10047155E-06
         639          630  -0.33913183E-07
         639          647   0.26297616E-09
         639          648  -0.26664388E-14
         639          649  -0.21708995E-06
         639          650  -0.73276574E-07
         640          640   0.10345257E+05
         640          631   0.27853800E+04
         640          632   0.19052009E+03
         640          635   0.16720766E-05
         640          637   0.37983247E-01
         640          638  -0.35944246E-04
         640          639   0.25728412E+02
         640          621  -0.36714711E-05
         640          622  -0.25112880E-06
         640          625  -0.22040016E-14
         640          627  -0.50042212E-10
         640          628   0.47692624E-14
         640          629  -0.33913183E-07
         640          630  -0.13636315E-04
         640          641  -0.79329864E-05
         640          642  -0.54261665E-06
         640          645  -0.47622095E-14
         640          647  -0.10812674E-09
         640          648   0.10304996E-13
         640          649  -0.73276574E-07
         640          650  -0.29464129E-04
         641          641   0.74607781E+04
         641          646   0.60850225E+02
         641          647   0.57981186E+02
         641          650   0.27656219E+04
         641          631  -0.96509076E-05
         641          636  -0.78712682E-07
         641          637  -0.75001710E-07
         641          640  -0.35774766E-05
         641          651  -0.21196782E-04
         641          656  -0.17288069E-06
         641          657  -0.16473009E-06
         641          660  -0.78573950E-05
         642          642   0.46977087E+04
         642          644   0.63450217E+01
         642          645   0.63450217E+01
         642          647  -0.21136331E+02
         642          650   0.18916864E+03
         642          632  -0.60739974E-05
         642          640  -0.24469958E-06
         642          652  -0.13340631E-04
         642          660  -0.53744620E-06
         643          643   0.59477523E+03
         643          633  -0.76937300E-06
         643          653  -0.16898133E-05
         644          644   0.10259791E+04
         644          642   0.63443872E+01
         644          645   0.19035065E+02
         644          647  -0.65258341E+02
         644          634  -0.13025350E-05
         644          637   0.23922306E-08
         644          654  -0.28608242E-05
         644          657   0.52541784E-08
         645          645   0.19048611E+02
         645          642   0.63443872E+01
         645          644   0.19035065E+02
         645          647  -0.63461479E+02
         645          650   0.16602388E-05
         645          635  -0.17479616E-10
         645          637   0.67767835E-10
         645          640  -0.21476061E-14
         645          655  -0.38391374E-10
         645          657   0.14884196E-09
         645          660  -0.47168972E-14
         646          646   0.13754581E+04
         646          641   0.60850225E+02
         646          647   0.16383722E+04
         646          649   0.43198833E-04
         646          631  -0.78712682E-07
         646          636  -0.54216489E-04
         646          637  -0.10699909E-03
         646          651  -0.17288069E-06
         646          656  -0.59994603E-04
         646          657  -0.11683397E-03
         647          647   0.23853232E+04
         647          641   0.57981186E+02
         647          642  -0.21147957E+02
         647          644  -0.65299751E+02
         647          645  -0.63502717E+02
         647          646   0.16383455E+04
         647          648  -0.37324096E-04
         647          649  -0.91679466E-01
         647          650   0.37713944E-01
         647          631  -0.75001710E-07
         647          634   0.23924698E-08
         647          635   0.67784526E-10
         647          636  -0.10699381E-03
         647          637  -0.21257166E-03
         647          638   0.64652713E-14
         647          639   0.11860416E-09
         647          640  -0.48761067E-10
         647          651  -0.16473009E-06
         647          654   0.52547038E-08
         647          655   0.14887862E-09
         647          656  -0.11682829E-03
         647          657  -0.23053483E-03
         647          658   0.14200006E-13
         647          659   0.26049637E-09
         647          660  -0.10709642E-09
         648          648   0.63988051E-04
         648          647  -0.37333390E-04
         648          649  -0.15237031E-04
         648          650  -0.35928010E-04
         648          637   0.64657932E-14
         648          638  -0.95949423E-14
         648          639  -0.12025081E-14
         648          640   0.46478602E-14
         648          657   0.14201152E-13
         648          658  -0.21073863E-13
         648          659  -0.26411300E-14
         648          660   0.10208333E-13
         649          649   0.75682595E+02
         649          646   0.43198833E-04
         649          647  -0.91670297E-01
         649          648  -0.15233429E-04
         649          650   0.25545908E+02
         649          637   0.11859230E-09
         649          638  -0.12024630E-14
         649          639  -0.97899351E-07
         649          640  -0.33044962E-07
         649          657   0.26047033E-09
         649          658  -0.26410310E-14
         649          659  -0.21502135E-06
         649          660  -0.72578340E-07
         650          650   0.10271873E+05
         650          641   0.27656219E+04
         650          642   0.18916864E+03
         650          645   0.16602157E-05
         650          647   0.37713944E-01
         650          648  -0.35918580E-04
         650          649   0.25545908E+02
         650          631  -0.35774766E-05
         650          632  -0.24469958E-06
         650          635  -0.21475763E-14
         650          637  -0.48761067E-10
         650          638   0.46471631E-14
         650          639  -0.33044962E-07
         650          640  -0.13287207E-04
         650          651  -0.78573950E-05
         650          652  -0.53744620E-06
         650          655  -0.47168316E-14
         650          657  -0.10709642E-09
         650          658   0.10206802E-13
         650          659  -0.72578340E-07
         650          660  -0.29183373E-04
         651          651   0.74172562E+04
         651          656   0.60495260E+02
         651          657   0.57642957E+02
         651          660   0.27494888E+04
         651          641  -0.94469857E-05
         651          646  -0.77049498E-07
         651          647  -0.73416938E-07
         651          650  -0.35018852E-05
         651          661  -0.21032725E-04
         651          666  -0.17154265E-06
         651          667  -0.16345513E-06
         651          670  -0.77965811E-05
         652          652   0.46703173E+04
         652          654   0.63450217E+01
         652          655   0.63450217E+01
         652          657  -0.21136331E+02
         652          660   0.18806514E+03
         652          642  -0.59456549E-05
         652          650  -0.23952912E-06
         652          662  -0.13237379E-04
         652          670  -0.53328652E-06
         653          653   0.59130564E+03
         653          643  -0.75311629E-06
         653          663  -0.16767346E-05
         654          654   0.10201052E+04
         654          652   0.63443872E+01
         654          655   0.19035065E+02
         654          657  -0.65247553E+02
         654          644  -0.12750127E-05
         654          647   0.23416832E-08
         654          664  -0.28386823E-05
         654          667   0.52135126E-08
         655          655   0.19048532E+02
         655          652   0.63443872E+01
         655          654   0.19035065E+02
         655          657  -0.63461173E+02
         655          660   0.16505539E-05
         655          645  -0.17110274E-10
         655          647   0.66335913E-10
         655          650  -0.21022276E-14
         655          665  -0.38094236E-10
         655          667   0.14768997E-09
         655          670  -0.46803899E-14
         656          656   0.13692665E+04
         656          651   0.60495260E+02
         656          657   0.16324791E+04
         656          659   0.43198833E-04
         656          641  -0.77049498E-07
         656          646  -0.57946277E-04
         656          647  -0.11448945E-03
         656          661  -0.17154265E-06
         656          666  -0.63174024E-04
         656          667  -0.12321760E-03
         657          657   0.23799701E+04
         657          651   0.57642957E+02
         657          652  -0.21147957E+02
         657          654  -0.65288962E+02
         657          655  -0.63502411E+02
         657          656   0.16324524E+04
         657          658  -0.37294940E-04
         657          659  -0.91144606E-01
         657          660   0.37494050E-01
         657          641  -0.73416938E-07
         657          644   0.23419173E-08
         657          645   0.66352252E-10
         657          646  -0.11448379E-03
         657          647  -0.22758253E-03
         657          648   0.63286613E-14
         657          649   0.11609807E-09
         657          650  -0.47730754E-10
         657          661  -0.16345513E-06
         657          664   0.52140340E-08
         657          665   0.14772635E-09
         657          666  -0.12321159E-03
         657          667  -0.24332633E-03
         657          668   0.14090102E-13
         657          669   0.25848021E-09
         657          670  -0.10626753E-09
         658          658   0.63944782E-04
         658          657  -0.37304231E-04
         658          659  -0.15242454E-04
         658          660  -0.35907050E-04
         658          647   0.63291721E-14
         658          648  -0.93922029E-14
         658          649  -0.11770993E-14
         658          650   0.45496517E-14
         658          667   0.14091240E-13
         658          668  -0.20910757E-13
         658          669  -0.26206885E-14
         658          670   0.10129324E-13
         659          659   0.75241106E+02
         659          656   0.43198833E-04
         659          657  -0.91135491E-01
         659          658  -0.15238852E-04
         659          660   0.25396887E+02
         659          647   0.11608646E-09
         659          648  -0.11770552E-14
         659          649  -0.95830755E-07
         659          650  -0.32346728E-07
         659          667   0.25845436E-09
         659          668  -0.26205902E-14
         659          669  -0.21335715E-06
         659          670  -0.72016605E-07
         660          660   0.10211953E+05
         660          651   0.27494888E+04
         660          652   0.18806514E+03
         660          655   0.16505310E-05
         660          657   0.37494050E-01
         660          658  -0.35897623E-04
         660          659   0.25396887E+02
         660          641  -0.35018852E-05
         660          642  -0.23952912E-06
         660          645  -0.21021984E-14
         660          647  -0.47730754E-10
         660          648   0.45489694E-14
         660          649  -0.32346728E-07
         660          650  -0.13006451E-04
         660          661  -0.77965811E-05
         660          662  -0.53328652E-06
         660          665  -0.46803248E-14
         660          667  -0.10626753E-09
         660          668   0.10127804E-13
         660          669  -0.72016605E-07
         660          670  -0.28957503E-04
         661          661   0.73818022E+04
         661          666   0.60206098E+02
         661          667   0.57367428E+02
         661          670   0.27363465E+04
         661          651  -0.92829290E-05
         661          656  -0.75711453E-07
         661          657  -0.72141977E-07
         661          660  -0.34410713E-05
         661          671  -0.20900696E-04
         661          676  -0.17046582E-06
         661          677  -0.16242907E-06
         661          680  -0.77476394E-05
         662          662   0.46480036E+04
         662          664   0.63450217E+01
         662          665   0.63450217E+01
         662          667  -0.21136331E+02
         662          670   0.18716620E+03
         662          652  -0.58424025E-05
         662          660  -0.23536945E-06
         662          672  -0.13154283E-04
         662          680  -0.52993891E-06
         663          663   0.58847925E+03
         663          653  -0.74003764E-06
         663          673  -0.16662092E-05
         664          664   0.10153202E+04
         664          662   0.63443872E+01
         664          665   0.19035065E+02
         664          667  -0.65238765E+02
         664          654  -0.12528707E-05
         664          657   0.23010174E-08
         664          674  -0.28208630E-05
         664          677   0.51807857E-08
         665          665   0.19048468E+02
         665          662   0.63443872E+01
         665          664   0.19035065E+02
         665          667  -0.63460924E+02
         665          670   0.16426644E-05
         665          655  -0.16813137E-10
         665          657   0.65183921E-10
         665          660  -0.20657203E-14
         665          675  -0.37855106E-10
         665          677   0.14676287E-09
         665          680  -0.46510095E-14
         666          666   0.13642227E+04
         666          661   0.60206098E+02
         666          667   0.16276785E+04
         666          669   0.43198833E-04
         666          651  -0.75711453E-07
         666          656  -0.61125697E-04
         666          657  -0.12087308E-03
         666          671  -0.17046582E-06
         666          676  -0.65854822E-04
         666          677  -0.12859915E-03
         667          667   0.23756093E+04
         667          661   0.57367428E+02
         667          662  -0.21147957E+02
         667          664  -0.65280173E+02
         667          665  -0.63502162E+02
         667          666   0.16276518E+04
         667          668  -0.37271189E-04
         667          669  -0.90708897E-01
         667          670   0.37314920E-01
         667          651  -0.72141977E-07
         667          654   0.23012475E-08
         667          655   0.65199976E-10
         667          656  -0.12086710E-03
         667          657  -0.24037403E-03
         667          658   0.62187575E-14
         667          659   0.11408191E-09
         667          660  -0.46901860E-10
         667          671  -0.16242907E-06
         667          674   0.51813038E-08
         667          675   0.14679902E-09
         667          676  -0.12859288E-03
         667          677  -0.25410896E-03
         667          678   0.14001654E-13
         667          679   0.25685765E-09
         667          680  -0.10560046E-09
         668          668   0.63909533E-04
         668          667  -0.37280478E-04
         668          669  -0.15246872E-04
         668          670  -0.35889975E-04
         668          657   0.62192595E-14
         668          658  -0.92290976E-14
         668          659  -0.11566578E-14
         668          660   0.44706423E-14
         668          677   0.14002784E-13
         668          678  -0.20779494E-13
         668          679  -0.26042376E-14
         668          680   0.10065739E-13
         669          669   0.74881459E+02
         669          666   0.43198833E-04
         669          667  -0.90699826E-01
         669          668  -0.15243269E-04
         669          670   0.25275492E+02
         669          657   0.11407050E-09
         669          658  -0.11566144E-14
         669          659  -0.94166555E-07
         669          660  -0.31784993E-07
         669          677   0.25683196E-09
         669          678  -0.26041399E-14
         669          679  -0.21201784E-06
         669          680  -0.71564534E-07
         670          670   0.10163141E+05
         670          661   0.27363465E+04
         670          662   0.18716620E+03
         670          665   0.16426416E-05
         670          667   0.37314920E-01
         670          668  -0.35880551E-04
         670          669   0.25275492E+02
         670          651  -0.34410713E-05
         670          652  -0.23536945E-06
         670          655  -0.20656915E-14
         670          657  -0.46901860E-10
         670          658   0.44699718E-14
         670          659  -0.31784993E-07
         670          660  -0.12780581E-04
         670          671  -0.77476394E-05
         670          672  -0.52993891E-06
         670          675  -0.46509449E-14
         670          677  -0.10560046E-09
         670          678   0.10064229E-13
         670          679  -0.71564534E-07
         670          680  -0.28775727E-04
         671          671   0.73529763E+04
         671          676   0.59970995E+02
         671          677   0.57143408E+02
         671          680   0.27256611E+04
         671          661  -0.91508997E-05
         671          666  -0.74634624E-07
         671          667  -0.71115916E-07
         671          670  -0.33921297E-05
         671          681  -0.20794410E-04
         671          686  -0.16959895E-06
         671          687  -0.16160307E-06
         671          690  -0.77082406E-05
         672          672   0.46298614E+04
         672          674   0.63450217E+01
         672          675   0.63450217E+01
         672          677  -0.21136331E+02
         672          680   0.18643532E+03
         672          662  -0.57593071E-05
         672          670  -0.23202183E-06
         672          682  -0.13087390E-04
         672          690  -0.52724403E-06
         673          673   0.58618124E+03
         673          663  -0.72951224E-06
         673          683  -0.16577361E-05
         674          674   0.10114297E+04
         674          672   0.63443872E+01
         674          675   0.19035065E+02
         674          677  -0.65231620E+02
         674          664  -0.12350514E-05
         674          667   0.22682905E-08
         674          684  -0.28065181E-05
         674          687   0.51544400E-08
         675          675   0.19048415E+02
         675          672   0.63443872E+01
         675          674   0.19035065E+02
         675          677  -0.63460722E+02
         675          680   0.16362498E-05
         675          665  -0.16574007E-10
         675          667   0.64256823E-10
         675          670  -0.20363399E-14
         675          685  -0.37662603E-10
         675          687   0.14601654E-09
         675          690  -0.46273579E-14
         676          676   0.13601218E+04
         676          671   0.59970995E+02
         676          677   0.16237753E+04
         676          679   0.43198833E-04
         676          661  -0.74634624E-07
         676          666  -0.63806496E-04
         676          667  -0.12625463E-03
         676          681  -0.16959895E-06
         676          686  -0.68095481E-04
         676          687  -0.13309655E-03
         677          677   0.23720637E+04
         677          671   0.57143408E+02
         677          672  -0.21147957E+02
         677          674  -0.65273027E+02
         677          675  -0.63501959E+02
         677          676   0.16237486E+04
         677          678  -0.37251878E-04
         677          679  -0.90354644E-01
         677          680   0.37169277E-01
         677          661  -0.71115916E-07
         677          664   0.22685173E-08
         677          665   0.64272650E-10
         677          666  -0.12624839E-03
         677          667  -0.25115666E-03
         677          668   0.61303094E-14
         677          669   0.11245934E-09
         677          670  -0.46234784E-10
         677          681  -0.16160307E-06
         677          684   0.51549554E-08
         677          685   0.14605251E-09
         677          686  -0.13309005E-03
         677          687  -0.26311945E-03
         677          688   0.13930452E-13
         677          689   0.25555145E-09
         677          690  -0.10506345E-09
         678          678   0.63880874E-04
         678          677  -0.37261166E-04
         678          679  -0.15250463E-04
         678          680  -0.35876092E-04
         678          667   0.61308042E-14
         678          668  -0.90978340E-14
         678          669  -0.11402068E-14
         678          670   0.44070573E-14
         678          687   0.13931576E-13
         678          688  -0.20673824E-13
         678          689  -0.25909943E-14
         678          690   0.10014552E-13
         679          679   0.74589048E+02
         679          676   0.43198833E-04
         679          677  -0.90345607E-01
         679          678  -0.15246861E-04
         679          680   0.25176792E+02
         679          667   0.11244810E-09
         679          668  -0.11401641E-14
         679          669  -0.92827243E-07
         679          670  -0.31332922E-07
         679          687   0.25552590E-09
         679          688  -0.25908972E-14
         679          689  -0.21093967E-06
         679          690  -0.71200609E-07
         680          680   0.10123454E+05
         680          671   0.27256611E+04
         680          672   0.18643532E+03
         680          675   0.16362271E-05
         680          677   0.37169277E-01
         680          678  -0.35866671E-04
         680          679   0.25176792E+02
         680          661  -0.33921297E-05
         680          662  -0.23202183E-06
         680          665  -0.20363116E-14
         680          667  -0.46234784E-10
         680          668   0.44063963E-14
         680          669  -0.31332922E-07
         680          670  -0.12598805E-04
         680          681  -0.77082406E-05
         680          682  -0.52724403E-06
         680          685  -0.46272935E-14
         680          687  -0.10506345E-09
         680          688   0.10013050E-13
         680          689  -0.71200609E-07
         680          690  -0.28629395E-04
         681          681   0.73295764E+04
         681          686   0.59780145E+02
         681          687   0.56961557E+02
         681          690   0.27169870E+04
         681          671  -0.90446140E-05
         681          676  -0.73767759E-07
         681          677  -0.70289920E-07
         681          680  -0.33527308E-05
         681          691  -0.20708827E-04
         681          696  -0.16890093E-06
         681          697  -0.16093797E-06
         681          700  -0.76765158E-05
         682          682   0.46151342E+04
         682          684   0.63450217E+01
         682          685   0.63450217E+01
         682          687  -0.21136331E+02
         682          690   0.18584201E+03
         682          672  -0.56924140E-05
         682          680  -0.22932695E-06
         682          692  -0.13033527E-04
         682          700  -0.52507405E-06
         683          683   0.58431579E+03
         683          673  -0.72103911E-06
         683          693  -0.16509134E-05
         684          684   0.10082715E+04
         684          682   0.63443872E+01
         684          685   0.19035065E+02
         684          687  -0.65225820E+02
         684          674  -0.12207066E-05
         684          677   0.22419448E-08
         684          694  -0.27949673E-05
         684          697   0.51332259E-08
         685          685   0.19048373E+02
         685          682   0.63443872E+01
         685          684   0.19035065E+02
         685          687  -0.63460558E+02
         685          690   0.16310427E-05
         685          675  -0.16381503E-10
         685          677   0.63510494E-10
         685          680  -0.20126883E-14
         685          695  -0.37507595E-10
         685          697   0.14541558E-09
         685          700  -0.46083131E-14
         686          686   0.13567928E+04
         686          681   0.59780145E+02
         686          687   0.16206069E+04
         686          689   0.43198833E-04
         686          671  -0.73767759E-07
         686          676  -0.66047155E-04
         686          677  -0.13075202E-03
         686          691  -0.16890093E-06
         686          696  -0.69955138E-04
         686          697  -0.13682881E-03
         687          687   0.23691856E+04
         687          681   0.56961557E+02
         687          682  -0.21147957E+02
         687          684  -0.65267226E+02
         687          685  -0.63501795E+02
         687          686   0.16205801E+04
         687          688  -0.37236202E-04
         687          689  -0.90067072E-01
         687          690   0.37051049E-01
         687          671  -0.70289920E-07
         687          674   0.22421690E-08
         687          675   0.63526137E-10
         687          676  -0.13074555E-03
         687          677  -0.26016715E-03
         687          678   0.60591072E-14
         687          679   0.11115315E-09
         687          680  -0.45697777E-10
         687          691  -0.16093797E-06
         687          694   0.51337392E-08
         687          695   0.14545140E-09
         687          696  -0.13682212E-03
         687          697  -0.27059663E-03
         687          698   0.13873118E-13
         687          699   0.25449968E-09
         687          700  -0.10463104E-09
         688          688   0.63857610E-04
         688          687  -0.37245489E-04
         688          689  -0.15253379E-04
         688          690  -0.35864823E-04
         688          677   0.60595962E-14
         688          678  -0.89921646E-14
         688          679  -0.11269636E-14
         688          680   0.43558702E-14
         688          697   0.13874238E-13
         688          698  -0.20588737E-13
         688          699  -0.25803306E-14
         688          700   0.99733347E-14
         689          689   0.74351678E+02
         689          686   0.43198833E-04
         689          687  -0.90058065E-01
         689          688  -0.15249776E-04
         689          690   0.25096670E+02
         689          677   0.11114204E-09
         689          678  -0.11269213E-14
         689          679  -0.91749074E-07
         689          680  -0.30968997E-07
         689          697   0.25447423E-09
         689          698  -0.25802338E-14
         689          699  -0.21007151E-06
         689          700  -0.70907568E-07
         690          690   0.10091237E+05
         690          681   0.27169870E+04
         690          682   0.18584201E+03
         690          685   0.16310200E-05
         690          687   0.37051049E-01
         690          688  -0.35855403E-04
         690          689   0.25096670E+02
         690          671  -0.33527308E-05
         690          672  -0.22932695E-06
         690          675  -0.20126603E-14
         690          677  -0.45697777E-10
         690          678   0.43552170E-14
         690          679  -0.30968997E-07
         690          680  -0.12452473E-04
         690          691  -0.76765158E-05
         690          692  -0.52507405E-06
         690          695  -0.46082490E-14
         690          697  -0.10463104E-09
         690          698   0.99718389E-14
         690          699  -0.70907568E-07
         690          700  -0.28511565E-04
         691          691   0.73106057E+04
         691          696   0.59625420E+02
         691          697   0.56814127E+02
         691          700   0.27099548E+04
         691          681  -0.89590304E-05
         691          686  -0.73069741E-07
         691          687  -0.69624810E-07
         691          690  -0.33210060E-05
         691          701  -0.20639898E-04
         691          706  -0.16833875E-06
         691          707  -0.16040229E-06
         691          710  -0.76509647E-05
         692          692   0.46031946E+04
         692          694   0.63450217E+01
         692          695   0.63450217E+01
         692          697  -0.21136331E+02
         692          700   0.18536101E+03
         692          682  -0.56385503E-05
         692          690  -0.22715697E-06
         692          702  -0.12990145E-04
         692          710  -0.52332636E-06
         693          693   0.58280344E+03
         693          683  -0.71421636E-06
         693          703  -0.16454183E-05
         694          694   0.10057111E+04
         694          692   0.63443872E+01
         694          695   0.19035065E+02
         694          697  -0.65221117E+02
         694          684  -0.12091558E-05
         694          687   0.22207307E-08
         694          704  -0.27856644E-05
         694          707   0.51161401E-08
         695          695   0.19048339E+02
         695          692   0.63443872E+01
         695          694   0.19035065E+02
         695          697  -0.63460424E+02
         695          700   0.16268211E-05
         695          685  -0.16226495E-10
         695          687   0.62909533E-10
         695          690  -0.19936435E-14
         695          705  -0.37382752E-10
         695          707   0.14493157E-09
         695          710  -0.45929745E-14
         696          696   0.13540940E+04
         696          691   0.59625420E+02
         696          697   0.16180381E+04
         696          699   0.43198833E-04
         696          681  -0.73069741E-07
         696          686  -0.67906812E-04
         696          687  -0.13448429E-03
         696          701  -0.16833875E-06
         696          706  -0.71489878E-04
         696          707  -0.13990872E-03
         697          697   0.23668522E+04
         697          691   0.56814127E+02
         697          692  -0.21147957E+02
         697          694  -0.65262523E+02
         697          695  -0.63501662E+02
         697          696   0.16180114E+04
         697          698  -0.37223493E-04
         697          699  -0.89833933E-01
         697          700   0.36955200E-01
         697          681  -0.69624810E-07
         697          684   0.22209527E-08
         697          685   0.62925028E-10
         697          686  -0.13447763E-03
         697          687  -0.26764433E-03
         697          688   0.60017736E-14
         697          689   0.11010138E-09
         697          690  -0.45265368E-10
         697          701  -0.16040229E-06
         697          704   0.51166517E-08
         697          705   0.14496727E-09
         697          706  -0.13990188E-03
         697          707  -0.27676664E-03
         697          708   0.13826942E-13
         697          709   0.25365259E-09
         697          710  -0.10428278E-09
         698          698   0.63838750E-04
         698          697  -0.37232779E-04
         698          699  -0.15255743E-04
         698          700  -0.35855687E-04
         698          687   0.60022581E-14
         698          688  -0.89070773E-14
         698          689  -0.11162998E-14
         698          690   0.43146534E-14
         698          707   0.13828058E-13
         698          708  -0.20520208E-13
         698          709  -0.25717420E-14
         698          710   0.99401388E-14
         699          699   0.74159238E+02
         699          696   0.43198833E-04
         699          697  -0.89824949E-01
         699          698  -0.15252140E-04
         699          700   0.25031714E+02
         699          687   0.11009037E-09
         699          688  -0.11162580E-14
         699          689  -0.90880910E-07
         699          690  -0.30675956E-07
         699          707   0.25362723E-09
         699          708  -0.25716456E-14
         699          709  -0.20937229E-06
         699          710  -0.70671555E-07
         700          700   0.10065119E+05
         700          691   0.27099548E+04
         700          692   0.18536101E+03
         700          695   0.16267985E-05
         700          697   0.36955200E-01
         700          698  -0.35846269E-04
         700          699   0.25031714E+02
         700          681  -0.33210060E-05
         700          682  -0.22715697E-06
         700          685  -0.19936157E-14
         700          687  -0.45265368E-10
         700          688   0.43140062E-14
         700          689  -0.30675956E-07
         700          690  -0.12334643E-04
         700          701  -0.76509647E-05
         700          702  -0.52332636E-06
         700          705  -0.45929106E-14
         700          707  -0.10428278E-09
         700          708   0.99386480E-14
         700          709  -0.70671555E-07
         700          710  -0.28416665E-04
         701          701   0.72952421E+04
         701          706   0.59500115E+02
         701          707   0.56694729E+02
         701          710   0.27042597E+04
         701          691  -0.88901018E-05
         701          696  -0.72507560E-07
         701          697  -0.69089133E-07
         701          700  -0.32954550E-05
         701          711  -0.20584373E-04
         701          716  -0.16788589E-06
         701          717  -0.15997078E-06
         701          720  -0.76303824E-05
         702          702   0.45935252E+04
         702          704   0.63450217E+01
         702          705   0.63450217E+01
         702          707  -0.21136331E+02
         702          710   0.18497146E+03
         702          692  -0.55951686E-05
         702          700  -0.22540928E-06
         702          712  -0.12955199E-04
         702          720  -0.52191852E-06
         703          703   0.58157865E+03
         703          693  -0.70872136E-06
         703          713  -0.16409919E-05
         704          704   0.10036376E+04
         704          702   0.63443872E+01
         704          705   0.19035065E+02
         704          707  -0.65217309E+02
         704          694  -0.11998528E-05
         704          697   0.22036449E-08
         704          714  -0.27781705E-05
         704          717   0.51023768E-08
         705          705   0.19048311E+02
         705          702   0.63443872E+01
         705          704   0.19035065E+02
         705          707  -0.63460316E+02
         705          710   0.16234023E-05
         705          695  -0.16101653E-10
         705          697   0.62425523E-10
         705          700  -0.19783049E-14
         705          715  -0.37282186E-10
         705          717   0.14454168E-09
         705          720  -0.45806186E-14
         706          706   0.13519083E+04
         706          701   0.59500115E+02
         706          707   0.16159578E+04
         706          709   0.43198833E-04
         706          691  -0.72507560E-07
         706          696  -0.69441551E-04
         706          697  -0.13756420E-03
         706          711  -0.16788589E-06
         706          716  -0.72750722E-04
         706          717  -0.14243882E-03
         707          707   0.23649625E+04
         707          701   0.56694729E+02
         707          702  -0.21147957E+02
         707          704  -0.65258714E+02
         707          705  -0.63501554E+02
         707          706   0.16159311E+04
         707          708  -0.37213201E-04
         707          709  -0.89645123E-01
         707          710   0.36877576E-01
         707          691  -0.69089133E-07
         707          694   0.22038653E-08
         707          695   0.62440899E-10
         707          696  -0.13755739E-03
         707          697  -0.27381434E-03
         707          698   0.59555974E-14
         707          699   0.10925429E-09
         707          700  -0.44917107E-10
         707          711  -0.15997078E-06
         707          714   0.51028871E-08
         707          715   0.14457728E-09
         707          716  -0.14243185E-03
         707          717  -0.28183504E-03
         707          718   0.13789745E-13
         707          719   0.25297022E-09
         707          720  -0.10400224E-09
         708          708   0.63823475E-04
         708          707  -0.37222486E-04
         708          709  -0.15257657E-04
         708          710  -0.35848288E-04
         708          697   0.59560781E-14
         708          698  -0.88385484E-14
         708          699  -0.11077113E-14
         708          700   0.42814575E-14
         708          717   0.13790858E-13
         708          718  -0.20465005E-13
         708          719  -0.25648236E-14
         708          720   0.99133981E-14
         709          709   0.74003389E+02
         709          706   0.43198833E-04
         709          707  -0.89636158E-01
         709          708  -0.15254054E-04
         709          710   0.24979108E+02
         709          697   0.10924336E-09
         709          698  -0.11076698E-14
         709          699  -0.90181694E-07
         709          700  -0.30439943E-07
         709          717   0.25294493E-09
         709          718  -0.25647274E-14
         709          719  -0.20880904E-06
         709          720  -0.70481437E-07
         710          710   0.10043966E+05
         710          701   0.27042597E+04
         710          702   0.18497146E+03
         710          705   0.16233797E-05
         710          707   0.36877576E-01
         710          708  -0.35838871E-04
         710          709   0.24979108E+02
         710          691  -0.32954550E-05
         710          692  -0.22540928E-06
         710          695  -0.19782773E-14
         710          697  -0.44917107E-10
         710          698   0.42808153E-14
         710          699  -0.30439943E-07
         710          700  -0.12239743E-04
         710          711  -0.76303824E-05
         710          712  -0.52191852E-06
         710          715  -0.45805549E-14
         710          717  -0.10400224E-09
         710          718   0.99119113E-14
         710          719  -0.70481437E-07
         710          720  -0.28340219E-04
         711          711   0.72828105E+04
         711          716   0.59398722E+02
         711          717   0.56598116E+02
         711          720   0.26996514E+04
         711          701  -0.88345770E-05
         711          706  -0.72054700E-07
         711          707  -0.68657624E-07
         711          710  -0.32748726E-05
         711          721  -0.20539639E-04
         711          726  -0.16752104E-06
         711          727  -0.15962313E-06
         711          730  -0.76137999E-05
         712          712   0.45857011E+04
         712          714   0.63450217E+01
         712          715   0.63450217E+01
         712          717  -0.21136331E+02
         712          720   0.18465626E+03
         712          702  -0.55602229E-05
         712          710  -0.22400145E-06
         712          722  -0.12927045E-04
         712          730  -0.52078428E-06
         713          713   0.58058760E+03
         713          703  -0.70429490E-06
         713          723  -0.16374257E-05
         714          714   0.10019597E+04
         714          712   0.63443872E+01
         714          715   0.19035065E+02
         714          717  -0.65214227E+02
         714          704  -0.11923589E-05
         714          707   0.21898816E-08
         714          724  -0.27721329E-05
         714          727   0.50912883E-08
         715          715   0.19048288E+02
         715          712   0.63443872E+01
         715          714   0.19035065E+02
         715          717  -0.63460229E+02
         715          720   0.16206359E-05
         715          705  -0.16001087E-10
         715          707   0.62035632E-10
         715          710  -0.19659490E-14
         715          725  -0.37201164E-10
         715          727   0.14422756E-09
         715          730  -0.45706639E-14
         716          716   0.13501397E+04
         716          711   0.59398722E+02
         716          717   0.16142745E+04
         716          719   0.43198833E-04
         716          701  -0.72054700E-07
         716          706  -0.70702395E-04
         716          707  -0.14009429E-03
         716          721  -0.16752104E-06
         716          726  -0.73782765E-04
         716          727  -0.14450968E-03
         717          717   0.23634334E+04
         717          711   0.56598116E+02
         717          712  -0.21147957E+02
         717          714  -0.65255633E+02
         717          715  -0.63501467E+02
         717          716   0.16142477E+04
         717          718  -0.37204873E-04
         717          719  -0.89492345E-01
         717          720   0.36814765E-01
         717          701  -0.68657624E-07
         717          704   0.21901006E-08
         717          705   0.62050912E-10
         717          706  -0.14008736E-03
         717          707  -0.27888274E-03
         717          708   0.59184006E-14
         717          709   0.10857192E-09
         717          710  -0.44636569E-10
         717          721  -0.15962313E-06
         717          724   0.50917974E-08
         717          725   0.14426309E-09
         717          726  -0.14450261E-03
         717          727  -0.28598338E-03
         717          728   0.13759777E-13
         717          729   0.25242046E-09
         717          730  -0.10377622E-09
         718          718   0.63811115E-04
         718          717  -0.37214157E-04
         718          719  -0.15259206E-04
         718          720  -0.35842301E-04
         718          707   0.59188783E-14
         718          708  -0.87833456E-14
         718          709  -0.11007929E-14
         718          710   0.42547168E-14
         718          727   0.13760888E-13
         718          728  -0.20420530E-13
         718          729  -0.25592497E-14
         718          730   0.98918542E-14
         719          719   0.73877281E+02
         719          716   0.43198833E-04
         719          717  -0.89483395E-01
         719          718  -0.15255603E-04
         719          720   0.24936542E+02
         719          707   0.10856106E-09
         719          708  -0.11007516E-14
         719          709  -0.89618448E-07
         719          710  -0.30249824E-07
         719          727   0.25239522E-09
         719          728  -0.25591537E-14
         719          729  -0.20835526E-06
         719          730  -0.70328266E-07
         720          720   0.10026851E+05
         720          711   0.26996514E+04
         720          712   0.18465626E+03
         720          715   0.16206133E-05
         720          717   0.36814765E-01
         720          718  -0.35832884E-04
         720          719   0.24936542E+02
         720          701  -0.32748726E-05
         720          702  -0.22400145E-06
         720          705  -0.19659216E-14
         720          707  -0.44636569E-10
         720          708   0.42540787E-14
         720          709  -0.30249824E-07
         720          710  -0.12163297E-04
         720          721  -0.76137999E-05
         720          722  -0.52078428E-06
         720          725  -0.45706004E-14
         720          727  -0.10377622E-09
         720          728   0.98903706E-14
         720          729  -0.70328266E-07
         720          730  -0.28278630E-04
         721          721   0.72727583E+04
         721          726   0.59316737E+02
         721          727   0.56519996E+02
         721          730   0.26959252E+04
         721          711  -0.87898428E-05
         721          716  -0.71689849E-07
         721          717  -0.68309974E-07
         721          720  -0.32582902E-05
         721          731  -0.20503594E-04
         721          736  -0.16722706E-06
         721          737  -0.15934301E-06
         721          740  -0.76004384E-05
         722          722   0.45793745E+04
         722          724   0.63450217E+01
         722          725   0.63450217E+01
         722          727  -0.21136331E+02
         722          730   0.18440138E+03
         722          712  -0.55320686E-05
         722          720  -0.22286721E-06
         722          732  -0.12904359E-04
         722          740  -0.51987036E-06
         723          723   0.57978623E+03
         723          713  -0.70072868E-06
         723          733  -0.16345521E-05
         724          724   0.10006030E+04
         724          722   0.63443872E+01
         724          725   0.19035065E+02
         724          727  -0.65211736E+02
         724          714  -0.11863214E-05
         724          717   0.21787931E-08
         724          734  -0.27672681E-05
         724          737   0.50823536E-08
         725          725   0.19048270E+02
         725          722   0.63443872E+01
         725          724   0.19035065E+02
         725          727  -0.63460159E+02
         725          730   0.16183990E-05
         725          715  -0.15920065E-10
         725          717   0.61721513E-10
         725          720  -0.19559943E-14
         725          735  -0.37135880E-10
         725          737   0.14397446E-09
         725          740  -0.45626429E-14
         726          726   0.13487097E+04
         726          721   0.59316737E+02
         726          727   0.16129134E+04
         726          729   0.43198833E-04
         726          711  -0.71689849E-07
         726          716  -0.71734439E-04
         726          717  -0.14216516E-03
         726          731  -0.16722706E-06
         726          736  -0.74625041E-04
         726          737  -0.14619969E-03
         727          727   0.23621970E+04
         727          721   0.56519996E+02
         727          722  -0.21147957E+02
         727          724  -0.65253141E+02
         727          725  -0.63501396E+02
         727          726   0.16128866E+04
         727          728  -0.37198139E-04
         727          729  -0.89368809E-01
         727          730   0.36763976E-01
         727          711  -0.68309974E-07
         727          714   0.21790110E-08
         727          715   0.61736715E-10
         727          716  -0.14215811E-03
         727          717  -0.28303108E-03
         727          718   0.58884326E-14
         727          719   0.10802216E-09
         727          720  -0.44410550E-10
         727          731  -0.15934301E-06
         727          734   0.50828618E-08
         727          735   0.14400992E-09
         727          736  -0.14619253E-03
         727          737  -0.28936873E-03
         727          738   0.13735630E-13
         727          739   0.25197749E-09
         727          740  -0.10359410E-09
         728          728   0.63801122E-04
         728          727  -0.37207423E-04
         728          729  -0.15260458E-04
         728          730  -0.35837460E-04
         728          717   0.58889079E-14
         728          718  -0.87388708E-14
         728          719  -0.10952190E-14
         728          720   0.42331729E-14
         728          737   0.13736739E-13
         728          738  -0.20384694E-13
         728          739  -0.25547585E-14
         728          740   0.98744950E-14
         729          729   0.73775311E+02
         729          726   0.43198833E-04
         729          727  -0.89359871E-01
         729          728  -0.15256856E-04
         729          730   0.24902123E+02
         729          717   0.10801136E-09
         729          718  -0.10951779E-14
         729          719  -0.89164661E-07
         729          720  -0.30096653E-07
         729          737   0.25195229E-09
         729          738  -0.25546627E-14
         729          739  -0.20798961E-06
         729          740  -0.70204846E-07
         730          730   0.10013011E+05
         730          721   0.26959252E+04
         730          722   0.18440138E+03
         730          725   0.16183765E-05
         730          727   0.36763976E-01
         730          728  -0.35828044E-04
         730          729   0.24902123E+02
         730          711  -0.32582902E-05
         730          712  -0.22286721E-06
         730          715  -0.19559671E-14
         730          717  -0.44410550E-10
         730          718   0.42325380E-14
         730          719  -0.30096653E-07
         730          720  -0.12101708E-04
         730          731  -0.76004384E-05
         730          732  -0.51987036E-06
         730          735  -0.45625794E-14
         730          737  -0.10359410E-09
         730          738   0.98730140E-14
         730          739  -0.70204846E-07
         730          740  -0.28229004E-04
         731          731   0.72646347E+04
         731          736   0.59250481E+02
         731          737   0.56456864E+02
         731          740   0.26929139E+04
         731          721  -0.87537978E-05
         731          726  -0.71395866E-07
         731          727  -0.68029851E-07
         731          730  -0.32449287E-05
         731          741  -0.20474547E-04
         731          746  -0.16699015E-06
         731          747  -0.15911727E-06
         731          750  -0.75896712E-05
         732          732   0.45742618E+04
         732          734   0.63450217E+01
         732          735   0.63450217E+01
         732          737  -0.21136331E+02
         732          740   0.18419541E+03
         732          722  -0.55093829E-05
         732          730  -0.22195328E-06
         732          742  -0.12886078E-04
         732          750  -0.51913388E-06
         733          733   0.57913862E+03
         733          723  -0.69785516E-06
         733          743  -0.16322365E-05
         734          734   0.99950663E+03
         734          732   0.63443872E+01
         734          735   0.19035065E+02
         734          737  -0.65209722E+02
         734          724  -0.11814565E-05
         734          727   0.21698584E-08
         734          744  -0.27633478E-05
         734          747   0.50751536E-08
         735          735   0.19048255E+02
         735          732   0.63443872E+01
         735          734   0.19035065E+02
         735          737  -0.63460102E+02
         735          740   0.16165912E-05
         735          725  -0.15854780E-10
         735          727   0.61468407E-10
         735          730  -0.19479733E-14
         735          745  -0.37083271E-10
         735          747   0.14377049E-09
         735          750  -0.45561791E-14
         736          736   0.13475540E+04
         736          731   0.59250481E+02
         736          737   0.16118134E+04
         736          739   0.43198833E-04
         736          721  -0.71395866E-07
         736          726  -0.72576714E-04
         736          727  -0.14385517E-03
         736          741  -0.16699015E-06
         736          746  -0.75310812E-04
         736          747  -0.14757563E-03
         737          737   0.23611978E+04
         737          731   0.56456864E+02
         737          732  -0.21147957E+02
         737          734  -0.65251127E+02
         737          735  -0.63501339E+02
         737          736   0.16117866E+04
         737          738  -0.37192697E-04
         737          739  -0.89268975E-01
         737          740   0.36722932E-01
         737          721  -0.68029851E-07
         737          724   0.21700754E-08
         737          725   0.61483547E-10
         737          726  -0.14384804E-03
         737          727  -0.28641643E-03
         737          728   0.58642855E-14
         737          729   0.10757919E-09
         737          730  -0.44228433E-10
         737          741  -0.15911727E-06
         737          744   0.50756611E-08
         737          745   0.14380590E-09
         737          746  -0.14756841E-03
         737          747  -0.29212490E-03
         737          748   0.13716172E-13
         737          749   0.25162052E-09
         737          750  -0.10344735E-09
         738          738   0.63793045E-04
         738          737  -0.37201980E-04
         738          739  -0.15261471E-04
         738          740  -0.35833547E-04
         738          727   0.58647589E-14
         738          728  -0.87030348E-14
         738          729  -0.10907277E-14
         738          730   0.42158137E-14
         738          747   0.13717279E-13
         738          748  -0.20355816E-13
         738          749  -0.25511392E-14
         738          750   0.98605062E-14
         739          739   0.73692905E+02
         739          736   0.43198833E-04
         739          737  -0.89260048E-01
         739          738  -0.15257868E-04
         739          740   0.24874308E+02
         739          727   0.10756843E-09
         739          728  -0.10906868E-14
         739          729  -0.88799018E-07
         739          730  -0.29973234E-07
         739          747   0.25159536E-09
         739          748  -0.25510436E-14
         739          749  -0.20769496E-06
         739          750  -0.70105390E-07
         740          740   0.10001827E+05
         740          731   0.26929139E+04
         740          732   0.18419541E+03
         740          735   0.16165688E-05
         740          737   0.36722932E-01
         740          738  -0.35824132E-04
         740          739   0.24874308E+02
         740          721  -0.32449287E-05
         740          722  -0.22195328E-06
         740          725  -0.19479462E-14
         740          727  -0.44228433E-10
         740          728   0.42151814E-14
         740          729  -0.29973234E-07
         740          730  -0.12052082E-04
         740          741  -0.75896712E-05
         740          742  -0.51913388E-06
         740          745  -0.45561158E-14
         740          747  -0.10344735E-09
         740          748   0.98590273E-14
         740          749  -0.70105390E-07
         740          750  -0.28189013E-04
         741          741   0.72580728E+04
         741          746   0.59196962E+02
         741          747   0.56405868E+02
         741          750   0.26904814E+04
         741          731  -0.87247511E-05
         741          736  -0.71158961E-07
         741          737  -0.67804116E-07
         741          740  -0.32341615E-05
         741          751  -0.20451138E-04
         741          756  -0.16679923E-06
         741          757  -0.15893535E-06
         741          760  -0.75809938E-05
         742          742   0.45701319E+04
         742          744   0.63450217E+01
         742          745   0.63450217E+01
         742          747  -0.21136331E+02
         742          750   0.18402903E+03
         742          732  -0.54911017E-05
         742          740  -0.22121680E-06
         742          752  -0.12871345E-04
         742          760  -0.51854034E-06
         743          743   0.57861550E+03
         743          733  -0.69553955E-06
         743          753  -0.16303704E-05
         744          744   0.99862100E+03
         744          742   0.63443872E+01
         744          745   0.19035065E+02
         744          747  -0.65208095E+02
         744          734  -0.11775363E-05
         744          737   0.21626584E-08
         744          754  -0.27601884E-05
         744          757   0.50693511E-08
         745          745   0.19048243E+02
         745          742   0.63443872E+01
         745          744   0.19035065E+02
         745          747  -0.63460055E+02
         745          750   0.16151310E-05
         745          735  -0.15802171E-10
         745          737   0.61264444E-10
         745          740  -0.19415095E-14
         745          755  -0.37040873E-10
         745          757   0.14360612E-09
         745          760  -0.45509700E-14
         746          746   0.13466204E+04
         746          741   0.59196962E+02
         746          747   0.16109249E+04
         746          749   0.43198833E-04
         746          731  -0.71158961E-07
         746          736  -0.73262485E-04
         746          737  -0.14523111E-03
         746          751  -0.16679923E-06
         746          756  -0.75868091E-04
         746          757  -0.14869374E-03
         747          747   0.23603907E+04
         747          741   0.56405868E+02
         747          742  -0.21147957E+02
         747          744  -0.65249500E+02
         747          745  -0.63501293E+02
         747          746   0.16108981E+04
         747          748  -0.37188301E-04
         747          749  -0.89188333E-01
         747          750   0.36689778E-01
         747          731  -0.67804116E-07
         747          734   0.21628747E-08
         747          735   0.61279534E-10
         747          736  -0.14522391E-03
         747          737  -0.28917261E-03
         747          738   0.58448267E-14
         747          739   0.10722222E-09
         747          740  -0.44081675E-10
         747          751  -0.15893535E-06
         747          754   0.50698580E-08
         747          755   0.14364149E-09
         747          756  -0.14868646E-03
         747          757  -0.29436458E-03
         747          758   0.13700490E-13
         747          759   0.25133284E-09
         747          760  -0.10332907E-09
         748          748   0.63786521E-04
         748          747  -0.37197584E-04
         748          749  -0.15262288E-04
         748          750  -0.35830387E-04
         748          737   0.58452985E-14
         748          738  -0.86741566E-14
         748          739  -0.10871085E-14
         748          740   0.42018248E-14
         748          757   0.13701595E-13
         748          758  -0.20332543E-13
         748          759  -0.25482225E-14
         748          760   0.98492324E-14
         749          749   0.73626341E+02
         749          746   0.43198833E-04
         749          747  -0.89179413E-01
         749          748  -0.15258685E-04
         749          750   0.24851839E+02
         749          737   0.10721150E-09
         749          738  -0.10870677E-14
         749          739  -0.88504367E-07
         749          740  -0.29873778E-07
         749          757   0.25130771E-09
         749          758  -0.25481269E-14
         749          759  -0.20745750E-06
         749          760  -0.70025237E-07
         750          750   0.99927922E+04
         750          741   0.26904814E+04
         750          742   0.18402903E+03
         750          745   0.16151086E-05
         750          747   0.36689778E-01
         750          748  -0.35820973E-04
         750          749   0.24851839E+02
         750          731  -0.32341615E-05
         750          732  -0.22121680E-06
         750          735  -0.19414825E-14
         750          737  -0.44081675E-10
         750          738   0.42011946E-14
         750          739  -0.29873778E-07
         750          740  -0.12012091E-04
         750          751  -0.75809938E-05
         750          752  -0.51854034E-06
         750          755  -0.45509067E-14
         750          757  -0.10332907E-09
         750          758   0.98477552E-14
         750          759  -0.70025237E-07
         750          760  -0.28156784E-04
         751          751   0.72527743E+04
         751          756   0.59153748E+02
         751          757   0.56364691E+02
         751          760   0.26885173E+04
         751          741  -0.87013421E-05
         751          746  -0.70968038E-07
         751          747  -0.67622194E-07
         751          750  -0.32254840E-05
         751          761  -0.20432271E-04
         751          766  -0.16664535E-06
         751          767  -0.15878872E-06
         751          770  -0.75740000E-05
         752          752   0.45667972E+04
         752          754   0.63450217E+01
         752          755   0.63450217E+01
         752          757  -0.21136331E+02
         752          760   0.18389469E+03
         752          742  -0.54763688E-05
         752          750  -0.22062326E-06
         752          762  -0.12859471E-04
         752          770  -0.51806196E-06
         753          753   0.57819310E+03
         753          743  -0.69367338E-06
         753          763  -0.16288663E-05
         754          754   0.99790589E+03
         754          752   0.63443872E+01
         754          755   0.19035065E+02
         754          757  -0.65206782E+02
         754          744  -0.11743769E-05
         754          747   0.21568559E-08
         754          764  -0.27576420E-05
         754          767   0.50646744E-08
         755          755   0.19048234E+02
         755          752   0.63443872E+01
         755          754   0.19035065E+02
         755          757  -0.63460018E+02
         755          760   0.16139520E-05
         755          745  -0.15759773E-10
         755          747   0.61100068E-10
         755          750  -0.19363004E-14
         755          765  -0.37006701E-10
         755          767   0.14347363E-09
         755          770  -0.45467715E-14
         756          756   0.13458667E+04
         756          751   0.59153748E+02
         756          757   0.16102075E+04
         756          759   0.43198833E-04
         756          741  -0.70968038E-07
         756          746  -0.73819765E-04
         756          747  -0.14634922E-03
         756          761  -0.16664535E-06
         756          766  -0.76320257E-04
         756          767  -0.14960093E-03
         757          757   0.23597390E+04
         757          751   0.56364691E+02
         757          752  -0.21147957E+02
         757          754  -0.65248187E+02
         757          755  -0.63501256E+02
         757          756   0.16101807E+04
         757          758  -0.37184751E-04
         757          759  -0.89123217E-01
         757          760   0.36663008E-01
         757          741  -0.67622194E-07
         757          744   0.21570715E-08
         757          745   0.61115118E-10
         757          746  -0.14634196E-03
         757          747  -0.29141228E-03
         757          748   0.58291448E-14
         757          749   0.10693454E-09
         757          750  -0.43963401E-10
         757          761  -0.15878872E-06
         757          764   0.50651808E-08
         757          765   0.14350897E-09
         757          766  -0.14959360E-03
         757          767  -0.29618174E-03
         757          768   0.13687850E-13
         757          769   0.25110097E-09
         757          770  -0.10323375E-09
         758          758   0.63781253E-04
         758          757  -0.37194034E-04
         758          759  -0.15262948E-04
         758          760  -0.35827835E-04
         758          747   0.58296153E-14
         758          748  -0.86508833E-14
         758          749  -0.10841917E-14
         758          750   0.41905511E-14
         758          767   0.13688955E-13
         758          768  -0.20313785E-13
         758          769  -0.25458716E-14
         758          770   0.98401461E-14
         759          759   0.73572592E+02
         759          756   0.43198833E-04
         759          757  -0.89114304E-01
         759          758  -0.15259346E-04
         759          760   0.24833697E+02
         759          747   0.10692384E-09
         759          748  -0.10841511E-14
         759          749  -0.88266905E-07
         759          750  -0.29793625E-07
         759          767   0.25107587E-09
         759          768  -0.25457761E-14
         759          769  -0.20726611E-06
         759          770  -0.69960635E-07
         760          760   0.99854973E+04
         760          751   0.26885173E+04
         760          752   0.18389469E+03
         760          755   0.16139295E-05
         760          757   0.36663008E-01
         760          758  -0.35818421E-04
         760          759   0.24833697E+02
         760          741  -0.32254840E-05
         760          742  -0.22062326E-06
         760          745  -0.19362734E-14
         760          747  -0.43963401E-10
         760          748   0.41899226E-14
         760          749  -0.29793625E-07
         760          750  -0.11979862E-04
         760          761  -0.75740000E-05
         760          762  -0.51806196E-06
         760          765  -0.45467083E-14
         760          767  -0.10323375E-09
         760          768   0.98386703E-14
         760          769  -0.69960635E-07
         760          770  -0.28130808E-04
         761          761   0.72484972E+04
         761          766   0.59118864E+02
         761          767   0.56331452E+02
         761          770   0.26869319E+04
         761          751  -0.86824753E-05
         761          756  -0.70814161E-07
         761          757  -0.67475571E-07
         761          760  -0.32184903E-05
         761          771  -0.20417064E-04
         761          776  -0.16652132E-06
         761          777  -0.15867054E-06
         761          780  -0.75683629E-05
         762          762   0.45641053E+04
         762          764   0.63450217E+01
         762          765   0.63450217E+01
         762          767  -0.21136331E+02
         762          770   0.18378624E+03
         762          752  -0.54644946E-05
         762          760  -0.22014489E-06
         762          772  -0.12849900E-04
         762          780  -0.51767639E-06
         763          763   0.57785213E+03
         763          753  -0.69216931E-06
         763          773  -0.16276540E-05
         764          764   0.99732863E+03
         764          762   0.63443872E+01
         764          765   0.19035065E+02
         764          767  -0.65205722E+02
         764          754  -0.11718305E-05
         764          757   0.21521792E-08
         764          774  -0.27555896E-05
         764          777   0.50609049E-08
         765          765   0.19048226E+02
         765          762   0.63443872E+01
         765          764   0.19035065E+02
         765          767  -0.63459988E+02
         765          770   0.16130002E-05
         765          755  -0.15725602E-10
         765          757   0.60967587E-10
         765          760  -0.19321019E-14
         765          775  -0.36979158E-10
         765          777   0.14336685E-09
         765          780  -0.45433875E-14
         766          766   0.13452582E+04
         766          761   0.59118864E+02
         766          767   0.16096283E+04
         766          769   0.43198833E-04
         766          751  -0.70814161E-07
         766          756  -0.74271930E-04
         766          757  -0.14725641E-03
         766          771  -0.16652132E-06
         766          776  -0.76686679E-04
         766          777  -0.15033608E-03
         767          767   0.23592129E+04
         767          761   0.56331452E+02
         767          762  -0.21147957E+02
         767          764  -0.65247126E+02
         767          765  -0.63501226E+02
         767          766   0.16096015E+04
         767          768  -0.37181886E-04
         767          769  -0.89070654E-01
         767          770   0.36641398E-01
         767          751  -0.67475571E-07
         767          754   0.21523944E-08
         767          755   0.60982604E-10
         767          756  -0.14724911E-03
         767          757  -0.29322945E-03
         767          758   0.58165056E-14
         767          759   0.10670267E-09
         767          760  -0.43868077E-10
         767          771  -0.15867054E-06
         767          774   0.50614110E-08
         767          775   0.14340217E-09
         767          776  -0.15032871E-03
         767          777  -0.29765429E-03
         767          778   0.13677663E-13
         767          779   0.25091409E-09
         767          780  -0.10315691E-09
         768          768   0.63777001E-04
         768          767  -0.37191168E-04
         768          769  -0.15263481E-04
         768          770  -0.35825776E-04
         768          757   0.58169751E-14
         768          758  -0.86321259E-14
         768          759  -0.10818409E-14
         768          760   0.41814649E-14
         768          777   0.13678767E-13
         768          778  -0.20298667E-13
         768          779  -0.25439768E-14
         768          780   0.98328225E-14
         769          769   0.73529206E+02
         769          766   0.43198833E-04
         769          767  -0.89061747E-01
         769          768  -0.15259878E-04
         769          770   0.24819052E+02
         769          757   0.10669200E-09
         769          758  -0.10818004E-14
         769          759  -0.88075519E-07
         769          760  -0.29729024E-07
         769          777   0.25088900E-09
         769          778  -0.25438814E-14
         769          779  -0.20711185E-06
         769          780  -0.69908567E-07
         770          770   0.99796087E+04
         770          761   0.26869319E+04
         770          762   0.18378624E+03
         770          765   0.16129778E-05
         770          767   0.36641398E-01
         770          768  -0.35816362E-04
         770          769   0.24819052E+02
         770          751  -0.32184903E-05
         770          752  -0.22014489E-06
         770          755  -0.19320751E-14
         770          757  -0.43868077E-10
         770          758   0.41808377E-14
         770          759  -0.29729024E-07
         770          760  -0.11953886E-04
         770          771  -0.75683629E-05
         770          772  -0.51767639E-06
         770          775  -0.45433243E-14
         770          777  -0.10315691E-09
         770          778   0.98313477E-14
         770          779  -0.69908567E-07
         770          780  -0.28109871E-04
         771          771   0.72450455E+04
         771          776   0.59090712E+02
         771          777   0.56304627E+02
         771          780   0.26856524E+04
         771          761  -0.86672685E-05
         771          766  -0.70690134E-07
         771          767  -0.67357391E-07
         771          770  -0.32128533E-05
         771          781  -0.20404807E-04
         771          786  -0.16642135E-06
         771          787  -0.15857529E-06
         771          790  -0.75638193E-05
         772          772   0.45619329E+04
         772          774   0.63450217E+01
         772          775   0.63450217E+01
         772          777  -0.21136331E+02
         772          780   0.18369872E+03
         772          762  -0.54549239E-05
         772          770  -0.21975932E-06
         772          782  -0.12842185E-04
         772          790  -0.51736561E-06
         773          773   0.57757696E+03
         773          763  -0.69095702E-06
         773          783  -0.16266768E-05
         774          774   0.99686277E+03
         774          772   0.63443872E+01
         774          775   0.19035065E+02
         774          777  -0.65204866E+02
         774          764  -0.11697781E-05
         774          767   0.21484098E-08
         774          784  -0.27539353E-05
         774          787   0.50578666E-08
         775          775   0.19048220E+02
         775          772   0.63443872E+01
         775          774   0.19035065E+02
         775          777  -0.63459964E+02
         775          780   0.16122321E-05
         775          765  -0.15698059E-10
         775          767   0.60860806E-10
         775          770  -0.19287180E-14
         775          785  -0.36956958E-10
         775          787   0.14328078E-09
         775          790  -0.45406599E-14
         776          776   0.13447671E+04
         776          771   0.59090712E+02
         776          777   0.16091610E+04
         776          779   0.43198833E-04
         776          761  -0.70690134E-07
         776          766  -0.74638353E-04
         776          767  -0.14799156E-03
         776          781  -0.16642135E-06
         776          786  -0.76983320E-04
         776          787  -0.15093122E-03
         777          777   0.23587884E+04
         777          771   0.56304627E+02
         777          772  -0.21147957E+02
         777          774  -0.65246271E+02
         777          775  -0.63501201E+02
         777          776   0.16091342E+04
         777          778  -0.37179574E-04
         777          779  -0.89028235E-01
         777          780   0.36623958E-01
         777          761  -0.67357391E-07
         777          764   0.21486247E-08
         777          765   0.60875797E-10
         777          766  -0.14798422E-03
         777          767  -0.29470199E-03
         777          768   0.58063184E-14
         777          769   0.10651579E-09
         777          770  -0.43791245E-10
         777          781  -0.15857529E-06
         777          784   0.50583724E-08
         777          785   0.14331607E-09
         777          786  -0.15092382E-03
         777          787  -0.29884638E-03
         777          788   0.13669452E-13
         777          789   0.25076345E-09
         777          790  -0.10309498E-09
         778          778   0.63773570E-04
         778          777  -0.37188856E-04
         778          779  -0.15263911E-04
         778          780  -0.35824113E-04
         778          767   0.58067871E-14
         778          768  -0.86170073E-14
         778          769  -0.10799461E-14
         778          770   0.41741413E-14
         778          787   0.13670555E-13
         778          788  -0.20286480E-13
         778          789  -0.25424495E-14
         778          790   0.98269193E-14
         779          779   0.73494191E+02
         779          776   0.43198833E-04
         779          777  -0.89019332E-01
         779          778  -0.15260308E-04
         779          780   0.24807234E+02
         779          767   0.10650514E-09
         779          768  -0.10799057E-14
         779          769  -0.87921260E-07
         779          770  -0.29676956E-07
         779          787   0.25073838E-09
         779          788  -0.25423542E-14
         779          789  -0.20698751E-06
         779          790  -0.69866597E-07
         780          780   0.99748564E+04
         780          771   0.26856524E+04
         780          772   0.18369872E+03
         780          775   0.16122097E-05
         780          777   0.36623958E-01
         780          778  -0.35814700E-04
         780          779   0.24807234E+02
         780          761  -0.32128533E-05
         780          762  -0.21975932E-06
         780          765  -0.19286912E-14
         780          767  -0.43791245E-10
         780          768   0.41735153E-14
         780          769  -0.29676956E-07
         780          770  -0.11932950E-04
         780          781  -0.75638193E-05
         780          782  -0.51736561E-06
         780          785  -0.45405968E-14
         780          787  -0.10309498E-09
         780          788   0.98254455E-14
         780          789  -0.69866597E-07
         780          790  -0.28092995E-04
         781          781   0.72422605E+04
         781          786   0.59067997E+02
         781          787   0.56282984E+02
         781          790   0.26846200E+04
         781          771  -0.86550111E-05
         781          776  -0.70590163E-07
         781          777  -0.67262134E-07
         781          780  -0.32083097E-05
         781          791  -0.20394927E-04
         781          796  -0.16634077E-06
         781          797  -0.15849850E-06
         781          800  -0.75601568E-05
         782          782   0.45601801E+04
         782          784   0.63450217E+01
         782          785   0.63450217E+01
         782          787  -0.21136331E+02
         782          790   0.18362811E+03
         782          772  -0.54472094E-05
         782          780  -0.21944854E-06
         782          792  -0.12835967E-04
         782          800  -0.51711509E-06
         783          783   0.57735494E+03
         783          773  -0.68997986E-06
         783          793  -0.16258892E-05
         784          784   0.99648689E+03
         784          782   0.63443872E+01
         784          785   0.19035065E+02
         784          787  -0.65204176E+02
         784          774  -0.11681238E-05
         784          777   0.21453715E-08
         784          794  -0.27526018E-05
         784          797   0.50554175E-08
         785          785   0.19048215E+02
         785          782   0.63443872E+01
         785          784   0.19035065E+02
         785          787  -0.63459944E+02
         785          790   0.16116123E-05
         785          775  -0.15675859E-10
         785          777   0.60774736E-10
         785          780  -0.19259904E-14
         785          795  -0.36939063E-10
         785          797   0.14321140E-09
         785          800  -0.45384612E-14
         786          786   0.13443709E+04
         786          781   0.59067997E+02
         786          787   0.16087839E+04
         786          789   0.43198833E-04
         786          771  -0.70590163E-07
         786          776  -0.74934994E-04
         786          777  -0.14858670E-03
         786          791  -0.16634077E-06
         786          796  -0.77223276E-04
         786          797  -0.15141263E-03
         787          787   0.23584458E+04
         787          781   0.56282984E+02
         787          782  -0.21147957E+02
         787          784  -0.65245580E+02
         787          785  -0.63501182E+02
         787          786   0.16087571E+04
         787          788  -0.37177708E-04
         787          789  -0.88994009E-01
         787          790   0.36609887E-01
         787          771  -0.67262134E-07
         787          774   0.21455860E-08
         787          775   0.60789705E-10
         787          776  -0.14857933E-03
         787          777  -0.29589409E-03
         787          778   0.57981070E-14
         787          779   0.10636516E-09
         787          780  -0.43729314E-10
         787          791  -0.15849850E-06
         787          794   0.50559231E-08
         787          795   0.14324668E-09
         787          796  -0.15140521E-03
         787          797  -0.29981066E-03
         787          798   0.13662833E-13
         787          799   0.25064203E-09
         787          800  -0.10304506E-09
         788          788   0.63770801E-04
         788          787  -0.37186990E-04
         788          789  -0.15264258E-04
         788          790  -0.35822772E-04
         788          777   0.57985750E-14
         788          778  -0.86048210E-14
         788          779  -0.10784189E-14
         788          780   0.41682382E-14
         788          797   0.13663935E-13
         788          798  -0.20276657E-13
         788          799  -0.25412184E-14
         788          800   0.98221610E-14
         789          789   0.73465940E+02
         789          786   0.43198833E-04
         789          787  -0.88985109E-01
         789          788  -0.15260655E-04
         789          790   0.24797698E+02
         789          777   0.10635452E-09
         789          778  -0.10783784E-14
         789          779  -0.87796921E-07
         789          780  -0.29634986E-07
         789          797   0.25061697E-09
         789          798  -0.25411232E-14
         789          799  -0.20688729E-06
         789          800  -0.69832766E-07
         790          790   0.99710220E+04
         790          781   0.26846200E+04
         790          782   0.18362811E+03
         790          785   0.16115899E-05
         790          787   0.36609887E-01
         790          788  -0.35813358E-04
         790          789   0.24797698E+02
         790          771  -0.32083097E-05
         790          772  -0.21944854E-06
         790          775  -0.19259636E-14
         790          777  -0.43729314E-10
         790          778   0.41676130E-14
         790          779  -0.29634986E-07
         790          780  -0.11916074E-04
         790          791  -0.75601568E-05
         790          792  -0.51711509E-06
         790          795  -0.45383981E-14
         790          797  -0.10304506E-09
         790          798   0.98206878E-14
         790          799  -0.69832766E-07
         790          800  -0.28079392E-04
         791          791   0.72400137E+04
         791          796   0.59049673E+02
         791          797   0.56265523E+02
         791          800   0.26837871E+04
         791          781  -0.86451308E-05
         791          786  -0.70509579E-07
         791          787  -0.67185349E-07
         791          790  -0.32046471E-05
         791          801  -0.20386962E-04
         791          806  -0.16627581E-06
         791          807  -0.15843661E-06
         791          810  -0.75572044E-05
         792          792   0.45587661E+04
         792          794   0.63450217E+01
         792          795   0.63450217E+01
         792          797  -0.21136331E+02
         792          800   0.18357114E+03
         792          782  -0.54409910E-05
         792          790  -0.21919802E-06
         792          802  -0.12830954E-04
         792          810  -0.51691315E-06
         793          793   0.57717583E+03
         793          783  -0.68919220E-06
         793          803  -0.16252542E-05
         794          794   0.99618365E+03
         794          792   0.63443872E+01
         794          795   0.19035065E+02
         794          797  -0.65203619E+02
         794          784  -0.11667903E-05
         794          787   0.21429224E-08
         794          804  -0.27515269E-05
         794          807   0.50534433E-08
         795          795   0.19048211E+02
         795          792   0.63443872E+01
         795          794   0.19035065E+02
         795          797  -0.63459929E+02
         795          800   0.16111124E-05
         795          785  -0.15657964E-10
         795          787   0.60705357E-10
         795          790  -0.19237917E-14
         795          805  -0.36924637E-10
         795          807   0.14315548E-09
         795          810  -0.45366889E-14
         796          796   0.13440513E+04
         796          791   0.59049673E+02
         796          797   0.16084796E+04
         796          799   0.43198833E-04
         796          781  -0.70509579E-07
         796          786  -0.75174949E-04
         796          787  -0.14906810E-03
         796          801  -0.16627581E-06
         796          806  -0.77417251E-04
         796          807  -0.15180179E-03
         797          797   0.23581695E+04
         797          791   0.56265523E+02
         797          792  -0.21147957E+02
         797          794  -0.65245023E+02
         797          795  -0.63501166E+02
         797          796   0.16084528E+04
         797          798  -0.37176203E-04
         797          799  -0.88966397E-01
         797          800   0.36598535E-01
         797          781  -0.67185349E-07
         797          784   0.21431367E-08
         797          785   0.60720309E-10
         797          786  -0.14906071E-03
         797          787  -0.29685836E-03
         797          788   0.57914880E-14
         797          789   0.10624373E-09
         797          790  -0.43679394E-10
         797          801  -0.15843661E-06
         797          804   0.50539486E-08
         797          805   0.14319074E-09
         797          806  -0.15179435E-03
         797          807  -0.30059015E-03
         797          808   0.13657497E-13
         797          809   0.25054415E-09
         797          810  -0.10300482E-09
         798          798   0.63768567E-04
         798          797  -0.37185485E-04
         798          799  -0.15264538E-04
         798          800  -0.35821690E-04
         798          787   0.57919555E-14
         798          788  -0.85949979E-14
         798          789  -0.10771878E-14
         798          790   0.41634798E-14
         798          807   0.13658599E-13
         798          808  -0.20268739E-13
         798          809  -0.25402261E-14
         798          810   0.98183253E-14
         799          799   0.73443148E+02
         799          796   0.43198833E-04
         799          797  -0.88957500E-01
         799          798  -0.15260935E-04
         799          800   0.24790005E+02
         799          787   0.10623311E-09
         799          788  -0.10771474E-14
         799          789  -0.87696694E-07
         799          790  -0.29601155E-07
         799          807   0.25051910E-09
         799          808  -0.25401308E-14
         799          809  -0.20680649E-06
         799          810  -0.69805496E-07
         800          800   0.99679287E+04
         800          791   0.26837871E+04
         800          792   0.18357114E+03
         800          795   0.16110900E-05
         800          797   0.36598535E-01
         800          798  -0.35812277E-04
         800          799   0.24790005E+02
         800          781  -0.32046471E-05
         800          782  -0.21919802E-06
         800          785  -0.19237650E-14
         800          787  -0.43679394E-10
         800          788   0.41628554E-14
         800          789  -0.29601155E-07
         800          790  -0.11902471E-04
         800          801  -0.75572044E-05
         800          802  -0.51691315E-06
         800          805  -0.45366258E-14
         800          807  -0.10300482E-09
         800          808   0.98168527E-14
         800          809  -0.69805496E-07
         800          810  -0.28068427E-04
         801          801   0.72382014E+04
         801          806   0.59034891E+02
         801          807   0.56251438E+02
         801          810   0.26831153E+04
         801          791  -0.86371662E-05
         801          796  -0.70444620E-07
         801          797  -0.67123453E-07
         801          800  -0.32016948E-05
         801          811  -0.20380542E-04
         801          816  -0.16622345E-06
         801          817  -0.15838671E-06
         801          820  -0.75548245E-05
         802          802   0.45576254E+04
         802          804   0.63450217E+01
         802          805   0.63450217E+01
         802          807  -0.21136331E+02
         802          810   0.18352519E+03
         802          792  -0.54359784E-05
         802          800  -0.21899608E-06
         802          812  -0.12826914E-04
         802          820  -0.51675036E-06
         803          803   0.57703135E+03
         803          793  -0.68855726E-06
         803          813  -0.16247424E-05
         804          804   0.99593905E+03
         804          802   0.63443872E+01
         804          805   0.19035065E+02
         804          807  -0.65203170E+02
         804          794  -0.11657154E-05
         804          797   0.21409482E-08
         804          814  -0.27506604E-05
         804          817   0.50518519E-08
         805          805   0.19048207E+02
         805          802   0.63443872E+01
         805          804   0.19035065E+02
         805          807  -0.63459916E+02
         805          810   0.16107091E-05
         805          795  -0.15643539E-10
         805          797   0.60649431E-10
         805          800  -0.19220194E-14
         805          815  -0.36913009E-10
         805          817   0.14311039E-09
         805          820  -0.45352602E-14
         806          806   0.13437935E+04
         806          801   0.59034891E+02
         806          807   0.16082342E+04
         806          809   0.43198833E-04
         806          791  -0.70444620E-07
         806          796  -0.75368925E-04
         806          797  -0.14945726E-03
         806          811  -0.16622345E-06
         806          816  -0.77573975E-04
         806          817  -0.15211621E-03
         807          807   0.23579466E+04
         807          801   0.56251438E+02
         807          802  -0.21147957E+02
         807          804  -0.65244574E+02
         807          805  -0.63501153E+02
         807          806   0.16082074E+04
         807          808  -0.37174989E-04
         807          809  -0.88944124E-01
         807          810   0.36589378E-01
         807          791  -0.67123453E-07
         807          794   0.21411623E-08
         807          795   0.60664369E-10
         807          796  -0.14944985E-03
         807          797  -0.29763786E-03
         807          798   0.57861525E-14
         807          799   0.10614585E-09
         807          800  -0.43639154E-10
         807          811  -0.15838671E-06
         807          814   0.50523570E-08
         807          815   0.14314564E-09
         807          816  -0.15210875E-03
         807          817  -0.30121995E-03
         807          818   0.13653196E-13
         807          819   0.25046525E-09
         807          820  -0.10297238E-09
         808          808   0.63766765E-04
         808          807  -0.37184271E-04
         808          809  -0.15264764E-04
         808          810  -0.35820817E-04
         808          797   0.57866195E-14
         808          798  -0.85870796E-14
         808          799  -0.10761954E-14
         808          800   0.41596441E-14
         808          817   0.13654298E-13
         808          818  -0.20262356E-13
         808          819  -0.25394261E-14
         808          820   0.98152333E-14
         809          809   0.73424764E+02
         809          806   0.43198833E-04
         809          807  -0.88935229E-01
         809          808  -0.15261161E-04
         809          810   0.24783799E+02
         809          797   0.10613524E-09
         809          798  -0.10761550E-14
         809          799  -0.87615901E-07
         809          800  -0.29573885E-07
         809          817   0.25044020E-09
         809          818  -0.25393309E-14
         809          819  -0.20674137E-06
         809          820  -0.69783512E-07
         810          810   0.99654335E+04
         810          801   0.26831153E+04
         810          802   0.18352519E+03
         810          805   0.16106867E-05
         810          807   0.36589378E-01
         810          808  -0.35811404E-04
         810          809   0.24783799E+02
         810          791  -0.32016948E-05
         810          792  -0.21899608E-06
         810          795  -0.19219926E-14
         810          797  -0.43639154E-10
         810          798   0.41590203E-14
         810          799  -0.29573885E-07
         810          800  -0.11891505E-04
         810          811  -0.75548245E-05
         810          812  -0.51675036E-06
         810          815  -0.45351971E-14
         810          817  -0.10297238E-09
         810          818   0.98137612E-14
         810          819  -0.69783512E-07
         810          820  -0.28059588E-04
         811          811   0.72367396E+04
         811          816   0.59022969E+02
         811          817   0.56240079E+02
         811          820   0.26825735E+04
         811          801  -0.86307459E-05
         811          806  -0.70392256E-07
         811          807  -0.67073557E-07
         811          810  -0.31993148E-05
         811          821  -0.20375366E-04
         811          826  -0.16618123E-06
         811          827  -0.15834649E-06
         811          830  -0.75529059E-05
         812          812   0.45567055E+04
         812          814   0.63450217E+01
         812          815   0.63450217E+01
         812          817  -0.21136331E+02
         812          820   0.18348813E+03
         812          802  -0.54319376E-05
         812          810  -0.21883329E-06
         812          822  -0.12823656E-04
         812          830  -0.51661913E-06
         813          813   0.57691482E+03
         813          803  -0.68804543E-06
         813          823  -0.16243298E-05
         814          814   0.99574177E+03
         814          812   0.63443872E+01
         814          815   0.19035065E+02
         814          817  -0.65202808E+02
         814          804  -0.11648488E-05
         814          807   0.21393567E-08
         814          824  -0.27499618E-05
         814          827   0.50505689E-08
         815          815   0.19048205E+02
         815          812   0.63443872E+01
         815          814   0.19035065E+02
         815          817  -0.63459906E+02
         815          820   0.16103838E-05
         815          805  -0.15631910E-10
         815          807   0.60604348E-10
         815          810  -0.19205907E-14
         815          825  -0.36903635E-10
         815          827   0.14307405E-09
         815          830  -0.45341085E-14
         816          816   0.13435855E+04
         816          811   0.59022969E+02
         816          817   0.16080363E+04
         816          819   0.43198833E-04
         816          801  -0.70392256E-07
         816          806  -0.75525649E-04
         816          807  -0.14977168E-03
         816          821  -0.16618123E-06
         816          826  -0.77700548E-04
         816          827  -0.15237014E-03
         817          817   0.23577668E+04
         817          811   0.56240079E+02
         817          812  -0.21147957E+02
         817          814  -0.65244212E+02
         817          815  -0.63501143E+02
         817          816   0.16080095E+04
         817          818  -0.37174010E-04
         817          819  -0.88926161E-01
         817          820   0.36581993E-01
         817          801  -0.67073557E-07
         817          804   0.21395707E-08
         817          805   0.60619275E-10
         817          806  -0.14976426E-03
         817          807  -0.29826765E-03
         817          808   0.57818514E-14
         817          809   0.10606695E-09
         817          810  -0.43606715E-10
         817          821  -0.15834649E-06
         817          824   0.50510740E-08
         817          825   0.14310929E-09
         817          826  -0.15236267E-03
         817          827  -0.30172857E-03
         817          828   0.13649729E-13
         817          829   0.25040164E-09
         817          830  -0.10294623E-09
         818          818   0.63765312E-04
         818          817  -0.37183291E-04
         818          819  -0.15264946E-04
         818          820  -0.35820113E-04
         818          807   0.57823181E-14
         818          808  -0.85806965E-14
         818          809  -0.10753954E-14
         818          810   0.41565521E-14
         818          827   0.13650831E-13
         818          828  -0.20257210E-13
         818          829  -0.25387812E-14
         818          830   0.98127407E-14
         819          819   0.73409936E+02
         819          816   0.43198833E-04
         819          817  -0.88917267E-01
         819          818  -0.15261343E-04
         819          820   0.24778794E+02
         819          807   0.10605634E-09
         819          808  -0.10753551E-14
         819          809  -0.87550773E-07
         819          810  -0.29551901E-07
         819          827   0.25037660E-09
         819          828  -0.25386860E-14
         819          829  -0.20668886E-06
         819          830  -0.69765791E-07
         820          820   0.99634211E+04
         820          811   0.26825735E+04
         820          812   0.18348813E+03
         820          815   0.16103614E-05
         820          817   0.36581993E-01
         820          818  -0.35810700E-04
         820          819   0.24778794E+02
         820          801  -0.31993148E-05
         820          802  -0.21883329E-06
         820          805  -0.19205640E-14
         820          807  -0.43606715E-10
         820          808   0.41559287E-14
         820          809  -0.29551901E-07
         820          810  -0.11882666E-04
         820          821  -0.75529059E-05
         820          822  -0.51661913E-06
         820          825  -0.45340454E-14
         820          827  -0.10294623E-09
         820          828   0.98112690E-14
         820          829  -0.69765791E-07
         820          830  -0.28052462E-04
         821          821   0.72355608E+04
         821          826   0.59013355E+02
         821          827   0.56230917E+02
         821          830   0.26821365E+04
         821          811  -0.86255703E-05
         821          816  -0.70350044E-07
         821          817  -0.67033335E-07
         821          820  -0.31973963E-05
         821          831  -0.20371194E-04
         821          836  -0.16614720E-06
         821          837  -0.15831406E-06
         821          840  -0.75513593E-05
         822          822   0.45559635E+04
         822          824   0.63450217E+01
         822          825   0.63450217E+01
         822          827  -0.21136331E+02
         822          830   0.18345824E+03
         822          812  -0.54286802E-05
         822          820  -0.21870206E-06
         822          832  -0.12821030E-04
         822          840  -0.51651334E-06
         823          823   0.57682084E+03
         823          813  -0.68763283E-06
         823          833  -0.16239972E-05
         824          824   0.99558267E+03
         824          822   0.63443872E+01
         824          825   0.19035065E+02
         824          827  -0.65202515E+02
         824          814  -0.11641503E-05
         824          817   0.21380738E-08
         824          834  -0.27493987E-05
         824          837   0.50495347E-08
         825          825   0.19048203E+02
         825          822   0.63443872E+01
         825          824   0.19035065E+02
         825          827  -0.63459897E+02
         825          830   0.16101215E-05
         825          815  -0.15622536E-10
         825          817   0.60568005E-10
         825          820  -0.19194389E-14
         825          835  -0.36896078E-10
         825          837   0.14304475E-09
         825          840  -0.45331800E-14
         826          826   0.13434178E+04
         826          821   0.59013355E+02
         826          827   0.16078767E+04
         826          829   0.43198833E-04
         826          811  -0.70350044E-07
         826          816  -0.75652222E-04
         826          817  -0.15002561E-03
         826          831  -0.16614720E-06
         826          836  -0.77802735E-04
         826          837  -0.15257514E-03
         827          827   0.23576218E+04
         827          821   0.56230917E+02
         827          822  -0.21147957E+02
         827          824  -0.65243919E+02
         827          825  -0.63501135E+02
         827          826   0.16078499E+04
         827          828  -0.37173220E-04
         827          829  -0.88911673E-01
         827          830   0.36576037E-01
         827          811  -0.67033335E-07
         827          814   0.21382876E-08
         827          815   0.60582923E-10
         827          816  -0.15001818E-03
         827          817  -0.29877627E-03
         827          818   0.57783842E-14
         827          819   0.10600334E-09
         827          820  -0.43580565E-10
         827          831  -0.15831406E-06
         827          834   0.50500397E-08
         827          835   0.14307999E-09
         827          836  -0.15256767E-03
         827          837  -0.30213920E-03
         827          838   0.13646934E-13
         827          839   0.25035037E-09
         827          840  -0.10292515E-09
         828          828   0.63764140E-04
         828          827  -0.37182501E-04
         828          829  -0.15265093E-04
         828          830  -0.35819545E-04
         828          817   0.57788506E-14
         828          818  -0.85755509E-14
         828          819  -0.10747505E-14
         828          820   0.41540595E-14
         828          837   0.13648035E-13
         828          838  -0.20253062E-13
         828          839  -0.25382613E-14
         828          840   0.98107313E-14
         829          829   0.73397978E+02
         829          826   0.43198833E-04
         829          827  -0.88902781E-01
         829          828  -0.15261490E-04
         829          830   0.24774758E+02
         829          817   0.10599274E-09
         829          818  -0.10747102E-14
         829          819  -0.87498271E-07
         829          820  -0.29534180E-07
         829          837   0.25032533E-09
         829          838  -0.25381662E-14
         829          839  -0.20664654E-06
         829          840  -0.69751505E-07
         830          830   0.99617980E+04
         830          821   0.26821365E+04
         830          822   0.18345824E+03
         830          825   0.16100991E-05
         830          827   0.36576037E-01
         830          828  -0.35810132E-04
         830          829   0.24774758E+02
         830          811  -0.31973963E-05
         830          812  -0.21870206E-06
         830          815  -0.19194122E-14
         830          817  -0.43580565E-10
         830          818   0.41534365E-14
         830          819  -0.29534180E-07
         830          820  -0.11875540E-04
         830          831  -0.75513593E-05
         830          832  -0.51651334E-06
         830          835  -0.45331170E-14
         830          837  -0.10292515E-09
         830          838   0.98092599E-14
         830          839  -0.69751505E-07
         830          840  -0.28046717E-04
         831          831   0.72346101E+04
         831          836   0.59005601E+02
         831          837   0.56223529E+02
         831          840   0.26817841E+04
         831          821  -0.86213980E-05
         831          826  -0.70316015E-07
         831          827  -0.67000910E-07
         831          830  -0.31958497E-05
         831          841  -0.20367830E-04
         831          846  -0.16611977E-06
         831          847  -0.15828792E-06
         831          850  -0.75501125E-05
         832          832   0.45553652E+04
         832          834   0.63450217E+01
         832          835   0.63450217E+01
         832          837  -0.21136331E+02
         832          840   0.18343413E+03
         832          822  -0.54260543E-05
         832          830  -0.21859627E-06
         832          842  -0.12818913E-04
         832          850  -0.51642806E-06
         833          833   0.57674505E+03
         833          823  -0.68730021E-06
         833          843  -0.16237290E-05
         834          834   0.99545436E+03
         834          832   0.63443872E+01
         834          835   0.19035065E+02
         834          837  -0.65202280E+02
         834          824  -0.11635872E-05
         834          827   0.21370396E-08
         834          844  -0.27489448E-05
         834          847   0.50487010E-08
         835          835   0.19048201E+02
         835          832   0.63443872E+01
         835          834   0.19035065E+02
         835          837  -0.63459891E+02
         835          840   0.16099099E-05
         835          825  -0.15614979E-10
         835          827   0.60538708E-10
         835          830  -0.19185105E-14
         835          845  -0.36889986E-10
         835          847   0.14302114E-09
         835          850  -0.45324315E-14
         836          836   0.13432826E+04
         836          831   0.59005601E+02
         836          837   0.16077480E+04
         836          839   0.43198833E-04
         836          821  -0.70316015E-07
         836          826  -0.75754409E-04
         836          827  -0.15023062E-03
         836          841  -0.16611977E-06
         836          846  -0.77885213E-04
         836          847  -0.15274061E-03
         837          837   0.23575049E+04
         837          831   0.56223529E+02
         837          832  -0.21147957E+02
         837          834  -0.65243684E+02
         837          835  -0.63501128E+02
         837          836   0.16077212E+04
         837          838  -0.37172583E-04
         837          839  -0.88899990E-01
         837          840   0.36571234E-01
         837          821  -0.67000910E-07
         837          824   0.21372533E-08
         837          825   0.60553619E-10
         837          826  -0.15022317E-03
         837          827  -0.29918690E-03
         837          828   0.57755891E-14
         837          829   0.10595207E-09
         837          830  -0.43559485E-10
         837          841  -0.15828792E-06
         837          844   0.50492059E-08
         837          845   0.14305636E-09
         837          846  -0.15273312E-03
         837          847  -0.30247063E-03
         837          848   0.13644680E-13
         837          849   0.25030903E-09
         837          850  -0.10290816E-09
         838          838   0.63763195E-04
         838          837  -0.37181865E-04
         838          839  -0.15265212E-04
         838          840  -0.35819088E-04
         838          827   0.57760553E-14
         838          828  -0.85714028E-14
         838          829  -0.10742307E-14
         838          830   0.41520501E-14
         838          847   0.13645782E-13
         838          848  -0.20249718E-13
         838          849  -0.25378422E-14
         838          850   0.98091114E-14
         839          839   0.73388334E+02
         839          836   0.43198833E-04
         839          837  -0.88891100E-01
         839          838  -0.15261609E-04
         839          840   0.24771503E+02
         839          827   0.10594147E-09
         839          828  -0.10741904E-14
         839          829  -0.87455947E-07
         839          830  -0.29519894E-07
         839          847   0.25028400E-09
         839          848  -0.25377471E-14
         839          849  -0.20661242E-06
         839          850  -0.69739988E-07
         840          840   0.99604892E+04
         840          831   0.26817841E+04
         840          832   0.18343413E+03
         840          835   0.16098875E-05
         840          837   0.36571234E-01
         840          838  -0.35809675E-04
         840          839   0.24771503E+02
         840          821  -0.31958497E-05
         840          822  -0.21859627E-06
         840          825  -0.19184838E-14
         840          827  -0.43559485E-10
         840          828   0.41514274E-14
         840          829  -0.29519894E-07
         840          830  -0.11869796E-04
         840          841  -0.75501125E-05
         840          842  -0.51642806E-06
         840          845  -0.45323685E-14
         840          847  -0.10290816E-09
         840          848   0.98076403E-14
         840          849  -0.69739988E-07
         840          850  -0.28042087E-04
         841          841   0.72338435E+04
         841          846   0.58999349E+02
         841          847   0.56217572E+02
         841          850   0.26814999E+04
         841          831  -0.86180344E-05
         841          836  -0.70288582E-07
         841          837  -0.66974771E-07
         841          840  -0.31946029E-05
         841          851  -0.20365119E-04
         841          856  -0.16609766E-06
         841          857  -0.15826685E-06
         841          860  -0.75491073E-05
         842          842   0.45548828E+04
         842          844   0.63450217E+01
         842          845   0.63450217E+01
         842          847  -0.21136331E+02
         842          850   0.18341470E+03
         842          832  -0.54239374E-05
         842          840  -0.21851099E-06
         842          852  -0.12817207E-04
         842          860  -0.51635931E-06
         843          843   0.57668394E+03
         843          833  -0.68703207E-06
         843          853  -0.16235129E-05
         844          844   0.99535090E+03
         844          842   0.63443872E+01
         844          845   0.19035065E+02
         844          847  -0.65202090E+02
         844          834  -0.11631332E-05
         844          837   0.21362059E-08
         844          854  -0.27485788E-05
         844          857   0.50480289E-08
         845          845   0.19048200E+02
         845          842   0.63443872E+01
         845          844   0.19035065E+02
         845          847  -0.63459885E+02
         845          850   0.16097393E-05
         845          835  -0.15608887E-10
         845          837   0.60515089E-10
         845          840  -0.19177620E-14
         845          855  -0.36885075E-10
         845          857   0.14300210E-09
         845          860  -0.45318281E-14
         846          846   0.13431735E+04
         846          841   0.58999349E+02
         846          847   0.16076442E+04
         846          849   0.43198833E-04
         846          831  -0.70288582E-07
         846          836  -0.75836886E-04
         846          837  -0.15039608E-03
         846          851  -0.16609766E-06
         846          856  -0.77951767E-04
         846          857  -0.15287413E-03
         847          847   0.23574106E+04
         847          841   0.56217572E+02
         847          842  -0.21147957E+02
         847          844  -0.65243494E+02
         847          845  -0.63501123E+02
         847          846   0.16076174E+04
         847          848  -0.37172069E-04
         847          849  -0.88890569E-01
         847          850   0.36567360E-01
         847          831  -0.66974771E-07
         847          834   0.21364195E-08
         847          835   0.60529994E-10
         847          836  -0.15038863E-03
         847          837  -0.29951833E-03
         847          838   0.57733358E-14
         847          839   0.10591073E-09
         847          840  -0.43542490E-10
         847          851  -0.15826685E-06
         847          854   0.50485337E-08
         847          855   0.14303732E-09
         847          856  -0.15286663E-03
         847          857  -0.30273807E-03
         847          858   0.13642864E-13
         847          859   0.25027571E-09
         847          860  -0.10289446E-09
         848          848   0.63762433E-04
         848          847  -0.37181351E-04
         848          849  -0.15265307E-04
         848          850  -0.35818718E-04
         848          837   0.57738019E-14
         848          838  -0.85680587E-14
         848          839  -0.10738116E-14
         848          840   0.41504303E-14
         848          857   0.13643965E-13
         848          858  -0.20247022E-13
         848          859  -0.25375044E-14
         848          860   0.98078056E-14
         849          849   0.73380558E+02
         849          846   0.43198833E-04
         849          847  -0.88881680E-01
         849          848  -0.15261704E-04
         849          850   0.24768878E+02
         849          837   0.10590014E-09
         849          838  -0.10737713E-14
         849          839  -0.87421827E-07
         849          840  -0.29508377E-07
         849          857   0.25025068E-09
         849          858  -0.25374092E-14
         849          859  -0.20658491E-06
         849          860  -0.69730703E-07
         850          850   0.99594338E+04
         850          841   0.26814999E+04
         850          842   0.18341470E+03
         850          845   0.16097169E-05
         850          847   0.36567360E-01
         850          848  -0.35809306E-04
         850          849   0.24768878E+02
         850          831  -0.31946029E-05
         850          832  -0.21851099E-06
         850          835  -0.19177353E-14
         850          837  -0.43542490E-10
         850          838   0.41498078E-14
         850          839  -0.29508377E-07
         850          840  -0.11865165E-04
         850          851  -0.75491073E-05
         850          852  -0.51635931E-06
         850          855  -0.45317651E-14
         850          857  -0.10289446E-09
         850          858   0.98063346E-14
         850          859  -0.69730703E-07
         850          860  -0.28038353E-04
         851          851   0.72332254E+04
         851          856   0.58994307E+02
         851          857   0.56212768E+02
         851          860   0.26812708E+04
         851          841  -0.86153229E-05
         851          846  -0.70266466E-07
         851          847  -0.66953698E-07
         851          850  -0.31935977E-05
         851          861  -0.20362933E-04
         851          866  -0.16607983E-06
         851          867  -0.15824986E-06
         851          870  -0.75482970E-05
         852          852   0.45544937E+04
         852          854   0.63450217E+01
         852          855   0.63450217E+01
         852          857  -0.21136331E+02
         852          860   0.18339902E+03
         852          842  -0.54222308E-05
         852          850  -0.21844224E-06
         852          862  -0.12815831E-04
         852          870  -0.51630388E-06
         853          853   0.57663466E+03
         853          843  -0.68681590E-06
         853          863  -0.16233386E-05
         854          854   0.99526747E+03
         854          852   0.63443872E+01
         854          855   0.19035065E+02
         854          857  -0.65201936E+02
         854          844  -0.11627673E-05
         854          847   0.21355337E-08
         854          864  -0.27482838E-05
         854          867   0.50474870E-08
         855          855   0.19048198E+02
         855          852   0.63443872E+01
         855          854   0.19035065E+02
         855          857  -0.63459881E+02
         855          860   0.16096018E-05
         855          845  -0.15603976E-10
         855          847   0.60496049E-10
         855          850  -0.19171586E-14
         855          865  -0.36881116E-10
         855          867   0.14298675E-09
         855          870  -0.45313417E-14
         856          856   0.13430856E+04
         856          851   0.58994307E+02
         856          857   0.16075605E+04
         856          859   0.43198833E-04
         856          841  -0.70266466E-07
         856          846  -0.75903440E-04
         856          847  -0.15052960E-03
         856          861  -0.16607983E-06
         856          866  -0.78005462E-04
         856          867  -0.15298185E-03
         857          857   0.23573345E+04
         857          851   0.56212768E+02
         857          852  -0.21147957E+02
         857          854  -0.65243340E+02
         857          855  -0.63501118E+02
         857          856   0.16075337E+04
         857          858  -0.37171655E-04
         857          859  -0.88882973E-01
         857          860   0.36564237E-01
         857          841  -0.66953698E-07
         857          844   0.21357473E-08
         857          845   0.60510949E-10
         857          846  -0.15052214E-03
         857          847  -0.29978577E-03
         857          848   0.57715193E-14
         857          849   0.10587741E-09
         857          850  -0.43528790E-10
         857          861  -0.15824986E-06
         857          864   0.50479918E-08
         857          865   0.14302196E-09
         857          866  -0.15297435E-03
         857          867  -0.30295384E-03
         857          868   0.13641399E-13
         857          869   0.25024884E-09
         857          870  -0.10288341E-09
         858          858   0.63761818E-04
         858          857  -0.37180937E-04
         858          859  -0.15265384E-04
         858          860  -0.35818421E-04
         858          847   0.57719852E-14
         858          848  -0.85653629E-14
         858          849  -0.10734737E-14
         858          850   0.41491244E-14
         858          867   0.13642501E-13
         858          868  -0.20244849E-13
         858          869  -0.25372320E-14
         858          870   0.98067528E-14
         859          859   0.73374288E+02
         859          856   0.43198833E-04
         859          857  -0.88874084E-01
         859          858  -0.15261781E-04
         859          860   0.24766761E+02
         859          847   0.10586682E-09
         859          848  -0.10734334E-14
         859          849  -0.87394321E-07
         859          850  -0.29499093E-07
         859          867   0.25022382E-09
         859          868  -0.25371369E-14
         859          869  -0.20656274E-06
         859          870  -0.69723219E-07
         860          860   0.99585827E+04
         860          851   0.26812708E+04
         860          852   0.18339902E+03
         860          855   0.16095794E-05
         860          857   0.36564237E-01
         860          858  -0.35809008E-04
         860          859   0.24766761E+02
         860          841  -0.31935977E-05
         860          842  -0.21844224E-06
         860          845  -0.19171319E-14
         860          847  -0.43528790E-10
         860          848   0.41485021E-14
         860          849  -0.29499093E-07
         860          850  -0.11861432E-04
         860          861  -0.75482970E-05
         860          862  -0.51630388E-06
         860          865  -0.45312787E-14
         860          867  -0.10288341E-09
         860          868   0.98052820E-14
         860          869  -0.69723219E-07
         860          870  -0.28035344E-04
         861          861   0.72327270E+04
         861          866   0.58990242E+02
         861          867   0.56208894E+02
         861          870   0.26810861E+04
         861          851  -0.86131369E-05
         861          856  -0.70248638E-07
         861          857  -0.66936710E-07
         861          860  -0.31927874E-05
         861          871  -0.20361171E-04
         861          876  -0.16606545E-06
         861          877  -0.15823617E-06
         861          880  -0.75476438E-05
         862          862   0.45541800E+04
         862          864   0.63450217E+01
         862          865   0.63450217E+01
         862          867  -0.21136331E+02
         862          870   0.18338639E+03
         862          852  -0.54208551E-05
         862          860  -0.21838681E-06
         862          872  -0.12814722E-04
         862          880  -0.51625920E-06
         863          863   0.57659493E+03
         863          853  -0.68664164E-06
         863          873  -0.16231981E-05
         864          864   0.99520021E+03
         864          862   0.63443872E+01
         864          865   0.19035065E+02
         864          867  -0.65201813E+02
         864          854  -0.11624722E-05
         864          857   0.21349919E-08
         864          874  -0.27480459E-05
         864          877   0.50470502E-08
         865          865   0.19048198E+02
         865          862   0.63443872E+01
         865          864   0.19035065E+02
         865          867  -0.63459877E+02
         865          870   0.16094909E-05
         865          855  -0.15600017E-10
         865          857   0.60480699E-10
         865          860  -0.19166721E-14
         865          875  -0.36877924E-10
         865          877   0.14297437E-09
         865          880  -0.45309495E-14
         866          866   0.13430147E+04
         866          861   0.58990242E+02
         866          867   0.16074930E+04
         866          869   0.43198833E-04
         866          851  -0.70248638E-07
         866          856  -0.75957136E-04
         866          857  -0.15063733E-03
         866          871  -0.16606545E-06
         866          876  -0.78048778E-04
         866          877  -0.15306875E-03
         867          867   0.23572732E+04
         867          861   0.56208894E+02
         867          862  -0.21147957E+02
         867          864  -0.65243217E+02
         867          865  -0.63501115E+02
         867          866   0.16074662E+04
         867          868  -0.37171321E-04
         867          869  -0.88876848E-01
         867          870   0.36561719E-01
         867          851  -0.66936710E-07
         867          854   0.21352054E-08
         867          855   0.60495596E-10
         867          856  -0.15062986E-03
         867          857  -0.30000154E-03
         867          858   0.57700549E-14
         867          859   0.10585055E-09
         867          860  -0.43517746E-10
         867          871  -0.15823617E-06
         867          874   0.50475549E-08
         867          875   0.14300959E-09
         867          876  -0.15306125E-03
         867          877  -0.30312789E-03
         867          878   0.13640219E-13
         867          879   0.25022719E-09
         867          880  -0.10287451E-09
         868          868   0.63761322E-04
         868          867  -0.37180603E-04
         868          869  -0.15265446E-04
         868          870  -0.35818181E-04
         868          857   0.57705207E-14
         868          858  -0.85631896E-14
         868          859  -0.10732013E-14
         868          860   0.41480716E-14
         868          877   0.13641320E-13
         868          878  -0.20243097E-13
         868          879  -0.25370124E-14
         868          880   0.98059041E-14
         869          869   0.73369232E+02
         869          866   0.43198833E-04
         869          867  -0.88867959E-01
         869          868  -0.15261843E-04
         869          870   0.24765055E+02
         869          857   0.10583996E-09
         869          858  -0.10731611E-14
         869          859  -0.87372147E-07
         869          860  -0.29491608E-07
         869          877   0.25020217E-09
         869          878  -0.25369173E-14
         869          879  -0.20654486E-06
         869          880  -0.69717185E-07
         870          870   0.99578965E+04
         870          861   0.26810861E+04
         870          862   0.18338639E+03
         870          865   0.16094685E-05
         870          867   0.36561719E-01
         870          868  -0.35808768E-04
         870          869   0.24765055E+02
         870          851  -0.31927874E-05
         870          852  -0.21838681E-06
         870          855  -0.19166455E-14
         870          857  -0.43517746E-10
         870          858   0.41474495E-14
         870          859  -0.29491608E-07
         870          860  -0.11858422E-04
         870          871  -0.75476438E-05
         870          872  -0.51625920E-06
         870          875  -0.45308865E-14
         870          877  -0.10287451E-09
         870          878   0.98044334E-14
         870          879  -0.69717185E-07
         870          880  -0.28032918E-04
         871          871   0.72323251E+04
         871          876   0.58986965E+02
         871          877   0.56205771E+02
         871          880   0.26809371E+04
         871          861  -0.86113746E-05
         871          866  -0.70234265E-07
         871          867  -0.66923014E-07
         871          870  -0.31921342E-05
         871          881  -0.20359750E-04
         871          886  -0.16605387E-06
         871          887  -0.15822513E-06
         871          890  -0.75471171E-05
         872          872   0.45539271E+04
         872          874   0.63450217E+01
         872          875   0.63450217E+01
         872          877  -0.21136331E+02
         872          880   0.18337620E+03
         872          862  -0.54197459E-05
         872          870  -0.21834213E-06
         872          882  -0.12813828E-04
         872          890  -0.51622318E-06
         873          873   0.57656289E+03
         873          863  -0.68650115E-06
         873          883  -0.16230849E-05
         874          874   0.99514597E+03
         874          872   0.63443872E+01
         874          875   0.19035065E+02
         874          877  -0.65201713E+02
         874          864  -0.11622344E-05
         874          867   0.21345551E-08
         874          884  -0.27478542E-05
         874          887   0.50466980E-08
         875          875   0.19048197E+02
         875          872   0.63443872E+01
         875          874   0.19035065E+02
         875          877  -0.63459875E+02
         875          880   0.16094014E-05
         875          865  -0.15596825E-10
         875          867   0.60468325E-10
         875          870  -0.19162800E-14
         875          885  -0.36875351E-10
         875          887   0.14296440E-09
         875          890  -0.45306334E-14
         876          876   0.13429575E+04
         876          871   0.58986965E+02
         876          877   0.16074386E+04
         876          879   0.43198833E-04
         876          861  -0.70234265E-07
         876          866  -0.76000451E-04
         876          867  -0.15072422E-03
         876          881  -0.16605387E-06
         876          886  -0.78083715E-04
         876          887  -0.15313884E-03
         877          877   0.23572238E+04
         877          871   0.56205771E+02
         877          872  -0.21147957E+02
         877          874  -0.65243117E+02
         877          875  -0.63501112E+02
         877          876   0.16074118E+04
         877          878  -0.37171052E-04
         877          879  -0.88871909E-01
         877          880   0.36559689E-01
         877          861  -0.66923014E-07
         877          864   0.21347685E-08
         877          865   0.60483218E-10
         877          866  -0.15071675E-03
         877          867  -0.30017559E-03
         877          868   0.57688744E-14
         877          869   0.10582889E-09
         877          870  -0.43508842E-10
         877          881  -0.15822513E-06
         877          884   0.50472027E-08
         877          885   0.14299961E-09
         877          886  -0.15313133E-03
         877          887  -0.30326828E-03
         877          888   0.13639267E-13
         877          889   0.25020973E-09
         877          890  -0.10286733E-09
         878          878   0.63760923E-04
         878          877  -0.37180334E-04
         878          879  -0.15265496E-04
         878          880  -0.35817987E-04
         878          867   0.57693400E-14
         878          868  -0.85614376E-14
         878          869  -0.10729817E-14
         878          870   0.41472229E-14
         878          887   0.13640368E-13
         878          888  -0.20241684E-13
         878          889  -0.25368354E-14
         878          890   0.98052199E-14
         879          879   0.73365155E+02
         879          876   0.43198833E-04
         879          877  -0.88863021E-01
         879          878  -0.15261893E-04
         879          880   0.24763679E+02
         879          867   0.10581831E-09
         879          868  -0.10729415E-14
         879          869  -0.87354270E-07
         879          870  -0.29485574E-07
         879          887   0.25018471E-09
         879          888  -0.25367403E-14
         879          889  -0.20653045E-06
         879          890  -0.69712320E-07
         880          880   0.99573432E+04
         880          871   0.26809371E+04
         880          872   0.18337620E+03
         880          875   0.16093791E-05
         880          877   0.36559689E-01
         880          878  -0.35808574E-04
         880          879   0.24763679E+02
         880          861  -0.31921342E-05
         880          862  -0.21834213E-06
         880          865  -0.19162533E-14
         880          867  -0.43508842E-10
         880          868   0.41466009E-14
         880          869  -0.29485574E-07
         880          870  -0.11855996E-04
         880          881  -0.75471171E-05
         880          882  -0.51622318E-06
         880          885  -0.45305704E-14
         880          887  -0.10286733E-09
         880          888   0.98037493E-14
         880          889  -0.69712320E-07
         880          890  -0.28030962E-04
         881          881   0.72320011E+04
         881          886   0.58984322E+02
         881          887   0.56203253E+02
         881          890   0.26808170E+04
         881          871  -0.86099539E-05
         881          876  -0.70222677E-07
         881          877  -0.66911973E-07
         881          880  -0.31916075E-05
         881          891  -0.20358605E-04
         881          896  -0.16604453E-06
         881          897  -0.15821622E-06
         881          900  -0.75466926E-05
         882          882   0.45537232E+04
         882          884   0.63450217E+01
         882          885   0.63450217E+01
         882          887  -0.21136331E+02
         882          890   0.18336798E+03
         882          872  -0.54188518E-05
         882          880  -0.21830611E-06
         882          892  -0.12813107E-04
         882          900  -0.51619414E-06
         883          883   0.57653706E+03
         883          873  -0.68638789E-06
         883          893  -0.16229935E-05
         884          884   0.99510224E+03
         884          882   0.63443872E+01
         884          885   0.19035065E+02
         884          887  -0.65201633E+02
         884          874  -0.11620427E-05
         884          877   0.21342029E-08
         884          894  -0.27476996E-05
         884          897   0.50464141E-08
         885          885   0.19048196E+02
         885          882   0.63443872E+01
         885          884   0.19035065E+02
         885          887  -0.63459872E+02
         885          890   0.16093293E-05
         885          875  -0.15594252E-10
         885          877   0.60458349E-10
         885          880  -0.19159638E-14
         885          895  -0.36873276E-10
         885          897   0.14295635E-09
         885          900  -0.45303785E-14
         886          886   0.13429114E+04
         886          881   0.58984322E+02
         886          887   0.16073947E+04
         886          889   0.43198833E-04
         886          871  -0.70222677E-07
         886          876  -0.76035389E-04
         886          877  -0.15079431E-03
         886          891  -0.16604453E-06
         886          896  -0.78111892E-04
         886          897  -0.15319537E-03
         887          887   0.23571839E+04
         887          881   0.56203253E+02
         887          882  -0.21147957E+02
         887          884  -0.65243037E+02
         887          885  -0.63501110E+02
         887          886   0.16073679E+04
         887          888  -0.37170835E-04
         887          889  -0.88867927E-01
         887          890   0.36558052E-01
         887          871  -0.66911973E-07
         887          874   0.21344163E-08
         887          875   0.60473240E-10
         887          876  -0.15078684E-03
         887          877  -0.30031598E-03
         887          878   0.57679226E-14
         887          879   0.10581143E-09
         887          880  -0.43501664E-10
         887          891  -0.15821622E-06
         887          894   0.50469188E-08
         887          895   0.14299156E-09
         887          896  -0.15318786E-03
         887          897  -0.30338151E-03
         887          898   0.13638500E-13
         887          899   0.25019565E-09
         887          900  -0.10286155E-09
         888          888   0.63760601E-04
         888          887  -0.37180117E-04
         888          889  -0.15265537E-04
         888          890  -0.35817831E-04
         888          877   0.57683882E-14
         888          878  -0.85600251E-14
         888          879  -0.10728047E-14
         888          880   0.41465387E-14
         888          897   0.13639601E-13
         888          898  -0.20240546E-13
         888          899  -0.25366927E-14
         888          900   0.98046683E-14
         889          889   0.73361868E+02
         889          886   0.43198833E-04
         889          887  -0.88859039E-01
         889          888  -0.15261934E-04
         889          890   0.24762569E+02
         889          877   0.10580085E-09
         889          878  -0.10727645E-14
         889          879  -0.87339858E-07
         889          880  -0.29480709E-07
         889          897   0.25017063E-09
         889          898  -0.25365976E-14
         889          899  -0.20651883E-06
         889          900  -0.69708398E-07
         890          890   0.99568971E+04
         890          881   0.26808170E+04
         890          882   0.18336798E+03
         890          885   0.16093070E-05
         890          887   0.36558052E-01
         890          888  -0.35808418E-04
         890          889   0.24762569E+02
         890          871  -0.31916075E-05
         890          872  -0.21830611E-06
         890          875  -0.19159372E-14
         890          877  -0.43501664E-10
         890          878   0.41459168E-14
         890          879  -0.29480709E-07
         890          880  -0.11854040E-04
         890          891  -0.75466926E-05
         890          892  -0.51619414E-06
         890          895  -0.45303155E-14
         890          897  -0.10286155E-09
         890          898   0.98031978E-14
         890          899  -0.69708398E-07
         890          900  -0.28029385E-04
         891          891   0.72317399E+04
         891          896   0.58982191E+02
         891          897   0.56201223E+02
         891          900   0.26807201E+04
         891          881  -0.86088086E-05
         891          886  -0.70213336E-07
         891          887  -0.66903072E-07
         891          890  -0.31911829E-05
         891          901  -0.20357681E-04
         891          906  -0.16603699E-06
         891          907  -0.15820905E-06
         891          910  -0.75463503E-05
         892          892   0.45535588E+04
         892          894   0.63450217E+01
         892          895   0.63450217E+01
         892          897  -0.21136331E+02
         892          900   0.18336136E+03
         892          882  -0.54181309E-05
         892          890  -0.21827707E-06
         892          902  -0.12812526E-04
         892          910  -0.51617072E-06
         893          893   0.57651623E+03
         893          883  -0.68629658E-06
         893          903  -0.16229199E-05
         894          894   0.99506698E+03
         894          892   0.63443872E+01
         894          895   0.19035065E+02
         894          897  -0.65201568E+02
         894          884  -0.11618881E-05
         894          887   0.21339190E-08
         894          904  -0.27475750E-05
         894          907   0.50461852E-08
         895          895   0.19048196E+02
         895          892   0.63443872E+01
         895          894   0.19035065E+02
         895          897  -0.63459871E+02
         895          900   0.16092712E-05
         895          885  -0.15592178E-10
         895          887   0.60450306E-10
         895          890  -0.19157090E-14
         895          905  -0.36871604E-10
         895          907   0.14294987E-09
         895          910  -0.45301730E-14
         896          896   0.13428742E+04
         896          891   0.58982191E+02
         896          897   0.16073593E+04
         896          899   0.43198833E-04
         896          881  -0.70213336E-07
         896          886  -0.76063566E-04
         896          887  -0.15085084E-03
         896          901  -0.16603699E-06
         896          906  -0.78134616E-04
         896          907  -0.15324095E-03
         897          897   0.23571518E+04
         897          891   0.56201223E+02
         897          892  -0.21147957E+02
         897          894  -0.65242972E+02
         897          895  -0.63501108E+02
         897          896   0.16073325E+04
         897          898  -0.37170660E-04
         897          899  -0.88864716E-01
         897          900   0.36556732E-01
         897          881  -0.66903072E-07
         897          884   0.21341324E-08
         897          885   0.60465195E-10
         897          886  -0.15084336E-03
         897          887  -0.30042921E-03
         897          888   0.57671553E-14
         897          889   0.10579735E-09
         897          890  -0.43495877E-10
         897          901  -0.15820905E-06
         897          904   0.50466899E-08
         897          905   0.14298508E-09
         897          906  -0.15323344E-03
         897          907  -0.30347282E-03
         897          908   0.13637881E-13
         897          909   0.25018430E-09
         897          910  -0.10285688E-09
         898          898   0.63760341E-04
         898          897  -0.37179942E-04
         898          899  -0.15265569E-04
         898          900  -0.35817705E-04
         898          887   0.57676208E-14
         898          888  -0.85588864E-14
         898          889  -0.10726620E-14
         898          890   0.41459871E-14
         898          907   0.13638982E-13
         898          908  -0.20239628E-13
         898          909  -0.25365776E-14
         898          910   0.98042236E-14
         899          899   0.73359218E+02
         899          896   0.43198833E-04
         899          897  -0.88855829E-01
         899          898  -0.15261966E-04
         899          900   0.24761675E+02
         899          887   0.10578677E-09
         899          888  -0.10726218E-14
         899          889  -0.87328240E-07
         899          890  -0.29476787E-07
         899          907   0.25015929E-09
         899          908  -0.25364825E-14
         899          909  -0.20650947E-06
         899          910  -0.69705237E-07
         900          900   0.99565375E+04
         900          891   0.26807201E+04
         900          892   0.18336136E+03
         900          895   0.16092488E-05
         900          897   0.36556732E-01
         900          898  -0.35808293E-04
         900          899   0.24761675E+02
         900          881  -0.31911829E-05
         900          882  -0.21827707E-06
         900          885  -0.19156823E-14
         900          887  -0.43495877E-10
         900          888   0.41453653E-14
         900          889  -0.29476787E-07
         900          890  -0.11852463E-04
         900          901  -0.75463503E-05
         900          902  -0.51617072E-06
         900          905  -0.45301100E-14
         900          907  -0.10285688E-09
         900          908   0.98027532E-14
         900          909  -0.69705237E-07
         900          910  -0.28028113E-04
         901          901   0.72315292E+04
         901          906   0.58980474E+02
         901          907   0.56199586E+02
         901          910   0.26806421E+04
         901          891  -0.86078852E-05
         901          896  -0.70205805E-07
         901          897  -0.66895896E-07
         901          900  -0.31908407E-05
         901          911  -0.20356937E-04
         901          916  -0.16603092E-06
         901          917  -0.15820326E-06
         901          920  -0.75460743E-05
         902          902   0.45534262E+04
         902          904   0.63450217E+01
         902          905   0.63450217E+01
         902          907  -0.21136331E+02
         902          910   0.18335602E+03
         902          892  -0.54175498E-05
         902          900  -0.21825366E-06
         902          912  -0.12812057E-04
         902          920  -0.51615185E-06
         903          903   0.57649944E+03
         903          893  -0.68622297E-06
         903          913  -0.16228606E-05
         904          904   0.99503855E+03
         904          902   0.63443872E+01
         904          905   0.19035065E+02
         904          907  -0.65201516E+02
         904          894  -0.11617635E-05
         904          897   0.21336901E-08
         904          914  -0.27474745E-05
         904          917   0.50460007E-08
         905          905   0.19048195E+02
         905          902   0.63443872E+01
         905          904   0.19035065E+02
         905          907  -0.63459869E+02
         905          910   0.16092243E-05
         905          895  -0.15590505E-10
         905          897   0.60443822E-10
         905          900  -0.19155035E-14
         905          915  -0.36870256E-10
         905          917   0.14294464E-09
         905          920  -0.45300074E-14
         906          906   0.13428443E+04
         906          901   0.58980474E+02
         906          907   0.16073308E+04
         906          909   0.43198833E-04
         906          891  -0.70205805E-07
         906          896  -0.76086290E-04
         906          897  -0.15089643E-03
         906          911  -0.16603092E-06
         906          916  -0.78152941E-04
         906          917  -0.15327772E-03
         907          907   0.23571259E+04
         907          901   0.56199586E+02
         907          902  -0.21147957E+02
         907          904  -0.65242920E+02
         907          905  -0.63501106E+02
         907          906   0.16073040E+04
         907          908  -0.37170519E-04
         907          909  -0.88862128E-01
         907          910   0.36555667E-01
         907          891  -0.66895896E-07
         907          894   0.21339035E-08
         907          895   0.60458710E-10
         907          896  -0.15088895E-03
         907          897  -0.30052052E-03
         907          898   0.57665367E-14
         907          899   0.10578600E-09
         907          900  -0.43491212E-10
         907          911  -0.15820326E-06
         907          914   0.50465053E-08
         907          915   0.14297985E-09
         907          916  -0.15327020E-03
         907          917  -0.30354645E-03
         907          918   0.13637383E-13
         907          919   0.25017515E-09
         907          920  -0.10285312E-09
         908          908   0.63760132E-04
         908          907  -0.37179800E-04
         908          909  -0.15265596E-04
         908          910  -0.35817604E-04
         908          897   0.57670022E-14
         908          898  -0.85579684E-14
         908          899  -0.10725470E-14
         908          900   0.41455424E-14
         908          917   0.13638483E-13
         908          918  -0.20238888E-13
         908          919  -0.25364849E-14
         908          920   0.98038651E-14
         909          909   0.73357082E+02
         909          906   0.43198833E-04
         909          907  -0.88853241E-01
         909          908  -0.15261993E-04
         909          910   0.24760954E+02
         909          897   0.10577543E-09
         909          898  -0.10725067E-14
         909          899  -0.87318873E-07
         909          900  -0.29473626E-07
         909          917   0.25015014E-09
         909          918  -0.25363898E-14
         909          919  -0.20650192E-06
         909          920  -0.69702688E-07
         910          910   0.99562475E+04
         910          901   0.26806421E+04
         910          902   0.18335602E+03
         910          905   0.16092019E-05
         910          907   0.36555667E-01
         910          908  -0.35808191E-04
         910          909   0.24760954E+02
         910          891  -0.31908407E-05
         910          892  -0.21825366E-06
         910          895  -0.19154769E-14
         910          897  -0.43491212E-10
         910          898   0.41449207E-14
         910          899  -0.29473626E-07
         910          900  -0.11851192E-04
         910          911  -0.75460743E-05
         910          912  -0.51615185E-06
         910          915  -0.45299444E-14
         910          917  -0.10285312E-09
         910          918   0.98023947E-14
         910          919  -0.69702688E-07
         910          920  -0.28027088E-04
         911          911   0.72313594E+04
         911          916   0.58979089E+02
         911          917   0.56198267E+02
         911          920   0.26805791E+04
         911          901  -0.86071408E-05
         911          906  -0.70199734E-07
         911          907  -0.66890111E-07
         911          910  -0.31905647E-05
         911          921  -0.20356337E-04
         911          926  -0.16602603E-06
         911          927  -0.15819860E-06
         911          930  -0.75458519E-05
         912          912   0.45533193E+04
         912          914   0.63450217E+01
         912          915   0.63450217E+01
         912          917  -0.21136331E+02
         912          920   0.18335171E+03
         912          902  -0.54170813E-05
         912          910  -0.21823478E-06
         912          922  -0.12811680E-04
         912          930  -0.51613663E-06
         913          913   0.57648591E+03
         913          903  -0.68616363E-06
         913          923  -0.16228127E-05
         914          914   0.99501563E+03
         914          912   0.63443872E+01
         914          915   0.19035065E+02
         914          917  -0.65201474E+02
         914          904  -0.11616630E-05
         914          907   0.21335056E-08
         914          924  -0.27473935E-05
         914          927   0.50458520E-08
         915          915   0.19048195E+02
         915          912   0.63443872E+01
         915          914   0.19035065E+02
         915          917  -0.63459868E+02
         915          920   0.16091865E-05
         915          905  -0.15589157E-10
         915          907   0.60438595E-10
         915          910  -0.19153378E-14
         915          925  -0.36869169E-10
         915          927   0.14294043E-09
         915          930  -0.45298738E-14
         916          916   0.13428201E+04
         916          911   0.58979089E+02
         916          917   0.16073078E+04
         916          919   0.43198833E-04
         916          901  -0.70199734E-07
         916          906  -0.76104614E-04
         916          907  -0.15093319E-03
         916          921  -0.16602603E-06
         916          926  -0.78167717E-04
         916          927  -0.15330736E-03
         917          917   0.23571050E+04
         917          911   0.56198267E+02
         917          912  -0.21147957E+02
         917          914  -0.65242878E+02
         917          915  -0.63501105E+02
         917          916   0.16072810E+04
         917          918  -0.37170405E-04
         917          919  -0.88860041E-01
         917          920   0.36554809E-01
         917          901  -0.66890111E-07
         917          904   0.21337190E-08
         917          905   0.60453482E-10
         917          906  -0.15092571E-03
         917          907  -0.30059415E-03
         917          908   0.57660381E-14
         917          909   0.10577686E-09
         917          910  -0.43487451E-10
         917          921  -0.15819860E-06
         917          924   0.50463565E-08
         917          925   0.14297563E-09
         917          926  -0.15329984E-03
         917          927  -0.30360583E-03
         917          928   0.13636981E-13
         917          929   0.25016778E-09
         917          930  -0.10285009E-09
         918          918   0.63759963E-04
         918          917  -0.37179687E-04
         918          919  -0.15265617E-04
         918          920  -0.35817522E-04
         918          907   0.57665035E-14
         918          908  -0.85572283E-14
         918          909  -0.10724542E-14
         918          910   0.41451839E-14
         918          927   0.13638081E-13
         918          928  -0.20238291E-13
         918          929  -0.25364101E-14
         918          930   0.98035761E-14
         919          919   0.73355359E+02
         919          916   0.43198833E-04
         919          917  -0.88851154E-01
         919          918  -0.15262014E-04
         919          920   0.24760372E+02
         919          907   0.10576628E-09
         919          908  -0.10724140E-14
         919          909  -0.87311322E-07
         919          910  -0.29471077E-07
         919          927   0.25014276E-09
         919          928  -0.25363150E-14
         919          929  -0.20649583E-06
         919          930  -0.69700633E-07
         920          920   0.99560137E+04
         920          911   0.26805791E+04
         920          912   0.18335171E+03
         920          915   0.16091642E-05
         920          917   0.36554809E-01
         920          918  -0.35808109E-04
         920          919   0.24760372E+02
         920          901  -0.31905647E-05
         920          902  -0.21823478E-06
         920          905  -0.19153112E-14
         920          907  -0.43487451E-10
         920          908   0.41445622E-14
         920          909  -0.29471077E-07
         920          910  -0.11850167E-04
         920          921  -0.75458519E-05
         920          922  -0.51613663E-06
         920          925  -0.45298108E-14
         920          927  -0.10285009E-09
         920          928   0.98021057E-14
         920          929  -0.69700633E-07
         920          930  -0.28026262E-04
         921          921   0.72312225E+04
         921          926   0.58977972E+02
         921          927   0.56197203E+02
         921          930   0.26805284E+04
         921          911  -0.86065407E-05
         921          916  -0.70194839E-07
         921          917  -0.66885447E-07
         921          920  -0.31903423E-05
         921          931  -0.20355853E-04
         921          936  -0.16602208E-06
         921          937  -0.15819484E-06
         921          940  -0.75456725E-05
         922          922   0.45532332E+04
         922          924   0.63450217E+01
         922          925   0.63450217E+01
         922          927  -0.21136331E+02
         922          930   0.18334824E+03
         922          912  -0.54167036E-05
         922          920  -0.21821957E-06
         922          932  -0.12811375E-04
         922          940  -0.51612437E-06
         923          923   0.57647499E+03
         923          913  -0.68611579E-06
         923          933  -0.16227742E-05
         924          924   0.99499716E+03
         924          922   0.63443872E+01
         924          925   0.19035065E+02
         924          927  -0.65201440E+02
         924          914  -0.11615820E-05
         924          917   0.21333568E-08
         924          934  -0.27473282E-05
         924          937   0.50457320E-08
         925          925   0.19048195E+02
         925          922   0.63443872E+01
         925          924   0.19035065E+02
         925          927  -0.63459867E+02
         925          930   0.16091561E-05
         925          915  -0.15588070E-10
         925          917   0.60434381E-10
         925          920  -0.19152043E-14
         925          935  -0.36868292E-10
         925          937   0.14293703E-09
         925          940  -0.45297662E-14
         926          926   0.13428006E+04
         926          921   0.58977972E+02
         926          927   0.16072893E+04
         926          929   0.43198833E-04
         926          911  -0.70194839E-07
         926          916  -0.76119390E-04
         926          917  -0.15096284E-03
         926          931  -0.16602208E-06
         926          936  -0.78179631E-04
         926          937  -0.15333126E-03
         927          927   0.23570882E+04
         927          921   0.56197203E+02
         927          922  -0.21147957E+02
         927          924  -0.65242844E+02
         927          925  -0.63501104E+02
         927          926   0.16072625E+04
         927          928  -0.37170314E-04
         927          929  -0.88858359E-01
         927          930   0.36554118E-01
         927          911  -0.66885447E-07
         927          914   0.21335702E-08
         927          915   0.60449266E-10
         927          916  -0.15095535E-03
         927          917  -0.30065353E-03
         927          918   0.57656360E-14
         927          919   0.10576948E-09
         927          920  -0.43484418E-10
         927          931  -0.15819484E-06
         927          934   0.50462366E-08
         927          935   0.14297224E-09
         927          936  -0.15332375E-03
         927          937  -0.30365370E-03
         927          938   0.13636656E-13
         927          939   0.25016183E-09
         927          940  -0.10284764E-09
         928          928   0.63759827E-04
         928          927  -0.37179595E-04
         928          929  -0.15265634E-04
         928          930  -0.35817456E-04
         928          917   0.57661014E-14
         928          918  -0.85566317E-14
         928          919  -0.10723794E-14
         928          920   0.41448949E-14
         928          937   0.13637757E-13
         928          938  -0.20237810E-13
         928          939  -0.25363498E-14
         928          940   0.98033431E-14
         929          929   0.73353970E+02
         929          926   0.43198833E-04
         929          927  -0.88849472E-01
         929          928  -0.15262031E-04
         929          930   0.24759903E+02
         929          917   0.10575891E-09
         929          918  -0.10723392E-14
         929          919  -0.87305234E-07
         929          920  -0.29469022E-07
         929          937   0.25013682E-09
         929          938  -0.25362547E-14
         929          939  -0.20649092E-06
         929          940  -0.69698976E-07
         930          930   0.99558252E+04
         930          921   0.26805284E+04
         930          922   0.18334824E+03
         930          925   0.16091337E-05
         930          927   0.36554118E-01
         930          928  -0.35808043E-04
         930          929   0.24759903E+02
         930          911  -0.31903423E-05
         930          912  -0.21821957E-06
         930          915  -0.19151777E-14
         930          917  -0.43484418E-10
         930          918   0.41442733E-14
         930          919  -0.29469022E-07
         930          920  -0.11849341E-04
         930          931  -0.75456725E-05
         930          932  -0.51612437E-06
         930          935  -0.45297032E-14
         930          937  -0.10284764E-09
         930          938   0.98018728E-14
         930          939  -0.69698976E-07
         930          940  -0.28025596E-04
         931          931   0.72311121E+04
         931          936   0.58977072E+02
         931          937   0.56196345E+02
         931          940   0.26804875E+04
         931          921  -0.86060569E-05
         931          926  -0.70190893E-07
         931          927  -0.66881687E-07
         931          930  -0.31901629E-05
         931          941  -0.20355463E-04
         931          946  -0.16601890E-06
         931          947  -0.15819181E-06
         931          950  -0.75455279E-05
         932          932   0.45531637E+04
         932          934   0.63450217E+01
         932          935   0.63450217E+01
         932          937  -0.21136331E+02
         932          940   0.18334544E+03
         932          922  -0.54163991E-05
         932          930  -0.21820730E-06
         932          942  -0.12811130E-04
         932          950  -0.51611448E-06
         933          933   0.57646619E+03
         933          923  -0.68607722E-06
         933          943  -0.16227431E-05
         934          934   0.99498226E+03
         934          932   0.63443872E+01
         934          935   0.19035065E+02
         934          937  -0.65201413E+02
         934          924  -0.11615167E-05
         934          927   0.21332369E-08
         934          944  -0.27472756E-05
         934          947   0.50456353E-08
         935          935   0.19048195E+02
         935          932   0.63443872E+01
         935          934   0.19035065E+02
         935          937  -0.63459866E+02
         935          940   0.16091315E-05
         935          925  -0.15587194E-10
         935          927   0.60430984E-10
         935          930  -0.19150966E-14
         935          945  -0.36867586E-10
         935          947   0.14293429E-09
         935          950  -0.45296794E-14
         936          936   0.13427849E+04
         936          931   0.58977072E+02
         936          937   0.16072743E+04
         936          939   0.43198833E-04
         936          921  -0.70190893E-07
         936          926  -0.76131305E-04
         936          927  -0.15098674E-03
         936          941  -0.16601890E-06
         936          946  -0.78189238E-04
         936          947  -0.15335053E-03
         937          937   0.23570746E+04
         937          931   0.56196345E+02
         937          932  -0.21147957E+02
         937          934  -0.65242817E+02
         937          935  -0.63501103E+02
         937          936   0.16072475E+04
         937          938  -0.37170240E-04
         937          939  -0.88857002E-01
         937          940   0.36553560E-01
         937          921  -0.66881687E-07
         937          924   0.21334502E-08
         937          925   0.60445868E-10
         937          926  -0.15097925E-03
         937          927  -0.30070140E-03
         937          928   0.57653119E-14
         937          929   0.10576354E-09
         937          930  -0.43481974E-10
         937          941  -0.15819181E-06
         937          944   0.50461399E-08
         937          945   0.14296950E-09
         937          946  -0.15334302E-03
         937          947  -0.30369230E-03
         937          948   0.13636395E-13
         937          949   0.25015704E-09
         937          950  -0.10284567E-09
         938          938   0.63759717E-04
         938          937  -0.37179521E-04
         938          939  -0.15265648E-04
         938          940  -0.35817403E-04
         938          927   0.57657773E-14
         938          928  -0.85561506E-14
         938          929  -0.10723191E-14
         938          930   0.41446619E-14
         938          947   0.13637496E-13
         938          948  -0.20237422E-13
         938          949  -0.25363012E-14
         938          950   0.98031552E-14
         939          939   0.73352851E+02
         939          936   0.43198833E-04
         939          937  -0.88848116E-01
         939          938  -0.15262045E-04
         939          940   0.24759525E+02
         939          927   0.10575296E-09
         939          928  -0.10722789E-14
         939          929  -0.87300326E-07
         939          930  -0.29467365E-07
         939          947   0.25013203E-09
         939          948  -0.25362061E-14
         939          949  -0.20648696E-06
         939          950  -0.69697641E-07
         940          940   0.99556732E+04
         940          931   0.26804875E+04
         940          932   0.18334544E+03
         940          935   0.16091091E-05
         940          937   0.36553560E-01
         940          938  -0.35807990E-04
         940          939   0.24759525E+02
         940          921  -0.31901629E-05
         940          922  -0.21820730E-06
         940          925  -0.19150700E-14
         940          927  -0.43481974E-10
         940          928   0.41440403E-14
         940          929  -0.29467365E-07
         940          930  -0.11848674E-04
         940          941  -0.75455279E-05
         940          942  -0.51611448E-06
         940          945  -0.45296164E-14
         940          947  -0.10284567E-09
         940          948   0.98016849E-14
         940          949  -0.69697641E-07
         940          950  -0.28025059E-04
         941          941   0.72310231E+04
         941          946   0.58976346E+02
         941          947   0.56195653E+02
         941          950   0.26804545E+04
         941          931  -0.86056668E-05
         941          936  -0.70187712E-07
         941          937  -0.66878656E-07
         941          940  -0.31900183E-05
         941          951  -0.20355148E-04
         941          956  -0.16601634E-06
         941          957  -0.15818936E-06
         941          960  -0.75454114E-05
         942          942   0.45531077E+04
         942          944   0.63450217E+01
         942          945   0.63450217E+01
         942          947  -0.21136331E+02
         942          950   0.18334319E+03
         942          932  -0.54161536E-05
         942          940  -0.21819741E-06
         942          952  -0.12810932E-04
         942          960  -0.51610650E-06
         943          943   0.57645910E+03
         943          933  -0.68604612E-06
         943          953  -0.16227180E-05
         944          944   0.99497025E+03
         944          942   0.63443872E+01
         944          945   0.19035065E+02
         944          947  -0.65201390E+02
         944          934  -0.11614640E-05
         944          937   0.21331402E-08
         944          954  -0.27472331E-05
         944          957   0.50455574E-08
         945          945   0.19048194E+02
         945          942   0.63443872E+01
         945          944   0.19035065E+02
         945          947  -0.63459865E+02
         945          950   0.16091117E-05
         945          935  -0.15586487E-10
         945          937   0.60428245E-10
         945          940  -0.19150098E-14
         945          955  -0.36867016E-10
         945          957   0.14293208E-09
         945          960  -0.45296094E-14
         946          946   0.13427723E+04
         946          941   0.58976346E+02
         946          947   0.16072623E+04
         946          949   0.43198833E-04
         946          931  -0.70187712E-07
         946          936  -0.76140911E-04
         946          937  -0.15100601E-03
         946          951  -0.16601634E-06
         946          956  -0.78196983E-04
         946          957  -0.15336607E-03
         947          947   0.23570637E+04
         947          941   0.56195653E+02
         947          942  -0.21147957E+02
         947          944  -0.65242794E+02
         947          945  -0.63501103E+02
         947          946   0.16072355E+04
         947          948  -0.37170180E-04
         947          949  -0.88855908E-01
         947          950   0.36553110E-01
         947          931  -0.66878656E-07
         947          934   0.21333535E-08
         947          935   0.60443129E-10
         947          936  -0.15099852E-03
         947          937  -0.30074001E-03
         947          938   0.57650506E-14
         947          939   0.10575874E-09
         947          940  -0.43480003E-10
         947          951  -0.15818936E-06
         947          954   0.50460620E-08
         947          955   0.14296729E-09
         947          956  -0.15335855E-03
         947          957  -0.30372343E-03
         947          958   0.13636184E-13
         947          959   0.25015318E-09
         947          960  -0.10284408E-09
         948          948   0.63759628E-04
         948          947  -0.37179461E-04
         948          949  -0.15265659E-04
         948          950  -0.35817360E-04
         948          937   0.57655160E-14
         948          938  -0.85557629E-14
         948          939  -0.10722705E-14
         948          940   0.41444741E-14
         948          957   0.13637285E-13
         948          958  -0.20237110E-13
         948          959  -0.25362620E-14
         948          960   0.98030038E-14
         949          949   0.73351948E+02
         949          946   0.43198833E-04
         949          947  -0.88847022E-01
         949          948  -0.15262056E-04
         949          950   0.24759221E+02
         949          937   0.10574817E-09
         949          938  -0.10722303E-14
         949          939  -0.87296370E-07
         949          940  -0.29466030E-07
         949          957   0.25012816E-09
         949          958  -0.25361669E-14
         949          959  -0.20648377E-06
         949          960  -0.69696564E-07
         950          950   0.99555507E+04
         950          941   0.26804545E+04
         950          942   0.18334319E+03
         950          945   0.16090893E-05
         950          947   0.36553110E-01
         950          948  -0.35807947E-04
         950          949   0.24759221E+02
         950          931  -0.31900183E-05
         950          932  -0.21819741E-06
         950          935  -0.19149832E-14
         950          937  -0.43480003E-10
         950          938   0.41438525E-14
         950          939  -0.29466030E-07
         950          940  -0.11848137E-04
         950          951  -0.75454114E-05
         950          952  -0.51610650E-06
         950          955  -0.45295464E-14
         950          957  -0.10284408E-09
         950          958   0.98015335E-14
         950          959  -0.69696564E-07
         950          960  -0.28024626E-04
         951          951   0.72309514E+04
         951          956   0.58975761E+02
         951          957   0.56195096E+02
         951          960   0.26804279E+04
         951          941  -0.86053524E-05
         951          946  -0.70185147E-07
         951          947  -0.66876212E-07
         951          950  -0.31899018E-05
         951          961  -0.20354895E-04
         951          966  -0.16601427E-06
         951          967  -0.15818739E-06
         951          970  -0.75453174E-05
         952          952   0.45530625E+04
         952          954   0.63450217E+01
         952          955   0.63450217E+01
         952          957  -0.21136331E+02
         952          960   0.18334137E+03
         952          942  -0.54159557E-05
         952          950  -0.21818944E-06
         952          962  -0.12810772E-04
         952          970  -0.51610008E-06
         953          953   0.57645338E+03
         953          943  -0.68602105E-06
         953          963  -0.16226978E-05
         954          954   0.99496056E+03
         954          952   0.63443872E+01
         954          955   0.19035065E+02
         954          957  -0.65201373E+02
         954          944  -0.11614216E-05
         954          947   0.21330623E-08
         954          964  -0.27471989E-05
         954          967   0.50454946E-08
         955          955   0.19048194E+02
         955          952   0.63443872E+01
         955          954   0.19035065E+02
         955          957  -0.63459865E+02
         955          960   0.16090957E-05
         955          945  -0.15585918E-10
         955          947   0.60426037E-10
         955          950  -0.19149399E-14
         955          965  -0.36866557E-10
         955          967   0.14293030E-09
         955          970  -0.45295530E-14
         956          956   0.13427621E+04
         956          951   0.58975761E+02
         956          957   0.16072526E+04
         956          959   0.43198833E-04
         956          941  -0.70185147E-07
         956          946  -0.76148657E-04
         956          947  -0.15102155E-03
         956          961  -0.16601427E-06
         956          966  -0.78203228E-04
         956          967  -0.15337860E-03
         957          957   0.23570548E+04
         957          951   0.56195096E+02
         957          952  -0.21147957E+02
         957          954  -0.65242777E+02
         957          955  -0.63501102E+02
         957          956   0.16072257E+04
         957          958  -0.37170132E-04
         957          959  -0.88855027E-01
         957          960   0.36552748E-01
         957          941  -0.66876212E-07
         957          944   0.21332756E-08
         957          945   0.60440920E-10
         957          946  -0.15101406E-03
         957          947  -0.30077113E-03
         957          948   0.57648399E-14
         957          949   0.10575488E-09
         957          950  -0.43478414E-10
         957          961  -0.15818739E-06
         957          964   0.50459991E-08
         957          965   0.14296551E-09
         957          966  -0.15337108E-03
         957          967  -0.30374852E-03
         957          968   0.13636015E-13
         957          969   0.25015006E-09
         957          970  -0.10284280E-09
         958          958   0.63759557E-04
         958          957  -0.37179413E-04
         958          959  -0.15265668E-04
         958          960  -0.35817325E-04
         958          947   0.57653053E-14
         958          948  -0.85554502E-14
         958          949  -0.10722314E-14
         958          950   0.41443226E-14
         958          967   0.13637115E-13
         958          968  -0.20236858E-13
         958          969  -0.25362305E-14
         958          970   0.98028817E-14
         959          959   0.73351220E+02
         959          956   0.43198833E-04
         959          957  -0.88846141E-01
         959          958  -0.15262065E-04
         959          960   0.24758975E+02
         959          947   0.10574430E-09
         959          948  -0.10721912E-14
         959          949  -0.87293180E-07
         959          950  -0.29464953E-07
         959          967   0.25012505E-09
         959          968  -0.25361353E-14
         959          969  -0.20648120E-06
         959          970  -0.69695696E-07
         960          960   0.99554519E+04
         960          951   0.26804279E+04
         960          952   0.18334137E+03
         960          955   0.16090734E-05
         960          957   0.36552748E-01
         960          958  -0.35807913E-04
         960          959   0.24758975E+02
         960          941  -0.31899018E-05
         960          942  -0.21818944E-06
         960          945  -0.19149132E-14
         960          947  -0.43478414E-10
         960          948   0.41437010E-14
         960          949  -0.29464953E-07
         960          950  -0.11847705E-04
         960          961  -0.75453174E-05
         960          962  -0.51610008E-06
         960          965  -0.45294900E-14
         960          967  -0.10284280E-09
         960          968   0.98014114E-14
         960          969  -0.69695696E-07
         960          970  -0.28024277E-04
         961          961   0.72308936E+04
         961          966   0.58975289E+02
         961          967   0.56194646E+02
         961          970   0.26804064E+04
         961          951  -0.86050989E-05
         961          956  -0.70183079E-07
         961          957  -0.66874242E-07
         961          960  -0.31898078E-05
         961          971  -0.20354690E-04
         961          976  -0.16601260E-06
         961          977  -0.15818581E-06
         961          980  -0.75452416E-05
         962          962   0.45530261E+04
         962          964   0.63450217E+01
         962          965   0.63450217E+01
         962          967  -0.21136331E+02
         962          970   0.18333990E+03
         962          952  -0.54157961E-05
         962          960  -0.21818301E-06
         962          972  -0.12810644E-04
         962          980  -0.51609489E-06
         963          963   0.57644877E+03
         963          953  -0.68600084E-06
         963          973  -0.16226815E-05
         964          964   0.99495276E+03
         964          962   0.63443872E+01
         964          965   0.19035065E+02
         964          967  -0.65201358E+02
         964          954  -0.11613874E-05
         964          957   0.21329994E-08
         964          974  -0.27471713E-05
         964          977   0.50454439E-08
         965          965   0.19048194E+02
         965          962   0.63443872E+01
         965          964   0.19035065E+02
         965          967  -0.63459865E+02
         965          970   0.16090829E-05
         965          955  -0.15585459E-10
         965          957   0.60424257E-10
         965          960  -0.19148834E-14
         965          975  -0.36866187E-10
         965          977   0.14292887E-09
         965          980  -0.45295075E-14
         966          966   0.13427538E+04
         966          961   0.58975289E+02
         966          967   0.16072447E+04
         966          969   0.43198833E-04
         966          951  -0.70183079E-07
         966          956  -0.76154902E-04
         966          957  -0.15103408E-03
         966          971  -0.16601260E-06
         966          976  -0.78208263E-04
         966          977  -0.15338870E-03
         967          967   0.23570477E+04
         967          961   0.56194646E+02
         967          962  -0.21147957E+02
         967          964  -0.65242762E+02
         967          965  -0.63501102E+02
         967          966   0.16072179E+04
         967          968  -0.37170093E-04
         967          969  -0.88854316E-01
         967          970   0.36552456E-01
         967          951  -0.66874242E-07
         967          954   0.21332127E-08
         967          955   0.60439139E-10
         967          956  -0.15102659E-03
         967          957  -0.30079623E-03
         967          958   0.57646701E-14
         967          959   0.10575176E-09
         967          960  -0.43477134E-10
         967          971  -0.15818581E-06
         967          974   0.50459484E-08
         967          975   0.14296407E-09
         967          976  -0.15338118E-03
         967          977  -0.30376876E-03
         967          978   0.13635878E-13
         967          979   0.25014755E-09
         967          980  -0.10284177E-09
         968          968   0.63759500E-04
         968          967  -0.37179375E-04
         968          969  -0.15265675E-04
         968          970  -0.35817298E-04
         968          957   0.57651354E-14
         968          958  -0.85551982E-14
         968          959  -0.10721998E-14
         968          960   0.41442005E-14
         968          977   0.13636978E-13
         968          978  -0.20236654E-13
         968          979  -0.25362050E-14
         968          980   0.98027833E-14
         969          969   0.73350633E+02
         969          966   0.43198833E-04
         969          967  -0.88845430E-01
         969          968  -0.15262072E-04
         969          970   0.24758777E+02
         969          957   0.10574119E-09
         969          958  -0.10721596E-14
         969          959  -0.87290608E-07
         969          960  -0.29464085E-07
         969          977   0.25012254E-09
         969          978  -0.25361099E-14
         969          979  -0.20647913E-06
         969          980  -0.69694996E-07
         970          970   0.99553723E+04
         970          961   0.26804064E+04
         970          962   0.18333990E+03
         970          965   0.16090605E-05
         970          967   0.36552456E-01
         970          968  -0.35807885E-04
         970          969   0.24758777E+02
         970          951  -0.31898078E-05
         970          952  -0.21818301E-06
         970          955  -0.19148568E-14
         970          957  -0.43477134E-10
         970          958   0.41435790E-14
         970          959  -0.29464085E-07
         970          960  -0.11847355E-04
         970          971  -0.75452416E-05
         970          972  -0.51609489E-06
         970          975  -0.45294445E-14
         970          977  -0.10284177E-09
         970          978   0.98013130E-14
         970          979  -0.69694996E-07
         970          980  -0.28023996E-04
         971          971   0.72308469E+04
         971          976   0.58974909E+02
         971          977   0.56194284E+02
         971          980   0.26803891E+04
         971          961  -0.86048945E-05
         971          966  -0.70181412E-07
         971          967  -0.66872654E-07
         971          970  -0.31897320E-05
         971          981  -0.20354526E-04
         971          986  -0.16601126E-06
         971          987  -0.15818453E-06
         971          990  -0.75451806E-05
         972          972   0.45529968E+04
         972          974   0.63450217E+01
         972          975   0.63450217E+01
         972          977  -0.21136331E+02
         972          980   0.18333872E+03
         972          962  -0.54156675E-05
         972          970  -0.21817783E-06
         972          982  -0.12810540E-04
         972          990  -0.51609072E-06
         973          973   0.57644505E+03
         973          963  -0.68598455E-06
         973          983  -0.16226684E-05
         974          974   0.99494646E+03
         974          972   0.63443872E+01
         974          975   0.19035065E+02
         974          977  -0.65201347E+02
         974          964  -0.11613598E-05
         974          967   0.21329488E-08
         974          984  -0.27471491E-05
         974          987   0.50454031E-08
         975          975   0.19048194E+02
         975          972   0.63443872E+01
         975          974   0.19035065E+02
         975          977  -0.63459864E+02
         975          980   0.16090725E-05
         975          965  -0.15585088E-10
         975          967   0.60422822E-10
         975          970  -0.19148380E-14
         975          985  -0.36865889E-10
         975          987   0.14292771E-09
         975          990  -0.45294708E-14
         976          976   0.13427472E+04
         976          971   0.58974909E+02
         976          977   0.16072384E+04
         976          979   0.43198833E-04
         976          961  -0.70181412E-07
         976          966  -0.76159937E-04
         976          967  -0.15104418E-03
         976          981  -0.16601126E-06
         976          986  -0.78212323E-04
         976          987  -0.15339685E-03
         977          977   0.23570420E+04
         977          971   0.56194284E+02
         977          972  -0.21147957E+02
         977          974  -0.65242751E+02
         977          975  -0.63501102E+02
         977          976   0.16072116E+04
         977          978  -0.37170062E-04
         977          979  -0.88853743E-01
         977          980   0.36552220E-01
         977          961  -0.66872654E-07
         977          964   0.21331621E-08
         977          965   0.60437704E-10
         977          966  -0.15103669E-03
         977          967  -0.30081646E-03
         977          968   0.57645332E-14
         977          969   0.10574925E-09
         977          970  -0.43476101E-10
         977          981  -0.15818453E-06
         977          984   0.50459076E-08
         977          985   0.14296292E-09
         977          986  -0.15338933E-03
         977          987  -0.30378507E-03
         977          988   0.13635767E-13
         977          989   0.25014552E-09
         977          990  -0.10284094E-09
         978          978   0.63759453E-04
         978          977  -0.37179343E-04
         978          979  -0.15265681E-04
         978          980  -0.35817275E-04
         978          967   0.57649985E-14
         978          968  -0.85549950E-14
         978          969  -0.10721743E-14
         978          970   0.41441021E-14
         978          987   0.13636868E-13
         978          988  -0.20236490E-13
         978          989  -0.25361845E-14
         978          990   0.98027039E-14
         979          979   0.73350160E+02
         979          976   0.43198833E-04
         979          977  -0.88844857E-01
         979          978  -0.15262078E-04
         979          980   0.24758617E+02
         979          967   0.10573868E-09
         979          968  -0.10721341E-14
         979          969  -0.87288535E-07
         979          970  -0.29463385E-07
         979          987   0.25012051E-09
         979          988  -0.25360894E-14
         979          989  -0.20647746E-06
         979          990  -0.69694432E-07
         980          980   0.99553081E+04
         980          971   0.26803891E+04
         980          972   0.18333872E+03
         980          975   0.16090501E-05
         980          977   0.36552220E-01
         980          978  -0.35807863E-04
         980          979   0.24758617E+02
         980          961  -0.31897320E-05
         980          962  -0.21817783E-06
         980          965  -0.19148113E-14
         980          967  -0.43476101E-10
         980          968   0.41434806E-14
         980          969  -0.29463385E-07
         980          970  -0.11847074E-04
         980          981  -0.75451806E-05
         980          982  -0.51609072E-06
         980          985  -0.45294079E-14
         980          987  -0.10284094E-09
         980          988   0.98012337E-14
         980          989  -0.69694432E-07
         980          990  -0.28023769E-04
         981          981   0.72308093E+04
         981          986   0.58974602E+02
         981          987   0.56193992E+02
         981          990   0.26803752E+04
         981          971  -0.86047297E-05
         981          976  -0.70180069E-07
         981          977  -0.66871373E-07
         981          980  -0.31896710E-05
         981          991  -0.20354393E-04
         981          996  -0.16601018E-06
         981          997  -0.15818349E-06
         981         1000  -0.75451313E-05
         982          982   0.45529731E+04
         982          984   0.63450217E+01
         982          985   0.63450217E+01
         982          987  -0.21136331E+02
         982          990   0.18333776E+03
         982          972  -0.54155638E-05
         982          980  -0.21817365E-06
         982          992  -0.12810456E-04
         982         1000  -0.51608735E-06
         983          983   0.57644205E+03
         983          973  -0.68597141E-06
         983          993  -0.16226578E-05
         984          984   0.99494139E+03
         984          982   0.63443872E+01
         984          985   0.19035065E+02
         984          987  -0.65201338E+02
         984          974  -0.11613376E-05
         984          977   0.21329079E-08
         984          994  -0.27471312E-05
         984          997   0.50453701E-08
         985          985   0.19048194E+02
         985          982   0.63443872E+01
         985          984   0.19035065E+02
         985          987  -0.63459864E+02
         985          990   0.16090641E-05
         985          975  -0.15584790E-10
         985          977   0.60421665E-10
         985          980  -0.19148013E-14
         985          995  -0.36865648E-10
         985          997   0.14292678E-09
         985         1000  -0.45294413E-14
         986          986   0.13427418E+04
         986          981   0.58974602E+02
         986          987   0.16072333E+04
         986          989   0.43198833E-04
         986          971  -0.70180069E-07
         986          976  -0.76163997E-04
         986          977  -0.15105232E-03
         986          991  -0.16601018E-06
         986          996  -0.78215596E-04
         986          997  -0.15340341E-03
         987          987   0.23570374E+04
         987          981   0.56193992E+02
         987          982  -0.21147957E+02
         987          984  -0.65242742E+02
         987          985  -0.63501101E+02
         987          986   0.16072065E+04
         987          988  -0.37170037E-04
         987          989  -0.88853281E-01
         987          990   0.36552030E-01
         987          971  -0.66871373E-07
         987          974   0.21331212E-08
         987          975   0.60436547E-10
         987          976  -0.15104483E-03
         987          977  -0.30083277E-03
         987          978   0.57644228E-14
         987          979   0.10574723E-09
         987          980  -0.43475268E-10
         987          991  -0.15818349E-06
         987          994   0.50458747E-08
         987          995   0.14296198E-09
         987          996  -0.15339589E-03
         987          997  -0.30379822E-03
         987          998   0.13635678E-13
         987          999   0.25014389E-09
         987         1000  -0.10284027E-09
         988          988   0.63759416E-04
         988          987  -0.37179318E-04
         988          989  -0.15265685E-04
         988          990  -0.35817257E-04
         988          977   0.57648881E-14
         988          978  -0.85548312E-14
         988          979  -0.10721538E-14
         988          980   0.41440227E-14
         988          997   0.13636779E-13
         988          998  -0.20236358E-13
         988          999  -0.25361679E-14
         988         1000   0.98026400E-14
         989          989   0.73349779E+02
         989          986   0.43198833E-04
         989          987  -0.88844395E-01
         989          988  -0.15262082E-04
         989          990   0.24758489E+02
         989          977   0.10573665E-09
         989          978  -0.10721136E-14
         989          979  -0.87286863E-07
         989          980  -0.29462821E-07
         989          997   0.25011888E-09
         989          998  -0.25360728E-14
         989          999  -0.20647611E-06
         989         1000  -0.69693978E-07
         990          990   0.99552563E+04
         990          981   0.26803752E+04
         990          982   0.18333776E+03
         990          985   0.16090418E-05
         990          987   0.36552030E-01
         990          988  -0.35807844E-04
         990          989   0.24758489E+02
         990          971  -0.31896710E-05
         990          972  -0.21817365E-06
         990          975  -0.19147747E-14
         990          977  -0.43475268E-10
         990          978   0.41434012E-14
         990          979  -0.29462821E-07
         990          980  -0.11846847E-04
         990          991  -0.75451313E-05
         990          992  -0.51608735E-06
         990          995  -0.45293783E-14
         990          997  -0.10284027E-09
         990          998   0.98011698E-14
         990          999  -0.69693978E-07
         990         1000  -0.28023586E-04
         991          991   0.72307790E+04
         991          996   0.58974355E+02
         991          997   0.56193756E+02
         991         1000   0.26803640E+04
         991          981  -0.86045969E-05
         991          986  -0.70178985E-07
         991          987  -0.66870341E-07
         991          990  -0.31896217E-05
         991         1001  -0.20354286E-04
         991         1006  -0.16600930E-06
         991         1007  -0.15818266E-06
         991         1010  -0.75450916E-05
         992          992   0.45529541E+04
         992          994   0.63450217E+01
         992          995   0.63450217E+01
         992          997  -0.21136331E+02
         992         1000   0.18333700E+03
         992          982  -0.54154802E-05
         992          990  -0.21817028E-06
         992         1002  -0.12810389E-04
         992         1010  -0.51608463E-06
         993          993   0.57643964E+03
         993          983  -0.68596082E-06
         993         1003  -0.16226492E-05
         994          994   0.99493730E+03
         994          992   0.63443872E+01
         994          995   0.19035065E+02
         994          997  -0.65201330E+02
         994          984  -0.11613196E-05
         994          987   0.21328750E-08
         994         1004  -0.27471167E-05
         994         1007   0.50453436E-08
         995          995   0.19048194E+02
         995          992   0.63443872E+01
         995          994   0.19035065E+02
         995          997  -0.63459864E+02
         995         1000   0.16090574E-05
         995          985  -0.15584549E-10
         995          987   0.60420732E-10
         995          990  -0.19147717E-14
         995         1005  -0.36865454E-10
         995         1007   0.14292603E-09
         995         1010  -0.45294174E-14
         996          996   0.13427375E+04
         996          991   0.58974355E+02
         996          997   0.16072292E+04
         996          999   0.43198833E-04
         996          981  -0.70178985E-07
         996          986  -0.76167269E-04
         996          987  -0.15105889E-03
         996         1001  -0.16600930E-06
         996         1006  -0.78218234E-04
         996         1007  -0.15340871E-03
         997          997   0.23570336E+04
         997          991   0.56193756E+02
         997          992  -0.21147957E+02
         997          994  -0.65242734E+02
         997          995  -0.63501101E+02
         997          996   0.16072024E+04
         997          998  -0.37170017E-04
         997          999  -0.88852908E-01
         997         1000   0.36551877E-01
         997          981  -0.66870341E-07
         997          984   0.21330883E-08
         997          985   0.60435614E-10
         997          986  -0.15105140E-03
         997          987  -0.30084592E-03
         997          988   0.57643338E-14
         997          989   0.10574559E-09
         997          990  -0.43474597E-10
         997         1001  -0.15818266E-06
         997         1004   0.50458481E-08
         997         1005   0.14296123E-09
         997         1006  -0.15340119E-03
         997         1007  -0.30380882E-03
         997         1008   0.13635607E-13
         997         1009   0.25014257E-09
         997         1010  -0.10283973E-09
         998          998   0.63759386E-04
         998          997  -0.37179298E-04
         998          999  -0.15265689E-04
         998         1000  -0.35817242E-04
         998          987   0.57647991E-14
         998          988  -0.85546991E-14
         998          989  -0.10721372E-14
         998          990   0.41439588E-14
         998         1007   0.13636707E-13
         998         1008  -0.20236252E-13
         998         1009  -0.25361546E-14
         998         1010   0.98025883E-14
         999          999   0.73349472E+02
         999          996   0.43198833E-04
         999          997  -0.88844022E-01
         999          998  -0.15262086E-04
         999         1000   0.24758385E+02
         999          987   0.10573502E-09
         999          988  -0.10720970E-14
         999          989  -0.87285516E-07
         999          990  -0.29462366E-07
         999         1007   0.25011756E-09
         999         1008  -0.25360595E-14
         999         1009  -0.20647502E-06
         999         1010  -0.69693611E-07
        1000         1000   0.99552146E+04
        1000          991   0.26803640E+04
        1000          992   0.18333700E+03
        1000          995   0.16090350E-05
        1000          997   0.36551877E-01
        1000          998  -0.35807830E-04
        1000          999   0.24758385E+02
        1000          981  -0.31896217E-05
        1000          982  -0.21817028E-06
        1000          985  -0.19147451E-14
        1000          987  -0.43474597E-10
        1000          988   0.41433373E-14
        1000          989  -0.29462366E-07
        1000          990  -0.11846664E-04
        1000         1001  -0.75450916E-05
        1000         1002  -0.51608463E-06
        1000         1005  -0.45293545E-14
        1000         1007  -0.10283973E-09
        1000         1008   0.98011182E-14
        1000         1009  -0.69693611E-07
        1000         1010  -0.28023439E-04
        1001         1001   0.36153773E+04
        1001         1006   0.29487078E+02
        1001         1007   0.28096783E+02
        1001         1010   0.13401775E+04
        1001          991  -0.86044898E-05
        1001          996  -0.70178112E-07
        1001          997  -0.66869509E-07
        1001         1000  -0.31895820E-05
        1002         1002   0.22764694E+04
        1002         1004   0.31725108E+01
        1002         1005   0.31725108E+01
        1002         1007  -0.10568165E+02
        1002         1010   0.91668189E+02
        1002          992  -0.54154128E-05
        1002         1000  -0.21816756E-06
        1003         1003   0.28821885E+03
        1003          993  -0.68595229E-06
        1004         1004   0.49746701E+03
        1004         1002   0.31721936E+01
        1004         1005   0.95175325E+01
        1004         1007  -0.32600662E+02
        1004          994  -0.11613052E-05
        1004          997   0.21328485E-08
        1005         1005   0.95240970E+01
        1005         1002   0.31721936E+01
        1005         1004   0.95175325E+01
        1005         1007  -0.31729932E+02
        1005         1010   0.80452598E-06
        1005          995  -0.15584355E-10
        1005          997   0.60419980E-10
        1005         1000  -0.19147479E-14
        1006         1006   0.67136733E+03
        1006         1001   0.29487078E+02
        1006         1007   0.80361356E+03
        1006         1009   0.21599416E-04
        1006          991  -0.70178112E-07
        1006          996  -0.76169908E-04
        1006          997  -0.15106418E-03
        1007         1007   0.11785165E+04
        1007         1001   0.28096783E+02
        1007         1002  -0.10573979E+02
        1007         1004  -0.32621364E+02
        1007         1005  -0.31750550E+02
        1007         1006   0.80360015E+03
        1007         1008  -0.18585000E-04
        1007         1009  -0.44426305E-01
        1007         1010   0.18275877E-01
        1007          991  -0.66869509E-07
        1007          994   0.21330618E-08
        1007          995   0.60434862E-10
        1007          996  -0.15105669E-03
        1007          997  -0.30085653E-03
        1007          998   0.57642621E-14
        1007          999   0.10574428E-09
        1007         1000  -0.43474056E-10
        1008         1008   0.31879681E-04
        1008         1007  -0.18589641E-04
        1008         1009  -0.76328461E-05
        1008         1010  -0.17908615E-04
        1008          997   0.57647274E-14
        1008          998  -0.85545926E-14
        1008          999  -0.10721239E-14
        1008         1000   0.41439072E-14
        1009         1009   0.36674612E+02
        1009         1006   0.21599416E-04
        1009         1007  -0.44421862E-01
        1009         1008  -0.76310445E-05
        1009         1010   0.12379151E+02
        1009          997   0.10573370E-09
        1009          998  -0.10720837E-14
        1009          999  -0.87284430E-07
        1009         1000  -0.29462000E-07
        1010         1010   0.49775905E+04
        1010         1001   0.13401775E+04
        1010         1002   0.91668189E+02
        1010         1005   0.80451479E-06
        1010         1007   0.18275877E-01
        1010         1008  -0.17903909E-04
        1010         1009   0.12379151E+02
        1010          991  -0.31895820E-05
        1010          992  -0.21816756E-06
        1010          995  -0.19147213E-14
        1010          997  -0.43474056E-10
        1010          998   0.41432857E-14
        1010          999  -0.29462000E-07
        1010         1000  -0.11846517E-04
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140122/266abaa1/attachment-0003.png>
        1010
 -3.449869938711822E-004
  -1.05741178096217
  0.000000000000000E+000
  -3.17219351605396
  -3.17218826825896
 -7.887598353594752E-005
   10.5738682044873
  5.233241132884998E-007
 -3.389991959634191E-006
 -3.559078687230301E-004
 -6.899739877423644E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
 -1.577519670718950E-004
   21.1477364089746
  1.046648226577000E-006
 -6.779983919268382E-006
 -7.118157374460602E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
 -6.899739877423754E-004
  -2.11482356192435
 -8.748791553952855E-019
  -6.34438703210792
  -6.34437653651792
 -1.577519670718970E-004
   21.1477364089746
 -6.779983919268493E-006
 -7.118157374460753E-004
 -6.899739877423425E-004
  -2.11482356192435
  1.749652431672164E-018
  -6.34438703210792
  -6.34437653651792
 -1.577519670718912E-004
   21.1477364089746
 -6.779983919268159E-006
 -7.118157374460300E-004
  -2.11482356192435
 -8.747732762768787E-019
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
 -6.899739877423535E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
 -1.577519670718931E-004
   21.1477364089746
 -6.779983919268271E-006
 -7.118157374460452E-004
 -6.899739877423863E-004
  -2.11482356192435
 -1.749652431672164E-018
  -6.34438703210792
  -6.34437653651792
 -1.577519670718989E-004
   21.1477364089746
 -6.779983919268604E-006
 -7.118157374460905E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
 -6.899739159861965E-004
  -2.11482356187919
  5.720421399947007E-012
  -6.34438703209823
  -6.34437653651792
 -1.577519545627373E-004
   21.1477364089889
  1.046648226576974E-006
 -6.779983191369767E-006
 -7.118156386533741E-004
 -6.899739869539865E-004
  -2.11482356192385
  6.284970873748105E-014
  -6.34438703210781
  -6.34437653651792
 -1.577519669344581E-004
   21.1477364089748
  1.046648226576999E-006
 -6.779983911271031E-006
 -7.118157363606347E-004
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
  -2.11482356192435
  -6.34438703210792
  -6.34437653651792
   21.1477364089746
 -6.899739797405390E-004
  -2.11482356191931
  6.379077183923750E-013
  -6.34438703210684
  -6.34437653651792
 -1.577519656769474E-004
   21.1477364089762
  1.046648226576997E-006
 -6.779983838097413E-006
 -7.118157264292815E-004
 -6.839169730044121E-004
  -2.11482331728470
 -6.662870093233409E-012
  -6.34438703309127
  -6.34437653650898
 -1.567005374296405E-004
   21.1477373988668
  1.046648222910566E-006
 -6.723068088836391E-006
 -7.055702135204329E-004
 -6.648299610889552E-004
  -2.11482254616652
  1.885389461469666E-018
  -6.34438703614308
  -6.34437653648079
 -1.533872462003842E-004
   21.1477405182513
  1.046648211356895E-006
 -6.543713300847808E-006
 -6.858890475224518E-004
 -6.437900739333921E-004
  -2.11482169620430
  8.970078911423041E-019
  -6.34438703951970
  -6.34437653644973
 -1.497349575050653E-004
   21.1477439567907
  1.046648198621096E-006
 -6.346007995049283E-006
 -6.641942440345406E-004
 -6.236638383047850E-004
  -2.11482088315247
  3.435777392300256E-019
  -6.34438704274944
  -6.34437653642001
 -1.462412687857692E-004
   21.1477472460118
  1.046648186438346E-006
 -6.156888029553015E-006
 -6.434415355977556E-004
 -6.054813627073377E-004
  -2.11482014862422
  2.326164231397122E-019
  -6.34438704566743
  -6.34437653639316
 -1.430849950469276E-004
   21.1477502175657
  1.046648175432186E-006
 -5.986032934860665E-006
 -6.246930886437701E-004
 -5.895483600731941E-004
  -2.11481950496933
  1.485484031247229E-019
  -6.34438704822451
  -6.34437653636964
 -1.403192046153178E-004
   21.1477528214891
  1.046648165787671E-006
 -5.836315475427259E-006
 -6.082641356968455E-004
 -5.758478170424553E-004
  -2.11481895150046
  5.696296570285170E-020
  -6.34438705042321
  -6.34437653634941
 -1.379409436665921E-004
   21.1477550605627
  1.046648157494500E-006
 -5.707575703584699E-006
 -5.941371322865401E-004
 -5.642191409952483E-004
  -2.11481848172962
  6.172752603115714E-020
  -6.34438705228938
  -6.34437653633224
 -1.359223361097511E-004
   21.1477569610316
  1.046648150455466E-006
 -5.598304647542227E-006
 -5.821464883635690E-004
 -5.544439266814491E-004
  -2.11481808683408
  8.364450354136216E-021
  -6.34438705385820
  -6.34437653631780
 -1.342254685458599E-004
   21.1477585585907
  1.046648144538364E-006
 -5.506449999843343E-006
 -5.720669987994166E-004
 -5.462886304181852E-004
  -2.11481775737979
  5.293955920339377E-020
  -6.34438705516697
  -6.34437653630576
 -1.328098005021367E-004
   21.1477598914073
  1.046648139601824E-006
 -5.429817197909135E-006
 -5.636578483306119E-004
 -5.395261745261200E-004
  -2.11481748419292
  8.893845946170154E-021
  -6.34438705625206
  -6.34437653629578
 -1.316359142398496E-004
   21.1477609965917
  1.046648135508397E-006
 -5.366272517012090E-006
 -5.566848968145716E-004
 -5.339466764753271E-004
  -2.11481725879472
 -3.494010907423989E-021
  -6.34438705714764
  -6.34437653628754
 -1.306673758597487E-004
   21.1477619084466
  1.046648132131032E-006
 -5.313843693148873E-006
 -5.509317244278313E-004
 -5.293622098695204E-004
  -2.11481707359338
  2.096406544454393E-020
  -6.34438705788341
  -6.34437653628077
 -1.298715638070382E-004
   21.1477626576843
  1.046648129355976E-006
 -5.270764887726361E-006
 -5.462045566172901E-004
 -5.256082148000023E-004
  -2.11481692194053
  1.048203272227197E-020
  -6.34438705848581
  -6.34437653627523
 -1.292199123620203E-004
   21.1477632711978
  1.046648127083620E-006
 -5.235489757396058E-006
 -5.423337089109968E-004
 -5.225429584179513E-004
  -2.11481679811157
  4.658681209898652E-021
  -6.34438705897771
  -6.34437653627070
 -1.286878182204833E-004
   21.1477637721511
  1.046648125228168E-006
 -5.206686497170843E-006
 -5.391730403614336E-004
 -5.200459356619586E-004
  -2.11481669723799
 -3.176373552203626E-021
  -6.34438705937842
  -6.34437653626702
 -1.282543631774347E-004
   21.1477641802387
  1.046648123716679E-006
 -5.183222746994063E-006
 -5.365982924883831E-004
 -5.180157258051534E-004
  -2.11481661522241
  2.472595052153709E-018
  -6.34438705970428
  -6.34437653626402
 -1.279019413676222E-004
   21.1477645120351
  1.046648122487758E-006
 -5.164145495012296E-006
 -5.345048864177030E-004
 -5.163676684011973E-004
  -2.11481654864408
 -2.388209394783500E-018
  -6.34438705996865
  -6.34437653626158
 -1.276158571917882E-004
   21.1477647813760
  1.046648121490161E-006
 -5.148659198600179E-006
 -5.328055287255515E-004
 -5.150315606166338E-004
  -2.11481649466922
  7.379774552953092E-020
  -6.34438706018311
  -6.34437653625961
 -1.273839238554627E-004
   21.1477649997356
  1.046648120681392E-006
 -5.136104211702906E-006
 -5.314278327278900E-004
 -5.139494995206588E-004
  -2.11481645095657
 -5.717472393966527E-021
  -6.34438706035688
  -6.34437653625801
 -1.271960902754225E-004
   21.1477651765761
  1.046648120026402E-006
 -5.125936428204076E-006
 -5.303120906686458E-004
 -5.130739370556627E-004
  -2.11481641558603
 -9.105604182983729E-021
  -6.34438706049738
  -6.34437653625672
 -1.270441022849977E-004
   21.1477653196693
  1.046648119496409E-006
 -5.117709041704634E-006
 -5.294092740344087E-004
 -5.123659583837803E-004
  -2.11481638698508
 -2.234049398383217E-020
  -6.34438706061085
  -6.34437653625567
 -1.269212052582411E-004
   21.1477654353736
  1.046648119067859E-006
 -5.111056384600308E-006
 -5.286792584335477E-004
 -5.117938156890674E-004
  -2.11481636387226
 -2.424631811515435E-020
  -6.34438706070264
  -6.34437653625483
 -1.268218878186382E-004
   21.1477655288786
  1.046648118721531E-006
 -5.105680134207707E-006
 -5.280893063072035E-004
 -5.113316592153980E-004
  -2.11481634520200
 -1.132906566952627E-020
  -6.34438706077690
  -6.34437653625415
 -1.267416624366885E-004
   21.1477656044087
  1.046648118441780E-006
 -5.101337403249047E-006
 -5.276127635103513E-004
 -5.109584859992954E-004
  -2.11481633012671
 -2.076045799402355E-014
  -6.34438706083693
  -6.34437653625360
 -1.266768836765059E-004
   21.1477656653966
  1.046648118215891E-006
 -5.097830791597171E-006
 -5.272279736859138E-004
 -5.106572499054436E-004
  -2.11481631795739
 -6.882612905606035E-015
  -6.34438706088518
  -6.34437653625315
 -1.266245926867701E-004
   21.1477657146269
  1.046648118033549E-006
 -5.095000186731332E-006
 -5.269173628907000E-004
 -5.104141473346194E-004
  -2.11481630813655
 -1.524659305057741E-020
  -6.34438706092408
  -6.34437653625279
 -1.265823928497912E-004
   21.1477657543571
  1.046648117886395E-006
 -5.092715823860421E-006
 -5.266666928532241E-004
 -5.102179976361569E-004
  -2.11481630021266
 -1.281137332722129E-020
  -6.34438706095557
  -6.34437653625250
 -1.265483433134784E-004
   21.1477657864141
  1.046648117767662E-006
 -5.090872661602090E-006
 -5.264644359775928E-004
 -5.100597563983116E-004
  -2.11481629382033
 -9.529120656610879E-021
  -6.34438706098111
  -6.34437653625227
 -1.265208744109423E-004
   21.1477658122754
  1.046648117671875E-006
 -5.089385717309248E-006
 -5.263012697885092E-004
 -5.099321140191491E-004
  -2.11481628866368
 -6.776263578034403E-021
  -6.34438706100146
  -6.34437653625208
 -1.264987170872531E-004
   21.1477658331359
  1.046648117594611E-006
 -5.088186300090830E-006
 -5.261696541796867E-004
 -5.098291653098504E-004
  -2.11481628450450
 -1.905824131322176E-021
  -6.34438706101795
  -6.34437653625193
 -1.264808460937316E-004
   21.1477658499611
  1.046648117532294E-006
 -5.087218909563365E-006
 -5.260635009846245E-004
 -5.097461374045232E-004
  -2.11481628115031
 -1.291725244562808E-020
  -6.34438706103131
  -6.34437653625181
 -1.264664336680100E-004
   21.1477658635299
  1.046648117482036E-006
 -5.086438738844267E-006
 -5.259778888165848E-004
 -5.096791842073509E-004
  -2.11481627844604
  9.529120656610879E-022
  -6.34438706104215
  -6.34437653625171
 -1.264548111878069E-004
   21.1477658744722
  1.046648117441508E-006
 -5.085809585977427E-006
 -5.259088503867411E-004
 -5.096251927214114E-004
  -2.11481627626516
 -6.352747104407253E-021
  -6.34438706105077
  -6.34437653625163
 -1.264454389283695E-004
   21.1477658832959
  1.046648117408826E-006
 -5.085302248051595E-006
 -5.258531788329968E-004
 -5.095816559148314E-004
  -2.11481627450608
  2.541098841762901E-021
  -6.34438706105790
  -6.34437653625156
 -1.264378816957729E-004
   21.1477658904110
  1.046648117382474E-006
 -5.084893165947644E-006
 -5.258082887044721E-004
 -5.095465539041116E-004
  -2.11481627308800
 -2.329340604949326E-021
  -6.34438706106339
  -6.34437653625151
 -1.264317882753473E-004
   21.1477658961476
  1.046648117361225E-006
 -5.084563310432240E-006
 -5.257720923921624E-004
 -5.095182493954511E-004
  -2.11481627194439
 -1.090554919589912E-020
  -6.34438706106785
  -6.34437653625147
 -1.264268750943861E-004
   21.1477659007733
  1.046648117344092E-006
 -5.084297356010633E-006
 -5.257429086400962E-004
 -5.094954306527410E-004
  -2.11481627102297
  1.577598864261134E-020
  -6.34438706107156
  -6.34437653625144
 -1.264229136814157E-004
   21.1477659045031
  1.046648117330278E-006
 -5.084082910474766E-006
 -5.257193769973274E-004
 -5.094770307022287E-004
  -2.11481627027918
 -3.059906521956160E-020
  -6.34438706107453
  -6.34437653625141
 -1.264197196292417E-004
   21.1477659075100
  1.046648117319141E-006
 -5.083910022928004E-006
 -5.257004055386015E-004
 -5.094621964401749E-004
  -2.11481626967975
  2.011703249728963E-020
  -6.34438706107691
  -6.34437653625139
 -1.264171445562565E-004
   21.1477659099342
  1.046648117310162E-006
 -5.083770636114452E-006
 -5.256851102678429E-004
 -5.094502363535248E-004
  -2.11481626919735
  5.823351512373315E-021
  -6.34438706107884
  -6.34437653625137
 -1.264150685225949E-004
   21.1477659118888
  1.046648117302923E-006
 -5.083658252247140E-006
 -5.256727770968291E-004
 -5.094405943802322E-004
  -2.11481626880763
 -1.122318655111948E-020
  -6.34438706108032
  -6.34437653625136
 -1.264133947576435E-004
   21.1477659134647
  1.046648117297085E-006
 -5.083567645248807E-006
 -5.256628345173452E-004
 -5.094328202145093E-004
  -2.11481626849336
 -9.846758011831241E-021
  -6.34438706108166
  -6.34437653625134
 -1.264120454310595E-004
   21.1477659147349
  1.046648117292380E-006
 -5.083494591646390E-006
 -5.256548179658953E-004
 -5.060815356522641E-004
  -2.11481612917191
  9.634999775017666E-021
  -6.34438704980852
  -6.34437652443437
 -1.255838927712457E-004
   21.1477669158700
  1.046648079563715E-006
 -5.052001680164712E-006
 -5.221992149526888E-004
 -5.094214993561429E-004
  -2.11481626803592
 -1.334076891925523E-020
  -6.34438706108344
  -6.34437653625133
 -1.264100803690820E-004
   21.1477659165851
  1.046648117285528E-006
 -5.083388213539689E-006
 -5.256431465981643E-004
 -5.094174263164934E-004
  -2.11481626787136
  2.498747194400186E-020
  -6.34438706108419
  -6.34437653625132
 -1.264093730730575E-004
   21.1477659172509
  1.046648117283062E-006
 -5.083349932254337E-006
 -5.256389452363801E-004
 -5.094141422235573E-004
  -2.11481626773828
 -2.181109839179823E-020
  -6.34438706108463
  -6.34437653625132
 -1.264088029015316E-004
   21.1477659177879
  1.046648117281073E-006
 -5.083319077048680E-006
 -5.256355589611024E-004
 -5.094114937407896E-004
  -2.11481626763190
  4.707452519968607E-015
  -6.34438706108507
  -6.34437653625131
 -1.264083432749158E-004
   21.1477659182206
  1.046648117279471E-006
 -5.083294199208046E-006
 -5.256328284725790E-004
 -5.094093599136891E-004
  -2.11481626754524
 -4.891531625890043E-015
  -6.34438706108553
  -6.34437653625131
 -1.264079727456793E-004
   21.1477659185693
  1.046648117278179E-006
 -5.083274140832774E-006
 -5.256306281535075E-004
 -2.943296861707911E-004
  -1.05740813373827
 -3.278720682676122E-006
  -3.17219906218562
  -3.17218826816752
 -3.613763829702449E-004
   10.5732933234176
  5.592671362847189E-003
 -2.833869742587263E-006
 -3.018267318854513E-004
        1010
 -8.338417188609290E-008
 -3.241210828438684E-007
 -6.244957548924484E-089
 -4.511105188913592E-006
 -0.333032008552731
  1.643014585787483E-005
 -1.443174261402130E-005
  1.577608636962097E-002
 -7.524184291697959E-008
 -2.403457011040645E-008
 -8.338417188713679E-008
 -3.241210824965483E-007
 -8.686834889600580E-081
 -4.511105184123918E-006
 -0.333032008552736
  1.643014585795265E-005
 -1.443174261408780E-005
  1.577608636962091E-002
 -7.524184291792769E-008
 -2.403457010790807E-008
 -8.338417188715606E-008
 -3.241210824965987E-007
 -2.416704988543999E-072
 -4.511105184124334E-006
 -0.333032008552736
  1.643014585796528E-005
 -1.443174261409885E-005
  1.577608636962090E-002
 -7.524184291794283E-008
 -2.403457010790288E-008
 -6.723349845920686E-064
 -0.333032008552736
 -1.870457228537256E-055
 -0.333032008552736
 -5.203671270966238E-047
 -0.333032008552736
 -1.447677834229612E-038
 -0.333032008552736
 -4.027485601200533E-030
 -0.333032008552736
 -8.338417188715691E-008
 -1.120459254424483E-021
 -0.333032008552736
 -7.524184291794378E-008
 -2.403457010790352E-008
 -8.338417188715466E-008
  2.240782918675702E-021
 -0.333032008552736
  1.643014585796529E-005
 -7.524184291794135E-008
 -2.403457010790050E-008
 -1.120323657540709E-021
 -0.333032008552736
 -2.683024578529301E-030
 -0.333032008552736
 -6.425483243649848E-039
 -0.333032008552736
 -1.538816872749498E-047
 -0.333032008552736
 -3.685259579812523E-056
 -0.333032008552736
 -8.825701362588855E-065
 -0.333032008552736
  2.205048830349716E-072
 -0.333032008552736
  6.722536176564006E-064
 -0.333032008552736
  1.870230863144302E-055
 -0.333032008552736
  5.203041515271167E-047
 -0.333032008552736
  1.447502634200006E-038
 -0.333032008552736
  4.026998189167354E-030
 -0.333032008552736
 -8.338417188715575E-008
  1.120323654852599E-021
 -0.333032008552736
 -7.524184291794243E-008
 -2.403457010790055E-008
 -8.338417188715765E-008
 -3.241210824965988E-007
 -2.240782918580883E-021
 -0.333032008552736
 -1.443174261409884E-005
 -7.524184291794463E-008
 -2.403457010790426E-008
 -8.338417184946561E-008
 -3.241210824925158E-007
  1.146793082584984E-021
 -4.511105184111806E-006
 -0.333032008552713
  1.643014584517168E-005
 -1.443174260710825E-005
  1.577608636962845E-002
 -7.524184292081215E-008
 -2.403457007464408E-008
 -8.295560392964903E-008
 -3.240915569992925E-007
  7.326153679145363E-015
 -4.511105173310567E-006
 -0.333032008440761
  1.643013399645413E-005
 -1.443173404139269E-005
  1.577608637592672E-002
 -7.524271399717454E-008
 -2.403193695297238E-008
 -8.338417182214991E-008
 -3.241210827655244E-007
  8.049174931316722E-017
 -4.511105189004981E-006
 -0.333032008552731
  1.643014585803528E-005
 -1.443174261409143E-005
  1.577608636962095E-002
 -7.524184285103302E-008
 -2.403457006763838E-008
 -8.338417188714108E-008
 -3.241210824964904E-007
 -2.240590154432253E-021
 -4.511105184125209E-006
 -0.333032008552736
  1.643014585795435E-005
 -1.443174261408930E-005
 -7.524184291793147E-008
 -2.403457010790887E-008
 -8.338417188713910E-008
 -3.241210824964924E-007
  1.120323657541162E-021
 -4.511105184125210E-006
 -0.333032008552736
  1.643014585795436E-005
 -1.443174261408931E-005
 -7.524184291792946E-008
 -2.403457010790495E-008
 -8.338417188713941E-008
 -1.343981908475667E-030
 -0.333032008552736
 -7.524184291792975E-008
 -2.403457010790717E-008
 -8.338417188714029E-008
 -1.120323654852574E-021
 -0.333032008552736
 -7.524184291793065E-008
 -8.338417188713833E-008
  2.240782918675514E-021
 -0.333032008552736
 -7.524184291792859E-008
 -2.403457010790431E-008
 -1.120459261139591E-021
 -0.333032008552736
 -1.120323657535923E-021
 -0.333032008552736
  2.240782914648507E-021
 -0.333032008552736
 -8.338417188714116E-008
 -2.240782911965157E-021
 -0.333032008552736
 -7.524184291793150E-008
 -2.403457010790876E-008
  2.240782915992164E-021
 -0.333032008552736
 -0.333032008552736
 -0.333032008552736
 -0.333032008552736
 -0.333032008552736
 -1.120323661563416E-021
 -0.333032008552736
  1.120323664251543E-021
 -0.333032008552736
  1.120459261134489E-021
 -0.333032008552736
 -1.120459259795609E-021
 -0.333032008552736
 -6.710355995153332E-030
 -0.333032008552736
 -1.120323658880067E-021
 -0.333032008552736
  1.120323660224049E-021
 -0.333032008552736
 -8.338417188713939E-008
  6.721074294077321E-030
 -0.333032008552736
 -7.524184291792973E-008
 -2.403457010790733E-008
 -8.338417188731790E-008
 -3.241210824964570E-007
  1.123395861669665E-021
 -4.511105184126588E-006
 -0.333032008552736
  1.643014585804372E-005
 -1.443174261416745E-005
  1.577608636962440E-002
 -7.524184291816330E-008
 -2.403457010775047E-008
 -8.339938183576963E-008
 -3.241219219748727E-007
  8.169694985577568E-016
 -4.511113913191772E-006
 -0.333032024428145
  1.643560292830082E-005
 -1.443651402716854E-005
  1.577608450179245E-002
 -7.589752923070914E-008
 -2.210376648956267E-008
 -8.333857954818737E-008
 -3.241335242058581E-007
 -8.608739088952169E-015
 -4.511048407671012E-006
 -0.333034298600979
  1.630149381697741E-005
 -1.430200356995096E-005
  1.579654413153522E-002
 -7.508112430862753E-008
 -2.404727829547334E-008
 -8.319595048933168E-008
 -3.241739293961036E-007
  2.486129352897566E-021
 -4.510892283819484E-006
 -0.333041525534156
  1.589915936014586E-005
 -1.389627583721517E-005
  1.586135358259596E-002
 -7.457851613459461E-008
 -2.408697512681972E-008
 -8.304057915783950E-008
 -3.242208054051449E-007
  1.231230201853829E-021
 -4.510762412572393E-006
 -0.333049510327177
  1.546098137068040E-005
 -1.345441392124834E-005
  1.593340487742060E-002
 -7.403119928065080E-008
 -2.413018177159356E-008
 -8.289372739973350E-008
 -3.242681485393357E-007
  4.868160466869150E-022
 -4.510682498459712E-006
 -0.333057166119290
  1.504695833669005E-005
 -1.303692255875233E-005
  1.600293445613365E-002
 -7.351411540532835E-008
 -2.417096808053362E-008
 -8.276251842578570E-008
 -3.243132279194307E-007
  3.394947454757295E-022
 -4.510650288893693E-006
 -0.333064097176219
  1.467715304076277E-005
 -1.266403090753128E-005
  1.606626602830690E-002
 -7.305230894892753E-008
 -2.420736073401025E-008
 -8.264865965645245E-008
 -3.243546962792262E-007
  2.226613440730950E-022
 -4.510655477576764E-006
 -0.333070181993772
  1.435634649442817E-005
 -1.234055678846346E-005
  1.612217074160450E-002
 -7.265173399889169E-008
 -2.423889827170745E-008
 -8.255157479589254E-008
 -3.243919439166894E-007
  8.741454193501803E-023
 -4.510686531392372E-006
 -0.333075422516211
  1.408288012298051E-005
 -1.206482444809987E-005
  1.617055053488133E-002
 -7.231030235501433E-008
 -2.426575431047336E-008
 -8.246975777336901E-008
 -3.244247957885168E-007
  9.667899492719235E-023
 -4.510733317947243E-006
 -0.333079876473872
  1.385248092292148E-005
 -1.183252233384284E-005
  1.621183971294984E-002
 -7.202266561483954E-008
 -2.428835893077813E-008
 -8.240139237595596E-008
 -3.244533455728236E-007
  1.333161700734427E-023
 -4.510787911533156E-006
 -0.333083624699319
  1.366000750549110E-005
 -1.163846391712367E-005
  1.624670944777031E-002
 -7.178239389808366E-008
 -2.430722567526031E-008
 -8.234464052878215E-008
 -3.244778522706501E-007
  8.563728595763292E-023
 -4.510844605264085E-006
 -0.333086754670682
  1.350026337232488E-005
 -1.147740775199283E-005
  1.627591431040235E-002
 -7.158299161582750E-008
 -2.432287138535402E-008
 -8.229777509410203E-008
 -3.244986697140573E-007
  1.456744096877431E-023
 -4.510899601882447E-006
 -0.333089352053330
  1.336837237996986E-005
 -1.134443597874725E-005
  1.630021009639248E-002
 -7.141836598682198E-008
 -2.433578002698283E-008
 -8.225923945376521E-008
 -3.245161972780775E-007
 -5.782741253222975E-024
 -4.510950606520317E-006
 -0.333091496418418
  1.325994000476298E-005
 -1.123511681495079E-005
  1.632030986963359E-002
 -7.128302704862886E-008
 -2.434638613301154E-008
 -8.222766444567607E-008
 -3.245308445850917E-007
  3.499701431167479E-023
 -4.510996427323985E-006
 -0.333093259267444
  1.317110559856265E-005
 -1.114555712672112E-005
  1.633686181769703E-002
 -7.117215335793220E-008
 -2.435507071661316E-008
 -8.220186835582693E-008
 -3.245430077541056E-007
  1.762351942027062E-023
 -4.511036635520087E-006
 -0.333094703383003
  1.309853766101157E-005
 -1.107239756056702E-005
  1.635044013688226E-002
 -7.108158451533732E-008
 -2.436216172308460E-008
 -8.218084406552327E-008
 -3.245530549582387E-007
  7.878634781756971E-024
 -4.511071295393695E-006
 -0.333095882951206
  1.303939957937057E-005
 -1.101277791833670E-005
  1.636154382310850E-002
 -7.100777862222163E-008
 -2.436793832248883E-008
 -8.216374327057668E-008
 -3.245613177837353E-007
 -5.397584588294846E-024
 -4.511100763902632E-006
 -0.333096844119302
  1.299130123409987E-005
 -1.096428830048561E-005
  1.637060015052214E-002
 -7.094775186514581E-008
 -2.437263507901227E-008
 -8.214985668966015E-008
 -3.245680883392535E-007
  4.218140874307891E-021
 -4.511125550288737E-006
 -0.333097625775398
  1.295224546596078E-005
 -1.092491508165775E-005
  1.637797072917963E-002
 -7.089901121056289E-008
 -2.437644769133028E-008
 -8.213859528262123E-008
 -3.245736192921307E-007
 -4.087189538260720E-021
 -4.511146221936746E-006
 -0.333098260413949
  1.292057466007207E-005
 -1.089298702615173E-005
  1.638395874970752E-002
 -7.085948717947242E-008
 -2.437953875495975E-008
 -8.212947276330660E-008
 -3.245781268539299E-007
  1.266254404026546E-022
 -4.511163346423627E-006
 -0.333098775002054
  1.289492053032331E-005
 -1.086712463440838E-005
  1.638881651617584E-002
 -7.082747218787215E-008
 -2.438204231508626E-008
 -8.212208957401094E-008
 -3.245817926048152E-007
 -9.830952899720251E-024
 -4.511177456464825E-006
 -0.333099191796292
  1.287415864397413E-005
 -1.084619427825718E-005
  1.639275271521431E-002
 -7.080156270579034E-008
 -2.438406806143053E-008
 -8.211611871589195E-008
 -3.245847689602188E-007
 -1.568342885615921E-023
 -4.511189032767604E-006
 -0.333099529083400
  1.285736829377697E-005
 -1.082926773580888E-005
  1.639593911055227E-002
 -7.078060969711747E-008
 -2.438570611288287E-008
 -8.211129254335904E-008
 -3.245871821984749E-007
 -3.853229492247418E-023
 -4.511198497726688E-006
 -0.333099801833960
  1.284379781925782E-005
 -1.081558721952919E-005
  1.639851651493437E-002
 -7.076367467977718E-008
 -2.438702986081544E-008
 -8.210739383654908E-008
 -3.245891369467323E-007
 -4.186617395048462E-023
 -4.511206215334569E-006
 -0.333100022267744
  1.283283502446498E-005
 -1.080453555068078E-005
  1.640059999666906E-002
 -7.074999404908045E-008
 -2.438809917064173E-008
 -8.210424553292237E-008
 -3.245907186705241E-007
 -1.968078171987702E-023
 -4.511212494340975E-006
 -0.333100200335479
  1.282398228299749E-005
 -1.079561105501439E-005
  1.640228334211539E-002
 -7.073894683998768E-008
 -2.438896256818479E-008
 -8.210645528644108E-008
 -3.245925148394980E-007
 -3.590575180129631E-017
 -4.511217595467794E-006
 -0.333100344116057
  1.281683255166569E-005
 -1.078840407978787E-005
  1.640364283082635E-002
 -7.073027718373873E-008
 -2.440099778403492E-008
 -8.209965252600075E-008
 -3.245930317072054E-007
 -1.191068187799167E-017
 -4.511221732362545E-006
 -0.333100460197851
  1.281106798971391E-005
 -1.078259211102698E-005
  1.640474040057344E-002
 -7.072283094223931E-008
 -2.439022216355638E-008
 -8.209799736998025E-008
 -3.245938665010844E-007
 -2.641175776904724E-023
 -4.511225078900105E-006
 -0.333100553874124
  1.280641402078696E-005
 -1.077790043530727E-005
  1.640562626971253E-002
 -7.071702323820029E-008
 -2.439067600921412E-008
 -8.209666218386677E-008
 -3.245945408212940E-007
 -2.218977009740676E-023
 -4.511227789941017E-006
 -0.333100629459671
  1.280265937663758E-005
 -1.077411537354125E-005
  1.640634111367591E-002
 -7.071233792044246E-008
 -2.439104204777990E-008
 -8.209558500658798E-008
 -3.245950851795915E-007
 -1.650990959323718E-023
 -4.511229982489681E-006
 -0.333100690438190
  1.279963068351285E-005
 -1.077106214559597E-005
  1.640691784770685E-002
 -7.070855841452415E-008
 -2.439133748178377E-008
 -8.209471619473282E-008
 -3.245955244136708E-007
 -1.174331974007119E-023
 -4.511231754255983E-006
 -0.333100739626010
  1.279718784738427E-005
 -1.076859952154540E-005
  1.640738308812562E-002
 -7.070550999223556E-008
 -2.439157568400194E-008
 -8.209401558670533E-008
 -3.245958787945822E-007
 -3.303475869515094E-024
 -4.511233185593212E-006
 -0.333100779298725
  1.279521771546717E-005
 -1.076661343156243E-005
  1.640775834518771E-002
 -7.070305137329146E-008
 -2.439176785969087E-008
 -8.209345036888638E-008
 -3.245961647147716E-007
 -2.239387273369799E-023
 -4.511234341477283E-006
 -0.333100811294228
  1.279362893101245E-005
 -1.076501177836177E-005
  1.640806099444672E-002
 -7.070106882681782E-008
 -2.439192270724779E-008
 -8.209299491375782E-008
 -3.245963954867169E-007
  1.652224027020812E-024
 -4.511235274620808E-006
 -0.333100837096365
  1.279234775020715E-005
 -1.076372022086950E-005
  1.640830506620082E-002
 -7.069947005016878E-008
 -2.439204761247251E-008
 -8.209262740300614E-008
 -3.245965815684465E-007
 -1.101599448612540E-023
 -4.511236027587680E-006
 -0.333100857902825
  1.279131466825865E-005
 -1.076267877157893E-005
  1.640850188606945E-002
 -7.069818084214526E-008
 -2.439214836538972E-008
 -8.209233089024338E-008
 -3.245967315182275E-007
  4.406774336264436E-024
 -4.511236635317821E-006
 -0.333100874680081
  1.279048166973133E-005
 -1.076183902669265E-005
  1.640866059413143E-002
 -7.069714139289459E-008
 -2.439222968840878E-008
 -8.209209221502473E-008
 -3.245968525146110E-007
 -4.039821579585247E-024
 -4.511237125351514E-006
 -0.333100888207910
  1.278981002657277E-005
 -1.076116194378314E-005
  1.640878856520116E-002
 -7.069630326700289E-008
 -2.439229508059930E-008
 -8.209189942091900E-008
 -3.245969500262708E-007
 -1.891476077088888E-023
 -4.511237520652955E-006
 -0.333100899115333
  1.278926849376623E-005
 -1.076061602526959E-005
  1.640889174881125E-002
 -7.069562751208636E-008
 -2.439234800981305E-008
 -8.209174441920120E-008
 -3.245970288062451E-007
  2.736335549281360E-023
 -4.511237839609705E-006
 -0.333100907909728
  1.278883187562634E-005
 -1.076017587117675E-005
  1.640897494404143E-002
 -7.069508258715930E-008
 -2.439239040924435E-008
 -8.209161907846193E-008
 -3.245970921246258E-007
 -5.307580830015016E-023
 -4.511238096827009E-006
 -0.333100915000312
  1.278847985476974E-005
 -1.075982099901621E-005
  1.640904202157539E-002
 -7.069464332236294E-008
 -2.439242481219308E-008
 -8.209151810506256E-008
 -3.245971432322590E-007
  3.489514639284237E-023
 -4.511238304228064E-006
 -0.333100920717084
  1.278819604130167E-005
 -1.075953488685794E-005
  1.640909610304305E-002
 -7.069428920798688E-008
 -2.439245256778495E-008
 -8.209143673740770E-008
 -3.245971846404256E-007
  1.010146378937816E-023
 -4.511238471492310E-006
 -0.333100925326163
  1.278796722095298E-005
 -1.075930421347037E-005
  1.640913970580284E-002
 -7.069400369822757E-008
 -2.439247477481094E-008
 -8.209137119403522E-008
 -3.245972178485633E-007
 -1.946864431923514E-023
 -4.511238606288694E-006
 -0.333100929042140
  1.278778273965501E-005
 -1.075911823832507E-005
  1.640917485980278E-002
 -7.069377349258445E-008
 -2.439249274561738E-008
 -8.209131828821959E-008
 -3.245972446090551E-007
 -1.708124106819415E-023
 -4.511238715121491E-006
 -0.333100932038053
  1.278763400847715E-005
 -1.075896830261550E-005
  1.640920320188048E-002
 -7.069358785521780E-008
 -2.439250718887099E-008
 -8.172444363259551E-008
 -3.245775030622441E-007
  1.671410817918572E-023
 -4.511238904473879E-006
 -0.333100933635656
  1.278781779885479E-005
 -1.075860002643647E-005
  1.640922585910439E-002
 -7.034779299623005E-008
 -2.414605603251850E-008
 -8.209124113379910E-008
 -3.245972836115867E-007
 -2.314284091831468E-023
 -4.511238873458133E-006
 -0.333100936400708
  1.278741742523692E-005
 -1.075874996559076E-005
  1.640924447385321E-002
 -7.069331747825346E-008
 -2.439252848938491E-008
 -8.209121355937312E-008
 -3.245972976663730E-007
  4.334725525655337E-023
 -4.511238930543843E-006
 -0.333100937970644
  1.278733948844182E-005
 -1.075867139732722E-005
  1.640925932589955E-002
 -7.069322024100353E-008
 -2.439253596826105E-008
 -8.209119122846005E-008
 -3.245973089039781E-007
 -3.781426697047465E-023
 -4.511238976413339E-006
 -0.333100939236334
  1.278727665297279E-005
 -1.075860805315832E-005
  1.640927129975742E-002
 -7.069314190689124E-008
 -2.439254211600485E-008
 -8.209117312006287E-008
 -3.245973181642273E-007
  8.166393188012209E-018
 -4.511239013472271E-006
 -0.333100940256744
  1.278722599589484E-005
 -1.075855698580898E-005
  1.640928095316266E-002
 -7.069307873192055E-008
 -2.439254705141506E-008
 -8.209115711877414E-008
 -3.245973254746535E-007
 -4.050809044659268E-017
 -4.511239032758687E-006
 -0.333100941059827
  1.278717931814685E-005
 -1.075850994347849E-005
  1.640934441282033E-002
 -7.069290061386267E-008
 -2.439255004791285E-008
 -2.494112243329667E-007
 -3.479029262868195E-007
 -1.137580248718141E-008
 -4.472608004520357E-006
 -0.333009969822696
 -2.034575101356445E-005
  1.655702340979619E-005
   175.430613487105
  3.625848640257070E-005
  5.537502804194373E-007
