[petsc-users] Petsc cannot be initialized on vesta in some --mode options
Roc Wang pengxwang at hotmail.com
Wed Jan 22 13:01:32 CST 2014
> From: jeff.science at gmail.com
> Date: Wed, 22 Jan 2014 12:50:28 -0600
> Subject: Re: [petsc-users] Petsc cannot be initialized on vesta in some --mode options
> To: pengxwang at hotmail.com
> CC: jed at jedbrown.org; petsc-users at mcs.anl.gov
> >> From: jed at jedbrown.org
> >> To: pengxwang at hotmail.com; petsc-users at mcs.anl.gov
> >> CC: jeff.science at gmail.com
> >> Subject: RE: [petsc-users] Petsc cannot be initialized on vesta in some
> >> --mode options
> >> Date: Wed, 22 Jan 2014 11:24:21 -0700
> >> Roc Wang <pengxwang at hotmail.com> writes:
> >> > The configure.log is attached.
> >> > I also tried running the program with command like:
> >> > qsub -n <number of nodes> -t 10 --mode <ranks per node> --env
> >> > "F00=a:BAR=b:PAMID_COLLECTIVES=0" ./x.r
> >> > For 1024 as the total number of ranks, the program was able to run in
> >> > c1, c16, c32, and c64 mode, but still petsc cannot be initialized in
> >> > c2, c4, and c8 mode. The runtime log files for c8 mode were
> >> > attached. Thanks.
> >> Hmm, appears to be this line erroring.
> >> ierr = MPI_Bcast(&len,1,MPIU_SIZE_T,0,PETSC_COMM_WORLD);CHKERRQ(ierr);
> >> But at least some processes are stuck in an earlier
> >> PetscOptionsInsertFile (which contains MPI_Bcast). This is like the
> >> problem we have seen before, but it used to go away with
> >> PAMID_COLLECTIVES=0. Can you run with -skip_petscrc? That will skip a
> >> couple MPI_Bcasts and might get it working again.
> >> Jeff, has the Vesta stack changed recently? Any reason why
> >> PAMID_COLLECTIVES=0 would not be taking effect here?
> >> I'll try to reproduce Roc's findings later today.
> > Yeah. The program works with -skip_petscrc. I am trying to run the full
> > PETSc solver and take a look what will happen.
> > I just recalled there was an error caused by calling MPI_Bcast() when I
> > transferred the program from other machine to vesta. At that time I just
> > replace the MPI_Bcast(). I am not sure whether it is the same problem as
> > what we have here. But just for your information.
> You cannot relocate Blue Gene binaries to machines with a different
> driver.  Vesta has a different driver than Mira/Cetus right now.
   There may be some misunderstanding. When I said "transferred the program" I meant that the code was compiled successfully on other machines (local PC and cluster on other institution)  and copy the source code and compile it to vesta, not just copy the executable binary file.
> Jeff
> Jeff Hammond
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140122/65665b34/attachment-0001.html>
