[petsc-users] DMLocalToGlobal
Dharmendar Reddy dharmareddy84 at gmail.com
Tue Jan 21 22:52:41 CST 2014
Hello,
         I did the test again with CHKERRQ(ierr) after each line in
sequence 1 to 4.
I get ierr = 0
 lb begin:           0
 ub begin:           0
 lb end:           0
 ub end :           0
Thanks
Reddy
On Tue, Jan 21, 2014 at 10:04 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jan 21, 2014, at 9:52 PM, Dharmendar Reddy <dharmareddy84 at gmail.com> wrote:
>> Hello,
>>         I am trying to understand the usage rule for DMLocalToGlobalBegin/End.
>> I have a sequence of calls like this:
>> call DMLocalToGlobalBegin(dm, localLB, INSERT_VALUES, LB, ierr)    ----- (1)
>> call DMLocalToGlobalBegin(dm, localUB, INSERT_VALUES, UB, ierr)   ------ (2)
>> call DMLocalToGlobalEnd(dm, localLB, INSERT_VALUES, LB, ierr)    ------- (3)
>> call DMLocalToGlobalEnd(dm, localUB, INSERT_VALUES, UB, ierr)    --------(4)
>> call SNESVISetVariableBounds(snes,LB,UB, ierr)
>> SNES fails to run. I get function norm zero right in the first call
>> and simulation ends.
>> If i change the order of DM calls above to
>> 1,3,2,4 then code works as expected
>> Does that mean the End call should occur immediately after Begin call ?
>   Currently they do need to be called in that order. Note that if you checked the ierr after (2) it would have indicated an error condition. I am surprised that PETSc didn’t print an error message “Scatter ctx already in use”. Note in FORTRAN you can do a lazy check of ierr with
>   call DMLocalToGlobalBegin(dm, localUB, INSERT_VALUES, UB, ierr) ; CHKERRQ(ierr)
>   so it does not make the Fortran code particularly ugly just put the CHKERRQ(ierr) on the same line as the code
>   Barry
>> Thanks
>> Reddy
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
