[petsc-users] DMLocalToGlobal
Dharmendar Reddy dharmareddy84 at gmail.com
Tue Jan 21 21:52:41 CST 2014
Hello,
         I am trying to understand the usage rule for DMLocalToGlobalBegin/End.
I have a sequence of calls like this:
call DMLocalToGlobalBegin(dm, localLB, INSERT_VALUES, LB, ierr)    ----- (1)
call DMLocalToGlobalBegin(dm, localUB, INSERT_VALUES, UB, ierr)   ------ (2)
call DMLocalToGlobalEnd(dm, localLB, INSERT_VALUES, LB, ierr)    ------- (3)
call DMLocalToGlobalEnd(dm, localUB, INSERT_VALUES, UB, ierr)    --------(4)
call SNESVISetVariableBounds(snes,LB,UB, ierr)
SNES fails to run. I get function norm zero right in the first call
and simulation ends.
If i change the order of DM calls above to
1,3,2,4 then code works as expected
Does that mean the End call should occur immediately after Begin call ?
Thanks
Reddy
