[petsc-users] general problem with application based on PETSc
yan chang yan.chang.suse at gmail.com
Sun Jan 19 18:59:12 CST 2014
ok, thank you very much!!
On Sun, Jan 19, 2014 at 10:10 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi,
> ah, sorry, the matrix view was okay, I'm still confused from a recent
> debugging session. If you want to verify that the distribution is okay,
> verify the return values of MatGetOwnerShipRange() to get the rows 'owned'
> by the respective process. In your example you should get {0,1} for the
> first MPI rank and {2,3} for the second.
>  Example:
>> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/
>> examples/tutorials/ex11.c.html
>> Run it with
>>   mpirun -np 2 ./Release/spin-scenarios-petsc  -n 2
>> This is the results:
>> 1+1i
>> 1+1i
>> Norm of error 1.19381e-16 iterations 4
>> Vector Object: 2 MPI processes
>>    type: mpi
>> Process [0]
>> 4.16334e-17
>> 0 + 1.38778e-17 i
>> Process [1]
>> 0
>> 1.11022e-16
>> Matrix Object: 1 MPI processes
>>    type: mpiaij
>> row 0: (0, -7.11111 + 0.0800036 i) (1, -1)  (2, -1)
>> row 1: (0, -1)  (1, -7.11111 + 0.00111359 i) (3, -1)
>> row 2: (0, -1)  (2, -7.11111 + 0.0601271 i) (3, -1)
>> row 3: (1, -1)  (2, -1)  (3, -7.11111 + 0.0943018 i)
>> I am not sure about it, but the results is the same as I tried before
>> with c++ class.
> The output looks okay to me - sorry for the confusion.
>  By the way, I install PETSc using
>> --with-mpi-dir=/usr/local --with-scalar-type=complex
>> --with-clanguage=cxx --with-fortran-kernels=1
>> --with-blas-lapack-dir=/opt/intel/composer_xe_2013_sp1.0.080/mkl
>> --with-debugging=no
> Please perform *all* development using --with-debugging=yes and only use
> optimized builds once everything is working. Chances are high that this
> will save you a lot of headache :-)
> Best regards,
> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140120/45eaa4b0/attachment.html>
