[petsc-users] general problem with application based on PETSc
yan chang yan.chang.suse at gmail.com
Sun Jan 19 07:33:27 CST 2014
Well, to make sure about the results, I again just copy the example and add
two lines before the Destroy code, then ,compile.
Example:
http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex11.c.html
Run it with
 mpirun -np 2 ./Release/spin-scenarios-petsc  -n 2
This is the results:
1+1i
1+1i
Norm of error 1.19381e-16 iterations 4
Vector Object: 2 MPI processes
  type: mpi
Process [0]
4.16334e-17
0 + 1.38778e-17 i
Process [1]
0
1.11022e-16
Matrix Object: 1 MPI processes
  type: mpiaij
row 0: (0, -7.11111 + 0.0800036 i) (1, -1)  (2, -1)
row 1: (0, -1)  (1, -7.11111 + 0.00111359 i) (3, -1)
row 2: (0, -1)  (2, -7.11111 + 0.0601271 i) (3, -1)
row 3: (1, -1)  (2, -1)  (3, -7.11111 + 0.0943018 i)
I am not sure about it, but the results is the same as I tried before with
c++ class.
By the way, I install PETSc using
--with-mpi-dir=/usr/local --with-scalar-type=complex --with-clanguage=cxx
--with-fortran-kernels=1
--with-blas-lapack-dir=/opt/intel/composer_xe_2013_sp1.0.080/mkl
--with-debugging=no
Isn’t it strange? Or can you run it again to make sure about it?
On Sun, Jan 19, 2014 at 9:11 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi Yan,
> > Right now I test  'src/ksp/ksp/examples/tutorials/ex11.c'  with n=2
>> I rewrite the sample into a c++ class, and run it as mpirun -np 2  .....
>> I notice that the vector x is stored in 2 processors.
>> But the matrix A seems not as you told me 'MatView should report your
>> matrix R as being equally split over the MPI ranks.'
>>    type: mpi
>> Process [0]
>> 4.16334e-17
>> 0 + 1.38778e-17 i
>> Process [1]
>> 0
>> 1.11022e-16
> This looks good.
>>    type: mpiaij
> This doesn't. How to do you create the matrix and set its sizes?
> Best regards,
> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140119/a897d9ec/attachment-0001.html>
