[petsc-users] computing matrix exponentials
amlan barua abarua at iit.edu
Sat Jan 18 03:00:26 CST 2014
Jose,
Thanks for pointing out slepc. Looks like I can get started. Can I bind
slepc to petsc or currently it works independently?
Amlan
On Sat, Jan 18, 2014 at 1:43 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> The latest SLEPc version can do exp(tA)*v with a Krylov method (similar to
> Expokit), see the MFN class. This is quite experimental. Send feedback to
> slepc-maint.
> Jose
> El 18/01/2014, a las 08:39, amlan barua escribió:
> > I would like to explore some exponential time differencing schemes.
> > Amlan
> > On Sat, Jan 18, 2014 at 1:06 PM, Jed Brown <jed at jedbrown.org> wrote:
> > amlan barua <abarua at iit.edu> writes:
> > > Hi,
> > > Is there a way to compute matrix exponentials in Petsc?
> > There isn't a function to do it, but you can implement various
> > algorithms using PETSc.  What do you want to use the exponential for?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140118/f099f968/attachment.html>
