[petsc-users] MatAssemblyEnd hangs during a parallel calculation with PETSc>3.3
Jed Brown jed at jedbrown.org
Thu Jan 16 08:12:59 CST 2014
Projet_TRIOU <triou at cea.fr> writes:
> Sorry a typo, it is really MatMPISBAIJSetPreallocation()
> Yes, I call MatMPISBAIJSetPreallocation() on ALL processes and
> sometimes a local part of the matrix has zero rows. It worked well
> with Petsc 3.3 and before in this particular case.
I believe this is the relevant conditional:
  if (nz >= 0 || nnz) realalloc = PETSC_TRUE;
Instead of this:
       if (nb_rows==0) // Local matrix is empty
          ierr = MatMPISBAIJSetPreallocation(MatricePetsc, block_size_, 0, NULL, 0, NULL);
       else
          ierr = MatMPISBAIJSetPreallocation(MatricePetsc, block_size_, PETSC_DEFAULT, d_nnz.addr(), PETSC_DEFAULT, o_nnz.addr());
can you just call the following?
          ierr = MatMPISBAIJSetPreallocation(MatricePetsc, block_size_, 0, d_nnz.addr(), 0, o_nnz.addr());
If you are passing an nnz array (can be empty if there are zero rows),
we will trust that.  PETSC_DEFAULT is only intended to be used if you
don't pass an array, though we're currently being tolerant by ignoring
it if the array is non-NULL.  The problem arises because we can't tell
the difference between a zero-length semantically-meaningful array and
an "I'm not passing this argument" NULL.
Is this something we can fix in the documentation or should we guard in
the code?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140116/6451b7d1/attachment-0001.pgp>
