[petsc-users] MatAssemblyEnd hangs during a parallel calculation with PETSc>3.3
Wed Jan 15 14:28:52 CST 2014
  Hmm, sometimes you talk about MatMPIAIJSetPreallocation() and sometimes MatMPISBAIJSetPreallocation() which one is it?
  If a process has zero rows that should not affect the nonew variable.
   It is crucial the the SetPreallocation routines be called on ALL processes that share the matrix, even if they have zero rows, but it shouldn’t matter what the values are for a matrix with zero rows.
   Can you send use your test case so we can track down the problem?
    Barry
On Jan 15, 2014, at 5:57 AM, Projet_TRIOU <triou at cea.fr> wrote:
> Hi all,
> I switched from PETSc 3.3 to PETSc 3.4.3 and all was fine except for
> one of my test case on 3 processors where one processor was
> dealing an empty local part of the global matrix.
> My code hangs just during the call at MatAssemblyEnd:
> ierr = MatMPIAIJSetPreallocation(MatricePetsc, PETSC_DEFAULT, d_nnz.addr(), PETSC_DEFAULT, o_nnz.addr());
> ierr = MatAssemblyEnd(MatricePetsc, MAT_FINAL_ASSEMBLY);
> When I debugged, I notice on the empty processor, that in
> src/mat/impls/aij/mpi/mpiaij.c:
>  if (!((Mat_SeqAIJ*)aij->B->data)->nonew) {
>    ierr = MPI_Allreduce(&mat->was_assembled,&other_disassembled,1,MPIU_BOOL,MPI_PROD,PetscObjectComm((PetscObject)mat));CHKERRQ(ierr);
>    if (mat->was_assembled && !other_disassembled) {
>      ierr = MatDisAssemble_MPIAIJ(mat);CHKERRQ(ierr);
> ((Mat_SeqAIJ*)aij->B->data)->nonew was 0 on the "empty" processor
> and -2 on the 2 others...
> I bypassed my problem with a different call to MatMPIAIJSetPreallocation():
>      if (nb_rows==0) // Local matrix is empty
>         ierr = MatMPISBAIJSetPreallocation(MatricePetsc, block_size_, 0, NULL, 0, NULL);
>      else
>         ierr = MatMPISBAIJSetPreallocation(MatricePetsc, block_size_, PETSC_DEFAULT, d_nnz.addr(), PETSC_DEFAULT, o_nnz.addr());
> Now, it runs well. So I don't know if it is a PETSc regression or if I was abusively
> calling MatMPISBAIJSetPreallocation with d_nnz/o_nnz empty arrays....
> Thanks,
> Pierre
