[petsc-users] PETSc/VC12 compilation
Abilash Nair abilash at gmail.com
Wed Jan 15 11:47:12 CST 2014
Thanks! it compiles fine.
On Tue, Jan 14, 2014 at 4:48 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Latest slepc [3.4] should work with petsc-3.4
> If you encounter problems - let us know.
> Satish
> On Tue, 14 Jan 2014, Abilash Nair wrote:
> > Thanks Satish, I was able to get to a successful petsc build.
> > In a related question: could you please direct me to the version of slepc
> > that compiles well with this installation of petsc? also, are there any
> > special configurations that you would recommend for a VS2012-slepc build?
> > Thanks,
> > Abilash.
> > On Tue, Jan 14, 2014 at 3:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Configure Options: --configModules=PETSc.Configure
> > > --optionsModule=PETSc.compilerOptions --with-mpi=0
> > > --download-f2cblaslapack=1 --with-fc=0 --with-cxx="win32fe cl"
> > > --with-debugging=1 --useThreads=0
> > > You've removed the option: --with-cc="win32fe cl"
> > > You need both: --with-cc="win32fe cl" --with-cxx="win32fe cl"
> > > Suggest:
> > > rm -rf arch-mswin-c-debug
> > > rerun configure...
> > > Satish
> > > > Thank you Satish for that input. I had a successful build and test on
> > > > cygwin, However I notice two things: a) when I make a test case, say
> ex1,
> > > > the make calls gcc; instead of win32fe cl and b) The petsc archive
> > > created
> > > > is a ".a" extension, my assumption was that a ".lib" would be
> generated
> > > in
> > > > this exercise. In any case, I am unable to build "ex1" as a project
> in
> > > > VS2012, is there some flags that I need to play around with?
> > > > I send the config, make and test logs with this email.
> > > > Thank you greatly,
> > > > Abilash.
> > > > On Tue, Jan 14, 2014 at 11:37 AM, Satish Balay <balay at mcs.anl.gov>
> > > wrote:
> > > > > Try adding configure option: --with-cxx='win32fe cl'
> > > > > Satish
> > > > > > Hello all,
> > > > > > I am trying to build petsc to use as a library on a visual C++
> > > project.
> > > > > > I configured the petsc (v3.4.3) with VC++ 2012 under the shell
> > > provided
> > > > > by
> > > > > > VC2012 with the following command (in cygwin):
> > > > > > ./config/configure.py --with-mpi=0 --download-f2cblaslapack=1
> > > --with-fc=0
> > > > > > --with-cc='win32fe cl' --with-debugging=1
> > > > > > then I did a make all; make test while still in cygwin. I have
> sent
> > > the
> > > > > log
> > > > > > file outputs from these commands. As the files show, I am able to
> > > make
> > > > > with
> > > > > > no errors at all, however I am unable to execute any of the tests
> > > (error
> > > > > > being that a libstcc++.lib not found).
> > > > > > I hope you would be able to suggest a path forward.
> > > > > > Thanks!
> > > > > > Abilash.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140115/44a59238/attachment.html>
