[petsc-users] DMPlexMatSetClosure from Fortran
Dharmendar Reddy dharmareddy84 at gmail.com
Mon Jan 13 12:32:59 CST 2014
Hello Jed,
              I see that plex.c has the following lines in the
function DMPLexMatSetClosure:
5640   PetscValidHeaderSpecific(section, PETSC_SECTION_CLASSID, 2);
5641  PetscValidHeaderSpecific(globalSection, PETSC_SECTION_CLASSID, 3);
the petsc code i have is at : v3.4.3-2568-gb45093d
Does the fix you pushed takes care of above calls, even if i pass null object ?
I do not see a code related to retrieving the defualt and default
globalsections when a null is passed to DMPlexMAtSetClosure.
Thanks
Reddy
On Mon, Jan 13, 2014 at 9:12 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Dharmendar Reddy <dharmareddy84 at gmail.com> writes:
>> Hello,
>>          I had my code working earlier, but after an update to
>>  Petsc Development GIT revision: b45093d79c132b908a729253318f8991
>> 55602205  GIT Date: 2013-11-11 16:19:16 -0600
>> I am seeing errors related to some DMPlex routines. I fixed some based
>> on earlier queries. Looks like i have found one more.
> I pushed a commit to 'next'.  Please pull and let me know if it works for you.
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
