[petsc-users] Compare PETSc FD Jacobian with hand-coded Jacobian for parallel computations
Matteo Parsani parsani.matteo at gmail.com
Mon Jan 13 08:52:51 CST 2014
Dear All,
I have been using -snes_check_jacobian -snes_check_jacobian_view petsc to
verify the correctness of my hand-coded Jacobian.
I would like to know if there is also a way to run such a command line
options using at least 2 processors.
Thank you in advance.
Best Regards
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140113/26e49be3/attachment.html>
