[petsc-users] query DMPlexCreateSection
Brad Aagaard baagaard at usgs.gov
Fri Jan 10 14:37:48 CST 2014
On 01/10/2014 11:19 AM, Dharmendar Reddy wrote:
> Hello,
>          I was able to create the petsc section as per your advice.
>>    DMPlexSetChart()
>>    <loop over region 1>
>>      DMPlexSetDof() and DMPlexSetFieldDof()
>>    <loop over region 2>
> I could program the code upto this step.
>    ! Create Section
>    call PetscSectionCreate(comm, section, ierr)
>    ! This call sets the number of fields in the section. Default number
> of compents per field is 1
>    call PetscSectionSetNumFields(section, numField, ierr)
>    ! Set the number of componets per field
>    do fid=0,numField-1
>      call PetscSectionSetFieldComponents(section, fid, numComp(fid+1), ierr)
>    end do
>    ! Set the chart for section
>    call DMPlexGetChart(meshDM, cellIdStart, cellIdEnd, ierr)
>    call PetscSectionSetChart(section, cellIdStart, cellIdEnd, ierr)
>    print*,'Sucessfully set chart',cellIdStart,cellIdEnd
>    rgnLabel = "region"
>    call DMPlexGetLabelIdIS(meshDM,rgnLabel,regionIS,ierr)
>    call ISView(regionIS,PETSC_VIEWER_STDOUT_SELF,ierr)
>    call ISGetIndicesF90(regionIS, regionId, ierr)
>    print*, 'region', regionId
>    do jc=1,size(regionId) ! Loop Over region1
>      rgnId = regionId(jc)
>      call DMPlexGetStratumIS(meshDM, "region",rgnId, regionCellIS, ierr)
>      !print*,'Number of cells in region',rgnId
>      call ISGetSize(regionCellIS, numCell, ierr)
>      !print*,'Number of cells in region',rgnId, 'is',numCell
>      call ISGetIndicesF90(regionCellIS, regionCell, ierr)
>      do ic=1,numCell ! Get the cells of this region and loop over Cells
>        cellId = regionCell(ic)
>        ! Get the dimension of the cell
>        call DMPlexGetLabelValue(meshDM, "depth", cellId, cellDim, ierr)
>        do fid=0,numField-1 ! Loop over fields
>           ! Set field only if the field is defined for this region
>           !print*, 'settinf Field
> for',cellId,cellDim,fid,rgnId,numDof(fid+1,cellDim+1)
>           if(fieldInRegion(fid+1,rgnId)) then
>              call PetscSectionSetFieldDof(section, cellId, fid,
> numDof(fid+1,cellDim+1), ierr)
>           end if
>        end do
>        call  PetscSectionSetDof(section, cellId,
> numDofTot(cellDim+1,rgnId), ierr)
>      end do
>      call ISRestoreIndicesF90(regionCellIS, regionCell, ierr)
>    end do
>    call ISRestoreIndicesF90(regionIS, regionId, ierr)
> Now I need to work on the code for BC. Can you help me with a bit more
> detail here.
>>    <loop over BC>
>>      DMPlexSetConstraintDof() and DMPlexSetFieldConstraintDof()
Use DMPlexSetConstraintDof() to set the number of DOF constrained at
each point on the BC. DMPlexSetFieldConstraintDof() is used if you have
multiple fields in a section.
>>    DMPlexSetUp()
>>    <loop over BC>
>>      DMPlexSetConstraintIndices() and DMPlexSetFieldConstraintIndices()
Use DMPlexSetConstraintIndices() to set the indices of the DOF that are
constrained.
For example, one might constrain the DOF normal and/or tangential to a
boundary in an elasticity problem. You first set the size for all the
points, allocate via DMPlexSetUp, and then set the indices for the
constrained DOF at each point.
Brad
> On Thu, Jan 2, 2014 at 9:56 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jan 2, 2014 at 4:11 AM, Dharmendar Reddy <dharmareddy84 at gmail.com>
>> wrote:
>>> Hello,
>>>           I am trying to use DMPlexCreateSection from fortran. I was
>>> able to solve a Poisson equation earlier using DMPlex for handling
>>> mesh data.
>>> Now i need to solve a system of equations: (poisson + continuity
>>> equations)
>>> - div (grad phi) = (C + n)  --- (1)
>>>    div (J ) = 0  ---------------  (2)
>>>    J = n grad(phi)
>>> ( C is constant)
>>> Simulation domain is defined as, rectangular regions 1 and 2 shown below.
>>> |     1        |
>>> |       2      |
>>> Now, equation 1 is defined in region 1 and 2
>>> and equation 2 is defined only for region 2.
>>> How do i setup the section  ? DMPlexCreateSection applies the given
>>> DOF layout  per cell to all cells in the mesh.
>>> I am not sure if all the function calls inside
>>> DMPlexCreateSectionIntial and DMPlexCreateSectionBCDof  are accessible
>>> from Fotran.
>> You don't want them anyway since they apply to the whole domain. The control
>> flow could be:
>>    DMPlexSetChart()
>>    <loop over BC>
>>    DMPlexSetUp()
>>    <loop over BC>
>> We could try and package some of this up if it looks generic.
>>    Thanks,
>>       Matt
>>> Thanks
>>> Reddy
>>> Dharmendar Reddy Palle
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
