[petsc-users] Building Linux 32-bit PETSc lib
Qin Lu lu_qin_2000 at yahoo.com
Thu Jan 9 09:25:00 CST 2014
Thanks a lot for pointing out the problem. Configure passed it after I set the path of libirc.so.
Qin
On Wednesday, January 8, 2014 4:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> ('Linux', 'houhpclc01', '2.6.18-308.4.1.el5', '#1 SMP Tue Apr 17 17:08:10 EDT 2012', 'i686', 'i686')
the machine appears to to be running 32bit linux - so I'm not sure why it has a 64bit libirc.so
[and the paths linker is referencing to are 32bit library paths]
The workarround to try [for intel compilers] is:
--with-clib-autodetect=0 --with-fortranlib-autodetect=0 --with-cxxlib-autodetect=0 LIBS="-Bstatic -lifcore -Bdynamic"
Satish
The On Wed, 8 Jan 2014, Barry Smith wrote:
>   Here is how icc is linking a C main program:
> ld    --eh-frame-hdr -dynamic-linker /lib/ld-linux.so.2 -m elf_i386 -o /tmp/petsc-3SW45q/config.compilers/conftest -L/apps/compilers/intel/Compiler/11.1/056/lib/ia32 -L/usr/lib/gcc/i386-redhat-linux/4.1.2/ -L/usr/lib/gcc/i386-redhat-linux/4.1.2/../../../ -L/lib/ -L/usr/lib /usr/lib/gcc/i386-redhat-linux/4.1.2/../../../crt1.o /usr/lib/gcc/i386-redhat-linux/4.1.2/../../../crti.o /usr/lib/gcc/i386-redhat-linux/4.1.2/crtbegin.o /tmp/petsc-3SW45q/config.compilers/conftest.o -ldl -Bstatic -limf -lsvml -Bdynamic -lm -Bstatic -lipgo -ldecimal -Bdynamic -lgcc_s -lgcc -Bstatic -lirc -Bdynamic -lc -lgcc_s -lgcc -Bstatic -lirc_s -Bdynamic -ldl -lc /usr/lib/gcc/i386-redhat-linux/4.1.2/crtend.o /usr/lib/gcc/i386-redhat-linux/4.1.2/../../../crtn.o
>    Since PETSc uses C if you use Fortran it needs to link against this same stuff with the intel Fortran linker. We try to rationalize the above list and get
> Libraries needed to link C code with another linker: ['-ldl', '-L/apps/compilers/intel/Compiler/11.1/056/lib/ia32', '-L/usr/lib/gcc/i386-redhat-linux/4.1.2', '-limf', '-lsvml', '-lipgo', '-ldecimal', '-lgcc_s', '-lirc', '-lirc_s', '-L/apps/compilers/intel/Compiler/11.1/056/lib/ia32', '-L/usr/lib/gcc/i386-redhat-linux/4.1.2’]
> So when it uses ifort to link something it uses
> /apps/compilers/intel/Compiler/11.1/056/bin/ia32/ifort  -o /tmp/petsc-3SW45q/config.setCompilers/conftest    -O3 /tmp/petsc-3SW45q/config.setCompilers/conftest.o -ldl -L/apps/compilers/intel/Compiler/11.1/056/lib/ia32 -L/usr/lib/gcc/i386-redhat-linux/4.1.2 -limf -lsvml -lipgo -ldecimal -lgcc_s -lirc -lirc_s -L/apps/compilers/intel/Compiler/11.1/056/lib/ia32 -L/usr/lib/gcc/i386-redhat-linux/4.1.2 -ldl
> which when running the code results in
> ERROR while running executable: Could not execute "/tmp/petsc-3SW45q/config.setCompilers/conftest":
> /tmp/petsc-3SW45q/config.setCompilers/conftest: error while loading shared libraries: libirc.so: wrong ELF class: ELFCLASS64
> Because the -Bstatic are stripped from the link line the wrong libirc.so gets picked up by the linker resulting in the runtime error.
> I’ve seen these perverse icc link lines mess things up before but don’t remember a solution. Satish must remember!
> Is there a reason to use the 32bit version?  Have you tried using the 64 bit compilers ? Generally I don’t think there is a reason to use 32bit now a days.
> Barry
> On Jan 8, 2014, at 3:21 PM, Qin Lu <lu_qin_2000 at yahoo.com> wrote:
> > Hello,
>> > I am trying to build a Linux 32-bit PETSc lib. I first built python-2.7.5 in a 32-bit Linux workstation without problem, then used this python to configure PETSc-3.4.2 with Intel C/C++/Fortran compilers, it got the following error:
>> > ===============================================================================        TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:161)        *******************************************************************************
> >                     UNABLE to EXECUTE BINARIES for ./configure
> > Cannot run executables created with FC. If this machine uses a batch system
> > to submit jobs you will need to configure using ./configure with the additional option  --with-batch.
> >  Otherwise there is problem with the compilers. Can you compile and run code with your C/C++ (and maybe Fortran) compilers?
> > See http://www.mcs.anl.gov/petsc/documentation/faq.html#libimf
>> > It seems that a test program built with the given Intel ifort does not run. But I have built another program using ifort in the same workstation and it runs fine.
>> > Please see the attached configure.log file for details.
>> > Thanks for your suggestions!
>> > Regards,
> > Qin
>>> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140109/42234331/attachment.html>
