[petsc-users] KSP: domain decomposition and distribution
Dave May dave.mayhem23 at gmail.com
Wed Jan 8 05:34:29 CST 2014
Please check out the manual page for MatSetSizes()
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetSizes.html
Basically you have two choices:
1/ Define the global size of the matrix and use PETSC_DECIDE for the local
sizes.
In this case, PETSc will define the local row size in a manner such that
there are approximately the same number of rows on each process.
2/ Define the local sizes yourself and use PETSC_DETERMINE for the global
size.
Then you have full control over the parallel layout.
The following functions described by these pages
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetSize.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetLocalSize.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetOwnershipRanges.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetOwnershipRangesColumn.html
might also be useful for you in double checking what the matrix
decomposition looks like
Cheers,
  Dave
On 8 January 2014 12:26, mary sweat <mary.sweat78 at yahoo.it> wrote:
> My target is the following. I got a huge linear system with a sparse huge
> matrix, nothing to deal with PDE. How is the system splitted between
> processes? is there in this suggested book the answer?
> Thanks again
>   Il Martedì 7 Gennaio 2014 17:34, Jed Brown <jedbrown at mcs.anl.gov> ha
> scritto:
>  mary sweat <mary.sweat78 at yahoo.it> writes:
> > Hi all,  I need to know how does KSP separate and distribute domain
> > between processes and the way processes share and communicate halfway
> > results. Is there any good documentation about it???
> The communication is in Mat and Vec functions.  You can see it
> summarized in -log_summary.  For the underlying theory, see Barry's
> book.
> http://www.mcs.anl.gov/~bsmith/ddbook.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140108/1d36d0d3/attachment.html>
