[petsc-users] Convergence problem in newton iteration
Danyang Su danyang.su at gmail.com
Tue Jan 7 16:09:28 CST 2014
Hi All,
I have implemented the KSP solver to a CFD problem and it works well for
most of the scenarios. But for some scenarios, it will give out solution 0.
The matrix structure, rhs and solution from PETSc and another sequential
solver can be found in the attached files. Please note that the first
value is the number of data in the file.
For linear equations 1 to 48, it works well and the solutions are the
same as the other solver. For equation 49, PETSc give out zero solution
and the iteration number is 0, but the other solver give out acceptable
solution. The KSPConvergencedReason is 3 for all these equations.
All suggestions and comments are appreciated.
Danyang
        1010
  7.692317852028667E-014
  1.910425722511429E-014
  0.000000000000000E+000
  2.151196235372827E-015
 -1.339343939320253E-016
 -3.993764454413820E-014
 -5.008334547052743E-014
  5.268984928573743E-020
  9.890002749557718E-016
  2.373411932482875E-013
  1.538573278113062E-013
  3.821541946281461E-014
  8.748791553952855E-019
  4.303876048952771E-015
 -2.678687962039133E-016
 -7.987337611730459E-014
 -1.001645039019851E-013
  1.053796948590954E-019
  1.978111847062963E-015
  4.746974971011328E-013
  1.538353828817087E-013
  3.820160943764257E-014
 -8.748791553952855E-019
  4.300908045505591E-015
 -7.987720216512734E-014
 -1.001688779801247E-013
  1.053797022806988E-019
  1.977889209746733E-015
  4.746672817418383E-013
  1.538463553465074E-013
  3.820851445022859E-014
  4.302392047229181E-015
 -7.987528914121596E-014
 -1.001666909410549E-013
  1.053796985698971E-019
  1.978000528404848E-015
  4.746823894214856E-013
  1.538244087228441E-013
  3.819470103692477E-014
 -1.749652431672164E-018
  4.299430820045580E-015
 -7.987911518903871E-014
 -1.001710650191945E-013
  1.053797059915005E-019
  1.977777891088618E-015
  4.746521706740593E-013
  1.538683019701708E-013
  3.822232786353241E-014
  4.305353274412782E-015
 -7.987146732855795E-014
 -1.001623236391788E-013
  1.053796912366462E-019
  1.978223165721077E-015
  4.747126081689118E-013
  1.553904202028566E-013
  3.830728357407612E-014
  4.301185872312291E-015
 -2.675785550705807E-016
  2.536547019053254E-014
  4.015077116267807E-014
 -1.754179218468910E-020
  1.977770317939917E-015
  4.752046576812546E-013
 -1.989747344632443E-009
 -1.345892535095617E-010
  2.167985571881886E-014
 -4.191341369162932E-016
  8.488674496513349E-011
  8.084152326102685E-011
 -1.008259857542674E-019
 -5.493083802893609E-015
  3.815901098776400E-009
  1.548938979330358E-013
  3.828576724314997E-014
 -7.986588114627081E-014
 -1.001573634142397E-013
  1.053796517431138E-019
  1.978111886767632E-015
  4.750554837178285E-013
 -7.987911307145634E-014
 -1.001710599369968E-013
  1.053797059536352E-019
  1.531053514424916E-013
  3.818985431440058E-014
  4.315239842973134E-015
 -2.669360276405291E-016
 -2.626018551818168E-013
 -3.252379648151921E-013
  1.540417226614677E-019
  1.978386090833441E-015
  4.746673420135265E-013
  3.709395705530032E-009
  2.548907476483176E-010
 -6.867319619864240E-019
  4.597538306007690E-013
  1.419230517011317E-015
 -3.834828678624261E-010
 -6.775380444542936E-013
  3.993312964225796E-020
  4.183025348165710E-016
 -3.742440984840552E-009
 -2.022848362076961E-013
 -5.056262212307233E-014
  1.259961509040772E-019
  1.948887963986942E-014
 -2.474866423941331E-016
  7.986204519875049E-014
  9.851581525652676E-014
 -2.406123383533958E-019
 -4.586035038334547E-016
 -1.434917009079163E-013
 -1.479915214458995E-013
 -1.412716548832103E-013
  5.759824041329242E-020
 -1.586579446381103E-014
 -1.928308885604837E-016
 -1.417571428283574E-014
 -5.051763620324366E-014
 -2.896412678114106E-019
  1.076588132111270E-015
  9.490426713243112E-014
  1.926586087558664E-013
 -1.328474700715678E-013
 -1.430426889675700E-019
  2.114734982180261E-014
 -1.455899817377597E-016
  3.898967629215288E-014
  2.439905001400556E-014
  2.735568922994761E-020
  4.265985788436537E-015
 -2.509108181614433E-013
  2.801845202346451E-013
 -3.075512256976373E-014
  9.740878893424454E-020
  1.583217064393683E-014
 -1.102675034622835E-016
 -2.603033761164215E-014
 -6.626142404133218E-014
  5.853522241999534E-019
  2.036809572844533E-015
 -3.138305171784164E-014
 -4.214098860113676E-014
 -3.467479633230321E-014
 -4.129285617864714E-020
  1.702852675490238E-014
 -8.671634793391868E-017
 -1.226288923097511E-013
 -1.416640140969056E-013
 -3.885471549647214E-019
  3.789330583645982E-015
 -2.179288884573443E-013
  2.418001092814634E-013
  7.839071392338158E-015
  2.149346103657787E-020
 -3.441189932833211E-016
 -6.897297968752142E-017
 -1.233855414946379E-013
 -1.414420846884614E-013
  3.854083203495021E-019
  3.694901843356201E-015
  1.758389488511075E-013
  5.576484014005933E-014
  2.278633994001484E-014
 -1.715241718189958E-020
 -3.189180690366111E-016
 -5.745697119955817E-017
 -7.821985422243993E-014
 -6.763112205682154E-014
  4.429098563617727E-019
 -2.920790249872889E-015
  2.853280400859973E-014
 -4.254884028566540E-014
 -3.229574336367953E-014
  1.238785685359414E-020
  8.621081008363535E-015
 -4.786188785217986E-017
 -1.261329704419813E-013
 -1.646141769851830E-013
 -4.836359360865053E-019
 -3.227036589386110E-016
  4.120637236772702E-014
 -3.466241975157573E-014
  4.638333953846299E-014
 -1.334076891925523E-020
 -1.138574911435652E-014
 -4.273560475072743E-017
  8.421503655902892E-014
  8.553203684322132E-014
  4.827473957459752E-019
 -3.182911340645037E-016
 -6.807840601025085E-014
  1.555642349370534E-013
  7.870323350553463E-014
 -6.988021814847978E-021
 -1.416829300366837E-014
 -3.766435232106693E-017
 -1.358580837229167E-013
 -1.668520193971040E-013
 -1.267018570346458E-019
  7.301497843609448E-016
  4.973211886496502E-014
 -4.767260828159964E-015
 -5.710175035719342E-014
  1.185846126156020E-020
  1.603609552005419E-014
 -3.380700398394025E-017
  3.765874475119787E-014
  5.982571175380726E-014
 -1.271027004530992E-019
 -3.095973059687482E-015
 -2.386390153036557E-013
  1.984401159671427E-013
 -7.918433636111381E-014
  7.305659170068340E-021
 -6.868224251051908E-015
 -3.079578200411651E-017
 -1.059658649567400E-013
 -1.524999439608040E-013
 -4.338739733842884E-019
 -1.405102331292325E-016
  1.172454434939465E-013
 -1.878023195768732E-013
 -4.934235766013758E-014
 -1.365840627447559E-020
  1.129253483257708E-014
 -2.964250694176038E-017
  1.038296123677902E-013
  1.151449405658103E-013
 -6.297480498619044E-019
 -1.611333247163966E-015
  6.326176367742666E-014
 -6.571544899696560E-014
 -7.712934125745068E-014
  1.461131834013668E-020
 -2.256390061773639E-014
 -2.800760762210647E-017
  8.354812760322797E-014
  9.063014349956246E-014
 -3.681435656702082E-019
  3.825577052495881E-015
 -5.146853258195318E-014
 -1.959989160852998E-013
 -1.842206535972515E-014
 -1.641126335305207E-020
 -2.634177598270782E-015
 -2.664005307642970E-017
 -7.200948226562847E-014
 -9.604794749525167E-014
 -1.484108233847152E-019
  2.947097255529479E-015
 -1.582784373891492E-013
  1.287504230835409E-013
 -6.663283613024193E-014
  6.670384459627615E-021
 -3.992283120844015E-015
 -2.573864458442862E-017
  5.901729048581620E-014
  9.701481866388351E-014
  7.446975266197469E-019
  1.084556472811919E-015
 -1.181540687331280E-013
  3.042305508184461E-014
  6.677176986238237E-014
  3.677181782267731E-019
  9.610117335159124E-015
 -2.508307417047829E-017
 -4.547209111765320E-014
 -4.013319522902254E-014
  4.404050649630794E-019
  2.447824101249091E-015
 -1.426811217043781E-013
  1.657771183610634E-013
 -5.998055954096072E-014
 -9.169131654027801E-020
  1.287894622762145E-014
 -2.383755854365514E-017
 -7.101354616726322E-014
 -6.351949029964350E-014
 -3.443924135888860E-019
  2.575601895536537E-015
 -2.237119479888452E-014
  1.626285752674819E-013
 -6.871933747141113E-014
 -8.682087709356578E-020
 -2.544843405016123E-014
 -2.438870567707678E-017
  6.801852861593473E-014
  1.225210779592879E-013
 -6.050200704815007E-019
 -3.628957678849555E-016
  2.419877400230024E-013
 -1.817047161338846E-014
 -1.260952537589059E-014
 -2.339928516790005E-020
 -2.016595034405946E-014
 -2.387368979281146E-017
  5.446912722319953E-014
  5.681212268747286E-014
  5.569056775998826E-020
 -1.404535975047474E-015
  1.586305675274035E-013
 -1.271186003199004E-013
  9.948662682242922E-014
 -4.309280119156253E-020
  1.711684179811490E-017
 -2.253419983095739E-017
 -8.309979695530387E-014
 -1.127621945335366E-013
  6.273256579950547E-019
 -3.380109644663802E-015
  7.776869013019325E-014
  1.858524064277344E-013
  4.486433333129522E-014
 -1.842296660278103E-020
  2.144564772077126E-014
 -2.250066262020204E-017
  6.674532218504664E-014
  8.035539668014256E-014
  1.757105544697393E-019
  1.806610384608805E-015
  1.392538110681302E-013
 -1.529342868654558E-013
 -7.363181855142738E-014
 -1.821120836596746E-020
  1.522326237507823E-014
 -2.092408945990047E-017
 -2.104356163069590E-013
 -2.961762067966566E-013
  4.423081225781397E-019
 -8.227528887004539E-016
 -1.483836041562771E-013
 -1.872511398062134E-013
 -8.661496338408826E-014
 -1.725829630030637E-020
  2.212660122399152E-015
 -2.336873242479479E-017
  8.807717550274704E-014
  1.111769300211028E-013
  5.616219354827122E-019
 -1.696619100637893E-015
 -3.643126668304557E-013
  1.803610164791605E-009
  1.233020509408170E-010
 -1.418780186650953E-020
 -9.087423467803862E-015
 -2.268016743057095E-017
 -4.043137417280166E-015
  7.142489792427882E-014
 -2.872878314065473E-016
  1.122477915400608E-015
 -1.721339024630439E-009
 -1.605861409477425E-013
 -1.055714031955113E-013
 -3.388131789017201E-021
 -2.278765284108308E-014
 -2.205848495195569E-017
  5.124152580656023E-014
  4.798231751431282E-014
  5.365431062451634E-019
  1.550157440054829E-015
 -2.324163132073451E-013
 -6.339974003734357E-014
 -7.440964213062742E-016
 -5.823351512373315E-021
 -2.224055764858332E-014
 -2.220651719437818E-017
  1.107555344120965E-013
  1.257311413999356E-013
  1.299525111307020E-019
 -2.481528884114088E-015
 -9.518589386128081E-014
  6.915370554882335E-015
  7.908873005829133E-014
 -2.255225222064575E-020
  1.475172252147355E-015
 -2.152370937721771E-017
 -9.076118870798600E-014
 -1.350264132004685E-013
 -4.529003019228128E-019
  1.492980660674739E-015
 -9.760125447367207E-014
  1.637450415866728E-013
 -5.790995870227737E-014
  9.124577721002225E-015
 -2.218823981156321E-017
 -1.128888182564453E-013
 -1.373983409279399E-013
 -2.331153840551933E-019
 -2.794678022729705E-015
  3.213790826866864E-013
 -6.255713265195022E-014
  6.541362368222767E-014
 -1.831708748437424E-020
 -2.244326957352022E-014
 -2.244505623070377E-017
  4.910057776987667E-014
  5.692196761413870E-014
  2.104821963023263E-019
  1.313910956820612E-015
  3.918491782324636E-014
 -1.069193878655049E-013
  2.925780040604568E-014
  1.270549420881451E-021
  2.504539544506690E-014
 -2.126536432830515E-017
 -7.133163829976692E-014
 -9.492853416314881E-014
 -4.650637308212995E-020
 -9.945649196828109E-016
  3.791779723144007E-014
 -1.902243257980104E-013
  9.847536604516358E-014
 -9.952637130238029E-021
  1.731810360264610E-014
 -2.188312927953935E-017
 -2.672745602397671E-015
 -1.445482053280198E-014
 -7.056260552229103E-019
 -2.167111538394590E-015
 -1.034153035393464E-013
  1.566768285686699E-013
 -4.460274753432646E-014
  7.093900933254765E-021
  2.796513156677963E-014
 -2.155300480579189E-017
  7.741095700134184E-014
  8.750379571322367E-014
  3.050365989700803E-019
 -2.426942270688927E-016
  2.465330489434055E-013
 -3.602353008647166E-013
  5.743370934548596E-014
  9.052207225988818E-015
 -2.179316511611808E-017
 -4.469092916984979E-014
 -7.884495397607154E-014
  6.048585617692710E-019
  3.239685500098327E-015
 -3.475305496361457E-014
 -2.584788078557295E-014
  8.269567417450684E-015
 -1.694065894508601E-021
 -9.045098925495459E-015
 -2.196296213481807E-017
 -3.705927692923422E-014
 -4.550075153621474E-014
 -3.135868464136965E-020
 -1.889716087876460E-015
 -1.755986530155098E-013
 -2.179240909156706E-013
 -5.816010277819462E-014
  4.235164736271502E-022
 -1.006630895175956E-014
 -2.254710384851322E-017
  8.231623864541356E-014
  1.251399191790157E-013
 -1.184064723110423E-019
  2.037681248639609E-015
 -1.058760018284675E-013
 -1.443330552271782E-013
  7.916720766085444E-014
 -1.355252715606881E-020
 -1.470558971903430E-014
 -2.162442027115727E-017
 -5.525721932987958E-014
 -6.505266397988704E-014
  4.505414362547323E-019
 -1.174947154907148E-015
 -2.465370936845473E-013
  2.114144279666994E-013
  7.222941489977864E-014
  5.717472393966527E-021
  1.180084269235618E-014
 -2.150021083037630E-017
 -1.319723042484594E-014
 -1.059403419482151E-014
  2.926046646522465E-019
  2.179681179044539E-015
  2.442671698468095E-013
 -2.598792433998555E-013
 -4.062165880091336E-014
  5.150908996207071E-016
 -2.171810343861257E-017
 -7.190140816721799E-015
 -3.216035022925862E-015
  6.011918337361970E-019
  5.060090062080907E-016
 -2.470453144852213E-013
 -7.423419926675707E-014
 -7.349304914367871E-014
  5.611593275559740E-021
 -2.568619281032372E-014
 -2.150814514681191E-017
  4.869906877393619E-014
  4.579393674431376E-014
 -4.606906701569477E-019
  3.319191853437393E-016
 -1.770716880711823E-013
 -6.487470571933092E-014
  3.183122202507580E-014
 -2.223461486542538E-021
  2.718772472778963E-015
 -2.194245467307165E-017
  4.493993038656296E-014
  6.462372480133156E-014
 -3.734750551191014E-019
  2.834733634984257E-015
  1.033999690666275E-013
  5.579672828354550E-014
 -7.037299820026981E-014
 -3.811648262644352E-021
 -4.267467184747992E-015
 -2.256848481298649E-017
 -3.953466565486665E-015
  1.182009405718137E-014
  1.507024335488070E-019
  2.283033174032807E-015
 -1.071837350295864E-013
  1.530833233977862E-013
 -3.886137525872021E-014
 -7.093900933254765E-021
 -2.255061236485986E-014
 -2.150689444972573E-017
 -1.717830462635004E-016
 -3.071316055755675E-014
  5.148128411807675E-019
 -7.483858170891793E-016
  3.302907574323166E-014
 -1.894146527212024E-013
  1.050817266724400E-013
  1.524659305057741E-020
 -1.069679962011419E-014
 -2.191159091005608E-017
 -5.987995799368069E-014
 -9.542931867629039E-014
 -4.081447062801448E-019
  6.737912497680457E-016
 -1.073568724682977E-013
  8.428414589778606E-014
 -5.515169755349741E-014
 -1.852884572118782E-020
  4.572283849278713E-016
 -2.167798848762620E-017
  4.991845669011943E-014
  8.965322990830797E-014
 -6.730022398714607E-019
 -2.585249614040653E-015
  2.433552246090517E-013
 -7.519934974089613E-014
  3.836045352624117E-014
  8.576208590949791E-021
  1.853264042879152E-014
 -2.158478839364863E-017
 -1.023738736190215E-013
 -1.209898253497687E-013
  1.587303977450672E-019
  3.764967433352039E-015
  3.284010073393553E-014
 -1.042547002198834E-013
 -1.149392979068759E-013
 -5.929230630780102E-021
 -1.993689230633117E-014
 -2.090437609154211E-017
 -8.632754453806613E-014
 -1.118034701277915E-013
 -1.962861783611365E-019
  4.852417143082013E-015
  1.029548385356479E-013
  2.619894949890003E-014
 -2.139144438841056E-014
  2.157732682747670E-015
 -2.304481882013307E-014
 -2.051650117614864E-017
 -1.868617449431356E-013
 -2.300264521909587E-013
  1.676043301851060E-020
 -3.188101930214876E-015
  1.401713342957783E-013
 -6.597140157484886E-014
 -2.933114498894843E-014
  2.061585264514204E-015
 -1.343608384274386E-014
 -2.296925051104598E-017
 -1.165297693955343E-013
 -1.345954258962466E-013
  2.733973469566225E-016
 -7.507175177179644E-016
 -6.985540990341346E-014
 -1.824271595872624E-013
 -1.110006775082707E-008
 -4.191978761455741E-016
 -7.880083928892142E-012
 -2.144573957527955E-013
 -1.174666581940740E-009
  5.066411011306771E-008
 -1.133786393936465E-008
 -4.535182722836451E-008
 -2.220011096490198E-008
        1010
 -2.830935220401662E-014
  1.914279891828026E-014
  2.266823008936617E-015
  5.170037292310709E-020
 -5.047043359819202E-014
  6.369912642447531E-020
  4.409120554393607E-016
 -1.835883502783898E-013
 -5.660772736396263E-014
  3.829250284914654E-014
  4.535129596080351E-015
  1.033909591242280E-019
 -1.009386801573142E-013
  1.273982491413044E-019
  8.819354392562086E-016
 -3.671615918183411E-013
 -5.662967568169189E-014
  3.827869282397450E-014
  4.532161592633172E-015
 -1.009430542354538E-013
  1.273982565629078E-019
  8.817128019399787E-016
 -3.671918071776356E-013
 -5.661870152282726E-014
  3.828559783656052E-014
  4.533645594356761E-015
 -1.009408671963840E-013
  1.273982528521061E-019
  8.818241205980937E-016
 -3.671766994979884E-013
 -5.664064984055651E-014
  3.827178442325670E-014
  4.530684367173160E-015
 -1.009452412745237E-013
  1.273982602737095E-019
  8.816014832818638E-016
 -3.672069182454146E-013
 -5.659675320509801E-014
  3.829941124986434E-014
  4.536606821540362E-015
 -1.009364998945080E-013
  1.273982455062333E-019
  8.820467579143235E-016
 -3.671464807505621E-013
 -5.513288712226082E-014
  3.838016228885788E-014
  4.531531400120414E-015
 -6.713530200378381E-019
  2.536965326274256E-014
  3.938362866894290E-014
  1.968267799621428E-020
  8.815890110525877E-016
 -3.664674522488285E-013
 -1.033115482601575E-009
 -7.046754693671787E-011
 -2.177797601542880E-014
  1.587395329691722E-017
  1.617025050692320E-011
  1.538570055322104E-011
  3.754501527363386E-019
  3.248690067581608E-015
  7.435369024957457E-010
 -5.560996659781033E-014
  3.836024854426794E-014
 -7.986309398435787E-014
 -1.009288850683122E-013
  1.273982031854235E-019
  8.819350819141840E-016
 -3.666790235957632E-013
 -1.009452361923260E-013
  1.273982602358441E-019
 -5.719532004870357E-014
  3.827824897871014E-014
  4.546520495155026E-015
  1.026550992513009E-018
 -2.626252366792928E-013
 -3.260392681476900E-013
  1.827749139378669E-019
  8.822077117518899E-016
 -3.673349094765468E-013
  1.008921952612941E-009
  6.912016692818166E-011
 -3.256208101548239E-014
 -2.763815567331579E-018
  5.972630720701852E-013
  4.448452641251705E-010
  3.209149543436952E-019
  5.269227275276995E-016
 -1.391691410840249E-009
 -2.021768903288980E-013
 -5.048390565721809E-014
  1.970277239971008E-014
  4.595153738854579E-020
  7.984670082633407E-014
  9.778200689739783E-014
 -2.406123329765199E-019
 -1.435856673549530E-013
 -1.479922651408272E-013
 -1.412158980924243E-013
 -1.569850884486010E-014
  5.381306193024977E-020
 -1.717511124331747E-013
 -1.557619051101300E-013
 -3.456903241832594E-019
  1.076451024856788E-015
  9.490426490896963E-014
 -1.581164288251644E-013
 -6.265019732653535E-014
  2.127448607905369E-014
  4.128226826680646E-019
  4.118127922842285E-014
  8.097433720722844E-014
 -3.073137694644423E-020
 -4.503523203959302E-015
  3.103284005627339E-013
 -2.810561323045535E-013
 -3.072310133622573E-014
  1.592824450894620E-014
 -3.867896544297957E-019
  1.562296107632198E-014
  3.426465281484731E-014
  4.698967969413305E-019
  2.036679421455220E-015
 -1.716932753294702E-013
  9.816922634163902E-014
 -3.464955136234325E-014
  1.710426505291407E-014
 -3.680490504717943E-019
  7.468221161558146E-014
  7.731644236516969E-014
 -3.885471549142343E-019
  3.789416914521960E-015
 -2.179288782929489E-013
 -2.492844582573867E-013
  7.859142685056296E-015
 -2.839051151289074E-016
 -5.408570066014725E-019
  3.770483890775891E-015
  2.497420063178428E-014
  3.854083203242585E-019
  3.694978581935604E-015
  3.552867694536602E-014
  5.576562105149714E-014
  2.280329923368477E-014
 -2.680418820927288E-016
  2.206917874291478E-019
  6.209075805819746E-014
  7.250814125546803E-014
  4.938249359052839E-019
 -2.920651161210647E-015
  2.853277862408109E-014
 -3.228169616928227E-014
  8.663222591555331E-015
 -2.290959424526865E-019
  6.131224822349146E-014
  6.982546932690105E-014
 -5.395543188295401E-019
 -3.226878316130716E-016
  4.120640402558343E-014
 -3.466280345750084E-014
  4.639584343883035E-014
 -1.134823571918853E-014
 -4.101492349282932E-019
  9.079154890991443E-014
  1.511766176110450E-013
  4.318649846617323E-019
 -3.183534842507410E-016
 -6.807837722436553E-014
  1.555646186429785E-013
  7.871448210307417E-014
 -1.413455398731334E-014
  3.574876084107173E-019
  1.102932514109954E-014
  2.157655835683531E-014
 -1.267018570472675E-019
  7.302265229920459E-016
 -4.766877122234858E-015
 -5.709176045061350E-014
  1.606607371012342E-014
 -5.076903727605463E-020
  3.677626977490852E-015
 -8.237827398851170E-015
 -7.115164924448511E-020
 -3.095912148433619E-015
 -2.386390469615121E-013
  1.984397153470284E-013
 -7.917517485275631E-014
 -6.840739725979400E-015
  9.215453768330771E-020
 -6.376326918765992E-014
 -1.032632824599566E-013
 -4.881463673606833E-019
 -1.405716240444531E-016
  1.172454741856560E-013
  9.281736431087981E-014
 -4.933330287793143E-014
  1.131970087326142E-014
  8.825355391450763E-019
 -2.074835094976779E-013
 -2.620296066577340E-013
 -5.789309755762912E-019
 -1.611424374291630E-015
  1.334169171135868E-013
 -6.571583947915429E-014
 -7.712084043479204E-014
 -2.253840153789224E-014
  6.156870735354696E-019
 -8.142586101054501E-014
 -9.909251933273074E-014
 -3.681435656828300E-019
  3.825500313916479E-015
 -5.146853597008497E-014
 -1.841416762452495E-014
 -2.610481004538395E-015
 -6.277969977032459E-020
 -7.200927304849050E-014
 -9.612682997956357E-014
 -1.484108228356680E-019
  1.287508067894660E-013
 -6.662527720822063E-014
 -3.969602966648333E-015
 -2.988438117031578E-019
  4.147893089419231E-014
  4.432334863447695E-014
 -7.220668871337284E-019
  1.085049038755865E-015
 -1.181532370923576E-013
  3.042345909009067E-014
  6.677933386660135E-014
  9.632817818145539E-015
  3.604456062812069E-019
 -8.986669086663398E-014
 -1.114605742500840E-013
  4.912548078468004E-019
  2.447886451331930E-015
 -1.426811470888968E-013
 -2.551521129280936E-013
 -5.997332587959116E-014
  1.290065059986190E-014
  4.851381205399005E-019
  4.353730756513912E-014
  4.273712019854919E-014
 -2.918640137443141E-019
  2.575740504640818E-015
 -1.626813971288103E-013
  1.626293511231918E-013
 -6.871216649047968E-014
 -2.542691263703739E-014
 -2.574516938510043E-019
  4.280718345522361E-014
  1.940829800746533E-014
 -4.982519450693150E-019
 -3.627725064965541E-016
  2.419876829673925E-013
 -1.817085531931357E-014
 -1.260223919847831E-014
 -2.014409011775672E-014
  6.011816343137397E-019
 -1.028317576339203E-013
 -1.000133695072724E-013
  5.569056774105560E-020
 -1.404612713678575E-015
  9.949360976204639E-014
  3.806227251781924E-017
  9.199836598365770E-019
 -8.309968006475715E-014
 -1.128320899982781E-013
  4.487101303311727E-014
  2.146568513217151E-014
 -6.926479577274033E-020
  6.674493593802269E-014
  8.028756289359465E-014
  1.757105545139155E-019
 -1.529346722125073E-013
 -7.362562843464884E-014
  1.524183611354563E-014
 -1.604134818311836E-019
 -1.805718548302551E-014
  8.258130778596856E-016
  3.406576398214555E-019
 -8.228009165128787E-016
 -1.483835770909275E-013
 -1.871867763401201E-013
 -8.660336242084267E-014
  2.234337389585284E-015
  9.126118262175044E-019
 -8.621209302091308E-014
 -1.147031417330496E-013
  5.870793992682299E-019
 -5.237108858149981E-017
  2.670317369107943E-013
  4.639309177257687E-010
  3.171483970828746E-011
  1.723650383663941E-014
 -4.592109714200384E-019
  1.403754929926938E-013
  1.863381631205538E-013
 -7.397592802708611E-017
  4.330391490268449E-015
 -6.737166437836051E-010
 -1.605593620011151E-013
 -1.055631141310895E-013
 -2.276836081867642E-014
 -4.893269631618691E-019
  6.823504161925816E-014
  9.944444458165596E-014
  4.772837109934471E-019
  1.550097421794136E-015
 -2.324375198418499E-013
 -6.340012204920279E-014
 -7.371609155341560E-016
 -2.221975451939875E-014
  1.084566131955028E-018
 -1.945290773613933E-013
 -2.744421799327290E-013
  1.791072624011084E-019
 -2.481619531632093E-015
 -9.518592168101917E-014
  6.914995319286702E-015
  7.909541992450874E-014
  1.495236768601915E-015
  9.360375811650061E-019
 -2.316195436848718E-013
 -2.764995924684236E-013
 -4.529003019417455E-019
  1.492904001452977E-015
 -9.760122398048597E-014
  2.343524589873617E-014
 -5.790327900045533E-014
  9.144615132402473E-015
  2.381287547417656E-019
  2.632564905772725E-014
  3.573021801930691E-014
 -1.976675720793146E-019
 -4.438866721179890E-015
 -3.100153847516226E-013
 -6.255712926381843E-014
  6.542031016031329E-014
 -2.242321183332924E-014
 -3.666064474835019E-021
  4.910045325603343E-014
  3.931584062217414E-014
  2.104821962960155E-019
  1.313910983290392E-015
  3.918493137577352E-014
  2.926417687007261E-014
  2.506452483714769E-014
  1.436382590086081E-019
 -7.133177213097259E-014
 -9.499290019681066E-014
 -4.650637305688640E-020
 -1.902247095039355E-013
  9.848177977864019E-014
  1.733735496747130E-014
 -3.807214574561067E-019
  3.240465176307328E-014
  5.563654598876935E-014
 -7.682917352278721E-019
 -2.167170531209818E-015
 -1.034152680433719E-013
  1.566764178106300E-013
 -4.459641342194690E-014
 -2.463207724812469E-014
 -2.891294025893351E-019
 -6.344793327389681E-014
 -8.904434535637190E-014
  3.050365990079456E-019
 -2.427709656482950E-016
  2.465330421671419E-013
  2.010042006096463E-013
  5.744013493742383E-014
  9.071485695868325E-015
 -2.344626902669306E-019
 -2.715173006269606E-014
  8.785507044084540E-015
  5.455828645681089E-019
  3.239625548115481E-015
  3.540235945133758E-014
 -2.584790789062726E-014
  8.276501229156907E-015
 -9.024309348838050E-015
  1.318525896409526E-018
 -2.124467719498875E-013
 -2.560356542394542E-013
  1.949105800884847E-020
 -1.889730476321324E-015
 -1.755986851762920E-013
  2.030061424664026E-013
 -5.815320623593807E-014
 -1.004562101905582E-014
  6.259573480209280E-019
 -1.193789765248005E-013
 -1.730887907503732E-013
 -1.168734951833936E-020
  2.037727771396909E-015
 -1.058757744927653E-013
 -1.443330620034418E-013
  7.917358412488137E-014
 -1.468645355068993E-014
 -2.183558293792980E-019
 -5.525681105999900E-014
 -6.511592548258567E-014
  4.505414362357997E-019
  2.114144076379086E-013
  7.223580322226683E-014
  1.182001274201844E-014
 -5.117270141498050E-020
 -1.065819863464192E-014
  2.442671630705459E-013
  1.610508511482237E-013
 -4.061528064282054E-014
  5.342270679650762E-016
 -3.111853464424490E-019
 -7.189751949189670E-015
 -3.279799663195165E-015
 -3.658015151177508E-014
 -7.423459144301165E-014
 -7.348662185767494E-014
  2.694930867006007E-014
  4.390012946941428E-020
 -1.003808260052580E-013
 -1.121196963261217E-013
  3.318424467126382E-016
 -1.770716914593141E-013
  3.183760526536631E-014
  2.737922193650488E-015
 -5.109130684270529E-019
  4.494019889600724E-014
  6.456011940325634E-014
 -3.734750551380341E-019
  5.579711198947060E-014
 -7.036607285889306E-014
 -4.246697936881316E-015
  6.796248261633684E-019
 -3.793454241106279E-014
 -5.621255210982480E-014
  1.998408506211336E-019
  2.283096003777005E-015
 -1.071837628493248E-013
  1.530825560388755E-013
 -3.885495644304592E-014
 -2.253135422377109E-014
  7.590209300786582E-021
 -1.043088698826844E-013
 -1.162788347731794E-013
  4.521798295972086E-019
 -7.485215485355076E-016
  3.302911123920610E-014
 -1.894150364271275E-013
  1.050881437940484E-013
 -1.067754147902542E-014
 -3.779024259285260E-019
 -2.370612814699884E-014
 -2.314520577690986E-014
 -4.606731062004474E-019
  6.737293792948650E-016
 -1.073568427295003E-013
  8.428452955077161E-014
 -5.514513135409030E-014
  4.769337594127954E-016
  3.847051592861621E-019
 -1.238251222392773E-013
 -1.877459708424060E-013
 -5.696730999141119E-019
 -2.585202132012336E-015
  2.433551660843690E-013
 -7.519896603497102E-014
  3.836683168433400E-014
  1.855177659713589E-014
 -1.766328392821233E-019
  2.094640417231897E-014
  2.035338857089147E-014
  1.587303977261345E-019
  3.765044555794944E-015
 -1.149329061962559E-013
 -1.991772225666891E-014
  5.392489674906694E-019
 -8.632790360062643E-014
 -1.118682308788067E-013
 -1.695256681938298E-019
 -3.368953700606954E-015
  1.029548231964107E-013
  2.619933317835536E-014
 -2.138536946811286E-014
 -2.302659067110815E-014
 -1.260887951326831E-019
 -3.887857489798892E-014
 -5.689309226096680E-014
  1.676037432725925E-020
 -3.188025032765097E-015
 -6.597220117395107E-014
 -2.972128497632197E-014
 -1.341625649551453E-014
 -2.197653451430884E-020
  2.647153888912833E-014
  3.034183656007352E-014
 -2.783029525395113E-019
 -2.533068962443594E-015
 -7.074042290805014E-014
 -3.146623044590624E-014
  6.871545467238092E-015
 -1.712183929250370E-015
 -2.158275662222175E-016
 -1.105729331880856E-012
 -3.885565588897244E-012
  2.837140244960068E-013
  1.134827201931488E-012
  1.575473285901977E-013
        1011
           1
          21
          41
          61
          81
         101
         121
         141
         161
         181
         201
         231
         261
         291
         321
         351
         381
         411
         441
         471
         501
         531
         561
         591
         621
         651
         681
         711
         741
         771
         801
         831
         861
         891
         921
         951
         981
        1011
        1041
        1071
        1101
        1131
        1161
        1191
        1221
        1251
        1281
        1311
        1341
        1371
        1401
        1431
        1461
        1491
        1521
        1551
        1581
        1611
        1641
        1671
        1701
        1731
        1761
        1791
        1821
        1851
        1881
        1911
        1941
        1971
        2031
        2061
        2091
        2121
        2151
        2181
        2211
        2241
        2271
        2301
        2331
        2361
        2391
        2421
        2451
        2481
        2511
        2541
        2571
        2601
        2631
        2661
        2691
        2721
        2751
        2781
        2811
        2841
        2871
        2901
        2931
        2961
        2991
        3021
        3051
        3081
        3111
        3141
        3171
        3201
        3231
        3261
        3291
        3321
        3351
        3381
        3411
        3441
        3471
        3501
        3531
        3561
        3591
        3621
        3651
        3681
        3711
        3741
        3771
        3801
        3831
        3861
        3891
        3921
        3951
        3981
        4011
        4041
        4071
        4101
        4131
        4161
        4191
        4221
        4251
        4281
        4311
        4341
        4371
        4401
        4431
        4461
        4491
        4521
        4551
        4581
        4611
        4641
        4671
        4701
        4731
        4761
        4791
        4821
        4851
        4881
        4911
        4941
        4971
        5001
        5031
        5061
        5091
        5121
        5151
        5181
        5211
        5241
        5271
        5301
        5331
        5361
        5391
        5421
        5451
        5481
        5511
        5541
        5571
        5601
        5631
        5661
        5691
        5721
        5751
        5781
        5811
        5841
        5871
        5901
        5931
        5961
        5991
        6021
        6051
        6081
        6111
        6141
        6171
        6201
        6231
        6261
        6291
        6321
        6351
        6381
        6411
        6441
        6471
        6501
        6531
        6561
        6591
        6621
        6651
        6681
        6711
        6741
        6771
        6801
        6831
        6861
        6891
        6921
        6951
        6981
        7011
        7041
        7071
        7101
        7131
        7161
        7191
        7221
        7251
        7281
        7311
        7341
        7371
        7401
        7431
        7461
        7491
        7521
        7551
        7581
        7611
        7641
        7671
        7701
        7731
        7761
        7791
        7821
        7851
        7881
        7911
        7941
        7971
        8001
        8031
        8061
        8091
        8121
        8151
        8181
        8211
        8241
        8271
        8301
        8331
        8361
        8391
        8421
        8451
        8481
        8511
        8541
        8571
        8601
        8631
        8661
        8691
        8721
        8751
        8781
        8811
        8841
        8871
        8901
        8931
        8961
        8991
        9021
        9051
        9081
        9111
        9141
        9171
        9201
        9231
        9261
        9291
        9321
        9351
        9381
        9411
        9441
        9471
        9501
        9531
        9561
        9591
        9621
        9651
        9681
        9711
        9741
        9771
        9801
        9831
        9861
        9891
        9921
        9951
        9981
       10011
       10041
       10071
       10101
       10131
       10161
       10191
       10221
       10251
       10281
       10311
       10341
       10371
       10401
       10431
       10461
       10491
       10521
       10551
       10581
       10611
       10641
       10671
       10701
       10731
       10761
       10791
       10821
       10851
       10881
       10911
       10941
       10971
       11001
       11031
       11061
       11091
       11121
       11151
       11181
       11211
       11241
       11271
       11301
       11331
       11361
       11391
       11421
       11451
       11481
       11511
       11541
       11571
       11601
       11631
       11661
       11691
       11721
       11751
       11781
       11811
       11841
       11871
       11901
       11931
       11961
       11991
       12021
       12051
       12081
       12111
       12141
       12171
       12201
       12231
       12261
       12291
       12321
       12351
       12381
       12411
       12441
       12471
       12501
       12531
       12561
       12591
       12621
       12651
       12681
       12711
       12741
       12771
       12801
       12831
       12861
       12891
       12921
       12951
       12981
       13011
       13041
       13071
       13101
       13131
       13161
       13191
       13221
       13251
       13281
       13311
       13341
       13371
       13401
       13431
       13461
       13491
       13521
       13551
       13581
       13611
       13641
       13671
       13701
       13731
       13761
       13791
       13821
       13851
       13881
       13911
       13941
       13971
       14001
       14031
       14061
       14091
       14121
       14151
       14181
       14211
       14241
       14271
       14301
       14331
       14361
       14391
       14421
       14451
       14481
       14511
       14541
       14571
       14601
       14631
       14661
       14691
       14721
       14751
       14781
       14811
       14841
       14871
       14901
       14931
       14961
       14991
       15021
       15051
       15081
       15111
       15141
       15171
       15201
       15231
       15261
       15291
       15321
       15351
       15381
       15411
       15441
       15471
       15501
       15531
       15561
       15591
       15621
       15651
       15681
       15711
       15741
       15771
       15801
       15831
       15861
       15891
       15921
       15951
       15981
       16011
       16041
       16071
       16101
       16131
       16161
       16191
       16221
       16251
       16281
       16311
       16341
       16371
       16401
       16431
       16461
       16491
       16521
       16551
       16581
       16611
       16641
       16671
       16701
       16731
       16761
       16791
       16821
       16851
       16881
       16911
       16941
       16971
       17001
       17031
       17061
       17091
       17121
       17151
       17181
       17211
       17241
       17271
       17301
       17331
       17361
       17391
       17421
       17451
       17481
       17511
       17541
       17571
       17601
       17631
       17661
       17691
       17721
       17751
       17781
       17811
       17841
       17871
       17901
       17931
       17961
       17991
       18021
       18051
       18081
       18111
       18141
       18171
       18201
       18231
       18261
       18291
       18321
       18351
       18381
       18411
       18441
       18471
       18501
       18531
       18561
       18591
       18621
       18651
       18681
       18711
       18741
       18771
       18801
       18831
       18861
       18891
       18921
       18951
       18981
       19011
       19041
       19071
       19101
       19131
       19161
       19191
       19221
       19251
       19281
       19311
       19341
       19371
       19401
       19431
       19461
       19491
       19521
       19551
       19581
       19611
       19641
       19671
       19701
       19731
       19761
       19791
       19821
       19851
       19881
       19911
       19941
       19971
       20001
       20031
       20061
       20091
       20121
       20151
       20181
       20211
       20241
       20271
       20301
       20331
       20361
       20391
       20421
       20451
       20481
       20511
       20541
       20571
       20601
       20631
       20661
       20691
       20721
       20751
       20781
       20811
       20841
       20871
       20901
       20931
       20961
       20991
       21021
       21051
       21081
       21111
       21141
       21171
       21201
       21231
       21261
       21291
       21321
       21351
       21381
       21411
       21441
       21471
       21501
       21531
       21561
       21591
       21621
       21651
       21681
       21711
       21741
       21771
       21801
       21831
       21861
       21891
       21921
       21951
       21981
       22011
       22041
       22071
       22101
       22131
       22161
       22191
       22221
       22251
       22281
       22311
       22341
       22371
       22401
       22431
       22461
       22491
       22521
       22551
       22581
       22611
       22641
       22671
       22701
       22731
       22761
       22791
       22821
       22851
       22881
       22911
       22941
       22971
       23001
       23031
       23061
       23091
       23121
       23151
       23181
       23211
       23241
       23271
       23301
       23331
       23361
       23391
       23421
       23451
       23481
       23511
       23541
       23571
       23601
       23631
       23661
       23691
       23721
       23751
       23781
       23811
       23841
       23871
       23901
       23931
       23961
       23991
       24021
       24051
       24081
       24111
       24141
       24171
       24201
       24231
       24261
       24291
       24321
       24351
       24381
       24411
       24441
       24471
       24501
       24531
       24561
       24591
       24621
       24651
       24681
       24711
       24741
       24771
       24801
       24831
       24861
       24891
       24921
       24951
       24981
       25011
       25041
       25071
       25101
       25131
       25161
       25191
       25221
       25251
       25281
       25311
       25341
       25371
       25401
       25431
       25461
       25491
       25521
       25551
       25581
       25611
       25641
       25671
       25701
       25731
       25761
       25791
       25821
       25851
       25881
       25911
       25941
       25971
       26001
       26031
       26061
       26091
       26121
       26151
       26181
       26211
       26241
       26271
       26301
       26331
       26361
       26391
       26421
       26451
       26481
       26511
       26541
       26571
       26601
       26631
       26661
       26691
       26721
       26751
       26781
       26811
       26841
       26871
       26901
       26931
       26961
       26991
       27021
       27051
       27081
       27111
       27141
       27171
       27201
       27231
       27261
       27291
       27321
       27351
       27381
       27411
       27441
       27471
       27501
       27531
       27561
       27591
       27621
       27651
       27681
       27711
       27741
       27771
       27801
       27831
       27861
       27891
       27921
       27951
       27981
       28011
       28041
       28071
       28101
       28131
       28161
       28191
       28221
       28251
       28281
       28311
       28341
       28371
       28401
       28431
       28461
       28491
       28521
       28551
       28581
       28611
       28641
       28671
       28701
       28731
       28761
       28791
       28821
       28851
       28881
       28911
       28941
       28971
       29001
       29031
       29061
       29091
       29121
       29151
       29181
       29211
       29241
       29271
       29301
       29331
       29361
       29391
       29421
       29451
       29481
       29511
       29541
       29571
       29601
       29631
       29661
       29691
       29721
       29751
       29781
       29811
       29841
       29871
       29901
       29921
       29941
       29961
       29981
       30001
       30021
       30041
       30061
       30081
       30101
       30100
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           2
           1
           3
           4
           5
           6
           7
           8
           9
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           3
           1
           2
           4
           5
           6
           7
           8
           9
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           4
           1
           2
           3
           5
           6
           7
           8
           9
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           5
           1
           2
           3
           4
           6
           7
           8
           9
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           6
           1
           2
           3
           4
           5
           7
           8
           9
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           7
           1
           2
           3
           4
           5
           6
           8
           9
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           8
           1
           2
           3
           4
           5
           6
           7
           9
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           9
           1
           2
           3
           4
           5
           6
           7
           8
          10
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          10
           1
           2
           3
           4
           5
           6
           7
           8
           9
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          12
          11
          13
          14
          15
          16
          17
          18
          19
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          13
          11
          12
          14
          15
          16
          17
          18
          19
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          14
          11
          12
          13
          15
          16
          17
          18
          19
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          15
          11
          12
          13
          14
          16
          17
          18
          19
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          16
          11
          12
          13
          14
          15
          17
          18
          19
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          17
          11
          12
          13
          14
          15
          16
          18
          19
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          18
          11
          12
          13
          14
          15
          16
          17
          19
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          19
          11
          12
          13
          14
          15
          16
          17
          18
          20
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          20
          11
          12
          13
          14
          15
          16
          17
          18
          19
           1
           2
           3
           4
           5
           6
           7
           8
           9
          10
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          22
          21
          23
          24
          25
          26
          27
          28
          29
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          23
          21
          22
          24
          25
          26
          27
          28
          29
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          24
          21
          22
          23
          25
          26
          27
          28
          29
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          25
          21
          22
          23
          24
          26
          27
          28
          29
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          26
          21
          22
          23
          24
          25
          27
          28
          29
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          27
          21
          22
          23
          24
          25
          26
          28
          29
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          28
          21
          22
          23
          24
          25
          26
          27
          29
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          29
          21
          22
          23
          24
          25
          26
          27
          28
          30
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          30
          21
          22
          23
          24
          25
          26
          27
          28
          29
          11
          12
          13
          14
          15
          16
          17
          18
          19
          20
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          32
          31
          33
          34
          35
          36
          37
          38
          39
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          33
          31
          32
          34
          35
          36
          37
          38
          39
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          34
          31
          32
          33
          35
          36
          37
          38
          39
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          35
          31
          32
          33
          34
          36
          37
          38
          39
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          36
          31
          32
          33
          34
          35
          37
          38
          39
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          37
          31
          32
          33
          34
          35
          36
          38
          39
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          38
          31
          32
          33
          34
          35
          36
          37
          39
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          39
          31
          32
          33
          34
          35
          36
          37
          38
          40
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          40
          31
          32
          33
          34
          35
          36
          37
          38
          39
          21
          22
          23
          24
          25
          26
          27
          28
          29
          30
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          42
          41
          43
          44
          45
          46
          47
          48
          49
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          43
          41
          42
          44
          45
          46
          47
          48
          49
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          44
          41
          42
          43
          45
          46
          47
          48
          49
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          45
          41
          42
          43
          44
          46
          47
          48
          49
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          46
          41
          42
          43
          44
          45
          47
          48
          49
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          47
          41
          42
          43
          44
          45
          46
          48
          49
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          48
          41
          42
          43
          44
          45
          46
          47
          49
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          49
          41
          42
          43
          44
          45
          46
          47
          48
          50
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          50
          41
          42
          43
          44
          45
          46
          47
          48
          49
          31
          32
          33
          34
          35
          36
          37
          38
          39
          40
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          52
          51
          53
          54
          55
          56
          57
          58
          59
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          53
          51
          52
          54
          55
          56
          57
          58
          59
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          54
          51
          52
          53
          55
          56
          57
          58
          59
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          55
          51
          52
          53
          54
          56
          57
          58
          59
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          56
          51
          52
          53
          54
          55
          57
          58
          59
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          57
          51
          52
          53
          54
          55
          56
          58
          59
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          58
          51
          52
          53
          54
          55
          56
          57
          59
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          59
          51
          52
          53
          54
          55
          56
          57
          58
          60
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          60
          51
          52
          53
          54
          55
          56
          57
          58
          59
          41
          42
          43
          44
          45
          46
          47
          48
          49
          50
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          62
          61
          63
          64
          65
          66
          67
          68
          69
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          63
          61
          62
          64
          65
          66
          67
          68
          69
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          64
          61
          62
          63
          65
          66
          67
          68
          69
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          65
          61
          62
          63
          64
          66
          67
          68
          69
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          66
          61
          62
          63
          64
          65
          67
          68
          69
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          67
          61
          62
          63
          64
          65
          66
          68
          69
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          68
          61
          62
          63
          64
          65
          66
          67
          69
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          69
          61
          62
          63
          64
          65
          66
          67
          68
          70
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          70
          61
          62
          63
          64
          65
          66
          67
          68
          69
          51
          52
          53
          54
          55
          56
          57
          58
          59
          60
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          72
          71
          73
          74
          75
          76
          77
          78
          79
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          73
          71
          72
          74
          75
          76
          77
          78
          79
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          74
          71
          72
          73
          75
          76
          77
          78
          79
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          75
          71
          72
          73
          74
          76
          77
          78
          79
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          76
          71
          72
          73
          74
          75
          77
          78
          79
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          77
          71
          72
          73
          74
          75
          76
          78
          79
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          78
          71
          72
          73
          74
          75
          76
          77
          79
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          79
          71
          72
          73
          74
          75
          76
          77
          78
          80
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          80
          71
          72
          73
          74
          75
          76
          77
          78
          79
          61
          62
          63
          64
          65
          66
          67
          68
          69
          70
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          82
          81
          83
          84
          85
          86
          87
          88
          89
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          83
          81
          82
          84
          85
          86
          87
          88
          89
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          84
          81
          82
          83
          85
          86
          87
          88
          89
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          85
          81
          82
          83
          84
          86
          87
          88
          89
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          86
          81
          82
          83
          84
          85
          87
          88
          89
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          87
          81
          82
          83
          84
          85
          86
          88
          89
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          88
          81
          82
          83
          84
          85
          86
          87
          89
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          89
          81
          82
          83
          84
          85
          86
          87
          88
          90
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          90
          81
          82
          83
          84
          85
          86
          87
          88
          89
          71
          72
          73
          74
          75
          76
          77
          78
          79
          80
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          92
          91
          93
          94
          95
          96
          97
          98
          99
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          93
          91
          92
          94
          95
          96
          97
          98
          99
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          94
          91
          92
          93
          95
          96
          97
          98
          99
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          95
          91
          92
          93
          94
          96
          97
          98
          99
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          96
          91
          92
          93
          94
          95
          97
          98
          99
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          97
          91
          92
          93
          94
          95
          96
          98
          99
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          98
          91
          92
          93
          94
          95
          96
          97
          99
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          99
          91
          92
          93
          94
          95
          96
          97
          98
         100
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         100
          91
          92
          93
          94
          95
          96
          97
          98
          99
          81
          82
          83
          84
          85
          86
          87
          88
          89
          90
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         102
         101
         103
         104
         105
         106
         107
         108
         109
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         103
         101
         102
         104
         105
         106
         107
         108
         109
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         104
         101
         102
         103
         105
         106
         107
         108
         109
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         105
         101
         102
         103
         104
         106
         107
         108
         109
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         106
         101
         102
         103
         104
         105
         107
         108
         109
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         107
         101
         102
         103
         104
         105
         106
         108
         109
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         108
         101
         102
         103
         104
         105
         106
         107
         109
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         109
         101
         102
         103
         104
         105
         106
         107
         108
         110
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         110
         101
         102
         103
         104
         105
         106
         107
         108
         109
          91
          92
          93
          94
          95
          96
          97
          98
          99
         100
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         112
         111
         113
         114
         115
         116
         117
         118
         119
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         113
         111
         112
         114
         115
         116
         117
         118
         119
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         114
         111
         112
         113
         115
         116
         117
         118
         119
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         115
         111
         112
         113
         114
         116
         117
         118
         119
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         116
         111
         112
         113
         114
         115
         117
         118
         119
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         117
         111
         112
         113
         114
         115
         116
         118
         119
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         118
         111
         112
         113
         114
         115
         116
         117
         119
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         119
         111
         112
         113
         114
         115
         116
         117
         118
         120
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         120
         111
         112
         113
         114
         115
         116
         117
         118
         119
         101
         102
         103
         104
         105
         106
         107
         108
         109
         110
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         122
         121
         123
         124
         125
         126
         127
         128
         129
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         123
         121
         122
         124
         125
         126
         127
         128
         129
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         124
         121
         122
         123
         125
         126
         127
         128
         129
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         125
         121
         122
         123
         124
         126
         127
         128
         129
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         126
         121
         122
         123
         124
         125
         127
         128
         129
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         127
         121
         122
         123
         124
         125
         126
         128
         129
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         128
         121
         122
         123
         124
         125
         126
         127
         129
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         129
         121
         122
         123
         124
         125
         126
         127
         128
         130
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         130
         121
         122
         123
         124
         125
         126
         127
         128
         129
         111
         112
         113
         114
         115
         116
         117
         118
         119
         120
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         132
         131
         133
         134
         135
         136
         137
         138
         139
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         133
         131
         132
         134
         135
         136
         137
         138
         139
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         134
         131
         132
         133
         135
         136
         137
         138
         139
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         135
         131
         132
         133
         134
         136
         137
         138
         139
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         136
         131
         132
         133
         134
         135
         137
         138
         139
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         137
         131
         132
         133
         134
         135
         136
         138
         139
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         138
         131
         132
         133
         134
         135
         136
         137
         139
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         139
         131
         132
         133
         134
         135
         136
         137
         138
         140
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         140
         131
         132
         133
         134
         135
         136
         137
         138
         139
         121
         122
         123
         124
         125
         126
         127
         128
         129
         130
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         142
         141
         143
         144
         145
         146
         147
         148
         149
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         143
         141
         142
         144
         145
         146
         147
         148
         149
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         144
         141
         142
         143
         145
         146
         147
         148
         149
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         145
         141
         142
         143
         144
         146
         147
         148
         149
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         146
         141
         142
         143
         144
         145
         147
         148
         149
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         147
         141
         142
         143
         144
         145
         146
         148
         149
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         148
         141
         142
         143
         144
         145
         146
         147
         149
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         149
         141
         142
         143
         144
         145
         146
         147
         148
         150
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         150
         141
         142
         143
         144
         145
         146
         147
         148
         149
         131
         132
         133
         134
         135
         136
         137
         138
         139
         140
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         152
         151
         153
         154
         155
         156
         157
         158
         159
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         153
         151
         152
         154
         155
         156
         157
         158
         159
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         154
         151
         152
         153
         155
         156
         157
         158
         159
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         155
         151
         152
         153
         154
         156
         157
         158
         159
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         156
         151
         152
         153
         154
         155
         157
         158
         159
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         157
         151
         152
         153
         154
         155
         156
         158
         159
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         158
         151
         152
         153
         154
         155
         156
         157
         159
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         159
         151
         152
         153
         154
         155
         156
         157
         158
         160
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         160
         151
         152
         153
         154
         155
         156
         157
         158
         159
         141
         142
         143
         144
         145
         146
         147
         148
         149
         150
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         162
         161
         163
         164
         165
         166
         167
         168
         169
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         163
         161
         162
         164
         165
         166
         167
         168
         169
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         164
         161
         162
         163
         165
         166
         167
         168
         169
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         165
         161
         162
         163
         164
         166
         167
         168
         169
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         166
         161
         162
         163
         164
         165
         167
         168
         169
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         167
         161
         162
         163
         164
         165
         166
         168
         169
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         168
         161
         162
         163
         164
         165
         166
         167
         169
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         169
         161
         162
         163
         164
         165
         166
         167
         168
         170
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         170
         161
         162
         163
         164
         165
         166
         167
         168
         169
         151
         152
         153
         154
         155
         156
         157
         158
         159
         160
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         172
         171
         173
         174
         175
         176
         177
         178
         179
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         173
         171
         172
         174
         175
         176
         177
         178
         179
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         174
         171
         172
         173
         175
         176
         177
         178
         179
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         175
         171
         172
         173
         174
         176
         177
         178
         179
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         176
         171
         172
         173
         174
         175
         177
         178
         179
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         177
         171
         172
         173
         174
         175
         176
         178
         179
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         178
         171
         172
         173
         174
         175
         176
         177
         179
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         179
         171
         172
         173
         174
         175
         176
         177
         178
         180
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         180
         171
         172
         173
         174
         175
         176
         177
         178
         179
         161
         162
         163
         164
         165
         166
         167
         168
         169
         170
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         182
         181
         183
         184
         185
         186
         187
         188
         189
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         183
         181
         182
         184
         185
         186
         187
         188
         189
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         184
         181
         182
         183
         185
         186
         187
         188
         189
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         185
         181
         182
         183
         184
         186
         187
         188
         189
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         186
         181
         182
         183
         184
         185
         187
         188
         189
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         187
         181
         182
         183
         184
         185
         186
         188
         189
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         188
         181
         182
         183
         184
         185
         186
         187
         189
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         189
         181
         182
         183
         184
         185
         186
         187
         188
         190
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         190
         181
         182
         183
         184
         185
         186
         187
         188
         189
         171
         172
         173
         174
         175
         176
         177
         178
         179
         180
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         192
         191
         193
         194
         195
         196
         197
         198
         199
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         193
         191
         192
         194
         195
         196
         197
         198
         199
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         194
         191
         192
         193
         195
         196
         197
         198
         199
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         195
         191
         192
         193
         194
         196
         197
         198
         199
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         196
         191
         192
         193
         194
         195
         197
         198
         199
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         197
         191
         192
         193
         194
         195
         196
         198
         199
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         198
         191
         192
         193
         194
         195
         196
         197
         199
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         199
         191
         192
         193
         194
         195
         196
         197
         198
         200
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         200
         191
         192
         193
         194
         195
         196
         197
         198
         199
         181
         182
         183
         184
         185
         186
         187
         188
         189
         190
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         202
         201
         203
         204
         205
         206
         207
         208
         209
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         203
         201
         202
         204
         205
         206
         207
         208
         209
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         204
         201
         202
         203
         205
         206
         207
         208
         209
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         205
         201
         202
         203
         204
         206
         207
         208
         209
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         206
         201
         202
         203
         204
         205
         207
         208
         209
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         207
         201
         202
         203
         204
         205
         206
         208
         209
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         208
         201
         202
         203
         204
         205
         206
         207
         209
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         209
         201
         202
         203
         204
         205
         206
         207
         208
         210
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         210
         201
         202
         203
         204
         205
         206
         207
         208
         209
         191
         192
         193
         194
         195
         196
         197
         198
         199
         200
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         212
         211
         213
         214
         215
         216
         217
         218
         219
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         213
         211
         212
         214
         215
         216
         217
         218
         219
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         214
         211
         212
         213
         215
         216
         217
         218
         219
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         215
         211
         212
         213
         214
         216
         217
         218
         219
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         216
         211
         212
         213
         214
         215
         217
         218
         219
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         217
         211
         212
         213
         214
         215
         216
         218
         219
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         218
         211
         212
         213
         214
         215
         216
         217
         219
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         219
         211
         212
         213
         214
         215
         216
         217
         218
         220
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         220
         211
         212
         213
         214
         215
         216
         217
         218
         219
         201
         202
         203
         204
         205
         206
         207
         208
         209
         210
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         222
         221
         223
         224
         225
         226
         227
         228
         229
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         223
         221
         222
         224
         225
         226
         227
         228
         229
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         224
         221
         222
         223
         225
         226
         227
         228
         229
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         225
         221
         222
         223
         224
         226
         227
         228
         229
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         226
         221
         222
         223
         224
         225
         227
         228
         229
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         227
         221
         222
         223
         224
         225
         226
         228
         229
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         228
         221
         222
         223
         224
         225
         226
         227
         229
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         229
         221
         222
         223
         224
         225
         226
         227
         228
         230
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         230
         221
         222
         223
         224
         225
         226
         227
         228
         229
         211
         212
         213
         214
         215
         216
         217
         218
         219
         220
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         232
         231
         233
         234
         235
         236
         237
         238
         239
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         233
         231
         232
         234
         235
         236
         237
         238
         239
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         234
         231
         232
         233
         235
         236
         237
         238
         239
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         235
         231
         232
         233
         234
         236
         237
         238
         239
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         236
         231
         232
         233
         234
         235
         237
         238
         239
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         237
         231
         232
         233
         234
         235
         236
         238
         239
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         238
         231
         232
         233
         234
         235
         236
         237
         239
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         239
         231
         232
         233
         234
         235
         236
         237
         238
         240
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         240
         231
         232
         233
         234
         235
         236
         237
         238
         239
         221
         222
         223
         224
         225
         226
         227
         228
         229
         230
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         242
         241
         243
         244
         245
         246
         247
         248
         249
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         243
         241
         242
         244
         245
         246
         247
         248
         249
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         244
         241
         242
         243
         245
         246
         247
         248
         249
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         245
         241
         242
         243
         244
         246
         247
         248
         249
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         246
         241
         242
         243
         244
         245
         247
         248
         249
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         247
         241
         242
         243
         244
         245
         246
         248
         249
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         248
         241
         242
         243
         244
         245
         246
         247
         249
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         249
         241
         242
         243
         244
         245
         246
         247
         248
         250
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         250
         241
         242
         243
         244
         245
         246
         247
         248
         249
         231
         232
         233
         234
         235
         236
         237
         238
         239
         240
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         252
         251
         253
         254
         255
         256
         257
         258
         259
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         253
         251
         252
         254
         255
         256
         257
         258
         259
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         254
         251
         252
         253
         255
         256
         257
         258
         259
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         255
         251
         252
         253
         254
         256
         257
         258
         259
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         256
         251
         252
         253
         254
         255
         257
         258
         259
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         257
         251
         252
         253
         254
         255
         256
         258
         259
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         258
         251
         252
         253
         254
         255
         256
         257
         259
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         259
         251
         252
         253
         254
         255
         256
         257
         258
         260
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         260
         251
         252
         253
         254
         255
         256
         257
         258
         259
         241
         242
         243
         244
         245
         246
         247
         248
         249
         250
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         262
         261
         263
         264
         265
         266
         267
         268
         269
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         263
         261
         262
         264
         265
         266
         267
         268
         269
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         264
         261
         262
         263
         265
         266
         267
         268
         269
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         265
         261
         262
         263
         264
         266
         267
         268
         269
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         266
         261
         262
         263
         264
         265
         267
         268
         269
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         267
         261
         262
         263
         264
         265
         266
         268
         269
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         268
         261
         262
         263
         264
         265
         266
         267
         269
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         269
         261
         262
         263
         264
         265
         266
         267
         268
         270
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         270
         261
         262
         263
         264
         265
         266
         267
         268
         269
         251
         252
         253
         254
         255
         256
         257
         258
         259
         260
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         272
         271
         273
         274
         275
         276
         277
         278
         279
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         273
         271
         272
         274
         275
         276
         277
         278
         279
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         274
         271
         272
         273
         275
         276
         277
         278
         279
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         275
         271
         272
         273
         274
         276
         277
         278
         279
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         276
         271
         272
         273
         274
         275
         277
         278
         279
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         277
         271
         272
         273
         274
         275
         276
         278
         279
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         278
         271
         272
         273
         274
         275
         276
         277
         279
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         279
         271
         272
         273
         274
         275
         276
         277
         278
         280
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         280
         271
         272
         273
         274
         275
         276
         277
         278
         279
         261
         262
         263
         264
         265
         266
         267
         268
         269
         270
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         282
         281
         283
         284
         285
         286
         287
         288
         289
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         283
         281
         282
         284
         285
         286
         287
         288
         289
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         284
         281
         282
         283
         285
         286
         287
         288
         289
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         285
         281
         282
         283
         284
         286
         287
         288
         289
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         286
         281
         282
         283
         284
         285
         287
         288
         289
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         287
         281
         282
         283
         284
         285
         286
         288
         289
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         288
         281
         282
         283
         284
         285
         286
         287
         289
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         289
         281
         282
         283
         284
         285
         286
         287
         288
         290
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         290
         281
         282
         283
         284
         285
         286
         287
         288
         289
         271
         272
         273
         274
         275
         276
         277
         278
         279
         280
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         292
         291
         293
         294
         295
         296
         297
         298
         299
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         293
         291
         292
         294
         295
         296
         297
         298
         299
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         294
         291
         292
         293
         295
         296
         297
         298
         299
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         295
         291
         292
         293
         294
         296
         297
         298
         299
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         296
         291
         292
         293
         294
         295
         297
         298
         299
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         297
         291
         292
         293
         294
         295
         296
         298
         299
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         298
         291
         292
         293
         294
         295
         296
         297
         299
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         299
         291
         292
         293
         294
         295
         296
         297
         298
         300
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         300
         291
         292
         293
         294
         295
         296
         297
         298
         299
         281
         282
         283
         284
         285
         286
         287
         288
         289
         290
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         302
         301
         303
         304
         305
         306
         307
         308
         309
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         303
         301
         302
         304
         305
         306
         307
         308
         309
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         304
         301
         302
         303
         305
         306
         307
         308
         309
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         305
         301
         302
         303
         304
         306
         307
         308
         309
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         306
         301
         302
         303
         304
         305
         307
         308
         309
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         307
         301
         302
         303
         304
         305
         306
         308
         309
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         308
         301
         302
         303
         304
         305
         306
         307
         309
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         309
         301
         302
         303
         304
         305
         306
         307
         308
         310
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         310
         301
         302
         303
         304
         305
         306
         307
         308
         309
         291
         292
         293
         294
         295
         296
         297
         298
         299
         300
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         312
         311
         313
         314
         315
         316
         317
         318
         319
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         313
         311
         312
         314
         315
         316
         317
         318
         319
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         314
         311
         312
         313
         315
         316
         317
         318
         319
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         315
         311
         312
         313
         314
         316
         317
         318
         319
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         316
         311
         312
         313
         314
         315
         317
         318
         319
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         317
         311
         312
         313
         314
         315
         316
         318
         319
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         318
         311
         312
         313
         314
         315
         316
         317
         319
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         319
         311
         312
         313
         314
         315
         316
         317
         318
         320
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         320
         311
         312
         313
         314
         315
         316
         317
         318
         319
         301
         302
         303
         304
         305
         306
         307
         308
         309
         310
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         322
         321
         323
         324
         325
         326
         327
         328
         329
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         323
         321
         322
         324
         325
         326
         327
         328
         329
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         324
         321
         322
         323
         325
         326
         327
         328
         329
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         325
         321
         322
         323
         324
         326
         327
         328
         329
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         326
         321
         322
         323
         324
         325
         327
         328
         329
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         327
         321
         322
         323
         324
         325
         326
         328
         329
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         328
         321
         322
         323
         324
         325
         326
         327
         329
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         329
         321
         322
         323
         324
         325
         326
         327
         328
         330
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         330
         321
         322
         323
         324
         325
         326
         327
         328
         329
         311
         312
         313
         314
         315
         316
         317
         318
         319
         320
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         332
         331
         333
         334
         335
         336
         337
         338
         339
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         333
         331
         332
         334
         335
         336
         337
         338
         339
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         334
         331
         332
         333
         335
         336
         337
         338
         339
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         335
         331
         332
         333
         334
         336
         337
         338
         339
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         336
         331
         332
         333
         334
         335
         337
         338
         339
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         337
         331
         332
         333
         334
         335
         336
         338
         339
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         338
         331
         332
         333
         334
         335
         336
         337
         339
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         339
         331
         332
         333
         334
         335
         336
         337
         338
         340
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         340
         331
         332
         333
         334
         335
         336
         337
         338
         339
         321
         322
         323
         324
         325
         326
         327
         328
         329
         330
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         342
         341
         343
         344
         345
         346
         347
         348
         349
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         343
         341
         342
         344
         345
         346
         347
         348
         349
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         344
         341
         342
         343
         345
         346
         347
         348
         349
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         345
         341
         342
         343
         344
         346
         347
         348
         349
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         346
         341
         342
         343
         344
         345
         347
         348
         349
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         347
         341
         342
         343
         344
         345
         346
         348
         349
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         348
         341
         342
         343
         344
         345
         346
         347
         349
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         349
         341
         342
         343
         344
         345
         346
         347
         348
         350
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         350
         341
         342
         343
         344
         345
         346
         347
         348
         349
         331
         332
         333
         334
         335
         336
         337
         338
         339
         340
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         352
         351
         353
         354
         355
         356
         357
         358
         359
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         353
         351
         352
         354
         355
         356
         357
         358
         359
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         354
         351
         352
         353
         355
         356
         357
         358
         359
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         355
         351
         352
         353
         354
         356
         357
         358
         359
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         356
         351
         352
         353
         354
         355
         357
         358
         359
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         357
         351
         352
         353
         354
         355
         356
         358
         359
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         358
         351
         352
         353
         354
         355
         356
         357
         359
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         359
         351
         352
         353
         354
         355
         356
         357
         358
         360
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         360
         351
         352
         353
         354
         355
         356
         357
         358
         359
         341
         342
         343
         344
         345
         346
         347
         348
         349
         350
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         362
         361
         363
         364
         365
         366
         367
         368
         369
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         363
         361
         362
         364
         365
         366
         367
         368
         369
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         364
         361
         362
         363
         365
         366
         367
         368
         369
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         365
         361
         362
         363
         364
         366
         367
         368
         369
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         366
         361
         362
         363
         364
         365
         367
         368
         369
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         367
         361
         362
         363
         364
         365
         366
         368
         369
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         368
         361
         362
         363
         364
         365
         366
         367
         369
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         369
         361
         362
         363
         364
         365
         366
         367
         368
         370
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         370
         361
         362
         363
         364
         365
         366
         367
         368
         369
         351
         352
         353
         354
         355
         356
         357
         358
         359
         360
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         372
         371
         373
         374
         375
         376
         377
         378
         379
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         373
         371
         372
         374
         375
         376
         377
         378
         379
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         374
         371
         372
         373
         375
         376
         377
         378
         379
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         375
         371
         372
         373
         374
         376
         377
         378
         379
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         376
         371
         372
         373
         374
         375
         377
         378
         379
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         377
         371
         372
         373
         374
         375
         376
         378
         379
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         378
         371
         372
         373
         374
         375
         376
         377
         379
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         379
         371
         372
         373
         374
         375
         376
         377
         378
         380
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         380
         371
         372
         373
         374
         375
         376
         377
         378
         379
         361
         362
         363
         364
         365
         366
         367
         368
         369
         370
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         382
         381
         383
         384
         385
         386
         387
         388
         389
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         383
         381
         382
         384
         385
         386
         387
         388
         389
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         384
         381
         382
         383
         385
         386
         387
         388
         389
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         385
         381
         382
         383
         384
         386
         387
         388
         389
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         386
         381
         382
         383
         384
         385
         387
         388
         389
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         387
         381
         382
         383
         384
         385
         386
         388
         389
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         388
         381
         382
         383
         384
         385
         386
         387
         389
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         389
         381
         382
         383
         384
         385
         386
         387
         388
         390
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         390
         381
         382
         383
         384
         385
         386
         387
         388
         389
         371
         372
         373
         374
         375
         376
         377
         378
         379
         380
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         392
         391
         393
         394
         395
         396
         397
         398
         399
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         393
         391
         392
         394
         395
         396
         397
         398
         399
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         394
         391
         392
         393
         395
         396
         397
         398
         399
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         395
         391
         392
         393
         394
         396
         397
         398
         399
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         396
         391
         392
         393
         394
         395
         397
         398
         399
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         397
         391
         392
         393
         394
         395
         396
         398
         399
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         398
         391
         392
         393
         394
         395
         396
         397
         399
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         399
         391
         392
         393
         394
         395
         396
         397
         398
         400
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         400
         391
         392
         393
         394
         395
         396
         397
         398
         399
         381
         382
         383
         384
         385
         386
         387
         388
         389
         390
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         402
         401
         403
         404
         405
         406
         407
         408
         409
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         403
         401
         402
         404
         405
         406
         407
         408
         409
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         404
         401
         402
         403
         405
         406
         407
         408
         409
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         405
         401
         402
         403
         404
         406
         407
         408
         409
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         406
         401
         402
         403
         404
         405
         407
         408
         409
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         407
         401
         402
         403
         404
         405
         406
         408
         409
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         408
         401
         402
         403
         404
         405
         406
         407
         409
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         409
         401
         402
         403
         404
         405
         406
         407
         408
         410
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         410
         401
         402
         403
         404
         405
         406
         407
         408
         409
         391
         392
         393
         394
         395
         396
         397
         398
         399
         400
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         412
         411
         413
         414
         415
         416
         417
         418
         419
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         413
         411
         412
         414
         415
         416
         417
         418
         419
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         414
         411
         412
         413
         415
         416
         417
         418
         419
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         415
         411
         412
         413
         414
         416
         417
         418
         419
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         416
         411
         412
         413
         414
         415
         417
         418
         419
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         417
         411
         412
         413
         414
         415
         416
         418
         419
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         418
         411
         412
         413
         414
         415
         416
         417
         419
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         419
         411
         412
         413
         414
         415
         416
         417
         418
         420
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         420
         411
         412
         413
         414
         415
         416
         417
         418
         419
         401
         402
         403
         404
         405
         406
         407
         408
         409
         410
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         422
         421
         423
         424
         425
         426
         427
         428
         429
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         423
         421
         422
         424
         425
         426
         427
         428
         429
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         424
         421
         422
         423
         425
         426
         427
         428
         429
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         425
         421
         422
         423
         424
         426
         427
         428
         429
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         426
         421
         422
         423
         424
         425
         427
         428
         429
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         427
         421
         422
         423
         424
         425
         426
         428
         429
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         428
         421
         422
         423
         424
         425
         426
         427
         429
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         429
         421
         422
         423
         424
         425
         426
         427
         428
         430
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         430
         421
         422
         423
         424
         425
         426
         427
         428
         429
         411
         412
         413
         414
         415
         416
         417
         418
         419
         420
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         432
         431
         433
         434
         435
         436
         437
         438
         439
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         433
         431
         432
         434
         435
         436
         437
         438
         439
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         434
         431
         432
         433
         435
         436
         437
         438
         439
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         435
         431
         432
         433
         434
         436
         437
         438
         439
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         436
         431
         432
         433
         434
         435
         437
         438
         439
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         437
         431
         432
         433
         434
         435
         436
         438
         439
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         438
         431
         432
         433
         434
         435
         436
         437
         439
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         439
         431
         432
         433
         434
         435
         436
         437
         438
         440
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         440
         431
         432
         433
         434
         435
         436
         437
         438
         439
         421
         422
         423
         424
         425
         426
         427
         428
         429
         430
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         442
         441
         443
         444
         445
         446
         447
         448
         449
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         443
         441
         442
         444
         445
         446
         447
         448
         449
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         444
         441
         442
         443
         445
         446
         447
         448
         449
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         445
         441
         442
         443
         444
         446
         447
         448
         449
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         446
         441
         442
         443
         444
         445
         447
         448
         449
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         447
         441
         442
         443
         444
         445
         446
         448
         449
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         448
         441
         442
         443
         444
         445
         446
         447
         449
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         449
         441
         442
         443
         444
         445
         446
         447
         448
         450
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         450
         441
         442
         443
         444
         445
         446
         447
         448
         449
         431
         432
         433
         434
         435
         436
         437
         438
         439
         440
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         452
         451
         453
         454
         455
         456
         457
         458
         459
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         453
         451
         452
         454
         455
         456
         457
         458
         459
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         454
         451
         452
         453
         455
         456
         457
         458
         459
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         455
         451
         452
         453
         454
         456
         457
         458
         459
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         456
         451
         452
         453
         454
         455
         457
         458
         459
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         457
         451
         452
         453
         454
         455
         456
         458
         459
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         458
         451
         452
         453
         454
         455
         456
         457
         459
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         459
         451
         452
         453
         454
         455
         456
         457
         458
         460
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         460
         451
         452
         453
         454
         455
         456
         457
         458
         459
         441
         442
         443
         444
         445
         446
         447
         448
         449
         450
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         462
         461
         463
         464
         465
         466
         467
         468
         469
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         463
         461
         462
         464
         465
         466
         467
         468
         469
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         464
         461
         462
         463
         465
         466
         467
         468
         469
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         465
         461
         462
         463
         464
         466
         467
         468
         469
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         466
         461
         462
         463
         464
         465
         467
         468
         469
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         467
         461
         462
         463
         464
         465
         466
         468
         469
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         468
         461
         462
         463
         464
         465
         466
         467
         469
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         469
         461
         462
         463
         464
         465
         466
         467
         468
         470
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         470
         461
         462
         463
         464
         465
         466
         467
         468
         469
         451
         452
         453
         454
         455
         456
         457
         458
         459
         460
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         472
         471
         473
         474
         475
         476
         477
         478
         479
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         473
         471
         472
         474
         475
         476
         477
         478
         479
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         474
         471
         472
         473
         475
         476
         477
         478
         479
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         475
         471
         472
         473
         474
         476
         477
         478
         479
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         476
         471
         472
         473
         474
         475
         477
         478
         479
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         477
         471
         472
         473
         474
         475
         476
         478
         479
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         478
         471
         472
         473
         474
         475
         476
         477
         479
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         479
         471
         472
         473
         474
         475
         476
         477
         478
         480
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         480
         471
         472
         473
         474
         475
         476
         477
         478
         479
         461
         462
         463
         464
         465
         466
         467
         468
         469
         470
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         482
         481
         483
         484
         485
         486
         487
         488
         489
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         483
         481
         482
         484
         485
         486
         487
         488
         489
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         484
         481
         482
         483
         485
         486
         487
         488
         489
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         485
         481
         482
         483
         484
         486
         487
         488
         489
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         486
         481
         482
         483
         484
         485
         487
         488
         489
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         487
         481
         482
         483
         484
         485
         486
         488
         489
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         488
         481
         482
         483
         484
         485
         486
         487
         489
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         489
         481
         482
         483
         484
         485
         486
         487
         488
         490
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         490
         481
         482
         483
         484
         485
         486
         487
         488
         489
         471
         472
         473
         474
         475
         476
         477
         478
         479
         480
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         492
         491
         493
         494
         495
         496
         497
         498
         499
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         493
         491
         492
         494
         495
         496
         497
         498
         499
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         494
         491
         492
         493
         495
         496
         497
         498
         499
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         495
         491
         492
         493
         494
         496
         497
         498
         499
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         496
         491
         492
         493
         494
         495
         497
         498
         499
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         497
         491
         492
         493
         494
         495
         496
         498
         499
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         498
         491
         492
         493
         494
         495
         496
         497
         499
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         499
         491
         492
         493
         494
         495
         496
         497
         498
         500
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         500
         491
         492
         493
         494
         495
         496
         497
         498
         499
         481
         482
         483
         484
         485
         486
         487
         488
         489
         490
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         502
         501
         503
         504
         505
         506
         507
         508
         509
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         503
         501
         502
         504
         505
         506
         507
         508
         509
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         504
         501
         502
         503
         505
         506
         507
         508
         509
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         505
         501
         502
         503
         504
         506
         507
         508
         509
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         506
         501
         502
         503
         504
         505
         507
         508
         509
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         507
         501
         502
         503
         504
         505
         506
         508
         509
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         508
         501
         502
         503
         504
         505
         506
         507
         509
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         509
         501
         502
         503
         504
         505
         506
         507
         508
         510
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         510
         501
         502
         503
         504
         505
         506
         507
         508
         509
         491
         492
         493
         494
         495
         496
         497
         498
         499
         500
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         512
         511
         513
         514
         515
         516
         517
         518
         519
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         513
         511
         512
         514
         515
         516
         517
         518
         519
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         514
         511
         512
         513
         515
         516
         517
         518
         519
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         515
         511
         512
         513
         514
         516
         517
         518
         519
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         516
         511
         512
         513
         514
         515
         517
         518
         519
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         517
         511
         512
         513
         514
         515
         516
         518
         519
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         518
         511
         512
         513
         514
         515
         516
         517
         519
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         519
         511
         512
         513
         514
         515
         516
         517
         518
         520
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         520
         511
         512
         513
         514
         515
         516
         517
         518
         519
         501
         502
         503
         504
         505
         506
         507
         508
         509
         510
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         522
         521
         523
         524
         525
         526
         527
         528
         529
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         523
         521
         522
         524
         525
         526
         527
         528
         529
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         524
         521
         522
         523
         525
         526
         527
         528
         529
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         525
         521
         522
         523
         524
         526
         527
         528
         529
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         526
         521
         522
         523
         524
         525
         527
         528
         529
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         527
         521
         522
         523
         524
         525
         526
         528
         529
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         528
         521
         522
         523
         524
         525
         526
         527
         529
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         529
         521
         522
         523
         524
         525
         526
         527
         528
         530
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         530
         521
         522
         523
         524
         525
         526
         527
         528
         529
         511
         512
         513
         514
         515
         516
         517
         518
         519
         520
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         532
         531
         533
         534
         535
         536
         537
         538
         539
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         533
         531
         532
         534
         535
         536
         537
         538
         539
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         534
         531
         532
         533
         535
         536
         537
         538
         539
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         535
         531
         532
         533
         534
         536
         537
         538
         539
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         536
         531
         532
         533
         534
         535
         537
         538
         539
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         537
         531
         532
         533
         534
         535
         536
         538
         539
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         538
         531
         532
         533
         534
         535
         536
         537
         539
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         539
         531
         532
         533
         534
         535
         536
         537
         538
         540
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         540
         531
         532
         533
         534
         535
         536
         537
         538
         539
         521
         522
         523
         524
         525
         526
         527
         528
         529
         530
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         542
         541
         543
         544
         545
         546
         547
         548
         549
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         543
         541
         542
         544
         545
         546
         547
         548
         549
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         544
         541
         542
         543
         545
         546
         547
         548
         549
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         545
         541
         542
         543
         544
         546
         547
         548
         549
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         546
         541
         542
         543
         544
         545
         547
         548
         549
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         547
         541
         542
         543
         544
         545
         546
         548
         549
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         548
         541
         542
         543
         544
         545
         546
         547
         549
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         549
         541
         542
         543
         544
         545
         546
         547
         548
         550
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         550
         541
         542
         543
         544
         545
         546
         547
         548
         549
         531
         532
         533
         534
         535
         536
         537
         538
         539
         540
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         552
         551
         553
         554
         555
         556
         557
         558
         559
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         553
         551
         552
         554
         555
         556
         557
         558
         559
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         554
         551
         552
         553
         555
         556
         557
         558
         559
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         555
         551
         552
         553
         554
         556
         557
         558
         559
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         556
         551
         552
         553
         554
         555
         557
         558
         559
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         557
         551
         552
         553
         554
         555
         556
         558
         559
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         558
         551
         552
         553
         554
         555
         556
         557
         559
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         559
         551
         552
         553
         554
         555
         556
         557
         558
         560
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         560
         551
         552
         553
         554
         555
         556
         557
         558
         559
         541
         542
         543
         544
         545
         546
         547
         548
         549
         550
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         562
         561
         563
         564
         565
         566
         567
         568
         569
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         563
         561
         562
         564
         565
         566
         567
         568
         569
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         564
         561
         562
         563
         565
         566
         567
         568
         569
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         565
         561
         562
         563
         564
         566
         567
         568
         569
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         566
         561
         562
         563
         564
         565
         567
         568
         569
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         567
         561
         562
         563
         564
         565
         566
         568
         569
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         568
         561
         562
         563
         564
         565
         566
         567
         569
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         569
         561
         562
         563
         564
         565
         566
         567
         568
         570
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         570
         561
         562
         563
         564
         565
         566
         567
         568
         569
         551
         552
         553
         554
         555
         556
         557
         558
         559
         560
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         572
         571
         573
         574
         575
         576
         577
         578
         579
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         573
         571
         572
         574
         575
         576
         577
         578
         579
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         574
         571
         572
         573
         575
         576
         577
         578
         579
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         575
         571
         572
         573
         574
         576
         577
         578
         579
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         576
         571
         572
         573
         574
         575
         577
         578
         579
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         577
         571
         572
         573
         574
         575
         576
         578
         579
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         578
         571
         572
         573
         574
         575
         576
         577
         579
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         579
         571
         572
         573
         574
         575
         576
         577
         578
         580
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         580
         571
         572
         573
         574
         575
         576
         577
         578
         579
         561
         562
         563
         564
         565
         566
         567
         568
         569
         570
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         582
         581
         583
         584
         585
         586
         587
         588
         589
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         583
         581
         582
         584
         585
         586
         587
         588
         589
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         584
         581
         582
         583
         585
         586
         587
         588
         589
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         585
         581
         582
         583
         584
         586
         587
         588
         589
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         586
         581
         582
         583
         584
         585
         587
         588
         589
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         587
         581
         582
         583
         584
         585
         586
         588
         589
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         588
         581
         582
         583
         584
         585
         586
         587
         589
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         589
         581
         582
         583
         584
         585
         586
         587
         588
         590
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         590
         581
         582
         583
         584
         585
         586
         587
         588
         589
         571
         572
         573
         574
         575
         576
         577
         578
         579
         580
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         592
         591
         593
         594
         595
         596
         597
         598
         599
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         593
         591
         592
         594
         595
         596
         597
         598
         599
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         594
         591
         592
         593
         595
         596
         597
         598
         599
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         595
         591
         592
         593
         594
         596
         597
         598
         599
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         596
         591
         592
         593
         594
         595
         597
         598
         599
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         597
         591
         592
         593
         594
         595
         596
         598
         599
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         598
         591
         592
         593
         594
         595
         596
         597
         599
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         599
         591
         592
         593
         594
         595
         596
         597
         598
         600
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         600
         591
         592
         593
         594
         595
         596
         597
         598
         599
         581
         582
         583
         584
         585
         586
         587
         588
         589
         590
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         602
         601
         603
         604
         605
         606
         607
         608
         609
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         603
         601
         602
         604
         605
         606
         607
         608
         609
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         604
         601
         602
         603
         605
         606
         607
         608
         609
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         605
         601
         602
         603
         604
         606
         607
         608
         609
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         606
         601
         602
         603
         604
         605
         607
         608
         609
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         607
         601
         602
         603
         604
         605
         606
         608
         609
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         608
         601
         602
         603
         604
         605
         606
         607
         609
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         609
         601
         602
         603
         604
         605
         606
         607
         608
         610
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         610
         601
         602
         603
         604
         605
         606
         607
         608
         609
         591
         592
         593
         594
         595
         596
         597
         598
         599
         600
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         612
         611
         613
         614
         615
         616
         617
         618
         619
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         613
         611
         612
         614
         615
         616
         617
         618
         619
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         614
         611
         612
         613
         615
         616
         617
         618
         619
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         615
         611
         612
         613
         614
         616
         617
         618
         619
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         616
         611
         612
         613
         614
         615
         617
         618
         619
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         617
         611
         612
         613
         614
         615
         616
         618
         619
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         618
         611
         612
         613
         614
         615
         616
         617
         619
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         619
         611
         612
         613
         614
         615
         616
         617
         618
         620
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         620
         611
         612
         613
         614
         615
         616
         617
         618
         619
         601
         602
         603
         604
         605
         606
         607
         608
         609
         610
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         622
         621
         623
         624
         625
         626
         627
         628
         629
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         623
         621
         622
         624
         625
         626
         627
         628
         629
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         624
         621
         622
         623
         625
         626
         627
         628
         629
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         625
         621
         622
         623
         624
         626
         627
         628
         629
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         626
         621
         622
         623
         624
         625
         627
         628
         629
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         627
         621
         622
         623
         624
         625
         626
         628
         629
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         628
         621
         622
         623
         624
         625
         626
         627
         629
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         629
         621
         622
         623
         624
         625
         626
         627
         628
         630
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         630
         621
         622
         623
         624
         625
         626
         627
         628
         629
         611
         612
         613
         614
         615
         616
         617
         618
         619
         620
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         632
         631
         633
         634
         635
         636
         637
         638
         639
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         633
         631
         632
         634
         635
         636
         637
         638
         639
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         634
         631
         632
         633
         635
         636
         637
         638
         639
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         635
         631
         632
         633
         634
         636
         637
         638
         639
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         636
         631
         632
         633
         634
         635
         637
         638
         639
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         637
         631
         632
         633
         634
         635
         636
         638
         639
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         638
         631
         632
         633
         634
         635
         636
         637
         639
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         639
         631
         632
         633
         634
         635
         636
         637
         638
         640
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         640
         631
         632
         633
         634
         635
         636
         637
         638
         639
         621
         622
         623
         624
         625
         626
         627
         628
         629
         630
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         642
         641
         643
         644
         645
         646
         647
         648
         649
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         643
         641
         642
         644
         645
         646
         647
         648
         649
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         644
         641
         642
         643
         645
         646
         647
         648
         649
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         645
         641
         642
         643
         644
         646
         647
         648
         649
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         646
         641
         642
         643
         644
         645
         647
         648
         649
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         647
         641
         642
         643
         644
         645
         646
         648
         649
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         648
         641
         642
         643
         644
         645
         646
         647
         649
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         649
         641
         642
         643
         644
         645
         646
         647
         648
         650
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         650
         641
         642
         643
         644
         645
         646
         647
         648
         649
         631
         632
         633
         634
         635
         636
         637
         638
         639
         640
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         652
         651
         653
         654
         655
         656
         657
         658
         659
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         653
         651
         652
         654
         655
         656
         657
         658
         659
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         654
         651
         652
         653
         655
         656
         657
         658
         659
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         655
         651
         652
         653
         654
         656
         657
         658
         659
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         656
         651
         652
         653
         654
         655
         657
         658
         659
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         657
         651
         652
         653
         654
         655
         656
         658
         659
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         658
         651
         652
         653
         654
         655
         656
         657
         659
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         659
         651
         652
         653
         654
         655
         656
         657
         658
         660
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         660
         651
         652
         653
         654
         655
         656
         657
         658
         659
         641
         642
         643
         644
         645
         646
         647
         648
         649
         650
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         662
         661
         663
         664
         665
         666
         667
         668
         669
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         663
         661
         662
         664
         665
         666
         667
         668
         669
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         664
         661
         662
         663
         665
         666
         667
         668
         669
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         665
         661
         662
         663
         664
         666
         667
         668
         669
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         666
         661
         662
         663
         664
         665
         667
         668
         669
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         667
         661
         662
         663
         664
         665
         666
         668
         669
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         668
         661
         662
         663
         664
         665
         666
         667
         669
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         669
         661
         662
         663
         664
         665
         666
         667
         668
         670
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         670
         661
         662
         663
         664
         665
         666
         667
         668
         669
         651
         652
         653
         654
         655
         656
         657
         658
         659
         660
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         672
         671
         673
         674
         675
         676
         677
         678
         679
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         673
         671
         672
         674
         675
         676
         677
         678
         679
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         674
         671
         672
         673
         675
         676
         677
         678
         679
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         675
         671
         672
         673
         674
         676
         677
         678
         679
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         676
         671
         672
         673
         674
         675
         677
         678
         679
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         677
         671
         672
         673
         674
         675
         676
         678
         679
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         678
         671
         672
         673
         674
         675
         676
         677
         679
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         679
         671
         672
         673
         674
         675
         676
         677
         678
         680
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         680
         671
         672
         673
         674
         675
         676
         677
         678
         679
         661
         662
         663
         664
         665
         666
         667
         668
         669
         670
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         682
         681
         683
         684
         685
         686
         687
         688
         689
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         683
         681
         682
         684
         685
         686
         687
         688
         689
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         684
         681
         682
         683
         685
         686
         687
         688
         689
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         685
         681
         682
         683
         684
         686
         687
         688
         689
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         686
         681
         682
         683
         684
         685
         687
         688
         689
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         687
         681
         682
         683
         684
         685
         686
         688
         689
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         688
         681
         682
         683
         684
         685
         686
         687
         689
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         689
         681
         682
         683
         684
         685
         686
         687
         688
         690
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         690
         681
         682
         683
         684
         685
         686
         687
         688
         689
         671
         672
         673
         674
         675
         676
         677
         678
         679
         680
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         692
         691
         693
         694
         695
         696
         697
         698
         699
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         693
         691
         692
         694
         695
         696
         697
         698
         699
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         694
         691
         692
         693
         695
         696
         697
         698
         699
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         695
         691
         692
         693
         694
         696
         697
         698
         699
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         696
         691
         692
         693
         694
         695
         697
         698
         699
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         697
         691
         692
         693
         694
         695
         696
         698
         699
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         698
         691
         692
         693
         694
         695
         696
         697
         699
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         699
         691
         692
         693
         694
         695
         696
         697
         698
         700
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         700
         691
         692
         693
         694
         695
         696
         697
         698
         699
         681
         682
         683
         684
         685
         686
         687
         688
         689
         690
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         702
         701
         703
         704
         705
         706
         707
         708
         709
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         703
         701
         702
         704
         705
         706
         707
         708
         709
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         704
         701
         702
         703
         705
         706
         707
         708
         709
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         705
         701
         702
         703
         704
         706
         707
         708
         709
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         706
         701
         702
         703
         704
         705
         707
         708
         709
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         707
         701
         702
         703
         704
         705
         706
         708
         709
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         708
         701
         702
         703
         704
         705
         706
         707
         709
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         709
         701
         702
         703
         704
         705
         706
         707
         708
         710
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         710
         701
         702
         703
         704
         705
         706
         707
         708
         709
         691
         692
         693
         694
         695
         696
         697
         698
         699
         700
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         712
         711
         713
         714
         715
         716
         717
         718
         719
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         713
         711
         712
         714
         715
         716
         717
         718
         719
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         714
         711
         712
         713
         715
         716
         717
         718
         719
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         715
         711
         712
         713
         714
         716
         717
         718
         719
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         716
         711
         712
         713
         714
         715
         717
         718
         719
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         717
         711
         712
         713
         714
         715
         716
         718
         719
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         718
         711
         712
         713
         714
         715
         716
         717
         719
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         719
         711
         712
         713
         714
         715
         716
         717
         718
         720
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         720
         711
         712
         713
         714
         715
         716
         717
         718
         719
         701
         702
         703
         704
         705
         706
         707
         708
         709
         710
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         722
         721
         723
         724
         725
         726
         727
         728
         729
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         723
         721
         722
         724
         725
         726
         727
         728
         729
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         724
         721
         722
         723
         725
         726
         727
         728
         729
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         725
         721
         722
         723
         724
         726
         727
         728
         729
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         726
         721
         722
         723
         724
         725
         727
         728
         729
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         727
         721
         722
         723
         724
         725
         726
         728
         729
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         728
         721
         722
         723
         724
         725
         726
         727
         729
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         729
         721
         722
         723
         724
         725
         726
         727
         728
         730
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         730
         721
         722
         723
         724
         725
         726
         727
         728
         729
         711
         712
         713
         714
         715
         716
         717
         718
         719
         720
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         732
         731
         733
         734
         735
         736
         737
         738
         739
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         733
         731
         732
         734
         735
         736
         737
         738
         739
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         734
         731
         732
         733
         735
         736
         737
         738
         739
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         735
         731
         732
         733
         734
         736
         737
         738
         739
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         736
         731
         732
         733
         734
         735
         737
         738
         739
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         737
         731
         732
         733
         734
         735
         736
         738
         739
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         738
         731
         732
         733
         734
         735
         736
         737
         739
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         739
         731
         732
         733
         734
         735
         736
         737
         738
         740
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         740
         731
         732
         733
         734
         735
         736
         737
         738
         739
         721
         722
         723
         724
         725
         726
         727
         728
         729
         730
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         742
         741
         743
         744
         745
         746
         747
         748
         749
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         743
         741
         742
         744
         745
         746
         747
         748
         749
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         744
         741
         742
         743
         745
         746
         747
         748
         749
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         745
         741
         742
         743
         744
         746
         747
         748
         749
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         746
         741
         742
         743
         744
         745
         747
         748
         749
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         747
         741
         742
         743
         744
         745
         746
         748
         749
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         748
         741
         742
         743
         744
         745
         746
         747
         749
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         749
         741
         742
         743
         744
         745
         746
         747
         748
         750
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         750
         741
         742
         743
         744
         745
         746
         747
         748
         749
         731
         732
         733
         734
         735
         736
         737
         738
         739
         740
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         752
         751
         753
         754
         755
         756
         757
         758
         759
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         753
         751
         752
         754
         755
         756
         757
         758
         759
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         754
         751
         752
         753
         755
         756
         757
         758
         759
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         755
         751
         752
         753
         754
         756
         757
         758
         759
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         756
         751
         752
         753
         754
         755
         757
         758
         759
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         757
         751
         752
         753
         754
         755
         756
         758
         759
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         758
         751
         752
         753
         754
         755
         756
         757
         759
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         759
         751
         752
         753
         754
         755
         756
         757
         758
         760
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         760
         751
         752
         753
         754
         755
         756
         757
         758
         759
         741
         742
         743
         744
         745
         746
         747
         748
         749
         750
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         762
         761
         763
         764
         765
         766
         767
         768
         769
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         763
         761
         762
         764
         765
         766
         767
         768
         769
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         764
         761
         762
         763
         765
         766
         767
         768
         769
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         765
         761
         762
         763
         764
         766
         767
         768
         769
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         766
         761
         762
         763
         764
         765
         767
         768
         769
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         767
         761
         762
         763
         764
         765
         766
         768
         769
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         768
         761
         762
         763
         764
         765
         766
         767
         769
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         769
         761
         762
         763
         764
         765
         766
         767
         768
         770
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         770
         761
         762
         763
         764
         765
         766
         767
         768
         769
         751
         752
         753
         754
         755
         756
         757
         758
         759
         760
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         772
         771
         773
         774
         775
         776
         777
         778
         779
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         773
         771
         772
         774
         775
         776
         777
         778
         779
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         774
         771
         772
         773
         775
         776
         777
         778
         779
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         775
         771
         772
         773
         774
         776
         777
         778
         779
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         776
         771
         772
         773
         774
         775
         777
         778
         779
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         777
         771
         772
         773
         774
         775
         776
         778
         779
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         778
         771
         772
         773
         774
         775
         776
         777
         779
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         779
         771
         772
         773
         774
         775
         776
         777
         778
         780
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         780
         771
         772
         773
         774
         775
         776
         777
         778
         779
         761
         762
         763
         764
         765
         766
         767
         768
         769
         770
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         782
         781
         783
         784
         785
         786
         787
         788
         789
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         783
         781
         782
         784
         785
         786
         787
         788
         789
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         784
         781
         782
         783
         785
         786
         787
         788
         789
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         785
         781
         782
         783
         784
         786
         787
         788
         789
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         786
         781
         782
         783
         784
         785
         787
         788
         789
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         787
         781
         782
         783
         784
         785
         786
         788
         789
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         788
         781
         782
         783
         784
         785
         786
         787
         789
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         789
         781
         782
         783
         784
         785
         786
         787
         788
         790
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         790
         781
         782
         783
         784
         785
         786
         787
         788
         789
         771
         772
         773
         774
         775
         776
         777
         778
         779
         780
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         792
         791
         793
         794
         795
         796
         797
         798
         799
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         793
         791
         792
         794
         795
         796
         797
         798
         799
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         794
         791
         792
         793
         795
         796
         797
         798
         799
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         795
         791
         792
         793
         794
         796
         797
         798
         799
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         796
         791
         792
         793
         794
         795
         797
         798
         799
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         797
         791
         792
         793
         794
         795
         796
         798
         799
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         798
         791
         792
         793
         794
         795
         796
         797
         799
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         799
         791
         792
         793
         794
         795
         796
         797
         798
         800
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         800
         791
         792
         793
         794
         795
         796
         797
         798
         799
         781
         782
         783
         784
         785
         786
         787
         788
         789
         790
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         802
         801
         803
         804
         805
         806
         807
         808
         809
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         803
         801
         802
         804
         805
         806
         807
         808
         809
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         804
         801
         802
         803
         805
         806
         807
         808
         809
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         805
         801
         802
         803
         804
         806
         807
         808
         809
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         806
         801
         802
         803
         804
         805
         807
         808
         809
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         807
         801
         802
         803
         804
         805
         806
         808
         809
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         808
         801
         802
         803
         804
         805
         806
         807
         809
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         809
         801
         802
         803
         804
         805
         806
         807
         808
         810
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         810
         801
         802
         803
         804
         805
         806
         807
         808
         809
         791
         792
         793
         794
         795
         796
         797
         798
         799
         800
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         812
         811
         813
         814
         815
         816
         817
         818
         819
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         813
         811
         812
         814
         815
         816
         817
         818
         819
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         814
         811
         812
         813
         815
         816
         817
         818
         819
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         815
         811
         812
         813
         814
         816
         817
         818
         819
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         816
         811
         812
         813
         814
         815
         817
         818
         819
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         817
         811
         812
         813
         814
         815
         816
         818
         819
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         818
         811
         812
         813
         814
         815
         816
         817
         819
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         819
         811
         812
         813
         814
         815
         816
         817
         818
         820
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         820
         811
         812
         813
         814
         815
         816
         817
         818
         819
         801
         802
         803
         804
         805
         806
         807
         808
         809
         810
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         822
         821
         823
         824
         825
         826
         827
         828
         829
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         823
         821
         822
         824
         825
         826
         827
         828
         829
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         824
         821
         822
         823
         825
         826
         827
         828
         829
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         825
         821
         822
         823
         824
         826
         827
         828
         829
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         826
         821
         822
         823
         824
         825
         827
         828
         829
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         827
         821
         822
         823
         824
         825
         826
         828
         829
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         828
         821
         822
         823
         824
         825
         826
         827
         829
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         829
         821
         822
         823
         824
         825
         826
         827
         828
         830
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         830
         821
         822
         823
         824
         825
         826
         827
         828
         829
         811
         812
         813
         814
         815
         816
         817
         818
         819
         820
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         832
         831
         833
         834
         835
         836
         837
         838
         839
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         833
         831
         832
         834
         835
         836
         837
         838
         839
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         834
         831
         832
         833
         835
         836
         837
         838
         839
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         835
         831
         832
         833
         834
         836
         837
         838
         839
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         836
         831
         832
         833
         834
         835
         837
         838
         839
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         837
         831
         832
         833
         834
         835
         836
         838
         839
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         838
         831
         832
         833
         834
         835
         836
         837
         839
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         839
         831
         832
         833
         834
         835
         836
         837
         838
         840
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         840
         831
         832
         833
         834
         835
         836
         837
         838
         839
         821
         822
         823
         824
         825
         826
         827
         828
         829
         830
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         842
         841
         843
         844
         845
         846
         847
         848
         849
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         843
         841
         842
         844
         845
         846
         847
         848
         849
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         844
         841
         842
         843
         845
         846
         847
         848
         849
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         845
         841
         842
         843
         844
         846
         847
         848
         849
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         846
         841
         842
         843
         844
         845
         847
         848
         849
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         847
         841
         842
         843
         844
         845
         846
         848
         849
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         848
         841
         842
         843
         844
         845
         846
         847
         849
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         849
         841
         842
         843
         844
         845
         846
         847
         848
         850
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         850
         841
         842
         843
         844
         845
         846
         847
         848
         849
         831
         832
         833
         834
         835
         836
         837
         838
         839
         840
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         852
         851
         853
         854
         855
         856
         857
         858
         859
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         853
         851
         852
         854
         855
         856
         857
         858
         859
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         854
         851
         852
         853
         855
         856
         857
         858
         859
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         855
         851
         852
         853
         854
         856
         857
         858
         859
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         856
         851
         852
         853
         854
         855
         857
         858
         859
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         857
         851
         852
         853
         854
         855
         856
         858
         859
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         858
         851
         852
         853
         854
         855
         856
         857
         859
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         859
         851
         852
         853
         854
         855
         856
         857
         858
         860
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         860
         851
         852
         853
         854
         855
         856
         857
         858
         859
         841
         842
         843
         844
         845
         846
         847
         848
         849
         850
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         862
         861
         863
         864
         865
         866
         867
         868
         869
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         863
         861
         862
         864
         865
         866
         867
         868
         869
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         864
         861
         862
         863
         865
         866
         867
         868
         869
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         865
         861
         862
         863
         864
         866
         867
         868
         869
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         866
         861
         862
         863
         864
         865
         867
         868
         869
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         867
         861
         862
         863
         864
         865
         866
         868
         869
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         868
         861
         862
         863
         864
         865
         866
         867
         869
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         869
         861
         862
         863
         864
         865
         866
         867
         868
         870
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         870
         861
         862
         863
         864
         865
         866
         867
         868
         869
         851
         852
         853
         854
         855
         856
         857
         858
         859
         860
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         872
         871
         873
         874
         875
         876
         877
         878
         879
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         873
         871
         872
         874
         875
         876
         877
         878
         879
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         874
         871
         872
         873
         875
         876
         877
         878
         879
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         875
         871
         872
         873
         874
         876
         877
         878
         879
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         876
         871
         872
         873
         874
         875
         877
         878
         879
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         877
         871
         872
         873
         874
         875
         876
         878
         879
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         878
         871
         872
         873
         874
         875
         876
         877
         879
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         879
         871
         872
         873
         874
         875
         876
         877
         878
         880
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         880
         871
         872
         873
         874
         875
         876
         877
         878
         879
         861
         862
         863
         864
         865
         866
         867
         868
         869
         870
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         882
         881
         883
         884
         885
         886
         887
         888
         889
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         883
         881
         882
         884
         885
         886
         887
         888
         889
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         884
         881
         882
         883
         885
         886
         887
         888
         889
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         885
         881
         882
         883
         884
         886
         887
         888
         889
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         886
         881
         882
         883
         884
         885
         887
         888
         889
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         887
         881
         882
         883
         884
         885
         886
         888
         889
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         888
         881
         882
         883
         884
         885
         886
         887
         889
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         889
         881
         882
         883
         884
         885
         886
         887
         888
         890
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         890
         881
         882
         883
         884
         885
         886
         887
         888
         889
         871
         872
         873
         874
         875
         876
         877
         878
         879
         880
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         892
         891
         893
         894
         895
         896
         897
         898
         899
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         893
         891
         892
         894
         895
         896
         897
         898
         899
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         894
         891
         892
         893
         895
         896
         897
         898
         899
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         895
         891
         892
         893
         894
         896
         897
         898
         899
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         896
         891
         892
         893
         894
         895
         897
         898
         899
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         897
         891
         892
         893
         894
         895
         896
         898
         899
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         898
         891
         892
         893
         894
         895
         896
         897
         899
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         899
         891
         892
         893
         894
         895
         896
         897
         898
         900
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         900
         891
         892
         893
         894
         895
         896
         897
         898
         899
         881
         882
         883
         884
         885
         886
         887
         888
         889
         890
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         902
         901
         903
         904
         905
         906
         907
         908
         909
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         903
         901
         902
         904
         905
         906
         907
         908
         909
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         904
         901
         902
         903
         905
         906
         907
         908
         909
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         905
         901
         902
         903
         904
         906
         907
         908
         909
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         906
         901
         902
         903
         904
         905
         907
         908
         909
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         907
         901
         902
         903
         904
         905
         906
         908
         909
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         908
         901
         902
         903
         904
         905
         906
         907
         909
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         909
         901
         902
         903
         904
         905
         906
         907
         908
         910
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         910
         901
         902
         903
         904
         905
         906
         907
         908
         909
         891
         892
         893
         894
         895
         896
         897
         898
         899
         900
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         912
         911
         913
         914
         915
         916
         917
         918
         919
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         913
         911
         912
         914
         915
         916
         917
         918
         919
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         914
         911
         912
         913
         915
         916
         917
         918
         919
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         915
         911
         912
         913
         914
         916
         917
         918
         919
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         916
         911
         912
         913
         914
         915
         917
         918
         919
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         917
         911
         912
         913
         914
         915
         916
         918
         919
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         918
         911
         912
         913
         914
         915
         916
         917
         919
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         919
         911
         912
         913
         914
         915
         916
         917
         918
         920
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         920
         911
         912
         913
         914
         915
         916
         917
         918
         919
         901
         902
         903
         904
         905
         906
         907
         908
         909
         910
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         922
         921
         923
         924
         925
         926
         927
         928
         929
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         923
         921
         922
         924
         925
         926
         927
         928
         929
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         924
         921
         922
         923
         925
         926
         927
         928
         929
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         925
         921
         922
         923
         924
         926
         927
         928
         929
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         926
         921
         922
         923
         924
         925
         927
         928
         929
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         927
         921
         922
         923
         924
         925
         926
         928
         929
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         928
         921
         922
         923
         924
         925
         926
         927
         929
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         929
         921
         922
         923
         924
         925
         926
         927
         928
         930
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         930
         921
         922
         923
         924
         925
         926
         927
         928
         929
         911
         912
         913
         914
         915
         916
         917
         918
         919
         920
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         932
         931
         933
         934
         935
         936
         937
         938
         939
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         933
         931
         932
         934
         935
         936
         937
         938
         939
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         934
         931
         932
         933
         935
         936
         937
         938
         939
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         935
         931
         932
         933
         934
         936
         937
         938
         939
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         936
         931
         932
         933
         934
         935
         937
         938
         939
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         937
         931
         932
         933
         934
         935
         936
         938
         939
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         938
         931
         932
         933
         934
         935
         936
         937
         939
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         939
         931
         932
         933
         934
         935
         936
         937
         938
         940
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         940
         931
         932
         933
         934
         935
         936
         937
         938
         939
         921
         922
         923
         924
         925
         926
         927
         928
         929
         930
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         942
         941
         943
         944
         945
         946
         947
         948
         949
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         943
         941
         942
         944
         945
         946
         947
         948
         949
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         944
         941
         942
         943
         945
         946
         947
         948
         949
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         945
         941
         942
         943
         944
         946
         947
         948
         949
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         946
         941
         942
         943
         944
         945
         947
         948
         949
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         947
         941
         942
         943
         944
         945
         946
         948
         949
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         948
         941
         942
         943
         944
         945
         946
         947
         949
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         949
         941
         942
         943
         944
         945
         946
         947
         948
         950
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         950
         941
         942
         943
         944
         945
         946
         947
         948
         949
         931
         932
         933
         934
         935
         936
         937
         938
         939
         940
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         952
         951
         953
         954
         955
         956
         957
         958
         959
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         953
         951
         952
         954
         955
         956
         957
         958
         959
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         954
         951
         952
         953
         955
         956
         957
         958
         959
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         955
         951
         952
         953
         954
         956
         957
         958
         959
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         956
         951
         952
         953
         954
         955
         957
         958
         959
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         957
         951
         952
         953
         954
         955
         956
         958
         959
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         958
         951
         952
         953
         954
         955
         956
         957
         959
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         959
         951
         952
         953
         954
         955
         956
         957
         958
         960
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         960
         951
         952
         953
         954
         955
         956
         957
         958
         959
         941
         942
         943
         944
         945
         946
         947
         948
         949
         950
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         962
         961
         963
         964
         965
         966
         967
         968
         969
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         963
         961
         962
         964
         965
         966
         967
         968
         969
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         964
         961
         962
         963
         965
         966
         967
         968
         969
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         965
         961
         962
         963
         964
         966
         967
         968
         969
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         966
         961
         962
         963
         964
         965
         967
         968
         969
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         967
         961
         962
         963
         964
         965
         966
         968
         969
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         968
         961
         962
         963
         964
         965
         966
         967
         969
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         969
         961
         962
         963
         964
         965
         966
         967
         968
         970
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         970
         961
         962
         963
         964
         965
         966
         967
         968
         969
         951
         952
         953
         954
         955
         956
         957
         958
         959
         960
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         972
         971
         973
         974
         975
         976
         977
         978
         979
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         973
         971
         972
         974
         975
         976
         977
         978
         979
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         974
         971
         972
         973
         975
         976
         977
         978
         979
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         975
         971
         972
         973
         974
         976
         977
         978
         979
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         976
         971
         972
         973
         974
         975
         977
         978
         979
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         977
         971
         972
         973
         974
         975
         976
         978
         979
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         978
         971
         972
         973
         974
         975
         976
         977
         979
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         979
         971
         972
         973
         974
         975
         976
         977
         978
         980
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         980
         971
         972
         973
         974
         975
         976
         977
         978
         979
         961
         962
         963
         964
         965
         966
         967
         968
         969
         970
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         982
         981
         983
         984
         985
         986
         987
         988
         989
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         983
         981
         982
         984
         985
         986
         987
         988
         989
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         984
         981
         982
         983
         985
         986
         987
         988
         989
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         985
         981
         982
         983
         984
         986
         987
         988
         989
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         986
         981
         982
         983
         984
         985
         987
         988
         989
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         987
         981
         982
         983
         984
         985
         986
         988
         989
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         988
         981
         982
         983
         984
         985
         986
         987
         989
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         989
         981
         982
         983
         984
         985
         986
         987
         988
         990
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         990
         981
         982
         983
         984
         985
         986
         987
         988
         989
         971
         972
         973
         974
         975
         976
         977
         978
         979
         980
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         992
         991
         993
         994
         995
         996
         997
         998
         999
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         993
         991
         992
         994
         995
         996
         997
         998
         999
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         994
         991
         992
         993
         995
         996
         997
         998
         999
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         995
         991
         992
         993
         994
         996
         997
         998
         999
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         996
         991
         992
         993
         994
         995
         997
         998
         999
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         997
         991
         992
         993
         994
         995
         996
         998
         999
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         998
         991
         992
         993
         994
         995
         996
         997
         999
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         999
         991
         992
         993
         994
         995
         996
         997
         998
        1000
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
        1000
         991
         992
         993
         994
         995
         996
         997
         998
         999
         981
         982
         983
         984
         985
         986
         987
         988
         989
         990
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1002
        1001
        1003
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1003
        1001
        1002
        1004
        1005
        1006
        1007
        1008
        1009
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1004
        1001
        1002
        1003
        1005
        1006
        1007
        1008
        1009
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1005
        1001
        1002
        1003
        1004
        1006
        1007
        1008
        1009
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1006
        1001
        1002
        1003
        1004
        1005
        1007
        1008
        1009
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1007
        1001
        1002
        1003
        1004
        1005
        1006
        1008
        1009
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1008
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1009
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1009
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1010
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1010
        1001
        1002
        1003
        1004
        1005
        1006
        1007
        1008
        1009
         991
         992
         993
         994
         995
         996
         997
         998
         999
        1000
        1010
  4.525632312878637E-017
  8.174142974573745E-017
  2.310482725749959E-027
  5.471848733854491E-017
 -1.802358851929466E-012
  2.401670273708002E-015
 -1.880364654602115E-015
  3.029429188060291E-015
  1.384211080519451E-016
  5.821471956666956E-016
  4.526957549493448E-017
  8.175979517202989E-017
  1.897647089522624E-020
  5.473749684573027E-017
 -1.802358926825446E-012
  2.401687602058653E-015
 -1.880363761179542E-015
  3.029442123487434E-015
  1.384350075025719E-016
  5.821622322684777E-016
  4.524307123003622E-017
  8.172306408317584E-017
 -1.897647128077726E-020
  5.469946705067220E-017
 -1.802358889720597E-012
  2.401653004741754E-015
 -1.880365607270873E-015
  3.029416220714103E-015
  1.384072036553985E-016
  5.821321651344231E-016
  4.525632336288927E-017
  8.174142962816260E-017
  3.855511010309057E-028
  5.471848194878063E-017
 -1.802358908273023E-012
  2.401670303400729E-015
 -1.880364684225178E-015
  3.029429172101169E-015
  1.384211055794088E-016
  5.821471987019086E-016
  8.175979517202988E-017
  1.897647089522616E-020
  5.473749684573005E-017
  2.401687602058655E-015
 -1.880363761179543E-015
  3.029442123487433E-015
  1.384350075025718E-016
  5.821622322684778E-016
  3.855511010309100E-028
  1.897647089522623E-020
  4.524307123084294E-017
  8.172306408429389E-017
 -1.897647012553594E-020
  5.469946705182979E-017
 -1.802358889720599E-012
  2.401653004742804E-015
 -1.880365607270814E-015
  3.029416220714903E-015
  1.384072036562448E-016
  5.821321651353384E-016
  4.526957549439701E-017
  8.175979517128497E-017
  1.897647012553591E-020
  5.473749684495881E-017
 -1.802358926825445E-012
  2.401687602057956E-015
 -1.880363761179583E-015
  3.029442123486901E-015
  1.384350075020079E-016
  5.821622322678680E-016
 -1.897647128077736E-020
  4.525632336208246E-017
  8.174142962704455E-017
 -7.696902149872032E-028
  5.471848194762304E-017
 -1.802358908273021E-012
  2.401670303399684E-015
 -1.880364684225241E-015
  3.029429172100367E-015
  1.384211055785625E-016
  5.821471987009934E-016
  4.525632336342680E-017
  8.174142962890750E-017
  1.155241355127568E-027
  5.471848194955189E-017
  2.401670303401428E-015
 -1.880364684225139E-015
  3.029429172101701E-015
  1.384211055799727E-016
  5.821471987025183E-016
  1.897647089522619E-020
 -1.897647128077733E-020
 -7.696902149871975E-028
  1.155241425455849E-027
  4.526957549574129E-017
  8.175979517314794E-017
  1.897647205046751E-020
  5.473749684688762E-017
 -1.802358926825447E-012
  2.401687602059714E-015
 -1.880363761179492E-015
  3.029442123488228E-015
  1.384350075034182E-016
  5.821622322693930E-016
  4.525632336154390E-017
  8.174142962629771E-017
 -1.540652647205267E-027
  5.471848194685567E-017
 -1.802358908273020E-012
  2.401670303398973E-015
 -1.880364684225272E-015
  3.029429172099840E-015
  1.384211055779978E-016
  5.821471987003822E-016
  4.522981763075549E-017
  8.170468937943148E-017
 -3.795064523098306E-020
  5.468053904093091E-017
 -1.802358871112833E-012
  2.401635658994381E-015
 -1.880366492786026E-015
  3.029403289077721E-015
  1.383933030252238E-016
  5.821171278729277E-016
  4.528282909421590E-017
  8.177816987577580E-017
  3.795064484679719E-020
  5.475642485547099E-017
 -1.802358945433211E-012
  2.401704947806038E-015
 -1.880362875664399E-015
  3.029455055123811E-015
  1.384489081327474E-016
  5.821772695299748E-016
  4.524307123057366E-017
  8.172306408392113E-017
 -1.897647051118016E-020
  5.469946705143994E-017
 -1.802358889720598E-012
  2.401653004742457E-015
 -1.880365607270837E-015
  3.029416220714634E-015
  1.384072036559623E-016
  5.821321651350332E-016
  3.855511322459554E-028
  1.897647012553598E-020
 -1.897647012553598E-020
 -7.696902149872018E-028
  1.155241355127572E-027
  1.897647089522626E-020
 -1.897647012553605E-020
  4.526957549359023E-017
  8.175979517016639E-017
  1.897646897043440E-020
  5.473749684380652E-017
 -1.802358926825444E-012
  2.401687602056895E-015
 -1.880363761179633E-015
  3.029442123486108E-015
  1.384350075011619E-016
  5.821622322669525E-016
  4.522981763129646E-017
  8.170468938017195E-017
 -3.795064446129280E-020
  5.468053904169747E-017
  2.401635658994888E-015
 -1.880366492785781E-015
  3.029403289078370E-015
  1.383933030257872E-016
  5.821171278735373E-016
  4.528288397500707E-017
  8.177809683549009E-017
  3.795064509523776E-020
  5.475634785570527E-017
 -1.802358933838714E-012
  2.401701771617066E-015
 -1.880359502990610E-015
  3.029456979441110E-015
  1.384489019943140E-016
  5.821772663004749E-016
  4.870283357737753E-018
 -3.208929640857337E-016
 -1.489548392823338E-020
  1.172629990841306E-016
 -1.791992805762718E-012
  3.433010540476642E-016
 -2.326872001566707E-016
  6.058177447060112E-015
  2.454467088803596E-016
 -2.808182006739377E-016
 -3.102432092591675E-016
 -1.360336945851189E-016
  2.757114602856581E-021
  2.552578147564166E-016
 -1.662839345828251E-012
 -1.078228489734434E-015
  3.183355649049127E-016
 -8.573716256366406E-015
 -4.629656703124344E-017
 -9.562666644037879E-017
 -3.525870005819226E-016
 -4.117589479522278E-016
  1.296588633886802E-021
 -2.135672022077262E-016
 -1.312407053500212E-012
  2.936616086817481E-015
 -2.664174091986387E-015
 -6.785258957309329E-015
  1.109254196832778E-016
  2.259515587987974E-016
  5.295831968771518E-016
 -3.718850202447038E-016
 -3.325278852867065E-021
  2.899435863736663E-016
 -9.907050788562353E-013
  1.627733109647616E-015
 -1.214913006665789E-015
 -1.798234863026595E-016
  9.384617148769207E-016
 -4.758089727501779E-016
  3.159631807460466E-016
 -8.824276368132590E-017
  2.337531174449478E-021
  2.293760637929723E-016
 -7.475262366386281E-013
 -1.973558221942073E-015
  1.933847204169134E-015
  1.300700948319828E-014
  2.228547925538499E-016
 -1.276127863796669E-016
  3.401414243822311E-016
 -9.220824855911259E-017
 -1.020673866684500E-021
  2.542771134317878E-016
 -5.881795221063690E-013
 -1.965943733118045E-015
  2.456301195325099E-015
 -5.101515984485590E-015
  8.754459101414803E-016
 -4.039794462656886E-016
  4.360033053093423E-016
  1.967393149896591E-017
  5.456354541709954E-022
 -1.361157728649078E-016
 -4.773448408877015E-013
  4.269440445860261E-016
 -2.136010910705601E-016
  6.303610634970142E-015
  6.900132014441439E-016
  1.390045451907562E-016
 -3.668536208820499E-017
  7.293725261296230E-017
 -4.457956455776028E-022
  2.991652204804310E-019
 -3.796604202459981E-013
 -3.847128436642102E-015
  2.395180485468078E-015
  1.351108893506168E-014
 -6.113722048998270E-016
  5.298570658958845E-017
 -1.237993499299580E-016
 -1.124494008618846E-016
  3.286009567196736E-022
  1.409766407376956E-016
 -3.274462037775481E-013
 -3.054821083589059E-015
  2.840510518433416E-015
 -2.384588091799183E-015
 -9.711216540985703E-017
  9.892433533266991E-017
 -4.911377954884980E-017
  1.625100000083767E-016
 -3.601187212214044E-022
 -1.829028052232225E-016
 -2.976362246445325E-013
  2.268275782980868E-015
 -1.076038191807863E-015
  8.366959903494938E-015
 -3.638534072078862E-017
 -9.608311693309076E-017
  3.611235721730177E-016
  2.741204320280776E-016
 -1.914503815250361E-022
 -2.295454025778561E-016
 -2.599490507519902E-013
 -1.114929238487911E-015
 -4.431527939641692E-016
 -2.595836851216215E-015
  1.647019445505483E-016
 -2.379257563815675E-017
  7.319553519775736E-017
 -5.213395671062362E-017
  3.289587428502064E-022
 -4.539496438947701E-016
 -2.310149982242614E-013
 -1.486719549719792E-015
  6.801934337247862E-016
 -7.214083682498053E-015
 -5.823800295559346E-016
 -6.259925909860529E-016
  4.195807857258028E-016
 -2.844449250373392E-016
  2.047803689278409E-022
 -1.169376648643817E-016
 -2.246360061143093E-013
  1.075549150563510E-015
 -2.005632234151442E-015
 -9.252850654593092E-015
 -6.134138466189108E-017
  8.272411125288834E-017
 -7.205437456688902E-016
 -4.263913964250035E-016
 -3.861667797041397E-022
  1.854655198070081E-016
 -2.067276034377652E-013
  1.248275797905669E-015
 -1.944905015118435E-015
 -1.277010662392692E-014
 -4.693753899101042E-016
 -3.796175712198395E-017
 -1.198354771300028E-016
 -4.027764553092417E-016
  4.160599590119424E-022
 -3.815096360368109E-016
 -1.949464825461827E-013
 -1.918554868006354E-016
 -1.316438342589972E-015
 -6.608421701507834E-015
  8.704322806790649E-016
 -4.734082460665203E-017
 -3.826253005584749E-016
 -6.035465152641328E-017
 -4.700557781817701E-022
 -4.564459395348138E-017
 -1.837262075189382E-013
  9.128997100180615E-017
 -8.094649361022162E-016
 -3.135406882319494E-015
  7.164340958828101E-016
 -1.601500301043912E-016
 -2.961118550042523E-016
  1.765484029686094E-017
  1.919730501116846E-022
 -6.712141805615882E-017
 -1.769368017894056E-013
 -1.196326538264931E-015
  1.906155546476616E-016
 -1.191220686309774E-014
  5.337264736347278E-016
 -1.188246825628960E-016
  1.768730018737208E-016
  2.561861661593480E-016
  1.062435567209367E-020
  1.682627429971478E-016
 -1.705953370879159E-013
 -1.797283773305027E-015
  2.105127662761016E-015
  1.043629032181247E-014
  6.572774888666489E-016
 -2.926841757423667E-016
  4.518530095053730E-016
 -2.138679820615386E-016
 -2.657663481833010E-021
  2.239008838552174E-016
 -1.633371113655345E-013
 -2.877979309245204E-015
  1.650696061638851E-015
 -5.421980732837669E-015
  6.416372897795221E-016
 -1.568676431251505E-016
  1.148656110027339E-016
 -2.635406123484880E-016
 -2.523024663667660E-021
 -4.365492776741039E-016
 -1.614460185059186E-013
  2.591160162016777E-016
 -5.413916474011705E-017
 -8.392217691925060E-015
 -1.719224633547966E-016
  2.634930431803722E-016
 -1.655804299438491E-016
 -5.914504711701332E-017
 -6.814180381207081E-022
 -3.477094270062925E-016
 -1.638964567295366E-013
  1.470447852985118E-015
 -6.531990902067121E-016
  7.289022610749632E-016
 -4.283020352897330E-016
  3.142239695628403E-016
 -9.217052331749208E-017
  3.710844922947376E-016
 -1.257061155806484E-021
 -2.133789827707830E-018
 -1.599242116537912E-013
  4.011967741550591E-016
 -1.514544209371159E-015
  1.240228691915243E-014
 -7.477269358657449E-016
 -8.578938963892332E-017
  3.780546847104775E-016
  1.607962403484879E-016
 -5.381596450416201E-022
 -3.861274279583434E-016
 -1.599625855791575E-013
  7.865709378242202E-016
  2.343554214006605E-017
 -2.452726382893789E-015
  3.707721973512125E-016
  1.298665478287029E-016
 -1.231094354101211E-016
 -2.641478153059330E-016
 -5.325687573725127E-022
  2.615531162690618E-016
 -1.660562704063456E-013
  2.013144725366929E-015
 -9.468645388374120E-016
  7.819028670053827E-015
 -1.183442071701837E-016
 -2.129522697946462E-016
 -2.258072970695316E-016
 -2.988815140774921E-016
 -5.051580787505633E-022
  3.493388407627177E-017
 -1.602133336960061E-013
  1.101179065609818E-015
 -2.008678230412441E-015
  1.112969369139862E-014
 -2.066640879412241E-016
 -5.509907228877365E-016
  3.554113346802330E-016
  2.643714463655383E-016
 -4.155867033948228E-022
 -3.070702661056634E-016
 -1.516389965504377E-013
 -8.259250010556661E-016
  8.854276294548469E-016
 -6.765025420220438E-015
  4.769367043751115E-016
  3.431085100153769E-016
 -2.471435827783515E-016
 -3.789152482908748E-016
 -9.930315931912690E-023
 -3.946071681930700E-016
 -1.561524814049201E-013
 -8.134687597579961E-016
 -2.423709197657425E-016
  9.871890716830576E-015
  4.655447808494697E-016
 -3.222205069117876E-016
  1.367885268121480E-016
  1.000298751219711E-017
 -1.707586242062932E-022
 -3.833663110537139E-016
 -1.534201249100895E-013
 -1.241664664614998E-015
  8.196391950855910E-016
  2.055357172774103E-015
 -5.903810856872583E-016
 -3.162811757706140E-016
  9.561001423822786E-017
  3.018742718508256E-016
 -6.615557397407825E-022
  2.602507012608088E-017
 -1.522092991402718E-013
 -8.013158828976937E-016
  6.834692874473279E-017
 -7.391508361329592E-015
  4.110900382103633E-016
 -1.981065689714610E-016
  2.106435153288910E-016
 -2.351866399596474E-016
  4.287465609392390E-022
  1.581946831743592E-016
 -1.502821464776689E-013
 -1.231749967001175E-015
 -1.671188456931032E-016
 -4.414312614918436E-015
 -8.119775087689945E-016
  4.956860233126344E-016
 -2.844300130013083E-016
  2.280306546424511E-016
 -5.376212468587899E-022
 -3.864906864944598E-016
 -1.484150166321928E-013
 -1.377331263203222E-015
  1.228168603074769E-015
  5.838005044504578E-015
  1.773370190933397E-016
  3.769884504862298E-016
 -2.930764477312321E-016
  1.030924406852915E-016
  3.729915552118602E-023
  4.310738570004973E-016
 -1.579935726946038E-013
  6.401731387235232E-016
 -1.939270632242804E-015
 -1.960945859040799E-015
 -2.797984335389849E-016
  1.421676253626147E-016
 -5.108507083434325E-016
  3.776713071421834E-016
 -2.922245045293677E-022
  2.983292953241379E-016
 -1.550992112156320E-013
  2.001443984365210E-015
 -1.289126896309313E-015
  1.091062544863898E-014
 -2.797688333874232E-016
 -2.830763850580884E-016
  2.236812103382818E-016
 -1.804943820783214E-016
  2.083150454555826E-022
  4.847120839778636E-016
 -1.540041943674223E-013
  1.421556267763985E-015
 -3.804806392116858E-016
  5.659884110339651E-015
 -1.789004964330911E-016
  3.627387005821464E-016
  3.241408170195310E-016
  2.149917034861833E-016
 -9.950429989548675E-023
  1.557434859996862E-016
 -1.528986825754895E-013
  1.465140033846602E-016
 -8.880330676590093E-016
  8.612600349796219E-015
  6.311660659506714E-016
 -3.259565062071092E-017
  5.979173039479484E-017
  4.346892546682340E-017
 -4.975640397504962E-023
 -1.567438791131900E-016
 -1.484300605067728E-013
 -3.613753262812719E-016
 -9.071380197879688E-017
 -9.130227630948294E-016
 -3.300629148915194E-016
 -3.147142953794207E-016
 -4.990404695413582E-016
 -2.146329724015107E-016
  1.243993784132767E-023
 -1.706353858658174E-016
 -1.522718728124706E-013
 -1.326477161284607E-015
  1.993834811454476E-015
 -9.662977196408675E-016
  4.872949491526458E-016
 -4.297685649269843E-017
  7.490895781781152E-017
  3.028850913742974E-016
 -3.981007614739116E-022
 -4.075182822806170E-016
 -1.491173477038620E-013
 -6.980119114517813E-016
 -2.963097401666816E-016
  9.959080984395485E-015
 -2.020693995620320E-016
 -2.059219421988362E-016
 -3.813155184142752E-016
  2.625999582311853E-016
  1.679562805562945E-022
  2.059049599842897E-016
 -1.493022620107247E-013
 -6.582246756135101E-016
  4.363907328353635E-016
  5.150453702549501E-015
  7.048992881013334E-016
  1.535725721731088E-016
 -5.207588919600857E-016
 -1.399349736792109E-016
  3.732497881304782E-023
  5.643863920274066E-018
 -1.594714039711094E-013
  3.745619503053808E-015
 -1.978966056528690E-015
  1.006209183409418E-014
  2.082621513115570E-016
 -2.779528666750741E-016
 -7.865597410251371E-017
 -2.623546196777479E-016
  1.648567391534644E-022
 -4.471729884209777E-016
 -1.548623198806589E-013
  1.777414627672620E-015
 -9.689279172551071E-016
 -9.304954102926800E-015
  1.684412490633583E-016
 -2.756189101663360E-016
 -6.076885421424910E-017
  1.108740478899626E-016
 -6.532213161941451E-023
  4.810129095991623E-017
 -1.551162416793948E-013
  8.996817132024526E-017
  3.139997739070977E-016
 -5.488629084079079E-015
  5.911995385637902E-016
  1.887431022019135E-016
  2.223234912547297E-016
 -2.522267064323672E-016
 -1.119829249771367E-022
 -7.136422740236220E-017
 -1.479213103333019E-013
 -1.583074339200995E-015
  1.272751167673065E-015
  3.590793978999539E-015
  6.093754131732008E-016
 -2.390692585900395E-016
  1.920336880651634E-016
 -1.449010673780802E-016
 -2.084158071711677E-022
 -3.913448319221651E-016
 -1.545142276525884E-013
  1.002771495578451E-016
 -1.850365990696871E-016
  5.189258361535471E-015
 -1.756010916562367E-016
  7.590905144962987E-018
  5.365701143566854E-016
  3.901401986970559E-016
  4.479439747028663E-022
 -1.873967326603033E-016
 -1.547914369820225E-013
  7.272001132618216E-016
 -1.148488414373879E-015
 -7.259466752995073E-015
  1.462316127272767E-016
  2.339474809690108E-017
  4.575231288071927E-017
 -2.216423299535825E-016
 -5.443817749481694E-022
  1.246623586761170E-017
 -1.454371610626823E-013
 -2.103302595875791E-015
  2.281524562547782E-015
 -1.129069207195355E-014
 -7.317421485044872E-016
  4.075726792719733E-016
 -2.203323186170238E-016
  7.690869289790213E-018
  2.519729991308861E-022
 -4.357812311888085E-016
 -1.517917510679626E-013
 -1.373043161162639E-015
  1.739758469282360E-015
  1.295039861845350E-015
  8.332859875143093E-016
  1.129710464835813E-016
 -3.374280860222684E-016
 -4.386680095798498E-016
 -1.711822812856088E-022
 -3.469118123657939E-016
 -1.497066935800095E-013
 -2.633865274406694E-016
 -6.772622575720105E-016
 -3.623673857288076E-015
  1.027918038210212E-015
  2.715249567450531E-016
 -1.129337249509656E-017
 -8.946470809300769E-017
  6.339593641428919E-017
 -4.005235853753490E-016
 -1.464313867661378E-013
 -1.762971851457260E-015
 -4.958006947257242E-016
 -6.104059587040200E-017
 -8.194641294070323E-016
  2.451937627779521E-016
 -1.120253921779056E-016
 -1.071139900622929E-016
  6.057129851426940E-017
 -2.471251021753828E-016
 -1.852202218179294E-013
  6.149999762539767E-015
 -7.783300467831166E-015
 -3.016625641248090E-012
 -5.649466488384430E-016
 -8.678036781431048E-017
  8.735313480449531E-012
 -2.977673874681073E-011
 -2.463293743544682E-017
 -2.704214321075471E-012
 -7.527615859596326E-009
  1.582179106883333E-009
 -1.344499570192687E-009
 -2.790876176694438E-006
  8.379689238118644E-012
 -3.015335177034951E-011
        1010
  8.153586085887367E-017
  1.247809674290731E-016
  5.961866680655368E-017
  5.921074377631222E-015
 -6.539172240766337E-016
  7.877249149188572E-016
  3.644926235002892E-015
  3.154145968951859E-016
 -4.861917178752205E-016
  8.154911675647922E-017
  1.247993328537312E-016
  5.963767639670687E-017
  5.920989896446852E-015
 -6.538999344749132E-016
  7.877258448034865E-016
  3.644939192622492E-015
  3.154285006498938E-016
 -4.861766812044828E-016
  8.152260597872028E-017
  1.247626016941214E-016
  5.959964660082862E-017
  5.921026999796897E-015
 -6.539345309759265E-016
  7.877239982655648E-016
  3.644913290428664E-015
  3.154006962093494E-016
 -4.862067465822176E-016
  8.153586136800386E-017
  1.247809672744860E-016
  3.855511010309058E-028
  5.961866149934714E-017
  5.921008448121042E-015
 -6.539172327248924E-016
  7.877249215345537E-016
  3.644926241525976E-015
  3.154145984300454E-016
 -4.861917138928922E-016
  8.154911675647925E-017
  5.963767639670666E-017
  5.920989896446492E-015
 -6.538999344749114E-016
  7.877258448034849E-016
  3.644939192622491E-015
  3.154285006498939E-016
 -4.861766812044827E-016
  3.855511010309101E-028
  8.152260597952722E-017
  1.247626016952394E-016
  5.959964660198620E-017
  5.921026999795588E-015
 -6.539345309748731E-016
  7.877239982656207E-016
  3.644913290429461E-015
  3.154006962101958E-016
 -4.862067465813024E-016
  8.154911675594169E-017
  1.247993328529864E-016
  5.963767639593541E-017
  5.920989896447361E-015
 -6.538999344756120E-016
  7.877258448034466E-016
  3.644939192621959E-015
  3.154285006493300E-016
 -4.861766812050926E-016
  8.153586136719689E-017
  1.247809672733680E-016
 -7.696902149872033E-028
  5.961866149818955E-017
  5.921008448122351E-015
 -6.539172327259456E-016
  7.877249215344977E-016
  3.644926241525179E-015
  3.154145984291991E-016
 -4.861917138938074E-016
  8.153586136854140E-017
  1.247809672752309E-016
  5.961866150011839E-017
  5.921008448120170E-015
 -6.539172327241906E-016
  7.877249215345909E-016
  3.644926241526507E-015
  3.154145984306092E-016
 -4.861917138922823E-016
 -7.696902149871976E-028
  8.154911675728624E-017
  1.247993328548493E-016
  5.963767639786424E-017
  5.920989896445188E-015
 -6.538999344738606E-016
  7.877258448035431E-016
  3.644939192623290E-015
  3.154285006507402E-016
 -4.861766812035676E-016
  8.153586136665823E-017
  1.247809672726211E-016
  5.961866149742219E-017
  5.921008448123227E-015
 -6.539172327266516E-016
  7.877249215344626E-016
  3.644926241524649E-015
  3.154145984286342E-016
 -4.861917138944182E-016
  8.150935237943974E-017
  1.247442269903770E-016
  5.958071859108735E-017
  5.921045607561324E-015
 -6.539518767233011E-016
  7.877231127504140E-016
  3.644900358792284E-015
  3.153867955791746E-016
 -4.862217838437130E-016
  8.156237035576068E-017
  1.248177075574771E-016
  5.965660440644763E-017
  5.920971288682065E-015
 -6.538825887275355E-016
  7.877267303186362E-016
  3.644952124258872E-015
  3.154424012800695E-016
 -4.861616439429858E-016
  8.152260597925786E-017
  1.247626016948667E-016
  5.959964660159634E-017
  5.921026999796025E-015
 -6.539345309752232E-016
  7.877239982656010E-016
  3.644913290429194E-015
  3.154006962099133E-016
 -4.862067465816077E-016
  3.855511322459555E-028
 -7.696902149872019E-028
  8.154911675513487E-017
  1.247993328518678E-016
  5.963767639478312E-017
  5.920989896448673E-015
 -6.538999344766683E-016
  7.877258448033931E-016
  3.644939192621163E-015
  3.154285006484838E-016
 -4.861766812060080E-016
  8.150935237998065E-017
  1.247442269911174E-016
  5.958071859185389E-017
  5.921045607561145E-015
 -6.539518767227934E-016
  7.877231127506571E-016
  3.644900358792932E-015
  3.153867955797383E-016
 -4.862217838431035E-016
  8.156242353633883E-017
  1.248176344772485E-016
  5.965652734522961E-017
  5.920982707972919E-015
 -6.538857264697922E-016
  7.877300694719966E-016
  3.644954030445096E-015
  3.154423971166120E-016
 -4.861616461808058E-016
  4.888408415382692E-018
 -3.208927601129616E-016
  1.172820376488318E-016
 -1.586766358447676E-015
  3.313893419414632E-016
 -2.222810270881709E-016
  6.064138510504100E-015
  2.454610772515045E-016
 -2.808231641885324E-016
 -3.291062748150379E-016
 -1.362388291695852E-016
  2.538291152388878E-016
 -2.715472896160305E-015
  1.744262712795822E-015
 -4.595355052815404E-016
 -9.017058348291692E-015
 -4.896539917140241E-017
 -9.053466170297361E-017
 -3.275674840751962E-016
 -4.114855973780757E-016
 -2.029103664914817E-016
  1.524394752203724E-014
 -5.351301419535579E-015
  3.138355147311577E-015
 -4.512276766033612E-015
  1.202813263045486E-016
  2.191656396411418E-016
 -5.020636098527481E-016
 -2.070049471667258E-016
  2.945722981655455E-016
 -5.246625724763935E-016
 -1.030423238050390E-015
  1.305387606753711E-015
  2.179284594951511E-016
 -1.009934153774448E-015
  5.592175646831084E-016
  3.151007259989826E-016
 -8.825280539495283E-017
  2.248480193239116E-016
 -3.539360385029897E-015
  4.699893592960997E-016
 -5.315475469796728E-016
  1.264338367391075E-014
  2.197786972200080E-016
 -1.273636950015483E-016
  3.418331661084824E-016
 -9.219019371862193E-017
  2.521144598605905E-016
  4.059532593939438E-015
 -1.030995627645253E-015
  1.278837894213587E-015
 -4.537975435122238E-015
  8.741779167447969E-016
 -4.044277950407611E-016
  4.360079778598718E-016
  1.967398516190702E-017
 -1.361114295633186E-016
 -1.378089106743176E-015
  4.241788566629928E-016
 -2.112392369892467E-016
  6.304963141331940E-015
  6.900165175879760E-016
  1.390032677854028E-016
 -5.808899765501843E-017
  7.270358006116967E-017
 -7.631514355343081E-018
 -1.143462380202385E-014
  2.627896351700955E-015
 -1.922971258967743E-015
  1.215193431917806E-014
 -6.185869941147686E-016
  5.878656894396461E-017
 -1.176444223094471E-016
 -1.123847063137150E-016
  1.260299611492284E-016
 -1.020904635727444E-014
  4.017756226042996E-015
 -5.297645111577684E-015
 -3.933845851891997E-015
 -1.064605699931021E-016
  9.731908656630192E-017
 -4.067386277257270E-017
  1.626028455996997E-016
 -1.748101915524973E-016
  9.568600397016493E-015
 -2.860228968037910E-015
  3.330388674486881E-015
  9.936376707591644E-015
 -3.023849011877391E-017
 -9.838866993397261E-017
  3.475437642140447E-016
  2.739731913135067E-016
 -2.275044930843041E-016
  6.790323548032618E-015
 -6.748689550152288E-016
  6.681610610524952E-016
 -1.957501620379280E-015
  1.648270524445270E-016
 -2.013798868999484E-017
  1.120283898861643E-016
 -9.715730000189787E-017
  4.103472830935870E-016
  7.543587049427807E-015
 -1.085088906345173E-015
  1.845363264816736E-015
 -6.295703586339844E-015
 -7.192100547181554E-016
  4.915882655367800E-016
  4.147940856011893E-016
 -2.844969298395080E-016
 -1.170504996906904E-016
 -3.688747558217335E-015
  1.662267851819297E-015
 -2.067191351033050E-015
 -1.030504380692825E-014
 -6.187429984645956E-017
  8.401540701588433E-017
  2.117235175096021E-016
 -4.301656761366487E-016
  1.884346398945236E-016
  4.823814514835898E-015
 -2.528823023055613E-015
 -3.281753603482043E-016
 -1.179948301357225E-014
 -4.990201027180898E-016
  5.572401640208989E-017
 -1.442041718830137E-016
 -4.030413130941549E-016
 -3.823551575186215E-016
 -1.103305754500861E-014
  2.935748643112627E-015
 -1.776945250594120E-015
 -7.917611409681881E-015
  8.676250145423500E-016
 -4.076618142583438E-017
 -3.826235260157805E-016
 -6.035463778619347E-017
 -4.564313138991478E-017
  9.662068630201612E-016
  9.032351237307658E-017
 -8.086558287016939E-016
 -3.134943660359332E-015
  7.164352489388665E-016
 -1.601505145405320E-016
 -3.021246477783797E-016
  1.758866920744919E-017
 -7.296345116988442E-017
 -4.448340600320655E-015
  2.497040365465874E-015
 -2.990282582553300E-015
 -1.262183058394295E-014
  5.292999198243133E-016
 -1.171818826554930E-016
  1.706624319776776E-016
  2.561177161757126E-016
  1.614910232123640E-016
 -6.484431094706701E-015
  2.400091740459382E-015
 -1.582007000563854E-015
  9.373505796677870E-015
  6.522135220705181E-016
 -2.909846465736486E-016
 -5.502676323506312E-016
 -2.152537770849048E-016
  2.195088696906749E-016
 -2.202979574556163E-015
  1.452425916436342E-015
 -7.407047310191860E-016
 -5.790271790561523E-015
  6.271218738004765E-016
 -1.224689152354327E-016
  1.148671877539249E-016
 -2.635406008804442E-016
 -4.365480395548875E-016
  1.792142166291974E-015
  2.582560726700109E-016
 -5.341881297618011E-017
 -8.391805294413138E-015
 -1.719214353044310E-016
  2.634926078545257E-016
 -1.424559831096246E-016
 -5.889320806936653E-017
 -3.433217087305126E-016
  7.461385425440597E-015
 -3.357051336535043E-015
  1.736027898178343E-015
  2.094432225613791E-015
 -4.232673000680642E-016
  3.079719540355635E-016
 -1.117982603983011E-016
  3.708714370049475E-016
 -1.037420028854783E-018
 -7.330313632798694E-016
  1.998539932863847E-015
 -9.177010592460510E-016
  1.157199521897595E-014
 -7.488049794268375E-016
 -8.050035073405292E-017
  3.922062897084866E-016
  1.609494091480255E-016
 -3.900330537363629E-016
  2.499966032410457E-015
  1.250467938406285E-015
 -2.103057326968487E-015
 -2.877497896950353E-015
  3.694749008597927E-016
  1.260645397400574E-016
 -1.223492713369050E-016
 -2.641389789990922E-016
  2.655098470742376E-016
 -1.364105102776033E-015
 -1.228394267716549E-016
  1.207483147560798E-015
  8.004742100494817E-015
 -1.156568086350242E-016
 -2.131716913298067E-016
 -3.023694729722754E-016
 -3.428543916815318E-016
  3.888055979578698E-017
  3.985758451416498E-015
 -1.024894309092556E-015
  1.401769753022742E-016
  1.133610954468209E-014
 -1.942549801639422E-016
  5.405155447626759E-016
  3.554127659601544E-016
  2.643714655207195E-016
 -3.070690857595644E-016
 -2.635662668575267E-015
 -8.267011703995378E-016
  8.860766238646161E-016
 -6.764653878866292E-015
  4.769376291697133E-016
  3.431081179220725E-016
 -2.471420839426087E-016
 -3.789152277116996E-016
 -3.946060172670380E-016
  1.666236398953449E-017
 -8.142773665486485E-016
 -2.416955916012956E-016
  9.872277333425359E-015
  4.655457451280640E-016
 -3.222209161943373E-016
  1.334696562393999E-016
  9.966300820636117E-018
 -3.876793037300665E-016
  9.137700797067335E-016
  1.361450305559873E-015
 -1.528715557565351E-015
  1.632634277259950E-015
 -5.935414986435616E-016
 -3.153704415172422E-016
  9.561146241930531E-017
  3.018742842558020E-016
  2.602618193142986E-017
 -2.805243569786379E-015
 -8.020913694991789E-016
  6.899486987204487E-017
 -7.391137424850929E-015
  4.110909642729371E-016
 -1.981069636206272E-016
  2.733706979149071E-016
 -1.912557506268651E-016
  1.591290174888921E-016
  5.308577040689641E-016
 -8.912401828249144E-017
  3.416358630166969E-016
 -4.083763751854853E-015
 -8.224525411679690E-016
 -5.947783052837313E-016
 -2.852104725702227E-016
  2.280215748658877E-016
 -3.905662835247943E-016
 -1.891242848570904E-016
  8.225568081958682E-016
 -9.909190317075550E-016
  5.520796745897637E-015
  1.745685588047576E-016
  3.772137741601839E-016
 -3.126228657987130E-016
  1.028804091187706E-016
  4.332516447475588E-016
 -4.044568147484395E-015
  1.667624740489220E-015
 -7.535299143951963E-016
 -2.391343876733902E-015
 -2.801487809114564E-016
  1.474307800294463E-016
  4.377229554478654E-016
  3.735393434806540E-016
  3.034465444181021E-016
  4.269236993255880E-015
 -8.152760955373382E-016
  1.497130932109175E-015
  1.137995514138174E-014
 -3.110024663700758E-016
 -1.805120012640734E-016
  2.384317986839544E-016
 -1.803342853681036E-016
 -4.290660109764787E-016
  1.394611971107466E-017
  3.738839009593854E-016
 -9.895142487812669E-016
  5.309156200301156E-015
 -1.783042728951374E-016
  3.587650167553517E-016
  3.241423092626085E-016
  2.149917261379169E-016
  1.557447980410804E-016
  3.298197949204545E-015
  1.457046114261751E-016
 -8.873561494013359E-016
  8.612987876769357E-015
  6.311670315977121E-016
 -3.259605817572562E-017
  7.975447991948333E-017
  4.368577873581429E-017
 -1.568171597407242E-016
  6.687127317047944E-015
 -2.526310890364687E-015
 -1.304615703838905E-016
  1.537596014797781E-017
 -3.282724795299293E-016
 -3.200974208391005E-016
  6.101411631929783E-016
 -2.025839822127205E-016
 -1.784644057566546E-016
 -5.240946152318472E-015
  1.183411975628830E-015
 -2.268863260689783E-015
 -1.548482694906540E-015
  5.830753701060250E-016
 -3.420598994900139E-016
  7.491038794331426E-017
  3.028851078128216E-016
 -4.075170620500989E-016
  2.356305222712658E-017
 -6.987821215367987E-016
 -2.956667625393490E-016
  9.959449079125820E-015
 -2.020684811932222E-016
 -2.059223326510615E-016
 -3.813140851893559E-016
  2.625999691670913E-016
  2.059060603279397E-016
  1.097573709363565E-016
 -6.590024082601302E-016
  4.370408962114174E-016
  5.150825915332756E-015
  7.049002136426998E-016
  1.535721864851592E-016
  4.456660604883143E-016
 -1.438807342447330E-016
  1.007918813715289E-017
 -6.361715379596583E-016
 -6.320927640431254E-016
  4.359761365760193E-016
  1.056963863670881E-014
  1.781366381812718E-016
 -1.800104242553367E-016
 -5.810357539190713E-017
 -2.621309138078980E-016
  4.687818587644100E-016
  6.901445777212072E-015
 -1.997780768399970E-015
  6.134769442839011E-016
 -8.401235419067741E-015
  1.722524303539789E-016
 -2.811718974755924E-016
 -4.633786007275109E-017
  1.110303956887564E-016
  4.520667601330914E-017
  1.730051613517988E-015
 -1.319700936300379E-018
 -1.261982084324852E-015
 -5.470912762043309E-015
  5.906013151459123E-016
  1.848620534725615E-016
  2.215905665071697E-016
 -2.522352188804811E-016
 -7.519214598988652E-017
 -1.094768552165905E-017
  4.831514286968097E-016
 -8.115141675503258E-016
  3.318713454422767E-015
  6.067762360780061E-016
 -2.388576551012761E-016
  1.920351930327220E-016
 -1.449010450279344E-016
 -3.913434719409880E-016
  1.883740178207471E-015
  9.946323436319972E-017
 -1.843563253658160E-016
  5.189647808598874E-015
 -1.756001208081426E-016
  7.590494365274284E-018
 -6.057591812195597E-016
  3.921777554609552E-016
 -1.821736058161119E-016
  5.291742553294652E-015
 -6.496209545721380E-016
  1.695452396955285E-015
 -6.670973971469997E-015
  1.667621076460995E-016
 -2.718235823766324E-017
  5.387663850756816E-017
 -2.215554821030469E-016
  2.734831519506752E-018
 -9.640423193794541E-015
  2.047229885676693E-015
 -3.017123804497190E-015
 -1.238862148225944E-014
 -7.374570567444266E-016
  4.054173248530685E-016
 -2.211008176819077E-016
  7.681931169863042E-018
 -4.397945585937942E-016
 -3.786007334818432E-015
  7.931903945961133E-016
 -4.453819322312165E-016
  9.654925183131414E-016
  8.305601461182993E-016
  1.131929211172325E-016
 -3.393768504337958E-016
 -4.388796647749798E-016
 -3.469122458023339E-016
 -2.951097938257036E-016
 -2.630067482096656E-016
 -6.775083485810696E-016
 -3.655824463974508E-015
 -8.721264453548669E-016
  2.767789068765200E-016
 -2.888186228895717E-017
 -8.965587896417150E-017
 -4.010765769168666E-016
  1.759003684734286E-015
  4.646878471130058E-016
 -7.968444505692832E-016
 -2.312141702752619E-016
 -8.214349593800767E-016
  2.499388617769905E-016
  5.831150193506925E-017
 -1.052614945152446E-016
 -2.332747095707758E-016
  7.166790827474248E-016
  3.166828925458488E-016
 -2.421142066373794E-016
 -3.401870313212905E-015
 -5.403272490714433E-016
 -1.327643764517737E-016
  2.636174522058980E-016
 -4.335449141928176E-016
 -1.846335731462768E-016
 -3.539880623376984E-012
  1.608155630259402E-013
 -1.570558685243538E-013
  6.881348082018194E-011
  4.046405070583830E-016
 -4.655077203699127E-016
Vector Object: 4 MPI processes
  type: mpi
Process [0]
5.67273e-017
8.18601e-017
2.31048e-027
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67273e-017
8.18601e-017
3.85551e-028
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67273e-017
8.18601e-017
3.85551e-028
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67273e-017
8.18601e-017
3.85551e-028
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67273e-017
8.18601e-017
-7.6969e-028
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67273e-017
8.18601e-017
1.15524e-027
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67273e-017
8.18601e-017
-7.6969e-028
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67273e-017
8.18601e-017
1.15524e-027
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67273e-017
8.18601e-017
-1.54065e-027
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67008e-017
8.18234e-017
-3.79506e-020
5.67128e-017
-1.79946e-012
3.62854e-017
-7.26244e-016
1.92523e-015
1.40816e-016
5.79016e-016
5.67538e-017
8.18968e-017
3.79506e-020
5.67887e-017
-1.79946e-012
3.63546e-017
-7.26241e-016
1.92528e-015
1.40872e-016
5.79076e-016
5.23704e-017
8.20378e-017
-1.89765e-020
5.94923e-017
-1.7924e-012
-6.39844e-016
7.76678e-016
4.88134e-016
1.4203e-016
5.80807e-016
-3.4406e-012
-3.69778e-013
-7.6969e-028
Process [1]
-1.98953e-015
-7.01887e-012
2.25793e-012
-1.23707e-012
1.57053e-012
-1.62148e-012
4.7966e-012
5.85482e-017
8.20734e-017
1.89765e-020
5.67697e-017
-1.79946e-012
3.64015e-017
-7.26277e-016
1.92532e-015
1.40806e-016
5.79215e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67273e-017
8.18601e-017
-7.6969e-028
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67273e-017
8.18601e-017
1.15524e-027
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67273e-017
8.18601e-017
3.85551e-028
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67273e-017
8.18601e-017
-7.6969e-028
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67273e-017
8.18601e-017
1.15524e-027
5.67508e-017
-1.79946e-012
3.632e-017
-7.26242e-016
1.92526e-015
1.40844e-016
5.79046e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67141e-017
8.18417e-017
-1.89765e-020
5.67318e-017
-1.79946e-012
3.63027e-017
-7.26243e-016
1.92525e-015
1.4083e-016
5.79031e-016
5.67406e-017
8.18785e-017
1.89765e-020
5.67698e-017
-1.79946e-012
3.63373e-017
-7.26241e-016
1.92527e-015
1.40858e-016
5.79061e-016
5.67008e-017
8.18234e-017
-3.79506e-020
5.67128e-017
-1.79946e-012
3.62851e-017
-7.26244e-016
1.92523e-015
1.40816e-016
5.79016e-016
7.0038e-017
8.19915e-017
3.79506e-020
5.46939e-017
-1.7973e-012
-3.98681e-016
-1.93043e-015
2.14375e-015
1.40636e-016
5.75553e-016
6.44763e-012
7.00299e-013
-1.48955e-020
5.87468e-015
9.31396e-012
-4.10542e-012
Process [2]
-4.49096e-015
-2.23948e-012
1.58793e-012
-4.70425e-012
-3.24804e-016
-1.36256e-016
2.75712e-021
2.55489e-016
-1.66099e-012
3.01752e-016
4.46153e-016
-4.31127e-015
-4.73103e-017
-9.19273e-017
-3.52585e-016
-4.11764e-016
1.29659e-021
-2.13631e-016
-1.30921e-012
2.93514e-015
-2.66289e-015
-6.78453e-015
1.10927e-016
2.25951e-016
5.27487e-016
-3.71912e-016
-3.32528e-021
2.89258e-016
-9.91688e-013
2.18842e-015
-1.56064e-015
-3.88654e-016
9.37861e-016
-4.75241e-016
6.10885e-016
-8.50222e-017
2.33753e-021
2.20804e-016
-7.59513e-013
2.83878e-015
-2.71056e-015
9.4163e-015
4.50924e-016
-2.07629e-016
4.87647e-017
-9.53766e-017
-1.02067e-021
2.49888e-016
-5.92091e-013
-1.45126e-015
8.37079e-017
-7.17617e-015
8.46008e-016
-3.25388e-016
4.51271e-016
1.98382e-017
5.45635e-022
-3.8112e-018
-4.71785e-013
-1.68905e-015
2.38957e-016
7.62887e-015
6.91942e-016
1.34884e-016
1.22486e-016
7.4665e-017
-4.45796e-022
-7.54658e-019
-3.8863e-013
-3.05363e-015
1.83124e-015
9.18431e-015
-5.97701e-016
1.00663e-017
-1.1622e-016
-1.12369e-016
3.28601e-022
1.33479e-016
-3.33952e-013
-1.24653e-017
-1.23235e-015
-9.7423e-015
-1.01503e-016
9.69081e-017
-4.91134e-017
1.62509e-016
-3.60119e-022
-1.82915e-016
-2.98513e-013
2.26806e-015
-1.07586e-015
8.36706e-015
-3.63851e-017
-9.60832e-017
3.61124e-016
2.7412e-016
-1.9145e-022
-2.29556e-016
-2.61798e-013
-1.11515e-015
-4.4296e-016
-2.59573e-015
1.64702e-016
-2.37927e-017
1.4258e-016
-1.83809e-016
3.28959e-022
2.65377e-016
-2.30348e-013
-9.22282e-016
1.1551e-015
-2.11006e-015
-5.32784e-016
-4.16999e-016
4.19581e-016
-2.84446e-016
2.0478e-022
-1.16947e-016
-2.20084e-013
1.0753e-015
-2.00542e-015
-9.25273e-015
-6.13411e-017
8.2724e-017
-5.27938e-016
-1.86759e-016
-3.86167e-022
1.87782e-016
-2.08096e-013
2.10397e-015
-6.80028e-016
-1.21795e-014
-4.43378e-016
2.50254e-016
-1.42861e-016
-2.76414e-016
4.1606e-022
-3.80379e-016
-1.96427e-013
1.86469e-015
-6.96502e-016
-7.0809e-015
8.69871e-016
-4.34681e-017
-3.82625e-016
-6.03551e-017
-4.70056e-022
-4.56508e-017
-1.87794e-013
9.11803e-017
-8.0937e-016
-3.13535e-015
7.16434e-016
-1.6015e-016
4.05823e-016
-2.3068e-016
1.91973e-022
-6.37155e-017
-1.71879e-013
-1.72913e-015
2.04834e-015
1.50637e-014
3.50047e-016
-3.02791e-016
1.86335e-016
2.56288e-016
1.06244e-020
1.66388e-016
-1.71001e-013
-1.8722e-015
1.08706e-015
8.89832e-015
6.56817e-016
-2.95229e-016
4.51853e-016
-2.13868e-016
-2.65766e-021
2.23895e-016
-1.60398e-013
-2.87809e-015
1.65079e-015
-5.42193e-015
6.41637e-016
-1.56868e-016
2.47946e-016
-2.66858e-016
-2.52302e-021
-4.30663e-016
-1.5859e-013
-2.92934e-015
3.15433e-015
-9.39884e-015
-1.95792e-016
3.45818e-016
-1.6558e-016
-5.91455e-017
-6.81418e-022
-3.47716e-016
-1.6807e-013
1.47041e-015
-6.53181e-016
7.28912e-016
-4.28302e-016
3.14224e-016
-3.73664e-016
3.58463e-016
-1.25706e-021
-1.29423e-018
-1.60566e-013
2.34415e-016
-1.05416e-015
1.10507e-014
-8.52906e-016
2.27489e-016
3.78088e-016
1.60796e-016
-5.3816e-022
3.70499e-016
-1.56847e-013
7.46321e-016
6.2873e-017
3.51038e-015
3.70982e-016
1.29857e-016
-2.78448e-016
-2.65836e-016
-5.32569e-022
2.57011e-016
-1.57443e-013
1.45593e-015
-3.41818e-015
6.20289e-015
-1.35478e-016
-1.71046e-016
-2.42602e-016
-2.99086e-016
-5.05158e-022
3.93934e-017
-1.61275e-013
6.1265e-016
4.22799e-016
1.04055e-014
-2.05411e-016
-5.46066e-016
4.21377e-012
4.57488e-013
-4.15587e-022
3.56653e-016
6.52152e-013
-5.19831e-013
2.79642e-013
-5.22808e-012
Process [3]
9.86547e-013
-2.922e-012
-2.65051e-016
-3.79128e-016
-9.93032e-023
-3.96084e-016
-1.56724e-013
1.90577e-015
-1.04387e-015
9.41515e-015
4.62901e-016
-3.17293e-016
-1.12476e-016
2.50057e-018
-1.70759e-022
-3.8586e-016
-1.56165e-013
2.04068e-015
-5.35566e-016
1.90711e-015
-5.28609e-016
-1.30062e-016
9.4877e-017
3.01865e-016
-6.61556e-022
2.21898e-017
-1.56883e-013
1.26605e-015
-2.01694e-015
-9.64645e-015
4.08489e-016
-1.97894e-016
2.10644e-016
-2.35187e-016
4.28747e-022
1.5819e-016
-1.55217e-013
-1.23176e-015
-1.6712e-016
-4.41431e-015
-8.11978e-016
4.95686e-016
-1.93988e-016
2.38634e-016
-5.37621e-022
-3.89048e-016
-1.56645e-013
8.21236e-016
-1.62007e-016
3.99466e-015
2.64474e-016
1.13773e-016
-2.97649e-016
1.03043e-016
3.72992e-023
4.33248e-016
-1.5112e-013
1.35779e-017
-7.51707e-016
-1.29946e-015
-2.78767e-016
1.43393e-016
-4.2175e-016
3.69001e-016
-2.92225e-022
2.99057e-016
-1.55857e-013
1.05092e-015
-8.90743e-016
-1.39182e-014
-4.78276e-016
-6.78696e-017
2.23681e-016
-1.80495e-016
2.08315e-022
4.84707e-016
-1.51833e-013
1.42142e-015
-3.80362e-016
5.65995e-015
-1.789e-016
3.62739e-016
-9.09995e-016
2.0641e-016
-9.95043e-023
1.53697e-016
-1.58812e-013
1.87057e-015
-2.00027e-015
1.04959e-014
6.84418e-016
1.80415e-016
5.97918e-017
4.34686e-017
-4.97564e-023
-1.56748e-016
-1.53205e-013
-3.61485e-016
-9.06141e-017
-9.12966e-016
-3.30063e-016
-3.14714e-016
-4.9904e-016
-2.14633e-016
1.24399e-023
-1.7064e-016
-1.5013e-013
-1.32653e-015
1.99387e-015
-9.66275e-016
4.87295e-016
-4.29769e-017
-1.94216e-016
3.09591e-016
-3.98101e-022
-2.54707e-016
-1.50321e-013
-7.6335e-016
6.26824e-017
8.23238e-015
-1.45429e-016
-3.7238e-016
3.83843e-016
2.56442e-016
1.67956e-022
2.05869e-016
-1.48647e-013
-6.84306e-016
4.18573e-016
6.01565e-015
4.00301e-016
3.06423e-016
-5.02448e-016
-1.39736e-016
3.7325e-023
9.96141e-018
-1.50025e-013
-5.15987e-016
3.73763e-016
1.13883e-014
2.12809e-016
-2.82907e-016
-7.86558e-017
-2.62355e-016
1.64857e-022
-4.47178e-016
-1.52662e-013
1.77729e-015
-9.68816e-016
-9.30489e-015
1.68441e-016
-2.75619e-016
-2.4325e-016
1.08891e-016
-6.53221e-023
4.90019e-017
-1.50232e-013
-3.88148e-016
8.06742e-016
-6.2446e-015
5.75119e-016
2.37949e-016
2.22324e-016
-2.52227e-016
-1.11983e-022
-7.13687e-017
-1.52801e-013
-1.58319e-015
1.27285e-015
3.59085e-015
6.09376e-016
-2.39069e-016
3.68947e-016
-1.4298e-016
-2.08416e-022
-3.95262e-016
-1.57295e-013
2.75324e-015
-2.31554e-015
8.26149e-015
-1.62055e-016
-4.01031e-017
-4.11861e-016
3.94283e-016
4.47944e-022
-1.8869e-016
-1.5888e-013
1.47578e-015
-1.8488e-015
-8.70779e-015
1.80106e-016
-7.94469e-017
4.57525e-017
-2.21643e-016
-5.44382e-022
1.24615e-017
-1.43266e-013
-2.1034e-015
2.2816e-015
-1.12906e-014
-7.31742e-016
4.07573e-016
-2.04919e-016
1.38496e-016
2.51973e-022
3.22147e-016
-1.50379e-013
-1.40457e-015
1.0219e-016
3.33189e-015
8.33535e-016
1.06417e-016
-3.37428e-016
-4.38668e-016
-1.71182e-022
-3.46916e-016
-1.47507e-013
-2.63509e-016
-6.77155e-016
-3.62361e-015
1.02792e-015
2.71525e-016
-1.12932e-017
-8.94651e-017
6.33959e-017
-4.00528e-016
-1.44246e-013
-1.76306e-015
-4.95729e-016
-6.09994e-017
-8.19464e-016
2.45194e-016
-1.10913e-016
-1.07101e-016
6.05713e-017
-2.41324e-016
-1.75451e-013
3.0153e-015
-4.62148e-015
-3.01797e-012
-5.61036e-016
-8.71014e-017
8.73523e-012
-2.97766e-011
-2.46329e-017
-2.70437e-012
-7.52762e-009
1.58218e-009
-1.3445e-009
-2.79088e-006
8.37922e-012
-3.01536e-011
  type: mpi
Process [0]
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Process [1]
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Process [2]
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Process [3]
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
       30100
   289.157378291039
  0.000000000000000E+000
   2.35848715447320
   2.24718715729226
   107.187298514184
 -3.520635541128995E-005
 -2.871447516020242E-007
 -2.736065697946534E-007
 -1.305057742489361E-005
   181.986776096693
  2.144163914850775E-005
  2.144163914853570E-005
 -7.142569373454557E-005
   7.33159484531732
 -2.215782314298757E-005
 -8.926593008695023E-007
   23.0516813358080
 -2.806660512375638E-006
   39.0256111898909
  2.143949512756913E-005
  6.432491744560709E-005
 -7.189125083447521E-002
 -4.751557990842203E-006
  8.727039427158606E-009
  7.453579203267734E-005
  6.432491744552325E-005
 -2.535934638693765E-004
  1.216430794201867E-009
 -1.205643801707345E-012
  4.674246165800974E-012
 -1.481066923661102E-016
   50.4084945110622
   2.35848715447885
   57.6973758037132
  2.160039825520571E-005
 -2.871447516027123E-007
 -6.137477127688787E-006
 -7.024951628340893E-006
   72.6468267712957
   2.24718715729774
 -7.146498375856377E-005
 -7.189855784207468E-002
 -2.537424151276844E-004
   57.6966324907930
 -1.530534907997273E-005
 -3.549397999033822E-003
  1.469541458726699E-003
 -2.736065697953207E-007
  8.727912131094343E-009
  4.675397458386443E-012
 -7.024861126177891E-006
 -8.845035655106354E-006
  2.298134474661520E-014
  4.326834053731664E-010
 -1.778721978920656E-010
  2.673112330921119E-005
 -1.530952128352600E-005
 -7.523796211241239E-006
 -1.525478864756869E-005
  2.298315003369370E-014
 -3.373540461642602E-014
 -4.407993119285159E-015
  1.631917070392312E-014
   2.93324923983276
 -3.549042439345927E-003
 -7.522096880604719E-006
  0.990085735305337
  4.326401404554087E-010
 -4.407827829174405E-015
 -3.571352565174789E-007
 -1.205474937505633E-007
   398.106804614521
   107.187298514360
   7.33159484531732
  1.216413880302431E-009
  1.469541458726728E-003
 -1.525061116903379E-005
  0.990085735090708
 -1.305057742491496E-005
 -1.481046330120455E-016
  1.631672315462805E-014
 -1.205474937507302E-007
 -4.847151934692717E-005
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.345656025757231E-005
 -1.913128493396564E-007
 -1.822929103646404E-007
 -8.695068040611865E-006
 -3.520635541130103E-005
 -2.871447516021146E-007
 -2.736065697947395E-007
 -1.305057742489772E-005
   363.973544798418
  4.288327829701550E-005
  4.288327829707139E-005
 -1.428513874690911E-004
   14.6631893927179
 -1.476285482147483E-005
 -5.947425240618130E-007
 -2.215782314299454E-005
 -8.926593008697834E-007
   46.1033617349190
 -1.869963552375436E-006
 -2.806660512376521E-006
   78.0512207939933
  4.287899025513826E-005
  1.286498348912142E-004
 -0.143782498756382
 -3.165769504610466E-006
  5.814470819314348E-009
 -4.751557990843700E-006
  8.727039427161354E-009
  1.490715836629822E-004
  1.286498348910465E-004
 -5.071869261787667E-004
  2.432861538974496E-009
 -8.032713455721126E-013
  3.114259785370372E-012
 -9.867745506316522E-017
 -1.205643801707725E-012
  4.674246165802446E-012
 -1.481066923661568E-016
   100.816986973798
   4.71697421312579
   115.394749262914
  4.320079651041143E-005
 -1.913128493401149E-007
 -4.089150961332895E-006
 -4.680439064245399E-006
 -2.871447516028027E-007
 -6.137477127690720E-006
 -7.024951628343103E-006
   145.293650590643
   4.49437422328183
 -1.429299675171275E-004
 -0.143797112771289
 -5.074848286949984E-004
   115.393262637104
 -3.061069815227564E-005
 -7.098795853663563E-003
  2.939082858090199E-003
 -1.822929103650850E-007
  5.815052266391630E-009
  3.115026844714904E-012
 -4.680378766341368E-006
 -5.893086898675263E-006
  1.531153371462460E-014
  2.882793249122460E-010
 -1.185089987094802E-010
 -2.736065697954068E-007
  8.727912131097091E-009
  4.675397458387915E-012
 -7.024861126180104E-006
 -8.845035655109137E-006
  2.298134474662243E-014
  4.326834053733025E-010
 -1.778721978921216E-010
  5.346224660716349E-005
 -3.061904255938158E-005
 -1.504759242395360E-005
 -3.050957728969101E-005
  1.531273650385525E-014
 -2.247652567141389E-014
 -2.936866227974265E-015
  1.087279857566365E-014
  2.298315003370093E-014
 -3.373540461643663E-014
 -4.407993119286547E-015
  1.631917070392826E-014
   5.86649836047494
  4.320079651041141E-005
 -7.098084734302212E-003
 -1.504419376268051E-005
   1.98017143037906
  2.882504992602134E-010
 -2.936756101907605E-015
 -2.379446712601044E-007
 -8.031588382342602E-008
  4.326401404555450E-010
 -4.407827829175793E-015
 -3.571352565175913E-007
 -1.205474937506013E-007
   796.213593052121
   214.374592673210
   14.6631893927179
  2.432827711176313E-009
  2.939082858090257E-003
 -3.050122233262203E-005
   1.98017142994981
 -8.695068040626092E-006
 -9.867608299945275E-017
  1.087116787328470E-014
 -8.031588382353718E-008
 -3.229459854775751E-005
 -1.305057742491907E-005
 -8.926593008697833E-007
 -1.481046330120921E-016
  1.631672315463319E-014
 -1.205474937507681E-007
 -4.847151934694243E-005
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.345656025757242E-005
 -1.913128493396574E-007
 -1.822929103646412E-007
 -8.695068040611908E-006
   363.973544798418
   14.6631893927179
 -1.476285482147490E-005
 -5.947425240618158E-007
   46.1033617349190
 -1.869963552375445E-006
   78.0512207939933
 -0.143782498756382
 -3.165769504610481E-006
  5.814470819314375E-009
 -8.032713455721165E-013
  3.114259785370387E-012
 -9.867745506316571E-017
   100.816986973798
   4.71697421312579
   115.394749262914
 -1.913128493401159E-007
 -4.089150961332914E-006
 -4.680439064245421E-006
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
 -1.822929103650859E-007
  5.815052266391657E-009
  3.115026844714919E-012
 -4.680378766341390E-006
 -5.893086898675290E-006
  1.531153371462467E-014
  2.882793249122473E-010
 -1.185089987094808E-010
  1.531273650385532E-014
 -2.247652567141400E-014
 -2.936866227974278E-015
  1.087279857566370E-014
   5.86649836047494
   1.98017143037906
  2.882504992602148E-010
 -2.936756101907619E-015
 -2.379446712601056E-007
 -8.031588382342641E-008
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
 -8.695068040626134E-006
 -5.947425240618157E-007
 -9.867608299945322E-017
  1.087116787328475E-014
 -8.031588382353757E-008
 -3.229459854775766E-005
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
 -3.520635541127886E-005
 -2.871447516019338E-007
 -2.736065697945673E-007
 -1.305057742488950E-005
   363.973544798418
   14.6631893927179
 -2.215782314298059E-005
 -8.926593008692215E-007
   46.1033617349190
 -2.806660512374755E-006
   78.0512207939933
 -0.143782498756382
 -4.751557990840708E-006
  8.727039427155858E-009
 -1.205643801706966E-012
  4.674246165799503E-012
 -1.481066923660635E-016
   100.816986973798
   4.71697421312579
   115.394749262914
 -2.871447516026220E-007
 -6.137477127686855E-006
 -7.024951628338681E-006
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
 -2.736065697952346E-007
  8.727912131091596E-009
  4.675397458384971E-012
 -7.024861126175681E-006
 -8.845035655103569E-006
  2.298134474660796E-014
  4.326834053730301E-010
 -1.778721978920096E-010
  2.298315003368646E-014
 -3.373540461641539E-014
 -4.407993119283771E-015
  1.631917070391799E-014
   5.86649836047494
   1.98017143037906
  4.326401404552726E-010
 -4.407827829173018E-015
 -3.571352565173664E-007
 -1.205474937505253E-007
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
 -1.305057742491085E-005
 -8.926593008692213E-007
 -1.481046330119989E-016
  1.631672315462292E-014
 -1.205474937506922E-007
 -4.847151934691191E-005
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.345656025757220E-005
 -1.913128493396556E-007
 -1.822929103646396E-007
 -8.695068040611825E-006
 -2.736065697950732E-007
   363.973544798418
   14.6631893927179
 -1.476285482147476E-005
 -5.947425240618102E-007
   46.1033617349190
 -1.869963552375428E-006
   78.0512207939933
 -0.143782498756382
 -3.165769504610451E-006
  5.814470819314320E-009
  8.727039427140501E-009
 -8.032713455721090E-013
  3.114259785370358E-012
 -9.867745506316478E-017
 -1.205643801706373E-012
  4.674246165803797E-012
 -1.481066923663510E-016
   100.816986973798
   4.71697421312579
   115.394749262914
 -1.913128493401141E-007
 -4.089150961332876E-006
 -4.680439064245377E-006
 -6.137477127702731E-006
 -7.024951628334095E-006
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
 -1.822929103650841E-007
  5.815052266391602E-009
  3.115026844714890E-012
 -4.680378766341346E-006
 -5.893086898675235E-006
  1.531153371462453E-014
  2.882793249122446E-010
 -1.185089987094797E-010
  4.675397458382585E-012
 -7.024861126193449E-006
 -8.845035655101441E-006
  2.298134474661249E-014
 -1.778721978917958E-010
  1.531273650385518E-014
 -2.247652567141379E-014
 -2.936866227974251E-015
  1.087279857566360E-014
  2.298315003371087E-014
 -3.373540461643414E-014
 -4.407993119284059E-015
  1.631917070396804E-014
   5.86649836047494
   1.98017143037906
  2.882504992602121E-010
 -2.936756101907591E-015
 -2.379446712601034E-007
 -8.031588382342565E-008
  4.326401404548934E-010
 -4.407827829165849E-015
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
 -8.695068040626053E-006
 -5.947425240618103E-007
 -9.867608299945229E-017
  1.087116787328465E-014
 -8.031588382353681E-008
 -3.229459854775736E-005
 -1.481046330122476E-016
   578.314744832283
   4.71697421311449
   4.49437422327634
   214.374592672859
 -3.520635541286104E-005
 -2.871447516142445E-007
 -2.736065698063315E-007
 -1.305057742536340E-005
   363.973544798418
  4.288327829707138E-005
   14.6631893927179
 -2.215782314307299E-005
 -8.926593008695024E-007
   46.1033617349190
   78.0512207939933
 -0.143782498756039
  8.727039427137755E-009
  1.490715836629600E-004
 -5.071869261787160E-004
  2.432861538977686E-009
 -1.205643801707273E-012
  4.674246165799947E-012
 -1.481066923662656E-016
   100.816986973995
   4.71697421312579
   115.394749262766
 -2.871447516149327E-007
 -6.137477127703686E-006
 -7.024951628340559E-006
   145.293650590516
   4.49437422328183
 -0.143797112771289
 -5.074848286949106E-004
   115.393262637323
 -3.061069815224670E-005
  2.939082858084962E-003
 -2.736065698069988E-007
  4.675397458386212E-012
 -7.024861126194908E-006
 -8.845035655104663E-006
  2.298134474663508E-014
  4.326834053712112E-010
 -1.778721978917398E-010
  5.346224660711309E-005
 -3.061904255948248E-005
 -1.504759242395365E-005
 -3.050957728989310E-005
  2.298315003368624E-014
 -3.373540461654037E-014
 -4.407993119272731E-015
  1.631917070398279E-014
   5.86649836047494
  4.320079651041142E-005
 -7.098084734291479E-003
 -1.504419376266629E-005
   1.98017143037906
  4.326401404541053E-010
 -4.407827829154527E-015
 -3.571352565176438E-007
 -1.205474937497292E-007
   796.213593052121
   214.374592673210
   14.6631893927179
  2.432827711178865E-009
  2.939082858090314E-003
 -3.050122233259326E-005
   1.98017142994981
 -1.305057742540611E-005
 -8.926593008695025E-007
 -1.481046330121232E-016
 -1.778721978914140E-010
  1.631672315468771E-014
 -1.205474937498960E-007
 -4.847151934743884E-005
   578.314744858091
   4.71697421331523
   4.49437422346269
   214.374592680576
 -1.822929103648627E-007
   363.973544799821
  4.288327829718315E-005
  4.288327829712726E-005
 -1.428513874695196E-004
   14.6631893927179
   46.1033617349190
   78.0512207939933
  1.286498348913818E-004
 -0.143782498756041
  5.814470819300454E-009
  1.490715836631487E-004
  1.286498348915494E-004
 -5.071869261800350E-004
  2.432861538977048E-009
 -8.032713455712116E-013
  3.114259785371272E-012
 -9.867745506329463E-017
   100.816986974043
   4.71697421332654
   115.394749262908
  4.320079651031550E-005
 -4.089150961340898E-006
 -4.680439064239396E-006
   145.293650590615
   4.49437422347366
 -0.143797112771291
 -5.074848286955533E-004
   115.393262637383
 -3.061069815227597E-005
 -7.098795853631457E-003
  2.939082858084895E-003
  3.115026844711353E-012
 -4.680378766350260E-006
 -5.893086898670134E-006
  1.531153371461797E-014
 -1.185089987092631E-010
  5.346224660716538E-005
 -3.061904255936468E-005
 -1.504759242393702E-005
 -3.050957728977592E-005
  1.531273650386187E-014
 -2.247652567141223E-014
 -2.936866227972606E-015
  1.087279857569015E-014
   5.86649836047765
  4.320079651021957E-005
 -7.098084734280805E-003
 -1.504419376268084E-005
   1.98017143036536
  2.882504992597793E-010
 -2.936756101900980E-015
   796.213593060526
   214.374592681278
   14.6631893927179
  2.432827711177589E-009
  2.939082858079544E-003
 -3.050122233262302E-005
   1.98017142993610
 -9.867608299955626E-017
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.345656025861906E-005
 -1.913128493477984E-007
 -1.822929103724211E-007
 -8.695068040924869E-006
   363.973544798418
   14.6631893927179
 -1.476285482153174E-005
 -5.947425240618131E-007
   46.1033617349190
   78.0512207939933
 -0.143782498756382
 -8.032713455720649E-013
  3.114259785369688E-012
 -9.867745506326875E-017
   100.816986973798
   4.71697421312579
   115.394749262914
 -1.913128493482569E-007
 -4.089150961342821E-006
 -4.680439064245177E-006
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
 -1.822929103728656E-007
  3.115026844714750E-012
 -4.680378766352706E-006
 -5.893086898674137E-006
  1.531153371463785E-014
  2.882793249109434E-010
 -1.185089987092632E-010
  1.531273650385028E-014
 -2.247652567149008E-014
 -2.936866227965985E-015
  1.087279857570340E-014
   5.86649836047494
   1.98017143037906
  2.882504992593449E-010
 -2.936756101894361E-015
 -2.379446712602143E-007
 -8.031588382287026E-008
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
 -8.695068040953325E-006
 -9.867608299950450E-017
 -1.185089987090461E-010
  1.087116787332445E-014
 -8.031588382298141E-008
 -3.229459854809841E-005
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.736065697945672E-007
   363.973544798418
   14.6631893927179
   46.1033617349190
   78.0512207939933
 -0.143782498756382
  8.727039427145433E-009
 -1.205643801706886E-012
  4.674246165797116E-012
   100.816986973798
   4.71697421312579
   115.394749262914
 -6.137477127689525E-006
 -7.024951628326668E-006
   145.293650590643
   4.49437422328183
 -0.143797112771289
   115.393262637104
  4.675397458384811E-012
 -7.024861126181020E-006
 -8.845035655090209E-006
  2.298134474664774E-014
  4.326834053723784E-010
 -1.778721978916838E-010
  2.298315003368895E-014
 -3.373540461642036E-014
 -4.407993119291232E-015
  1.631917070395776E-014
   5.86649836047494
   1.98017143037906
  4.326401404559243E-010
 -4.407827829192915E-015
 -3.571352565173658E-007
   796.213593052121
   214.374592673210
   14.6631893927179
   1.98017142994981
   578.314744832283
   4.71697421311449
   4.49437422327086
   214.374592672859
 -3.520635541054860E-005
 -2.871447504873535E-007
 -2.736065689142083E-007
 -1.305057742523939E-005
   363.973544798418
  4.288327829699688E-005
  4.288327829703413E-005
 -1.428513874691098E-004
   14.6631893927179
 -2.215782314296252E-005
 -8.926593008791258E-007
   46.1033617349190
   78.0512207939933
  4.287899025502649E-005
  1.286498348911024E-004
 -0.143782498756211
 -4.751557990854377E-006
  8.727039304363716E-009
  1.490715836628691E-004
  1.286498348909906E-004
 -5.071869261787106E-004
 -1.205643792452803E-012
  4.674246126760011E-012
 -1.481066993236416E-016
   100.816986973842
   4.71697421312579
   115.394749262717
 -6.137477120352171E-006
 -7.024951631126169E-006
   145.293650590423
   4.49437422328183
 -1.429299675167550E-004
 -0.143797112771289
 -5.074848286946232E-004
   115.393262637191
 -3.061069815223793E-005
 -7.098795853652868E-003
  2.939082858084933E-003
  8.727912008309880E-009
  4.675397419339358E-012
 -7.024861128977849E-006
 -8.845035677423390E-006
  2.298134456956188E-014
  4.326833992840672E-010
 -1.778722003987977E-010
  5.346224660709644E-005
 -3.061904255943199E-005
 -1.504759242393670E-005
 -3.050957728984275E-005
  2.298314985658071E-014
 -3.373540452877954E-014
 -4.407993034398111E-015
  1.631917067073562E-014
   5.86649836047493
 -7.098084734312902E-003
 -1.504419376266100E-005
   1.98017143037906
  4.326401343676129E-010
 -4.407827744327143E-015
 -3.571352565176750E-007
 -1.205474937551057E-007
   796.213593052121
   214.374592673210
   14.6631893927179
 -3.050122233258366E-005
   1.98017142994981
 -1.305057742528209E-005
 -8.926593008804605E-007
 -1.481046399696158E-016
 -1.778722003991235E-010
  1.631672312141071E-014
 -1.205474937552725E-007
 -4.847151934687336E-005
   578.314744480113
   4.71697419202774
   4.49437420616609
   214.374592552510
 -1.822929103646413E-007
 -3.486654897000965E-005
 -2.843732684917476E-007
 -2.709657603039671E-007
 -1.292461521851804E-005
   363.973544584028
  4.288327830096431E-005
  4.288327830092706E-005
 -1.428513874820179E-004
   14.6631893842555
 -2.194395915160788E-005
 -8.840434869354315E-007
   46.1033617078295
 -2.779571047736505E-006
   78.0512207483073
  4.287899025893806E-005
  1.286498349027812E-004
 -0.143782496655064
  5.814470819307429E-009
 -4.705696611749664E-006
  8.642803955623622E-009
  1.490715835137977E-004
  1.286498349028929E-004
 -5.071869255397630E-004
  2.432861651831504E-009
 -8.032713455720634E-013
  3.114259785368797E-012
 -1.193954935116820E-012
  4.628928683143745E-012
 -1.466709969133122E-016
   100.816986794100
   4.71697419202774
   115.394749241006
  4.320079576326505E-005
 -4.089150961334693E-006
 -4.680439064237418E-006
 -6.078329641437480E-006
 -6.957328915326465E-006
   145.293650872176
   4.49437420616609
 -1.429299675297935E-004
 -0.143797110670135
 -5.074848280557323E-004
   115.393262615438
 -3.061069814911658E-005
 -7.098795749463098E-003
  2.939082897549174E-003
  3.115026844714813E-012
 -4.680378766344947E-006
 -5.893086898666391E-006
  1.531153371465117E-014
  2.882793249118131E-010
 -1.185089987092637E-010
  8.643668236021943E-009
  4.630068813763787E-012
 -6.957239277629070E-006
 -8.760026825389280E-006
  2.275952751382219E-014
  4.285070467479389E-010
 -1.761554695294057E-010
  5.346224660534764E-005
 -3.061904255631746E-005
 -1.504759242535699E-005
 -3.050957728912255E-005
  1.531273650385697E-014
 -2.247652567141731E-014
 -2.936866227979249E-015
  1.087279857569020E-014
  2.276131537680262E-014
 -3.340979322801475E-014
 -4.365445551681045E-015
  1.616165963931530E-014
   5.86649835702856
  4.320079576326504E-005
 -7.098084630123536E-003
 -1.504419376410242E-005
   1.98017142928955
  2.882504992606490E-010
 -2.936756101920876E-015
 -2.379446712601052E-007
  4.284641994334349E-010
 -4.365281857014185E-015
 -3.536882408005964E-007
 -1.193839875477508E-007
   796.213592583147
   214.374592553211
   14.6631893842774
  2.432827824033979E-009
  2.939082897554546E-003
 -3.050122233189004E-005
   1.98017142886029
 -1.292461521849688E-005
 -1.466689575214149E-016
  1.615923571345655E-014
 -1.193839875479161E-007
 -4.800367954116850E-005
   573.236785850516
   4.67555804638392
   4.45491080915552
   212.492253674625
 -2.311675381601131E-005
 -1.885413707034071E-007
 -1.796521003744173E-007
 -8.569105832683311E-006
 -3.349292095255420E-005
 -2.731698758155861E-007
 -2.602905950237209E-007
 -1.241542764737865E-005
   360.777629553299
  4.287768223874186E-005
  4.287768223868598E-005
 -1.428327460610472E-004
   14.5344374185661
 -1.454899084899629E-005
 -5.861267109123344E-007
 -2.107943885768097E-005
 -8.492150619031830E-007
   45.6985454231791
 -1.842874087736116E-006
 -2.670065037570279E-006
   77.3658828833511
  4.287339475634754E-005
  1.286330467160579E-004
 -0.142523649744143
 -3.119908182378097E-006
  5.730238668248649E-009
 -4.520307374147624E-006
  8.302295506096310E-009
  1.488800159138534E-004
  1.286330467162256E-004
 -5.064534086964426E-004
  2.411397693958620E-009
 -7.916346470666782E-013
  3.069144639589147E-012
 -9.724795613864656E-017
 -1.146766292105987E-012
  4.445979426856287E-012
 -1.408747768596518E-016
   100.094575244242
   4.67555804638392
   114.707172043914
  4.320078000335900E-005
 -1.885413707034070E-007
 -4.030003137070910E-006
 -4.612815671016741E-006
 -5.860066576354462E-006
 -6.725641569909249E-006
   144.669215621096
   4.45491080915552
 -1.429113158544918E-004
 -0.142538137843543
 -5.067511079614432E-004
   114.705682189466
 -3.060738338030736E-005
 -7.036385438731686E-003
  2.913428718245663E-003
  5.730811692125800E-009
  3.069900586826985E-012
 -4.612756237617038E-006
 -5.808076721557834E-006
  1.508972111939525E-014
  2.841031258386892E-010
 -1.167922046852722E-010
 -2.602905950240384E-007
  8.303125735671243E-009
  4.447074496054045E-012
 -6.725553343336950E-006
 -8.499727737298235E-006
  2.186286226625323E-014
  4.116247788004690E-010
 -1.692157223309037E-010
  5.345738077287618E-005
 -3.061572752717744E-005
 -1.504822824520829E-005
 -3.050722349460647E-005
  1.509090648422768E-014
 -2.215091656836733E-014
 -2.894320886402879E-015
  1.071528837557085E-014
  2.186457969406128E-014
 -3.209354958294585E-014
 -4.193454414432512E-015
  1.552494043392866E-014
   5.81498725798600
  4.320078000326307E-005
 -7.035680559925152E-003
 -1.504482956005489E-005
   1.96278436519492
  2.840747177739838E-010
 -2.894212355717602E-015
 -2.344976555415765E-007
 -7.915237756870999E-008
  4.115836195796509E-010
 -4.193297169067478E-015
 -3.397540806669183E-007
 -1.146806489851974E-007
   789.222344344578
   212.492253674277
   14.5344374185661
  2.411364164596840E-009
  2.913428718245664E-003
 -3.049886889031407E-005
   1.96278436476563
 -8.569105832711352E-006
 -5.861267109132109E-007
 -9.724660395153493E-017
 -1.167922046854862E-010
  1.071368129654956E-014
 -7.915237756881953E-008
 -3.182675874180299E-005
 -1.408728180619298E-016
 -1.692157223312137E-010
  1.552261200324829E-014
 -4.611249153817101E-005
   557.235362001020
   4.54504939266005
   4.33055556547175
   206.560716167587
 -2.174312579951971E-005
 -1.773379910972862E-007
 -1.689769359944208E-007
 -8.059918257133631E-006
 -3.142132125622325E-005
 -2.562737925626133E-007
 -2.441911351082218E-007
 -1.164751027220156E-005
   350.706812792142
  4.286085886880316E-005
 -1.427767045961633E-004
   14.1287202953765
 -1.368447060198972E-005
 -5.512982878006303E-007
 -1.977563614154677E-005
 -7.966895220793213E-007
   44.4229074337771
 -1.733368077569763E-006
 -2.504916529709468E-006
   75.2062785197769
  4.285657306869472E-005
  1.285825766064095E-004
 -0.138556839931210
 -2.934519085661557E-006
  5.389738279786483E-009
 -4.240717726998273E-006
  7.788772538061874E-009
  1.482790118965059E-004
 -5.041509466809778E-004
  2.343788291346290E-009
 -7.445621410806123E-013
  2.886645843876636E-012
 -9.146548859109044E-017
 -1.075692422825496E-012
  4.170427850655089E-012
 -1.321443582063807E-016
   97.8181459799936
   4.54504939266005
   112.540512012562
  4.320072833754909E-005
 -1.773379910972861E-007
 -3.811739274192630E-006
 -4.381126679225338E-006
 -5.812694823422505E-006
 -6.939848257529945E-006
   142.701527270255
   4.33055556547703
 -1.428552435623157E-004
 -0.138570931257496
 -5.044480109535446E-004
   112.539011984218
 -3.059693803892544E-005
 -6.839721065705652E-003
  2.832588455194078E-003
  5.390277253616183E-009
  2.887356840640921E-012
 -4.381068657006511E-006
 -5.547774331749306E-006
  1.419306712276919E-014
  2.672212449656307E-010
 -1.098522981883248E-010
  7.789551415307988E-009
  4.171455049935934E-012
 -6.939733979480371E-006
 -9.234404060528168E-006
  2.051058880800890E-014
  3.861645151616364E-010
 -1.587496207749230E-010
  5.344204779212135E-005
 -3.060528136525533E-005
 -1.505023180984298E-005
 -3.049980632848518E-005
  1.419418205185865E-014
 -2.083467846839404E-014
 -2.722335149452230E-015
  1.007857126809174E-014
  2.051220001061674E-014
 -3.010849642032199E-014
 -3.934074418227148E-015
  1.456469115786936E-014
   5.65266791137200
  4.320072833764502E-005
 -6.839035851788081E-003
 -1.504683304959855E-005
   1.90799506871417
  2.671945249552784E-010
 -2.722233067834192E-015
 -2.205634954050934E-007
 -7.444903887481935E-008
  3.861259017643370E-010
 -3.933926898996727E-015
 -3.187396564265027E-007
 -1.075874368945911E-007
   767.191852521460
   206.560716167587
   14.1287202953765
  2.343755702069003E-009
  2.832588455199236E-003
 -3.049145283666357E-005
   1.90799506828217
 -8.059918257120442E-006
 -5.512982878006302E-007
 -9.146421680607339E-017
  1.007705968388188E-014
 -7.444903887492239E-008
 -2.993557073862503E-005
 -7.966895220805124E-007
 -1.321425208006627E-016
  1.456250674540884E-014
 -1.075874368947400E-007
 -4.326034784014350E-005
   539.596691719340
   4.40118726684648
   4.19347643925001
   200.022270877505
 -1.967152610346334E-005
 -1.604419139912711E-007
 -1.528774764598324E-007
 -7.292000879739466E-006
 -2.944468827499374E-005
 -2.401522650561294E-007
 -2.288297099080265E-007
 -1.091479592853509E-005
   339.605562179836
  4.284370806161757E-005
  4.284370806158032E-005
 -1.427195723829561E-004
   13.6814906845670
 -1.238066791256103E-005
 -4.987727490638209E-007
 -1.853160263156738E-005
 -7.465718694291021E-007
   43.0167477003996
 -1.568219569708895E-006
 -2.347338794964417E-006
   72.8257060411034
  4.283942397648450E-005
  1.285311241847409E-004
 -0.134184177806723
 -2.654929518753772E-006
  4.876219156824097E-009
 -3.973945100149960E-006
  7.298791948068736E-009
  1.476210689525275E-004
  1.285311241848527E-004
 -5.016282715238819E-004
  2.269305363901451E-009
 -6.735346577174080E-013
  2.611274199546776E-012
 -8.274052460936160E-017
 -1.007904511366794E-012
  3.907615883047643E-012
 -1.238174856409888E-016
   95.3087963439611
   4.40118726684648
   110.152164212528
  4.320067198847722E-005
 -3.764366744088836E-006
 -4.595331789196597E-006
 -2.401522650555538E-007
 -6.663026588044828E-006
 -8.935388570133978E-006
   140.532512104102
   4.19347643925001
 -1.427980799216150E-004
 -0.134197831771967
 -5.019246452415444E-004
   110.150652968432
 -3.058542396137143E-005
 -6.622934873901766E-003
  2.743476449058607E-003
 -1.528774764600188E-007
  4.876706778754064E-009
  2.611917370751203E-012
 -4.595247715614770E-006
 -6.282447496212577E-006
  1.284079899678699E-014
  2.417611647690060E-010
 -9.938612113479834E-011
 -2.288297099077475E-007
  7.299521827263974E-009
  3.908578350289547E-012
 -8.935159881719338E-006
 -1.351770786693766E-005
  1.922030847104638E-014
  3.618714721639332E-010
 -1.487632813965375E-010
  5.342514596825573E-005
 -3.059376638320985E-005
 -1.505244036781237E-005
 -3.049163025013619E-005
  1.284180770026809E-014
 -1.884962793385653E-014
 -2.462957712587975E-015
  9.118322986322014E-015
  1.922181831770456E-014
 -2.821444343082935E-014
 -3.686585893280699E-015
  1.364846219057790E-014
   5.47374024455735
  4.320067198847721E-005
 -6.622271336864224E-003
 -1.504904152475754E-005
   1.84759979715768
  2.417369905655119E-010
 -2.462865357062839E-015
 -1.995490711623880E-007
 -6.735582672141907E-008
  3.618352878789700E-010
 -3.686447654399971E-015
 -2.986885799027866E-007
 -1.008193933241817E-007
   742.907227287099
   200.022270877505
   13.6814906845875
  2.269273810267925E-009
  2.743476449058664E-003
 -3.048327798470777E-005
   1.84759979672824
 -7.292000879739467E-006
 -4.987727490638208E-007
 -8.273937414116043E-017
 -9.938612113498041E-011
  9.116955420173514E-015
 -2.708342704041426E-005
 -1.091479592851723E-005
 -7.465718694279858E-007
 -1.238157640168604E-016
 -1.487632813965374E-010
  1.364641519413032E-014
 -4.053895272173315E-005
   522.723980485613
   4.26357236788475
   4.06234996894840
   193.767757492847
 -1.769489312245172E-005
 -1.443203910014657E-007
 -1.375160516629884E-007
 -6.559286534408385E-006
 -2.773500259998458E-005
 -2.262079754659282E-007
 -2.155428685233438E-007
 -1.028103577695066E-005
   328.986383243958
  4.282862688210201E-005
  4.282862688217652E-005
 -1.426693344462113E-004
   13.2536820145078
 -1.113663442411282E-005
 -4.486550972829839E-007
 -1.745557775027560E-005
 -7.032226824477336E-007
   41.6716504367713
 -1.410641834963987E-006
 -2.211042174219612E-006
   70.5485098982672
  4.282434430491127E-005
  1.284858806465295E-004
 -0.130001424215399
 -2.388156956539782E-006
  4.386241319778850E-009
 -3.743200527853205E-006
  6.874984719344465E-009
  1.469960137172198E-004
  1.284858806463060E-004
 -4.992297040467714E-004
  2.198097262593681E-009
 -6.057753682384825E-013
  2.348573266237877E-012
 -7.441699463015951E-017
 -9.492879700951248E-013
  3.680361097547897E-012
 -1.166171499981291E-016
   92.9084174782699
   4.26357236787453
   107.867534985192
  4.320061865945368E-005
 -4.614696806811609E-006
 -6.590868678818449E-006
 -8.898964831325699E-006
 -1.366246832385883E-005
   138.457695718420
   4.06234996894344
 -1.427478143497042E-004
 -0.130014659822511
 -4.995254261317875E-004
   107.866013012907
 -3.057440990055210E-005
 -6.415563239636363E-003
  2.658233875692940E-003
  4.386679943906497E-009
  2.349151732730160E-012
 -6.590670195008027E-006
 -1.056574445157187E-005
  1.155052245819835E-014
  2.174682524566081E-010
 -8.939972797247181E-011
 -2.155428685230809E-007
  6.875672217815162E-009
  3.681267590660993E-012
 -1.366199063182827E-005
 -2.322462537178349E-005
  1.810428351462764E-014
  3.408592778400850E-010
 -1.401255975737136E-010
  5.340897811483113E-005
 -3.058275145715274E-005
 -1.505455301053148E-005
 -3.048380922146546E-005
  1.155142980571923E-014
 -1.695557681648410E-014
 -2.215471010866972E-015
  8.202094727285608E-015
  1.810570569374851E-014
 -2.657618570997923E-014
 -3.472521575305685E-015
  1.285597154157513E-014
   5.30258250954564
 -6.414920438125191E-003
 -1.505115408827758E-005
   1.78982718936297
  2.174465073513423E-010
 -2.215387935524770E-015
 -1.794979946375389E-007
 -6.058778310575515E-008
  3.408251946088613E-010
 -3.472391363325674E-015
 -2.813454319198783E-007
 -9.496538437425974E-008
   719.677161615744
   193.767757492530
   13.2536820144880
  2.198066699081070E-009
  2.658233875692939E-003
 -3.047545812899454E-005
   1.78982718893097
 -6.559286534408386E-006
 -4.486550972836547E-007
 -7.441595989652955E-017
 -8.939972797247182E-011
  8.200864577072990E-015
 -6.058778310583901E-008
 -2.436203192186941E-005
 -1.028103577693384E-005
 -1.166155284914077E-016
 -1.401255975739702E-010
  1.285404340286527E-014
 -3.818508617480307E-005
   507.480809558198
   4.13924811560649
   3.94388748706581
   188.117295315910
 -1.598520744764492E-005
 -1.303761051939632E-007
 -1.242292106780673E-007
 -5.925526381426114E-006
 -2.631357944261519E-005
 -2.146147712591423E-007
 -2.044962624089082E-007
 -9.754131113075971E-006
   319.392788155672
  4.281607858269229E-005
  4.281607858274817E-005
 -1.426275339576240E-004
   12.8671904430283
 -1.006060956177639E-005
 -4.053059110676836E-007
 -1.656097665124283E-005
 -6.671824096030911E-007
   40.4564605826200
 -1.274345214219084E-006
 -2.097725922095767E-006
   68.4912418338210
  4.281179726025444E-005
  1.284482357482445E-004
 -0.126222655558858
 -2.157412441190556E-006
  3.962436359231722E-009
 -3.551360774868571E-006
  6.522634194127350E-009
  1.464348220769871E-004
  1.284482357480769E-004
 -4.970745765125015E-004
  2.133797892761583E-009
 -5.471806171335267E-013
  2.121403016152055E-012
 -6.721919332723600E-017
 -9.005649721624430E-013
  3.491463330248999E-012
 -1.106320875694377E-016
   90.7398666114437
   4.13924811560649
   105.803557976582
  4.320057094635411E-005
 -1.303761051936507E-007
 -6.850632260937538E-006
 -1.131794283692613E-005
 -2.146147712596567E-007
 -1.260739259271132E-005
 -2.129168337138879E-005
   136.583274524073
   3.94388748706100
 -1.427059908675148E-004
 -0.126235513220085
 -4.973697171441409E-004
   105.802026311327
 -3.056445957537884E-005
 -6.228219748320937E-003
  2.581223687348777E-003
 -1.242292106779157E-007
  3.962832602867879E-009
  2.121925529359861E-012
 -1.131749534981046E-005
 -2.027265075968782E-005
  1.043450062191119E-014
  1.964561654686551E-010
 -8.076199997456193E-011
 -2.044962624094069E-007
  6.523286457548657E-009
  3.492323296785865E-012
 -2.129081371104701E-005
 -3.869319706225908E-005
  1.717642721819822E-014
  3.233898785021479E-010
 -1.329442662065657E-010
  5.339437173469686E-005
 -3.057280035034988E-005
 -1.505646161032820E-005
 -3.047674353829522E-005
  1.043532030157021E-014
 -1.531732063350382E-014
 -2.001408190410393E-015
  7.409604660104775E-015
  1.717777651096070E-014
 -2.521414767292956E-014
 -3.294550000909386E-015
  1.219709934524964E-014
   5.14795492337030
  4.320057094625819E-005
 -6.227595679686349E-003
 -1.505306261647085E-005
   1.73763417035051
  1.964365214059950E-010
 -2.001333141995374E-015
 -1.621548466533910E-007
 -5.473377411848640E-008
  3.233575420734400E-010
 -3.294426462458326E-015
 -2.669264351855626E-007
 -9.009839389891173E-008
   698.690619691020
   188.117295315602
   12.8671904430283
  2.133768223303658E-009
  2.581223687353416E-003
 -3.046839350544701E-005
   1.73763416991851
 -5.925526381416418E-006
 -4.053059110670776E-007
 -6.721825867584545E-017
 -8.076199997456191E-011
  7.408493367549946E-015
 -2.200816537485697E-005
 -6.671824096040885E-007
 -1.106305492818064E-016
  1.219527002419845E-014
 -9.009839389891174E-008
 -3.622809462479421E-005
   494.123472076652
   4.03030484844881
   3.84008077972004
   183.165889166908
 -1.456378429042649E-005
 -1.187829042951558E-007
 -1.131826049482859E-007
 -5.398621716291095E-006
 -2.515337412618467E-005
 -2.051520742428913E-007
 -1.954797136058126E-007
 -9.324056796903173E-006
   310.986080138009
  4.280589474007890E-005
  4.280589474000440E-005
 -1.425936098709115E-004
   12.5285142990101
 -9.166008479837793E-006
 -3.692656389118050E-007
 -1.583077822578839E-005
 -6.377653314100721E-007
   39.3916098987321
 -1.161028962095281E-006
 -2.005234029400292E-006
   66.6884920045010
  4.280161443598695E-005
  1.284176842200132E-004
 -0.122911399390467
 -1.965572739607205E-006
  3.610087797596484E-009
 -3.394775805088766E-006
  6.235036123879028E-009
  1.459456901877262E-004
  1.284176842202367E-004
 -4.951949416277289E-004
  2.077476370918727E-009
 -4.984757140772692E-013
  1.932575450185631E-012
 -6.123623068050503E-017
 -8.608025886781755E-013
  3.337305634051750E-012
 -1.057477156323251E-016
   88.8396049256758
   4.03030484845847
   103.994936051950
  4.320052948783570E-005
 -1.055905666819975E-005
 -1.894715116048681E-005
 -2.051520742424145E-007
 -1.754807733606879E-005
 -3.134657801546246E-005
   134.940764133576
   3.84008077972941
 -1.426720481199565E-004
 -0.122923925870147
 -4.954895782012453E-004
   103.993395892940
 -3.055574028219376E-005
 -6.064054151815194E-003
  2.513740776797339E-003
 -1.131826049481478E-007
  3.610448806375594E-009
  1.933051454112882E-012
 -1.894631170536965E-005
 -3.574120899671548E-005
  9.506647020826595E-015
  1.789868588603020E-010
 -7.358063044247951E-011
 -1.954797136055743E-007
  6.235659627488153E-009
  3.338127630690971E-012
 -3.134519704335050E-005
 -5.897450979705088E-005
  1.641908537408146E-014
  3.091308802709708E-010
 -1.270826570897611E-010
  5.338157241213808E-005
 -3.056408037229324E-005
 -1.505813407913032E-005
 -3.047055199955559E-005
  9.507393813975940E-015
 -1.395528392496591E-014
 -1.823437909705915E-015
  6.750732966416450E-015
  1.642037517485431E-014
 -2.410241435041434E-014
 -3.149284820100354E-015
  1.165930951518852E-014
   5.01245733810184
  4.320052948773977E-005
 -6.063446498456228E-003
 -1.505473502256900E-005
   1.69189829464496
  1.789689615903928E-010
 -1.823369534764103E-015
 -1.477358499176869E-007
 -4.986678361028624E-008
  3.090999696287466E-010
 -3.149166728801813E-015
 -2.551572469730332E-007
 -8.612582021365064E-008
   680.300461606910
   183.165889166908
   12.5285142990289
  2.077447484577741E-009
 -3.046220289536761E-005
   1.69189829421296
 -5.398621716282260E-006
 -6.123537921946655E-017
 -7.358063044261430E-011
  6.749720491434658E-015
 -2.005117382471376E-005
 -9.324056796918428E-006
 -1.057462452600261E-016
 -1.270826570899939E-010
  1.165756085188981E-014
 -3.463074341469075E-005
   482.637703409917
   3.93662621916758
   3.75081899008138
   178.908251317559
 -1.340357897419682E-005
 -1.093202101931597E-007
 -1.041660565071896E-007
 -4.968547399030346E-006
 -2.421476737820223E-005
 -1.974967472828751E-007
 -1.881853205290631E-007
 -8.976126435281720E-006
   303.757281459947
  4.279772522315862E-005
  4.279772522323313E-005
 -1.425663958408658E-004
   12.2372919017685
 -8.435810069810161E-006
 -3.398485613411929E-007
 -1.524004729204105E-005
 -6.139668987381353E-007
   38.4759612048478
 -1.068537069399785E-006
 -1.930408036628126E-006
   65.1383352081991
  4.279344573598605E-005
  1.283931756696994E-004
 -0.120064112940655
 -1.808987816181531E-006
  3.322491443303755E-009
 -3.268098476248128E-006
  6.002369299012972E-009
  1.455269920844508E-004
  1.283931756694759E-004
 -4.935850702633079E-004
  2.029062415915347E-009
 -4.587286861560861E-013
  1.778477328960975E-012
 -5.635363771208165E-017
 -8.286390777655816E-013
  3.212608567892347E-012
 -1.017967701040474E-016
   87.2056024382091
   3.93662621915843
   102.439736444119
  4.320049409262739E-005
 -1.093202101934217E-007
 -1.549973821015255E-005
 -2.900203938739696E-005
 -1.974967472828607E-007
 -2.331567762669899E-005
 -4.302233760459242E-005
   133.528407846665
   3.75081899007680
 -1.426448191199535E-004
 -0.120076354646677
 -4.938792773534822E-004
   102.438188980770
 -3.054824270479299E-005
 -5.922890974539811E-003
  2.455713142815584E-003
 -1.041660565074436E-007
  3.322823692449049E-009
  1.778915377665720E-012
 -2.900068862087290E-005
 -5.602250889185315E-005
  8.749307528295077E-015
  1.647279415334707E-010
 -6.771898802868645E-011
  6.002969535934473E-009
  3.213399850951916E-012
 -4.302036592269477E-005
 -8.246479154077336E-005
  1.580639565365942E-014
  2.975953514876635E-010
 -1.223406084504786E-010
  5.337056647610990E-005
 -3.055658220590746E-005
 -1.505957220522758E-005
 -3.046522799241957E-005
  8.749994829395280E-015
 -1.284355176148487E-014
 -1.678173857643763E-015
  6.212943574883318E-015
  1.580763732549135E-014
 -2.320302159750705E-014
 -3.031765329709943E-015
  1.122423729009047E-014
   4.89594505251747
 -5.922297436371849E-003
 -1.505617309478000E-005
   1.65257071981538
  1.647114700428902E-010
 -1.678110929778371E-015
 -1.359666617045749E-007
 -4.589420989668041E-008
  2.975655943067855E-010
 -3.031651645120872E-015
 -2.456359671459297E-007
 -8.291200588438052E-008
   664.487048059114
   178.908251317852
   12.2372919017685
  2.029034202755835E-009
  2.455713142820051E-003
 -3.045687968675835E-005
   1.65257071938338
 -4.968547399030345E-006
 -3.398485613417010E-007
 -5.635285414100591E-017
  6.212011757559409E-015
 -4.589420989668040E-008
 -1.845382261455814E-005
 -6.139668987381352E-007
 -1.017953546676934E-016
  1.122255387889002E-014
 -8.291200588426578E-008
 -3.333848539495451E-005
   472.888872939196
   3.85711416892407
   3.67505583538615
   175.294475800181
 -1.246497222632115E-005
 -1.016648857835638E-007
 -9.687166376494651E-008
 -4.620617036385969E-006
 -2.345864863641312E-005
 -1.913298024073700E-007
 -1.823091350305216E-007
 -8.695842207772688E-006
   297.621659642064
  4.279120496664985E-005
  4.279120496672436E-005
 -1.425446757738270E-004
   11.9901096833589
 -7.845079149841812E-006
 -3.160501292214860E-007
 -1.476416883537590E-005
 -5.947954608412494E-007
   37.6987817101859
 -9.937110766276354E-007
 -1.870130038811978E-006
   63.8226012564150
  4.278692613155250E-005
  1.283736149001731E-004
 -0.117647416401758
 -1.682310528708263E-006
  3.089826109386854E-009
 -3.166050303653915E-006
  5.814938679589548E-009
  1.451729467819219E-004
  1.283736148999496E-004
 -4.922231489171028E-004
  1.987980852824093E-009
 -4.265781722321298E-013
  1.653830688102203E-012
 -5.240419562565373E-017
 -8.027316768137468E-013
  3.112166274530711E-012
 -9.861431387796796E-017
   85.8187052081662
   3.85711416892379
   101.119727942248
  4.320046422960203E-005
 -1.016648857833275E-007
 -2.126733599433903E-005
 -4.067779395097674E-005
 -1.913298024073561E-007
 -2.947778891852427E-005
 -5.545994269023499E-005
   132.329646852493
   3.67505583538615
 -1.426230871051750E-004
 -0.117659416402176
 -4.925169942479289E-004
   101.118174279081
 -3.054187895626234E-005
 -5.803075440925698E-003
  2.406460666734063E-003
 -9.687166376482836E-008
  3.090135091996175E-009
  1.654238035650354E-012
 -4.067585247482739E-005
 -7.951278057947582E-005
  8.136619848406993E-015
  1.531924829466343E-010
 -6.297691049814014E-011
 -1.823091350307439E-007
  5.815520173473563E-009
  3.112932818097953E-012
 -5.545734355962956E-005
 -1.074517854571011E-004
  1.531282789388166E-014
  2.883026159007314E-010
 -1.185205272610541E-010
  5.336122491818296E-005
 -3.055021795761691E-005
 -1.506079284747548E-005
 -3.046070911070657E-005
  8.137259020341956E-015
 -1.194416001439922E-014
 -1.560655346610554E-015
  5.777871730282703E-015
  1.531403079413796E-014
 -2.247849277441292E-014
 -2.937094566788681E-015
  1.087375372913898E-014
   4.79705236601993
  4.320046422950610E-005
 -5.802493883357964E-003
 -1.505739369120166E-005
   1.61919046711385
  1.531771649103785E-010
 -1.560596825445597E-015
 -1.264453818763223E-007
 -4.268039554242989E-008
  2.882737879194158E-010
 -2.936984432116499E-015
 -2.379658559534812E-007
 -8.032303531320715E-008
   651.065021870458
   175.294475800181
   11.9901096833589
  1.987953210882533E-009
  2.406460666734064E-003
 -3.045236148265977E-005
   1.61919046667961
 -4.620617036393530E-006
 -3.160501292214861E-007
 -5.240346696993633E-017
 -6.297691049825551E-011
  5.777005165052041E-015
 -1.716156459469205E-005
 -8.695842207758458E-006
 -5.947954608403601E-007
 -9.861294269204807E-017
 -1.185205272608369E-010
  1.087212288346382E-014
 -8.032303531298483E-008
 -3.229747379982123E-005
   464.693881009595
   3.79027532339420
   3.61136835500045
   172.256689749724
 -1.170885348468595E-005
 -9.549794311544257E-008
 -9.099547857011259E-008
 -4.340332808042565E-006
 -2.285068524137260E-005
 -1.863712205310216E-007
 -1.775843404781262E-007
 -8.470477405734992E-006
   292.463977248685
  4.278601026351810E-005
 -1.425273713466394E-004
   11.7823251403194
 -7.369200705302896E-006
 -2.968786918119697E-007
 -1.438153490975490E-005
 -5.793805109966138E-007
   37.0454746591313
 -9.334330788114754E-007
 -1.821663026717604E-006
   62.7165784223655
  4.278173194765203E-005
  1.283580307905543E-004
 -0.115615916095341
 -1.580262392541541E-006
  2.902396772408631E-009
 -3.083997643528247E-006
  5.664233641591620E-009
  1.448762539008770E-004
 -4.910814055460251E-004
  1.953454567316949E-009
 -4.006816750168926E-013
  1.553430699440027E-012
 -4.922299883151060E-017
 -7.819023784351341E-013
  3.031411649430136E-012
 -9.605564539199402E-017
   84.6528639144330
   3.79027532339392
   100.010116480861
  4.320043925022237E-005
 -9.549794311543564E-008
 -2.742944572589129E-005
 -5.311539590482501E-005
 -1.863712205319150E-007
 -3.565854980157561E-005
 -6.791275318198185E-005
   131.321962245372
   3.61136835500485
 -1.426057731588401E-004
 -0.115627712917652
 -4.913749486983265E-004
   100.008557605831
 -3.053652951191726E-005
 -5.702357112453811E-003
  2.365058343641200E-003
  2.902687012081810E-009
  1.553813317916789E-012
 -5.311282698014829E-005
 -1.044997682275948E-004
  7.643053841445383E-015
  1.438998076615579E-010
 -5.915680449044789E-011
 -1.775843404785593E-007
  5.664800064957864E-009
  3.032158302678193E-012
 -6.790952693945255E-005
 -1.324472870664380E-004
  1.491597084291542E-014
  2.808307201187177E-010
 -1.154489586201529E-010
  5.335337228695571E-005
 -3.054486809295097E-005
 -1.506181893290360E-005
 -3.045691048147392E-005
  7.643654241743639E-015
 -1.121963205526296E-014
 -1.465985424971685E-015
  5.427388496216679E-015
  1.491714256838460E-014
 -2.189592955925978E-014
 -2.860973822222798E-015
  1.059194460369983E-014
   4.71392190537953
  4.320043925022236E-005
 -5.701785625912606E-003
 -1.505841973820000E-005
   1.59113059852330
  1.438854188191802E-010
 -1.465930453714844E-015
 -1.187752706833705E-007
 -4.009142494986485E-008
  2.808026392688783E-010
 -2.860866542009515E-015
 -2.317986409597516E-007
 -7.824135256660783E-008
   639.782294509423
   172.256689749442
   11.7823251403018
  1.953427405444676E-009
  2.365058343636861E-003
 -3.044856342318655E-005
   1.59113059808689
 -4.922231440879337E-017
 -5.915680449044791E-011
  5.426574496445686E-015
 -4.009142494980936E-008
 -1.612055299949967E-005
 -8.470477405762714E-006
 -5.793805109957476E-007
 -9.605430978330164E-017
  1.059035602380571E-014
 -7.824135256649955E-008
 -3.146043999974818E-005
   457.856936836778
   3.73451279934156
   3.55823495885675
   169.722315851128
 -1.110089008968243E-005
 -9.053936312887398E-008
 -8.627068428730841E-008
 -4.114968005269801E-006
 -2.236217953142352E-005
 -1.823869419501355E-007
 -1.737879126816982E-007
 -8.289394147281641E-006
   288.161009424264
  4.278187191647566E-005
 -1.425135858193165E-004
   11.6089739847437
 -6.986566790237860E-006
 -2.814637423910151E-007
 -1.407408406797488E-005
 -5.669944182119043E-007
   36.5004315553476
 -8.849660667171142E-007
 -1.782719214737096E-006
   61.7938421424438
  4.277759401447099E-005
  1.283456157494270E-004
 -0.113921073488889
 -1.498209764083056E-006
  2.751692825995482E-009
 -3.018067369211945E-006
  5.543140421411732E-009
  1.446293568164033E-004
 -4.901309851847045E-004
  1.924654811956465E-009
 -3.798614427424410E-013
  1.472711249903622E-012
 -4.666537602381475E-017
 -7.651669216566170E-013
  2.966528738367267E-012
 -9.399986097607462E-017
   83.6802238907506
   3.73451279935946
   99.0843898581283
  4.320041849511186E-005
 -9.053936312886741E-008
 -3.361020599707520E-005
 -6.556820516295102E-005
 -4.157444984756805E-005
 -7.981799979327088E-005
   130.481275094809
   3.55823495886543
 -1.425919800482366E-004
 -0.113932700803911
 -4.904242775436500E-004
   99.0828266346855
 -3.053206656334373E-005
 -5.618329603075525E-003
  2.330517039043538E-003
 -8.627068428741362E-008
  2.751967995285679E-009
  1.473073986735602E-012
 -6.556500912659949E-005
 -1.294952673655358E-004
  7.246198280507383E-015
  1.364279631484903E-010
 -5.608521474906845E-011
  5.543694735460854E-009
  2.967259410590072E-012
 -7.981417470039366E-005
 -1.563300004253111E-004
  1.459709161749033E-014
  2.748269665410614E-010
 -1.129809163255220E-010
  5.334682097016735E-005
 -3.054040479373947E-005
 -1.506267497739121E-005
 -3.045374134942629E-005
  7.246767506115433E-015
 -1.063706957455127E-014
 -1.389865395669692E-015
  5.145579648696373E-015
  1.459823829397963E-014
 -2.142783322304175E-014
 -2.799809943101551E-015
  1.036550768219463E-014
   4.64456755781483
  4.320041849520778E-005
 -5.617766518640608E-003
 -1.505927575061468E-005
   1.56772072124482
  1.364143214312263E-010
 -1.389813278733635E-015
 -1.126080556889533E-007
 -3.800974218512911E-008
  2.747994860186012E-010
 -2.799704956315467E-015
 -2.268432114671239E-007
 -7.656869609354258E-008
   630.369304506717
   169.722315851684
   11.6089739847264
  1.924628050534102E-009
 -3.044539476657120E-005
   1.56772072081065
 -4.114968005263068E-006
 -2.814637423905944E-007
 -4.666472716358307E-017
 -5.608521474896570E-011
  5.144807914617666E-015
 -3.800974218502392E-008
 -1.528351919938359E-005
 -8.289394147268078E-006
 -5.669944182119041E-007
 -9.399855395192383E-017
  1.036395306327346E-014
 -7.656869609343663E-008
 -3.078787353606376E-005
   452.187674056961
   3.68827395609145
   3.51417621270744
   167.620787559024
 -1.061238437990190E-005
 -8.655508614882397E-008
 -8.247425672789331E-008
 -3.933884746186034E-006
 -2.196968760225051E-005
 -1.791857569026542E-007
 -1.707376570794504E-007
 -8.143902055742190E-006
   284.592945286095
  4.277857254335617E-005
 -1.425025950544521E-004
   11.4652294654552
 -6.679115957492790E-006
 -2.690776499685709E-007
 -1.382706141978584E-005
 -5.570427608249762E-007
   36.0484763393176
 -8.460222547366138E-007
 -1.751429648240367E-006
   61.0286999516254
  4.277429497130070E-005
  1.283357176300685E-004
 -0.112515695692110
 -1.432279516965045E-006
  2.630600526294370E-009
 -2.965095417609066E-006
  5.445847601100625E-009
  1.444250519251203E-004
 -4.893443164706605E-004
  1.900777046818836E-009
 -3.631334684217427E-013
  0.000000000000000E+000
  1.407857370474751E-012
 -4.461045347181723E-017
 -7.517214757834269E-013
  2.914401110886344E-012
 -9.234821981452248E-017
   82.8737023594073
   3.68827395609145
   98.3167707369268
  4.320040134211208E-005
 -8.655508614923886E-008
 -3.952610622979888E-005
 -7.747345213954138E-005
 -4.703851801375168E-005
 -9.080521812602951E-005
   129.784174263810
   3.51417621270744
 -1.425809832376690E-004
 -0.112527182451312
 -4.896374017554470E-004
   98.3152039077066
 -3.052836584345376E-005
 -5.548653217527482E-003
  2.301875013870460E-003
 -8.247425672809446E-008
  2.630863586347968E-009
  1.408204133435388E-012
 -7.746965725271312E-005
 -1.533779814513316E-004
  6.927320310632367E-015
  1.304242527566959E-010
 -5.361715468025307E-011
 -1.707376570796586E-007
  5.446392185858594E-009
  2.915118943784893E-012
 -9.080084079332537E-005
 -1.783624626578317E-004
  1.434088682848105E-014
  2.700032273503620E-010
 -1.109979569781182E-010
  5.334138855327791E-005
 -3.053670378324961E-005
 -1.506338481712195E-005
 -3.045111347376718E-005
  6.927864486920098E-015
 -1.016897385717798E-014
 -1.328702119063527E-015
  4.919142961261070E-015
  1.434201337905224E-014
 -2.105173930953690E-014
 -2.750667591529566E-015
  1.018357601044244E-014
   4.58705823622703
 -5.548097100170235E-003
 -1.505998556368894E-005
   1.54830901586015
  1.304112113634483E-010
 -1.328652295662273E-015
 -1.076526261956419E-007
 -3.633708569653336E-008
  2.699762291634563E-010
 -2.750564447523719E-015
 -2.228617511851999E-007
 -7.522479334503947E-008
   622.563958653790
   167.620787558750
   11.4652294654552
  1.900750617402029E-009
 -3.044276728494199E-005
   1.54830901542600
 -3.933884746198907E-006
 -2.690776499681686E-007
 -4.460983318438711E-017
 -5.361715468025308E-011
  4.918405188180024E-015
 -3.633708569648307E-008
 -1.461095273561755E-005
 -8.143902055755514E-006
 -5.570427608258092E-007
 -9.234693575572148E-017
  1.018204867764435E-014
 -7.522479334503948E-008
 -3.024749723440055E-005
   447.510135391996
   3.65012367468435
   3.47782466256937
   165.886879601416
 -1.021989245077285E-005
 -8.335390244660461E-008
 -7.942400133025836E-008
 -3.788392654134612E-006
 -2.165426891283150E-005
 -1.766131853122837E-007
 -1.682863770463405E-007
 -8.026980097818116E-006
   281.649042592051
  4.277593901587760E-005
  4.277593901595212E-005
 -1.424938223331893E-004
   11.3466301742757
 -6.432093317009632E-006
 -2.591259928922192E-007
 -1.362854635692849E-005
 -5.490453002446791E-007
   35.6755816472936
 -8.147326882398728E-007
 -1.726284381999297E-006
   60.3974040812521
  4.277166170712584E-005
  1.283278170478563E-004
 -0.111356162460254
 -1.379307588475011E-006
  2.533308475891363E-009
 -2.922525513708920E-006
  5.367660089926239E-009
  1.442567707205671E-004
  1.283278170476328E-004
 -4.886962176592666E-004
  1.881078386040355E-009
 -3.496941626477391E-013
  1.355753566669911E-012
 -4.295951869150960E-017
 -7.409167661561686E-013
  2.872511546364561E-012
 -9.102096601691952E-017
   82.2082666172848
   3.65012367468434
   97.6834331889763
  4.320038722805753E-005
 -4.499017516881933E-005
 -8.846067201134001E-005
 -1.766131853129122E-007
 -5.194766046838670E-005
 -1.006710349689302E-004
   129.209021214641
   3.47782466257362
 -1.425722056904195E-004
 -0.111367533251469
 -4.889891326877488E-004
   97.6818633846870
 -3.052531249186766E-005
 -5.491165368773658E-003
  2.278243318719138E-003
 -7.942400133025833E-008
  2.533561806742143E-009
  1.356087496174562E-012
 -8.845632488424842E-005
 -1.754104467587240E-004
  6.671116570511341E-015
  1.256005496546069E-010
 -5.163418047932553E-011
 -1.682863770467510E-007
  5.368196855923373E-009
  2.873219061642526E-012
 -1.006661620339487E-004
 -1.981407274894897E-004
  1.413499273840045E-014
  2.661267217955105E-010
 -1.094043889674762E-010
  5.333690642976127E-005
 -3.053365019184154E-005
 -1.506397048389406E-005
 -3.044894529250718E-005
  6.671640620968049E-015
 -9.792880460728668E-015
 -1.279560270987629E-015
  4.737211485169815E-015
  1.413610311521793E-014
 -2.074949858696516E-014
 -2.711175285866556E-015
  1.003737008035456E-014
   4.53960902001947
  4.320038722815345E-005
 -5.490614999742333E-003
 -1.506057120851802E-005
   1.53229299999960
  1.255879905932847E-010
 -1.279512290259229E-015
 -1.036711659131532E-007
 -3.499318293515653E-008
  2.661001112290489E-010
 -2.711073622700178E-015
 -2.196621261976654E-007
 -7.414479140827847E-008
   616.124001916561
   165.886879601687
   11.3466301742927
  1.881052230525264E-009
  2.278243318719197E-003
 -3.044059942893811E-005
   1.53229299956760
 -3.788392654128413E-006
 -4.295892135947258E-017
  4.736500998155165E-015
 -3.499318293510810E-008
 -1.407057643394822E-005
 -8.026980097831250E-006
 -5.490453002454999E-007
 -9.101970041307808E-017
 -1.094043889674763E-010
  1.003586467550823E-014
 -7.414479140838108E-008
 -2.981323407590485E-005
   443.666775594105
   3.61877700614280
   3.44795594373770
   164.462191829850
 -9.904473761425769E-006
 -8.078133197860108E-008
 -7.697272147181097E-008
 -3.671470695762520E-006
 -2.140070154580523E-005
 -1.745450764033989E-007
 -1.663157752799306E-007
 -7.932985689706988E-006
   279.230147085017
  4.277383428287394E-005
  4.277383428291119E-005
 -1.424868111145058E-004
   11.2491815415255
 -6.233578260614989E-006
 -2.511285325703940E-007
 -1.346895866120113E-005
 -5.426160838050282E-007
   35.3691879281293
 -7.895874219987956E-007
 -1.706069920498922E-006
   59.8786917110657
  4.276955718458261E-005
  1.283215028487336E-004
 -0.110403418296697
 -1.336737704036558E-006
  2.455121604382728E-009
 -2.888303259606923E-006
  5.304804594805312E-009
  1.441186899552918E-004
  1.283215028486218E-004
 -4.881643371389970E-004
  1.864894154185544E-009
 -3.388944698528405E-013
  1.313883467787089E-012
 -4.163284142345393E-017
 -7.322310837001110E-013
  2.838837392698416E-012
 -8.995401340280483E-017
   81.6615034818710
   3.61877700615568
   97.1630446485407
  4.320037565664122E-005
 -8.078133197860109E-008
 -4.989931876990252E-005
 -9.832649114074252E-005
 -1.745450764034116E-007
 -5.626355196749959E-005
 -1.093410661722017E-004
   128.736442122647
   3.44795594374611
 -1.425651906152753E-004
 -0.110414693801726
 -4.884571126701513E-004
   97.1614723993839
 -3.052280366716041E-005
 -5.443929770127349E-003
  2.258826019480924E-003
 -7.697272147190484E-008
  2.455367116542201E-009
  1.314207084455540E-012
 -9.832164841179849E-005
 -1.951887161606262E-004
  6.465223351365131E-015
  1.217240740609345E-010
 -5.004060013802933E-011
 -1.663157752801335E-007
  5.305335075267050E-009
  2.839536613839363E-012
 -1.093357578794385E-004
 -2.155182770118111E-004
  1.396947300600221E-014
  2.630103714964189E-010
 -1.081233078774354E-010
  5.333322363573870E-005
 -3.053114117000387E-005
 -1.506445170412150E-005
 -3.044716377877505E-005
  6.465731227980186E-015
 -9.490640167424360E-015
 -1.240068383308191E-015
  4.591005717467733E-015
  1.397057038056839E-014
 -2.050652509100838E-014
 -2.679427143493064E-015
  9.919834078137517E-015
   4.50062176132410
  4.320037565654531E-005
 -5.443384124293607E-003
 -1.506105241067033E-005
   1.51913323459308
  1.217119026164127E-010
 -1.240021883461764E-015
 -1.004715409250106E-007
 -3.391318098753017E-008
  2.629840725405677E-010
 -2.679326670835904E-015
 -2.170899245149918E-007
 -7.327657003535931E-008
   610.832528645480
   164.462191830119
   11.2491815415423
  1.864868223707010E-009
  2.258826019480905E-003
 -3.043881818231811E-005
   1.51913323416318
 -3.671470695768528E-006
 -2.511285325707695E-007
 -4.163226253826753E-017
 -5.004060013802935E-011
  4.590317158399552E-015
 -1.363631327539815E-005
 -7.932985689719970E-006
 -5.426160838066508E-007
 -8.995276263433809E-017
  9.918346301373946E-015
 -2.946412678015120E-005
   440.519636170443
   3.59310875246699
   3.42349791014528
   163.295584671313
 -9.650906394460541E-006
 -7.871322399928052E-008
 -7.500211985336229E-008
 -3.577476287289291E-006
 -2.119677974267003E-005
 -1.728818793547234E-007
 -1.647309945900269E-007
 -7.857394301881798E-006
   277.249431822299
  4.277215006228163E-005
  4.277215006222576E-005
 -1.424812006933117E-004
   11.1693856207631
 -6.073990570300188E-006
 -2.446993163477350E-007
 -1.334061639431453E-005
 -5.374456337391004E-007
   35.1182970921375
 -7.693729604984341E-007
 -1.689813217254249E-006
   59.4539435128307
  4.276787313250394E-005
  1.283164501866773E-004
 -0.109623263502374
 -1.302515466200490E-006
  2.392266637755820E-009
 -2.860781327675288E-006
  5.254255487148679E-009
  1.440057481312579E-004
  1.283164501868449E-004
 -4.877292293584942E-004
  1.851642614029554E-009
 -3.302128732696427E-013
  1.280225167728672E-012
 -4.056635790840008E-017
 -7.252461526003717E-013
  2.811757005775898E-012
 -8.909598126478346E-017
   81.2137863741361
   3.59310875246725
   96.7369248979542
  4.320036619831868E-005
 -7.871322399956063E-008
 -5.421521160678160E-005
 -1.069965250148672E-004
 -1.728818793547109E-007
 -5.999325751391114E-005
 -1.168312627944689E-004
   128.349472177386
   3.42349791014945
 -1.425595771083465E-004
 -0.109634460982953
 -4.880218909235392E-004
   96.7353506469428
 -3.052074931389529E-005
 -5.405250869063909E-003
  2.242926133811596E-003
 -7.500211985354522E-008
  2.392505864414310E-009
  1.280540494177594E-012
 -1.069912469278409E-004
 -2.125662710223152E-004
  6.299704337921451E-015
  1.186077484976275E-010
 -4.875950886721495E-011
  5.254780912691263E-009
  2.812449556865815E-012
 -1.168255785005302E-004
 -2.305288178276323E-004
  1.383636013738787E-014
  2.605041669825349E-010
 -1.070930475295342E-010
  5.333020797609215E-005
 -3.052908665539111E-005
 -1.506484575156780E-005
 -3.044570498430089E-005
  6.300199212293391E-015
 -9.247667025882853E-015
 -1.208320586033193E-015
  4.473469849386574E-015
  1.383744705547416E-014
 -2.031112300645993E-014
 -2.653894926042466E-015
  9.825310270657643E-015
   4.46869700138961
  4.320036619822275E-005
 -5.404709090819155E-003
 -1.506144644329229E-005
   1.50835734611809
  1.185958886612572E-010
 -1.208275276643788E-015
 -9.789933924232610E-008
 -3.304495960582077E-008
  2.604781186274062E-010
 -2.653795410797950E-015
 -2.150213302348083E-007
 -7.257833638673053E-008
   606.499599901935
   163.295584671580
   11.1693856207965
  1.851616867805393E-009
  2.242926133811616E-003
 -3.043735960667308E-005
   1.50835734568609
 -3.577476287295145E-006
 -2.446993163481009E-007
 -4.056579385221995E-017
  4.472798918342162E-015
 -3.304495960586651E-008
 -1.328720597961191E-005
 -5.374456337382968E-007
 -8.909474242694049E-017
 -1.070930475297304E-010
  9.823836670513794E-015
 -7.257833638663007E-008
 -2.918337066368183E-005
   437.949897794531
   3.57214981594411
   3.40352715597823
   162.343013215102
 -9.446984591386500E-006
 -7.705002771782946E-008
 -7.341733928727085E-008
 -3.501884899144399E-006
 -2.103272310875387E-005
 -1.715438247451492E-007
 -1.634560265272820E-007
 -7.796580458275913E-006
   275.632115479322
  4.277080078025992E-005
 -1.424767060089472E-004
   11.1042297404043
 -5.945648307932664E-006
 -2.395288664613593E-007
 -1.323736406927219E-005
 -5.332859675277749E-007
   34.9134368293553
 -7.531162572537467E-007
 -1.676734576461128E-006
   59.1071232427771
  4.276652398535648E-005
  1.283124023407798E-004
 -0.108986243105615
 -1.274993547774900E-006
  2.341717964720884E-009
 -2.838639725004530E-006
  5.213588351892312E-009
  1.439136106569968E-004
 -4.873742296866825E-004
  1.840822927572956E-009
 -3.232312618464168E-013
  1.253157661624905E-012
 -3.970870659220238E-017
 -7.196268487599244E-013
  2.789971118525012E-012
 -8.840570309620066E-017
   80.8482116053791
   3.57214981594385
   96.3889853901355
  4.320035848637524E-005
 -7.705002771783506E-008
 -5.794491854563154E-005
 -1.144867244181734E-004
 -1.715438247451617E-007
 -6.317260862305885E-005
 -1.232147500818086E-004
   128.033500398286
   3.40352715597823
 -1.425550799511882E-004
 -0.108997376876563
 -4.876667983688242E-004
   96.3874095044883
 -3.051907187019861E-005
 -5.373668343258995E-003
  2.229943371022152E-003
 -7.341733928736039E-008
  2.341952136518352E-009
  1.253466321195263E-012
 -1.144810703296626E-004
 -2.275768173982416E-004
  6.166592060313085E-015
  1.161015643147702E-010
 -4.772924015138579E-011
  5.214109710738572E-009
  2.790658303629126E-012
 -1.232087454145159E-004
 -2.433200463516528E-004
  1.372926983397702E-014
  2.584879067168843E-010
 -1.062641951866594E-010
  5.332774559526459E-005
 -3.052740908003987E-005
 -1.506516750346181E-005
 -3.044451383294561E-005
  6.167076478106378E-015
 -9.052265232660515E-015
 -1.182788652238517E-015
  4.378946152054744E-015
  1.373034833965058E-014
 -2.015392055400889E-014
 -2.633354067126942E-015
  9.749265153371935E-015
   4.44262943027817
 -5.373129723019007E-003
 -1.506176818312350E-005
   1.49955849407509
  1.160899550770934E-010
 -1.182744300251176E-015
 -9.583074496174046E-008
 -3.234672594970982E-008
  2.584620599708344E-010
 -2.633255322131362E-015
 -2.133571304810875E-007
 -7.201660213190042E-008
   602.961627231680
   162.343013215102
   11.1042297403877
  1.840797331793298E-009
  2.229943371026206E-003
 -3.043616863381924E-005
   1.49955849364102
 -3.501884899150129E-006
 -2.395288664620755E-007
 -3.970815446121699E-017
  4.378289397689436E-015
 -1.300644986310301E-005
 -7.796580458275912E-006
 -5.332859675277750E-007
 -8.840447385630920E-017
 -1.062641951868541E-010
  9.747802958516685E-015
 -7.201660213190043E-008
 -2.895750024317093E-005
   435.856533989540
   3.55507621852601
   3.38725855273509
   161.567028146726
 -9.282927957502518E-006
 -7.571197373801585E-008
 -7.214237132768992E-008
 -3.441071055299448E-006
 -2.090069391933208E-005
 -1.704669876740429E-007
 -1.624299601243751E-007
 -7.747638807545348E-006
   274.314615019204
  4.276971871454773E-005
  4.276971871460360E-005
 -1.424731014667287E-004
   11.0511523676404
 -5.842395986584868E-006
 -2.353692003993957E-007
 -1.315426885719857E-005
 -5.299383591730159E-007
   34.7465532807177
 -7.400376164606419E-007
 -1.666209172511005E-006
   58.8245960380765
  4.276544202777090E-005
  1.283091561438108E-004
 -0.108467313033493
 -1.252851956258190E-006
  2.301051185587760E-009
 -2.820820647537982E-006
  5.180860334082501E-009
  1.438386082125998E-004
  1.283091561436432E-004
 -4.870852234329364E-004
  1.832009380658619E-009
 -3.176146503278751E-013
  1.231382221049244E-012
 -3.901873706405734E-017
 -7.151046375965771E-013
  2.772438629648986E-012
 -8.785019215694010E-017
   80.5504068164047
   3.55507621852627
   96.1055468931487
  4.320035221155433E-005
 -7.571197373801036E-008
 -6.112427100829704E-005
 -1.208702144091390E-004
 -1.704669876736344E-007
 -6.585334898024460E-005
 -1.285961894843817E-004
   127.776103960948
   3.38725855273509
 -1.425514734259030E-004
 -0.108478394905840
 -4.873777165654366E-004
   96.1039696758911
 -3.051770538904784E-005
 -5.347940552041451E-003
  2.219367331127845E-003
  2.301281290703634E-009
  1.231685517208031E-012
 -1.208642399472556E-004
 -2.403680513278657E-004
  6.059502240846147E-015
  1.140853206989764E-010
 -4.690038095573633E-011
 -1.624299601237808E-007
  5.181378420116782E-009
  2.773121496399584E-012
 -1.285899147807225E-004
 -2.541024442046058E-004
  1.364308590522483E-014
  2.568652647199739E-010
 -1.055971528948741E-010
  5.332573968746229E-005
 -3.052604249146993E-005
 -1.506542960929769E-005
 -3.044354349551140E-005
  6.059978246277782E-015
 -8.895063018718209E-015
 -1.162248025611198E-015
  4.302901125071349E-015
  1.364415764085441E-014
 -2.002740746197280E-014
 -2.616823235393775E-015
  9.688065707643591E-015
   4.42139422969764
 -5.347404504356430E-003
 -1.506203027916912E-005
   1.49239076113331
  1.140739130697513E-010
 -1.162204443856954E-015
 -9.416654520771351E-008
 -3.178499168895625E-008
  2.568395802253840E-010
 -2.616725110239105E-015
 -2.120178189320390E-007
 -7.156453069430163E-008
   600.079519075438
   161.567028146726
   11.0511523676404
  1.831983907426312E-009
  2.219367331131880E-003
 -3.043519844199390E-005
   1.49239076070131
 -3.441071055299447E-006
 -2.353692003990437E-007
 -3.901819452681409E-017
 -4.690038095582225E-011
  4.302255775912677E-015
 -3.178499168891226E-008
 -1.278057944257934E-005
 -7.747638807558028E-006
 -5.299383591746007E-007
 -8.784897064113218E-017
 -1.055971528950676E-010
  9.686612691516271E-015
 -7.156453069449969E-008
 -2.877572467076581E-005
   434.154519485745
   3.54119448901639
   3.37403132549889
   160.936111610325
 -9.150898768111447E-006
 -7.463513718222089E-008
 -7.111630500980420E-008
 -3.392129404367263E-006
 -2.079440824347460E-005
 -1.696001160660285E-007
 -1.616039597386632E-007
 -7.708239971238291E-006
   273.243418084039
  4.276885016762128E-005
  4.276885016756540E-005
 -1.424702081914188E-004
   11.0079976813644
 -5.759300777564532E-006
 -2.320215921670148E-007
 -1.308737584044767E-005
 -5.272434792147244E-007
   34.6108682079401
 -7.295122125105121E-007
 -1.657736048669890E-006
   58.5948866111737
  4.276457356764378E-005
  1.283065505026962E-004
 -0.108045395920169
 -1.235032887959470E-006
  2.268323458645017E-009
 -2.806475996109689E-006
  5.154513741567428E-009
  1.437776632331932E-004
  1.283065505028638E-004
 -4.868503671062711E-004
  1.824843766886650E-009
 -3.130946197392922E-013
  1.213858193233719E-012
 -3.846347595477757E-017
 -7.114642358675866E-013
  2.758324891849386E-012
 -8.740300305271352E-017
   80.3082760691913
   3.54119448900790
   95.8750968509041
  4.320034711467118E-005
 -7.463513718222629E-008
 -6.380501262143098E-005
 -1.262516563208329E-004
 -1.696001160660286E-007
 -6.809395932911142E-005
 -1.330934855125717E-004
   127.566827792586
   3.37403132548655
 -1.425485785588126E-004
 -0.108056435595818
 -4.871427988864262E-004
   95.8735185510710
 -3.051659436844445E-005
 -5.327022515331151E-003
  2.210768453781833E-003
  2.268550290995698E-009
  1.214157173127581E-012
 -1.262454118225448E-004
 -2.511504541976938E-004
  5.973318707291893E-015
  1.124626922969741E-010
 -4.623333306866172E-011
  5.155029192938815E-009
  2.759004282313663E-012
 -1.330869851680694E-004
 -2.631127494165569E-004
  1.357370642338088E-014
  2.555590112354043E-010
 -1.050601728050689E-010
  5.332410877940000E-005
 -3.052493138360041E-005
 -1.506564271504982E-005
 -3.044275456023786E-005
  5.973787942596737E-015
 -8.768550121478907E-015
 -1.145717383539545E-015
  4.241701753057919E-015
  1.357477270901569E-014
 -1.992556233687219E-014
 -2.603515644428682E-015
  9.638799144670352E-015
   4.40412889851707
  4.320034711457526E-005
 -5.326488559286325E-003
 -1.506224337691887E-005
   1.48656301853014
  1.124514469173167E-010
 -1.145674421653262E-015
 -9.282723365832645E-008
 -3.133292024645614E-008
  2.555334573564888E-010
 -2.603418018274277E-015
 -2.109396510370615E-007
 -7.120060572831805E-008
   597.736214069190
   160.936111610589
   11.0079976813974
  1.824818393288101E-009
  2.210768453785966E-003
 -3.043440962523989E-005
   1.48656301810225
 -3.846294113816109E-017
 -4.623333306874642E-011
  4.241065582599608E-015
 -1.259880387017179E-005
 -7.708239971225679E-006
 -5.272434792147245E-007
 -8.740178775470035E-017
 -1.050601728048765E-010
  9.637353517499141E-015
 -7.120060572821953E-008
 -2.862939233586876E-005
   432.772880215518
   3.52992575868915
   3.36329389840954
   160.423954363694
 -9.044613092265273E-006
 -7.376826599472746E-008
 -7.029030469453415E-008
 -3.352730567861765E-006
 -2.070882471717270E-005
 -1.689020922885662E-007
 -1.609388463519474E-007
 -7.676515175605659E-006
   272.373855722071
  4.276815247334811E-005
  4.276815247332948E-005
 -1.424678840548454E-004
   10.9729661295846
 -5.692407763311126E-006
 -2.293267123076940E-007
 -1.303351213574679E-005
 -5.250735035527098E-007
   34.5007235384659
 -7.210390886690292E-007
 -1.650913305990361E-006
   58.4084160703709
  4.276387594318261E-005
  1.283044574199885E-004
 -0.107702897670485
 -1.220688244042261E-006
  2.241977103138109E-009
 -2.794925372309308E-006
  5.133298896287621E-009
  1.437282136687462E-004
  1.283044574200443E-004
 -4.866597977394499E-004
  1.819027128699327E-009
 -3.094559822993813E-013
  1.199751301272898E-012
 -3.801648888823460E-017
 -7.085329398827906E-013
  2.746960337636150E-012
 -8.704292083574471E-017
   80.1117224146802
   3.52992575868915
   95.6880253129520
  4.320034298018626E-005
 -7.376826599455065E-008
 -6.604562409917454E-005
 -1.307489546044904E-004
 -1.689020922881614E-007
 -6.995357610178657E-005
 -1.368256688044519E-004
   127.396944718301
   3.36329389840954
 -1.425462531439420E-004
 -0.107713903092398
 -4.869521797662555E-004
   95.6864461340802
 -3.051569247858293E-005
 -5.310041946693324E-003
  2.203788166936222E-003
 -7.029030469427699E-008
  2.242201300848801E-009
  1.200046806559783E-012
 -1.307424844653232E-004
 -2.601607639194506E-004
  5.903939547344930E-015
  1.111564498863636E-010
 -4.569634842102112E-011
 -1.609388463517511E-007
  5.133812226173356E-009
  2.747636928946702E-012
 -1.368189812265006E-004
 -2.705897685732509E-004
  1.351784056505548E-014
  2.545071877242118E-010
 -1.046277847906294E-010
  5.332278486191991E-005
 -3.052402942283579E-005
 -1.506581570714203E-005
 -3.044211412883760E-005
  5.904403332621349E-015
 -8.666705155044877E-015
 -1.132409947073320E-015
  4.192435250057940E-015
  1.351890246218829E-014
 -1.984355443906377E-014
 -2.592800085069492E-015
  9.599128642325146E-015
   4.39011347177679
  4.320034298028218E-005
 -5.309509688584754E-003
 -1.506241636255315E-005
   1.48183224918742
  1.111453351206562E-010
 -1.132367484174144E-015
 -9.174906576343611E-008
 -3.096899527631498E-008
  2.544817390192884E-010
 -2.592702860750060E-015
 -2.100714869162149E-007
 -7.090756546997859E-008
   595.833996308847
   160.423954363432
   10.9729661295846
  1.819001835975070E-009
  2.203788166932217E-003
 -3.043376928974679E-005
   1.48183224875337
 -3.352730567867251E-006
 -2.293267123083797E-007
 -3.801596028674838E-017
 -4.569634842110484E-011
  4.191806468605077E-015
 -3.096899527640069E-008
 -1.245247153521047E-005
 -7.676515175580539E-006
 -5.250735035527097E-007
 -8.704171054462753E-017
 -1.046277847904378E-010
  9.597688964926160E-015
 -7.090756547007672E-008
 -2.851156237307707E-005
   431.652762342319
   3.52079001217599
   3.35458888816012
   160.008739988460
 -8.959029566007674E-006
 -7.307024255959268E-008
 -6.962519136542052E-008
 -3.321005772110726E-006
 -2.063989614253028E-005
 -1.683399071794100E-007
 -1.604031671180195E-007
 -7.650964172506501E-006
   271.668887092405
  4.276759166147122E-005
  4.276759166152710E-005
 -1.424660158965419E-004
   10.9445654695033
 -5.638544060652410E-006
 -2.271567367276132E-007
 -1.299013055807623E-005
 -5.233258152304505E-007
   34.4114274280303
 -7.142163459895920E-007
 -1.645418300717152E-006
   58.2572413100881
  4.276331518742727E-005
  1.283027749845813E-004
 -0.107425228760565
 -1.209137626377401E-006
  2.220762450577875E-009
 -2.785622553506704E-006
  5.116212559165398E-009
  1.436881395069855E-004
  1.283027749844137E-004
 -4.865053518643024E-004
  1.814311595039324E-009
 -3.065261126771891E-013
  1.188392281684106E-012
 -3.765656994604997E-017
 -7.061721099320848E-013
  2.737807464622339E-012
 -8.675291496722455E-017
   79.9523731771158
   3.52079001216755
   95.5363634544521
  4.320033963044964E-005
 -7.307024255959270E-008
 -6.790524186167909E-005
 -1.344811398746005E-004
 -7.148828268931468E-005
 -1.399055153437034E-004
   127.259217973118
   3.35458888815603
 -1.425443839580909E-004
 -0.107436206412480
 -4.867976935880989E-004
   95.5347835631807
 -3.051496130161218E-005
 -5.296275520731472E-003
  2.198129131514192E-003
  2.220984526821740E-009
  1.188684989184366E-012
 -1.344744825015285E-004
 -2.676377870316731E-004
  5.848073950627501E-015
  1.101046353764912E-010
 -4.526395670171829E-011
 -1.604031671178239E-007
  5.116724180414483E-009
  2.738481801533425E-012
 -1.398986732703470E-004
 -2.767596519752524E-004
  1.347284646327814E-014
  2.536600539922729E-010
 -1.042795414748301E-010
  5.332171154013383E-005
 -3.052329818850029E-005
 -1.506595595471586E-005
 -3.044159492046854E-005
  5.848533347423803E-015
 -8.584697386201672E-015
 -1.121694513298766E-015
  4.152764796517333E-015
  1.347390482594658E-014
 -1.977750565955998E-014
 -2.584169823872052E-015
  9.567178204146044E-015
   4.37875093286027
 -5.295744639155804E-003
 -1.506255660484830E-005
   1.47799693601042
  1.100936257841985E-010
 -1.121652452202653E-015
 -9.088090164226766E-008
 -3.067595501486942E-008
  2.536346899939725E-010
 -2.584072923145672E-015
 -2.093722715642149E-007
 -7.067155220666001E-008
   594.291836819207
   160.008739987936
   10.9445654695033
  1.814286367884879E-009
  2.198129131510196E-003
 -3.043325015917651E-005
   1.47799693558047
 -3.321005772105292E-006
 -3.765604634899907E-017
 -4.526395670163537E-011
  4.152141964820627E-015
 -3.067595501482698E-008
 -1.233464157242225E-005
 -7.650964172519020E-006
 -5.233258152312330E-007
 -8.675170870850273E-017
 -1.042795414748300E-010
  9.565743318696226E-015
 -7.067155220666003E-008
 -2.841666266815171E-005
   430.745623632705
   3.51339133613417
   3.34753904816525
   159.672474455931
 -8.890100991349506E-006
 -7.250805772914912E-008
 -6.908951217852742E-008
 -3.295454768911611E-006
 -2.058437136462901E-005
 -1.678870441483667E-007
 -1.599716556491177E-007
 -7.630381797519948E-006
   271.097961166583
  4.276714063372506E-005
  4.276714063372507E-005
 -1.424645134473318E-004
   10.9215649096747
 -5.595162484652461E-006
 -2.254090484717089E-007
 -1.295518492811676E-005
 -5.219179810132272E-007
   34.3391100760728
 -7.087213407164695E-007
 -1.640991849877798E-006
   58.1348109120591
  4.276286420473853E-005
  1.283014219011752E-004
 -0.107200355871680
 -1.199834812571979E-006
  2.203676269901345E-009
 -2.778128753560112E-006
  5.102448818282729E-009
  1.436556951231866E-004
 -4.863803062241781E-004
  1.810492745328839E-009
 -3.041664351928392E-013
  1.179243880535920E-012
 -3.736669595595753E-017
 -7.042703795446756E-013
  2.730434508054045E-012
 -8.651930515018887E-017
   79.8233226428675
   3.51339133613417
   95.4135386681799
  4.320033691898645E-005
 -7.250805772897533E-008
 -6.943994930242008E-005
 -1.375609881183117E-004
 -1.678870441479766E-007
 -7.274909968206874E-005
 -1.424355562837827E-004
   127.147678771713
   3.34753904816117
 -1.425428806824617E-004
 -0.107211311033766
 -4.866726153283996E-004
   95.4119581996475
 -3.051436915070126E-005
 -5.285126644137344E-003
  2.193546104111416E-003
 -6.908951217844317E-008
  2.203896637526664E-009
  1.179534334734207E-012
 -1.375541762502556E-004
 -2.738076738418393E-004
  5.803080061257641E-015
  1.092575089505849E-010
 -4.491571037918696E-011
 -1.599716556487275E-007
  5.102959063172764E-009
  2.731107028959728E-012
 -1.424285873038437E-004
 -2.818279425765646E-004
  1.343660188014774E-014
  2.529776532494319E-010
 -1.039990172719161E-010
  5.332084229982340E-005
 -3.052270599091813E-005
 -1.506606953553953E-005
 -3.044117443427131E-005
  5.803535923571511E-015
 -8.518648711354949E-015
 -1.113064354035169E-015
  4.120814397953772E-015
  1.343765739567821E-014
 -1.972430067445400E-014
 -2.577217796899757E-015
  9.541440823339225E-015
   4.36954886658265
 -5.284596877360138E-003
 -1.506267018148296E-005
   1.47489086911128
  1.092465840642160E-010
 -1.113022616561876E-015
 -9.018168629045588E-008
 -3.043994174889610E-008
  2.529523574860598E-010
 -2.577121156848202E-015
 -2.088090250838499E-007
 -7.048143389810325E-008
   593.042903465963
   159.672474456192
   10.9215649096910
  1.810467571273700E-009
  2.193546104111378E-003
 -3.043282973613301E-005
   1.47489086867928
 -3.295454768900826E-006
 -3.736617638952112E-017
 -4.491571037910468E-011
  4.120196358173787E-015
 -3.043994174893823E-008
 -1.223974186751536E-005
 -7.630381797519947E-006
 -8.651810213970726E-017
  9.540009797994868E-015
 -7.048143389829835E-008
 -2.834021708573982E-005
   430.011600574057
   3.50740460145315
   3.34183457865189
   159.400380837126
 -8.834576213503412E-006
 -7.205519492348902E-008
 -6.865800074795069E-008
 -3.274872393834945E-006
 -2.053963718895595E-005
 -1.675221898404239E-007
 -1.596240034725487E-007
 -7.613799370475134E-006
   270.635989045675
  4.276677773647100E-005
  4.276677773643374E-005
 -1.424633045758366E-004
   10.9029537082234
 -5.560216856043503E-006
 -2.240012143094261E-007
 -1.292703057954740E-005
 -5.207837431899208E-007
   34.2805935523729
 -7.042948898771393E-007
 -1.637425628865588E-006
   58.0357447668207
  4.276250134386197E-005
  1.283003332093012E-004
 -0.107018397099023
 -1.192341016692345E-006
  2.189912655872936E-009
 -2.772091287463663E-006
  5.091359902518451E-009
  1.436294489092180E-004
  1.283003332094130E-004
 -4.862791460561435E-004
  1.807402720804625E-009
 -3.022656355421320E-013
  1.171874535466507E-012
 -3.713319261535630E-017
 -7.027382379514755E-013
  2.724494437112242E-012
 -8.633109584248913E-017
   79.7188997595963
   3.50740460144500
   95.3141534602759
  4.320033472589264E-005
 -7.070076701949043E-005
 -1.400910305065070E-004
 -7.378112123586171E-005
 -1.445063741745651E-004
   127.057425502969
   3.34183457864374
 -1.425416711462066E-004
 -0.107029334063550
 -4.865714287790276E-004
   95.3125725248460
 -3.051389000407216E-005
 -5.276105387107716E-003
  2.189837687556400E-003
 -6.865800074786697E-008
  2.190131647135599E-009
  1.172163174556230E-012
 -1.400840917311424E-004
 -2.788759673387710E-004
  5.766835650272265E-015
  1.085751141304629E-010
 -4.463518373865407E-011
 -1.596240034723540E-007
  5.091869038508427E-009
  2.725165494944705E-012
 -1.444993013273154E-004
 -2.859761918087256E-004
  1.340740101556091E-014
  2.524278692623353E-010
 -1.037730097154137E-010
  5.332013894264126E-005
 -3.052222680669403E-005
 -1.506616144098054E-005
 -3.044083419239293E-005
  5.767288665422695E-015
 -8.465443811141090E-015
 -1.106112409673907E-015
  4.095077049275078E-015
  1.340845423720765E-014
 -1.968143546673411E-014
 -2.571616816658609E-015
  9.520705206695958E-015
   4.36210289525918
  4.320033472589265E-005
 -5.275576522390140E-003
 -1.506276208343958E-005
   1.47237755477438
  1.085642574781563E-010
 -1.106070932873518E-015
 -8.961843980972815E-008
 -3.024982343829676E-008
  2.524026284731270E-010
 -2.571520386665408E-015
 -2.083552390807462E-007
 -7.032826289708467E-008
   592.032312837690
   159.400380837126
   10.9029537082234
  1.807377589714935E-009
 -3.043248954530838E-005
   1.47237755434646
 -3.274872393840303E-006
 -2.240012143097610E-007
 -3.713267629567438E-017
  4.094462869592363E-015
 -1.216329628509589E-005
 -8.632989544889551E-017
 -1.037730097156037E-010
  9.519277291265364E-015
 -7.032826289718199E-008
 -2.827862782335228E-005
   429.418072002371
   3.50256374796886
   3.33722196381546
   159.180366853747
 -8.789842037809557E-006
 -7.169034079878005E-008
 -6.831034860257206E-008
 -3.258289966708754E-006
 -2.050359213167310E-005
 -1.672282044428539E-007
 -1.593438788820862E-007
 -7.600437896292358E-006
   270.262439944945
  4.276648564156393E-005
  4.276648564154530E-005
 -1.424623315588440E-004
   10.8879047534372
 -5.532062508570556E-006
 -2.228669765296685E-007
 -1.290434490150553E-005
 -5.198698185067095E-007
   34.2332772884270
 -7.007286688649723E-007
 -1.634552106805837E-006
   57.9556402155837
  4.276220927810531E-005
  1.282994569246359E-004
 -0.106871265877190
 -1.186303553891904E-006
  2.178823842819916E-009
 -2.767226532306721E-006
  5.082424886081833E-009
  1.436082306020251E-004
  1.282994569246918E-004
 -4.861973627246934E-004
  1.804904168158892E-009
 -3.007342453383419E-013
  1.165937380124207E-012
 -3.694506924792402E-017
 -7.015037039741444E-013
  2.719708182744512E-012
 -8.617944484102631E-017
   79.6344637877851
   3.50256374796886
   95.2337909562457
  4.320033295313462E-005
 -7.169034079861344E-008
 -7.173278918273066E-005
 -1.421618496145623E-004
 -1.672282044432425E-007
 -7.462337908232303E-005
 -1.461963497933112E-004
   126.984447094865
   3.33722196381139
 -1.425406975936843E-004
 -0.106882188126812
 -4.864896241251698E-004
   95.2322096430826
 -3.051350256776859E-005
 -5.268810829823098E-003
  2.186839074110302E-003
 -6.831034860240545E-008
  2.179041725207703E-009
  1.166224556857631E-012
 -1.421548069724762E-004
 -2.830242190049646E-004
  5.737634925027605E-015
  1.080253349382935E-010
 -4.440917420866043E-011
 -1.593438788824749E-007
  5.082933128563579E-009
  2.720378061692399E-012
 -1.461891921845477E-004
 -2.893614719072470E-004
  1.338387209585462E-014
  2.519848747385765E-010
 -1.035909016204071E-010
  5.331957021044600E-005
 -3.052183933993127E-005
 -1.506623575538609E-005
 -3.044055907398019E-005
  5.738085646335384E-015
 -8.422578672119475E-015
 -1.100511496343609E-015
  4.074341458606448E-015
  1.338492346929868E-014
 -1.964689635123165E-014
 -2.567103764975986E-015
  9.503997254084455E-015
   4.35608210792469
  4.320033295313463E-005
 -5.268282694505954E-003
 -1.506283639505300E-005
   1.47034529727132
  1.080145332596642E-010
 -1.100470229560541E-015
 -8.916465380671746E-008
 -3.009665243540990E-008
  2.519596782460064E-010
 -2.567007504166014E-015
 -2.079895959851324E-007
 -7.020484366721345E-008
   591.215152660388
   159.180366853747
   10.8879047534372
  1.804879071808852E-009
  2.186839074114276E-003
 -3.043221446818160E-005
   1.47034529684135
 -3.694455554401168E-017
  4.073730388853275E-015
 -3.009665243549320E-008
 -1.210170702268488E-005
 -7.600437896304794E-006
 -5.198698185074868E-007
 -8.617824655622314E-017
 -1.035909016205969E-010
  9.502571844517565E-015
 -2.822900159334222E-005
   428.938419520022
   3.49865167449400
   3.33349433844606
   159.002565382194
 -8.753796980541730E-006
 -7.139635554942254E-008
 -6.803022403780863E-008
 -3.244928492483445E-006
 -2.047454548157105E-005
 -1.669912984257077E-007
 -1.591181424965637E-007
 -7.589670648485526E-006
   269.960561043216
  4.276625046405372E-005
  4.276625046401646E-005
 -1.424615481431320E-004
   10.8757431341526
 -5.509376831420294E-006
 -2.219530518826500E-007
 -1.288606381106815E-005
 -5.191333388769517E-007
   34.1950392582348
 -6.978551468052400E-007
 -1.632236499727627E-006
   57.8909047526019
  4.276197412406445E-005
  1.282987513920494E-004
 -0.106752363690963
 -1.181438801413362E-006
  2.169888909502336E-009
 -2.763306304362292E-006
  5.075224667494879E-009
  1.435910860979865E-004
  1.282987513921612E-004
 -4.861312799889004E-004
  1.802885014996849E-009
 -2.995003177952206E-013
  1.161153478890061E-012
 -3.679348759476574E-017
 -7.005088675955084E-013
  2.715851229394195E-012
 -8.605723844806705E-017
   79.5662279567332
   3.49865167450213
   95.1688470588595
  4.320033152080831E-005
 -7.139635554942252E-008
 -7.257504753671503E-005
 -1.438518262478797E-004
 -1.669912984255015E-007
 -7.530913559263378E-005
 -1.475722633585020E-004
   126.925470586341
   3.33349433845420
 -1.425399137468815E-004
 -0.106763274048935
 -4.864235241635095E-004
   95.1672654406833
 -3.051318946612860E-005
 -5.262915827639567E-003
  2.184415783018401E-003
 -6.803022403772566E-008
  2.170105898393168E-009
  1.161439477321949E-012
 -1.438446988439430E-004
 -2.864095011322226E-004
  5.714106118195508E-015
  1.075823442948329E-010
 -4.422706451684361E-011
 -1.591181424963697E-007
  5.075732189969059E-009
  2.716520158351808E-012
 -1.475650367426621E-004
 -2.921175932619515E-004
  1.336491148550127E-014
  2.516278907967956E-010
 -1.034441511197498E-010
  5.331911059686860E-005
 -3.052152621371713E-005
 -1.506629581162327E-005
 -3.044033674062845E-005
  5.714554991190989E-015
 -8.388039612211937E-015
 -1.095998498789488E-015
  4.057633527033072E-015
  1.336596136947032E-014
 -1.961906325357271E-014
 -2.563466954854835E-015
  9.490533270721339E-015
   4.35121648606998
 -5.262388281790459E-003
 -1.506289644902959E-005
   1.46870295450303
  1.075715869118117E-010
 -1.095957401248400E-015
 -8.879901071114275E-008
 -2.997323320424912E-008
  2.516027299983690E-010
 -2.563370830445651E-015
 -2.076949451273921E-007
 -7.010538716903165E-008
   590.554775171662
   159.002565382454
   10.8757431341689
  1.802859946725415E-009
  2.184415783022371E-003
 -3.043199216815636E-005
   1.46870295407103
 -3.679297599849368E-017
 -4.422706451692463E-011
  4.057024963129540E-015
 -2.997323320429059E-008
 -1.205208079269425E-005
 -7.589670648473107E-006
 -8.605604186238652E-017
 -1.034441511195603E-010
  9.489109880459988E-015
 -2.818901065297637E-005
   428.550973140835
   3.49549163936416
   3.33048329399165
   158.858943617485
 -8.724750330464116E-006
 -7.115944965184266E-008
 -6.780448767249601E-008
 -3.234161244600296E-006
 -2.045113650593140E-005
 -1.668003735790921E-007
 -1.589362193637752E-007
 -7.580993219587552E-006
   269.716713900543
  4.276606106626358E-005
  4.276606106626357E-005
 -1.424609172273694E-004
   10.8659194065261
 -5.491095741702411E-006
 -2.212165722809183E-007
 -1.287133090391416E-005
 -5.185398028428095E-007
   34.1641519244336
 -6.955395397270483E-007
 -1.630370329643472E-006
   57.8386137261048
  4.276178474519881E-005
  1.282981831987907E-004
 -0.106656318705425
 -1.177518575631265E-006
  2.162688758127530E-009
 -2.760146954835401E-006
  5.069421941955428E-009
  1.435772391950455E-004
 -4.860779068152861E-004
  1.801254027236606E-009
 -2.985059707472237E-013
  1.157298424284928E-012
 -3.667133715045292E-017
 -6.997071219213487E-013
  2.712742883412031E-012
 -8.595875144646893E-017
   79.5111094648237
   3.49549163935985
   95.1163876838152
  4.320033036416549E-005
 -7.115944965200804E-008
 -7.326080446705498E-005
 -1.452277406527969E-004
 -1.668003735790800E-007
 -7.586640318530472E-005
 -1.486903454462271E-004
   126.877831475362
   3.33048329398759
 -1.425392824839960E-004
 -0.106667219458157
 -4.863701370800871E-004
   95.1148058192421
 -3.051293655355261E-005
 -5.258154052875787E-003
  2.182458333715624E-003
 -6.780448767266139E-008
  2.162905027000423E-009
  1.157583473194134E-012
 -1.452205442414472E-004
 -2.891656241660495E-004
  5.695145598941859E-015
  1.072253634889271E-010
 -4.408031272479139E-011
 -1.589362193637751E-007
  5.069928884150390E-009
  2.713411046764879E-012
 -1.486830627558681E-004
 -2.943572181942225E-004
  1.334963094669267E-014
  2.513401939976207E-010
 -1.033258834740739E-010
  5.331873933701905E-005
 -3.052127328146019E-005
 -1.506634432291078E-005
 -3.044015714764013E-005
  5.695592982539065E-015
 -8.360206559523237E-015
 -1.092361732421092E-015
  4.044169560669907E-015
  1.335067963032767E-014
 -1.959663229157082E-014
 -2.560536014546477E-015
  9.479682516578802E-015
   4.34728620813888
  4.320033036416550E-005
 -5.257626983136613E-003
 -1.506294495845427E-005
   1.46737632787414
  1.072146418014556E-010
 -1.092320771231061E-015
 -8.850435985317780E-008
 -2.987377670469297E-008
  2.513150619664392E-010
 -2.560440000034010E-015
 -2.074574831583652E-007
 -7.002523421785181E-008
   590.021345500043
   158.858943617225
   10.8659194065261
  1.801228981641199E-009
  2.182458333711658E-003
 -3.043181260191590E-005
   1.46737632744214
 -3.234161244605587E-006
 -2.212165722812491E-007
 -3.667082725269133E-017
 -4.408031272487214E-011
  4.043563016094209E-015
 -2.987377670469296E-008
 -1.201208985228127E-005
 -7.580993219575148E-006
 -5.185398028420343E-007
 -8.595755622984005E-017
  9.478260753709267E-015
 -7.002523421785184E-008
 -2.815678156850803E-005
   428.238124405433
   3.49294002692345
   3.32805198604921
   158.742974312559
 -8.701341354931357E-006
 -7.096852490391886E-008
 -6.762256455809600E-008
 -3.225483815668489E-006
 -2.043226971094716E-005
 -1.666464950002949E-007
 -1.587895958434067E-007
 -7.573999522957144E-006
   269.519816281025
  4.276590850585056E-005
  4.276590850575743E-005
 -1.424604090229935E-004
   10.8579871070590
 -5.476362835133770E-006
 -2.206230362651746E-007
 -1.285945670890157E-005
 -5.180614340680183E-007
   34.1392115358341
 -6.936733696429102E-007
 -1.628866263456985E-006
   57.7963906410371
  4.276163220018987E-005
  1.282977255172723E-004
 -0.106578765911959
 -1.174359227858434E-006
  2.156886086901910E-009
 -2.757600632375060E-006
  5.064745153258071E-009
  1.435660595157096E-004
  1.282977255175517E-004
 -4.860348139286142E-004
  1.799937072964838E-009
 -2.977046198457161E-013
  1.154191610135591E-012
 -3.657289527981732E-017
 -6.990609453137846E-013
  2.710237674434753E-012
 -8.587937465266661E-017
   79.4666033107106
   3.49294002692320
   95.0740286747602
  4.320032943025648E-005
 -7.096852490383122E-008
 -7.381807240596931E-005
 -1.463458234323711E-004
 -1.666464949998834E-007
 -7.631855884710159E-005
 -1.495975157480273E-004
   126.839364664111
   3.32805198604920
 -1.425387740006329E-004
 -0.106589658908433
 -4.863270329631897E-004
   95.0724466111179
 -3.051273233550589E-005
 -5.254309094678813E-003
  2.180877765157988E-003
 -6.762256455801353E-008
  2.157101775513757E-009
  1.154475893818842E-012
 -1.463385709465917E-004
 -2.914052504817416E-004
  5.679865133927551E-015
  1.069376692251879E-010
 -4.396204403532289E-011
 -1.587895958430194E-007
  5.065251627765295E-009
  2.710905220738300E-012
 -1.495901875615648E-004
 -2.961743480437437E-004
  1.333731538059046E-014
  2.511083206949014E-010
 -1.032305639888848E-010
  5.331843955756923E-005
 -3.052106904730943E-005
 -1.506638349369686E-005
 -3.044001213225274E-005
  5.680311317155700E-015
 -8.337775633993091E-015
 -1.089430827480659E-015
  4.033318820347411E-015
  1.333836309666174E-014
 -1.957855374075729E-014
 -2.558173781772270E-015
  9.470937197867221E-015
   4.34411265293273
 -5.253782409401703E-003
 -1.506298412781963E-005
   1.46630512555775
  1.069269763042598E-010
 -1.089389976205225E-015
 -8.826689788419685E-008
 -2.979362375230428E-008
  2.510832118499173E-010
 -2.558077855902490E-015
 -2.072660973242139E-007
 -6.996063381183577E-008
   589.590620618883
   158.742974312299
   10.8579871070428
  1.799912045673442E-009
 -3.043166760834007E-005
   1.46630512512575
 -3.225483815663212E-006
 -3.657238675080133E-017
 -4.396204403524236E-011
  4.032713903156138E-015
 -1.197986076761119E-005
 -7.573999522944752E-006
 -5.180614340672437E-007
 -8.587818053985619E-017
  9.469516746680629E-015
 -6.996063381183580E-008
 -2.813080608143066E-005
   427.985586832898
   3.49088031586198
   3.32608938710895
   158.649361636486
 -8.682474559812810E-006
 -7.081464640107943E-008
 -6.747594104897685E-008
 -3.218490119025520E-006
 -2.041706291395762E-005
 -1.665224675578423E-007
 -1.586714160398334E-007
 -7.568362544105563E-006
   269.360876697523
  4.276578559795321E-005
  4.276578559787871E-005
 -1.424599995962056E-004
   10.8515840006505
 -5.464488640607088E-006
 -2.201446675165107E-007
 -1.284988600692518E-005
 -5.176758647778848E-007
   34.1190791696888
 -6.921693034564379E-007
 -1.627653973341041E-006
   57.7623073465766
  4.276150930445560E-005
  1.282973567936361E-004
 -0.106516163795908
 -1.171812906815847E-006
  2.152209342068556E-009
 -2.755548274852013E-006
  5.060975621889821E-009
  1.435570358346327E-004
  1.282973567938596E-004
 -4.860000311136375E-004
  1.798874007371863E-009
 -2.970587616800648E-013
  1.151687636807230E-012
 -3.649355488927380E-017
 -6.985401225644583E-013
  2.708218458920920E-012
 -8.581539641381704E-017
   79.4306770825670
   3.49088031585337
   95.0398356675637
  4.320032867649141E-005
 -7.081464640107430E-008
 -7.427022835159533E-005
 -1.472529943011431E-004
 -1.665224675582414E-007
 -7.668497319083680E-005
 -1.503326489934906E-004
   126.808313522111
   3.32608938710084
 -1.425383643481853E-004
 -0.106527050531309
 -4.862922410851383E-004
   95.0382534432284
 -3.051256748781728E-005
 -5.251205369882826E-003
  2.179601899431111E-003
  2.152424563003088E-009
  1.151971303747266E-012
 -1.472456963195189E-004
 -2.932223814649971E-004
  5.667549627079766E-015
  1.067057979692152E-010
 -4.386672370866227E-011
 -1.586714160400269E-007
  5.061481719445356E-009
  2.708885507885245E-012
 -1.503252839395081E-004
 -2.976468626905682E-004
  1.332738892948363E-014
  2.509214288464262E-010
 -1.031537356742622E-010
  5.331819757166629E-005
 -3.052090418646973E-005
 -1.506641511365014E-005
 -3.043989507391158E-005
  5.667994842873987E-015
 -8.319697112198258E-015
 -1.087068623268757E-015
  4.024573512646906E-015
  1.332843586595967E-014
 -1.956398227504413E-014
 -2.556269802121510E-015
  9.463888396734214E-015
   4.34155089752353
  4.320032867658734E-005
 -5.250678994968371E-003
 -1.506301574662667E-005
   1.46544043022278
  1.066951282335110E-010
 -1.087027860567788E-015
 -8.807551205004614E-008
 -2.972902334621340E-008
  2.508963386880428E-010
 -2.556173947588698E-015
 -2.071118387171714E-007
 -6.990856533652302E-008
   589.242931119715
   158.649361636226
   10.8515840006343
  1.798848994864434E-009
  2.179601899431131E-003
 -3.043155056778929E-005
   1.46544042979078
 -3.218490119020254E-006
 -2.201446675161816E-007
 -3.649304746329429E-017
  4.023969907075096E-015
 -2.972902334621341E-008
 -1.195388528084363E-005
 -7.568362544117949E-006
 -5.176758647778849E-007
 -8.581420319076596E-017
 -1.031537356744511E-010
  9.462469002654801E-015
 -6.990856533661979E-008
 -2.810986961848134E-005
   427.781783388565
   3.48921808315066
   3.32450552604389
   158.573814123007
 -8.667267762843182E-006
 -7.069061902276092E-008
 -6.735776125699242E-008
 -3.212853140145486E-006
 -2.040480555893195E-005
 -1.664224959208947E-007
 -1.585761578594306E-007
 -7.563818888337241E-006
   269.232608915544
  4.276568656588949E-005
  4.276568656581498E-005
 -1.424596697037420E-004
   10.8464165513061
 -5.454917939000393E-006
 -2.197590982397958E-007
 -1.284217159527324E-005
 -5.173650787736352E-007
   34.1028319020053
 -6.909570133404974E-007
 -1.626676813565425E-006
   57.7348013691564
  4.276141028230116E-005
  1.282970596974449E-004
 -0.106465642497743
 -1.169760550438250E-006
  2.148439846128822E-009
 -2.753893983366581E-006
  5.057937211897547E-009
  1.435497540260737E-004
  1.282970596976685E-004
 -4.859719622989282E-004
  1.798016093369714E-009
 -2.965381957705166E-013
  1.149669417915220E-012
 -3.642960600805834E-017
 -6.981203169547546E-013
  2.706590884089205E-012
 -8.576382719121136E-017
   79.4016838188577
   3.48921808315902
   95.0122411543008
  4.320032806852969E-005
 -7.069061902258636E-008
 -7.463664292727881E-005
 -1.479881280102205E-004
 -7.698160790712263E-005
 -1.509277761309502E-004
   126.783254568890
   3.32450552604795
 -1.425380342743372E-004
 -0.106476524180500
 -4.862641649577426E-004
   95.0106588001741
 -3.051243445137225E-005
 -5.248700594967602E-003
  2.178572247359067E-003
 -6.735776125682814E-008
  2.148654690109999E-009
  1.149952587755810E-012
 -1.479807931609973E-004
 -2.946948970388718E-004
  5.657623224263201E-015
  1.065189077733507E-010
 -4.378989471353768E-011
 -1.585761578596240E-007
  5.058443005624168E-009
  2.707257532174606E-012
 -1.509203812315019E-004
 -2.988389290791847E-004
  1.331938776843600E-014
  2.507707857005661E-010
 -1.030918086337276E-010
  5.331800228244966E-005
 -3.052077113975043E-005
 -1.506644063146503E-005
 -3.043980060493228E-005
  5.658067660239120E-015
 -8.305125670372338E-015
 -1.085164666685363E-015
  4.017524720467370E-015
  1.332043407628291E-014
 -1.955223702542676E-014
 -2.554735109842482E-015
  9.458206749338822E-015
   4.33948350387970
  4.320032806843378E-005
 -5.248174470487680E-003
 -1.506304126336601E-005
   1.46474260184520
  1.065082567254851E-010
 -1.085123975405807E-015
 -8.792125344283161E-008
 -2.967695487009564E-008
  2.507457106065346E-010
 -2.554639312881742E-015
 -2.069874994159260E-007
 -6.986659582862663E-008
   588.962337956860
   158.573814123266
   10.8464165513061
  1.797991092794777E-009
  2.178572247363025E-003
 -3.043145611277071E-005
   1.46474260141522
 -3.212853140140229E-006
 -2.197590982394673E-007
 -3.642909947130969E-017
  4.016922172098911E-015
 -1.193294881780779E-005
 -7.563818888337243E-006
 -5.173650787736354E-007
 -8.576263468532053E-017
 -1.030918086339165E-010
  9.456788207419465E-015
 -6.986659582882003E-008
 -2.809299389775827E-005
   427.617341939523
   3.48787688916692
   3.32322756722473
   158.512857633417
 -8.655010407820777E-006
 -7.059064743655396E-008
 -6.726250308557331E-008
 -3.208309484348713E-006
 -2.039492522747631E-005
 -1.663419114140982E-007
 -1.584993727464437E-007
 -7.560156366951090E-006
   269.129114394251
  4.276560676295213E-005
  4.276560676289626E-005
 -1.424594038665250E-004
   10.8422471278692
 -5.447203527654215E-006
 -2.194483122480482E-007
 -1.283595321099170E-005
 -5.171145623519010E-007
   34.0897225836300
 -6.899798535648867E-007
 -1.625889150776778E-006
   57.7126078150224
  4.276133048724280E-005
  1.282968202886888E-004
 -0.106424878736046
 -1.168106259877016E-006
  2.145401464734623E-009
 -2.752560502517244E-006
  5.055488029552408E-009
  1.435438789315588E-004
  1.282968202888564E-004
 -4.859493157120819E-004
  1.797323876677477E-009
 -2.961185973004314E-013
  1.148042646848532E-012
 -3.637806046065036E-017
 -6.977819231540718E-013
  2.705278940606689E-012
 -8.572225865252021E-017
   79.3782902301682
   3.48787688916692
   94.9899761668216
  4.320032757769031E-005
 -7.059064743672312E-008
 -7.493327783257892E-005
 -1.485832555256957E-004
 -7.722155797554066E-005
 -1.514091737988736E-004
   126.763035434040
   3.32322756722878
 -1.425377682908093E-004
 -0.106435756342242
 -4.862415124714016E-004
   94.9883937082932
 -3.051232710929393E-005
 -5.246679584914525E-003
  2.177741459226937E-003
 -6.726250308565536E-008
  2.145616004878276E-009
  1.148325416008479E-012
 -1.485758908307350E-004
 -2.958869641833681E-004
  5.649622101859762E-015
  1.063682659628008E-010
 -4.372796712381164E-011
  5.055993578359623E-009
  2.705945265556072E-012
 -1.514017547577261E-004
 -2.998031851121998E-004
  1.331293824293489E-014
  2.506493562253894E-010
 -1.030418908752109E-010
  5.331784471098449E-005
 -3.052066378926180E-005
 -1.506646122075549E-005
 -3.043972438136438E-005
  5.650065909381669E-015
 -8.293380439807156E-015
 -1.083629993001331E-015
  4.011843080338120E-015
  1.331398404417457E-014
 -1.954276948868124E-014
 -2.553498034766739E-015
  9.453626922863420E-015
   4.33781540053863
  4.320032757778623E-005
 -5.246153662545348E-003
 -1.506306185192227E-005
   1.46417954998105
  1.063576299774557E-010
 -1.083589359244036E-015
 -8.779691414158208E-008
 -2.963498536166982E-008
  2.506242932727399E-010
 -2.553402284173688E-015
 -2.068872727760169E-007
 -6.983276531233290E-008
   588.735937729090
   158.512857633417
   10.8422471278692
  1.797298885729885E-009
  2.177741459230896E-003
 -3.043137990061141E-005
   1.46417954955310
 -3.208309484353963E-006
 -3.637755464069136E-017
 -4.372796712389175E-011
  4.011241384071527E-015
 -2.963498536171083E-008
 -1.191607309708201E-005
 -5.171145623526741E-007
 -8.572106672459976E-017
 -1.030418908753996E-010
  9.452209067824626E-015
 -2.807939082325618E-005
   427.484681384506
   3.48679490199628
   3.32219659403879
   158.463681943455
 -8.645130076392008E-006
 -7.051006297112987E-008
 -6.718571797951538E-008
 -3.204646962946553E-006
 -2.038696071859271E-005
 -1.662769524576993E-007
 -1.584374764709177E-007
 -7.557204018185197E-006
   269.045621815976
  4.276554244969151E-005
  4.276554244976602E-005
 -1.424591896285888E-004
   10.8388835110509
 -5.440985143614131E-006
 -2.191977958360406E-007
 -1.283094058793818E-005
 -5.169126217304612E-007
   34.0791468470743
 -6.891921907762622E-007
 -1.625254217897762E-006
   57.6947035140013
  4.276126618066909E-005
  1.282966273492981E-004
 -0.106391993213459
 -1.166772779776667E-006
  2.142952305464977E-009
 -2.751485587152947E-006
  5.053513750193907E-009
  1.435391395044510E-004
  1.282966273490745E-004
 -4.859310466506578E-004
  1.796765443256963E-009
 -2.957803705413881E-013
  1.146731351541131E-012
 -3.633651101334174E-017
 -6.975091451065465E-013
  2.704221387605704E-012
 -8.568875039973341E-017
   79.3594178213272
   3.48679490199628
   94.9720142404904
  4.320032718200680E-005
 -7.051006297112984E-008
 -7.517322805459934E-005
 -1.490646535005930E-004
 -7.741552913585588E-005
 -1.517983233305570E-004
   126.746723969295
   3.32219659403879
 -1.425375539355636E-004
 -0.106402867530724
 -4.862232386510857E-004
   94.9704316975355
 -3.051224051278913E-005
 -5.245049166874753E-003
  2.177071233944895E-003
 -6.718571797959729E-008
  2.143166600697825E-009
  1.147013797722587E-012
 -1.490572646639391E-004
 -2.968512208302241E-004
  5.643172607720799E-015
  1.062468375637829E-010
 -4.367804892210587E-011
 -1.584374764711110E-007
  5.054019101577109E-009
  2.704887452069975E-012
 -1.517908847736276E-004
 -3.005826616396734E-004
  1.330773929763396E-014
  2.505514722493659E-010
 -1.030016523026644E-010
  5.331771759273513E-005
 -3.052057718595037E-005
 -1.506647783090240E-005
 -3.043966288920605E-005
  5.643615908560412E-015
 -8.283912918507115E-015
 -1.082392932955246E-015
  4.007263259690814E-015
  1.330878469049639E-014
 -1.953513773252967E-014
 -2.552500831836274E-015
  9.449935136893252E-015
   4.33646968438194
 -5.244523407521813E-003
 -1.506307846143237E-005
   1.46372531673754
  1.062362137208380E-010
 -1.082352345595365E-015
 -8.769668750185622E-008
 -2.960115484505503E-008
  2.505264190837793E-010
 -2.552405118640952E-015
 -2.068064803482763E-007
 -6.980549462308215E-008
   588.553292904112
   158.463681943455
   10.8388835110671
  1.796740460073692E-009
  2.177071233948852E-003
 -3.043131841768043E-005
   1.46372531630554
 -3.204646962946554E-006
 -2.191977958360407E-007
 -3.633600577115685E-017
 -4.367804892218589E-011
  4.006662250317007E-015
 -2.960115484513696E-008
 -1.190247002256264E-005
 -7.557204018197563E-006
 -8.568755893770515E-017
 -1.030016523028531E-010
  9.448517835593116E-015
 -6.980549462317875E-008
 -2.806842542103702E-005
   427.377673348977
   3.48592213826098
   3.32136497972595
   158.424015336813
 -8.637165567493328E-006
 -7.044510404781003E-008
 -6.712382170985159E-008
 -3.201694614183957E-006
 -2.038054039673184E-005
 -1.662245879718866E-007
 -1.583875808633551E-007
 -7.554824081228100E-006
   268.978274164011
  4.276549061608933E-005
  4.276549061603344E-005
 -1.424590169621145E-004
   10.8361703154810
 -5.435972520780436E-006
 -2.189958552227503E-007
 -1.282689982992292E-005
 -5.167498340688454E-007
   34.0706161365071
 -6.885572578972313E-007
 -1.624742388042591E-006
   57.6802613606224
  4.276121435213329E-005
  1.282964718481004E-004
 -0.106365466752400
 -1.165697865013743E-006
  2.140978044719604E-009
 -2.750619080167261E-006
  5.051922251075621E-009
  1.435353166766259E-004
  1.282964718482680E-004
 -4.859163107361481E-004
  1.796314994870508E-009
 -2.955077271951045E-013
  1.145674321217614E-012
 -3.630301815491981E-017
 -6.972892544227020E-013
  2.703368877452696E-012
 -8.566173886839909E-017
   79.3441947633111
   3.48592213826098
   94.9575256060241
  4.320032686267823E-005
 -7.044510404781002E-008
 -7.536719933997042E-005
 -1.494538032817643E-004
 -7.757224957299458E-005
 -1.521127373932547E-004
   126.733566648691
   3.32136497973000
 -1.425373811737776E-004
 -0.106376338416817
 -4.862084988970396E-004
   94.9559429949711
 -3.051217066147302E-005
 -5.243734022158845E-003
  2.176530609850995E-003
  2.141192142525880E-009
  1.145956507047931E-012
 -1.494463949297643E-004
 -2.976306978565781E-004
  5.637973687647144E-015
  1.061489544559703E-010
 -4.363780999195673E-011
 -1.583875808629688E-007
  5.052427443312074E-009
  2.704034731944932E-012
 -1.521052830686398E-004
 -3.012124389382927E-004
  1.330354834217172E-014
  2.504725663624024E-010
 -1.029692153262516E-010
  5.331761505538921E-005
 -3.052050732911166E-005
 -1.506649122914134E-005
 -3.043961328758332E-005
  5.638416580099900E-015
 -8.276281174774552E-015
 -1.081395742154347E-015
  4.003571478461733E-015
  1.330459340580155E-014
 -1.952898564813457E-014
 -2.551696970142057E-015
  9.446959127462007E-015
   4.33538418882794
 -5.243208394298223E-003
 -1.506309185919519E-005
   1.46335891839547
  1.061383404003055E-010
 -1.081355192178500E-015
 -8.761589507404770E-008
 -2.957388415555174E-008
  2.504475210881416E-010
 -2.551601287091897E-015
 -2.067413522411717E-007
 -6.978351127136345E-008
   588.405966035698
   158.424015337072
   10.8361703154810
  1.796290017950000E-009
  2.176530609855066E-003
 -3.043126882373527E-005
   1.46335891796550
 -3.201694614183956E-006
 -2.189958552230778E-007
 -3.630251337842867E-017
 -4.363780999203668E-011
  4.002971022780520E-015
 -1.189150462037888E-005
 -7.554824081215738E-006
 -5.167498340680726E-007
 -8.566054778197181E-017
 -1.029692153260630E-010
  9.445542272462284E-015
 -2.805958602968587E-005
   427.291366387335
   3.48521821367142
   3.32069424407601
   158.392022372914
 -8.630745245654584E-006
 -7.039273958954706E-008
 -6.707392610698451E-008
 -3.199314677195099E-006
 -2.037536477018403E-005
 -1.661823752879282E-007
 -1.583473584201577E-007
 -7.552905538003010E-006
   268.923955148508
  4.276544883802262E-005
  4.276544883800398E-005
 -1.424588777922491E-004
   10.8339819969854
 -5.431931762914986E-006
 -2.188330675670712E-007
 -1.282364244577263E-005
 -5.166186057327697E-007
   34.0637357213883
 -6.880454280420786E-007
 -1.624329785643417E-006
   57.6686130917486
  4.276117257825754E-005
  1.282963465140120E-004
 -0.106344071927431
 -1.164831358513878E-006
  2.139386560624465E-009
 -2.749920561197911E-006
  5.050639292792705E-009
  1.435322334783841E-004
  1.282963465140679E-004
 -4.859044258376399E-004
  1.795951687924593E-009
 -2.952879451245872E-013
  1.144822232525814E-012
 -3.627601903623192E-017
 -6.971119936413064E-013
  2.702681642266298E-012
 -8.563996402496546E-017
   79.3319166587262
   3.48521821367143
   94.9458398486465
  4.320032660512423E-005
 -7.552391987852371E-005
 -1.497682175472181E-004
 -7.769881947994255E-005
 -1.523666617484635E-004
   126.722954658724
   3.32069424406792
 -1.425372419275251E-004
 -0.106354941452202
 -4.861966109034047E-004
   94.9442571826356
 -3.051211432308537E-005
 -5.242673296719729E-003
  2.176094571351480E-003
 -6.707392610706632E-008
  2.139600499283991E-009
  1.145104208480330E-012
 -1.497607934274479E-004
 -2.982604755606273E-004
  5.633782752557015E-015
  1.060700492710442E-010
 -4.360537272704143E-011
  5.051144356717774E-009
  2.703347327490156E-012
 -1.523591946899723E-004
 -3.017210528075657E-004
  1.330016987904845E-014
  2.504089578071729E-010
 -1.029430668430854E-010
  5.331753235415877E-005
 -3.052045098627892E-005
 -1.506650203539703E-005
 -3.043957328189070E-005
  5.634225315801326E-015
 -8.270129100433974E-015
 -1.080591890227618E-015
  4.000595472777054E-015
  1.330121467729936E-014
 -1.952402625636053E-014
 -2.551048951543496E-015
  9.444560071132037E-015
   4.33450868614257
 -5.242147774951779E-003
 -1.506310266508878E-005
   1.46306340108363
  1.060594431050364E-010
 -1.080551370396493E-015
 -8.755076696687986E-008
 -2.955190080340337E-008
  2.503839188927681E-010
 -2.550953292768967E-015
 -2.066888503930144E-007
 -6.976578978911438E-008
   588.287140060265
   158.392022372655
   10.8339819969692
  1.795926716056081E-009
  2.176094571347525E-003
 -3.043122882385960E-005
   1.46306340065163
 -3.199314677200335E-006
 -3.627551463514057E-017
 -4.360537272712133E-011
  3.999995463456065E-015
 -2.955190080344427E-008
 -1.188266522899093E-005
 -8.563877324126118E-017
  9.443143575964853E-015
 -6.976578978892128E-008
 -2.805246031389365E-005
   427.221761646610
   3.48465051338284
   3.32015330994758
   158.366220723240
 -8.625569619081469E-006
 -7.035052692638890E-008
 -6.703370366733956E-008
 -3.197396133960991E-006
 -2.037119246752903E-005
 -1.661483457663766E-007
 -1.583149333204717E-007
 -7.551358915013174E-006
   268.880148009682
  4.276541516310235E-005
  4.276541516315824E-005
 -1.424587656157666E-004
   10.8322171643238
 -5.428674378905390E-006
 -2.187018392370192E-007
 -1.282101652362439E-005
 -5.165128167381734E-007
   34.0581868119367
 -6.876328256429030E-007
 -1.623997168507272E-006
   57.6592190088932
  4.276113890667142E-005
  1.282962454894747E-004
 -0.106326817453438
 -1.164132839939863E-006
  2.138103614457015E-009
 -2.749357454006343E-006
  5.049605043097707E-009
  1.435297470025583E-004
  1.282962454893071E-004
 -4.858948411150894E-004
  1.795658688961651E-009
 -2.951107719216757E-013
  1.144135337170234E-012
 -3.625425420120058E-017
 -6.969690959262713E-013
  2.702127631748744E-012
 -8.562241036549971E-017
   79.3220146272307
   3.48465051338284
   94.9364155329219
  4.320032639754627E-005
 -7.035052692638893E-008
 -7.565048986719308E-005
 -1.500221420660175E-004
 -1.661483457663887E-007
 -7.780100450241315E-005
 -1.525716642618201E-004
   126.714396314350
   3.32015330994758
 -1.425371296889047E-004
 -0.106337685252249
 -4.861870236842572E-004
   94.9348328226627
 -3.051206888735961E-005
 -5.241817844092463E-003
  2.175742915507465E-003
 -6.703370366717607E-008
  2.138317424823262E-009
  1.144417143941161E-012
 -1.500147052121065E-004
 -2.987690897570248E-004
  5.630404305894612E-015
  1.060064412803966E-010
 -4.357922401121403E-011
  5.050110003599864E-009
  2.702793180514365E-012
 -1.525641869231969E-004
 -3.021316746628452E-004
  1.329744634976692E-014
  2.503576801232304E-010
 -1.029219873881656E-010
  5.331746565735354E-005
 -3.052040554685719E-005
 -1.506651075045783E-005
 -3.043954101786382E-005
  5.630846603739516E-015
 -8.265169716748017E-015
 -1.079943879519946E-015
  3.998196419541821E-015
  1.329849093408829E-014
 -1.952002827018112E-014
 -2.550526554947418E-015
  9.442626085200824E-015
   4.33380261171709
 -5.241292407852646E-003
 -1.506311137981129E-005
   1.46282507261281
  1.059958414752610E-010
 -1.079903383988697E-015
 -8.749826511887928E-008
 -2.953417932095777E-008
  2.503326463364695E-010
 -2.550430915765432E-015
 -2.066465263193631E-007
 -6.975150371436822E-008
   588.191309421025
   158.366220723240
   10.8322171643238
  1.795633721166188E-009
 -3.043119656479924E-005
   1.46282507217676
 -3.197396133955758E-006
 -2.187018392366922E-007
 -3.625375010274682E-017
 -4.357922401113419E-011
  3.997596770013282E-015
 -2.953417932095776E-008
 -1.187553951319527E-005
 -7.551358915013176E-006
 -8.562121982603910E-017
  9.441209880080573E-015
 -6.975150371427169E-008
 -2.804671595761421E-005
   427.165630693373
   3.48419270607668
   3.31971708752929
   158.345413646306
 -8.621397316433378E-006
 -7.031649742253563E-008
 -6.700127857075572E-008
 -3.195849510969310E-006
 -2.036782894674352E-005
 -1.661209127124594E-007
 -1.582887936783737E-007
 -7.550112097846397E-006
   268.844820869730
  4.276538801890088E-005
  4.276538801897538E-005
 -1.424586751936566E-004
   10.8307939604322
 -5.426048456843738E-006
 -2.185960502460161E-007
 -1.281889962450808E-005
 -5.164275344581396E-007
   34.0537120366246
 -6.873002085067687E-007
 -1.623729027687673E-006
   57.6516433924335
  4.276111176515215E-005
  1.282961640569261E-004
 -0.106312903027081
 -1.163569733063606E-006
  2.137069374525986E-009
 -2.748903502580216E-006
  5.048771277983503E-009
  1.435277418863349E-004
  1.282961640567026E-004
 -4.858871118903962E-004
  1.795422407754879E-009
 -2.949679448206707E-013
  1.143581600654601E-012
 -3.623670861121077E-017
 -6.968538983349057E-013
  2.701681013846164E-012
 -8.560825940936026E-017
   79.3140293888552
   3.48419270607693
   94.9288155363349
  4.320032623006424E-005
 -7.575267495573040E-005
 -1.502271447117636E-004
 -1.661209127128696E-007
 -7.788347994990878E-005
 -1.527371250344215E-004
   126.707494658483
   3.31971708752929
 -1.425370392171738E-004
 -0.106323769434344
 -4.861792924467380E-004
   94.9272327904122
 -3.051203224687058E-005
 -5.241127986329533E-003
  2.175459331690614E-003
  2.137283081461657E-009
  1.143863271037796E-012
 -1.502196975773690E-004
 -2.991797118770367E-004
  5.627680789849276E-015
  1.059551640522675E-010
 -4.355814436878827E-011
 -1.582887936789529E-007
  5.049276155116842E-009
  2.702346452609733E-012
 -1.527296393981116E-004
 -3.024630934672114E-004
  1.329525076423765E-014
  2.503163423844980E-010
 -1.029049940896415E-010
  5.331741187140007E-005
 -3.052036890363413E-005
 -1.506651777848080E-005
 -3.043951499959878E-005
  5.628122873754924E-015
 -8.261171737100695E-015
 -1.079421489283533E-015
  3.996262436062200E-015
  1.329629517605149E-014
 -1.951680527537724E-014
 -2.550105422557203E-015
  9.441066993605417E-015
   4.33323321615882
  4.320032623016016E-005
 -5.240602619075892E-003
 -1.506311840756585E-005
   1.46263287874512
  0.000000000000000E+000
  1.059445693742388E-010
 -1.079381013330768E-015
 -8.745594104516931E-008
 -2.951989324612681E-008
  2.502913127307291E-010
 -2.550009799173551E-015
 -2.066124065746644E-007
 -6.973998693008840E-008
   588.114029266581
   158.345413646306
   10.8307939604322
  1.795397443248323E-009
 -3.043117055029229E-005
   1.46263287831109
 -3.623620475670077E-017
 -4.355814436878828E-011
  3.995663076601849E-015
 -2.951989324604511E-008
 -1.186979515691743E-005
 -7.550112097846398E-006
 -8.560706906658389E-017
  9.439651022317102E-015
 -6.973998693008842E-008
 -2.804208511860767E-005
   427.120367802092
   3.48382353931030
   3.31936532638615
   158.328635230704
 -8.618033795640178E-006
 -7.028906438278944E-008
 -6.697513893136564E-008
 -3.194602693795374E-006
 -2.036511740166231E-005
 -1.660987972075013E-007
 -1.582677208741126E-007
 -7.549106960328156E-006
   268.816333761917
  4.276536613798017E-005
  4.276536613799879E-005
 -1.424586023046213E-004
   10.8296463169372
 -5.423931557820016E-006
 -2.185107679693339E-007
 -1.281719305936730E-005
 -5.163587830634264E-007
   34.0501036662429
 -6.870320676871627E-007
 -1.623512862557403E-006
   57.6455345650659
  4.276108988646662E-005
  1.282960984139964E-004
 -0.106301682708543
 -1.163115781890991E-006
  2.136235617302067E-009
 -2.748537543865891E-006
  5.048099127652607E-009
  1.435261250244497E-004
  1.282960984139405E-004
 -4.858808792787607E-004
  1.795231875435826E-009
 -2.948528041637004E-013
  1.143135203678554E-012
 -3.622256416114226E-017
 -6.967610303658226E-013
  2.701320967287081E-012
 -8.559685144018454E-017
   79.3075902503988
   3.48382353931890
   94.9226870493384
  4.320032609500428E-005
 -7.028906438279453E-008
 -7.583515045740812E-005
 -1.503926055921201E-004
 -1.660987972067051E-007
 -7.795003268525673E-005
 -1.528706415558738E-004
   126.701929299798
   3.31936532639830
 -1.425369662882220E-004
 -0.106312547993815
 -4.861730582110836E-004
   94.9211042746185
 -3.051200270072189E-005
 -5.240571698660217E-003
  2.175230655305691E-003
  2.136449240862887E-009
  1.143416764110714E-012
 -1.503851501605659E-004
 -2.995111308968701E-004
  5.625485214999972E-015
  1.059138266814374E-010
 -4.354115091885202E-011
 -1.582677208733406E-007
  5.048603937566217E-009
  2.701986317360831E-012
 -1.528631492238330E-004
 -3.027305273819054E-004
  1.329348076503747E-014
  2.502830174411476E-010
 -1.028912947256777E-010
  5.331736849949978E-005
 -3.052033935512057E-005
 -1.506652344573948E-005
 -3.043949401884162E-005
  5.625927126439296E-015
 -8.257948747596203E-015
 -1.079000362018608E-015
  3.994703346481365E-015
  1.329452503786177E-014
 -1.951420701720114E-014
 -2.549765921317497E-015
  9.439810112110089E-015
   4.33277406683485
  4.320032609510020E-005
 -5.240046387021417E-003
 -1.506312407461668E-005
   1.46247789740747
  1.059032361369377E-010
 -1.078959901858808E-015
 -8.742182130037747E-008
 -2.950837646177622E-008
  2.502579911199242E-010
 -2.549670310656882E-015
 -2.065849005088242E-007
 -6.973070252807960E-008
   588.051712076768
   158.328635230704
   10.8296463169372
  1.795206913576893E-009
 -3.043114957272498E-005
   1.46247789697547
 -3.622206050337539E-017
  3.994104220848080E-015
 -2.950837646173538E-008
 -1.186516431793148E-005
 -7.549106960315804E-006
 -5.163587830641984E-007
 -8.559566125603437E-017
 -1.028912947258662E-010
  9.438394329345615E-015
 -6.973070252827261E-008
 -2.803835190888569E-005
   427.083870308086
   3.48352586364375
   3.31908168565849
   158.315106043777
 -8.615322250599633E-006
 -7.026694888904167E-008
 -6.695406612867801E-008
 -3.193597556282375E-006
 -2.036293143734809E-005
 -1.660809683662370E-007
 -1.582507326261814E-007
 -7.548296649335668E-006
   268.793363332956
  4.276534849951674E-005
  4.276534849949811E-005
 -1.424585435480269E-004
   10.8287209206603
 -5.422224992756780E-006
 -2.184420165778577E-007
 -1.281581727896991E-005
 -5.163033578003423E-007
   34.0471940758620
 -6.868159025568957E-007
 -1.623338596866648E-006
   57.6406087443808
  4.276107224980995E-005
  1.282960454984943E-004
 -0.106292635264398
 -1.162749823383462E-006
  2.135563473315306E-009
 -2.748242519185980E-006
  5.047557260693362E-009
  1.435248212928277E-004
  1.282960454985502E-004
 -4.858758537005023E-004
  1.795078240819078E-009
 -2.947599820992058E-013
  1.142775335234385E-012
 -3.621116143763019E-017
 -6.966861630852870E-013
  2.701030708890091E-012
 -8.558765468858950E-017
   79.3023980853885
   3.48352586362705
   94.9177453766207
  4.320032598622728E-005
 -7.026694888921517E-008
 -7.590170323587593E-005
 -1.505261221997530E-004
 -1.660809683662490E-007
 -7.800372715734212E-005
 -1.529783618806493E-004
   126.697441702862
   3.31908168564230
 -1.425369074993665E-004
 -0.106303499644730
 -4.861680313232953E-004
   94.9161625786708
 -3.051197887638103E-005
 -5.240123139044841E-003
  2.175046263303828E-003
 -6.695406612892297E-008
  2.135777029664981E-009
  1.143056807029988E-012
 -1.505186600724684E-004
 -2.997785649838988E-004
  5.623715224432495E-015
  1.058805020344929E-010
 -4.352745143316113E-011
 -1.582507326259884E-007
  5.048062016403261E-009
  2.701695987476529E-012
 -1.529708641466058E-004
 -3.029462912019867E-004
  1.329205384605864E-014
  2.502561518960025E-010
 -1.028802507195626E-010
  5.331733352686886E-005
 -3.052031552892848E-005
 -1.506652801553732E-005
 -3.043947710114636E-005
  5.624156996815900E-015
 -8.255350493625450E-015
 -1.078660864924658E-015
  3.993446466586470E-015
  1.329309800677772E-014
 -1.951211238122979E-014
 -2.549492225859209E-015
  9.438796852852940E-015
   4.33240383420635
 -5.239597872265053E-003
 -1.506312864423373E-005
   1.46235292902598
  1.058699148220019E-010
 -1.078620417498130E-015
 -8.739431523442963E-008
 -2.949909205965623E-008
  2.502311282603169E-010
 -2.549396625464191E-015
 -2.065627259630647E-007
 -6.972321772838804E-008
   588.001462940412
   158.315106043518
   10.8287209206765
  1.795053281096442E-009
  2.175046263307820E-003
 -3.043113265761534E-005
   1.46235292859803
 -3.193597556282376E-006
 -3.621065793837978E-017
 -4.352745143316114E-011
  3.992847529459772E-015
 -2.949909205965624E-008
 -1.186143110820734E-005
 -7.548296649348020E-006
 -8.558646463241676E-017
  9.437381222050936E-015
 -6.972321772848453E-008
 -2.803534230984747E-005
   427.054441793998
   3.48328584296820
   3.31885298158054
   158.304197243316
 -8.613136286226467E-006
 -7.024912005710925E-008
 -6.693707788239468E-008
 -3.192787245277546E-006
 -2.036116916837287E-005
 -1.660665952073843E-007
 -1.582370371320010E-007
 -7.547643397178636E-006
   268.774841907557
  4.276533428057466E-005
  4.276533428063054E-005
 -1.424584961824484E-004
   10.8279747587862
 -5.420849212398619E-006
 -2.183865913167930E-007
 -1.281470815972889E-005
 -5.162586753604533E-007
   34.0448480264053
 -6.866416368661422E-007
 -1.623198108291640E-006
   57.6366369760248
  4.276105803230211E-005
  1.282960028418916E-004
 -0.106285340164909
 -1.162454798870676E-006
  2.135021611478840E-009
 -2.748004677779252E-006
  5.047120421297088E-009
  1.435237700837061E-004
  1.282960028417240E-004
 -4.858718015308750E-004
  1.794954362838231E-009
 -2.946851518264534E-013
  1.142485220447861E-012
 -3.620196891504346E-017
 -6.966258069955335E-013
  2.700796709995819E-012
 -8.558024050269235E-017
   79.2982115594912
   3.48328584296845
   94.9137608266114
  4.320032589845749E-005
 -7.024912005677252E-008
 -7.595539774293084E-005
 -1.506338425945159E-004
 -1.660665952073963E-007
 -7.804704139903842E-005
 -1.530652575172588E-004
   126.693823281568
   3.31885298157649
 -1.425368601076737E-004
 -0.106296203815296
 -4.861639780987359E-004
   94.9121780100629
 -3.051195966642308E-005
 -5.239761458243430E-003
  2.174897585080744E-003
 -6.693707788206818E-008
  2.135235113640345E-009
  1.142766620783063E-012
 -1.506263750651346E-004
 -2.999943289439286E-004
  5.622288312379276E-015
  1.058536367275073E-010
 -4.351640732825920E-011
  5.047625133335980E-009
  2.701461930937767E-012
 -1.530577554256869E-004
 -3.031203430070810E-004
  1.329090350017094E-014
  2.502344935741696E-010
 -1.028713473218871E-010
  5.331730532785735E-005
 -3.052029631749958E-005
 -1.506653170021128E-005
 -3.043946346017078E-005
  5.622729972693740E-015
 -8.253255861076980E-015
 -1.078387172788445E-015
  3.992433208613188E-015
  1.329194757054679E-014
 -1.951042373884011E-014
 -2.549271579511680E-015
  9.437979988971453E-015
   4.33210530969059
  4.320032589845750E-005
 -5.239236227611977E-003
 -1.506313232878384E-005
   1.46225216501561
  1.058430522014676E-010
 -1.078346735621595E-015
 -8.737214068865612E-008
 -2.949160725975691E-008
  2.502094721044812E-010
 -2.549175987400272E-015
 -2.065448494071410E-007
 -6.971718367279060E-008
   587.960946254958
   158.304197243575
   10.8279747587862
  1.794929404840176E-009
  2.174897585080802E-003
 -3.043111901868071E-005
   1.46225216458563
 -3.192787245272321E-006
 -2.183865913171196E-007
 -3.620146554361236E-017
 -4.351640732833891E-011
  3.991834423462010E-015
 -2.949160725983854E-008
 -1.185842150915850E-005
 -7.547643397190986E-006
 -5.162586753612252E-007
 -8.557905054924107E-017
 -1.028713473220755E-010
  9.436564480647867E-015
 -6.971718367288709E-008
 -2.803291604751108E-005
   427.030713789360
   3.48309231599418
   3.31866857909252
   158.295401554149
 -8.611374017284860E-006
 -7.023474690541795E-008
 -6.692338238952820E-008
 -3.192133993125735E-006
 -2.035974846431673E-005
 -1.660550078698065E-007
 -1.582259961136863E-007
 -7.547116759088606E-006
   268.759908212365
  4.276532281805169E-005
  4.276532281803306E-005
 -1.424584579989358E-004
   10.8273731337211
 -5.419740093215403E-006
 -2.183419088788042E-007
 -1.281381401120848E-005
 -5.162226533204438E-007
   34.0429564232562
 -6.865011482911346E-007
 -1.623084849367424E-006
   57.6334345671615
  4.276104657087810E-005
  1.282959684540992E-004
 -0.106279458177356
 -1.162216957599191E-006
  2.134584776225769E-009
 -2.747812935059043E-006
  5.046768250604163E-009
  1.435229225074713E-004
  1.282959684541551E-004
 -4.858685343177390E-004
  1.794854480942685E-009
 -2.946248255784452E-013
  1.142251337337596E-012
 -3.619455813880856E-017
 -6.965771492022558E-013
  2.700608065061853E-012
 -8.557426334351483E-017
   79.2948359928025
   3.48309231599443
   94.9105481120185
  4.320032582766612E-005
 -7.023474690542304E-008
 -7.599871201290335E-005
 -1.507207382877833E-004
 -1.660550078697944E-007
 -7.808197806418022E-005
 -1.531353462221790E-004
   126.690905773981
   3.31866857909252
 -1.425368219029270E-004
 -0.106290321239752
 -4.861607100334176E-004
   94.9089652801122
 -3.051194417747818E-005
 -5.239469837530585E-003
  2.174777706868896E-003
 -6.692338238944658E-008
  2.134798234696553E-009
  1.142532680068191E-012
 -1.507132664007129E-004
 -3.001683808623186E-004
  5.621137972127227E-015
  1.058319785996188E-010
 -4.350750385149706E-011
 -1.582259961134934E-007
  5.047272927426687E-009
  2.701273239544328E-012
 -1.531278406162897E-004
 -3.032607304522242E-004
  1.328997611560622E-014
  2.502170330926490E-010
 -1.028641695906628E-010
  5.331728259103376E-005
 -3.052028082737200E-005
 -1.506653467113831E-005
 -3.043945246158842E-005
  5.621579542070819E-015
 -8.251567221499560E-015
 -1.078166529145517E-015
  3.991616345768794E-015
  1.329102011313908E-014
 -1.950906239105018E-014
 -2.549093699091955E-015
  9.437321450517553E-015
   4.33186461147288
  4.320032582757020E-005
 -5.238944636065963E-003
 -1.506313529956569E-005
   1.46217091970105
  1.058213962388804E-010
 -1.078126100253428E-015
 -8.735426413288181E-008
 -2.948557320418542E-008
  2.501920133695916E-010
 -2.548998113628936E-015
 -2.065304377049929E-007
 -6.971231914453291E-008
   587.928277936701
   158.295401554408
   10.8273731337373
  1.794829524325695E-009
  2.174777706872848E-003
 -3.043110802161291E-005
   1.46217091927107
 -3.192133993130958E-006
 -3.619405487046350E-017
 -4.350750385149707E-011
  3.991017683128105E-015
 -2.948557320422622E-008
 -1.185599524682917E-005
 -7.547116759088605E-006
 -8.557307347329493E-017
 -1.028641695908513E-010
  9.435906041001554E-015
 -6.971231914453293E-008
 -2.803096004603314E-005
   427.011582508512
   3.48293628015925
   3.31851990010276
   158.288309816091
 -8.609953313235059E-006
 -7.022315957398169E-008
 -6.691234137219474E-008
 -3.191607355023419E-006
 -2.035860311777709E-005
 -1.660456663626308E-007
 -1.582170950391454E-007
 -7.546692192743798E-006
   268.747867557494
  4.276531357751725E-005
 -1.424584272170971E-004
   10.8268880588805
 -5.418845944729966E-006
 -2.183058868402541E-007
 -1.281309316446185E-005
 -5.161936129883974E-007
   34.0414312722104
 -6.863878893669312E-007
 -1.622993542021346E-006
   57.6308525471772
  4.276103733121911E-005
  1.282959407325518E-004
 -0.106274715682045
 -1.162025214985318E-006
  2.134232608859360E-009
 -2.747658355462356E-006
  5.046484336799493E-009
  1.435222391333156E-004
 -4.858659000623510E-004
  1.794773948764061E-009
 -2.945761918398498E-013
  1.142062785752157E-012
 -3.618858372868639E-017
 -6.965379221546591E-013
  2.700455982865518E-012
 -8.556944466413073E-017
   79.2921143605058
   3.48293628015900
   94.9079577827078
  4.320032577049585E-005
 -7.022315957398678E-008
 -7.603364870076584E-005
 -1.507908270384977E-004
 -1.660456663626188E-007
 -7.811015485539615E-005
 -1.531918734377338E-004
   126.688553462536
   3.31851990009871
 -1.425367911040637E-004
 -0.106285578270155
 -4.861580750924348E-004
   94.9063749389489
 -3.051193168925161E-005
 -5.239234711248062E-003
  2.174681052146364E-003
 -6.691234137219472E-008
  2.134446032118877E-009
  1.142344082037542E-012
 -1.507833516367383E-004
 -3.003087683990309E-004
  5.620210592078148E-015
  1.058145182734019E-010
 -4.350032605626727E-011
  5.046988985231202E-009
  2.701121119898640E-012
 -1.531843649967908E-004
 -3.033739542100911E-004
  1.328922847459617E-014
  2.502029567608860E-010
 -1.028583830306593E-010
  5.331726425911362E-005
 -3.052026833812379E-005
 -1.506653706650351E-005
 -3.043944359357514E-005
  5.620652089180673E-015
 -8.250205875887358E-015
 -1.077988650889766E-015
  3.990957808184881E-015
  1.329027241331511E-014
 -1.950796489648490E-014
 -2.548950295039907E-015
  9.436790548457404E-015
   4.33167054267984
  4.320032577059178E-005
 -5.238709533309313E-003
 -1.506313769488709E-005
   1.46210541369056
  1.058039376587003E-010
 -1.077948228671890E-015
 -8.733985243082010E-008
 -2.948070867587265E-008
  2.501779384449471E-010
 -2.548854714982849E-015
 -2.065188192451716E-007
 -6.970839744771226E-008
   587.901938310819
   158.288309816091
   10.8268880588805
  1.794748993269387E-009
  2.174681052150375E-003
 -3.043109915507198E-005
   1.46210541325856
 -3.191607355028641E-006
 -2.183058868405805E-007
 -3.618808054325652E-017
 -4.350032605634695E-011
  3.990359244296933E-015
 -2.948070867591345E-008
 -1.185403924534047E-005
 -5.161936129883973E-007
 -8.556825486111702E-017
 -1.028583830304708E-010
  9.435375218571635E-015
 -6.970839744771225E-008
 -2.802938315214927E-005
   426.996157735478
   3.48281047481478
   3.31840002627649
   158.282592036146
 -8.608807966700272E-006
 -7.021381807174705E-008
 -6.690344029887806E-008
 -3.191182788683806E-006
 -2.035767975645063E-005
 -1.660381353785324E-007
 -1.582099191254524E-007
 -7.546349913664298E-006
   268.738159667821
  4.276530612815975E-005
  4.276530612823425E-005
 -1.424584024018186E-004
   10.8264969628007
 -5.418125098001261E-006
 -2.182768465084438E-007
 -1.281251202851354E-005
 -5.161702011023048E-007
   34.0402016050016
 -6.862965820208480E-007
 -1.622919931395471E-006
   57.6287707695779
  4.276102988266255E-005
  1.282959183847028E-004
 -0.106270892000988
 -1.161870635474583E-006
  2.133948697747291E-009
 -2.747533735684850E-006
  5.046255449715919E-009
  1.435216881596102E-004
  1.282959183844793E-004
 -4.858637761786322E-004
  1.794709018969544E-009
 -2.945369841864100E-013
  1.141910778818638E-012
 -3.618376726546069E-017
 -6.965062978955374E-013
  2.700333376477204E-012
 -8.556555991674080E-017
   79.2899200187420
   3.48281047481453
   94.9058693055960
  4.320032572454859E-005
 -7.021381807174194E-008
 -7.606182551076424E-005
 -1.508473542907695E-004
 -1.660381353789303E-007
 -7.813287802281887E-005
 -1.532374597534693E-004
   126.686656889572
   3.31840002627649
 -1.425367662755418E-004
 -0.106281754206702
 -4.861559506570827E-004
   94.9042864518453
 -3.051192162048649E-005
 -5.239045138503998E-003
  2.174603123382914E-003
 -6.690344029879647E-008
  2.134162092615993E-009
  1.142192037665917E-012
 -1.508398760547628E-004
 -3.004219922303148E-004
  5.619462954653293E-015
  1.058004420667283E-010
 -4.349453944444023E-011
 -1.582099191258382E-007
  5.046760075259376E-009
  2.700998483315350E-012
 -1.532299490264917E-004
 -3.034652633502726E-004
  1.328862573745638E-014
  2.501916086311893E-010
 -1.028537179917249E-010
  5.331724947880172E-005
 -3.052025826843650E-005
 -1.506653899783600E-005
 -3.043943644372511E-005
  5.619904393028321E-015
 -8.249108383106033E-015
 -1.077845248582974E-015
  3.990426906792013E-015
  1.328966962884345E-014
 -1.950708011260887E-014
 -2.548834684824847E-015
  9.436362543115239E-015
   4.33151407291416
  4.320032572454860E-005
 -5.238519979512613E-003
 -1.506313962612738E-005
   1.46205259886104
  1.057898628598408E-010
 -1.077804831733179E-015
 -8.732823397091536E-008
 -2.947678697899607E-008
  2.501665914499524E-010
 -2.548739109097057E-015
 -2.065094526156288E-007
 -6.970523583401790E-008
   587.880701742405
   158.282592036146
   10.8264969628007
  1.794684064381982E-009
  2.174603123378963E-003
 -3.043109200632316E-005
   1.46205259842904
 -3.618326414705299E-017
 -4.349453944451992E-011
  3.989828422545568E-015
 -2.947678697899608E-008
 -1.185246235146184E-005
 -7.546349913676647E-006
 -5.161702011030765E-007
 -8.556437016778028E-017
  9.434947277387043E-015
 -6.970523583411436E-008
 -2.802811188372582E-005
   426.983721556495
   3.48270904461472
   3.31830337834958
   158.277982092186
 -8.607884605340087E-006
 -7.020628709139003E-008
 -6.689626438563796E-008
 -3.190840509604301E-006
 -2.035693535415960E-005
 -1.660320639942398E-007
 -1.582041339942309E-007
 -7.546073972585514E-006
   268.730332708918
  4.276530012272596E-005
  4.276530012278184E-005
 -1.424583823967507E-004
   10.8261816426503
 -5.417543962083103E-006
 -2.182534346247850E-007
 -1.281204352402836E-005
 -5.161513267366070E-007
   34.0392101892812
 -6.862229713949716E-007
 -1.622860587436898E-006
   57.6270923421903
  4.276102387775030E-005
  1.282959003683455E-004
 -0.106267809169089
 -1.161746015769914E-006
  2.133719812824236E-009
 -2.747433268794067E-006
  5.046070923833038E-009
  1.435212439402741E-004
  1.282959003681779E-004
 -4.858620638104884E-004
  1.794656669516091E-009
 -2.945053755635727E-013
  1.141788233103722E-012
 -3.617988430496484E-017
 -6.964808028153291E-013
  2.700234532763034E-012
 -8.556242808271928E-017
   79.2881508371350
   3.48270904462307
   94.9041854769732
  4.320032568742628E-005
 -7.020628709138492E-008
 -7.608454869277924E-005
 -1.508929406360291E-004
 -1.660320639942519E-007
 -7.815120200175601E-005
 -1.532742205627429E-004
   126.685127783171
   3.31830337835767
 -1.425367462591677E-004
 -0.106278671066496
 -4.861542378426596E-004
   94.9026026152962
 -3.051191350248130E-005
 -5.238892296010439E-003
  2.174540293532246E-003
  2.133933184804685E-009
  1.142069461771265E-012
 -1.508854601136330E-004
 -3.005133014295376E-004
  5.618860220495018E-015
  1.057890940381847E-010
 -4.348987436405509E-011
 -1.582041339944238E-007
  5.046575530930303E-009
  2.700899615243236E-012
 -1.532667079922211E-004
 -3.035388950204200E-004
  1.328813981839679E-014
  2.501824599123675E-010
 -1.028499570961289E-010
  5.331723756205752E-005
 -3.052025014982751E-005
 -1.506654055494028E-005
 -3.043943067924605E-005
  5.619301611487105E-015
 -8.248223600731123E-015
 -1.077729639775344E-015
  3.989998901985312E-015
  1.328918367164582E-014
 -1.950636681107553E-014
 -2.548741481310975E-015
  9.436017490602162E-015
   4.33138791960991
 -5.238367152301658E-003
 -1.506314118313982E-005
   1.46201001705403
  1.057785159658398E-010
 -1.077689227272729E-015
 -8.731886734121013E-008
 -2.947362536524598E-008
  2.501574436455362E-010
 -2.548645909083775E-015
 -2.065019013565692E-007
 -6.970268698093460E-008
   587.863579818955
   158.277982092445
   10.8261816426665
  1.794631715657212E-009
  2.174540293532188E-003
 -3.043108624257365E-005
   1.46201001662405
 -3.617938124063444E-017
 -4.348987436397542E-011
  3.989400481933371E-015
 -2.947362536524597E-008
 -1.185119108304070E-005
 -7.546073972597860E-006
 -5.161513267358354E-007
 -8.556123837717347E-017
  9.434602276636308E-015
 -6.970268698083814E-008
 -2.802708700315142E-005
   426.973695043101
   3.48262726779579
   3.31822545717369
   158.274265382899
 -8.607140203068169E-006
 -7.020021571005436E-008
 -6.689047925500247E-008
 -3.190564568525489E-006
 -2.035633522506632E-005
 -1.660271693093557E-007
 -1.581994700840368E-007
 -7.545851511890537E-006
   268.724022321620
  4.276529528127874E-005
  4.276529528126011E-005
 -1.424583662690987E-004
   10.8259274197844
 -5.417075457627720E-006
 -2.182345602585520E-007
 -1.281166582078565E-005
 -5.161361104265306E-007
   34.0384108728368
 -6.861636274363930E-007
 -1.622812744977956E-006
   57.6257391312955
  4.276101903675011E-005
  1.282958858437803E-004
 -0.106265323674648
 -1.161645548933729E-006
  2.133535288688245E-009
 -2.747352273470457E-006
  5.045922161057735E-009
  1.435208857948906E-004
  1.282958858438362E-004
 -4.858606832390021E-004
  1.794614463437635E-009
 -2.944798930932821E-013
  1.141689438306403E-012
 -3.617675391145964E-017
 -6.964602489613875E-013
  2.700154846034624E-012
 -8.555990323233618E-017
   79.2867244567746
   3.48262726779604
   94.9028279113774
  4.320032565749822E-005
 -7.020021571022261E-008
 -7.610287268380385E-005
 -1.509297014693749E-004
 -7.816597774737068E-005
 -1.533038630340781E-004
   126.683894960427
   3.31822545717774
 -1.425367301225004E-004
 -0.106276185323613
 -4.861528569104755E-004
   94.9012450433212
 -3.051190695757319E-005
 -5.238769068679896E-003
  2.174489637755595E-003
 -6.689047925516562E-008
  2.133748642216474E-009
  1.141970642641791E-012
 -1.509222191035221E-004
 -3.005869331478227E-004
  5.618374303787992E-015
  1.057799454005784E-010
 -4.348611343496049E-011
 -1.581994700838439E-007
  5.046426753272988E-009
  2.700819908888291E-012
 -1.532963489767953E-004
 -3.035982686855063E-004
  1.328774807565719E-014
  2.501750843132486E-010
 -1.028469251029643E-010
  5.331722795456309E-005
 -3.052024360446352E-005
 -1.506654181030277E-005
 -3.043942603168677E-005
  5.618815656615661E-015
 -8.247510300308448E-015
 -1.077636437412721E-015
  3.989653849910769E-015
  1.328879189814602E-014
 -1.950579175501185E-014
 -2.548666341665593E-015
  9.435739312995785E-015
   4.33128621008786
  4.320032565749821E-005
 -5.238243937284556E-003
 -1.506314243852706E-005
   1.46197568600855
  1.057693682430158E-010
 -1.077596028402512E-015
 -8.731131608249054E-008
 -2.947107651210676E-008
  2.501500687846586E-010
 -2.548570772234328E-015
 -2.064958136133774E-007
 -6.970063212310561E-008
   587.849775483743
   158.274265383158
   10.8259274197682
  1.794589510162843E-009
 -3.043108159575484E-005
   1.46197568557452
 -3.190564568530710E-006
 -2.182345602588783E-007
 -3.617625089067181E-017
  3.989055481595080E-015
 -2.947107651214755E-008
 -1.185016620246559E-005
 -7.545851511878190E-006
 -8.555871356186328E-017
 -1.028469251027759E-010
  9.434324140722150E-015
 -6.970063212300914E-008
 -2.802626075551777E-005
   426.965611371865
   3.48256133690085
   3.31816263482366
   158.271268862616
 -8.606540073977602E-006
 -7.019532102800799E-008
 -6.688581534509083E-008
 -3.190342107805830E-006
 -2.035585140661568E-005
 -1.660232232608258E-007
 -1.581957100831921E-007
 -7.545672166121366E-006
   268.718934701357
  4.276529137823295E-005
  4.276529137825157E-005
 -1.424583532673962E-004
   10.8257224577982
 -5.416697754387867E-006
 -2.182193439489215E-007
 -1.281136131994871E-005
 -5.161238431783811E-007
   34.0377664403113
 -6.861157849774536E-007
 -1.622774174833888E-006
   57.6246481326935
  4.276101513424448E-005
  1.282958741347547E-004
 -0.106263319795624
 -1.161564553655851E-006
  2.133386527320685E-009
 -2.747286975793671E-006
  5.045802229901306E-009
  1.435205970488206E-004
  1.282958741346988E-004
 -4.858595701844496E-004
  1.794580435660466E-009
 -2.944593494011066E-013
  1.141609791014766E-012
 -3.617423022224609E-017
 -6.964436786370695E-013
  2.700090603342022E-012
 -8.555786772132381E-017
   79.2855744665871
   3.48256133690085
   94.9017334018397
  4.320032563342148E-005
 -7.019532102801309E-008
 -7.611764843917326E-005
 -1.509593439600134E-004
 -1.660232232610188E-007
 -7.817789186475828E-005
 -1.533277646157751E-004
   126.682901022274
   3.31816263481961
 -1.425367171141483E-004
 -0.106274181244060
 -4.861517435665755E-004
   94.9001505284871
 -3.051190168078352E-005
 -5.238669719150963E-003
  2.174448797578070E-003
 -6.688581534517240E-008
  2.133599865975480E-009
  1.141890975727434E-012
 -1.509518601075828E-004
 -3.006463068515062E-004
  5.617982562993246E-015
  1.057725698677976E-010
 -4.348308141450368E-011
 -1.581957100835779E-007
  5.046306810111623E-009
  2.700755650372454E-012
 -1.533202493602557E-004
 -3.036461433760814E-004
  1.328743225634730E-014
  2.501691381750622E-010
 -1.028444807377414E-010
  5.331722020855730E-005
 -3.052023832725481E-005
 -1.506654282247326E-005
 -3.043942228466027E-005
  5.618423885061761E-015
 -8.246935245236915E-015
 -1.077561298667175E-015
  3.989375672651378E-015
  1.328847605402711E-014
 -1.950532815018461E-014
 -2.548605764761058E-015
  9.435515048765581E-015
   4.33120420887484
  4.320032563342149E-005
 -5.238144597705333E-003
 -1.506314345061209E-005
   1.46194800730609
  1.057619934475635E-010
 -1.077520892476899E-015
 -8.730522833903519E-008
 -2.946902165422219E-008
  2.501441232402744E-010
 -2.548510197622799E-015
 -2.064909057315703E-007
 -6.969897551581621E-008
   587.838646021496
   158.271268862357
   10.8257224577982
  1.794555482858103E-009
  2.174448797574099E-003
 -3.043107784926092E-005
   1.46194800687207
 -3.190342107811051E-006
 -2.182193439485953E-007
 -3.617372723649315E-017
  3.988777346061521E-015
 -2.946902165418140E-008
 -1.184933995480764E-005
 -7.545672166146059E-006
 -5.161238431783812E-007
 -8.555667807919373E-017
 -1.028444807379298E-010
  9.434099910144249E-015
 -6.969897551591266E-008
 -2.802559464235045E-005
   426.959094129235
   3.48250818190070
   3.31811198598945
   158.268852997813
 -8.606056255503477E-006
 -7.019137498084019E-008
 -6.688205534449898E-008
 -3.190162762059464E-006
 -2.035546135607770E-005
 -1.660200419874224E-007
 -1.581926788008469E-007
 -7.545527579033733E-006
   268.714832943814
  4.276528823164522E-005
  4.276528823160796E-005
 -1.424583427856498E-004
   10.8255572126736
 -5.416393253566752E-006
 -2.182070767019904E-007
 -1.281111583385109E-005
 -5.161139534233635E-007
   34.0372468838682
 -6.860772148333890E-007
 -1.622743079898055E-006
   57.6237685442733
  4.276101198789891E-005
  1.282958646948239E-004
 -0.106261704222007
 -1.161499256018225E-006
  2.133266597294065E-009
 -2.747234333342335E-006
  5.045705542371045E-009
  1.435203642551996E-004
  1.282958646949357E-004
 -4.858586728155775E-004
  1.794553001674517E-009
 -2.944427872706213E-013
  1.141545580116501E-012
 -3.617219564778119E-017
 -6.964303197765119E-013
  2.700038811407218E-012
 -8.555622670917828E-017
   79.2846473181921
   3.48250818190475
   94.9008509829327
  4.320032561394905E-005
 -7.612956256402891E-005
 -1.509832455572767E-004
 -1.660200419878202E-007
 -7.818749826062401E-005
 -1.533470365398229E-004
   126.682099686352
   3.31811198599754
 -1.425367066263297E-004
 -0.106272565508620
 -4.861508459634562E-004
   94.8992681056600
 -3.051189742650846E-005
 -5.238589621278706E-003
  2.174415871267034E-003
 -6.688205534441743E-008
  2.133479923953434E-009
  1.141826749013988E-012
 -1.509757605059795E-004
 -3.006941815732105E-004
  5.617666745203215E-015
  1.057666237817681E-010
 -4.348063702801298E-011
  5.046210112912804E-009
  2.700703845679940E-012
 -1.533395203176841E-004
 -3.036847448888105E-004
  1.328717764540539E-014
  2.501643444461704E-010
 -1.028425101111152E-010
  5.331721396353824E-005
 -3.052023407265754E-005
 -1.506654363846523E-005
 -3.043941926366945E-005
  5.618108042468185E-015
 -8.246471641175329E-015
 -1.077500722520690E-015
  3.989151408742478E-015
  1.328822142304845E-014
 -1.950495439579977E-014
 -2.548556928181000E-015
  9.435334248786193E-015
   4.33113809759490
  4.320032561404498E-005
 -5.238064507826189E-003
 -1.506314426657541E-005
   1.46192569209282
  1.057560479564082E-010
 -1.077460318592739E-015
 -8.730032045721020E-008
 -2.946736504697374E-008
  2.501393299910853E-010
 -2.548461362863891E-015
 -2.064869490372893E-007
 -6.969763997251947E-008
   587.829673190301
   158.268852998331
   10.8255572126736
  1.794528049254450E-009
  2.174415871270985E-003
 -3.043107482874513E-005
   1.46192569166284
 -3.190162762054243E-006
 -3.617169269030373E-017
 -4.348063702793333E-011
  3.988553115775524E-015
 -2.946736504693295E-008
 -1.184867384166442E-005
 -7.545527579033732E-006
 -5.161139534233636E-007
 -8.555503708986610E-017
 -1.028425101109268E-010
  9.433919137304169E-015
 -6.969763997261594E-008
 -2.802505762735366E-005
   426.953839809535
   3.48246532735344
   3.31807115197796
   158.266905284177
 -8.605666205003257E-006
 -7.018819371009247E-008
 -6.687902406268150E-008
 -3.190018174966645E-006
 -2.035514690016226E-005
 -1.660174772688286E-007
 -1.581902350028845E-007
 -7.545411013976851E-006
   268.711526032695
  4.276528569486942E-005
  4.276528569492530E-005
 -1.424583343353247E-004
   10.8254239890790
 -5.416147767483558E-006
 -2.181971869470944E-007
 -1.281091792474686E-005
 -5.161059803746826E-007
   34.0368280080783
 -6.860461198975629E-007
 -1.622718011384625E-006
   57.6230594042746
  4.276100945130937E-005
  1.282958570847759E-004
 -0.106260401717179
 -1.161446613593840E-006
  2.133169910686191E-009
 -2.747191893374932E-006
  5.045627593580105E-009
  1.435201765733074E-004
  1.282958570846082E-004
 -4.858579493415494E-004
  1.794530883905171E-009
 -2.944294350167700E-013
  1.141493813816873E-012
 -3.617055539038974E-017
 -6.964195499620597E-013
  2.699997057126239E-012
 -8.555490373719369E-017
   79.2838998340206
   3.48246532736179
   94.9001395607898
  4.320032559831356E-005
 -7.018819371017403E-008
 -7.613916896652981E-005
 -1.510025174940315E-004
 -7.819524373374042E-005
 -1.533625751579372E-004
   126.681453634753
   3.31807115197796
 -1.425366981710312E-004
 -0.106271262873532
 -4.861501223013934E-004
   94.8985566799734
 -3.051189399666809E-005
 -5.238525044911617E-003
  2.174389325494898E-003
 -6.687902406284462E-008
  2.133383227671902E-009
  1.141774969964076E-012
 -1.509950314766574E-004
 -3.007327831113469E-004
  5.617412135488233E-015
  1.057618300960989E-010
 -4.347866638328127E-011
 -1.581902350030775E-007
  5.046132156345226E-009
  2.700662081120758E-012
 -1.533550581566731E-004
 -3.037158686138536E-004
  1.328697237982561E-014
  2.501604797767045E-010
 -1.028409214058074E-010
  5.331720892874945E-005
 -3.052023064252061E-005
 -1.506654429636244E-005
 -3.043941682811621E-005
  5.617853412752377E-015
 -8.246097887361708E-015
 -1.077451886515178E-015
  3.988970608990192E-015
  1.328801614141457E-014
 -1.950465307763022E-014
 -2.548517556458936E-015
  9.435188489151988E-015
   4.33108479748752
  4.320032559821764E-005
 -5.237999937923950E-003
 -1.506314492443618E-005
   1.46190770116477
  1.057512547497464E-010
 -1.077411484427563E-015
 -8.729636376286197E-008
 -2.946602950367732E-008
  2.501354657080486E-010
 -2.548421992603776E-015
 -2.064837591785907E-007
 -6.969656326722411E-008
   587.822439131920
   158.266905284177
   10.8254239890790
  1.794505931792650E-009
  2.174389325490947E-003
 -3.043107239358404E-005
   1.46190770073479
 -3.190018174977084E-006
 -3.617005245573619E-017
 -4.347866638336090E-011
  3.988372343146837E-015
 -2.946602950371809E-008
 -1.184813682666263E-005
 -7.545411013964506E-006
 -5.161059803746827E-007
 -8.555371413628148E-017
 -1.028409214056190E-010
  9.433773399507938E-015
 -6.969656326712765E-008
 -2.802462468974206E-005
   426.949603704196
   3.48243077744378
   3.31803823102973
   158.265335010558
 -8.605351749078163E-006
 -7.018562899199176E-008
 -6.687658026497014E-008
 -3.189901609897344E-006
 -2.035489338782534E-005
 -1.660154096087947E-007
 -1.581882648289533E-007
 -7.545317039967493E-006
   268.708859955296
  4.276528364979509E-005
  4.276528364985096E-005
 -1.424583275228806E-004
   10.8253165823734
 -5.415949858368446E-006
 -2.181892138980823E-007
 -1.281075837167326E-005
 -5.160995525533272E-007
   34.0364903045788
 -6.860210513841179E-007
 -1.622697801310276E-006
   57.6224876856810
  4.276100740657031E-005
  1.282958509495529E-004
 -0.106259351619635
 -1.161404173651725E-006
  2.133091962634969E-009
 -2.747157678545749E-006
  5.045564751784127E-009
  1.435200252617616E-004
  1.282958509493853E-004
 -4.858573660676703E-004
  1.794513052255729E-009
 -2.944186705260052E-013
  1.141452080199824E-012
 -3.616923302681760E-017
 -6.964108674061774E-013
  2.699963395094450E-012
 -8.555383716554957E-017
   79.2832972021052
   3.48243077744378
   94.8995660023395
  4.320032558574761E-005
 -7.018562899215996E-008
 -7.614691444451317E-005
 -1.510180561221530E-004
 -1.660154096091805E-007
 -7.820148864701823E-005
 -1.533751034174834E-004
   126.680932778992
   3.31803823103378
 -1.425366913552343E-004
 -0.106270212671349
 -4.861495388756816E-004
   94.8979831189436
 -3.051189123140660E-005
 -5.238472982549963E-003
  2.174367923917021E-003
 -6.687658026497013E-008
  2.133305271825957E-009
  1.141733226067356E-012
 -1.510105693253798E-004
 -3.007639068563979E-004
  5.617206870973811E-015
  1.057579654609046E-010
 -4.347707766397704E-011
 -1.581882648293392E-007
  5.046069308241079E-009
  2.700628410798725E-012
 -1.533675857878689E-004
 -3.037409626119193E-004
  1.328680689609322E-014
  2.501573641053281E-010
 -1.028396406017309E-010
  5.331720486949995E-005
 -3.052022787714411E-005
 -1.506654482675529E-005
 -3.043941486458652E-005
  5.617648132098244E-015
 -8.245796569748091E-015
 -1.077412515290372E-015
  3.988824849537810E-015
  1.328785064468270E-014
 -1.950441015693471E-014
 -2.548485815246155E-015
  9.435070978688280E-015
   4.33104182619286
  4.320032558565169E-005
 -5.237947880767963E-003
 -1.506314545477586E-005
   1.46189319662986
  1.057473905011406E-010
 -1.077372114674814E-015
 -8.729317390437377E-008
 -2.946495279828483E-008
  2.501323503482088E-010
 -2.548390252576872E-015
 -2.064811875351917E-007
 -6.969569523435634E-008
   587.816606933511
   158.265335010299
   10.8253165823734
  1.794488100391246E-009
  2.174367923913069E-003
 -3.043107043024763E-005
   1.46189319619584
 -3.189901609897345E-006
 -3.616873011055106E-017
 -4.347707766389740E-011
  3.988226605565151E-015
 -2.946495279832561E-008
 -1.184770388903798E-005
 -7.545317039955147E-006
 -5.160995525525555E-007
 -8.555264757947566E-017
 -1.028396406019193E-010
  9.433655906668404E-015
 -6.969569523425990E-008
 -2.802427565821245E-005
   426.946188511141
   3.48240292293184
   3.31801168981778
   158.264069039100
 -8.605098236742186E-006
 -7.018356133322694E-008
 -6.687461009098895E-008
 -3.189807635893292E-006
 -2.035468900766445E-005
 -1.660137426730200E-007
 -1.581866764859530E-007
 -7.545241278679801E-006
   268.706710534864
  4.276528200111059E-005
  4.276528200116647E-005
 -1.424583220308108E-004
   10.8252299899318
 -5.415790305321223E-006
 -2.181827860775043E-007
 -1.281062974093478E-005
 -5.160943704809681E-007
   34.0362180444352
 -6.860008413097873E-007
 -1.622681508065824E-006
   57.6220267600790
  4.276100575796032E-005
  1.282958460034994E-004
 -0.106258505020236
 -1.161369958842430E-006
  2.133029121417334E-009
 -2.747130094750857E-006
  5.045514089071070E-009
  1.435199032730061E-004
  1.282958460033318E-004
 -4.858568958267628E-004
  1.794498676188171E-009
 -2.944099922640958E-013
  1.141418434828436E-012
 -3.616816694590910E-017
 -6.964038675772490E-013
  2.699936256958903E-012
 -8.555297730182467E-017
   79.2828113538501
   3.48240292293993
   94.8991035936415
  4.320032557548383E-005
 -7.018356133322695E-008
 -7.615315936197227E-005
 -1.510305843898720E-004
 -7.820652362565820E-005
 -1.533852043591716E-004
   126.680512859756
   3.31801168982588
 -1.425366858598677E-004
 -0.106269365986778
 -4.861490685123983E-004
   94.8975207079665
 -3.051188900215556E-005
 -5.238431009327998E-003
  2.174350669736393E-003
 -6.687461009107052E-008
  2.133242424331912E-009
  1.141699572411509E-012
 -1.510230969649319E-004
 -3.007890008708151E-004
  5.617041388012191E-015
  1.057548498169738E-010
 -4.347579684856024E-011
 -1.581866764857601E-007
  5.046018640473908E-009
  2.700601265969674E-012
 -1.533776862230314E-004
 -3.037611947106388E-004
  1.328667348410020E-014
  2.501548522692360E-010
 -1.028386080250453E-010
  5.331720159712057E-005
 -3.052022564767477E-005
 -1.506654525436329E-005
 -3.043941328157490E-005
  5.617482636166912E-015
 -8.245553649393999E-015
 -1.077380774452504E-015
  3.988707339207890E-015
  1.328771722217076E-014
 -1.950421431565209E-014
 -2.548460225661033E-015
  9.434976242423631E-015
   4.33100718228291
  4.320032557548382E-005
 -5.237905911742856E-003
 -1.506314588240629E-005
   1.46188150292035
  1.057442751687464E-010
 -1.077340375021069E-015
 -8.729060226086726E-008
 -2.946408476536219E-008
  2.501298387625221E-010
 -2.548364663972841E-015
 -2.064791142911556E-007
 -6.969499543122679E-008
   587.811904953060
   158.264069038841
   10.8252299899157
  1.794473724523751E-009
  2.174350669740345E-003
 -3.043106884751661E-005
   1.46188150248633
 -3.189807635888074E-006
 -2.181827860775044E-007
 -3.616766404446790E-017
 -4.347579684848060E-011
  3.988109112849683E-015
 -2.946408476532142E-008
 -1.184735485751461E-005
 -7.545241278667455E-006
 -5.160943704817398E-007
 -8.555178772740326E-017
  9.433561184606514E-015
 -6.969499543113033E-008
 -2.802399427103444E-005
   426.943435155674
   3.48238046639780
   3.31799029207755
   158.263048403137
 -8.604893856570520E-006
 -7.018189439858215E-008
 -6.687302174829210E-008
 -3.189731874593214E-006
 -2.035452423743067E-005
 -1.660123987989255E-007
 -1.581853959723828E-007
 -7.545180200309861E-006
   268.704977655538
  4.276528067192589E-005
  4.276528067185139E-005
 -1.424583176030016E-004
   10.8251601784161
 -5.415661674570815E-006
 -2.181776040055880E-007
 -1.281052603948917E-005
 -5.160901927223853E-007
   34.0359985461497
 -6.859845480653272E-007
 -1.622668372538709E-006
   57.6216551582373
  4.276100442903639E-005
  1.282958420155542E-004
 -0.106257822484620
 -1.161342375061900E-006
  2.132978459200592E-009
 -2.747107856842156E-006
  5.045473245062462E-009
  1.435198049241810E-004
  1.282958420157777E-004
 -4.858565167146348E-004
  1.794487086091552E-009
 -2.944029958995815E-013
  1.141391310126418E-012
 -3.616730747763075E-017
 -6.963982243552043E-013
  2.699914378340107E-012
 -8.555228408435049E-017
   79.2824196591046
   3.48238046639780
   94.8987307957915
  4.320032556733034E-005
 -7.018189439874525E-008
 -7.615819434383546E-005
 -1.510406853380994E-004
 -1.660123987987085E-007
 -7.821058303658353E-005
 -1.533933481602558E-004
   126.680174317217
   3.31799029207350
 -1.425366814301213E-004
 -0.106268683383157
 -4.861486893000344E-004
   94.8971479085392
 -3.051188720484487E-005
 -5.238397170185081E-003
  2.174336759281641E-003
 -6.687302174845520E-008
  2.133191757038806E-009
  1.141672441028909E-012
 -1.510331974065350E-004
 -3.008092329826009E-004
  5.616907976635010E-015
  1.057523380030726E-010
 -4.347476426258489E-011
  5.045977792393038E-009
  2.700579381963845E-012
 -1.533858296159896E-004
 -3.037775066722521E-004
  1.328656592809605E-014
  2.501528272391815E-010
 -1.028377755673881E-010
  5.331719895877668E-005
 -3.052022385024848E-005
 -1.506654559908754E-005
 -3.043941200532786E-005
  5.617349214309622E-015
 -8.245357808448340E-015
 -1.077355185180444E-015
  3.988612603069765E-015
  1.328760965762705E-014
 -1.950405642948055E-014
 -2.548439595473204E-015
  9.434899866558846E-015
   4.33097925208654
 -5.237872075967665E-003
 -1.506314622712915E-005
   1.46187207535744
  1.057417636060043E-010
 -1.077314786706712E-015
 -8.728852901689302E-008
 -2.946338496227305E-008
  2.501278139357043E-010
 -2.548344034591645E-015
 -2.064774428528270E-007
 -6.969443125366160E-008
   587.808114179413
   158.263048402878
   10.8251601784323
  1.794462134581920E-009
 -3.043106757143447E-005
   1.46187207492342
 -3.189731874587995E-006
 -2.181776040052618E-007
 -3.616680458814349E-017
 -4.347476426266453E-011
  3.988014390920067E-015
 -2.946338496223228E-008
 -1.184707347032459E-005
 -7.545180200285170E-006
 -5.160901927208420E-007
 -8.555109451971580E-017
 -1.028377755671998E-010
  9.433484820196554E-015
 -6.969443125356515E-008
 -2.802376741816479E-005
   426.941215383923
   3.48236236182475
   3.31797304109856
   158.262225560075
 -8.604729086366908E-006
 -7.018055052461234E-008
 -6.687174123475222E-008
 -3.189670796240869E-006
 -2.035439142853194E-005
 -1.660113151082722E-007
 -1.581843639368438E-007
 -7.545130969761375E-006
   268.703580597662
  4.276527960038249E-005
  4.276527960032662E-005
 -1.424583140334254E-004
   10.8251038959829
 -5.415557973152586E-006
 -2.181734262466809E-007
 -1.281044245352203E-005
 -5.160868253382744E-007
   34.0358215853674
 -6.859714125382178E-007
 -1.622657784975226E-006
   57.6213555706956
  4.276100335754888E-005
  1.282958388009799E-004
 -0.106257272220507
 -1.161320137165235E-006
  2.132937615581161E-009
 -2.747089932530356E-006
  5.045439944842662E-009
  1.435197256354511E-004
  1.282958388011475E-004
 -4.858562110726288E-004
  1.794477742090926E-009
 -2.943973554665448E-013
  1.141369442335518E-012
 -3.616661457893567E-017
 -6.963936490122185E-013
  2.699896630118277E-012
 -8.555174700693166E-017
   79.2821038725201
   3.48236236182020
   94.8984302441434
  4.320032556061572E-005
 -7.616225375728734E-005
 -1.510488291444914E-004
 -1.660113151082601E-007
 -7.821386155520323E-005
 -1.533999253320959E-004
   126.679901382443
   3.31797304109856
 -1.425366778584963E-004
 -0.106268133064265
 -4.861483835790524E-004
   94.8968473554559
 -3.051188575591827E-005
 -5.238369888849147E-003
  2.174325544596640E-003
 -6.687174123467067E-008
  2.133150909340153E-009
  1.141650567847950E-012
 -1.510413408045418E-004
 -3.008255449548294E-004
  5.616800421104308E-015
  1.057503129920773E-010
 -4.347393179730671E-011
 -1.581843639368437E-007
  5.045944488851035E-009
  2.700561629372804E-012
 -1.533924064580351E-004
 -3.037906806482121E-004
  1.328626780881315E-014
  2.501511760714987E-010
 -1.028371122105264E-010
  5.331719683186030E-005
 -3.052022240107186E-005
 -1.506654587701976E-005
 -3.043941097636321E-005
  5.617241650313507E-015
 -8.245199922505838E-015
 -1.077334555243634E-015
  3.988536227293546E-015
  1.328731149721826E-014
 -1.950348632958902E-014
 -2.548430207049808E-015
  9.434615947522418E-015
   4.33095673460129
 -5.237844797375392E-003
 -1.506314650508383E-005
   1.46186447480191
  1.057397387971736E-010
 -1.077294157552585E-015
 -8.728685757858435E-008
 -2.946282078470812E-008
  2.501261629323524E-010
 -2.548334646481228E-015
 -2.064760954746408E-007
 -6.969397646526419E-008
   587.805058035403
   158.262225559558
   10.8251038959505
  1.794452790714320E-009
  2.174325544592670E-003
 -3.043106654272486E-005
   1.46186447436788
 -3.189670796235650E-006
 -2.181734262470071E-007
 -3.616611169895452E-017
  3.987938026596241E-015
 -2.946282078466733E-008
 -1.184684661747227E-005
 -7.545130969761376E-006
 -8.555055744994637E-017
  9.433200943765956E-015
 -2.802358456905298E-005
   426.939425816343
   3.48234775562515
   3.31795913534753
   158.261562191413
 -8.604596250379154E-006
 -7.017946710809477E-008
 -6.687070889850087E-008
 -3.189621555517943E-006
 -2.035427512217298E-005
 -1.654851251891334E-007
 -1.577785549917913E-007
 -7.545583749490482E-006
   268.702454296841
  4.276527908046164E-005
  4.276527908049889E-005
 -1.424583123015542E-004
   10.8250585212537
 -5.415474370168192E-006
 -2.181700581824576E-007
 -1.280995925604595E-005
 -5.160907287364459E-007
   34.0356789205215
 -6.859608228169462E-007
 -1.622648464756864E-006
   57.6211140447850
  4.276100283753489E-005
  1.282958372414967E-004
 -0.106256820655837
 -1.161302209211199E-006
  2.132904687893257E-009
 -2.747074153799365E-006
  4.980646319927206E-009
  1.435196622010645E-004
  1.282958372413849E-004
 -4.858559657738092E-004
  1.794470663610731E-009
 -2.943928082110695E-013
  1.141351812757602E-012
 -3.616605597147069E-017
 -6.916976227738507E-013
  2.680009602088206E-012
 -8.935029103955430E-017
   79.2818505051576
   3.48234775562489
   94.8981903749391
  4.320032229970414E-005
 -7.017946710800305E-008
 -7.616552657433147E-005
 -1.510553949165308E-004
 -1.654851251891455E-007
 -7.899152271035248E-005
 -1.549634286492186E-004
   126.679686168218
   3.31795913534753
 -1.425366761251163E-004
 -0.106267681454600
 -4.861481382185414E-004
   94.8966074848645
 -3.051063378641429E-005
 -5.238347853635315E-003
  2.174315950904559E-003
  2.133117978364613E-009
  1.141632933928530E-012
 -1.510479062475903E-004
 -3.008386961372297E-004
  5.616713711002555E-015
  1.057486804494188E-010
 -4.347326067279173E-011
  4.981144384557687E-009
  2.680669515243838E-012
 -1.549558312143983E-004
 -3.069317095326939E-004
  9.415557553927816E-010
  4.006924889328721E-009
 -1.041753831263751E-010
  5.331500468681468E-005
 -3.051897008811121E-005
 -1.506592262578091E-005
 -3.043815877346983E-005
  5.617154933361975E-015
 -8.245072636562693E-015
 -1.077317923609424E-015
  3.988474653964339E-015
  9.414651520647170E-010
 -1.560152800245750E-010
 -6.240845218995018E-010
 -9.872272217852908E-017
   4.33093857764780
  4.320032229960822E-005
 -5.237822764402131E-003
 -1.506252339398459E-005
   1.46185834592877
  1.057381064180733E-010
 -1.077277526555995E-015
 -8.728551008292087E-008
 -2.946236595079772E-008
  4.006397191955832E-009
 -6.240611200983000E-010
 -2.036527183397271E-007
 -6.790233617569297E-008
   587.802594187079
   158.261562191413
   10.8250585212537
  1.794445712336357E-009
  2.174315950904597E-003
 -3.042981468340173E-005
   1.46185834549679
 -3.189621555507504E-006
 -2.181700581818052E-007
 -3.616555309931924E-017
 -4.347326067271210E-011
  3.987876462501788E-015
 -2.946236595075695E-008
 -1.184666373112321E-005
 -7.545583749478139E-006
 -5.160907287356742E-007
 -8.934904862462855E-017
 -9.871902029201832E-017
 -6.790233617559650E-008
 -2.802259726951357E-005
   213.468933331965
   1.73565732094121
   1.65472701741592
   79.1356934968637
 -8.604489158181523E-006
 -7.017859344997429E-008
 -6.686987666850530E-008
 -3.189581857768856E-006
   134.349757822927
  2.140102093079570E-005
  2.140102093083295E-005
 -1.002986125822604E-002
  2.490109537320677E-003
  9.961558740586041E-003
   5.41922210845445
 -5.415406969541057E-006
 -2.181673428505834E-007
   17.0177769376919
 -6.859522853965867E-007
   28.8104512299769
  2.139888097139516E-005
  6.420306279249887E-005
 -5.244917037837558E-002
 -1.161287755716109E-006
  2.132877981446280E-009
  7.176715753642707E-005
  6.420306279238712E-005
 -2.429074191862324E-004
  9.370750074673876E-010
 -2.943891309053146E-013
  1.141337551831639E-012
 -3.616561478486440E-017
   39.6403822577692
   1.73565732094134
   47.5329323218072
  2.072005132621489E-005
 -7.017859344996918E-008
 -7.616817087988300E-005
 -1.510606997635297E-004
   63.7208033400925
   1.65472701741592
 -1.003189225438256E-002
 -5.245453295465854E-002
 -2.430535723596063E-004
   47.5321326044573
 -2.189843915386578E-002
 -9.012219948050426E-002
 -1.882956590311081E-002
  2.133091269250295E-009
  1.141618669490984E-012
 -1.510532108286016E-004
 -3.008493216627550E-004
  5.616554428317507E-015
  1.057473562877636E-010
 -4.347272283630205E-011
  4.072991403432796E-003
  2.490140662786143E-003
 -2.189557628298246E-002
  1.629313686168371E-002
  4.980531375009348E-003
  5.616995630679060E-015
 -8.244782815488683E-015
 -1.077307575809154E-015
  3.988331015304555E-015
   2.17485194161956
  9.960562651144573E-003
  2.072005132623877E-005
 -9.010496978519021E-002
  1.629196561373119E-002
  0.732058382344239
  1.057367823884971E-010
 -1.077267179127230E-015
 -8.728442366716038E-008
 -2.946199924431619E-008
   293.904823761006
   79.1356934967342
   5.41922177642760
  9.370619774485451E-010
 -1.882458628571770E-002
  4.980220109972361E-003
  0.732059378465841
 -3.189581857768857E-006
 -3.616511191892420E-017
 -4.347272283630206E-011
  3.987732845394931E-015
 -1.184651628836199E-005
       30100
   289.157378291215
   2.35848715447320
   2.24718715729226
   107.187298514184
 -3.520635541131130E-005
 -2.871447516020242E-007
 -2.736065697946534E-007
 -1.305057742489361E-005
   181.986776096704
  2.144163914840530E-005
 -7.142569373415442E-005
   7.33159484532828
 -2.215782314298891E-005
 -8.926593008708369E-007
   23.0516813358080
 -2.806660512375638E-006
   39.0256111898909
  2.143949512748531E-005
  6.432491744521592E-005
 -7.189125083447404E-002
 -4.751557990842203E-006
  8.727039427158606E-009
  7.453579203225218E-005
  6.432491744521591E-005
 -2.535934638681364E-004
  1.216430794199952E-009
 -1.205643801703205E-012
  4.674246165792860E-012
 -1.481066923658771E-016
   50.4084945110622
   2.35848715447885
   57.6973758037132
  2.160039825520571E-005
 -2.871447516027123E-007
 -6.137477127688787E-006
 -7.024951628340893E-006
   72.6468267712957
   2.24718715729774
 -7.146498375828437E-005
 -7.189855784207365E-002
 -2.537424151262485E-004
   57.6966324907930
 -1.530534907995834E-005
 -3.549397999033826E-003
  1.469541458726742E-003
 -2.736065697953207E-007
  8.727912131094343E-009
  4.675397458370369E-012
 -7.024861126177891E-006
 -8.845035655106354E-006
  2.298134474661520E-014
  4.326834053731664E-010
 -1.778721978920656E-010
  2.673112330918601E-005
 -1.530952128355118E-005
 -7.523796211232846E-006
 -1.525478864764456E-005
  2.298315003369370E-014
 -3.373540461642602E-014
 -4.407993119285159E-015
  1.631917070396290E-014
   2.93324923983276
 -3.549042439345920E-003
 -7.522096880597526E-006
  0.990085735305337
  4.326401404554087E-010
 -4.407827829174405E-015
 -3.571352565174789E-007
 -1.205474937505633E-007
   398.106804614532
   107.187298514535
   7.33159484532828
  1.216413880299879E-009
  1.469541458726743E-003
 -1.525061116901941E-005
  0.990085735090708
 -1.305057742493632E-005
 -8.926593008708370E-007
 -1.481046330117348E-016
  1.631672315462805E-014
 -1.205474937507302E-007
 -4.847151934692850E-005
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.345656025758654E-005
 -1.913128493396564E-007
 -1.822929103646404E-007
 -8.695068040611864E-006
 -3.520635541132238E-005
 -2.871447516021146E-007
 -2.736065697947395E-007
 -1.305057742489772E-005
   363.973544798440
  4.288327829681061E-005
 -1.428513874683088E-004
   14.6631893927398
 -1.476285482147572E-005
 -5.947425240627022E-007
 -2.215782314299588E-005
 -8.926593008711180E-007
   46.1033617349190
 -1.869963552375436E-006
 -2.806660512376521E-006
   78.0512207939933
  4.287899025497063E-005
  1.286498348904318E-004
 -0.143782498756379
 -3.165769504610466E-006
  5.814470819314348E-009
 -4.751557990843700E-006
  8.727039427161354E-009
  1.490715836621319E-004
 -5.071869261762863E-004
  2.432861538970667E-009
 -8.032713455693538E-013
  3.114259785364966E-012
 -9.867745506300995E-017
 -1.205643801703584E-012
  4.674246165794331E-012
 -1.481066923659237E-016
   100.816986973798
   4.71697421312579
   115.394749262914
  4.320079651041143E-005
 -1.913128493401149E-007
 -4.089150961332895E-006
 -4.680439064245399E-006
 -2.871447516028027E-007
 -6.137477127690720E-006
 -7.024951628343103E-006
   145.293650590643
   4.49437422328183
 -1.429299675165687E-004
 -0.143797112771287
 -5.074848286921265E-004
   115.393262637104
 -3.061069815224686E-005
 -7.098795853663573E-003
  2.939082858090285E-003
 -1.822929103650850E-007
  5.815052266391630E-009
  3.115026844704195E-012
 -4.680378766341368E-006
 -5.893086898675263E-006
  1.531153371462460E-014
  2.882793249122460E-010
 -1.185089987094802E-010
 -2.736065697954068E-007
  8.727912131097091E-009
  4.675397458371842E-012
 -7.024861126180104E-006
 -8.845035655109137E-006
  2.298134474662243E-014
  4.326834053733025E-010
 -1.778721978921216E-010
  5.346224660711313E-005
 -3.061904255943195E-005
 -1.504759242393682E-005
 -3.050957728984274E-005
  1.531273650385525E-014
 -2.247652567141389E-014
 -2.936866227974265E-015
  1.087279857569015E-014
  2.298315003370093E-014
 -3.373540461643663E-014
 -4.407993119286547E-015
  1.631917070396804E-014
   5.86649836047494
  4.320079651041141E-005
 -7.098084734302197E-003
 -1.504419376266612E-005
   1.98017143037906
  2.882504992602134E-010
 -2.936756101907605E-015
 -2.379446712601044E-007
 -8.031588382342602E-008
  4.326401404555450E-010
 -4.407827829175793E-015
 -3.571352565175913E-007
 -1.205474937506013E-007
   796.213593052143
   214.374592673561
   14.6631893927398
  2.432827711171208E-009
  2.939082858090286E-003
 -3.050122233259326E-005
   1.98017142994981
 -8.695068040640319E-006
 -9.867608299924571E-017
  1.087116787328470E-014
 -8.031588382353718E-008
 -3.229459854775840E-005
 -1.305057742494042E-005
 -8.926593008711181E-007
 -1.481046330117814E-016
  1.631672315463319E-014
 -1.205474937507681E-007
 -4.847151934694376E-005
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.345656025758665E-005
 -1.913128493396574E-007
 -1.822929103646412E-007
 -8.695068040611906E-006
   363.973544798440
   14.6631893927398
 -1.476285482147579E-005
 -5.947425240627050E-007
   46.1033617349190
 -1.869963552375445E-006
   78.0512207939933
 -0.143782498756379
 -3.165769504610481E-006
  5.814470819314375E-009
 -8.032713455693576E-013
  3.114259785364981E-012
 -9.867745506301042E-017
   100.816986973798
   4.71697421312579
   115.394749262914
 -1.913128493401159E-007
 -4.089150961332914E-006
 -4.680439064245421E-006
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
 -1.822929103650859E-007
  5.815052266391657E-009
  3.115026844704210E-012
 -4.680378766341390E-006
 -5.893086898675290E-006
  1.531153371462467E-014
  2.882793249122473E-010
 -1.185089987094808E-010
  1.531273650385532E-014
 -2.247652567141400E-014
 -2.936866227974278E-015
  1.087279857569020E-014
   5.86649836047494
   1.98017143037906
  2.882504992602148E-010
 -2.936756101907619E-015
 -2.379446712601056E-007
 -8.031588382342641E-008
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
 -8.695068040640360E-006
 -5.947425240627051E-007
 -9.867608299924618E-017
  1.087116787328475E-014
 -8.031588382353757E-008
 -3.229459854775855E-005
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
 -3.520635541130022E-005
 -2.871447516019338E-007
 -2.736065697945673E-007
 -1.305057742488950E-005
   363.973544798440
   14.6631893927398
 -2.215782314298193E-005
 -8.926593008705560E-007
   46.1033617349190
 -2.806660512374755E-006
   78.0512207939933
 -0.143782498756379
 -4.751557990840708E-006
  8.727039427155858E-009
 -1.205643801702825E-012
  4.674246165791388E-012
 -1.481066923658305E-016
   100.816986973798
   4.71697421312579
   115.394749262914
 -2.871447516026220E-007
 -6.137477127686855E-006
 -7.024951628338681E-006
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
 -2.736065697952346E-007
  8.727912131091596E-009
  4.675397458368897E-012
 -7.024861126175681E-006
 -8.845035655103569E-006
  2.298134474660796E-014
  4.326834053730301E-010
 -1.778721978920096E-010
  2.298315003368646E-014
 -3.373540461641539E-014
 -4.407993119283771E-015
  1.631917070395776E-014
   5.86649836047494
   1.98017143037906
  4.326401404552726E-010
 -4.407827829173018E-015
 -3.571352565173664E-007
 -1.205474937505254E-007
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
 -1.305057742493221E-005
 -1.481046330116882E-016
  1.631672315462292E-014
 -1.205474937506922E-007
 -4.847151934691324E-005
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.345656025758643E-005
 -1.913128493396556E-007
 -1.822929103646396E-007
 -8.695068040611823E-006
 -2.736065697950732E-007
   363.973544798440
   14.6631893927398
 -1.476285482147565E-005
 -5.947425240626995E-007
  0.000000000000000E+000
   46.1033617349190
 -1.869963552375428E-006
   78.0512207939933
 -0.143782498756379
 -3.165769504610451E-006
  5.814470819314320E-009
  8.727039427140501E-009
 -8.032713455693502E-013
  3.114259785364951E-012
 -9.867745506300949E-017
 -1.205643801706131E-012
  4.674246165794408E-012
 -1.481066923659626E-016
   100.816986973798
   4.71697421312579
   115.394749262914
 -1.913128493401141E-007
 -4.089150961332876E-006
 -4.680439064245377E-006
 -6.137477127702731E-006
 -7.024951628334095E-006
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
 -1.822929103650841E-007
  5.815052266391602E-009
  3.115026844704181E-012
 -4.680378766341346E-006
 -5.893086898675235E-006
  1.531153371462453E-014
  2.882793249122446E-010
 -1.185089987094797E-010
  4.675397458382025E-012
 -7.024861126193449E-006
 -8.845035655101441E-006
  2.298134474661249E-014
 -1.778721978917957E-010
  1.531273650385518E-014
 -2.247652567141379E-014
 -2.936866227974251E-015
  1.087279857569010E-014
  2.298315003371087E-014
 -3.373540461643414E-014
 -4.407993119284059E-015
  1.631917070392826E-014
   5.86649836047494
   1.98017143037906
  2.882504992602121E-010
 -2.936756101907591E-015
 -2.379446712601034E-007
 -8.031588382342565E-008
  4.326401404548934E-010
 -4.407827829165849E-015
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
 -8.695068040640280E-006
 -9.867608299924525E-017
  1.087116787328465E-014
 -8.031588382353681E-008
 -3.229459854775825E-005
 -1.481046330117037E-016
   578.314744832634
   4.71697421311449
   4.49437422327634
   214.374592672859
 -3.520635541281765E-005
 -2.871447516135563E-007
 -2.736065698059978E-007
 -1.305057742542747E-005
   363.973544798440
  4.288327829677336E-005
  4.288327829679199E-005
 -1.428513874683275E-004
   14.6631893927398
 -2.215782314307699E-005
 -8.926593008735062E-007
   46.1033617349190
   78.0512207939933
  4.287899025474710E-005
  1.286498348903760E-004
 -0.143782498756037
 -4.751557990842216E-006
  1.490715836621178E-004
  1.286498348903201E-004
 -5.071869261763436E-004
  2.432861538971305E-009
 -1.205643801701538E-012
  4.674246165788804E-012
 -1.481066923662267E-016
   100.816986973995
   4.71697421312579
   115.394749262766
 -2.871447516142653E-007
 -6.137477127712352E-006
 -7.024951628349567E-006
   145.293650590516
   4.49437422328183
 -1.429299675158237E-004
 -0.143797112771287
 -5.074848286921076E-004
   115.393262637323
 -3.061069815223711E-005
 -7.098795853663563E-003
  2.939082858084885E-003
 -2.736065698063315E-007
  8.727912131104773E-009
  4.675397458364168E-012
 -7.024861126202249E-006
 -8.845035655112358E-006
  2.298134474670469E-014
  4.326834053718629E-010
 -1.778721978923914E-010
  5.346224660709631E-005
 -3.061904255941534E-005
 -1.504759242395365E-005
 -3.050957728975815E-005
  2.298315003371855E-014
 -3.373540461655280E-014
 -4.407993119280189E-015
  1.631917070402256E-014
   5.86649836047494
  4.320079651041142E-005
 -7.098084734291498E-003
 -1.504419376266149E-005
   1.98017143037906
  4.326401404541053E-010
 -4.407827829204246E-015
 -3.571352565176444E-007
 -1.205474937502296E-007
   796.213593052143
   214.374592673561
   14.6631893927398
  2.432827711169932E-009
  2.939082858090276E-003
 -3.050122233258366E-005
   1.98017142994981
 -1.305057742544882E-005
  1.631672315468771E-014
 -4.847151934767823E-005
   578.314744857378
   4.71697421330393
   4.49437422345721
   214.374592681629
 -1.822929103648627E-007
   363.973544799887
  4.288327829679200E-005
  4.288327829671749E-005
 -1.428513874681784E-004
   14.6631893927836
   46.1033617349190
   78.0512207939935
  1.286498348901524E-004
 -0.143782498756379
  5.814470819300454E-009
  1.490715836617524E-004
 -5.071869261759013E-004
  2.432861538976410E-009
 -8.032713455710507E-013
  3.114259785365017E-012
 -9.867745506303581E-017
   100.816986974185
   4.71697421331557
   115.394749263056
  4.320079651031549E-005
 -4.089150961340898E-006
 -4.680439064239396E-006
   145.293650590741
   4.49437422346269
 -0.143797112771459
 -5.074848286908751E-004
   115.393262637504
 -3.061069815226752E-005
 -7.098795853642142E-003
  2.939082858095638E-003
  3.115026844710980E-012
 -4.680378766350260E-006
 -5.893086898670134E-006
  1.531153371461797E-014
 -1.185089987092631E-010
  5.346224660714880E-005
 -3.061904255943236E-005
 -1.504759242397047E-005
 -3.050957728984372E-005
  1.531273650386187E-014
 -2.247652567141223E-014
 -2.936866227972606E-015
  1.087279857566365E-014
   5.86649836047766
  4.320079651021958E-005
 -7.098084734280785E-003
 -1.504419376267523E-005
   1.98017143037358
  2.882504992597793E-010
 -2.936756101900980E-015
   796.213593064459
   214.374592681979
   14.6631893927836
 -3.050122233261343E-005
   1.98017142994158
 -9.867608299919394E-017
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.345656025859016E-005
 -1.913128493473399E-007
 -1.822929103721987E-007
 -8.695068040967551E-006
   363.973544798440
   14.6631893927398
 -1.476285482153441E-005
 -5.947425240644806E-007
   46.1033617349190
   78.0512207939933
 -0.143782498756379
 -3.165769504610473E-006
 -8.032713455682433E-013
  3.114259785362264E-012
 -9.867745506324285E-017
   100.816986973798
   4.71697421312579
   115.394749262914
 -1.913128493478123E-007
 -4.089150961348596E-006
 -4.680439064251179E-006
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
 -1.822929103724210E-007
  5.815052266398577E-009
  3.115026844700064E-012
 -4.680378766357597E-006
 -5.893086898679264E-006
  1.531153371468423E-014
  2.882793249113775E-010
 -1.185089987096973E-010
  1.531273650387180E-014
 -2.247652567149836E-014
 -2.936866227970954E-015
  1.087279857572990E-014
   5.86649836047494
   1.98017143037906
  2.882504992593449E-010
 -2.936756101927487E-015
 -2.379446712602148E-007
 -8.031588382320370E-008
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
 -8.695068040981778E-006
 -1.185089987096974E-010
  1.087116787332445E-014
 -8.031588382320373E-008
 -3.229459854825791E-005
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
   100.816986973798
   4.71697421312579
   115.394749262914
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
   5.86649836047494
   1.98017143037906
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
 -2.736065697945672E-007
   363.973544798440
   14.6631893927398
   46.1033617349190
   78.0512207939933
 -0.143782498756379
  8.727039427145433E-009
 -1.205643801702904E-012
  4.674246165788921E-012
   100.816986973798
   4.71697421312579
   115.394749262914
 -6.137477127689525E-006
 -7.024951628326668E-006
   145.293650590643
   4.49437422328183
 -0.143797112771287
   115.393262637104
  4.675397458369057E-012
 -7.024861126181020E-006
 -8.845035655090209E-006
  2.298134474664774E-014
  4.326834053723784E-010
 -1.778721978916838E-010
  2.298315003368895E-014
 -3.373540461642036E-014
 -4.407993119291232E-015
   5.86649836047494
   1.98017143037906
  4.326401404559243E-010
 -4.407827829192915E-015
 -3.571352565173658E-007
   796.213593052143
   214.374592673561
   14.6631893927398
   1.98017142994981
   578.314744832634
   4.71697421311449
   4.49437422327086
   214.374592672859
 -3.520635541069944E-005
 -2.871447504880625E-007
 -2.736065689148757E-007
 -1.305057742530345E-005
   363.973544798440
   14.6631893927398
 -2.215782314295851E-005
 -8.926593008777913E-007
   46.1033617349190
   78.0512207939933
  4.287899025491473E-005
 -0.143782498756208
 -4.751557990854356E-006
  8.727039304384570E-009
  1.490715836621332E-004
 -5.071869261762459E-004
 -1.205643792465304E-012
  4.674246126803139E-012
 -1.481066993243408E-016
   100.816986973842
   4.71697421312579
   115.394749262717
 -2.871447504887089E-007
 -6.137477120339518E-006
 -7.024951631097475E-006
   145.293650590423
   4.49437422328183
 -1.429299675163825E-004
 -0.143797112771287
 -5.074848286921291E-004
   115.393262637191
 -3.061069815227629E-005
 -7.098795853652858E-003
  2.939082858084905E-003
 -2.736065689155431E-007
  8.727912008289027E-009
  4.675397419387816E-012
 -7.024861128962501E-006
 -8.845035677386710E-006
  2.298134456951216E-014
  4.326833992860222E-010
 -1.778722003981460E-010
  5.346224660716357E-005
 -3.061904255938163E-005
 -1.504759242395348E-005
 -3.050957728979237E-005
  2.298314985658072E-014
 -3.373540452877207E-014
 -4.407993034388167E-015
  1.631917067075550E-014
   5.86649836047493
 -7.098084734312917E-003
 -1.504419376268018E-005
   1.98017143037906
  4.326401343689164E-010
 -4.407827744297310E-015
 -3.571352565176770E-007
 -1.205474937549388E-007
   796.213593052143
   214.374592673561
   14.6631893927398
 -3.050122233262203E-005
   1.98017142994981
 -8.926593008764564E-007
 -1.481046399702373E-016
 -1.778722003981461E-010
  1.631672312141071E-014
 -1.205474937549389E-007
 -4.847151934676509E-005
   578.314744482591
   4.71697419203939
   4.49437420617705
   214.374592553562
 -1.822929103646413E-007
 -3.486654897000965E-005
 -2.843732684917476E-007
 -2.709657603039671E-007
 -1.292461521851804E-005
   363.973544583962
  4.288327830215641E-005
  4.288327830224953E-005
 -1.428513874861157E-004
   14.6631893842336
 -2.194395915160788E-005
 -8.840434869354315E-007
   46.1033617078295
 -2.779571047736505E-006
   78.0512207483070
  4.287899026022327E-005
  1.286498349067486E-004
 -0.143782496655419
  5.814470819307429E-009
 -4.705696611749664E-006
  8.642803955623622E-009
  1.490715835179705E-004
  1.286498349064692E-004
 -5.071869255528378E-004
  2.432861651842989E-009
 -8.032713455694107E-013
  3.114259785363337E-012
 -1.193954935115560E-012
  4.628928683137126E-012
 -1.466709969130813E-016
   100.816986793892
   4.71697419205001
   115.394749240535
  4.320079576307320E-005
 -4.089150961334693E-006
 -4.680439064237418E-006
 -6.078329641437480E-006
 -6.957328915326465E-006
   145.293650871573
   4.49437420618801
 -1.429299675340776E-004
 -0.143797110669805
 -5.074848280697531E-004
   115.393262615186
 -3.061069814911576E-005
 -7.098795749495203E-003
  2.939082897538479E-003
  3.115026844704316E-012
 -4.680378766344947E-006
 -5.893086898666391E-006
  1.531153371465117E-014
  2.882793249118131E-010
 -1.185089987092637E-010
  8.643668236021943E-009
  4.630068813758746E-012
 -6.957239277629070E-006
 -8.760026825389280E-006
  2.275952751382219E-014
  4.285070467479389E-010
 -1.761554695294057E-010
  5.346224660534750E-005
 -3.061904255630068E-005
 -1.504759242537394E-005
 -3.050957728913967E-005
  1.531273650385697E-014
 -2.247652567141731E-014
 -2.936866227979249E-015
  2.276131537680262E-014
 -3.340979322801475E-014
 -4.365445551681045E-015
  1.616165963931530E-014
   5.86649835702859
  4.320079576316912E-005
 -7.098084630144951E-003
 -1.504419376410291E-005
   1.98017142928681
  2.882504992606490E-010
 -2.936756101920876E-015
 -2.379446712601052E-007
  4.284641994334349E-010
 -4.365281857014185E-015
 -3.536882408005964E-007
 -1.193839875477508E-007
   796.213592581368
   214.374592553562
   14.6631893842117
  2.432827824044188E-009
  2.939082897538480E-003
 -3.050122233189004E-005
   1.98017142885481
 -1.292461521849688E-005
 -1.466689575216457E-016
  1.615923571345655E-014
 -1.193839875479161E-007
 -4.800367954116850E-005
   573.236785850516
   4.67555804638392
   4.45491080915552
   212.492253674625
 -2.311675381611035E-005
 -1.885413707038726E-007
 -1.796521003748555E-007
 -8.569105832725374E-006
 -3.349292095255420E-005
 -2.731698758155861E-007
 -2.602905950240384E-007
 -1.241542764737865E-005
   360.777629553299
  4.287768223851834E-005
  4.287768223855560E-005
 -1.428327460603394E-004
   14.5344374185661
 -1.454899084899366E-005
 -5.861267109114581E-007
 -2.107943885768097E-005
 -8.492150619031830E-007
   45.6985454231791
 -1.842874087736116E-006
 -2.670065037570279E-006
   77.3658828833511
  4.287339475606815E-005
  1.286330467156668E-004
 -0.142523649744141
 -3.119908182378083E-006
  5.730238668262342E-009
 -4.520307374147624E-006
  8.302295506116147E-009
  1.488800159134415E-004
  1.286330467155550E-004
 -5.064534086942103E-004
  2.411397693954825E-009
 -7.916346470748867E-013
  3.069144639617465E-012
 -9.724795613910564E-017
 -1.146766292100916E-012
  4.445979426857498E-012
 -1.408747768595779E-016
   100.094575244242
   4.67555804638392
   114.707172043914
  4.320078000335900E-005
 -1.885413707042971E-007
 -4.030003137062601E-006
 -4.612815670997898E-006
 -5.860066576345600E-006
 -6.725641569922338E-006
   144.669215621096
   4.45491080915552
 -1.429113158535605E-004
 -0.142538137843541
 -5.067511079600564E-004
   114.705682189466
 -3.060738338030736E-005
 -7.036385438731686E-003
  2.913428718245663E-003
 -1.796521003752937E-007
  5.730811692112108E-009
  3.069900586858803E-012
 -4.612756237606959E-006
 -5.808076721533749E-006
  1.508972111936260E-014
  2.841031258399729E-010
 -1.167922046848444E-010
  8.303125735671243E-009
  4.447074496034066E-012
 -6.725553343329381E-006
 -8.499727737313961E-006
  2.186286226630052E-014
  4.116247788010889E-010
 -1.692157223309037E-010
  5.345738077287618E-005
 -3.061572752717744E-005
 -1.504822824520829E-005
 -3.050722349460647E-005
  1.509090648422768E-014
 -2.215091656836243E-014
 -2.894320886396349E-015
  1.071528837558391E-014
  2.186457969407074E-014
 -3.209354958295294E-014
 -4.193454414427783E-015
  1.552494043389082E-014
   5.81498725798600
  4.320078000326307E-005
 -7.035680559925152E-003
 -1.504482956005489E-005
   1.96278436519492
  2.840747177748397E-010
 -2.894212355698014E-015
 -2.344976555415777E-007
 -7.915237756860046E-008
  4.115836195802709E-010
 -4.193297169095868E-015
 -3.397540806669189E-007
 -1.146806489851974E-007
   789.222344344578
   212.492253674277
   14.5344374185661
  2.411364164600635E-009
  2.913428718245664E-003
 -3.049886889031407E-005
   1.96278436476563
 -5.861267109105817E-007
 -9.724660395194300E-017
  1.071368129654956E-014
 -3.182675874173190E-005
 -1.408728180617080E-016
 -1.692157223312137E-010
  1.552261200324829E-014
 -4.611249153817101E-005
   557.235362001020
   4.54504939266005
   4.33055556547703
   206.560716167587
 -2.174312579951971E-005
 -1.773379910972862E-007
 -1.689769359944208E-007
 -8.059918257133631E-006
 -3.142132125622325E-005
 -2.562737925623156E-007
 -2.441911351085195E-007
 -1.164751027218250E-005
   350.706812792142
  4.286085886865414E-005
  4.286085886865413E-005
 -1.427767045958094E-004
   14.1287202953765
 -1.368447060198972E-005
 -5.512982878006303E-007
 -1.977563614154677E-005
 -7.966895220793212E-007
   44.4229074337771
 -1.733368077569763E-006
 -2.504916529709468E-006
   75.2062785197769
  4.285657306847119E-005
  1.285825766059624E-004
 -0.138556839931539
 -2.934519085661557E-006
  5.389738279786483E-009
 -4.240717726998273E-006
  7.788772538052566E-009
  1.482790118959745E-004
 -5.041509466799362E-004
  2.343788291345060E-009
 -7.445621410798270E-013
  2.886645843872508E-012
 -9.146548859094650E-017
 -1.075692422826776E-012
  4.170427850648199E-012
 -1.321443582062073E-016
   97.8181459798465
   4.54504939266005
   112.540512012781
  4.320072833754909E-005
 -1.773379910972861E-007
 -3.811739274192630E-006
 -4.381126679225338E-006
 -2.562737925626133E-007
 -5.812694823420621E-006
 -6.939848257519523E-006
   142.701527270519
   4.33055556547703
 -1.428552435615706E-004
 -0.138570931257494
 -5.044480109517221E-004
   112.539011984093
 -3.059693803890704E-005
 -6.839721065715974E-003
  2.832588455194030E-003
  5.390277253616183E-009
  2.887356840637778E-012
 -4.381068657006511E-006
 -5.547774331749306E-006
  1.419306712276919E-014
  2.672212449656307E-010
 -1.098522981883248E-010
 -2.441911351082218E-007
  7.789551415307988E-009
  4.171455049940835E-012
 -6.939733979476899E-006
 -9.234404060516547E-006
  2.051058880806215E-014
  3.861645151610547E-010
 -1.587496207746322E-010
  5.344204779208789E-005
 -3.060528136523870E-005
 -1.505023180982627E-005
 -3.049980632840063E-005
  1.419418205185865E-014
 -2.083467846839404E-014
 -2.722335149452230E-015
  1.007857126809174E-014
  2.051220001063893E-014
 -3.010849642033087E-014
 -3.934074418242679E-015
  1.456469115788710E-014
   5.65266791137201
  4.320072833764502E-005
 -6.839035851798400E-003
 -1.504683304958849E-005
   1.90799506871417
  2.671945249552784E-010
 -2.722233067834192E-015
 -2.205634954050934E-007
 -7.444903887481935E-008
  3.861259017643371E-010
 -3.933926899032234E-015
 -3.187396564265022E-007
 -1.075874368945911E-007
   767.191852521460
   206.560716167587
   14.1287202953765
  2.343755702065313E-009
  2.832588455199226E-003
 -3.049145283664438E-005
   1.90799506828217
 -8.059918257120442E-006
 -5.512982878006302E-007
 -9.146421680621731E-017
  1.007705968388188E-014
 -7.444903887492239E-008
 -2.993557073862503E-005
 -1.164751027220155E-005
 -7.966895220805124E-007
 -1.321425208009401E-016
 -1.587496207749231E-010
  1.456250674540884E-014
 -1.075874368947400E-007
 -4.326034784012443E-005
   539.596691719340
   4.40118726684136
   4.19347643925513
   200.022270877178
 -1.967152610346334E-005
 -1.604419139912711E-007
 -1.528774764600188E-007
 -7.292000879739466E-006
 -2.944468827499431E-005
 -2.401522650561294E-007
 -2.288297099083056E-007
 -1.091479592851723E-005
   339.605562179836
  4.284370806150581E-005
  4.284370806158032E-005
 -1.427195723825277E-004
   13.6814906845670
 -1.238066791256103E-005
 -4.987727490638209E-007
 -1.853160263156738E-005
 -7.465718694291021E-007
   43.0167477003996
 -1.568219569708895E-006
 -2.347338794964417E-006
   72.8257060411034
  4.283942397631686E-005
  1.285311241847409E-004
 -0.134184177806562
 -2.654929518753772E-006
  4.876219156835748E-009
 -3.973945100149968E-006
  7.298791948068736E-009
  1.476210689525495E-004
  1.285311241845174E-004
 -5.016282715224783E-004
  2.269305363898474E-009
 -6.735346577144297E-013
  2.611274199547488E-012
 -8.274052460931817E-017
 -1.007904511365527E-012
  3.907615883047510E-012
 -1.238174856409888E-016
   95.3087963439340
   4.40118726684648
   110.152164212349
  4.320067198847721E-005
 -3.764366744084013E-006
 -4.595331789205429E-006
 -6.663026588033665E-006
 -8.935388570132449E-006
   140.532512103902
   4.19347643925002
 -1.427980799210562E-004
 -0.134197831771966
 -5.019246452416286E-004
   110.150652968383
 -3.058542396138194E-005
 -6.622934873891777E-003
  2.743476449053670E-003
  4.876706778754064E-009
  2.611917370739468E-012
 -4.595247715611087E-006
 -6.282447496224100E-006
  1.284079899681477E-014
  2.417611647693701E-010
 -9.938612113479833E-011
  7.299521827272695E-009
  3.908578350284754E-012
 -8.935159881705943E-006
 -1.351770786693433E-005
  1.922030847097985E-014
  3.618714721639332E-010
 -1.487632813962649E-010
  5.342514596827266E-005
 -3.059376638324380E-005
 -1.505244036781210E-005
 -3.049163025023721E-005
  1.284180770027365E-014
 -1.884962793386070E-014
 -2.462957712585197E-015
  9.118322986299792E-015
  1.922181831772951E-014
 -2.821444343080233E-014
 -3.686585893266141E-015
  1.364846219059453E-014
   5.47374024455733
 -6.622271336864215E-003
 -1.504904152476173E-005
   1.84759979715768
  2.417369905658760E-010
 -2.462865357079513E-015
 -1.995490711623883E-007
 -6.735582672141907E-008
  3.618352878789701E-010
 -3.686447654358379E-015
 -2.986885799027866E-007
 -1.008193933241817E-007
   742.907227286771
   200.022270877505
   13.6814906845875
  2.269273810272688E-009
  2.743476449058684E-003
 -3.048327798471736E-005
   1.84759979672824
 -7.292000879739467E-006
 -4.987727490638208E-007
 -8.273937414103021E-017
 -9.938612113498041E-011
  9.116955420173514E-015
 -2.708342704041426E-005
 -7.465718694279858E-007
 -1.238157640166654E-016
 -1.487632813965374E-010
  1.364641519412200E-014
 -4.053895272171529E-005
   522.723980485623
   4.26357236788475
   4.06234996895335
   193.767757492530
 -1.769489312245172E-005
 -1.443203910012981E-007
 -1.375160516631561E-007
 -6.559286534397651E-006
 -2.773500259998460E-005
 -2.262079754664868E-007
 -2.155428685233438E-007
 -1.028103577695066E-005
   328.986383243958
  4.282862688202751E-005
 -1.426693344458388E-004
   13.2536820145078
 -1.113663442411282E-005
 -4.486550972829839E-007
 -1.745557775027560E-005
 -7.032226824477336E-007
   41.6716504367713
 -1.410641834963987E-006
 -2.211042174219612E-006
   70.5485098982674
  4.282434430485539E-005
  1.284858806460825E-004
 -0.130001424215398
 -2.388156956539782E-006
  4.386241319773609E-009
 -3.743200527853205E-006
  6.874984719344465E-009
  1.469960137168231E-004
 -4.992297040455787E-004
  2.198097262593681E-009
 -6.057753682392035E-013
  2.348573266233997E-012
 -7.441699463006189E-017
 -9.492879700929949E-013
  3.680361097545891E-012
 -1.166171499980067E-016
   92.9084174780717
   4.26357236788475
   107.867534985195
  4.320061865935775E-005
 -1.443203910014657E-007
 -4.614696806808962E-006
 -6.590868678812579E-006
 -2.262079754659446E-007
 -8.898964831335870E-006
 -1.366246832386364E-005
   138.457695718421
   4.06234996895335
 -1.427478143495179E-004
 -0.130014659822665
 -4.995254261304305E-004
   107.866013012669
 -3.057440990051254E-005
 -6.415563239636361E-003
  2.658233875688121E-003
 -1.375160516629884E-007
  4.386679943906497E-009
  2.349151732732920E-012
 -6.590670195002901E-006
 -1.056574445156532E-005
  1.155052245822834E-014
  2.174682524562805E-010
 -8.939972797230806E-011
 -2.155428685230809E-007
  6.875672217815162E-009
  3.681267590652722E-012
 -1.366199063184802E-005
 -2.322462537179310E-005
  1.810428351462764E-014
  3.408592778400850E-010
 -1.401255975737136E-010
  5.340897811476350E-005
 -3.058275145718675E-005
 -1.505455301053174E-005
 -3.048380922149933E-005
  1.155142980573172E-014
 -1.695557681648910E-014
 -2.215471010875720E-015
  8.202094727295602E-015
  1.810570569374851E-014
 -2.657618570997923E-014
 -3.472521575305685E-015
  1.285597154157513E-014
   5.30258250954564
 -6.414920438125181E-003
 -1.505115408825913E-005
   1.78982718936297
  2.174465073513424E-010
 -2.215387935544766E-015
 -1.794979946375386E-007
 -6.058778310575515E-008
  3.408251946088613E-010
 -3.472391363325674E-015
 -2.813454319198783E-007
 -9.496538437425974E-008
   719.677161615427
   193.767757492530
   13.2536820144880
  2.198066699077609E-009
  2.658233875692959E-003
 -3.047545812895602E-005
   1.78982718893097
 -6.559286534408384E-006
 -4.486550972836547E-007
 -7.441595989668572E-017
 -8.939972797247184E-011
  8.200864577072990E-015
 -6.058778310583901E-008
 -2.436203192185867E-005
 -1.028103577693384E-005
 -1.166155284910405E-016
 -1.401255975739702E-010
  1.285404340286527E-014
 -3.818508617480307E-005
   507.480809558198
   4.13924811561671
   3.94388748706581
   188.117295315910
 -1.598520744764524E-005
 -1.303761051939632E-007
 -1.242292106782187E-007
 -5.925526381416418E-006
 -2.631357944261518E-005
 -2.146147712591424E-007
 -2.044962624089082E-007
 -9.754131113075971E-006
   319.392788155672
  4.281607858259916E-005
  4.281607858258054E-005
 -1.426275339573818E-004
   12.8671904430283
 -1.006060956177639E-005
 -4.053059110676836E-007
 -1.656097665124283E-005
 -6.671824096030911E-007
   40.4564605826200
 -1.274345214219084E-006
 -2.097725922095767E-006
   68.4912418338210
  4.281179726008679E-005
  1.284482357477416E-004
 -0.126222655558857
 -2.157412441190561E-006
  3.962436359231722E-009
 -3.551360774868571E-006
  6.522634194127350E-009
  1.464348220764452E-004
  1.284482357477975E-004
 -4.970745765117384E-004
  2.133797892759344E-009
 -5.471806171328391E-013
  2.121403016151983E-012
 -6.721919332723600E-017
 -9.005649721606008E-013
  3.491463330247929E-012
 -1.106320875694086E-016
   90.7398666114593
   4.13924811560679
   105.803557976585
  4.320057094635411E-005
 -6.850632260931479E-006
 -1.131794283692148E-005
 -2.146147712596412E-007
 -1.260739259268388E-005
 -2.129168337138779E-005
   136.583274524079
   3.94388748706100
 -1.427059908669560E-004
 -0.126235513220084
 -4.973697171423132E-004
   105.802026311347
 -3.056445957537884E-005
 -6.228219748320937E-003
  2.581223687348777E-003
  3.962832602872613E-009
  2.121925529357259E-012
 -1.131749534980319E-005
 -2.027265075967836E-005
  1.043450062187507E-014
  1.964561654686551E-010
 -8.076199997441398E-011
 -2.044962624094069E-007
  6.523286457548657E-009
  3.492323296778374E-012
 -2.129081371100810E-005
 -3.869319706225708E-005
  1.717642721819822E-014
  3.233898785021479E-010
 -1.329442662065657E-010
  5.339437173469686E-005
 -3.057280035034988E-005
 -1.505646161032820E-005
 -3.047674353829522E-005
  1.043532030158376E-014
 -1.531732063348915E-014
 -2.001408190402490E-015
  7.409604660113805E-015
  1.717777651096070E-014
 -2.521414767292956E-014
 -3.294550000909386E-015
  1.219709934524964E-014
   5.14795492337030
  4.320057094635413E-005
 -6.227595679686349E-003
 -1.505306261647085E-005
   1.73763417035051
  1.964365214059950E-010
 -2.001333141972795E-015
 -1.621548466533910E-007
 -5.473377411848640E-008
  3.233575420734400E-010
 -3.294426462458326E-015
 -2.669264351855626E-007
 -9.009839389891173E-008
   698.690619691020
   188.117295315602
   12.8671904430283
  2.133768223296939E-009
  2.581223687353416E-003
 -3.046839350544701E-005
   1.73763416991851
 -5.925526381416419E-006
 -4.053059110670776E-007
 -6.721825867573963E-017
 -8.076199997456191E-011
  7.408493367545432E-015
 -2.200816537484728E-005
 -9.754131113075973E-006
 -6.671824096040885E-007
 -1.106305492819806E-016
  1.219527002419845E-014
 -9.009839389891174E-008
 -3.622809462479421E-005
   494.123472076652
   4.03030484844881
   3.84008077972004
   183.165889166908
 -1.456378429042650E-005
 -1.187829042954491E-007
 -1.131826049482859E-007
 -5.398621716291095E-006
 -2.515337412618467E-005
 -2.051520742424145E-007
 -1.954797136058127E-007
 -9.324056796903173E-006
   310.986080138009
  4.280589474002302E-005
  4.280589473998577E-005
 -1.425936098706880E-004
   12.5285142990101
 -9.166008479837793E-006
 -3.692656389118050E-007
 -1.583077822578839E-005
 -6.377653314100721E-007
   39.3916098987321
 -1.161028962095281E-006
 -2.005234029400292E-006
   66.6884920045010
  4.280161443598695E-005
  1.284176842199573E-004
 -0.122911399390467
 -1.965572739607205E-006
  3.610087797596484E-009
 -3.394775805088766E-006
  6.235036123879029E-009
  1.459456901876358E-004
  1.284176842200691E-004
 -4.951949416269657E-004
  2.077476370918183E-009
 -4.984757140761507E-013
  1.932575450184578E-012
 -6.123623068044075E-017
 -8.608025886773212E-013
  3.337305634048852E-012
 -1.057477156323251E-016
   88.8396049253354
   4.03030484845817
   103.994936051931
  4.320052948783570E-005
 -1.187829042951644E-007
 -1.055905666821901E-005
 -1.894715116049629E-005
 -1.754807733606927E-005
 -3.134657801546342E-005
   134.940764133538
   3.84008077972941
 -1.426720481199565E-004
 -0.122923925870147
 -4.954895782009185E-004
   103.993395892559
 -3.055574028219376E-005
 -6.064054151815194E-003
  2.513740776797339E-003
 -1.131826049481478E-007
  3.610448806375594E-009
  1.933051454108538E-012
 -1.894631170540786E-005
 -3.574120899673445E-005
  9.506647020826595E-015
  1.789868588603020E-010
 -7.358063044247951E-011
 -1.954797136055743E-007
  6.235659627488153E-009
  3.338127630687446E-012
 -3.134519704335193E-005
 -5.897450979705279E-005
  1.641908537410987E-014
  3.091308802709708E-010
 -1.270826570897611E-010
  5.338157241213808E-005
 -3.056408037229324E-005
 -1.505813407913032E-005
 -3.047055199955559E-005
  9.507393813975940E-015
 -1.395528392496591E-014
 -1.823437909705915E-015
  6.750732966416450E-015
  1.642037517485076E-014
 -2.410241435040546E-014
 -3.149284820100352E-015
  1.165930951518852E-014
   5.01245733810184
  4.320052948773977E-005
 -6.063446498456228E-003
 -1.505473502256900E-005
   1.69189829464496
  1.789689615903928E-010
 -1.823369534764103E-015
 -1.477358499176869E-007
 -4.986678361028624E-008
  3.090999696292122E-010
 -3.149166728823126E-015
 -2.551572469730332E-007
 -8.612582021365064E-008
   680.300461606910
   183.165889166908
   12.5285142990289
  2.077447484581011E-009
 -3.046220289536761E-005
   1.69189829421296
 -5.398621716282260E-006
 -6.123537921927372E-017
 -7.358063044261430E-011
  6.749720491434658E-015
 -2.005117382471376E-005
 -9.324056796918428E-006
 -1.057462452598041E-016
 -1.270826570899940E-010
  1.165756085188271E-014
 -3.463074341469075E-005
   482.637703409917
   3.93662621915843
   3.75081899008138
   178.908251317559
 -1.340357897419681E-005
 -1.093202101931598E-007
 -1.041660565071896E-007
 -4.968547399030346E-006
 -2.421476737820223E-005
 -1.974967472828751E-007
 -1.881853205288337E-007
 -8.976126435281720E-006
   303.757281459947
  4.279772522312137E-005
  4.279772522306550E-005
 -1.425663958406795E-004
   12.2372919017685
 -8.435810069810161E-006
 -3.398485613411929E-007
 -1.524004729204105E-005
 -6.139668987381353E-007
   38.4759612048478
 -1.068537069399785E-006
 -1.930408036628126E-006
   65.1383352081991
  4.279344573587430E-005
  1.283931756691965E-004
 -0.120064112940655
 -1.808987816181531E-006
  3.322491443303755E-009
 -3.268098476248128E-006
  6.002369299005800E-009
  1.455269920838588E-004
  1.283931756693641E-004
 -4.935850702627663E-004
  2.029062415915347E-009
 -4.587286861551478E-013
  1.778477328960429E-012
 -5.635363771206687E-017
 -8.286390777636647E-013
  3.212608567887804E-012
 -1.017967701040207E-016
   87.2056024382183
   3.93662621915843
   102.439736444137
  4.320049409262739E-005
 -1.093202101934138E-007
 -1.549973821012784E-005
 -2.900203938739646E-005
 -1.974967472828607E-007
 -2.331567762669807E-005
 -4.302233760456776E-005
   133.528407846701
   3.75081899007680
 -1.426448191195810E-004
 -0.120076354646676
 -4.938792773515199E-004
   102.438188980797
 -3.054824270478395E-005
 -5.922890974539811E-003
  2.455713142815604E-003
 -1.041660565074436E-007
  3.322823692449049E-009
  1.778915377661905E-012
 -2.900068862083162E-005
 -5.602250889185213E-005
  8.749307528295077E-015
  1.647279415334707E-010
 -6.771898802868645E-011
 -1.881853205290631E-007
  6.002969535934473E-009
  3.213399850944474E-012
 -4.302036592269294E-005
 -8.246479154072428E-005
  1.580639565370046E-014
  2.975953514876636E-010
 -1.223406084502545E-010
  5.337056647609295E-005
 -3.055658220594097E-005
 -1.505957220522758E-005
 -3.046522799245314E-005
  8.749994829395280E-015
 -1.284355176148487E-014
 -1.678173857643763E-015
  6.212943574883318E-015
  1.580763732547083E-014
 -2.320302159750192E-014
 -3.031765329716781E-015
  1.122423729010415E-014
   4.89594505251747
 -5.922297436380773E-003
 -1.505617309477480E-005
   1.65257071981538
  1.647114700428902E-010
 -1.678110929778371E-015
 -1.359666617045749E-007
 -4.589420989668041E-008
  2.975655943063373E-010
 -3.031651645155069E-015
 -2.456359671459297E-007
 -8.291200588438052E-008
   664.487048059114
   178.908251317852
   12.2372919017685
  2.029034202751575E-009
  2.455713142820070E-003
 -3.045687968674863E-005
   1.65257071938338
 -4.968547399030347E-006
 -3.398485613417010E-007
 -5.635285414109463E-017
  6.212011757559409E-015
 -4.589420989668040E-008
 -1.845382261455814E-005
 -6.139668987381352E-007
 -1.017953546674797E-016
 -1.223406084502544E-010
  1.122255387888318E-014
 -8.291200588426578E-008
 -3.333848539495451E-005
   472.888872939196
   3.85711416892407
   3.67505583538167
   175.294475800181
 -1.246497222632115E-005
 -1.016648857833275E-007
 -9.687166376494651E-008
 -4.620617036385969E-006
 -2.345864863641313E-005
 -1.913298024073700E-007
 -1.823091350307439E-007
 -8.695842207772688E-006
   297.621659642064
  4.279120496661262E-005
  4.279120496661261E-005
 -1.425446757734917E-004
   11.9901096833589
 -7.845079149841812E-006
 -3.160501292214860E-007
 -1.476416883537590E-005
 -5.947954608412494E-007
   37.6987817101859
 -9.937110766276354E-007
 -1.870130038811978E-006
   63.8226012564150
  4.278692613149661E-005
  1.283736148998378E-004
 -0.117647416401617
 -1.682310528708263E-006
  3.089826109386854E-009
 -3.166050303653915E-006
  5.814938679596496E-009
  1.451729467814764E-004
 -4.922231489160810E-004
  1.987980852823571E-009
 -4.265781722317064E-013
  1.653830688100767E-012
 -5.240419562565373E-017
 -8.027316768119451E-013
  3.112166274535217E-012
 -9.861431387796796E-017
   85.8187052081483
   3.85711416892379
   101.119727942204
  4.320046422960203E-005
 -2.126733599433926E-005
 -4.067779395097722E-005
 -2.947778891852606E-005
 -5.545994269029702E-005
   132.329646852409
   3.67505583538615
 -1.426230871049887E-004
 -0.117659416402176
 -4.925169942464478E-004
   101.118174279045
 -3.054187895623437E-005
 -5.803075440925709E-003
  2.406460666729715E-003
 -9.687166376482836E-008
  3.090135091996175E-009
  1.654238035648607E-012
 -4.067585247482809E-005
 -7.951278057947675E-005
  8.136619848421074E-015
  1.531924829466343E-010
 -6.297691049814014E-011
  5.815520173473563E-009
  3.112932818090903E-012
 -5.545734355963312E-005
 -1.074517854572249E-004
  1.531282789390816E-014
  2.883026159002972E-010
 -1.185205272610541E-010
  5.336122491813248E-005
 -3.055021795756615E-005
 -1.506079284745856E-005
 -3.046070911075719E-005
  8.137259020340196E-015
 -1.194416001439482E-014
 -1.560655346610553E-015
  5.777871730282703E-015
  1.531403079417108E-014
 -2.247849277443114E-014
 -2.937094566788683E-015
  1.087375372913898E-014
   4.79705236601993
  4.320046422950610E-005
 -5.802493883349224E-003
 -1.505739369118660E-005
   1.61919046711385
  1.531771649106091E-010
 -1.560596825456159E-015
 -1.264453818763223E-007
 -4.268039554242989E-008
  2.882737879198500E-010
 -2.936984432136395E-015
 -2.379658559534807E-007
 -8.032303531320715E-008
   651.065021870458
   175.294475800181
   11.9901096833589
  1.987953210878359E-009
  2.406460666729658E-003
 -3.045236148263085E-005
   1.61919046667961
 -4.620617036393530E-006
 -3.160501292214861E-007
 -5.240346696982631E-017
 -6.297691049825552E-011
  5.777005165048519E-015
 -1.716156459469205E-005
 -8.695842207758458E-006
 -5.947954608403601E-007
 -9.861294269173748E-017
 -1.185205272608369E-010
  1.087212288347045E-014
 -8.032303531298483E-008
 -3.229747379982123E-005
   464.693881009595
   3.79027532339420
   3.61136835500485
   172.256689749724
 -1.170885348468595E-005
 -9.549794311544257E-008
 -9.099547857000161E-008
 -4.340332808042565E-006
 -2.285068524137260E-005
 -1.863712205314548E-007
 -1.775843404781262E-007
 -8.470477405734992E-006
   292.463977248685
  4.278601026346223E-005
  4.278601026338771E-005
 -1.425273713467139E-004
   11.7823251403194
 -7.369200705302896E-006
 -2.968786918119697E-007
 -1.438153490975490E-005
 -5.793805109966138E-007
   37.0454746591313
 -9.334330788114754E-007
 -1.821663026717604E-006
   62.7165784223655
  4.278173194759615E-005
  1.283580307901631E-004
 -0.115615916095479
 -1.580262392541541E-006
  2.902396772405163E-009
 -3.083997643528247E-006
  5.664233641591620E-009
  1.448762539005229E-004
  1.283580307903866E-004
 -4.910814055463379E-004
  1.953454567316949E-009
 -4.006816750159657E-013
  1.553430699437830E-012
 -4.922299883149769E-017
 -7.819023784351846E-013
  3.031411649429309E-012
 -9.605564539199402E-017
   84.6528639144682
   3.79027532339420
   100.010116480909
  4.320043925022237E-005
 -9.549794311543564E-008
 -2.742944572589085E-005
 -5.311539590479399E-005
 -1.863712205319150E-007
 -3.565854980161262E-005
 -6.791275318198878E-005
   131.321962245464
   3.61136835500485
 -1.426057731586538E-004
 -0.115627712917652
 -4.913749486971013E-004
   100.008557605901
 -3.053652951194656E-005
 -5.702357112445189E-003
  2.365058343641181E-003
 -9.099547857011259E-008
  2.902687012081810E-009
  1.553813317913191E-012
 -5.311282698014740E-005
 -1.044997682275328E-004
  7.643053841465227E-015
  1.438998076615579E-010
 -5.915680449033953E-011
 -1.775843404785593E-007
  5.664800064957864E-009
  3.032158302678347E-012
 -6.790952693952616E-005
 -1.324472870664449E-004
  1.491597084291542E-014
  2.808307201187177E-010
 -1.154489586201529E-010
  5.335337228700642E-005
 -3.054486809298520E-005
 -1.506181893293717E-005
 -3.045691048144035E-005
  7.643654241733717E-015
 -1.121963205526048E-014
 -1.465985424974992E-015
  5.427388496223294E-015
  1.491714256838460E-014
 -2.189592955925978E-014
 -2.860973822222798E-015
  1.059194460369983E-014
   4.71392190537952
  4.320043925022236E-005
 -5.701785625921198E-003
 -1.505841973821399E-005
   1.59113059852330
  1.438854188189634E-010
 -1.465930453731380E-015
 -1.187752706833705E-007
 -4.009142494986485E-008
  2.808026392688783E-010
 -2.860866542009515E-015
 -2.317986409597516E-007
 -7.824135256660783E-008
   639.782294509423
   172.256689749442
   11.7823251403018
  1.953427405438523E-009
  2.365058343636880E-003
 -3.044856342321545E-005
   1.59113059808689
 -4.922231440869002E-017
 -5.915680449033951E-011
  5.426574496442379E-015
 -4.009142494980936E-008
 -1.612055299949967E-005
 -8.470477405762714E-006
 -5.793805109957476E-007
 -9.605430978315037E-017
  1.059035602380571E-014
 -7.824135256649955E-008
 -3.146043999974818E-005
   457.856936836778
   3.73451279935024
   3.55823495885675
   169.722315851128
 -1.110089008968244E-005
 -9.053936312887399E-008
 -8.627068428741360E-008
 -4.114968005269801E-006
 -2.236217953142310E-005
 -1.823869419501355E-007
 -1.737879126816982E-007
 -8.289394147281641E-006
   288.161009424264
  4.278187191641978E-005
  4.278187191643841E-005
 -1.425135858192233E-004
   11.6089739847437
 -6.986566790237860E-006
 -2.814637423910151E-007
 -1.407408406797488E-005
 -5.669944182119043E-007
   36.5004315553476
 -8.849660667171142E-007
 -1.782719214737096E-006
   61.7938421424438
  4.277759401441512E-005
  1.283456157493152E-004
 -0.113921073488889
 -1.498209764083056E-006
  2.751692825998769E-009
 -3.018067369211945E-006
  5.543140421411730E-009
  1.446293568162926E-004
  1.283456157492594E-004
 -4.901309851844084E-004
  1.924654811956465E-009
 -3.798614427415885E-013
  1.472711249905754E-012
 -4.666537602381475E-017
 -7.651669216566661E-013
  2.966528738364792E-012
 -9.399986097607462E-017
   83.6802238907465
   3.73451279935946
   99.0843898582671
  4.320041849511186E-005
 -9.053936312887398E-008
 -3.361020599707605E-005
 -6.556820516302686E-005
 -1.823869419497116E-007
 -4.157444984765205E-005
 -7.981799979322546E-005
   130.481275094948
   3.55823495886543
 -1.425919800480504E-004
 -0.113932700803910
 -4.904242775432806E-004
   99.0828266346686
 -3.053206656334373E-005
 -5.618329603075525E-003
  2.330517039043538E-003
 -8.627068428741362E-008
  2.751967995285679E-009
  1.473073986732267E-012
 -6.556500912660118E-005
 -1.294952673656874E-004
  7.246198280519924E-015
  1.364279631482848E-010
 -5.608521474906845E-011
 -1.737879126812743E-007
  5.543694735460854E-009
  2.967259410590223E-012
 -7.981417470056846E-005
 -1.563300004252203E-004
  1.459709161754086E-014
  2.748269665410614E-010
 -1.129809163255220E-010
  5.334682097016735E-005
 -3.054040479373947E-005
 -1.506267497739121E-005
 -3.045374134942629E-005
  7.246767506131108E-015
 -1.063706957455989E-014
 -1.389865395669693E-015
  5.145579648696373E-015
  1.459823829395909E-014
 -2.142783322303702E-014
 -2.799809943098393E-015
  1.036550768219463E-014
   4.64456755781483
  4.320041849520777E-005
 -5.617766518640608E-003
 -1.505927575061468E-005
   1.56772072124482
  1.364143214314318E-010
 -1.389813278743050E-015
 -1.126080556889531E-007
 -3.800974218512911E-008
  2.747994860190150E-010
 -2.799704956347053E-015
 -2.268432114671239E-007
 -7.656869609354258E-008
   630.369304506717
   169.722315851684
   11.6089739847264
  1.924628050531071E-009
 -3.044539476657120E-005
   1.56772072081065
 -4.114968005263068E-006
 -2.814637423905944E-007
 -4.666472716343609E-017
 -5.608521474896570E-011
  5.144807914620802E-015
 -3.800974218502392E-008
 -1.528351919938359E-005
 -8.289394147268078E-006
 -5.669944182119041E-007
 -9.399855395192384E-017
  1.036395306326714E-014
 -7.656869609343663E-008
 -3.078787353606376E-005
   452.187674056952
   3.68827395609145
   3.51417621270744
   167.620787559024
 -1.061238437990190E-005
 -8.655508614902513E-008
 -8.247425672789331E-008
 -3.933884746186034E-006
 -2.196968760225050E-005
 -1.791857569026412E-007
 -1.707376570796586E-007
 -8.143902055742190E-006
   284.592945286095
  4.277857254333755E-005
  4.277857254331892E-005
 -1.425025950543404E-004
   11.4652294654552
 -6.679115957492790E-006
 -2.690776499685709E-007
 -1.382706141978584E-005
 -5.570427608249762E-007
   36.0484763393176
 -8.460222547366138E-007
 -1.751429648240367E-006
   61.0286999516254
  4.277429497135657E-005
  1.283357176299567E-004
 -0.112515695692110
 -1.432279516965045E-006
  2.630600526294370E-009
 -2.965095417609060E-006
  5.445847601113638E-009
  1.444250519250095E-004
  1.283357176300126E-004
 -4.893443164702751E-004
  1.900777046818836E-009
 -3.631334684217662E-013
  1.407857370474367E-012
 -4.461045347181723E-017
 -7.517214757843205E-013
  2.914401110890515E-012
 -9.234821981442553E-017
   82.8737023593140
   3.68827395608288
   98.3167707369048
  4.320040134211208E-005
 -8.655508614923886E-008
 -3.952610622984322E-005
 -7.747345213954460E-005
 -4.703851801369225E-005
 -9.080521812608830E-005
   129.784174263766
   3.51417621269887
 -1.425809832378552E-004
 -0.112527182451312
 -4.896374017550776E-004
   98.3152039076572
 -3.052836584339723E-005
 -5.548653217527472E-003
  2.301875013870488E-003
 -8.247425672809446E-008
  2.630863586347968E-009
  1.408204133435459E-012
 -7.746965725280159E-005
 -1.533779814513349E-004
  6.927320310632367E-015
  1.304242527566959E-010
 -5.361715468025307E-011
  5.446392185852086E-009
  2.915118943788318E-012
 -9.080084079321318E-005
 -1.783624626579424E-004
  1.434088682848105E-014
  2.700032273503620E-010
 -1.109979569781182E-010
  5.334138855317710E-005
 -3.053670378323240E-005
 -1.506338481713880E-005
 -3.045111347381753E-005
  6.927864486920098E-015
 -1.016897385717798E-014
 -1.328702119063527E-015
  4.919142961261070E-015
  1.434201337905689E-014
 -2.105173930954776E-014
 -2.750667591529566E-015
  1.018357601041762E-014
   4.58705823622703
  4.320040134211207E-005
 -5.548097100178608E-003
 -1.505998556365953E-005
   1.54830901586015
  1.304112113634483E-010
 -1.328652295662273E-015
 -1.076526261956419E-007
 -3.633708569653336E-008
  2.699762291642696E-010
 -2.750564447517513E-015
 -2.228617511851999E-007
 -7.522479334503947E-008
   622.563958653790
   167.620787558750
   11.4652294654552
  1.900750617402029E-009
  2.301875013870450E-003
 -3.044276728488430E-005
   1.54830901542600
 -3.933884746198907E-006
 -2.690776499681686E-007
 -4.460983318431687E-017
 -5.361715468025308E-011
  4.918405188180024E-015
 -3.633708569648307E-008
 -1.461095273561755E-005
 -8.143902055755514E-006
 -5.570427608258092E-007
 -9.234693575581843E-017
 -1.109979569783216E-010
  1.018204867765056E-014
 -7.522479334503948E-008
 -3.024749723440055E-005
   447.510135391996
   3.65012367468408
   3.47782466257362
   165.886879601416
 -1.021989245077265E-005
 -8.335390244660463E-008
 -7.942400133025835E-008
 -3.788392654134612E-006
 -2.165426891283109E-005
 -1.766131853124889E-007
 -1.682863770461354E-007
 -8.026980097818116E-006
   281.649042592051
  4.277593901585898E-005
  4.277593901587760E-005
 -1.424938223332824E-004
   11.3466301742757
 -6.432093317009632E-006
 -2.591259928922192E-007
 -1.362854635692849E-005
 -5.490453002446791E-007
   35.6755816472936
 -8.147326882398728E-007
 -1.726284381999297E-006
   60.3974040812520
  4.277166170712584E-005
  1.283278170476328E-004
 -0.111356162460519
 -1.379307588475011E-006
  2.533308475891363E-009
 -2.922525513708920E-006
  5.367660089926241E-009
  1.442567707203618E-004
  1.283278170475769E-004
 -4.886962176596308E-004
  1.881078386038380E-009
 -3.496941626477615E-013
  1.355753566668780E-012
 -4.295951869150960E-017
 -7.409167661535257E-013
  2.872511546363826E-012
 -9.102096601689562E-017
   82.2082666171099
   3.65012367468408
   97.6834331891382
  4.320038722805753E-005
 -8.335390244641091E-008
 -4.499017516891919E-005
 -8.846067201128855E-005
 -1.766131853125017E-007
 -5.194766046845125E-005
 -1.006710349690448E-004
   129.209021214825
   3.47782466257362
 -1.425722056904195E-004
 -0.111367533251336
 -4.889891326870735E-004
   97.6818633844735
 -3.052531249186766E-005
 -5.491165368773658E-003
  2.278243318719099E-003
 -7.942400133006463E-008
  2.533561806742143E-009
  1.356087496174631E-012
 -8.845632488445122E-005
 -1.754104467586210E-004
  6.671116570534434E-015
  1.256005496546069E-010
 -5.163418047932553E-011
 -1.682863770463406E-007
  5.368196855923373E-009
  2.873219061632396E-012
 -1.006661620340711E-004
 -1.981407274897190E-004
  1.413499273838211E-014
  2.661267217955105E-010
 -1.094043889676766E-010
  5.333690642976148E-005
 -3.053365019187521E-005
 -1.506397048389406E-005
 -3.044894529243953E-005
  6.671640620958666E-015
 -9.792880460726505E-015
 -1.279560270986186E-015
  4.737211485169815E-015
  1.413610311522405E-014
 -2.074949858696363E-014
 -2.711175285863497E-015
  1.003737008035456E-014
   4.53960902001947
  4.320038722815345E-005
 -5.490614999758892E-003
 -1.506057120851815E-005
   1.53229299999960
  1.255879905934738E-010
 -1.279512290273664E-015
 -1.036711659131532E-007
 -3.499318293515653E-008
  2.661001112290489E-010
 -2.711073622694056E-015
 -2.196621261976654E-007
 -7.414479140827847E-008
   616.124001916561
   165.886879601687
   11.3466301742927
  1.881052230527239E-009
  2.278243318723357E-003
 -3.044059942893824E-005
   1.53229299956760
 -3.788392654128413E-006
 -4.295892135947258E-017
 -5.163418047932551E-011
  4.736500998152278E-015
 -3.499318293510810E-008
 -1.407057643394822E-005
 -8.026980097831250E-006
 -5.490453002454999E-007
 -9.101970041293473E-017
 -1.094043889674763E-010
  1.003586467550823E-014
 -7.414479140838108E-008
 -2.981323407590485E-005
   443.666775594097
   3.61877700614701
   3.44795594373349
   164.462191829850
 -9.904473761425764E-006
 -8.078133197859520E-008
 -7.697272147190485E-008
 -3.671470695762520E-006
 -2.140070154580522E-005
 -1.745450764031961E-007
 -1.663157752799306E-007
 -7.932985689706988E-006
   279.230147085017
  4.277383428283669E-005
  4.277383428281806E-005
 -1.424868111144127E-004
   11.2491815415255
 -6.233578260614989E-006
 -2.511285325703940E-007
 -1.346895866120113E-005
 -5.426160838050282E-007
   35.3691879281293
 -7.895874219987956E-007
 -1.706069920498922E-006
   59.8786917110657
  4.276955718458261E-005
  1.283215028484542E-004
 -0.110403418296697
 -1.336737704036555E-006
  2.455121604388595E-009
 -2.888303259606923E-006
  5.304804594805312E-009
  1.441186899549583E-004
  1.283215028485101E-004
 -4.881643371386299E-004
  1.864894154185054E-009
 -3.388944698532433E-013
  1.313883467788969E-012
 -4.163284142341022E-017
 -7.322310836976917E-013
  2.838837392697642E-012
 -8.995401340280483E-017
   81.6615034820317
   3.61877700614727
   97.1630446485635
  4.320037565664122E-005
 -8.078133197859523E-008
 -4.989931876984180E-005
 -9.832649114080293E-005
 -1.745450764033989E-007
 -5.626355196762280E-005
 -1.093410661721953E-004
   128.736442122697
   3.44795594373770
 -1.425651906152753E-004
 -0.110414693801725
 -4.884571126690124E-004
   97.1614723995665
 -3.052280366716963E-005
 -5.443929770127349E-003
  2.258826019485049E-003
 -7.697272147190484E-008
  2.455367116539267E-009
  1.314207084457084E-012
 -9.832164841168007E-005
 -1.951887161607439E-004
  6.465223351365131E-015
  1.217240740609345E-010
 -5.004060013802933E-011
 -1.663157752801335E-007
  5.305335075267050E-009
  2.839536613829786E-012
 -1.093357578796852E-004
 -2.155182770118045E-004
  1.396947300600221E-014
  2.630103714964189E-010
 -1.081233078774354E-010
  5.333322363575545E-005
 -3.053114117007113E-005
 -1.506445170412156E-005
 -3.044716377880862E-005
  6.465731227982284E-015
 -9.490640167429256E-015
 -1.240068383308191E-015
  4.591005717456543E-015
  1.397057038056839E-014
 -2.050652509100838E-014
 -2.679427143493064E-015
  9.919834078137517E-015
   4.50062176132410
  4.320037565654530E-005
 -5.443384124293586E-003
 -1.506105241067525E-005
   1.51913323459308
  1.217119026167794E-010
 -1.240021883458966E-015
 -1.004715409250106E-007
 -3.391318098753017E-008
  2.629840725405677E-010
 -2.679326670835904E-015
 -2.170899245149918E-007
 -7.327657003535931E-008
   610.832528645480
   164.462191830119
   11.2491815415423
  1.864868223704073E-009
  2.258826019480944E-003
 -3.043881818232770E-005
   1.51913323416318
 -3.671470695768528E-006
 -2.511285325707695E-007
 -4.163226253831124E-017
 -5.004060013812101E-011
  4.590317158402351E-015
 -1.363631327539815E-005
 -7.932985689719970E-006
 -5.426160838066508E-007
 -8.995276263419644E-017
  9.918346301373946E-015
 -2.946412678015120E-005
   440.519636170443
   3.59310875246282
   3.42349791014528
   163.295584671313
 -9.650906394460359E-006
 -7.871322399937198E-008
 -7.500211985327084E-008
 -3.577476287289291E-006
 -2.119677974267003E-005
 -1.728818793547234E-007
 -1.647309945900269E-007
 -7.857394301881798E-006
   277.249431822299
  4.277215006226301E-005
  4.277215006215125E-005
 -1.424812006932372E-004
   11.1693856207631
 -6.073990570300188E-006
 -2.446993163477350E-007
 -1.334061639431453E-005
 -5.374456337391004E-007
   35.1182970921375
 -7.693729604984341E-007
 -1.689813217254249E-006
   59.4539435128307
  4.276787313239219E-005
  1.283164501864537E-004
 -0.109623263502374
 -1.302515466200490E-006
  2.392266637755820E-009
 -2.860781327675288E-006
  5.254255487148679E-009
  1.440057481309845E-004
  1.283164501867890E-004
 -4.877292293582548E-004
  1.851642614029554E-009
 -3.302128732684648E-013
  1.280225167728344E-012
 -4.056635790838943E-017
 -7.252461526003724E-013
  2.811757005775035E-012
 -8.909598126478346E-017
   81.2137863741256
   3.59310875246699
   96.7369248978206
  4.320036619831868E-005
 -7.871322399937771E-008
 -5.421521160684710E-005
 -1.069965250149917E-004
 -1.728818793547109E-007
 -5.999325751391114E-005
 -1.168312627944689E-004
   128.349472177252
   3.42349791014945
 -1.425595771079739E-004
 -0.109634460982953
 -4.880218909225970E-004
   96.7353506469261
 -3.052074931389529E-005
 -5.405250869063909E-003
  2.242926133811596E-003
 -7.500211985336230E-008
  2.392505864414310E-009
  1.280540494173080E-012
 -1.069912469279689E-004
 -2.125662710225643E-004
  6.299704337913275E-015
  1.186077484976275E-010
 -4.875950886730426E-011
  5.254780912691263E-009
  2.812449556865817E-012
 -1.168255785005302E-004
 -2.305288178276323E-004
  1.383636013738787E-014
  2.605041669825349E-010
 -1.070930475295342E-010
  5.333020797609215E-005
 -3.052908665539111E-005
 -1.506484575156780E-005
 -3.044570498430089E-005
  6.300199212296116E-015
 -9.247667025882170E-015
 -1.208320586031830E-015
  4.473469849386574E-015
  1.383744705547416E-014
 -2.031112300645993E-014
 -2.653894926042466E-015
  9.825310270657643E-015
   4.46869700138961
  4.320036619822276E-005
 -5.404709090819155E-003
 -1.506144644329229E-005
   1.50835734611809
  1.185958886612572E-010
 -1.208275276641059E-015
 -9.789933924232610E-008
 -3.304495960582077E-008
  2.604781186274062E-010
 -2.653795410797950E-015
 -2.150213302348083E-007
 -7.257833638673053E-008
   606.499599901935
   163.295584671580
   11.1693856207965
  1.851616867802476E-009
  2.242926133811616E-003
 -3.043735960667308E-005
   1.50835734568609
 -3.577476287295145E-006
 -2.446993163481009E-007
 -4.056579385215607E-017
 -4.875950886721495E-011
  4.472798918342162E-015
 -3.304495960586651E-008
 -1.328720597961191E-005
 -5.374456337382968E-007
 -8.909474242694049E-017
 -1.070930475297304E-010
  9.823836670513794E-015
 -7.257833638663007E-008
 -2.918337066368183E-005
   437.949897794531
   3.57214981594411
   3.40352715597823
   162.343013215102
 -9.446984591386494E-006
 -7.705002771773993E-008
 -7.341733928727085E-008
 -3.501884899144399E-006
 -2.103272310875386E-005
 -1.715438247451492E-007
 -1.634560265272820E-007
 -7.796580458275913E-006
   275.632115479322
  4.277080078025992E-005
  4.277080078025993E-005
 -1.424767060088727E-004
   11.1042297404043
 -5.945648307932664E-006
 -2.395288664613593E-007
 -1.323736406927219E-005
 -5.332859675277749E-007
   34.9134368293553
 -7.531162572537467E-007
 -1.676734576461128E-006
   59.1071232427771
  4.276652398518883E-005
  1.283124023407798E-004
 -0.108986243105615
 -1.274993547774900E-006
  2.341717964720884E-009
 -2.838639725004530E-006
  5.213588351904769E-009
  1.439136106569968E-004
 -4.873742296864411E-004
  1.840822927572956E-009
 -3.232312618453488E-013
  1.253157661624563E-012
 -3.970870659220238E-017
 -7.196268487606374E-013
  2.789971118524204E-012
 -8.840570309627028E-017
   80.8482116053791
   3.57214981594385
   96.3889853901355
  4.320035848637524E-005
 -7.705002771782946E-008
 -5.794491854576422E-005
 -1.144867244181705E-004
 -6.317260862313079E-005
 -1.232147500819508E-004
   128.033500398286
   3.40352715597823
 -1.425550799506294E-004
 -0.108997376876563
 -4.876667983688242E-004
   96.3874095044883
 -3.051907187019861E-005
 -5.373668343258995E-003
  2.229943371022152E-003
 -7.341733928736039E-008
  2.341952136518352E-009
  1.253466321191035E-012
 -1.144810703299280E-004
 -2.275768173982388E-004
  6.166592060313085E-015
  1.161015643147702E-010
 -4.772924015138579E-011
  5.214109710738572E-009
  2.790658303632025E-012
 -1.232087454146598E-004
 -2.433200463519374E-004
  1.372926983391761E-014
  2.584879067168842E-010
 -1.062641951866594E-010
  5.332774559526459E-005
 -3.052740908003987E-005
 -1.506516750346181E-005
 -3.044451383294561E-005
  6.167076478106378E-015
 -9.052265232660515E-015
 -1.182788652238517E-015
  4.378946152054744E-015
  1.373034833966098E-014
 -2.015392055399700E-014
 -2.633354067116544E-015
  9.749265153371935E-015
   4.44262943027817
 -5.373129723019007E-003
 -1.506176818312350E-005
   1.49955849407509
  1.160899550770934E-010
 -1.182744300251176E-015
 -9.583074496174046E-008
 -3.234672594970982E-008
  2.584620599712238E-010
 -2.633255322083825E-015
 -2.133571304810875E-007
 -7.201660213190042E-008
   602.961627231680
   162.343013215102
   11.1042297403877
  1.840797331793299E-009
  2.229943371026206E-003
 -3.043616863381924E-005
   1.49955849364102
 -3.501884899150129E-006
 -2.395288664620755E-007
 -3.970815446115445E-017
  4.378289397689436E-015
 -1.300644986310301E-005
 -7.796580458275912E-006
 -5.332859675277750E-007
 -8.840447385640205E-017
 -1.062641951868541E-010
  9.747802958516685E-015
 -7.201660213190043E-008
 -2.895750024317093E-005
   435.856533989540
   3.55507621852601
   3.38725855273509
   161.567028146726
 -9.282927957502518E-006
 -7.571197373801585E-008
 -7.214237132768992E-008
 -3.441071055299448E-006
 -2.090069391933228E-005
 -1.704669876740429E-007
 -1.624299601241770E-007
 -7.747638807545348E-006
   274.314615019204
  4.276971871452910E-005
  4.276971871456635E-005
 -1.424731014666542E-004
   11.0511523676404
 -5.842395986584868E-006
 -2.353692003993957E-007
 -1.315426885719857E-005
 -5.299383591730159E-007
   34.7465532807177
 -7.400376164606419E-007
 -1.666209172511005E-006
   58.8245960380765
  4.276544202771502E-005
  1.283091561436991E-004
 -0.108467313033751
 -1.252851956258190E-006
  2.301051185587760E-009
 -2.820820647537982E-006
  5.180860334076310E-009
  1.438386082125028E-004
  1.283091561435873E-004
 -4.870852234326962E-004
  1.832009380660061E-009
 -3.176146503278754E-013
  1.231382221048867E-012
 -3.901873706405734E-017
 -7.151046375966716E-013
  2.772438629645726E-012
 -8.785019215703233E-017
   80.5504068164431
   3.55507621852601
   96.1055468931925
  4.320035221155433E-005
 -7.571197373801036E-008
 -6.112427100829704E-005
 -1.208702144091390E-004
 -1.704669876738324E-007
 -6.585334898009114E-005
 -1.285961894841593E-004
   127.776103961036
   3.38725855273509
 -1.425514734257167E-004
 -0.108478394905840
 -4.873777165651242E-004
   96.1039696759680
 -3.051770538901783E-005
 -5.347940552041439E-003
  2.219367331127836E-003
  2.301281290703634E-009
  1.231685517208031E-012
 -1.208642399472556E-004
 -2.403680513278657E-004
  6.059502240846147E-015
  1.140853206989764E-010
 -4.690038095573633E-011
 -1.624299601239789E-007
  5.181378420116782E-009
  2.773121496399820E-012
 -1.285899147804219E-004
 -2.541024442041612E-004
  1.364308590526025E-014
  2.568652647199739E-010
 -1.055971528948741E-010
  5.332573968741169E-005
 -3.052604249145336E-005
 -1.506542960931469E-005
 -3.044354349549461E-005
  0.000000000000000E+000
  6.059978246277782E-015
 -8.895063018718209E-015
 -1.162248025611198E-015
  4.302901125071349E-015
  1.364415764084999E-014
 -2.002740746197871E-014
 -2.616823235396728E-015
  9.688065707667205E-015
   4.42139422969764
  4.320035221155432E-005
 -5.347404504364502E-003
 -1.506203027915572E-005
   1.49239076113331
  1.140739130697513E-010
 -1.162204443856954E-015
 -9.416654520771351E-008
 -3.178499168895625E-008
  2.568395802249971E-010
 -2.616725110262724E-015
 -2.120178189320390E-007
 -7.156453069430163E-008
   600.079519075438
   161.567028146726
   11.0511523676404
  1.831983907428236E-009
  2.219367331131870E-003
 -3.043519844196512E-005
   1.49239076070131
 -3.441071055299447E-006
 -2.353692003990437E-007
 -3.901819452681410E-017
 -4.690038095582225E-011
  4.302255775912677E-015
 -3.178499168891226E-008
 -1.278057944257934E-005
 -7.747638807558028E-006
 -5.299383591746007E-007
 -8.784897064117829E-017
 -1.055971528950676E-010
  9.686612691516271E-015
 -7.156453069449969E-008
 -2.877572467076581E-005
   434.154519485749
   3.54119448901638
   3.37403132549478
   160.936111610325
 -9.150898768111442E-006
 -7.463513718222086E-008
 -7.111630500980419E-008
 -3.392129404367263E-006
 -2.079440824347461E-005
 -1.696001160660286E-007
 -1.616039597386631E-007
 -7.708239971225679E-006
   273.243418084039
  4.276885016758403E-005
  4.276885016754678E-005
 -1.424702081911395E-004
   11.0079976813644
 -5.759300777564532E-006
 -2.320215921670148E-007
 -1.308737584044767E-005
 -5.272434792147244E-007
   34.6108682079401
 -7.295122125105121E-007
 -1.657736048669890E-006
   58.5948866111737
  4.276457356769968E-005
  1.283065505026403E-004
 -0.108045395920039
 -1.235032887959470E-006
  2.268323458650437E-009
 -2.806475996109689E-006
  5.154513741567427E-009
  1.437776632330665E-004
  1.283065505027521E-004
 -4.868503671055106E-004
  1.824843766888566E-009
 -3.130946197396024E-013
  1.213858193233367E-012
 -3.846347595480786E-017
 -7.114642358677276E-013
  2.758324891851641E-012
 -8.740300305271352E-017
   80.3082760690487
   3.54119448901201
   95.8750968508506
  4.320034711467118E-005
 -7.463513718222087E-008
 -6.380501262150522E-005
 -1.262516563209807E-004
 -1.696001160660409E-007
 -6.809395932918842E-005
 -1.330934855125725E-004
   127.566827792484
   3.37403132549066
 -1.425485785589989E-004
 -0.108056435595818
 -4.871427988860265E-004
   95.8735185509175
 -3.051659436841641E-005
 -5.327022515331150E-003
  2.210768453781890E-003
 -7.111630500980420E-008
  2.268550290995698E-009
  1.214157173128843E-012
 -1.262454118226933E-004
 -2.511504541979893E-004
  5.973318707266048E-015
  1.124626922969741E-010
 -4.623333306866172E-011
 -1.616039597386632E-007
  5.155029192938815E-009
  2.759004282314038E-012
 -1.330869851682234E-004
 -2.631127494165585E-004
  1.357370642339263E-014
  2.555590112354043E-010
 -1.050601728050689E-010
  5.332410877934976E-005
 -3.052493138356675E-005
 -1.506564271504975E-005
 -3.044275456033907E-005
  5.973787942601259E-015
 -8.768550121473738E-015
 -1.145717383535021E-015
  4.241701753057919E-015
  1.357477270901716E-014
 -1.992556233686191E-014
 -2.603515644428682E-015
  9.638799144646858E-015
   4.40412889851707
  4.320034711457526E-005
 -5.326488559278298E-003
 -1.506224337690398E-005
   1.48656301853014
  1.124514469174861E-010
 -1.145674421632580E-015
 -9.282723365832645E-008
 -3.133292024645614E-008
  2.555334573564888E-010
 -2.603418018280151E-015
 -2.109396510370615E-007
 -7.120060572831805E-008
   597.736214069190
   160.936111610589
   11.0079976813974
  1.824818393289059E-009
  2.210768453785948E-003
 -3.043440962521110E-005
   1.48656301810225
 -3.846294113820149E-017
 -4.623333306874642E-011
  4.241065582599608E-015
 -1.259880387017179E-005
 -5.272434792147245E-007
 -8.740178775483801E-017
  9.637353517493269E-015
 -7.120060572821953E-008
 -2.862939233585615E-005
   432.772880215518
   3.52992575868915
   3.36329389840954
   160.423954363432
 -9.044613092265361E-006
 -7.376826599472746E-008
 -7.029030469444843E-008
 -3.352730567861765E-006
 -2.070882471717270E-005
 -1.689020922883700E-007
 -1.609388463521436E-007
 -7.676515175605659E-006
   272.373855722071
  4.276815247332948E-005
  4.276815247338536E-005
 -1.424678840547709E-004
   10.9729661295846
 -5.692407763311126E-006
 -2.293267123076940E-007
 -1.303351213574679E-005
 -5.250735035527098E-007
   34.5007235384659
 -7.210390886690292E-007
 -1.650913305990361E-006
   58.4084160703709
  4.276387594323849E-005
  1.283044574201561E-004
 -0.107702897670485
 -1.220688244042261E-006
  2.241977103135431E-009
 -2.794925372309302E-006
  5.133298896293756E-009
  1.437282136689167E-004
  1.283044574199885E-004
 -4.866597977392734E-004
  1.819027128699327E-009
 -3.094559822994222E-013
  1.199751301271487E-012
 -3.801648888827451E-017
 -7.085329398811050E-013
  2.746960337639331E-012
 -8.704292083581324E-017
   80.1117224147021
   3.52992575868940
   95.6880253129684
  4.320034298018626E-005
 -7.376826599463639E-008
 -6.604562409901934E-005
 -1.307489546042610E-004
 -1.689020922881614E-007
 -6.995357610178718E-005
 -1.368256688045384E-004
   127.396944718333
   3.36329389840954
 -1.425462531441283E-004
 -0.107713903092398
 -4.869521797668221E-004
   95.6864461341240
 -3.051569247856399E-005
 -5.310041946693334E-003
  2.203788166936194E-003
 -7.029030469436270E-008
  2.242201300848801E-009
  1.200046806559886E-012
 -1.307424844650155E-004
 -2.601607639189919E-004
  5.903939547360258E-015
  1.111564498863636E-010
 -4.569634842102112E-011
 -1.609388463517511E-007
  5.133812226167223E-009
  2.747636928940291E-012
 -1.368189812265020E-004
 -2.705897685734175E-004
  1.351784056509642E-014
  2.545071877242118E-010
 -1.046277847904377E-010
  5.332278486188612E-005
 -3.052402942288617E-005
 -1.506581570712525E-005
 -3.044211412878675E-005
  5.904403332619432E-015
 -8.666705155047433E-015
 -1.132409947074598E-015
  4.192435250068158E-015
  1.351890246218829E-014
 -1.984355443906816E-014
 -2.592800085070955E-015
  9.599128642301750E-015
   4.39011347177679
  4.320034298028218E-005
 -5.309509688584738E-003
 -1.506241636254343E-005
   1.48183224918742
  1.111453351204888E-010
 -1.132367484184365E-015
 -9.174906576343611E-008
 -3.096899527631498E-008
  2.544817390192885E-010
 -2.592702860767613E-015
 -2.100714869162149E-007
 -7.090756546997859E-008
   595.833996308585
   160.423954363432
   10.9729661295846
  1.819001835977935E-009
  2.203788166936251E-003
 -3.043376928972749E-005
   1.48183224875337
 -3.352730567867251E-006
 -2.293267123083797E-007
 -3.801596028676834E-017
 -4.569634842110484E-011
  4.191806468605077E-015
 -3.096899527640069E-008
 -1.245247153521047E-005
 -7.676515175580539E-006
 -5.250735035527097E-007
 -8.704171054449044E-017
 -1.046277847904378E-010
  9.597688964926160E-015
 -7.090756547007672E-008
 -2.851156237307707E-005
   431.652762342319
   3.52079001217190
   3.35458888816421
   160.008739988460
 -8.959029566007679E-006
 -7.307024255959268E-008
 -6.962519136542052E-008
 -3.321005772105292E-006
 -2.063989614253067E-005
 -1.683399071797890E-007
 -1.604031671180195E-007
 -7.650964172506501E-006
   271.668887092405
  4.276759166143397E-005
  4.276759166141534E-005
 -1.424660158966537E-004
   10.9445654695033
 -5.638544060652410E-006
 -2.271567367276132E-007
 -1.299013055807623E-005
 -5.233258152304505E-007
   34.4114274280303
 -7.142163459895920E-007
 -1.645418300717152E-006
   58.2572413100879
  4.276331518737138E-005
  1.283027749842460E-004
 -0.107425228760693
 -1.209137626377401E-006
  2.220762450577875E-009
 -2.785622553506704E-006
  5.116212559165398E-009
  1.436881395066151E-004
  1.283027749843019E-004
 -4.865053518647041E-004
  1.814311595040752E-009
 -3.065261126772499E-013
  1.188392281685078E-012
 -3.765656994604997E-017
 -7.061721099290524E-013
  2.737807464622246E-012
 -8.675291496731563E-017
   79.9523731771281
   3.52079001216755
   95.5363634546254
  4.320033963044964E-005
 -7.307024255959800E-008
 -6.790524186175787E-005
 -1.344811398746008E-004
 -1.683399071798012E-007
 -7.148828268947558E-005
 -1.399055153437034E-004
   127.259217973329
   3.35458888815603
 -1.425443839579046E-004
 -0.107436206412352
 -4.867976935868477E-004
   95.5347835632093
 -3.051496130162263E-005
 -5.296275520731482E-003
  2.198129131510149E-003
  2.220984526821740E-009
  1.188684989184528E-012
 -1.344744825016860E-004
 -2.676377870316737E-004
  5.848073950632562E-015
  1.101046353764912E-010
 -4.526395670171827E-011
 -1.604031671182152E-007
  5.116724180414483E-009
  2.738481801521392E-012
 -1.398986732706684E-004
 -2.767596519752524E-004
  1.347284646327814E-014
  2.536600539922729E-010
 -1.042795414748301E-010
  5.332171154015070E-005
 -3.052329818848351E-005
 -1.506595595469904E-005
 -3.044159492038411E-005
  5.848533347424435E-015
 -8.584697386197244E-015
 -1.121694513298766E-015
  4.152764796507212E-015
  1.347390482594658E-014
 -1.977750565955998E-014
 -2.584169823872052E-015
  9.567178204146044E-015
   4.37875093286027
 -5.295744639155811E-003
 -1.506255660485273E-005
   1.47799693601042
  1.100936257841984E-010
 -1.121652452205184E-015
 -9.088090164226766E-008
 -3.067595501486942E-008
  2.536346899939725E-010
 -2.584072923145672E-015
 -2.093722715642149E-007
 -7.067155220666001E-008
   594.291836819207
   160.008739987936
   10.9445654695033
  1.814286367882021E-009
  2.198129131510187E-003
 -3.043325015918610E-005
   1.47799693558047
 -3.321005772105291E-006
 -3.765604634905837E-017
 -4.526395670171828E-011
  4.152141964818097E-015
 -3.067595501482698E-008
 -1.233464157241681E-005
 -7.650964172519020E-006
 -5.233258152312330E-007
 -8.675170870836608E-017
 -1.042795414748300E-010
  9.565743318696226E-015
 -7.067155220666003E-008
 -2.841666266815171E-005
   430.745623632713
   3.51339133614208
   3.34753904816525
   159.672474455931
 -8.890100991349506E-006
 -7.250805772906487E-008
 -6.908951217861169E-008
 -3.295454768911611E-006
 -2.058437136462901E-005
 -1.678870441483667E-007
 -1.599716556491177E-007
 -7.630381797519948E-006
   271.097961166583
  4.276714063372506E-005
  4.276714063365056E-005
 -1.424645134472573E-004
   10.9215649096747
 -5.595162484652461E-006
 -2.254090484717089E-007
 -1.295518492811676E-005
 -5.219179810132272E-007
   34.3391100760728
 -7.087213407164695E-007
 -1.640991849877798E-006
   58.1348109120591
  4.276286420473853E-005
  1.283014219009517E-004
 -0.107200355871680
 -1.199834812571976E-006
  2.203676269903978E-009
 -2.778128753560112E-006
  5.102448818282729E-009
  1.436556951229726E-004
  1.283014219011752E-004
 -4.863803062238798E-004
  1.810492745330740E-009
 -3.041664351921157E-013
  1.179243880537286E-012
 -3.736669595598696E-017
 -7.042703795447214E-013
  2.730434508053254E-012
 -8.651930515018887E-017
   79.8233226428866
   3.51339133614233
   95.4135386681799
  4.320033691898645E-005
 -7.250805772897533E-008
 -6.943994930242035E-005
 -1.375609881183954E-004
 -1.678870441479766E-007
 -7.274909968206874E-005
 -1.424355562837827E-004
   127.147678771713
   3.34753904816933
 -1.425428806824617E-004
 -0.107211311033766
 -4.866726153276216E-004
   95.4119581996780
 -3.051436915070126E-005
 -5.285126644137344E-003
  2.193546104111416E-003
 -6.908951217844317E-008
  2.203896637524030E-009
  1.179534334731454E-012
 -1.375541762502562E-004
 -2.738076738420040E-004
  5.803080061275218E-015
  1.092575089505849E-010
 -4.491571037910468E-011
 -1.599716556487275E-007
  5.102959063172764E-009
  2.731107028959821E-012
 -1.424285873038437E-004
 -2.818279425765646E-004
  1.343660188014774E-014
  2.529776532494319E-010
 -1.039990172719161E-010
  5.332084229982340E-005
 -3.052270599091813E-005
 -1.506606953553953E-005
 -3.044117443427131E-005
  5.803535923571509E-015
 -8.518648711356831E-015
 -1.113064354035797E-015
  4.120814397943728E-015
  1.343765739567821E-014
 -1.972430067445400E-014
 -2.577217796899757E-015
  9.541440823339225E-015
   4.36954886658265
 -5.284596877360138E-003
 -1.506267018148296E-005
   1.47489086911128
  1.092465840642161E-010
 -1.113022616569411E-015
 -9.018168629045588E-008
 -3.043994174889610E-008
  2.529523574860598E-010
 -2.577121156848202E-015
 -2.088090250838499E-007
 -7.048143389810325E-008
   593.042903465963
   159.672474456192
   10.9215649096910
  1.810467571270848E-009
  2.193546104111378E-003
 -3.043282973613301E-005
   1.47489086867928
 -3.295454768900826E-006
 -3.736617638946227E-017
 -4.491571037910469E-011
  4.120196358173787E-015
 -3.043994174893823E-008
 -1.223974186751536E-005
 -7.630381797519947E-006
 -8.651810213970726E-017
  9.540009797994868E-015
 -7.048143389829835E-008
 -2.834021708573982E-005
   430.011600574057
   3.50740460145315
   3.34183457865189
   159.400380837126
 -8.834576213503580E-006
 -7.205519492365124E-008
 -6.865800074795069E-008
 -3.274872393834945E-006
 -2.053963718895595E-005
 -1.675221898404239E-007
 -1.596240034725487E-007
 -7.613799370475134E-006
   270.635989045675
  4.276677773643374E-005
  4.276677773641513E-005
 -1.424633045757621E-004
   10.9029537082234
 -5.560216856043503E-006
 -2.240012143094261E-007
 -1.292703057954740E-005
 -5.207837431899208E-007
   34.2805935523729
 -7.042948898771393E-007
 -1.637425628865588E-006
   58.0357447668207
  4.276250134380608E-005
  1.283003332092454E-004
 -0.107018397099023
 -1.192341016692345E-006
  2.189912655872936E-009
 -2.772091287463663E-006
  5.091359902518451E-009
  1.436294489092358E-004
  1.283003332093012E-004
 -4.862791460559035E-004
  1.807402720804625E-009
 -3.022656355408341E-013
  1.171874535466467E-012
 -3.713319261539529E-017
 -7.027382379507803E-013
  2.724494437111498E-012
 -8.633109584239848E-017
   79.7188997595963
   3.50740460144500
   95.3141534602759
  4.320033472589264E-005
 -7.205519492365648E-008
 -7.070076701965411E-005
 -1.400910305065070E-004
 -7.378112123586171E-005
 -1.445063741745651E-004
   127.057425502969
   3.34183457864374
 -1.425416711460203E-004
 -0.107029334063550
 -4.865714287790617E-004
   95.3125725248460
 -3.051389000407216E-005
 -5.276105387107716E-003
  2.189837687556400E-003
 -6.865800074803443E-008
  2.190131647135599E-009
  1.172163174551079E-012
 -1.400840917314696E-004
 -2.788759673387710E-004
  5.766835650272265E-015
  1.085751141304629E-010
 -4.463518373865407E-011
 -1.596240034723540E-007
  5.091869038508427E-009
  2.725165494941875E-012
 -1.444993013273154E-004
 -2.859761918087256E-004
  1.340740101556091E-014
  2.524278692623353E-010
 -1.037730097154137E-010
  5.332013894264126E-005
 -3.052222680669403E-005
 -1.506616144098054E-005
 -3.044083419239293E-005
  5.767288665422695E-015
 -8.465443811141090E-015
 -1.106112409673907E-015
  4.095077049275078E-015
  1.340845423720765E-014
 -1.968143546673411E-014
 -2.571616816658609E-015
  9.520705206695958E-015
   4.36210289525918
  4.320033472589265E-005
 -5.275576522390140E-003
 -1.506276208343958E-005
   1.47237755477438
  1.085642574781563E-010
 -1.106070932873518E-015
 -8.961843980972815E-008
 -3.024982343829676E-008
  2.524026284731270E-010
 -2.571520386665408E-015
 -2.083552390807462E-007
 -7.032826289708467E-008
   592.032312837690
   159.400380837126
   10.9029537082234
  1.807377589714935E-009
 -3.043248954530838E-005
   1.47237755434646
 -3.274872393840303E-006
 -2.240012143097610E-007
 -3.713267629561590E-017
  4.094462869592363E-015
 -1.216329628509589E-005
 -8.632989544898616E-017
 -1.037730097156037E-010
  9.519277291265364E-015
 -7.032826289718199E-008
 -2.827862782335228E-005
   429.418072002371
   3.50256374796886
   3.33722196381546
   159.180366853747
 -8.789842037809557E-006
 -7.169034079878005E-008
 -6.831034860257206E-008
 -3.258289966708754E-006
 -2.050359213167291E-005
 -1.672282044430482E-007
 -1.593438788820862E-007
 -7.600437896292358E-006
   270.262439944945
  4.276648564154531E-005
  4.276648564154530E-005
 -1.424623315587881E-004
   10.8879047534372
 -5.532062508570556E-006
 -2.228669765296685E-007
 -1.290434490150553E-005
 -5.198698185067095E-007
   34.2332772884270
 -7.007286688649723E-007
 -1.634552106805837E-006
   57.9556402155837
  4.276220927810531E-005
  1.282994569246359E-004
 -0.106871265877190
 -1.186303553891904E-006
  2.178823842819916E-009
 -2.767226532306721E-006
  5.082424886069687E-009
  1.436082306020106E-004
 -4.861973627245102E-004
  1.804904168156997E-009
 -3.007342453383616E-013
  1.165937380123870E-012
 -3.694506924792402E-017
 -7.015037039732620E-013
  2.719708182740574E-012
 -8.617944484109419E-017
   79.6344637877851
   3.50256374796886
   95.2337909562457
  4.320033295313462E-005
 -7.169034079861344E-008
 -7.173278918273066E-005
 -1.421618496145623E-004
 -7.462337908249744E-005
 -1.461963497932265E-004
   126.984447094865
   3.33722196381139
 -1.425406975936843E-004
 -0.106882188126812
 -4.864896241251106E-004
   95.2322096430826
 -3.051350256776859E-005
 -5.268810829823098E-003
  2.186839074110302E-003
 -6.831034860240545E-008
  2.179041725207703E-009
  1.166224556857671E-012
 -1.421548069724762E-004
 -2.830242190049646E-004
  5.737634925027605E-015
  1.080253349382935E-010
 -4.440917420866043E-011
 -1.593438788822805E-007
  5.082933128563579E-009
  2.720378061689060E-012
 -1.461891921848901E-004
 -2.893614719070775E-004
  1.338387209589516E-014
  2.519848747389561E-010
 -1.035909016204071E-010
  5.331957021044600E-005
 -3.052183933993127E-005
 -1.506623575538609E-005
 -3.044055907398019E-005
  5.738085646335384E-015
 -8.422578672119475E-015
 -1.100511496343609E-015
  4.074341458606448E-015
  1.338492346926828E-014
 -1.964689635123889E-014
 -2.567103764977433E-015
  9.503997254061293E-015
   4.35608210792469
  4.320033295313463E-005
 -5.268282694505954E-003
 -1.506283639505300E-005
   1.47034529727132
  1.080145332596642E-010
 -1.100470229560541E-015
 -8.916465380671746E-008
 -3.009665243540990E-008
  2.519596782452473E-010
 -2.567007504194975E-015
 -2.079895959851328E-007
 -7.020484366721345E-008
   591.215152660388
   159.180366853747
   10.8879047534372
  1.804879071810748E-009
  2.186839074114276E-003
 -3.043221446818160E-005
   1.47034529684135
 -3.694455554401168E-017
  4.073730388853275E-015
 -3.009665243549320E-008
 -1.210170702268488E-005
 -7.600437896304794E-006
 -5.198698185074868E-007
 -8.617824655608741E-017
  9.502571844517565E-015
 -2.822900159334222E-005
   428.938419520018
   3.49865167449806
   3.33349433844606
   159.002565382194
 -8.753796980541730E-006
 -7.139635554942254E-008
 -6.803022403780863E-008
 -3.244928492483445E-006
 -2.047454548157105E-005
 -1.669912984259017E-007
 -1.591181424965637E-007
 -7.589670648485525E-006
   269.960561043216
  4.276625046401646E-005
  4.276625046394196E-005
 -1.424615481429086E-004
   10.8757431341526
 -5.509376831420294E-006
 -2.219530518826500E-007
 -1.288606381106815E-005
 -5.191333388777279E-007
   34.1950392582348
 -6.978551468052400E-007
 -1.632236499727627E-006
   57.8909047526019
  4.276197412400856E-005
  1.282987513918259E-004
 -0.106752363690708
 -1.181438801413362E-006
  2.169888909502336E-009
 -2.763306304362292E-006
  5.075224667494880E-009
  1.435910860978173E-004
  1.282987513920494E-004
 -4.861312799880748E-004
  1.802885014998269E-009
 -2.995003177949243E-013
  1.161153478889744E-012
 -3.679348759472710E-017
 -7.005088675954628E-013
  2.715851229394889E-012
 -8.605723844808964E-017
   79.5662279568787
   3.49865167449806
   95.1688470588376
  4.320033152080831E-005
 -7.139635554942252E-008
 -7.257504753671503E-005
 -1.438518262478797E-004
 -1.669912984255015E-007
 -7.530913559263320E-005
 -1.475722633585020E-004
   126.925470586297
   3.33349433845013
 -1.425399137466952E-004
 -0.106763274048935
 -4.864235241629128E-004
   95.1672654408401
 -3.051318946610067E-005
 -5.262915827647527E-003
  2.184415783018362E-003
 -6.803022403772566E-008
  2.170105898393168E-009
  1.161439477320742E-012
 -1.438446988439430E-004
 -2.864095011322226E-004
  5.714106118195508E-015
  1.075823442948329E-010
 -4.422706451684361E-011
 -1.591181424963697E-007
  5.075732189969059E-009
  2.716520158351763E-012
 -1.475650367426608E-004
 -2.921175932619516E-004
  1.336491148551283E-014
  2.516278907967956E-010
 -1.034441511195603E-010
  5.331911059681837E-005
 -3.052152621364935E-005
 -1.506629581158967E-005
 -3.044033674056081E-005
  5.714554991190989E-015
 -8.388039612211937E-015
 -1.095998498789488E-015
  4.057633527033072E-015
  1.336596136948189E-014
 -1.961906325358573E-014
 -2.563466954856283E-015
  9.490533270732905E-015
   4.35121648606999
  4.320033152090424E-005
 -5.262388281774598E-003
 -1.506289644901459E-005
   1.46870295450303
  1.075715869118117E-010
 -1.095957401248400E-015
 -8.879901071114275E-008
 -2.997323320424912E-008
  2.516027299983690E-010
 -2.563370830451445E-015
 -2.076949451273921E-007
 -7.010538716903165E-008
   590.554775171662
   159.002565382454
   10.8757431341689
  1.802859946722575E-009
 -3.043199216812758E-005
   1.46870295407103
 -3.679297599853231E-017
 -4.422706451692463E-011
  4.057024963129540E-015
 -2.997323320429059E-008
 -1.205208079269425E-005
 -7.589670648473107E-006
 -5.191333388769517E-007
 -8.605604186238654E-017
 -1.034441511197498E-010
  9.489109880465770E-015
 -2.818901065297714E-005
   428.550973140835
   3.49549163936822
   3.33048329399165
   158.858943617485
 -8.724750330464033E-006
 -7.115944965192536E-008
 -6.780448767249602E-008
 -3.234161244600296E-006
 -2.045113650599385E-005
 -1.668003735795040E-007
 -1.589362193645504E-007
 -7.580993219587552E-006
   269.716713900543
  4.276606106626358E-005
  4.276606106624497E-005
 -1.424609172272949E-004
   10.8659194065423
 -5.491095741702411E-006
 -2.212165722809183E-007
 -1.287133090391183E-005
 -5.185398028404837E-007
   34.1641519244336
 -6.955395397270483E-007
 -1.630370329643472E-006
   57.8386137261048
  4.276178474519881E-005
  1.282981831987349E-004
 -0.106656318705425
 -1.177518575631265E-006
  2.162688758122362E-009
 -2.760146954835401E-006
  5.069421941961485E-009
  1.435772391949886E-004
  1.282981831987907E-004
 -4.860779068149318E-004
  1.801254027237079E-009
 -2.985059707468481E-013
  1.157298424283252E-012
 -3.667133715048180E-017
 -6.997071219231063E-013
  2.712742883413697E-012
 -8.595875144613047E-017
   79.5111094648115
   3.49549163935985
   95.1163876838153
  4.320033036416549E-005
 -7.115944965192534E-008
 -7.326080446722734E-005
 -1.452277406527118E-004
 -7.586640318513961E-005
 -1.486903454464058E-004
   126.877831475362
   3.33048329398759
 -1.425392824839960E-004
 -0.106667219458157
 -4.863701370799000E-004
   95.1148058192136
 -3.051293655359123E-005
 -5.258154052875797E-003
  2.182458333711649E-003
 -6.780448767257871E-008
  2.162905027000423E-009
  1.157583473192714E-012
 -1.452205442417892E-004
 -2.891656241658792E-004
  5.695145598959110E-015
  1.072253634890886E-010
 -4.408031272479139E-011
 -1.589362193641628E-007
  5.069928884150390E-009
  2.713411046771489E-012
 -1.486830627555312E-004
 -2.943572181945729E-004
  1.334963094679665E-014
  2.513401939972422E-010
 -1.033258834738846E-010
  5.331873933708647E-005
 -3.052127328144365E-005
 -1.506634432289396E-005
 -3.044015714762359E-005
  5.695592982526128E-015
 -8.360206559526317E-015
 -1.092361732421708E-015
  4.044169560660051E-015
  1.335067963040277E-014
 -1.959663229171523E-014
 -2.560536014546479E-015
  9.479682516648116E-015
   4.34728620813888
  4.320033036416550E-005
 -5.257626983136618E-003
 -1.506294495847333E-005
   1.46737632787414
  1.072146418011326E-010
 -1.092320771243385E-015
 -8.850435985317796E-008
 -2.987377670469297E-008
  2.513150619671964E-010
 -2.560440000057126E-015
 -2.074574831583648E-007
 -7.002523421765799E-008
   590.021345500060
   158.858943617225
   10.8659194065261
  1.801228981641199E-009
  2.182458333715614E-003
 -3.043181260195439E-005
   1.46737632744214
 -3.234161244605587E-006
 -2.212165722812491E-007
 -3.667082725263358E-017
  4.043563016094209E-015
 -2.987377670469296E-008
 -1.201208985228127E-005
 -5.185398028397085E-007
 -8.595755623002057E-017
 -1.033258834738847E-010
  9.478260753778582E-015
 -2.815678156843107E-005
   428.238124406740
   3.49294002693208
   3.32805198606544
   158.742974312559
 -8.701341354931357E-006
 -7.096852490400132E-008
 -6.762256455809600E-008
 -3.225483815668490E-006
 -2.043226971094718E-005
 -1.666464950003069E-007
 -1.587895958434067E-007
 -7.573999522957144E-006
   269.519816280976
  4.276590850583193E-005
  4.276590850588782E-005
 -1.424604090230867E-004
   10.8579871070103
 -5.476362835133770E-006
 -2.206230362655044E-007
 -1.285945670890157E-005
 -5.180614340680183E-007
   34.1392115358341
 -6.936733696429102E-007
 -1.628866263456985E-006
   57.7963906410371
  4.276163220002222E-005
  1.282977255176635E-004
 -0.106578765912086
 -1.174359227858434E-006
  2.156886086901910E-009
 -2.757600632375060E-006
  5.064745153258070E-009
  1.435660595161376E-004
  1.282977255174958E-004
 -4.860348139289285E-004
  1.799937072957751E-009
 -2.977046198456968E-013
  1.154191610135886E-012
 -3.657289527982692E-017
 -6.990609453137846E-013
  2.710237674434060E-012
 -8.587937465257644E-017
   79.4666033108214
   3.49294002693208
   95.0740286749339
  4.320032943025648E-005
 -7.096852490383122E-008
 -7.381807240596907E-005
 -1.463458234323711E-004
 -1.666464949998955E-007
 -7.631855884710315E-005
 -1.495975157481133E-004
   126.839364664313
   3.32805198605732
 -1.425387740000741E-004
 -0.106589658908433
 -4.863270329646319E-004
   95.0724466112006
 -3.051273233589176E-005
 -5.254309094670742E-003
  2.180877765154265E-003
 -6.762256455801353E-008
  2.157101775513757E-009
  1.154475893818823E-012
 -1.463385709465911E-004
 -2.914052504817416E-004
  5.679865133932466E-015
  1.069376692251879E-010
 -4.396204403524237E-011
 -1.587895958430194E-007
  5.065251627765295E-009
  2.710905220738300E-012
 -1.495901875615679E-004
 -2.961743480439156E-004
  1.333731538055006E-014
  2.511083206949015E-010
 -1.032305639888848E-010
  5.331843955824372E-005
 -3.052106904773067E-005
 -1.506638349394866E-005
 -3.044001213267384E-005
  5.680311317160615E-015
 -8.337775633998623E-015
 -1.089430827481275E-015
  4.033318820352326E-015
  1.333836309667473E-014
 -1.957855374073998E-014
 -2.558173781769384E-015
  9.470937197878762E-015
   4.34411265293272
  4.320032943016057E-005
 -5.253782409417439E-003
 -1.506298412801099E-005
   1.46630512555369
  1.069269763042598E-010
 -1.089389976207688E-015
 -8.826689788419685E-008
 -2.979362375230428E-008
  2.510832118495391E-010
 -2.558077855879405E-015
 -2.072660973242139E-007
 -6.996063381183577E-008
   589.590620617271
   158.742974312559
   10.8579871069941
  1.799912045677221E-009
 -3.043166760872522E-005
   1.46630512512169
 -3.225483815663212E-006
 -2.206230362651746E-007
 -3.657238675080134E-017
 -4.396204403532289E-011
  4.032713903158596E-015
 -1.197986076761152E-005
 -7.573999522944752E-006
 -5.180614340672437E-007
 -8.587818053981110E-017
  9.469516746674858E-015
 -6.996063381183580E-008
 -2.813080608143066E-005
   427.985586832898
   3.49088031586224
   3.32608938710895
   158.649361636486
 -8.682474559839322E-006
 -7.081464640125432E-008
 -6.747594104930600E-008
 -3.218490119025520E-006
 -2.041706291395743E-005
 -1.665224675580479E-007
 -1.586714160396399E-007
 -7.568362544105563E-006
   269.360876697523
  4.276578559791596E-005
  4.276578559787870E-005
 -1.424599995961497E-004
   10.8515840006505
 -5.464488640606101E-006
 -2.201446675155233E-007
 -1.284988600692518E-005
 -5.176758647778848E-007
   34.1190791696888
 -6.921693034564379E-007
 -1.627653973341041E-006
   57.7623073465766
  4.276150930428797E-005
  1.282973567936361E-004
 -0.106516163795908
 -1.171812906815847E-006
  2.152209342071127E-009
 -2.755548274852013E-006
  5.060975621889821E-009
  1.435570358345600E-004
  1.282973567937479E-004
 -4.860000311135281E-004
  1.798874007369975E-009
 -2.970587616808110E-013
  1.151687636807937E-012
 -3.649355488913011E-017
 -6.985401225643646E-013
  2.708218458915476E-012
 -8.581539641379450E-017
   79.4306770825997
   3.49088031585362
   95.0398356675694
  4.320032867649141E-005
 -7.081464640125431E-008
 -7.427022835142577E-005
 -1.472529943013184E-004
 -1.665224675580600E-007
 -7.668497319075131E-005
 -1.503326489933105E-004
   126.808313522122
   3.32608938710084
 -1.425383643476265E-004
 -0.106527050531309
 -4.862922410849200E-004
   95.0382534432933
 -3.051256748776848E-005
 -5.251205369882817E-003
  2.179601899431140E-003
 -6.747594104914142E-008
  2.152424563003088E-009
  1.151971303750072E-012
 -1.472456963191769E-004
 -2.932223814653448E-004
  5.667549627123907E-015
  1.067057979690545E-010
 -4.386672370858191E-011
 -1.586714160398334E-007
  5.061481719445356E-009
  2.708885507885014E-012
 -1.503252839393369E-004
 -2.976468626902144E-004
  1.332738892950670E-014
  2.509214288460482E-010
 -1.031537356742622E-010
  5.331819757158199E-005
 -3.052090418655393E-005
 -1.506641511366699E-005
 -3.043989507396219E-005
  5.667994842905867E-015
 -8.319697112259566E-015
 -1.087068623268758E-015
  4.024573512676332E-015
  1.332843586594382E-014
 -1.956398227503693E-014
 -2.556269802120070E-015
  9.463888396745749E-015
   4.34155089752353
  4.320032867658733E-005
 -5.250678994960425E-003
 -1.506301574660317E-005
   1.46544043022278
  1.066951282338324E-010
 -1.087027860577602E-015
 -8.807551205004598E-008
 -2.972902334613111E-008
  2.508963386880428E-010
 -2.556173947606004E-015
 -2.071118387171710E-007
 -6.990856533652302E-008
   589.242931119715
   158.649361636226
   10.8515840006343
  1.798848994863490E-009
  2.179601899431179E-003
 -3.043155056774121E-005
   1.46544042979078
 -2.201446675151942E-007
 -3.649304746337093E-017
 -4.386672370858193E-011
  4.023969907104523E-015
 -2.972902334613112E-008
 -1.195388528081095E-005
 -7.568362544117949E-006
 -5.176758647778849E-007
 -8.581420319081102E-017
  9.462469002649033E-015
 -6.990856533661979E-008
 -2.810986961848134E-005
   427.781783388562
   3.48921808315497
   3.32450552603984
   158.573814123007
 -8.667267762843187E-006
 -7.069061902276604E-008
 -6.735776125699241E-008
 -3.212853140145486E-006
 -2.040480555893157E-005
 -1.664224959204958E-007
 -1.585761578594306E-007
 -7.563818888337241E-006
   269.232608915544
  4.276568656587086E-005
  4.276568656583361E-005
 -1.424596697034812E-004
   10.8464165513061
 -5.454917939000393E-006
 -2.197590982397958E-007
 -1.284217159527324E-005
 -5.173650787736352E-007
   34.1028319020053
 -6.909570133404974E-007
 -1.626676813565425E-006
   57.7348013691564
  4.276141028230116E-005
  1.282970596975008E-004
 -0.106465642497742
 -1.169760550438250E-006
  2.148439846128823E-009
 -2.753893983366581E-006
  5.057937211897547E-009
  1.435497540260548E-004
  1.282970596976126E-004
 -4.859719622981046E-004
  1.798016093369242E-009
 -2.965381957705166E-013
  1.149669417914926E-012
 -3.642960600802010E-017
 -6.981203169554922E-013
  2.706590884087685E-012
 -8.576382719123386E-017
   79.4016838188725
   3.48921808315522
   95.0122411541394
  4.320032806852969E-005
 -7.069061902259148E-008
 -7.463664292727947E-005
 -1.479881280103070E-004
 -1.664224959205079E-007
 -7.698160790712225E-005
 -1.509277761309502E-004
   126.783254568700
   3.32450552604389
 -1.425380342743372E-004
 -0.106476524180500
 -4.862641649577059E-004
   95.0106588001992
 -3.051243445134396E-005
 -5.248700594959693E-003
  2.178572247359133E-003
 -6.735776125682814E-008
  2.148654690109999E-009
  1.149952587755810E-012
 -1.479807931609987E-004
 -2.946948970390446E-004
  5.657623224246064E-015
  1.065189077733507E-010
 -4.378989471353768E-011
 -1.585761578592372E-007
  5.058443005624168E-009
  2.707257532177557E-012
 -1.509203812315016E-004
 -2.988389290791847E-004
  1.331938776843600E-014
  2.507707857005661E-010
 -1.030918086337276E-010
  5.331800228239916E-005
 -3.052077113976688E-005
 -1.506644063144827E-005
 -3.043980060505003E-005
  5.658067660244628E-015
 -8.305125670364993E-015
 -1.085164666684139E-015
  4.017524720472266E-015
  1.332043407628291E-014
 -1.955223702542676E-014
 -2.554735109842482E-015
  9.458206749338822E-015
   4.33948350387970
 -5.248174470487675E-003
 -1.506304126335126E-005
   1.46474260184520
  1.065082567253247E-010
 -1.085123975396015E-015
 -8.792125344283161E-008
 -2.967695487009564E-008
  2.507457106065346E-010
 -2.554639312881742E-015
 -2.069874994159260E-007
 -6.986659582862663E-008
   588.962337956860
   158.573814123266
   10.8464165513061
  1.797991092795721E-009
  2.178572247359075E-003
 -3.043145611274181E-005
   1.46474260141522
 -3.212853140140229E-006
 -2.197590982394673E-007
 -3.642909947129057E-017
 -4.378989471353769E-011
  4.016922172096464E-015
 -1.193294881780779E-005
 -7.563818888337243E-006
 -5.173650787736354E-007
 -8.576263468536555E-017
 -1.030918086339165E-010
  9.456788207419465E-015
 -6.986659582882003E-008
 -2.809299389775827E-005
   427.617341939515
   3.48787688915856
   3.32322756722473
   158.512857633417
 -8.655010407820701E-006
 -7.059064743664111E-008
 -6.726250308549130E-008
 -3.208309484348713E-006
 -2.039492522746394E-005
 -1.663419114141103E-007
 -1.584993727462504E-007
 -7.560156366938720E-006
   269.129114394251
  4.276560676291488E-005
 -1.424594038664692E-004
   10.8422471278692
 -5.447203527654215E-006
 -2.194483122480482E-007
 -1.283595321099170E-005
 -5.171145623519009E-007
   34.0897225836300
 -6.899798535648867E-007
 -1.625889150776778E-006
   57.7126078150224
  4.276133048729868E-005
  1.282968202887446E-004
 -0.106424878736046
 -1.168106259877016E-006
  2.145401464734623E-009
 -2.752560502517244E-006
  5.055488029552408E-009
  1.435438789317029E-004
 -4.859493157118096E-004
  1.797323876677949E-009
 -2.961185973003917E-013
  1.148042646846225E-012
 -3.637806046064080E-017
 -6.977819231548105E-013
  2.705278940605905E-012
 -8.572225865252020E-017
   79.3782902301598
   3.48787688915882
   94.9899761668216
  4.320032757769031E-005
 -7.059064743664623E-008
 -7.493327783249250E-005
 -1.485832555255190E-004
 -1.663419114140982E-007
 -7.722155797536724E-005
 -1.514091737988673E-004
   126.763035434040
   3.32322756722068
 -1.425377682909956E-004
 -0.106435756342242
 -4.862415124718679E-004
   94.9883937082851
 -3.051232710929393E-005
 -5.246679584914525E-003
  2.177741459226937E-003
 -6.726250308557331E-008
  2.145616004878276E-009
  1.148325416008381E-012
 -1.485758908305621E-004
 -2.958869641830174E-004
  5.649622101869541E-015
  1.063682659626405E-010
 -4.372796712381164E-011
 -1.584993727464437E-007
  5.055993578359623E-009
  2.705945265559022E-012
 -1.514017547573792E-004
 -2.998031851121934E-004
  1.331293824293489E-014
  2.506493562253894E-010
 -1.030418908753996E-010
  5.331784471098449E-005
 -3.052066378926180E-005
 -1.506646122075549E-005
 -3.043972438136438E-005
  5.650065909374948E-015
 -8.293380439804101E-015
 -1.083629993000721E-015
  4.011843080343009E-015
  1.331398404417457E-014
 -1.954276948868124E-014
 -2.553498034766739E-015
  9.453626922863419E-015
   4.33781540053863
  4.320032757778623E-005
 -5.246153662545348E-003
 -1.506306185192227E-005
   1.46417954998105
  1.063576299774557E-010
 -1.083589359251372E-015
 -8.779691414158192E-008
 -2.963498536166982E-008
  2.506242932727399E-010
 -2.553402284173688E-015
 -2.068872727759202E-007
 -6.983276531223624E-008
   588.735937729090
   158.512857633417
   10.8422471278692
  1.797298885730828E-009
  2.177741459230896E-003
 -3.043137990061141E-005
   1.46417954955310
 -3.208309484353963E-006
 -3.637755464071046E-017
 -4.372796712381163E-011
  4.011241384069082E-015
 -2.963498536171083E-008
 -1.191607309708201E-005
 -5.171145623526741E-007
 -8.572106672468974E-017
  9.452209067824626E-015
 -6.983276531223626E-008
 -2.807939082324371E-005
   427.484681384247
   3.48679490199653
   3.32219659403474
   158.463681943195
 -8.645130076391843E-006
 -7.051006297096087E-008
 -6.718571797951538E-008
 -3.204646962946553E-006
 -2.038696071859271E-005
 -1.662769524576993E-007
 -1.584374764709177E-007
 -7.557204018185197E-006
   269.045621815976
  4.276554244965425E-005
  4.276554244969152E-005
 -1.424591896285329E-004
   10.8388835110509
 -5.440985143614131E-006
 -2.191977958360406E-007
 -1.283094058793818E-005
 -5.169126217304612E-007
   34.0791468470743
 -6.891921907762622E-007
 -1.625254217897762E-006
   57.6947035140013
  4.276126618050144E-005
  1.282966273490745E-004
 -0.106391993213459
 -1.166772779776667E-006
  2.142952305464977E-009
 -2.751485587152947E-006
  5.053513750193907E-009
  1.435391395043157E-004
  1.282966273489628E-004
 -4.859310466504010E-004
  1.796765443256963E-009
 -2.957803705417006E-013
  1.146731351540486E-012
 -3.633651101335129E-017
 -6.975091451066377E-013
  2.704221387605612E-012
 -8.568875039973341E-017
   79.3594178213322
   3.48679490199628
   94.9720142403567
  4.320032718200680E-005
 -7.051006297096599E-008
 -7.517322805459915E-005
 -1.490646535005930E-004
 -7.741552913585588E-005
 -1.517983233305570E-004
   126.746723969161
   3.32219659403879
 -1.425375539350048E-004
 -0.106402867530724
 -4.862232386506208E-004
   94.9704316975450
 -3.051224051280831E-005
 -5.245049166874763E-003
  2.177071233948823E-003
 -6.718571797943344E-008
  2.143166600697825E-009
  1.147013797723837E-012
 -1.490572646639389E-004
 -2.968512208302241E-004
  5.643172607720799E-015
  1.062468375637829E-010
 -4.367804892210587E-011
 -1.584374764711110E-007
  5.054019101577109E-009
  2.704887452070205E-012
 -1.517908847736276E-004
 -3.005826616396734E-004
  1.330773929763396E-014
  2.505514722493659E-010
 -1.030016523026644E-010
  5.331771759276869E-005
 -3.052057718590001E-005
 -1.506647783088561E-005
 -3.043966288915569E-005
  5.643615908560412E-015
 -8.283912918507115E-015
 -1.082392932955246E-015
  4.007263259690814E-015
  1.330878469049639E-014
 -1.953513773252967E-014
 -2.552500831836274E-015
  9.449935136893252E-015
   4.33646968437991
 -5.244523407521827E-003
 -1.506307846144196E-005
   1.46372531673552
  1.062362137208380E-010
 -1.082352345595365E-015
 -8.769668750185622E-008
 -2.960115484505503E-008
  2.505264190837793E-010
 -2.552405118640952E-015
 -2.068064803482763E-007
 -6.980549462308215E-008
   588.553292903851
   158.463681943195
   10.8388835110671
  1.796740460075578E-009
 -3.043131841769961E-005
   1.46372531630352
 -3.204646962946554E-006
 -2.191977958360407E-007
 -3.633600577117592E-017
 -4.367804892218589E-011
  4.006662250317007E-015
 -2.960115484513696E-008
 -1.190247002256264E-005
 -7.557204018197563E-006
 -8.568755893770515E-017
 -1.030016523028531E-010
  9.448517835593116E-015
 -6.980549462317875E-008
 -2.806842542103702E-005
   427.377673348977
   3.48592213826098
   3.32136497972595
   158.424015336813
 -8.637165567488089E-006
 -7.044510404781514E-008
 -6.712382170976973E-008
 -3.201694614178718E-006
 -2.038054039673184E-005
 -1.662245879718866E-007
 -1.583875808633551E-007
 -7.554824081228100E-006
   268.978274164011
  4.276549061607070E-005
  4.276549061599619E-005
 -1.424590169620772E-004
   10.8361703154810
 -5.435972520780436E-006
 -2.189958552227503E-007
 -1.282689982992292E-005
 -5.167498340688454E-007
   34.0706161365071
 -6.885572578972313E-007
 -1.624742388042591E-006
   57.6802613606224
  4.276121435213329E-005
  1.282964718479886E-004
 -0.106365466752400
 -1.165697865013743E-006
  2.140978044719604E-009
 -2.750619080167261E-006
  5.051922251075621E-009
  1.435353166765161E-004
  1.282964718482121E-004
 -4.859163107360343E-004
  1.796314994870508E-009
 -2.955077271954173E-013
  1.145674321217282E-012
 -3.630301815491981E-017
 -6.972892544226552E-013
  2.703368877451959E-012
 -8.566173886839909E-017
   79.3441947633111
   3.48592213826098
   94.9575256060241
  4.320032686267823E-005
 -7.044510404781002E-008
 -7.536719933979609E-005
 -1.494538032817616E-004
 -7.757224957299458E-005
 -1.521127373932547E-004
   126.733566648691
   3.32136497973000
 -1.425373811737776E-004
 -0.106376338416816
 -4.862084988966720E-004
   94.9559429949711
 -3.051217066147302E-005
 -5.243734022158845E-003
  2.176530609850995E-003
 -6.712382170985159E-008
  2.141192142525880E-009
  1.145956507049181E-012
 -1.494463949294157E-004
 -2.976306978565754E-004
  5.637973687647144E-015
  1.061489544559703E-010
 -4.363780999203667E-011
 -1.583875808629688E-007
  5.052427443312074E-009
  2.704034731944792E-012
 -1.521052830686398E-004
 -3.012124389382927E-004
  1.330354834217172E-014
  2.504725663624024E-010
 -1.029692153262516E-010
  5.331761505538921E-005
 -3.052050732911166E-005
 -1.506649122914134E-005
 -3.043961328758332E-005
  5.638416580099900E-015
 -8.276281174774552E-015
 -1.081395742154347E-015
  4.003571478461733E-015
  1.330459340580155E-014
 -1.952898564813457E-014
 -2.551696970142057E-015
  9.446959127462007E-015
   4.33538418882794
 -5.243208394298223E-003
 -1.506309185919519E-005
   1.46335891839547
  1.061383404003055E-010
 -1.081355192178500E-015
 -8.761589507400676E-008
 -2.957388415551082E-008
  2.504475210881416E-010
 -2.551601287091897E-015
 -2.067413522411717E-007
 -6.978351127136345E-008
   588.405966035698
   158.424015337072
   10.8361703154810
  1.796290017950000E-009
  2.176530609855066E-003
 -3.043126882373527E-005
   1.46335891796550
 -2.189958552230778E-007
 -3.630251337846677E-017
 -4.363780999203668E-011
  4.002971022780520E-015
 -1.189150462037360E-005
 -7.554824081215738E-006
 -5.167498340680726E-007
 -8.566054778197183E-017
 -1.029692153260630E-010
  9.445542272462284E-015
 -2.805958602968587E-005
   427.291366387335
   3.48521821367142
   3.32069424407601
   158.392022372914
 -8.630745245654584E-006
 -7.039273958954706E-008
 -6.707392610698451E-008
 -3.199314677195099E-006
 -2.037536477018403E-005
 -1.661823752875420E-007
 -1.583473584199647E-007
 -7.552905538003010E-006
   268.923955148508
  4.276544883800399E-005
 -1.424588777921932E-004
   10.8339819969854
 -5.431931762914986E-006
 -2.188330675670712E-007
 -1.282364244577263E-005
 -5.166186057327697E-007
   34.0637357213883
 -6.880454280420786E-007
 -1.624329785643417E-006
   57.6686130917486
  4.276117257820165E-005
  1.282963465140120E-004
 -0.106344071927431
 -1.164831358513878E-006
  2.139386560624465E-009
 -2.749920561197917E-006
  5.050639292792704E-009
  1.435322334784559E-004
 -4.859044258374568E-004
  1.795951687924593E-009
 -2.952879451246259E-013
  1.144822232525775E-012
 -3.627601903623192E-017
 -6.971119936389567E-013
  2.702681642264871E-012
 -8.563996402494300E-017
   79.3319166587262
   3.48521821367143
   94.9458398486465
  4.320032660512423E-005
 -7.552391987852371E-005
 -1.497682175472181E-004
 -1.661823752879282E-007
 -7.769881947994370E-005
 -1.523666617482872E-004
   126.722954658724
   3.32069424406792
 -1.425372419273388E-004
 -0.106354941452202
 -4.861966109036201E-004
   94.9442571826356
 -3.051211432308537E-005
 -5.242673296719729E-003
  2.176094571351480E-003
 -6.707392610706632E-008
  2.139600499283991E-009
  1.145104208480427E-012
 -1.497607934274479E-004
 -2.982604755606273E-004
  5.633782752557015E-015
  1.060700492710442E-010
 -4.360537272704143E-011
 -1.583473584201577E-007
  5.051144356723808E-009
  2.703347327480947E-012
 -1.523591946899750E-004
 -3.017210528072133E-004
  1.330016987905421E-014
  2.504089578075501E-010
 -1.029430668430854E-010
  5.331753235415877E-005
 -3.052045098627892E-005
 -1.506650203539703E-005
 -3.043957328189070E-005
  5.634225315801326E-015
 -8.270129100433974E-015
 -1.080591890227618E-015
  4.000595472777054E-015
  1.330121467733245E-014
 -1.952402625635190E-014
 -2.551048951546373E-015
  9.444560071166567E-015
   4.33450868614257
 -5.242147774951779E-003
 -1.506310266508878E-005
   1.46306340108363
  1.060594431050364E-010
 -1.080551370396493E-015
 -8.755076696687986E-008
 -2.955190080340337E-008
  2.503839188927681E-010
 -2.550953292780482E-015
 -2.066888503930148E-007
 -6.976578978911438E-008
   588.287140060265
   158.392022372655
   10.8339819969692
  1.795926716056081E-009
  2.176094571347525E-003
 -3.043122882385960E-005
   1.46306340065163
 -3.199314677200335E-006
 -3.627551463514057E-017
 -4.360537272712133E-011
  3.999995463456065E-015
 -2.955190080344427E-008
 -1.188266522899093E-005
 -8.563877324112632E-017
 -1.029430668430855E-010
  9.443143575959096E-015
 -6.976578978892128E-008
 -2.805246031389365E-005
   427.221761646610
   3.48465051337474
   3.32015330994354
   158.366220723240
 -8.625569619081469E-006
 -7.035052692638890E-008
 -6.703370366733956E-008
 -3.197396133960991E-006
 -2.037119246752922E-005
 -1.661483457663766E-007
 -1.583149333202787E-007
 -7.551358915013174E-006
   268.880148009682
  4.276541516306511E-005
  4.276541516304648E-005
 -1.424587656156921E-004
   10.8322171643238
 -5.428674378905390E-006
 -2.187018392370192E-007
 -1.282101652362439E-005
 -5.165128167381734E-007
   34.0581868119367
 -6.876328256429030E-007
 -1.623997168507272E-006
   57.6592190088933
  4.276113890661555E-005
  1.282962454891394E-004
 -0.106326817453437
 -1.164132839939863E-006
  2.138103614457015E-009
 -2.749357454006337E-006
  5.049605043103739E-009
  1.435297470021010E-004
  1.282962454891953E-004
 -4.858948411149086E-004
  1.795658688961180E-009
 -2.951107719216558E-013
  1.144135337169922E-012
 -3.625425420120058E-017
 -6.969690959260849E-013
  2.702127631748054E-012
 -8.562241036547724E-017
   79.3220146272550
   3.48465051338284
   94.9364155328902
  4.320032639754627E-005
 -7.035052692638893E-008
 -7.565048986719308E-005
 -1.500221420660175E-004
 -1.661483457665697E-007
 -7.780100450223757E-005
 -1.525716642617383E-004
   126.714396314290
   3.32015330994758
 -1.425371296887185E-004
 -0.106337685252375
 -4.861870236827282E-004
   94.9348328227194
 -3.051206888734055E-005
 -5.241817844100381E-003
  2.175742915507532E-003
 -6.703370366717607E-008
  2.138317424823262E-009
  1.144417143941102E-012
 -1.500147052121065E-004
 -2.987690897570248E-004
  5.630404305894612E-015
  1.060064412803966E-010
 -4.357922401121403E-011
 -1.583149333206648E-007
  5.050110003593831E-009
  2.702793180513903E-012
 -1.525641869228457E-004
 -3.021316746626756E-004
  1.329744634976692E-014
  2.503576801232304E-010
 -1.029219873881656E-010
  5.331746565731978E-005
 -3.052040554697540E-005
 -1.506651075044098E-005
 -3.043954101798205E-005
  5.630846603739516E-015
 -8.265169716748017E-015
 -1.079943879519946E-015
  3.998196419541821E-015
  1.329849093408829E-014
 -1.952002827018112E-014
 -2.550526554947418E-015
  9.442626085200824E-015
   4.33380261171710
 -5.241292407852612E-003
 -1.506311137980146E-005
   1.46282507261281
  1.059958414752610E-010
 -1.079903383988697E-015
 -8.749826511887928E-008
 -2.953417932095777E-008
  2.503326463364695E-010
 -2.550430915765432E-015
 -2.066465263193631E-007
 -6.975150371436822E-008
   588.191309421025
   158.366220723240
   10.8322171643238
  1.795633721163360E-009
 -3.043119656477993E-005
   1.46282507217676
 -3.197396133955758E-006
 -2.187018392366922E-007
 -3.625375010274683E-017
 -4.357922401113419E-011
  3.997596770013282E-015
 -2.953417932095776E-008
 -1.187553951319527E-005
 -7.551358915013176E-006
 -8.562121982599415E-017
  9.441209880080573E-015
 -6.975150371427169E-008
 -2.804671595761421E-005
   427.165630693377
   3.48419270607668
   3.31971708752524
   158.345413646306
 -8.621397316433378E-006
 -7.031649742237221E-008
 -6.700127857067402E-008
 -3.195849510969310E-006
 -2.036782894674313E-005
 -1.661209127120733E-007
 -1.582887936785668E-007
 -7.550112097834043E-006
   268.844820869730
  4.276538801882637E-005
  4.276538801884499E-005
 -1.424586751936007E-004
   10.8307939604322
 -5.426048456843738E-006
 -2.185960502460161E-007
 -1.281889962450808E-005
 -5.164275344581396E-007
   34.0537120366246
 -6.873002085067687E-007
 -1.623729027687673E-006
   57.6516433924334
  4.276111176509627E-005
  1.282961640565350E-004
 -0.106312903027208
 -1.163569733063609E-006
  2.137069374525986E-009
 -2.748903502580216E-006
  5.048771277983504E-009
  1.435277418859398E-004
  1.282961640564791E-004
 -4.858871118902142E-004
  1.795422407754408E-009
 -2.949679448196765E-013
  1.143581600653997E-012
 -3.623670861120126E-017
 -6.968538983348135E-013
  2.701681013850077E-012
 -8.560825940938273E-017
   79.3140293888438
   3.48419270608072
   94.9288155364546
  4.320032623006424E-005
 -7.031649742253563E-008
 -7.575267495573088E-005
 -1.502271447115876E-004
 -1.661209127124835E-007
 -7.788347994990298E-005
 -1.527371250345112E-004
   126.707494658598
   3.31971708753334
 -1.425370392169875E-004
 -0.106323769434217
 -4.861792924454244E-004
   94.9272327903893
 -3.051203224687058E-005
 -5.241127986329533E-003
  2.175459331690614E-003
 -6.700127857075572E-008
  2.137283081464211E-009
  1.143863271033899E-012
 -1.502196975773702E-004
 -2.991797118766847E-004
  5.627680789851711E-015
  1.059551640524270E-010
 -4.355814436878828E-011
  5.049276155116842E-009
  2.702346452609457E-012
 -1.527296393981066E-004
 -3.024630934673905E-004
  1.329525076419163E-014
  2.503163423841209E-010
 -1.029049940896415E-010
  5.331741187140007E-005
 -3.052036890363413E-005
 -1.506651777848080E-005
 -3.043951499959878E-005
  5.628122873768926E-015
 -8.261171737097042E-015
 -1.079421489284750E-015
  3.996262436076811E-015
  1.329629517608745E-014
 -1.951680527537149E-014
 -2.550105422550012E-015
  9.441066993628428E-015
   4.33323321615882
  4.320032623016016E-005
 -5.240602619075892E-003
 -1.506311840756585E-005
   1.46263287874512
  1.059445693742388E-010
 -1.079381013335640E-015
 -8.745594104516947E-008
 -2.951989324612681E-008
  2.502913127307292E-010
 -2.550009799150539E-015
 -2.066124065746640E-007
 -6.973998693008840E-008
   588.114029266581
   158.345413646306
   10.8307939604322
  1.795397443247380E-009
 -3.043117055029229E-005
   1.46263287831109
 -3.623620475664370E-017
 -4.355814436878829E-011
  3.995663076599413E-015
 -2.951989324604511E-008
 -1.186979515691743E-005
 -7.550112097846397E-006
 -8.560706906667379E-017
  9.439651022317102E-015
 -6.973998693008842E-008
 -2.804208511859531E-005
   427.120367802084
   3.48382353930220
   3.31936532639020
   158.328635230445
 -8.618033795640255E-006
 -7.028906438278944E-008
 -6.697513893128398E-008
 -3.194602693795374E-006
 -2.036511740166231E-005
 -1.660987972075013E-007
 -1.582677208741126E-007
 -7.549106960328156E-006
   268.816333761917
  4.276536613799878E-005
  4.276536613801741E-005
 -1.424586023047331E-004
   10.8296463169372
 -5.423931557820016E-006
 -2.185107679693339E-007
 -1.281719305936730E-005
 -5.163587830634264E-007
   34.0501036662429
 -6.870320676871627E-007
 -1.623512862557403E-006
   57.6455345650659
  4.276108988652248E-005
  1.282960984140522E-004
 -0.106301682708543
 -1.163115781890988E-006
  2.136235617304620E-009
 -2.748537543865891E-006
  5.048099127652606E-009
  1.435261250246491E-004
  1.282960984139963E-004
 -4.858808792791054E-004
  1.795231875436297E-009
 -2.948528041636215E-013
  1.143135203678262E-012
 -3.622256416113276E-017
 -6.967610303658688E-013
  2.701320967285562E-012
 -8.559685144016206E-017
   79.3075902502773
   3.48382353931080
   94.9226870493806
  4.320032609500428E-005
 -7.028906438287110E-008
 -7.583515045723236E-005
 -1.503926055920348E-004
 -1.660987972067051E-007
 -7.795003268525751E-005
 -1.528706415557866E-004
   126.701929299878
   3.31936532639020
 -1.425369662884083E-004
 -0.106312547993815
 -4.861730582117008E-004
   94.9211042745133
 -3.051200270070174E-005
 -5.240571698652299E-003
  2.175230655305720E-003
 -6.697513893144731E-008
  2.136449240860335E-009
  1.143416764110519E-012
 -1.503851501602144E-004
 -2.995111308966969E-004
  5.625485214999972E-015
  1.059138266814374E-010
 -4.354115091885202E-011
 -1.582677208733406E-007
  5.048603937566217E-009
  2.701986317360969E-012
 -1.528631492238346E-004
 -3.027305273817310E-004
  1.329348076503172E-014
  2.502830174411476E-010
 -1.028912947256777E-010
  5.331736849946610E-005
 -3.052033935517168E-005
 -1.506652344575642E-005
 -3.043949401889246E-005
  5.625927126439296E-015
 -8.257948747596203E-015
 -1.079000362018608E-015
  3.994703346481365E-015
  1.329452503783589E-014
 -1.951420701718963E-014
 -2.549765921317497E-015
  9.439810112110089E-015
   4.33277406683484
  4.320032609510020E-005
 -5.240046387021404E-003
 -1.506312407460757E-005
   1.46247789740747
  1.059032361369377E-010
 -1.078959901858808E-015
 -8.742182130037747E-008
 -2.950837646177622E-008
  2.502579911199242E-010
 -2.549670310656882E-015
 -2.065849005088242E-007
 -6.973070252807960E-008
   588.051712076509
   158.328635230704
   10.8296463169372
  1.795206913578779E-009
 -3.043114957270579E-005
   1.46247789697547
 -3.622206050335637E-017
  3.994104220848080E-015
 -2.950837646173538E-008
 -1.186516431793148E-005
 -7.549106960315804E-006
 -5.163587830641984E-007
 -8.559566125607932E-017
 -1.028912947260547E-010
  9.438394329339861E-015
 -6.973070252827261E-008
 -2.803835190888569E-005
   427.083870308086
   3.48352586364375
   3.31908168565849
   158.315106043777
 -8.615322250599468E-006
 -7.026694888887836E-008
 -6.695406612875968E-008
 -3.193597556277150E-006
 -2.036293143732337E-005
 -1.660809683662370E-007
 -1.582507326259884E-007
 -7.548296649335668E-006
   268.793363332956
  4.276534849949812E-005
  4.276534849949811E-005
 -1.424585435479524E-004
   10.8287209206603
 -5.422224992756780E-006
 -2.184420165778577E-007
 -1.281581727896991E-005
 -5.163033578003423E-007
   34.0471940758620
 -6.868159025568957E-007
 -1.623338596866648E-006
   57.6406087443808
  4.276107224975408E-005
  1.282960454984943E-004
 -0.106292635264397
 -1.162749823383462E-006
  2.135563473315306E-009
 -2.748242519185980E-006
  5.047557260681299E-009
  1.435248212928287E-004
  1.282960454984944E-004
 -4.858758537001741E-004
  1.795078240818607E-009
 -2.947599820991669E-013
  1.142775335236040E-012
 -3.621116143763969E-017
 -6.966861630859311E-013
  2.701030708886960E-012
 -8.558765468856701E-017
   79.3023980854047
   3.48352586362705
   94.9177453766312
  4.320032598622728E-005
 -7.026694888905187E-008
 -7.590170323587347E-005
 -1.505261221998417E-004
 -1.660809683662249E-007
 -7.800372715742243E-005
 -1.529783618802939E-004
   126.697441702883
   3.31908168564230
 -1.425369074991803E-004
 -0.106303499644730
 -4.861680313232982E-004
   94.9161625787032
 -3.051197887635213E-005
 -5.240123139044841E-003
  2.175046263303828E-003
 -6.695406612875967E-008
  2.135777029664981E-009
  1.143056807029872E-012
 -1.505186600724663E-004
 -2.997785649840761E-004
  5.623715224413027E-015
  1.058805020343334E-010
 -4.352745143316114E-011
  5.048062016403261E-009
  2.701695987479198E-012
 -1.529708641467726E-004
 -3.029462912012761E-004
  1.329205384608164E-014
  2.502561518956256E-010
 -1.028802507195626E-010
  5.331733352681825E-005
 -3.052031552886080E-005
 -1.506652801553732E-005
 -3.043947710114636E-005
  5.624156996831109E-015
 -8.255350493623017E-015
 -1.078660864921616E-015
  3.993446466596203E-015
  1.329309800676621E-014
 -1.951211238122261E-014
 -2.549492225859209E-015
  9.438796852864443E-015
   4.33240383420635
 -5.239597872265071E-003
 -1.506312864421933E-005
   1.46235292902598
  1.058699148220020E-010
 -1.078620417488397E-015
 -8.739431523442948E-008
 -2.949909205965623E-008
  2.502311282599400E-010
 -2.549396625481451E-015
 -2.065627259630643E-007
 -6.972321772838804E-008
   588.001462940412
   158.315106043518
   10.8287209206765
  1.795053281097384E-009
  2.175046263311733E-003
 -3.043113265758644E-005
   1.46235292859803
 -3.193597556282375E-006
 -3.621065793841780E-017
 -4.352745143316113E-011
  3.992847529459772E-015
 -2.949909205965624E-008
 -1.186143110820211E-005
 -7.548296649323318E-006
 -8.558646463237182E-017
  9.437381222045184E-015
 -6.972321772848453E-008
 -2.803534230984747E-005
   427.054441793479
   3.48328584296820
   3.31885298157649
   158.304197243316
 -8.613136286226467E-006
 -7.024912005710925E-008
 -6.693707788239468E-008
 -3.192787245277546E-006
 -2.036116916837287E-005
 -1.660665952073843E-007
 -1.582370371320010E-007
 -7.547643397178636E-006
   268.774841907557
  4.276533428055604E-005
  4.276533428063054E-005
 -1.424584961822248E-004
   10.8279747587862
 -5.420849212398619E-006
 -2.183865913167930E-007
 -1.281470815972889E-005
 -5.162586753604533E-007
   34.0448480264053
 -6.866416368661422E-007
 -1.623198108291640E-006
   57.6366369760248
  4.276105803224623E-005
  1.282960028418916E-004
 -0.106285340164655
 -1.162454798870676E-006
  2.135021611478840E-009
 -2.748004677779252E-006
  5.047120421297088E-009
  1.435237700837924E-004
  1.282960028416681E-004
 -4.858718015301387E-004
  1.794954362837759E-009
 -2.946851518264730E-013
  1.142485220447218E-012
 -3.620196891503395E-017
 -6.966258069963152E-013
  2.700796709995036E-012
 -8.558024050269235E-017
   79.2982115593350
   3.48328584296795
   94.9137608265196
  4.320032589845749E-005
 -7.024912005677252E-008
 -7.595539774293116E-005
 -1.506338425944282E-004
 -1.660665952073963E-007
 -7.804704139903842E-005
 -1.530652575172588E-004
   126.693823281389
   3.31885298157649
 -1.425368601074874E-004
 -0.106296203815296
 -4.861639780990102E-004
   94.9121780098801
 -3.051195966640438E-005
 -5.239761458235516E-003
  2.174897585080773E-003
 -6.693707788206818E-008
  2.135235113640345E-009
  1.142766620783122E-012
 -1.506263750651352E-004
 -2.999943289437531E-004
  5.622288312376843E-015
  1.058536367275073E-010
 -4.351640732825920E-011
  5.047625133335980E-009
  2.701461930940803E-012
 -1.530577554256869E-004
 -3.031203430070810E-004
  1.329090350017094E-014
  2.502344935741696E-010
 -1.028713473218871E-010
  5.331730532782362E-005
 -3.052029631744898E-005
 -1.506653170022806E-005
 -3.043946346022138E-005
  5.622729972682792E-015
 -8.253255861072113E-015
 -1.078387172788445E-015
  3.992433208613188E-015
  1.329194757054679E-014
 -1.951042373884011E-014
 -2.549271579511680E-015
  9.437979988971453E-015
   4.33210530969058
 -5.239236227604087E-003
 -1.506313232877389E-005
   1.46225216501561
  1.058430522014676E-010
 -1.078346735621595E-015
 -8.737214068865612E-008
 -2.949160725975691E-008
  2.502094721044812E-010
 -2.549175987400272E-015
 -2.065448494071410E-007
 -6.971718367279060E-008
   587.960946254958
   158.304197243057
   10.8279747587862
  1.794929404839233E-009
 -3.043111901866141E-005
   1.46225216458563
 -3.192787245272321E-006
 -2.183865913171196E-007
 -3.620146554363137E-017
 -4.351640732841862E-011
  3.991834423459577E-015
 -2.949160725983854E-008
 -1.185842150915850E-005
 -7.547643397190986E-006
 -5.162586753612252E-007
 -8.557905054933092E-017
 -1.028713473220755E-010
  9.436564480647867E-015
 -6.971718367288709E-008
 -2.803291604751108E-005
   427.030713789360
   3.48309231599418
   3.31866857909252
   158.295401554149
 -8.611374017274404E-006
 -7.023474690541793E-008
 -6.692338238944656E-008
 -3.192133993125735E-006
 -2.035974846431673E-005
 -1.660550078698065E-007
 -1.582259961136863E-007
 -7.547116759088606E-006
   268.759908212365
  4.276532281803306E-005
  4.276532281797719E-005
 -1.424584579988613E-004
   10.8273731337211
 -5.419740093215403E-006
 -2.183419088788042E-007
 -1.281381401120848E-005
 -5.162226533204438E-007
   34.0429564232562
 -6.865011482911346E-007
 -1.623084849367424E-006
   57.6334345671615
  4.276104657087810E-005
  1.282959684539316E-004
 -0.106279458177356
 -1.162216957599191E-006
  2.134584776220668E-009
 -2.747812935059043E-006
  5.046768250604163E-009
  1.435229225073201E-004
  1.282959684540992E-004
 -4.858685343174991E-004
  1.794854480942685E-009
 -2.946248255787177E-013
  1.142251337336272E-012
 -3.619455813879906E-017
 -6.965771492030833E-013
  2.700608065061806E-012
 -8.557426334351483E-017
   79.2948359928025
   3.48309231599443
   94.9105481120185
  4.320032582766612E-005
 -7.023474690541284E-008
 -7.599871201298816E-005
 -1.507207382874295E-004
 -1.660550078697944E-007
 -7.808197806418022E-005
 -1.531353462221790E-004
   126.690905773981
   3.31866857909252
 -1.425368219029270E-004
 -0.106290321239752
 -4.861607100329226E-004
   94.9089652801122
 -3.051194417747818E-005
 -5.239469837530585E-003
  2.174777706868896E-003
 -6.692338238944658E-008
  2.134798234696553E-009
  1.142532680069320E-012
 -1.507132664008851E-004
 -3.001683808616113E-004
  5.621137972136956E-015
  1.058319785994594E-010
 -4.350750385149707E-011
 -1.582259961134934E-007
  5.047272927426687E-009
  2.701273239547502E-012
 -1.531278406162897E-004
 -3.032607304522242E-004
  1.328997611560622E-014
  2.502170330926490E-010
 -1.028641695906628E-010
  5.331728259103376E-005
 -3.052028082737200E-005
 -1.506653467113831E-005
 -3.043945246158842E-005
  5.621579542065954E-015
 -8.251567221496519E-015
 -1.078166529145517E-015
  3.991616345773659E-015
  1.329102011313908E-014
 -1.950906239105018E-014
 -2.549093699091955E-015
  9.437321450517553E-015
   4.33186461147288
  4.320032582757020E-005
 -5.238944636065963E-003
 -1.506313529956569E-005
   1.46217091970105
  1.058213962387210E-010
 -1.078126100260727E-015
 -8.735426413288162E-008
 -2.948557320418542E-008
  2.501920133695916E-010
 -2.548998113628936E-015
 -2.065304377049929E-007
 -6.971231914453291E-008
   587.928277936701
   158.295401554408
   10.8273731337373
  1.794829524327580E-009
  2.174777706872848E-003
 -3.043110802161291E-005
   1.46217091927107
 -3.192133993120512E-006
 -3.619405487044450E-017
  3.991017683125673E-015
 -2.948557320422622E-008
 -1.185599524682917E-005
 -7.547116759088605E-006
 -8.557307347329491E-017
 -1.028641695908513E-010
  9.435906041001554E-015
 -6.971231914453293E-008
 -2.803096004603314E-005
   427.011582508512
   3.48293628015925
   3.31851990010276
   158.288309816091
 -8.609953313235059E-006
 -7.022315957398169E-008
 -6.691234137219474E-008
 -3.191607355023419E-006
 -2.035860311777728E-005
 -1.660456663631976E-007
 -1.582170950393383E-007
 -7.546692192743798E-006
   268.747867557494
  4.276531357749862E-005
 -1.424584272170226E-004
   10.8268880588805
 -5.418845944729966E-006
 -2.183058868402541E-007
 -1.281309316446185E-005
 -5.161936129883974E-007
   34.0414312722104
 -6.863878893669312E-007
 -1.622993542021346E-006
   57.6308525471772
  4.276103733121911E-005
  1.282959407324959E-004
 -0.106274715682045
 -1.162025214985318E-006
  2.134232608859360E-009
 -2.747658355462356E-006
  5.046484336799493E-009
  1.435222391333499E-004
 -4.858659000620537E-004
  1.794773948764061E-009
 -2.945761918401803E-013
  1.142062785751826E-012
 -3.618858372868639E-017
 -6.965379221530483E-013
  2.700455982864782E-012
 -8.556944466404090E-017
   79.2921143605058
   3.48293628015900
   94.9079577827078
  4.320032577049585E-005
 -7.022315957398678E-008
 -7.603364870076584E-005
 -1.507908270384977E-004
 -1.660456663628117E-007
 -7.811015485539672E-005
 -1.531918734377340E-004
   126.688553462536
   3.31851990009871
 -1.425367911040637E-004
 -0.106285578270155
 -4.861580750925333E-004
   94.9063749389489
 -3.051193168925161E-005
 -5.239234711248062E-003
  2.174681052146364E-003
 -6.691234137219472E-008
  2.134446032118877E-009
  1.142344082038826E-012
 -1.507833516367383E-004
 -3.003087683990309E-004
  5.620210592078148E-015
  1.058145182734019E-010
 -4.350032605626727E-011
  5.046988985231202E-009
  2.701121119892383E-012
 -1.531843649967913E-004
 -3.033739542100913E-004
  1.328922847459617E-014
  2.502029567608860E-010
 -1.028583830306593E-010
  5.331726425911362E-005
 -3.052026833812379E-005
 -1.506653706650351E-005
 -3.043944359357514E-005
  5.620652089180673E-015
 -8.250205875887358E-015
 -1.077988650889766E-015
  3.990957808184881E-015
  1.329027241331511E-014
 -1.950796489648490E-014
 -2.548950295039907E-015
  9.436790548457404E-015
   4.33167054267984
  4.320032577059178E-005
 -5.238709533309313E-003
 -1.506313769488709E-005
   1.46210541369056
  1.058039376587003E-010
 -1.077948228671890E-015
 -8.733985243082010E-008
 -2.948070867587265E-008
  2.501779384449471E-010
 -2.548854714982849E-015
 -2.065188192451716E-007
 -6.970839744771226E-008
   587.901938310819
   158.288309816091
   10.8268880588805
  1.794748993269387E-009
  2.174681052150375E-003
 -3.043109915507198E-005
   1.46210541325856
 -3.191607355028641E-006
 -2.183058868405805E-007
 -3.618808054329452E-017
 -4.350032605634695E-011
  3.990359244296933E-015
 -2.948070867591345E-008
 -1.185403924534047E-005
 -5.161936129883973E-007
 -8.556825486093733E-017
 -1.028583830304708E-010
  9.435375218571635E-015
 -6.970839744771225E-008
 -2.802938315214927E-005
   426.996157735481
   3.48281047482667
   3.31840002628053
   158.282592036146
 -8.608807966700272E-006
 -7.021381807174705E-008
 -6.690344029887806E-008
 -3.191182788683806E-006
 -2.035767975645025E-005
 -1.660381353785444E-007
 -1.582099191254524E-007
 -7.546349913664298E-006
   268.738159667821
  0.000000000000000E+000
  4.276530612814112E-005
  4.276530612814113E-005
 -1.424584024017627E-004
   10.8264969628007
 -5.418125098001261E-006
 -2.182768465084438E-007
 -1.281251202851354E-005
 -5.161702011023048E-007
   34.0402016050016
 -6.862965820208480E-007
 -1.622919931395471E-006
   57.6287707695779
  4.276102988260666E-005
  1.282959183844234E-004
 -0.106270892000988
 -1.161870635474583E-006
  2.133948697747291E-009
 -2.747533735684855E-006
  5.046255449715919E-009
  1.435216881593697E-004
 -4.858637761784492E-004
  1.794709018967659E-009
 -2.945369841867598E-013
  1.141910778818618E-012
 -3.618376726546069E-017
 -6.965062978948476E-013
  2.700333376476468E-012
 -8.556555991671835E-017
   79.2899200187539
   3.48281047481857
   94.9058693056000
  4.320032572454859E-005
 -7.021381807174194E-008
 -7.606182551076424E-005
 -1.508473542907695E-004
 -1.660381353785565E-007
 -7.813287802263710E-005
 -1.532374597533818E-004
   126.686656889576
   3.31840002628053
 -1.425367662753556E-004
 -0.106281754206702
 -4.861559506562385E-004
   94.9042864518574
 -3.051192162048649E-005
 -5.239045138503998E-003
  2.174603123382914E-003
 -6.690344029879647E-008
  2.134162092615993E-009
  1.142192037667259E-012
 -1.508398760547628E-004
 -3.004219922303148E-004
  5.619462954653293E-015
  1.058004420667283E-010
 -4.349453944444023E-011
 -1.582099191254523E-007
  5.046760075265405E-009
  2.700998483312544E-012
 -1.532299490261344E-004
 -3.034652633500976E-004
  1.328862573745638E-014
  2.501916086311893E-010
 -1.028537179917249E-010
  5.331724947880172E-005
 -3.052025826843650E-005
 -1.506653899783600E-005
 -3.043943644372511E-005
  5.619904393028321E-015
 -8.249108383106033E-015
 -1.077845248582974E-015
  3.990426906792013E-015
  1.328966962884345E-014
 -1.950708011260887E-014
 -2.548834684824847E-015
  9.436362543115239E-015
   4.33151407291416
  4.320032572454860E-005
 -5.238519979512613E-003
 -1.506313962612738E-005
   1.46205259886104
  1.057898628598408E-010
 -1.077804831733179E-015
 -8.732823397091536E-008
 -2.947678697899607E-008
  2.501665914499524E-010
 -2.548739109097057E-015
 -2.065094526156288E-007
 -6.970523583401790E-008
   587.880701742405
   158.282592036146
   10.8264969628007
  1.794684064378213E-009
  2.174603123378963E-003
 -3.043109200632316E-005
   1.46205259842904
 -3.618326414705300E-017
 -4.349453944451992E-011
  3.989828422545568E-015
 -2.947678697899608E-008
 -1.185246235146184E-005
 -7.546349913676647E-006
 -5.161702011030765E-007
 -8.556437016773536E-017
  9.434947277387043E-015
 -6.970523583411436E-008
 -2.802811188372582E-005
   426.983721556487
   3.48270904461498
   3.31830337834958
   158.277982092186
 -8.607884605340169E-006
 -7.020628709162966E-008
 -6.689626438571953E-008
 -3.190840509604301E-006
 -2.035693535415960E-005
 -1.660320639942398E-007
 -1.582041339942309E-007
 -7.546073972585514E-006
   268.730332708918
  4.276530012270733E-005
  4.276530012278184E-005
 -1.424583823966762E-004
   10.8261816426503
 -5.417543962083103E-006
 -2.182534346247850E-007
 -1.281204352402836E-005
 -5.161513267366070E-007
   34.0392101892812
 -6.862229713949716E-007
 -1.622860587436898E-006
   57.6270923421905
  4.276102387775030E-005
  1.282959003683455E-004
 -0.106267809169088
 -1.161746015769914E-006
  2.133719812824236E-009
 -2.747433268794067E-006
  5.046070923833038E-009
  1.435212439403324E-004
  1.282959003681220E-004
 -4.858620638101766E-004
  1.794656669515620E-009
 -2.945053755628916E-013
  1.141788233103411E-012
 -3.617988430492685E-017
 -6.964808028168938E-013
  2.700234532762344E-012
 -8.556242808271928E-017
   79.2881508370105
   3.48270904461523
   94.9041854769836
  4.320032568742628E-005
 -7.020628709146650E-008
 -7.608454869277947E-005
 -1.508929406360292E-004
 -1.660320639942519E-007
 -7.815120200175601E-005
 -1.532742205627429E-004
   126.685127783192
   3.31830337834958
 -1.425367462591677E-004
 -0.106278671066622
 -4.861542378428190E-004
   94.9026026151761
 -3.051191350248130E-005
 -5.238892296010439E-003
  2.174540293532246E-003
  2.133933184804685E-009
  1.142069461768620E-012
 -1.508854601136332E-004
 -3.005133014295377E-004
  5.618860220495018E-015
  1.057890940381847E-010
 -4.348987436405509E-011
 -1.582041339944238E-007
  5.046575530930303E-009
  2.700899615249401E-012
 -1.532667079922211E-004
 -3.035388950204200E-004
  1.328813981839679E-014
  2.501824599123675E-010
 -1.028499570961289E-010
  5.331723756205752E-005
 -3.052025014982751E-005
 -1.506654055494028E-005
 -3.043943067924605E-005
  5.619301611487105E-015
 -8.248223600731123E-015
 -1.077729639775344E-015
  3.989998901985312E-015
  1.328918367164582E-014
 -1.950636681107553E-014
 -2.548741481310975E-015
  9.436017490602162E-015
   4.33138791960991
 -5.238367152301658E-003
 -1.506314118313982E-005
   1.46201001705403
  1.057785159658398E-010
 -1.077689227272729E-015
 -8.731886734121013E-008
 -2.947362536524598E-008
  2.501574436455362E-010
 -2.548645909083775E-015
 -2.065019013565692E-007
 -6.970268698093460E-008
   587.863579818955
   158.277982092445
   10.8261816426665
  1.794631715656270E-009
  2.174540293532188E-003
 -3.043108624257365E-005
   1.46201001662405
 -3.190840509604302E-006
 -3.617938124055847E-017
 -4.348987436397542E-011
  3.989400481933371E-015
 -2.947362536524597E-008
 -1.185119108304070E-005
 -7.546073972597860E-006
 -5.161513267358354E-007
 -8.556123837726332E-017
  9.434602276636308E-015
 -6.970268698083814E-008
 -2.802708700315142E-005
   426.973695043101
   3.48262726779579
   3.31822545717369
   158.274265382899
 -8.607140203068011E-006
 -7.020021571005947E-008
 -6.689047925500247E-008
 -3.190564568525489E-006
 -2.035633522506672E-005
 -1.660271693093557E-007
 -1.581994700840368E-007
 -7.545851511890537E-006
   268.724022321620
  4.276529528122286E-005
  4.276529528129737E-005
 -1.424583662690428E-004
   10.8259274197844
 -5.417075457627720E-006
 -2.182345602585520E-007
 -1.281166582078565E-005
 -5.161361104265306E-007
   34.0384108728368
 -6.861636274363930E-007
 -1.622812744977956E-006
   57.6257391312955
  4.276101903663835E-005
  1.282958858438921E-004
 -0.106265323674647
 -1.161645548933731E-006
  2.133535288688245E-009
 -2.747352273470457E-006
  5.045922161057735E-009
  1.435208857951080E-004
  1.282958858436686E-004
 -4.858606832388200E-004
  1.794614463437635E-009
 -2.944798930929904E-013
  1.141689438306092E-012
 -3.617675391145015E-017
 -6.964602489621226E-013
  2.700154846034625E-012
 -8.555990323233618E-017
   79.2867244567746
   3.48262726779604
   94.9028279113774
  4.320032565749822E-005
 -7.020021571006456E-008
 -7.610287268362518E-005
 -1.509297014692870E-004
 -1.660271693097536E-007
 -7.816597774746584E-005
 -1.533038630340719E-004
   126.683894960427
   3.31822545717774
 -1.425367301221278E-004
 -0.106276185323612
 -4.861528569111956E-004
   94.9012450433212
 -3.051190695757319E-005
 -5.238769068679896E-003
  2.174489637755595E-003
  2.133748642219022E-009
  1.141970642640604E-012
 -1.509222191031674E-004
 -3.005869331476470E-004
  5.618374303787992E-015
  1.057799454005784E-010
 -4.348611343496049E-011
 -1.581994700842297E-007
  5.046426753272988E-009
  2.700819908891188E-012
 -1.532963489769795E-004
 -3.035982686855001E-004
  1.328774807561695E-014
  2.501750843136254E-010
 -1.028469251029643E-010
  5.331722795456309E-005
 -3.052024360446352E-005
 -1.506654181030277E-005
 -3.043942603168677E-005
  5.618815656615661E-015
 -8.247510300308448E-015
 -1.077636437412721E-015
  3.989653849910769E-015
  1.328879189815609E-014
 -1.950579175499460E-014
 -2.548666341658404E-015
  9.435739312995785E-015
   4.33128621008786
  4.320032565749821E-005
 -5.238243937284556E-003
 -1.506314243852706E-005
   1.46197568600855
  1.057693682430158E-010
 -1.077596028402512E-015
 -8.731131608249054E-008
 -2.947107651210676E-008
  2.501500687842819E-010
 -2.548570772211318E-015
 -2.064958136133777E-007
 -6.970063212310561E-008
   587.849775483743
   158.274265383158
   10.8259274197682
  1.794589510164728E-009
 -3.043108159575484E-005
   1.46197568557452
 -3.190564568530710E-006
 -2.182345602588783E-007
 -3.617625089065281E-017
  3.989055481595080E-015
 -2.947107651214755E-008
 -1.185016620246559E-005
 -7.545851511878190E-006
 -8.555871356181838E-017
 -1.028469251027759E-010
  9.434324140716399E-015
 -6.970063212300914E-008
 -2.802626075551777E-005
   426.965611371873
   3.48256133690084
   3.31816263482366
   158.271268862616
 -8.606540073977602E-006
 -7.019532102800799E-008
 -6.688581534509083E-008
 -3.190342107805830E-006
 -2.035585140661548E-005
 -1.660232232608259E-007
 -1.581957100831921E-007
 -7.545672166121366E-006
   268.718934701357
  4.276529137823295E-005
  4.276529137825157E-005
 -1.424583532673404E-004
   10.8257224577982
 -5.416697754387867E-006
 -2.182193439489215E-007
 -1.281136131994871E-005
 -5.161238431783811E-007
   34.0377664403113
 -6.861157849774536E-007
 -1.622774174833888E-006
   57.6246481326935
  4.276101513418861E-005
  1.282958741347547E-004
 -0.106263319795624
 -1.161564553655851E-006
  2.133386527320685E-009
 -2.747286975793671E-006
  5.045802229895276E-009
  1.435205970488360E-004
  1.282958741346988E-004
 -4.858595701842091E-004
  1.794580435660466E-009
 -2.944593494017681E-013
  1.141609791014474E-012
 -3.617423022224609E-017
 -6.964436786370701E-013
  2.700090603342022E-012
 -8.555786772143611E-017
   79.2855744667385
   3.48256133690919
   94.9017334017103
  4.320032563342148E-005
 -7.019532102801309E-008
 -7.611764843917326E-005
 -1.509593439600134E-004
 -1.660232232608258E-007
 -7.817789186476448E-005
 -1.533277646158640E-004
   126.682901022144
   3.31816263482770
 -1.425367171139620E-004
 -0.106274181244060
 -4.861517435666363E-004
   94.9001505286604
 -3.051190168074431E-005
 -5.238669719158875E-003
  2.174448797578060E-003
 -6.688581534517240E-008
  2.133599865975480E-009
  1.141890975730040E-012
 -1.509518601075828E-004
 -3.006463068515062E-004
  5.617982562993246E-015
  1.057725698677976E-010
 -4.348308141450368E-011
 -1.581957100833850E-007
  5.046306810111623E-009
  2.700755650372454E-012
 -1.533202493602619E-004
 -3.036461433762594E-004
  1.328743225635880E-014
  2.501691381746855E-010
 -1.028444807377414E-010
  5.331722020848978E-005
 -3.052023832727182E-005
 -1.506654282245663E-005
 -3.043942228464348E-005
  5.618423885061761E-015
 -8.246935245236915E-015
 -1.077561298667175E-015
  3.989375672651378E-015
  1.328847605404724E-014
 -1.950532815018749E-014
 -2.548605764769682E-015
  9.435515048765581E-015
   4.33120420887485
  4.320032563342147E-005
 -5.238144597697426E-003
 -1.506314345059339E-005
   1.46194800730609
  1.057619934475635E-010
 -1.077520892476899E-015
 -8.730522833903519E-008
 -2.946902165422219E-008
  2.501441232406511E-010
 -2.548510197634298E-015
 -2.064909057315699E-007
 -6.969897551581621E-008
   587.838646021496
   158.271268862357
   10.8257224577982
  1.794555482857161E-009
  2.174448797574108E-003
 -3.043107784922243E-005
   1.46194800687207
 -3.190342107811051E-006
 -2.182193439485953E-007
 -3.617372723653115E-017
  3.988777346061521E-015
 -2.946902165418140E-008
 -1.184933995480764E-005
 -7.545672166146059E-006
 -5.161238431783812E-007
 -8.555667807928356E-017
 -1.028444807379298E-010
  9.434099910144249E-015
 -6.969897551591266E-008
 -2.802559464235045E-005
   426.959094129231
   3.48250818190070
   3.31811198598945
   158.268852997813
 -8.606056255503645E-006
 -7.019137498084017E-008
 -6.688205534449900E-008
 -3.190162762059464E-006
 -2.035546135607771E-005
 -1.660200419874344E-007
 -1.581926788010398E-007
 -7.545527579033733E-006
   268.714832943814
  4.276528823160796E-005
 -1.424583427855939E-004
   10.8255572126736
 -5.416393253566752E-006
 -2.182070767019904E-007
 -1.281111583385109E-005
 -5.161139534233635E-007
   34.0372468838682
 -6.860772148333890E-007
 -1.622743079898055E-006
   57.6237685442733
  4.276101198795478E-005
  1.282958646948239E-004
 -0.106261704221880
 -1.161499256018225E-006
  2.133266597294065E-009
 -2.747234333342341E-006
  5.045705542377075E-009
  1.435203642551269E-004
 -4.858586728154827E-004
  1.794553001676872E-009
 -2.944427872709321E-013
  1.141545580116501E-012
 -3.617219564778119E-017
 -6.964303197749014E-013
  2.700038811410392E-012
 -8.555622670926811E-017
   79.2846473183215
   3.48250818190070
   94.9008509829546
  4.320032561394905E-005
 -7.019137498100840E-008
 -7.612956256412007E-005
 -1.509832455572741E-004
 -1.660200419878323E-007
 -7.818749826062478E-005
 -1.533470365401784E-004
   126.682099686396
   3.31811198599349
 -1.425367066265159E-004
 -0.106272565508620
 -4.861508459632379E-004
   94.8992681057895
 -3.051189742650870E-005
 -5.238589621270814E-003
  2.174415871267025E-003
 -6.688205534458055E-008
  2.133479923953434E-009
  1.141826749015213E-012
 -1.509757605061592E-004
 -3.006941815732080E-004
  5.617666745186199E-015
  1.057666237819274E-010
 -4.348063702801298E-011
 -1.581926788008469E-007
  5.046210112918832E-009
  2.700703845673776E-012
 -1.533395203176856E-004
 -3.036847448895212E-004
  1.328717764540539E-014
  2.501643444465473E-010
 -1.028425101109268E-010
  5.331721396353830E-005
 -3.052023407270832E-005
 -1.506654363844826E-005
 -3.043941926365267E-005
  5.618108042472440E-015
 -8.246471641168037E-015
 -1.077500722517651E-015
  3.989151408742478E-015
  1.328822142308726E-014
 -1.950495439579977E-014
 -2.548556928183877E-015
  9.435334248797692E-015
   4.33113809759490
  4.320032561404498E-005
 -5.238064507834077E-003
 -1.506314426657517E-005
   1.46192569209282
  1.057560479562490E-010
 -1.077460318583012E-015
 -8.730032045721038E-008
 -2.946736504697374E-008
  2.501393299914620E-010
 -2.548461362863897E-015
 -2.064869490372897E-007
 -6.969763997251947E-008
   587.829673190301
   158.268852998331
   10.8255572126736
  1.794528049256334E-009
  2.174415871271014E-003
 -3.043107482874513E-005
   1.46192569166284
 -3.190162762054243E-006
 -3.617169269028474E-017
 -4.348063702793333E-011
  3.988553115773093E-015
 -2.946736504693295E-008
 -1.184867384166442E-005
 -7.545527579033732E-006
 -5.161139534233636E-007
 -8.555503708986609E-017
 -1.028425101111152E-010
  9.433919137304169E-015
 -6.969763997261594E-008
 -2.802505762735366E-005
   426.953839809535
   3.48246532735370
   3.31807115198201
   158.266905284177
 -8.605666205003176E-006
 -7.018819371009249E-008
 -6.687902406268150E-008
 -3.190018174966645E-006
 -2.035514690016189E-005
 -1.660174772684427E-007
 -1.581902350028845E-007
 -7.545411013976851E-006
   268.711526032695
  4.276528569486942E-005
  4.276528569483217E-005
 -1.424583343354364E-004
   10.8254239890790
 -5.416147767483558E-006
 -2.181971869470944E-007
 -1.281091792474686E-005
 -5.161059803746826E-007
   34.0368280080783
 -6.860461198975629E-007
 -1.622718011384625E-006
   57.6230594042747
  4.276100945142112E-005
  1.282958570844965E-004
 -0.106260401717306
 -1.161446613593840E-006
  2.133169910683642E-009
 -2.747191893374932E-006
  5.045627593586134E-009
  1.435201765729942E-004
  1.282958570846082E-004
 -4.858579493419512E-004
  1.794530883907056E-009
 -2.944294350167703E-013
  1.141493813816873E-012
 -3.617055539043722E-017
 -6.964195499605877E-013
  2.699997057125504E-012
 -8.555490373717122E-017
   79.2838998340370
   3.48246532736204
   94.9001395608654
  4.320032559831356E-005
 -7.018819371009247E-008
 -7.613916896653241E-005
 -1.510025174941201E-004
 -1.660174772684548E-007
 -7.819524373374081E-005
 -1.533625751580316E-004
   126.681453634901
   3.31807115197796
 -1.425366981714037E-004
 -0.106271262873658
 -4.861501223003328E-004
   94.8985566800057
 -3.051189399667767E-005
 -5.238525044919531E-003
  2.174389325490956E-003
 -6.687902406276307E-008
  2.133383227671902E-009
  1.141774969964077E-012
 -1.509950314766600E-004
 -3.007327831115240E-004
  5.617412135493093E-015
  1.057618300959396E-010
 -4.347866638328127E-011
 -1.581902350026916E-007
  5.046132156345226E-009
  2.700662081114824E-012
 -1.533550581566743E-004
 -3.037158686140364E-004
  1.328697237984861E-014
  2.501604797770813E-010
 -1.028409214058074E-010
  5.331720892876623E-005
 -3.052023064257178E-005
 -1.506654429634560E-005
 -3.043941682813324E-005
  5.617853412760884E-015
 -8.246097887362925E-015
 -1.077451886518825E-015
  3.988970608990192E-015
  1.328801614143182E-014
 -1.950465307763310E-014
 -2.548517556464685E-015
  9.435188489151988E-015
   4.33108479748753
  4.320032559821764E-005
 -5.237999937931839E-003
 -1.506314492444097E-005
   1.46190770116477
  1.057512547499057E-010
 -1.077411484432424E-015
 -8.729636376286182E-008
 -2.946602950367732E-008
  2.501354657080485E-010
 -2.548421992615269E-015
 -2.064837591785911E-007
 -6.969656326722411E-008
   587.822439131920
   158.266905284177
   10.8254239890790
  1.794505931792650E-009
  2.174389325494928E-003
 -3.043107239359363E-005
   1.46190770073479
 -3.190018174977084E-006
 -3.617005245577417E-017
 -4.347866638336091E-011
  3.988372343146837E-015
 -2.946602950371809E-008
 -1.184813682666263E-005
 -7.545411013964506E-006
 -5.161059803746827E-007
 -8.555371413619165E-017
 -1.028409214056191E-010
  9.433773399507938E-015
 -6.969656326712765E-008
 -2.802462468974206E-005
   426.949603704188
   3.48243077743568
   3.31803823102973
   158.265335010558
 -8.605351749078168E-006
 -7.018562899199686E-008
 -6.687658026505168E-008
 -3.189901609897344E-006
 -2.035489338782513E-005
 -1.660154096085898E-007
 -1.581882648291462E-007
 -7.545317039967493E-006
   268.708859955296
  4.276528364981371E-005
  4.276528364985097E-005
 -1.424583275227874E-004
   10.8253165823734
 -5.415949858368446E-006
 -2.181892138980823E-007
 -1.281075837167326E-005
 -5.160995525533272E-007
   34.0364903045788
 -6.860210513841179E-007
 -1.622697801310276E-006
   57.6224876856810
  4.276100740662619E-005
  1.282958509495529E-004
 -0.106259351619761
 -1.161404173651727E-006
  2.133091962637518E-009
 -2.747157678545749E-006
  5.045564751784127E-009
  1.435200252617308E-004
  1.282958509494411E-004
 -4.858573660673755E-004
  1.794513052255257E-009
 -2.944186705253243E-013
  1.141452080201166E-012
 -3.616923302685557E-017
 -6.964108674062242E-013
  2.699963395095186E-012
 -8.555383716557204E-017
   79.2832972021133
   3.48243077743594
   94.8995660024748
  4.320032558574761E-005
 -7.018562899216506E-008
 -7.614691444451349E-005
 -1.510180561225070E-004
 -1.660154096089756E-007
 -7.820148864701108E-005
 -1.533751034175649E-004
   126.680932779133
   3.31803823102569
 -1.425366913554206E-004
 -0.106270212671349
 -4.861495388755572E-004
   94.8979831189679
 -3.051189123140708E-005
 -5.238472982557876E-003
  2.174367923916991E-003
 -6.687658026497013E-008
  2.133305271828506E-009
  1.141733226064750E-012
 -1.510105693253804E-004
 -3.007639068571060E-004
  5.617206870973811E-015
  1.057579654610639E-010
 -4.347707766389740E-011
  5.046069308241079E-009
  2.700628410798818E-012
 -1.533675857878610E-004
 -3.037409626120883E-004
  1.328680689609322E-014
  2.501573641053281E-010
 -1.028396406017309E-010
  5.331720486950001E-005
 -3.052022787716126E-005
 -1.506654482673838E-005
 -3.043941486453617E-005
  5.617648132114650E-015
 -8.245796569748091E-015
 -1.077412515291588E-015
  3.988824849542671E-015
  1.328785064468270E-014
 -1.950441015693471E-014
 -2.548485815246155E-015
  9.435070978688280E-015
   4.33104182619287
  4.320032558565169E-005
 -5.237947880767957E-003
 -1.506314545477562E-005
   1.46189319662986
  1.057473905012998E-010
 -1.077372114674817E-015
 -8.729317390437392E-008
 -2.946495279828483E-008
  2.501323503482088E-010
 -2.548390252576872E-015
 -2.064811875351917E-007
 -6.969569523435634E-008
   587.816606933511
   158.265335010299
   10.8253165823734
  1.794488100389362E-009
  2.174367923913079E-003
 -3.043107043024763E-005
   1.46189319619584
 -3.189901609897345E-006
 -3.616873011055106E-017
 -4.347707766397705E-011
  3.988226605565151E-015
 -2.946495279832561E-008
 -1.184770388903798E-005
 -7.545317039955147E-006
 -5.160995525525555E-007
 -8.555264757956551E-017
 -1.028396406019193E-010
  9.433655906668404E-015
 -6.969569523425990E-008
 -2.802427565821245E-005
   426.946188511137
   3.48240292292754
   3.31801168982183
   158.264069039100
 -8.605098236742029E-006
 -7.018356133306383E-008
 -6.687461009098896E-008
 -3.189807635893292E-006
 -2.035468900766445E-005
 -1.660137426730200E-007
 -1.581866764859530E-007
 -7.545241278679801E-006
   268.706710534864
  4.276528200109196E-005
  4.276528200118509E-005
 -1.424583220307363E-004
   10.8252299899318
 -5.415790305321223E-006
 -2.181827860775043E-007
 -1.281062974093478E-005
 -5.160943704809681E-007
   34.0362180444352
 -6.860008413097873E-007
 -1.622681508065824E-006
   57.6220267600790
  4.276100575796032E-005
  1.282958460035553E-004
 -0.106258505020236
 -1.161369958842430E-006
  2.133029121419882E-009
 -2.747130094750857E-006
  5.045514089071070E-009
  1.435199032730630E-004
  1.282958460032759E-004
 -4.858568958265549E-004
  1.794498676188643E-009
 -2.944099922634736E-013
  1.141418434828125E-012
 -3.616816694589960E-017
 -6.964038675787683E-013
  2.699936256958903E-012
 -8.555297730180221E-017
   79.2828113537001
   3.48240292293563
   94.8991035935056
  4.320032557548383E-005
 -7.018356133306894E-008
 -7.615315936197243E-005
 -1.510305843899628E-004
 -7.820652362565820E-005
 -1.533852043591716E-004
   126.680512859610
   3.31801168982183
 -1.425366858598677E-004
 -0.106269365986778
 -4.861490685125866E-004
   94.8975207078006
 -3.051188900215556E-005
 -5.238431009327998E-003
  2.174350669736393E-003
 -6.687461009090741E-008
  2.133242424331912E-009
  1.141699572409001E-012
 -1.510230969649324E-004
 -3.007890008709942E-004
  5.617041388021912E-015
  1.057548498171331E-010
 -4.347579684856024E-011
 -1.581866764857601E-007
  5.046018640473908E-009
  2.700601265975700E-012
 -1.533776862230314E-004
 -3.037611947106388E-004
  1.328667348411745E-014
  2.501548522688592E-010
 -1.028386080250453E-010
  5.331720159712057E-005
 -3.052022564767477E-005
 -1.506654525436329E-005
 -3.043941328157490E-005
  5.617482636174205E-015
 -8.245553649395214E-015
 -1.077380774454934E-015
  3.988707339207890E-015
  1.328771722217364E-014
 -1.950421431565352E-014
 -2.548460225658156E-015
  9.434976242423631E-015
   4.33100718228291
 -5.237905911742856E-003
 -1.506314588240629E-005
   1.46188150292035
  1.057442751687464E-010
 -1.077340375025927E-015
 -8.729060226086742E-008
 -2.946408476536219E-008
  2.501298387625221E-010
 -2.548364663978590E-015
 -2.064791142911552E-007
 -6.969499543122679E-008
   587.811904953060
   158.264069038841
   10.8252299899157
  1.794473724525636E-009
  2.174350669740345E-003
 -3.043106884751661E-005
   1.46188150248633
 -3.189807635888074E-006
 -2.181827860775044E-007
 -3.616766404442993E-017
 -4.347579684848061E-011
  3.988109112849683E-015
 -2.946408476532142E-008
 -1.184735485751461E-005
 -7.545241278667455E-006
 -5.160943704817398E-007
 -8.555178772762781E-017
  9.433561184606514E-015
 -6.969499543113035E-008
 -2.802399427103444E-005
   426.943435155674
  0.000
