[petsc-users] [KSP] Different behaviour between
Norihiro Watanabe norihiro.w at gmail.com
Tue Jan 7 05:15:40 CST 2014
It seems the problem is solved if I call KSPSetOperators() before
KSPSolve().
I have one more question. How is a norm of the RHS calculated to check
relative tolerance in iterative solvers? Is it norm2 or norm infinity?
Best,
Nori
On Tue, Jan 7, 2014 at 11:39 AM, Norihiro Watanabe <norihiro.w at gmail.com>wrote:
> Matthew, Thank you for your quick response. I followed your suggestion and
> confirmed that the matrices are identical (I checked the norm1 of a matrix
> resulted from MatAXPY()).
> The next step is to check whether PETSc objects are correctly reset before
> reassembling equations. A question I have is, do I have to reset or
> recreate a KSP object? The coefficient matrix, RHS and solution vectors are
> all set zero by calling MatZeroEntries() and VecSet().
> Best,
> Nori
> On Mon, Jan 6, 2014 at 7:36 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Jan 6, 2014 at 12:06 PM, Norihiro Watanabe <norihiro.w at gmail.com>wrote:
>>> Hi,
>>> I got a strange problem with PETSc 3.4 that linear equations assembled
>>> in our FEM codes cannot be solved within 5000 iterations, whereas linear
>>> equations loaded from binary files can be solved with only 24 iterations
>>> using ksp/examples/tutorials/ex10.c. The binary files were created by the
>>> FEM codes using MatView() and VecView() right before calling KSPSolve().
>>> Linear solver types are -ksp_type bcgs -pc_type bjacobi. I set the same
>>> tolerance to both programs.
>>> As you can see from attached log files, both programs calculate the same
>>> "true resid norm" at the beginning but different "preconditioned resid
>>> norm". Does it mean both programs are actually solving the same problem but
>>> somewhat with different preconditoner? It would be so helpful if you have
>>> any clue for this problem.
>> Yes, that would be the likely conclusion. It appears that the parallel
>> partition is the same, that the number of nonzeros in both
>> matrices is the same, and that the solvers are identical. Thus I would
>> make sure that the matrices are indeed identical. For example,
>> you can MatLoad the matrix you used in ex10, and MatAXPY() to get the
>> difference. It is a common error to forget to MatZeroEntries()
>> before reassembling the FEM operator which can produce the convergence
>> degredation you see.
>>   Thanks,
>>       Matt
>>>  just tell you background of this: Currently I'm facing a convergence
>>> problem in linear solvers for solving transient heat transport problems
>>> using FEM. At early time steps, PETSc converges quickly (<20 iterations).
>>> Later, iteration numbers increase as time steps increase (>5000 after 19
>>> time steps). I'm in the middle of checking where is a problem for the slow
>>> convergence. Because I don't get  such slow convergence with other linear
>>> solvers (BiCGSTAB+Jacobi), I suspect the FEM  codes are missing some PETSc
>>> functions or options to be used. As I wrote above, if I use ex10.c with the
>>> binary files, the convergence problem is solved, which means something
>>> going wrong in the FEM codes.
>>> Thank you in advance,
>>> Nori
>> experiments lead.
>> -- Norbert Wiener
> Norihiro Watanabe
Norihiro Watanabe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140107/fffeec3d/attachment-0001.html>
