[petsc-users] Reductions in various vector and matrix kernels
R. Oğuz Selvitopi roguzsel at gmail.com
Sat Jan 4 18:18:57 CST 2014
And if I want to run my code without debugging mode on, I have to build
PETSc from the beginning with the corresponding configure options, right?
That is some headache for me, as I am using PETSc on a supercomputer and it
is built with the default option, where debug mode is on.
On Sun, Jan 5, 2014 at 1:52 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   The debug version does extra reductions for error checking, you should
> never look at -log_summary with a debug build.
>    Normally MatMult() for MPIAIJ matrices has nearest neighbor
> communication so neither MatMult() or MatMultTranspose() has global
> reductions but if some scatters involve all entries then VecScatter does
> use global reductions in those cases.  You could run a slimmed down run on
> 2 process with one process in the debugger and put a break point in
> MPI_Allreduce() and MPI_Reduce() to see when it is being triggered inside
> the MatMultTranspose(). Use -start_in_debugger -debugger_nodes 0
>    Barry
> On Jan 4, 2014, at 1:32 PM, R. Oğuz Selvitopi <roguzsel at gmail.com> wrote:
> > Hello,
> > I am trying to understand the output generated by PETSc with
> -log_summary option.
> > Using PetscLogStageRegister/PetscLogStagePush/PetscLogStagePop I want to
> find out if there exists unnecessary communication in my code.
> > My problem is with understanding the number of reductions performed.
> > I have a solver whose stages are logged, and in the summary stages
> output, I get
> > Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> ---  -- Message Lengths --  -- Reductions --
> >                                  Avg     %Total     Avg     %Total
> counts   %Total     Avg         %Total   counts   %Total
> > 4:          Solver: 6.5625e-04   4.3%  4.2000e+02  59.7%  1.600e+01
>  23.2%  3.478e+00       14.5%  8.000e+00   5.3%
> > where it seems I have 8 reduction operations performed. But in the
> details of the stage events, I get:
> > --- Event Stage 4: Solver
> > Event                Count      Time (sec)     Flops
>         --- Global ---  --- Stage ---   Total
> >                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
> > MatMult                      1 1.0 1.2207e-04 1.8 4.10e+01 4.1 8.0e+00
> 1.5e+01 0.0e+00  1 16 12  7  0  15 27 50 50  0     1
> > MatMultTranspose       1 1.0 1.2112e-04 1.0 4.60e+01 3.8 8.0e+00 1.5e+01
> 2.0e+00  1 18 12  7  1  18 30 50 50 25     1
> > VecDot                       3 1.0 2.6989e-04 1.2 2.90e+01 2.6 0.0e+00
> 0.0e+00 3.0e+00  2 12  0  0  2  36 20  0  0 38     0
> > VecSet                       2 1.0 8.1062e-06 1.5 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
> > VecAXPY                   2 1.0 3.7909e-05 1.3 2.00e+01 2.0 0.0e+00
> 0.0e+00 0.0e+00  0  9  0  0  0   5 15  0  0  0     2
> > VecAYPX                   1 1.0 5.0068e-06 1.2 1.00e+01 1.7 0.0e+00
> 0.0e+00 0.0e+00  0  5  0  0  0   1  8  0  0  0     6
> > VecScatterBegin         2 1.0 7.2956e-05 2.4 0.00e+00 0.0 1.6e+01
> 1.5e+01 0.0e+00  0  0 23 14  0   6  0100100  0     0
> > VecScatterEnd           2 1.0 9.5129e-05 2.2 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0  10  0  0  0  0     0
> > It seems there are only 5 reductions.
> > But when I detail my log stages, it shows up VecAXPY/VecAYPX operations
> require reductions as well (I have two VecAXPY and a single VecAYPX, so 5+3
> = 8).
> > (Whose logs I have not included here).
> > Normally these two operations should not require any reductions at all,
> as opposed to VecDot.
> > Do VecAXPY/VecAYPX require reductions? Is it because PETSc is compiled
> with the debugging option so that it performs additional checks that
> perform reductions?
> > Which is the correct number of reductions in above statistics, 5 or 8?
> > Moreover, why does MatMult require no reduction whereas MatMultTranspose
> requires two of them?
> > Thanks in advance.
Oguz.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140105/0bcffc8e/attachment.html>
