[petsc-users] DMPlexCreateFromCellList and hybrid meshes
Fri Jan 3 10:30:00 CST 2014
On Fri, Jan 3, 2014 at 9:57 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Cedric Doucet <cedric.doucet at inria.fr> writes:
> > I could use DMPlexCreateFromDAG but there are several drawbacks:
> > 1. DMPlexCreateFromDAG is not well documented;
> > 2. other developers will have to understand a tricky data structure
> > (DAG) to modify my code (see point 1 to understand why it is a
> > problem);;
> Every public function is supposed to have a man page.  Matt neglected
> this rule in DMPlexCreateFromDAG and it's perfectly valid to complain
> about that.  However, I think DMPlexCreateFromDAG provides the
> functionality you need, and is sufficiently general to deal with things
> like boundary faces which are needed for most real simulations.
> > 3. DMPlexCreateFromDAG looks like a low-level function in comparison
> > with DMPlexCreateFromCellList which acts at a higher level: if you
> > modify this structure, I or someone else will have to modify my code
> > (see point 2 to understand why it is a problem);
> It only uses complicated words; the data structure is basically the same
> as what you're asking for, with the added flexibility of being able to
> represent meshes containing cells with more than one topological
> dimension (e.g., volumes and faces).
> > You proposed to modify DMPlexCreateFromCellList function for me and I
> > decided to accept it after thinking about it.  Did you change your
> > mind?
> I didn't propose that.  Maybe Matt did and of course he's welcome to
> generalize the function.
DMPlexCreateFromDAG() is exactly that generalization. What is different from
CreateFrmCellList()?
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140103/32721767/attachment.html>
