[petsc-users] DMPlexCreateFromCellList and hybrid meshes
Cedric Doucet cedric.doucet at inria.fr
Thu Jan 2 08:08:24 CST 2014
Hello,
indeed, I need to have a generalized version of DMPlexCreateFromCellList function which can take an hybrid mesh as an input parameter.
Modern mesh generators often provide mixed generation functionalities (e.g. gmsh which can generate pyramids and prisms).
As a matter of fact, cells are never numbered independently of vertices in hybrid meshes because different generators are used (structured and unstructured ones).
>From a practical point of view, it is far much easier to let each generator number its own cells without renumbering shared vertices.
Therefore, cells of hybrid meshes are sorted in a canonical way: cells of generator 1, cells of generator 2, etc.
I deeply think that this new version is very useful for real-life applications.
Please let me know when this new version will be available.
Thank you very much,
Cédric Doucet
----- Mail original -----
> De: "Matthew Knepley" <knepley at gmail.com>
> À: "Cedric Doucet" <cedric.doucet at inria.fr>
> Cc: petsc-users at mcs.anl.gov
> Envoyé: Jeudi 31 Octobre 2013 14:13:14
> Objet: Re: [petsc-users] DMPlexCreateFromCellList and hybrid meshes
> On Thu, Oct 31, 2013 at 5:20 AM, Cedric Doucet <
> cedric.doucet at inria.fr > wrote:
> > Thank you very much for your help.
> > Do you plan to add this code to Petsc?
> > It would be better for us to call an official Petsc function than
> > maintaining a Petsc-style code into our C++ software.
> If this is really what you need, then I will put it in. However, I
> intended this to be used primarily for mesh generators, since they
> tend to number cells and vertices independently and have the int and
> double types hardwired.
> If you are writing your own code, please consider
> DMPlexCreateFromDAG() which has the flexibility for cell topology
> that you
> want. The main differences are that it uses PETSc types and a single
> contiguous numbering. Would this work for you?
> Thanks,
> Matt
> > Best regards,
> > Cédric Doucet
> > > De: "Matthew Knepley" < knepley at gmail.com >
> > > À: "Cedric Doucet" < cedric.doucet at inria.fr >
> > > Envoyé: Mardi 29 Octobre 2013 17:24:03
> > > meshes
> > > On Tue, Oct 29, 2013 at 10:24 AM, Cedric Doucet <
> > > > Hello,
> > > > I have a short question about the code I need to modify.
> > > > As far as I understand, numCorner should be replaced by an
> > > > array
> > > > numCorners[numCells] containing the number of vertices of each
> > > > cell.
> > > > The body of DMPlexBuildFromCellList_Private function becomes
> > > > ierr = DMPlexSetChart(dm, 0,
> > > > numCells+numVertices);CHKERRQ(ierr);
> > > maxCorners = 0;
> > > > for (c = 0; c < numCells; ++c) {
> > > > ierr = DMPlexSetConeSize(dm, c, numCorners[c]);CHKERRQ(ierr);
> > > maxCorners = PetscMax(maxCorners, numCorners[c]);
> > > > ierr = DMSetUp(dm);CHKERRQ(ierr);
> > > ierr = DMGetWorkArray(dm, maxCorners, PETSC_INT,
> > > &cone);CHKERRQ(ierr);
> > > > for (c = 0, off = 0; c < numCells; ++c) {
> > > > for (p = 0; p < numCorners[c]; ++p) {
> > > > cone[p] = cells[off+p]+numCells;
> > > > ierr = DMPlexSetCone(dm, c, cone);CHKERRQ(ierr);
> > > off += numCorners[c];
> > > ierr = DMRestoreWorkArray(dm, maxCorners, PETSC_INT,
> > > > ierr = DMPlexSymmetrize(dm);CHKERRQ(ierr);
> > > > ierr = DMPlexStratify(dm);CHKERRQ(ierr);
> > > Matt
> > > > However, I am not quite sure that DMGetWorkArray and
> > > > DMRestoreWorkArray should be used like this.
> > > > I guess that DMRestoreWorkArray behaves like free function in
> > > > ansi
> > > > c
> > > > but I am not sure.
> > > > Do you think that calling DMGetWorkArray and DMRestoreWorkArray
> > > > inside a loop is a good thing from the point of view of
> > > > computational time and memory management?
> > > > Note: the best way to do this may be to first sort cells by
> > > > numCorners to avoid many calls to DMGetWorkArray and
> > > > DMRestoreWorkArray. This is actually what I have in my own code
> > > > but
> > > > I would like to maintain Petsc's philosophy.
> > > > Thanks,
> > > > Cédric
> > > > > Envoyé: Vendredi 25 Octobre 2013 16:31:59
> > > > > meshes
> > > > > On Fri, Oct 25, 2013 at 7:23 AM, Cedric Doucet <
> > > > > > Hello,
> > > > > > I've noticed that DMPlexCreateFromCellList assumes that
> > > > > > cells
> > > > > > have
> > > > > > the same number of vertices (numcorners argument).
> > > > > > What should be done when one wants to create a DMPlex from
> > > > > > a
> > > > > > mesh
> > > > > > containing different types of cells?
> > > > > > Does one have to create several DMPlex structures and merge
> > > > > > them?
> > > > > > Does one have to create a unique DMPlex by hand?
> > > > > The code is very short:
> > > > > ierr = DMPlexSetConeSize(dm, c, numCorners);CHKERRQ(ierr);
> > > > > ierr = DMGetWorkArray(dm, numCorners, PETSC_INT,
> > > > > for (p = 0; p < numCorners; ++p) {
> > > > > cone[p] = cells[c*numCorners+p]+numCells;
> > > > > ierr = DMRestoreWorkArray(dm, numCorners, PETSC_INT,
> > > > > This code is all in plexcreate.c. If you want different
> > > > > cells,
> > > > > you
> > > > > can change numCorners for each cell.
> > > > > I could make a convenience form if necessary.
> > > > > Matt
> > > > > > Cédric
> > > > > What most experimenters take for granted before they begin
> > > > > their
> > > > > experiments is infinitely more interesting than any results
> > > > > to
> > > > > which
> > > > > their experiments lead.
> > > > > -- Norbert Wiener
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to
> > > which
> > > -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140102/8a541d2a/attachment.html>
