[petsc-users] dmda and vec distribution
Matthew Knepley
knepley at gmail.com
Wed Jan 1 14:03:38 CST 2014
On Wed, Jan 1, 2014 at 1:48 PM, Gideon Simpson <gideon.simpson at gmail.com>wrote:
> I'll try that, but I'm still a bit confused over the relationship between
> DMDA and Vec objects.
> Supposing I called DMDACreate1d with M as my global dimension and dof as
> the number of degrees of freedom. So this is really managing M * dof
> scalars. When I call DMCreateGlobalVector, isn't that associated with an M
> * dof size vector? I really just want to clone a vector of size M, but with
> the same partitioning.
DMDA structures are very lightweight, and the partitioning only depends on
M, not dof. Thus just create a separate DMDA for every
dof you want.
Matt
> -gideon
> On Jan 1, 2014, at 2:41 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Gideon Simpson <gideon.simpson at gmail.com> writes:
> >> Suppose I have a 1D dmda structure distributed across N processors,
> >> where there are some number of degrees of freedom (dof) associated
> >> with each element. Now, suppose I want to have a vec also distributed
> >> across the N processors, but distributed "in the same way" as the
> >> dmda. That is to say, if I call
> >> DMDAGetCorners(da, &idx_lo, NULL, NULL, &idx_width, NULL, NULL);
> >> idx_lo to idx_lo+ idx_width
> >> are the same indices I'd get if I called
> >> VecGetOwnershipRange(vec, &idx_low, &idx_hi);
> >> Can I do this? How?
> > What's wrong with DMCreateGlobalVector()?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140101/d2543a5f/attachment.html>
