[petsc-users] dmda and vec distribution
Gideon Simpson gideon.simpson at gmail.com
Wed Jan 1 13:37:05 CST 2014
Suppose I have a 1D dmda structure distributed across N processors, where there are some number of degrees of freedom (dof) associated with each element.  Now, suppose I want to have a vec also distributed across the N processors, but distributed "in the same way" as the dmda.  That is to say, if I call
DMDAGetCorners(da, &idx_lo, NULL, NULL, &idx_width, NULL, NULL);
idx_lo to idx_lo+ idx_width
are the same indices I'd get if I called
VecGetOwnershipRange(vec, &idx_low, &idx_hi);
Can I do this?  How?
The idea here is that I am doing monte carlo where the dmda holds all the random samples.  I then want to apply functionals to each of the samples, storing the results of each realization in a vector.  Obviously, I can just store this as part of the dmda, but it would be cleaner if I could put it right into a vec.
-gideon
