[petsc-users] Fill-in of factorization
Fri Feb 28 16:05:35 CST 2014
On Fri, Feb 28, 2014 at 1:59 PM, Jan Blechta <blechta at karlin.mff.cuni.cz>wrote:
> On Fri, 28 Feb 2014 12:30:05 -0800
> Matthew Knepley <knepley at gmail.com> wrote:
> > On Fri, Feb 28, 2014 at 12:13 PM, Jan Blechta
> > > Hi,
> > > is it possible to check an amount of fill-in produced during
> > > factorization with PCLU or PCCHOLESKY? Or should I ask the library,
> > > say MUMPS, directly?
> > This is from the PCFactorView():
> >       MatInfo info;
> >       ierr = MatGetInfo(factor->fact,MAT_LOCAL,&info);CHKERRQ(ierr);
> MatGetInfo does not seem to be available in petsc4py. Am I grepping
> correctly?
It appears to be missing, probably because it passes a struct around.
  Matt
> Jan
> >       ierr = PetscViewerASCIIPrintf(viewer,"  factor fill ratio given
> > %g, needed
> %g\n",(double)info.fill_ratio_given,(double)info.fill_ratio_needed);CHKERRQ(ierr);
> >   THanks,
> >      MAtt
> > > Jan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140228/319c1669/attachment.html>
