[petsc-users] Build hypre with Cmake and VS2010 to hypre.lib, no 'include' folder
Danyang Su danyang.su at gmail.com
Tue Feb 25 13:30:21 CST 2014
On 25/02/2014 6:40 AM, Satish Balay wrote:
> MSVCRT.lib(MSVCR100.dll) : error LNK2005: malloc already defined in LIBCMT.lib(malloc.obj)
> MSVCRT.lib(MSVCR100.dll) : error LNK2005: realloc already defined in LIBCMT.lib(realloc.obj)
> MSVCRT.lib(MSVCR100.dll) : error LNK2005: free already defined in LIBCMT.lib(free.obj)
> You'll have to build hypre with '/MT' or equivalent option.
> All libraries should be built with the same option - otherwise MS
> compilers barf at link time.
It can now be configured without any problem now. Thanks so much.
Danyang
> Satish
> On Tue, 25 Feb 2014, Danyang Su wrote:
>> On 24/02/2014 10:35 PM, Jed Brown wrote:
>>> Danyang Su <danyang.su at gmail.com> writes:
>>>> Hi All,
>>>> I can successfully build hypre to hypre.lib with cmake and vs2010, but I
>>>> cannot find the include folder in the release folder. There is only one
>>>> folder named "include" in src\FEI_mv\ml\src\include. Is this the one I
>>>> need to configure with PETSc?
>>> You should do what the "make install" target does.  See
>>> $PETSC_DIR/config/PETSc/packages/hypre.py to see exactly which commands
>>> PETSc normally executes.  You'll have to look at the hypre build system.
>> After run install, I can get both lib file and include folder. But when
>> configure with option
>> "--with-hypre-include=/cygdrive/c/cygwin64/packages/hypre-2.9.0b/src/hypre/include
>> --with-hypre-lib=/cygdrive/c/cygwin64/packages/hypre-2.9.0b/src/hypre/lib/HYPRE.lib",
>> I got error indicating this option did not work.
>> Thanks,
>> Danyang
