[petsc-users] DMDA questions
Jed Brown jed at jedbrown.org
Tue Feb 25 11:48:55 CST 2014
Xiangdong <epscodes at gmail.com> writes:
> For example, if the values on the 4-by-4 grid are [1,2,3,4;  5,6,7,8;
>  9,10,11,12; 13,14,15,16]. If I use 4 processors and set m=2, n=2 (or use
> petsc_decide), then on processor zero, the local portion of the global
> vector is 1,2,3,4
No, PETSc global ordering is different from natural.  There is a
detailed picture of this in the users manual and in most PETSc
tutorials.  Please read that.
> while the local vector has value 1,2,5,6. On processor one, the local
> portion of the global vector is 5,6,7,8; and the local vector is
> 3,4,7,8. It looks like the global is natural order, while local vector
> is petsc order.
No.
>> > 2) DOF. In each cell, I have two unknowns, say ux and uy. One way is to
>> > store them using one global vector with dof=2. The other way is to create
>> > two global vectors for each ux and uy with dof=1. Is one approach better
>> > than the other?
>> The former is better for memory streaming unless your operations
>> traverse the grid using only one at a time (and then, it would be better
>> to rephrase to traverse fewer times, using both values each time).
> Any examples in petsc tutorials demonstrating the case dof>1? I found most
> of them are dof=1. For dof>1, are the values stored in a interleaved
> manner?
src/snes/examples/tutorials/ex48.c uses dof=2 and MatSetValuesBlockedStencil.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140225/2f0a2b6a/attachment.pgp>
