[petsc-users] Build hypre with Cmake and VS2010 to hypre.lib, no 'include' folder
Jed Brown jed at jedbrown.org
Tue Feb 25 00:35:18 CST 2014
Danyang Su <danyang.su at gmail.com> writes:
> Hi All,
> I can successfully build hypre to hypre.lib with cmake and vs2010, but I
> cannot find the include folder in the release folder. There is only one
> folder named "include" in src\FEI_mv\ml\src\include. Is this the one I
> need to configure with PETSc?
You should do what the "make install" target does.  See
$PETSC_DIR/config/PETSc/packages/hypre.py to see exactly which commands
PETSc normally executes.  You'll have to look at the hypre build system.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140224/b7a5fb71/attachment.pgp>
