[petsc-users] Error using MUMPS to solve large linear system
Hong Zhang hzhang at mcs.anl.gov
Mon Feb 24 10:47:55 CST 2014
Samar:
The crash occurs in
> [161]PETSC ERROR: Error in external library!
> [161]PETSC ERROR: Error reported by MUMPS in numerical factorization
> phase: INFO(1)=-1, INFO(2)=48
for very large matrix, likely memory problem as you suspected.
I would suggest
1. run problems with increased sizes (not jump from a small one to a very
large one) and observe memory usage using
'-ksp_view'.
   I see you use '-mat_mumps_icntl_14 1000', i.e., percentage of estimated
workspace increase. Is it too large?
   Anyway, this input should not cause the crash, I guess.
2. experimenting with different matrix ordering -mat_mumps_icntl_7 <> (I
usually use sequential ordering 2)
    I see you use parallel ordering -mat_mumps_icntl_29 2.
3. send bug report to mumps developers for their suggestion.
4. try other direct solvers, e.g., superlu_dist.
> etc etc. The above error I can tell has something to do with processor 48
> (INFO(2)) and so forth but not the previous one.
> The full output enabled with -mat_mumps_icntl_4 3 looks as in the attached
> file. Any hints as to what could be giving this
> error would be very much appreciated.
I do not know how to interpret this  output file. mumps developer would
give you better suggestion on it.
I would appreciate to learn as well :-)
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140224/e2d9d7c4/attachment.html>
