[petsc-users] cannot compile/use ml with 64 bit integers
Xiangdong epscodes at gmail.com
Fri Feb 21 13:15:13 CST 2014
Hello everyone,
When I compile petsc with options -with-64-bit-indices and  ml packages, I
got the error like this: "Cannot use ml with 64 bit integers, it is not
coded for this capability".
If I want to use ml as a preconditioner for long vectors (> 2 billions), is
there any solution?
Thank you.
Best,
Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140221/39824b0a/attachment.html>
