[petsc-users] Plex mesh reference element
Dharmendar Reddy dharmareddy84 at gmail.com
Mon Feb 17 13:23:41 CST 2014
Hello,
         My petsc code is at version e4acbc4 on next. I get undefined
reference error:
undefined reference to `petscdualspacecreatereferencecell_'
Here is the code, i used.
   print*,'Testing Reference Cell'
   call PetscDualSpaceCreate(comm, Q, ierr)
   Kdim=3
   call PetscDualSpaceCreateReferenceCell(Q,Kdim, PETSC_TRUE, K, ierr)
   call PetscViewerPushFormat(PETSC_VIEWER_STDOUT_WORLD,
PETSC_VIEWER_ASCII_INFO_DETAIL, ierr)
   call DMView(K, PETSC_VIEWER_STDOUT_WORLD, ierr)
Thanks
Reddy
On Mon, Feb 17, 2014 at 7:28 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 11, 2014 at 7:50 AM, Dharmendar Reddy <dharmareddy84 at gmail.com>
> wrote:
>> Hello,
>>        Where do i find the information on reference elements used by
>> plex for local numbering.
> You can use
>   PetscDualSpaceCreateReferenceCell(sp, dim, isSimplex, &refCell)
> PETSC_VIEWER_ASCII_INFO_DETAIL)
>   DMView(refCell, PETSC_VIEWER_STDOUT_WORLD)
>     Matt
>> I currently use the following for the tetrahedron. Is this correct ?
>> what is the corresponding information for a  triangle ?
>>         ! Vertex coordiantes
>>        vert(1:3,1)=[0.0, 0.0, 0.0]
>>         vert(1:3,2)=[1.0, 0.0, 0.0]
>>         vert(1:3,3)=[0.0, 1.0, 0.0]
>>         vert(1:3,4)=[0.0, 0.0, 1.0]
>>         ! vertex intdices
>>         vs(1:4)= [1, 2, 3, 4]
>>         ! Edges id to node Id
>>         edge(:,1) = [3, 4]
>>         edge(:,2) = [2, 4]
>>         edge(:,3) = [2, 3]
>>         edge(:,4) = [1, 4]
>>         edge(:,5) = [1, 3]
>>         edge(:,6) = [1, 2]
>>         ! Faces id to node id
>>         face(1:3,1)=[2,3,4]
>>         face(1:3,2)=[1,3,4]
>>         face(1:3,3)=[1,2,4]
>>         face(1:3,4)=[1,2,3]
>>         numFacet = 4
>>         ! Tets
>>         tet(1:4,1) = [1,2,3,4]
>> thanks
>> Reddy
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
