[petsc-users] iteration count
Jed Brown jed at jedbrown.org
Fri Feb 14 09:01:29 CST 2014
Wadud.Miah at awe.co.uk writes:
> I am running PETSc to solve a system and the iteration count is
> zero. I suppose this is due to the initial guess vector being the
> solution within the tolerances.
Don't assume, use -ksp_converged_reason (or -snes_converged_reason (or
-ts_converged_reason)) to determine why it is exiting early.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140214/d061c5c7/attachment.pgp>
