[petsc-users] [petsc-dev] aij and baij data access
Tue Feb 4 10:10:36 CST 2014
On Tue, Feb 4, 2014 at 10:01 AM, Jose David Bermeol <jbermeol at purdue.edu>wrote:
> Looking the code for MatGetRowIJ_SeqAIJ_Inode_Nonsymmetric, it is copying
> the data and I want to avoid that. So, is there other way to do this??
Turn off inodes.
   Matt
> From: "Matthew Knepley" <knepley at gmail.com>
> To: "Jed Brown" <jed at jedbrown.org>
> Cc: "Jose David Bermeol" <jbermeol at purdue.edu>, "petsc-dev" <
> petsc-dev at mcs.anl.gov>
> Sent: Tuesday, February 4, 2014 9:21:34 AM
> Subject: Re: [petsc-dev] aij and baij data access
> On Tue, Feb 4, 2014 at 7:41 AM, Jed Brown < jed at jedbrown.org > wrote:
> Matthew Knepley < knepley at gmail.com > writes:
> > On Mon, Feb 3, 2014 at 10:22 AM, Jose David Bermeol <
> jbermeol at purdue.edu >wrote:
> >> Hi, Is it possible to access to the raw data of aij matrices(row
> indices,
> >> column indices and data). I need to used for and optimize algorithm,
> this
> >> data will keep constant all the time. So is it cossible with the public
> >> interface you have or not??
> > This is a question for petsc-maint.
> I disagree; there is no reason to keep such questions private.
> Let me rephrase: This is a question for petsc-maint (my default suggestion
> so as not to force
> people into the public) or petsc-users, not petsc-dev which is for
> development discussion.
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatGetColumnIJ.html
> You actually want MatGetRowIJ because MatGetColumnIJ is expensive with a
> row-based format like AIJ.
> Yes, bad click.
> Matt
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatSeqAIJGetArray.html
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140204/1984f477/attachment.html>
