[petsc-users] Out of memory and parallel issues
TAY wee-beng zonexo at gmail.com
Wed Dec 31 23:20:01 CST 2014
I used to run my CFD code with 96 procs, with a grid size of 231 x 461 x
368.
I used MPI and partition my grid in the z direction. Hence with 96 procs
(8 nodes, each 12 procs), each procs has a size of 231 x 461 x 3 or 231
x 461 x 4.
It worked fine.
Now I modified the code and added some more routines which increases the
fixed memory requirement per procs. However, the grid size is still the
same. But the code aborts while solving the Poisson eqn, saying:
Out of memory trying to allocate XXX bytes
I'm using PETSc with HYPRE boomeramg to solve the linear Poisson eqn. I
am guessing that now the amt of memory per procs is less because I added
some routines which uses some memory. The result is less memory
available for the solving of the Poisson eqn.
I'm now changing to KSPBCGS but it seems to take forever. When I abort
it, the error msg is:
Out of memory. This could be due to allocating
[10]PETSC ERROR: too large an object or bleeding by not properly
[10]PETSC ERROR: destroying unneeded objects.
[10]PETSC ERROR: Memory allocated 0 Memory used by process 4028370944
[10]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
I can't use more procs because some procs will have a size of 231 x 461
x 2 (or even 1). This will give error since I need to reference the
nearby values along the z direction.
So what options do I have? I'm thinking of these at the moment:
1. Remove as much fixed overhead memory per procs as possible so that
there's enough memory for each procs.
2. Re-partition my grid in both x,y direction or x,y,z direction so I
will not encounter extremely skew grid dimensions per procs. Btw, does
having extremely skew grid dimensions affect the performance in solving
the linear eqn?
Are there other feasible options
Thank you.
Yours sincerely,
TAY wee-beng
