[petsc-users] no decrease in iteration counts of KSPCG during time stepping
Alp Kalpalp alpkalpalp at gmail.com
Sun Dec 28 10:54:25 CST 2014
Thank you Mark.
Let me clarify my questions;
1-)How to implement or activate a Reorthogonalization procedure for KSPCG..
As you know, search directions can be found more rapidly (with less numer
of iterations) by using previous successive directions
2-) How to implement or activate a projection space over CG. A sample
projection can be;
P = I - G*((G'*G)\G').
I need to insert project,scale,precondition,re-scae,re-project steps during
each KSPCG iteration. How can I utilize this?
Thanks again and merry christmas to all
On Sun, Dec 28, 2014 at 4:28 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Sat, Dec 27, 2014 at 5:00 AM, Alp Kalpalp <alpkalpalp at gmail.com> wrote:
>> Hi,
>> I implemented a newmark time stepping algorithm without using TS
>> structure. I am following ex59 about PCBDDC.
> use TS
>> ComputeMatrix
>> ComputeKSPBDDC
>> for // a time loop
>> Compute RHS
>> KSPSolve
>> GatherResults
>> MoveToNextTS
>> However, when I watch the iteration counts of KSPSolve they do not
>> decrease signicantly..Decrease was around 5%.
>> So I have some problems;
>> 1-) I guess currently, factorization is not taking place for each time
>> step in my code. Ok this is expected. But I wonder whether Kspsolve stores
>> the Krylov subspace vectors and reuse them for the next time step.
> No.  Certainly not by default.
>> 2-) PCBDDC uses KSPCG and AFAIK petsc doesnot have preconditioned
>> conjugate projected gradient (PCPG). Is it possible to simulate PCPG
>> iteration in some way?
> KSP has a PC object and all methods use it AFAIK.
>> Thanks,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141228/ad9face5/attachment.html>
