[petsc-users] MatAXPY not working as expected
Jed Brown jed at jedbrown.org
Sun Dec 21 10:54:27 CST 2014
Christoph Pohl <Metal-Gear-Rex at web.de> writes:
> Dear fellow PETSc users,
> I've been trying to subtract one matrix from another, i.e. Y = Y - X, using
> `call MatAXPY(Y, minus_one, X, SAME_NONZERO_PATTERN, ierr)`.
You can only use SAME_NONZERO_PATTERN pattern if the matrices have the
same nonzero pattern.  These matrices don't even have the same number of
nonzeros and there are quite a few entries in different places (neither
is a subset of the other).  Use DIFFERENT_NONZERO_PATTERN in cases like
this.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141221/c23d1b84/attachment-0001.pgp>
