[petsc-users] Confusion with MatGetLocalSubMatrix
Jed Brown jed at jedbrown.org
Fri Dec 19 12:01:38 CST 2014
Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> writes:
> What is ISSetBlockSize for then?  Just hanging information on the IS for use elsewhere?
The index set would need to be contiguous:
static PetscErrorCode ISSetBlockSize_Stride(IS is,PetscInt bs)
  IS_Stride     *sub = (IS_Stride*)is->data;
  PetscErrorCode ierr;
  PetscFunctionBegin;
  if (sub->step != 1 && bs != 1) SETERRQ2(PetscObjectComm((PetscObject)is),PETSC_ERR_ARG_SIZ,"ISSTRIDE has stride %D, cannot be blocked of size %D",sub->step,bs);
  ierr = PetscLayoutSetBlockSize(is->map, bs);CHKERRQ(ierr);
  PetscFunctionReturn(0);
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141219/ccd431e0/attachment.pgp>
