[petsc-users] Richardson: damping factor=0
Mark Adams mfadams at lbl.gov
Fri Dec 19 09:23:02 CST 2014
Oh, SOR probably grabs the iteration ...
Never mind.
On Fri, Dec 19, 2014 at 10:20 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Richardson damping factor does not seem to do anything.  I set it to zero
> and the solve was fine.
> Am I missing something?
> Thanks,
> Mark
>   Down solver (pre-smoother) on level 3 -------------------------------
>     KSP Object:    (mg_levels_3_)     1024 MPI processes
>       type: richardson
>       maximum iterations=4
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>       left preconditioning
>       using nonzero initial guess
>       using NONE norm type for convergence test
>     PC Object:    (mg_levels_3_)     1024 MPI processes
>       type: sor
>         SOR: type = local_symmetric, iterations = 1, local iterations = 1,
> omega = 1
>       linear system matrix followed by preconditioner matrix:
>       Mat Object:       1024 MPI processes
>         type: shell
>         rows=33427584, cols=33427584
>         type: mpiaij
>         total: nonzeros=1.7272e+09, allocated nonzeros=3.4544e+09
>         total number of mallocs used during MatSetValues calls =0
>           not using I-node (on process 0) routines
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141219/8cbeb88e/attachment.html>
