[petsc-users] DMPlex and MatSetValuesLocal
Abhyankar, Shrirang G. abhyshr at mcs.anl.gov
Mon Dec 15 20:33:33 CST 2014
Matt,
   Does MatSetValuesLocal work with a matrix that is created with DMPlex?
Well, actually I am using DMNetwork. I am getting the following error
because ISLocalToGlobalMapping mat->rmap->mapping and mat->cmap->mapping
are not set on the matrix. Perhaps I am not setting up something correctly?
Shri
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Object: Parameter # 1
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-1134-g7fbfed6  GIT
Date: 2014-12-13 14:24:34 -0600
[0]PETSC ERROR: ./DYN on a debug-master named Shrirangs-MacBook-Pro.local
by Shri Mon Dec 15 20:11:18 2014
[0]PETSC ERROR: Configure options --download-chaco --download-metis
--download-parmetis --download-superlu_dist PETSC_ARCH=debug-master
[0]PETSC ERROR: #1 ISLocalToGlobalMappingApply() line 396 in
/Users/Shri/packages/petsc/src/vec/is/utils/isltog.c
[0]PETSC ERROR: #2 MatSetValuesLocal() line 2017 in
/Users/Shri/packages/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 DYNIJacobian() line 282 in
/Users/Shri/Documents/tsopf-code/src/dyn/dyn.c
[0]PETSC ERROR: #4 TSComputeIJacobian() line 763 in
/Users/Shri/packages/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: #5 SNESTSFormJacobian_Theta() line 320 in
/Users/Shri/packages/petsc/src/ts/impls/implicit/theta/theta.c
[0]PETSC ERROR: #6 SNESTSFormJacobian() line 3552 in
[0]PETSC ERROR: #7 SNESComputeJacobian() line 2193 in
/Users/Shri/packages/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 230 in
/Users/Shri/packages/petsc/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #9 SNESSolve() line 3743 in
[0]PETSC ERROR: #10 TSStep_Theta() line 195 in
[0]PETSC ERROR: #11 TSStep() line 2628 in
[0]PETSC ERROR: #12 TSSolve() line 2745 in
[0]PETSC ERROR: #13 DYNSolve() line 620 in
[0]PETSC ERROR: #14 main() line 35 in
/Users/Shri/Documents/tsopf-code/applications/dyn-main.c
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 85) - process 0
Shri
