[petsc-users] Changing TSAdapt
Miguel Angel Salazar de Troya salazardetroya at gmail.com
Fri Dec 12 10:38:57 CST 2014
Thanks a lot for the fix.
Miguel
On Thu, Dec 11, 2014 at 10:58 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Yikes, seven days out and not yet put into maint! Meanwhile Miguel has
> to waste a whole day because no one told him about the fix.
>    I won't appologize for fixing it again. Since a fix that is not
> accessible is not a fix.
>   Barry
> > On Dec 11, 2014, at 10:50 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Barry Smith <bsmith at mcs.anl.gov> writes:
> >>   Miguel,
> >>    Thanks for reporting this, you have found a bug in our code. When we
> changed the adapt type we did not zero out the function pointers for the
> old basic adaptor hence they were improperly called when the object was
> finally destroyed at the end.
> > Lisandro fixed this here.
> https://bitbucket.org/petsc/petsc/commits/40813bd21acd4c08b8080bc6cc1eef9949a22ac8
*Miguel Angel Salazar de Troya*
Graduate Research Assistant
Department of Mechanical Science and Engineering
University of Illinois at Urbana-Champaign
(217) 550-2360
salaza11 at illinois.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141212/f17877b5/attachment.html>
