[petsc-users] F90 program interfaced with petsc 3.4.3 - inconsitencies
Tue Dec 9 10:02:25 CST 2014
On Tue, Dec 9, 2014 at 9:54 AM, <Carol.Brickley at awe.co.uk> wrote:
>   Hi,
> I am trying to runs a F90 program interfaced with petsc 3.4.3. When the
> routine DMDACreate2D is called, if I run with a debugger such as ddt, it
> shows me that in the petsc routines the DM array (inra) is populated,
> however when I return to the F90 code the DM array has one value and no
> longer seems to be populated as a DM array. I am including
> finclude/petsc.h90 in the routine calling DMDACreate2D.
Lets try to eliminate variables. Can you run SNES ex5f? If so, then you
just have to
modify the source and build until you can run yours.
    Matt
> Any ideas?
> Carol
> *Dr Carol Brickley *
> *BSc,PhD,ARCS,DIC,MBCS*
> *Senior Software Engineer*
> *Engineering Applications Team*
> *DS+T,*
> *AWE*
> *Aldermaston*
> *Reading*
> *Berkshire*
> *RG7 4PR*
> *Direct: 0118 9855035*
> ___________________________________________________
> ____________________________ The information in this email and in any
> attachment(s) is commercial in confidence. If you are not the named
> addressee(s) or if you receive this email in error then any distribution,
> copying or use of this communication or the information in it is strictly
> prohibited. Please notify us immediately by email at admin.internet(at)
> awe.co.uk, and then delete this message from your computer. While
> attachments are virus checked, AWE plc does not accept any liability in
> respect of any virus which is not detected. AWE Plc Registered in England
> and Wales Registration No 02763902 AWE, Aldermaston, Reading, RG7 4PR
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141209/b50e1527/attachment-0001.html>
