[petsc-users] reconfigure after pull?
Jed Brown jed at jedbrown.org
Sat Dec 6 08:43:07 CST 2014
Alp Kalpalp <alpkalpalp at gmail.com> writes:
> Hi,
> How to understand that I should reconfigure after a git pull?
It is usually not necessary, but may be necessary if changes in config/
are relevant to you.  You can see the changes to config/ with
  $ git pull
  $ git log --stat ORIG_HEAD.. -- config/
Change --stat to -p to see the full diffs instead of just a stat.
When in doubt reconfigure.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141206/6000e65b/attachment.pgp>
