[petsc-users] Parallelization efficiency diagnose
Sun, Hui hus003 at ucsd.edu
Thu Dec 4 18:49:17 CST 2014
Hello,
I try to test the efficiency of parallelization of my current installation of petsc by running the following command:
make PETSC_DIR=/Users/Paul/Documents/software/petsc-install PETSC_ARCH= streams NPMAX=4
I get the following results:
Number of MPI processes 1
Process 0 Huis-MacBook-Pro.local
Function      Rate (MB/s)
Copy:       13354.1380
Scale:      13012.7268
Add:        14725.4078
Triad:      14822.7110
Number of MPI processes 2
Process 1 Huis-MacBook-Pro.local
Copy:       14135.6610
Scale:      14071.0462
Add:        15598.0208
Triad:      15717.5890
Number of MPI processes 3
Process 2 Huis-MacBook-Pro.local
Copy:       13755.8241
Scale:      13704.7662
Add:        15312.1487
Triad:      15319.4803
Number of MPI processes 4
Process 3 Huis-MacBook-Pro.local
Copy:       13769.1621
Scale:      13708.0972
Add:        15103.1783
Triad:      15133.8786
np  speedup
1 1.0
2 1.06
3 1.03
4 1.02
Estimation of possible speedup of MPI programs based on Streams benchmark.
It appears you have 1 node(s)
Does this result basically says that my MacBook only have one node? However, I know my computer has 4 cores, as I type sysctl -n hw.ncpu in bash, it gives me 4. What does it really mean? By the way, here is my configuration for this installation:
./configure --download-fblaslapack --download-suitesparse --download-superlu_dist --download-parmetis  --download-metis --download-hypre --prefix=/Users/Paul/Documents/software/petsc-install --with-mpi-dir=/Users/Paul/Documents/software/mpich-3.1.3-install
Is there anything in this configuration command that causes trouble?
Best,
Hui
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141205/11659d27/attachment.html>
