[petsc-users] can't find PETSc package
Jed Brown jed at jedbrown.org
Mon Dec 1 21:28:35 CST 2014
paul zhang <paulhuaizhang at gmail.com> writes:
> Like this? still in trouble though...
> CMAKE_MINIMUM_REQUIRED(VERSION 2.8)
> set(PETSC_DIR /home/hzh225/LIB_CFD/nP/petsc-3.5.2)
If you're going to manually set local paths in your build files, then
CMake is definitely a waste of time.  These are normally environment
variables.
> set(PETSC_ARCH /home/hzh225/LIB_CFD/nP/petsc-3.5.2/linux-gnu-intel)
This is not how PETSC_ARCH works.  It should probably be
"linux-gnu-intel".  Please read what PETSc's build prints or read the
documentation.
  http://www.mcs.anl.gov/petsc/documentation/installation.html
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141201/622f499d/attachment.pgp>
